( FIXTURE X ) ( File created: Friday, January 27, 2012 - 02:28 PM) ( for Mach2/3 ) ( Material Size) ( X= 36.000, Y= 20.000, Z= 1.000) () (Toolpaths used in this file:) (surface 1) (key rough) (keyfinish) (keyfinish OD) (TRIM OD PLATE) (spot keyway) (DRILL KEYWAY) (TRIM OUTSIDE [1]) (TRIM OUTSIDE [2]) (Tools used in this file: ) (40 = #40 FACE Mill {2 inches}) (6 = #6 End Mill 1/2) (75 = 75 spot drill) (50 = #50 number drill 25) (6 = #6 End Mill 1/2) N220G00G20G17G90G40G49G80 N230G70G91.1 N240T40M06 N250 (Tool: #40 FACE Mill {2 inches}) N260G00G43Z0.5000H40 N270S3500M03 N280(Toolpath:- surface 1) N290() N300G94 N310X0.0000Y0.0000F20.0 N320G00X-11.0000Y-4.0000Z0.2000 N330G1X-11.0000Y-4.0000Z0.0000F10.0 N340G1X11.0000Y-4.0000Z0.0000F20.0 N350G00X11.0000Y-4.0000Z0.2000 N360G00X-11.0000Y-3.0000Z0.2000 N370G1X-11.0000Y-3.0000Z0.0000F10.0 N380G1X11.0000Y-3.0000Z0.0000F20.0 N390G00X11.0000Y-3.0000Z0.2000 N400G00X-11.0000Y-2.0000Z0.2000 N410G1X-11.0000Y-2.0000Z0.0000F10.0 N420G1X11.0000Y-2.0000Z0.0000F20.0 N430G00X11.0000Y-2.0000Z0.2000 N440G00X-11.0000Y-1.0000Z0.2000 N450G1X-11.0000Y-1.0000Z0.0000F10.0 N460G1X11.0000Y-1.0000Z0.0000F20.0 N470G00X11.0000Y-1.0000Z0.2000 N480G00X-11.0000Y0.0000Z0.2000 N490G1X-11.0000Y0.0000Z0.0000F10.0 N500G1X11.0000Y0.0000Z0.0000F20.0 N510G00X11.0000Y0.0000Z0.2000 N520G00X-11.0000Y1.0000Z0.2000 N530G1X-11.0000Y1.0000Z0.0000F10.0 N540G1X11.0000Y1.0000Z0.0000F20.0 N550G00X11.0000Y1.0000Z0.2000 N560G00X-11.0000Y2.0000Z0.2000 N570G1X-11.0000Y2.0000Z0.0000F10.0 N580G1X11.0000Y2.0000Z0.0000F20.0 N590G00X11.0000Y2.0000Z0.2000 N600G00X-11.0000Y3.0000Z0.2000 N610G1X-11.0000Y3.0000Z0.0000F10.0 N620G1X11.0000Y3.0000Z0.0000F20.0 N630G00X11.0000Y3.0000Z0.2000 N640G00X-11.0000Y4.0000Z0.2000 N650G1X-11.0000Y4.0000Z0.0000F10.0 N660G1X11.0000Y4.0000Z0.0000F20.0 N670G00X11.0000Y4.0000Z0.2000 N680T6M6 N690 (Tool: #6 End Mill 1/2) N700G43H6 N710S2600M03 (key rough) () N740G00X-9.6000Y-0.0525Z0.2000 N750G1X-9.6000Y-0.0525Z-0.0469F20.0 N760G1X9.3400Y-0.0525Z-0.0469 N770G1X9.3400Y0.0525Z-0.0469 N780G1X-9.6000Y0.0525Z-0.0469 N790G00X-9.6000Y0.0525Z0.2000 N800G00X-9.6000Y-0.0525Z0.2000 N810G1X-9.6000Y-0.0525Z-0.0938F20.0 N820G1X9.3400Y-0.0525Z-0.0938 N830G1X9.3400Y0.0525Z-0.0938 N840G1X-9.6000Y0.0525Z-0.0938 N850G00X-9.6000Y0.0525Z0.2000 N860G00X-9.6000Y-0.0525Z0.2000 N870G1X-9.6000Y-0.0525Z-0.1407F20.0 N880G1X9.3400Y-0.0525Z-0.1407 N890G1X9.3400Y0.0525Z-0.1407 N900G1X-9.6000Y0.0525Z-0.1407 N910G00X-9.6000Y0.0525Z0.2000 N920G00X-9.6000Y-0.0525Z0.2000 N930G1X-9.6000Y-0.0525Z-0.1875F20.0 N940G1X9.3400Y-0.0525Z-0.1875 N950G1X9.3400Y0.0525Z-0.1875 N960G1X-9.6000Y0.0525Z-0.1875 N970G00X-9.6000Y0.0525Z0.2000 N980G00X-9.6000Y-0.0525Z0.2000 N990G1X-9.6000Y-0.0525Z-0.2344F20.0 N1000G1X9.3400Y-0.0525Z-0.2344 N1010G1X9.3400Y0.0525Z-0.2344 N1020G1X-9.6000Y0.0525Z-0.2344 N1030G00X-9.6000Y0.0525Z0.2000 N1040G00X-9.6000Y-0.0525Z0.2000 N1050G1X-9.6000Y-0.0525Z-0.2813F20.0 N1060G1X9.3400Y-0.0525Z-0.2813 N1070G1X9.3400Y0.0525Z-0.2813 N1080G1X-9.6000Y0.0525Z-0.2813 N1090G00X-9.6000Y0.0525Z0.2000 N1100S2600M03 (keyfinish) () N1130G00X-9.6000Y-0.0625Z0.2000 N1140G1X-9.6000Y-0.0625Z-0.2813F20.0 N1150G1X9.3500Y-0.0625Z-0.2813 N1160G1X9.3500Y0.0625Z-0.2813 N1170G1X-9.6000Y0.0625Z-0.2813 N1180G00X-9.6000Y0.0625Z0.2000 N1190S2600M03 (keyfinish OD) () N1220G00X-9.6000Y0.5615Z0.2000 N1230G1X-9.6000Y0.5615Z0.0000F20.0 N1240G1X9.8490Y0.5615Z0.0000 N1250G1X9.8490Y-0.5615Z0.0000 N1260G1X-9.6000Y-0.5615Z0.0000 N1270G00X-9.6000Y-0.5615Z0.2000 N1280S5000M03 (TRIM OD PLATE) () N1310G00X-9.5681Y3.8325Z0.2000 N1320G1X-9.5681Y3.8325Z-0.0500F20.0 N1330G1X-9.1875Y4.1942Z-0.0500 N1340G1X-9.1869Y4.2164Z-0.0500 N1350G1X-9.1850Y4.2416Z-0.0500 N1360G1X-9.1818Y4.2665Z-0.0500 N1370G1X-9.1774Y4.2911Z-0.0500 N1380G1X-9.1718Y4.3153Z-0.0500 N1390G1X-9.1650Y4.3390Z-0.0500 N1400G1X-9.1571Y4.3622Z-0.0500 N1410G1X-9.1469Y4.3878Z-0.0500 N1420G1X-9.1271Y4.4286Z-0.0500 N1430G1X-9.1021Y4.4696Z-0.0500 N1440G1X-9.0733Y4.5077Z-0.0500 N1450G1X-9.0411Y4.5429Z-0.0500 N1460G1X-9.0058Y4.5748Z-0.0500 N1470G1X-8.9675Y4.6033Z-0.0500 N1480G1X-8.9264Y4.6281Z-0.0500 N1490G1X-8.8855Y4.6476Z-0.0500 N1500G1X-8.8600Y4.6576Z-0.0500 N1510G1X-8.8368Y4.6654Z-0.0500 N1520G1X-8.8132Y4.6720Z-0.0500 N1530G1X-8.7891Y4.6776Z-0.0500 N1540G1X-8.7645Y4.6819Z-0.0500 N1550G1X-8.7397Y4.6850Z-0.0500 N1560G1X-8.7146Y4.6869Z-0.0500 N1570G1X-8.6924Y4.6875Z-0.0500 N1580G1X8.6924Y4.6875Z-0.0500 N1590G1X8.7146Y4.6869Z-0.0500 N1600G1X8.7397Y4.6850Z-0.0500 N1610G1X8.7645Y4.6819Z-0.0500 N1620G1X8.7891Y4.6776Z-0.0500 N1630G1X8.8132Y4.6720Z-0.0500 N1640G1X8.8368Y4.6654Z-0.0500 N1650G1X8.8600Y4.6576Z-0.0500 N1660G1X8.8855Y4.6476Z-0.0500 N1670G1X8.9264Y4.6281Z-0.0500 N1680G1X8.9675Y4.6033Z-0.0500 N1690G1X9.0058Y4.5748Z-0.0500 N1700G1X9.0411Y4.5429Z-0.0500 N1710G1X9.0733Y4.5077Z-0.0500 N1720G1X9.1021Y4.4696Z-0.0500 N1730G1X9.1271Y4.4286Z-0.0500 N1740G1X9.1469Y4.3878Z-0.0500 N1750G1X9.1571Y4.3622Z-0.0500 N1760G1X9.1650Y4.3390Z-0.0500 N1770G1X9.1718Y4.3153Z-0.0500 N1780G1X9.1774Y4.2911Z-0.0500 N1790G1X9.1818Y4.2665Z-0.0500 N1800G1X9.1850Y4.2416Z-0.0500 N1810G1X9.1869Y4.2164Z-0.0500 N1820G1X9.1875Y4.1942Z-0.0500 N1830G1X9.1875Y-4.1942Z-0.0500 N1840G1X9.1869Y-4.2164Z-0.0500 N1850G1X9.1850Y-4.2416Z-0.0500 N1860G1X9.1818Y-4.2665Z-0.0500 N1870G1X9.1774Y-4.2911Z-0.0500 N1880G1X9.1718Y-4.3153Z-0.0500 N1890G1X9.1650Y-4.3390Z-0.0500 N1900G1X9.1571Y-4.3622Z-0.0500 N1910G1X9.1469Y-4.3878Z-0.0500 N1920G1X9.1271Y-4.4286Z-0.0500 N1930G1X9.1021Y-4.4696Z-0.0500 N1940G1X9.0733Y-4.5077Z-0.0500 N1950G1X9.0411Y-4.5429Z-0.0500 N1960G1X9.0058Y-4.5748Z-0.0500 N1970G1X8.9675Y-4.6033Z-0.0500 N1980G1X8.9264Y-4.6281Z-0.0500 N1990G1X8.8855Y-4.6476Z-0.0500 N2000G1X8.8600Y-4.6576Z-0.0500 N2010G1X8.8368Y-4.6654Z-0.0500 N2020G1X8.8132Y-4.6720Z-0.0500 N2030G1X8.7891Y-4.6776Z-0.0500 N2040G1X8.7645Y-4.6819Z-0.0500 N2050G1X8.7397Y-4.6850Z-0.0500 N2060G1X8.7146Y-4.6869Z-0.0500 N2070G1X8.6924Y-4.6875Z-0.0500 N2080G1X-8.6924Y-4.6875Z-0.0500 N2090G1X-8.7146Y-4.6869Z-0.0500 N2100G1X-8.7397Y-4.6850Z-0.0500 N2110G1X-8.7645Y-4.6819Z-0.0500 N2120G1X-8.7891Y-4.6776Z-0.0500 N2130G1X-8.8132Y-4.6720Z-0.0500 N2140G1X-8.8368Y-4.6654Z-0.0500 N2150G1X-8.8600Y-4.6576Z-0.0500 N2160G1X-8.8855Y-4.6476Z-0.0500 N2170G1X-8.9264Y-4.6281Z-0.0500 N2180G1X-8.9675Y-4.6033Z-0.0500 N2190G1X-9.0058Y-4.5748Z-0.0500 N2200G1X-9.0411Y-4.5429Z-0.0500 N2210G1X-9.0733Y-4.5077Z-0.0500 N2220G1X-9.1021Y-4.4696Z-0.0500 N2230G1X-9.1271Y-4.4286Z-0.0500 N2240G1X-9.1469Y-4.3878Z-0.0500 N2250G1X-9.1571Y-4.3622Z-0.0500 N2260G1X-9.1650Y-4.3390Z-0.0500 N2270G1X-9.1718Y-4.3153Z-0.0500 N2280G1X-9.1774Y-4.2911Z-0.0500 N2290G1X-9.1818Y-4.2665Z-0.0500 N2300G1X-9.1850Y-4.2416Z-0.0500 N2310G1X-9.1869Y-4.2164Z-0.0500 N2320G1X-9.1875Y-4.1942Z-0.0500 N2330G1X-9.1875Y4.1942Z-0.0500 N2340G1X-9.1869Y4.2164Z-0.0500 N2350G1X-9.1850Y4.2416Z-0.0500 N2360G1X-9.1818Y4.2665Z-0.0500 N2370G1X-9.1774Y4.2911Z-0.0500 N2380G00X-9.1774Y4.2911Z0.2000 N2390G00X-9.5681Y3.8325Z0.2000 N2400G1X-9.5681Y3.8325Z-0.1000F20.0 N2410G1X-9.1875Y4.1942Z-0.1000 N2420G1X-9.1869Y4.2164Z-0.1000 N2430G1X-9.1850Y4.2416Z-0.1000 N2440G1X-9.1818Y4.2665Z-0.1000 N2450G1X-9.1774Y4.2911Z-0.1000 N2460G1X-9.1718Y4.3153Z-0.1000 N2470G1X-9.1650Y4.3390Z-0.1000 N2480G1X-9.1571Y4.3622Z-0.1000 N2490G1X-9.1469Y4.3878Z-0.1000 N2500G1X-9.1271Y4.4286Z-0.1000 N2510G1X-9.1021Y4.4696Z-0.1000 N2520G1X-9.0733Y4.5077Z-0.1000 N2530G1X-9.0411Y4.5429Z-0.1000 N2540G1X-9.0058Y4.5748Z-0.1000 N2550G1X-8.9675Y4.6033Z-0.1000 N2560G1X-8.9264Y4.6281Z-0.1000 N2570G1X-8.8855Y4.6476Z-0.1000 N2580G1X-8.8600Y4.6576Z-0.1000 N2590G1X-8.8368Y4.6654Z-0.1000 N2600G1X-8.8132Y4.6720Z-0.1000 N2610G1X-8.7891Y4.6776Z-0.1000 N2620G1X-8.7645Y4.6819Z-0.1000 N2630G1X-8.7397Y4.6850Z-0.1000 N2640G1X-8.7146Y4.6869Z-0.1000 N2650G1X-8.6924Y4.6875Z-0.1000 N2660G1X8.6924Y4.6875Z-0.1000 N2670G1X8.7146Y4.6869Z-0.1000 N2680G1X8.7397Y4.6850Z-0.1000 N2690G1X8.7645Y4.6819Z-0.1000 N2700G1X8.7891Y4.6776Z-0.1000 N2710G1X8.8132Y4.6720Z-0.1000 N2720G1X8.8368Y4.6654Z-0.1000 N2730G1X8.8600Y4.6576Z-0.1000 N2740G1X8.8855Y4.6476Z-0.1000 N2750G1X8.9264Y4.6281Z-0.1000 N2760G1X8.9675Y4.6033Z-0.1000 N2770G1X9.0058Y4.5748Z-0.1000 N2780G1X9.0411Y4.5429Z-0.1000 N2790G1X9.0733Y4.5077Z-0.1000 N2800G1X9.1021Y4.4696Z-0.1000 N2810G1X9.1271Y4.4286Z-0.1000 N2820G1X9.1469Y4.3878Z-0.1000 N2830G1X9.1571Y4.3622Z-0.1000 N2840G1X9.1650Y4.3390Z-0.1000 N2850G1X9.1718Y4.3153Z-0.1000 N2860G1X9.1774Y4.2911Z-0.1000 N2870G1X9.1818Y4.2665Z-0.1000 N2880G1X9.1850Y4.2416Z-0.1000 N2890G1X9.1869Y4.2164Z-0.1000 N2900G1X9.1875Y4.1942Z-0.1000 N2910G1X9.1875Y-4.1942Z-0.1000 N2920G1X9.1869Y-4.2164Z-0.1000 N2930G1X9.1850Y-4.2416Z-0.1000 N2940G1X9.1818Y-4.2665Z-0.1000 N2950G1X9.1774Y-4.2911Z-0.1000 N2960G1X9.1718Y-4.3153Z-0.1000 N2970G1X9.1650Y-4.3390Z-0.1000 N2980G1X9.1571Y-4.3622Z-0.1000 N2990G1X9.1469Y-4.3878Z-0.1000 N3000G1X9.1271Y-4.4286Z-0.1000 N3010G1X9.1021Y-4.4696Z-0.1000 N3020G1X9.0733Y-4.5077Z-0.1000 N3030G1X9.0411Y-4.5429Z-0.1000 N3040G1X9.0058Y-4.5748Z-0.1000 N3050G1X8.9675Y-4.6033Z-0.1000 N3060G1X8.9264Y-4.6281Z-0.1000 N3070G1X8.8855Y-4.6476Z-0.1000 N3080G1X8.8600Y-4.6576Z-0.1000 N3090G1X8.8368Y-4.6654Z-0.1000 N3100G1X8.8132Y-4.6720Z-0.1000 N3110G1X8.7891Y-4.6776Z-0.1000 N3120G1X8.7645Y-4.6819Z-0.1000 N3130G1X8.7397Y-4.6850Z-0.1000 N3140G1X8.7146Y-4.6869Z-0.1000 N3150G1X8.6924Y-4.6875Z-0.1000 N3160G1X-8.6924Y-4.6875Z-0.1000 N3170G1X-8.7146Y-4.6869Z-0.1000 N3180G1X-8.7397Y-4.6850Z-0.1000 N3190G1X-8.7645Y-4.6819Z-0.1000 N3200G1X-8.7891Y-4.6776Z-0.1000 N3210G1X-8.8132Y-4.6720Z-0.1000 N3220G1X-8.8368Y-4.6654Z-0.1000 N3230G1X-8.8600Y-4.6576Z-0.1000 N3240G1X-8.8855Y-4.6476Z-0.1000 N3250G1X-8.9264Y-4.6281Z-0.1000 N3260G1X-8.9675Y-4.6033Z-0.1000 N3270G1X-9.0058Y-4.5748Z-0.1000 N3280G1X-9.0411Y-4.5429Z-0.1000 N3290G1X-9.0733Y-4.5077Z-0.1000 N3300G1X-9.1021Y-4.4696Z-0.1000 N3310G1X-9.1271Y-4.4286Z-0.1000 N3320G1X-9.1469Y-4.3878Z-0.1000 N3330G1X-9.1571Y-4.3622Z-0.1000 N3340G1X-9.1650Y-4.3390Z-0.1000 N3350G1X-9.1718Y-4.3153Z-0.1000 N3360G1X-9.1774Y-4.2911Z-0.1000 N3370G1X-9.1818Y-4.2665Z-0.1000 N3380G1X-9.1850Y-4.2416Z-0.1000 N3390G1X-9.1869Y-4.2164Z-0.1000 N3400G1X-9.1875Y-4.1942Z-0.1000 N3410G1X-9.1875Y4.1942Z-0.1000 N3420G1X-9.1869Y4.2164Z-0.1000 N3430G1X-9.1850Y4.2416Z-0.1000 N3440G1X-9.1818Y4.2665Z-0.1000 N3450G1X-9.1774Y4.2911Z-0.1000 N3460G00X-9.1774Y4.2911Z0.2000 N3470T75M6 N3480 (Tool: 75 spot drill) N3490G43H75 N3500S3000M03 (spot keyway) () N3530G00X6.0000Y0.0000Z0.2000 N3540G1X6.0000Y0.0000Z-0.4250F15.0 N3550G00X6.0000Y0.0000Z0.2000 N3560G00X0.0000Y0.0000Z0.2000 N3570G1X0.0000Y0.0000Z-0.4250F15.0 N3580G00X0.0000Y0.0000Z0.2000 N3590G00X-6.0000Y0.0000Z0.2000 N3600G1X-6.0000Y0.0000Z-0.4250F15.0 N3610G00X-6.0000Y0.0000Z0.2000 N3620T50M6 N3630 (Tool: #50 number drill 25) N3640G43H50 N3650S3500M03 (DRILL KEYWAY) () N3680G00X6.0000Y0.0000Z0.2000 N3690G1X6.0000Y0.0000Z-0.4135F15.0 N3700G00X6.0000Y0.0000Z-0.3750 N3710G1X6.0000Y0.0000Z-0.4519F15.0 N3720G00X6.0000Y0.0000Z-0.3750 N3730G1X6.0000Y0.0000Z-0.4904F15.0 N3740G00X6.0000Y0.0000Z-0.3750 N3750G1X6.0000Y0.0000Z-0.5288F15.0 N3760G00X6.0000Y0.0000Z-0.3750 N3770G1X6.0000Y0.0000Z-0.5673F15.0 N3780G00X6.0000Y0.0000Z-0.3750 N3790G1X6.0000Y0.0000Z-0.6058F15.0 N3800G00X6.0000Y0.0000Z-0.3750 N3810G1X6.0000Y0.0000Z-0.6442F15.0 N3820G00X6.0000Y0.0000Z-0.3750 N3830G1X6.0000Y0.0000Z-0.6827F15.0 N3840G00X6.0000Y0.0000Z-0.3750 N3850G1X6.0000Y0.0000Z-0.7212F15.0 N3860G00X6.0000Y0.0000Z-0.3750 N3870G1X6.0000Y0.0000Z-0.7596F15.0 N3880G00X6.0000Y0.0000Z-0.3750 N3890G1X6.0000Y0.0000Z-0.7981F15.0 N3900G00X6.0000Y0.0000Z-0.3750 N3910G1X6.0000Y0.0000Z-0.8365F15.0 N3920G00X6.0000Y0.0000Z-0.3750 N3930G1X6.0000Y0.0000Z-0.8750F15.0 N3940G00X6.0000Y0.0000Z0.2000 N3950G00X0.0000Y0.0000Z0.2000 N3960G1X0.0000Y0.0000Z-0.4135F15.0 N3970G00X0.0000Y0.0000Z-0.3750 N3980G1X0.0000Y0.0000Z-0.4519F15.0 N3990G00X0.0000Y0.0000Z-0.3750 N4000G1X0.0000Y0.0000Z-0.4904F15.0 N4010G00X0.0000Y0.0000Z-0.3750 N4020G1X0.0000Y0.0000Z-0.5288F15.0 N4030G00X0.0000Y0.0000Z-0.3750 N4040G1X0.0000Y0.0000Z-0.5673F15.0 N4050G00X0.0000Y0.0000Z-0.3750 N4060G1X0.0000Y0.0000Z-0.6058F15.0 N4070G00X0.0000Y0.0000Z-0.3750 N4080G1X0.0000Y0.0000Z-0.6442F15.0 N4090G00X0.0000Y0.0000Z-0.3750 N4100G1X0.0000Y0.0000Z-0.6827F15.0 N4110G00X0.0000Y0.0000Z-0.3750 N4120G1X0.0000Y0.0000Z-0.7212F15.0 N4130G00X0.0000Y0.0000Z-0.3750 N4140G1X0.0000Y0.0000Z-0.7596F15.0 N4150G00X0.0000Y0.0000Z-0.3750 N4160G1X0.0000Y0.0000Z-0.7981F15.0 N4170G00X0.0000Y0.0000Z-0.3750 N4180G1X0.0000Y0.0000Z-0.8365F15.0 N4190G00X0.0000Y0.0000Z-0.3750 N4200G1X0.0000Y0.0000Z-0.8750F15.0 N4210G00X0.0000Y0.0000Z0.2000 N4220G00X-6.0000Y0.0000Z0.2000 N4230G1X-6.0000Y0.0000Z-0.4135F15.0 N4240G00X-6.0000Y0.0000Z-0.3750 N4250G1X-6.0000Y0.0000Z-0.4519F15.0 N4260G00X-6.0000Y0.0000Z-0.3750 N4270G1X-6.0000Y0.0000Z-0.4904F15.0 N4280G00X-6.0000Y0.0000Z-0.3750 N4290G1X-6.0000Y0.0000Z-0.5288F15.0 N4300G00X-6.0000Y0.0000Z-0.3750 N4310G1X-6.0000Y0.0000Z-0.5673F15.0 N4320G00X-6.0000Y0.0000Z-0.3750 N4330G1X-6.0000Y0.0000Z-0.6058F15.0 N4340G00X-6.0000Y0.0000Z-0.3750 N4350G1X-6.0000Y0.0000Z-0.6442F15.0 N4360G00X-6.0000Y0.0000Z-0.3750 N4370G1X-6.0000Y0.0000Z-0.6827F15.0 N4380G00X-6.0000Y0.0000Z-0.3750 N4390G1X-6.0000Y0.0000Z-0.7212F15.0 N4400G00X-6.0000Y0.0000Z-0.3750 N4410G1X-6.0000Y0.0000Z-0.7596F15.0 N4420G00X-6.0000Y0.0000Z-0.3750 N4430G1X-6.0000Y0.0000Z-0.7981F15.0 N4440G00X-6.0000Y0.0000Z-0.3750 N4450G1X-6.0000Y0.0000Z-0.8365F15.0 N4460G00X-6.0000Y0.0000Z-0.3750 N4470G1X-6.0000Y0.0000Z-0.8750F15.0 N4480G00X-6.0000Y0.0000Z0.2000 N4490T6M6 N4500 (Tool: #6 End Mill 1/2) N4510G43H6 N4520S5000M03 (TRIM OUTSIDE [1]) () N4550G00X-9.5781Y3.8326Z0.2000 N4560G1X-9.5781Y3.8326Z-0.0950F20.0 N4570G1X-9.1975Y4.1943Z-0.0950 N4580G1X-9.1969Y4.2169Z-0.0950 N4590G1X-9.1950Y4.2426Z-0.0950 N4600G1X-9.1917Y4.2681Z-0.0950 N4610G1X-9.1872Y4.2931Z-0.0950 N4620G1X-9.1815Y4.3178Z-0.0950 N4630G1X-9.1745Y4.3420Z-0.0950 N4640G1X-9.1665Y4.3657Z-0.0950 N4650G1X-9.1561Y4.3918Z-0.0950 N4660G1X-9.1359Y4.4334Z-0.0950 N4670G1X-9.1103Y4.4752Z-0.0950 N4680G1X-9.0810Y4.5141Z-0.0950 N4690G1X-9.0482Y4.5500Z-0.0950 N4700G1X-9.0121Y4.5825Z-0.0950 N4710G1X-8.9730Y4.6116Z-0.0950 N4720G1X-8.9311Y4.6369Z-0.0950 N4730G1X-8.8895Y4.6568Z-0.0950 N4740G1X-8.8635Y4.6670Z-0.0950 N4750G1X-8.8398Y4.6749Z-0.0950 N4760G1X-8.8156Y4.6817Z-0.0950 N4770G1X-8.7910Y4.6874Z-0.0950 N4780G1X-8.7660Y4.6918Z-0.0950 N4790G1X-8.7407Y4.6950Z-0.0950 N4800G1X-8.7151Y4.6969Z-0.0950 N4810G1X-8.6925Y4.6975Z-0.0950 N4820G1X8.6925Y4.6975Z-0.0950 N4830G1X8.7151Y4.6969Z-0.0950 N4840G1X8.7407Y4.6950Z-0.0950 N4850G1X8.7660Y4.6918Z-0.0950 N4860G1X8.7910Y4.6874Z-0.0950 N4870G1X8.8156Y4.6817Z-0.0950 N4880G1X8.8398Y4.6749Z-0.0950 N4890G1X8.8635Y4.6670Z-0.0950 N4900G1X8.8895Y4.6568Z-0.0950 N4910G1X8.9311Y4.6369Z-0.0950 N4920G1X8.9730Y4.6116Z-0.0950 N4930G1X9.0121Y4.5825Z-0.0950 N4940G1X9.0482Y4.5500Z-0.0950 N4950G1X9.0810Y4.5141Z-0.0950 N4960G1X9.1103Y4.4752Z-0.0950 N4970G1X9.1359Y4.4334Z-0.0950 N4980G1X9.1561Y4.3918Z-0.0950 N4990G1X9.1665Y4.3657Z-0.0950 N5000G1X9.1745Y4.3420Z-0.0950 N5010G1X9.1815Y4.3178Z-0.0950 N5020G1X9.1872Y4.2931Z-0.0950 N5030G1X9.1917Y4.2681Z-0.0950 N5040G1X9.1950Y4.2426Z-0.0950 N5050G1X9.1969Y4.2169Z-0.0950 N5060G1X9.1975Y4.1943Z-0.0950 N5070G1X9.1975Y-4.1943Z-0.0950 N5080G1X9.1969Y-4.2169Z-0.0950 N5090G1X9.1950Y-4.2426Z-0.0950 N5100G1X9.1917Y-4.2681Z-0.0950 N5110G1X9.1872Y-4.2931Z-0.0950 N5120G1X9.1815Y-4.3178Z-0.0950 N5130G1X9.1745Y-4.3420Z-0.0950 N5140G1X9.1665Y-4.3657Z-0.0950 N5150G1X9.1561Y-4.3918Z-0.0950 N5160G1X9.1359Y-4.4334Z-0.0950 N5170G1X9.1103Y-4.4752Z-0.0950 N5180G1X9.0810Y-4.5141Z-0.0950 N5190G1X9.0482Y-4.5500Z-0.0950 N5200G1X9.0121Y-4.5825Z-0.0950 N5210G1X8.9730Y-4.6116Z-0.0950 N5220G1X8.9311Y-4.6369Z-0.0950 N5230G1X8.8895Y-4.6568Z-0.0950 N5240G1X8.8635Y-4.6670Z-0.0950 N5250G1X8.8398Y-4.6749Z-0.0950 N5260G1X8.8156Y-4.6817Z-0.0950 N5270G1X8.7910Y-4.6874Z-0.0950 N5280G1X8.7660Y-4.6918Z-0.0950 N5290G1X8.7407Y-4.6950Z-0.0950 N5300G1X8.7151Y-4.6969Z-0.0950 N5310G1X8.6925Y-4.6975Z-0.0950 N5320G1X-8.6925Y-4.6975Z-0.0950 N5330G1X-8.7151Y-4.6969Z-0.0950 N5340G1X-8.7407Y-4.6950Z-0.0950 N5350G1X-8.7660Y-4.6918Z-0.0950 N5360G1X-8.7910Y-4.6874Z-0.0950 N5370G1X-8.8156Y-4.6817Z-0.0950 N5380G1X-8.8398Y-4.6749Z-0.0950 N5390G1X-8.8635Y-4.6670Z-0.0950 N5400G1X-8.8895Y-4.6568Z-0.0950 N5410G1X-8.9311Y-4.6369Z-0.0950 N5420G1X-8.9730Y-4.6116Z-0.0950 N5430G1X-9.0121Y-4.5825Z-0.0950 N5440G1X-9.0482Y-4.5500Z-0.0950 N5450G1X-9.0810Y-4.5141Z-0.0950 N5460G1X-9.1103Y-4.4752Z-0.0950 N5470G1X-9.1359Y-4.4334Z-0.0950 N5480G1X-9.1561Y-4.3918Z-0.0950 N5490G1X-9.1665Y-4.3657Z-0.0950 N5500G1X-9.1745Y-4.3420Z-0.0950 N5510G1X-9.1815Y-4.3178Z-0.0950 N5520G1X-9.1872Y-4.2931Z-0.0950 N5530G1X-9.1917Y-4.2681Z-0.0950 N5540G1X-9.1950Y-4.2426Z-0.0950 N5550G1X-9.1969Y-4.2169Z-0.0950 N5560G1X-9.1975Y-4.1943Z-0.0950 N5570G1X-9.1975Y4.1943Z-0.0950 N5580G1X-9.1969Y4.2169Z-0.0950 N5590G1X-9.1950Y4.2426Z-0.0950 N5600G1X-9.1917Y4.2681Z-0.0950 N5610G1X-9.1872Y4.2931Z-0.0950 N5620G00X-9.1872Y4.2931Z0.2000 N5630G00X-9.5781Y3.8326Z0.2000 N5640G1X-9.5781Y3.8326Z-0.1900F20.0 N5650G1X-9.1975Y4.1943Z-0.1900 N5660G1X-9.1969Y4.2169Z-0.1900 N5670G1X-9.1950Y4.2426Z-0.1900 N5680G1X-9.1917Y4.2681Z-0.1900 N5690G1X-9.1872Y4.2931Z-0.1900 N5700G1X-9.1815Y4.3178Z-0.1900 N5710G1X-9.1745Y4.3420Z-0.1900 N5720G1X-9.1665Y4.3657Z-0.1900 N5730G1X-9.1561Y4.3918Z-0.1900 N5740G1X-9.1359Y4.4334Z-0.1900 N5750G1X-9.1103Y4.4752Z-0.1900 N5760G1X-9.0810Y4.5141Z-0.1900 N5770G1X-9.0482Y4.5500Z-0.1900 N5780G1X-9.0121Y4.5825Z-0.1900 N5790G1X-8.9730Y4.6116Z-0.1900 N5800G1X-8.9311Y4.6369Z-0.1900 N5810G1X-8.8895Y4.6568Z-0.1900 N5820G1X-8.8635Y4.6670Z-0.1900 N5830G1X-8.8398Y4.6749Z-0.1900 N5840G1X-8.8156Y4.6817Z-0.1900 N5850G1X-8.7910Y4.6874Z-0.1900 N5860G1X-8.7660Y4.6918Z-0.1900 N5870G1X-8.7407Y4.6950Z-0.1900 N5880G1X-8.7151Y4.6969Z-0.1900 N5890G1X-8.6925Y4.6975Z-0.1900 N5900G1X8.6925Y4.6975Z-0.1900 N5910G1X8.7151Y4.6969Z-0.1900 N5920G1X8.7407Y4.6950Z-0.1900 N5930G1X8.7660Y4.6918Z-0.1900 N5940G1X8.7910Y4.6874Z-0.1900 N5950G1X8.8156Y4.6817Z-0.1900 N5960G1X8.8398Y4.6749Z-0.1900 N5970G1X8.8635Y4.6670Z-0.1900 N5980G1X8.8895Y4.6568Z-0.1900 N5990G1X8.9311Y4.6369Z-0.1900 N6000G1X8.9730Y4.6116Z-0.1900 N6010G1X9.0121Y4.5825Z-0.1900 N6020G1X9.0482Y4.5500Z-0.1900 N6030G1X9.0810Y4.5141Z-0.1900 N6040G1X9.1103Y4.4752Z-0.1900 N6050G1X9.1359Y4.4334Z-0.1900 N6060G1X9.1561Y4.3918Z-0.1900 N6070G1X9.1665Y4.3657Z-0.1900 N6080G1X9.1745Y4.3420Z-0.1900 N6090G1X9.1815Y4.3178Z-0.1900 N6100G1X9.1872Y4.2931Z-0.1900 N6110G1X9.1917Y4.2681Z-0.1900 N6120G1X9.1950Y4.2426Z-0.1900 N6130G1X9.1969Y4.2169Z-0.1900 N6140G1X9.1975Y4.1943Z-0.1900 N6150G1X9.1975Y-4.1943Z-0.1900 N6160G1X9.1969Y-4.2169Z-0.1900 N6170G1X9.1950Y-4.2426Z-0.1900 N6180G1X9.1917Y-4.2681Z-0.1900 N6190G1X9.1872Y-4.2931Z-0.1900 N6200G1X9.1815Y-4.3178Z-0.1900 N6210G1X9.1745Y-4.3420Z-0.1900 N6220G1X9.1665Y-4.3657Z-0.1900 N6230G1X9.1561Y-4.3918Z-0.1900 N6240G1X9.1359Y-4.4334Z-0.1900 N6250G1X9.1103Y-4.4752Z-0.1900 N6260G1X9.0810Y-4.5141Z-0.1900 N6270G1X9.0482Y-4.5500Z-0.1900 N6280G1X9.0121Y-4.5825Z-0.1900 N6290G1X8.9730Y-4.6116Z-0.1900 N6300G1X8.9311Y-4.6369Z-0.1900 N6310G1X8.8895Y-4.6568Z-0.1900 N6320G1X8.8635Y-4.6670Z-0.1900 N6330G1X8.8398Y-4.6749Z-0.1900 N6340G1X8.8156Y-4.6817Z-0.1900 N6350G1X8.7910Y-4.6874Z-0.1900 N6360G1X8.7660Y-4.6918Z-0.1900 N6370G1X8.7407Y-4.6950Z-0.1900 N6380G1X8.7151Y-4.6969Z-0.1900 N6390G1X8.6925Y-4.6975Z-0.1900 N6400G1X-8.6925Y-4.6975Z-0.1900 N6410G1X-8.7151Y-4.6969Z-0.1900 N6420G1X-8.7407Y-4.6950Z-0.1900 N6430G1X-8.7660Y-4.6918Z-0.1900 N6440G1X-8.7910Y-4.6874Z-0.1900 N6450G1X-8.8156Y-4.6817Z-0.1900 N6460G1X-8.8398Y-4.6749Z-0.1900 N6470G1X-8.8635Y-4.6670Z-0.1900 N6480G1X-8.8895Y-4.6568Z-0.1900 N6490G1X-8.9311Y-4.6369Z-0.1900 N6500G1X-8.9730Y-4.6116Z-0.1900 N6510G1X-9.0121Y-4.5825Z-0.1900 N6520G1X-9.0482Y-4.5500Z-0.1900 N6530G1X-9.0810Y-4.5141Z-0.1900 N6540G1X-9.1103Y-4.4752Z-0.1900 N6550G1X-9.1359Y-4.4334Z-0.1900 N6560G1X-9.1561Y-4.3918Z-0.1900 N6570G1X-9.1665Y-4.3657Z-0.1900 N6580G1X-9.1745Y-4.3420Z-0.1900 N6590G1X-9.1815Y-4.3178Z-0.1900 N6600G1X-9.1872Y-4.2931Z-0.1900 N6610G1X-9.1917Y-4.2681Z-0.1900 N6620G1X-9.1950Y-4.2426Z-0.1900 N6630G1X-9.1969Y-4.2169Z-0.1900 N6640G1X-9.1975Y-4.1943Z-0.1900 N6650G1X-9.1975Y4.1943Z-0.1900 N6660G1X-9.1969Y4.2169Z-0.1900 N6670G1X-9.1950Y4.2426Z-0.1900 N6680G1X-9.1917Y4.2681Z-0.1900 N6690G1X-9.1872Y4.2931Z-0.1900 N6700G00X-9.1872Y4.2931Z0.2000 N6710G00X-9.5781Y3.8326Z0.2000 N6720G1X-9.5781Y3.8326Z-0.2850F20.0 N6730G1X-9.1975Y4.1943Z-0.2850 N6740G1X-9.1969Y4.2169Z-0.2850 N6750G1X-9.1950Y4.2426Z-0.2850 N6760G1X-9.1917Y4.2681Z-0.2850 N6770G1X-9.1872Y4.2931Z-0.2850 N6780G1X-9.1815Y4.3178Z-0.2850 N6790G1X-9.1745Y4.3420Z-0.2850 N6800G1X-9.1665Y4.3657Z-0.2850 N6810G1X-9.1561Y4.3918Z-0.2850 N6820G1X-9.1359Y4.4334Z-0.2850 N6830G1X-9.1103Y4.4752Z-0.2850 N6840G1X-9.0810Y4.5141Z-0.2850 N6850G1X-9.0482Y4.5500Z-0.2850 N6860G1X-9.0121Y4.5825Z-0.2850 N6870G1X-8.9730Y4.6116Z-0.2850 N6880G1X-8.9311Y4.6369Z-0.2850 N6890G1X-8.8895Y4.6568Z-0.2850 N6900G1X-8.8635Y4.6670Z-0.2850 N6910G1X-8.8398Y4.6749Z-0.2850 N6920G1X-8.8156Y4.6817Z-0.2850 N6930G1X-8.7910Y4.6874Z-0.2850 N6940G1X-8.7660Y4.6918Z-0.2850 N6950G1X-8.7407Y4.6950Z-0.2850 N6960G1X-8.7151Y4.6969Z-0.2850 N6970G1X-8.6925Y4.6975Z-0.2850 N6980G1X8.6925Y4.6975Z-0.2850 N6990G1X8.7151Y4.6969Z-0.2850 N7000G1X8.7407Y4.6950Z-0.2850 N7010G1X8.7660Y4.6918Z-0.2850 N7020G1X8.7910Y4.6874Z-0.2850 N7030G1X8.8156Y4.6817Z-0.2850 N7040G1X8.8398Y4.6749Z-0.2850 N7050G1X8.8635Y4.6670Z-0.2850 N7060G1X8.8895Y4.6568Z-0.2850 N7070G1X8.9311Y4.6369Z-0.2850 N7080G1X8.9730Y4.6116Z-0.2850 N7090G1X9.0121Y4.5825Z-0.2850 N7100G1X9.0482Y4.5500Z-0.2850 N7110G1X9.0810Y4.5141Z-0.2850 N7120G1X9.1103Y4.4752Z-0.2850 N7130G1X9.1359Y4.4334Z-0.2850 N7140G1X9.1561Y4.3918Z-0.2850 N7150G1X9.1665Y4.3657Z-0.2850 N7160G1X9.1745Y4.3420Z-0.2850 N7170G1X9.1815Y4.3178Z-0.2850 N7180G1X9.1872Y4.2931Z-0.2850 N7190G1X9.1917Y4.2681Z-0.2850 N7200G1X9.1950Y4.2426Z-0.2850 N7210G1X9.1969Y4.2169Z-0.2850 N7220G1X9.1975Y4.1943Z-0.2850 N7230G1X9.1975Y-4.1943Z-0.2850 N7240G1X9.1969Y-4.2169Z-0.2850 N7250G1X9.1950Y-4.2426Z-0.2850 N7260G1X9.1917Y-4.2681Z-0.2850 N7270G1X9.1872Y-4.2931Z-0.2850 N7280G1X9.1815Y-4.3178Z-0.2850 N7290G1X9.1745Y-4.3420Z-0.2850 N7300G1X9.1665Y-4.3657Z-0.2850 N7310G1X9.1561Y-4.3918Z-0.2850 N7320G1X9.1359Y-4.4334Z-0.2850 N7330G1X9.1103Y-4.4752Z-0.2850 N7340G1X9.0810Y-4.5141Z-0.2850 N7350G1X9.0482Y-4.5500Z-0.2850 N7360G1X9.0121Y-4.5825Z-0.2850 N7370G1X8.9730Y-4.6116Z-0.2850 N7380G1X8.9311Y-4.6369Z-0.2850 N7390G1X8.8895Y-4.6568Z-0.2850 N7400G1X8.8635Y-4.6670Z-0.2850 N7410G1X8.8398Y-4.6749Z-0.2850 N7420G1X8.8156Y-4.6817Z-0.2850 N7430G1X8.7910Y-4.6874Z-0.2850 N7440G1X8.7660Y-4.6918Z-0.2850 N7450G1X8.7407Y-4.6950Z-0.2850 N7460G1X8.7151Y-4.6969Z-0.2850 N7470G1X8.6925Y-4.6975Z-0.2850 N7480G1X-8.6925Y-4.6975Z-0.2850 N7490G1X-8.7151Y-4.6969Z-0.2850 N7500G1X-8.7407Y-4.6950Z-0.2850 N7510G1X-8.7660Y-4.6918Z-0.2850 N7520G1X-8.7910Y-4.6874Z-0.2850 N7530G1X-8.8156Y-4.6817Z-0.2850 N7540G1X-8.8398Y-4.6749Z-0.2850 N7550G1X-8.8635Y-4.6670Z-0.2850 N7560G1X-8.8895Y-4.6568Z-0.2850 N7570G1X-8.9311Y-4.6369Z-0.2850 N7580G1X-8.9730Y-4.6116Z-0.2850 N7590G1X-9.0121Y-4.5825Z-0.2850 N7600G1X-9.0482Y-4.5500Z-0.2850 N7610G1X-9.0810Y-4.5141Z-0.2850 N7620G1X-9.1103Y-4.4752Z-0.2850 N7630G1X-9.1359Y-4.4334Z-0.2850 N7640G1X-9.1561Y-4.3918Z-0.2850 N7650G1X-9.1665Y-4.3657Z-0.2850 N7660G1X-9.1745Y-4.3420Z-0.2850 N7670G1X-9.1815Y-4.3178Z-0.2850 N7680G1X-9.1872Y-4.2931Z-0.2850 N7690G1X-9.1917Y-4.2681Z-0.2850 N7700G1X-9.1950Y-4.2426Z-0.2850 N7710G1X-9.1969Y-4.2169Z-0.2850 N7720G1X-9.1975Y-4.1943Z-0.2850 N7730G1X-9.1975Y4.1943Z-0.2850 N7740G1X-9.1969Y4.2169Z-0.2850 N7750G1X-9.1950Y4.2426Z-0.2850 N7760G1X-9.1917Y4.2681Z-0.2850 N7770G1X-9.1872Y4.2931Z-0.2850 N7780G00X-9.1872Y4.2931Z0.2000 N7790G00X-9.5781Y3.8326Z0.2000 N7800G1X-9.5781Y3.8326Z-0.3800F20.0 N7810G1X-9.1975Y4.1943Z-0.3800 N7820G1X-9.1969Y4.2169Z-0.3800 N7830G1X-9.1950Y4.2426Z-0.3800 N7840G1X-9.1917Y4.2681Z-0.3800 N7850G1X-9.1872Y4.2931Z-0.3800 N7860G1X-9.1815Y4.3178Z-0.3800 N7870G1X-9.1745Y4.3420Z-0.3800 N7880G1X-9.1665Y4.3657Z-0.3800 N7890G1X-9.1561Y4.3918Z-0.3800 N7900G1X-9.1359Y4.4334Z-0.3800 N7910G1X-9.1103Y4.4752Z-0.3800 N7920G1X-9.0810Y4.5141Z-0.3800 N7930G1X-9.0482Y4.5500Z-0.3800 N7940G1X-9.0121Y4.5825Z-0.3800 N7950G1X-8.9730Y4.6116Z-0.3800 N7960G1X-8.9311Y4.6369Z-0.3800 N7970G1X-8.8895Y4.6568Z-0.3800 N7980G1X-8.8635Y4.6670Z-0.3800 N7990G1X-8.8398Y4.6749Z-0.3800 N8000G1X-8.8156Y4.6817Z-0.3800 N8010G1X-8.7910Y4.6874Z-0.3800 N8020G1X-8.7660Y4.6918Z-0.3800 N8030G1X-8.7407Y4.6950Z-0.3800 N8040G1X-8.7151Y4.6969Z-0.3800 N8050G1X-8.6925Y4.6975Z-0.3800 N8060G1X8.6925Y4.6975Z-0.3800 N8070G1X8.7151Y4.6969Z-0.3800 N8080G1X8.7407Y4.6950Z-0.3800 N8090G1X8.7660Y4.6918Z-0.3800 N8100G1X8.7910Y4.6874Z-0.3800 N8110G1X8.8156Y4.6817Z-0.3800 N8120G1X8.8398Y4.6749Z-0.3800 N8130G1X8.8635Y4.6670Z-0.3800 N8140G1X8.8895Y4.6568Z-0.3800 N8150G1X8.9311Y4.6369Z-0.3800 N8160G1X8.9730Y4.6116Z-0.3800 N8170G1X9.0121Y4.5825Z-0.3800 N8180G1X9.0482Y4.5500Z-0.3800 N8190G1X9.0810Y4.5141Z-0.3800 N8200G1X9.1103Y4.4752Z-0.3800 N8210G1X9.1359Y4.4334Z-0.3800 N8220G1X9.1561Y4.3918Z-0.3800 N8230G1X9.1665Y4.3657Z-0.3800 N8240G1X9.1745Y4.3420Z-0.3800 N8250G1X9.1815Y4.3178Z-0.3800 N8260G1X9.1872Y4.2931Z-0.3800 N8270G1X9.1917Y4.2681Z-0.3800 N8280G1X9.1950Y4.2426Z-0.3800 N8290G1X9.1969Y4.2169Z-0.3800 N8300G1X9.1975Y4.1943Z-0.3800 N8310G1X9.1975Y-4.1943Z-0.3800 N8320G1X9.1969Y-4.2169Z-0.3800 N8330G1X9.1950Y-4.2426Z-0.3800 N8340G1X9.1917Y-4.2681Z-0.3800 N8350G1X9.1872Y-4.2931Z-0.3800 N8360G1X9.1815Y-4.3178Z-0.3800 N8370G1X9.1745Y-4.3420Z-0.3800 N8380G1X9.1665Y-4.3657Z-0.3800 N8390G1X9.1561Y-4.3918Z-0.3800 N8400G1X9.1359Y-4.4334Z-0.3800 N8410G1X9.1103Y-4.4752Z-0.3800 N8420G1X9.0810Y-4.5141Z-0.3800 N8430G1X9.0482Y-4.5500Z-0.3800 N8440G1X9.0121Y-4.5825Z-0.3800 N8450G1X8.9730Y-4.6116Z-0.3800 N8460G1X8.9311Y-4.6369Z-0.3800 N8470G1X8.8895Y-4.6568Z-0.3800 N8480G1X8.8635Y-4.6670Z-0.3800 N8490G1X8.8398Y-4.6749Z-0.3800 N8500G1X8.8156Y-4.6817Z-0.3800 N8510G1X8.7910Y-4.6874Z-0.3800 N8520G1X8.7660Y-4.6918Z-0.3800 N8530G1X8.7407Y-4.6950Z-0.3800 N8540G1X8.7151Y-4.6969Z-0.3800 N8550G1X8.6925Y-4.6975Z-0.3800 N8560G1X-8.6925Y-4.6975Z-0.3800 N8570G1X-8.7151Y-4.6969Z-0.3800 N8580G1X-8.7407Y-4.6950Z-0.3800 N8590G1X-8.7660Y-4.6918Z-0.3800 N8600G1X-8.7910Y-4.6874Z-0.3800 N8610G1X-8.8156Y-4.6817Z-0.3800 N8620G1X-8.8398Y-4.6749Z-0.3800 N8630G1X-8.8635Y-4.6670Z-0.3800 N8640G1X-8.8895Y-4.6568Z-0.3800 N8650G1X-8.9311Y-4.6369Z-0.3800 N8660G1X-8.9730Y-4.6116Z-0.3800 N8670G1X-9.0121Y-4.5825Z-0.3800 N8680G1X-9.0482Y-4.5500Z-0.3800 N8690G1X-9.0810Y-4.5141Z-0.3800 N8700G1X-9.1103Y-4.4752Z-0.3800 N8710G1X-9.1359Y-4.4334Z-0.3800 N8720G1X-9.1561Y-4.3918Z-0.3800 N8730G1X-9.1665Y-4.3657Z-0.3800 N8740G1X-9.1745Y-4.3420Z-0.3800 N8750G1X-9.1815Y-4.3178Z-0.3800 N8760G1X-9.1872Y-4.2931Z-0.3800 N8770G1X-9.1917Y-4.2681Z-0.3800 N8780G1X-9.1950Y-4.2426Z-0.3800 N8790G1X-9.1969Y-4.2169Z-0.3800 N8800G1X-9.1975Y-4.1943Z-0.3800 N8810G1X-9.1975Y4.1943Z-0.3800 N8820G1X-9.1969Y4.2169Z-0.3800 N8830G1X-9.1950Y4.2426Z-0.3800 N8840G1X-9.1917Y4.2681Z-0.3800 N8850G1X-9.1872Y4.2931Z-0.3800 N8860G00X-9.1872Y4.2931Z0.2000 N8870G00X-9.5781Y3.8326Z0.2000 N8880G1X-9.5781Y3.8326Z-0.4750F20.0 N8890G1X-9.1975Y4.1943Z-0.4750 N8900G1X-9.1969Y4.2169Z-0.4750 N8910G1X-9.1950Y4.2426Z-0.4750 N8920G1X-9.1917Y4.2681Z-0.4750 N8930G1X-9.1872Y4.2931Z-0.4750 N8940G1X-9.1815Y4.3178Z-0.4750 N8950G1X-9.1745Y4.3420Z-0.4750 N8960G1X-9.1665Y4.3657Z-0.4750 N8970G1X-9.1561Y4.3918Z-0.4750 N8980G1X-9.1359Y4.4334Z-0.4750 N8990G1X-9.1103Y4.4752Z-0.4750 N9000G1X-9.0810Y4.5141Z-0.4750 N9010G1X-9.0482Y4.5500Z-0.4750 N9020G1X-9.0121Y4.5825Z-0.4750 N9030G1X-8.9730Y4.6116Z-0.4750 N9040G1X-8.9311Y4.6369Z-0.4750 N9050G1X-8.8895Y4.6568Z-0.4750 N9060G1X-8.8635Y4.6670Z-0.4750 N9070G1X-8.8398Y4.6749Z-0.4750 N9080G1X-8.8156Y4.6817Z-0.4750 N9090G1X-8.7910Y4.6874Z-0.4750 N9100G1X-8.7660Y4.6918Z-0.4750 N9110G1X-8.7407Y4.6950Z-0.4750 N9120G1X-8.7151Y4.6969Z-0.4750 N9130G1X-8.6925Y4.6975Z-0.4750 N9140G1X8.6925Y4.6975Z-0.4750 N9150G1X8.7151Y4.6969Z-0.4750 N9160G1X8.7407Y4.6950Z-0.4750 N9170G1X8.7660Y4.6918Z-0.4750 N9180G1X8.7910Y4.6874Z-0.4750 N9190G1X8.8156Y4.6817Z-0.4750 N9200G1X8.8398Y4.6749Z-0.4750 N9210G1X8.8635Y4.6670Z-0.4750 N9220G1X8.8895Y4.6568Z-0.4750 N9230G1X8.9311Y4.6369Z-0.4750 N9240G1X8.9730Y4.6116Z-0.4750 N9250G1X9.0121Y4.5825Z-0.4750 N9260G1X9.0482Y4.5500Z-0.4750 N9270G1X9.0810Y4.5141Z-0.4750 N9280G1X9.1103Y4.4752Z-0.4750 N9290G1X9.1359Y4.4334Z-0.4750 N9300G1X9.1561Y4.3918Z-0.4750 N9310G1X9.1665Y4.3657Z-0.4750 N9320G1X9.1745Y4.3420Z-0.4750 N9330G1X9.1815Y4.3178Z-0.4750 N9340G1X9.1872Y4.2931Z-0.4750 N9350G1X9.1917Y4.2681Z-0.4750 N9360G1X9.1950Y4.2426Z-0.4750 N9370G1X9.1969Y4.2169Z-0.4750 N9380G1X9.1975Y4.1943Z-0.4750 N9390G1X9.1975Y-4.1943Z-0.4750 N9400G1X9.1969Y-4.2169Z-0.4750 N9410G1X9.1950Y-4.2426Z-0.4750 N9420G1X9.1917Y-4.2681Z-0.4750 N9430G1X9.1872Y-4.2931Z-0.4750 N9440G1X9.1815Y-4.3178Z-0.4750 N9450G1X9.1745Y-4.3420Z-0.4750 N9460G1X9.1665Y-4.3657Z-0.4750 N9470G1X9.1561Y-4.3918Z-0.4750 N9480G1X9.1359Y-4.4334Z-0.4750 N9490G1X9.1103Y-4.4752Z-0.4750 N9500G1X9.0810Y-4.5141Z-0.4750 N9510G1X9.0482Y-4.5500Z-0.4750 N9520G1X9.0121Y-4.5825Z-0.4750 N9530G1X8.9730Y-4.6116Z-0.4750 N9540G1X8.9311Y-4.6369Z-0.4750 N9550G1X8.8895Y-4.6568Z-0.4750 N9560G1X8.8635Y-4.6670Z-0.4750 N9570G1X8.8398Y-4.6749Z-0.4750 N9580G1X8.8156Y-4.6817Z-0.4750 N9590G1X8.7910Y-4.6874Z-0.4750 N9600G1X8.7660Y-4.6918Z-0.4750 N9610G1X8.7407Y-4.6950Z-0.4750 N9620G1X8.7151Y-4.6969Z-0.4750 N9630G1X8.6925Y-4.6975Z-0.4750 N9640G1X-8.6925Y-4.6975Z-0.4750 N9650G1X-8.7151Y-4.6969Z-0.4750 N9660G1X-8.7407Y-4.6950Z-0.4750 N9670G1X-8.7660Y-4.6918Z-0.4750 N9680G1X-8.7910Y-4.6874Z-0.4750 N9690G1X-8.8156Y-4.6817Z-0.4750 N9700G1X-8.8398Y-4.6749Z-0.4750 N9710G1X-8.8635Y-4.6670Z-0.4750 N9720G1X-8.8895Y-4.6568Z-0.4750 N9730G1X-8.9311Y-4.6369Z-0.4750 N9740G1X-8.9730Y-4.6116Z-0.4750 N9750G1X-9.0121Y-4.5825Z-0.4750 N9760G1X-9.0482Y-4.5500Z-0.4750 N9770G1X-9.0810Y-4.5141Z-0.4750 N9780G1X-9.1103Y-4.4752Z-0.4750 N9790G1X-9.1359Y-4.4334Z-0.4750 N9800G1X-9.1561Y-4.3918Z-0.4750 N9810G1X-9.1665Y-4.3657Z-0.4750 N9820G1X-9.1745Y-4.3420Z-0.4750 N9830G1X-9.1815Y-4.3178Z-0.4750 N9840G1X-9.1872Y-4.2931Z-0.4750 N9850G1X-9.1917Y-4.2681Z-0.4750 N9860G1X-9.1950Y-4.2426Z-0.4750 N9870G1X-9.1969Y-4.2169Z-0.4750 N9880G1X-9.1975Y-4.1943Z-0.4750 N9890G1X-9.1975Y4.1943Z-0.4750 N9900G1X-9.1969Y4.2169Z-0.4750 N9910G1X-9.1950Y4.2426Z-0.4750 N9920G1X-9.1917Y4.2681Z-0.4750 N9930G1X-9.1872Y4.2931Z-0.4750 N9940G00X-9.1872Y4.2931Z0.2000 N9950G00X-9.5781Y3.8326Z0.2000 N9960G1X-9.5781Y3.8326Z-0.5700F20.0 N9970G1X-9.1975Y4.1943Z-0.5700 N9980G1X-9.1969Y4.2169Z-0.5700 N9990G1X-9.1950Y4.2426Z-0.5700 N10000G1X-9.1917Y4.2681Z-0.5700 N10010G1X-9.1872Y4.2931Z-0.5700 N10020G1X-9.1815Y4.3178Z-0.5700 N10030G1X-9.1745Y4.3420Z-0.5700 N10040G1X-9.1665Y4.3657Z-0.5700 N10050G1X-9.1561Y4.3918Z-0.5700 N10060G1X-9.1359Y4.4334Z-0.5700 N10070G1X-9.1103Y4.4752Z-0.5700 N10080G1X-9.0810Y4.5141Z-0.5700 N10090G1X-9.0482Y4.5500Z-0.5700 N10100G1X-9.0121Y4.5825Z-0.5700 N10110G1X-8.9730Y4.6116Z-0.5700 N10120G1X-8.9311Y4.6369Z-0.5700 N10130G1X-8.8895Y4.6568Z-0.5700 N10140G1X-8.8635Y4.6670Z-0.5700 N10150G1X-8.8398Y4.6749Z-0.5700 N10160G1X-8.8156Y4.6817Z-0.5700 N10170G1X-8.7910Y4.6874Z-0.5700 N10180G1X-8.7660Y4.6918Z-0.5700 N10190G1X-8.7407Y4.6950Z-0.5700 N10200G1X-8.7151Y4.6969Z-0.5700 N10210G1X-8.6925Y4.6975Z-0.5700 N10220G1X8.6925Y4.6975Z-0.5700 N10230G1X8.7151Y4.6969Z-0.5700 N10240G1X8.7407Y4.6950Z-0.5700 N10250G1X8.7660Y4.6918Z-0.5700 N10260G1X8.7910Y4.6874Z-0.5700 N10270G1X8.8156Y4.6817Z-0.5700 N10280G1X8.8398Y4.6749Z-0.5700 N10290G1X8.8635Y4.6670Z-0.5700 N10300G1X8.8895Y4.6568Z-0.5700 N10310G1X8.9311Y4.6369Z-0.5700 N10320G1X8.9730Y4.6116Z-0.5700 N10330G1X9.0121Y4.5825Z-0.5700 N10340G1X9.0482Y4.5500Z-0.5700 N10350G1X9.0810Y4.5141Z-0.5700 N10360G1X9.1103Y4.4752Z-0.5700 N10370G1X9.1359Y4.4334Z-0.5700 N10380G1X9.1561Y4.3918Z-0.5700 N10390G1X9.1665Y4.3657Z-0.5700 N10400G1X9.1745Y4.3420Z-0.5700 N10410G1X9.1815Y4.3178Z-0.5700 N10420G1X9.1872Y4.2931Z-0.5700 N10430G1X9.1917Y4.2681Z-0.5700 N10440G1X9.1950Y4.2426Z-0.5700 N10450G1X9.1969Y4.2169Z-0.5700 N10460G1X9.1975Y4.1943Z-0.5700 N10470G1X9.1975Y-4.1943Z-0.5700 N10480G1X9.1969Y-4.2169Z-0.5700 N10490G1X9.1950Y-4.2426Z-0.5700 N10500G1X9.1917Y-4.2681Z-0.5700 N10510G1X9.1872Y-4.2931Z-0.5700 N10520G1X9.1815Y-4.3178Z-0.5700 N10530G1X9.1745Y-4.3420Z-0.5700 N10540G1X9.1665Y-4.3657Z-0.5700 N10550G1X9.1561Y-4.3918Z-0.5700 N10560G1X9.1359Y-4.4334Z-0.5700 N10570G1X9.1103Y-4.4752Z-0.5700 N10580G1X9.0810Y-4.5141Z-0.5700 N10590G1X9.0482Y-4.5500Z-0.5700 N10600G1X9.0121Y-4.5825Z-0.5700 N10610G1X8.9730Y-4.6116Z-0.5700 N10620G1X8.9311Y-4.6369Z-0.5700 N10630G1X8.8895Y-4.6568Z-0.5700 N10640G1X8.8635Y-4.6670Z-0.5700 N10650G1X8.8398Y-4.6749Z-0.5700 N10660G1X8.8156Y-4.6817Z-0.5700 N10670G1X8.7910Y-4.6874Z-0.5700 N10680G1X8.7660Y-4.6918Z-0.5700 N10690G1X8.7407Y-4.6950Z-0.5700 N10700G1X8.7151Y-4.6969Z-0.5700 N10710G1X8.6925Y-4.6975Z-0.5700 N10720G1X-8.6925Y-4.6975Z-0.5700 N10730G1X-8.7151Y-4.6969Z-0.5700 N10740G1X-8.7407Y-4.6950Z-0.5700 N10750G1X-8.7660Y-4.6918Z-0.5700 N10760G1X-8.7910Y-4.6874Z-0.5700 N10770G1X-8.8156Y-4.6817Z-0.5700 N10780G1X-8.8398Y-4.6749Z-0.5700 N10790G1X-8.8635Y-4.6670Z-0.5700 N10800G1X-8.8895Y-4.6568Z-0.5700 N10810G1X-8.9311Y-4.6369Z-0.5700 N10820G1X-8.9730Y-4.6116Z-0.5700 N10830G1X-9.0121Y-4.5825Z-0.5700 N10840G1X-9.0482Y-4.5500Z-0.5700 N10850G1X-9.0810Y-4.5141Z-0.5700 N10860G1X-9.1103Y-4.4752Z-0.5700 N10870G1X-9.1359Y-4.4334Z-0.5700 N10880G1X-9.1561Y-4.3918Z-0.5700 N10890G1X-9.1665Y-4.3657Z-0.5700 N10900G1X-9.1745Y-4.3420Z-0.5700 N10910G1X-9.1815Y-4.3178Z-0.5700 N10920G1X-9.1872Y-4.2931Z-0.5700 N10930G1X-9.1917Y-4.2681Z-0.5700 N10940G1X-9.1950Y-4.2426Z-0.5700 N10950G1X-9.1969Y-4.2169Z-0.5700 N10960G1X-9.1975Y-4.1943Z-0.5700 N10970G1X-9.1975Y4.1943Z-0.5700 N10980G1X-9.1969Y4.2169Z-0.5700 N10990G1X-9.1950Y4.2426Z-0.5700 N11000G1X-9.1917Y4.2681Z-0.5700 N11010G1X-9.1872Y4.2931Z-0.5700 N11020G00X-9.1872Y4.2931Z0.2000 N11030G00X-9.5781Y3.8326Z0.2000 N11040G1X-9.5781Y3.8326Z-0.6650F20.0 N11050G1X-9.1975Y4.1943Z-0.6650 N11060G1X-9.1969Y4.2169Z-0.6650 N11070G1X-9.1950Y4.2426Z-0.6650 N11080G1X-9.1917Y4.2681Z-0.6650 N11090G1X-9.1872Y4.2931Z-0.6650 N11100G1X-9.1815Y4.3178Z-0.6650 N11110G1X-9.1745Y4.3420Z-0.6650 N11120G1X-9.1665Y4.3657Z-0.6650 N11130G1X-9.1561Y4.3918Z-0.6650 N11140G1X-9.1359Y4.4334Z-0.6650 N11150G1X-9.1103Y4.4752Z-0.6650 N11160G1X-9.0810Y4.5141Z-0.6650 N11170G1X-9.0482Y4.5500Z-0.6650 N11180G1X-9.0121Y4.5825Z-0.6650 N11190G1X-8.9730Y4.6116Z-0.6650 N11200G1X-8.9311Y4.6369Z-0.6650 N11210G1X-8.8895Y4.6568Z-0.6650 N11220G1X-8.8635Y4.6670Z-0.6650 N11230G1X-8.8398Y4.6749Z-0.6650 N11240G1X-8.8156Y4.6817Z-0.6650 N11250G1X-8.7910Y4.6874Z-0.6650 N11260G1X-8.7660Y4.6918Z-0.6650 N11270G1X-8.7407Y4.6950Z-0.6650 N11280G1X-8.7151Y4.6969Z-0.6650 N11290G1X-8.6925Y4.6975Z-0.6650 N11300G1X8.6925Y4.6975Z-0.6650 N11310G1X8.7151Y4.6969Z-0.6650 N11320G1X8.7407Y4.6950Z-0.6650 N11330G1X8.7660Y4.6918Z-0.6650 N11340G1X8.7910Y4.6874Z-0.6650 N11350G1X8.8156Y4.6817Z-0.6650 N11360G1X8.8398Y4.6749Z-0.6650 N11370G1X8.8635Y4.6670Z-0.6650 N11380G1X8.8895Y4.6568Z-0.6650 N11390G1X8.9311Y4.6369Z-0.6650 N11400G1X8.9730Y4.6116Z-0.6650 N11410G1X9.0121Y4.5825Z-0.6650 N11420G1X9.0482Y4.5500Z-0.6650 N11430G1X9.0810Y4.5141Z-0.6650 N11440G1X9.1103Y4.4752Z-0.6650 N11450G1X9.1359Y4.4334Z-0.6650 N11460G1X9.1561Y4.3918Z-0.6650 N11470G1X9.1665Y4.3657Z-0.6650 N11480G1X9.1745Y4.3420Z-0.6650 N11490G1X9.1815Y4.3178Z-0.6650 N11500G1X9.1872Y4.2931Z-0.6650 N11510G1X9.1917Y4.2681Z-0.6650 N11520G1X9.1950Y4.2426Z-0.6650 N11530G1X9.1969Y4.2169Z-0.6650 N11540G1X9.1975Y4.1943Z-0.6650 N11550G1X9.1975Y-4.1943Z-0.6650 N11560G1X9.1969Y-4.2169Z-0.6650 N11570G1X9.1950Y-4.2426Z-0.6650 N11580G1X9.1917Y-4.2681Z-0.6650 N11590G1X9.1872Y-4.2931Z-0.6650 N11600G1X9.1815Y-4.3178Z-0.6650 N11610G1X9.1745Y-4.3420Z-0.6650 N11620G1X9.1665Y-4.3657Z-0.6650 N11630G1X9.1561Y-4.3918Z-0.6650 N11640G1X9.1359Y-4.4334Z-0.6650 N11650G1X9.1103Y-4.4752Z-0.6650 N11660G1X9.0810Y-4.5141Z-0.6650 N11670G1X9.0482Y-4.5500Z-0.6650 N11680G1X9.0121Y-4.5825Z-0.6650 N11690G1X8.9730Y-4.6116Z-0.6650 N11700G1X8.9311Y-4.6369Z-0.6650 N11710G1X8.8895Y-4.6568Z-0.6650 N11720G1X8.8635Y-4.6670Z-0.6650 N11730G1X8.8398Y-4.6749Z-0.6650 N11740G1X8.8156Y-4.6817Z-0.6650 N11750G1X8.7910Y-4.6874Z-0.6650 N11760G1X8.7660Y-4.6918Z-0.6650 N11770G1X8.7407Y-4.6950Z-0.6650 N11780G1X8.7151Y-4.6969Z-0.6650 N11790G1X8.6925Y-4.6975Z-0.6650 N11800G1X-8.6925Y-4.6975Z-0.6650 N11810G1X-8.7151Y-4.6969Z-0.6650 N11820G1X-8.7407Y-4.6950Z-0.6650 N11830G1X-8.7660Y-4.6918Z-0.6650 N11840G1X-8.7910Y-4.6874Z-0.6650 N11850G1X-8.8156Y-4.6817Z-0.6650 N11860G1X-8.8398Y-4.6749Z-0.6650 N11870G1X-8.8635Y-4.6670Z-0.6650 N11880G1X-8.8895Y-4.6568Z-0.6650 N11890G1X-8.9311Y-4.6369Z-0.6650 N11900G1X-8.9730Y-4.6116Z-0.6650 N11910G1X-9.0121Y-4.5825Z-0.6650 N11920G1X-9.0482Y-4.5500Z-0.6650 N11930G1X-9.0810Y-4.5141Z-0.6650 N11940G1X-9.1103Y-4.4752Z-0.6650 N11950G1X-9.1359Y-4.4334Z-0.6650 N11960G1X-9.1561Y-4.3918Z-0.6650 N11970G1X-9.1665Y-4.3657Z-0.6650 N11980G1X-9.1745Y-4.3420Z-0.6650 N11990G1X-9.1815Y-4.3178Z-0.6650 N12000G1X-9.1872Y-4.2931Z-0.6650 N12010G1X-9.1917Y-4.2681Z-0.6650 N12020G1X-9.1950Y-4.2426Z-0.6650 N12030G1X-9.1969Y-4.2169Z-0.6650 N12040G1X-9.1975Y-4.1943Z-0.6650 N12050G1X-9.1975Y4.1943Z-0.6650 N12060G1X-9.1969Y4.2169Z-0.6650 N12070G1X-9.1950Y4.2426Z-0.6650 N12080G1X-9.1917Y4.2681Z-0.6650 N12090G1X-9.1872Y4.2931Z-0.6650 N12100G00X-9.1872Y4.2931Z0.2000 N12110G00X-9.5781Y3.8326Z0.2000 N12120G1X-9.5781Y3.8326Z-0.7600F20.0 N12130G1X-9.1975Y4.1943Z-0.7600 N12140G1X-9.1969Y4.2169Z-0.7600 N12150G1X-9.1950Y4.2426Z-0.7600 N12160G1X-9.1917Y4.2681Z-0.7600 N12170G1X-9.1872Y4.2931Z-0.7600 N12180G1X-9.1815Y4.3178Z-0.7600 N12190G1X-9.1745Y4.3420Z-0.7600 N12200G1X-9.1665Y4.3657Z-0.7600 N12210G1X-9.1561Y4.3918Z-0.7600 N12220G1X-9.1359Y4.4334Z-0.7600 N12230G1X-9.1103Y4.4752Z-0.7600 N12240G1X-9.0810Y4.5141Z-0.7600 N12250G1X-9.0482Y4.5500Z-0.7600 N12260G1X-9.0121Y4.5825Z-0.7600 N12270G1X-8.9730Y4.6116Z-0.7600 N12280G1X-8.9311Y4.6369Z-0.7600 N12290G1X-8.8895Y4.6568Z-0.7600 N12300G1X-8.8635Y4.6670Z-0.7600 N12310G1X-8.8398Y4.6749Z-0.7600 N12320G1X-8.8156Y4.6817Z-0.7600 N12330G1X-8.7910Y4.6874Z-0.7600 N12340G1X-8.7660Y4.6918Z-0.7600 N12350G1X-8.7407Y4.6950Z-0.7600 N12360G1X-8.7151Y4.6969Z-0.7600 N12370G1X-8.6925Y4.6975Z-0.7600 N12380G1X8.6925Y4.6975Z-0.7600 N12390G1X8.7151Y4.6969Z-0.7600 N12400G1X8.7407Y4.6950Z-0.7600 N12410G1X8.7660Y4.6918Z-0.7600 N12420G1X8.7910Y4.6874Z-0.7600 N12430G1X8.8156Y4.6817Z-0.7600 N12440G1X8.8398Y4.6749Z-0.7600 N12450G1X8.8635Y4.6670Z-0.7600 N12460G1X8.8895Y4.6568Z-0.7600 N12470G1X8.9311Y4.6369Z-0.7600 N12480G1X8.9730Y4.6116Z-0.7600 N12490G1X9.0121Y4.5825Z-0.7600 N12500G1X9.0482Y4.5500Z-0.7600 N12510G1X9.0810Y4.5141Z-0.7600 N12520G1X9.1103Y4.4752Z-0.7600 N12530G1X9.1359Y4.4334Z-0.7600 N12540G1X9.1561Y4.3918Z-0.7600 N12550G1X9.1665Y4.3657Z-0.7600 N12560G1X9.1745Y4.3420Z-0.7600 N12570G1X9.1815Y4.3178Z-0.7600 N12580G1X9.1872Y4.2931Z-0.7600 N12590G1X9.1917Y4.2681Z-0.7600 N12600G1X9.1950Y4.2426Z-0.7600 N12610G1X9.1969Y4.2169Z-0.7600 N12620G1X9.1975Y4.1943Z-0.7600 N12630G1X9.1975Y-4.1943Z-0.7600 N12640G1X9.1969Y-4.2169Z-0.7600 N12650G1X9.1950Y-4.2426Z-0.7600 N12660G1X9.1917Y-4.2681Z-0.7600 N12670G1X9.1872Y-4.2931Z-0.7600 N12680G1X9.1815Y-4.3178Z-0.7600 N12690G1X9.1745Y-4.3420Z-0.7600 N12700G1X9.1665Y-4.3657Z-0.7600 N12710G1X9.1561Y-4.3918Z-0.7600 N12720G1X9.1359Y-4.4334Z-0.7600 N12730G1X9.1103Y-4.4752Z-0.7600 N12740G1X9.0810Y-4.5141Z-0.7600 N12750G1X9.0482Y-4.5500Z-0.7600 N12760G1X9.0121Y-4.5825Z-0.7600 N12770G1X8.9730Y-4.6116Z-0.7600 N12780G1X8.9311Y-4.6369Z-0.7600 N12790G1X8.8895Y-4.6568Z-0.7600 N12800G1X8.8635Y-4.6670Z-0.7600 N12810G1X8.8398Y-4.6749Z-0.7600 N12820G1X8.8156Y-4.6817Z-0.7600 N12830G1X8.7910Y-4.6874Z-0.7600 N12840G1X8.7660Y-4.6918Z-0.7600 N12850G1X8.7407Y-4.6950Z-0.7600 N12860G1X8.7151Y-4.6969Z-0.7600 N12870G1X8.6925Y-4.6975Z-0.7600 N12880G1X-8.6925Y-4.6975Z-0.7600 N12890G1X-8.7151Y-4.6969Z-0.7600 N12900G1X-8.7407Y-4.6950Z-0.7600 N12910G1X-8.7660Y-4.6918Z-0.7600 N12920G1X-8.7910Y-4.6874Z-0.7600 N12930G1X-8.8156Y-4.6817Z-0.7600 N12940G1X-8.8398Y-4.6749Z-0.7600 N12950G1X-8.8635Y-4.6670Z-0.7600 N12960G1X-8.8895Y-4.6568Z-0.7600 N12970G1X-8.9311Y-4.6369Z-0.7600 N12980G1X-8.9730Y-4.6116Z-0.7600 N12990G1X-9.0121Y-4.5825Z-0.7600 N13000G1X-9.0482Y-4.5500Z-0.7600 N13010G1X-9.0810Y-4.5141Z-0.7600 N13020G1X-9.1103Y-4.4752Z-0.7600 N13030G1X-9.1359Y-4.4334Z-0.7600 N13040G1X-9.1561Y-4.3918Z-0.7600 N13050G1X-9.1665Y-4.3657Z-0.7600 N13060G1X-9.1745Y-4.3420Z-0.7600 N13070G1X-9.1815Y-4.3178Z-0.7600 N13080G1X-9.1872Y-4.2931Z-0.7600 N13090G1X-9.1917Y-4.2681Z-0.7600 N13100G1X-9.1950Y-4.2426Z-0.7600 N13110G1X-9.1969Y-4.2169Z-0.7600 N13120G1X-9.1975Y-4.1943Z-0.7600 N13130G1X-9.1975Y4.1943Z-0.7600 N13140G1X-9.1969Y4.2169Z-0.7600 N13150G1X-9.1950Y4.2426Z-0.7600 N13160G1X-9.1917Y4.2681Z-0.7600 N13170G1X-9.1872Y4.2931Z-0.7600 N13180G00X-9.1872Y4.2931Z0.2000 N13190G00X-9.5781Y3.8326Z0.2000 N13200G1X-9.5781Y3.8326Z-0.8550F20.0 N13210G1X-9.1975Y4.1943Z-0.8550 N13220G1X-9.1969Y4.2169Z-0.8550 N13230G1X-9.1950Y4.2426Z-0.8550 N13240G1X-9.1917Y4.2681Z-0.8550 N13250G1X-9.1872Y4.2931Z-0.8550 N13260G1X-9.1815Y4.3178Z-0.8550 N13270G1X-9.1745Y4.3420Z-0.8550 N13280G1X-9.1665Y4.3657Z-0.8550 N13290G1X-9.1561Y4.3918Z-0.8550 N13300G1X-9.1359Y4.4334Z-0.8550 N13310G1X-9.1103Y4.4752Z-0.8550 N13320G1X-9.0810Y4.5141Z-0.8550 N13330G1X-9.0482Y4.5500Z-0.8550 N13340G1X-9.0121Y4.5825Z-0.8550 N13350G1X-8.9730Y4.6116Z-0.8550 N13360G1X-8.9311Y4.6369Z-0.8550 N13370G1X-8.8895Y4.6568Z-0.8550 N13380G1X-8.8635Y4.6670Z-0.8550 N13390G1X-8.8398Y4.6749Z-0.8550 N13400G1X-8.8156Y4.6817Z-0.8550 N13410G1X-8.7910Y4.6874Z-0.8550 N13420G1X-8.7660Y4.6918Z-0.8550 N13430G1X-8.7407Y4.6950Z-0.8550 N13440G1X-8.7151Y4.6969Z-0.8550 N13450G1X-8.6925Y4.6975Z-0.8550 N13460G1X8.6925Y4.6975Z-0.8550 N13470G1X8.7151Y4.6969Z-0.8550 N13480G1X8.7407Y4.6950Z-0.8550 N13490G1X8.7660Y4.6918Z-0.8550 N13500G1X8.7910Y4.6874Z-0.8550 N13510G1X8.8156Y4.6817Z-0.8550 N13520G1X8.8398Y4.6749Z-0.8550 N13530G1X8.8635Y4.6670Z-0.8550 N13540G1X8.8895Y4.6568Z-0.8550 N13550G1X8.9311Y4.6369Z-0.8550 N13560G1X8.9730Y4.6116Z-0.8550 N13570G1X9.0121Y4.5825Z-0.8550 N13580G1X9.0482Y4.5500Z-0.8550 N13590G1X9.0810Y4.5141Z-0.8550 N13600G1X9.1103Y4.4752Z-0.8550 N13610G1X9.1359Y4.4334Z-0.8550 N13620G1X9.1561Y4.3918Z-0.8550 N13630G1X9.1665Y4.3657Z-0.8550 N13640G1X9.1745Y4.3420Z-0.8550 N13650G1X9.1815Y4.3178Z-0.8550 N13660G1X9.1872Y4.2931Z-0.8550 N13670G1X9.1917Y4.2681Z-0.8550 N13680G1X9.1950Y4.2426Z-0.8550 N13690G1X9.1969Y4.2169Z-0.8550 N13700G1X9.1975Y4.1943Z-0.8550 N13710G1X9.1975Y-4.1943Z-0.8550 N13720G1X9.1969Y-4.2169Z-0.8550 N13730G1X9.1950Y-4.2426Z-0.8550 N13740G1X9.1917Y-4.2681Z-0.8550 N13750G1X9.1872Y-4.2931Z-0.8550 N13760G1X9.1815Y-4.3178Z-0.8550 N13770G1X9.1745Y-4.3420Z-0.8550 N13780G1X9.1665Y-4.3657Z-0.8550 N13790G1X9.1561Y-4.3918Z-0.8550 N13800G1X9.1359Y-4.4334Z-0.8550 N13810G1X9.1103Y-4.4752Z-0.8550 N13820G1X9.0810Y-4.5141Z-0.8550 N13830G1X9.0482Y-4.5500Z-0.8550 N13840G1X9.0121Y-4.5825Z-0.8550 N13850G1X8.9730Y-4.6116Z-0.8550 N13860G1X8.9311Y-4.6369Z-0.8550 N13870G1X8.8895Y-4.6568Z-0.8550 N13880G1X8.8635Y-4.6670Z-0.8550 N13890G1X8.8398Y-4.6749Z-0.8550 N13900G1X8.8156Y-4.6817Z-0.8550 N13910G1X8.7910Y-4.6874Z-0.8550 N13920G1X8.7660Y-4.6918Z-0.8550 N13930G1X8.7407Y-4.6950Z-0.8550 N13940G1X8.7151Y-4.6969Z-0.8550 N13950G1X8.6925Y-4.6975Z-0.8550 N13960G1X-8.6925Y-4.6975Z-0.8550 N13970G1X-8.7151Y-4.6969Z-0.8550 N13980G1X-8.7407Y-4.6950Z-0.8550 N13990G1X-8.7660Y-4.6918Z-0.8550 N14000G1X-8.7910Y-4.6874Z-0.8550 N14010G1X-8.8156Y-4.6817Z-0.8550 N14020G1X-8.8398Y-4.6749Z-0.8550 N14030G1X-8.8635Y-4.6670Z-0.8550 N14040G1X-8.8895Y-4.6568Z-0.8550 N14050G1X-8.9311Y-4.6369Z-0.8550 N14060G1X-8.9730Y-4.6116Z-0.8550 N14070G1X-9.0121Y-4.5825Z-0.8550 N14080G1X-9.0482Y-4.5500Z-0.8550 N14090G1X-9.0810Y-4.5141Z-0.8550 N14100G1X-9.1103Y-4.4752Z-0.8550 N14110G1X-9.1359Y-4.4334Z-0.8550 N14120G1X-9.1561Y-4.3918Z-0.8550 N14130G1X-9.1665Y-4.3657Z-0.8550 N14140G1X-9.1745Y-4.3420Z-0.8550 N14150G1X-9.1815Y-4.3178Z-0.8550 N14160G1X-9.1872Y-4.2931Z-0.8550 N14170G1X-9.1917Y-4.2681Z-0.8550 N14180G1X-9.1950Y-4.2426Z-0.8550 N14190G1X-9.1969Y-4.2169Z-0.8550 N14200G1X-9.1975Y-4.1943Z-0.8550 N14210G1X-9.1975Y4.1943Z-0.8550 N14220G1X-9.1969Y4.2169Z-0.8550 N14230G1X-9.1950Y4.2426Z-0.8550 N14240G1X-9.1917Y4.2681Z-0.8550 N14250G1X-9.1872Y4.2931Z-0.8550 N14260G00X-9.1872Y4.2931Z0.2000 N14270G00X-9.5781Y3.8326Z0.2000 N14280G1X-9.5781Y3.8326Z-0.9500F20.0 N14290G1X-9.1975Y4.1943Z-0.9500 N14300G1X-9.1969Y4.2169Z-0.9500 N14310G1X-9.1950Y4.2426Z-0.9500 N14320G1X-9.1917Y4.2681Z-0.9500 N14330G1X-9.1872Y4.2931Z-0.9500 N14340G1X-9.1815Y4.3178Z-0.9500 N14350G1X-9.1745Y4.3420Z-0.9500 N14360G1X-9.1665Y4.3657Z-0.9500 N14370G1X-9.1561Y4.3918Z-0.9500 N14380G1X-9.1359Y4.4334Z-0.9500 N14390G1X-9.1103Y4.4752Z-0.9500 N14400G1X-9.0810Y4.5141Z-0.9500 N14410G1X-9.0482Y4.5500Z-0.9500 N14420G1X-9.0121Y4.5825Z-0.9500 N14430G1X-8.9730Y4.6116Z-0.9500 N14440G1X-8.9311Y4.6369Z-0.9500 N14450G1X-8.8895Y4.6568Z-0.9500 N14460G1X-8.8635Y4.6670Z-0.9500 N14470G1X-8.8398Y4.6749Z-0.9500 N14480G1X-8.8156Y4.6817Z-0.9500 N14490G1X-8.7910Y4.6874Z-0.9500 N14500G1X-8.7660Y4.6918Z-0.9500 N14510G1X-8.7407Y4.6950Z-0.9500 N14520G1X-8.7151Y4.6969Z-0.9500 N14530G1X-8.6925Y4.6975Z-0.9500 N14540G1X8.6925Y4.6975Z-0.9500 N14550G1X8.7151Y4.6969Z-0.9500 N14560G1X8.7407Y4.6950Z-0.9500 N14570G1X8.7660Y4.6918Z-0.9500 N14580G1X8.7910Y4.6874Z-0.9500 N14590G1X8.8156Y4.6817Z-0.9500 N14600G1X8.8398Y4.6749Z-0.9500 N14610G1X8.8635Y4.6670Z-0.9500 N14620G1X8.8895Y4.6568Z-0.9500 N14630G1X8.9311Y4.6369Z-0.9500 N14640G1X8.9730Y4.6116Z-0.9500 N14650G1X9.0121Y4.5825Z-0.9500 N14660G1X9.0482Y4.5500Z-0.9500 N14670G1X9.0810Y4.5141Z-0.9500 N14680G1X9.1103Y4.4752Z-0.9500 N14690G1X9.1359Y4.4334Z-0.9500 N14700G1X9.1561Y4.3918Z-0.9500 N14710G1X9.1665Y4.3657Z-0.9500 N14720G1X9.1745Y4.3420Z-0.9500 N14730G1X9.1815Y4.3178Z-0.9500 N14740G1X9.1872Y4.2931Z-0.9500 N14750G1X9.1917Y4.2681Z-0.9500 N14760G1X9.1950Y4.2426Z-0.9500 N14770G1X9.1969Y4.2169Z-0.9500 N14780G1X9.1975Y4.1943Z-0.9500 N14790G1X9.1975Y-4.1943Z-0.9500 N14800G1X9.1969Y-4.2169Z-0.9500 N14810G1X9.1950Y-4.2426Z-0.9500 N14820G1X9.1917Y-4.2681Z-0.9500 N14830G1X9.1872Y-4.2931Z-0.9500 N14840G1X9.1815Y-4.3178Z-0.9500 N14850G1X9.1745Y-4.3420Z-0.9500 N14860G1X9.1665Y-4.3657Z-0.9500 N14870G1X9.1561Y-4.3918Z-0.9500 N14880G1X9.1359Y-4.4334Z-0.9500 N14890G1X9.1103Y-4.4752Z-0.9500 N14900G1X9.0810Y-4.5141Z-0.9500 N14910G1X9.0482Y-4.5500Z-0.9500 N14920G1X9.0121Y-4.5825Z-0.9500 N14930G1X8.9730Y-4.6116Z-0.9500 N14940G1X8.9311Y-4.6369Z-0.9500 N14950G1X8.8895Y-4.6568Z-0.9500 N14960G1X8.8635Y-4.6670Z-0.9500 N14970G1X8.8398Y-4.6749Z-0.9500 N14980G1X8.8156Y-4.6817Z-0.9500 N14990G1X8.7910Y-4.6874Z-0.9500 N15000G1X8.7660Y-4.6918Z-0.9500 N15010G1X8.7407Y-4.6950Z-0.9500 N15020G1X8.7151Y-4.6969Z-0.9500 N15030G1X8.6925Y-4.6975Z-0.9500 N15040G1X-8.6925Y-4.6975Z-0.9500 N15050G1X-8.7151Y-4.6969Z-0.9500 N15060G1X-8.7407Y-4.6950Z-0.9500 N15070G1X-8.7660Y-4.6918Z-0.9500 N15080G1X-8.7910Y-4.6874Z-0.9500 N15090G1X-8.8156Y-4.6817Z-0.9500 N15100G1X-8.8398Y-4.6749Z-0.9500 N15110G1X-8.8635Y-4.6670Z-0.9500 N15120G1X-8.8895Y-4.6568Z-0.9500 N15130G1X-8.9311Y-4.6369Z-0.9500 N15140G1X-8.9730Y-4.6116Z-0.9500 N15150G1X-9.0121Y-4.5825Z-0.9500 N15160G1X-9.0482Y-4.5500Z-0.9500 N15170G1X-9.0810Y-4.5141Z-0.9500 N15180G1X-9.1103Y-4.4752Z-0.9500 N15190G1X-9.1359Y-4.4334Z-0.9500 N15200G1X-9.1561Y-4.3918Z-0.9500 N15210G1X-9.1665Y-4.3657Z-0.9500 N15220G1X-9.1745Y-4.3420Z-0.9500 N15230G1X-9.1815Y-4.3178Z-0.9500 N15240G1X-9.1872Y-4.2931Z-0.9500 N15250G1X-9.1917Y-4.2681Z-0.9500 N15260G1X-9.1950Y-4.2426Z-0.9500 N15270G1X-9.1969Y-4.2169Z-0.9500 N15280G1X-9.1975Y-4.1943Z-0.9500 N15290G1X-9.1975Y4.1943Z-0.9500 N15300G1X-9.1969Y4.2169Z-0.9500 N15310G1X-9.1950Y4.2426Z-0.9500 N15320G1X-9.1917Y4.2681Z-0.9500 N15330G1X-9.1872Y4.2931Z-0.9500 N15340G00X-9.1872Y4.2931Z0.2000 N15350S5000M03 (TRIM OUTSIDE [2]) () N15380G00X-9.5681Y3.8325Z0.2000 N15390G1X-9.5681Y3.8325Z-0.9500F20.0 N15400G1X-9.1875Y4.1942Z-0.9500 N15410G1X-9.1869Y4.2164Z-0.9500 N15420G1X-9.1850Y4.2416Z-0.9500 N15430G1X-9.1818Y4.2665Z-0.9500 N15440G1X-9.1774Y4.2911Z-0.9500 N15450G1X-9.1718Y4.3153Z-0.9500 N15460G1X-9.1650Y4.3390Z-0.9500 N15470G1X-9.1571Y4.3622Z-0.9500 N15480G1X-9.1469Y4.3878Z-0.9500 N15490G1X-9.1271Y4.4286Z-0.9500 N15500G1X-9.1021Y4.4696Z-0.9500 N15510G1X-9.0733Y4.5077Z-0.9500 N15520G1X-9.0411Y4.5429Z-0.9500 N15530G1X-9.0058Y4.5748Z-0.9500 N15540G1X-8.9675Y4.6033Z-0.9500 N15550G1X-8.9264Y4.6281Z-0.9500 N15560G1X-8.8855Y4.6476Z-0.9500 N15570G1X-8.8600Y4.6576Z-0.9500 N15580G1X-8.8368Y4.6654Z-0.9500 N15590G1X-8.8132Y4.6720Z-0.9500 N15600G1X-8.7891Y4.6776Z-0.9500 N15610G1X-8.7645Y4.6819Z-0.9500 N15620G1X-8.7397Y4.6850Z-0.9500 N15630G1X-8.7146Y4.6869Z-0.9500 N15640G1X-8.6924Y4.6875Z-0.9500 N15650G1X8.6924Y4.6875Z-0.9500 N15660G1X8.7146Y4.6869Z-0.9500 N15670G1X8.7397Y4.6850Z-0.9500 N15680G1X8.7645Y4.6819Z-0.9500 N15690G1X8.7891Y4.6776Z-0.9500 N15700G1X8.8132Y4.6720Z-0.9500 N15710G1X8.8368Y4.6654Z-0.9500 N15720G1X8.8600Y4.6576Z-0.9500 N15730G1X8.8855Y4.6476Z-0.9500 N15740G1X8.9264Y4.6281Z-0.9500 N15750G1X8.9675Y4.6033Z-0.9500 N15760G1X9.0058Y4.5748Z-0.9500 N15770G1X9.0411Y4.5429Z-0.9500 N15780G1X9.0733Y4.5077Z-0.9500 N15790G1X9.1021Y4.4696Z-0.9500 N15800G1X9.1271Y4.4286Z-0.9500 N15810G1X9.1469Y4.3878Z-0.9500 N15820G1X9.1571Y4.3622Z-0.9500 N15830G1X9.1650Y4.3390Z-0.9500 N15840G1X9.1718Y4.3153Z-0.9500 N15850G1X9.1774Y4.2911Z-0.9500 N15860G1X9.1818Y4.2665Z-0.9500 N15870G1X9.1850Y4.2416Z-0.9500 N15880G1X9.1869Y4.2164Z-0.9500 N15890G1X9.1875Y4.1942Z-0.9500 N15900G1X9.1875Y-4.1942Z-0.9500 N15910G1X9.1869Y-4.2164Z-0.9500 N15920G1X9.1850Y-4.2416Z-0.9500 N15930G1X9.1818Y-4.2665Z-0.9500 N15940G1X9.1774Y-4.2911Z-0.9500 N15950G1X9.1718Y-4.3153Z-0.9500 N15960G1X9.1650Y-4.3390Z-0.9500 N15970G1X9.1571Y-4.3622Z-0.9500 N15980G1X9.1469Y-4.3878Z-0.9500 N15990G1X9.1271Y-4.4286Z-0.9500 N16000G1X9.1021Y-4.4696Z-0.9500 N16010G1X9.0733Y-4.5077Z-0.9500 N16020G1X9.0411Y-4.5429Z-0.9500 N16030G1X9.0058Y-4.5748Z-0.9500 N16040G1X8.9675Y-4.6033Z-0.9500 N16050G1X8.9264Y-4.6281Z-0.9500 N16060G1X8.8855Y-4.6476Z-0.9500 N16070G1X8.8600Y-4.6576Z-0.9500 N16080G1X8.8368Y-4.6654Z-0.9500 N16090G1X8.8132Y-4.6720Z-0.9500 N16100G1X8.7891Y-4.6776Z-0.9500 N16110G1X8.7645Y-4.6819Z-0.9500 N16120G1X8.7397Y-4.6850Z-0.9500 N16130G1X8.7146Y-4.6869Z-0.9500 N16140G1X8.6924Y-4.6875Z-0.9500 N16150G1X-8.6924Y-4.6875Z-0.9500 N16160G1X-8.7146Y-4.6869Z-0.9500 N16170G1X-8.7397Y-4.6850Z-0.9500 N16180G1X-8.7645Y-4.6819Z-0.9500 N16190G1X-8.7891Y-4.6776Z-0.9500 N16200G1X-8.8132Y-4.6720Z-0.9500 N16210G1X-8.8368Y-4.6654Z-0.9500 N16220G1X-8.8600Y-4.6576Z-0.9500 N16230G1X-8.8855Y-4.6476Z-0.9500 N16240G1X-8.9264Y-4.6281Z-0.9500 N16250G1X-8.9675Y-4.6033Z-0.9500 N16260G1X-9.0058Y-4.5748Z-0.9500 N16270G1X-9.0411Y-4.5429Z-0.9500 N16280G1X-9.0733Y-4.5077Z-0.9500 N16290G1X-9.1021Y-4.4696Z-0.9500 N16300G1X-9.1271Y-4.4286Z-0.9500 N16310G1X-9.1469Y-4.3878Z-0.9500 N16320G1X-9.1571Y-4.3622Z-0.9500 N16330G1X-9.1650Y-4.3390Z-0.9500 N16340G1X-9.1718Y-4.3153Z-0.9500 N16350G1X-9.1774Y-4.2911Z-0.9500 N16360G1X-9.1818Y-4.2665Z-0.9500 N16370G1X-9.1850Y-4.2416Z-0.9500 N16380G1X-9.1869Y-4.2164Z-0.9500 N16390G1X-9.1875Y-4.1942Z-0.9500 N16400G1X-9.1875Y4.1942Z-0.9500 N16410G1X-9.1869Y4.2164Z-0.9500 N16420G1X-9.1850Y4.2416Z-0.9500 N16430G1X-9.1818Y4.2665Z-0.9500 N16440G1X-9.1774Y4.2911Z-0.9500 N16450G00X-9.1774Y4.2911Z0.2000 N16460G00Z0.5000 N16470G00X0.0000Y0.0000 N16480M09 N16490M30 %
