Const cdoSendUsingPickup = 1 'Send message using the local SMTP service pickup directory. Const cdoSendUsingPort = 2 'Send the message using the network (SMTP over the network). Const cdoAnonymous = 0 'Do not authenticate Const cdoBasic = 1 'basic (clear-text) authentication Const cdoNTLM = 2 'NTLM Set objMessage = CreateObject("CDO.Message") objMessage.Subject = "Example CDO Message" objMessage.From = """Me"" " objMessage.To = "xxxxxxxx@xxxxx.com" *******************Insert Your Email address objMessage.TextBody = "This is some sample message text.." & vbCRLF & "It was sent using SMTP authentication." '==This section provides the configuration information for the remote SMTP server. objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2 'Name or IP of Remote SMTP Server objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "smtp.embarqmail.com" 'Type of authentication, NONE, Basic (Base64 encoded), NTLM objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic 'Your UserID on the SMTP server objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/sendusername") = "XXXXXXXXX@XXXXX.com" 'Your password on the SMTP server objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "xxxxxx" ***PASSWORD 'Server port (typically 25) objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25 'Use SSL for the connection (False or True) objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = False 'Connection Timeout in seconds (the maximum time CDO will try to establish a connection to the SMTP server) objMessage.Configuration.Fields.Item _ ("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 60 objMessage.Configuration.Fields.Update '==End remote SMTP server configuration section== objMessage.Send end
