% O10 (V-Bit 5/8 Inch 45 degree) (CREATED BY Ya-Nvr-No) (Miscelaneous Information ) ( ToolpathName :V-Bit 5/8 Inch 45 degree) ( Comment :Machine Relief) ( PathName :C:\Users\Public\Documents\ArtCAM Files\Toolpaths\jr.txt) ( FileName :jr) ( FileExtension :.txt) (MATERIAL:) ( Min Position X: X0.0000 Y: Y0.0000 Z: Z-0.0600) ( Max Position X: X2.5000 Y: Y2.0000 Z: Z0.0000) ( Sizes X: X2.5000 Y: Y2.0000 Z: Z0.0600) ( Material Thickness: Material Thickness 0.2500) (FEED RATES IN INCHES PER MINUTE) ( CUTTING FEED RATE:60) ( PLUNGE FEED RATE :20) ( RAPID FEED RATE :9999) ( SPINDLE SPEED :S7000 r.p.m) (FIRST TOOL INFORMATION) ( TOOL NUMBER:1) ( DESCRIPTION) ( Machine Relief) ( 22.5 deg. conical with 0.000 inches tip rad.) N310 M07 (VACUUM ON) N320 M05 N330 T1 M06 N340 S7000 M03 (H DX= X2.5000 DY= Y2.0000 DZ= Material Thickness 0.2500 -AB C=0 T=0 R=1 *MM /"DEF" BX=0 BY=350 BZ=0) (C=0) (G0 X=0 Y=0 Z1.0000 S7000 T=1) N380 G00 X0.3805 Y0.2137 Z0.1000 N390 G01 Z0.0000 F20.0 N400 G01 X0.3816 Z-0.0000 F60.0 N410 X2.1867 N420 X2.1878 Z0.0000 N430 Y0.2187 N440 X2.1867 Z-0.0013 N450 X2.1834 Z-0.0070 N460 X2.1823 Z-0.0081 N470 X2.0370 Z-0.0081 N480 X1.8928 Z-0.0081 N490 X1.7574 Z-0.0081 N500 X1.6330 Z-0.0081 N510 X1.5406 Z-0.0081 N520 X1.3293 Z-0.0081 N530 X1.2269 Z-0.0081 N540 X1.1047 Z-0.0081 N550 X0.9550 Z-0.0081 N560 X0.7944 Z-0.0081 N570 X0.6953 Z-0.0081 N580 X0.6083 Z-0.0081 N590 X0.5258 Z-0.0081 N600 X0.3981 Z-0.0081 N610 X0.3860 Z-0.0081 N620 X0.3849 Z-0.0070 N630 X0.3816 Z-0.0013 N640 X0.3805 Z0.0000 N650 Y0.2237 Z-0.0000 N660 X0.3816 Z-0.0013 N670 X0.3893 Z-0.0147 N680 X0.3904 Z-0.0164 N690 X0.4058 Z-0.0164 N700 X0.5247 Z-0.0164 N710 X0.5885 Z-0.0164 N720 X0.6601 Z-0.0164 N730 X0.7899 Z-0.0164 N740 X0.9319 Z-0.0164 N750 X1.0684 Z-0.0164 N760 X1.2038 Z-0.0164 N770 X1.3271 Z-0.0164 N780 X1.4646 Z-0.0164 N790 X1.6011 Z-0.0164 N800 X1.7255 Z-0.0164 N810 X2.1305 Z-0.0164 N820 X2.1757 Z-0.0164 N830 X2.1779 Z-0.0164 N840 X2.1790 Z-0.0147 N850 X2.1867 Z-0.0013 N860 X2.1878 Z-0.0000 N870 Y0.2286 Z-0.0000 N880 X2.1867 Z-0.0013 N890 X2.1735 Z-0.0242 N900 X2.1724 Z-0.0255 N910 X2.0590 Z-0.0255 N920 X1.9401 Z-0.0255 N930 X1.8114 Z-0.0255 N940 X1.6760 Z-0.0255 N950 X1.5285 Z-0.0255 N960 X1.4129 Z-0.0255 N970 X1.3183 Z-0.0255 N980 X1.1961 Z-0.0255 N990 X1.0794 Z-0.0255 N1000 X0.9650 Z-0.0255 N1010 X0.8560 Z-0.0255 N1020 X0.7195 Z-0.0255 N1030 X0.5940 Z-0.0255 N1040 X0.4664 Z-0.0255 N1050 X0.3992 Z-0.0255 N1060 X0.3959 Z-0.0255 N1070 X0.3948 Z-0.0242 N1080 X0.3816 Z-0.0013 N1090 X0.3805 Z-0.0000 N1100 Y0.2336 Z-0.0000 N1110 X0.3816 Z-0.0013 N1120 X0.4003 Z-0.0337 N1130 X0.4025 Z-0.0338 N1140 X0.4994 Z-0.0338 N1150 X0.6006 Z-0.0338 N1160 X0.6788 Z-0.0338 N1170 X0.7899 Z-0.0338 N1180 X0.9143 Z-0.0338 N1190 X1.0420 Z-0.0338 N1200 X1.1664 Z-0.0338 N1210 X1.3172 Z-0.0338 N1220 X1.4327 Z-0.0338 N1230 X1.5549 Z-0.0338 N1240 X1.6815 Z-0.0338 N1250 X1.7838 Z-0.0338 N1260 X1.9016 Z-0.0338 N1270 X2.0359 Z-0.0338 N1280 X2.1338 Z-0.0338 N1290 X2.1669 Z-0.0338 N1300 X2.1680 Z-0.0337 N1310 X2.1867 Z-0.0013 N1320 X2.1878 Z-0.0000 N1330 Y0.2386 Z-0.0000 N1340 X2.1867 Z-0.0013 N1350 X2.1636 Z-0.0413 N1360 X2.1625 Z-0.0428 N1370 X2.0447 Z-0.0428 N1380 X1.9214 Z-0.0428 N1390 X1.8025 Z-0.0428 N1400 X1.6507 Z-0.0428 N1410 X1.5021 Z-0.0428 N1420 X1.3557 Z-0.0428 N1430 X1.3183 Z-0.0428 N1440 X1.2060 Z-0.0428 N1450 X1.0893 Z-0.0428 N1460 X0.9528 Z-0.0428 N1470 X0.8571 Z-0.0428 N1480 X0.7437 Z-0.0428 N1490 X0.6546 Z-0.0428 N1500 X0.5379 Z-0.0428 N1510 X0.4245 Z-0.0428 N1520 X0.4058 Z-0.0428 N1530 X0.4047 Z-0.0413 N1540 X0.3816 Z-0.0013 N1550 X0.3805 Z-0.0000 N1560 Y0.2436 Z-0.0000 N1570 X0.3816 Z-0.0013 N1580 X0.4102 Z-0.0509 N1590 X0.4113 Z-0.0511 N1600 X0.5192 Z-0.0511 N1610 X0.6083 Z-0.0511 N1620 X0.7030 Z-0.0511 N1630 X0.7888 Z-0.0511 N1640 X0.8395 Z-0.0511 N1650 X0.9617 Z-0.0511 N1660 X1.1356 Z-0.0511 N1670 X1.2885 Z-0.0511 N1680 X1.3172 Z-0.0511 N1690 X1.4162 Z-0.0511 N1700 X1.5461 Z-0.0511 N1710 X1.7178 Z-0.0511 N1720 X1.7794 Z-0.0511 N1730 X1.9203 Z-0.0511 N1740 X2.0414 Z-0.0511 N1750 X2.1305 Z-0.0511 N1760 X2.1570 Z-0.0511 N1770 X2.1581 Z-0.0509 N1780 X2.1867 Z-0.0013 N1790 X2.1878 Z-0.0000 N1800 Y0.2486 Z-0.0000 N1810 X2.1867 Z-0.0013 N1820 X2.1537 Z-0.0585 N1830 X2.1526 Z-0.0598 N1840 X2.1493 Z-0.0566 N1850 X2.1460 Z-0.0538 N1860 X2.1426 Z-0.0514 N1870 X2.1404 Z-0.0500 N1880 X2.1382 Z-0.0490 N1890 X2.1360 Z-0.0482 N1900 X2.1338 Z-0.0477 N1910 X2.1316 Z-0.0475 N1920 X2.0095 Z-0.0475 N1930 X1.8917 Z-0.0475 N1940 X1.8047 Z-0.0475 N1950 X1.8025 Z-0.0477 N1960 X1.8003 Z-0.0481 N1970 X1.7970 Z-0.0492 N1980 X1.7948 Z-0.0502 N1990 X1.7926 Z-0.0515 N2000 X1.7904 Z-0.0531 N2010 X1.7871 Z-0.0558 N2020 X1.7827 Z-0.0600 N2030 X1.6639 N2040 X1.5406 N2050 X1.4107 N2060 X1.3392 N2070 X1.3381 Z-0.0591 N2080 X1.3348 Z-0.0558 N2090 X1.3315 Z-0.0530 N2100 X1.3293 Z-0.0515 N2110 X1.3271 Z-0.0501 N2120 X1.3249 Z-0.0490 N2130 X1.3227 Z-0.0482 N2140 X1.3205 Z-0.0477 N2150 X1.3183 Z-0.0475 N2160 X1.2049 Z-0.0475 N2170 X1.0915 Z-0.0475 N2180 X0.8571 Z-0.0475 N2190 X0.8560 Z-0.0476 N2200 X0.8538 Z-0.0479 N2210 X0.8516 Z-0.0485 N2220 X0.8494 Z-0.0494 N2230 X0.8472 Z-0.0506 N2240 X0.8450 Z-0.0520 N2250 X0.8417 Z-0.0546 N2260 X0.8384 Z-0.0577 N2270 X0.8362 Z-0.0600 N2280 X0.8197 Z-0.0600 N2290 X0.7019 N2300 X0.5709 N2310 X0.4377 N2320 X0.4157 N2330 X0.4146 Z-0.0585 N2340 X0.3816 Z-0.0013 N2350 X0.3805 Z-0.0000 N2360 Y0.2536 Z-0.0000 N2370 X0.3816 Z-0.0013 N2380 X0.4146 Z-0.0585 N2390 X0.4157 Z-0.0600 N2400 X0.8307 N2410 X0.8318 Z-0.0589 N2420 X0.8351 Z-0.0548 N2430 X0.8384 Z-0.0510 N2440 X0.8417 Z-0.0475 N2450 X0.8450 Z-0.0445 N2460 X0.8472 Z-0.0429 N2470 X0.8494 Z-0.0415 N2480 X0.8516 Z-0.0404 N2490 X0.8538 Z-0.0397 N2500 X0.8549 Z-0.0394 N2510 X0.8560 Z-0.0393 N2520 X0.8593 Z-0.0392 N2530 X0.9716 Z-0.0392 N2540 X1.1168 Z-0.0392 N2550 X1.2368 Z-0.0392 N2560 X1.3172 Z-0.0392 N2570 X1.3194 Z-0.0393 N2580 X1.3216 Z-0.0397 N2590 X1.3238 Z-0.0405 N2600 X1.3260 Z-0.0416 N2610 X1.3282 Z-0.0430 N2620 X1.3304 Z-0.0447 N2630 X1.3326 Z-0.0467 N2640 X1.3359 Z-0.0500 N2650 X1.3392 Z-0.0538 N2660 X1.3425 Z-0.0578 N2670 X1.3436 Z-0.0593 N2680 X1.3447 Z-0.0600 N2690 X1.7772 N2700 X1.7783 Z-0.0595 N2710 X1.7827 Z-0.0540 N2720 X1.7860 Z-0.0502 N2730 X1.7893 Z-0.0468 N2740 X1.7915 Z-0.0448 N2750 X1.7937 Z-0.0431 N2760 X1.7959 Z-0.0416 N2770 X1.7981 Z-0.0405 N2780 X1.7992 Z-0.0401 N2790 X1.8003 Z-0.0398 N2800 X1.8014 Z-0.0395 N2810 X1.8036 Z-0.0392 N2820 X1.9159 Z-0.0392 N2830 X2.0535 Z-0.0392 N2840 X2.1305 Z-0.0392 N2850 X2.1327 Z-0.0393 N2860 X2.1338 Z-0.0394 N2870 X2.1349 Z-0.0397 N2880 X2.1371 Z-0.0404 N2890 X2.1393 Z-0.0415 N2900 X2.1415 Z-0.0428 N2910 X2.1437 Z-0.0444 N2920 X2.1460 Z-0.0463 N2930 X2.1493 Z-0.0496 N2940 X2.1526 Z-0.0533 N2950 X2.1548 Z-0.0560 N2960 X2.1559 Z-0.0547 N2970 X2.1867 Z-0.0013 N2980 X2.1878 Z-0.0000 N2990 Y0.2586 Z-0.0000 N3000 X2.1867 Z-0.0013 N3010 X2.1570 Z-0.0528 N3020 X2.1559 Z-0.0516 N3030 X2.1515 Z-0.0457 N3040 X2.1482 Z-0.0416 N3050 X2.1449 Z-0.0380 N3060 X2.1415 Z-0.0349 N3070 X2.1393 Z-0.0332 N3080 X2.1382 Z-0.0324 N3090 X2.1360 Z-0.0312 N3100 X2.1349 Z-0.0308 N3110 X2.1338 Z-0.0304 N3120 X2.1327 Z-0.0302 N3130 X2.1316 Z-0.0302 N3140 X2.0106 Z-0.0302 N3150 X1.8752 Z-0.0302 N3160 X1.8047 Z-0.0302 N3170 X1.8036 Z-0.0302 N3180 X1.8025 Z-0.0304 N3190 X1.8014 Z-0.0307 N3200 X1.7992 Z-0.0315 N3210 X1.7981 Z-0.0320 N3220 X1.7970 Z-0.0327 N3230 X1.7948 Z-0.0342 N3240 X1.7926 Z-0.0361 N3250 X1.7904 Z-0.0383 N3260 X1.7871 Z-0.0420 N3270 X1.7827 Z-0.0476 N3280 X1.7739 Z-0.0592 N3290 X1.7728 Z-0.0600 N3300 X1.3480 N3310 X1.3469 Z-0.0587 N3320 X1.3414 Z-0.0508 N3330 X1.3370 Z-0.0449 N3340 X1.3337 Z-0.0408 N3350 X1.3304 Z-0.0371 N3360 X1.3282 Z-0.0350 N3370 X1.3260 Z-0.0332 N3380 X1.3238 Z-0.0318 N3390 X1.3227 Z-0.0313 N3400 X1.3216 Z-0.0308 N3410 X1.3205 Z-0.0305 N3420 X1.3194 Z-0.0303 N3430 X1.3183 Z-0.0302 N3440 X1.2027 Z-0.0302 N3450 X1.0717 Z-0.0302 N3460 X0.9484 Z-0.0302 N3470 X0.8571 Z-0.0302 N3480 X0.8560 Z-0.0302 N3490 X0.8549 Z-0.0304 N3500 X0.8538 Z-0.0307 N3510 X0.8527 Z-0.0312 N3520 X0.8516 Z-0.0317 N3530 X0.8505 Z-0.0323 N3540 X0.8483 Z-0.0339 N3550 X0.8461 Z-0.0358 N3560 X0.8439 Z-0.0380 N3570 X0.8406 Z-0.0418 N3580 X0.8362 Z-0.0474 N3590 X0.8307 Z-0.0551 N3600 X0.8274 Z-0.0599 N3610 X0.8252 Z-0.0600 N3620 X0.7118 N3630 X0.5918 N3640 X0.4642 N3650 X0.4157 N3660 X0.4146 Z-0.0585 N3670 X0.3816 Z-0.0013 N3680 X0.3805 Z-0.0000 N3690 Y0.2636 Z-0.0000 N3700 X0.3816 Z-0.0013 N3710 X0.4146 Z-0.0585 N3720 X0.4157 Z-0.0600 N3730 X0.8241 N3740 X0.8252 Z-0.0597 N3750 X0.8318 Z-0.0492 N3760 X0.8373 Z-0.0409 N3770 X0.8417 Z-0.0347 N3780 X0.8450 Z-0.0305 N3790 X0.8472 Z-0.0280 N3800 X0.8494 Z-0.0259 N3810 X0.8516 Z-0.0240 N3820 X0.8527 Z-0.0233 N3830 X0.8538 Z-0.0227 N3840 X0.8549 Z-0.0222 N3850 X0.8560 Z-0.0220 N3860 X0.8571 Z-0.0219 N3870 X1.0299 Z-0.0219 N3880 X1.1653 Z-0.0219 N3890 X1.2973 Z-0.0219 N3900 X1.3183 Z-0.0219 N3910 X1.3194 Z-0.0220 N3920 X1.3205 Z-0.0223 N3930 X1.3216 Z-0.0228 N3940 X1.3227 Z-0.0235 N3950 X1.3249 Z-0.0251 N3960 X1.3271 Z-0.0271 N3970 X1.3293 Z-0.0295 N3980 X1.3315 Z-0.0322 N3990 X1.3348 Z-0.0366 N4000 X1.3392 Z-0.0429 N4010 X1.3458 Z-0.0530 N4020 X1.3502 Z-0.0600 N4030 X1.4768 N4040 X1.6088 N4050 X1.7376 N4060 X1.7684 N4070 X1.7695 Z-0.0599 N4080 X1.7893 Z-0.0337 N4090 X1.7926 Z-0.0295 N4100 X1.7948 Z-0.0271 N4110 X1.7959 Z-0.0260 N4120 X1.7970 Z-0.0250 N4130 X1.7981 Z-0.0241 N4140 X1.7992 Z-0.0234 N4150 X1.8003 Z-0.0228 N4160 X1.8014 Z-0.0224 N4170 X1.8025 Z-0.0221 N4180 X1.8036 Z-0.0219 N4190 X1.8058 Z-0.0219 N4200 X1.9181 Z-0.0219 N4210 X2.0579 Z-0.0219 N4220 X2.1305 Z-0.0219 N4230 X2.1316 Z-0.0219 N4240 X2.1327 Z-0.0220 N4250 X2.1338 Z-0.0223 N4260 X2.1360 Z-0.0233 N4270 X2.1371 Z-0.0239 N4280 X2.1382 Z-0.0247 N4290 X2.1393 Z-0.0255 N4300 X2.1415 Z-0.0277 N4310 X2.1437 Z-0.0302 N4320 X2.1471 Z-0.0344 N4330 X2.1515 Z-0.0407 N4340 X2.1581 Z-0.0507 N4350 X2.1614 Z-0.0452 N4360 X2.1867 Z-0.0013 N4370 X2.1878 Z0.0000 N4380 Y0.2686 Z-0.0000 N4390 X2.1867 Z-0.0013 N4400 X2.1592 Z-0.0490 N4410 X2.1581 Z-0.0473 N4420 X2.1504 Z-0.0347 N4430 X2.1449 Z-0.0261 N4440 X2.1415 Z-0.0214 N4450 X2.1393 Z-0.0186 N4460 X2.1371 Z-0.0162 N4470 X2.1360 Z-0.0151 N4480 X2.1349 Z-0.0142 N4490 X2.1338 Z-0.0135 N4500 X2.1327 Z-0.0130 N4510 X2.1316 Z-0.0128 N4520 X2.0139 Z-0.0128 N4530 X1.8752 Z-0.0128 N4540 X1.8047 N4550 X1.8036 Z-0.0129 N4560 X1.8025 Z-0.0133 N4570 X1.8014 Z-0.0139 N4580 X1.8003 Z-0.0145 N4590 X1.7992 Z-0.0154 N4600 X1.7981 Z-0.0165 N4610 X1.7959 Z-0.0190 N4620 X1.7651 Z-0.0597 N4630 X1.7640 Z-0.0600 N4640 X1.3524 N4650 X1.3513 Z-0.0594 N4660 X1.3414 Z-0.0428 N4670 X1.3337 Z-0.0303 N4680 X1.3293 Z-0.0236 N4690 X1.3260 Z-0.0190 N4700 X1.3238 Z-0.0164 N4710 X1.3227 Z-0.0153 N4720 X1.3216 Z-0.0143 N4730 X1.3205 Z-0.0135 N4740 X1.3194 Z-0.0130 N4750 X1.3183 Z-0.0128 N4760 X1.2016 Z-0.0128 N4770 X1.0728 Z-0.0128 N4780 X0.9418 Z-0.0128 N4790 X0.8571 Z-0.0128 N4800 X0.8560 Z-0.0130 N4810 X0.8549 Z-0.0134 N4820 X0.8538 Z-0.0141 N4830 X0.8527 Z-0.0150 N4840 X0.8516 Z-0.0161 N4850 X0.8494 Z-0.0187 N4860 X0.8461 Z-0.0232 N4870 X0.8417 Z-0.0299 N4880 X0.8340 Z-0.0423 N4890 X0.8241 Z-0.0588 N4900 X0.8230 Z-0.0600 N4910 X0.4157 N4920 X0.4146 Z-0.0585 N4930 X0.3816 Z-0.0013 N4940 X0.3805 Z-0.0000 N4950 Y0.2736 Z-0.0000 N4960 X0.3816 Z-0.0013 N4970 X0.4146 Z-0.0585 N4980 X0.4157 Z-0.0600 N4990 X0.8219 N5000 X0.8230 Z-0.0594 N5010 X0.8406 Z-0.0291 N5020 X0.8483 Z-0.0162 N5030 X0.8527 Z-0.0091 N5040 X0.8538 Z-0.0075 N5050 X0.8549 Z-0.0061 N5060 X0.8560 Z-0.0051 N5070 X0.8571 Z-0.0045 N5080 X0.9914 Z-0.0045 N5090 X1.1047 Z-0.0045 N5100 X1.2412 Z-0.0045 N5110 X1.3172 Z-0.0045 N5120 X1.3183 Z-0.0046 N5130 X1.3194 Z-0.0054 N5140 X1.3205 Z-0.0066 N5150 X1.3216 Z-0.0080 N5160 X1.3238 Z-0.0112 N5170 X1.3304 Z-0.0221 N5180 X1.3469 Z-0.0504 N5190 X1.3524 Z-0.0599 N5200 X1.3535 Z-0.0600 N5210 X1.7607 N5220 X1.7618 Z-0.0589 N5230 X1.8003 Z-0.0079 N5240 X1.8014 Z-0.0064 N5250 X1.8025 Z-0.0052 N5260 X1.8036 Z-0.0047 N5270 X1.8047 Z-0.0045 N5280 X2.1250 Z-0.0045 N5290 X2.1316 Z-0.0045 N5300 X2.1327 Z-0.0051 N5310 X2.1338 Z-0.0058 N5320 X2.1349 Z-0.0072 N5330 X2.1371 Z-0.0106 N5340 X2.1437 Z-0.0214 N5350 X2.1570 Z-0.0439 N5360 X2.1592 Z-0.0477 N5370 X2.1603 Z-0.0471 N5380 X2.1867 Z-0.0013 N5390 X2.1878 Z-0.0000 N5400 Y0.2786 Z-0.0000 N5410 X2.1867 Z-0.0013 N5420 X2.1603 Z-0.0470 N5430 X2.1592 Z-0.0476 N5440 X2.1427 Z-0.0192 N5450 X2.1372 Z-0.0099 N5460 X2.1328 Z-0.0028 N5470 X2.1317 Z-0.0013 N5480 X2.1306 Z0.0000 N5490 X2.1302 Y0.2796 Z-0.0003 N5500 X2.1298 Y0.2806 Z0.0000 N5510 X2.1294 Y0.2816 N5520 X2.1289 Y0.2826 Z-0.0002 N5530 X2.1285 Y0.2836 Z0.0000 N5540 X2.1296 Z-0.0014 N5550 X2.1307 Z-0.0030 N5560 X2.1483 Z-0.0311 N5570 X2.1560 Z-0.0438 N5580 X2.1582 Z-0.0475 N5590 X2.1593 Z-0.0487 N5600 X2.1867 Z-0.0013 N5610 X2.1878 Z0.0000 N5620 Y0.2886 Z-0.0000 N5630 X2.1867 Z-0.0013 N5640 X2.1593 Z-0.0486 N5650 X2.1582 Z-0.0502 N5660 X2.1276 Z-0.0008 N5670 X2.1265 Z0.0000 N5680 X2.1261 Y0.2896 N5690 X2.1257 Y0.2906 Z-0.0003 N5700 X2.1253 Y0.2916 Z0.0000 N5710 X2.1249 Y0.2926 Z-0.0001 N5720 X2.1245 Y0.2936 Z-0.0000 N5730 X2.1256 Z-0.0008 N5740 X2.1561 Z-0.0503 N5750 X2.1572 Z-0.0520 N5760 X2.1583 Z-0.0503 N5770 X2.1867 Z-0.0013 N5780 X2.1878 Z-0.0000 N5790 Y0.2986 Z-0.0000 N5800 X2.1867 Z-0.0013 N5810 X2.1573 Z-0.0520 N5820 X2.1562 Z-0.0534 N5830 X2.1322 Z-0.0146 N5840 X2.1235 Z-0.0006 N5850 X2.1224 Z-0.0004 N5860 X2.1220 Y0.2996 Z0.0000 N5870 X2.1216 Y0.3006 N5880 X2.1212 Y0.3016 Z-0.0001 N5890 X2.1208 Y0.3026 Z0.0000 N5900 X2.1204 Y0.3036 Z-0.0002 N5910 X2.1215 Z-0.0010 N5920 X2.1465 Z-0.0409 N5930 X2.1552 Z-0.0550 N5940 X2.1563 Z-0.0537 N5950 X2.1867 Z-0.0013 N5960 X2.1878 Z-0.0000 N5970 Y0.3086 Z0.0000 N5980 X2.1867 Z-0.0013 N5990 X2.1563 Z-0.0536 N6000 X2.1552 Z-0.0554 N6010 X2.1541 Z-0.0566 N6020 X2.1411 Z-0.0355 N6030 X2.1205 Z-0.0026 N6040 X2.1194 Z-0.0013 N6050 X2.1184 Z-0.0003 N6060 X2.1179 Y0.3096 Z-0.0003 N6070 X2.1175 Y0.3106 Z0.0000 N6080 X2.1163 Y0.3136 N6090 X2.1174 Z-0.0014 N6100 X2.1196 Z-0.0048 N6110 X2.1526 Z-0.0576 N6120 X2.1537 Z-0.0584 N6130 X2.1867 Z-0.0013 N6140 X2.1878 Z-0.0000 N6150 Y0.3186 Z-0.0000 N6160 X2.1867 Z-0.0013 N6170 X2.1538 Z-0.0582 N6180 X2.1527 Z-0.0600 N6190 X2.1516 Z-0.0591 N6200 X2.1165 Z-0.0029 N6210 X2.1143 Z0.0000 N6220 X2.1139 Y0.3195 Z-0.0004 N6230 X2.1135 Y0.3205 Z-0.0001 N6240 X2.1131 Y0.3215 Z0.0000 N6250 X2.1126 Y0.3225 Z-0.0001 N6260 X2.1122 Y0.3235 Z0.0000 N6270 X2.1133 Z-0.0008 N6280 X2.1473 Z-0.0556 N6290 X2.1495 Z-0.0591 N6300 X2.1506 Z-0.0600 N6310 X2.1527 Z-0.0600 N6320 X2.1867 Z-0.0013 N6330 X2.1878 Z-0.0000 N6340 Y0.3285 Z-0.0000 N6350 X2.1867 Z-0.0013 N6360 X2.1528 Z-0.0598 N6370 X2.1517 Z-0.0600 N6380 X2.1484 N6390 X2.1474 Z-0.0590 N6400 X2.1342 Z-0.0380 N6410 X2.1179 Z-0.0115 N6420 X2.1113 Z-0.0010 N6430 X2.1102 Z-0.0002 N6440 X2.1098 Y0.3295 Z0.0000 N6450 X2.1094 Y0.3305 Z-0.0003 N6460 X2.1090 Y0.3315 Z0.0000 N6470 X2.1086 Y0.3325 N6480 X2.1082 Y0.3335 Z-0.0003 N6490 X2.1093 Z-0.0008 N6500 X2.1322 Z-0.0373 N6510 X2.1452 Z-0.0585 N6520 X2.1463 Z-0.0600 N6530 X2.1518 N6540 X2.1529 Z-0.0596 N6550 X2.1867 Z-0.0013 N6560 X2.1878 Z0.0000 N6570 Y0.3385 Z-0.0000 N6580 X2.1867 Z-0.0013 N6590 X2.1529 Z-0.0595 N6600 X2.1519 Z-0.0600 N6610 X2.1442 N6620 X2.1431 Z-0.0586 N6630 X2.1246 Z-0.0290 N6640 X2.1083 Z-0.0027 N6650 X2.1072 Z-0.0013 N6660 X2.1061 Z-0.0003 N6670 X2.1057 Y0.3395 Z0.0000 N6680 X2.1053 Y0.3405 N6690 X2.1049 Y0.3415 Z-0.0003 N6700 X2.1045 Y0.3425 Z0.0000 N6710 X2.1041 Y0.3435 N6720 X2.1063 Z-0.0028 N6730 X2.1415 Z-0.0593 N6740 X2.1426 Z-0.0600 N6750 X2.1525 N6760 X2.1536 Z-0.0585 N6770 X2.1867 Z-0.0013 N6780 X2.1878 Z-0.0000 N6790 Y0.3485 Z-0.0000 N6800 X2.1867 Z-0.0013 N6810 X2.1537 Z-0.0584 N6820 X2.1526 Z-0.0600 N6830 X2.1405 N6840 X2.1394 Z-0.0593 N6850 X2.1043 Z-0.0029 N6860 X2.1021 Z0.0000 N6870 X2.1016 Y0.3495 Z-0.0005 N6880 X2.1012 Y0.3505 Z0.0000 N6890 X2.1004 Y0.3525 Z-0.0003 N6900 X2.0985 Y0.3527 Z-0.0005 N6910 X2.0966 Y0.3529 Z-0.0001 N6920 X2.0956 Y0.3530 Z0.0000 N6930 X2.0909 Y0.3535 N6940 X2.0953 N6950 X2.0964 Z-0.0001 N6960 X2.0997 Z-0.0007 N6970 X2.1008 Z-0.0011 N6980 X2.1030 Z-0.0041 N6990 X2.1372 Z-0.0588 N7000 X2.1383 Z-0.0600 N7010 X2.1526 N7020 X2.1537 Z-0.0585 N7030 X2.1867 Z-0.0013 N7040 X2.1878 Z-0.0000 N7050 Y0.3585 Z-0.0000 N7060 X2.1867 Z-0.0013 N7070 X2.1527 Z-0.0600 N7080 X2.1473 Z-0.0600 N7090 X2.1363 N7100 X2.1352 Z-0.0592 N7110 X2.1144 Z-0.0257 N7120 X2.1101 Z-0.0189 N7130 X2.1079 Z-0.0159 N7140 X2.1057 Z-0.0132 N7150 X2.1046 Z-0.0120 N7160 X2.1035 Z-0.0110 N7170 X2.1024 Z-0.0102 N7180 X2.1002 Z-0.0097 N7190 X2.0925 Z-0.0083 N7200 X2.0849 Z-0.0067 N7210 X2.0772 Z-0.0048 N7220 X2.0695 Z-0.0028 N7230 X2.0652 Z-0.0015 N7240 X2.0630 Z-0.0014 N7250 X2.0619 Z-0.0012 N7260 X2.0586 Z-0.0001 N7270 X2.0572 Y0.3588 Z0.0000 N7280 X2.0561 Y0.3590 N7290 X2.0551 Y0.3592 Z-0.0005 N7300 X2.0541 Y0.3595 Z-0.0003 N7310 X2.0531 Y0.3597 Z0.0000 N7320 X2.0510 Y0.3601 N7330 X2.0500 Y0.3604 Z-0.0006 N7340 X2.0491 Y0.3606 Z-0.0001 N7350 X2.0481 Y0.3608 Z0.0000 N7360 X2.0471 Y0.3611 N7370 X2.0461 Y0.3613 Z-0.0002 N7380 X2.0442 Y0.3618 Z-0.0002 N7390 X2.0433 Y0.3620 Z0.0000 N7400 X2.0423 Y0.3623 N7410 X2.0414 Y0.3625 Z-0.0005 N7420 X2.0405 Y0.3628 Z-0.0000 N7430 X2.0388 Y0.3633 Z0.0000 N7440 X2.0380 Y0.3635 Z-0.0002 N7450 X2.0402 Z-0.0002 N7460 X2.0468 Z-0.0031 N7470 X2.0534 Z-0.0057 N7480 X2.0600 Z-0.0081 N7490 X2.0667 Z-0.0102 N7500 X2.0733 Z-0.0121 N7510 X2.0799 Z-0.0138 N7520 X2.0876 Z-0.0156 N7530 X2.0953 Z-0.0171 N7540 X2.1008 Z-0.0181 N7550 X2.1030 Z-0.0187 N7560 X2.1041 Z-0.0192 N7570 X2.1052 Z-0.0200 N7580 X2.1063 Z-0.0208 N7590 X2.1085 Z-0.0229 N7600 X2.1118 Z-0.0267 N7610 X2.1151 Z-0.0310 N7620 X2.1184 Z-0.0357 N7630 X2.1250 Z-0.0458 N7640 X2.1338 Z-0.0599 N7650 X2.1360 Z-0.0600 N7660 X2.1525 N7670 X2.1536 Z-0.0585 N7680 X2.1867 Z-0.0013 N7690 X2.1878 Z0.0000 N7700 Y0.3685 Z-0.0000 N7710 X2.1867 Z-0.0013 N7720 X2.1538 Z-0.0582 N7730 X2.1527 Z-0.0600 N7740 X2.1318 N7750 X2.1307 Z-0.0588 N7760 X2.1253 Z-0.0506 N7770 X2.1209 Z-0.0444 N7780 X2.1176 Z-0.0400 N7790 X2.1143 Z-0.0361 N7800 X2.1121 Z-0.0338 N7810 X2.1088 Z-0.0308 N7820 X2.1066 Z-0.0292 N7830 X2.1055 Z-0.0285 N7840 X2.1044 Z-0.0280 N7850 X2.1033 Z-0.0276 N7860 X2.1000 Z-0.0269 N7870 X2.0934 Z-0.0257 N7880 X2.0858 Z-0.0241 N7890 X2.0781 Z-0.0223 N7900 X2.0715 Z-0.0205 N7910 X2.0649 Z-0.0185 N7920 X2.0583 Z-0.0162 N7930 X2.0518 Z-0.0137 N7940 X2.0452 Z-0.0109 N7950 X2.0397 Z-0.0084 N7960 X2.0342 Z-0.0056 N7970 X2.0287 Z-0.0026 N7980 X2.0276 Z-0.0019 N7990 X2.0265 Z-0.0016 N8000 X2.0254 Z-0.0010 N8010 X2.0243 Z-0.0004 N8020 X2.0232 Z-0.0001 N8030 X2.0224 Y0.3688 Z0.0000 N8040 X2.0216 Y0.3692 Z-0.0005 N8050 X2.0207 Y0.3695 Z0.0000 N8060 X2.0199 Y0.3699 N8070 X2.0190 Y0.3702 Z-0.0005 N8080 X2.0182 Y0.3706 Z0.0000 N8090 X2.0173 Y0.3710 N8100 X2.0165 Y0.3714 Z-0.0001 N8110 X2.0156 Y0.3717 N8120 X2.0148 Y0.3722 Z0.0000 N8130 X2.0139 Y0.3726 Z-0.0002 N8140 X2.0130 Y0.3731 Z0.0000 N8150 X2.0121 Y0.3735 Z-0.0002 N8160 X2.0143 Z-0.0005 N8170 X2.0176 Z-0.0030 N8180 X2.0231 Z-0.0068 N8190 X2.0286 Z-0.0103 N8200 X2.0341 Z-0.0134 N8210 X2.0396 Z-0.0163 N8220 X2.0451 Z-0.0189 N8230 X2.0505 Z-0.0213 N8240 X2.0560 Z-0.0235 N8250 X2.0626 Z-0.0258 N8260 X2.0692 Z-0.0280 N8270 X2.0758 Z-0.0299 N8280 X2.0824 Z-0.0315 N8290 X2.0890 Z-0.0331 N8300 X2.0967 Z-0.0346 N8310 X2.1021 Z-0.0356 N8320 X2.1043 Z-0.0361 N8330 X2.1054 Z-0.0365 N8340 X2.1065 Z-0.0369 N8350 X2.1087 Z-0.0382 N8360 X2.1109 Z-0.0398 N8370 X2.1131 Z-0.0416 N8380 X2.1153 Z-0.0437 N8390 X2.1186 Z-0.0473 N8400 X2.1219 Z-0.0513 N8410 X2.1263 Z-0.0571 N8420 X2.1285 Z-0.0600 N8430 X2.1526 N8440 X2.1537 Z-0.0583 N8450 X2.1867 Z-0.0013 N8460 X2.1878 Z-0.0000 N8470 Y0.3785 Z-0.0000 N8480 X2.1867 Z-0.0013 N8490 X2.1537 Z-0.0583 N8500 X2.1526 Z-0.0600 N8510 X2.1241 N8520 X2.1230 Z-0.0590 N8530 X2.1197 Z-0.0554 N8540 X2.1164 Z-0.0523 N8550 X2.1142 Z-0.0505 N8560 X2.1120 Z-0.0488 N8570 X2.1098 Z-0.0474 N8580 X2.1076 Z-0.0462 N8590 X2.1054 Z-0.0453 N8600 X2.1021 Z-0.0446 N8610 X2.0944 Z-0.0432 N8620 X2.0878 Z-0.0418 N8630 X2.0802 Z-0.0400 N8640 X2.0736 Z-0.0382 N8650 X2.0670 Z-0.0362 N8660 X2.0604 Z-0.0340 N8670 X2.0538 Z-0.0315 N8680 X2.0472 Z-0.0287 N8690 X2.0417 Z-0.0261 N8700 X2.0362 Z-0.0233 N8710 X2.0307 Z-0.0202 N8720 X2.0252 Z-0.0167 N8730 X2.0198 Z-0.0129 N8740 X2.0143 Z-0.0087 N8750 X2.0110 Z-0.0059 N8760 X2.0077 Z-0.0028 N8770 X2.0066 Z-0.0016 N8780 X2.0044 Z0.0000 N8790 X2.0036 Y0.3791 Z-0.0006 N8800 X2.0029 Y0.3798 Z0.0000 N8810 X2.0021 Y0.3805 N8820 X2.0013 Y0.3812 Z-0.0003 N8830 X2.0005 Y0.3819 Z0.0000 N8840 X1.9987 Y0.3835 Z-0.0000 N8850 X1.9998 Z-0.0005 N8860 X2.0009 Z-0.0016 N8870 X2.0075 Z-0.0092 N8880 X2.0108 Z-0.0128 N8890 X2.0130 Z-0.0150 N8900 X2.0163 Z-0.0178 N8910 X2.0218 Z-0.0220 N8920 X2.0262 Z-0.0251 N8930 X2.0317 Z-0.0286 N8940 X2.0372 Z-0.0317 N8950 X2.0427 Z-0.0346 N8960 X2.0482 Z-0.0372 N8970 X2.0537 Z-0.0395 N8980 X2.0592 Z-0.0417 N8990 X2.0647 Z-0.0436 N9000 X2.0713 Z-0.0457 N9010 X2.0779 Z-0.0476 N9020 X2.0845 Z-0.0492 N9030 X2.0911 Z-0.0507 N9040 X2.0987 Z-0.0522 N9050 X2.1031 Z-0.0530 N9060 X2.1064 Z-0.0538 N9070 X2.1086 Z-0.0547 N9080 X2.1108 Z-0.0558 N9090 X2.1130 Z-0.0572 N9100 X2.1152 Z-0.0587 N9110 X2.1163 Z-0.0596 N9120 X2.1174 Z-0.0600 N9130 X2.1526 N9140 X2.1537 Z-0.0584 N9150 X2.1867 Z-0.0013 N9160 X2.1878 Z-0.0000 N9170 Y0.3885 Z-0.0000 N9180 X2.1867 Z-0.0013 N9190 X2.1538 Z-0.0582 N9200 X2.1527 Z-0.0600 N9210 X2.0935 N9220 X2.0924 Z-0.0599 N9230 X2.0869 Z-0.0587 N9240 X2.0804 Z-0.0571 N9250 X2.0727 Z-0.0549 N9260 X2.0672 Z-0.0533 N9270 X2.0617 Z-0.0514 N9280 X2.0563 Z-0.0493 N9290 X2.0508 Z-0.0470 N9300 X2.0453 Z-0.0444 N9310 X2.0409 Z-0.0422 N9320 X2.0354 Z-0.0392 N9330 X2.0310 Z-0.0365 N9340 X2.0267 Z-0.0336 N9350 X2.0223 Z-0.0304 N9360 X2.0179 Z-0.0269 N9370 X2.0157 Z-0.0250 N9380 X2.0135 Z-0.0227 N9390 X2.0025 Z-0.0102 N9400 X1.9960 Z-0.0029 N9410 X1.9927 Z0.0000 N9420 X1.9920 Y0.3890 Z-0.0001 N9430 X1.9913 Y0.3896 N9440 X1.9905 Y0.3902 Z-0.0004 N9450 X1.9898 Y0.3908 Z0.0000 N9460 X1.9890 Y0.3914 Z-0.0001 N9470 X1.9882 Y0.3921 Z-0.0001 N9480 X1.9874 Y0.3928 Z0.0000 N9490 X1.9866 Y0.3935 N9500 X1.9877 Z-0.0007 N9510 X1.9888 Z-0.0016 N9520 X2.0020 Z-0.0161 N9530 X2.0086 Z-0.0235 N9540 X2.0163 Z-0.0324 N9550 X2.0185 Z-0.0348 N9560 X2.0207 Z-0.0367 N9570 X2.0262 Z-0.0410 N9580 X2.0306 Z-0.0440 N9590 X2.0350 Z-0.0468 N9600 X2.0405 Z-0.0500 N9610 X2.0460 Z-0.0529 N9620 X2.0526 Z-0.0559 N9630 X2.0592 Z-0.0586 N9640 X2.0625 Z-0.0598 N9650 X2.0636 Z-0.0600 N9660 X2.1526 N9670 X2.1537 Z-0.0584 N9680 X2.1867 Z-0.0013 N9690 X2.1878 Z-0.0000 N9700 Y0.3985 Z-0.0000 N9710 X2.1867 Z-0.0013 N9720 X2.1538 Z-0.0582 N9730 X2.1527 Z-0.0600 N9740 X2.0442 N9750 X2.0431 Z-0.0599 N9760 X2.0387 Z-0.0574 N9770 X2.0343 Z-0.0547 N9780 X2.0300 Z-0.0518 N9790 X2.0245 Z-0.0476 N9800 X2.0234 Z-0.0467 N9810 X2.0223 Z-0.0457 N9820 X2.0146 Z-0.0370 N9830 X2.0091 Z-0.0308 N9840 X1.9949 Z-0.0152 N9850 X1.9839 Z-0.0030 N9860 X1.9817 Z-0.0009 N9870 X1.9806 Z0.0000 N9880 X1.9792 Y0.3997 N9890 X1.9784 Y0.4003 Z-0.0002 N9900 X1.9769 Y0.4016 Z-0.0001 N9910 X1.9762 Y0.4022 Z-0.0005 N9920 X1.9754 Y0.4028 Z0.0000 N9930 X1.9747 Y0.4035 Z-0.0001 N9940 X1.9758 Z-0.0009 N9950 X1.9769 Z-0.0015 N9960 X2.0000 Z-0.0272 N9970 X2.0109 Z-0.0392 N9980 X2.0186 Z-0.0479 N9990 X2.0252 Z-0.0555 N10000 X2.0263 Z-0.0565 N10010 X2.0307 Z-0.0599 N10020 X2.0329 Z-0.0600 N10030 X2.1482 N10040 X2.1526 N10050 X2.1537 Z-0.0583 N10060 X2.1867 Z-0.0013 N10070 X2.1878 Z-0.0000 N10080 Y0.4085 Z-0.0000 N10090 X2.1867 Z-0.0013 N10100 X2.1537 Z-0.0585 N10110 X2.1526 Z-0.0600 N10120 X2.0238 N10130 X2.0227 Z-0.0592 N10140 X2.0150 Z-0.0506 N10150 X2.0018 Z-0.0361 N10160 X1.9765 Z-0.0079 N10170 X1.9699 Z-0.0005 N10180 X1.9688 Z0.0000 N10190 X1.9680 Y0.4091 N10200 X1.9672 Y0.4098 Z-0.0003 N10210 X1.9664 Y0.4105 Z0.0000 N10220 X1.9650 Y0.4117 N10230 X1.9643 Y0.4123 Z-0.0001 N10240 X1.9637 Y0.4129 Z-0.0000 N10250 X1.9630 Y0.4134 Z-0.0003 N10260 X1.9641 Z-0.0012 N10270 X1.9652 Z-0.0016 N10280 X1.9838 Z-0.0225 N10290 X2.0079 Z-0.0493 N10300 X2.0167 Z-0.0588 N10310 X2.0178 Z-0.0600 N10320 X2.1527 N10330 X2.1593 Z-0.0487 N10340 X2.1867 Z-0.0013 N10350 X2.1878 Z-0.0000 N10360 Y0.4184 Z-0.0000 N10370 X2.1867 Z-0.0013 N10380 X2.1537 Z-0.0583 N10390 X2.1526 Z-0.0600 N10400 X2.0121 N10410 X2.0110 Z-0.0590 N10420 X1.9858 Z-0.0310 N10430 X1.9649 Z-0.0076 N10440 X1.9594 Z-0.0014 N10450 X1.9583 Z-0.0004 N10460 X1.9572 Z0.0000 N10470 X1.9564 Y0.4191 N10480 X1.9557 Y0.4198 Z-0.0002 N10490 X1.9549 Y0.4204 N10500 X1.9542 Y0.4211 Z-0.0004 N10510 X1.9534 Y0.4218 Z0.0000 N10520 X1.9521 Y0.4229 Z-0.0001 N10530 X1.9515 Y0.4234 Z0.0000 N10540 X1.9526 Z-0.0007 N10550 X1.9537 Z-0.0018 N10560 X1.9713 Z-0.0218 N10570 X1.9911 Z-0.0441 N10580 X2.0043 Z-0.0588 N10590 X2.0054 Z-0.0600 N10600 X2.1526 N10610 X2.1537 Z-0.0584 N10620 X2.1867 Z-0.0013 N10630 X2.1878 Z-0.0000 N10640 Y0.4284 Z-0.0000 N10650 X2.1867 Z-0.0013 N10660 X2.1537 Z-0.0584 N10670 X2.1526 Z-0.0600 N10680 X2.0009 N10690 X1.9998 Z-0.0600 N10700 X1.9800 Z-0.0378 N10710 X1.9602 Z-0.0153 N10720 X1.9470 Z-0.0001 N10730 X1.9459 Z-0.0000 N10740 X1.9443 Y0.4298 Z-0.0004 N10750 X1.9436 Y0.4305 Z0.0000 N10760 X1.9428 Y0.4312 Z-0.0001 N10770 X1.9420 Y0.4319 Z-0.0005 N10780 X1.9412 Y0.4326 Z0.0000 N10790 X1.9404 Y0.4334 N10800 X1.9415 Z-0.0008 N10810 X1.9590 Z-0.0211 N10820 X1.9766 Z-0.0411 N10830 X1.9931 Z-0.0597 N10840 X1.9942 Z-0.0600 N10850 X2.1526 N10860 X2.1537 Z-0.0584 N10870 X2.1867 Z-0.0013 N10880 X2.1878 Z-0.0000 N10890 Y0.4384 Z-0.0000 N10900 X2.1867 Z-0.0013 N10910 X2.1537 Z-0.0584 N10920 X2.1526 Z-0.0600 N10930 X1.9888 N10940 X1.9877 Z-0.0597 N10950 X1.9690 Z-0.0384 N10960 X1.9536 Z-0.0207 N10970 X1.9393 Z-0.0040 N10980 X1.9360 Z-0.0002 N10990 X1.9349 Y0.4384 Z-0.0000 N11000 X1.9335 Y0.4398 Z-0.0001 N11010 X1.9327 Y0.4405 Z0.0000 N11020 X1.9320 Y0.4412 Z-0.0002 N11030 X1.9313 Y0.4419 Z-0.0002 N11040 X1.9305 Y0.4426 Z0.0000 N11050 X1.9298 Y0.4433 Z-0.0003 N11060 X1.9297 Y0.4434 N11070 X1.9308 Z-0.0007 N11080 X1.9461 Z-0.0188 N11090 X1.9615 Z-0.0367 N11100 X1.9780 Z-0.0555 N11110 X1.9813 Z-0.0592 N11120 X1.9824 Z-0.0600 N11130 X2.1526 N11140 X2.1537 Z-0.0583 N11150 X2.1867 Z-0.0013 N11160 X2.1878 Z-0.0000 N11170 Y0.4484 Z-0.0000 N11180 X2.1867 Z-0.0013 N11190 X2.1538 Z-0.0582 N11200 X2.1527 Z-0.0600 N11210 X1.9772 N11220 X1.9761 Z-0.0596 N11230 X1.9607 Z-0.0419 N11240 X1.9443 Z-0.0228 N11250 X1.9322 Z-0.0084 N11260 X1.9267 Z-0.0018 N11270 X1.9256 Z-0.0009 N11280 X1.9245 Z-0.0004 N11290 X1.9238 Y0.4492 Z0.0000 N11300 X1.9223 Y0.4507 Z-0.0005 N11310 X1.9215 Y0.4515 Z0.0000 N11320 X1.9207 Y0.4522 Z-0.0000 N11330 X1.9202 Y0.4528 Z-0.0004 N11340 X1.9196 Y0.4534 Z-0.0000 N11350 X1.9207 Z-0.0005 N11360 X1.9328 Z-0.0153 N11370 X1.9449 Z-0.0298 N11380 X1.9603 Z-0.0480 N11390 X1.9702 Z-0.0595 N11400 X1.9713 Z-0.0600 N11410 X2.1526 N11420 X2.1537 Z-0.0584 N11430 X2.1867 Z-0.0013 N11440 X2.1878 Z-0.0000 N11450 Y0.4584 Z-0.0000 N11460 X2.1867 Z-0.0013 N11470 X2.1537 Z-0.0585 N11480 X2.1526 Z-0.0600 N11490 X1.9655 N11500 X1.9644 Z-0.0594 N11510 X1.9512 Z-0.0438 N11520 X1.9391 Z-0.0293 N11530 X1.9270 Z-0.0145 N11540 X1.9160 Z-0.0007 N11550 X1.9149 Z0.0000 N11560 X1.9119 Y0.4618 N11570 X1.9112 Y0.4626 Z-0.0001 N11580 X1.9105 Y0.4634 Z0.0000 N11590 X1.9116 Z-0.0007 N11600 X1.9215 Z-0.0136 N11610 X1.9325 Z-0.0274 N11620 X1.9435 Z-0.0409 N11630 X1.9578 Z-0.0580 N11640 X1.9589 Z-0.0593 N11650 X1.9600 Z-0.0600 N11660 X2.1526 N11670 X2.1537 Z-0.0585 N11680 X2.1867 Z-0.0013 N11690 X2.1878 Z-0.0000 N11700 Y0.4684 Z-0.0000 N11710 X2.1867 Z-0.0013 N11720 X2.1537 Z-0.0584 N11730 X2.1526 Z-0.0600 N11740 X1.9547 N11750 X1.9536 Z-0.0591 N11760 X1.9426 Z-0.0458 N11770 X1.9316 Z-0.0321 N11780 X1.9217 Z-0.0195 N11790 X1.9107 Z-0.0050 N11800 X1.9085 Z-0.0021 N11810 X1.9074 Z-0.0008 N11820 X1.9063 Z0.0000 N11830 X1.9057 Y0.4692 Z-0.0001 N11840 X1.9050 Y0.4700 Z0.0000 N11850 X1.9036 Y0.4717 Z-0.0003 N11860 X1.9029 Y0.4725 Z-0.0001 N11870 X1.9022 Y0.4734 N11880 X1.9033 Z-0.0005 N11890 X1.9230 Z-0.0267 N11900 X1.9329 Z-0.0395 N11910 X1.9439 Z-0.0533 N11920 X1.9494 Z-0.0600 N11930 X2.0604 Z-0.0600 N11940 X2.1526 N11950 X2.1537 Z-0.0583 N11960 X2.1867 Z-0.0013 N11970 X2.1878 Z-0.0000 N11980 Y0.4784 Z-0.0000 N11990 X2.1867 Z-0.0013 N12000 X2.1537 Z-0.0583 N12010 X2.1527 Z-0.0600 N12020 X1.9452 N12030 X1.9441 Z-0.0595 N12040 X1.9342 Z-0.0470 N12050 X1.9232 Z-0.0326 N12060 X1.9002 Z-0.0020 N12070 X1.8991 Z-0.0013 N12080 X1.8980 Z-0.0003 N12090 X1.8973 Y0.4792 Z-0.0001 N12100 X1.8966 Y0.4800 N12110 X1.8959 Y0.4809 Z0.0000 N12120 X1.8952 Y0.4817 N12130 X1.8945 Y0.4825 Z-0.0004 N12140 X1.8938 Y0.4834 Z0.0000 N12150 X1.8949 Z-0.0009 N12160 X1.9324 Z-0.0506 N12170 X1.9390 Z-0.0593 N12180 X1.9401 Z-0.0600 N12190 X2.1525 N12200 X2.1536 Z-0.0585 N12210 X2.1867 Z-0.0013 N12220 X2.1878 Z-0.0000 N12230 Y0.4884 Z-0.0000 N12240 X2.1867 Z-0.0013 N12250 X2.1537 Z-0.0585 N12260 X2.1526 Z-0.0600 N12270 X1.9358 N12280 X1.9347 Z-0.0593 N12290 X1.8929 Z-0.0038 N12300 X1.8907 Z-0.0011 N12310 X1.8896 Z0.0000 N12320 X1.8889 Y0.4892 Z-0.0004 N12330 X1.8882 Y0.4900 Z0.0000 N12340 X1.8876 Y0.4909 N12350 X1.8869 Y0.4917 Z-0.0004 N12360 X1.8862 Y0.4925 Z-0.0002 N12370 X1.8855 Y0.4934 Z-0.0000 N12380 X1.8866 Z-0.0002 N12390 X1.9305 Z-0.0587 N12400 X1.9316 Z-0.0600 N12410 X2.1526 N12420 X2.1537 Z-0.0584 N12430 X2.1867 Z-0.0013 N12440 X2.1878 Z-0.0000 N12450 Y0.4984 Z-0.0000 N12460 X2.1867 Z-0.0013 N12470 X2.1537 Z-0.0583 N12480 X2.1526 Z-0.0600 N12490 X1.9274 N12500 X1.9263 Z-0.0591 N12510 X1.8835 Z-0.0021 N12520 X1.8824 Z-0.0010 N12530 X1.8813 Z-0.0004 N12540 X1.8799 Y0.5000 Z0.0000 N12550 X1.8785 Y0.5017 N12560 X1.8778 Y0.5025 Z-0.0001 N12570 X1.8771 Y0.5033 Z-0.0001 N12580 X1.8793 Z-0.0020 N12590 X1.9221 Z-0.0588 N12600 X1.9232 Z-0.0600 N12610 X2.1526 N12620 X2.1537 Z-0.0583 N12630 X2.1867 Z-0.0013 N12640 X2.1878 Z-0.0000 N12650 Y0.5083 Z-0.0000 N12660 X2.1867 Z-0.0013 N12670 X2.1537 Z-0.0585 N12680 X2.1525 Z-0.0600 N12690 X1.9192 N12700 X1.9181 Z-0.0593 N12710 X1.8762 Z-0.0037 N12720 X1.8751 Z-0.0023 N12730 X1.8740 Z-0.0012 N12740 X1.8729 Z0.0000 N12750 X1.8722 Y0.5092 N12760 X1.8715 Y0.5100 Z-0.0002 N12770 X1.8708 Y0.5108 Z0.0000 N12780 X1.8702 Y0.5117 Z-0.0003 N12790 X1.8695 Y0.5125 Z-0.0002 N12800 X1.8688 Y0.5133 Z0.0000 N12810 X1.8699 Z-0.0005 N12820 X1.9139 Z-0.0591 N12830 X1.9150 Z-0.0600 N12840 X2.1526 N12850 X2.1537 Z-0.0585 N12860 X2.1867 Z-0.0013 N12870 X2.1878 Z-0.0000 N12880 Y0.5183 Z-0.0000 N12890 X2.1867 Z-0.0013 N12900 X2.1537 Z-0.0584 N12910 X2.1526 Z-0.0600 N12920 X1.9108 N12930 X1.9097 Z-0.0590 N12940 X1.8800 Z-0.0196 N12950 X1.8657 Z-0.0006 N12960 X1.8646 Z-0.0001 N12970 X1.8639 Y0.5192 Z-0.0003 N12980 X1.8632 Y0.5200 Z-0.0000 N12990 X1.8611 Y0.5225 Z0.0000 N13000 X1.8604 Y0.5233 Z-0.0005 N13010 X1.8615 Z-0.0008 N13020 X1.8626 Z-0.0018 N13030 X1.9054 Z-0.0587 N13040 X1.9065 Z-0.0600 N13050 X2.1526 N13060 X2.1537 Z-0.0583 N13070 X2.1867 Z-0.0013 N13080 X2.1878 Z-0.0000 N13090 Y0.5283 Z-0.0000 N13100 X2.1867 Z-0.0013 N13110 X2.1537 Z-0.0583 N13120 X2.1526 Z-0.0600 N13130 X1.9023 N13140 X1.9012 Z-0.0592 N13150 X1.8584 Z-0.0023 N13160 X1.8573 Z-0.0012 N13170 X1.8562 Z0.0000 N13180 X1.8555 Y0.5292 N13190 X1.8548 Y0.5300 Z-0.0005 N13200 X1.8541 Y0.5308 Z0.0000 N13210 X1.8534 Y0.5316 N13220 X1.8527 Y0.5325 Z-0.0003 N13230 X1.8521 Y0.5333 Z-0.0001 N13240 X1.8532 Z-0.0010 N13250 X1.8543 Z-0.0022 N13260 X1.8972 Z-0.0592 N13270 X1.8983 Z-0.0600 N13280 X2.1526 N13290 X2.1537 Z-0.0585 N13300 X2.1867 Z-0.0013 N13310 X2.1878 Z-0.0000 N13320 Y0.5383 Z-0.0000 N13330 X2.1867 Z-0.0013 N13340 X2.1537 Z-0.0585 N13350 X2.1526 Z-0.0600 N13360 X1.8941 N13370 X1.8930 Z-0.0591 N13380 X1.8490 Z-0.0006 N13390 X1.8479 Z0.0000 N13400 X1.8472 Y0.5391 Z-0.0003 N13410 X1.8465 Y0.5400 Z-0.0001 N13420 X1.8458 Y0.5408 Z0.0000 N13430 X1.8444 Y0.5425 N13440 X1.8437 Y0.5433 Z-0.0002 N13450 X1.8448 Z-0.0009 N13460 X1.8459 Z-0.0019 N13470 X1.8888 Z-0.0590 N13480 X1.8899 Z-0.0600 N13490 X2.1526 N13500 X2.1537 Z-0.0584 N13510 X2.1867 Z-0.0013 N13520 X2.1878 Z-0.0000 N13530 Y0.5483 Z-0.0000 N13540 X2.1867 Z-0.0013 N13550 X2.1537 Z-0.0584 N13560 X2.1526 Z-0.0600 N13570 X1.8857 N13580 X1.8846 Z-0.0589 N13590 X1.8417 Z-0.0021 N13600 X1.8406 Z-0.0008 N13610 X1.8395 Z0.0000 N13620 X1.8381 Y0.5500 Z-0.0001 N13630 X1.8374 Y0.5508 Z-0.0003 N13640 X1.8367 Y0.5516 Z0.0000 N13650 X1.8360 Y0.5525 Z-0.0003 N13660 X1.8353 Y0.5533 Z-0.0001 N13670 X1.8364 Z-0.0014 N13680 X1.8375 Z-0.0020 N13690 X1.8804 Z-0.0589 N13700 X1.8815 Z-0.0600 N13710 X2.1526 N13720 X2.1537 Z-0.0583 N13730 X2.1867 Z-0.0013 N13740 X2.1878 Z-0.0000 N13750 Y0.5583 Z-0.0000 N13760 X2.1867 Z-0.0013 N13770 X2.1537 Z-0.0585 N13780 X2.1526 Z-0.0600 N13790 X1.8774 N13800 X1.8763 Z-0.0592 N13810 X1.8323 Z-0.0007 N13820 X1.8312 Z0.0000 N13830 X1.8305 Y0.5591 Z-0.0002 N13840 X1.8298 Y0.5599 Z-0.0002 N13850 X1.8291 Y0.5608 Z0.0000 N13860 X1.8270 Y0.5633 N13870 X1.8281 Z-0.0009 N13880 X1.8721 Z-0.0594 N13890 X1.8732 Z-0.0600 N13900 X2.1526 N13910 X2.1537 Z-0.0585 N13920 X2.1867 Z-0.0013 N13930 X2.1878 Z-0.0000 N13940 Y0.5683 Z-0.0000 N13950 X2.1867 Z-0.0013 N13960 X2.1537 Z-0.0584 N13970 X2.1526 Z-0.0600 N13980 X1.8690 N13990 X1.8250 Z-0.0017 N14000 X1.8239 Z-0.0003 N14010 X1.8228 Z0.0000 N14020 X1.8214 Y0.5699 N14030 X1.8207 Y0.5708 Z-0.0006 N14040 X1.8200 Y0.5716 Z-0.0000 N14050 X1.8193 Y0.5724 Z0.0000 N14060 X1.8186 Y0.5733 Z-0.0002 N14070 X1.8197 Z-0.0011 N14080 X1.8208 Z-0.0021 N14090 X1.8637 Z-0.0591 N14100 X1.8648 Z-0.0600 N14110 X2.1526 N14120 X2.1537 Z-0.0584 N14130 X2.1867 Z-0.0013 N14140 X2.1878 Z-0.0000 N14150 Y0.5783 Z-0.0000 N14160 X2.1867 Z-0.0013 N14170 X2.1536 Z-0.0585 N14180 X2.1525 Z-0.0600 N14190 X1.8607 N14200 X1.8596 Z-0.0592 N14210 X1.8167 Z-0.0022 N14220 X1.8156 Z-0.0009 N14230 X1.8145 Z-0.0002 N14240 X1.8138 Y0.5791 Z0.0000 N14250 X1.8131 Y0.5799 Z-0.0002 N14260 X1.8124 Y0.5808 Z-0.0000 N14270 X1.8103 Y0.5833 Z0.0000 N14280 X1.8114 Z-0.0010 N14290 X1.8125 Z-0.0025 N14300 X1.8136 Z-0.0038 N14310 X1.8554 Z-0.0593 N14320 X1.8565 Z-0.0600 N14330 X2.1526 N14340 X2.1537 Z-0.0585 N14350 X2.1867 Z-0.0013 N14360 X2.1878 Z-0.0000 N14370 Y0.5883 Z-0.0000 N14380 X2.1867 Z-0.0013 N14390 X2.1537 Z-0.0584 N14400 X2.1526 Z-0.0600 N14410 X1.8523 N14420 X1.8512 Z-0.0589 N14430 X1.8072 Z-0.0004 N14440 X1.8061 Z0.0000 N14450 X1.8047 Y0.5899 N14460 X1.8040 Y0.5907 Z-0.0001 N14470 X1.8033 Y0.5916 Z-0.0004 N14480 X1.8026 Y0.5924 Z0.0000 N14490 X1.8019 Y0.5932 Z-0.0003 N14500 X1.8030 Z-0.0007 N14510 X1.8470 Z-0.0590 N14520 X1.8481 Z-0.0600 N14530 X2.1526 N14540 X2.1537 Z-0.0584 N14550 X2.1867 Z-0.0013 N14560 X2.1878 Z-0.0000 N14570 Y0.5982 Z-0.0000 N14580 X2.1867 Z-0.0013 N14590 X2.1537 Z-0.0584 N14600 X2.1526 Z-0.0600 N14610 X1.8439 N14620 X1.8428 Z-0.0588 N14630 X1.8000 Z-0.0019 N14640 X1.7989 Z-0.0011 N14650 X1.7978 Z-0.0005 N14660 X1.7971 Y0.5991 Z0.0000 N14670 X1.7964 Y0.5999 Z-0.0003 N14680 X1.7957 Y0.6007 Z-0.0001 N14690 X1.7950 Y0.6016 Z0.0000 N14700 X1.7936 Y0.6032 N14710 X1.7947 Z-0.0011 N14720 X1.7969 Z-0.0038 N14730 X1.8387 Z-0.0594 N14740 X1.8398 Z-0.0600 N14750 X2.1525 N14760 X2.1536 Z-0.0585 N14770 X2.1867 Z-0.0013 N14780 X2.1878 Z-0.0000 N14790 Y0.6082 Z-0.0000 N14800 X2.1867 Z-0.0013 N14810 X2.1537 Z-0.0585 N14820 X2.1526 Z-0.0600 N14830 X1.8356 N14840 X1.8345 Z-0.0593 N14850 X1.7905 Z-0.0008 N14860 X1.7894 Z0.0000 N14870 X1.7887 Y0.6091 Z-0.0001 N14880 X1.7873 Y0.6107 Z0.0000 N14890 X1.7866 Y0.6116 Z-0.0006 N14900 X1.7859 Y0.6124 Z-0.0001 N14910 X1.7852 Y0.6132 Z0.0000 N14920 X1.7863 Z-0.0004 N14930 X1.8303 Z-0.0589 N14940 X1.8314 Z-0.0600 N14950 X2.1526 N14960 X2.1537 Z-0.0584 N14970 X2.1867 Z-0.0013 N14980 X2.1878 Z-0.0000 N14990 Y0.6182 Z-0.0000 N15000 X2.1867 Z-0.0013 N15010 X2.1537 Z-0.0584 N15020 X2.1526 Z-0.0600 N15030 X1.8272 N15040 X1.8261 Z-0.0589 N15050 X1.7833 Z-0.0019 N15060 X1.7822 Z-0.0010 N15070 X1.7811 Z-0.0005 N15080 X1.7797 Y0.6199 Z0.0000 N15090 X1.7790 Y0.6207 Z-0.0002 N15100 X1.7783 Y0.6215 Z0.0000 N15110 X1.7776 Y0.6224 Z-0.0001 N15120 X1.7769 Y0.6232 Z0.0000 N15130 X1.7791 Z-0.0022 N15140 X1.8219 Z-0.0590 N15150 X1.8230 Z-0.0600 N15160 X2.1526 N15170 X2.1537 Z-0.0584 N15180 X2.1867 Z-0.0013 N15190 X2.1878 Z-0.0000 N15200 Y0.6282 Z-0.0000 N15210 X2.1867 Z-0.0013 N15220 X2.1536 Z-0.0585 N15230 X2.1525 Z-0.0600 N15240 X1.8189 N15250 X1.8178 Z-0.0592 N15260 X1.7749 Z-0.0021 N15270 X1.7738 Z-0.0013 N15280 X1.7727 Z0.0000 N15290 X1.7706 Y0.6307 N15300 X1.7692 Y0.6324 Z-0.0004 N15310 X1.7685 Y0.6332 Z0.0000 N15320 X1.7696 Z-0.0004 N15330 X1.8136 Z-0.0590 N15340 X1.8147 Z-0.0600 N15350 X2.1526 N15360 X2.1537 Z-0.0585 N15370 X2.1867 Z-0.0013 N15380 X2.1878 Z-0.0000 N15390 Y0.6382 Z-0.0000 N15400 X2.1867 Z-0.0013 N15410 X2.1537 Z-0.0584 N15420 X2.1526 Z-0.0600 N15430 X1.8105 N15440 X1.8094 Z-0.0592 N15450 X1.7665 Z-0.0022 N15460 X1.7654 Z-0.0008 N15470 X1.7643 Z-0.0001 N15480 X1.7637 Y0.6390 Z-0.0005 N15490 X1.7630 Y0.6399 Z0.0000 N15500 X1.7623 Y0.6407 Z-0.0002 N15510 X1.7616 Y0.6415 Z0.0000 N15520 X1.7602 Y0.6432 Z-0.0000 N15530 X1.7613 Z-0.0006 N15540 X1.7624 Z-0.0018 N15550 X1.8052 Z-0.0587 N15560 X1.8063 Z-0.0600 N15570 X2.1526 N15580 X2.1537 Z-0.0584 N15590 X2.1867 Z-0.0013 N15600 X2.1878 Z-0.0000 N15610 Y0.6482 Z-0.0000 N15620 X2.1867 Z-0.0013 N15630 X2.1537 Z-0.0584 N15640 X2.1526 Z-0.0600 N15650 X1.8021 N15660 X1.8010 Z-0.0591 N15670 X1.7582 Z-0.0021 N15680 X1.7571 Z-0.0012 N15690 X1.7560 Z-0.0000 N15700 X1.7553 Y0.6490 Z0.0000 N15710 X1.7546 Y0.6498 Z-0.0002 N15720 X1.7539 Y0.6507 Z0.0000 N15730 X1.7532 Y0.6515 N15740 X1.7525 Y0.6523 Z-0.0005 N15750 X1.7518 Y0.6532 Z-0.0002 N15760 X1.7529 Z-0.0008 N15770 X1.7970 Z-0.0593 N15780 X1.7981 Z-0.0600 N15790 X2.1525 N15800 X2.1536 Z-0.0585 N15810 X2.1867 Z-0.0013 N15820 X2.1878 Z-0.0000 N15830 Y0.6582 Z-0.0000 N15840 X2.1867 Z-0.0013 N15850 X2.1537 Z-0.0585 N15860 X2.1526 Z-0.0600 N15870 X1.7939 N15880 X1.7928 Z-0.0593 N15890 X1.7487 Z-0.0008 N15900 X1.7476 Z0.0000 N15910 X1.7469 Y0.6590 Z-0.0005 N15920 X1.7456 Y0.6607 Z0.0000 N15930 X1.7449 Y0.6615 Z-0.0001 N15940 X1.7442 Y0.6623 Z0.0000 N15950 X1.7435 Y0.6632 Z-0.0002 N15960 X1.7446 Z-0.0005 N15970 X1.7457 Z-0.0017 N15980 X1.7886 Z-0.0588 N15990 X1.7897 Z-0.0600 N16000 X2.1526 N16010 X2.1537 Z-0.0584 N16020 X2.1867 Z-0.0013 N16030 X2.1878 Z-0.0000 N16040 Y0.6682 Z-0.0000 N16050 X2.1867 Z-0.0013 N16060 X2.1537 Z-0.0584 N16070 X2.1526 Z-0.0600 N16080 X1.7855 N16090 X1.7844 Z-0.0592 N16100 X1.7404 Z-0.0008 N16110 X1.7393 Z-0.0001 N16120 X1.7386 Y0.6690 Z0.0000 N16130 X1.7365 Y0.6715 N16140 X1.7358 Y0.6723 Z-0.0003 N16150 X1.7351 Y0.6732 Z-0.0004 N16160 X1.7373 Z-0.0020 N16170 X1.7802 Z-0.0589 N16180 X1.7813 Z-0.0600 N16190 X2.1526 N16200 X2.1537 Z-0.0584 N16210 X2.1867 Z-0.0013 N16220 X2.1878 Z-0.0000 N16230 Y0.6782 Z-0.0000 N16240 X2.1867 Z-0.0013 N16250 X2.1537 Z-0.0585 N16260 X2.1525 Z-0.0600 N16270 X1.7772 N16280 X1.7761 Z-0.0594 N16290 X1.7320 Z-0.0009 N16300 X1.7309 Z0.0000 N16310 X1.7295 Y0.6798 Z-0.0004 N16320 X1.7288 Y0.6806 Z-0.0001 N16330 X1.7282 Y0.6815 Z-0.0001 N16340 X1.7275 Y0.6823 Z0.0000 N16350 X1.7268 Y0.6831 N16360 X1.7279 Z-0.0008 N16370 X1.7312 Z-0.0051 N16380 X1.7719 Z-0.0592 N16390 X1.7730 Z-0.0600 N16400 X2.1526 N16410 X2.1537 Z-0.0585 N16420 X2.1867 Z-0.0013 N16430 X2.1878 Z-0.0000 N16440 Y0.6881 Z-0.0000 N16450 X2.1867 Z-0.0013 N16460 X2.1537 Z-0.0584 N16470 X2.1526 Z-0.0600 N16480 X1.7688 N16490 X1.7677 Z-0.0588 N16500 X1.7237 Z-0.0005 N16510 X1.7226 Z-0.0002 N16520 X1.7219 Y0.6890 Z0.0000 N16530 X1.7212 Y0.6898 N16540 X1.7205 Y0.6906 Z-0.0003 N16550 X1.7198 Y0.6915 Z0.0000 N16560 X1.7191 Y0.6923 N16570 X1.7184 Y0.6931 Z-0.0004 N16580 X1.7195 Z-0.0013 N16590 X1.7206 Z-0.0020 N16600 X1.7635 Z-0.0589 N16610 X1.7646 Z-0.0600 N16620 X2.1526 N16630 X2.1537 Z-0.0584 N16640 X2.1867 Z-0.0013 N16650 X2.1878 Z-0.0000 N16660 Y0.6981 Z-0.0000 N16670 X2.1867 Z-0.0013 N16680 X2.1536 Z-0.0586 N16690 X2.1525 Z-0.0600 N16700 X1.7605 N16710 X1.7594 Z-0.0594 N16720 X1.7164 Z-0.0023 N16730 X1.7153 Z-0.0009 N16740 X1.7142 Z0.0000 N16750 X1.7135 Y0.6990 N16760 X1.7128 Y0.6998 Z-0.0005 N16770 X1.7114 Y0.7015 Z0.0000 N16780 X1.7101 Y0.7031 N16790 X1.7123 Z-0.0023 N16800 X1.7552 Z-0.0593 N16810 X1.7563 Z-0.0600 N16820 X2.1526 N16830 X2.1537 Z-0.0585 N16840 X2.1867 Z-0.0013 N16850 X2.1878 Z-0.0000 N16860 Y0.7081 Z-0.0000 N16870 X2.1867 Z-0.0013 N16880 X2.1537 Z-0.0585 N16890 X2.1526 Z-0.0600 N16900 X1.7521 N16910 X1.7510 Z-0.0588 N16920 X1.7070 Z-0.0002 N16930 X1.7059 Z0.0000 N16940 X1.7045 Y0.7098 N16950 X1.7038 Y0.7106 Z-0.0001 N16960 X1.7031 Y0.7114 Z0.0000 N16970 X1.7024 Y0.7123 N16980 X1.7017 Y0.7131 Z-0.0004 N16990 X1.7028 Z-0.0009 N17000 X1.7039 Z-0.0022 N17010 X1.7468 Z-0.0592 N17020 X1.7479 Z-0.0600 N17030 X2.1526 N17040 X2.1537 Z-0.0584 N17050 X2.1867 Z-0.0013 N17060 X2.1878 Z-0.0000 N17070 Y0.7181 Z-0.0000 N17080 X2.1867 Z-0.0013 N17090 X2.1537 Z-0.0584 N17100 X2.1526 Z-0.0600 N17110 X1.7437 N17120 X1.7426 Z-0.0588 N17130 X1.6997 Z-0.0020 N17140 X1.6986 Z-0.0009 N17150 X1.6975 Z-0.0001 N17160 X1.6968 Y0.7189 Z0.0000 N17170 X1.6961 Y0.7198 Z-0.0002 N17180 X1.6954 Y0.7206 Z-0.0003 N17190 X1.6947 Y0.7214 Z-0.0001 N17200 X1.6934 Y0.7231 Z0.0000 N17210 X1.6945 Z-0.0013 N17220 X1.6956 Z-0.0022 N17230 X1.7385 Z-0.0593 N17240 X1.7396 Z-0.0600 N17250 X2.1525 N17260 X2.1536 Z-0.0585 N17270 X2.1867 Z-0.0013 N17280 X2.1878 Z-0.0000 N17290 Y0.7281 Z-0.0000 N17300 X2.1867 Z-0.0013 N17310 X2.1537 Z-0.0585 N17320 X2.1526 Z-0.0600 N17330 X1.7354 N17340 X1.7343 Z-0.0592 N17350 X1.6903 Z-0.0006 N17360 X1.6892 Z-0.0001 N17370 X1.6885 Y0.7289 N17380 X1.6878 Y0.7298 Z0.0000 N17390 X1.6871 Y0.7306 N17400 X1.6864 Y0.7314 Z-0.0004 N17410 X1.6857 Y0.7323 Z0.0000 N17420 X1.6850 Y0.7331 N17430 X1.6861 Z-0.0006 N17440 X1.7301 Z-0.0591 N17450 X1.7312 Z-0.0600 N17460 X2.1526 N17470 X2.1537 Z-0.0585 N17480 X2.1867 Z-0.0013 N17490 X2.1878 Z-0.0000 N17500 Y0.7381 Z-0.0000 N17510 X2.1867 Z-0.0013 N17520 X2.1537 Z-0.0584 N17530 X2.1526 Z-0.0600 N17540 X1.7270 N17550 X1.7259 Z-0.0587 N17560 X1.6830 Z-0.0018 N17570 X1.6819 Z-0.0007 N17580 X1.6808 Z-0.0005 N17590 X1.6801 Y0.7389 Z0.0000 N17600 X1.6794 Y0.7398 N17610 X1.6787 Y0.7406 Z-0.0004 N17620 X1.6780 Y0.7414 Z-0.0001 N17630 X1.6766 Y0.7431 Z0.0000 N17640 X1.6777 Z-0.0010 N17650 X1.6788 Z-0.0023 N17660 X1.7217 Z-0.0593 N17670 X1.7228 Z-0.0600 N17680 X2.1526 N17690 X2.1537 Z-0.0584 N17700 X2.1867 Z-0.0013 N17710 X2.1878 Z-0.0000 N17720 Y0.7481 Z-0.0000 N17730 X2.1867 Z-0.0013 N17740 X2.1536 Z-0.0585 N17750 X2.1525 Z-0.0600 N17760 X1.7187 N17770 X1.7176 Z-0.0592 N17780 X1.6747 Z-0.0021 N17790 X1.6736 Z-0.0011 N17800 X1.6725 Z-0.0002 N17810 X1.6718 Y0.7489 Z0.0000 N17820 X1.6704 Y0.7506 N17830 X1.6697 Y0.7514 Z-0.0002 N17840 X1.6683 Y0.7531 Z0.0000 N17850 X1.6694 Z-0.0007 N17860 X1.7134 Z-0.0592 N17870 X1.7145 Z-0.0600 N17880 X2.1526 N17890 X2.1537 Z-0.0585 N17900 X2.1867 Z-0.0013 N17910 X2.1878 Z-0.0000 N17920 Y0.7581 Z-0.0000 N17930 X2.1867 Z-0.0013 N17940 X2.1537 Z-0.0585 N17950 X2.1526 Z-0.0600 N17960 X1.7103 N17970 X1.7092 Z-0.0591 N17980 X1.6663 Z-0.0020 N17990 X1.6652 Z-0.0009 N18000 X1.6641 Z-0.0000 N18010 X1.6634 Y0.7589 Z-0.0002 N18020 X1.6627 Y0.7597 Z0.0000 N18030 X1.6620 Y0.7606 Z-0.0003 N18040 X1.6613 Y0.7614 Z-0.0002 N18050 X1.6606 Y0.7622 Z0.0000 N18060 X1.6599 Y0.7631 N18070 X1.6610 Z-0.0006 N18080 X1.7050 Z-0.0589 N18090 X1.7061 Z-0.0600 N18100 X2.1526 N18110 X2.1537 Z-0.0584 N18120 X2.1867 Z-0.0013 N18130 X2.1878 Z-0.0000 N18140 Y0.7681 Z-0.0000 N18150 X2.1867 Z-0.0013 N18160 X2.1537 Z-0.0584 N18170 X2.1526 Z-0.0600 N18180 X1.7019 N18190 X1.7008 Z-0.0589 N18200 X1.6580 Z-0.0020 N18210 X1.6569 Z-0.0014 N18220 X1.6558 Z-0.0002 N18230 X1.6551 Y0.7689 Z0.0000 N18240 X1.6530 Y0.7714 N18250 X1.6523 Y0.7722 Z-0.0005 N18260 X1.6516 Y0.7730 Z0.0000 N18270 X1.6527 Z-0.0007 N18280 X1.6967 Z-0.0593 N18290 X1.6978 Z-0.0600 N18300 X2.1525 N18310 X2.1536 Z-0.0585 N18320 X2.1867 Z-0.0013 N18330 X2.1878 Z-0.0000 N18340 Y0.7780 Z-0.0000 N18350 X2.1867 Z-0.0013 N18360 X2.1537 Z-0.0585 N18370 X2.1526 Z-0.0600 N18380 X1.6936 N18390 X1.6925 Z-0.0593 N18400 X1.6507 Z-0.0038 N18410 X1.6485 Z-0.0010 N18420 X1.6474 Z0.0000 N18430 X1.6467 Y0.7789 Z-0.0006 N18440 X1.6460 Y0.7797 Z0.0000 N18450 X1.6453 Y0.7805 N18460 X1.6446 Y0.7814 Z-0.0003 N18470 X1.6439 Y0.7822 Z-0.0000 N18480 X1.6432 Y0.7830 N18490 X1.6443 Z-0.0002 N18500 X1.6883 Z-0.0586 N18510 X1.6894 Z-0.0600 N18520 X2.1526 N18530 X2.1537 Z-0.0585 N18540 X2.1867 Z-0.0013 N18550 X2.1878 Z-0.0000 N18560 Y0.7880 Z-0.0000 N18570 X2.1867 Z-0.0013 N18580 X2.1537 Z-0.0584 N18590 X2.1526 Z-0.0600 N18600 X1.6852 N18610 X1.6841 Z-0.0591 N18620 X1.6413 Z-0.0021 N18630 X1.6402 Z-0.0010 N18640 X1.6391 Z-0.0003 N18650 X1.6384 Y0.7889 Z-0.0001 N18660 X1.6370 Y0.7905 Z0.0000 N18670 X1.6363 Y0.7914 N18680 X1.6356 Y0.7922 Z-0.0003 N18690 X1.6349 Y0.7930 Z-0.0002 N18700 X1.6360 Z-0.0010 N18710 X1.6371 Z-0.0021 N18720 X1.6799 Z-0.0589 N18730 X1.6810 Z-0.0600 N18740 X2.1526 N18750 X2.1537 Z-0.0584 N18760 X2.1867 Z-0.0013 N18770 X2.1878 Z-0.0000 N18780 Y0.7980 Z-0.0000 N18790 X2.1867 Z-0.0013 N18800 X2.1536 Z-0.0585 N18810 X2.1525 Z-0.0600 N18820 X1.6769 N18830 X1.6758 Z-0.0593 N18840 X1.6340 Z-0.0037 N18850 X1.6318 Z-0.0011 N18860 X1.6307 Z0.0000 N18870 X1.6293 Y0.7997 Z-0.0003 N18880 X1.6286 Y0.8005 Z0.0000 N18890 X1.6279 Y0.8013 Z-0.0004 N18900 X1.6272 Y0.8022 Z-0.0001 N18910 X1.6265 Y0.8030 Z0.0000 N18920 X1.6276 Z-0.0005 N18930 X1.6716 Z-0.0590 N18940 X1.6727 Z-0.0600 N18950 X2.1526 N18960 X2.1537 Z-0.0585 N18970 X2.1867 Z-0.0013 N18980 X2.1878 Z-0.0000 N18990 Y0.8080 Z-0.0000 N19000 X2.1867 Z-0.0013 N19010 X2.1537 Z-0.0585 N19020 X2.1526 Z-0.0600 N19030 X1.6686 N19040 X1.6675 Z-0.0590 N19050 X1.6235 Z-0.0006 N19060 X1.6224 Z-0.0003 N19070 X1.6210 Y0.8097 Z0.0000 N19080 X1.6189 Y0.8122 N19090 X1.6182 Y0.8130 Z-0.0005 N19100 X1.6193 Z-0.0010 N19110 X1.6204 Z-0.0019 N19120 X1.6633 Z-0.0588 N19130 X1.6644 Z-0.0600 N19140 X2.1526 N19150 X2.1537 Z-0.0584 N19160 X2.1867 Z-0.0013 N19170 X2.1878 Z-0.0000 N19180 Y0.8180 Z-0.0000 N19190 X2.1867 Z-0.0013 N19200 X2.1536 Z-0.0586 N19210 X2.1525 Z-0.0600 N19220 X1.6603 N19230 X1.6592 Z-0.0594 N19240 X1.6173 Z-0.0038 N19250 X1.6162 Z-0.0024 N19260 X1.6140 Z0.0000 N19270 X1.6133 Y0.8188 N19280 X1.6126 Y0.8197 Z-0.0007 N19290 X1.6119 Y0.8205 Z-0.0000 N19300 X1.6112 Y0.8213 Z0.0000 N19310 X1.6105 Y0.8222 Z-0.0002 N19320 X1.6098 Y0.8230 Z0.0000 N19330 X1.6109 Z-0.0009 N19340 X1.6120 Z-0.0022 N19350 X1.6550 Z-0.0593 N19360 X1.6561 Z-0.0600 N19370 X2.1525 N19380 X2.1536 Z-0.0585 N19390 X2.1867 Z-0.0013 N19400 X2.1878 Z-0.0000 N19410 Y0.8280 Z-0.0000 N19420 X2.1867 Z-0.0013 N19430 X2.1537 Z-0.0585 N19440 X2.1526 Z-0.0600 N19450 X1.6519 N19460 X1.6508 Z-0.0590 N19470 X1.6067 Z-0.0005 N19480 X1.6056 Z0.0000 N19490 X1.6049 Y0.8288 Z-0.0002 N19500 X1.6043 Y0.8297 Z0.0000 N19510 X1.6036 Y0.8305 Z-0.0001 N19520 X1.6029 Y0.8313 Z0.0000 N19530 X1.6022 Y0.8321 N19540 X1.6015 Y0.8330 Z-0.0004 N19550 X1.6026 Z-0.0010 N19560 X1.6037 Z-0.0019 N19570 X1.6466 Z-0.0590 N19580 X1.6477 Z-0.0600 N19590 X2.1526 N19600 X2.1537 Z-0.0585 N19610 X2.1867 Z-0.0013 N19620 X2.1878 Z-0.0000 N19630 Y0.8380 Z-0.0000 N19640 X2.1867 Z-0.0013 N19650 X2.1537 Z-0.0584 N19660 X2.1526 Z-0.0600 N19670 X1.6435 N19680 X1.6424 Z-0.0590 N19690 X1.5995 Z-0.0021 N19700 X1.5984 Z-0.0009 N19710 X1.5973 Z0.0000 N19720 X1.5966 Y0.8388 N19730 X1.5952 Y0.8405 Z-0.0004 N19740 X1.5945 Y0.8413 Z0.0000 N19750 X1.5938 Y0.8421 Z-0.0003 N19760 X1.5931 Y0.8430 Z-0.0000 N19770 X1.5942 Z-0.0014 N19780 X1.5953 Z-0.0021 N19790 X1.6383 Z-0.0592 N19800 X1.6394 Z-0.0600 N19810 X2.1525 N19820 X2.1536 Z-0.0586 N19830 X2.1867 Z-0.0013 N19840 X2.1878 Z-0.0000 N19850 Y0.8480 Z-0.0000 N19860 X2.1867 Z-0.0013 N19870 X2.1537 Z-0.0585 N19880 X2.1526 Z-0.0600 N19890 X1.6352 N19900 X1.6341 Z-0.0591 N19910 X1.5900 Z-0.0005 N19920 X1.5889 Z0.0000 N19930 X1.5882 Y0.8488 Z-0.0003 N19940 X1.5875 Y0.8496 Z-0.0001 N19950 X1.5855 Y0.8521 Z0.0000 N19960 X1.5848 Y0.8530 N19970 X1.5859 Z-0.0008 N19980 X1.6299 Z-0.0593 N19990 X1.6310 Z-0.0600 N20000 X2.1526 N20010 X2.1537 Z-0.0585 N20020 X2.1867 Z-0.0013 N20030 X2.1878 Z-0.0000 N20040 Y0.8580 Z-0.0000 N20050 X2.1867 Z-0.0013 N20060 X2.1537 Z-0.0585 N20070 X2.1526 Z-0.0600 N20080 X1.6268 N20090 X1.6257 Z-0.0587 N20100 X1.5828 Z-0.0018 N20110 X1.5817 Z-0.0005 N20120 X1.5806 Z-0.0001 N20130 X1.5792 Y0.8596 Z0.0000 N20140 X1.5785 Y0.8604 Z-0.0006 N20150 X1.5778 Y0.8613 Z-0.0001 N20160 X1.5771 Y0.8621 Z-0.0000 N20170 X1.5764 Y0.8629 Z-0.0001 N20180 X1.5786 Z-0.0021 N20190 X1.6215 Z-0.0591 N20200 X1.6226 Z-0.0600 N20210 X2.1526 N20220 X2.1537 Z-0.0584 N20230 X2.1867 Z-0.0013 N20240 X2.1878 Z-0.0000 N20250 Y0.8679 Z-0.0000 N20260 X2.1867 Z-0.0013 N20270 X2.1536 Z-0.0585 N20280 X2.1525 Z-0.0600 N20290 X1.6185 N20300 X1.6174 Z-0.0592 N20310 X1.5744 Z-0.0022 N20320 X1.5733 Z-0.0009 N20330 X1.5722 Z-0.0002 N20340 X1.5715 Y0.8688 Z0.0000 N20350 X1.5708 Y0.8696 Z-0.0001 N20360 X1.5701 Y0.8704 Z0.0000 N20370 X1.5695 Y0.8713 Z-0.0002 N20380 X1.5688 Y0.8721 Z0.0000 N20390 X1.5681 Y0.8729 N20400 X1.5692 Z-0.0009 N20410 X1.6132 Z-0.0594 N20420 X1.6143 Z-0.0600 N20430 X2.1526 N20440 X2.1537 Z-0.0585 N20450 X2.1867 Z-0.0013 N20460 X2.1878 Z-0.0000 N20470 Y0.8779 Z-0.0000 N20480 X2.1867 Z-0.0013 N20490 X2.1537 Z-0.0585 N20500 X2.1526 Z-0.0600 N20510 X1.6101 N20520 X1.6090 Z-0.0589 N20530 X1.5661 Z-0.0018 N20540 X1.5650 Z-0.0004 N20550 X1.5639 Z-0.0000 N20560 X1.5625 Y0.8796 Z0.0000 N20570 X1.5618 Y0.8804 Z-0.0003 N20580 X1.5611 Y0.8813 Z-0.0004 N20590 X1.5604 Y0.8821 Z0.0000 N20600 X1.5597 Y0.8829 Z-0.0002 N20610 X1.5608 Z-0.0007 N20620 X1.6048 Z-0.0591 N20630 X1.6059 Z-0.0600 N20640 X2.1526 N20650 X2.1537 Z-0.0585 N20660 X2.1867 Z-0.0013 N20670 X2.1878 Z-0.0000 N20680 Y0.8879 Z-0.0000 N20690 X2.1867 Z-0.0013 N20700 X2.1537 Z-0.0584 N20710 X2.1526 Z-0.0600 N20720 X1.6017 N20730 X1.6006 Z-0.0589 N20740 X1.5577 Z-0.0020 N20750 X1.5566 Z-0.0013 N20760 X1.5555 Z-0.0004 N20770 X1.5548 Y0.8888 Z0.0000 N20780 X1.5541 Y0.8896 Z-0.0002 N20790 X1.5534 Y0.8904 Z0.0000 N20800 X1.5514 Y0.8929 N20810 X1.5525 Z-0.0010 N20820 X1.5965 Z-0.0594 N20830 X1.5976 Z-0.0600 N20840 X2.1525 N20850 X2.1536 Z-0.0585 N20860 X2.1867 Z-0.0013 N20870 X2.1878 Z-0.0000 N20880 Y0.8979 Z-0.0000 N20890 X2.1867 Z-0.0013 N20900 X2.1537 Z-0.0585 N20910 X2.1526 Z-0.0600 N20920 X1.5934 N20930 X1.5923 Z-0.0593 N20940 X1.5494 Z-0.0023 N20950 X1.5483 Z-0.0008 N20960 X1.5472 Z0.0000 N20970 X1.5465 Y0.8987 Z-0.0001 N20980 X1.5458 Y0.8996 Z0.0000 N20990 X1.5451 Y0.9004 N21000 X1.5444 Y0.9012 Z-0.0005 N21010 X1.5437 Y0.9021 Z-0.0002 N21020 X1.5430 Y0.9029 Z-0.0001 N21030 X1.5441 Z-0.0004 N21040 X1.5881 Z-0.0588 N21050 X1.5892 Z-0.0600 N21060 X2.1526 N21070 X2.1537 Z-0.0585 N21080 X2.1867 Z-0.0013 N21090 X2.1878 Z-0.0000 N21100 Y0.9079 Z-0.0000 N21110 X2.1867 Z-0.0013 N21120 X2.1537 Z-0.0585 N21130 X2.1526 Z-0.0600 N21140 X1.5850 N21150 X1.5839 Z-0.0589 N21160 X1.5410 Z-0.0019 N21170 X1.5399 Z-0.0012 N21180 X1.5388 Z-0.0005 N21190 X1.5374 Y0.9096 Z0.0000 N21200 X1.5367 Y0.9104 Z-0.0000 N21210 X1.5360 Y0.9112 Z0.0000 N21220 X1.5353 Y0.9121 Z-0.0002 N21230 X1.5346 Y0.9129 Z0.0000 N21240 X1.5357 Z-0.0010 N21250 X1.5368 Z-0.0022 N21260 X1.5797 Z-0.0591 N21270 X1.5808 Z-0.0600 N21280 X2.1526 N21290 X2.1537 Z-0.0584 N21300 X2.1867 Z-0.0013 N21310 X2.1878 Z-0.0000 N21320 Y0.9179 Z-0.0000 N21330 X2.1867 Z-0.0013 N21340 X2.1536 Z-0.0585 N21350 X2.1525 Z-0.0600 N21360 X1.5822 N21370 X1.5811 Z-0.0596 N21380 X1.5723 Z-0.0523 N21390 X1.5679 Z-0.0487 N21400 X1.5668 Z-0.0475 N21410 X1.5327 Z-0.0022 N21420 X1.5316 Z-0.0012 N21430 X1.5305 Z0.0000 N21440 X1.5298 Y0.9187 Z-0.0001 N21450 X1.5291 Y0.9196 Z0.0000 N21460 X1.5284 Y0.9204 N21470 X1.5277 Y0.9212 Z-0.0004 N21480 X1.5270 Y0.9220 Z-0.0003 N21490 X1.5263 Y0.9229 Z0.0000 N21500 X1.5274 Z-0.0003 N21510 X1.5428 Z-0.0208 N21520 X1.5527 Z-0.0284 N21530 X1.5604 Z-0.0344 N21540 X1.5703 Z-0.0424 N21550 X1.5813 Z-0.0517 N21560 X1.5901 Z-0.0593 N21570 X1.5912 Z-0.0600 N21580 X2.1526 N21590 X2.1537 Z-0.0585 N21600 X2.1867 Z-0.0013 N21610 X2.1878 Z-0.0000 N21620 Y0.9279 Z-0.0000 N21630 X2.1867 Z-0.0013 N21640 X2.1537 Z-0.0585 N21650 X2.1526 Z-0.0600 N21660 X1.5992 N21670 X1.5981 Z-0.0593 N21680 X1.5860 Z-0.0485 N21690 X1.5772 Z-0.0409 N21700 X1.5673 Z-0.0326 N21710 X1.5574 Z-0.0246 N21720 X1.5464 Z-0.0160 N21730 X1.5398 Z-0.0110 N21740 X1.5265 Z-0.0015 N21750 X1.5254 Z-0.0013 N21760 X1.5243 Z-0.0006 N21770 X1.5232 Z-0.0003 N21780 X1.5242 Y0.9283 Z-0.0002 N21790 X1.5252 Y0.9288 Z0.0000 N21800 X1.5262 Y0.9292 Z-0.0002 N21810 X1.5272 Y0.9297 Z0.0000 N21820 X1.5292 Y0.9306 Z-0.0000 N21830 X1.5302 Y0.9311 Z0.0000 N21840 X1.5312 Y0.9315 Z-0.0005 N21850 X1.5322 Y0.9320 Z0.0000 N21860 X1.5332 Y0.9324 Z-0.0004 N21870 X1.5342 Y0.9329 Z0.0000 N21880 X1.5353 Z-0.0001 N21890 X1.5364 Z-0.0005 N21900 X1.5463 Z-0.0080 N21910 X1.5562 Z-0.0157 N21920 X1.5650 Z-0.0228 N21930 X1.5760 Z-0.0320 N21940 X1.5848 Z-0.0397 N21950 X1.5958 Z-0.0495 N21960 X1.6046 Z-0.0576 N21970 X1.6068 Z-0.0597 N21980 X1.6079 Z-0.0600 N21990 X2.1526 N22000 X2.1537 Z-0.0585 N22010 X2.1867 Z-0.0013 N22020 X2.1878 Z-0.0000 N22030 Y0.9379 Z-0.0000 N22040 X2.1867 Z-0.0013 N22050 X2.1537 Z-0.0584 N22060 X2.1526 Z-0.0600 N22070 X1.6149 N22080 X1.6138 Z-0.0595 N22090 X1.6028 Z-0.0491 N22100 X1.5918 Z-0.0389 N22110 X1.5808 Z-0.0291 N22120 X1.5721 Z-0.0215 N22130 X1.5622 Z-0.0132 N22140 X1.5534 Z-0.0061 N22150 X1.5479 Z-0.0018 N22160 X1.5468 Z-0.0013 N22170 X1.5457 Z-0.0010 N22180 X1.5446 Z-0.0002 N22190 X1.5455 Y0.9383 Z-0.0000 N22200 X1.5464 Y0.9388 Z-0.0002 N22210 X1.5473 Y0.9392 N22220 X1.5482 Y0.9397 Z0.0000 N22230 X1.5491 Y0.9402 Z-0.0002 N22240 X1.5501 Y0.9406 Z0.0000 N22250 X1.5510 Y0.9411 Z-0.0002 N22260 X1.5518 Y0.9415 Z-0.0002 N22270 X1.5526 Y0.9420 Z0.0000 N22280 X1.5535 Y0.9424 Z-0.0003 N22290 X1.5543 Y0.9429 Z0.0000 N22300 X1.5554 Z-0.0004 N22310 X1.5598 Z-0.0039 N22320 X1.5708 Z-0.0131 N22330 X1.5796 Z-0.0208 N22340 X1.5895 Z-0.0296 N22350 X1.5983 Z-0.0377 N22360 X1.6093 Z-0.0481 N22370 X1.6192 Z-0.0578 N22380 X1.6214 Z-0.0599 N22390 X1.6247 Z-0.0600 N22400 X1.7391 N22410 X1.8688 N22420 X1.9975 N22430 X2.1229 N22440 X2.1526 N22450 X2.1537 Z-0.0584 N22460 X2.1867 Z-0.0013 N22470 X2.1878 Z-0.0000 N22480 Y0.9479 Z-0.0000 N22490 X2.1867 Z-0.0013 N22500 X2.1536 Z-0.0585 N22510 X2.1525 Z-0.0600 N22520 X1.6285 N22530 X1.6274 Z-0.0590 N22540 X1.6152 Z-0.0469 N22550 X1.6042 Z-0.0362 N22560 X1.5932 Z-0.0258 N22570 X1.5844 Z-0.0177 N22580 X1.5734 Z-0.0079 N22590 X1.5657 Z-0.0012 N22600 X1.5646 Z-0.0009 N22610 X1.5635 Z-0.0001 N22620 X1.5644 Y0.9484 Z0.0000 N22630 X1.5653 Y0.9489 Z-0.0003 N22640 X1.5662 Y0.9494 Z0.0000 N22650 X1.5690 Y0.9510 N22660 X1.5718 Y0.9526 Z-0.0001 N22670 X1.5722 Y0.9528 Z0.0000 N22680 X1.5733 Z-0.0004 N22690 X1.5832 Z-0.0093 N22700 X1.5920 Z-0.0174 N22710 X1.6019 Z-0.0268 N22720 X1.6119 Z-0.0365 N22730 X1.6218 Z-0.0464 N22740 X1.6317 Z-0.0566 N22750 X1.6350 Z-0.0600 N22760 X1.7506 N22770 X1.8717 N22780 X2.0017 N22790 X2.1305 N22800 X2.1525 N22810 X2.1536 Z-0.0585 N22820 X2.1867 Z-0.0013 N22830 X2.1878 Z-0.0000 N22840 Y0.9578 Z-0.0000 N22850 X2.1867 Z-0.0013 N22860 X2.1537 Z-0.0585 N22870 X2.1526 Z-0.0600 N22880 X1.6421 N22890 X1.6410 Z-0.0591 N22900 X1.6311 Z-0.0486 N22910 X1.6212 Z-0.0383 N22920 X1.6113 Z-0.0284 N22930 X1.6014 Z-0.0186 N22940 X1.5915 Z-0.0092 N22950 X1.5827 Z-0.0009 N22960 X1.5816 Z-0.0008 N22970 X1.5805 Z-0.0002 N22980 X1.5814 Y0.9584 Z0.0000 N22990 X1.5823 Y0.9590 Z-0.0002 N23000 X1.5832 Y0.9595 Z0.0000 N23010 X1.5841 Y0.9601 Z-0.0006 N23020 X1.5850 Y0.9607 Z0.0000 N23030 X1.5867 Y0.9617 N23040 X1.5875 Y0.9623 Z-0.0005 N23050 X1.5883 Y0.9628 Z0.0000 N23060 X1.5894 Z-0.0005 N23070 X1.5916 Z-0.0024 N23080 X1.6015 Z-0.0120 N23090 X1.6147 Z-0.0252 N23100 X1.6246 Z-0.0353 N23110 X1.6356 Z-0.0468 N23120 X1.6455 Z-0.0575 N23130 X1.6477 Z-0.0599 N23140 X1.6488 Z-0.0600 N23150 X2.1526 N23160 X2.1537 Z-0.0585 N23170 X2.1867 Z-0.0013 N23180 X2.1878 Z-0.0000 N23190 Y0.9678 Z-0.0000 N23200 X2.1867 Z-0.0013 N23210 X2.1537 Z-0.0585 N23220 X2.1526 Z-0.0600 N23230 X1.6542 N23240 X1.6377 Z-0.0419 N23250 X1.6278 Z-0.0313 N23260 X1.6168 Z-0.0198 N23270 X1.6080 Z-0.0108 N23280 X1.5981 Z-0.0010 N23290 X1.5959 Z-0.0001 N23300 X1.5965 Y0.9683 Z0.0000 N23310 X1.5972 Y0.9687 Z-0.0004 N23320 X1.5978 Y0.9691 Z-0.0001 N23330 X1.5996 Y0.9704 Z0.0000 N23340 X1.6004 Y0.9710 Z-0.0005 N23350 X1.6013 Y0.9716 Z0.0000 N23360 X1.6022 Y0.9722 Z-0.0001 N23370 X1.6031 Y0.9728 Z0.0000 N23380 X1.6042 Z-0.0007 N23390 X1.6053 Z-0.0018 N23400 X1.6064 Z-0.0026 N23410 X1.6163 Z-0.0128 N23420 X1.6273 Z-0.0244 N23430 X1.6372 Z-0.0351 N23440 X1.6482 Z-0.0472 N23450 X1.6581 Z-0.0583 N23460 X1.6592 Z-0.0596 N23470 X1.6603 Z-0.0600 N23480 X2.1525 N23490 X2.1536 Z-0.0585 N23500 X2.1867 Z-0.0013 N23510 X2.1878 Z-0.0000 N23520 Y0.9778 Z-0.0000 N23530 X2.1867 Z-0.0013 N23540 X2.1537 Z-0.0585 N23550 X2.1526 Z-0.0600 N23560 X1.6661 N23570 X1.6650 Z-0.0595 N23580 X1.6496 Z-0.0418 N23590 X1.6397 Z-0.0308 N23600 X1.6287 Z-0.0187 N23610 X1.6199 Z-0.0093 N23620 X1.6122 Z-0.0013 N23630 X1.6111 Z-0.0004 N23640 X1.6100 Z-0.0002 N23650 X1.6103 Y0.9780 Z0.0000 N23660 X1.6118 Y0.9792 N23670 X1.6126 Y0.9798 Z-0.0005 N23680 X1.6134 Y0.9804 Z0.0000 N23690 X1.6142 Y0.9810 Z-0.0002 N23700 X1.6150 Y0.9816 Z0.0000 N23710 X1.6158 Y0.9822 Z-0.0004 N23720 X1.6166 Y0.9828 Z0.0000 N23730 X1.6177 Z-0.0006 N23740 X1.6276 Z-0.0112 N23750 X1.6386 Z-0.0233 N23760 X1.6496 Z-0.0357 N23770 X1.6606 Z-0.0484 N23780 X1.6705 Z-0.0600 N23790 X1.7839 Z-0.0600 N23800 X1.9159 N23810 X2.0491 N23820 X2.1526 N23830 X2.1537 Z-0.0585 N23840 X2.1867 Z-0.0013 N23850 X2.1878 Z-0.0000 N23860 Y0.9878 Z-0.0000 N23870 X2.1867 Z-0.0013 N23880 X2.1536 Z-0.0585 N23890 X2.1525 Z-0.0600 N23900 X1.6769 N23910 X1.6758 Z-0.0598 N23920 X1.6615 Z-0.0428 N23930 X1.6516 Z-0.0313 N23940 X1.6394 Z-0.0175 N23950 X1.6295 Z-0.0064 N23960 X1.6240 Z-0.0004 N23970 X1.6229 Z-0.0002 N23980 X1.6237 Y0.9884 Z-0.0002 N23990 X1.6245 Y0.9891 Z0.0000 N24000 X1.6260 Y0.9903 N24010 X1.6267 Y0.9909 Z-0.0002 N24020 X1.6275 Y0.9916 Z0.0000 N24030 X1.6283 Y0.9922 Z-0.0003 N24040 X1.6290 Y0.9928 Z-0.0004 N24050 X1.6301 Z-0.0008 N24060 X1.6312 Z-0.0016 N24070 X1.6411 Z-0.0128 N24080 X1.6521 Z-0.0255 N24090 X1.6631 Z-0.0384 N24100 X1.6741 Z-0.0516 N24110 X1.6807 Z-0.0596 N24120 X1.6818 Z-0.0600 N24130 X2.1526 N24140 X2.1537 Z-0.0584 N24150 X2.1867 Z-0.0013 N24160 X2.1878 Z-0.0000 N24170 Y0.9978 Z-0.0000 N24180 X2.1867 Z-0.0013 N24190 X2.1537 Z-0.0584 N24200 X2.1526 Z-0.0600 N24210 X1.6866 N24220 X1.6855 Z-0.0593 N24230 X1.6734 Z-0.0445 N24240 X1.6624 Z-0.0313 N24250 X1.6514 Z-0.0183 N24260 X1.6382 Z-0.0031 N24270 X1.6360 Z-0.0006 N24280 X1.6349 Z-0.0000 N24290 X1.6357 Y0.9985 Z-0.0006 N24300 X1.6365 Y0.9992 Z0.0000 N24310 X1.6373 Y0.9999 Z-0.0002 N24320 X1.6381 Y1.0007 Z-0.0002 N24330 X1.6390 Y1.0014 Z-0.0000 N24340 X1.6406 Y1.0028 Z0.0000 N24350 X1.6417 Z-0.0011 N24360 X1.6439 Z-0.0031 N24370 X1.6549 Z-0.0161 N24380 X1.6659 Z-0.0293 N24390 X1.6780 Z-0.0441 N24400 X1.6901 Z-0.0592 N24410 X1.6912 Z-0.0600 N24420 X2.1525 N24430 X2.1536 Z-0.0585 N24440 X2.1867 Z-0.0013 N24450 X2.1878 Z-0.0000 N24460 Y1.0078 Z-0.0000 N24470 X2.1867 Z-0.0013 N24480 X2.1536 Z-0.0585 N24490 X2.1525 Z-0.0600 N24500 X1.6956 N24510 X1.6945 Z-0.0589 N24520 X1.6824 Z-0.0436 N24530 X1.6659 Z-0.0231 N24540 X1.6548 Z-0.0098 N24550 X1.6471 Z-0.0006 N24560 X1.6460 Z0.0000 N24570 X1.6468 Y1.0085 Z-0.0006 N24580 X1.6475 Y1.0092 Z0.0000 N24590 X1.6483 Y1.0099 N24600 X1.6490 Y1.0106 Z-0.0004 N24610 X1.6498 Y1.0114 Z-0.0001 N24620 X1.6506 Y1.0121 Z-0.0001 N24630 X1.6513 Y1.0128 Z-0.0003 N24640 X1.6524 Z-0.0013 N24650 X1.6535 Z-0.0017 N24660 X1.6645 Z-0.0151 N24670 X1.6766 Z-0.0301 N24680 X1.6887 Z-0.0454 N24690 X1.6997 Z-0.0595 N24700 X1.7008 Z-0.0600 N24710 X2.1526 N24720 X2.1537 Z-0.0584 N24730 X2.1867 Z-0.0013 N24740 X2.1878 Z-0.0000 N24750 Y1.0178 Z-0.0000 N24760 X2.1867 Z-0.0013 N24770 X2.1537 Z-0.0585 N24780 X2.1526 Z-0.0600 N24790 X1.7048 N24800 X1.7037 Z-0.0589 N24810 X1.6905 Z-0.0417 N24820 X1.6773 Z-0.0249 N24830 X1.6663 Z-0.0111 N24840 X1.6575 Z-0.0002 N24850 X1.6564 Z-0.0001 N24860 X1.6571 Y1.0185 Z-0.0002 N24870 X1.6578 Y1.0192 Z-0.0002 N24880 X1.6585 Y1.0199 Z0.0000 N24890 X1.6592 Y1.0206 Z-0.0002 N24900 X1.6599 Y1.0213 Z-0.0002 N24910 X1.6606 Y1.0221 Z0.0000 N24920 X1.6613 Y1.0228 Z-0.0003 N24930 X1.6624 Z-0.0012 N24940 X1.6635 Z-0.0018 N24950 X1.6756 Z-0.0171 N24960 X1.6888 Z-0.0340 N24970 X1.7020 Z-0.0512 N24980 X1.7086 Z-0.0599 N24990 X1.7097 Z-0.0600 N25000 X2.1526 N25010 X2.1537 Z-0.0584 N25020 X2.1867 Z-0.0013 N25030 X2.1878 Z-0.0000 N25040 Y1.0278 Z-0.0000 N25050 X2.1867 Z-0.0013 N25060 X2.1537 Z-0.0585 N25070 X2.1526 Z-0.0600 N25080 X1.7134 N25090 X1.7123 Z-0.0596 N25100 X1.7002 Z-0.0434 N25110 X1.6870 Z-0.0261 N25120 X1.6749 Z-0.0104 N25130 X1.6672 Z-0.0006 N25140 X1.6661 Z0.0000 N25150 X1.6665 Y1.0282 Z-0.0005 N25160 X1.6669 Y1.0286 Z0.0000 N25170 X1.6675 Y1.0293 Z-0.0003 N25180 X1.6682 Y1.0300 Z0.0000 N25190 X1.6688 Y1.0307 Z-0.0003 N25200 X1.6694 Y1.0314 Z0.0000 N25210 X1.6707 Y1.0328 N25220 X1.6718 Z-0.0007 N25230 X1.6729 Z-0.0019 N25240 X1.6861 Z-0.0190 N25250 X1.7015 Z-0.0395 N25260 X1.7158 Z-0.0588 N25270 X1.7169 Z-0.0600 N25280 X2.1526 N25290 X2.1537 Z-0.0585 N25300 X2.1867 Z-0.0013 N25310 X2.1878 Z-0.0000 N25320 Y1.0378 Z-0.0000 N25330 X2.1867 Z-0.0013 N25340 X2.1537 Z-0.0585 N25350 X2.1526 Z-0.0600 N25360 X1.7213 N25370 X1.7202 Z-0.0594 N25380 X1.7037 Z-0.0369 N25390 X1.6916 Z-0.0207 N25400 X1.6773 Z-0.0019 N25410 X1.6762 Z-0.0005 N25420 X1.6751 Z-0.0001 N25430 X1.6758 Y1.0385 Z-0.0001 N25440 X1.6764 Y1.0392 Z-0.0006 N25450 X1.6771 Y1.0400 Z0.0000 N25460 X1.6777 Y1.0407 Z-0.0002 N25470 X1.6783 Y1.0414 Z0.0000 N25480 X1.6794 Y1.0427 N25490 X1.6805 Z-0.0005 N25500 X1.6915 Z-0.0151 N25510 X1.7069 Z-0.0360 N25520 X1.7213 Z-0.0557 N25530 X1.7235 Z-0.0587 N25540 X1.7246 Z-0.0600 N25550 X2.1526 N25560 X2.1537 Z-0.0585 N25570 X2.1867 Z-0.0013 N25580 X2.1878 Z-0.0000 N25590 Y1.0477 Z-0.0000 N25600 X2.1867 Z-0.0013 N25610 X2.1537 Z-0.0585 N25620 X2.1526 Z-0.0600 N25630 X1.7288 N25640 X1.7277 Z-0.0598 N25650 X1.7134 Z-0.0398 N25660 X1.7002 Z-0.0217 N25670 X1.6869 Z-0.0038 N25680 X1.6847 Z-0.0009 N25690 X1.6836 Z0.0000 N25700 X1.6856 Y1.0501 N25710 X1.6862 Y1.0509 Z-0.0003 N25720 X1.6869 Y1.0517 Z-0.0001 N25730 X1.6877 Y1.0527 Z-0.0003 N25740 X1.6899 Z-0.0020 N25750 X1.7031 Z-0.0200 N25760 X1.7174 Z-0.0398 N25770 X1.7316 Z-0.0599 N25780 X1.7327 Z-0.0600 N25790 X2.1526 N25800 X2.1537 Z-0.0584 N25810 X2.1867 Z-0.0013 N25820 X2.1878 Z-0.0000 N25830 Y1.0577 Z-0.0000 N25840 X2.1867 Z-0.0013 N25850 X2.1537 Z-0.0585 N25860 X2.1526 Z-0.0600 N25870 X1.7356 N25880 X1.7345 Z-0.0593 N25890 X1.7191 Z-0.0374 N25900 X1.7026 Z-0.0143 N25910 X1.6927 Z-0.0007 N25920 X1.6916 Z0.0000 N25930 X1.6920 Y1.0582 Z-0.0003 N25940 X1.6924 Y1.0588 Z0.0000 N25950 X1.6936 Y1.0603 N25960 X1.6942 Y1.0611 Z-0.0002 N25970 X1.6948 Y1.0619 Z0.0000 N25980 X1.6954 Y1.0627 Z-0.0001 N25990 X1.6976 Z-0.0022 N26000 X1.7152 Z-0.0267 N26010 X1.7306 Z-0.0486 N26020 X1.7383 Z-0.0596 N26030 X1.7394 Z-0.0600 N26040 X2.1526 N26050 X2.1537 Z-0.0584 N26060 X2.1867 Z-0.0013 N26070 X2.1878 Z-0.0000 N26080 Y1.0677 Z-0.0000 N26090 X2.1867 Z-0.0013 N26100 X2.1537 Z-0.0585 N26110 X2.1526 Z-0.0600 N26120 X1.7420 N26130 X1.7409 Z-0.0590 N26140 X1.7277 Z-0.0400 N26150 X1.7123 Z-0.0180 N26160 X1.7024 Z-0.0040 N26170 X1.7002 Z-0.0011 N26180 X1.6991 Z0.0000 N26190 X1.7004 Y1.0694 N26200 X1.7010 Y1.0703 Z-0.0004 N26210 X1.7022 Y1.0719 Z0.0000 N26220 X1.7027 Y1.0727 Z-0.0002 N26230 X1.7038 Z-0.0003 N26240 X1.7192 Z-0.0223 N26250 X1.7346 Z-0.0445 N26260 X1.7445 Z-0.0590 N26270 X1.7456 Z-0.0600 N26280 X2.1526 N26290 X2.1537 Z-0.0585 N26300 X2.1867 Z-0.0013 N26310 X2.1878 Z-0.0000 N26320 Y1.0777 Z-0.0000 N26330 X2.1867 Z-0.0013 N26340 X2.1537 Z-0.0584 N26350 X2.1526 Z-0.0600 N26360 X1.7491 N26370 X1.7480 Z-0.0600 N26380 X1.7293 Z-0.0325 N26390 X1.7150 Z-0.0118 N26400 X1.7084 Z-0.0023 N26410 X1.7073 Z-0.0011 N26420 X1.7062 Z-0.0005 N26430 X1.7067 Y1.0785 Z0.0000 N26440 X1.7079 Y1.0802 N26450 X1.7084 Y1.0810 Z-0.0005 N26460 X1.7090 Y1.0819 Z0.0000 N26470 X1.7096 Y1.0827 N26480 X1.7107 Z-0.0007 N26490 X1.7205 Z-0.0150 N26500 X1.7436 Z-0.0488 N26510 X1.7502 Z-0.0586 N26520 X1.7513 Z-0.0600 N26530 X2.1526 N26540 X2.1537 Z-0.0584 N26550 X2.1867 Z-0.0013 N26560 X2.1878 Z-0.0000 N26570 Y1.0877 Z-0.0000 N26580 X2.1867 Z-0.0013 N26590 X2.1537 Z-0.0584 N26600 X2.1526 Z-0.0600 N26610 X1.7546 N26620 X1.7535 Z-0.0593 N26630 X1.7359 Z-0.0330 N26640 X1.7150 Z-0.0023 N26650 X1.7139 Z-0.0012 N26660 X1.7128 Z-0.0006 N26670 X1.7134 Y1.0886 Z0.0000 N26680 X1.7140 Y1.0895 Z-0.0001 N26690 X1.7145 Y1.0903 Z0.0000 N26700 X1.7150 Y1.0911 Z-0.0005 N26710 X1.7155 Y1.0919 Z0.0000 N26720 X1.7160 Y1.0927 Z-0.0003 N26730 X1.7171 Z-0.0006 N26740 X1.7325 Z-0.0233 N26750 X1.7523 Z-0.0528 N26760 X1.7567 Z-0.0594 N26770 X1.7578 Z-0.0600 N26780 X2.1526 N26790 X2.1537 Z-0.0584 N26800 X2.1867 Z-0.0013 N26810 X2.1878 Z-0.0000 N26820 Y1.0977 Z-0.0000 N26830 X2.1867 Z-0.0013 N26840 X2.1537 Z-0.0585 N26850 X2.1526 Z-0.0600 N26860 X1.7598 N26870 X1.7587 Z-0.0588 N26880 X1.7433 Z-0.0355 N26890 X1.7257 Z-0.0092 N26900 X1.7202 Z-0.0010 N26910 X1.7191 Z0.0000 N26920 X1.7196 Y1.0985 Z-0.0002 N26930 X1.7201 Y1.0994 Z0.0000 N26940 X1.7206 Y1.1002 Z-0.0001 N26950 X1.7211 Y1.1010 Z0.0000 N26960 X1.7216 Y1.1018 Z-0.0005 N26970 X1.7221 Y1.1027 Z0.0000 N26980 X1.7232 Z-0.0012 N26990 X1.7430 Z-0.0309 N27000 X1.7617 Z-0.0594 N27010 X1.7628 Z-0.0600 N27020 X2.1525 N27030 X2.1536 Z-0.0585 N27040 X2.1867 Z-0.0013 N27050 X2.1878 Z-0.0000 N27060 Y1.1077 Z-0.0000 N27070 X2.1867 Z-0.0013 N27080 X2.1537 Z-0.0584 N27090 X2.1526 Z-0.0600 N27100 X1.7656 N27110 X1.7645 Z-0.0591 N27120 X1.7436 Z-0.0272 N27130 X1.7272 Z-0.0023 N27140 X1.7261 Z-0.0009 N27150 X1.7250 Z-0.0006 N27160 X1.7254 Y1.1085 Z0.0000 N27170 X1.7259 Y1.1093 Z-0.0003 N27180 X1.7264 Y1.1101 Z-0.0001 N27190 X1.7268 Y1.1109 Z0.0000 N27200 X1.7273 Y1.1118 Z-0.0002 N27210 X1.7278 Y1.1127 Z0.0000 N27220 X1.7289 Z-0.0009 N27230 X1.7465 Z-0.0278 N27240 X1.7641 Z-0.0548 N27250 X1.7674 Z-0.0599 N27260 X1.7685 Z-0.0600 N27270 X2.1526 N27280 X2.1537 Z-0.0585 N27290 X2.1867 Z-0.0013 N27300 X2.1878 Z-0.0000 N27310 Y1.1177 Z-0.0000 N27320 X2.1867 Z-0.0013 N27330 X2.1537 Z-0.0584 N27340 X2.1526 Z-0.0600 N27350 X1.7712 N27360 X1.7701 Z-0.0599 N27370 X1.7514 Z-0.0310 N27380 X1.7327 Z-0.0023 N27390 X1.7316 Z-0.0010 N27400 X1.7305 Z-0.0004 N27410 X1.7310 Y1.1185 Z0.0000 N27420 X1.7314 Y1.1193 Z-0.0004 N27430 X1.7319 Y1.1202 Z0.0000 N27440 X1.7323 Y1.1210 N27450 X1.7328 Y1.1218 Z-0.0004 N27460 X1.7332 Y1.1227 Z0.0000 N27470 X1.7343 Z-0.0012 N27480 X1.7541 Z-0.0317 N27490 X1.7717 Z-0.0592 N27500 X1.7728 Z-0.0600 N27510 X2.1526 N27520 X2.1537 Z-0.0585 N27530 X2.1867 Z-0.0013 N27540 X2.1878 Z-0.0000 N27550 Y1.1277 Z-0.0000 N27560 X2.1867 Z-0.0013 N27570 X2.1537 Z-0.0584 N27580 X2.1526 Z-0.0600 N27590 X1.7754 N27600 X1.7743 Z-0.0589 N27610 X1.7567 Z-0.0313 N27620 X1.7369 Z-0.0005 N27630 X1.7358 Z-0.0002 N27640 X1.7362 Y1.1285 Z-0.0002 N27650 X1.7367 Y1.1294 Z0.0000 N27660 X1.7371 Y1.1303 Z-0.0002 N27670 X1.7375 Y1.1311 Z0.0000 N27680 X1.7379 Y1.1319 Z-0.0000 N27690 X1.7383 Y1.1326 Z-0.0002 N27700 X1.7394 Z-0.0011 N27710 X1.7581 Z-0.0303 N27720 X1.7767 Z-0.0597 N27730 X1.7778 Z-0.0600 N27740 X2.1526 N27750 X2.1537 Z-0.0584 N27760 X2.1867 Z-0.0013 N27770 X2.1878 Z-0.0000 N27780 Y1.1376 Z-0.0000 N27790 X2.1867 Z-0.0013 N27800 X2.1536 Z-0.0585 N27810 X2.1525 Z-0.0600 N27820 X1.7792 N27830 X1.7550 Z-0.0217 N27840 X1.7429 Z-0.0027 N27850 X1.7418 Z-0.0013 N27860 X1.7407 Z-0.0001 N27870 X1.7411 Y1.1384 Z0.0000 N27880 X1.7415 Y1.1393 Z-0.0004 N27890 X1.7419 Y1.1401 Z0.0000 N27900 X1.7423 Y1.1410 N27910 X1.7426 Y1.1418 Z-0.0005 N27920 X1.7430 Y1.1426 Z0.0000 N27930 X1.7452 Z-0.0029 N27940 X1.7706 Z-0.0430 N27950 X1.7805 Z-0.0588 N27960 X1.7816 Z-0.0600 N27970 X2.1525 N27980 X2.1536 Z-0.0585 N27990 X2.1867 Z-0.0013 N28000 X2.1878 Z-0.0000 N28010 Y1.1476 Z-0.0000 N28020 X2.1867 Z-0.0013 N28030 X2.1537 Z-0.0585 N28040 X2.1526 Z-0.0600 N28050 X1.7838 N28060 X1.7827 Z-0.0590 N28070 X1.7596 Z-0.0220 N28080 X1.7464 Z-0.0010 N28090 X1.7453 Z0.0000 N28100 X1.7457 Y1.1486 Z-0.0003 N28110 X1.7461 Y1.1495 Z-0.0003 N28120 X1.7465 Y1.1505 Z0.0000 N28130 X1.7470 Y1.1515 Z-0.0005 N28140 X1.7474 Y1.1524 Z0.0000 N28150 X1.7475 Y1.1526 N28160 X1.7497 Z-0.0029 N28170 X1.7706 Z-0.0364 N28180 X1.7849 Z-0.0594 N28190 X1.7860 Z-0.0600 N28200 X2.1526 N28210 X2.1537 Z-0.0585 N28220 X2.1867 Z-0.0013 N28230 X2.1878 Z-0.0000 N28240 Y1.1576 Z-0.0000 N28250 X2.1867 Z-0.0013 N28260 X2.1536 Z-0.0585 N28270 X2.1525 Z-0.0600 N28280 X1.7881 N28290 X1.7870 Z-0.0597 N28300 X1.7672 Z-0.0277 N28310 X1.7518 Z-0.0029 N28320 X1.7507 Z-0.0013 N28330 X1.7496 Z0.0000 N28340 X1.7499 Y1.1583 N28350 X1.7502 Y1.1591 Z-0.0005 N28360 X1.7506 Y1.1600 Z0.0000 N28370 X1.7509 Y1.1609 N28380 X1.7512 Y1.1617 Z-0.0004 N28390 X1.7516 Y1.1626 Z-0.0002 N28400 X1.7527 Z-0.0014 N28410 X1.7538 Z-0.0028 N28420 X1.7769 Z-0.0400 N28430 X1.7890 Z-0.0597 N28440 X1.7900 Z-0.0600 N28450 X2.1526 N28460 X2.1537 Z-0.0584 N28470 X2.1867 Z-0.0013 N28480 X2.1878 Z-0.0000 N28490 Y1.1676 Z-0.0000 N28500 X2.1867 Z-0.0013 N28510 X2.1537 Z-0.0584 N28520 X2.1526 Z-0.0600 N28530 X1.7920 N28540 X1.7909 Z-0.0599 N28550 X1.7657 Z-0.0187 N28560 X1.7547 Z-0.0009 N28570 X1.7536 Z-0.0003 N28580 X1.7539 Y1.1686 Z0.0000 N28590 X1.7543 Y1.1695 N28600 X1.7547 Y1.1705 Z-0.0005 N28610 X1.7550 Y1.1715 Z-0.0000 N28620 X1.7554 Y1.1726 Z0.0000 N28630 X1.7565 Z-0.0012 N28640 X1.7841 Z-0.0461 N28650 X1.7918 Z-0.0587 N28660 X1.7929 Z-0.0600 N28670 X2.1526 N28680 X2.1537 Z-0.0585 N28690 X2.1867 Z-0.0013 N28700 X2.1878 Z-0.0000 N28710 Y1.1776 Z-0.0000 N28720 X2.1867 Z-0.0013 N28730 X2.1536 Z-0.0585 N28740 X2.1525 Z-0.0600 N28750 X1.7947 N28760 X1.7936 Z-0.0590 N28770 X1.7671 Z-0.0156 N28780 X1.7594 Z-0.0030 N28790 X1.7572 Z0.0000 N28800 X1.7575 Y1.1784 N28810 X1.7578 Y1.1792 Z-0.0002 N28820 X1.7581 Y1.1800 Z-0.0002 N28830 X1.7584 Y1.1808 Z0.0000 N28840 X1.7587 Y1.1817 N28850 X1.7590 Y1.1826 Z-0.0004 N28860 X1.7601 Z-0.0009 N28870 X1.7843 Z-0.0407 N28880 X1.7953 Z-0.0589 N28890 X1.7964 Z-0.0600 N28900 X2.1526 N28910 X2.1537 Z-0.0584 N28920 X2.1867 Z-0.0013 N28930 X2.1878 Z-0.0000 N28940 Y1.1876 Z-0.0000 N28950 X2.1867 Z-0.0013 N28960 X2.1536 Z-0.0585 N28970 X2.1525 Z-0.0600 N28980 X1.7981 N28990 X1.7970 Z-0.0596 N29000 X1.7628 Z-0.0032 N29010 X1.7617 Z-0.0014 N29020 X1.7606 Z0.0000 N29030 X1.7610 Y1.1886 N29040 X1.7613 Y1.1896 Z-0.0003 N29050 X1.7616 Y1.1906 Z0.0000 N29060 X1.7619 Y1.1916 N29070 X1.7622 Y1.1926 Z-0.0002 N29080 X1.7633 Z-0.0008 N29090 X1.7919 Z-0.0483 N29100 X1.7985 Z-0.0593 N29110 X1.7996 Z-0.0600 N29120 X2.1526 N29130 X2.1537 Z-0.0584 N29140 X2.1867 Z-0.0013 N29150 X2.1878 Z-0.0000 N29160 Y1.1976 Z-0.0000 N29170 X2.1867 Z-0.0013 N29180 X2.1537 Z-0.0583 N29190 X2.1526 Z-0.0600 N29200 X1.8011 N29210 X1.8000 Z-0.0598 N29220 X1.7714 Z-0.0122 N29230 X1.7648 Z-0.0012 N29240 X1.7637 Z0.0000 N29250 X1.7643 Y1.1994 N29260 X1.7646 Y1.2004 Z-0.0004 N29270 X1.7648 Y1.2013 Z-0.0002 N29280 X1.7650 Y1.2019 Z0.0000 N29290 X1.7652 Y1.2026 N29300 X1.7663 Z-0.0012 N29310 X1.7960 Z-0.0509 N29320 X1.8004 Z-0.0583 N29330 X1.8015 Z-0.0600 N29340 X2.1526 N29350 X2.1537 Z-0.0585 N29360 X2.1867 Z-0.0013 N29370 X2.1878 Z-0.0000 N29380 Y1.2076 Z-0.0000 N29390 X2.1867 Z-0.0013 N29400 X2.1537 Z-0.0584 N29410 X2.1526 Z-0.0600 N29420 X1.8039 N29430 X1.8028 Z-0.0600 N29440 X1.7753 Z-0.0138 N29450 X1.7676 Z-0.0009 N29460 X1.7665 Z-0.0001 N29470 X1.7667 Y1.2083 Z-0.0004 N29480 X1.7670 Y1.2091 N29490 X1.7672 Y1.2098 Z0.0000 N29500 X1.7676 Y1.2116 Z-0.0000 N29510 X1.7679 Y1.2126 Z-0.0003 N29520 X1.7690 Z-0.0009 N29530 X1.8030 Z-0.0582 N29540 X1.8041 Z-0.0600 N29550 X2.1526 N29560 X2.1537 Z-0.0584 N29570 X2.1867 Z-0.0013 N29580 X2.1878 Z-0.0000 N29590 Y1.2176 Z-0.0000 N29600 X2.1867 Z-0.0013 N29610 X2.1537 Z-0.0584 N29620 X2.1526 Z-0.0600 N29630 X1.8054 N29640 X1.8043 Z-0.0586 N29650 X1.7702 Z-0.0012 N29660 X1.7691 Z-0.0003 N29670 X1.7693 Y1.2186 Z0.0000 N29680 X1.7698 Y1.2206 N29690 X1.7700 Y1.2215 Z-0.0004 N29700 X1.7703 Y1.2225 Z-0.0000 N29710 X1.7714 Z-0.0011 N29720 X1.8054 Z-0.0586 N29730 X1.8065 Z-0.0600 N29740 X2.1526 N29750 X2.1537 Z-0.0584 N29760 X2.1867 Z-0.0013 N29770 X2.1878 Z-0.0000 N29780 Y1.2275 Z-0.0000 N29790 X2.1867 Z-0.0013 N29800 X2.1537 Z-0.0584 N29810 X2.1526 Z-0.0600 N29820 X1.8076 N29830 X1.8065 Z-0.0590 N29840 X1.7780 Z-0.0106 N29850 X1.7725 Z-0.0013 N29860 X1.7714 Z-0.0002 N29870 X1.7716 Y1.2286 Z0.0000 N29880 X1.7720 Y1.2307 Z-0.0000 N29890 X1.7722 Y1.2316 Z-0.0005 N29900 X1.7724 Y1.2325 Z-0.0002 N29910 X1.7735 Z-0.0011 N29920 X1.8076 Z-0.0589 N29930 X1.8087 Z-0.0600 N29940 X2.1526 N29950 X2.1537 Z-0.0584 N29960 X2.1867 Z-0.0013 N29970 X2.1878 Z-0.0000 N29980 Y1.2375 Z-0.0000 N29990 X2.1867 Z-0.0013 N30000 X2.1537 Z-0.0584 N30010 X2.1526 Z-0.0600 N30020 X1.8096 N30030 X1.8085 Z-0.0592 N30040 X1.7778 Z-0.0068 N30050 X1.7745 Z-0.0012 N30060 X1.7734 Z-0.0006 N30070 X1.7735 Y1.2385 Z-0.0002 N30080 X1.7737 Y1.2394 Z0.0000 N30090 X1.7741 Y1.2415 N30100 X1.7743 Y1.2425 Z-0.0001 N30110 X1.7754 Z-0.0009 N30120 X1.8062 Z-0.0535 N30130 X1.8095 Z-0.0591 N30140 X1.8106 Z-0.0600 N30150 X2.1526 N30160 X2.1537 Z-0.0584 N30170 X2.1867 Z-0.0013 N30180 X2.1878 Z-0.0000 N30190 Y1.2475 Z-0.0000 N30200 X2.1867 Z-0.0013 N30210 X2.1537 Z-0.0585 N30220 X2.1526 Z-0.0600 N30230 X1.8114 N30240 X1.8103 Z-0.0598 N30250 X1.7762 Z-0.0014 N30260 X1.7751 Z0.0000 N30270 X1.7753 Y1.2485 N30280 X1.7754 Y1.2495 Z-0.0002 N30290 X1.7756 Y1.2505 Z-0.0005 N30300 X1.7759 Y1.2525 Z0.0000 N30310 X1.7770 Z-0.0013 N30320 X1.7968 Z-0.0352 N30330 X1.8111 Z-0.0598 N30340 X1.8122 Z-0.0600 N30350 X2.1525 N30360 X2.1536 Z-0.0586 N30370 X2.1867 Z-0.0013 N30380 X2.1878 Z-0.0000 N30390 Y1.2575 Z-0.0000 N30400 X2.1867 Z-0.0013 N30410 X2.1537 Z-0.0584 N30420 X2.1526 Z-0.0600 N30430 X1.8129 N30440 X1.8118 Z-0.0596 N30450 X1.7777 Z-0.0011 N30460 X1.7766 Z-0.0004 N30470 X1.7767 Y1.2583 Z-0.0005 N30480 X1.7769 Y1.2600 Z0.0000 N30490 X1.7772 Y1.2625 N30500 X1.7783 Z-0.0014 N30510 X1.8114 Z-0.0583 N30520 X1.8125 Z-0.0600 N30530 X2.1526 N30540 X2.1537 Z-0.0585 N30550 X2.1867 Z-0.0013 N30560 X2.1878 Z-0.0000 N30570 Y1.2675 Z-0.0000 N30580 X2.1867 Z-0.0013 N30590 X2.1537 Z-0.0584 N30600 X2.1526 Z-0.0600 N30610 X1.8141 N30620 X1.8130 Z-0.0597 N30630 X1.7789 Z-0.0011 N30640 X1.7778 Z-0.0005 N30650 X1.7781 Y1.2697 Z-0.0001 N30660 X1.7782 Y1.2706 Z0.0000 N30670 X1.7784 Y1.2725 N30680 X1.7795 Z-0.0014 N30690 X1.8125 Z-0.0584 N30700 X1.8136 Z-0.0600 N30710 X2.1526 N30720 X2.1537 Z-0.0585 N30730 X2.1867 Z-0.0013 N30740 X2.1878 Z-0.0000 N30750 Y1.2775 Z-0.0000 N30760 X2.1867 Z-0.0013 N30770 X2.1537 Z-0.0584 N30780 X2.1526 Z-0.0600 N30790 X1.8151 N30800 X1.8140 Z-0.0598 N30810 X1.7799 Z-0.0010 N30820 X1.7788 Z-0.0005 N30830 X1.7789 Y1.2785 Z-0.0005 N30840 X1.7791 Y1.2815 Z-0.0001 N30850 X1.7792 Y1.2825 Z0.0000 N30860 X1.7803 Z-0.0014 N30870 X1.8134 Z-0.0584 N30880 X1.8145 Z-0.0600 N30890 X2.1525 N30900 X2.1536 Z-0.0586 N30910 X2.1867 Z-0.0013 N30920 X2.1878 Z-0.0000 N30930 Y1.2875 Z-0.0000 N30940 X2.1867 Z-0.0013 N30950 X2.1537 Z-0.0585 N30960 X2.1526 Z-0.0600 N30970 X1.8148 N30980 X1.8137 Z-0.0583 N30990 X1.7807 Z-0.0012 N31000 X1.7796 Z0.0000 N31010 X1.7798 Y1.2905 Z-0.0001 N31020 X1.7799 Y1.2925 Z-0.0003 N31030 X1.7810 Z-0.0010 N31040 X1.8150 Z-0.0600 N31050 X1.9294 Z-0.0600 N31060 X2.0492 N31070 X2.1526 N31080 X2.1537 Z-0.0584 N31090 X2.1867 Z-0.0013 N31100 X2.1878 Z-0.0000 N31110 Y1.2975 Z-0.0000 N31120 X2.1867 Z-0.0013 N31130 X2.1537 Z-0.0584 N31140 X2.1526 Z-0.0600 N31150 X1.8152 N31160 X1.7812 Z-0.0011 N31170 X1.7801 Z-0.0003 N31180 X1.7801 Y1.2985 Z-0.0003 N31190 X1.7802 Y1.2995 N31200 X1.7803 Y1.3025 Z-0.0001 N31210 X1.7814 Z-0.0013 N31220 X1.8143 Z-0.0583 N31230 X1.8154 Z-0.0600 N31240 X2.1526 N31250 X2.1537 Z-0.0583 N31260 X2.1867 Z-0.0013 N31270 X2.1878 Z-0.0000 N31280 Y1.3075 Z-0.0000 N31290 X2.1867 Z-0.0013 N31300 X2.1536 Z-0.0585 N31310 X2.1525 Z-0.0600 N31320 X1.8156 N31330 X1.8145 Z-0.0586 N31340 X1.7826 Z-0.0033 N31350 X1.7815 Z-0.0015 N31360 X1.7804 Z0.0000 N31370 X1.7804 Y1.3124 N31380 X1.7826 Z-0.0033 N31390 X1.8145 Z-0.0586 N31400 X1.8156 Z-0.0600 N31410 X2.1525 N31420 X2.1536 Z-0.0585 N31430 X2.1867 Z-0.0013 N31440 X2.1878 Z-0.0000 N31450 Y1.3174 Z-0.0000 N31460 X2.1867 Z-0.0013 N31470 X2.1536 Z-0.0585 N31480 X2.1525 Z-0.0600 N31490 X1.8157 N31500 X1.8146 Z-0.0586 N31510 X1.7826 Z-0.0033 N31520 X1.7804 Z0.0000 N31530 X1.7804 Y1.3224 N31540 X1.7815 Z-0.0015 N31550 X1.7837 Z-0.0052 N31560 X1.8145 Z-0.0586 N31570 X1.8156 Z-0.0600 N31580 X2.1525 N31590 X2.1536 Z-0.0585 N31600 X2.1867 Z-0.0013 N31610 X2.1878 Z-0.0000 N31620 Y1.3274 Z-0.0000 N31630 X2.1867 Z-0.0013 N31640 X2.1537 Z-0.0583 N31650 X2.1526 Z-0.0600 N31660 X1.8154 N31670 X1.8143 Z-0.0583 N31680 X1.7814 Z-0.0013 N31690 X1.7803 Z-0.0001 N31700 X1.7801 Y1.3324 Z-0.0003 N31710 X1.7812 Z-0.0012 N31720 X1.8142 Z-0.0582 N31730 X1.8153 Z-0.0600 N31740 X2.1526 N31750 X2.1537 Z-0.0584 N31760 X2.1867 Z-0.0013 N31770 X2.1878 Z-0.0000 N31780 Y1.3374 Z-0.0000 N31790 X2.1867 Z-0.0013 N31800 X2.1537 Z-0.0584 N31810 X2.1526 Z-0.0600 N31820 X1.8151 N31830 X1.7810 Z-0.0011 N31840 X1.7799 Z-0.0004 N31850 X1.7797 Y1.3404 Z-0.0000 N31860 X1.7796 Y1.3424 Z0.0000 N31870 X1.7807 Z-0.0011 N31880 X1.8137 Z-0.0582 N31890 X1.8148 Z-0.0600 N31900 X2.1526 N31910 X2.1537 Z-0.0585 N31920 X2.1867 Z-0.0013 N31930 X2.1878 Z-0.0000 N31940 Y1.3474 Z-0.0000 N31950 X2.1867 Z-0.0013 N31960 X2.1536 Z-0.0585 N31970 X2.1525 Z-0.0600 N31980 X1.8145 N31990 X1.8134 Z-0.0585 N32000 X1.7815 Z-0.0033 N32010 X1.7793 Z0.0000 N32020 X1.7792 Y1.3487 N32030 X1.7791 Y1.3506 Z-0.0002 N32040 X1.7790 Y1.3515 Z-0.0004 N32050 X1.7789 Y1.3524 N32060 X1.7800 Z-0.0011 N32070 X1.8141 Z-0.0599 N32080 X1.8152 Z-0.0600 N32090 X2.1526 N32100 X2.1537 Z-0.0584 N32110 X2.1867 Z-0.0013 N32120 X2.1878 Z-0.0000 N32130 Y1.3574 Z-0.0000 N32140 X2.1867 Z-0.0013 N32150 X2.1537 Z-0.0585 N32160 X2.1526 Z-0.0600 N32170 X1.8137 N32180 X1.7796 Z-0.0012 N32190 X1.7785 Z0.0000 N32200 X1.7781 Y1.3614 N32210 X1.7780 Y1.3624 Z-0.0001 N32220 X1.7791 Z-0.0012 N32230 X1.8132 Z-0.0599 N32240 X1.8143 Z-0.0600 N32250 X2.1526 N32260 X2.1537 Z-0.0583 N32270 X2.1867 Z-0.0013 N32280 X2.1878 Z-0.0000 N32290 Y1.3674 Z-0.0000 N32300 X2.1867 Z-0.0013 N32310 X2.1537 Z-0.0585 N32320 X2.1526 Z-0.0600 N32330 X1.8138 N32340 X1.8127 Z-0.0598 N32350 X1.7786 Z-0.0010 N32360 X1.7775 Z0.0000 N32370 X1.7770 Y1.3713 Z-0.0000 N32380 X1.7769 Y1.3724 Z-0.0003 N32390 X1.7780 Z-0.0012 N32400 X1.8120 Z-0.0597 N32410 X1.8131 Z-0.0600 N32420 X2.1526 N32430 X2.1537 Z-0.0584 N32440 X2.1867 Z-0.0013 N32450 X2.1878 Z-0.0000 N32460 Y1.3774 Z-0.0000 N32470 X2.1867 Z-0.0013 N32480 X2.1537 Z-0.0585 N32490 X2.1526 Z-0.0600 N32500 X1.8125 N32510 X1.8114 Z-0.0599 N32520 X1.7773 Z-0.0013 N32530 X1.7762 Z0.0000 N32540 X1.7759 Y1.3794 N32550 X1.7758 Y1.3803 Z-0.0002 N32560 X1.7757 Y1.3813 Z-0.0004 N32570 X1.7755 Y1.3824 Z-0.0004 N32580 X1.7766 Z-0.0011 N32590 X1.8107 Z-0.0596 N32600 X1.8118 Z-0.0600 N32610 X2.1526 N32620 X2.1537 Z-0.0584 N32630 X2.1867 Z-0.0013 N32640 X2.1878 Z-0.0000 N32650 Y1.3874 Z-0.0000 N32660 X2.1867 Z-0.0013 N32670 X2.1537 Z-0.0583 N32680 X2.1526 Z-0.0600 N32690 X1.8110 N32700 X1.8099 Z-0.0594 N32710 X1.7758 Z-0.0012 N32720 X1.7747 Z-0.0000 N32730 X1.7746 Y1.3882 Z-0.0003 N32740 X1.7745 Y1.3890 Z-0.0005 N32750 X1.7743 Y1.3898 Z-0.0002 N32760 X1.7742 Y1.3907 Z0.0000 N32770 X1.7739 Y1.3924 N32780 X1.7761 Z-0.0032 N32790 X1.8091 Z-0.0596 N32800 X1.8102 Z-0.0600 N32810 X2.1525 N32820 X2.1537 Z-0.0585 N32830 X2.1867 Z-0.0013 N32840 X2.1878 Z-0.0000 N32850 Y1.3974 Z-0.0000 N32860 X2.1867 Z-0.0013 N32870 X2.1537 Z-0.0585 N32880 X2.1526 Z-0.0600 N32890 X1.8093 N32900 X1.8082 Z-0.0593 N32910 X1.7741 Z-0.0011 N32920 X1.7730 Z0.0000 N32930 X1.7726 Y1.3991 N32940 X1.7725 Y1.4000 Z-0.0003 N32950 X1.7723 Y1.4009 N32960 X1.7721 Y1.4017 Z-0.0002 N32970 X1.7720 Y1.4023 Z0.0000 N32980 X1.7731 Z-0.0010 N32990 X1.8072 Z-0.0591 N33000 X1.8083 Z-0.0600 N33010 X2.1526 N33020 X2.1537 Z-0.0585 N33030 X2.1867 Z-0.0013 N33040 X2.1878 Z-0.0000 N33050 Y1.4073 Z-0.0000 N33060 X2.1867 Z-0.0013 N33070 X2.1537 Z-0.0584 N33080 X2.1526 Z-0.0600 N33090 X1.8072 N33100 X1.8061 Z-0.0587 N33110 X1.7797 Z-0.0138 N33120 X1.7720 Z-0.0008 N33130 X1.7709 Z-0.0001 N33140 X1.7706 Y1.4091 Z0.0000 N33150 X1.7704 Y1.4100 Z-0.0001 N33160 X1.7702 Y1.4108 N33170 X1.7700 Y1.4116 Z-0.0004 N33180 X1.7698 Y1.4123 Z0.0000 N33190 X1.7709 Z-0.0010 N33200 X1.8050 Z-0.0587 N33210 X1.8061 Z-0.0600 N33220 X2.1526 N33230 X2.1537 Z-0.0584 N33240 X2.1867 Z-0.0013 N33250 X2.1878 Z-0.0000 N33260 Y1.4173 Z-0.0000 N33270 X2.1867 Z-0.0013 N33280 X2.1537 Z-0.0585 N33290 X2.1526 Z-0.0600 N33300 X1.8049 N33310 X1.8038 Z-0.0585 N33320 X1.7697 Z-0.0009 N33330 X1.7686 Z0.0000 N33340 X1.7681 Y1.4195 N33350 X1.7679 Y1.4205 Z-0.0004 N33360 X1.7676 Y1.4216 Z0.0000 N33370 X1.7674 Y1.4223 N33380 X1.7685 Z-0.0013 N33390 X1.8026 Z-0.0588 N33400 X1.8037 Z-0.0600 N33410 X2.1526 N33420 X2.1537 Z-0.0585 N33430 X2.1867 Z-0.0013 N33440 X2.1878 Z-0.0000 N33450 Y1.4273 Z-0.0000 N33460 X2.1867 Z-0.0013 N33470 X2.1536 Z-0.0585 N33480 X2.1525 Z-0.0600 N33490 X1.8024 N33500 X1.8013 Z-0.0584 N33510 X1.7727 Z-0.0103 N33520 X1.7683 Z-0.0030 N33530 X1.7672 Z-0.0014 N33540 X1.7661 Z-0.0000 N33550 X1.7659 Y1.4281 Z-0.0001 N33560 X1.7656 Y1.4289 Z-0.0005 N33570 X1.7654 Y1.4296 Z-0.0000 N33580 X1.7649 Y1.4314 Z0.0000 N33590 X1.7647 Y1.4323 Z-0.0003 N33600 X1.7658 Z-0.0011 N33610 X1.7965 Z-0.0524 N33620 X1.8009 Z-0.0598 N33630 X1.8020 Z-0.0600 N33640 X2.1526 N33650 X2.1537 Z-0.0584 N33660 X2.1867 Z-0.0013 N33670 X2.1878 Z-0.0000 N33680 Y1.4373 Z-0.0000 N33690 X2.1867 Z-0.0013 N33700 X2.1537 Z-0.0585 N33710 X2.1526 Z-0.0600 N33720 X1.8006 N33730 X1.7995 Z-0.0595 N33740 X1.7676 Z-0.0063 N33750 X1.7643 Z-0.0009 N33760 X1.7632 Z0.0000 N33770 X1.7626 Y1.4391 N33780 X1.7624 Y1.4400 Z-0.0005 N33790 X1.7621 Y1.4409 Z0.0000 N33800 X1.7617 Y1.4423 N33810 X1.7639 Z-0.0032 N33820 X1.7958 Z-0.0561 N33830 X1.7980 Z-0.0598 N33840 X1.7991 Z-0.0600 N33850 X2.1525 N33860 X2.1536 Z-0.0585 N33870 X2.1867 Z-0.0013 N33880 X2.1878 Z-0.0000 N33890 Y1.4473 Z-0.0000 N33900 X2.1867 Z-0.0013 N33910 X2.1537 Z-0.0584 N33920 X2.1526 Z-0.0600 N33930 X1.7974 N33940 X1.7963 Z-0.0590 N33950 X1.7710 Z-0.0171 N33960 X1.7611 Z-0.0008 N33970 X1.7600 Z-0.0003 N33980 X1.7598 Y1.4480 Z0.0000 N33990 X1.7595 Y1.4488 N34000 X1.7592 Y1.4497 Z-0.0004 N34010 X1.7586 Y1.4514 Z0.0000 N34020 X1.7583 Y1.4523 N34030 X1.7594 Z-0.0014 N34040 X1.7605 Z-0.0030 N34050 X1.7858 Z-0.0446 N34060 X1.7946 Z-0.0591 N34070 X1.7957 Z-0.0600 N34080 X2.1525 N34090 X2.1536 Z-0.0585 N34100 X2.1867 Z-0.0013 N34110 X2.1878 Z-0.0000 N34120 Y1.4573 Z-0.0000 N34130 X2.1867 Z-0.0013 N34140 X2.1537 Z-0.0585 N34150 X2.1526 Z-0.0600 N34160 X1.7939 N34170 X1.7928 Z-0.0588 N34180 X1.7631 Z-0.0102 N34190 X1.7576 Z-0.0012 N34200 X1.7565 Z0.0000 N34210 X1.7562 Y1.4581 N34220 X1.7556 Y1.4597 Z-0.0003 N34230 X1.7553 Y1.4606 Z0.0000 N34240 X1.7550 Y1.4614 N34250 X1.7546 Y1.4623 Z-0.0003 N34260 X1.7557 Z-0.0009 N34270 X1.7832 Z-0.0456 N34280 X1.7920 Z-0.0599 N34290 X1.7953 Z-0.0600 N34300 X1.9075 N34310 X2.0284 N34320 X2.1526 N34330 X2.1537 Z-0.0584 N34340 X2.1867 Z-0.0013 N34350 X2.1878 Z-0.0000 N34360 Y1.4673 Z-0.0000 N34370 X2.1867 Z-0.0013 N34380 X2.1537 Z-0.0584 N34390 X2.1526 Z-0.0600 N34400 X1.7911 N34410 X1.7900 Z-0.0597 N34420 X1.7659 Z-0.0204 N34430 X1.7549 Z-0.0027 N34440 X1.7538 Z-0.0014 N34450 X1.7527 Z-0.0003 N34460 X1.7522 Y1.4684 Z-0.0001 N34470 X1.7518 Y1.4693 Z0.0000 N34480 X1.7514 Y1.4703 Z-0.0001 N34490 X1.7510 Y1.4713 Z0.0000 N34500 X1.7506 Y1.4723 N34510 X1.7528 Z-0.0029 N34520 X1.7771 Z-0.0418 N34530 X1.7881 Z-0.0596 N34540 X1.7892 Z-0.0600 N34550 X2.1525 N34560 X2.1536 Z-0.0585 N34570 X2.1867 Z-0.0013 N34580 X2.1878 Z-0.0000 N34590 Y1.4773 Z-0.0000 N34600 X2.1867 Z-0.0013 N34610 X2.1536 Z-0.0585 N34620 X2.1525 Z-0.0600 N34630 X1.7870 N34640 X1.7859 Z-0.0592 N34650 X1.7617 Z-0.0204 N34660 X1.7507 Z-0.0028 N34670 X1.7496 Z-0.0016 N34680 X1.7485 Z0.0000 N34690 X1.7482 Y1.4780 Z-0.0001 N34700 X1.7474 Y1.4797 Z0.0000 N34710 X1.7471 Y1.4805 Z-0.0004 N34720 X1.7467 Y1.4814 Z0.0000 N34730 X1.7463 Y1.4823 N34740 X1.7474 Z-0.0012 N34750 X1.7507 Z-0.0063 N34760 X1.7760 Z-0.0466 N34770 X1.7837 Z-0.0589 N34780 X1.7848 Z-0.0600 N34790 X2.1525 N34800 X2.1536 Z-0.0585 N34810 X2.1867 Z-0.0013 N34820 X2.1878 Z-0.0000 N34830 Y1.4873 Z-0.0000 N34840 X2.1867 Z-0.0013 N34850 X2.1537 Z-0.0584 N34860 X2.1526 Z-0.0600 N34870 X1.7824 N34880 X1.7604 Z-0.0251 N34890 X1.7461 Z-0.0027 N34900 X1.7439 Z-0.0001 N34910 X1.7436 Y1.4880 Z-0.0004 N34920 X1.7432 Y1.4888 Z0.0000 N34930 X1.7428 Y1.4895 Z-0.0000 N34940 X1.7425 Y1.4903 Z-0.0005 N34950 X1.7422 Y1.4909 Z0.0000 N34960 X1.7415 Y1.4922 N34970 X1.7426 Z-0.0007 N34980 X1.7613 Z-0.0299 N34990 X1.7789 Z-0.0576 N35000 X1.7800 Z-0.0593 N35010 X1.7811 Z-0.0600 N35020 X2.1526 N35030 X2.1537 Z-0.0584 N35040 X2.1867 Z-0.0013 N35050 X2.1878 Z-0.0000 N35060 Y1.4972 Z-0.0000 N35070 X2.1867 Z-0.0013 N35080 X2.1537 Z-0.0585 N35090 X2.1526 Z-0.0600 N35100 X1.7786 N35110 X1.7775 Z-0.0592 N35120 X1.7555 Z-0.0247 N35130 X1.7401 Z-0.0009 N35140 X1.7390 Z-0.0000 N35150 X1.7385 Y1.4982 Z0.0000 N35160 X1.7381 Y1.4991 Z-0.0004 N35170 X1.7376 Y1.4999 Z0.0000 N35180 X1.7372 Y1.5007 Z-0.0001 N35190 X1.7368 Y1.5014 Z-0.0000 N35200 X1.7364 Y1.5022 Z-0.0001 N35210 X1.7375 Z-0.0011 N35220 X1.7430 Z-0.0094 N35230 X1.7650 Z-0.0434 N35240 X1.7749 Z-0.0589 N35250 X1.7760 Z-0.0600 N35260 X2.1525 N35270 X2.1536 Z-0.0585 N35280 X2.1867 Z-0.0013 N35290 X2.1878 Z-0.0000 N35300 Y1.5072 Z-0.0000 N35310 X2.1867 Z-0.0013 N35320 X2.1537 Z-0.0584 N35330 X2.1526 Z-0.0600 N35340 X1.7743 N35350 X1.7732 Z-0.0599 N35360 X1.7556 Z-0.0327 N35370 X1.7380 Z-0.0059 N35380 X1.7347 Z-0.0009 N35390 X1.7336 Z-0.0004 N35400 X1.7334 Y1.5077 Z0.0000 N35410 X1.7319 Y1.5104 Z-0.0000 N35420 X1.7308 Y1.5122 Z-0.0002 N35430 X1.7319 Z-0.0012 N35440 X1.7330 Z-0.0025 N35450 X1.7528 Z-0.0325 N35460 X1.7705 Z-0.0595 N35470 X1.7716 Z-0.0600 N35480 X2.1525 N35490 X2.1536 Z-0.0585 N35500 X2.1867 Z-0.0013 N35510 X2.1878 Z-0.0000 N35520 Y1.5172 Z-0.0000 N35530 X2.1867 Z-0.0013 N35540 X2.1537 Z-0.0585 N35550 X2.1526 Z-0.0600 N35560 X1.7686 N35570 X1.7675 Z-0.0590 N35580 X1.7488 Z-0.0305 N35590 X1.7323 Z-0.0057 N35600 X1.7290 Z-0.0008 N35610 X1.7279 Z0.0000 N35620 X1.7275 Y1.5179 Z-0.0002 N35630 X1.7270 Y1.5187 N35640 X1.7266 Y1.5194 Z0.0000 N35650 X1.7262 Y1.5201 Z-0.0005 N35660 X1.7257 Y1.5208 Z0.0000 N35670 X1.7253 Y1.5215 N35680 X1.7248 Y1.5222 Z-0.0004 N35690 X1.7259 Z-0.0006 N35700 X1.7292 Z-0.0053 N35710 X1.7457 Z-0.0299 N35720 X1.7655 Z-0.0598 N35730 X1.7666 Z-0.0600 N35740 X2.1526 N35750 X2.1537 Z-0.0584 N35760 X2.1867 Z-0.0013 N35770 X2.1878 Z-0.0000 N35780 Y1.5272 Z-0.0000 N35790 X2.1867 Z-0.0013 N35800 X2.1537 Z-0.0584 N35810 X2.1526 Z-0.0600 N35820 X1.7634 N35830 X1.7623 Z-0.0595 N35840 X1.7469 Z-0.0364 N35850 X1.7283 Z-0.0089 N35860 X1.7228 Z-0.0009 N35870 X1.7217 Z-0.0002 N35880 X1.7211 Y1.5281 Z0.0000 N35890 X1.7206 Y1.5289 Z-0.0006 N35900 X1.7200 Y1.5298 Z-0.0001 N35910 X1.7189 Y1.5314 Z0.0000 N35920 X1.7184 Y1.5322 Z-0.0006 N35930 X1.7195 Z-0.0011 N35940 X1.7206 Z-0.0022 N35950 X1.7371 Z-0.0262 N35960 X1.7547 Z-0.0521 N35970 X1.7591 Z-0.0587 N35980 X1.7602 Z-0.0600 N35990 X2.1526 N36000 X2.1537 Z-0.0584 N36010 X2.1867 Z-0.0013 N36020 X2.1878 Z-0.0000 N36030 Y1.5372 Z-0.0000 N36040 X2.1867 Z-0.0013 N36050 X2.1537 Z-0.0584 N36060 X2.1526 Z-0.0600 N36070 X1.7579 N36080 X1.7568 Z-0.0598 N36090 X1.7403 Z-0.0356 N36100 X1.7260 Z-0.0148 N36110 X1.7161 Z-0.0007 N36120 X1.7150 Z-0.0001 N36130 X1.7145 Y1.5380 Z0.0000 N36140 X1.7139 Y1.5387 Z-0.0005 N36150 X1.7134 Y1.5395 Z0.0000 N36160 X1.7128 Y1.5403 Z-0.0003 N36170 X1.7123 Y1.5410 Z0.0000 N36180 X1.7115 Y1.5422 Z-0.0000 N36190 X1.7126 Z-0.0008 N36200 X1.7137 Z-0.0022 N36210 X1.7291 Z-0.0242 N36220 X1.7434 Z-0.0449 N36230 X1.7533 Z-0.0594 N36240 X1.7544 Z-0.0600 N36250 X2.1526 N36260 X2.1537 Z-0.0585 N36270 X2.1867 Z-0.0013 N36280 X2.1878 Z-0.0000 N36290 Y1.5472 Z-0.0000 N36300 X2.1867 Z-0.0013 N36310 X2.1537 Z-0.0585 N36320 X2.1526 Z-0.0600 N36330 X1.7508 N36340 X1.7497 Z-0.0588 N36350 X1.7364 Z-0.0397 N36360 X1.7199 Z-0.0163 N36370 X1.7089 Z-0.0008 N36380 X1.7078 Z0.0000 N36390 X1.7074 Y1.5478 Z-0.0004 N36400 X1.7069 Y1.5484 Z0.0000 N36410 X1.7064 Y1.5491 Z-0.0000 N36420 X1.7046 Y1.5514 Z0.0000 N36430 X1.7040 Y1.5522 Z-0.0005 N36440 X1.7051 Z-0.0012 N36450 X1.7062 Z-0.0021 N36460 X1.7183 Z-0.0188 N36470 X1.7359 Z-0.0437 N36480 X1.7469 Z-0.0594 N36490 X1.7480 Z-0.0600 N36500 X2.1526 N36510 X2.1537 Z-0.0584 N36520 X2.1867 Z-0.0013 N36530 X2.1878 Z-0.0000 N36540 Y1.5572 Z-0.0000 N36550 X2.1867 Z-0.0013 N36560 X2.1536 Z-0.0585 N36570 X2.1525 Z-0.0600 N36580 X1.7441 N36590 X1.7430 Z-0.0589 N36600 X1.7254 Z-0.0340 N36610 X1.7133 Z-0.0172 N36620 X1.7012 Z-0.0007 N36630 X1.7001 Z0.0000 N36640 X1.6995 Y1.5579 Z-0.0003 N36650 X1.6989 Y1.5587 Z-0.0001 N36660 X1.6982 Y1.5595 Z-0.0000 N36670 X1.6970 Y1.5610 Z0.0000 N36680 X1.6964 Y1.5618 Z-0.0003 N36690 X1.6961 Y1.5622 Z-0.0001 N36700 X1.6972 Z-0.0008 N36710 X1.7082 Z-0.0156 N36720 X1.7236 Z-0.0367 N36730 X1.7379 Z-0.0566 N36740 X1.7401 Z-0.0597 N36750 X1.7412 Z-0.0600 N36760 X2.1526 N36770 X2.1537 Z-0.0585 N36780 X2.1867 Z-0.0013 N36790 X2.1878 Z-0.0000 N36800 Y1.5672 Z-0.0000 N36810 X2.1867 Z-0.0013 N36820 X2.1537 Z-0.0584 N36830 X2.1526 Z-0.0600 N36840 X1.7380 N36850 X1.7369 Z-0.0599 N36860 X1.7237 Z-0.0417 N36870 X1.7083 Z-0.0209 N36880 X1.6963 Z-0.0047 N36890 X1.6941 Z-0.0018 N36900 X1.6930 Z-0.0005 N36910 X1.6919 Z0.0000 N36920 X1.6902 Y1.5690 N36930 X1.6896 Y1.5698 Z-0.0003 N36940 X1.6889 Y1.5706 Z-0.0003 N36950 X1.6882 Y1.5714 Z0.0000 N36960 X1.6875 Y1.5722 Z-0.0003 N36970 X1.6886 Z-0.0010 N36980 X1.6897 Z-0.0020 N36990 X1.7029 Z-0.0194 N37000 X1.7194 Z-0.0415 N37010 X1.7326 Z-0.0595 N37020 X1.7337 Z-0.0600 N37030 X2.1526 N37040 X2.1537 Z-0.0584 N37050 X2.1867 Z-0.0013 N37060 X2.1878 Z-0.0000 N37070 Y1.5772 Z-0.0000 N37080 X2.1867 Z-0.0013 N37090 X2.1537 Z-0.0584 N37100 X2.1526 Z-0.0600 N37110 X1.7303 N37120 X1.7292 Z-0.0598 N37130 X1.7138 Z-0.0390 N37140 X1.7006 Z-0.0216 N37150 X1.6852 Z-0.0017 N37160 X1.6841 Z-0.0005 N37170 X1.6830 Z-0.0002 N37180 X1.6824 Y1.5778 Z0.0000 N37190 X1.6818 Y1.5785 Z-0.0001 N37200 X1.6811 Y1.5792 Z0.0000 N37210 X1.6805 Y1.5799 N37220 X1.6798 Y1.5806 Z-0.0006 N37230 X1.6791 Y1.5814 Z0.0000 N37240 X1.6783 Y1.5821 N37250 X1.6794 Z-0.0007 N37260 X1.6904 Z-0.0146 N37270 X1.7069 Z-0.0360 N37280 X1.7202 Z-0.0535 N37290 X1.7246 Z-0.0594 N37300 X1.7257 Z-0.0600 N37310 X2.1526 N37320 X2.1537 Z-0.0585 N37330 X2.1867 Z-0.0013 N37340 X2.1878 Z-0.0000 N37350 Y1.5871 Z-0.0000 N37360 X2.1867 Z-0.0013 N37370 X2.1536 Z-0.0586 N37380 X2.1525 Z-0.0600 N37390 X1.7220 N37400 X1.7209 Z-0.0599 N37410 X1.7065 Z-0.0411 N37420 X1.6933 Z-0.0241 N37430 X1.6812 Z-0.0088 N37440 X1.6757 Z-0.0020 N37450 X1.6746 Z-0.0008 N37460 X1.6735 Z-0.0003 N37470 X1.6734 Y1.5873 Z-0.0004 N37480 X1.6727 Y1.5880 Z0.0000 N37490 X1.6711 Y1.5895 Z-0.0004 N37500 X1.6704 Y1.5903 Z0.0000 N37510 X1.6696 Y1.5910 Z-0.0001 N37520 X1.6689 Y1.5918 Z-0.0004 N37530 X1.6685 Y1.5921 Z-0.0001 N37540 X1.6696 Z-0.0005 N37550 X1.6850 Z-0.0195 N37560 X1.6971 Z-0.0347 N37570 X1.7114 Z-0.0531 N37580 X1.7158 Z-0.0588 N37590 X1.7169 Z-0.0600 N37600 X2.1526 N37610 X2.1537 Z-0.0585 N37620 X2.1867 Z-0.0013 N37630 X2.1878 Z-0.0000 N37640 Y1.5971 Z-0.0000 N37650 X2.1867 Z-0.0013 N37660 X2.1537 Z-0.0584 N37670 X2.1526 Z-0.0600 N37680 X1.7129 N37690 X1.7118 Z-0.0591 N37700 X1.6997 Z-0.0436 N37710 X1.6865 Z-0.0271 N37720 X1.6722 Z-0.0096 N37730 X1.6656 Z-0.0016 N37740 X1.6634 Z-0.0005 N37750 X1.6626 Y1.5978 Z0.0000 N37760 X1.6620 Y1.5985 Z-0.0002 N37770 X1.6613 Y1.5991 Z0.0000 N37780 X1.6606 Y1.5997 N37790 X1.6599 Y1.6004 Z-0.0004 N37800 X1.6592 Y1.6010 Z0.0000 N37810 X1.6580 Y1.6021 N37820 X1.6591 Z-0.0010 N37830 X1.6602 Z-0.0023 N37840 X1.6613 Z-0.0032 N37850 X1.6734 Z-0.0176 N37860 X1.6877 Z-0.0351 N37870 X1.7020 Z-0.0529 N37880 X1.7075 Z-0.0598 N37890 X1.7086 Z-0.0600 N37900 X2.1526 N37910 X2.1537 Z-0.0584 N37920 X2.1867 Z-0.0013 N37930 X2.1878 Z-0.0000 N37940 Y1.6071 Z-0.0000 N37950 X2.1867 Z-0.0013 N37960 X2.1537 Z-0.0584 N37970 X2.1526 Z-0.0600 N37980 X1.7041 N37990 X1.7030 Z-0.0598 N38000 X1.6888 Z-0.0421 N38010 X1.6778 Z-0.0288 N38020 X1.6646 Z-0.0131 N38030 X1.6547 Z-0.0016 N38040 X1.6536 Z-0.0009 N38050 X1.6525 Z-0.0004 N38060 X1.6519 Y1.6076 Z0.0000 N38070 X1.6514 Y1.6081 Z-0.0004 N38080 X1.6508 Y1.6086 Z0.0000 N38090 X1.6501 Y1.6092 Z-0.0004 N38100 X1.6494 Y1.6098 Z0.0000 N38110 X1.6467 Y1.6121 N38120 X1.6478 Z-0.0004 N38130 X1.6566 Z-0.0103 N38140 X1.6698 Z-0.0256 N38150 X1.6830 Z-0.0413 N38160 X1.6973 Z-0.0587 N38170 X1.6984 Z-0.0600 N38180 X2.1526 N38190 X2.1537 Z-0.0584 N38200 X2.1867 Z-0.0013 N38210 X2.1878 Z-0.0000 N38220 Y1.6171 Z-0.0000 N38230 X2.1867 Z-0.0013 N38240 X2.1536 Z-0.0585 N38250 X2.1525 Z-0.0600 N38260 X1.6935 N38270 X1.6924 Z-0.0590 N38280 X1.6802 Z-0.0445 N38290 X1.6659 Z-0.0277 N38300 X1.6560 Z-0.0164 N38310 X1.6439 Z-0.0030 N38320 X1.6417 Z-0.0009 N38330 X1.6406 Z-0.0000 N38340 X1.6399 Y1.6177 N38350 X1.6392 Y1.6182 Z-0.0003 N38360 X1.6385 Y1.6188 Z0.0000 N38370 X1.6379 Y1.6194 Z-0.0005 N38380 X1.6372 Y1.6199 Z0.0000 N38390 X1.6344 Y1.6221 N38400 X1.6355 Z-0.0001 N38410 X1.6432 Z-0.0084 N38420 X1.6575 Z-0.0242 N38430 X1.6674 Z-0.0354 N38440 X1.6806 Z-0.0508 N38450 X1.6883 Z-0.0599 N38460 X1.6927 Z-0.0600 N38470 X1.8049 N38480 X1.9358 N38490 X2.0690 N38500 X2.1526 N38510 X2.1537 Z-0.0585 N38520 X2.1867 Z-0.0013 N38530 X2.1878 Z-0.0000 N38540 Y1.6271 N38550 X2.1867 Z-0.0013 N38560 X2.1537 Z-0.0584 N38570 X2.1526 Z-0.0600 N38580 X1.6829 N38590 X1.6807 Z-0.0575 N38600 X1.6708 Z-0.0460 N38610 X1.6598 Z-0.0336 N38620 X1.6433 Z-0.0154 N38630 X1.6323 Z-0.0036 N38640 X1.6301 Z-0.0013 N38650 X1.6290 Z-0.0010 N38660 X1.6279 Z-0.0005 N38670 X1.6273 Y1.6276 Z0.0000 N38680 X1.6267 Y1.6280 Z-0.0002 N38690 X1.6259 Y1.6287 Z0.0000 N38700 X1.6250 Y1.6293 Z-0.0001 N38710 X1.6241 Y1.6299 Z0.0000 N38720 X1.6233 Y1.6306 N38730 X1.6224 Y1.6312 Z-0.0004 N38740 X1.6216 Y1.6319 Z0.0000 N38750 X1.6213 Y1.6321 N38760 X1.6224 Z-0.0003 N38770 X1.6235 Z-0.0012 N38780 X1.6367 Z-0.0149 N38790 X1.6488 Z-0.0279 N38800 X1.6653 Z-0.0460 N38810 X1.6763 Z-0.0585 N38820 X1.6774 Z-0.0597 N38830 X1.6785 Z-0.0600 N38840 X2.1526 N38850 X2.1537 Z-0.0585 N38860 X2.1867 Z-0.0013 N38870 X2.1878 Z-0.0000 N38880 Y1.6371 Z-0.0000 N38890 X2.1867 Z-0.0013 N38900 X2.1537 Z-0.0585 N38910 X2.1525 Z-0.0600 N38920 X1.6715 N38930 X1.6704 Z-0.0589 N38940 X1.6528 Z-0.0395 N38950 X1.6407 Z-0.0265 N38960 X1.6275 Z-0.0128 N38970 X1.6175 Z-0.0027 N38980 X1.6164 Z-0.0017 N38990 X1.6142 Z0.0000 N39000 X1.6134 Y1.6377 N39010 X1.6126 Y1.6382 Z-0.0003 N39020 X1.6118 Y1.6388 Z-0.0000 N39030 X1.6110 Y1.6393 Z0.0000 N39040 X1.6093 Y1.6405 Z-0.0002 N39050 X1.6077 Y1.6415 Z0.0000 N39060 X1.6069 Y1.6421 Z-0.0000 N39070 X1.6080 Z-0.0002 N39080 X1.6091 Z-0.0009 N39090 X1.6201 Z-0.0117 N39100 X1.6300 Z-0.0217 N39110 X1.6443 Z-0.0365 N39120 X1.6564 Z-0.0495 N39130 X1.6652 Z-0.0592 N39140 X1.6663 Z-0.0600 N39150 X2.1526 N39160 X2.1537 Z-0.0585 N39170 X2.1867 Z-0.0013 N39180 X2.1878 Z-0.0000 N39190 Y1.6471 Z-0.0000 N39200 X2.1867 Z-0.0013 N39210 X2.1537 Z-0.0585 N39220 X2.1526 Z-0.0600 N39230 X1.6598 N39240 X1.6587 Z-0.0592 N39250 X1.6477 Z-0.0474 N39260 X1.6345 Z-0.0337 N39270 X1.6257 Z-0.0247 N39280 X1.6136 Z-0.0128 N39290 X1.6037 Z-0.0033 N39300 X1.6026 Z-0.0022 N39310 X1.6015 Z-0.0015 N39320 X1.6004 Z-0.0007 N39330 X1.5993 Z-0.0003 N39340 X1.5985 Y1.6476 Z0.0000 N39350 X1.5968 Y1.6486 N39360 X1.5959 Y1.6492 Z-0.0002 N39370 X1.5950 Y1.6498 Z0.0000 N39380 X1.5931 Y1.6509 Z-0.0001 N39390 X1.5922 Y1.6515 Z0.0000 N39400 X1.5912 Y1.6521 Z-0.0002 N39410 X1.5923 N39420 X1.5934 Z-0.0009 N39430 X1.6033 Z-0.0100 N39440 X1.6121 Z-0.0184 N39450 X1.6254 Z-0.0312 N39460 X1.6353 Z-0.0412 N39470 X1.6485 Z-0.0549 N39480 X1.6529 Z-0.0596 N39490 X1.6540 Z-0.0600 N39500 X2.1526 N39510 X2.1537 Z-0.0585 N39520 X2.1867 Z-0.0013 N39530 X2.1878 Z-0.0000 N39540 Y1.6571 Z-0.0000 N39550 X2.1867 Z-0.0013 N39560 X2.1537 Z-0.0585 N39570 X2.1526 Z-0.0600 N39580 X1.6466 N39590 X1.6455 Z-0.0590 N39600 X1.6356 Z-0.0488 N39610 X1.6246 Z-0.0379 N39620 X1.6125 Z-0.0262 N39630 X1.6026 Z-0.0169 N39640 X1.5894 Z-0.0050 N39650 X1.5861 Z-0.0021 N39660 X1.5850 Z-0.0015 N39670 X1.5839 Z-0.0006 N39680 X1.5828 Z-0.0001 N39690 X1.5804 Y1.6584 Z0.0000 N39700 X1.5795 Y1.6590 Z-0.0004 N39710 X1.5785 Y1.6595 Z0.0000 N39720 X1.5776 Y1.6600 Z-0.0004 N39730 X1.5766 Y1.6605 Z0.0000 N39740 X1.5756 Y1.6611 Z-0.0002 N39750 X1.5747 Y1.6616 Z0.0000 N39760 X1.5738 Y1.6621 Z-0.0002 N39770 X1.5760 Z-0.0007 N39780 X1.5859 Z-0.0090 N39790 X1.5947 Z-0.0168 N39800 X1.6068 Z-0.0278 N39810 X1.6167 Z-0.0371 N39820 X1.6299 Z-0.0499 N39830 X1.6398 Z-0.0598 N39840 X1.6409 Z-0.0600 N39850 X2.1526 N39860 X2.1537 Z-0.0585 N39870 X2.1867 Z-0.0013 N39880 X2.1878 Z-0.0000 N39890 Y1.6671 Z-0.0000 N39900 X2.1867 Z-0.0013 N39910 X2.1537 Z-0.0584 N39920 X2.1526 Z-0.0600 N39930 X1.6336 N39940 X1.6325 Z-0.0600 N39950 X1.6204 Z-0.0482 N39960 X1.6106 Z-0.0389 N39970 X1.5985 Z-0.0280 N39980 X1.5897 Z-0.0202 N39990 X1.5787 Z-0.0109 N40000 X1.5688 Z-0.0028 N40010 X1.5666 Z-0.0015 N40020 X1.5655 Z-0.0006 N40030 X1.5644 Z0.0000 N40040 X1.5635 Y1.6675 Z-0.0002 N40050 X1.5626 Y1.6679 Z0.0000 N40060 X1.5617 Y1.6684 N40070 X1.5607 Y1.6689 Z-0.0002 N40080 X1.5597 Y1.6694 Z0.0000 N40090 X1.5587 Y1.6699 Z-0.0006 N40100 X1.5577 Y1.6704 Z0.0000 N40110 X1.5569 Y1.6708 Z-0.0002 N40120 X1.5560 Y1.6712 Z0.0000 N40130 X1.5551 Y1.6716 N40140 X1.5542 Y1.6721 Z-0.0006 N40150 X1.5553 N40160 X1.5564 Z-0.0009 N40170 X1.5575 Z-0.0015 N40180 X1.5674 Z-0.0091 N40190 X1.5762 Z-0.0162 N40200 X1.5883 Z-0.0262 N40210 X1.5982 Z-0.0348 N40220 X1.6103 Z-0.0457 N40230 X1.6202 Z-0.0549 N40240 X1.6246 Z-0.0591 N40250 X1.6257 Z-0.0600 N40260 X2.1526 N40270 X2.1537 Z-0.0585 N40280 X2.1867 Z-0.0013 N40290 X2.1878 Z-0.0000 N40300 Y1.6770 Z-0.0000 N40310 X2.1867 Z-0.0013 N40320 X2.1537 Z-0.0584 N40330 X2.1526 Z-0.0600 N40340 X1.6181 N40350 X1.6170 Z-0.0596 N40360 X1.6060 Z-0.0496 N40370 X1.5962 Z-0.0408 N40380 X1.5852 Z-0.0315 N40390 X1.5753 Z-0.0234 N40400 X1.5665 Z-0.0164 N40410 X1.5544 Z-0.0073 N40420 X1.5478 Z-0.0025 N40430 X1.5467 Z-0.0020 N40440 X1.5445 Z-0.0004 N40450 X1.5434 Z0.0000 N40460 X1.5424 Y1.6775 Z-0.0004 N40470 X1.5414 Y1.6779 Z0.0000 N40480 X1.5404 Y1.6783 N40490 X1.5394 Y1.6788 Z-0.0001 N40500 X1.5384 Y1.6792 Z0.0000 N40510 X1.5365 Y1.6800 Z-0.0004 N40520 X1.5355 Y1.6804 Z0.0000 N40530 X1.5346 Y1.6808 Z-0.0005 N40540 X1.5336 Y1.6812 Z0.0000 N40550 X1.5326 Y1.6816 N40560 X1.5316 Y1.6820 Z-0.0002 N40570 X1.5327 Z-0.0008 N40580 X1.5338 N40590 X1.5349 Z-0.0014 N40600 X1.5448 Z-0.0082 N40610 X1.5536 Z-0.0144 N40620 X1.5647 Z-0.0227 N40630 X1.5746 Z-0.0304 N40640 X1.5845 Z-0.0385 N40650 X1.5955 Z-0.0477 N40660 X1.6043 Z-0.0554 N40670 X1.6087 Z-0.0594 N40680 X1.6098 Z-0.0600 N40690 X2.1525 N40700 X2.1536 Z-0.0585 N40710 X2.1867 Z-0.0013 N40720 X2.1878 Z-0.0000 N40730 Y1.6870 Z-0.0000 N40740 X2.1867 Z-0.0013 N40750 X2.1537 Z-0.0585 N40760 X2.1526 Z-0.0600 N40770 X1.6023 N40780 X1.6012 Z-0.0600 N40790 X1.5902 Z-0.0506 N40800 X1.5803 Z-0.0425 N40810 X1.5715 Z-0.0355 N40820 X1.5594 Z-0.0263 N40830 X1.5506 Z-0.0200 N40840 X1.5407 Z-0.0131 N40850 X1.5319 Z-0.0073 N40860 X1.5220 Z-0.0011 N40870 X1.5209 Z-0.0004 N40880 X1.5198 Z0.0000 N40890 X1.5187 N40900 X1.5177 Y1.6874 Z-0.0004 N40910 X1.5157 Y1.6881 Z0.0000 N40920 X1.5147 Y1.6885 Z-0.0005 N40930 X1.5138 Y1.6888 Z-0.0001 N40940 X1.5129 Y1.6892 Z0.0000 N40950 X1.5111 Y1.6898 Z-0.0002 N40960 X1.5102 Y1.6901 Z0.0000 N40970 X1.5093 Y1.6904 N40980 X1.5084 Y1.6907 Z-0.0004 N40990 X1.5075 Y1.6910 Z0.0000 N41000 X1.5059 Y1.6915 N41010 X1.5051 Y1.6918 Z-0.0004 N41020 X1.5044 Y1.6920 Z0.0000 N41030 X1.5055 Z-0.0006 N41040 X1.5066 Z-0.0010 N41050 X1.5077 N41060 X1.5110 Z-0.0027 N41070 X1.5187 Z-0.0072 N41080 X1.5286 Z-0.0132 N41090 X1.5363 Z-0.0182 N41100 X1.5462 Z-0.0249 N41110 X1.5561 Z-0.0318 N41120 X1.5660 Z-0.0391 N41130 X1.5759 Z-0.0467 N41140 X1.5847 Z-0.0538 N41150 X1.5913 Z-0.0592 N41160 X1.5924 Z-0.0600 N41170 X2.1526 N41180 X2.1537 Z-0.0585 N41190 X2.1867 Z-0.0013 N41200 X2.1878 Z-0.0000 N41210 Y1.6970 Z-0.0000 N41220 X2.1867 Z-0.0013 N41230 X2.1537 Z-0.0585 N41240 X2.1526 Z-0.0600 N41250 X1.5839 N41260 X1.5828 Z-0.0599 N41270 X1.5729 Z-0.0523 N41280 X1.5630 Z-0.0448 N41290 X1.5542 Z-0.0385 N41300 X1.5432 Z-0.0310 N41310 X1.5355 Z-0.0259 N41320 X1.5256 Z-0.0198 N41330 X1.5146 Z-0.0133 N41340 X1.5058 Z-0.0084 N41350 X1.4948 Z-0.0026 N41360 X1.4904 Z-0.0004 N41370 X1.4893 Z0.0000 N41380 X1.4882 N41390 X1.4877 Y1.6972 Z-0.0001 N41400 X1.4871 Y1.6973 Z-0.0005 N41410 X1.4862 Y1.6976 Z-0.0002 N41420 X1.4853 Y1.6978 Z0.0000 N41430 X1.4844 Y1.6981 N41440 X1.4836 Y1.6983 Z-0.0002 N41450 X1.4827 Y1.6986 Z-0.0005 N41460 X1.4818 Y1.6988 Z0.0000 N41470 X1.4797 Y1.6994 Z-0.0001 N41480 X1.4787 Y1.6996 Z-0.0004 N41490 X1.4776 Y1.6999 Z0.0000 N41500 X1.4756 Y1.7005 Z-0.0000 N41510 X1.4745 Y1.7007 Z-0.0003 N41520 X1.4734 Y1.7010 Z0.0000 N41530 X1.4713 Y1.7015 N41540 X1.4703 Y1.7018 Z-0.0003 N41550 X1.4692 Y1.7020 Z-0.0001 N41560 X1.4703 Z-0.0004 N41570 X1.4714 Z-0.0008 N41580 X1.4725 Z-0.0011 N41590 X1.4736 Z-0.0011 N41600 X1.4747 Z-0.0014 N41610 X1.4835 Z-0.0053 N41620 X1.4923 Z-0.0094 N41630 X1.5000 Z-0.0133 N41640 X1.5110 Z-0.0192 N41650 X1.5187 Z-0.0235 N41660 X1.5286 Z-0.0295 N41670 X1.5374 Z-0.0350 N41680 X1.5462 Z-0.0408 N41690 X1.5561 Z-0.0477 N41700 X1.5649 Z-0.0540 N41710 X1.5726 Z-0.0598 N41720 X1.5737 Z-0.0600 N41730 X2.1526 N41740 X2.1537 Z-0.0585 N41750 X2.1867 Z-0.0013 N41760 X2.1878 Z-0.0000 N41770 Y1.7070 Z-0.0000 N41780 X2.1867 Z-0.0013 N41790 X2.1536 Z-0.0585 N41800 X2.1525 Z-0.0600 N41810 X1.5635 N41820 X1.5624 Z-0.0599 N41830 X1.5525 Z-0.0530 N41840 X1.5426 Z-0.0463 N41850 X1.5338 Z-0.0406 N41860 X1.5228 Z-0.0340 N41870 X1.5151 Z-0.0295 N41880 X1.5052 Z-0.0241 N41890 X1.4964 Z-0.0196 N41900 X1.4876 Z-0.0154 N41910 X1.4777 Z-0.0109 N41920 X1.4710 Z-0.0082 N41930 X1.4611 Z-0.0044 N41940 X1.4545 Z-0.0020 N41950 X1.4490 Z-0.0001 N41960 X1.4479 Z0.0000 N41970 X1.4457 N41980 X1.4447 Y1.7072 Z-0.0003 N41990 X1.4437 Y1.7074 Z-0.0002 N42000 X1.4427 Y1.7075 Z0.0000 N42010 X1.4397 Y1.7081 N42020 X1.4377 Y1.7084 Z-0.0005 N42030 X1.4367 Y1.7086 Z-0.0002 N42040 X1.4357 Y1.7088 Z0.0000 N42050 X1.4328 Y1.7092 N42060 X1.4318 Y1.7094 Z-0.0003 N42070 X1.4308 Y1.7095 Z-0.0005 N42080 X1.4289 Y1.7098 Z0.0000 N42090 X1.4260 Y1.7103 N42100 X1.4249 Y1.7104 Z-0.0001 N42110 X1.4239 Y1.7105 Z-0.0004 N42120 X1.4208 Y1.7109 Z-0.0000 N42130 X1.4178 Y1.7113 Z0.0000 N42140 X1.4167 Y1.7115 Z-0.0000 N42150 X1.4157 Y1.7116 Z-0.0004 N42160 X1.4147 Y1.7117 Z-0.0004 N42170 X1.4137 Y1.7119 Z-0.0002 N42180 X1.4131 Y1.7119 Z-0.0002 N42190 X1.4125 Y1.7120 Z0.0000 N42200 X1.4180 Z-0.0012 N42210 X1.4191 Z-0.0013 N42220 X1.4213 Z-0.0014 N42230 X1.4268 Z-0.0026 N42240 X1.4356 Z-0.0049 N42250 X1.4455 Z-0.0079 N42260 X1.4565 Z-0.0115 N42270 X1.4697 Z-0.0165 N42280 X1.4774 Z-0.0197 N42290 X1.4874 Z-0.0241 N42300 X1.4962 Z-0.0282 N42310 X1.5050 Z-0.0327 N42320 X1.5149 Z-0.0380 N42330 X1.5226 Z-0.0424 N42340 X1.5325 Z-0.0483 N42350 X1.5424 Z-0.0545 N42360 X1.5501 Z-0.0596 N42370 X1.5512 Z-0.0600 N42380 X2.1525 N42390 X2.1536 Z-0.0586 N42400 X2.1867 Z-0.0013 N42410 X2.1878 Z-0.0000 N42420 Y1.7170 Z-0.0000 N42430 X2.1867 Z-0.0013 N42440 X2.1537 Z-0.0585 N42450 X2.1526 Z-0.0600 N42460 X1.5395 N42470 X1.5384 Z-0.0595 N42480 X1.5285 Z-0.0535 N42490 X1.5208 Z-0.0489 N42500 X1.5120 Z-0.0441 N42510 X1.5021 Z-0.0389 N42520 X1.4944 Z-0.0351 N42530 X1.4845 Z-0.0306 N42540 X1.4768 Z-0.0272 N42550 X1.4702 Z-0.0245 N42560 X1.4581 Z-0.0200 N42570 X1.4493 Z-0.0171 N42580 X1.4405 Z-0.0144 N42590 X1.4349 Z-0.0128 N42600 X1.4272 Z-0.0108 N42610 X1.4151 Z-0.0081 N42620 X1.4052 Z-0.0062 N42630 X1.3931 Z-0.0044 N42640 X1.3865 Z-0.0036 N42650 X1.3777 Z-0.0028 N42660 X1.3700 Z-0.0022 N42670 X1.3601 Z-0.0019 N42680 X1.3502 Z-0.0017 N42690 X1.2324 Z-0.0017 N42700 X1.1048 N42710 X1.0266 N42720 X1.0156 Z-0.0008 N42730 X1.0068 Z-0.0001 N42740 X0.9947 N42750 X0.9903 Y1.7172 Z-0.0006 N42760 X0.9837 Y1.7175 Z-0.0000 N42770 X0.9727 Y1.7180 Z0.0000 N42780 X0.9672 Y1.7183 Z-0.0006 N42790 X0.9606 Y1.7186 Z-0.0000 N42800 X0.9496 Y1.7191 Z0.0000 N42810 X0.9474 Y1.7192 Z-0.0002 N42820 X0.9441 Y1.7194 Z-0.0006 N42830 X0.9375 Y1.7197 Z-0.0000 N42840 X0.9266 Y1.7202 Z0.0000 N42850 X0.9255 Y1.7203 Z-0.0000 N42860 X0.9211 Y1.7205 Z-0.0005 N42870 X0.9156 Y1.7207 Z-0.0001 N42880 X0.9134 Y1.7209 Z0.0000 N42890 X0.9024 Y1.7214 Z-0.0000 N42900 X0.8980 Y1.7216 Z-0.0005 N42910 X0.8969 Y1.7216 Z-0.0005 N42920 X0.8903 Y1.7219 Z0.0000 N42930 X0.8892 Y1.7220 N42940 X0.8914 Z-0.0001 N42950 X0.9090 Z-0.0015 N42960 X0.9145 Z-0.0016 N42970 X1.0257 Z-0.0107 N42980 X1.0301 Z-0.0107 N42990 X1.1445 N43000 X1.2700 N43010 X1.3492 Z-0.0107 N43020 X1.3624 Z-0.0110 N43030 X1.3712 Z-0.0114 N43040 X1.3800 Z-0.0120 N43050 X1.3888 Z-0.0129 N43060 X1.3954 Z-0.0138 N43070 X1.4064 Z-0.0155 N43080 X1.4152 Z-0.0171 N43090 X1.4284 Z-0.0201 N43100 X1.4372 Z-0.0224 N43110 X1.4460 Z-0.0250 N43120 X1.4526 Z-0.0271 N43130 X1.4592 Z-0.0293 N43140 X1.4725 Z-0.0343 N43150 X1.4802 Z-0.0374 N43160 X1.4901 Z-0.0418 N43170 X1.4989 Z-0.0460 N43180 X1.5077 Z-0.0505 N43190 X1.5176 Z-0.0557 N43200 X1.5242 Z-0.0595 N43210 X1.5253 Z-0.0600 N43220 X2.1526 N43230 X2.1537 Z-0.0585 N43240 X2.1867 Z-0.0013 N43250 X2.1878 Z-0.0000 N43260 Y1.7270 Z-0.0000 N43270 X2.1867 Z-0.0013 N43280 X2.1537 Z-0.0585 N43290 X2.1526 Z-0.0600 N43300 X1.5109 N43310 X1.5010 Z-0.0550 N43320 X1.4911 Z-0.0503 N43330 X1.4823 Z-0.0464 N43340 X1.4746 Z-0.0432 N43350 X1.4602 Z-0.0378 N43360 X1.4503 Z-0.0345 N43370 X1.4404 Z-0.0315 N43380 X1.4327 Z-0.0294 N43390 X1.4272 Z-0.0280 N43400 X1.4162 Z-0.0256 N43410 X1.4063 Z-0.0237 N43420 X1.3931 Z-0.0217 N43430 X1.3843 Z-0.0207 N43440 X1.3744 Z-0.0199 N43450 X1.3689 Z-0.0196 N43460 X1.3601 Z-0.0192 N43470 X1.3502 Z-0.0190 N43480 X1.2247 Z-0.0190 N43490 X1.1003 N43500 X1.0266 N43510 X0.9209 Z-0.0104 N43520 X0.8582 Z-0.0053 N43530 X0.8571 Z-0.0052 N43540 X0.8560 Z-0.0056 N43550 X0.8549 Z-0.0066 N43560 X0.8538 Z-0.0079 N43570 X0.8516 Z-0.0111 N43580 X0.8461 Z-0.0200 N43590 X0.8340 Z-0.0406 N43600 X0.8230 Z-0.0595 N43610 X0.8219 Z-0.0600 N43620 X0.4157 N43630 X0.4146 Z-0.0585 N43640 X0.3816 Z-0.0013 N43650 X0.3805 Z-0.0000 N43660 Y1.7320 Z-0.0000 N43670 X0.3816 Z-0.0013 N43680 X0.4146 Z-0.0585 N43690 X0.4157 Z-0.0600 N43700 X0.8230 N43710 X0.8241 Z-0.0591 N43720 X0.8329 Z-0.0445 N43730 X0.8395 Z-0.0339 N43740 X0.8450 Z-0.0255 N43750 X0.8483 Z-0.0210 N43760 X0.8505 Z-0.0185 N43770 X0.8516 Z-0.0174 N43780 X0.8527 Z-0.0164 N43790 X0.8538 Z-0.0155 N43800 X0.8549 Z-0.0148 N43810 X0.8560 Z-0.0144 N43820 X0.8571 Z-0.0142 N43830 X0.9672 Z-0.0232 N43840 X1.0266 Z-0.0280 N43850 X1.1400 Z-0.0281 N43860 X1.2863 Z-0.0281 N43870 X1.3502 N43880 X1.3623 Z-0.0283 N43890 X1.3711 Z-0.0287 N43900 X1.3799 Z-0.0293 N43910 X1.3887 Z-0.0302 N43920 X1.3953 Z-0.0310 N43930 X1.4074 Z-0.0329 N43940 X1.4162 Z-0.0346 N43950 X1.4294 Z-0.0375 N43960 X1.4382 Z-0.0398 N43970 X1.4481 Z-0.0427 N43980 X1.4558 Z-0.0452 N43990 X1.4624 Z-0.0475 N44000 X1.4746 Z-0.0520 N44010 X1.4823 Z-0.0552 N44020 X1.4922 Z-0.0596 N44030 X1.4933 Z-0.0600 N44040 X2.1526 N44050 X2.1537 Z-0.0585 N44060 X2.1867 Z-0.0013 N44070 X2.1878 Z-0.0000 N44080 Y1.7370 Z-0.0000 N44090 X2.1867 Z-0.0013 N44100 X2.1537 Z-0.0585 N44110 X2.1526 Z-0.0600 N44120 X1.4746 N44130 X1.4735 Z-0.0597 N44140 X1.4624 Z-0.0556 N44150 X1.4525 Z-0.0522 N44160 X1.4437 Z-0.0496 N44170 X1.4371 Z-0.0477 N44180 X1.4294 Z-0.0457 N44190 X1.4173 Z-0.0430 N44200 X1.4074 Z-0.0412 N44210 X1.3942 Z-0.0391 N44220 X1.3865 Z-0.0382 N44230 X1.3777 Z-0.0374 N44240 X1.3700 Z-0.0369 N44250 X1.3601 Z-0.0366 N44260 X1.3502 Z-0.0364 N44270 X1.2280 Z-0.0364 N44280 X1.0926 Z-0.0364 N44290 X1.0266 Z-0.0364 N44300 X0.9121 Z-0.0270 N44310 X0.8582 Z-0.0226 N44320 X0.8571 Z-0.0225 N44330 X0.8560 Z-0.0226 N44340 X0.8549 Z-0.0229 N44350 X0.8538 Z-0.0233 N44360 X0.8527 Z-0.0239 N44370 X0.8516 Z-0.0245 N44380 X0.8494 Z-0.0263 N44390 X0.8472 Z-0.0285 N44400 X0.8439 Z-0.0324 N44410 X0.8406 Z-0.0367 N44420 X0.8351 Z-0.0446 N44430 X0.8285 Z-0.0547 N44440 X0.8252 Z-0.0599 N44450 X0.8219 Z-0.0600 N44460 X0.7074 N44470 X0.5764 N44480 X0.4432 N44490 X0.4157 N44500 X0.4146 Z-0.0585 N44510 X0.3816 Z-0.0013 N44520 X0.3805 Z-0.0000 N44530 Y1.7420 Z-0.0000 N44540 X0.3816 Z-0.0013 N44550 X0.4146 Z-0.0585 N44560 X0.4157 Z-0.0600 N44570 X0.8274 N44580 X0.8285 Z-0.0589 N44590 X0.8329 Z-0.0526 N44600 X0.8373 Z-0.0467 N44610 X0.8406 Z-0.0427 N44620 X0.8439 Z-0.0391 N44630 X0.8461 Z-0.0370 N44640 X0.8483 Z-0.0352 N44650 X0.8494 Z-0.0343 N44660 X0.8516 Z-0.0330 N44670 X0.8538 Z-0.0321 N44680 X0.8549 Z-0.0318 N44690 X0.8560 Z-0.0316 N44700 X0.8571 Z-0.0316 N44710 X0.8736 Z-0.0329 N44720 X0.9881 Z-0.0422 N44730 X1.0266 Z-0.0454 N44740 X1.0310 Z-0.0454 N44750 X1.1466 Z-0.0454 N44760 X1.2775 Z-0.0454 N44770 X1.3502 Z-0.0454 N44780 X1.3623 Z-0.0457 N44790 X1.3711 Z-0.0460 N44800 X1.3799 Z-0.0467 N44810 X1.3876 Z-0.0474 N44820 X1.3953 Z-0.0483 N44830 X1.4074 Z-0.0502 N44840 X1.4173 Z-0.0520 N44850 X1.4305 Z-0.0550 N44860 X1.4404 Z-0.0575 N44870 X1.4481 Z-0.0598 N44880 X1.4492 Z-0.0600 N44890 X2.1526 N44900 X2.1537 Z-0.0585 N44910 X2.1867 Z-0.0013 N44920 X2.1878 Z-0.0000 N44930 Y1.7470 Z-0.0000 N44940 X2.1867 Z-0.0013 N44950 X2.1537 Z-0.0585 N44960 X2.1526 Z-0.0600 N44970 X1.4206 N44980 X1.4162 N44990 X1.4129 Z-0.0594 N45000 X1.4096 Z-0.0588 N45010 X1.3953 Z-0.0566 N45020 X1.3887 Z-0.0558 N45030 X1.3799 Z-0.0549 N45040 X1.3711 Z-0.0543 N45050 X1.3612 Z-0.0540 N45060 X1.3502 Z-0.0537 N45070 X1.2225 Z-0.0537 N45080 X1.0860 Z-0.0537 N45090 X1.0266 Z-0.0537 N45100 X0.9011 Z-0.0434 N45110 X0.8582 Z-0.0399 N45120 X0.8571 Z-0.0399 N45130 X0.8560 Z-0.0399 N45140 X0.8549 Z-0.0401 N45150 X0.8538 Z-0.0403 N45160 X0.8516 Z-0.0411 N45170 X0.8494 Z-0.0421 N45180 X0.8472 Z-0.0435 N45190 X0.8450 Z-0.0452 N45200 X0.8428 Z-0.0471 N45210 X0.8395 Z-0.0504 N45220 X0.8351 Z-0.0554 N45230 X0.8318 Z-0.0596 N45240 X0.8307 Z-0.0600 N45250 X0.4157 N45260 X0.4146 Z-0.0585 N45270 X0.3816 Z-0.0013 N45280 X0.3805 Z-0.0000 N45290 Y1.7520 Z-0.0000 N45300 X0.3816 Z-0.0013 N45310 X0.4102 Z-0.0509 N45320 X0.4113 Z-0.0511 N45330 X0.4906 Z-0.0511 N45340 X0.6050 Z-0.0511 N45350 X0.7162 Z-0.0511 N45360 X0.8263 Z-0.0511 N45370 X0.8428 Z-0.0511 N45380 X0.8472 Z-0.0511 N45390 X0.8483 Z-0.0511 N45400 X0.8505 Z-0.0501 N45410 X0.8538 Z-0.0491 N45420 X0.8560 Z-0.0488 N45430 X0.8582 Z-0.0488 N45440 X0.8868 Z-0.0510 N45450 X0.8901 Z-0.0511 N45460 X1.0310 Z-0.0511 N45470 X1.1455 Z-0.0511 N45480 X1.2698 Z-0.0511 N45490 X1.3502 Z-0.0511 N45500 X1.3788 Z-0.0511 N45510 X1.4074 Z-0.0511 N45520 X1.4635 Z-0.0511 N45530 X1.6000 Z-0.0511 N45540 X1.7244 Z-0.0511 N45550 X1.8708 Z-0.0511 N45560 X2.0095 Z-0.0511 N45570 X2.1437 Z-0.0511 N45580 X2.1570 Z-0.0511 N45590 X2.1581 Z-0.0509 N45600 X2.1867 Z-0.0013 N45610 X2.1878 Z-0.0000 N45620 Y1.7570 Z-0.0000 N45630 X2.1867 Z-0.0013 N45640 X2.1636 Z-0.0413 N45650 X2.1625 Z-0.0428 N45660 X2.0293 Z-0.0428 N45670 X1.9566 Z-0.0428 N45680 X1.8323 Z-0.0428 N45690 X1.6837 Z-0.0428 N45700 X1.5417 Z-0.0428 N45710 X1.4646 Z-0.0428 N45720 X1.4085 Z-0.0428 N45730 X1.3513 Z-0.0428 N45740 X1.2302 Z-0.0428 N45750 X1.0915 Z-0.0428 N45760 X0.9154 Z-0.0428 N45770 X0.8593 Z-0.0428 N45780 X0.7316 Z-0.0428 N45790 X0.6601 Z-0.0428 N45800 X0.5335 Z-0.0428 N45810 X0.4179 Z-0.0428 N45820 X0.4058 Z-0.0428 N45830 X0.4047 Z-0.0413 N45840 X0.3816 Z-0.0013 N45850 X0.3805 Z-0.0000 N45860 Y1.7620 Z-0.0000 N45870 X0.3816 Z-0.0013 N45880 X0.4003 Z-0.0337 N45890 X0.4025 Z-0.0338 N45900 X0.4994 Z-0.0338 N45910 X0.6105 Z-0.0338 N45920 X0.7151 Z-0.0338 N45930 X0.8274 Z-0.0338 N45940 X0.9495 Z-0.0338 N45950 X1.0827 Z-0.0338 N45960 X1.2159 Z-0.0338 N45970 X1.3535 Z-0.0338 N45980 X1.4074 Z-0.0338 N45990 X1.5142 Z-0.0338 N46000 X1.6683 Z-0.0338 N46010 X1.7849 Z-0.0338 N46020 X1.8851 Z-0.0338 N46030 X2.0590 Z-0.0338 N46040 X2.1636 Z-0.0338 N46050 X2.1669 Z-0.0338 N46060 X2.1680 Z-0.0337 N46070 X2.1867 Z-0.0013 N46080 X2.1878 Z-0.0000 N46090 Y1.7669 Z-0.0000 N46100 X2.1867 Z-0.0013 N46110 X2.1735 Z-0.0242 N46120 X2.1724 Z-0.0255 N46130 X2.0920 Z-0.0255 N46140 X1.9754 Z-0.0255 N46150 X1.8708 Z-0.0255 N46160 X1.6782 Z-0.0255 N46170 X1.5054 Z-0.0255 N46180 X1.4085 Z-0.0255 N46190 X1.2456 Z-0.0255 N46200 X1.0937 Z-0.0255 N46210 X0.9341 Z-0.0255 N46220 X0.8450 Z-0.0255 N46230 X0.7195 Z-0.0255 N46240 X0.6204 Z-0.0255 N46250 X0.5456 Z-0.0255 N46260 X0.4113 Z-0.0255 N46270 X0.3959 Z-0.0255 N46280 X0.3948 Z-0.0242 N46290 X0.3816 Z-0.0013 N46300 X0.3805 Z-0.0000 N46310 Y1.7719 Z-0.0000 N46320 X0.3816 Z-0.0013 N46330 X0.3893 Z-0.0147 N46340 X0.3904 Z-0.0164 N46350 X0.4091 Z-0.0164 N46360 X0.5225 Z-0.0164 N46370 X0.6072 Z-0.0164 N46380 X0.7316 Z-0.0164 N46390 X0.9683 Z-0.0164 N46400 X1.0970 Z-0.0164 N46410 X1.2126 Z-0.0164 N46420 X1.3337 N46430 X1.4613 Z-0.0164 N46440 X1.6474 Z-0.0164 N46450 X1.8036 Z-0.0164 N46460 X1.9148 Z-0.0164 N46470 X2.0194 Z-0.0164 N46480 X2.1515 Z-0.0164 N46490 X2.1768 Z-0.0164 N46500 X2.1779 Z-0.0164 N46510 X2.1790 Z-0.0147 N46520 X2.1867 Z-0.0013 N46530 X2.1878 Z-0.0000 N46540 Y1.7769 Z0.0000 N46550 X2.1867 Z-0.0013 N46560 X2.1834 Z-0.0070 N46570 X2.1823 Z-0.0081 N46580 X2.0634 Z-0.0081 N46590 X1.9853 Z-0.0081 N46600 X1.9258 Z-0.0081 N46610 X1.8257 Z-0.0081 N46620 X1.6936 Z-0.0081 N46630 X1.5032 Z-0.0081 N46640 X1.3744 Z-0.0081 N46650 X1.1267 Z-0.0081 N46660 X1.0013 Z-0.0081 N46670 X0.8615 Z-0.0081 N46680 X0.7349 Z-0.0081 N46690 X0.6249 Z-0.0081 N46700 X0.5324 Z-0.0081 N46710 X0.4047 Z-0.0081 N46720 X0.3860 Z-0.0081 N46730 X0.3849 Z-0.0070 N46740 X0.3816 Z-0.0013 N46750 X0.3805 Z0.0000 N46760 Y1.7819 N46770 X0.4862 Z-0.0000 N46780 X0.6171 N46790 X0.7503 N46800 X0.8835 N46810 X1.0178 N46820 X1.1521 N46830 X1.2852 N46840 X1.4195 N46850 X1.5538 N46860 X1.6881 N46870 X1.8224 N46880 X1.9566 N46890 X2.0909 N46900 X2.1867 N46910 X2.1878 Z0.0000 N46920 G00 Z0.1000 N46930 G00 X0.3805 Y0.2786 N46940 G01 Z-0.0000 F20.0 N46950 G01 X0.3816 Z-0.0013 F60.0 N46960 X0.4146 Z-0.0585 N46970 X0.4157 Z-0.0600 N46980 X0.8220 N46990 X0.8231 Z-0.0592 N47000 X0.8451 Z-0.0212 N47010 X0.8517 Z-0.0100 N47020 X0.8572 Z-0.0011 N47030 X0.8583 Z0.0000 N47040 X0.8587 Y0.2796 Z-0.0001 N47050 X0.8595 Y0.2816 Z0.0000 N47060 X0.8599 Y0.2826 Z-0.0005 N47070 X0.8603 Y0.2836 Z0.0000 N47080 X0.8592 Z-0.0012 N47090 X0.8383 Z-0.0348 N47100 X0.8295 Z-0.0494 N47110 X0.8240 Z-0.0586 N47120 X0.8229 Z-0.0600 N47130 X0.4157 N47140 X0.4146 Z-0.0585 N47150 X0.3816 Z-0.0013 N47160 X0.3805 Z-0.0000 N47170 Y0.2886 Z-0.0000 N47180 X0.3816 Z-0.0013 N47190 X0.4146 Z-0.0585 N47200 X0.4157 Z-0.0600 N47210 X0.8239 N47220 X0.8250 Z-0.0590 N47230 X0.8613 Z-0.0006 N47240 X0.8624 Z0.0000 N47250 X0.8628 Y0.2896 N47260 X0.8632 Y0.2906 Z-0.0002 N47270 X0.8636 Y0.2916 Z0.0000 N47280 X0.8640 Y0.2926 N47290 X0.8644 Y0.2936 Z-0.0003 N47300 X0.8633 Z-0.0009 N47310 X0.8270 Z-0.0591 N47320 X0.8259 Z-0.0600 N47330 X0.4157 N47340 X0.4146 Z-0.0584 N47350 X0.3816 Z-0.0013 N47360 X0.3805 Z-0.0000 N47370 Y0.2986 Z-0.0000 N47380 X0.3816 Z-0.0013 N47390 X0.4146 Z-0.0584 N47400 X0.4157 Z-0.0600 N47410 X0.8280 N47420 X0.8291 Z-0.0589 N47430 X0.8642 Z-0.0025 N47440 X0.8653 Z-0.0008 N47450 X0.8664 Z-0.0003 N47460 X0.8668 Y0.2996 Z0.0000 N47470 X0.8672 Y0.3006 N47480 X0.8677 Y0.3016 Z-0.0004 N47490 X0.8681 Y0.3026 Z0.0000 N47500 X0.8685 Y0.3036 Z-0.0000 N47510 X0.8674 Z-0.0012 N47520 X0.8311 Z-0.0593 N47530 X0.8300 Z-0.0600 N47540 X0.4157 N47550 X0.4146 Z-0.0584 N47560 X0.3816 Z-0.0013 N47570 X0.3805 Z-0.0000 N47580 Y0.3086 Z-0.0000 N47590 X0.3816 Z-0.0013 N47600 X0.4146 Z-0.0585 N47610 X0.4157 Z-0.0600 N47620 X0.8320 N47630 X0.8331 Z-0.0593 N47640 X0.8683 Z-0.0027 N47650 X0.8694 Z-0.0016 N47660 X0.8705 Z-0.0001 N47670 X0.8709 Y0.3096 Z-0.0003 N47680 X0.8713 Y0.3106 Z0.0000 N47690 X0.8717 Y0.3116 N47700 X0.8721 Y0.3126 Z-0.0003 N47710 X0.8725 Y0.3136 Z0.0000 N47720 X0.8714 Z-0.0012 N47730 X0.8351 Z-0.0595 N47740 X0.8340 Z-0.0600 N47750 X0.4157 N47760 X0.4146 Z-0.0585 N47770 X0.3816 Z-0.0013 N47780 X0.3805 Z-0.0000 N47790 Y0.3186 Z-0.0000 N47800 X0.3816 Z-0.0013 N47810 X0.4146 Z-0.0585 N47820 X0.4157 Z-0.0600 N47830 X0.8361 N47840 X0.8372 Z-0.0594 N47850 X0.8735 Z-0.0012 N47860 X0.8746 Z0.0000 N47870 X0.8750 Y0.3195 Z-0.0002 N47880 X0.8754 Y0.3205 Z-0.0004 N47890 X0.8758 Y0.3215 Z0.0000 N47900 X0.8766 Y0.3235 Z-0.0001 N47910 X0.8755 Z-0.0007 N47920 X0.8392 Z-0.0589 N47930 X0.8381 Z-0.0600 N47940 X0.4157 N47950 X0.4146 Z-0.0585 N47960 X0.3816 Z-0.0013 N47970 X0.3805 Z-0.0000 N47980 Y0.3285 Z-0.0000 N47990 X0.3816 Z-0.0013 N48000 X0.4146 Z-0.0584 N48010 X0.4157 Z-0.0600 N48020 X0.8402 N48030 X0.8413 Z-0.0592 N48040 X0.8765 Z-0.0027 N48050 X0.8776 Z-0.0010 N48060 X0.8787 Z-0.0005 N48070 X0.8791 Y0.3295 Z0.0000 N48080 X0.8795 Y0.3305 Z-0.0003 N48090 X0.8803 Y0.3325 Z0.0000 N48100 X0.8807 Y0.3335 Z-0.0001 N48110 X0.8796 Z-0.0009 N48120 X0.8433 Z-0.0590 N48130 X0.8422 Z-0.0600 N48140 X0.4157 N48150 X0.4146 Z-0.0584 N48160 X0.3816 Z-0.0013 N48170 X0.3805 Z-0.0000 N48180 Y0.3385 Z-0.0000 N48190 X0.3816 Z-0.0013 N48200 X0.4146 Z-0.0584 N48210 X0.4157 Z-0.0600 N48220 X0.8443 N48230 X0.8454 Z-0.0592 N48240 X0.8805 Z-0.0028 N48250 X0.8816 Z-0.0014 N48260 X0.8827 Z-0.0001 N48270 X0.8831 Y0.3395 Z-0.0003 N48280 X0.8835 Y0.3405 Z0.0000 N48290 X0.8840 Y0.3415 Z-0.0003 N48300 X0.8844 Y0.3425 Z0.0000 N48310 X0.8848 Y0.3435 N48320 X0.8837 Z-0.0012 N48330 X0.8793 Z-0.0082 N48340 X0.8473 Z-0.0594 N48350 X0.8462 Z-0.0600 N48360 X0.4157 N48370 X0.4146 Z-0.0585 N48380 X0.3816 Z-0.0013 N48390 X0.3805 Z-0.0000 N48400 Y0.3485 Z-0.0000 N48410 X0.3816 Z-0.0013 N48420 X0.4146 Z-0.0585 N48430 X0.4157 Z-0.0600 N48440 X0.8483 N48450 X0.8494 Z-0.0595 N48460 X0.8846 Z-0.0030 N48470 X0.8857 Z-0.0013 N48480 X0.8868 Z0.0000 N48490 X0.8872 Y0.3495 Z-0.0003 N48500 X0.8880 Y0.3515 Z0.0000 N48510 X0.8884 Y0.3525 Z-0.0002 N48520 X0.8894 Y0.3526 Z-0.0004 N48530 X0.8904 Y0.3527 Z-0.0005 N48540 X0.8923 Y0.3529 Z-0.0001 N48550 X0.8960 Y0.3533 Z0.0000 N48560 X0.8977 Y0.3535 N48570 X0.8933 N48580 X0.8922 Z-0.0001 N48590 X0.8889 Z-0.0007 N48600 X0.8878 Z-0.0009 N48610 X0.8867 Z-0.0025 N48620 X0.8514 Z-0.0589 N48630 X0.8503 Z-0.0600 N48640 X0.4157 N48650 X0.4146 Z-0.0585 N48660 X0.3816 Z-0.0013 N48670 X0.3805 Z-0.0000 N48680 Y0.3585 Z-0.0000 N48690 X0.3816 Z-0.0013 N48700 X0.4146 Z-0.0585 N48710 X0.4157 Z-0.0600 N48720 X0.8524 N48730 X0.8535 Z-0.0591 N48740 X0.8744 Z-0.0257 N48750 X0.8777 Z-0.0206 N48760 X0.8810 Z-0.0159 N48770 X0.8832 Z-0.0131 N48780 X0.8843 Z-0.0118 N48790 X0.8854 Z-0.0109 N48800 X0.8865 Z-0.0102 N48810 X0.8876 Z-0.0099 N48820 X0.8953 Z-0.0084 N48830 X0.9019 Z-0.0070 N48840 X0.9096 Z-0.0051 N48850 X0.9162 Z-0.0033 N48860 X0.9217 Z-0.0016 N48870 X0.9228 Z-0.0014 N48880 X0.9239 Z-0.0014 N48890 X0.9250 Z-0.0012 N48900 X0.9283 Z-0.0001 N48910 X0.9293 Y0.3588 Z0.0000 N48920 X0.9304 Y0.3590 N48930 X0.9315 Y0.3592 Z-0.0005 N48940 X0.9336 Y0.3597 Z0.0000 N48950 X0.9347 Y0.3600 N48960 X0.9357 Y0.3603 Z-0.0004 N48970 X0.9368 Y0.3606 Z-0.0003 N48980 X0.9378 Y0.3608 Z0.0000 N48990 X0.9389 Y0.3611 N49000 X0.9399 Y0.3614 Z-0.0004 N49010 X0.9409 Y0.3617 Z-0.0001 N49020 X0.9428 Y0.3622 Z0.0000 N49030 X0.9438 Y0.3625 Z-0.0003 N49040 X0.9448 Y0.3629 Z-0.0003 N49050 X0.9458 Y0.3632 Z0.0000 N49060 X0.9468 Y0.3635 Z-0.0002 N49070 X0.9457 N49080 X0.9446 Z-0.0004 N49090 X0.9380 Z-0.0036 N49100 X0.9325 Z-0.0060 N49110 X0.9270 Z-0.0081 N49120 X0.9204 Z-0.0104 N49130 X0.9138 Z-0.0124 N49140 X0.9072 Z-0.0142 N49150 X0.9006 Z-0.0157 N49160 X0.8929 Z-0.0173 N49170 X0.8874 Z-0.0183 N49180 X0.8863 Z-0.0187 N49190 X0.8841 Z-0.0197 N49200 X0.8830 Z-0.0203 N49210 X0.8819 Z-0.0212 N49220 X0.8808 Z-0.0222 N49230 X0.8786 Z-0.0245 N49240 X0.8753 Z-0.0285 N49250 X0.8709 Z-0.0347 N49260 X0.8654 Z-0.0431 N49270 X0.8555 Z-0.0589 N49280 X0.8544 Z-0.0600 N49290 X0.4157 N49300 X0.4146 Z-0.0584 N49310 X0.3816 Z-0.0013 N49320 X0.3805 Z-0.0000 N49330 Y0.3685 Z-0.0000 N49340 X0.3816 Z-0.0013 N49350 X0.4146 Z-0.0585 N49360 X0.4157 Z-0.0600 N49370 X0.8570 N49380 X0.8581 Z-0.0587 N49390 X0.8636 Z-0.0505 N49400 X0.8691 Z-0.0428 N49410 X0.8724 Z-0.0386 N49420 X0.8757 Z-0.0349 N49430 X0.8790 Z-0.0316 N49440 X0.8812 Z-0.0298 N49450 X0.8823 Z-0.0291 N49460 X0.8834 Z-0.0285 N49470 X0.8845 Z-0.0280 N49480 X0.8856 Z-0.0276 N49490 X0.8878 Z-0.0271 N49500 X0.8944 Z-0.0259 N49510 X0.9010 Z-0.0245 N49520 X0.9087 Z-0.0225 N49530 X0.9153 Z-0.0207 N49540 X0.9219 Z-0.0185 N49550 X0.9274 Z-0.0166 N49560 X0.9330 Z-0.0143 N49570 X0.9385 Z-0.0119 N49580 X0.9440 Z-0.0091 N49590 X0.9484 Z-0.0067 N49600 X0.9528 Z-0.0040 N49610 X0.9561 Z-0.0018 N49620 X0.9572 Z-0.0011 N49630 X0.9583 Z-0.0003 N49640 X0.9594 Z0.0000 N49650 X0.9603 Y0.3689 N49660 X0.9611 Y0.3694 Z-0.0004 N49670 X0.9619 Y0.3698 Z0.0000 N49680 X0.9628 Y0.3702 Z-0.0002 N49690 X0.9636 Y0.3707 Z-0.0002 N49700 X0.9643 Y0.3711 Z0.0000 N49710 X0.9658 Y0.3720 N49720 X0.9665 Y0.3725 Z-0.0005 N49730 X0.9673 Y0.3730 Z0.0000 N49740 X0.9681 Y0.3735 Z-0.0000 N49750 X0.9670 Z-0.0003 N49760 X0.9659 Z-0.0009 N49770 X0.9615 Z-0.0048 N49780 X0.9571 Z-0.0084 N49790 X0.9527 Z-0.0115 N49800 X0.9483 Z-0.0144 N49810 X0.9439 Z-0.0169 N49820 X0.9384 Z-0.0198 N49830 X0.9340 Z-0.0219 N49840 X0.9285 Z-0.0242 N49850 X0.9230 Z-0.0263 N49860 X0.9164 Z-0.0285 N49870 X0.9098 Z-0.0304 N49880 X0.9021 Z-0.0324 N49890 X0.8944 Z-0.0341 N49900 X0.8856 Z-0.0358 N49910 X0.8834 Z-0.0364 N49920 X0.8812 Z-0.0375 N49930 X0.8790 Z-0.0388 N49940 X0.8768 Z-0.0405 N49950 X0.8746 Z-0.0425 N49960 X0.8724 Z-0.0447 N49970 X0.8691 Z-0.0484 N49980 X0.8646 Z-0.0539 N49990 X0.8602 Z-0.0599 N50000 X0.8580 Z-0.0600 N50010 X0.7447 N50020 X0.6138 N50030 X0.4806 N50040 X0.4157 N50050 X0.4146 Z-0.0585 N50060 X0.3816 Z-0.0013 N50070 X0.3805 Z-0.0000 N50080 Y0.3785 Z-0.0000 N50090 X0.3816 Z-0.0013 N50100 X0.4146 Z-0.0585 N50110 X0.4157 Z-0.0600 N50120 X0.8645 N50130 X0.8656 Z-0.0592 N50140 X0.8689 Z-0.0556 N50150 X0.8722 Z-0.0524 N50160 X0.8744 Z-0.0505 N50170 X0.8766 Z-0.0488 N50180 X0.8788 Z-0.0474 N50190 X0.8810 Z-0.0462 N50200 X0.8832 Z-0.0454 N50210 X0.8843 Z-0.0450 N50220 X0.8942 Z-0.0431 N50230 X0.9008 Z-0.0417 N50240 X0.9074 Z-0.0400 N50250 X0.9140 Z-0.0381 N50260 X0.9206 Z-0.0360 N50270 X0.9261 Z-0.0339 N50280 X0.9316 Z-0.0317 N50290 X0.9360 Z-0.0297 N50300 X0.9404 Z-0.0274 N50310 X0.9448 Z-0.0250 N50320 X0.9492 Z-0.0222 N50330 X0.9525 Z-0.0200 N50340 X0.9558 Z-0.0175 N50350 X0.9602 Z-0.0139 N50360 X0.9646 Z-0.0098 N50370 X0.9679 Z-0.0063 N50380 X0.9712 Z-0.0022 N50390 X0.9723 Z-0.0007 N50400 X0.9734 Z-0.0003 N50410 X0.9737 Y0.3789 Z0.0000 N50420 X0.9750 Y0.3806 N50430 X0.9754 Y0.3811 Z-0.0002 N50440 X0.9758 Y0.3817 Z0.0000 N50450 X0.9763 Y0.3826 Z-0.0001 N50460 X0.9769 Y0.3835 Z0.0000 N50470 X0.9758 Z-0.0007 N50480 X0.9703 Z-0.0085 N50490 X0.9659 Z-0.0144 N50500 X0.9626 Z-0.0184 N50510 X0.9604 Z-0.0207 N50520 X0.9560 Z-0.0247 N50530 X0.9527 Z-0.0273 N50540 X0.9483 Z-0.0305 N50550 X0.9439 Z-0.0333 N50560 X0.9406 Z-0.0352 N50570 X0.9362 Z-0.0375 N50580 X0.9318 Z-0.0396 N50590 X0.9263 Z-0.0420 N50600 X0.9208 Z-0.0440 N50610 X0.9142 Z-0.0462 N50620 X0.9076 Z-0.0482 N50630 X0.8999 Z-0.0501 N50640 X0.8911 Z-0.0520 N50650 X0.8845 Z-0.0532 N50660 X0.8823 Z-0.0538 N50670 X0.8801 Z-0.0547 N50680 X0.8779 Z-0.0557 N50690 X0.8757 Z-0.0571 N50700 X0.8735 Z-0.0586 N50710 X0.8724 Z-0.0595 N50720 X0.8713 Z-0.0600 N50730 X0.4157 N50740 X0.4146 Z-0.0585 N50750 X0.3816 Z-0.0013 N50760 X0.3805 Z-0.0000 N50770 Y0.3885 Z-0.0000 N50780 X0.3816 Z-0.0013 N50790 X0.4146 Z-0.0585 N50800 X0.4157 Z-0.0600 N50810 X0.8958 N50820 X0.8991 Z-0.0593 N50830 X0.9057 Z-0.0577 N50840 X0.9112 Z-0.0561 N50850 X0.9168 Z-0.0544 N50860 X0.9223 Z-0.0524 N50870 X0.9278 Z-0.0502 N50880 X0.9322 Z-0.0483 N50890 X0.9366 Z-0.0461 N50900 X0.9410 Z-0.0437 N50910 X0.9454 Z-0.0410 N50920 X0.9498 Z-0.0379 N50930 X0.9542 Z-0.0342 N50940 X0.9575 Z-0.0311 N50950 X0.9597 Z-0.0286 N50960 X0.9630 Z-0.0242 N50970 X0.9674 Z-0.0180 N50980 X0.9729 Z-0.0098 N50990 X0.9773 Z-0.0030 N51000 X0.9784 Z-0.0014 N51010 X0.9795 Z0.0000 N51020 X0.9799 Y0.3894 Z-0.0004 N51030 X0.9804 Y0.3904 Z0.0000 N51040 X0.9807 Y0.3912 Z-0.0001 N51050 X0.9810 Y0.3920 N51060 X0.9813 Y0.3927 Z-0.0000 N51070 X0.9815 Y0.3935 Z0.0000 N51080 X0.9793 Z-0.0030 N51090 X0.9694 Z-0.0188 N51100 X0.9617 Z-0.0307 N51110 X0.9573 Z-0.0372 N51120 X0.9551 Z-0.0402 N51130 X0.9540 Z-0.0415 N51140 X0.9507 Z-0.0445 N51150 X0.9474 Z-0.0471 N51160 X0.9441 Z-0.0495 N51170 X0.9397 Z-0.0522 N51180 X0.9342 Z-0.0553 N51190 X0.9287 Z-0.0579 N51200 X0.9243 Z-0.0597 N51210 X0.9232 Z-0.0600 N51220 X0.4157 N51230 X0.4146 Z-0.0585 N51240 X0.3816 Z-0.0013 N51250 X0.3805 Z-0.0000 N51260 Y0.3985 Z-0.0000 N51270 X0.3816 Z-0.0013 N51280 X0.4146 Z-0.0584 N51290 X0.4157 Z-0.0600 N51300 X0.9403 N51310 X0.9414 Z-0.0595 N51320 X0.9447 Z-0.0572 N51330 X0.9480 Z-0.0545 N51340 X0.9491 Z-0.0536 N51350 X0.9502 Z-0.0522 N51360 X0.9546 Z-0.0456 N51370 X0.9634 Z-0.0317 N51380 X0.9755 Z-0.0119 N51390 X0.9821 Z-0.0010 N51400 X0.9832 Z-0.0002 N51410 X0.9837 Y0.4004 Z0.0000 N51420 X0.9839 Y0.4014 N51430 X0.9842 Y0.4024 Z-0.0003 N51440 X0.9844 Y0.4035 Z-0.0004 N51450 X0.9833 Z-0.0011 N51460 X0.9668 Z-0.0288 N51470 X0.9547 Z-0.0489 N51480 X0.9481 Z-0.0595 N51490 X0.9470 Z-0.0600 N51500 X0.4157 N51510 X0.4146 Z-0.0585 N51520 X0.3816 Z-0.0013 N51530 X0.3805 Z-0.0000 N51540 Y0.4085 Z-0.0000 N51550 X0.3816 Z-0.0013 N51560 X0.4146 Z-0.0585 N51570 X0.4157 Z-0.0600 N51580 X0.9492 N51590 X0.9503 Z-0.0586 N51600 X0.9712 Z-0.0234 N51610 X0.9844 Z-0.0010 N51620 X0.9855 Z-0.0004 N51630 X0.9858 Y0.4100 Z0.0000 N51640 X0.9861 Y0.4126 N51650 X0.9863 Y0.4134 Z-0.0001 N51660 X0.9852 Z-0.0013 N51670 X0.9610 Z-0.0427 N51680 X0.9511 Z-0.0595 N51690 X0.9500 Z-0.0600 N51700 X0.4157 N51710 X0.4146 Z-0.0584 N51720 X0.3816 Z-0.0013 N51730 X0.3805 Z-0.0000 N51740 Y0.4184 Z-0.0000 N51750 X0.3816 Z-0.0013 N51760 X0.4146 Z-0.0585 N51770 X0.4157 Z-0.0600 N51780 X0.9506 N51790 X0.9517 Z-0.0597 N51800 X0.9792 Z-0.0125 N51810 X0.9858 Z-0.0011 N51820 X0.9869 Z0.0000 N51830 X0.9874 Y0.4226 Z-0.0000 N51840 X0.9874 Y0.4234 Z-0.0002 N51850 X0.9863 Z-0.0013 N51860 X0.9523 Z-0.0600 N51870 X0.8401 Z-0.0600 N51880 X0.7192 N51890 X0.5916 N51900 X0.4674 N51910 X0.4157 N51920 X0.4146 Z-0.0584 N51930 X0.3816 Z-0.0013 N51940 X0.3805 Z-0.0000 N51950 Y0.4284 Z-0.0000 N51960 X0.3816 Z-0.0013 N51970 X0.4146 Z-0.0585 N51980 X0.4157 Z-0.0600 N51990 X0.9515 N52000 X0.9526 Z-0.0598 N52010 X0.9867 Z-0.0009 N52020 X0.9878 Z-0.0001 N52030 X0.9879 Y0.4294 Z0.0000 N52040 X0.9881 Y0.4334 N52050 X0.9870 Z-0.0014 N52060 X0.9540 Z-0.0585 N52070 X0.9529 Z-0.0600 N52080 X0.4157 N52090 X0.4146 Z-0.0585 N52100 X0.3816 Z-0.0013 N52110 X0.3805 Z-0.0000 N52120 Y0.4384 Z-0.0000 N52130 X0.3816 Z-0.0013 N52140 X0.4146 Z-0.0585 N52150 X0.4157 Z-0.0600 N52160 X0.9531 N52170 X0.9542 Z-0.0586 N52180 X0.9861 Z-0.0033 N52190 X0.9883 Z0.0000 N52200 X0.9884 Y0.4434 N52210 X0.9873 Z-0.0014 N52220 X0.9543 Z-0.0586 N52230 X0.9532 Z-0.0600 N52240 X0.4157 N52250 X0.4146 Z-0.0586 N52260 X0.3816 Z-0.0013 N52270 X0.3805 Z-0.0000 N52280 Y0.4484 Z-0.0000 N52290 X0.3816 Z-0.0013 N52300 X0.4146 Z-0.0586 N52310 X0.4157 Z-0.0600 N52320 X0.9532 N52330 X0.9543 Z-0.0586 N52340 X0.9873 Z-0.0013 N52350 X0.9884 Z0.0000 N52360 Y0.4534 N52370 X0.9873 Z-0.0013 N52380 X0.9543 Z-0.0586 N52390 X0.9532 Z-0.0600 N52400 X0.4157 N52410 X0.4146 Z-0.0586 N52420 X0.3816 Z-0.0013 N52430 X0.3805 Z-0.0000 N52440 Y0.4584 Z-0.0000 N52450 X0.3816 Z-0.0013 N52460 X0.4146 Z-0.0586 N52470 X0.4157 Z-0.0600 N52480 X0.9532 N52490 X0.9543 Z-0.0586 N52500 X0.9873 Z-0.0013 N52510 X0.9884 Z0.0000 N52520 Y0.4634 N52530 X0.9873 Z-0.0013 N52540 X0.9543 Z-0.0586 N52550 X0.9532 Z-0.0600 N52560 X0.4157 N52570 X0.4146 Z-0.0586 N52580 X0.3816 Z-0.0013 N52590 X0.3805 Z-0.0000 N52600 Y0.4684 Z-0.0000 N52610 X0.3816 Z-0.0013 N52620 X0.4146 Z-0.0586 N52630 X0.4157 Z-0.0600 N52640 X0.9532 N52650 X0.9543 Z-0.0586 N52660 X0.9873 Z-0.0013 N52670 X0.9884 Z0.0000 N52680 Y0.4734 N52690 X0.9873 Z-0.0013 N52700 X0.9543 Z-0.0586 N52710 X0.9532 Z-0.0600 N52720 X0.4157 N52730 X0.4146 Z-0.0586 N52740 X0.3816 Z-0.0013 N52750 X0.3805 Z-0.0000 N52760 Y0.4784 Z-0.0000 N52770 X0.3816 Z-0.0013 N52780 X0.4146 Z-0.0586 N52790 X0.4157 Z-0.0600 N52800 X0.9532 N52810 X0.9543 Z-0.0586 N52820 X0.9873 Z-0.0013 N52830 X0.9884 Z0.0000 N52840 Y0.4834 N52850 X0.9873 Z-0.0013 N52860 X0.9543 Z-0.0586 N52870 X0.9532 Z-0.0600 N52880 X0.4157 N52890 X0.4146 Z-0.0586 N52900 X0.3816 Z-0.0013 N52910 X0.3805 Z-0.0000 N52920 Y0.4884 Z-0.0000 N52930 X0.3816 Z-0.0013 N52940 X0.4146 Z-0.0586 N52950 X0.4157 Z-0.0600 N52960 X0.9532 N52970 X0.9543 Z-0.0586 N52980 X0.9873 Z-0.0013 N52990 X0.9884 Z0.0000 N53000 Y0.4934 N53010 X0.9873 Z-0.0013 N53020 X0.9543 Z-0.0586 N53030 X0.9532 Z-0.0600 N53040 X0.4157 N53050 X0.4146 Z-0.0586 N53060 X0.3816 Z-0.0013 N53070 X0.3805 Z-0.0000 N53080 Y0.4984 Z-0.0000 N53090 X0.3816 Z-0.0013 N53100 X0.4146 Z-0.0586 N53110 X0.4157 Z-0.0600 N53120 X0.9532 N53130 X0.9543 Z-0.0586 N53140 X0.9873 Z-0.0013 N53150 X0.9884 Z0.0000 N53160 Y0.5033 N53170 X0.9873 Z-0.0013 N53180 X0.9543 Z-0.0586 N53190 X0.9532 Z-0.0600 N53200 X0.4157 N53210 X0.4146 Z-0.0586 N53220 X0.3816 Z-0.0013 N53230 X0.3805 Z-0.0000 N53240 Y0.5083 Z-0.0000 N53250 X0.3816 Z-0.0013 N53260 X0.4146 Z-0.0586 N53270 X0.4157 Z-0.0600 N53280 X0.9532 N53290 X0.9543 Z-0.0586 N53300 X0.9873 Z-0.0013 N53310 X0.9884 Z0.0000 N53320 Y0.5133 N53330 X0.9873 Z-0.0013 N53340 X0.9543 Z-0.0586 N53350 X0.9532 Z-0.0600 N53360 X0.4157 N53370 X0.4146 Z-0.0586 N53380 X0.3816 Z-0.0013 N53390 X0.3805 Z-0.0000 N53400 Y0.5183 Z-0.0000 N53410 X0.3816 Z-0.0013 N53420 X0.4146 Z-0.0586 N53430 X0.4157 Z-0.0600 N53440 X0.9532 N53450 X0.9543 Z-0.0586 N53460 X0.9873 Z-0.0013 N53470 X0.9884 Z0.0000 N53480 Y0.5233 N53490 X0.9873 Z-0.0013 N53500 X0.9543 Z-0.0586 N53510 X0.9532 Z-0.0600 N53520 X0.4157 N53530 X0.4146 Z-0.0586 N53540 X0.3816 Z-0.0013 N53550 X0.3805 Z-0.0000 N53560 Y0.5283 Z-0.0000 N53570 X0.3816 Z-0.0013 N53580 X0.4146 Z-0.0586 N53590 X0.4157 Z-0.0600 N53600 X0.9532 N53610 X0.9543 Z-0.0586 N53620 X0.9873 Z-0.0013 N53630 X0.9884 Z0.0000 N53640 Y0.5333 N53650 X0.9873 Z-0.0013 N53660 X0.9543 Z-0.0586 N53670 X0.9532 Z-0.0600 N53680 X0.4157 N53690 X0.4146 Z-0.0586 N53700 X0.3816 Z-0.0013 N53710 X0.3805 Z-0.0000 N53720 Y0.5383 Z-0.0000 N53730 X0.3816 Z-0.0013 N53740 X0.4146 Z-0.0586 N53750 X0.4157 Z-0.0600 N53760 X0.9532 N53770 X0.9543 Z-0.0586 N53780 X0.9873 Z-0.0013 N53790 X0.9884 Z0.0000 N53800 Y0.5433 N53810 X0.9873 Z-0.0013 N53820 X0.9543 Z-0.0586 N53830 X0.9532 Z-0.0600 N53840 X0.4157 N53850 X0.4146 Z-0.0586 N53860 X0.3816 Z-0.0013 N53870 X0.3805 Z-0.0000 N53880 Y0.5483 Z-0.0000 N53890 X0.3816 Z-0.0013 N53900 X0.4146 Z-0.0586 N53910 X0.4157 Z-0.0600 N53920 X0.9532 N53930 X0.9543 Z-0.0586 N53940 X0.9873 Z-0.0013 N53950 X0.9884 Z0.0000 N53960 Y0.5533 N53970 X0.9873 Z-0.0013 N53980 X0.9543 Z-0.0586 N53990 X0.9532 Z-0.0600 N54000 X0.4157 N54010 X0.4146 Z-0.0586 N54020 X0.3816 Z-0.0013 N54030 X0.3805 Z-0.0000 N54040 Y0.5583 Z-0.0000 N54050 X0.3816 Z-0.0013 N54060 X0.4146 Z-0.0586 N54070 X0.4157 Z-0.0600 N54080 X0.9532 N54090 X0.9543 Z-0.0586 N54100 X0.9873 Z-0.0013 N54110 X0.9884 Z0.0000 N54120 Y0.5633 N54130 X0.9873 Z-0.0013 N54140 X0.9543 Z-0.0586 N54150 X0.9532 Z-0.0600 N54160 X0.4157 N54170 X0.4146 Z-0.0586 N54180 X0.3816 Z-0.0013 N54190 X0.3805 Z-0.0000 N54200 Y0.5683 Z-0.0000 N54210 X0.3816 Z-0.0013 N54220 X0.4146 Z-0.0586 N54230 X0.4157 Z-0.0600 N54240 X0.9532 N54250 X0.9543 Z-0.0586 N54260 X0.9873 Z-0.0013 N54270 X0.9884 Z0.0000 N54280 Y0.5733 N54290 X0.9873 Z-0.0013 N54300 X0.9543 Z-0.0586 N54310 X0.9532 Z-0.0600 N54320 X0.4157 N54330 X0.4146 Z-0.0586 N54340 X0.3816 Z-0.0013 N54350 X0.3805 Z-0.0000 N54360 Y0.5783 Z-0.0000 N54370 X0.3816 Z-0.0013 N54380 X0.4146 Z-0.0586 N54390 X0.4157 Z-0.0600 N54400 X0.9532 N54410 X0.9543 Z-0.0586 N54420 X0.9873 Z-0.0013 N54430 X0.9884 Z0.0000 N54440 Y0.5833 N54450 X0.9873 Z-0.0013 N54460 X0.9543 Z-0.0586 N54470 X0.9532 Z-0.0600 N54480 X0.4157 N54490 X0.4146 Z-0.0586 N54500 X0.3816 Z-0.0013 N54510 X0.3805 Z-0.0000 N54520 Y0.5883 Z-0.0000 N54530 X0.3816 Z-0.0013 N54540 X0.4146 Z-0.0586 N54550 X0.4157 Z-0.0600 N54560 X0.9532 N54570 X0.9543 Z-0.0586 N54580 X0.9873 Z-0.0013 N54590 X0.9884 Z0.0000 N54600 Y0.5932 N54610 X0.9873 Z-0.0013 N54620 X0.9543 Z-0.0586 N54630 X0.9532 Z-0.0600 N54640 X0.4157 N54650 X0.4146 Z-0.0586 N54660 X0.3816 Z-0.0013 N54670 X0.3805 Z-0.0000 N54680 Y0.5982 Z-0.0000 N54690 X0.3816 Z-0.0013 N54700 X0.4146 Z-0.0586 N54710 X0.4157 Z-0.0600 N54720 X0.9532 N54730 X0.9543 Z-0.0586 N54740 X0.9873 Z-0.0013 N54750 X0.9884 Z0.0000 N54760 Y0.6032 N54770 X0.9873 Z-0.0013 N54780 X0.9543 Z-0.0586 N54790 X0.9532 Z-0.0600 N54800 X0.4157 N54810 X0.4146 Z-0.0586 N54820 X0.3816 Z-0.0013 N54830 X0.3805 Z-0.0000 N54840 Y0.6082 Z-0.0000 N54850 X0.3816 Z-0.0013 N54860 X0.4146 Z-0.0586 N54870 X0.4157 Z-0.0600 N54880 X0.9532 N54890 X0.9543 Z-0.0586 N54900 X0.9873 Z-0.0013 N54910 X0.9884 Z0.0000 N54920 Y0.6132 N54930 X0.9873 Z-0.0013 N54940 X0.9543 Z-0.0586 N54950 X0.9532 Z-0.0600 N54960 X0.4157 N54970 X0.4146 Z-0.0586 N54980 X0.3816 Z-0.0013 N54990 X0.3805 Z-0.0000 N55000 Y0.6182 Z-0.0000 N55010 X0.3816 Z-0.0013 N55020 X0.4146 Z-0.0586 N55030 X0.4157 Z-0.0600 N55040 X0.9532 N55050 X0.9543 Z-0.0586 N55060 X0.9873 Z-0.0013 N55070 X0.9884 Z0.0000 N55080 Y0.6232 N55090 X0.9873 Z-0.0013 N55100 X0.9543 Z-0.0586 N55110 X0.9532 Z-0.0600 N55120 X0.4157 N55130 X0.4146 Z-0.0586 N55140 X0.3816 Z-0.0013 N55150 X0.3805 Z-0.0000 N55160 Y0.6282 Z-0.0000 N55170 X0.3816 Z-0.0013 N55180 X0.4146 Z-0.0586 N55190 X0.4157 Z-0.0600 N55200 X0.9532 N55210 X0.9543 Z-0.0586 N55220 X0.9873 Z-0.0013 N55230 X0.9884 Z0.0000 N55240 Y0.6332 N55250 X0.9873 Z-0.0013 N55260 X0.9543 Z-0.0586 N55270 X0.9532 Z-0.0600 N55280 X0.4157 N55290 X0.4146 Z-0.0586 N55300 X0.3816 Z-0.0013 N55310 X0.3805 Z-0.0000 N55320 Y0.6382 Z-0.0000 N55330 X0.3816 Z-0.0013 N55340 X0.4146 Z-0.0586 N55350 X0.4157 Z-0.0600 N55360 X0.9532 N55370 X0.9543 Z-0.0586 N55380 X0.9873 Z-0.0013 N55390 X0.9884 Z0.0000 N55400 Y0.6432 N55410 X0.9873 Z-0.0013 N55420 X0.9543 Z-0.0586 N55430 X0.9532 Z-0.0600 N55440 X0.4157 N55450 X0.4146 Z-0.0586 N55460 X0.3816 Z-0.0013 N55470 X0.3805 Z-0.0000 N55480 Y0.6482 Z-0.0000 N55490 X0.3816 Z-0.0013 N55500 X0.4146 Z-0.0586 N55510 X0.4157 Z-0.0600 N55520 X0.9532 N55530 X0.9543 Z-0.0586 N55540 X0.9873 Z-0.0013 N55550 X0.9884 Z0.0000 N55560 Y0.6532 N55570 X0.9873 Z-0.0013 N55580 X0.9543 Z-0.0586 N55590 X0.9532 Z-0.0600 N55600 X0.4157 N55610 X0.4146 Z-0.0586 N55620 X0.3816 Z-0.0013 N55630 X0.3805 Z-0.0000 N55640 Y0.6582 Z-0.0000 N55650 X0.3816 Z-0.0013 N55660 X0.4146 Z-0.0586 N55670 X0.4157 Z-0.0600 N55680 X0.9532 N55690 X0.9543 Z-0.0586 N55700 X0.9873 Z-0.0013 N55710 X0.9884 Z0.0000 N55720 Y0.6632 N55730 X0.9873 Z-0.0013 N55740 X0.9543 Z-0.0586 N55750 X0.9532 Z-0.0600 N55760 X0.4157 N55770 X0.4146 Z-0.0586 N55780 X0.3816 Z-0.0013 N55790 X0.3805 Z-0.0000 N55800 Y0.6682 Z-0.0000 N55810 X0.3816 Z-0.0013 N55820 X0.4146 Z-0.0586 N55830 X0.4157 Z-0.0600 N55840 X0.9532 N55850 X0.9543 Z-0.0586 N55860 X0.9873 Z-0.0013 N55870 X0.9884 Z0.0000 N55880 Y0.6732 N55890 X0.9873 Z-0.0013 N55900 X0.9543 Z-0.0586 N55910 X0.9532 Z-0.0600 N55920 X0.4157 N55930 X0.4146 Z-0.0586 N55940 X0.3816 Z-0.0013 N55950 X0.3805 Z-0.0000 N55960 Y0.6782 Z-0.0000 N55970 X0.3816 Z-0.0013 N55980 X0.4146 Z-0.0586 N55990 X0.4157 Z-0.0600 N56000 X0.9532 N56010 X0.9543 Z-0.0586 N56020 X0.9873 Z-0.0013 N56030 X0.9884 Z0.0000 N56040 Y0.6831 N56050 X0.9873 Z-0.0013 N56060 X0.9543 Z-0.0586 N56070 X0.9532 Z-0.0600 N56080 X0.4157 N56090 X0.4146 Z-0.0586 N56100 X0.3816 Z-0.0013 N56110 X0.3805 Z-0.0000 N56120 Y0.6881 Z-0.0000 N56130 X0.3816 Z-0.0013 N56140 X0.4146 Z-0.0586 N56150 X0.4157 Z-0.0600 N56160 X0.9532 N56170 X0.9543 Z-0.0586 N56180 X0.9873 Z-0.0013 N56190 X0.9884 Z0.0000 N56200 Y0.6931 N56210 X0.9873 Z-0.0013 N56220 X0.9543 Z-0.0586 N56230 X0.9532 Z-0.0600 N56240 X0.6151 N56250 X0.6052 Z-0.0587 N56260 X0.5975 Z-0.0579 N56270 X0.5898 Z-0.0575 N56280 X0.5831 Z-0.0573 N56290 X0.5765 Z-0.0575 N56300 X0.5710 Z-0.0578 N56310 X0.5655 Z-0.0584 N56320 X0.5600 Z-0.0592 N56330 X0.5567 Z-0.0598 N56340 X0.5556 Z-0.0600 N56350 X0.4157 N56360 X0.4146 Z-0.0586 N56370 X0.3816 Z-0.0013 N56380 X0.3805 Z-0.0000 N56390 Y0.6981 Z-0.0000 N56400 X0.3816 Z-0.0013 N56410 X0.4146 Z-0.0586 N56420 X0.4157 Z-0.0600 N56430 X0.5281 N56440 X0.5336 Z-0.0577 N56450 X0.5402 Z-0.0553 N56460 X0.5468 Z-0.0533 N56470 X0.5534 Z-0.0516 N56480 X0.5600 Z-0.0502 N56490 X0.5666 Z-0.0492 N56500 X0.5721 Z-0.0487 N56510 X0.5776 Z-0.0484 N56520 X0.5842 Z-0.0483 N56530 X0.5909 Z-0.0485 N56540 X0.5986 Z-0.0490 N56550 X0.6052 Z-0.0496 N56560 X0.6129 Z-0.0507 N56570 X0.6184 Z-0.0516 N56580 X0.6261 Z-0.0532 N56590 X0.6327 Z-0.0548 N56600 X0.6393 Z-0.0567 N56610 X0.6459 Z-0.0588 N56620 X0.6492 Z-0.0599 N56630 X0.6503 Z-0.0600 N56640 X0.9532 N56650 X0.9543 Z-0.0586 N56660 X0.9873 Z-0.0013 N56670 X0.9884 Z0.0000 N56680 Y0.7031 N56690 X0.9873 Z-0.0013 N56700 X0.9543 Z-0.0586 N56710 X0.9532 Z-0.0600 N56720 X0.6691 N56730 X0.6635 Z-0.0575 N56740 X0.6569 Z-0.0547 N56750 X0.6503 Z-0.0522 N56760 X0.6426 Z-0.0495 N56770 X0.6371 Z-0.0479 N56780 X0.6294 Z-0.0458 N56790 X0.6239 Z-0.0445 N56800 X0.6162 Z-0.0430 N56810 X0.6096 Z-0.0419 N56820 X0.6019 Z-0.0410 N56830 X0.5953 Z-0.0404 N56840 X0.5876 Z-0.0400 N56850 X0.5809 Z-0.0400 N56860 X0.5743 Z-0.0402 N56870 X0.5688 Z-0.0407 N56880 X0.5633 Z-0.0414 N56890 X0.5578 Z-0.0424 N56900 X0.5523 Z-0.0436 N56910 X0.5468 Z-0.0451 N56920 X0.5402 Z-0.0472 N56930 X0.5336 Z-0.0497 N56940 X0.5270 Z-0.0525 N56950 X0.5215 Z-0.0551 N56960 X0.5160 Z-0.0579 N56970 X0.5127 Z-0.0597 N56980 X0.5116 Z-0.0600 N56990 X0.4157 N57000 X0.4146 Z-0.0586 N57010 X0.3816 Z-0.0013 N57020 X0.3805 Z-0.0000 N57030 Y0.7081 Z-0.0000 N57040 X0.3816 Z-0.0013 N57050 X0.4146 Z-0.0586 N57060 X0.4157 Z-0.0600 N57070 X0.4983 N57080 X0.4994 Z-0.0595 N57090 X0.5061 Z-0.0552 N57100 X0.5138 Z-0.0505 N57110 X0.5204 Z-0.0470 N57120 X0.5270 Z-0.0437 N57130 X0.5336 Z-0.0408 N57140 X0.5402 Z-0.0383 N57150 X0.5468 Z-0.0361 N57160 X0.5534 Z-0.0344 N57170 X0.5589 Z-0.0332 N57180 X0.5644 Z-0.0322 N57190 X0.5699 Z-0.0315 N57200 X0.5754 Z-0.0311 N57210 X0.5820 Z-0.0309 N57220 X0.5898 Z-0.0311 N57230 X0.5975 Z-0.0315 N57240 X0.6041 Z-0.0322 N57250 X0.6118 Z-0.0332 N57260 X0.6173 Z-0.0342 N57270 X0.6250 Z-0.0357 N57280 X0.6316 Z-0.0374 N57290 X0.6382 Z-0.0392 N57300 X0.6448 Z-0.0414 N57310 X0.6514 Z-0.0437 N57320 X0.6580 Z-0.0464 N57330 X0.6657 Z-0.0497 N57340 X0.6724 Z-0.0529 N57350 X0.6801 Z-0.0568 N57360 X0.6856 Z-0.0599 N57370 X0.6867 Z-0.0600 N57380 X0.9532 N57390 X0.9543 Z-0.0586 N57400 X0.9873 Z-0.0013 N57410 X0.9884 Z0.0000 N57420 Y0.7131 N57430 X0.9873 Z-0.0013 N57440 X0.9543 Z-0.0586 N57450 X0.9532 Z-0.0600 N57460 X0.6988 N57470 X0.6966 Z-0.0587 N57480 X0.6911 Z-0.0553 N57490 X0.6834 Z-0.0508 N57500 X0.6768 Z-0.0472 N57510 X0.6679 Z-0.0428 N57520 X0.6624 Z-0.0402 N57530 X0.6547 Z-0.0370 N57540 X0.6481 Z-0.0344 N57550 X0.6404 Z-0.0318 N57560 X0.6349 Z-0.0301 N57570 X0.6272 Z-0.0281 N57580 X0.6217 Z-0.0268 N57590 X0.6151 Z-0.0255 N57600 X0.6085 Z-0.0245 N57610 X0.6008 Z-0.0236 N57620 X0.5942 Z-0.0230 N57630 X0.5876 Z-0.0227 N57640 X0.5809 Z-0.0226 N57650 X0.5743 Z-0.0229 N57660 X0.5677 Z-0.0235 N57670 X0.5611 Z-0.0245 N57680 X0.5545 Z-0.0259 N57690 X0.5479 Z-0.0277 N57700 X0.5413 Z-0.0298 N57710 X0.5347 Z-0.0323 N57720 X0.5281 Z-0.0353 N57730 X0.5204 Z-0.0391 N57740 X0.5138 Z-0.0427 N57750 X0.5061 Z-0.0474 N57760 X0.4983 Z-0.0525 N57770 X0.4906 Z-0.0580 N57780 X0.4884 Z-0.0597 N57790 X0.4873 Z-0.0600 N57800 X0.4157 N57810 X0.4146 Z-0.0586 N57820 X0.3816 Z-0.0013 N57830 X0.3805 Z-0.0000 N57840 Y0.7181 Z-0.0000 N57850 X0.3816 Z-0.0013 N57860 X0.4146 Z-0.0586 N57870 X0.4157 Z-0.0600 N57880 X0.4774 N57890 X0.4785 Z-0.0598 N57900 X0.4862 Z-0.0535 N57910 X0.4939 Z-0.0476 N57920 X0.5017 Z-0.0421 N57930 X0.5094 Z-0.0370 N57940 X0.5160 Z-0.0330 N57950 X0.5226 Z-0.0294 N57960 X0.5292 Z-0.0261 N57970 X0.5358 Z-0.0232 N57980 X0.5424 Z-0.0206 N57990 X0.5479 Z-0.0188 N58000 X0.5523 Z-0.0176 N58010 X0.5578 Z-0.0163 N58020 X0.5633 Z-0.0152 N58030 X0.5688 Z-0.0145 N58040 X0.5743 Z-0.0139 N58050 X0.5798 Z-0.0137 N58060 X0.5865 Z-0.0137 N58070 X0.5942 Z-0.0141 N58080 X0.6008 Z-0.0146 N58090 X0.6085 Z-0.0156 N58100 X0.6151 Z-0.0166 N58110 X0.6228 Z-0.0181 N58120 X0.6294 Z-0.0198 N58130 X0.6360 Z-0.0216 N58140 X0.6426 Z-0.0237 N58150 X0.6492 Z-0.0261 N58160 X0.6558 Z-0.0287 N58170 X0.6624 Z-0.0316 N58180 X0.6691 Z-0.0347 N58190 X0.6768 Z-0.0387 N58200 X0.6834 Z-0.0424 N58210 X0.6900 Z-0.0463 N58220 X0.6966 Z-0.0505 N58230 X0.7054 Z-0.0564 N58240 X0.7098 Z-0.0595 N58250 X0.7109 Z-0.0600 N58260 X0.9532 N58270 X0.9543 Z-0.0586 N58280 X0.9873 Z-0.0013 N58290 X0.9884 Z0.0000 N58300 Y0.7231 N58310 X0.9873 Z-0.0013 N58320 X0.9543 Z-0.0586 N58330 X0.9532 Z-0.0600 N58340 X0.7208 N58350 X0.7109 Z-0.0526 N58360 X0.7032 Z-0.0471 N58370 X0.6933 Z-0.0405 N58380 X0.6867 Z-0.0364 N58390 X0.6790 Z-0.0320 N58400 X0.6724 Z-0.0284 N58410 X0.6646 Z-0.0245 N58420 X0.6591 Z-0.0220 N58430 X0.6525 Z-0.0192 N58440 X0.6470 Z-0.0171 N58450 X0.6393 Z-0.0144 N58460 X0.6338 Z-0.0127 N58470 X0.6261 Z-0.0106 N58480 X0.6206 Z-0.0093 N58490 X0.6140 Z-0.0080 N58500 X0.6074 Z-0.0070 N58510 X0.6008 Z-0.0062 N58520 X0.5942 Z-0.0057 N58530 X0.5876 Z-0.0053 N58540 X0.5809 Z-0.0053 N58550 X0.5743 Z-0.0055 N58560 X0.5688 Z-0.0061 N58570 X0.5633 Z-0.0069 N58580 X0.5578 Z-0.0079 N58590 X0.5523 Z-0.0093 N58600 X0.5468 Z-0.0109 N58610 X0.5413 Z-0.0129 N58620 X0.5358 Z-0.0150 N58630 X0.5303 Z-0.0175 N58640 X0.5237 Z-0.0208 N58650 X0.5160 Z-0.0251 N58660 X0.5094 Z-0.0292 N58670 X0.5028 Z-0.0336 N58680 X0.4950 Z-0.0391 N58690 X0.4873 Z-0.0450 N58700 X0.4796 Z-0.0514 N58710 X0.4708 Z-0.0590 N58720 X0.4697 Z-0.0600 N58730 X0.4157 N58740 X0.4146 Z-0.0586 N58750 X0.3816 Z-0.0013 N58760 X0.3805 Z-0.0000 N58770 Y0.7281 Z-0.0000 N58780 X0.3816 Z-0.0013 N58790 X0.4146 Z-0.0584 N58800 X0.4157 Z-0.0600 N58810 X0.4619 N58820 X0.4630 Z-0.0591 N58830 X0.4696 Z-0.0528 N58840 X0.4762 Z-0.0468 N58850 X0.4839 Z-0.0402 N58860 X0.4915 Z-0.0339 N58870 X0.4992 Z-0.0280 N58880 X0.5058 Z-0.0233 N58890 X0.5124 Z-0.0189 N58900 X0.5190 Z-0.0149 N58910 X0.5256 Z-0.0113 N58920 X0.5322 Z-0.0080 N58930 X0.5388 Z-0.0051 N58940 X0.5454 Z-0.0027 N58950 X0.5509 Z-0.0009 N58960 X0.5542 Z-0.0000 N58970 X0.5575 Z0.0000 N58980 X0.5545 Y0.7285 Z-0.0000 N58990 X0.5525 Y0.7288 Z-0.0006 N59000 X0.5515 Y0.7290 Z-0.0002 N59010 X0.5505 Y0.7292 Z0.0000 N59020 X0.5485 Y0.7296 N59030 X0.5475 Y0.7297 Z-0.0001 N59040 X0.5465 Y0.7299 Z-0.0004 N59050 X0.5455 Y0.7301 Z-0.0002 N59060 X0.5446 Y0.7303 Z0.0000 N59070 X0.5436 Y0.7306 N59080 X0.5426 Y0.7308 Z-0.0001 N59090 X0.5416 Y0.7310 Z-0.0006 N59100 X0.5406 Y0.7312 Z-0.0002 N59110 X0.5396 Y0.7314 Z0.0000 N59120 X0.5377 Y0.7319 Z-0.0000 N59130 X0.5367 Y0.7322 Z-0.0005 N59140 X0.5357 Y0.7324 Z0.0000 N59150 X0.5347 Y0.7327 N59160 X0.5338 Y0.7329 Z-0.0001 N59170 X0.5333 Y0.7331 N59180 X0.5322 Z-0.0007 N59190 X0.5311 Z-0.0009 N59200 X0.5300 N59210 X0.5289 Z-0.0014 N59220 X0.5234 Z-0.0044 N59230 X0.5179 Z-0.0076 N59240 X0.5124 Z-0.0110 N59250 X0.5069 Z-0.0147 N59260 X0.5003 Z-0.0195 N59270 X0.4926 Z-0.0255 N59280 X0.4849 Z-0.0318 N59290 X0.4772 Z-0.0386 N59300 X0.4706 Z-0.0447 N59310 X0.4629 Z-0.0522 N59320 X0.4563 Z-0.0590 N59330 X0.4552 Z-0.0600 N59340 X0.4157 N59350 X0.4146 Z-0.0584 N59360 X0.3816 Z-0.0013 N59370 X0.3805 Z-0.0000 N59380 Y0.7381 Z-0.0000 N59390 X0.3816 Z-0.0013 N59400 X0.4155 Z-0.0598 N59410 X0.4166 Z-0.0600 N59420 X0.4483 N59430 X0.4494 Z-0.0596 N59440 X0.4559 Z-0.0522 N59450 X0.4636 Z-0.0442 N59460 X0.4712 Z-0.0366 N59470 X0.4778 Z-0.0306 N59480 X0.4844 Z-0.0248 N59490 X0.4931 Z-0.0175 N59500 X0.4986 Z-0.0132 N59510 X0.5040 Z-0.0090 N59520 X0.5106 Z-0.0044 N59530 X0.5172 Z-0.0002 N59540 X0.5183 Z0.0000 N59550 X0.5174 Y0.7384 Z-0.0002 N59560 X0.5166 Y0.7387 N59570 X0.5157 Y0.7391 Z0.0000 N59580 X0.5148 Y0.7395 N59590 X0.5138 Y0.7399 Z-0.0005 N59600 X0.5129 Y0.7402 Z0.0000 N59610 X0.5120 Y0.7406 Z-0.0002 N59620 X0.5110 Y0.7410 N59630 X0.5101 Y0.7414 Z0.0000 N59640 X0.5083 Y0.7422 Z-0.0001 N59650 X0.5074 Y0.7427 Z0.0000 N59660 X0.5065 Y0.7431 Z-0.0003 N59670 X0.5054 Z-0.0008 N59680 X0.5043 Z-0.0008 N59690 X0.5032 Z-0.0014 N59700 X0.4977 Z-0.0057 N59710 X0.4901 Z-0.0120 N59720 X0.4835 Z-0.0178 N59730 X0.4769 Z-0.0239 N59740 X0.4692 Z-0.0315 N59750 X0.4616 Z-0.0396 N59760 X0.4539 Z-0.0481 N59770 X0.4462 Z-0.0572 N59780 X0.4440 Z-0.0599 N59790 X0.4430 Z-0.0600 N59800 X0.4156 N59810 X0.3816 Z-0.0013 N59820 X0.3805 Z-0.0000 N59830 Y0.7481 Z-0.0000 N59840 X0.3816 Z-0.0013 N59850 X0.4156 Z-0.0600 N59860 X0.4386 N59870 X0.4397 Z-0.0593 N59880 X0.4473 Z-0.0497 N59890 X0.4550 Z-0.0404 N59900 X0.4627 Z-0.0317 N59910 X0.4703 Z-0.0234 N59920 X0.4769 Z-0.0168 N59930 X0.4824 Z-0.0115 N59940 X0.4879 Z-0.0066 N59950 X0.4944 Z-0.0010 N59960 X0.4955 Z-0.0002 N59970 X0.4966 Z0.0000 N59980 X0.4947 Y0.7491 N59990 X0.4939 Y0.7496 Z-0.0001 N60000 X0.4930 Y0.7501 Z0.0000 N60010 X0.4921 Y0.7506 Z-0.0004 N60020 X0.4912 Y0.7511 Z0.0000 N60030 X0.4903 Y0.7516 N60040 X0.4894 Y0.7522 Z-0.0001 N60050 X0.4880 Y0.7531 Z-0.0000 N60060 X0.4869 Z-0.0006 N60070 X0.4858 Z-0.0010 N60080 X0.4792 Z-0.0073 N60090 X0.4726 Z-0.0141 N60100 X0.4660 Z-0.0213 N60110 X0.4595 Z-0.0288 N60120 X0.4518 Z-0.0381 N60130 X0.4441 Z-0.0479 N60140 X0.4353 Z-0.0595 N60150 X0.4342 Z-0.0600 N60160 X0.4156 N60170 X0.4068 Z-0.0449 N60180 X0.3816 Z-0.0013 N60190 X0.3805 Z-0.0000 N60200 Y0.7581 Z-0.0000 N60210 X0.3816 Z-0.0013 N60220 X0.4146 Z-0.0583 N60230 X0.4157 Z-0.0600 N60240 X0.4310 N60250 X0.4321 Z-0.0588 N60260 X0.4398 Z-0.0481 N60270 X0.4475 Z-0.0378 N60280 X0.4552 Z-0.0280 N60290 X0.4629 Z-0.0187 N60300 X0.4695 Z-0.0111 N60310 X0.4761 Z-0.0040 N60320 X0.4794 Z-0.0006 N60330 X0.4805 Z0.0000 N60340 X0.4796 Y0.7587 Z-0.0003 N60350 X0.4787 Y0.7594 Z-0.0002 N60360 X0.4778 Y0.7600 Z0.0000 N60370 X0.4752 Y0.7621 N60380 X0.4740 Y0.7631 Z-0.0004 N60390 X0.4729 Z-0.0006 N60400 X0.4685 Z-0.0055 N60410 X0.4608 Z-0.0148 N60420 X0.4531 Z-0.0246 N60430 X0.4454 Z-0.0349 N60440 X0.4366 Z-0.0472 N60450 X0.4289 Z-0.0583 N60460 X0.4278 Z-0.0599 N60470 X0.4267 Z-0.0600 N60480 X0.4157 N60490 X0.4146 Z-0.0585 N60500 X0.3816 Z-0.0013 N60510 X0.3805 Z-0.0000 N60520 Y0.7681 Z-0.0000 N60530 X0.3816 Z-0.0013 N60540 X0.4146 Z-0.0585 N60550 X0.4157 Z-0.0600 N60560 X0.4245 N60570 X0.4256 Z-0.0591 N60580 X0.4344 Z-0.0458 N60590 X0.4432 Z-0.0330 N60600 X0.4520 Z-0.0207 N60610 X0.4597 Z-0.0104 N60620 X0.4652 Z-0.0034 N60630 X0.4685 Z0.0000 N60640 X0.4679 Y0.7686 Z-0.0002 N60650 X0.4673 Y0.7692 Z0.0000 N60660 X0.4653 Y0.7714 N60670 X0.4646 Y0.7722 Z-0.0001 N60680 X0.4639 Y0.7730 N60690 X0.4628 Z-0.0005 N60700 X0.4562 Z-0.0095 N60710 X0.4485 Z-0.0204 N60720 X0.4397 Z-0.0334 N60730 X0.4277 Z-0.0518 N60740 X0.4233 Z-0.0586 N60750 X0.4222 Z-0.0600 N60760 X0.4156 N60770 X0.4123 Z-0.0544 N60780 X0.3816 Z-0.0013 N60790 X0.3805 Z-0.0000 N60800 Y0.7780 Z-0.0000 N60810 X0.3816 Z-0.0013 N60820 X0.4153 Z-0.0595 N60830 X0.4164 Z-0.0600 N60840 X0.4197 N60850 X0.4208 Z-0.0589 N60860 X0.4284 Z-0.0467 N60870 X0.4382 Z-0.0315 N60880 X0.4469 Z-0.0184 N60890 X0.4556 Z-0.0055 N60900 X0.4578 Z-0.0023 N60910 X0.4589 Z-0.0011 N60920 X0.4600 Z-0.0002 N60930 X0.4596 Y0.7785 N60940 X0.4593 Y0.7790 Z0.0000 N60950 X0.4581 Y0.7807 Z-0.0000 N60960 X0.4577 Y0.7815 Z-0.0003 N60970 X0.4572 Y0.7822 Z0.0000 N60980 X0.4567 Y0.7830 Z-0.0001 N60990 X0.4556 Z-0.0008 N61000 X0.4545 Z-0.0023 N61010 X0.4447 Z-0.0172 N61020 X0.4328 Z-0.0361 N61030 X0.4251 Z-0.0484 N61040 X0.4186 Z-0.0592 N61050 X0.4175 Z-0.0600 N61060 X0.4164 N61070 X0.4153 Z-0.0595 N61080 X0.3816 Z-0.0013 N61090 X0.3805 Z-0.0000 N61100 Y0.7880 Z-0.0000 N61110 X0.3816 Z-0.0013 N61120 X0.4145 Z-0.0583 N61130 X0.4156 Z-0.0600 N61140 X0.4167 N61150 X0.4178 Z-0.0583 N61160 X0.4321 Z-0.0347 N61170 X0.4442 Z-0.0151 N61180 X0.4519 Z-0.0028 N61190 X0.4541 Z0.0000 N61200 X0.4537 Y0.7888 Z-0.0002 N61210 X0.4533 Y0.7897 Z0.0000 N61220 X0.4526 Y0.7913 Z-0.0001 N61230 X0.4523 Y0.7922 Z-0.0001 N61240 X0.4519 Y0.7930 Z0.0000 N61250 X0.4508 Z-0.0013 N61260 X0.4486 Z-0.0048 N61270 X0.4355 Z-0.0265 N61280 X0.4190 Z-0.0541 N61290 X0.4157 Z-0.0596 N61300 X0.4146 Z-0.0584 N61310 X0.3816 Z-0.0013 N61320 X0.3805 Z-0.0000 N61330 Y0.7980 Z-0.0000 N61340 X0.3816 Z-0.0013 N61350 X0.4143 Z-0.0578 N61360 X0.4154 Z-0.0584 N61370 X0.4372 Z-0.0211 N61380 X0.4492 Z-0.0010 N61390 X0.4503 Z-0.0003 N61400 X0.4501 Y0.7990 Z-0.0003 N61410 X0.4498 Y0.8000 Z0.0000 N61420 X0.4494 Y0.8019 N61430 X0.4491 Y0.8030 Z-0.0005 N61440 X0.4481 Z-0.0009 N61450 X0.4317 Z-0.0287 N61460 X0.4154 Z-0.0570 N61470 X0.4143 Z-0.0577 N61480 X0.3816 Z-0.0013 N61490 X0.3805 Z-0.0000 N61500 Y0.8080 Z-0.0000 N61510 X0.3816 Z-0.0013 N61520 X0.4144 Z-0.0580 N61530 X0.4276 Z-0.0353 N61540 X0.4473 Z-0.0012 N61550 X0.4484 Z0.0000 N61560 X0.4482 Y0.8092 Z-0.0000 N61570 X0.4481 Y0.8112 Z-0.0004 N61580 X0.4480 Y0.8121 Z-0.0005 N61590 X0.4480 Y0.8130 Z-0.0004 N61600 X0.4469 Z-0.0011 N61610 X0.4251 Z-0.0386 N61620 X0.4153 Z-0.0557 N61630 X0.4142 Z-0.0575 N61640 X0.3816 Z-0.0013 N61650 X0.3805 Z-0.0000 N61660 Y0.8180 Z-0.0000 N61670 X0.3816 Z-0.0013 N61680 X0.4131 Z-0.0556 N61690 X0.4142 Z-0.0575 N61700 X0.4185 Z-0.0499 N61710 X0.4262 Z-0.0367 N61720 X0.4468 Z-0.0011 N61730 X0.4479 Z-0.0004 N61740 X0.4479 Y0.8203 Z-0.0004 N61750 X0.4480 Y0.8221 Z-0.0005 N61760 X0.4481 Y0.8230 Z-0.0004 N61770 X0.4470 Z-0.0011 N61780 X0.4328 Z-0.0255 N61790 X0.4154 Z-0.0559 N61800 X0.4143 Z-0.0577 N61810 X0.3816 Z-0.0013 N61820 X0.3805 Z-0.0000 N61830 Y0.8280 Z-0.0000 N61840 X0.3816 Z-0.0013 N61850 X0.4134 Z-0.0563 N61860 X0.4145 Z-0.0581 N61870 X0.4419 Z-0.0109 N61880 X0.4474 Z-0.0014 N61890 X0.4485 Z0.0000 N61900 X0.4487 Y0.8295 N61910 X0.4490 Y0.8314 Z-0.0002 N61920 X0.4491 Y0.8324 Z-0.0005 N61930 X0.4492 Y0.8330 Z-0.0002 N61940 X0.4481 Z-0.0010 N61950 X0.4372 Z-0.0196 N61960 X0.4154 Z-0.0574 N61970 X0.4143 Z-0.0578 N61980 X0.3816 Z-0.0013 N61990 X0.3805 Z-0.0000 N62000 Y0.8380 Z-0.0000 N62010 X0.3816 Z-0.0013 N62020 X0.4143 Z-0.0577 N62030 X0.4154 Z-0.0585 N62040 X0.4361 Z-0.0229 N62050 X0.4492 Z-0.0008 N62060 X0.4503 Z-0.0003 N62070 X0.4505 Y0.8389 Z0.0000 N62080 X0.4508 Y0.8399 N62090 X0.4511 Y0.8409 Z-0.0001 N62100 X0.4514 Y0.8419 Z-0.0004 N62110 X0.4517 Y0.8430 Z0.0000 N62120 X0.4506 Z-0.0012 N62130 X0.4364 Z-0.0250 N62140 X0.4177 Z-0.0564 N62150 X0.4167 Z-0.0583 N62160 X0.4156 Z-0.0600 N62170 X0.3816 Z-0.0013 N62180 X0.3805 Z-0.0000 N62190 Y0.8480 Z-0.0000 N62200 X0.3816 Z-0.0013 N62210 X0.4154 Z-0.0596 N62220 X0.4165 Z-0.0600 N62230 X0.4176 Z-0.0583 N62240 X0.4318 Z-0.0345 N62250 X0.4405 Z-0.0200 N62260 X0.4514 Z-0.0024 N62270 X0.4525 Z-0.0007 N62280 X0.4536 Z-0.0002 N62290 X0.4539 Y0.8487 Z0.0000 N62300 X0.4550 Y0.8511 N62310 X0.4554 Y0.8520 N62320 X0.4559 Y0.8530 Z-0.0001 N62330 X0.4548 Z-0.0009 N62340 X0.4472 Z-0.0128 N62350 X0.4362 Z-0.0303 N62360 X0.4209 Z-0.0555 N62370 X0.4187 Z-0.0591 N62380 X0.4177 Z-0.0600 N62390 X0.4166 N62400 X0.4155 Z-0.0598 N62410 X0.3816 Z-0.0013 N62420 X0.3805 Z-0.0000 N62430 Y0.8580 Z-0.0000 N62440 X0.3816 Z-0.0013 N62450 X0.4153 Z-0.0594 N62460 X0.4164 Z-0.0600 N62470 X0.4186 N62480 X0.4197 Z-0.0599 N62490 X0.4273 Z-0.0474 N62500 X0.4382 Z-0.0302 N62510 X0.4480 Z-0.0151 N62520 X0.4567 Z-0.0022 N62530 X0.4578 Z-0.0009 N62540 X0.4589 Z-0.0001 N62550 X0.4594 Y0.8587 Z0.0000 N62560 X0.4599 Y0.8595 Z-0.0002 N62570 X0.4604 Y0.8602 Z0.0000 N62580 X0.4620 Y0.8624 Z-0.0001 N62590 X0.4625 Y0.8629 Z-0.0001 N62600 X0.4614 Z-0.0007 N62610 X0.4549 Z-0.0098 N62620 X0.4461 Z-0.0225 N62630 X0.4363 Z-0.0375 N62640 X0.4242 Z-0.0563 N62650 X0.4221 Z-0.0599 N62660 X0.4210 Z-0.0600 N62670 X0.4166 N62680 X0.4155 Z-0.0599 N62690 X0.3816 Z-0.0013 N62700 X0.3805 Z-0.0000 N62710 Y0.8679 Z-0.0000 N62720 X0.3816 Z-0.0013 N62730 X0.4145 Z-0.0581 N62740 X0.4156 Z-0.0600 N62750 X0.4232 N62760 X0.4243 Z-0.0598 N62770 X0.4342 Z-0.0447 N62780 X0.4419 Z-0.0333 N62790 X0.4496 Z-0.0222 N62800 X0.4561 Z-0.0131 N62810 X0.4627 Z-0.0044 N62820 X0.4660 Z-0.0003 N62830 X0.4671 Z-0.0001 N62840 X0.4677 Y0.8685 N62850 X0.4683 Y0.8691 Z-0.0002 N62860 X0.4689 Y0.8697 N62870 X0.4696 Y0.8702 Z-0.0003 N62880 X0.4702 Y0.8708 Z-0.0001 N62890 X0.4709 Y0.8714 Z-0.0005 N62900 X0.4716 Y0.8720 Z0.0000 N62910 X0.4722 Y0.8726 Z-0.0005 N62920 X0.4727 Y0.8729 Z0.0000 N62930 X0.4716 Z-0.0006 N62940 X0.4639 Z-0.0096 N62950 X0.4573 Z-0.0176 N62960 X0.4496 Z-0.0277 N62970 X0.4419 Z-0.0382 N62980 X0.4332 Z-0.0509 N62990 X0.4277 Z-0.0590 N63000 X0.4266 Z-0.0600 N63010 X0.4156 N63020 X0.4134 Z-0.0563 N63030 X0.3816 Z-0.0013 N63040 X0.3805 Z-0.0000 N63050 Y0.8779 Z-0.0000 N63060 X0.3816 Z-0.0013 N63070 X0.4154 Z-0.0595 N63080 X0.4165 Z-0.0600 N63090 X0.4295 N63100 X0.4306 Z-0.0588 N63110 X0.4371 Z-0.0495 N63120 X0.4448 Z-0.0390 N63130 X0.4513 Z-0.0305 N63140 X0.4578 Z-0.0225 N63150 X0.4666 Z-0.0125 N63160 X0.4709 Z-0.0077 N63170 X0.4764 Z-0.0023 N63180 X0.4785 Z-0.0004 N63190 X0.4796 N63200 X0.4803 Y0.8783 Z0.0000 N63210 X0.4810 Y0.8788 N63220 X0.4817 Y0.8792 Z-0.0003 N63230 X0.4825 Y0.8796 Z0.0000 N63240 X0.4833 Y0.8801 Z-0.0003 N63250 X0.4849 Y0.8809 Z0.0000 N63260 X0.4857 Y0.8813 Z-0.0001 N63270 X0.4865 Y0.8817 N63280 X0.4874 Y0.8821 Z0.0000 N63290 X0.4880 Y0.8824 Z-0.0003 N63300 X0.4887 Y0.8826 N63310 X0.4894 Y0.8829 Z0.0000 N63320 X0.4883 Z-0.0003 N63330 X0.4839 Z-0.0034 N63340 X0.4795 Z-0.0070 N63350 X0.4751 Z-0.0109 N63360 X0.4696 Z-0.0163 N63370 X0.4641 Z-0.0221 N63380 X0.4564 Z-0.0310 N63390 X0.4498 Z-0.0389 N63400 X0.4432 Z-0.0473 N63410 X0.4355 Z-0.0575 N63420 X0.4344 Z-0.0590 N63430 X0.4333 Z-0.0600 N63440 X0.4157 N63450 X0.4146 Z-0.0584 N63460 X0.3816 Z-0.0013 N63470 X0.3805 Z-0.0000 N63480 Y0.8879 Z-0.0000 N63490 X0.3816 Z-0.0013 N63500 X0.4146 Z-0.0585 N63510 X0.4157 Z-0.0600 N63520 X0.4366 N63530 X0.4377 Z-0.0599 N63540 X0.4443 Z-0.0515 N63550 X0.4509 Z-0.0436 N63560 X0.4587 Z-0.0347 N63570 X0.4642 Z-0.0287 N63580 X0.4697 Z-0.0232 N63590 X0.4752 Z-0.0182 N63600 X0.4796 Z-0.0144 N63610 X0.4840 Z-0.0110 N63620 X0.4884 Z-0.0080 N63630 X0.4928 Z-0.0053 N63640 X0.4972 Z-0.0030 N63650 X0.5016 Z-0.0011 N63660 X0.5027 Z-0.0007 N63670 X0.5049 Z-0.0006 N63680 X0.5060 N63690 X0.5071 Z-0.0005 N63700 X0.5078 Y0.8880 Z-0.0002 N63710 X0.5086 Y0.8882 N63720 X0.5094 Y0.8883 Z0.0000 N63730 X0.5124 Y0.8887 N63740 X0.5134 Y0.8888 Z-0.0001 N63750 X0.5145 Y0.8889 Z-0.0004 N63760 X0.5155 Y0.8890 Z-0.0005 N63770 X0.5176 Y0.8892 Z-0.0002 N63780 X0.5185 Y0.8892 Z-0.0002 N63790 X0.5203 Y0.8893 Z0.0000 N63800 X0.5253 Y0.8895 N63810 X0.5297 Y0.8895 N63820 X0.5318 Y0.8893 N63830 X0.5338 Y0.8891 Z-0.0003 N63840 X0.5348 Y0.8890 Z-0.0005 N63850 X0.5359 Y0.8889 Z-0.0004 N63860 X0.5369 Y0.8888 Z0.0000 N63870 X0.5389 Y0.8884 N63880 X0.5397 Y0.8883 Z-0.0001 N63890 X0.5406 Y0.8881 N63900 X0.5414 Y0.8879 Z-0.0005 N63910 X0.5425 Z-0.0006 N63920 X0.5447 Z-0.0007 N63930 X0.5480 Z-0.0024 N63940 X0.5524 Z-0.0052 N63950 X0.5567 Z-0.0084 N63960 X0.5611 Z-0.0120 N63970 X0.5655 Z-0.0159 N63980 X0.5710 Z-0.0214 N63990 X0.5764 Z-0.0274 N64000 X0.5819 Z-0.0338 N64010 X0.5896 Z-0.0434 N64020 X0.5994 Z-0.0562 N64030 X0.6016 Z-0.0591 N64040 X0.6027 Z-0.0600 N64050 X0.6476 N64060 X0.6487 Z-0.0598 N64070 X0.6826 Z-0.0011 N64080 X0.6837 Z-0.0005 N64090 X0.6838 Y0.8929 Z-0.0003 N64100 X0.6827 Z-0.0010 N64110 X0.6486 Z-0.0600 N64120 X0.5981 Z-0.0600 N64130 X0.5970 Z-0.0587 N64140 X0.5893 Z-0.0490 N64150 X0.5838 Z-0.0424 N64160 X0.5772 Z-0.0349 N64170 X0.5728 Z-0.0303 N64180 X0.5673 Z-0.0249 N64190 X0.5629 Z-0.0211 N64200 X0.5585 Z-0.0175 N64210 X0.5552 Z-0.0151 N64220 X0.5508 Z-0.0123 N64230 X0.5475 Z-0.0105 N64240 X0.5442 Z-0.0090 N64250 X0.5409 Z-0.0078 N64260 X0.5376 Z-0.0068 N64270 X0.5343 Z-0.0061 N64280 X0.5300 Z-0.0056 N64290 X0.5267 Z-0.0054 N64300 X0.5223 Z-0.0055 N64310 X0.5179 Z-0.0059 N64320 X0.5135 Z-0.0065 N64330 X0.5091 Z-0.0074 N64340 X0.5047 Z-0.0087 N64350 X0.5003 Z-0.0102 N64360 X0.4959 Z-0.0121 N64370 X0.4915 Z-0.0143 N64380 X0.4871 Z-0.0169 N64390 X0.4827 Z-0.0199 N64400 X0.4783 Z-0.0231 N64410 X0.4739 Z-0.0267 N64420 X0.4684 Z-0.0317 N64430 X0.4618 Z-0.0382 N64440 X0.4552 Z-0.0453 N64450 X0.4464 Z-0.0554 N64460 X0.4431 Z-0.0593 N64470 X0.4420 Z-0.0600 N64480 X0.4157 N64490 X0.4146 Z-0.0584 N64500 X0.3816 Z-0.0013 N64510 X0.3805 Z-0.0000 N64520 Y0.8979 Z-0.0000 N64530 X0.3816 Z-0.0013 N64540 X0.4146 Z-0.0584 N64550 X0.4157 Z-0.0600 N64560 X0.4475 N64570 X0.4486 Z-0.0592 N64580 X0.4541 Z-0.0531 N64590 X0.4596 Z-0.0474 N64600 X0.4651 Z-0.0420 N64610 X0.4706 Z-0.0370 N64620 X0.4750 Z-0.0333 N64630 X0.4794 Z-0.0300 N64640 X0.4838 Z-0.0269 N64650 X0.4882 Z-0.0242 N64660 X0.4926 Z-0.0218 N64670 X0.4970 Z-0.0198 N64680 X0.5014 Z-0.0181 N64690 X0.5058 Z-0.0167 N64700 X0.5102 Z-0.0156 N64710 X0.5146 Z-0.0147 N64720 X0.5190 Z-0.0142 N64730 X0.5234 Z-0.0139 N64740 X0.5278 Z-0.0139 N64750 X0.5311 Z-0.0141 N64760 X0.5366 Z-0.0149 N64770 X0.5388 Z-0.0154 N64780 X0.5432 Z-0.0167 N64790 X0.5465 Z-0.0181 N64800 X0.5509 Z-0.0202 N64810 X0.5542 Z-0.0221 N64820 X0.5586 Z-0.0250 N64830 X0.5629 Z-0.0283 N64840 X0.5673 Z-0.0320 N64850 X0.5717 Z-0.0361 N64860 X0.5772 Z-0.0415 N64870 X0.5827 Z-0.0475 N64880 X0.5893 Z-0.0551 N64890 X0.5926 Z-0.0591 N64900 X0.5937 Z-0.0600 N64910 X0.6476 N64920 X0.6487 Z-0.0600 N64930 X0.6827 Z-0.0010 N64940 X0.6838 Z-0.0002 N64950 X0.6839 Y0.9029 Z-0.0002 N64960 X0.6828 Z-0.0010 N64970 X0.6487 Z-0.0600 N64980 X0.5882 Z-0.0600 N64990 X0.5871 Z-0.0591 N65000 X0.5816 Z-0.0532 N65010 X0.5750 Z-0.0467 N65020 X0.5696 Z-0.0417 N65030 X0.5641 Z-0.0372 N65040 X0.5597 Z-0.0340 N65050 X0.5553 Z-0.0312 N65060 X0.5520 Z-0.0294 N65070 X0.5476 Z-0.0273 N65080 X0.5443 Z-0.0259 N65090 X0.5399 Z-0.0245 N65100 X0.5366 Z-0.0236 N65110 X0.5311 Z-0.0228 N65120 X0.5278 Z-0.0226 N65130 X0.5234 Z-0.0227 N65140 X0.5190 Z-0.0229 N65150 X0.5146 Z-0.0234 N65160 X0.5102 Z-0.0242 N65170 X0.5058 Z-0.0253 N65180 X0.5014 Z-0.0266 N65190 X0.4970 Z-0.0282 N65200 X0.4926 Z-0.0302 N65210 X0.4882 Z-0.0324 N65220 X0.4838 Z-0.0350 N65230 X0.4794 Z-0.0379 N65240 X0.4739 Z-0.0419 N65250 X0.4684 Z-0.0464 N65260 X0.4629 Z-0.0513 N65270 X0.4574 Z-0.0566 N65280 X0.4541 Z-0.0600 N65290 X0.4157 Z-0.0600 N65300 X0.4146 Z-0.0584 N65310 X0.3816 Z-0.0013 N65320 X0.3805 Z-0.0000 N65330 Y0.9079 Z-0.0000 N65340 X0.3816 Z-0.0013 N65350 X0.4146 Z-0.0584 N65360 X0.4157 Z-0.0600 N65370 X0.4607 N65380 X0.4618 Z-0.0598 N65390 X0.4673 Z-0.0550 N65400 X0.4728 Z-0.0506 N65410 X0.4783 Z-0.0466 N65420 X0.4838 Z-0.0431 N65430 X0.4882 Z-0.0407 N65440 X0.4926 Z-0.0385 N65450 X0.4970 Z-0.0366 N65460 X0.5014 Z-0.0351 N65470 X0.5058 Z-0.0338 N65480 X0.5102 Z-0.0328 N65490 X0.5146 Z-0.0320 N65500 X0.5201 Z-0.0314 N65510 X0.5256 Z-0.0312 N65520 X0.5300 Z-0.0313 N65530 X0.5333 Z-0.0317 N65540 X0.5377 Z-0.0324 N65550 X0.5410 Z-0.0331 N65560 X0.5454 Z-0.0345 N65570 X0.5487 Z-0.0358 N65580 X0.5542 Z-0.0384 N65590 X0.5586 Z-0.0410 N65600 X0.5630 Z-0.0440 N65610 X0.5674 Z-0.0472 N65620 X0.5729 Z-0.0518 N65630 X0.5783 Z-0.0569 N65640 X0.5805 Z-0.0590 N65650 X0.5816 Z-0.0600 N65660 X0.6476 N65670 X0.6487 Z-0.0600 N65680 X0.6828 Z-0.0010 N65690 X0.6839 Z-0.0001 N65700 Y0.9129 N65710 X0.6828 Z-0.0010 N65720 X0.6487 Z-0.0600 N65730 X0.5740 Z-0.0600 N65740 X0.5729 Z-0.0595 N65750 X0.5696 Z-0.0568 N65760 X0.5641 Z-0.0528 N65770 X0.5597 Z-0.0500 N65780 X0.5564 Z-0.0481 N65790 X0.5520 Z-0.0459 N65800 X0.5476 Z-0.0439 N65810 X0.5443 Z-0.0427 N65820 X0.5399 Z-0.0414 N65830 X0.5366 Z-0.0407 N65840 X0.5322 Z-0.0400 N65850 X0.5289 Z-0.0398 N65860 X0.5234 Z-0.0398 N65870 X0.5179 Z-0.0402 N65880 X0.5124 Z-0.0409 N65890 X0.5069 Z-0.0420 N65900 X0.5014 Z-0.0435 N65910 X0.4970 Z-0.0450 N65920 X0.4926 Z-0.0467 N65930 X0.4882 Z-0.0488 N65940 X0.4838 Z-0.0511 N65950 X0.4794 Z-0.0538 N65960 X0.4750 Z-0.0566 N65970 X0.4706 Z-0.0598 N65980 X0.4695 Z-0.0600 N65990 X0.4157 N66000 X0.4146 Z-0.0584 N66010 X0.3816 Z-0.0013 N66020 X0.3805 Z-0.0000 N66030 Y0.9179 Z-0.0000 N66040 X0.3816 Z-0.0013 N66050 X0.4146 Z-0.0584 N66060 X0.4157 Z-0.0600 N66070 X0.4827 N66080 X0.4838 Z-0.0595 N66090 X0.4882 Z-0.0573 N66100 X0.4926 Z-0.0553 N66110 X0.4970 Z-0.0536 N66120 X0.5014 Z-0.0521 N66130 X0.5058 Z-0.0510 N66140 X0.5113 Z-0.0498 N66150 X0.5168 Z-0.0491 N66160 X0.5223 Z-0.0487 N66170 X0.5278 Z-0.0486 N66180 X0.5311 Z-0.0487 N66190 X0.5366 Z-0.0494 N66200 X0.5399 Z-0.0500 N66210 X0.5432 Z-0.0508 N66220 X0.5476 Z-0.0522 N66230 X0.5509 Z-0.0535 N66240 X0.5564 Z-0.0561 N66250 X0.5597 Z-0.0579 N66260 X0.5630 Z-0.0600 N66270 X0.6476 Z-0.0600 N66280 X0.6487 Z-0.0600 N66290 X0.6828 Z-0.0010 N66300 X0.6839 Z-0.0001 N66310 Y0.9229 N66320 X0.6828 Z-0.0010 N66330 X0.6487 Z-0.0600 N66340 X0.5465 Z-0.0600 N66350 X0.5454 Z-0.0600 N66360 X0.5421 Z-0.0590 N66370 X0.5388 Z-0.0582 N66380 X0.5333 Z-0.0573 N66390 X0.5300 Z-0.0570 N66400 X0.5256 Z-0.0569 N66410 X0.5201 Z-0.0571 N66420 X0.5146 Z-0.0577 N66430 X0.5102 Z-0.0583 N66440 X0.5058 Z-0.0592 N66450 X0.5036 Z-0.0598 N66460 X0.5025 Z-0.0600 N66470 X0.4157 N66480 X0.4146 Z-0.0584 N66490 X0.3816 Z-0.0013 N66500 X0.3805 Z-0.0000 N66510 Y0.9279 Z-0.0000 N66520 X0.3816 Z-0.0013 N66530 X0.4146 Z-0.0584 N66540 X0.4157 Z-0.0600 N66550 X0.6476 N66560 X0.6487 Z-0.0600 N66570 X0.6828 Z-0.0010 N66580 X0.6839 Z-0.0001 N66590 Y0.9329 N66600 X0.6828 Z-0.0010 N66610 X0.6487 Z-0.0600 N66620 X0.5344 Z-0.0600 N66630 X0.4157 N66640 X0.4146 Z-0.0584 N66650 X0.3816 Z-0.0013 N66660 X0.3805 Z-0.0000 N66670 Y0.9379 Z-0.0000 N66680 X0.3816 Z-0.0013 N66690 X0.4146 Z-0.0584 N66700 X0.4157 Z-0.0600 N66710 X0.6476 N66720 X0.6487 Z-0.0600 N66730 X0.6828 Z-0.0010 N66740 X0.6839 Z-0.0001 N66750 Y0.9429 N66760 X0.6828 Z-0.0010 N66770 X0.6487 Z-0.0600 N66780 X0.5344 Z-0.0600 N66790 X0.4157 N66800 X0.4146 Z-0.0584 N66810 X0.3816 Z-0.0013 N66820 X0.3805 Z-0.0000 N66830 Y0.9479 Z-0.0000 N66840 X0.3816 Z-0.0013 N66850 X0.4146 Z-0.0584 N66860 X0.4157 Z-0.0600 N66870 X0.6476 N66880 X0.6487 Z-0.0600 N66890 X0.6828 Z-0.0010 N66900 X0.6839 Z-0.0001 N66910 Y0.9528 N66920 X0.6828 Z-0.0010 N66930 X0.6487 Z-0.0600 N66940 X0.5377 Z-0.0600 N66950 X0.4157 N66960 X0.4146 Z-0.0584 N66970 X0.3816 Z-0.0013 N66980 X0.3805 Z-0.0000 N66990 Y0.9578 Z-0.0000 N67000 X0.3816 Z-0.0013 N67010 X0.4146 Z-0.0584 N67020 X0.4157 Z-0.0600 N67030 X0.6476 N67040 X0.6487 Z-0.0600 N67050 X0.6828 Z-0.0010 N67060 X0.6839 Z-0.0001 N67070 Y0.9628 N67080 X0.6828 Z-0.0010 N67090 X0.6487 Z-0.0600 N67100 X0.5355 Z-0.0600 N67110 X0.4157 N67120 X0.4146 Z-0.0584 N67130 X0.3816 Z-0.0013 N67140 X0.3805 Z-0.0000 N67150 Y0.9678 Z-0.0000 N67160 X0.3816 Z-0.0013 N67170 X0.4146 Z-0.0584 N67180 X0.4157 Z-0.0600 N67190 X0.6476 N67200 X0.6487 Z-0.0600 N67210 X0.6828 Z-0.0010 N67220 X0.6839 Z-0.0001 N67230 Y0.9728 N67240 X0.6828 Z-0.0010 N67250 X0.6487 Z-0.0600 N67260 X0.5333 Z-0.0600 N67270 X0.4157 N67280 X0.4146 Z-0.0584 N67290 X0.3816 Z-0.0013 N67300 X0.3805 Z-0.0000 N67310 Y0.9778 Z-0.0000 N67320 X0.3816 Z-0.0013 N67330 X0.4146 Z-0.0584 N67340 X0.4157 Z-0.0600 N67350 X0.6476 N67360 X0.6487 Z-0.0600 N67370 X0.6828 Z-0.0010 N67380 X0.6839 Z-0.0001 N67390 Y0.9828 N67400 X0.6828 Z-0.0010 N67410 X0.6487 Z-0.0600 N67420 X0.5355 Z-0.0600 N67430 X0.4157 N67440 X0.4146 Z-0.0584 N67450 X0.3816 Z-0.0013 N67460 X0.3805 Z-0.0000 N67470 Y0.9878 Z-0.0000 N67480 X0.3816 Z-0.0013 N67490 X0.4146 Z-0.0584 N67500 X0.4157 Z-0.0600 N67510 X0.6476 N67520 X0.6487 Z-0.0600 N67530 X0.6828 Z-0.0010 N67540 X0.6839 Z-0.0001 N67550 Y0.9928 N67560 X0.6828 Z-0.0010 N67570 X0.6487 Z-0.0600 N67580 X0.5333 Z-0.0600 N67590 X0.4157 N67600 X0.4146 Z-0.0584 N67610 X0.3816 Z-0.0013 N67620 X0.3805 Z-0.0000 N67630 Y0.9978 Z-0.0000 N67640 X0.3816 Z-0.0013 N67650 X0.4146 Z-0.0584 N67660 X0.4157 Z-0.0600 N67670 X0.6476 N67680 X0.6487 Z-0.0600 N67690 X0.6828 Z-0.0010 N67700 X0.6839 Z-0.0001 N67710 Y1.0028 N67720 X0.6828 Z-0.0010 N67730 X0.6487 Z-0.0600 N67740 X0.5399 Z-0.0600 N67750 X0.4190 N67760 X0.4157 N67770 X0.4146 Z-0.0584 N67780 X0.3816 Z-0.0013 N67790 X0.3805 Z-0.0000 N67800 Y1.0078 Z-0.0000 N67810 X0.3816 Z-0.0013 N67820 X0.4146 Z-0.0584 N67830 X0.4157 Z-0.0600 N67840 X0.6476 N67850 X0.6487 Z-0.0600 N67860 X0.6828 Z-0.0010 N67870 X0.6839 Z-0.0001 N67880 Y1.0128 N67890 X0.6828 Z-0.0010 N67900 X0.6487 Z-0.0600 N67910 X0.5333 Z-0.0600 N67920 X0.4157 N67930 X0.4146 Z-0.0584 N67940 X0.3816 Z-0.0013 N67950 X0.3805 Z-0.0000 N67960 Y1.0178 Z-0.0000 N67970 X0.3816 Z-0.0013 N67980 X0.4146 Z-0.0584 N67990 X0.4157 Z-0.0600 N68000 X0.6476 N68010 X0.6487 Z-0.0600 N68020 X0.6828 Z-0.0010 N68030 X0.6839 Z-0.0001 N68040 Y1.0228 N68050 X0.6828 Z-0.0010 N68060 X0.6487 Z-0.0600 N68070 X0.5311 Z-0.0600 N68080 X0.4157 N68090 X0.4146 Z-0.0584 N68100 X0.3816 Z-0.0013 N68110 X0.3805 Z-0.0000 N68120 Y1.0278 Z-0.0000 N68130 X0.3816 Z-0.0013 N68140 X0.4146 Z-0.0584 N68150 X0.4157 Z-0.0600 N68160 X0.6476 N68170 X0.6487 Z-0.0600 N68180 X0.6828 Z-0.0010 N68190 X0.6839 Z-0.0001 N68200 Y1.0328 N68210 X0.6828 Z-0.0010 N68220 X0.6487 Z-0.0600 N68230 X0.5333 Z-0.0600 N68240 X0.4157 N68250 X0.4146 Z-0.0584 N68260 X0.3816 Z-0.0013 N68270 X0.3805 Z-0.0000 N68280 Y1.0378 Z-0.0000 N68290 X0.3816 Z-0.0013 N68300 X0.4146 Z-0.0584 N68310 X0.4157 Z-0.0600 N68320 X0.6476 N68330 X0.6487 Z-0.0600 N68340 X0.6828 Z-0.0010 N68350 X0.6839 Z-0.0001 N68360 Y1.0427 N68370 X0.6828 Z-0.0010 N68380 X0.6487 Z-0.0600 N68390 X0.5399 Z-0.0600 N68400 X0.4190 N68410 X0.4157 N68420 X0.4146 Z-0.0584 N68430 X0.3816 Z-0.0013 N68440 X0.3805 Z-0.0000 N68450 Y1.0477 N68460 X0.3816 Z-0.0013 N68470 X0.4146 Z-0.0584 N68480 X0.4157 Z-0.0600 N68490 X0.6476 N68500 X0.6487 Z-0.0600 N68510 X0.6828 Z-0.0010 N68520 X0.6839 Z-0.0001 N68530 Y1.0527 N68540 X0.6828 Z-0.0010 N68550 X0.6487 Z-0.0600 N68560 X0.5399 Z-0.0600 N68570 X0.4190 N68580 X0.4157 N68590 X0.4146 Z-0.0584 N68600 X0.3816 Z-0.0013 N68610 X0.3805 Z-0.0000 N68620 Y1.0577 N68630 X0.3816 Z-0.0013 N68640 X0.4146 Z-0.0584 N68650 X0.4157 Z-0.0600 N68660 X0.6476 N68670 X0.6487 Z-0.0600 N68680 X0.6828 Z-0.0010 N68690 X0.6839 Z-0.0001 N68700 Y1.0627 N68710 X0.6828 Z-0.0010 N68720 X0.6487 Z-0.0600 N68730 X0.5322 Z-0.0600 N68740 X0.4157 N68750 X0.4146 Z-0.0584 N68760 X0.3816 Z-0.0013 N68770 X0.3805 Z-0.0000 N68780 Y1.0677 N68790 X0.3816 Z-0.0013 N68800 X0.4146 Z-0.0584 N68810 X0.4157 Z-0.0600 N68820 X0.6476 N68830 X0.6487 Z-0.0600 N68840 X0.6828 Z-0.0010 N68850 X0.6839 Z-0.0001 N68860 Y1.0727 N68870 X0.6828 Z-0.0010 N68880 X0.6487 Z-0.0600 N68890 X0.5322 Z-0.0600 N68900 X0.4157 N68910 X0.4146 Z-0.0584 N68920 X0.3816 Z-0.0013 N68930 X0.3805 Z-0.0000 N68940 Y1.0777 N68950 X0.3816 Z-0.0013 N68960 X0.4146 Z-0.0584 N68970 X0.4157 Z-0.0600 N68980 X0.6476 N68990 X0.6487 Z-0.0600 N69000 X0.6828 Z-0.0010 N69010 X0.6839 Z-0.0001 N69020 Y1.0827 N69030 X0.6828 Z-0.0010 N69040 X0.6487 Z-0.0600 N69050 X0.5355 Z-0.0600 N69060 X0.4157 N69070 X0.4146 Z-0.0584 N69080 X0.3816 Z-0.0013 N69090 X0.3805 Z-0.0000 N69100 Y1.0877 N69110 X0.3816 Z-0.0013 N69120 X0.4146 Z-0.0584 N69130 X0.4157 Z-0.0600 N69140 X0.6476 N69150 X0.6487 Z-0.0600 N69160 X0.6828 Z-0.0010 N69170 X0.6839 Z-0.0001 N69180 Y1.0927 N69190 X0.6828 Z-0.0010 N69200 X0.6487 Z-0.0600 N69210 X0.5355 Z-0.0600 N69220 X0.4157 N69230 X0.4146 Z-0.0584 N69240 X0.3816 Z-0.0013 N69250 X0.3805 Z-0.0000 N69260 Y1.0977 N69270 X0.3816 Z-0.0013 N69280 X0.4146 Z-0.0584 N69290 X0.4157 Z-0.0600 N69300 X0.6476 N69310 X0.6487 Z-0.0600 N69320 X0.6828 Z-0.0010 N69330 X0.6839 Z-0.0001 N69340 Y1.1027 N69350 X0.6828 Z-0.0010 N69360 X0.6487 Z-0.0600 N69370 X0.5355 Z-0.0600 N69380 X0.4157 N69390 X0.4146 Z-0.0584 N69400 X0.3816 Z-0.0013 N69410 X0.3805 Z-0.0000 N69420 Y1.1077 N69430 X0.3816 Z-0.0013 N69440 X0.4146 Z-0.0584 N69450 X0.4157 Z-0.0600 N69460 X0.6476 N69470 X0.6487 Z-0.0600 N69480 X0.6828 Z-0.0010 N69490 X0.6839 Z-0.0001 N69500 Y1.1127 N69510 X0.6828 Z-0.0010 N69520 X0.6487 Z-0.0600 N69530 X0.5355 Z-0.0600 N69540 X0.4157 N69550 X0.4146 Z-0.0584 N69560 X0.3816 Z-0.0013 N69570 X0.3805 Z-0.0000 N69580 Y1.1177 N69590 X0.3816 Z-0.0013 N69600 X0.4146 Z-0.0584 N69610 X0.4157 Z-0.0600 N69620 X0.6476 N69630 X0.6487 Z-0.0600 N69640 X0.6828 Z-0.0010 N69650 X0.6839 Z-0.0001 N69660 Y1.1227 N69670 X0.6828 Z-0.0010 N69680 X0.6487 Z-0.0600 N69690 X0.5355 Z-0.0600 N69700 X0.4157 N69710 X0.4146 Z-0.0584 N69720 X0.3816 Z-0.0013 N69730 X0.3805 Z-0.0000 N69740 Y1.1277 N69750 X0.3816 Z-0.0013 N69760 X0.4146 Z-0.0584 N69770 X0.4157 Z-0.0600 N69780 X0.6476 N69790 X0.6487 Z-0.0600 N69800 X0.6828 Z-0.0010 N69810 X0.6839 Z-0.0001 N69820 Y1.1326 N69830 X0.6828 Z-0.0010 N69840 X0.6487 Z-0.0600 N69850 X0.5322 Z-0.0600 N69860 X0.4157 N69870 X0.4146 Z-0.0584 N69880 X0.3816 Z-0.0013 N69890 X0.3805 Z-0.0000 N69900 Y1.1376 N69910 X0.3816 Z-0.0013 N69920 X0.4146 Z-0.0584 N69930 X0.4157 Z-0.0600 N69940 X0.6476 N69950 X0.6487 Z-0.0600 N69960 X0.6828 Z-0.0010 N69970 X0.6839 Z-0.0001 N69980 Y1.1426 N69990 X0.6828 Z-0.0010 N70000 X0.6487 Z-0.0600 N70010 X0.5322 Z-0.0600 N70020 X0.4157 N70030 X0.4146 Z-0.0584 N70040 X0.3816 Z-0.0013 N70050 X0.3805 Z-0.0000 N70060 Y1.1476 N70070 X0.3816 Z-0.0013 N70080 X0.4146 Z-0.0584 N70090 X0.4157 Z-0.0600 N70100 X0.6476 N70110 X0.6487 Z-0.0600 N70120 X0.6828 Z-0.0010 N70130 X0.6839 Z-0.0001 N70140 Y1.1526 N70150 X0.6828 Z-0.0010 N70160 X0.6487 Z-0.0600 N70170 X0.5399 Z-0.0600 N70180 X0.4190 N70190 X0.4157 N70200 X0.4146 Z-0.0584 N70210 X0.3816 Z-0.0013 N70220 X0.3805 Z-0.0000 N70230 Y1.1576 N70240 X0.3816 Z-0.0013 N70250 X0.4146 Z-0.0584 N70260 X0.4157 Z-0.0600 N70270 X0.6476 N70280 X0.6487 Z-0.0600 N70290 X0.6828 Z-0.0010 N70300 X0.6839 Z-0.0001 N70310 Y1.1626 N70320 X0.6828 Z-0.0010 N70330 X0.6487 Z-0.0600 N70340 X0.5399 Z-0.0600 N70350 X0.4190 N70360 X0.4157 N70370 X0.4146 Z-0.0584 N70380 X0.3816 Z-0.0013 N70390 X0.3805 Z-0.0000 N70400 Y1.1676 N70410 X0.3816 Z-0.0013 N70420 X0.4146 Z-0.0584 N70430 X0.4157 Z-0.0600 N70440 X0.6476 N70450 X0.6487 Z-0.0600 N70460 X0.6828 Z-0.0010 N70470 X0.6839 Z-0.0001 N70480 Y1.1726 N70490 X0.6828 Z-0.0010 N70500 X0.6487 Z-0.0600 N70510 X0.5399 Z-0.0600 N70520 X0.4190 N70530 X0.4157 N70540 X0.4146 Z-0.0584 N70550 X0.3816 Z-0.0013 N70560 X0.3805 Z-0.0000 N70570 Y1.1776 N70580 X0.3816 Z-0.0013 N70590 X0.4146 Z-0.0584 N70600 X0.4157 Z-0.0600 N70610 X0.6476 N70620 X0.6487 Z-0.0600 N70630 X0.6828 Z-0.0010 N70640 X0.6839 Z-0.0001 N70650 Y1.1826 N70660 X0.6828 Z-0.0010 N70670 X0.6487 Z-0.0600 N70680 X0.5399 Z-0.0600 N70690 X0.4190 N70700 X0.4157 N70710 X0.4146 Z-0.0584 N70720 X0.3816 Z-0.0013 N70730 X0.3805 Z-0.0000 N70740 Y1.1876 N70750 X0.3816 Z-0.0013 N70760 X0.4146 Z-0.0584 N70770 X0.4157 Z-0.0600 N70780 X0.6476 N70790 X0.6487 Z-0.0600 N70800 X0.6828 Z-0.0010 N70810 X0.6839 Z-0.0001 N70820 Y1.1926 N70830 X0.6828 Z-0.0010 N70840 X0.6487 Z-0.0600 N70850 X0.5399 Z-0.0600 N70860 X0.4190 N70870 X0.4157 N70880 X0.4146 Z-0.0584 N70890 X0.3816 Z-0.0013 N70900 X0.3805 Z-0.0000 N70910 Y1.1976 N70920 X0.3816 Z-0.0013 N70930 X0.4146 Z-0.0584 N70940 X0.4157 Z-0.0600 N70950 X0.6476 N70960 X0.6487 Z-0.0600 N70970 X0.6828 Z-0.0010 N70980 X0.6839 Z-0.0001 N70990 Y1.2026 N71000 X0.6828 Z-0.0010 N71010 X0.6487 Z-0.0600 N71020 X0.5399 Z-0.0600 N71030 X0.4190 N71040 X0.4157 N71050 X0.4146 Z-0.0584 N71060 X0.3816 Z-0.0013 N71070 X0.3805 Z-0.0000 N71080 Y1.2076 N71090 X0.3816 Z-0.0013 N71100 X0.4146 Z-0.0584 N71110 X0.4157 Z-0.0600 N71120 X0.6476 N71130 X0.6487 Z-0.0600 N71140 X0.6828 Z-0.0010 N71150 X0.6839 Z-0.0001 N71160 Y1.2126 N71170 X0.6828 Z-0.0010 N71180 X0.6487 Z-0.0600 N71190 X0.5399 Z-0.0600 N71200 X0.4190 N71210 X0.4157 N71220 X0.4146 Z-0.0584 N71230 X0.3816 Z-0.0013 N71240 X0.3805 Z-0.0000 N71250 Y1.2176 N71260 X0.3816 Z-0.0013 N71270 X0.4146 Z-0.0584 N71280 X0.4157 Z-0.0600 N71290 X0.6476 N71300 X0.6487 Z-0.0600 N71310 X0.6828 Z-0.0010 N71320 X0.6839 Z-0.0001 N71330 Y1.2225 N71340 X0.6828 Z-0.0010 N71350 X0.6487 Z-0.0600 N71360 X0.5399 Z-0.0600 N71370 X0.4190 N71380 X0.4157 N71390 X0.4146 Z-0.0584 N71400 X0.3816 Z-0.0013 N71410 X0.3805 Z-0.0000 N71420 Y1.2275 N71430 X0.3816 Z-0.0013 N71440 X0.4146 Z-0.0584 N71450 X0.4157 Z-0.0600 N71460 X0.6476 N71470 X0.6487 Z-0.0600 N71480 X0.6828 Z-0.0010 N71490 X0.6839 Z-0.0001 N71500 Y1.2325 N71510 X0.6828 Z-0.0010 N71520 X0.6487 Z-0.0600 N71530 X0.5399 Z-0.0600 N71540 X0.4190 N71550 X0.4157 N71560 X0.4146 Z-0.0584 N71570 X0.3816 Z-0.0013 N71580 X0.3805 Z-0.0000 N71590 Y1.2375 N71600 X0.3816 Z-0.0013 N71610 X0.4146 Z-0.0584 N71620 X0.4157 Z-0.0600 N71630 X0.6476 N71640 X0.6487 Z-0.0600 N71650 X0.6828 Z-0.0010 N71660 X0.6839 Z-0.0001 N71670 Y1.2425 N71680 X0.6828 Z-0.0010 N71690 X0.6487 Z-0.0600 N71700 X0.5399 Z-0.0600 N71710 X0.4190 N71720 X0.4157 N71730 X0.4146 Z-0.0584 N71740 X0.3816 Z-0.0013 N71750 X0.3805 Z-0.0000 N71760 Y1.2475 N71770 X0.3816 Z-0.0013 N71780 X0.4146 Z-0.0584 N71790 X0.4157 Z-0.0600 N71800 X0.6476 N71810 X0.6487 Z-0.0600 N71820 X0.6828 Z-0.0010 N71830 X0.6839 Z-0.0001 N71840 Y1.2525 N71850 X0.6828 Z-0.0010 N71860 X0.6487 Z-0.0600 N71870 X0.5399 Z-0.0600 N71880 X0.4190 N71890 X0.4157 N71900 X0.4146 Z-0.0584 N71910 X0.3816 Z-0.0013 N71920 X0.3805 Z-0.0000 N71930 Y1.2575 N71940 X0.3816 Z-0.0013 N71950 X0.4146 Z-0.0584 N71960 X0.4157 Z-0.0600 N71970 X0.6476 N71980 X0.6487 Z-0.0600 N71990 X0.6828 Z-0.0010 N72000 X0.6839 Z-0.0001 N72010 Y1.2625 N72020 X0.6828 Z-0.0010 N72030 X0.6487 Z-0.0600 N72040 X0.5399 Z-0.0600 N72050 X0.4190 N72060 X0.4157 N72070 X0.4146 Z-0.0584 N72080 X0.3816 Z-0.0013 N72090 X0.3805 Z-0.0000 N72100 Y1.2675 Z-0.0000 N72110 X0.3816 Z-0.0013 N72120 X0.4146 Z-0.0584 N72130 X0.4157 Z-0.0600 N72140 X0.6476 N72150 X0.6487 Z-0.0600 N72160 X0.6828 Z-0.0010 N72170 X0.6839 Z-0.0001 N72180 Y1.2725 N72190 X0.6828 Z-0.0010 N72200 X0.6487 Z-0.0600 N72210 X0.5333 Z-0.0600 N72220 X0.4157 N72230 X0.4146 Z-0.0584 N72240 X0.3816 Z-0.0013 N72250 X0.3805 Z-0.0000 N72260 Y1.2775 Z-0.0000 N72270 X0.3816 Z-0.0013 N72280 X0.4146 Z-0.0584 N72290 X0.4157 Z-0.0600 N72300 X0.6476 N72310 X0.6487 Z-0.0600 N72320 X0.6828 Z-0.0010 N72330 X0.6839 Z-0.0001 N72340 Y1.2825 N72350 X0.6828 Z-0.0010 N72360 X0.6487 Z-0.0600 N72370 X0.5355 Z-0.0600 N72380 X0.4157 N72390 X0.4146 Z-0.0584 N72400 X0.3816 Z-0.0013 N72410 X0.3805 Z-0.0000 N72420 Y1.2875 Z-0.0000 N72430 X0.3816 Z-0.0013 N72440 X0.4146 Z-0.0584 N72450 X0.4157 Z-0.0600 N72460 X0.6476 N72470 X0.6487 Z-0.0600 N72480 X0.6828 Z-0.0010 N72490 X0.6839 Z-0.0001 N72500 Y1.2925 N72510 X0.6828 Z-0.0010 N72520 X0.6487 Z-0.0600 N72530 X0.5333 Z-0.0600 N72540 X0.4157 N72550 X0.4146 Z-0.0584 N72560 X0.3816 Z-0.0013 N72570 X0.3805 Z-0.0000 N72580 Y1.2975 Z-0.0000 N72590 X0.3816 Z-0.0013 N72600 X0.4146 Z-0.0584 N72610 X0.4157 Z-0.0600 N72620 X0.6476 N72630 X0.6487 Z-0.0600 N72640 X0.6828 Z-0.0010 N72650 X0.6839 Z-0.0001 N72660 Y1.3025 N72670 X0.6828 Z-0.0010 N72680 X0.6487 Z-0.0600 N72690 X0.5377 Z-0.0600 N72700 X0.4168 N72710 X0.4157 N72720 X0.4146 Z-0.0584 N72730 X0.3816 Z-0.0013 N72740 X0.3805 Z-0.0000 N72750 Y1.3075 Z-0.0000 N72760 X0.3816 Z-0.0013 N72770 X0.4146 Z-0.0584 N72780 X0.4157 Z-0.0600 N72790 X0.6476 N72800 X0.6487 Z-0.0600 N72810 X0.6828 Z-0.0010 N72820 X0.6839 Z-0.0001 N72830 Y1.3124 N72840 X0.6828 Z-0.0010 N72850 X0.6487 Z-0.0600 N72860 X0.5366 Z-0.0600 N72870 X0.4190 N72880 X0.4157 N72890 X0.4146 Z-0.0584 N72900 X0.3816 Z-0.0013 N72910 X0.3805 Z-0.0000 N72920 Y1.3174 Z-0.0000 N72930 X0.3816 Z-0.0013 N72940 X0.4146 Z-0.0584 N72950 X0.4157 Z-0.0600 N72960 X0.6476 N72970 X0.6487 Z-0.0600 N72980 X0.6828 Z-0.0010 N72990 X0.6839 Z-0.0001 N73000 Y1.3224 N73010 X0.6828 Z-0.0010 N73020 X0.6487 Z-0.0600 N73030 X0.5344 Z-0.0600 N73040 X0.4157 N73050 X0.4146 Z-0.0584 N73060 X0.3816 Z-0.0013 N73070 X0.3805 Z-0.0000 N73080 Y1.3274 Z-0.0000 N73090 X0.3816 Z-0.0013 N73100 X0.4146 Z-0.0584 N73110 X0.4157 Z-0.0600 N73120 X0.6476 N73130 X0.6487 Z-0.0600 N73140 X0.6828 Z-0.0010 N73150 X0.6839 Z-0.0001 N73160 X0.6838 Y1.3324 Z-0.0002 N73170 X0.6827 Z-0.0010 N73180 X0.6487 Z-0.0600 N73190 X0.5388 Z-0.0600 N73200 X0.4157 N73210 X0.4146 Z-0.0584 N73220 X0.3816 Z-0.0013 N73230 X0.3805 Z-0.0000 N73240 Y1.3374 Z-0.0000 N73250 X0.3816 Z-0.0013 N73260 X0.4146 Z-0.0583 N73270 X0.4157 Z-0.0600 N73280 X0.6474 N73290 X0.6485 Z-0.0599 N73300 X0.6826 Z-0.0011 N73310 X0.6837 Z-0.0005 N73320 X0.6835 Y1.3404 Z-0.0001 N73330 X0.6833 Y1.3424 Z0.0000 N73340 X0.6811 Z-0.0032 N73350 X0.6557 Z-0.0466 N73360 X0.6480 Z-0.0598 N73370 X0.6469 Z-0.0600 N73380 X0.4157 N73390 X0.4146 Z-0.0585 N73400 X0.3816 Z-0.0013 N73410 X0.3805 Z-0.0000 N73420 Y1.3474 Z-0.0000 N73430 X0.3816 Z-0.0013 N73440 X0.4146 Z-0.0583 N73450 X0.4157 Z-0.0600 N73460 X0.6452 N73470 X0.6463 Z-0.0598 N73480 X0.6518 Z-0.0511 N73490 X0.6639 Z-0.0309 N73500 X0.6815 Z-0.0011 N73510 X0.6826 Z-0.0005 N73520 X0.6824 Y1.3482 Z-0.0002 N73530 X0.6823 Y1.3490 N73540 X0.6821 Y1.3498 Z0.0000 N73550 X0.6817 Y1.3515 N73560 X0.6815 Y1.3524 Z-0.0004 N73570 X0.6804 Z-0.0008 N73580 X0.6695 Z-0.0191 N73590 X0.6618 Z-0.0315 N73600 X0.6563 Z-0.0402 N73610 X0.6530 Z-0.0451 N73620 X0.6508 Z-0.0480 N73630 X0.6464 Z-0.0532 N73640 X0.6442 Z-0.0555 N73650 X0.6420 Z-0.0572 N73660 X0.6398 Z-0.0588 N73670 X0.6387 Z-0.0594 N73680 X0.6376 Z-0.0600 N73690 X0.4157 N73700 X0.4146 Z-0.0584 N73710 X0.3816 Z-0.0013 N73720 X0.3805 Z-0.0000 N73730 Y1.3574 Z-0.0000 N73740 X0.3816 Z-0.0013 N73750 X0.4146 Z-0.0586 N73760 X0.4157 Z-0.0600 N73770 X0.6184 N73780 X0.6217 Z-0.0590 N73790 X0.6272 Z-0.0571 N73800 X0.6316 Z-0.0553 N73810 X0.6360 Z-0.0533 N73820 X0.6393 Z-0.0515 N73830 X0.6426 Z-0.0494 N73840 X0.6459 Z-0.0469 N73850 X0.6481 Z-0.0449 N73860 X0.6503 Z-0.0426 N73870 X0.6536 Z-0.0388 N73880 X0.6580 Z-0.0333 N73890 X0.6624 Z-0.0271 N73900 X0.6679 Z-0.0187 N73910 X0.6779 Z-0.0030 N73920 X0.6790 Z-0.0013 N73930 X0.6801 Z0.0000 N73940 X0.6795 Y1.3590 Z-0.0001 N73950 X0.6792 Y1.3598 Z-0.0004 N73960 X0.6788 Y1.3607 Z0.0000 N73970 X0.6780 Y1.3624 N73980 X0.6769 Z-0.0010 N73990 X0.6758 Z-0.0025 N74000 X0.6703 Z-0.0108 N74010 X0.6648 Z-0.0186 N74020 X0.6604 Z-0.0243 N74030 X0.6550 Z-0.0308 N74040 X0.6517 Z-0.0343 N74050 X0.6495 Z-0.0364 N74060 X0.6473 Z-0.0382 N74070 X0.6440 Z-0.0405 N74080 X0.6407 Z-0.0425 N74090 X0.6374 Z-0.0442 N74100 X0.6330 Z-0.0462 N74110 X0.6275 Z-0.0484 N74120 X0.6220 Z-0.0502 N74130 X0.6165 Z-0.0518 N74140 X0.6121 Z-0.0531 N74150 X0.6088 Z-0.0538 N74160 X0.6067 Z-0.0546 N74170 X0.6045 Z-0.0555 N74180 X0.6023 Z-0.0566 N74190 X0.6001 Z-0.0579 N74200 X0.5979 Z-0.0595 N74210 X0.5968 Z-0.0600 N74220 X0.4156 N74230 X0.4145 Z-0.0583 N74240 X0.3816 Z-0.0013 N74250 X0.3805 Z-0.0000 N74260 Y1.3674 Z-0.0000 N74270 X0.3816 Z-0.0013 N74280 X0.4146 Z-0.0584 N74290 X0.4157 Z-0.0600 N74300 X0.5894 N74310 X0.5905 Z-0.0595 N74320 X0.5949 Z-0.0548 N74330 X0.5982 Z-0.0518 N74340 X0.6004 Z-0.0500 N74350 X0.6026 Z-0.0484 N74360 X0.6048 Z-0.0470 N74370 X0.6070 Z-0.0460 N74380 X0.6092 Z-0.0452 N74390 X0.6136 Z-0.0441 N74400 X0.6213 Z-0.0419 N74410 X0.6268 Z-0.0401 N74420 X0.6312 Z-0.0385 N74430 X0.6367 Z-0.0361 N74440 X0.6411 Z-0.0339 N74450 X0.6444 Z-0.0320 N74460 X0.6477 Z-0.0299 N74470 X0.6510 Z-0.0274 N74480 X0.6543 Z-0.0246 N74490 X0.6576 Z-0.0213 N74500 X0.6609 Z-0.0177 N74510 X0.6675 Z-0.0097 N74520 X0.6719 Z-0.0039 N74530 X0.6741 Z-0.0009 N74540 X0.6752 Z0.0000 N74550 X0.6750 Y1.3676 Z-0.0002 N74560 X0.6745 Y1.3683 Z0.0000 N74570 X0.6740 Y1.3689 N74580 X0.6735 Y1.3696 Z-0.0002 N74590 X0.6730 Y1.3703 Z0.0000 N74600 X0.6724 Y1.3709 Z-0.0004 N74610 X0.6719 Y1.3715 Z0.0000 N74620 X0.6714 Y1.3720 Z-0.0005 N74630 X0.6710 Y1.3724 Z0.0000 N74640 X0.6699 Z-0.0005 N74650 X0.6655 Z-0.0058 N74660 X0.6611 Z-0.0107 N74670 X0.6578 Z-0.0140 N74680 X0.6545 Z-0.0169 N74690 X0.6512 Z-0.0195 N74700 X0.6479 Z-0.0217 N74710 X0.6446 Z-0.0238 N74720 X0.6402 Z-0.0261 N74730 X0.6358 Z-0.0281 N74740 X0.6303 Z-0.0304 N74750 X0.6248 Z-0.0323 N74760 X0.6204 Z-0.0337 N74770 X0.6138 Z-0.0355 N74780 X0.6094 Z-0.0366 N74790 X0.6072 Z-0.0375 N74800 X0.6050 Z-0.0388 N74810 X0.6028 Z-0.0403 N74820 X0.6006 Z-0.0422 N74830 X0.5973 Z-0.0453 N74840 X0.5940 Z-0.0489 N74850 X0.5896 Z-0.0541 N74860 X0.5852 Z-0.0598 N74870 X0.5841 Z-0.0600 N74880 X0.4157 N74890 X0.4146 Z-0.0585 N74900 X0.3816 Z-0.0013 N74910 X0.3805 Z-0.0000 N74920 Y1.3774 Z-0.0000 N74930 X0.3816 Z-0.0013 N74940 X0.4146 Z-0.0585 N74950 X0.4157 Z-0.0600 N74960 X0.5809 N74970 X0.5820 Z-0.0590 N74980 X0.5875 Z-0.0511 N74990 X0.5919 Z-0.0452 N75000 X0.5963 Z-0.0397 N75010 X0.5985 Z-0.0372 N75020 X0.6018 Z-0.0338 N75030 X0.6040 Z-0.0319 N75040 X0.6062 Z-0.0302 N75050 X0.6073 Z-0.0294 N75060 X0.6084 Z-0.0288 N75070 X0.6095 Z-0.0282 N75080 X0.6106 Z-0.0278 N75090 X0.6161 Z-0.0264 N75100 X0.6227 Z-0.0245 N75110 X0.6282 Z-0.0227 N75120 X0.6326 Z-0.0211 N75130 X0.6370 Z-0.0193 N75140 X0.6414 Z-0.0173 N75150 X0.6458 Z-0.0150 N75160 X0.6502 Z-0.0124 N75170 X0.6546 Z-0.0093 N75180 X0.6579 Z-0.0067 N75190 X0.6612 Z-0.0037 N75200 X0.6623 Z-0.0026 N75210 X0.6634 Z-0.0016 N75220 X0.6645 Z-0.0009 N75230 X0.6656 Z0.0000 N75240 X0.6641 Y1.3785 N75250 X0.6633 Y1.3791 N75260 X0.6625 Y1.3796 Z-0.0002 N75270 X0.6617 Y1.3801 Z0.0000 N75280 X0.6591 Y1.3816 N75290 X0.6583 Y1.3820 Z-0.0004 N75300 X0.6575 Y1.3824 Z0.0000 N75310 X0.6564 Z-0.0000 N75320 X0.6509 Z-0.0037 N75330 X0.6465 Z-0.0063 N75340 X0.6421 Z-0.0085 N75350 X0.6366 Z-0.0111 N75360 X0.6311 Z-0.0132 N75370 X0.6245 Z-0.0154 N75380 X0.6157 Z-0.0180 N75390 X0.6113 Z-0.0190 N75400 X0.6102 Z-0.0195 N75410 X0.6091 Z-0.0200 N75420 X0.6069 Z-0.0216 N75430 X0.6047 Z-0.0236 N75440 X0.6025 Z-0.0259 N75450 X0.5992 Z-0.0298 N75460 X0.5948 Z-0.0356 N75470 X0.5893 Z-0.0435 N75480 X0.5827 Z-0.0534 N75490 X0.5794 Z-0.0586 N75500 X0.5783 Z-0.0600 N75510 X0.4157 N75520 X0.4146 Z-0.0584 N75530 X0.3816 Z-0.0013 N75540 X0.3805 Z-0.0000 N75550 Y1.3874 Z-0.0000 N75560 X0.3816 Z-0.0013 N75570 X0.4146 Z-0.0584 N75580 X0.4157 Z-0.0600 N75590 X0.5761 N75600 X0.5772 Z-0.0592 N75610 X0.5860 Z-0.0449 N75620 X0.5937 Z-0.0328 N75630 X0.5992 Z-0.0246 N75640 X0.6036 Z-0.0185 N75650 X0.6069 Z-0.0144 N75660 X0.6091 Z-0.0121 N75670 X0.6102 Z-0.0112 N75680 X0.6113 Z-0.0105 N75690 X0.6124 Z-0.0100 N75700 X0.6168 Z-0.0090 N75710 X0.6245 Z-0.0068 N75720 X0.6311 Z-0.0046 N75730 X0.6366 Z-0.0025 N75740 X0.6399 Z-0.0011 N75750 X0.6410 Z-0.0007 N75760 X0.6432 Z-0.0007 N75770 X0.6443 Z-0.0002 N75780 X0.6424 Y1.3879 Z0.0000 N75790 X0.6414 Y1.3882 N75800 X0.6404 Y1.3884 Z-0.0004 N75810 X0.6394 Y1.3887 Z-0.0001 N75820 X0.6384 Y1.3890 Z0.0000 N75830 X0.6373 Y1.3892 N75840 X0.6362 Y1.3895 Z-0.0004 N75850 X0.6352 Y1.3897 Z-0.0003 N75860 X0.6341 Y1.3900 Z0.0000 N75870 X0.6323 Y1.3904 N75880 X0.6314 Y1.3905 Z-0.0001 N75890 X0.6305 Y1.3907 Z-0.0005 N75900 X0.6296 Y1.3909 Z-0.0001 N75910 X0.6286 Y1.3911 Z0.0000 N75920 X0.6267 Y1.3914 N75930 X0.6258 Y1.3916 Z-0.0001 N75940 X0.6248 Y1.3918 Z-0.0004 N75950 X0.6239 Y1.3919 Z-0.0003 N75960 X0.6231 Y1.3921 Z0.0000 N75970 X0.6214 Y1.3924 N75980 X0.6192 Z-0.0001 N75990 X0.6159 Z-0.0010 N76000 X0.6137 Z-0.0015 N76010 X0.6126 Z-0.0020 N76020 X0.6115 Z-0.0030 N76030 X0.6104 Z-0.0042 N76040 X0.6082 Z-0.0070 N76050 X0.6049 Z-0.0117 N76060 X0.5994 Z-0.0202 N76070 X0.5906 Z-0.0345 N76080 X0.5763 Z-0.0584 N76090 X0.5752 Z-0.0600 N76100 X0.4157 N76110 X0.4146 Z-0.0584 N76120 X0.3816 Z-0.0013 N76130 X0.3805 Z-0.0000 N76140 Y1.3974 Z-0.0000 N76150 X0.3816 Z-0.0013 N76160 X0.4146 Z-0.0584 N76170 X0.4157 Z-0.0600 N76180 X0.5740 N76190 X0.5751 Z-0.0584 N76200 X0.5927 Z-0.0287 N76210 X0.6070 Z-0.0048 N76220 X0.6092 Z-0.0012 N76230 X0.6103 Z0.0000 N76240 X0.6101 Y1.3979 Z-0.0001 N76250 X0.6099 Y1.3984 Z-0.0006 N76260 X0.6097 Y1.3992 Z-0.0002 N76270 X0.6095 Y1.3999 Z0.0000 N76280 X0.6092 Y1.4013 N76290 X0.6090 Y1.4019 Z-0.0001 N76300 X0.6089 Y1.4023 Z-0.0004 N76310 X0.6078 Z-0.0010 N76320 X0.5924 Z-0.0270 N76330 X0.5737 Z-0.0589 N76340 X0.5726 Z-0.0600 N76350 X0.4156 N76360 X0.4145 Z-0.0583 N76370 X0.3816 Z-0.0013 N76380 X0.3805 Z-0.0000 N76390 Y1.4073 Z-0.0000 N76400 X0.3816 Z-0.0013 N76410 X0.4146 Z-0.0584 N76420 X0.4157 Z-0.0600 N76430 X0.5728 N76440 X0.6069 Z-0.0011 N76450 X0.6080 Z0.0000 N76460 X0.6079 Y1.4094 Z-0.0002 N76470 X0.6080 Y1.4108 Z0.0000 N76480 X0.6082 Y1.4123 N76490 X0.6071 Z-0.0015 N76500 X0.5884 Z-0.0336 N76510 X0.5741 Z-0.0582 N76520 X0.5730 Z-0.0600 N76530 X0.4157 N76540 X0.4146 Z-0.0585 N76550 X0.3816 Z-0.0013 N76560 X0.3805 Z-0.0000 N76570 Y1.4173 Z-0.0000 N76580 X0.3816 Z-0.0013 N76590 X0.4146 Z-0.0585 N76600 X0.4157 Z-0.0600 N76610 X0.5730 N76620 X0.5741 Z-0.0591 N76630 X0.5961 Z-0.0217 N76640 X0.6082 Z-0.0012 N76650 X0.6093 Z0.0000 N76660 X0.6095 Y1.4179 N76670 X0.6097 Y1.4187 Z-0.0003 N76680 X0.6098 Y1.4194 N76690 X0.6100 Y1.4201 Z-0.0002 N76700 X0.6103 Y1.4208 Z0.0000 N76710 X0.6105 Y1.4215 N76720 X0.6107 Y1.4221 Z-0.0004 N76730 X0.6109 Y1.4223 N76740 X0.6098 Z-0.0012 N76750 X0.6043 Z-0.0100 N76760 X0.5900 Z-0.0338 N76770 X0.5747 Z-0.0596 N76780 X0.5736 Z-0.0600 N76790 X0.4156 N76800 X0.4134 Z-0.0563 N76810 X0.3816 Z-0.0013 N76820 X0.3805 Z-0.0000 N76830 Y1.4273 Z-0.0000 N76840 X0.3816 Z-0.0013 N76850 X0.4146 Z-0.0586 N76860 X0.4157 Z-0.0600 N76870 X0.5754 N76880 X0.5765 Z-0.0585 N76890 X0.5887 Z-0.0383 N76900 X0.5975 Z-0.0239 N76910 X0.6030 Z-0.0154 N76920 X0.6074 Z-0.0089 N76930 X0.6107 Z-0.0048 N76940 X0.6118 Z-0.0035 N76950 X0.6129 Z-0.0026 N76960 X0.6140 Z-0.0022 N76970 X0.6151 Z-0.0021 N76980 X0.6316 Z-0.0025 N76990 X0.6448 Z-0.0030 N77000 X0.6591 Z-0.0038 N77010 X0.6801 Z-0.0052 N77020 X0.6867 Z-0.0057 N77030 X0.6955 Z-0.0068 N77040 X0.7043 Z-0.0076 N77050 X0.7142 Z-0.0083 N77060 X0.7263 Z-0.0089 N77070 X0.7384 Z-0.0091 N77080 X0.7583 Z-0.0091 N77090 X0.7737 Z-0.0091 N77100 X0.7858 Z-0.0089 N77110 X0.7968 Z-0.0085 N77120 X0.8056 Z-0.0079 N77130 X0.8144 Z-0.0072 N77140 X0.8221 Z-0.0063 N77150 X0.8265 Z-0.0057 N77160 X0.8508 Z-0.0041 N77170 X0.8651 Z-0.0032 N77180 X0.8794 Z-0.0026 N77190 X0.8915 Z-0.0023 N77200 X0.8981 Z-0.0022 N77210 X0.8992 Z-0.0022 N77220 X0.9003 Z-0.0023 N77230 X0.9014 Z-0.0031 N77240 X0.9025 Z-0.0042 N77250 X0.9047 Z-0.0068 N77260 X0.9069 Z-0.0097 N77270 X0.9113 Z-0.0162 N77280 X0.9190 Z-0.0284 N77290 X0.9301 Z-0.0466 N77300 X0.9378 Z-0.0595 N77310 X0.9389 Z-0.0600 N77320 X0.9532 N77330 X0.9543 Z-0.0586 N77340 X0.9873 Z-0.0013 N77350 X0.9884 Z0.0000 N77360 Y1.4223 N77370 X0.9873 Z-0.0013 N77380 X0.9544 Z-0.0582 N77390 X0.9533 Z-0.0600 N77400 X0.9391 N77410 X0.9127 Z-0.0156 N77420 X0.9051 Z-0.0030 N77430 X0.9040 Z-0.0012 N77440 X0.9029 Z0.0000 N77450 X0.9029 Y1.4222 N77460 X0.9034 Y1.4210 Z-0.0005 N77470 X0.9037 Y1.4203 Z0.0000 N77480 X0.9040 Y1.4188 N77490 X0.9042 Y1.4181 Z-0.0001 N77500 X0.9044 Y1.4173 Z-0.0004 N77510 X0.9055 Z-0.0009 N77520 X0.9262 Y1.4173 Z-0.0358 N77530 X0.9393 Y1.4173 Z-0.0583 N77540 X0.9404 Y1.4173 Z-0.0600 N77550 X0.9524 Y1.4173 N77560 X0.9535 Y1.4173 Z-0.0597 N77570 X0.9873 Y1.4173 Z-0.0013 N77580 X0.9884 Z0.0000 N77590 Y1.4123 N77600 X0.9873 Z-0.0013 N77610 X0.9535 Z-0.0597 N77620 X0.9524 Z-0.0600 N77630 X0.9415 N77640 X0.9404 Z-0.0593 N77650 X0.9284 Z-0.0384 N77660 X0.9099 Z-0.0067 N77670 X0.9066 Z-0.0011 N77680 X0.9055 Z-0.0006 N77690 X0.9056 Y1.4119 Z-0.0004 N77700 X0.9058 Y1.4109 Z-0.0002 N77710 X0.9058 Y1.4104 Z-0.0000 N77720 X0.9059 Y1.4090 Z0.0000 N77730 X0.9058 Y1.4079 Z-0.0001 N77740 X0.9057 Y1.4073 Z-0.0003 N77750 X0.9068 Z-0.0011 N77760 X0.9405 Z-0.0592 N77770 X0.9416 Z-0.0600 N77780 X0.9525 N77790 X0.9536 Z-0.0595 N77800 X0.9873 Z-0.0013 N77810 X0.9884 Z0.0000 N77820 Y1.4023 N77830 X0.9873 Z-0.0013 N77840 X0.9536 Z-0.0595 N77850 X0.9525 Z-0.0600 N77860 X0.9416 N77870 X0.9405 Z-0.0599 N77880 X0.9231 Z-0.0303 N77890 X0.9068 Z-0.0029 N77900 X0.9057 Z-0.0011 N77910 X0.9046 Z-0.0001 N77920 X0.9044 Y1.4017 Z-0.0006 N77930 X0.9043 Y1.4010 Z-0.0002 N77940 X0.9041 Y1.4003 Z0.0000 N77950 X0.9037 Y1.3988 N77960 X0.9035 Y1.3982 Z-0.0003 N77970 X0.9032 Y1.3975 Z-0.0004 N77980 X0.9032 Y1.3974 Z-0.0002 N77990 X0.9043 Z-0.0009 N78000 X0.9196 Z-0.0265 N78010 X0.9392 Z-0.0598 N78020 X0.9403 Z-0.0600 N78030 X0.9524 N78040 X0.9535 Z-0.0598 N78050 X0.9873 Z-0.0013 N78060 X0.9884 Z0.0000 N78070 Y1.3924 N78080 X0.9873 Z-0.0013 N78090 X0.9544 Z-0.0583 N78100 X0.9533 Z-0.0600 N78110 X0.9390 N78120 X0.9379 Z-0.0597 N78130 X0.9226 Z-0.0341 N78140 X0.9149 Z-0.0215 N78150 X0.9094 Z-0.0129 N78160 X0.9061 Z-0.0080 N78170 X0.9039 Z-0.0050 N78180 X0.9028 Z-0.0036 N78190 X0.9017 Z-0.0025 N78200 X0.9006 Z-0.0017 N78210 X0.8962 Z-0.0008 N78220 X0.8930 Z0.0000 N78230 X0.8908 N78240 X0.8894 Y1.3922 N78250 X0.8884 Y1.3920 Z-0.0002 N78260 X0.8875 Y1.3919 Z-0.0005 N78270 X0.8865 Y1.3917 Z-0.0002 N78280 X0.8856 Y1.3916 N78290 X0.8847 Y1.3914 Z0.0000 N78300 X0.8829 Y1.3911 N78310 X0.8820 Y1.3909 Z-0.0001 N78320 X0.8810 Y1.3908 Z-0.0004 N78330 X0.8800 Y1.3905 Z-0.0000 N78340 X0.8767 Y1.3899 Z0.0000 N78350 X0.8757 Y1.3896 Z-0.0006 N78360 X0.8747 Y1.3894 Z-0.0002 N78370 X0.8737 Y1.3891 Z0.0000 N78380 X0.8726 Y1.3889 N78390 X0.8717 Y1.3886 Z-0.0003 N78400 X0.8707 Y1.3884 Z-0.0002 N78410 X0.8697 Y1.3881 Z0.0000 N78420 X0.8688 Y1.3879 N78430 X0.8680 Y1.3876 Z-0.0001 N78440 X0.8672 Y1.3874 Z-0.0005 N78450 X0.8682 Z-0.0007 N78460 X0.8693 N78470 X0.8704 Z-0.0010 N78480 X0.8759 Z-0.0032 N78490 X0.8814 Z-0.0051 N78500 X0.8879 Z-0.0071 N78510 X0.8956 Z-0.0089 N78520 X0.8999 Z-0.0098 N78530 X0.9010 Z-0.0100 N78540 X0.9021 Z-0.0103 N78550 X0.9032 Z-0.0109 N78560 X0.9043 Z-0.0117 N78570 X0.9054 Z-0.0127 N78580 X0.9076 Z-0.0152 N78590 X0.9109 Z-0.0194 N78600 X0.9152 Z-0.0257 N78610 X0.9218 Z-0.0358 N78620 X0.9327 Z-0.0534 N78630 X0.9360 Z-0.0588 N78640 X0.9371 Z-0.0600 N78650 X0.9524 N78660 X0.9535 Z-0.0598 N78670 X0.9873 Z-0.0013 N78680 X0.9884 Z0.0000 N78690 Y1.3824 N78700 X0.9873 Z-0.0013 N78710 X0.9544 Z-0.0583 N78720 X0.9533 Z-0.0600 N78730 X0.9358 N78740 X0.9347 Z-0.0598 N78750 X0.9270 Z-0.0479 N78760 X0.9215 Z-0.0397 N78770 X0.9171 Z-0.0336 N78780 X0.9138 Z-0.0292 N78790 X0.9105 Z-0.0254 N78800 X0.9083 Z-0.0231 N78810 X0.9061 Z-0.0212 N78820 X0.9050 Z-0.0204 N78830 X0.9039 Z-0.0197 N78840 X0.9028 Z-0.0192 N78850 X0.9017 Z-0.0189 N78860 X0.8973 Z-0.0180 N78870 X0.8897 Z-0.0162 N78880 X0.8831 Z-0.0142 N78890 X0.8776 Z-0.0123 N78900 X0.8732 Z-0.0104 N78910 X0.8688 Z-0.0083 N78920 X0.8644 Z-0.0059 N78930 X0.8600 Z-0.0032 N78940 X0.8556 Z0.0000 N78950 X0.8546 N78960 X0.8537 Y1.3819 Z-0.0003 N78970 X0.8528 Y1.3814 Z0.0000 N78980 X0.8519 Y1.3809 Z-0.0004 N78990 X0.8511 Y1.3804 Z0.0000 N79000 X0.8502 Y1.3799 Z-0.0001 N79010 X0.8495 Y1.3793 Z-0.0000 N79020 X0.8487 Y1.3788 Z-0.0002 N79030 X0.8479 Y1.3782 Z0.0000 N79040 X0.8469 Y1.3774 N79050 X0.8480 Z-0.0008 N79060 X0.8491 Z-0.0013 N79070 X0.8524 Z-0.0047 N79080 X0.8557 Z-0.0076 N79090 X0.8590 Z-0.0103 N79100 X0.8623 Z-0.0126 N79110 X0.8656 Z-0.0147 N79120 X0.8699 Z-0.0171 N79130 X0.8743 Z-0.0192 N79140 X0.8798 Z-0.0215 N79150 X0.8853 Z-0.0233 N79160 X0.8908 Z-0.0249 N79170 X0.8985 Z-0.0268 N79180 X0.9018 Z-0.0274 N79190 X0.9029 Z-0.0276 N79200 X0.9040 Z-0.0280 N79210 X0.9051 Z-0.0285 N79220 X0.9062 Z-0.0291 N79230 X0.9083 Z-0.0306 N79240 X0.9116 Z-0.0335 N79250 X0.9149 Z-0.0370 N79260 X0.9193 Z-0.0422 N79270 X0.9237 Z-0.0479 N79280 X0.9292 Z-0.0556 N79290 X0.9314 Z-0.0587 N79300 X0.9325 Z-0.0600 N79310 X0.9533 N79320 X0.9555 Z-0.0563 N79330 X0.9873 Z-0.0013 N79340 X0.9884 Z0.0000 N79350 Y1.3724 N79360 X0.9873 Z-0.0013 N79370 X0.9534 Z-0.0599 N79380 X0.9523 Z-0.0600 N79390 X0.9294 N79400 X0.9283 Z-0.0592 N79410 X0.9239 Z-0.0535 N79420 X0.9195 Z-0.0483 N79430 X0.9163 Z-0.0448 N79440 X0.9130 Z-0.0417 N79450 X0.9108 Z-0.0400 N79460 X0.9086 Z-0.0385 N79470 X0.9064 Z-0.0373 N79480 X0.9042 Z-0.0366 N79490 X0.9020 Z-0.0361 N79500 X0.8988 Z-0.0355 N79510 X0.8922 Z-0.0340 N79520 X0.8867 Z-0.0325 N79530 X0.8824 Z-0.0311 N79540 X0.8780 Z-0.0294 N79550 X0.8736 Z-0.0275 N79560 X0.8692 Z-0.0253 N79570 X0.8660 Z-0.0234 N79580 X0.8627 Z-0.0211 N79590 X0.8594 Z-0.0186 N79600 X0.8561 Z-0.0158 N79610 X0.8528 Z-0.0125 N79620 X0.8485 Z-0.0075 N79630 X0.8441 Z-0.0022 N79640 X0.8430 Z-0.0010 N79650 X0.8419 Z0.0000 N79660 X0.8412 Y1.3716 N79670 X0.8405 Y1.3708 Z-0.0005 N79680 X0.8400 Y1.3701 Z0.0000 N79690 X0.8395 Y1.3694 Z-0.0003 N79700 X0.8389 Y1.3687 Z0.0000 N79710 X0.8381 Y1.3674 N79720 X0.8392 Z-0.0009 N79730 X0.8447 Z-0.0085 N79740 X0.8502 Z-0.0157 N79750 X0.8545 Z-0.0209 N79760 X0.8578 Z-0.0244 N79770 X0.8611 Z-0.0275 N79780 X0.8644 Z-0.0300 N79790 X0.8677 Z-0.0323 N79800 X0.8721 Z-0.0348 N79810 X0.8765 Z-0.0370 N79820 X0.8809 Z-0.0388 N79830 X0.8864 Z-0.0407 N79840 X0.8919 Z-0.0423 N79850 X0.8995 Z-0.0442 N79860 X0.9028 Z-0.0448 N79870 X0.9050 Z-0.0454 N79880 X0.9072 Z-0.0462 N79890 X0.9094 Z-0.0474 N79900 X0.9116 Z-0.0488 N79910 X0.9138 Z-0.0504 N79920 X0.9171 Z-0.0533 N79930 X0.9215 Z-0.0576 N79940 X0.9237 Z-0.0600 N79950 X0.9533 Z-0.0600 N79960 X0.9544 Z-0.0583 N79970 X0.9873 Z-0.0013 N79980 X0.9884 Z0.0000 N79990 Y1.3624 N80000 X0.9873 Z-0.0013 N80010 X0.9534 Z-0.0599 N80020 X0.9512 Z-0.0600 N80030 X0.9173 N80040 X0.9162 Z-0.0596 N80050 X0.9129 Z-0.0572 N80060 X0.9107 Z-0.0559 N80070 X0.9085 Z-0.0548 N80080 X0.9063 Z-0.0540 N80090 X0.9042 Z-0.0534 N80100 X0.9009 Z-0.0528 N80110 X0.8932 Z-0.0511 N80120 X0.8877 Z-0.0496 N80130 X0.8823 Z-0.0477 N80140 X0.8779 Z-0.0459 N80150 X0.8735 Z-0.0438 N80160 X0.8702 Z-0.0419 N80170 X0.8669 Z-0.0397 N80180 X0.8648 Z-0.0380 N80190 X0.8626 Z-0.0360 N80200 X0.8593 Z-0.0326 N80210 X0.8560 Z-0.0287 N80220 X0.8516 Z-0.0231 N80230 X0.8461 Z-0.0155 N80240 X0.8396 Z-0.0058 N80250 X0.8374 Z-0.0025 N80260 X0.8363 Z-0.0009 N80270 X0.8352 Z0.0000 N80280 X0.8349 Y1.3617 Z-0.0001 N80290 X0.8345 Y1.3609 Z0.0000 N80300 X0.8341 Y1.3600 Z-0.0002 N80310 X0.8334 Y1.3583 Z0.0000 N80320 X0.8330 Y1.3574 Z-0.0002 N80330 X0.8341 Z-0.0012 N80340 X0.8440 Z-0.0168 N80350 X0.8506 Z-0.0267 N80360 X0.8560 Z-0.0345 N80370 X0.8604 Z-0.0403 N80380 X0.8637 Z-0.0442 N80390 X0.8659 Z-0.0464 N80400 X0.8681 Z-0.0483 N80410 X0.8703 Z-0.0499 N80420 X0.8735 Z-0.0520 N80430 X0.8768 Z-0.0537 N80440 X0.8812 Z-0.0557 N80450 X0.8856 Z-0.0574 N80460 X0.8899 Z-0.0589 N80470 X0.8932 Z-0.0598 N80480 X0.8943 Z-0.0600 N80490 X0.9523 N80500 X0.9534 Z-0.0599 N80510 X0.9873 Z-0.0013 N80520 X0.9884 Z0.0000 N80530 Y1.3524 N80540 X0.9873 Z-0.0013 N80550 X0.9544 Z-0.0583 N80560 X0.9533 Z-0.0600 N80570 X0.8743 N80580 X0.8732 Z-0.0596 N80590 X0.8710 Z-0.0580 N80600 X0.8699 Z-0.0572 N80610 X0.8688 Z-0.0562 N80620 X0.8677 Z-0.0550 N80630 X0.8655 Z-0.0524 N80640 X0.8622 Z-0.0480 N80650 X0.8578 Z-0.0416 N80660 X0.8512 Z-0.0314 N80670 X0.8413 Z-0.0154 N80680 X0.8326 Z-0.0008 N80690 X0.8315 Z0.0000 N80700 X0.8311 Y1.3509 N80710 X0.8306 Y1.3489 Z-0.0005 N80720 X0.8304 Y1.3479 Z-0.0000 N80730 X0.8303 Y1.3474 Z0.0000 N80740 X0.8314 Z-0.0010 N80750 X0.8479 Z-0.0290 N80760 X0.8589 Z-0.0473 N80770 X0.8655 Z-0.0579 N80780 X0.8666 Z-0.0596 N80790 X0.8677 Z-0.0600 N80800 X0.9533 N80810 X0.9544 Z-0.0583 N80820 X0.9873 Z-0.0013 N80830 X0.9884 Z0.0000 N80840 Y1.3424 N80850 X0.9873 Z-0.0013 N80860 X0.9545 Z-0.0581 N80870 X0.9534 Z-0.0600 N80880 X0.8657 N80890 X0.8646 Z-0.0589 N80900 X0.8471 Z-0.0291 N80910 X0.8307 Z-0.0010 N80920 X0.8296 Z-0.0006 N80930 X0.8294 Y1.3406 Z-0.0001 N80940 X0.8293 Y1.3396 Z0.0000 N80950 X0.8291 Y1.3374 N80960 X0.8302 Z-0.0013 N80970 X0.8632 Z-0.0583 N80980 X0.8643 Z-0.0600 N80990 X0.9533 N81000 X0.9544 Z-0.0584 N81010 X0.9873 Z-0.0013 N81020 X0.9884 Z0.0000 N81030 Y1.3324 N81040 X0.9873 Z-0.0013 N81050 X0.9543 Z-0.0585 N81060 X0.9532 Z-0.0600 N81070 X0.8641 N81080 X0.8630 Z-0.0586 N81090 X0.8311 Z-0.0033 N81100 X0.8289 Z0.0000 N81110 X0.8289 Y1.3274 N81120 X0.8311 Z-0.0033 N81130 X0.8630 Z-0.0586 N81140 X0.8641 Z-0.0600 N81150 X0.9532 N81160 X0.9543 Z-0.0585 N81170 X0.9873 Z-0.0013 N81180 X0.9884 Z0.0000 N81190 Y1.3224 N81200 X0.9873 Z-0.0013 N81210 X0.9543 Z-0.0585 N81220 X0.9532 Z-0.0600 N81230 X0.8641 N81240 X0.8630 Z-0.0586 N81250 X0.8311 Z-0.0033 N81260 X0.8289 Z0.0000 N81270 Y1.3174 N81280 X0.8311 Z-0.0033 N81290 X0.8630 Z-0.0586 N81300 X0.8641 Z-0.0600 N81310 X0.9532 N81320 X0.9543 Z-0.0585 N81330 X0.9873 Z-0.0013 N81340 X0.9884 Z0.0000 N81350 Y1.3124 N81360 X0.9873 Z-0.0013 N81370 X0.9543 Z-0.0585 N81380 X0.9532 Z-0.0600 N81390 X0.8641 N81400 X0.8630 Z-0.0586 N81410 X0.8311 Z-0.0033 N81420 X0.8289 Z0.0000 N81430 Y1.3075 N81440 X0.8311 Z-0.0033 N81450 X0.8630 Z-0.0586 N81460 X0.8641 Z-0.0600 N81470 X0.9532 N81480 X0.9543 Z-0.0585 N81490 X0.9873 Z-0.0013 N81500 X0.9884 Z0.0000 N81510 Y1.3025 N81520 X0.9873 Z-0.0013 N81530 X0.9543 Z-0.0585 N81540 X0.9532 Z-0.0600 N81550 X0.8641 N81560 X0.8630 Z-0.0586 N81570 X0.8311 Z-0.0033 N81580 X0.8289 Z0.0000 N81590 Y1.2975 N81600 X0.8311 Z-0.0033 N81610 X0.8630 Z-0.0586 N81620 X0.8641 Z-0.0600 N81630 X0.9532 N81640 X0.9543 Z-0.0585 N81650 X0.9873 Z-0.0013 N81660 X0.9884 Z0.0000 N81670 Y1.2925 N81680 X0.9873 Z-0.0013 N81690 X0.9543 Z-0.0585 N81700 X0.9532 Z-0.0600 N81710 X0.8641 N81720 X0.8630 Z-0.0586 N81730 X0.8311 Z-0.0033 N81740 X0.8289 Z0.0000 N81750 Y1.2875 N81760 X0.8311 Z-0.0033 N81770 X0.8630 Z-0.0586 N81780 X0.8641 Z-0.0600 N81790 X0.9532 N81800 X0.9543 Z-0.0585 N81810 X0.9873 Z-0.0013 N81820 X0.9884 Z0.0000 N81830 Y1.2825 N81840 X0.9873 Z-0.0013 N81850 X0.9543 Z-0.0585 N81860 X0.9532 Z-0.0600 N81870 X0.8641 N81880 X0.8630 Z-0.0586 N81890 X0.8311 Z-0.0033 N81900 X0.8289 Z0.0000 N81910 Y1.2775 N81920 X0.8311 Z-0.0033 N81930 X0.8630 Z-0.0586 N81940 X0.8641 Z-0.0600 N81950 X0.9532 N81960 X0.9543 Z-0.0585 N81970 X0.9873 Z-0.0013 N81980 X0.9884 Z0.0000 N81990 Y1.2725 N82000 X0.9873 Z-0.0013 N82010 X0.9543 Z-0.0585 N82020 X0.9532 Z-0.0600 N82030 X0.8641 N82040 X0.8630 Z-0.0586 N82050 X0.8311 Z-0.0033 N82060 X0.8289 Z0.0000 N82070 Y1.2675 N82080 X0.8311 Z-0.0033 N82090 X0.8630 Z-0.0586 N82100 X0.8641 Z-0.0600 N82110 X0.9532 N82120 X0.9543 Z-0.0585 N82130 X0.9873 Z-0.0013 N82140 X0.9884 Z0.0000 N82150 Y1.2625 N82160 X0.9873 Z-0.0013 N82170 X0.9543 Z-0.0585 N82180 X0.9532 Z-0.0600 N82190 X0.8641 N82200 X0.8630 Z-0.0586 N82210 X0.8311 Z-0.0033 N82220 X0.8289 Z0.0000 N82230 Y1.2575 N82240 X0.8311 Z-0.0033 N82250 X0.8630 Z-0.0586 N82260 X0.8641 Z-0.0600 N82270 X0.9532 N82280 X0.9543 Z-0.0585 N82290 X0.9873 Z-0.0013 N82300 X0.9884 Z0.0000 N82310 Y1.2525 N82320 X0.9873 Z-0.0013 N82330 X0.9543 Z-0.0585 N82340 X0.9532 Z-0.0600 N82350 X0.8641 N82360 X0.8630 Z-0.0586 N82370 X0.8311 Z-0.0033 N82380 X0.8289 Z0.0000 N82390 Y1.2475 N82400 X0.8311 Z-0.0033 N82410 X0.8630 Z-0.0586 N82420 X0.8641 Z-0.0600 N82430 X0.9532 N82440 X0.9543 Z-0.0585 N82450 X0.9873 Z-0.0013 N82460 X0.9884 Z0.0000 N82470 Y1.2425 N82480 X0.9873 Z-0.0013 N82490 X0.9543 Z-0.0585 N82500 X0.9532 Z-0.0600 N82510 X0.8641 N82520 X0.8630 Z-0.0586 N82530 X0.8311 Z-0.0033 N82540 X0.8289 Z0.0000 N82550 Y1.2375 N82560 X0.8311 Z-0.0033 N82570 X0.8630 Z-0.0586 N82580 X0.8641 Z-0.0600 N82590 X0.9532 N82600 X0.9543 Z-0.0585 N82610 X0.9873 Z-0.0013 N82620 X0.9884 Z0.0000 N82630 Y1.2325 N82640 X0.9873 Z-0.0013 N82650 X0.9543 Z-0.0585 N82660 X0.9532 Z-0.0600 N82670 X0.8641 N82680 X0.8630 Z-0.0586 N82690 X0.8311 Z-0.0033 N82700 X0.8289 Z0.0000 N82710 Y1.2275 N82720 X0.8311 Z-0.0033 N82730 X0.8630 Z-0.0586 N82740 X0.8641 Z-0.0600 N82750 X0.9532 N82760 X0.9543 Z-0.0585 N82770 X0.9873 Z-0.0013 N82780 X0.9884 Z0.0000 N82790 Y1.2225 N82800 X0.9873 Z-0.0013 N82810 X0.9543 Z-0.0585 N82820 X0.9532 Z-0.0600 N82830 X0.8641 N82840 X0.8630 Z-0.0586 N82850 X0.8311 Z-0.0033 N82860 X0.8289 Z0.0000 N82870 Y1.2176 N82880 X0.8311 Z-0.0033 N82890 X0.8630 Z-0.0586 N82900 X0.8641 Z-0.0600 N82910 X0.9532 N82920 X0.9543 Z-0.0585 N82930 X0.9873 Z-0.0013 N82940 X0.9884 Z0.0000 N82950 Y1.2126 N82960 X0.9873 Z-0.0013 N82970 X0.9543 Z-0.0585 N82980 X0.9532 Z-0.0600 N82990 X0.8641 N83000 X0.8630 Z-0.0586 N83010 X0.8311 Z-0.0033 N83020 X0.8289 Z0.0000 N83030 Y1.2076 N83040 X0.8311 Z-0.0033 N83050 X0.8630 Z-0.0586 N83060 X0.8641 Z-0.0600 N83070 X0.9532 N83080 X0.9543 Z-0.0585 N83090 X0.9873 Z-0.0013 N83100 X0.9884 Z0.0000 N83110 Y1.2026 N83120 X0.9873 Z-0.0013 N83130 X0.9543 Z-0.0585 N83140 X0.9532 Z-0.0600 N83150 X0.8641 N83160 X0.8630 Z-0.0586 N83170 X0.8311 Z-0.0033 N83180 X0.8289 Z0.0000 N83190 Y1.1976 N83200 X0.8311 Z-0.0033 N83210 X0.8630 Z-0.0586 N83220 X0.8641 Z-0.0600 N83230 X0.9532 N83240 X0.9543 Z-0.0585 N83250 X0.9873 Z-0.0013 N83260 X0.9884 Z0.0000 N83270 Y1.1926 N83280 X0.9873 Z-0.0013 N83290 X0.9543 Z-0.0585 N83300 X0.9532 Z-0.0600 N83310 X0.8641 N83320 X0.8630 Z-0.0586 N83330 X0.8311 Z-0.0033 N83340 X0.8289 Z0.0000 N83350 Y1.1876 N83360 X0.8311 Z-0.0033 N83370 X0.8630 Z-0.0586 N83380 X0.8641 Z-0.0600 N83390 X0.9532 N83400 X0.9543 Z-0.0585 N83410 X0.9873 Z-0.0013 N83420 X0.9884 Z0.0000 N83430 Y1.1826 N83440 X0.9873 Z-0.0013 N83450 X0.9543 Z-0.0585 N83460 X0.9532 Z-0.0600 N83470 X0.8641 N83480 X0.8630 Z-0.0586 N83490 X0.8311 Z-0.0033 N83500 X0.8289 Z0.0000 N83510 Y1.1776 N83520 X0.8311 Z-0.0033 N83530 X0.8630 Z-0.0586 N83540 X0.8641 Z-0.0600 N83550 X0.9532 N83560 X0.9543 Z-0.0585 N83570 X0.9873 Z-0.0013 N83580 X0.9884 Z0.0000 N83590 Y1.1726 N83600 X0.9873 Z-0.0013 N83610 X0.9543 Z-0.0585 N83620 X0.9532 Z-0.0600 N83630 X0.8641 N83640 X0.8630 Z-0.0586 N83650 X0.8311 Z-0.0033 N83660 X0.8289 Z0.0000 N83670 Y1.1676 N83680 X0.8311 Z-0.0033 N83690 X0.8630 Z-0.0586 N83700 X0.8641 Z-0.0600 N83710 X0.9532 N83720 X0.9543 Z-0.0585 N83730 X0.9873 Z-0.0013 N83740 X0.9884 Z0.0000 N83750 Y1.1626 N83760 X0.9873 Z-0.0013 N83770 X0.9543 Z-0.0585 N83780 X0.9532 Z-0.0600 N83790 X0.8641 N83800 X0.8630 Z-0.0586 N83810 X0.8311 Z-0.0033 N83820 X0.8289 Z0.0000 N83830 Y1.1576 N83840 X0.8311 Z-0.0033 N83850 X0.8630 Z-0.0586 N83860 X0.8641 Z-0.0600 N83870 X0.9532 N83880 X0.9543 Z-0.0585 N83890 X0.9873 Z-0.0013 N83900 X0.9884 Z0.0000 N83910 Y1.1526 N83920 X0.9873 Z-0.0013 N83930 X0.9543 Z-0.0585 N83940 X0.9532 Z-0.0600 N83950 X0.8641 N83960 X0.8630 Z-0.0586 N83970 X0.8311 Z-0.0033 N83980 X0.8289 Z0.0000 N83990 Y1.1476 N84000 X0.8311 Z-0.0033 N84010 X0.8630 Z-0.0586 N84020 X0.8641 Z-0.0600 N84030 X0.9532 N84040 X0.9543 Z-0.0585 N84050 X0.9873 Z-0.0013 N84060 X0.9884 Z0.0000 N84070 Y1.1426 N84080 X0.9873 Z-0.0013 N84090 X0.9543 Z-0.0585 N84100 X0.9532 Z-0.0600 N84110 X0.8641 N84120 X0.8630 Z-0.0586 N84130 X0.8311 Z-0.0033 N84140 X0.8289 Z0.0000 N84150 Y1.1376 N84160 X0.8311 Z-0.0033 N84170 X0.8630 Z-0.0586 N84180 X0.8641 Z-0.0600 N84190 X0.9532 N84200 X0.9543 Z-0.0585 N84210 X0.9873 Z-0.0013 N84220 X0.9884 Z0.0000 N84230 Y1.1326 N84240 X0.9873 Z-0.0013 N84250 X0.9543 Z-0.0585 N84260 X0.9532 Z-0.0600 N84270 X0.8641 N84280 X0.8630 Z-0.0586 N84290 X0.8311 Z-0.0033 N84300 X0.8289 Z0.0000 N84310 Y1.1277 N84320 X0.8311 Z-0.0033 N84330 X0.8630 Z-0.0586 N84340 X0.8641 Z-0.0600 N84350 X0.9532 N84360 X0.9543 Z-0.0585 N84370 X0.9873 Z-0.0013 N84380 X0.9884 Z0.0000 N84390 Y1.1227 N84400 X0.9873 Z-0.0013 N84410 X0.9543 Z-0.0585 N84420 X0.9532 Z-0.0600 N84430 X0.8641 N84440 X0.8630 Z-0.0586 N84450 X0.8311 Z-0.0033 N84460 X0.8289 Z0.0000 N84470 Y1.1177 N84480 X0.8311 Z-0.0033 N84490 X0.8630 Z-0.0586 N84500 X0.8641 Z-0.0600 N84510 X0.9532 N84520 X0.9543 Z-0.0585 N84530 X0.9873 Z-0.0013 N84540 X0.9884 Z0.0000 N84550 Y1.1127 N84560 X0.9873 Z-0.0013 N84570 X0.9543 Z-0.0585 N84580 X0.9532 Z-0.0600 N84590 X0.8641 N84600 X0.8630 Z-0.0586 N84610 X0.8311 Z-0.0033 N84620 X0.8289 Z0.0000 N84630 Y1.1077 N84640 X0.8311 Z-0.0033 N84650 X0.8630 Z-0.0586 N84660 X0.8641 Z-0.0600 N84670 X0.9532 N84680 X0.9543 Z-0.0585 N84690 X0.9873 Z-0.0013 N84700 X0.9884 Z0.0000 N84710 Y1.1027 N84720 X0.9873 Z-0.0013 N84730 X0.9543 Z-0.0585 N84740 X0.9532 Z-0.0600 N84750 X0.8641 N84760 X0.8630 Z-0.0586 N84770 X0.8311 Z-0.0033 N84780 X0.8289 Z0.0000 N84790 Y1.0977 N84800 X0.8311 Z-0.0033 N84810 X0.8630 Z-0.0586 N84820 X0.8641 Z-0.0600 N84830 X0.9532 N84840 X0.9543 Z-0.0585 N84850 X0.9873 Z-0.0013 N84860 X0.9884 Z0.0000 N84870 Y1.0927 N84880 X0.9873 Z-0.0013 N84890 X0.9543 Z-0.0585 N84900 X0.9532 Z-0.0600 N84910 X0.8641 N84920 X0.8630 Z-0.0586 N84930 X0.8311 Z-0.0033 N84940 X0.8289 Z0.0000 N84950 Y1.0877 N84960 X0.8311 Z-0.0033 N84970 X0.8630 Z-0.0586 N84980 X0.8641 Z-0.0600 N84990 X0.9532 N85000 X0.9543 Z-0.0585 N85010 X0.9873 Z-0.0013 N85020 X0.9884 Z0.0000 N85030 Y1.0827 N85040 X0.9873 Z-0.0013 N85050 X0.9543 Z-0.0585 N85060 X0.9532 Z-0.0600 N85070 X0.8641 N85080 X0.8630 Z-0.0586 N85090 X0.8311 Z-0.0033 N85100 X0.8289 Z0.0000 N85110 Y1.0777 N85120 X0.8311 Z-0.0033 N85130 X0.8630 Z-0.0586 N85140 X0.8641 Z-0.0600 N85150 X0.9532 N85160 X0.9543 Z-0.0585 N85170 X0.9873 Z-0.0013 N85180 X0.9884 Z0.0000 N85190 Y1.0727 N85200 X0.9873 Z-0.0013 N85210 X0.9543 Z-0.0585 N85220 X0.9532 Z-0.0600 N85230 X0.8641 N85240 X0.8630 Z-0.0586 N85250 X0.8311 Z-0.0033 N85260 X0.8289 Z0.0000 N85270 Y1.0677 N85280 X0.8311 Z-0.0033 N85290 X0.8630 Z-0.0586 N85300 X0.8641 Z-0.0600 N85310 X0.9532 N85320 X0.9543 Z-0.0585 N85330 X0.9873 Z-0.0013 N85340 X0.9884 Z0.0000 N85350 Y1.0627 N85360 X0.9873 Z-0.0013 N85370 X0.9543 Z-0.0585 N85380 X0.9532 Z-0.0600 N85390 X0.8641 N85400 X0.8630 Z-0.0586 N85410 X0.8311 Z-0.0033 N85420 X0.8289 Z0.0000 N85430 Y1.0577 N85440 X0.8311 Z-0.0033 N85450 X0.8630 Z-0.0586 N85460 X0.8641 Z-0.0600 N85470 X0.9532 N85480 X0.9543 Z-0.0585 N85490 X0.9873 Z-0.0013 N85500 X0.9884 Z0.0000 N85510 Y1.0527 N85520 X0.9873 Z-0.0013 N85530 X0.9543 Z-0.0585 N85540 X0.9532 Z-0.0600 N85550 X0.8641 N85560 X0.8630 Z-0.0586 N85570 X0.8311 Z-0.0033 N85580 X0.8289 Z0.0000 N85590 Y1.0477 N85600 X0.8311 Z-0.0033 N85610 X0.8630 Z-0.0586 N85620 X0.8641 Z-0.0600 N85630 X0.9532 N85640 X0.9543 Z-0.0585 N85650 X0.9873 Z-0.0013 N85660 X0.9884 Z0.0000 N85670 Y1.0427 N85680 X0.9873 Z-0.0013 N85690 X0.9543 Z-0.0585 N85700 X0.9532 Z-0.0600 N85710 X0.8641 N85720 X0.8630 Z-0.0586 N85730 X0.8311 Z-0.0033 N85740 X0.8289 Z0.0000 N85750 Y1.0378 N85760 X0.8311 Z-0.0033 N85770 X0.8630 Z-0.0586 N85780 X0.8641 Z-0.0600 N85790 X0.9532 N85800 X0.9543 Z-0.0585 N85810 X0.9873 Z-0.0013 N85820 X0.9884 Z0.0000 N85830 Y1.0328 N85840 X0.9873 Z-0.0013 N85850 X0.9543 Z-0.0585 N85860 X0.9532 Z-0.0600 N85870 X0.8641 N85880 X0.8630 Z-0.0586 N85890 X0.8311 Z-0.0033 N85900 X0.8289 Z0.0000 N85910 Y1.0278 N85920 X0.8311 Z-0.0033 N85930 X0.8630 Z-0.0586 N85940 X0.8641 Z-0.0600 N85950 X0.9532 N85960 X0.9543 Z-0.0585 N85970 X0.9873 Z-0.0013 N85980 X0.9884 Z0.0000 N85990 Y1.0228 N86000 X0.9873 Z-0.0013 N86010 X0.9543 Z-0.0585 N86020 X0.9532 Z-0.0600 N86030 X0.8641 N86040 X0.8630 Z-0.0586 N86050 X0.8311 Z-0.0033 N86060 X0.8289 Z0.0000 N86070 Y1.0178 N86080 X0.8311 Z-0.0033 N86090 X0.8630 Z-0.0586 N86100 X0.8641 Z-0.0600 N86110 X0.9532 N86120 X0.9543 Z-0.0585 N86130 X0.9873 Z-0.0013 N86140 X0.9884 Z0.0000 N86150 Y1.0128 N86160 X0.9873 Z-0.0013 N86170 X0.9543 Z-0.0585 N86180 X0.9532 Z-0.0600 N86190 X0.8641 N86200 X0.8630 Z-0.0586 N86210 X0.8311 Z-0.0033 N86220 X0.8289 Z0.0000 N86230 Y1.0078 N86240 X0.8311 Z-0.0033 N86250 X0.8630 Z-0.0586 N86260 X0.8641 Z-0.0600 N86270 X0.9532 N86280 X0.9543 Z-0.0585 N86290 X0.9873 Z-0.0013 N86300 X0.9884 Z0.0000 N86310 Y1.0028 N86320 X0.9873 Z-0.0013 N86330 X0.9543 Z-0.0585 N86340 X0.9532 Z-0.0600 N86350 X0.8641 N86360 X0.8630 Z-0.0586 N86370 X0.8311 Z-0.0033 N86380 X0.8289 Z0.0000 N86390 Y0.9978 N86400 X0.8311 Z-0.0033 N86410 X0.8630 Z-0.0586 N86420 X0.8641 Z-0.0600 N86430 X0.9532 N86440 X0.9543 Z-0.0585 N86450 X0.9873 Z-0.0013 N86460 X0.9884 Z0.0000 N86470 Y0.9928 N86480 X0.9873 Z-0.0013 N86490 X0.9543 Z-0.0585 N86500 X0.9532 Z-0.0600 N86510 X0.8641 N86520 X0.8630 Z-0.0586 N86530 X0.8311 Z-0.0033 N86540 X0.8289 Z0.0000 N86550 X0.8289 Y0.9878 N86560 X0.8311 Z-0.0033 N86570 X0.8630 Z-0.0586 N86580 X0.8641 Z-0.0600 N86590 X0.9532 N86600 X0.9543 Z-0.0585 N86610 X0.9873 Z-0.0013 N86620 X0.9884 Z0.0000 N86630 Y0.9828 N86640 X0.9873 Z-0.0013 N86650 X0.9543 Z-0.0585 N86660 X0.9532 Z-0.0600 N86670 X0.8640 N86680 X0.8629 Z-0.0586 N86690 X0.8310 Z-0.0033 N86700 X0.8299 Z-0.0015 N86710 X0.8288 Z0.0000 N86720 X0.8287 Y0.9778 Z-0.0000 N86730 X0.8298 Z-0.0013 N86740 X0.8637 Z-0.0599 N86750 X0.8648 Z-0.0600 N86760 X0.9523 N86770 X0.9534 Z-0.0599 N86780 X0.9873 Z-0.0013 N86790 X0.9884 Z0.0000 N86800 Y0.9728 N86810 X0.9873 Z-0.0013 N86820 X0.9534 Z-0.0600 N86830 X0.9468 Z-0.0600 N86840 X0.8647 N86850 X0.8636 Z-0.0598 N86860 X0.8297 Z-0.0012 N86870 X0.8286 Z-0.0002 N86880 X0.8284 Y0.9688 Z-0.0005 N86890 X0.8284 Y0.9678 Z-0.0005 N86900 X0.8295 Z-0.0011 N86910 X0.8635 Z-0.0598 N86920 X0.8646 Z-0.0600 N86930 X0.9534 N86940 X0.9873 Z-0.0013 N86950 X0.9884 Z0.0000 N86960 Y0.9628 N86970 X0.9873 Z-0.0013 N86980 X0.9544 Z-0.0583 N86990 X0.9533 Z-0.0600 N87000 X0.8644 N87010 X0.8633 Z-0.0600 N87020 X0.8293 Z-0.0010 N87030 X0.8282 Z0.0000 N87040 X0.8279 Y0.9578 N87050 X0.8290 Z-0.0015 N87060 X0.8620 Z-0.0585 N87070 X0.8631 Z-0.0600 N87080 X0.9532 N87090 X0.9543 Z-0.0584 N87100 X0.9873 Z-0.0013 N87110 X0.9884 Z0.0000 N87120 Y0.9528 N87130 X0.9873 Z-0.0013 N87140 X0.9534 Z-0.0600 N87150 X0.8636 Z-0.0600 N87160 X0.8625 Z-0.0596 N87170 X0.8286 Z-0.0012 N87180 X0.8275 Z-0.0002 N87190 X0.8274 Y0.9511 Z-0.0005 N87200 X0.8273 Y0.9503 Z-0.0005 N87210 X0.8271 Y0.9479 Z0.0000 N87220 X0.8282 Z-0.0010 N87230 X0.8622 Z-0.0599 N87240 X0.8633 Z-0.0600 N87250 X0.9533 N87260 X0.9544 Z-0.0583 N87270 X0.9873 Z-0.0013 N87280 X0.9884 Z0.0000 N87290 Y0.9429 N87300 X0.9873 Z-0.0013 N87310 X0.9543 Z-0.0585 N87320 X0.9532 Z-0.0600 N87330 X0.8618 N87340 X0.8596 Z-0.0563 N87350 X0.8288 Z-0.0032 N87360 X0.8277 Z-0.0015 N87370 X0.8266 Z0.0000 N87380 X0.8265 Y0.9419 Z-0.0000 N87390 X0.8262 Y0.9399 Z-0.0005 N87400 X0.8261 Y0.9389 Z-0.0003 N87410 X0.8260 Y0.9379 Z-0.0000 N87420 X0.8271 Z-0.0010 N87430 X0.8611 Z-0.0597 N87440 X0.8622 Z-0.0600 N87450 X0.9533 N87460 X0.9544 Z-0.0583 N87470 X0.9873 Z-0.0013 N87480 X0.9884 Z0.0000 N87490 Y0.9329 N87500 X0.9873 Z-0.0013 N87510 X0.9534 Z-0.0599 N87520 X0.9523 Z-0.0600 N87530 X0.8615 N87540 X0.8604 Z-0.0593 N87550 X0.8276 Z-0.0030 N87560 X0.8265 Z-0.0012 N87570 X0.8254 Z0.0000 N87580 X0.8251 Y0.9311 Z-0.0005 N87590 X0.8250 Y0.9302 Z-0.0003 N87600 X0.8249 Y0.9293 Z-0.0000 N87610 X0.8247 Y0.9279 Z0.0000 N87620 X0.8258 Z-0.0013 N87630 X0.8599 Z-0.0598 N87640 X0.8610 Z-0.0600 N87650 X0.9533 N87660 X0.9544 Z-0.0584 N87670 X0.9873 Z-0.0013 N87680 X0.9884 Z0.0000 N87690 Y0.9229 N87700 X0.9873 Z-0.0013 N87710 X0.9544 Z-0.0582 N87720 X0.9533 Z-0.0600 N87730 X0.8601 N87740 X0.8590 Z-0.0591 N87750 X0.8338 Z-0.0159 N87760 X0.8250 Z-0.0009 N87770 X0.8239 Z-0.0003 N87780 X0.8238 Y0.9220 Z0.0000 N87790 X0.8232 Y0.9186 N87800 X0.8231 Y0.9179 Z-0.0003 N87810 X0.8242 Z-0.0012 N87820 X0.8581 Z-0.0590 N87830 X0.8592 Z-0.0600 N87840 X0.9523 N87850 X0.9534 Z-0.0600 N87860 X0.9873 Z-0.0013 N87870 X0.9884 Z0.0000 N87880 Y0.9129 N87890 X0.9873 Z-0.0013 N87900 X0.9534 Z-0.0599 N87910 X0.9523 Z-0.0600 N87920 X0.8582 N87930 X0.8571 Z-0.0587 N87940 X0.8243 Z-0.0030 N87950 X0.8232 Z-0.0013 N87960 X0.8221 Z-0.0002 N87970 X0.8219 Y0.9119 Z-0.0002 N87980 X0.8217 Y0.9109 Z-0.0003 N87990 X0.8215 Y0.9099 Z0.0000 N88000 X0.8211 Y0.9079 N88010 X0.8222 Z-0.0015 N88020 X0.8233 Z-0.0032 N88030 X0.8563 Z-0.0592 N88040 X0.8574 Z-0.0600 N88050 X0.9532 N88060 X0.9543 Z-0.0585 N88070 X0.9873 Z-0.0013 N88080 X0.9884 Z0.0000 N88090 Y0.9029 N88100 X0.9873 Z-0.0013 N88110 X0.9543 Z-0.0585 N88120 X0.9532 Z-0.0600 N88130 X0.8563 N88140 X0.8552 Z-0.0589 N88150 X0.8277 Z-0.0123 N88160 X0.8222 Z-0.0030 N88170 X0.8200 Z-0.0000 N88180 X0.8198 Y0.9021 N88190 X0.8196 Y0.9013 Z-0.0005 N88200 X0.8192 Y0.8997 Z0.0000 N88210 X0.8188 Y0.8979 N88220 X0.8199 Z-0.0012 N88230 X0.8396 Z-0.0343 N88240 X0.8538 Z-0.0582 N88250 X0.8549 Z-0.0600 N88260 X0.9523 N88270 X0.9534 Z-0.0599 N88280 X0.9873 Z-0.0013 N88290 X0.9884 Z0.0000 N88300 Y0.8929 N88310 X0.9873 Z-0.0013 N88320 X0.9545 Z-0.0581 N88330 X0.9534 Z-0.0600 N88340 X0.8548 N88350 X0.8537 Z-0.0599 N88360 X0.8186 Z-0.0010 N88370 X0.8175 Z-0.0005 N88380 X0.8172 Y0.8919 Z-0.0002 N88390 X0.8170 Y0.8909 Z0.0000 N88400 X0.8167 Y0.8899 N88410 X0.8164 Y0.8889 Z-0.0002 N88420 X0.8161 Y0.8879 Z-0.0001 N88430 X0.8172 Z-0.0008 N88440 X0.8348 Z-0.0301 N88450 X0.8523 Z-0.0597 N88460 X0.8534 Z-0.0600 N88470 X0.9533 N88480 X0.9544 Z-0.0583 N88490 X0.9873 Z-0.0013 N88500 X0.9884 Z0.0000 N88510 Y0.8829 N88520 X0.9873 Z-0.0013 N88530 X0.9543 Z-0.0585 N88540 X0.9532 Z-0.0600 N88550 X0.8520 N88560 X0.8509 Z-0.0597 N88570 X0.8278 Z-0.0212 N88580 X0.8168 Z-0.0030 N88590 X0.8157 Z-0.0016 N88600 X0.8146 Z0.0000 N88610 X0.8143 Y0.8820 Z-0.0004 N88620 X0.8140 Y0.8810 Z-0.0003 N88630 X0.8137 Y0.8801 Z0.0000 N88640 X0.8135 Y0.8794 N88650 X0.8132 Y0.8787 Z-0.0003 N88660 X0.8130 Y0.8779 N88670 X0.8141 Z-0.0009 N88680 X0.8459 Z-0.0533 N88690 X0.8492 Z-0.0588 N88700 X0.8503 Z-0.0600 N88710 X0.9533 N88720 X0.9621 Z-0.0449 N88730 X0.9873 Z-0.0013 N88740 X0.9884 Z0.0000 N88750 Y0.8729 N88760 X0.9873 Z-0.0013 N88770 X0.9543 Z-0.0585 N88780 X0.9532 Z-0.0600 N88790 X0.8487 N88800 X0.8476 Z-0.0591 N88810 X0.8289 Z-0.0282 N88820 X0.8135 Z-0.0029 N88830 X0.8124 Z-0.0016 N88840 X0.8113 Z0.0000 N88850 X0.8109 Y0.8719 Z-0.0005 N88860 X0.8105 Y0.8709 Z0.0000 N88870 X0.8094 Y0.8679 N88880 X0.8105 Z-0.0007 N88890 X0.8336 Z-0.0383 N88900 X0.8457 Z-0.0582 N88910 X0.8468 Z-0.0600 N88920 X0.9533 N88930 X0.9544 Z-0.0583 N88940 X0.9873 Z-0.0013 N88950 X0.9884 Z0.0000 N88960 Y0.8629 N88970 X0.9873 Z-0.0013 N88980 X0.9544 Z-0.0582 N88990 X0.9533 Z-0.0600 N89000 X0.8459 N89010 X0.8448 Z-0.0596 N89020 X0.8217 Z-0.0222 N89030 X0.8086 Z-0.0011 N89040 X0.8075 Z-0.0005 N89050 X0.8074 Y0.8628 Z-0.0003 N89060 X0.8070 Y0.8618 Z0.0000 N89070 X0.8066 Y0.8609 Z-0.0003 N89080 X0.8062 Y0.8599 Z0.0000 N89090 X0.8057 Y0.8589 Z-0.0001 N89100 X0.8053 Y0.8580 N89110 X0.8064 Z-0.0007 N89120 X0.8218 Z-0.0251 N89130 X0.8393 Z-0.0534 N89140 X0.8426 Z-0.0588 N89150 X0.8437 Z-0.0600 N89160 X0.9533 N89170 X0.9621 Z-0.0449 N89180 X0.9873 Z-0.0013 N89190 X0.9884 Z0.0000 N89200 Y0.8530 N89210 X0.9873 Z-0.0013 N89220 X0.9544 Z-0.0582 N89230 X0.9533 Z-0.0600 N89240 X0.8415 N89250 X0.8404 Z-0.0585 N89260 X0.8261 Z-0.0357 N89270 X0.8097 Z-0.0096 N89280 X0.8042 Z-0.0010 N89290 X0.8031 Z-0.0005 N89300 X0.8027 Y0.8521 Z0.0000 N89310 X0.8023 Y0.8512 Z-0.0003 N89320 X0.8019 Y0.8504 Z-0.0003 N89330 X0.8015 Y0.8496 Z0.0000 N89340 X0.8011 Y0.8488 Z-0.0004 N89350 X0.8007 Y0.8480 Z0.0000 N89360 X0.8018 Z-0.0005 N89370 X0.8149 Z-0.0212 N89380 X0.8314 Z-0.0473 N89390 X0.8391 Z-0.0596 N89400 X0.8402 Z-0.0600 N89410 X0.9533 N89420 X0.9544 Z-0.0583 N89430 X0.9873 Z-0.0013 N89440 X0.9884 Z0.0000 N89450 Y0.8430 N89460 X0.9873 Z-0.0013 N89470 X0.9543 Z-0.0585 N89480 X0.9532 Z-0.0600 N89490 X0.8377 N89500 X0.8366 Z-0.0595 N89510 X0.8201 Z-0.0335 N89520 X0.8014 Z-0.0045 N89530 X0.8003 Z-0.0028 N89540 X0.7992 Z-0.0013 N89550 X0.7981 Z0.0000 N89560 X0.7976 Y0.8420 Z-0.0005 N89570 X0.7971 Y0.8411 Z0.0000 N89580 X0.7966 Y0.8402 Z-0.0004 N89590 X0.7962 Y0.8394 Z0.0000 N89600 X0.7958 Y0.8387 N89610 X0.7953 Y0.8380 Z-0.0003 N89620 X0.7964 Z-0.0005 N89630 X0.8052 Z-0.0138 N89640 X0.8195 Z-0.0358 N89650 X0.8326 Z-0.0563 N89660 X0.8348 Z-0.0597 N89670 X0.8359 Z-0.0600 N89680 X0.9533 N89690 X0.9555 Z-0.0563 N89700 X0.9873 Z-0.0013 N89710 X0.9884 Z0.0000 N89720 Y0.8330 N89730 X0.9873 Z-0.0013 N89740 X0.9543 Z-0.0585 N89750 X0.9532 Z-0.0600 N89760 X0.8332 N89770 X0.8321 Z-0.0598 N89780 X0.8178 Z-0.0377 N89790 X0.8056 Z-0.0192 N89800 X0.7946 Z-0.0027 N89810 X0.7924 Z0.0000 N89820 X0.7919 Y0.8321 Z-0.0002 N89830 X0.7909 Y0.8305 Z-0.0002 N89840 X0.7904 Y0.8296 Z0.0000 N89850 X0.7898 Y0.8288 Z-0.0004 N89860 X0.7893 Y0.8280 Z-0.0000 N89870 X0.7904 Z-0.0011 N89880 X0.7915 Z-0.0025 N89890 X0.8047 Z-0.0219 N89900 X0.8201 Z-0.0451 N89910 X0.8289 Z-0.0585 N89920 X0.8300 Z-0.0600 N89930 X0.9532 N89940 X0.9543 Z-0.0585 N89950 X0.9873 Z-0.0013 N89960 X0.9884 Z0.0000 N89970 Y0.8230 N89980 X0.9873 Z-0.0013 N89990 X0.9543 Z-0.0585 N90000 X0.9532 Z-0.0600 N90010 X0.8278 N90020 X0.8267 Z-0.0596 N90030 X0.8102 Z-0.0348 N90040 X0.7981 Z-0.0169 N90050 X0.7882 Z-0.0026 N90060 X0.7871 Z-0.0011 N90070 X0.7860 Z0.0000 N90080 X0.7854 Y0.8221 Z-0.0003 N90090 X0.7848 Y0.8213 Z-0.0001 N90100 X0.7836 Y0.8196 Z0.0000 N90110 X0.7830 Y0.8188 N90120 X0.7824 Y0.8180 Z-0.0004 N90130 X0.7835 Z-0.0013 N90140 X0.7846 Z-0.0021 N90150 X0.7955 Z-0.0176 N90160 X0.8098 Z-0.0382 N90170 X0.8219 Z-0.0560 N90180 X0.8240 Z-0.0593 N90190 X0.8251 Z-0.0600 N90200 X0.9534 N90210 X0.9873 Z-0.0013 N90220 X0.9884 Z0.0000 N90230 Y0.8130 N90240 X0.9873 Z-0.0013 N90250 X0.9544 Z-0.0584 N90260 X0.9533 Z-0.0600 N90270 X0.8215 N90280 X0.8083 Z-0.0408 N90290 X0.7973 Z-0.0250 N90300 X0.7863 Z-0.0096 N90310 X0.7797 Z-0.0004 N90320 X0.7786 Z0.0000 N90330 X0.7780 Y0.8123 Z-0.0001 N90340 X0.7774 Y0.8115 Z0.0000 N90350 X0.7762 Y0.8100 N90360 X0.7757 Y0.8094 Z-0.0003 N90370 X0.7751 Y0.8087 Z0.0000 N90380 X0.7745 Y0.8080 Z-0.0006 N90390 X0.7756 Z-0.0011 N90400 X0.7767 Z-0.0019 N90410 X0.7866 Z-0.0152 N90420 X0.7997 Z-0.0335 N90430 X0.8107 Z-0.0491 N90440 X0.8173 Z-0.0586 N90450 X0.8184 Z-0.0600 N90460 X0.9533 N90470 X0.9555 Z-0.0563 N90480 X0.9873 Z-0.0013 N90490 X0.9884 Z0.0000 N90500 Y0.8030 N90510 X0.9873 Z-0.0013 N90520 X0.9544 Z-0.0582 N90530 X0.9533 Z-0.0600 N90540 X0.8151 N90550 X0.8140 Z-0.0586 N90560 X0.8042 Z-0.0448 N90570 X0.7921 Z-0.0281 N90580 X0.7833 Z-0.0164 N90590 X0.7724 Z-0.0020 N90600 X0.7713 Z-0.0008 N90610 X0.7702 Z0.0000 N90620 X0.7695 Y0.8023 N90630 X0.7689 Y0.8017 Z-0.0003 N90640 X0.7683 Y0.8010 Z0.0000 N90650 X0.7676 Y0.8002 N90660 X0.7669 Y0.7995 Z-0.0001 N90670 X0.7662 Y0.7988 Z0.0000 N90680 X0.7655 Y0.7980 Z-0.0001 N90690 X0.7666 Z-0.0009 N90700 X0.7677 Z-0.0019 N90710 X0.7765 Z-0.0131 N90720 X0.7885 Z-0.0290 N90730 X0.7995 Z-0.0438 N90740 X0.8105 Z-0.0591 N90750 X0.8116 Z-0.0600 N90760 X0.9533 N90770 X0.9544 Z-0.0583 N90780 X0.9873 Z-0.0013 N90790 X0.9884 Z0.0000 N90800 Y0.7930 N90810 X0.9873 Z-0.0013 N90820 X0.9543 Z-0.0585 N90830 X0.9532 Z-0.0600 N90840 X0.8078 N90850 X0.8067 Z-0.0590 N90860 X0.7957 Z-0.0442 N90870 X0.7836 Z-0.0283 N90880 X0.7748 Z-0.0170 N90890 X0.7649 Z-0.0047 N90900 X0.7616 Z-0.0007 N90910 X0.7605 Z0.0000 N90920 X0.7598 Y0.7924 N90930 X0.7591 Y0.7918 Z-0.0002 N90940 X0.7585 Y0.7911 Z0.0000 N90950 X0.7578 Y0.7905 Z-0.0001 N90960 X0.7571 Y0.7899 Z0.0000 N90970 X0.7557 Y0.7886 N90980 X0.7549 Y0.7880 Z-0.0001 N90990 X0.7560 Z-0.0012 N91000 X0.7571 Z-0.0018 N91010 X0.7582 Z-0.0029 N91020 X0.7659 Z-0.0119 N91030 X0.7747 Z-0.0226 N91040 X0.7845 Z-0.0350 N91050 X0.7944 Z-0.0478 N91060 X0.8032 Z-0.0594 N91070 X0.8043 Z-0.0600 N91080 X0.9534 N91090 X0.9873 Z-0.0013 N91100 X0.9884 Z0.0000 N91110 Y0.7830 N91120 X0.9873 Z-0.0013 N91130 X0.9544 Z-0.0584 N91140 X0.9533 Z-0.0600 N91150 X0.8005 N91160 X0.7995 Z-0.0597 N91170 X0.7896 Z-0.0469 N91180 X0.7775 Z-0.0317 N91190 X0.7687 Z-0.0211 N91200 X0.7599 Z-0.0108 N91210 X0.7511 Z-0.0010 N91220 X0.7500 Z-0.0000 N91230 X0.7489 Z-0.0000 N91240 X0.7482 Y0.7825 Z-0.0001 N91250 X0.7475 Y0.7819 Z-0.0001 N91260 X0.7461 Y0.7808 Z-0.0002 N91270 X0.7453 Y0.7802 Z0.0000 N91280 X0.7446 Y0.7796 Z-0.0002 N91290 X0.7440 Y0.7791 Z0.0000 N91300 X0.7426 Y0.7780 Z-0.0002 N91310 X0.7448 Z-0.0016 N91320 X0.7459 Z-0.0026 N91330 X0.7568 Z-0.0145 N91340 X0.7656 Z-0.0244 N91350 X0.7733 Z-0.0333 N91360 X0.7821 Z-0.0440 N91370 X0.7931 Z-0.0577 N91380 X0.7941 Z-0.0591 N91390 X0.7952 Z-0.0600 N91400 X0.9533 N91410 X0.9544 Z-0.0583 N91420 X0.9873 Z-0.0013 N91430 X0.9884 Z0.0000 N91440 Y0.7730 N91450 X0.9873 Z-0.0013 N91460 X0.9544 Z-0.0583 N91470 X0.9533 Z-0.0600 N91480 X0.7907 N91490 X0.7896 Z-0.0589 N91500 X0.7808 Z-0.0481 N91510 X0.7720 Z-0.0378 N91520 X0.7632 Z-0.0278 N91530 X0.7523 Z-0.0159 N91540 X0.7435 Z-0.0066 N91550 X0.7380 Z-0.0010 N91560 X0.7369 Z-0.0003 N91570 X0.7358 Z-0.0002 N91580 X0.7350 Y0.7725 Z-0.0000 N91590 X0.7342 Y0.7719 Z-0.0002 N91600 X0.7334 Y0.7714 Z0.0000 N91610 X0.7326 Y0.7708 Z-0.0002 N91620 X0.7318 Y0.7703 Z0.0000 N91630 X0.7310 Y0.7697 Z-0.0003 N91640 X0.7301 Y0.7692 Z0.0000 N91650 X0.7293 Y0.7686 Z-0.0003 N91660 X0.7284 Y0.7681 Z0.0000 N91670 X0.7306 Z-0.0020 N91680 X0.7317 Z-0.0024 N91690 X0.7394 Z-0.0099 N91700 X0.7493 Z-0.0200 N91710 X0.7592 Z-0.0305 N91720 X0.7690 Z-0.0414 N91730 X0.7778 Z-0.0514 N91740 X0.7844 Z-0.0591 N91750 X0.7855 Z-0.0600 N91760 X0.9533 N91770 X0.9555 Z-0.0563 N91780 X0.9873 Z-0.0013 N91790 X0.9884 Z0.0000 N91800 Y0.7631 N91810 X0.9873 Z-0.0013 N91820 X0.9544 Z-0.0583 N91830 X0.9533 Z-0.0600 N91840 X0.7809 N91850 X0.7798 Z-0.0597 N91860 X0.7710 Z-0.0498 N91870 X0.7590 Z-0.0367 N91880 X0.7502 Z-0.0275 N91890 X0.7414 Z-0.0186 N91900 X0.7337 Z-0.0111 N91910 X0.7260 Z-0.0039 N91920 X0.7227 Z-0.0009 N91930 X0.7216 Z-0.0006 N91940 X0.7205 Z-0.0004 N91950 X0.7196 Y0.7625 Z0.0000 N91960 X0.7187 Y0.7620 Z-0.0003 N91970 X0.7178 Y0.7615 Z0.0000 N91980 X0.7169 Y0.7609 Z-0.0002 N91990 X0.7160 Y0.7604 Z-0.0002 N92000 X0.7152 Y0.7599 Z0.0000 N92010 X0.7136 Y0.7590 N92020 X0.7127 Y0.7585 Z-0.0004 N92030 X0.7119 Y0.7581 Z0.0000 N92040 X0.7130 Z-0.0007 N92050 X0.7141 Z-0.0017 N92060 X0.7152 Z-0.0021 N92070 X0.7240 Z-0.0098 N92080 X0.7327 Z-0.0178 N92090 X0.7415 Z-0.0262 N92100 X0.7503 Z-0.0350 N92110 X0.7591 Z-0.0441 N92120 X0.7712 Z-0.0571 N92130 X0.7733 Z-0.0595 N92140 X0.7744 Z-0.0600 N92150 X0.9533 N92160 X0.9544 Z-0.0583 N92170 X0.9873 Z-0.0013 N92180 X0.9884 Z0.0000 N92190 Y0.7531 N92200 X0.9873 Z-0.0013 N92210 X0.9543 Z-0.0585 N92220 X0.9532 Z-0.0600 N92230 X0.7683 N92240 X0.7672 Z-0.0597 N92250 X0.7584 Z-0.0504 N92260 X0.7485 Z-0.0403 N92270 X0.7408 Z-0.0327 N92280 X0.7320 Z-0.0244 N92290 X0.7243 Z-0.0175 N92300 X0.7166 Z-0.0108 N92310 X0.7078 Z-0.0035 N92320 X0.7045 Z-0.0009 N92330 X0.7034 Z-0.0006 N92340 X0.7023 Z-0.0003 N92350 X0.7014 Y0.7526 Z0.0000 N92360 X0.7005 Y0.7522 Z-0.0000 N92370 X0.6996 Y0.7518 Z-0.0004 N92380 X0.6988 Y0.7514 Z0.0000 N92390 X0.6979 Y0.7509 Z-0.0004 N92400 X0.6970 Y0.7505 Z0.0000 N92410 X0.6961 Y0.7501 N92420 X0.6952 Y0.7497 Z-0.0006 N92430 X0.6943 Y0.7493 Z0.0000 N92440 X0.6915 Y0.7481 N92450 X0.6926 Z-0.0000 N92460 X0.7003 Z-0.0056 N92470 X0.7080 Z-0.0114 N92480 X0.7179 Z-0.0195 N92490 X0.7256 Z-0.0261 N92500 X0.7333 Z-0.0329 N92510 X0.7421 Z-0.0412 N92520 X0.7509 Z-0.0497 N92530 X0.7608 Z-0.0598 N92540 X0.7619 Z-0.0600 N92550 X0.9532 N92560 X0.9543 Z-0.0584 N92570 X0.9873 Z-0.0013 N92580 X0.9884 Z0.0000 N92590 Y0.7431 N92600 X0.9873 Z-0.0013 N92610 X0.9543 Z-0.0585 N92620 X0.9532 Z-0.0600 N92630 X0.7551 N92640 X0.7540 Z-0.0600 N92650 X0.7452 Z-0.0515 N92660 X0.7364 Z-0.0432 N92670 X0.7265 Z-0.0344 N92680 X0.7188 Z-0.0278 N92690 X0.7100 Z-0.0207 N92700 X0.7023 Z-0.0148 N92710 X0.6945 Z-0.0093 N92720 X0.6857 Z-0.0034 N92730 X0.6824 Z-0.0013 N92740 X0.6813 Z-0.0008 N92750 X0.6802 N92760 X0.6791 Z-0.0003 N92770 X0.6782 Y0.7427 Z0.0000 N92780 X0.6772 Y0.7424 N92790 X0.6762 Y0.7420 Z-0.0002 N92800 X0.6743 Y0.7414 Z0.0000 N92810 X0.6734 Y0.7410 Z-0.0004 N92820 X0.6724 Y0.7407 Z-0.0001 N92830 X0.6715 Y0.7404 Z0.0000 N92840 X0.6706 Y0.7401 Z-0.0000 N92850 X0.6696 Y0.7398 Z-0.0001 N92860 X0.6678 Y0.7392 Z0.0000 N92870 X0.6669 Y0.7389 Z-0.0002 N92880 X0.6660 Y0.7386 Z-0.0002 N92890 X0.6651 Y0.7384 Z0.0000 N92900 X0.6642 Y0.7381 N92910 X0.6664 Z-0.0004 N92920 X0.6719 Z-0.0033 N92930 X0.6785 Z-0.0070 N92940 X0.6851 Z-0.0110 N92950 X0.6939 Z-0.0167 N92960 X0.7016 Z-0.0220 N92970 X0.7104 Z-0.0285 N92980 X0.7181 Z-0.0346 N92990 X0.7258 Z-0.0409 N93000 X0.7345 Z-0.0486 N93010 X0.7433 Z-0.0566 N93020 X0.7466 Z-0.0597 N93030 X0.7477 Z-0.0600 N93040 X0.9533 N93050 X0.9544 Z-0.0584 N93060 X0.9873 Z-0.0013 N93070 X0.9884 Z0.0000 N93080 Y0.7331 N93090 X0.9873 Z-0.0013 N93100 X0.9543 Z-0.0585 N93110 X0.9532 Z-0.0600 N93120 X0.7386 N93130 X0.7298 Z-0.0523 N93140 X0.7221 Z-0.0458 N93150 X0.7144 Z-0.0397 N93160 X0.7067 Z-0.0338 N93170 X0.6990 Z-0.0283 N93180 X0.6902 Z-0.0223 N93190 X0.6836 Z-0.0182 N93200 X0.6758 Z-0.0137 N93210 X0.6692 Z-0.0101 N93220 X0.6626 Z-0.0068 N93230 X0.6571 Z-0.0042 N93240 X0.6505 Z-0.0014 N93250 X0.6494 Z-0.0010 N93260 X0.6472 Z-0.0009 N93270 X0.6450 Z-0.0002 N93280 X0.6440 Y0.7329 Z0.0000 N93290 X0.6418 Y0.7324 N93300 X0.6408 Y0.7322 Z-0.0004 N93310 X0.6397 Y0.7320 Z-0.0001 N93320 X0.6386 Y0.7318 Z0.0000 N93330 X0.6366 Y0.7314 N93340 X0.6357 Y0.7312 Z-0.0002 N93350 X0.6347 Y0.7310 Z-0.0006 N93360 X0.6337 Y0.7308 Z-0.0003 N93370 X0.6326 Y0.7307 Z0.0000 N93380 X0.6296 Y0.7302 N93390 X0.6286 Y0.7300 Z-0.0004 N93400 X0.6276 Y0.7299 Z-0.0003 N93410 X0.6265 Y0.7297 Z-0.0000 N93420 X0.6225 Y0.7291 Z0.0000 N93430 X0.6215 Y0.7290 Z-0.0002 N93440 X0.6204 Y0.7289 Z-0.0005 N93450 X0.6194 Y0.7288 Z-0.0004 N93460 X0.6173 Y0.7285 Z0.0000 N93470 X0.6136 Y0.7281 N93480 X0.6169 N93490 X0.6224 Z-0.0011 N93500 X0.6301 Z-0.0031 N93510 X0.6356 Z-0.0047 N93520 X0.6433 Z-0.0072 N93530 X0.6488 Z-0.0092 N93540 X0.6543 Z-0.0114 N93550 X0.6609 Z-0.0143 N93560 X0.6675 Z-0.0174 N93570 X0.6741 Z-0.0208 N93580 X0.6807 Z-0.0244 N93590 X0.6873 Z-0.0283 N93600 X0.6939 Z-0.0325 N93610 X0.7016 Z-0.0376 N93620 X0.7093 Z-0.0432 N93630 X0.7170 Z-0.0489 N93640 X0.7268 Z-0.0569 N93650 X0.7301 Z-0.0597 N93660 X0.7312 Z-0.0600 N93670 X0.9533 N93680 X0.9544 Z-0.0584 N93690 X0.9873 Z-0.0013 N93700 X0.9884 Z0.0000 N93710 G00 Z0.1000 N93720 G00 X1.3165 Y0.2786 N93730 G01 Z0.0000 F20.0 N93740 G01 X1.3176 Z-0.0009 F60.0 N93750 X1.3198 Z-0.0043 N93760 X1.3242 Z-0.0114 N93770 X1.3374 Z-0.0340 N93780 X1.3517 Z-0.0587 N93790 X1.3528 Z-0.0600 N93800 X1.7554 N93810 X1.7565 Z-0.0599 N93820 X1.8005 Z-0.0017 N93830 X1.8016 Z-0.0005 N93840 X1.8027 Z-0.0001 N93850 X1.8020 Y0.2794 Z0.0000 N93860 X1.8013 Y0.2803 Z-0.0000 N93870 X1.8006 Y0.2811 Z-0.0003 N93880 X1.7998 Y0.2819 Z-0.0000 N93890 X1.7991 Y0.2828 Z-0.0005 N93900 X1.7984 Y0.2836 Z-0.0000 N93910 X1.7973 Z-0.0007 N93920 X1.7533 Z-0.0590 N93930 X1.7522 Z-0.0600 N93940 X1.3527 N93950 X1.3516 Z-0.0597 N93960 X1.3417 Z-0.0431 N93970 X1.3351 Z-0.0323 N93980 X1.3153 Z-0.0011 N93990 X1.3142 Z-0.0004 N94000 X1.3137 Y0.2846 Z0.0000 N94010 X1.3132 Y0.2856 Z-0.0003 N94020 X1.3128 Y0.2866 Z-0.0000 N94030 X1.3119 Y0.2886 Z-0.0002 N94040 X1.3130 Z-0.0006 N94050 X1.3427 Z-0.0474 N94060 X1.3504 Z-0.0597 N94070 X1.3515 Z-0.0600 N94080 X1.7480 N94090 X1.7502 Z-0.0572 N94100 X1.7931 Z-0.0004 N94110 X1.7942 Z0.0000 N94120 X1.7935 Y0.2894 Z-0.0004 N94130 X1.7928 Y0.2902 Z-0.0003 N94140 X1.7921 Y0.2911 Z0.0000 N94150 X1.7914 Y0.2919 N94160 X1.7907 Y0.2927 Z-0.0001 N94170 X1.7900 Y0.2936 Z0.0000 N94180 X1.7889 Z-0.0012 N94190 X1.7878 Z-0.0022 N94200 X1.7449 Z-0.0589 N94210 X1.7438 Z-0.0600 N94220 X1.3491 N94230 X1.3480 Z-0.0596 N94240 X1.3106 Z-0.0009 N94250 X1.3095 Z-0.0002 N94260 X1.3091 Y0.2946 Z0.0000 N94270 X1.3086 Y0.2956 Z-0.0006 N94280 X1.3082 Y0.2966 Z0.0000 N94290 X1.3077 Y0.2976 Z-0.0004 N94300 X1.3072 Y0.2986 Z0.0000 N94310 X1.3083 Z-0.0007 N94320 X1.3457 Z-0.0596 N94330 X1.3468 Z-0.0600 N94340 X1.7396 N94350 X1.7407 Z-0.0590 N94360 X1.7836 Z-0.0023 N94370 X1.7847 Z-0.0010 N94380 X1.7858 Z0.0000 N94390 X1.7851 Y0.2994 Z-0.0004 N94400 X1.7844 Y0.3002 Z0.0000 N94410 X1.7837 Y0.3011 N94420 X1.7830 Y0.3019 Z-0.0002 N94430 X1.7823 Y0.3027 Z-0.0002 N94440 X1.7816 Y0.3036 Z-0.0004 N94450 X1.7805 Z-0.0013 N94460 X1.7794 Z-0.0019 N94470 X1.7364 Z-0.0587 N94480 X1.7353 Z-0.0600 N94490 X1.3446 N94500 X1.3435 Z-0.0598 N94510 X1.3060 Z-0.0010 N94520 X1.3049 Z0.0000 N94530 X1.3040 Y0.3056 Z-0.0001 N94540 X1.3036 Y0.3066 Z0.0000 N94550 X1.3031 Y0.3076 Z-0.0006 N94560 X1.3026 Y0.3086 Z0.0000 N94570 X1.3037 Z-0.0012 N94580 X1.3411 Z-0.0598 N94590 X1.3422 Z-0.0600 N94600 X1.7312 N94610 X1.7762 Z-0.0005 N94620 X1.7773 Z-0.0001 N94630 X1.7766 Y0.3094 N94640 X1.7759 Y0.3102 Z-0.0003 N94650 X1.7752 Y0.3111 Z-0.0002 N94660 X1.7745 Y0.3119 Z0.0000 N94670 X1.7738 Y0.3127 Z-0.0001 N94680 X1.7731 Y0.3136 Z-0.0000 N94690 X1.7720 Z-0.0008 N94700 X1.7709 Z-0.0020 N94710 X1.7280 Z-0.0588 N94720 X1.7269 Z-0.0600 N94730 X1.3388 N94740 X1.3300 Z-0.0463 N94750 X1.3014 Z-0.0012 N94760 X1.3003 Z0.0000 N94770 X1.2999 Y0.3146 Z-0.0003 N94780 X1.2994 Y0.3156 Z0.0000 N94790 X1.2989 Y0.3166 Z-0.0002 N94800 X1.2980 Y0.3186 Z-0.0000 N94810 X1.2991 Z-0.0016 N94820 X1.3002 Z-0.0027 N94830 X1.3365 Z-0.0598 N94840 X1.3376 Z-0.0600 N94850 X1.7227 N94860 X1.7238 Z-0.0589 N94870 X1.7678 Z-0.0007 N94880 X1.7689 Z0.0000 N94890 X1.7682 Y0.3194 Z-0.0000 N94900 X1.7675 Y0.3202 Z-0.0003 N94910 X1.7668 Y0.3210 Z0.0000 N94920 X1.7647 Y0.3235 Z-0.0001 N94930 X1.7636 Z-0.0009 N94940 X1.7625 Z-0.0022 N94950 X1.7195 Z-0.0590 N94960 X1.7184 Z-0.0600 N94970 X1.3353 N94980 X1.3342 Z-0.0600 N94990 X1.2979 Z-0.0028 N95000 X1.2957 Z0.0000 N95010 X1.2953 Y0.3245 Z-0.0002 N95020 X1.2948 Y0.3255 Z0.0000 N95030 X1.2943 Y0.3265 Z-0.0004 N95040 X1.2939 Y0.3275 Z0.0000 N95050 X1.2934 Y0.3285 Z-0.0003 N95060 X1.2945 Z-0.0014 N95070 X1.2956 Z-0.0026 N95080 X1.3319 Z-0.0596 N95090 X1.3330 Z-0.0600 N95100 X1.7143 N95110 X1.7154 Z-0.0590 N95120 X1.7583 Z-0.0023 N95130 X1.7594 Z-0.0012 N95140 X1.7605 Z0.0000 N95150 X1.7591 Y0.3302 N95160 X1.7584 Y0.3310 Z-0.0002 N95170 X1.7569 Y0.3327 Z0.0000 N95180 X1.7562 Y0.3335 Z-0.0004 N95190 X1.7551 Z-0.0010 N95200 X1.7540 Z-0.0019 N95210 X1.7101 Z-0.0600 N95220 X1.5825 Z-0.0600 N95230 X1.4582 N95240 X1.3307 N95250 X1.3296 Z-0.0596 N95260 X1.2922 Z-0.0009 N95270 X1.2911 Z-0.0000 N95280 X1.2902 Y0.3355 Z0.0000 N95290 X1.2897 Y0.3365 Z-0.0002 N95300 X1.2893 Y0.3375 Z0.0000 N95310 X1.2888 Y0.3385 Z-0.0006 N95320 X1.2899 Z-0.0012 N95330 X1.2910 Z-0.0027 N95340 X1.3273 Z-0.0598 N95350 X1.3284 Z-0.0600 N95360 X1.7058 N95370 X1.7069 Z-0.0590 N95380 X1.7509 Z-0.0008 N95390 X1.7520 Z-0.0003 N95400 X1.7513 Y0.3394 Z0.0000 N95410 X1.7506 Y0.3402 Z-0.0003 N95420 X1.7499 Y0.3410 Z-0.0002 N95430 X1.7492 Y0.3419 Z0.0000 N95440 X1.7478 Y0.3435 N95450 X1.7467 Z-0.0002 N95460 X1.7016 Z-0.0600 N95470 X1.5926 Z-0.0600 N95480 X1.4704 N95490 X1.3426 N95500 X1.3261 N95510 X1.3250 Z-0.0595 N95520 X1.2876 Z-0.0007 N95530 X1.2865 Z-0.0003 N95540 X1.2860 Y0.3445 Z0.0000 N95550 X1.2856 Y0.3455 Z-0.0002 N95560 X1.2851 Y0.3465 Z0.0000 N95570 X1.2842 Y0.3485 Z-0.0001 N95580 X1.2853 Z-0.0009 N95590 X1.3183 Z-0.0528 N95600 X1.3227 Z-0.0597 N95610 X1.3238 Z-0.0600 N95620 X1.6974 N95630 X1.6985 Z-0.0590 N95640 X1.7403 Z-0.0038 N95650 X1.7425 Z-0.0009 N95660 X1.7436 Z0.0000 N95670 X1.7429 Y0.3493 N95680 X1.7422 Y0.3502 Z-0.0001 N95690 X1.7415 Y0.3510 Z0.0000 N95700 X1.7408 Y0.3518 Z-0.0001 N95710 X1.7394 Y0.3535 Z-0.0000 N95720 X1.7383 Z-0.0006 N95730 X1.6943 Z-0.0589 N95740 X1.6932 Z-0.0600 N95750 X1.3215 N95760 X1.3204 Z-0.0594 N95770 X1.2830 Z-0.0006 N95780 X1.2819 Z0.0000 N95790 X1.2814 Y0.3545 N95800 X1.2804 Y0.3546 N95810 X1.2784 Y0.3548 Z-0.0004 N95820 X1.2774 Y0.3549 Z-0.0004 N95830 X1.2764 Y0.3550 Z-0.0002 N95840 X1.2754 Y0.3551 Z-0.0002 N95850 X1.2744 Y0.3552 Z-0.0001 N95860 X1.2715 Y0.3555 Z0.0000 N95870 X1.2695 Y0.3557 N95880 X1.2686 Y0.3558 Z-0.0002 N95890 X1.2666 Y0.3560 Z-0.0006 N95900 X1.2647 Y0.3562 Z-0.0001 N95910 X1.2637 Y0.3563 Z0.0000 N95920 X1.2596 Y0.3568 N95930 X1.2586 Y0.3569 Z-0.0003 N95940 X1.2576 Y0.3571 Z-0.0004 N95950 X1.2566 Y0.3572 Z-0.0002 N95960 X1.2556 Y0.3573 N95970 X1.2546 Y0.3575 Z0.0000 N95980 X1.2517 Y0.3579 N95990 X1.2507 Y0.3580 Z-0.0001 N96000 X1.2498 Y0.3581 Z-0.0005 N96010 X1.2481 Y0.3584 Z-0.0002 N96020 X1.2472 Y0.3585 Z0.0000 N96030 X1.2527 Z-0.0013 N96040 X1.2549 Z-0.0014 N96050 X1.2560 Z-0.0016 N96060 X1.2659 Z-0.0037 N96070 X1.2758 Z-0.0054 N96080 X1.2813 Z-0.0064 N96090 X1.2835 Z-0.0071 N96100 X1.2846 Z-0.0080 N96110 X1.2857 Z-0.0093 N96120 X1.2879 Z-0.0124 N96130 X1.3175 Z-0.0591 N96140 X1.3186 Z-0.0600 N96150 X1.6890 N96160 X1.6901 Z-0.0588 N96170 X1.7329 Z-0.0021 N96180 X1.7340 Z-0.0013 N96190 X1.7351 Z-0.0000 N96200 X1.7344 Y0.3593 Z-0.0003 N96210 X1.7337 Y0.3602 Z0.0000 N96220 X1.7330 Y0.3610 Z-0.0005 N96230 X1.7323 Y0.3618 Z-0.0001 N96240 X1.7316 Y0.3627 Z0.0000 N96250 X1.7309 Y0.3635 N96260 X1.7298 Z-0.0009 N96270 X1.7287 Z-0.0020 N96280 X1.6858 Z-0.0588 N96290 X1.6847 Z-0.0600 N96300 X1.3170 N96310 X1.3159 Z-0.0599 N96320 X1.2983 Z-0.0322 N96330 X1.2939 Z-0.0256 N96340 X1.2906 Z-0.0212 N96350 X1.2884 Z-0.0186 N96360 X1.2873 Z-0.0175 N96370 X1.2862 Z-0.0166 N96380 X1.2851 Z-0.0158 N96390 X1.2840 Z-0.0152 N96400 X1.2829 Z-0.0148 N96410 X1.2708 Z-0.0127 N96420 X1.2630 Z-0.0112 N96430 X1.2542 Z-0.0093 N96440 X1.2454 Z-0.0071 N96450 X1.2377 Z-0.0049 N96460 X1.2311 Z-0.0028 N96470 X1.2256 Z-0.0007 N96480 X1.2245 Z-0.0003 N96490 X1.2234 Z-0.0002 N96500 X1.2212 N96510 X1.2193 Y0.3640 Z-0.0002 N96520 X1.2184 Y0.3642 Z0.0000 N96530 X1.2174 Y0.3645 N96540 X1.2164 Y0.3648 Z-0.0005 N96550 X1.2153 Y0.3651 Z0.0000 N96560 X1.2143 Y0.3654 N96570 X1.2132 Y0.3657 Z-0.0002 N96580 X1.2123 Y0.3661 Z-0.0001 N96590 X1.2104 Y0.3667 Z0.0000 N96600 X1.2094 Y0.3670 Z-0.0004 N96610 X1.2086 Y0.3674 Z0.0000 N96620 X1.2077 Y0.3677 N96630 X1.2069 Y0.3680 Z-0.0003 N96640 X1.2060 Y0.3684 Z-0.0002 N96650 X1.2058 Y0.3685 Z0.0000 N96660 X1.2069 Z-0.0003 N96670 X1.2079 Z-0.0010 N96680 X1.2101 Z-0.0022 N96690 X1.2145 Z-0.0046 N96700 X1.2189 Z-0.0068 N96710 X1.2244 Z-0.0092 N96720 X1.2299 Z-0.0113 N96730 X1.2354 Z-0.0131 N96740 X1.2420 Z-0.0151 N96750 X1.2508 Z-0.0175 N96760 X1.2596 Z-0.0195 N96770 X1.2684 Z-0.0213 N96780 X1.2783 Z-0.0231 N96790 X1.2827 Z-0.0238 N96800 X1.2838 Z-0.0241 N96810 X1.2849 Z-0.0245 N96820 X1.2860 Z-0.0250 N96830 X1.2871 Z-0.0257 N96840 X1.2893 Z-0.0273 N96850 X1.2904 Z-0.0282 N96860 X1.2926 Z-0.0303 N96870 X1.2959 Z-0.0342 N96880 X1.2992 Z-0.0385 N96890 X1.3036 Z-0.0447 N96900 X1.3102 Z-0.0548 N96910 X1.3135 Z-0.0600 N96920 X1.4388 Z-0.0600 N96930 X1.5640 N96940 X1.6805 N96950 X1.6816 Z-0.0588 N96960 X1.7245 Z-0.0020 N96970 X1.7256 Z-0.0010 N96980 X1.7267 Z-0.0004 N96990 X1.7260 Y0.3693 Z0.0000 N97000 X1.7253 Y0.3702 N97010 X1.7246 Y0.3710 Z-0.0002 N97020 X1.7239 Y0.3718 Z0.0000 N97030 X1.7232 Y0.3727 Z-0.0001 N97040 X1.7225 Y0.3735 Z0.0000 N97050 X1.7214 Z-0.0003 N97060 X1.6773 Z-0.0586 N97070 X1.6762 Z-0.0600 N97080 X1.3118 N97090 X1.3107 Z-0.0593 N97100 X1.3063 Z-0.0530 N97110 X1.3019 Z-0.0471 N97120 X1.2986 Z-0.0431 N97130 X1.2953 Z-0.0395 N97140 X1.2931 Z-0.0374 N97150 X1.2909 Z-0.0357 N97160 X1.2887 Z-0.0342 N97170 X1.2876 Z-0.0336 N97180 X1.2865 Z-0.0331 N97190 X1.2854 Z-0.0327 N97200 X1.2832 Z-0.0322 N97210 X1.2733 Z-0.0305 N97220 X1.2656 Z-0.0290 N97230 X1.2568 Z-0.0272 N97240 X1.2491 Z-0.0253 N97250 X1.2413 Z-0.0232 N97260 X1.2347 Z-0.0211 N97270 X1.2292 Z-0.0191 N97280 X1.2237 Z-0.0169 N97290 X1.2193 Z-0.0149 N97300 X1.2149 Z-0.0126 N97310 X1.2116 Z-0.0107 N97320 X1.2083 Z-0.0086 N97330 X1.2050 Z-0.0062 N97340 X1.2017 Z-0.0033 N97350 X1.1995 Z-0.0011 N97360 X1.1984 Z-0.0005 N97370 X1.1973 Z-0.0003 N97380 X1.1968 Y0.3741 Z0.0000 N97390 X1.1962 Y0.3746 Z-0.0004 N97400 X1.1958 Y0.3751 Z0.0000 N97410 X1.1949 Y0.3762 N97420 X1.1944 Y0.3769 Z-0.0003 N97430 X1.1940 Y0.3774 N97440 X1.1937 Y0.3780 Z0.0000 N97450 X1.1934 Y0.3785 N97460 X1.1956 Z-0.0026 N97470 X1.1989 Z-0.0071 N97480 X1.2022 Z-0.0112 N97490 X1.2044 Z-0.0136 N97500 X1.2066 Z-0.0156 N97510 X1.2099 Z-0.0182 N97520 X1.2143 Z-0.0210 N97530 X1.2187 Z-0.0234 N97540 X1.2231 Z-0.0255 N97550 X1.2275 Z-0.0274 N97560 X1.2319 Z-0.0290 N97570 X1.2374 Z-0.0309 N97580 X1.2440 Z-0.0329 N97590 X1.2528 Z-0.0352 N97600 X1.2616 Z-0.0372 N97610 X1.2693 Z-0.0388 N97620 X1.2792 Z-0.0405 N97630 X1.2836 Z-0.0413 N97640 X1.2858 Z-0.0418 N97650 X1.2891 Z-0.0431 N97660 X1.2913 Z-0.0444 N97670 X1.2935 Z-0.0459 N97680 X1.2957 Z-0.0477 N97690 X1.2990 Z-0.0508 N97700 X1.3023 Z-0.0543 N97710 X1.3056 Z-0.0583 N97720 X1.3067 Z-0.0596 N97730 X1.3078 Z-0.0600 N97740 X1.6720 N97750 X1.6731 Z-0.0591 N97760 X1.7150 Z-0.0038 N97770 X1.7172 Z-0.0009 N97780 X1.7183 Z0.0000 N97790 X1.7176 Y0.3793 N97800 X1.7169 Y0.3801 Z-0.0002 N97810 X1.7162 Y0.3810 Z-0.0002 N97820 X1.7155 Y0.3818 Z-0.0004 N97830 X1.7147 Y0.3826 Z-0.0000 N97840 X1.7140 Y0.3835 Z0.0000 N97850 X1.7129 Z-0.0009 N97860 X1.6690 Z-0.0591 N97870 X1.6679 Z-0.0600 N97880 X1.3018 N97890 X1.3007 Z-0.0591 N97900 X1.2985 Z-0.0571 N97910 X1.2952 Z-0.0545 N97920 X1.2930 Z-0.0530 N97930 X1.2908 Z-0.0517 N97940 X1.2886 Z-0.0507 N97950 X1.2864 Z-0.0500 N97960 X1.2831 Z-0.0493 N97970 X1.2743 Z-0.0478 N97980 X1.2666 Z-0.0464 N97990 X1.2589 Z-0.0447 N98000 X1.2523 Z-0.0432 N98010 X1.2435 Z-0.0408 N98020 X1.2369 Z-0.0388 N98030 X1.2314 Z-0.0368 N98040 X1.2259 Z-0.0346 N98050 X1.2215 Z-0.0326 N98060 X1.2182 Z-0.0309 N98070 X1.2149 Z-0.0290 N98080 X1.2116 Z-0.0268 N98090 X1.2094 Z-0.0251 N98100 X1.2083 Z-0.0241 N98110 X1.2072 Z-0.0230 N98120 X1.2050 Z-0.0204 N98130 X1.2017 Z-0.0158 N98140 X1.1951 Z-0.0059 N98150 X1.1918 Z-0.0007 N98160 X1.1907 Z-0.0005 N98170 X1.1905 Y0.3840 Z0.0000 N98180 X1.1901 Y0.3850 N98190 X1.1897 Y0.3860 Z-0.0004 N98200 X1.1894 Y0.3868 Z0.0000 N98210 X1.1888 Y0.3885 N98220 X1.1899 Z-0.0012 N98230 X1.2020 Z-0.0207 N98240 X1.2086 Z-0.0310 N98250 X1.2108 Z-0.0341 N98260 X1.2119 Z-0.0352 N98270 X1.2141 Z-0.0369 N98280 X1.2174 Z-0.0390 N98290 X1.2207 Z-0.0409 N98300 X1.2251 Z-0.0431 N98310 X1.2295 Z-0.0450 N98320 X1.2350 Z-0.0471 N98330 X1.2405 Z-0.0489 N98340 X1.2460 Z-0.0505 N98350 X1.2548 Z-0.0529 N98360 X1.2625 Z-0.0546 N98370 X1.2702 Z-0.0562 N98380 X1.2801 Z-0.0579 N98390 X1.2856 Z-0.0589 N98400 X1.2878 Z-0.0594 N98410 X1.2900 Z-0.0600 N98420 X1.4032 N98430 X1.5208 N98440 X1.6428 N98450 X1.6637 N98460 X1.6670 Z-0.0557 N98470 X1.7076 Z-0.0020 N98480 X1.7087 Z-0.0013 N98490 X1.7098 Z-0.0003 N98500 X1.7091 Y0.3893 Z-0.0003 N98510 X1.7084 Y0.3901 Z0.0000 N98520 X1.7077 Y0.3910 N98530 X1.7070 Y0.3918 Z-0.0001 N98540 X1.7063 Y0.3926 Z0.0000 N98550 X1.7056 Y0.3935 N98560 X1.7045 Z-0.0008 N98570 X1.6605 Z-0.0590 N98580 X1.6594 Z-0.0600 N98590 X1.2512 N98600 X1.2490 Z-0.0595 N98610 X1.2424 Z-0.0575 N98620 X1.2369 Z-0.0557 N98630 X1.2325 Z-0.0541 N98640 X1.2281 Z-0.0523 N98650 X1.2248 Z-0.0508 N98660 X1.2215 Z-0.0491 N98670 X1.2193 Z-0.0478 N98680 X1.2171 Z-0.0464 N98690 X1.2160 Z-0.0456 N98700 X1.2149 Z-0.0443 N98710 X1.2105 Z-0.0373 N98720 X1.2006 Z-0.0212 N98730 X1.1885 Z-0.0011 N98740 X1.1874 Z-0.0004 N98750 X1.1872 Y0.3940 Z-0.0000 N98760 X1.1868 Y0.3958 Z0.0000 N98770 X1.1866 Y0.3967 Z-0.0002 N98780 X1.1862 Y0.3985 Z-0.0002 N98790 X1.1873 Z-0.0009 N98800 X1.2060 Z-0.0324 N98810 X1.2192 Z-0.0544 N98820 X1.2203 Z-0.0561 N98830 X1.2214 Z-0.0575 N98840 X1.2258 Z-0.0599 N98850 X1.2269 Z-0.0600 N98860 X1.6552 N98870 X1.6992 Z-0.0018 N98880 X1.7003 Z-0.0006 N98890 X1.7014 Z-0.0004 N98900 X1.7007 Y0.3993 Z0.0000 N98910 X1.7000 Y0.4001 N98920 X1.6993 Y0.4010 Z-0.0001 N98930 X1.6986 Y0.4018 N98940 X1.6979 Y0.4026 Z-0.0003 N98950 X1.6972 Y0.4035 Z0.0000 N98960 X1.6961 Z-0.0006 N98970 X1.6520 Z-0.0588 N98980 X1.6509 Z-0.0600 N98990 X1.2216 N99000 X1.2205 Z-0.0592 N99010 X1.2051 Z-0.0331 N99020 X1.1864 Z-0.0012 N99030 X1.1853 Z-0.0005 N99040 X1.1851 Y0.4045 Z-0.0003 N99050 X1.1850 Y0.4055 Z0.0000 N99060 X1.1846 Y0.4085 N99070 X1.1868 Z-0.0032 N99080 X1.2165 Z-0.0540 N99090 X1.2198 Z-0.0597 N99100 X1.2209 Z-0.0600 N99110 X1.6467 N99120 X1.6478 Z-0.0589 N99130 X1.6918 Z-0.0006 N99140 X1.6929 Z-0.0000 N99150 X1.6922 Y0.4093 Z-0.0002 N99160 X1.6915 Y0.4101 Z-0.0002 N99170 X1.6908 Y0.4109 Z0.0000 N99180 X1.6901 Y0.4118 Z-0.0003 N99190 X1.6894 Y0.4126 Z0.0000 N99200 X1.6887 Y0.4134 N99210 X1.6865 Z-0.0023 N99220 X1.6821 Z-0.0080 N99230 X1.6436 Z-0.0589 N99240 X1.6425 Z-0.0600 N99250 X1.2203 N99260 X1.2192 Z-0.0596 N99270 X1.1851 Z-0.0010 N99280 X1.1840 Z-0.0001 N99290 X1.1839 Y0.4144 Z0.0000 N99300 X1.1835 Y0.4184 N99310 X1.1857 Z-0.0032 N99320 X1.2176 Z-0.0583 N99330 X1.2187 Z-0.0600 N99340 X1.6383 N99350 X1.6394 Z-0.0589 N99360 X1.6823 Z-0.0021 N99370 X1.6834 Z-0.0010 N99380 X1.6845 Z-0.0002 N99390 X1.6838 Y0.4193 Z-0.0003 N99400 X1.6831 Y0.4201 Z0.0000 N99410 X1.6810 Y0.4226 Z-0.0000 N99420 X1.6803 Y0.4234 Z-0.0003 N99430 X1.6792 Z-0.0011 N99440 X1.6781 Z-0.0021 N99450 X1.6352 Z-0.0589 N99460 X1.6341 Z-0.0600 N99470 X1.2183 N99480 X1.2062 Z-0.0392 N99490 X1.1842 Z-0.0012 N99500 X1.1831 Z-0.0004 N99510 X1.1831 Y0.4243 Z-0.0005 N99520 X1.1830 Y0.4251 Z-0.0005 N99530 X1.1829 Y0.4276 Z-0.0002 N99540 X1.1829 Y0.4284 Z-0.0001 N99550 X1.1840 Z-0.0009 N99560 X1.2181 Z-0.0600 N99570 X1.3304 Z-0.0600 N99580 X1.4515 N99590 X1.5792 N99600 X1.6287 N99610 X1.6298 Z-0.0600 N99620 X1.6739 Z-0.0017 N99630 X1.6750 Z-0.0004 N99640 X1.6761 Z0.0000 N99650 X1.6754 Y0.4293 N99660 X1.6747 Y0.4301 Z-0.0002 N99670 X1.6740 Y0.4309 Z-0.0001 N99680 X1.6733 Y0.4318 Z0.0000 N99690 X1.6725 Y0.4326 Z-0.0006 N99700 X1.6718 Y0.4334 Z0.0000 N99710 X1.6707 Z-0.0008 N99720 X1.6268 Z-0.0591 N99730 X1.6257 Z-0.0600 N99740 X1.2178 N99750 X1.2167 Z-0.0584 N99760 X1.1838 Z-0.0012 N99770 X1.1827 Z0.0000 N99780 X1.1825 Y0.4384 N99790 X1.1836 Z-0.0015 N99800 X1.2166 Z-0.0586 N99810 X1.2177 Z-0.0600 N99820 X1.6214 N99830 X1.6225 Z-0.0588 N99840 X1.6665 Z-0.0005 N99850 X1.6676 Z0.0000 N99860 X1.6669 Y0.4392 Z-0.0004 N99870 X1.6655 Y0.4409 Z0.0000 N99880 X1.6634 Y0.4434 N99890 X1.6623 Z-0.0012 N99900 X1.6612 Z-0.0021 N99910 X1.6183 Z-0.0589 N99920 X1.6172 Z-0.0600 N99930 X1.2177 N99940 X1.2166 Z-0.0586 N99950 X1.1847 Z-0.0034 N99960 X1.1836 Z-0.0016 N99970 X1.1825 Z0.0000 N99980 X1.1824 Y0.4484 N99990 X1.1846 Z-0.0033 N100000 X1.2166 Z-0.0586 N100010 X1.2177 Z-0.0600 N100020 X1.6129 N100030 X1.6140 Z-0.0591 N100040 X1.6570 Z-0.0023 N100050 X1.6581 Z-0.0011 N100060 X1.6592 Z0.0000 N100070 X1.6585 Y0.4492 Z-0.0002 N100080 X1.6578 Y0.4501 Z0.0000 N100090 X1.6571 Y0.4509 Z-0.0001 N100100 X1.6564 Y0.4517 Z-0.0000 N100110 X1.6557 Y0.4526 Z-0.0002 N100120 X1.6550 Y0.4534 Z-0.0005 N100130 X1.6539 Z-0.0011 N100140 X1.6528 Z-0.0019 N100150 X1.6099 Z-0.0586 N100160 X1.6088 Z-0.0600 N100170 X1.2176 N100180 X1.2165 Z-0.0585 N100190 X1.1846 Z-0.0033 N100200 X1.1824 Z0.0000 N100210 Y0.4584 N100220 X1.1846 Z-0.0033 N100230 X1.2165 Z-0.0585 N100240 X1.2176 Z-0.0600 N100250 X1.6046 N100260 X1.6134 Z-0.0485 N100270 X1.6496 Z-0.0005 N100280 X1.6507 Z-0.0002 N100290 X1.6500 Y0.4592 Z-0.0001 N100300 X1.6493 Y0.4601 Z-0.0004 N100310 X1.6486 Y0.4609 Z-0.0001 N100320 X1.6479 Y0.4617 Z0.0000 N100330 X1.6465 Y0.4634 N100340 X1.6454 Z-0.0006 N100350 X1.6432 Z-0.0034 N100360 X1.6014 Z-0.0588 N100370 X1.6003 Z-0.0600 N100380 X1.2176 N100390 X1.2165 Z-0.0585 N100400 X1.1846 Z-0.0033 N100410 X1.1824 Z0.0000 N100420 Y0.4684 N100430 X1.1846 Z-0.0033 N100440 X1.2165 Z-0.0586 N100450 X1.2176 Z-0.0600 N100460 X1.5961 N100470 X1.5972 Z-0.0591 N100480 X1.6412 Z-0.0008 N100490 X1.6423 Z0.0000 N100500 X1.6416 Y0.4692 N100510 X1.6409 Y0.4700 Z-0.0002 N100520 X1.6402 Y0.4709 Z0.0000 N100530 X1.6388 Y0.4725 N100540 X1.6381 Y0.4734 Z-0.0002 N100550 X1.6370 Z-0.0009 N100560 X1.6359 Z-0.0022 N100570 X1.5930 Z-0.0589 N100580 X1.5919 Z-0.0600 N100590 X1.2176 N100600 X1.2165 Z-0.0586 N100610 X1.1846 Z-0.0033 N100620 X1.1824 Z0.0000 N100630 Y0.4784 N100640 X1.1846 Z-0.0033 N100650 X1.2166 Z-0.0586 N100660 X1.2177 Z-0.0600 N100670 X1.5876 N100680 X1.5887 Z-0.0590 N100690 X1.6317 Z-0.0022 N100700 X1.6328 Z-0.0012 N100710 X1.6339 Z0.0000 N100720 X1.6332 Y0.4792 Z-0.0001 N100730 X1.6325 Y0.4800 N100740 X1.6318 Y0.4809 Z-0.0004 N100750 X1.6311 Y0.4817 Z-0.0000 N100760 X1.6303 Y0.4825 Z0.0000 N100770 X1.6296 Y0.4834 Z-0.0003 N100780 X1.6285 Z-0.0008 N100790 X1.6274 Z-0.0018 N100800 X1.5835 Z-0.0599 N100810 X1.5824 Z-0.0600 N100820 X1.2176 N100830 X1.2165 Z-0.0585 N100840 X1.1846 Z-0.0033 N100850 X1.1824 Z0.0000 N100860 Y0.4884 N100870 X1.1846 Z-0.0033 N100880 X1.2165 Z-0.0585 N100890 X1.2176 Z-0.0600 N100900 X1.5793 N100910 X1.5804 Z-0.0589 N100920 X1.6243 Z-0.0008 N100930 X1.6254 Z-0.0003 N100940 X1.6247 Y0.4892 Z0.0000 N100950 X1.6240 Y0.4900 Z-0.0001 N100960 X1.6226 Y0.4917 Z0.0000 N100970 X1.6212 Y0.4934 N100980 X1.6201 Z-0.0002 N100990 X1.5750 Z-0.0600 N101000 X1.4618 Z-0.0600 N101010 X1.3441 N101020 X1.2209 N101030 X1.2176 N101040 X1.2165 Z-0.0585 N101050 X1.1846 Z-0.0033 N101060 X1.1824 Z0.0000 N101070 Y0.4984 N101080 X1.1846 Z-0.0033 N101090 X1.2165 Z-0.0586 N101100 X1.2176 Z-0.0600 N101110 X1.5708 N101120 X1.5719 Z-0.0590 N101130 X1.6137 Z-0.0037 N101140 X1.6159 Z-0.0011 N101150 X1.6170 Z0.0000 N101160 X1.6149 Y0.5008 Z-0.0001 N101170 X1.6142 Y0.5017 Z-0.0003 N101180 X1.6135 Y0.5025 Z0.0000 N101190 X1.6128 Y0.5033 N101200 X1.6117 Z-0.0007 N101210 X1.5676 Z-0.0590 N101220 X1.5665 Z-0.0600 N101230 X1.2176 N101240 X1.2165 Z-0.0586 N101250 X1.1846 Z-0.0033 N101260 X1.1824 Z0.0000 N101270 Y0.5083 N101280 X1.1846 Z-0.0033 N101290 X1.2166 Z-0.0586 N101300 X1.2177 Z-0.0600 N101310 X1.5623 N101320 X1.5634 Z-0.0588 N101330 X1.6063 Z-0.0020 N101340 X1.6074 Z-0.0013 N101350 X1.6085 Z-0.0002 N101360 X1.6078 Y0.5092 Z-0.0002 N101370 X1.6071 Y0.5100 Z0.0000 N101380 X1.6064 Y0.5108 Z-0.0004 N101390 X1.6057 Y0.5117 Z0.0000 N101400 X1.6043 Y0.5133 N101410 X1.6032 Z-0.0007 N101420 X1.6021 Z-0.0020 N101430 X1.5593 Z-0.0586 N101440 X1.5582 Z-0.0600 N101450 X1.2176 N101460 X1.2165 Z-0.0585 N101470 X1.1846 Z-0.0033 N101480 X1.1824 Z0.0000 N101490 Y0.5183 N101500 X1.1846 Z-0.0033 N101510 X1.2165 Z-0.0585 N101520 X1.2176 Z-0.0600 N101530 X1.5539 N101540 X1.5550 Z-0.0588 N101550 X1.5979 Z-0.0020 N101560 X1.5990 Z-0.0010 N101570 X1.6001 Z-0.0003 N101580 X1.5994 Y0.5192 Z0.0000 N101590 X1.5980 Y0.5208 Z-0.0000 N101600 X1.5973 Y0.5217 Z0.0000 N101610 X1.5966 Y0.5225 Z-0.0002 N101620 X1.5959 Y0.5233 Z0.0000 N101630 X1.5948 Z-0.0004 N101640 X1.5508 Z-0.0587 N101650 X1.5497 Z-0.0600 N101660 X1.2176 N101670 X1.2165 Z-0.0585 N101680 X1.1846 Z-0.0033 N101690 X1.1824 Z0.0000 N101700 Y0.5283 N101710 X1.1846 Z-0.0033 N101720 X1.2165 Z-0.0586 N101730 X1.2176 Z-0.0600 N101740 X1.5455 N101750 X1.5466 Z-0.0590 N101760 X1.5895 Z-0.0023 N101770 X1.5906 Z-0.0009 N101780 X1.5917 Z0.0000 N101790 X1.5910 Y0.5292 Z-0.0001 N101800 X1.5896 Y0.5308 Z-0.0001 N101810 X1.5889 Y0.5316 Z-0.0006 N101820 X1.5882 Y0.5325 Z0.0000 N101830 X1.5874 Y0.5333 N101840 X1.5863 Z-0.0010 N101850 X1.5852 Z-0.0025 N101860 X1.5841 Z-0.0038 N101870 X1.5423 Z-0.0591 N101880 X1.5412 Z-0.0600 N101890 X1.2176 N101900 X1.2165 Z-0.0586 N101910 X1.1846 Z-0.0033 N101920 X1.1824 Z0.0000 N101930 Y0.5383 N101940 X1.1846 Z-0.0033 N101950 X1.2166 Z-0.0586 N101960 X1.2177 Z-0.0600 N101970 X1.5370 N101980 X1.5381 Z-0.0588 N101990 X1.5810 Z-0.0020 N102000 X1.5821 Z-0.0013 N102010 X1.5832 Z-0.0005 N102020 X1.5825 Y0.5391 Z-0.0002 N102030 X1.5818 Y0.5400 Z0.0000 N102040 X1.5797 Y0.5425 N102050 X1.5790 Y0.5433 Z-0.0001 N102060 X1.5779 Z-0.0008 N102070 X1.5340 Z-0.0588 N102080 X1.5329 Z-0.0600 N102090 X1.2176 N102100 X1.2165 Z-0.0585 N102110 X1.1846 Z-0.0033 N102120 X1.1824 Z0.0000 N102130 Y0.5483 N102140 X1.1846 Z-0.0033 N102150 X1.2165 Z-0.0585 N102160 X1.2176 Z-0.0600 N102170 X1.5275 N102180 X1.5286 Z-0.0599 N102190 X1.5726 Z-0.0017 N102200 X1.5737 Z-0.0005 N102210 X1.5748 Z-0.0002 N102220 X1.5741 Y0.5491 Z0.0000 N102230 X1.5727 Y0.5508 Z-0.0000 N102240 X1.5713 Y0.5525 Z-0.0005 N102250 X1.5706 Y0.5533 Z0.0000 N102260 X1.5695 Z-0.0007 N102270 X1.5255 Z-0.0590 N102280 X1.5244 Z-0.0600 N102290 X1.2176 N102300 X1.2165 Z-0.0585 N102310 X1.1846 Z-0.0033 N102320 X1.1824 Z0.0000 N102330 Y0.5583 N102340 X1.1846 Z-0.0033 N102350 X1.2165 Z-0.0586 N102360 X1.2176 Z-0.0600 N102370 X1.5201 N102380 X1.5212 Z-0.0589 N102390 X1.5652 Z-0.0006 N102400 X1.5663 Z-0.0001 N102410 X1.5656 Y0.5591 Z-0.0004 N102420 X1.5649 Y0.5599 Z-0.0001 N102430 X1.5642 Y0.5608 Z0.0000 N102440 X1.5635 Y0.5616 Z-0.0001 N102450 X1.5628 Y0.5624 Z0.0000 N102460 X1.5621 Y0.5633 N102470 X1.5610 Z-0.0013 N102480 X1.5599 Z-0.0022 N102490 X1.5170 Z-0.0589 N102500 X1.5159 Z-0.0600 N102510 X1.2176 N102520 X1.2165 Z-0.0586 N102530 X1.1846 Z-0.0033 N102540 X1.1824 Z0.0000 N102550 Y0.5683 N102560 X1.1846 Z-0.0033 N102570 X1.2166 Z-0.0586 N102580 X1.2177 Z-0.0600 N102590 X1.5117 N102600 X1.5128 Z-0.0589 N102610 X1.5557 Z-0.0021 N102620 X1.5568 Z-0.0010 N102630 X1.5579 Z-0.0000 N102640 X1.5572 Y0.5691 Z-0.0002 N102650 X1.5565 Y0.5699 Z0.0000 N102660 X1.5551 Y0.5716 N102670 X1.5537 Y0.5733 Z-0.0004 N102680 X1.5526 Z-0.0011 N102690 X1.5515 Z-0.0020 N102700 X1.5087 Z-0.0588 N102710 X1.5076 Z-0.0600 N102720 X1.2176 N102730 X1.2165 Z-0.0584 N102740 X1.1846 Z-0.0033 N102750 X1.1824 Z0.0000 N102760 Y0.5783 N102770 X1.1846 Z-0.0033 N102780 X1.2165 Z-0.0585 N102790 X1.2176 Z-0.0600 N102800 X1.5022 N102810 X1.5033 Z-0.0598 N102820 X1.5484 Z-0.0003 N102830 X1.5495 Z-0.0001 N102840 X1.5488 Y0.5791 N102850 X1.5481 Y0.5799 Z-0.0003 N102860 X1.5474 Y0.5808 Z0.0000 N102870 X1.5467 Y0.5816 N102880 X1.5460 Y0.5824 Z-0.0004 N102890 X1.5452 Y0.5833 Z0.0000 N102900 X1.5441 Z-0.0010 N102910 X1.5430 Z-0.0023 N102920 X1.5046 Z-0.0532 N102930 X1.5002 Z-0.0591 N102940 X1.4991 Z-0.0600 N102950 X1.2176 N102960 X1.2165 Z-0.0585 N102970 X1.1846 Z-0.0033 N102980 X1.1824 Z0.0000 N102990 Y0.5883 N103000 X1.1846 Z-0.0033 N103010 X1.2165 Z-0.0586 N103020 X1.2176 Z-0.0600 N103030 X1.4948 N103040 X1.4959 Z-0.0589 N103050 X1.5399 Z-0.0006 N103060 X1.5410 Z0.0000 N103070 X1.5403 Y0.5891 Z-0.0003 N103080 X1.5396 Y0.5899 Z-0.0001 N103090 X1.5382 Y0.5916 Z0.0000 N103100 X1.5375 Y0.5924 N103110 X1.5368 Y0.5932 Z-0.0001 N103120 X1.5357 Z-0.0012 N103130 X1.5346 Z-0.0021 N103140 X1.4917 Z-0.0589 N103150 X1.4906 Z-0.0600 N103160 X1.2176 N103170 X1.2165 Z-0.0586 N103180 X1.1846 Z-0.0033 N103190 X1.1824 Z0.0000 N103200 Y0.5982 N103210 X1.1846 Z-0.0033 N103220 X1.2166 Z-0.0587 N103230 X1.2177 Z-0.0600 N103240 X1.4863 N103250 X1.4874 Z-0.0591 N103260 X1.5304 Z-0.0023 N103270 X1.5315 Z-0.0011 N103280 X1.5326 Z0.0000 N103290 X1.5319 Y0.5991 Z-0.0001 N103300 X1.5312 Y0.5999 Z0.0000 N103310 X1.5305 Y0.6007 Z-0.0002 N103320 X1.5298 Y0.6016 Z0.0000 N103330 X1.5291 Y0.6024 Z-0.0000 N103340 X1.5284 Y0.6032 Z-0.0006 N103350 X1.5273 Z-0.0009 N103360 X1.5262 Z-0.0018 N103370 X1.4822 Z-0.0600 N103380 X1.4768 Z-0.0600 N103390 X1.3680 N103400 X1.2461 N103410 X1.2176 N103420 X1.2165 Z-0.0584 N103430 X1.1846 Z-0.0033 N103440 X1.1824 Z0.0000 N103450 Y0.6082 N103460 X1.1846 Z-0.0033 N103470 X1.2165 Z-0.0585 N103480 X1.2176 Z-0.0600 N103490 X1.4780 N103500 X1.4824 Z-0.0543 N103510 X1.5088 Z-0.0194 N103520 X1.5231 Z-0.0005 N103530 X1.5241 Z-0.0002 N103540 X1.5234 Y0.6091 Z0.0000 N103550 X1.5227 Y0.6099 Z-0.0006 N103560 X1.5220 Y0.6107 Z0.0000 N103570 X1.5199 Y0.6132 N103580 X1.5188 Z-0.0005 N103590 X1.4749 Z-0.0588 N103600 X1.4738 Z-0.0600 N103610 X1.2176 N103620 X1.2165 Z-0.0585 N103630 X1.1846 Z-0.0033 N103640 X1.1824 Z0.0000 N103650 Y0.6182 N103660 X1.1846 Z-0.0033 N103670 X1.2165 Z-0.0586 N103680 X1.2176 Z-0.0600 N103690 X1.4695 N103700 X1.4706 Z-0.0590 N103710 X1.5124 Z-0.0038 N103720 X1.5146 Z-0.0009 N103730 X1.5157 Z0.0000 N103740 X1.5136 Y0.6207 N103750 X1.5129 Y0.6215 Z-0.0001 N103760 X1.5122 Y0.6224 Z0.0000 N103770 X1.5115 Y0.6232 Z-0.0003 N103780 X1.5104 Z-0.0009 N103790 X1.5093 Z-0.0021 N103800 X1.4664 Z-0.0589 N103810 X1.4653 Z-0.0600 N103820 X1.2176 N103830 X1.2165 Z-0.0586 N103840 X1.1846 Z-0.0033 N103850 X1.1824 Z0.0000 N103860 Y0.6282 N103870 X1.1846 Z-0.0033 N103880 X1.2166 Z-0.0587 N103890 X1.2177 Z-0.0600 N103900 X1.4610 N103910 X1.4621 Z-0.0590 N103920 X1.5051 Z-0.0022 N103930 X1.5073 Z-0.0000 N103940 X1.5059 Y0.6299 Z-0.0002 N103950 X1.5052 Y0.6307 Z-0.0005 N103960 X1.5045 Y0.6315 Z0.0000 N103970 X1.5038 Y0.6324 N103980 X1.5030 Y0.6332 Z-0.0001 N103990 X1.5020 Z-0.0006 N104000 X1.5009 Z-0.0018 N104010 X1.4569 Z-0.0598 N104020 X1.4558 Z-0.0600 N104030 X1.2176 N104040 X1.2165 Z-0.0584 N104050 X1.1846 Z-0.0033 N104060 X1.1824 Z0.0000 N104070 Y0.6382 N104080 X1.1846 Z-0.0033 N104090 X1.2165 Z-0.0585 N104100 X1.2176 Z-0.0600 N104110 X1.4527 N104120 X1.4538 Z-0.0589 N104130 X1.4780 Z-0.0269 N104140 X1.4977 Z-0.0008 N104150 X1.4988 Z-0.0002 N104160 X1.4981 Y0.6390 Z0.0000 N104170 X1.4960 Y0.6415 N104180 X1.4953 Y0.6424 Z-0.0001 N104190 X1.4946 Y0.6432 Z0.0000 N104200 X1.4935 Z-0.0003 N104210 X1.4495 Z-0.0586 N104220 X1.4484 Z-0.0600 N104230 X1.2176 N104240 X1.2165 Z-0.0585 N104250 X1.1846 Z-0.0033 N104260 X1.1824 Z0.0000 N104270 Y0.6482 N104280 X1.1846 Z-0.0033 N104290 X1.2165 Z-0.0586 N104300 X1.2176 Z-0.0600 N104310 X1.4442 N104320 X1.4453 Z-0.0589 N104330 X1.4871 Z-0.0037 N104340 X1.4882 Z-0.0023 N104350 X1.4893 Z-0.0012 N104360 X1.4904 Z0.0000 N104370 X1.4890 Y0.6498 Z-0.0000 N104380 X1.4876 Y0.6515 Z-0.0004 N104390 X1.4869 Y0.6523 Z0.0000 N104400 X1.4862 Y0.6532 N104410 X1.4851 Z-0.0009 N104420 X1.4410 Z-0.0591 N104430 X1.4399 Z-0.0600 N104440 X1.2176 N104450 X1.2165 Z-0.0586 N104460 X1.1846 Z-0.0033 N104470 X1.1824 Z0.0000 N104480 Y0.6582 N104490 X1.1846 Z-0.0033 N104500 X1.2166 Z-0.0587 N104510 X1.2177 Z-0.0600 N104520 X1.4357 N104530 X1.4368 Z-0.0588 N104540 X1.4797 Z-0.0020 N104550 X1.4808 Z-0.0013 N104560 X1.4820 Z-0.0003 N104570 X1.4812 Y0.6590 Z-0.0001 N104580 X1.4805 Y0.6598 Z0.0000 N104590 X1.4798 Y0.6607 Z-0.0003 N104600 X1.4791 Y0.6615 Z0.0000 N104610 X1.4777 Y0.6632 N104620 X1.4766 Z-0.0006 N104630 X1.4316 Z-0.0600 N104640 X1.4250 Z-0.0600 N104650 X1.3109 N104660 X1.2176 N104670 X1.2165 Z-0.0584 N104680 X1.1846 Z-0.0033 N104690 X1.1824 Z0.0000 N104700 Y0.6682 N104710 X1.1846 Z-0.0033 N104720 X1.2165 Z-0.0584 N104730 X1.2176 Z-0.0600 N104740 X1.4274 N104750 X1.4285 Z-0.0588 N104760 X1.4713 Z-0.0019 N104770 X1.4724 Z-0.0008 N104780 X1.4735 Z-0.0001 N104790 X1.4728 Y0.6690 Z0.0000 N104800 X1.4714 Y0.6707 N104810 X1.4707 Y0.6715 Z-0.0001 N104820 X1.4700 Y0.6723 Z-0.0003 N104830 X1.4693 Y0.6732 Z0.0000 N104840 X1.4682 Z-0.0006 N104850 X1.4242 Z-0.0588 N104860 X1.4231 Z-0.0600 N104870 X1.2176 N104880 X1.2165 Z-0.0585 N104890 X1.1846 Z-0.0033 N104900 X1.1824 Z0.0000 N104910 Y0.6782 N104920 X1.1846 Z-0.0033 N104930 X1.2165 Z-0.0585 N104940 X1.2176 Z-0.0600 N104950 X1.4189 N104960 X1.4200 Z-0.0589 N104970 X1.4629 Z-0.0022 N104980 X1.4640 Z-0.0009 N104990 X1.4651 Z-0.0000 N105000 X1.4644 Y0.6790 Z-0.0002 N105010 X1.4637 Y0.6798 Z0.0000 N105020 X1.4630 Y0.6806 N105030 X1.4623 Y0.6815 Z-0.0006 N105040 X1.4616 Y0.6823 Z0.0000 N105050 X1.4609 Y0.6831 N105060 X1.4587 Z-0.0024 N105070 X1.4520 Z-0.0110 N105080 X1.4157 Z-0.0591 N105090 X1.4146 Z-0.0600 N105100 X1.2176 N105110 X1.2165 Z-0.0586 N105120 X1.1846 Z-0.0033 N105130 X1.1824 Z0.0000 N105140 Y0.6881 N105150 X1.1846 Z-0.0033 N105160 X1.2166 Z-0.0587 N105170 X1.2177 Z-0.0600 N105180 X1.4104 N105190 X1.4115 Z-0.0587 N105200 X1.4544 Z-0.0019 N105210 X1.4555 Z-0.0011 N105220 X1.4566 Z-0.0004 N105230 X1.4559 Y0.6890 Z-0.0000 N105240 X1.4538 Y0.6915 Z0.0000 N105250 X1.4531 Y0.6923 Z-0.0000 N105260 X1.4524 Y0.6931 Z-0.0003 N105270 X1.4513 Z-0.0008 N105280 X1.4074 Z-0.0587 N105290 X1.4063 Z-0.0600 N105300 X1.2175 N105310 X1.2165 Z-0.0584 N105320 X1.1846 Z-0.0033 N105330 X1.1824 Z0.0000 N105340 Y0.6981 N105350 X1.1846 Z-0.0033 N105360 X1.2165 Z-0.0584 N105370 X1.2176 Z-0.0600 N105380 X1.4010 N105390 X1.4021 Z-0.0599 N105400 X1.4460 Z-0.0017 N105410 X1.4471 Z-0.0003 N105420 X1.4482 Z-0.0001 N105430 X1.4475 Y0.6990 Z0.0000 N105440 X1.4468 Y0.6998 Z-0.0002 N105450 X1.4461 Y0.7006 Z0.0000 N105460 X1.4454 Y0.7015 Z-0.0002 N105470 X1.4447 Y0.7023 Z-0.0006 N105480 X1.4440 Y0.7031 Z0.0000 N105490 X1.4429 Z-0.0008 N105500 X1.3989 Z-0.0590 N105510 X1.3978 Z-0.0600 N105520 X1.2176 N105530 X1.2165 Z-0.0585 N105540 X1.1846 Z-0.0033 N105550 X1.1824 Z0.0000 N105560 Y0.7081 N105570 X1.1846 Z-0.0033 N105580 X1.2165 Z-0.0585 N105590 X1.2176 Z-0.0600 N105600 X1.3936 N105610 X1.3947 Z-0.0589 N105620 X1.4387 Z-0.0006 N105630 X1.4398 Z-0.0001 N105640 X1.4390 Y0.7090 Z-0.0005 N105650 X1.4383 Y0.7098 Z0.0000 N105660 X1.4355 Y0.7131 N105670 X1.4344 Z-0.0014 N105680 X1.4333 Z-0.0021 N105690 X1.3904 Z-0.0589 N105700 X1.3893 Z-0.0600 N105710 X1.2176 N105720 X1.2165 Z-0.0586 N105730 X1.1846 Z-0.0033 N105740 X1.1824 Z0.0000 N105750 Y0.7181 N105760 X1.1846 Z-0.0033 N105770 X1.2166 Z-0.0587 N105780 X1.2177 Z-0.0600 N105790 X1.3851 N105800 X1.3862 Z-0.0589 N105810 X1.4291 Z-0.0021 N105820 X1.4313 Z0.0000 N105830 X1.4299 Y0.7198 N105840 X1.4292 Y0.7206 Z-0.0001 N105850 X1.4285 Y0.7214 Z0.0000 N105860 X1.4271 Y0.7231 Z-0.0005 N105870 X1.4260 Z-0.0011 N105880 X1.4249 Z-0.0020 N105890 X1.3821 Z-0.0587 N105900 X1.3810 Z-0.0600 N105910 X1.2175 N105920 X1.2164 Z-0.0584 N105930 X1.1846 Z-0.0033 N105940 X1.1824 Z0.0000 N105950 Y0.7281 N105960 X1.1846 Z-0.0033 N105970 X1.2165 Z-0.0584 N105980 X1.2176 Z-0.0600 N105990 X1.3757 N106000 X1.3768 Z-0.0599 N106010 X1.4119 Z-0.0133 N106020 X1.4218 Z-0.0003 N106030 X1.4229 Z-0.0001 N106040 X1.4222 Y0.7289 Z-0.0002 N106050 X1.4215 Y0.7298 Z-0.0004 N106060 X1.4208 Y0.7306 Z0.0000 N106070 X1.4201 Y0.7314 N106080 X1.4194 Y0.7323 Z-0.0003 N106090 X1.4187 Y0.7331 Z0.0000 N106100 X1.4176 Z-0.0009 N106110 X1.4154 Z-0.0037 N106120 X1.3934 Z-0.0328 N106130 X1.3736 Z-0.0589 N106140 X1.3725 Z-0.0600 N106150 X1.2176 N106160 X1.2165 Z-0.0585 N106170 X1.1846 Z-0.0033 N106180 X1.1824 Z0.0000 N106190 Y0.7381 N106200 X1.1846 Z-0.0033 N106210 X1.2165 Z-0.0585 N106220 X1.2176 Z-0.0600 N106230 X1.3683 N106240 X1.3694 Z-0.0591 N106250 X1.4133 Z-0.0008 N106260 X1.4144 Z0.0000 N106270 X1.4137 Y0.7389 Z-0.0002 N106280 X1.4130 Y0.7398 Z0.0000 N106290 X1.4109 Y0.7422 Z-0.0000 N106300 X1.4102 Y0.7431 Z-0.0002 N106310 X1.4091 Z-0.0012 N106320 X1.4080 Z-0.0020 N106330 X1.3651 Z-0.0588 N106340 X1.3640 Z-0.0600 N106350 X1.2176 N106360 X1.2165 Z-0.0586 N106370 X1.1846 Z-0.0033 N106380 X1.1824 Z0.0000 N106390 Y0.7481 N106400 X1.1846 Z-0.0033 N106410 X1.2166 Z-0.0587 N106420 X1.2177 Z-0.0600 N106430 X1.3597 N106440 X1.3608 Z-0.0591 N106450 X1.4038 Z-0.0023 N106460 X1.4049 Z-0.0010 N106470 X1.4060 Z0.0000 N106480 X1.4053 Y0.7489 N106490 X1.4046 Y0.7497 Z-0.0001 N106500 X1.4039 Y0.7506 Z-0.0004 N106510 X1.4032 Y0.7514 Z0.0000 N106520 X1.4025 Y0.7522 N106530 X1.4018 Y0.7531 Z-0.0005 N106540 X1.4007 Z-0.0008 N106550 X1.3996 Z-0.0018 N106560 X1.3579 Z-0.0570 N106570 X1.3557 Z-0.0599 N106580 X1.3546 Z-0.0600 N106590 X1.2175 N106600 X1.2164 Z-0.0583 N106610 X1.1846 Z-0.0033 N106620 X1.1824 Z0.0000 N106630 Y0.7581 N106640 X1.1846 Z-0.0033 N106650 X1.2165 Z-0.0584 N106660 X1.2176 Z-0.0600 N106670 X1.3515 N106680 X1.3526 Z-0.0588 N106690 X1.3910 Z-0.0078 N106700 X1.3965 Z-0.0005 N106710 X1.3976 Z-0.0001 N106720 X1.3968 Y0.7589 Z0.0000 N106730 X1.3961 Y0.7597 Z-0.0004 N106740 X1.3954 Y0.7606 Z0.0000 N106750 X1.3933 Y0.7631 N106760 X1.3922 Z-0.0005 N106770 X1.3483 Z-0.0588 N106780 X1.3472 Z-0.0600 N106790 X1.2176 N106800 X1.2165 Z-0.0585 N106810 X1.1846 Z-0.0033 N106820 X1.1824 Z0.0000 N106830 Y0.7681 N106840 X1.1846 Z-0.0033 N106850 X1.2165 Z-0.0585 N106860 X1.2176 Z-0.0600 N106870 X1.3429 N106880 X1.3440 Z-0.0589 N106890 X1.3858 Z-0.0037 N106900 X1.3880 Z-0.0011 N106910 X1.3891 Z0.0000 N106920 X1.3870 Y0.7705 Z-0.0001 N106930 X1.3863 Y0.7714 Z-0.0003 N106940 X1.3856 Y0.7722 Z0.0000 N106950 X1.3849 Y0.7730 Z-0.0002 N106960 X1.3838 Z-0.0009 N106970 X1.3827 Z-0.0021 N106980 X1.3398 Z-0.0588 N106990 X1.3387 Z-0.0600 N107000 X1.2176 N107010 X1.2165 Z-0.0586 N107020 X1.1846 Z-0.0033 N107030 X1.1824 Z0.0000 N107040 Y0.7780 N107050 X1.1846 Z-0.0033 N107060 X1.2164 Z-0.0582 N107070 X1.2175 Z-0.0600 N107080 X1.3347 N107090 X1.3358 Z-0.0587 N107100 X1.3785 Z-0.0021 N107110 X1.3807 Z-0.0002 N107120 X1.3800 Y0.7789 Z0.0000 N107130 X1.3793 Y0.7797 Z-0.0001 N107140 X1.3786 Y0.7805 Z-0.0006 N107150 X1.3779 Y0.7814 Z0.0000 N107160 X1.3765 Y0.7830 Z-0.0000 N107170 X1.3754 Z-0.0005 N107180 X1.3743 Z-0.0018 N107190 X1.3348 Z-0.0538 N107200 X1.3304 Z-0.0596 N107210 X1.3293 Z-0.0600 N107220 X1.2175 N107230 X1.2164 Z-0.0583 N107240 X1.1846 Z-0.0033 N107250 X1.1824 Z0.0000 N107260 Y0.7880 N107270 X1.1846 Z-0.0033 N107280 X1.2164 Z-0.0584 N107290 X1.2175 Z-0.0600 N107300 X1.3262 N107310 X1.3273 Z-0.0589 N107320 X1.3481 Z-0.0313 N107330 X1.3700 Z-0.0022 N107340 X1.3711 Z-0.0008 N107350 X1.3722 Z-0.0000 N107360 X1.3694 Y0.7914 Z0.0000 N107370 X1.3687 Y0.7922 Z-0.0002 N107380 X1.3680 Y0.7930 Z0.0000 N107390 X1.3669 Z-0.0004 N107400 X1.3230 Z-0.0587 N107410 X1.3219 Z-0.0600 N107420 X1.2176 N107430 X1.2165 Z-0.0584 N107440 X1.1846 Z-0.0033 N107450 X1.1824 Z0.0000 N107460 Y0.7980 N107470 X1.1846 Z-0.0033 N107480 X1.2165 Z-0.0585 N107490 X1.2176 Z-0.0600 N107500 X1.3176 N107510 X1.3187 Z-0.0588 N107520 X1.3616 Z-0.0022 N107530 X1.3627 Z-0.0012 N107540 X1.3638 Z0.0000 N107550 X1.3631 Y0.7989 Z-0.0001 N107560 X1.3624 Y0.7997 Z0.0000 N107570 X1.3617 Y0.8005 Z-0.0003 N107580 X1.3610 Y0.8013 Z-0.0005 N107590 X1.3603 Y0.8022 Z0.0000 N107600 X1.3596 Y0.8030 N107610 X1.3585 Z-0.0010 N107620 X1.3563 Z-0.0038 N107630 X1.3145 Z-0.0591 N107640 X1.3134 Z-0.0600 N107650 X1.2176 N107660 X1.2165 Z-0.0586 N107670 X1.1846 Z-0.0033 N107680 X1.1824 Z0.0000 N107690 Y0.8080 N107700 X1.1846 Z-0.0033 N107710 X1.2164 Z-0.0582 N107720 X1.2175 Z-0.0600 N107730 X1.3083 N107740 X1.3094 Z-0.0599 N107750 X1.3488 Z-0.0077 N107760 X1.3532 Z-0.0019 N107770 X1.3543 Z-0.0012 N107780 X1.3554 Z-0.0004 N107790 X1.3547 Y0.8088 Z0.0000 N107800 X1.3539 Y0.8097 N107810 X1.3532 Y0.8105 Z-0.0002 N107820 X1.3525 Y0.8113 Z0.0000 N107830 X1.3518 Y0.8122 N107840 X1.3511 Y0.8130 Z-0.0001 N107850 X1.3500 Z-0.0006 N107860 X1.3161 Z-0.0453 N107870 X1.3051 Z-0.0599 N107880 X1.3040 Z-0.0600 N107890 X1.2175 N107900 X1.2153 Z-0.0563 N107910 X1.1846 Z-0.0033 N107920 X1.1824 Z0.0000 N107930 Y0.8180 N107940 X1.1846 Z-0.0033 N107950 X1.2164 Z-0.0583 N107960 X1.2175 Z-0.0600 N107970 X1.3009 N107980 X1.3020 Z-0.0588 N107990 X1.3447 Z-0.0019 N108000 X1.3458 Z-0.0007 N108010 X1.3469 Z-0.0000 N108020 X1.3448 Y0.8205 Z0.0000 N108030 X1.3434 Y0.8222 Z-0.0005 N108040 X1.3427 Y0.8230 Z0.0000 N108050 X1.3416 Z-0.0007 N108060 X1.2988 Z-0.0575 N108070 X1.2977 Z-0.0590 N108080 X1.2966 Z-0.0600 N108090 X1.2176 N108100 X1.2165 Z-0.0584 N108110 X1.1846 Z-0.0033 N108120 X1.1824 Z0.0000 N108130 Y0.8280 N108140 X1.1846 Z-0.0033 N108150 X1.2165 Z-0.0585 N108160 X1.2176 Z-0.0600 N108170 X1.2923 N108180 X1.2934 Z-0.0588 N108190 X1.3363 Z-0.0022 N108200 X1.3374 Z-0.0009 N108210 X1.3385 Z-0.0001 N108220 X1.3378 Y0.8288 Z-0.0004 N108230 X1.3371 Y0.8297 Z0.0000 N108240 X1.3364 Y0.8305 N108250 X1.3357 Y0.8313 Z-0.0004 N108260 X1.3350 Y0.8321 Z0.0000 N108270 X1.3343 Y0.8330 N108280 X1.3332 Z-0.0013 N108290 X1.3321 Z-0.0022 N108300 X1.2891 Z-0.0590 N108310 X1.2880 Z-0.0600 N108320 X1.2176 N108330 X1.2165 Z-0.0586 N108340 X1.1846 Z-0.0033 N108350 X1.1824 Z0.0000 N108360 Y0.8380 N108370 X1.1846 Z-0.0033 N108380 X1.2174 Z-0.0600 N108390 X1.2349 Z-0.0600 N108400 X1.2830 N108410 X1.2841 Z-0.0596 N108420 X1.3136 Z-0.0206 N108430 X1.3278 Z-0.0018 N108440 X1.3289 Z-0.0009 N108450 X1.3300 Z-0.0003 N108460 X1.3293 Y0.8388 Z0.0000 N108470 X1.3272 Y0.8413 N108480 X1.3258 Y0.8430 Z-0.0004 N108490 X1.3247 Z-0.0008 N108500 X1.2974 Z-0.0368 N108510 X1.2809 Z-0.0587 N108520 X1.2798 Z-0.0600 N108530 X1.2175 N108540 X1.1846 Z-0.0033 N108550 X1.1824 Z0.0000 N108560 Y0.8480 N108570 X1.1846 Z-0.0033 N108580 X1.2164 Z-0.0583 N108590 X1.2175 Z-0.0600 N108600 X1.2745 N108610 X1.2756 Z-0.0599 N108620 X1.3205 Z-0.0002 N108630 X1.3216 Z0.0000 N108640 X1.3209 Y0.8488 Z-0.0001 N108650 X1.3202 Y0.8496 Z-0.0003 N108660 X1.3195 Y0.8505 Z0.0000 N108670 X1.3188 Y0.8513 Z-0.0001 N108680 X1.3181 Y0.8521 Z-0.0005 N108690 X1.3174 Y0.8530 Z0.0000 N108700 X1.3163 Z-0.0010 N108710 X1.3152 Z-0.0024 N108720 X1.3130 Z-0.0052 N108730 X1.2724 Z-0.0588 N108740 X1.2713 Z-0.0600 N108750 X1.2175 N108760 X1.2164 Z-0.0583 N108770 X1.1846 Z-0.0033 N108780 X1.1824 Z0.0000 N108790 Y0.8580 N108800 X1.1846 Z-0.0033 N108810 X1.2165 Z-0.0585 N108820 X1.2176 Z-0.0600 N108830 X1.2670 N108840 X1.2681 Z-0.0589 N108850 X1.3121 Z-0.0006 N108860 X1.3132 Z0.0000 N108870 X1.3125 Y0.8588 Z-0.0006 N108880 X1.3117 Y0.8596 Z0.0000 N108890 X1.3096 Y0.8621 N108900 X1.3089 Y0.8629 Z-0.0001 N108910 X1.3078 Z-0.0014 N108920 X1.3067 Z-0.0021 N108930 X1.2704 Z-0.0501 N108940 X1.2671 Z-0.0544 N108950 X1.2660 Z-0.0557 N108960 X1.2176 Z-0.0558 N108970 X1.2154 Z-0.0558 N108980 X1.2143 Z-0.0548 N108990 X1.1846 Z-0.0033 N109000 X1.1824 Z0.0000 N109010 Y0.8679 N109020 X1.1846 Z-0.0033 N109030 X1.2097 Z-0.0466 N109040 X1.2108 Z-0.0469 N109050 X1.2545 Z-0.0470 N109060 X1.2665 Z-0.0469 N109070 X1.2676 Z-0.0469 N109080 X1.2687 Z-0.0465 N109090 X1.3025 Z-0.0020 N109100 X1.3036 Z-0.0008 N109110 X1.3047 Z0.0000 N109120 X1.3033 Y0.8696 N109130 X1.3026 Y0.8704 Z-0.0002 N109140 X1.3019 Y0.8713 Z0.0000 N109150 X1.3012 Y0.8721 Z-0.0003 N109160 X1.3005 Y0.8729 Z-0.0004 N109170 X1.2994 Z-0.0010 N109180 X1.2983 Z-0.0019 N109190 X1.2743 Z-0.0339 N109200 X1.2710 Z-0.0383 N109210 X1.2699 Z-0.0384 N109220 X1.2109 Z-0.0384 N109230 X1.2054 Z-0.0384 N109240 X1.2043 Z-0.0373 N109250 X1.1846 Z-0.0033 N109260 X1.1824 Z0.0000 N109270 Y0.8779 N109280 X1.1846 Z-0.0033 N109290 X1.1999 Z-0.0298 N109300 X1.2602 Z-0.0298 N109310 X1.2711 Z-0.0298 N109320 X1.2722 Z-0.0297 N109330 X1.2733 Z-0.0294 N109340 X1.2952 Z-0.0003 N109350 X1.2963 Z0.0000 N109360 X1.2956 Y0.8788 Z-0.0002 N109370 X1.2949 Y0.8796 Z-0.0006 N109380 X1.2942 Y0.8804 Z0.0000 N109390 X1.2935 Y0.8813 N109400 X1.2928 Y0.8821 Z-0.0002 N109410 X1.2921 Y0.8829 Z0.0000 N109420 X1.2910 Z-0.0008 N109430 X1.2767 Z-0.0196 N109440 X1.2756 Z-0.0210 N109450 X1.2044 Z-0.0211 N109460 X1.1956 Z-0.0210 N109470 X1.1945 Z-0.0204 N109480 X1.1846 Z-0.0033 N109490 X1.1824 Z0.0000 N109500 Y0.8879 N109510 X1.1846 Z-0.0033 N109520 X1.1890 Z-0.0109 N109530 X1.1901 Z-0.0125 N109540 X1.1923 Z-0.0126 N109550 X1.2604 Z-0.0126 N109560 X1.2769 Z-0.0126 N109570 X1.2780 Z-0.0124 N109580 X1.2867 Z-0.0009 N109590 X1.2878 Z0.0000 N109600 X1.2857 Y0.8904 N109610 X1.2850 Y0.8912 Z-0.0001 N109620 X1.2843 Y0.8921 Z0.0000 N109630 X1.2836 Y0.8929 Z-0.0004 N109640 X1.2814 Z-0.0020 N109650 X1.2803 Z-0.0034 N109660 X1.2792 Z-0.0036 N109670 X1.2704 Z-0.0037 N109680 X1.1912 Z-0.0037 N109690 X1.1857 Z-0.0037 N109700 X1.1846 Z-0.0033 N109710 X1.1824 Z0.0000 N109720 G00 Z0.1000 N109730 G00 X0.6323 Y0.7780 N109740 G01 Z-0.0002 F20.0 N109750 G01 X0.6333 Z-0.0006 F60.0 N109760 X0.6344 Z-0.0012 N109770 X0.6355 Z-0.0017 N109780 X0.6377 Z-0.0032 N109790 X0.6399 Z-0.0043 N109800 X0.6421 Z-0.0050 N109810 X0.6442 Z-0.0054 N109820 X0.6453 Z-0.0055 N109830 X0.6464 Z-0.0054 N109840 X0.6486 Z-0.0049 N109850 X0.6508 Z-0.0041 N109860 X0.6530 Z-0.0030 N109870 X0.6551 Z-0.0016 N109880 X0.6562 Z-0.0013 N109890 X0.6573 Z-0.0007 N109900 X0.6584 Z-0.0003 N109910 X0.6587 Y0.7782 Z0.0000 N109920 X0.6607 Y0.7796 N109930 X0.6613 Y0.7800 Z-0.0002 N109940 X0.6619 Y0.7805 Z-0.0001 N109950 X0.6627 Y0.7812 Z-0.0005 N109960 X0.6633 Y0.7818 Z0.0000 N109970 X0.6639 Y0.7824 Z-0.0005 N109980 X0.6645 Y0.7830 Z0.0000 N109990 X0.6634 Z-0.0005 N110000 X0.6601 Z-0.0044 N110010 X0.6568 Z-0.0078 N110020 X0.6546 Z-0.0097 N110030 X0.6524 Z-0.0113 N110040 X0.6502 Z-0.0126 N110050 X0.6491 Z-0.0130 N110060 X0.6480 Z-0.0134 N110070 X0.6469 Z-0.0136 N110080 X0.6458 Z-0.0138 N110090 X0.6447 Z-0.0138 N110100 X0.6436 Z-0.0137 N110110 X0.6425 Z-0.0135 N110120 X0.6414 Z-0.0132 N110130 X0.6403 Z-0.0128 N110140 X0.6392 Z-0.0122 N110150 X0.6381 Z-0.0115 N110160 X0.6359 Z-0.0099 N110170 X0.6337 Z-0.0079 N110180 X0.6304 Z-0.0044 N110190 X0.6282 Z-0.0018 N110200 X0.6271 Z-0.0008 N110210 X0.6260 Z0.0000 N110220 X0.6258 Y0.7832 Z-0.0003 N110230 X0.6253 Y0.7837 Z0.0000 N110240 X0.6248 Y0.7843 Z-0.0003 N110250 X0.6243 Y0.7848 Z0.0000 N110260 X0.6238 Y0.7854 Z-0.0004 N110270 X0.6233 Y0.7860 Z0.0000 N110280 X0.6229 Y0.7866 Z-0.0002 N110290 X0.6223 Y0.7873 Z-0.0002 N110300 X0.6218 Y0.7880 Z0.0000 N110310 X0.6229 Z-0.0014 N110320 X0.6239 Z-0.0023 N110330 X0.6283 Z-0.0080 N110340 X0.6326 Z-0.0134 N110350 X0.6359 Z-0.0170 N110360 X0.6380 Z-0.0191 N110370 X0.6402 Z-0.0209 N110380 X0.6413 Z-0.0216 N110390 X0.6424 Z-0.0222 N110400 X0.6434 Z-0.0226 N110410 X0.6445 Z-0.0228 N110420 X0.6456 Z-0.0228 N110430 X0.6467 Z-0.0226 N110440 X0.6478 Z-0.0223 N110450 X0.6488 Z-0.0218 N110460 X0.6499 Z-0.0212 N110470 X0.6510 Z-0.0205 N110480 X0.6521 Z-0.0197 N110490 X0.6543 Z-0.0177 N110500 X0.6564 Z-0.0153 N110510 X0.6608 Z-0.0098 N110520 X0.6662 Z-0.0024 N110530 X0.6673 Z-0.0009 N110540 X0.6683 Z-0.0004 N110550 X0.6689 Y0.7889 Z0.0000 N110560 X0.6694 Y0.7898 Z-0.0004 N110570 X0.6699 Y0.7907 Z0.0000 N110580 X0.6704 Y0.7916 Z-0.0001 N110590 X0.6709 Y0.7925 Z0.0000 N110600 X0.6711 Y0.7930 Z-0.0002 N110610 X0.6700 Z-0.0012 N110620 X0.6689 Z-0.0026 N110630 X0.6624 Z-0.0126 N110640 X0.6569 Z-0.0204 N110650 X0.6536 Z-0.0248 N110660 X0.6514 Z-0.0275 N110670 X0.6503 Z-0.0286 N110680 X0.6492 Z-0.0295 N110690 X0.6481 Z-0.0303 N110700 X0.6470 Z-0.0308 N110710 X0.6459 Z-0.0311 N110720 X0.6448 Z-0.0311 N110730 X0.6437 Z-0.0310 N110740 X0.6426 Z-0.0305 N110750 X0.6415 Z-0.0297 N110760 X0.6404 Z-0.0287 N110770 X0.6383 Z-0.0265 N110780 X0.6350 Z-0.0225 N110790 X0.6306 Z-0.0166 N110800 X0.6240 Z-0.0073 N110810 X0.6207 Z-0.0025 N110820 X0.6196 Z-0.0010 N110830 X0.6185 Z-0.0002 N110840 X0.6181 Y0.7937 Z-0.0003 N110850 X0.6177 Y0.7943 Z0.0000 N110860 X0.6167 Y0.7958 N110870 X0.6162 Y0.7965 Z-0.0002 N110880 X0.6158 Y0.7973 N110890 X0.6153 Y0.7980 Z0.0000 N110900 X0.6164 Z-0.0012 N110910 X0.6175 Z-0.0026 N110920 X0.6284 Z-0.0185 N110930 X0.6350 Z-0.0280 N110940 X0.6394 Z-0.0340 N110950 X0.6427 Z-0.0380 N110960 X0.6438 Z-0.0392 N110970 X0.6448 Z-0.0401 N110980 X0.6459 Z-0.0399 N110990 X0.6470 Z-0.0389 N111000 X0.6481 Z-0.0377 N111010 X0.6503 Z-0.0348 N111020 X0.6547 Z-0.0286 N111030 X0.6624 Z-0.0169 N111040 X0.6711 Z-0.0031 N111050 X0.6722 Z-0.0014 N111060 X0.6733 Z0.0000 N111070 X0.6736 Y0.7987 Z-0.0003 N111080 X0.6738 Y0.7995 N111090 X0.6741 Y0.8004 Z0.0000 N111100 X0.6744 Y0.8012 N111110 X0.6747 Y0.8021 Z-0.0004 N111120 X0.6750 Y0.8030 Z-0.0003 N111130 X0.6739 Z-0.0008 N111140 X0.6618 Z-0.0206 N111150 X0.6530 Z-0.0347 N111160 X0.6464 Z-0.0448 N111170 X0.6453 Z-0.0464 N111180 X0.6442 Z-0.0456 N111190 X0.6398 Z-0.0394 N111200 X0.6310 Z-0.0265 N111210 X0.6189 Z-0.0088 N111220 X0.6134 Z-0.0007 N111230 X0.6122 Z0.0000 N111240 X0.6119 Y0.8037 N111250 X0.6115 Y0.8043 Z-0.0006 N111260 X0.6110 Y0.8051 Z0.0000 N111270 X0.6101 Y0.8067 N111280 X0.6097 Y0.8074 Z-0.0002 N111290 X0.6093 Y0.8080 Z-0.0002 N111300 X0.6104 Z-0.0009 N111310 X0.6247 Z-0.0222 N111320 X0.6379 Z-0.0415 N111330 X0.6445 Z-0.0511 N111340 X0.6456 Z-0.0503 N111350 X0.6566 Z-0.0324 N111360 X0.6719 Z-0.0066 N111370 X0.6752 Z-0.0011 N111380 X0.6763 Z0.0000 N111390 X0.6767 Y0.8094 N111400 X0.6769 Y0.8102 Z-0.0001 N111410 X0.6771 Y0.8111 Z-0.0005 N111420 X0.6773 Y0.8121 Z-0.0001 N111430 X0.6775 Y0.8130 Z0.0000 N111440 X0.6764 Z-0.0013 N111450 X0.6633 Z-0.0235 N111460 X0.6491 Z-0.0472 N111470 X0.6447 Z-0.0545 N111480 X0.6436 Z-0.0544 N111490 X0.6305 Z-0.0352 N111500 X0.6142 Z-0.0108 N111510 X0.6087 Z-0.0026 N111520 X0.6076 Z-0.0012 N111530 X0.6065 Z0.0000 N111540 X0.6063 Y0.8135 N111550 X0.6060 Y0.8140 Z-0.0003 N111560 X0.6055 Y0.8148 Z0.0000 N111570 X0.6038 Y0.8180 Z-0.0002 N111580 X0.6049 Z-0.0009 N111590 X0.6214 Z-0.0258 N111600 X0.6378 Z-0.0505 N111610 X0.6433 Z-0.0586 N111620 X0.6444 Z-0.0570 N111630 X0.6653 Z-0.0215 N111640 X0.6773 Z-0.0009 N111650 X0.6784 Z0.0000 N111660 X0.6790 Y0.8213 N111670 X0.6793 Y0.8230 Z-0.0006 N111680 X0.6782 Z-0.0012 N111690 X0.6518 Z-0.0463 N111700 X0.6441 Z-0.0594 N111710 X0.6430 Z-0.0600 N111720 X0.6419 N111730 X0.6408 Z-0.0595 N111740 X0.6254 Z-0.0364 N111750 X0.6067 Z-0.0078 N111760 X0.6023 Z-0.0011 N111770 X0.6012 Z0.0000 N111780 X0.6009 Y0.8235 N111790 X0.6007 Y0.8240 Z-0.0004 N111800 X0.6002 Y0.8249 Z-0.0000 N111810 X0.5998 Y0.8257 Z0.0000 N111820 X0.5994 Y0.8266 Z-0.0005 N111830 X0.5990 Y0.8273 Z0.0000 N111840 X0.5986 Y0.8280 N111850 X0.5997 Z-0.0013 N111860 X0.6008 Z-0.0028 N111870 X0.6206 Z-0.0332 N111880 X0.6382 Z-0.0599 N111890 X0.6404 Z-0.0600 N111900 X0.6437 N111910 X0.6448 Z-0.0597 N111920 X0.6778 Z-0.0032 N111930 X0.6800 Z0.0000 N111940 X0.6801 Y0.8288 N111950 X0.6802 Y0.8295 Z-0.0002 N111960 X0.6803 Y0.8303 N111970 X0.6804 Y0.8312 Z-0.0005 N111980 X0.6805 Y0.8321 Z-0.0003 N111990 X0.6806 Y0.8330 Z-0.0001 N112000 X0.6795 Z-0.0010 N112010 X0.6455 Z-0.0596 N112020 X0.6444 Z-0.0600 N112030 X0.6367 N112040 X0.6356 Z-0.0599 N112050 X0.6159 Z-0.0296 N112060 X0.5983 Z-0.0025 N112070 X0.5972 Z-0.0012 N112080 X0.5961 Z-0.0005 N112090 X0.5957 Y0.8337 Z0.0000 N112100 X0.5954 Y0.8344 N112110 X0.5949 Y0.8353 Z-0.0005 N112120 X0.5945 Y0.8362 Z0.0000 N112130 X0.5940 Y0.8370 Z-0.0001 N112140 X0.5935 Y0.8380 Z0.0000 N112150 X0.5946 Z-0.0007 N112160 X0.6099 Z-0.0244 N112170 X0.6318 Z-0.0584 N112180 X0.6329 Z-0.0600 N112190 X0.6450 N112200 X0.6461 Z-0.0596 N112210 X0.6789 Z-0.0032 N112220 X0.6800 Z-0.0014 N112230 X0.6811 Z0.0000 N112240 X0.6812 Y0.8389 Z-0.0000 N112250 X0.6815 Y0.8415 Z-0.0006 N112260 X0.6816 Y0.8430 Z-0.0003 N112270 X0.6805 Z-0.0010 N112280 X0.6575 Z-0.0406 N112290 X0.6465 Z-0.0596 N112300 X0.6454 Z-0.0600 N112310 X0.6312 N112320 X0.6301 Z-0.0596 N112330 X0.6104 Z-0.0291 N112340 X0.5961 Z-0.0074 N112350 X0.5929 Z-0.0025 N112360 X0.5918 Z-0.0012 N112370 X0.5907 Z-0.0004 N112380 X0.5901 Y0.8439 Z0.0000 N112390 X0.5895 Y0.8449 Z-0.0004 N112400 X0.5890 Y0.8457 Z0.0000 N112410 X0.5885 Y0.8466 Z-0.0000 N112420 X0.5876 Y0.8480 Z0.0000 N112430 X0.5887 Z-0.0010 N112440 X0.5920 Z-0.0058 N112450 X0.6063 Z-0.0271 N112460 X0.6206 Z-0.0487 N112470 X0.6271 Z-0.0589 N112480 X0.6282 Z-0.0600 N112490 X0.6469 N112500 X0.6765 Z-0.0090 N112510 X0.6809 Z-0.0014 N112520 X0.6820 Z0.0000 N112530 X0.6823 Y0.8520 Z-0.0000 N112540 X0.6824 Y0.8530 Z-0.0002 N112550 X0.6813 Z-0.0013 N112560 X0.6482 Z-0.0583 N112570 X0.6471 Z-0.0600 N112580 X0.6262 N112590 X0.6251 Z-0.0599 N112600 X0.6119 Z-0.0398 N112610 X0.5998 Z-0.0218 N112620 X0.5877 Z-0.0040 N112630 X0.5866 Z-0.0025 N112640 X0.5855 Z-0.0014 N112650 X0.5844 Z0.0000 N112660 X0.5839 Y0.8537 Z-0.0003 N112670 X0.5834 Y0.8544 Z0.0000 N112680 X0.5830 Y0.8551 Z-0.0004 N112690 X0.5824 Y0.8559 Z0.0000 N112700 X0.5812 Y0.8575 N112710 X0.5809 Y0.8580 Z-0.0001 N112720 X0.5820 Z-0.0011 N112730 X0.5831 Z-0.0022 N112740 X0.5940 Z-0.0178 N112750 X0.6072 Z-0.0369 N112760 X0.6203 Z-0.0563 N112770 X0.6225 Z-0.0596 N112780 X0.6236 Z-0.0600 N112790 X0.6466 N112800 X0.6477 Z-0.0597 N112810 X0.6663 Z-0.0274 N112820 X0.6816 Z-0.0010 N112830 X0.6827 Z-0.0003 N112840 X0.6828 Y0.8609 Z0.0000 N112850 X0.6830 Y0.8629 N112860 X0.6819 Z-0.0012 N112870 X0.6633 Z-0.0335 N112880 X0.6480 Z-0.0599 N112890 X0.6469 Z-0.0600 N112900 X0.6197 N112910 X0.6186 Z-0.0586 N112920 X0.6066 Z-0.0410 N112930 X0.5924 Z-0.0205 N112940 X0.5815 Z-0.0052 N112950 X0.5782 Z-0.0007 N112960 X0.5771 Z-0.0001 N112970 X0.5766 Y0.8636 Z-0.0003 N112980 X0.5761 Y0.8642 N112990 X0.5756 Y0.8648 Z-0.0000 N113000 X0.5737 Y0.8672 Z0.0000 N113010 X0.5730 Y0.8679 Z-0.0002 N113020 X0.5741 Z-0.0008 N113030 X0.5752 Z-0.0018 N113040 X0.5839 Z-0.0135 N113050 X0.5948 Z-0.0285 N113060 X0.6046 Z-0.0424 N113070 X0.6166 Z-0.0599 N113080 X0.6188 Z-0.0600 N113090 X0.6472 N113100 X0.6483 Z-0.0597 N113110 X0.6810 Z-0.0033 N113120 X0.6832 Z0.0000 N113130 X0.6833 Y0.8729 N113140 X0.6823 Z-0.0014 N113150 X0.6483 Z-0.0599 N113160 X0.6472 Z-0.0600 N113170 X0.6133 N113180 X0.6111 Z-0.0570 N113190 X0.6024 Z-0.0445 N113200 X0.5936 Z-0.0323 N113210 X0.5838 Z-0.0191 N113220 X0.5750 Z-0.0076 N113230 X0.5696 Z-0.0007 N113240 X0.5685 Z-0.0003 N113250 X0.5680 Y0.8734 Z-0.0002 N113260 X0.5668 Y0.8746 Z-0.0003 N113270 X0.5660 Y0.8753 Z0.0000 N113280 X0.5653 Y0.8759 Z-0.0005 N113290 X0.5645 Y0.8766 Z0.0000 N113300 X0.5638 Y0.8772 N113310 X0.5629 Y0.8779 Z-0.0003 N113320 X0.5640 Z-0.0005 N113330 X0.5651 Z-0.0012 N113340 X0.5706 Z-0.0075 N113350 X0.5771 Z-0.0156 N113360 X0.5859 Z-0.0271 N113370 X0.5958 Z-0.0404 N113380 X0.6078 Z-0.0571 N113390 X0.6089 Z-0.0587 N113400 X0.6100 Z-0.0600 N113410 X0.6473 N113420 X0.6484 Z-0.0600 N113430 X0.6824 Z-0.0012 N113440 X0.6835 Z-0.0003 N113450 X0.6836 Y0.8829 Z-0.0004 N113460 X0.6825 Z-0.0011 N113470 X0.6496 Z-0.0582 N113480 X0.6485 Z-0.0600 N113490 X0.6067 N113500 X0.6056 Z-0.0594 N113510 X0.5968 Z-0.0474 N113520 X0.5869 Z-0.0343 N113530 X0.5792 Z-0.0245 N113540 X0.5737 Z-0.0179 N113550 X0.5682 Z-0.0117 N113560 X0.5638 Z-0.0072 N113570 X0.5605 Z-0.0040 N113580 X0.5572 Z-0.0011 N113590 X0.5561 Z-0.0002 N113600 X0.5550 Z0.0000 N113610 G00 Z0.1000 N113620 G00 X0.7049 Y1.4223 N113630 G01 Z-0.0001 F20.0 N113640 G01 X0.7060 Z-0.0002 F60.0 N113650 X0.7126 Z-0.0006 N113660 X0.7268 Z-0.0012 N113670 X0.7377 Z-0.0013 N113680 X0.7847 N113690 X0.7956 Z-0.0009 N113700 X0.8043 Z-0.0004 N113710 X0.8087 Z-0.0000 N113720 G00 Z0.1000 N113730 G00 X0.3805 Y1.4323 N113740 G01 Z-0.0000 F20.0 N113750 G01 X0.3816 Z-0.0013 F60.0 N113760 X0.4146 Z-0.0586 N113770 X0.4157 Z-0.0600 N113780 X0.5765 N113790 X0.5776 Z-0.0594 N113800 X0.5865 Z-0.0451 N113810 X0.5942 Z-0.0330 N113820 X0.5997 Z-0.0249 N113830 X0.6030 Z-0.0203 N113840 X0.6063 Z-0.0162 N113850 X0.6074 Z-0.0150 N113860 X0.6085 Z-0.0140 N113870 X0.6096 Z-0.0131 N113880 X0.6107 Z-0.0124 N113890 X0.6129 Z-0.0114 N113900 X0.6140 Z-0.0112 N113910 X0.6162 Z-0.0112 N113920 X0.6217 Z-0.0113 N113930 X0.6316 Z-0.0116 N113940 X0.6459 Z-0.0121 N113950 X0.6602 Z-0.0129 N113960 X0.6801 Z-0.0143 N113970 X0.6867 Z-0.0147 N113980 X0.6966 Z-0.0159 N113990 X0.7054 Z-0.0168 N114000 X0.7142 Z-0.0174 N114010 X0.7263 Z-0.0179 N114020 X0.7395 Z-0.0181 N114030 X0.7660 Z-0.0182 N114040 X0.7792 Z-0.0181 N114050 X0.7902 Z-0.0178 N114060 X0.8001 Z-0.0173 N114070 X0.8089 Z-0.0167 N114080 X0.8177 Z-0.0159 N114090 X0.8265 Z-0.0148 N114100 X0.8486 Z-0.0133 N114110 X0.8640 Z-0.0123 N114120 X0.8783 Z-0.0117 N114130 X0.8904 Z-0.0113 N114140 X0.8981 Z-0.0112 N114150 X0.9003 Z-0.0113 N114160 X0.9014 Z-0.0116 N114170 X0.9036 Z-0.0127 N114180 X0.9047 Z-0.0135 N114190 X0.9058 Z-0.0145 N114200 X0.9080 Z-0.0169 N114210 X0.9113 Z-0.0211 N114220 X0.9157 Z-0.0273 N114230 X0.9224 Z-0.0373 N114240 X0.9312 Z-0.0514 N114250 X0.9356 Z-0.0585 N114260 X0.9367 Z-0.0600 N114270 X0.9532 N114280 X0.9543 Z-0.0586 N114290 X0.9873 Z-0.0013 N114300 X0.9884 Z0.0000 N114310 Y1.4373 N114320 X0.9873 Z-0.0013 N114330 X0.9543 Z-0.0586 N114340 X0.9532 Z-0.0600 N114350 X0.9356 N114360 X0.9345 Z-0.0597 N114370 X0.9279 Z-0.0496 N114380 X0.9224 Z-0.0415 N114390 X0.9168 Z-0.0339 N114400 X0.9135 Z-0.0297 N114410 X0.9113 Z-0.0272 N114420 X0.9080 Z-0.0239 N114430 X0.9058 Z-0.0220 N114440 X0.9047 Z-0.0212 N114450 X0.9036 Z-0.0206 N114460 X0.9025 Z-0.0201 N114470 X0.9014 Z-0.0198 N114480 X0.9003 Z-0.0196 N114490 X0.8981 Z-0.0195 N114500 X0.8827 Z-0.0198 N114510 X0.8695 Z-0.0204 N114520 X0.8552 Z-0.0211 N114530 X0.8298 Z-0.0228 N114540 X0.8254 Z-0.0231 N114550 X0.8188 Z-0.0240 N114560 X0.8100 Z-0.0249 N114570 X0.8012 Z-0.0256 N114580 X0.7913 Z-0.0261 N114590 X0.7803 Z-0.0264 N114600 X0.7660 Z-0.0265 N114610 X0.7428 Z-0.0265 N114620 X0.7307 Z-0.0263 N114630 X0.7197 Z-0.0260 N114640 X0.7098 Z-0.0254 N114650 X0.6999 Z-0.0246 N114660 X0.6911 Z-0.0235 N114670 X0.6867 Z-0.0230 N114680 X0.6591 Z-0.0212 N114690 X0.6459 Z-0.0204 N114700 X0.6316 Z-0.0199 N114710 X0.6184 Z-0.0196 N114720 X0.6151 Z-0.0195 N114730 X0.6129 Z-0.0196 N114740 X0.6118 Z-0.0199 N114750 X0.6107 Z-0.0203 N114760 X0.6085 Z-0.0216 N114770 X0.6063 Z-0.0233 N114780 X0.6030 Z-0.0266 N114790 X0.5997 Z-0.0304 N114800 X0.5964 Z-0.0346 N114810 X0.5920 Z-0.0406 N114820 X0.5854 Z-0.0504 N114830 X0.5798 Z-0.0589 N114840 X0.5787 Z-0.0600 N114850 X0.4157 N114860 X0.4146 Z-0.0586 N114870 X0.3816 Z-0.0013 N114880 X0.3805 Z-0.0000 N114890 Y1.4423 Z-0.0000 N114900 X0.3816 Z-0.0013 N114910 X0.4146 Z-0.0586 N114920 X0.4157 Z-0.0600 N114930 X0.5809 N114940 X0.5820 Z-0.0600 N114950 X0.5876 Z-0.0520 N114960 X0.5920 Z-0.0461 N114970 X0.5953 Z-0.0419 N114980 X0.5986 Z-0.0381 N114990 X0.6008 Z-0.0358 N115000 X0.6030 Z-0.0337 N115010 X0.6052 Z-0.0320 N115020 X0.6074 Z-0.0306 N115030 X0.6096 Z-0.0296 N115040 X0.6107 Z-0.0292 N115050 X0.6118 Z-0.0289 N115060 X0.6129 Z-0.0287 N115070 X0.6151 Z-0.0285 N115080 X0.6316 Z-0.0289 N115090 X0.6448 Z-0.0294 N115100 X0.6591 Z-0.0302 N115110 X0.6790 Z-0.0315 N115120 X0.6867 Z-0.0320 N115130 X0.6977 Z-0.0334 N115140 X0.7065 Z-0.0342 N115150 X0.7153 Z-0.0348 N115160 X0.7263 Z-0.0353 N115170 X0.7384 Z-0.0355 N115180 X0.7583 Z-0.0355 N115190 X0.7737 Z-0.0355 N115200 X0.7858 Z-0.0353 N115210 X0.7968 Z-0.0349 N115220 X0.8056 Z-0.0343 N115230 X0.8144 Z-0.0335 N115240 X0.8210 Z-0.0328 N115250 X0.8254 Z-0.0322 N115260 X0.8442 Z-0.0309 N115270 X0.8629 Z-0.0297 N115280 X0.8772 Z-0.0291 N115290 X0.8904 Z-0.0287 N115300 X0.8981 Z-0.0286 N115310 X0.9003 Z-0.0286 N115320 X0.9014 Z-0.0288 N115330 X0.9025 Z-0.0290 N115340 X0.9036 Z-0.0294 N115350 X0.9058 Z-0.0303 N115360 X0.9069 Z-0.0309 N115370 X0.9080 Z-0.0316 N115380 X0.9102 Z-0.0333 N115390 X0.9124 Z-0.0353 N115400 X0.9157 Z-0.0387 N115410 X0.9190 Z-0.0426 N115420 X0.9235 Z-0.0483 N115430 X0.9290 Z-0.0560 N115440 X0.9312 Z-0.0591 N115450 X0.9323 Z-0.0600 N115460 X0.9532 N115470 X0.9543 Z-0.0586 N115480 X0.9873 Z-0.0013 N115490 X0.9884 Z0.0000 N115500 Y1.4473 N115510 X0.9873 Z-0.0013 N115520 X0.9543 Z-0.0586 N115530 X0.9532 Z-0.0600 N115540 X0.9290 N115550 X0.9279 Z-0.0596 N115560 X0.9235 Z-0.0540 N115570 X0.9190 Z-0.0490 N115580 X0.9157 Z-0.0457 N115590 X0.9124 Z-0.0427 N115600 X0.9102 Z-0.0410 N115610 X0.9080 Z-0.0395 N115620 X0.9058 Z-0.0383 N115630 X0.9036 Z-0.0375 N115640 X0.9014 Z-0.0370 N115650 X0.8992 Z-0.0369 N115660 X0.8882 Z-0.0371 N115670 X0.8761 Z-0.0374 N115680 X0.8618 Z-0.0381 N115690 X0.8431 Z-0.0393 N115700 X0.8298 Z-0.0402 N115710 X0.8254 Z-0.0405 N115720 X0.8177 Z-0.0415 N115730 X0.8089 Z-0.0423 N115740 X0.8001 Z-0.0430 N115750 X0.7902 Z-0.0434 N115760 X0.7781 Z-0.0437 N115770 X0.7638 Z-0.0438 N115780 X0.7428 Z-0.0438 N115790 X0.7307 Z-0.0437 N115800 X0.7197 Z-0.0433 N115810 X0.7109 Z-0.0428 N115820 X0.7021 Z-0.0421 N115830 X0.6933 Z-0.0411 N115840 X0.6878 Z-0.0404 N115850 X0.6646 Z-0.0389 N115860 X0.6492 Z-0.0379 N115870 X0.6360 Z-0.0374 N115880 X0.6239 Z-0.0370 N115890 X0.6173 Z-0.0369 N115900 X0.6151 Z-0.0368 N115910 X0.6129 Z-0.0370 N115920 X0.6118 Z-0.0371 N115930 X0.6107 Z-0.0373 N115940 X0.6096 Z-0.0377 N115950 X0.6085 Z-0.0381 N115960 X0.6063 Z-0.0392 N115970 X0.6041 Z-0.0405 N115980 X0.6019 Z-0.0422 N115990 X0.5986 Z-0.0451 N116000 X0.5953 Z-0.0484 N116010 X0.5909 Z-0.0534 N116020 X0.5865 Z-0.0589 N116030 X0.5854 Z-0.0600 N116040 X0.4157 N116050 X0.4146 Z-0.0586 N116060 X0.3816 Z-0.0013 N116070 X0.3805 Z-0.0000 N116080 Y1.4523 Z-0.0000 N116090 X0.3816 Z-0.0013 N116100 X0.4146 Z-0.0586 N116110 X0.4157 Z-0.0600 N116120 X0.5898 N116130 X0.5909 Z-0.0600 N116140 X0.5942 Z-0.0566 N116150 X0.5975 Z-0.0535 N116160 X0.6008 Z-0.0509 N116170 X0.6030 Z-0.0495 N116180 X0.6052 Z-0.0483 N116190 X0.6074 Z-0.0473 N116200 X0.6096 Z-0.0466 N116210 X0.6118 Z-0.0461 N116220 X0.6140 Z-0.0459 N116230 X0.6162 Z-0.0459 N116240 X0.6250 Z-0.0461 N116250 X0.6349 Z-0.0464 N116260 X0.6503 Z-0.0471 N116270 X0.6691 Z-0.0482 N116280 X0.6856 Z-0.0493 N116290 X0.6878 Z-0.0494 N116300 X0.6977 Z-0.0507 N116310 X0.7065 Z-0.0515 N116320 X0.7153 Z-0.0521 N116330 X0.7263 Z-0.0526 N116340 X0.7384 Z-0.0528 N116350 X0.7594 Z-0.0529 N116360 X0.7748 Z-0.0528 N116370 X0.7869 Z-0.0526 N116380 X0.7979 Z-0.0522 N116390 X0.8067 Z-0.0516 N116400 X0.8155 Z-0.0507 N116410 X0.8221 Z-0.0499 N116420 X0.8254 Z-0.0495 N116430 X0.8497 Z-0.0479 N116440 X0.8640 Z-0.0470 N116450 X0.8772 Z-0.0464 N116460 X0.8904 Z-0.0461 N116470 X0.8981 Z-0.0459 N116480 X0.9003 Z-0.0460 N116490 X0.9025 Z-0.0462 N116500 X0.9047 Z-0.0468 N116510 X0.9080 Z-0.0481 N116520 X0.9102 Z-0.0492 N116530 X0.9124 Z-0.0505 N116540 X0.9146 Z-0.0522 N116550 X0.9179 Z-0.0550 N116560 X0.9213 Z-0.0583 N116570 X0.9224 Z-0.0594 N116580 X0.9235 Z-0.0600 N116590 X0.9532 N116600 X0.9543 Z-0.0586 N116610 X0.9873 Z-0.0013 N116620 X0.9884 Z0.0000 N116630 Y1.4573 N116640 X0.9873 Z-0.0013 N116650 X0.9543 Z-0.0586 N116660 X0.9532 Z-0.0600 N116670 X0.9157 N116680 X0.9146 Z-0.0599 N116690 X0.9124 Z-0.0584 N116700 X0.9102 Z-0.0571 N116710 X0.9080 Z-0.0561 N116720 X0.9058 Z-0.0553 N116730 X0.9036 Z-0.0547 N116740 X0.9014 Z-0.0544 N116750 X0.8981 Z-0.0542 N116760 X0.8816 Z-0.0546 N116770 X0.8673 Z-0.0552 N116780 X0.8519 Z-0.0560 N116790 X0.8298 Z-0.0575 N116800 X0.8243 Z-0.0579 N116810 X0.8177 Z-0.0588 N116820 X0.8089 Z-0.0597 N116830 X0.8045 Z-0.0600 N116840 X0.7087 N116850 X0.6999 Z-0.0592 N116860 X0.6900 Z-0.0580 N116870 X0.6878 Z-0.0577 N116880 X0.6613 Z-0.0560 N116890 X0.6470 Z-0.0552 N116900 X0.6327 Z-0.0546 N116910 X0.6184 Z-0.0543 N116920 X0.6151 Z-0.0542 N116930 X0.6118 Z-0.0544 N116940 X0.6096 Z-0.0548 N116950 X0.6074 Z-0.0554 N116960 X0.6052 Z-0.0563 N116970 X0.6019 Z-0.0581 N116980 X0.5997 Z-0.0595 N116990 X0.5986 Z-0.0600 N117000 X0.4157 N117010 X0.4146 Z-0.0586 N117020 X0.3816 Z-0.0013 N117030 X0.3805 Z-0.0000 N117040 Y1.4623 Z-0.0000 N117050 X0.3816 Z-0.0013 N117060 X0.4146 Z-0.0586 N117070 X0.4157 Z-0.0600 N117080 X0.9532 N117090 X0.9543 Z-0.0586 N117100 X0.9873 Z-0.0013 N117110 X0.9884 Z0.0000 N117120 Y1.4673 N117130 X0.9873 Z-0.0013 N117140 X0.9543 Z-0.0586 N117150 X0.9532 Z-0.0600 N117160 X0.4157 N117170 X0.4146 Z-0.0586 N117180 X0.3816 Z-0.0013 N117190 X0.3805 Z-0.0000 N117200 Y1.4723 Z-0.0000 N117210 X0.3816 Z-0.0013 N117220 X0.4146 Z-0.0586 N117230 X0.4157 Z-0.0600 N117240 X0.9532 N117250 X0.9543 Z-0.0586 N117260 X0.9873 Z-0.0013 N117270 X0.9884 Z0.0000 N117280 Y1.4773 N117290 X0.9873 Z-0.0013 N117300 X0.9543 Z-0.0586 N117310 X0.9532 Z-0.0600 N117320 X0.4157 N117330 X0.4146 Z-0.0586 N117340 X0.3816 Z-0.0013 N117350 X0.3805 Z-0.0000 N117360 Y1.4823 Z-0.0000 N117370 X0.3816 Z-0.0013 N117380 X0.4146 Z-0.0586 N117390 X0.4157 Z-0.0600 N117400 X0.9532 N117410 X0.9543 Z-0.0586 N117420 X0.9873 Z-0.0013 N117430 X0.9884 Z0.0000 N117440 Y1.4873 N117450 X0.9873 Z-0.0013 N117460 X0.9543 Z-0.0586 N117470 X0.9532 Z-0.0600 N117480 X0.4157 N117490 X0.4146 Z-0.0586 N117500 X0.3816 Z-0.0013 N117510 X0.3805 Z-0.0000 N117520 Y1.4922 Z-0.0000 N117530 X0.3816 Z-0.0013 N117540 X0.4146 Z-0.0586 N117550 X0.4157 Z-0.0600 N117560 X0.9532 N117570 X0.9543 Z-0.0586 N117580 X0.9873 Z-0.0013 N117590 X0.9884 Z0.0000 N117600 Y1.4972 N117610 X0.9873 Z-0.0013 N117620 X0.9543 Z-0.0586 N117630 X0.9532 Z-0.0600 N117640 X0.4157 N117650 X0.4146 Z-0.0586 N117660 X0.3816 Z-0.0013 N117670 X0.3805 Z-0.0000 N117680 Y1.5022 Z-0.0000 N117690 X0.3816 Z-0.0013 N117700 X0.4146 Z-0.0586 N117710 X0.4157 Z-0.0600 N117720 X0.9532 N117730 X0.9543 Z-0.0586 N117740 X0.9873 Z-0.0013 N117750 X0.9884 Z0.0000 N117760 Y1.5072 N117770 X0.9873 Z-0.0013 N117780 X0.9543 Z-0.0586 N117790 X0.9532 Z-0.0600 N117800 X0.4157 N117810 X0.4146 Z-0.0586 N117820 X0.3816 Z-0.0013 N117830 X0.3805 Z-0.0000 N117840 Y1.5122 Z-0.0000 N117850 X0.3816 Z-0.0013 N117860 X0.4146 Z-0.0586 N117870 X0.4157 Z-0.0600 N117880 X0.9532 N117890 X0.9543 Z-0.0586 N117900 X0.9873 Z-0.0013 N117910 X0.9884 Z0.0000 N117920 Y1.5172 N117930 X0.9873 Z-0.0013 N117940 X0.9543 Z-0.0586 N117950 X0.9532 Z-0.0600 N117960 X0.4157 N117970 X0.4146 Z-0.0586 N117980 X0.3816 Z-0.0013 N117990 X0.3805 Z-0.0000 N118000 Y1.5222 Z-0.0000 N118010 X0.3816 Z-0.0013 N118020 X0.4146 Z-0.0586 N118030 X0.4157 Z-0.0600 N118040 X0.9532 N118050 X0.9543 Z-0.0586 N118060 X0.9873 Z-0.0013 N118070 X0.9884 Z0.0000 N118080 Y1.5272 N118090 X0.9873 Z-0.0013 N118100 X0.9543 Z-0.0586 N118110 X0.9532 Z-0.0600 N118120 X0.4157 N118130 X0.4146 Z-0.0586 N118140 X0.3816 Z-0.0013 N118150 X0.3805 Z-0.0000 N118160 Y1.5322 Z-0.0000 N118170 X0.3816 Z-0.0013 N118180 X0.4146 Z-0.0586 N118190 X0.4157 Z-0.0600 N118200 X0.9532 N118210 X0.9543 Z-0.0586 N118220 X0.9873 Z-0.0013 N118230 X0.9884 Z0.0000 N118240 Y1.5372 N118250 X0.9873 Z-0.0013 N118260 X0.9543 Z-0.0586 N118270 X0.9532 Z-0.0600 N118280 X0.4157 N118290 X0.4146 Z-0.0586 N118300 X0.3816 Z-0.0013 N118310 X0.3805 Z-0.0000 N118320 Y1.5422 Z-0.0000 N118330 X0.3816 Z-0.0013 N118340 X0.4146 Z-0.0586 N118350 X0.4157 Z-0.0600 N118360 X0.9532 N118370 X0.9543 Z-0.0586 N118380 X0.9873 Z-0.0013 N118390 X0.9884 Z0.0000 N118400 Y1.5472 N118410 X0.9873 Z-0.0013 N118420 X0.9543 Z-0.0586 N118430 X0.9532 Z-0.0600 N118440 X0.4157 N118450 X0.4146 Z-0.0586 N118460 X0.3816 Z-0.0013 N118470 X0.3805 Z-0.0000 N118480 Y1.5522 Z-0.0000 N118490 X0.3816 Z-0.0013 N118500 X0.4146 Z-0.0586 N118510 X0.4157 Z-0.0600 N118520 X0.9532 N118530 X0.9543 Z-0.0586 N118540 X0.9862 Z-0.0033 N118550 X0.9873 Z-0.0014 N118560 X0.9884 Z0.0000 N118570 X0.9884 Y1.5572 N118580 X0.9873 Z-0.0015 N118590 X0.9851 Z-0.0052 N118600 X0.9542 Z-0.0586 N118610 X0.9531 Z-0.0600 N118620 X0.4157 N118630 X0.4146 Z-0.0585 N118640 X0.3816 Z-0.0013 N118650 X0.3805 Z-0.0000 N118660 Y1.5622 Z-0.0000 N118670 X0.3816 Z-0.0013 N118680 X0.4146 Z-0.0585 N118690 X0.4157 Z-0.0600 N118700 X0.9530 N118710 X0.9541 Z-0.0586 N118720 X0.9860 Z-0.0034 N118730 X0.9871 Z-0.0015 N118740 X0.9882 Z0.0000 N118750 X0.9880 Y1.5672 N118760 X0.9869 Z-0.0011 N118770 X0.9539 Z-0.0583 N118780 X0.9528 Z-0.0600 N118790 X0.4157 N118800 X0.4146 Z-0.0585 N118810 X0.3816 Z-0.0013 N118820 X0.3805 Z-0.0000 N118830 Y1.5722 Z-0.0000 N118840 X0.3816 Z-0.0013 N118850 X0.4146 Z-0.0585 N118860 X0.4157 Z-0.0600 N118870 X0.9514 N118880 X0.9525 Z-0.0599 N118890 X0.9866 Z-0.0011 N118900 X0.9877 Z-0.0004 N118910 X0.9876 Y1.5730 Z-0.0005 N118920 X0.9876 Y1.5739 Z-0.0004 N118930 X0.9875 Y1.5748 N118940 X0.9873 Y1.5772 Z0.0000 N118950 X0.9862 Z-0.0013 N118960 X0.9807 Z-0.0107 N118970 X0.9532 Z-0.0582 N118980 X0.9521 Z-0.0600 N118990 X0.4157 N119000 X0.4146 Z-0.0586 N119010 X0.3816 Z-0.0013 N119020 X0.3805 Z-0.0000 N119030 Y1.5821 Z-0.0000 N119040 X0.3816 Z-0.0013 N119050 X0.4146 Z-0.0585 N119060 X0.4157 Z-0.0600 N119070 X0.9505 N119080 X0.9516 Z-0.0597 N119090 X0.9857 Z-0.0010 N119100 X0.9868 Z0.0000 N119110 X0.9868 Y1.5826 N119120 X0.9865 Y1.5844 Z-0.0006 N119130 X0.9863 Y1.5862 Z-0.0001 N119140 X0.9862 Y1.5871 Z0.0000 N119150 X0.9851 Z-0.0014 N119160 X0.9840 Z-0.0031 N119170 X0.9521 Z-0.0578 N119180 X0.9510 Z-0.0596 N119190 X0.9499 Z-0.0600 N119200 X0.4157 N119210 X0.4146 Z-0.0586 N119220 X0.3816 Z-0.0013 N119230 X0.3805 Z-0.0000 N119240 Y1.5921 Z-0.0000 N119250 X0.3816 Z-0.0013 N119260 X0.4146 Z-0.0584 N119270 X0.4157 Z-0.0600 N119280 X0.9491 N119290 X0.9502 Z-0.0590 N119300 X0.9744 Z-0.0181 N119310 X0.9843 Z-0.0012 N119320 X0.9854 Z-0.0005 N119330 X0.9853 Y1.5929 Z-0.0002 N119340 X0.9852 Y1.5936 Z-0.0001 N119350 X0.9850 Y1.5945 Z0.0000 N119360 X0.9846 Y1.5962 N119370 X0.9845 Y1.5971 Z-0.0003 N119380 X0.9834 Z-0.0009 N119390 X0.9614 Z-0.0379 N119400 X0.9504 Z-0.0561 N119410 X0.9482 Z-0.0597 N119420 X0.9471 Z-0.0600 N119430 X0.4157 N119440 X0.4146 Z-0.0585 N119450 X0.3816 Z-0.0013 N119460 X0.3805 Z-0.0000 N119470 Y1.6021 Z-0.0000 N119480 X0.3816 Z-0.0013 N119490 X0.4146 Z-0.0585 N119500 X0.4157 Z-0.0600 N119510 X0.9316 N119520 X0.9360 Z-0.0584 N119530 X0.9404 Z-0.0566 N119540 X0.9437 Z-0.0551 N119550 X0.9470 Z-0.0533 N119560 X0.9492 Z-0.0519 N119570 X0.9514 Z-0.0504 N119580 X0.9525 Z-0.0495 N119590 X0.9580 Z-0.0409 N119600 X0.9690 Z-0.0230 N119610 X0.9822 Z-0.0011 N119620 X0.9833 Z-0.0005 N119630 X0.9828 Y1.6038 Z0.0000 N119640 X0.9823 Y1.6055 Z-0.0001 N119650 X0.9821 Y1.6063 Z-0.0004 N119660 X0.9818 Y1.6071 Z0.0000 N119670 X0.9807 Z-0.0014 N119680 X0.9796 Z-0.0030 N119690 X0.9697 Z-0.0191 N119700 X0.9620 Z-0.0313 N119710 X0.9598 Z-0.0346 N119720 X0.9576 Z-0.0375 N119730 X0.9565 Z-0.0388 N119740 X0.9554 Z-0.0400 N119750 X0.9532 Z-0.0417 N119760 X0.9499 Z-0.0439 N119770 X0.9477 Z-0.0452 N119780 X0.9444 Z-0.0470 N119790 X0.9411 Z-0.0485 N119800 X0.9367 Z-0.0502 N119810 X0.9312 Z-0.0521 N119820 X0.9256 Z-0.0537 N119830 X0.9190 Z-0.0554 N119840 X0.9135 Z-0.0566 N119850 X0.9069 Z-0.0579 N119860 X0.9003 Z-0.0590 N119870 X0.8937 Z-0.0600 N119880 X0.7814 Z-0.0600 N119890 X0.6602 N119900 X0.5325 N119910 X0.4157 N119920 X0.4146 Z-0.0586 N119930 X0.3816 Z-0.0013 N119940 X0.3805 Z-0.0000 N119950 Y1.6121 Z-0.0000 N119960 X0.3816 Z-0.0013 N119970 X0.4146 Z-0.0584 N119980 X0.4157 Z-0.0600 N119990 X0.8699 N120000 X0.8710 Z-0.0595 N120010 X0.8732 Z-0.0577 N120020 X0.8754 Z-0.0562 N120030 X0.8776 Z-0.0548 N120040 X0.8798 Z-0.0537 N120050 X0.8820 Z-0.0528 N120060 X0.8842 Z-0.0523 N120070 X0.8919 Z-0.0512 N120080 X0.9007 Z-0.0500 N120090 X0.9095 Z-0.0485 N120100 X0.9161 Z-0.0471 N120110 X0.9227 Z-0.0455 N120120 X0.9282 Z-0.0441 N120130 X0.9337 Z-0.0423 N120140 X0.9381 Z-0.0408 N120150 X0.9425 Z-0.0390 N120160 X0.9458 Z-0.0375 N120170 X0.9502 Z-0.0351 N120180 X0.9535 Z-0.0331 N120190 X0.9557 Z-0.0316 N120200 X0.9579 Z-0.0298 N120210 X0.9590 Z-0.0288 N120220 X0.9612 Z-0.0264 N120230 X0.9645 Z-0.0223 N120240 X0.9689 Z-0.0160 N120250 X0.9766 Z-0.0042 N120260 X0.9788 Z-0.0008 N120270 X0.9799 Z-0.0005 N120280 X0.9796 Y1.6130 Z0.0000 N120290 X0.9792 Y1.6137 N120300 X0.9789 Y1.6144 Z-0.0004 N120310 X0.9784 Y1.6153 Z-0.0000 N120320 X0.9775 Y1.6171 Z0.0000 N120330 X0.9764 Z-0.0012 N120340 X0.9753 Z-0.0026 N120350 X0.9709 Z-0.0088 N120360 X0.9676 Z-0.0130 N120370 X0.9643 Z-0.0168 N120380 X0.9621 Z-0.0191 N120390 X0.9599 Z-0.0210 N120400 X0.9577 Z-0.0227 N120410 X0.9544 Z-0.0249 N120420 X0.9511 Z-0.0269 N120430 X0.9467 Z-0.0291 N120440 X0.9423 Z-0.0311 N120450 X0.9379 Z-0.0328 N120460 X0.9324 Z-0.0347 N120470 X0.9269 Z-0.0363 N120480 X0.9203 Z-0.0380 N120490 X0.9148 Z-0.0392 N120500 X0.9082 Z-0.0405 N120510 X0.9005 Z-0.0418 N120520 X0.8917 Z-0.0430 N120530 X0.8862 Z-0.0437 N120540 X0.8840 Z-0.0442 N120550 X0.8818 Z-0.0449 N120560 X0.8796 Z-0.0459 N120570 X0.8774 Z-0.0472 N120580 X0.8752 Z-0.0488 N120590 X0.8719 Z-0.0517 N120600 X0.8686 Z-0.0550 N120610 X0.8642 Z-0.0600 N120620 X0.7455 N120630 X0.6224 N120640 X0.4926 N120650 X0.4157 N120660 X0.4146 Z-0.0584 N120670 X0.3816 Z-0.0013 N120680 X0.3805 Z-0.0000 N120690 Y1.6221 Z-0.0000 N120700 X0.3816 Z-0.0013 N120710 X0.4146 Z-0.0585 N120720 X0.4157 Z-0.0600 N120730 X0.8594 N120740 X0.8605 Z-0.0592 N120750 X0.8660 Z-0.0518 N120760 X0.8704 Z-0.0464 N120770 X0.8737 Z-0.0428 N120780 X0.8759 Z-0.0406 N120790 X0.8781 Z-0.0387 N120800 X0.8803 Z-0.0371 N120810 X0.8825 Z-0.0359 N120820 X0.8847 Z-0.0350 N120830 X0.8869 Z-0.0345 N120840 X0.8957 Z-0.0334 N120850 X0.9034 Z-0.0323 N120860 X0.9112 Z-0.0309 N120870 X0.9178 Z-0.0295 N120880 X0.9244 Z-0.0280 N120890 X0.9310 Z-0.0261 N120900 X0.9365 Z-0.0244 N120910 X0.9409 Z-0.0228 N120920 X0.9464 Z-0.0205 N120930 X0.9508 Z-0.0184 N120940 X0.9541 Z-0.0167 N120950 X0.9574 Z-0.0146 N120960 X0.9607 Z-0.0124 N120970 X0.9640 Z-0.0098 N120980 X0.9673 Z-0.0067 N120990 X0.9706 Z-0.0031 N121000 X0.9728 Z-0.0004 N121010 X0.9739 Z-0.0000 N121020 X0.9731 Y1.6230 Z-0.0001 N121030 X0.9725 Y1.6235 Z0.0000 N121040 X0.9710 Y1.6248 N121050 X0.9695 Y1.6260 N121060 X0.9687 Y1.6264 Z-0.0005 N121070 X0.9680 Y1.6269 Z0.0000 N121080 X0.9677 Y1.6271 N121090 X0.9666 Z-0.0009 N121100 X0.9655 Z-0.0017 N121110 X0.9644 Z-0.0020 N121120 X0.9611 Z-0.0044 N121130 X0.9578 Z-0.0066 N121140 X0.9534 Z-0.0091 N121150 X0.9490 Z-0.0113 N121160 X0.9446 Z-0.0132 N121170 X0.9402 Z-0.0150 N121180 X0.9347 Z-0.0169 N121190 X0.9292 Z-0.0185 N121200 X0.9226 Z-0.0202 N121210 X0.9160 Z-0.0217 N121220 X0.9094 Z-0.0230 N121230 X0.9017 Z-0.0243 N121240 X0.8929 Z-0.0256 N121250 X0.8863 Z-0.0264 N121260 X0.8852 Z-0.0267 N121270 X0.8841 Z-0.0270 N121280 X0.8830 Z-0.0276 N121290 X0.8819 Z-0.0282 N121300 X0.8808 Z-0.0290 N121310 X0.8786 Z-0.0308 N121320 X0.8764 Z-0.0331 N121330 X0.8731 Z-0.0369 N121340 X0.8698 Z-0.0412 N121350 X0.8632 Z-0.0505 N121360 X0.8577 Z-0.0588 N121370 X0.8566 Z-0.0600 N121380 X0.4157 N121390 X0.4146 Z-0.0584 N121400 X0.3816 Z-0.0013 N121410 X0.3805 Z-0.0000 N121420 Y1.6321 Z-0.0000 N121430 X0.3816 Z-0.0013 N121440 X0.4146 Z-0.0585 N121450 X0.4157 Z-0.0600 N121460 X0.8538 N121470 X0.8549 Z-0.0600 N121480 X0.8649 Z-0.0440 N121490 X0.8715 Z-0.0338 N121500 X0.8759 Z-0.0274 N121510 X0.8792 Z-0.0232 N121520 X0.8814 Z-0.0208 N121530 X0.8836 Z-0.0189 N121540 X0.8847 Z-0.0182 N121550 X0.8858 Z-0.0176 N121560 X0.8869 Z-0.0173 N121570 X0.8968 Z-0.0160 N121580 X0.9045 Z-0.0148 N121590 X0.9122 Z-0.0134 N121600 X0.9188 Z-0.0121 N121610 X0.9254 Z-0.0105 N121620 X0.9320 Z-0.0087 N121630 X0.9375 Z-0.0070 N121640 X0.9430 Z-0.0051 N121650 X0.9485 Z-0.0028 N121660 X0.9529 Z-0.0007 N121670 X0.9540 Z-0.0002 N121680 X0.9562 N121690 X0.9553 Y1.6324 Z0.0000 N121700 X0.9545 Y1.6327 N121710 X0.9536 Y1.6329 Z-0.0004 N121720 X0.9527 Y1.6332 Z-0.0001 N121730 X0.9518 Y1.6335 Z0.0000 N121740 X0.9509 Y1.6337 N121750 X0.9500 Y1.6339 Z-0.0003 N121760 X0.9491 Y1.6342 Z-0.0004 N121770 X0.9482 Y1.6344 Z0.0000 N121780 X0.9462 Y1.6349 N121790 X0.9452 Y1.6351 Z-0.0003 N121800 X0.9443 Y1.6354 Z-0.0002 N121810 X0.9433 Y1.6356 Z0.0000 N121820 X0.9422 Y1.6358 N121830 X0.9412 Y1.6361 Z-0.0001 N121840 X0.9401 Y1.6363 Z-0.0005 N121850 X0.9390 Y1.6365 Z-0.0002 N121860 X0.9380 Y1.6367 Z0.0000 N121870 X0.9359 Y1.6371 Z-0.0000 N121880 X0.9315 Z-0.0014 N121890 X0.9293 Z-0.0015 N121900 X0.9282 Z-0.0016 N121910 X0.9227 Z-0.0029 N121920 X0.9161 Z-0.0044 N121930 X0.9084 Z-0.0059 N121940 X0.9007 Z-0.0071 N121950 X0.8919 Z-0.0083 N121960 X0.8875 Z-0.0089 N121970 X0.8864 Z-0.0092 N121980 X0.8853 Z-0.0100 N121990 X0.8842 Z-0.0111 N122000 X0.8831 Z-0.0124 N122010 X0.8809 Z-0.0154 N122020 X0.8765 Z-0.0220 N122030 X0.8534 Z-0.0592 N122040 X0.8523 Z-0.0600 N122050 X0.4157 N122060 X0.4146 Z-0.0584 N122070 X0.3816 Z-0.0013 N122080 X0.3805 Z-0.0000 N122090 Y1.6421 Z-0.0000 N122100 X0.3816 Z-0.0013 N122110 X0.4146 Z-0.0584 N122120 X0.4157 Z-0.0600 N122130 X0.8501 N122140 X0.8512 Z-0.0593 N122150 X0.8875 Z-0.0007 N122160 X0.8886 Z-0.0003 N122170 X0.8897 Z0.0000 N122180 X0.8941 N122190 X0.8894 Y1.6424 N122200 X0.8884 Y1.6425 Z-0.0003 N122210 X0.8881 Y1.6434 Z0.0000 N122220 X0.8877 Y1.6443 N122230 X0.8874 Y1.6452 Z-0.0003 N122240 X0.8870 Y1.6462 Z-0.0000 N122250 X0.8867 Y1.6471 Z0.0000 N122260 X0.8856 Z-0.0011 N122270 X0.8493 Z-0.0599 N122280 X0.8482 Z-0.0600 N122290 X0.4157 N122300 X0.4146 Z-0.0585 N122310 X0.3816 Z-0.0013 N122320 X0.3805 Z-0.0000 N122330 Y1.6521 Z-0.0000 N122340 X0.3816 Z-0.0013 N122350 X0.4146 Z-0.0585 N122360 X0.4157 Z-0.0600 N122370 X0.8462 N122380 X0.8473 Z-0.0599 N122390 X0.8826 Z-0.0029 N122400 X0.8837 Z-0.0013 N122410 X0.8848 Z0.0000 N122420 X0.8844 Y1.6531 N122430 X0.8840 Y1.6541 Z-0.0003 N122440 X0.8836 Y1.6551 Z0.0000 N122450 X0.8832 Y1.6561 Z-0.0001 N122460 X0.8829 Y1.6571 Z-0.0003 N122470 X0.8818 Z-0.0013 N122480 X0.8807 Z-0.0028 N122490 X0.8455 Z-0.0597 N122500 X0.8444 Z-0.0600 N122510 X0.4157 N122520 X0.4146 Z-0.0584 N122530 X0.3816 Z-0.0013 N122540 X0.3805 Z-0.0000 N122550 Y1.6621 Z-0.0000 N122560 X0.3816 Z-0.0013 N122570 X0.4146 Z-0.0584 N122580 X0.4157 Z-0.0600 N122590 X0.8424 N122600 X0.8435 Z-0.0594 N122610 X0.8798 Z-0.0007 N122620 X0.8809 Z-0.0003 N122630 X0.8806 Y1.6631 Z0.0000 N122640 X0.8802 Y1.6641 N122650 X0.8798 Y1.6651 Z-0.0004 N122660 X0.8790 Y1.6671 Z0.0000 N122670 X0.8779 Z-0.0013 N122680 X0.8702 Z-0.0137 N122690 X0.8416 Z-0.0599 N122700 X0.8372 Z-0.0600 N122710 X0.7228 N122720 X0.6028 N122730 X0.4751 N122740 X0.4157 N122750 X0.4146 Z-0.0585 N122760 X0.3816 Z-0.0013 N122770 X0.3805 Z-0.0000 N122780 Y1.6721 Z-0.0000 N122790 X0.3816 Z-0.0013 N122800 X0.4146 Z-0.0585 N122810 X0.4157 Z-0.0600 N122820 X0.8386 N122830 X0.8397 Z-0.0600 N122840 X0.8749 Z-0.0030 N122850 X0.8771 Z0.0000 N122860 X0.8767 Y1.6730 N122870 X0.8764 Y1.6740 Z-0.0001 N122880 X0.8760 Y1.6750 N122890 X0.8756 Y1.6760 Z0.0000 N122900 X0.8752 Y1.6770 Z-0.0005 N122910 X0.8741 Z-0.0010 N122920 X0.8730 Z-0.0027 N122930 X0.8378 Z-0.0595 N122940 X0.8367 Z-0.0600 N122950 X0.4157 N122960 X0.4146 Z-0.0584 N122970 X0.3816 Z-0.0013 N122980 X0.3805 Z-0.0000 N122990 Y1.6820 Z-0.0000 N123000 X0.3816 Z-0.0013 N123010 X0.4146 Z-0.0585 N123020 X0.4157 Z-0.0600 N123030 X0.8348 N123040 X0.8359 Z-0.0595 N123050 X0.8722 Z-0.0008 N123060 X0.8733 Z-0.0001 N123070 X0.8729 Y1.6830 Z0.0000 N123080 X0.8725 Y1.6840 N123090 X0.8722 Y1.6850 Z-0.0002 N123100 X0.8718 Y1.6860 Z-0.0002 N123110 X0.8714 Y1.6870 Z0.0000 N123120 X0.8703 Z-0.0013 N123130 X0.8681 Z-0.0047 N123140 X0.8340 Z-0.0599 N123150 X0.8329 Z-0.0600 N123160 X0.4157 N123170 X0.4146 Z-0.0585 N123180 X0.3816 Z-0.0013 N123190 X0.3805 Z-0.0000 N123200 Y1.6920 Z-0.0000 N123210 X0.3816 Z-0.0013 N123220 X0.4146 Z-0.0586 N123230 X0.4157 Z-0.0600 N123240 X0.8320 N123250 X0.8673 Z-0.0030 N123260 X0.8684 Z-0.0014 N123270 X0.8695 Z0.0000 N123280 X0.8691 Y1.6930 N123290 X0.8687 Y1.6940 Z-0.0003 N123300 X0.8683 Y1.6950 Z0.0000 N123310 X0.8679 Y1.6960 N123320 X0.8676 Y1.6970 Z-0.0003 N123330 X0.8665 Z-0.0008 N123340 X0.8302 Z-0.0594 N123350 X0.8291 Z-0.0600 N123360 X0.4157 N123370 X0.4146 Z-0.0584 N123380 X0.3816 Z-0.0013 N123390 X0.3805 Z-0.0000 N123400 Y1.7020 Z-0.0000 N123410 X0.3816 Z-0.0013 N123420 X0.4146 Z-0.0585 N123430 X0.4157 Z-0.0600 N123440 X0.8271 N123450 X0.8282 Z-0.0597 N123460 X0.8646 Z-0.0009 N123470 X0.8657 Z0.0000 N123480 X0.8653 Y1.7030 Z-0.0002 N123490 X0.8649 Y1.7040 Z0.0000 N123500 X0.8645 Y1.7050 Z-0.0001 N123510 X0.8637 Y1.7070 Z0.0000 N123520 X0.8626 Z-0.0011 N123530 X0.8263 Z-0.0599 N123540 X0.8252 Z-0.0600 N123550 X0.4157 N123560 X0.4146 Z-0.0585 N123570 X0.3816 Z-0.0013 N123580 X0.3805 Z-0.0000 N123590 Y1.7120 Z-0.0000 N123600 X0.3816 Z-0.0013 N123610 X0.4146 Z-0.0584 N123620 X0.4157 Z-0.0600 N123630 X0.8234 N123640 X0.8245 Z-0.0599 N123650 X0.8596 Z-0.0030 N123660 X0.8607 Z-0.0013 N123670 X0.8618 Z-0.0001 N123680 X0.8614 Y1.7130 Z0.0000 N123690 X0.8611 Y1.7140 Z-0.0004 N123700 X0.8607 Y1.7150 Z0.0000 N123710 X0.8603 Y1.7160 N123720 X0.8599 Y1.7170 Z-0.0002 N123730 X0.8588 Z-0.0007 N123740 X0.8401 Z-0.0310 N123750 X0.8313 Z-0.0456 N123760 X0.8236 Z-0.0586 N123770 X0.8225 Z-0.0600 N123780 X0.4157 N123790 X0.4146 Z-0.0584 N123800 X0.3816 Z-0.0013 N123810 X0.3805 Z-0.0000 N123820 Y1.7220 Z-0.0000 N123830 X0.3816 Z-0.0013 N123840 X0.4146 Z-0.0585 N123850 X0.4157 Z-0.0600 N123860 X0.8217 N123870 X0.8228 Z-0.0593 N123880 X0.8459 Z-0.0194 N123890 X0.8525 Z-0.0082 N123900 X0.8569 Z-0.0011 N123910 X0.8580 Z0.0000 N123920 G00 Z0.1000 N123930 G00 X1.1824 Y1.0755 N123940 G01 Z0.0000 F20.0 N123950 G01 X1.1835 F60.0 N123960 X1.3423 N123970 X1.3533 Y1.0757 N123980 X1.3599 Y1.0760 N123990 X1.3609 Y1.0760 Z-0.0001 N124000 X1.3642 Y1.0762 Z-0.0006 N124010 X1.3685 Y1.0766 Z-0.0000 N124020 X1.3738 Y1.0770 Z0.0000 N124030 X1.3749 Y1.0771 Z-0.0000 N124040 X1.3770 Y1.0773 Z-0.0005 N124050 X1.3792 Y1.0775 Z-0.0001 N124060 X1.3802 Y1.0777 Z0.0000 N124070 X1.3844 Y1.0782 Z-0.0000 N124080 X1.3854 Y1.0783 Z-0.0003 N124090 X1.3864 Y1.0785 Z-0.0006 N124100 X1.3885 Y1.0788 Z-0.0000 N124110 X1.3916 Y1.0792 Z0.0000 N124120 X1.3937 Y1.0796 Z-0.0005 N124130 X1.3947 Y1.0797 Z-0.0001 N124140 X1.3957 Y1.0799 Z0.0000 N124150 X1.3977 Y1.0803 N124160 X1.3987 Y1.0804 Z-0.0001 N124170 X1.3990 Y1.0805 Z-0.0002 N124180 X1.3957 N124190 X1.3946 Z-0.0003 N124200 X1.3891 Z-0.0018 N124210 X1.3825 Z-0.0034 N124220 X1.3759 Z-0.0047 N124230 X1.3671 Z-0.0061 N124240 X1.3605 Z-0.0068 N124250 X1.3528 Z-0.0074 N124260 X1.3451 Z-0.0076 N124270 X1.3352 Z-0.0077 N124280 X1.2154 Z-0.0077 N124290 X1.1879 Z-0.0077 N124300 X1.1868 Z-0.0071 N124310 X1.1846 Z-0.0033 N124320 X1.1824 Z0.0000 N124330 Y1.0854 N124340 X1.1846 Z-0.0033 N124350 X1.1923 Z-0.0166 N124360 X1.1934 Z-0.0167 N124370 X1.2901 Z-0.0167 N124380 X1.3406 Z-0.0167 N124390 X1.3494 Z-0.0165 N124400 X1.3560 Z-0.0161 N124410 X1.3626 Z-0.0156 N124420 X1.3703 Z-0.0145 N124430 X1.3780 Z-0.0132 N124440 X1.3857 Z-0.0116 N124450 X1.3923 Z-0.0098 N124460 X1.3999 Z-0.0075 N124470 X1.4076 Z-0.0048 N124480 X1.4142 Z-0.0022 N124490 X1.4153 Z-0.0018 N124500 X1.4164 Z-0.0015 N124510 X1.4197 Z-0.0001 N124520 X1.4208 Z0.0000 N124530 X1.4224 Y1.0859 N124540 X1.4234 Y1.0861 Z-0.0005 N124550 X1.4243 Y1.0864 Z0.0000 N124560 X1.4262 Y1.0870 N124570 X1.4272 Y1.0873 Z-0.0004 N124580 X1.4281 Y1.0875 Z-0.0001 N124590 X1.4291 Y1.0878 Z0.0000 N124600 X1.4310 Y1.0884 Z-0.0003 N124610 X1.4319 Y1.0887 Z0.0000 N124620 X1.4328 Y1.0890 N124630 X1.4338 Y1.0893 Z-0.0003 N124640 X1.4346 Y1.0896 Z-0.0003 N124650 X1.4354 Y1.0899 Z0.0000 N124660 X1.4361 Y1.0901 N124670 X1.4369 Y1.0904 Z-0.0002 N124680 X1.4358 N124690 X1.4347 Z-0.0005 N124700 X1.4336 Z-0.0010 N124710 X1.4260 Z-0.0050 N124720 X1.4194 Z-0.0081 N124730 X1.4128 Z-0.0109 N124740 X1.4062 Z-0.0135 N124750 X1.3996 Z-0.0158 N124760 X1.3931 Z-0.0178 N124770 X1.3865 Z-0.0195 N124780 X1.3788 Z-0.0212 N124790 X1.3722 Z-0.0224 N124800 X1.3645 Z-0.0235 N124810 X1.3579 Z-0.0242 N124820 X1.3514 Z-0.0247 N124830 X1.3426 Z-0.0249 N124840 X1.2373 Z-0.0249 N124850 X1.1989 Z-0.0249 N124860 X1.1978 Z-0.0249 N124870 X1.1967 Z-0.0242 N124880 X1.1846 Z-0.0033 N124890 X1.1824 Z0.0000 N124900 Y1.0954 N124910 X1.1846 Z-0.0033 N124920 X1.2023 Z-0.0339 N124930 X1.2056 Z-0.0339 N124940 X1.3025 Z-0.0339 N124950 X1.3410 Z-0.0339 N124960 X1.3498 Z-0.0337 N124970 X1.3564 Z-0.0334 N124980 X1.3630 Z-0.0327 N124990 X1.3707 Z-0.0317 N125000 X1.3773 Z-0.0306 N125010 X1.3851 Z-0.0289 N125020 X1.3906 Z-0.0274 N125030 X1.3972 Z-0.0254 N125040 X1.4038 Z-0.0232 N125050 X1.4104 Z-0.0206 N125060 X1.4181 Z-0.0173 N125070 X1.4247 Z-0.0141 N125080 X1.4324 Z-0.0100 N125090 X1.4390 Z-0.0062 N125100 X1.4456 Z-0.0022 N125110 X1.4467 Z-0.0019 N125120 X1.4478 Z-0.0013 N125130 X1.4489 Z-0.0006 N125140 X1.4500 Z0.0000 N125150 X1.4510 Y1.0958 N125160 X1.4519 Y1.0962 Z-0.0002 N125170 X1.4528 Y1.0966 Z0.0000 N125180 X1.4538 Y1.0970 Z-0.0001 N125190 X1.4547 Y1.0974 Z-0.0004 N125200 X1.4556 Y1.0978 Z0.0000 N125210 X1.4565 Y1.0982 Z-0.0004 N125220 X1.4574 Y1.0986 Z0.0000 N125230 X1.4583 Y1.0990 N125240 X1.4591 Y1.0994 Z-0.0003 N125250 X1.4600 Y1.0998 Z0.0000 N125260 X1.4606 Y1.1001 N125270 X1.4612 Y1.1003 Z-0.0003 N125280 X1.4601 N125290 X1.4590 Z-0.0008 N125300 X1.4513 Z-0.0061 N125310 X1.4447 Z-0.0105 N125320 X1.4370 Z-0.0152 N125330 X1.4304 Z-0.0189 N125340 X1.4227 Z-0.0229 N125350 X1.4162 Z-0.0260 N125360 X1.4096 Z-0.0289 N125370 X1.4030 Z-0.0314 N125380 X1.3964 Z-0.0336 N125390 X1.3887 Z-0.0359 N125400 X1.3821 Z-0.0376 N125410 X1.3756 Z-0.0390 N125420 X1.3690 Z-0.0401 N125430 X1.3624 Z-0.0410 N125440 X1.3558 Z-0.0416 N125450 X1.3492 Z-0.0420 N125460 X1.3404 Z-0.0422 N125470 X1.2175 Z-0.0422 N125480 X1.2077 Z-0.0422 N125490 X1.2066 Z-0.0413 N125500 X1.1846 Z-0.0033 N125510 X1.1824 Z0.0000 N125520 Y1.1053 N125530 X1.1846 Z-0.0033 N125540 X1.2122 Z-0.0510 N125550 X1.2133 Z-0.0512 N125560 X1.3410 Z-0.0512 N125570 X1.3487 Z-0.0510 N125580 X1.3542 Z-0.0507 N125590 X1.3608 Z-0.0502 N125600 X1.3674 Z-0.0493 N125610 X1.3740 Z-0.0483 N125620 X1.3818 Z-0.0467 N125630 X1.3873 Z-0.0453 N125640 X1.3950 Z-0.0431 N125650 X1.4016 Z-0.0408 N125660 X1.4082 Z-0.0382 N125670 X1.4159 Z-0.0349 N125680 X1.4225 Z-0.0317 N125690 X1.4302 Z-0.0276 N125700 X1.4379 Z-0.0230 N125710 X1.4445 Z-0.0188 N125720 X1.4522 Z-0.0136 N125730 X1.4588 Z-0.0088 N125740 X1.4665 Z-0.0028 N125750 X1.4676 Z-0.0019 N125760 X1.4687 Z-0.0017 N125770 X1.4710 Z0.0000 N125780 X1.4718 Y1.1058 Z-0.0002 N125790 X1.4727 Y1.1063 Z0.0000 N125800 X1.4736 Y1.1068 N125810 X1.4745 Y1.1073 Z-0.0005 N125820 X1.4754 Y1.1078 Z0.0000 N125830 X1.4762 Y1.1083 Z-0.0003 N125840 X1.4771 Y1.1088 Z0.0000 N125850 X1.4788 Y1.1098 N125860 X1.4797 Y1.1103 Z-0.0004 N125870 X1.4786 N125880 X1.4775 Z-0.0012 N125890 X1.4687 Z-0.0087 N125900 X1.4610 Z-0.0149 N125910 X1.4533 Z-0.0207 N125920 X1.4456 Z-0.0261 N125930 X1.4390 Z-0.0304 N125940 X1.4313 Z-0.0350 N125950 X1.4247 Z-0.0386 N125960 X1.4180 Z-0.0420 N125970 X1.4103 Z-0.0455 N125980 X1.4037 Z-0.0481 N125990 X1.3971 Z-0.0505 N126000 X1.3905 Z-0.0525 N126010 X1.3839 Z-0.0543 N126020 X1.3762 Z-0.0561 N126030 X1.3696 Z-0.0572 N126040 X1.3630 Z-0.0582 N126050 X1.3575 Z-0.0587 N126060 X1.3509 Z-0.0591 N126070 X1.3410 Z-0.0594 N126080 X1.2243 Z-0.0594 N126090 X1.2177 Z-0.0594 N126100 X1.2166 Z-0.0586 N126110 X1.1846 Z-0.0033 N126120 X1.1824 Z0.0000 N126130 Y1.1152 N126140 X1.1846 Z-0.0033 N126150 X1.2165 Z-0.0584 N126160 X1.2176 Z-0.0600 N126170 X1.3943 N126180 X1.3965 Z-0.0593 N126190 X1.4042 Z-0.0565 N126200 X1.4097 Z-0.0542 N126210 X1.4163 Z-0.0512 N126220 X1.4239 Z-0.0472 N126230 X1.4305 Z-0.0436 N126240 X1.4382 Z-0.0389 N126250 X1.4459 Z-0.0337 N126260 X1.4525 Z-0.0290 N126270 X1.4602 Z-0.0231 N126280 X1.4668 Z-0.0178 N126290 X1.4744 Z-0.0113 N126300 X1.4821 Z-0.0043 N126310 X1.4843 Z-0.0023 N126320 X1.4854 Z-0.0017 N126330 X1.4865 Z-0.0007 N126340 X1.4876 Z-0.0000 N126350 X1.4884 Y1.1158 Z-0.0004 N126360 X1.4893 Y1.1163 Z0.0000 N126370 X1.4909 Y1.1174 Z-0.0000 N126380 X1.4917 Y1.1180 Z-0.0004 N126390 X1.4925 Y1.1186 Z0.0000 N126400 X1.4933 Y1.1191 Z-0.0003 N126410 X1.4941 Y1.1197 Z0.0000 N126420 X1.4949 Y1.1202 Z-0.0004 N126430 X1.4938 Z-0.0004 N126440 X1.4916 Z-0.0025 N126450 X1.4850 Z-0.0089 N126460 X1.4762 Z-0.0171 N126470 X1.4685 Z-0.0238 N126480 X1.4608 Z-0.0303 N126490 X1.4531 Z-0.0363 N126500 X1.4465 Z-0.0411 N126510 X1.4388 Z-0.0464 N126520 X1.4322 Z-0.0505 N126530 X1.4256 Z-0.0544 N126540 X1.4179 Z-0.0585 N126550 X1.4157 Z-0.0596 N126560 X1.4146 Z-0.0600 N126570 X1.2176 N126580 X1.2165 Z-0.0586 N126590 X1.1846 Z-0.0033 N126600 X1.1824 Z0.0000 N126610 Y1.1252 N126620 X1.1846 Z-0.0033 N126630 X1.2165 Z-0.0586 N126640 X1.2176 Z-0.0600 N126650 X1.4300 N126660 X1.4311 Z-0.0595 N126670 X1.4366 Z-0.0560 N126680 X1.4443 Z-0.0507 N126690 X1.4520 Z-0.0450 N126700 X1.4586 Z-0.0398 N126710 X1.4663 Z-0.0333 N126720 X1.4740 Z-0.0265 N126730 X1.4817 Z-0.0193 N126740 X1.4906 Z-0.0107 N126750 X1.4983 Z-0.0028 N126760 X1.4994 Z-0.0020 N126770 X1.5005 Z-0.0008 N126780 X1.5016 Z0.0000 N126790 X1.5032 Y1.1265 N126800 X1.5041 Y1.1271 Z-0.0003 N126810 X1.5049 Y1.1278 Z-0.0001 N126820 X1.5056 Y1.1284 Z0.0000 N126830 X1.5064 Y1.1290 Z-0.0003 N126840 X1.5071 Y1.1296 Z0.0000 N126850 X1.5078 Y1.1302 N126860 X1.5067 Z-0.0005 N126870 X1.5056 Z-0.0014 N126880 X1.4968 Z-0.0108 N126890 X1.4891 Z-0.0188 N126900 X1.4803 Z-0.0275 N126910 X1.4726 Z-0.0347 N126920 X1.4649 Z-0.0416 N126930 X1.4572 Z-0.0482 N126940 X1.4506 Z-0.0534 N126950 X1.4440 Z-0.0584 N126960 X1.4418 Z-0.0600 N126970 X1.3352 Z-0.0600 N126980 X1.2176 N126990 X1.2165 Z-0.0585 N127000 X1.1846 Z-0.0033 N127010 X1.1824 Z0.0000 N127020 Y1.1351 N127030 X1.1846 Z-0.0033 N127040 X1.2165 Z-0.0586 N127050 X1.2176 Z-0.0600 N127060 X1.4520 N127070 X1.4531 Z-0.0595 N127080 X1.4608 Z-0.0531 N127090 X1.4685 Z-0.0462 N127100 X1.4762 Z-0.0390 N127110 X1.4850 Z-0.0303 N127120 X1.4927 Z-0.0224 N127130 X1.5015 Z-0.0129 N127140 X1.5103 Z-0.0031 N127150 X1.5114 Z-0.0020 N127160 X1.5125 Z-0.0008 N127170 X1.5136 Z0.0000 N127180 X1.5146 Y1.1360 N127190 X1.5153 Y1.1366 Z-0.0002 N127200 X1.5160 Y1.1373 Z0.0000 N127210 X1.5183 Y1.1394 Z-0.0000 N127220 X1.5190 Y1.1401 Z-0.0001 N127230 X1.5179 Z-0.0006 N127240 X1.5091 Z-0.0108 N127250 X1.4992 Z-0.0220 N127260 X1.4904 Z-0.0315 N127270 X1.4827 Z-0.0395 N127280 X1.4739 Z-0.0482 N127290 X1.4662 Z-0.0554 N127300 X1.4618 Z-0.0594 N127310 X1.4607 Z-0.0600 N127320 X1.2176 N127330 X1.2165 Z-0.0586 N127340 X1.1846 Z-0.0033 N127350 X1.1824 Z0.0000 N127360 Y1.1451 N127370 X1.1846 Z-0.0033 N127380 X1.2165 Z-0.0585 N127390 X1.2176 Z-0.0600 N127400 X1.4681 N127410 X1.4692 Z-0.0598 N127420 X1.4780 Z-0.0511 N127430 X1.4868 Z-0.0420 N127440 X1.4956 Z-0.0325 N127450 X1.5055 Z-0.0214 N127460 X1.5142 Z-0.0111 N127470 X1.5230 Z-0.0005 N127480 X1.5241 Z-0.0002 N127490 X1.5263 Y1.1473 Z-0.0002 N127500 X1.5276 Y1.1487 Z0.0000 N127510 X1.5282 Y1.1493 Z-0.0001 N127520 X1.5289 Y1.1500 Z0.0000 N127530 X1.5278 Z-0.0006 N127540 X1.5190 Z-0.0116 N127550 X1.5091 Z-0.0236 N127560 X1.5003 Z-0.0339 N127570 X1.4915 Z-0.0438 N127580 X1.4827 Z-0.0533 N127590 X1.4772 Z-0.0590 N127600 X1.4761 Z-0.0600 N127610 X1.2176 N127620 X1.2165 Z-0.0586 N127630 X1.1846 Z-0.0033 N127640 X1.1824 Z0.0000 N127650 Y1.1550 N127660 X1.1846 Z-0.0033 N127670 X1.2165 Z-0.0586 N127680 X1.2176 Z-0.0600 N127690 X1.4828 N127700 X1.4839 Z-0.0589 N127710 X1.4916 Z-0.0504 N127720 X1.5004 Z-0.0403 N127730 X1.5103 Z-0.0285 N127740 X1.5202 Z-0.0163 N127750 X1.5301 Z-0.0036 N127760 X1.5323 Z-0.0008 N127770 X1.5334 Z0.0000 N127780 X1.5341 Y1.1559 Z-0.0001 N127790 X1.5348 Y1.1567 Z-0.0004 N127800 X1.5355 Y1.1575 Z-0.0000 N127810 X1.5361 Y1.1583 Z-0.0001 N127820 X1.5368 Y1.1591 Z0.0000 N127830 X1.5375 Y1.1600 N127840 X1.5364 Z-0.0006 N127850 X1.5353 Z-0.0020 N127860 X1.5254 Z-0.0151 N127870 X1.5155 Z-0.0277 N127880 X1.5056 Z-0.0400 N127890 X1.4957 Z-0.0518 N127900 X1.4891 Z-0.0594 N127910 X1.4880 Z-0.0600 N127920 X1.2176 N127930 X1.2165 Z-0.0585 N127940 X1.1846 Z-0.0033 N127950 X1.1824 Z0.0000 N127960 Y1.1649 N127970 X1.1846 Z-0.0033 N127980 X1.2166 Z-0.0587 N127990 X1.2177 Z-0.0600 N128000 X1.4940 N128010 X1.4951 Z-0.0590 N128020 X1.5040 Z-0.0484 N128030 X1.5139 Z-0.0360 N128040 X1.5238 Z-0.0231 N128050 X1.5348 Z-0.0084 N128060 X1.5392 Z-0.0024 N128070 X1.5403 Z-0.0011 N128080 X1.5414 Z0.0000 N128090 X1.5420 Y1.1658 N128100 X1.5426 Y1.1666 Z-0.0005 N128110 X1.5432 Y1.1674 Z-0.0000 N128120 X1.5439 Y1.1683 Z-0.0001 N128130 X1.5445 Y1.1691 Z0.0000 N128140 X1.5450 Y1.1699 Z-0.0003 N128150 X1.5439 Z-0.0007 N128160 X1.5428 Z-0.0020 N128170 X1.5319 Z-0.0172 N128180 X1.5209 Z-0.0321 N128190 X1.5110 Z-0.0450 N128200 X1.5022 Z-0.0562 N128210 X1.5000 Z-0.0589 N128220 X1.4989 Z-0.0600 N128230 X1.2176 N128240 X1.2165 Z-0.0585 N128250 X1.1846 Z-0.0033 N128260 X1.1824 Z0.0000 N128270 Y1.1749 N128280 X1.1846 Z-0.0033 N128290 X1.2165 Z-0.0585 N128300 X1.2176 Z-0.0600 N128310 X1.5034 N128320 X1.5045 Z-0.0592 N128330 X1.5133 Z-0.0477 N128340 X1.5232 Z-0.0344 N128350 X1.5341 Z-0.0192 N128360 X1.5473 Z-0.0005 N128370 X1.5484 Z-0.0001 N128380 X1.5496 Y1.1767 Z0.0000 N128390 X1.5502 Y1.1775 Z-0.0004 N128400 X1.5508 Y1.1784 Z0.0000 N128410 X1.5512 Y1.1791 N128420 X1.5516 Y1.1798 Z-0.0003 N128430 X1.5505 Z-0.0008 N128440 X1.5494 Z-0.0022 N128450 X1.5374 Z-0.0197 N128460 X1.5264 Z-0.0352 N128470 X1.5165 Z-0.0489 N128480 X1.5088 Z-0.0592 N128490 X1.5077 Z-0.0600 N128500 X1.2176 N128510 X1.2165 Z-0.0585 N128520 X1.1846 Z-0.0033 N128530 X1.1824 Z0.0000 N128540 Y1.1848 N128550 X1.1846 Z-0.0033 N128560 X1.2166 Z-0.0587 N128570 X1.2177 Z-0.0600 N128580 X1.5117 N128590 X1.5128 Z-0.0596 N128600 X1.5227 Z-0.0458 N128610 X1.5348 Z-0.0285 N128620 X1.5480 Z-0.0091 N128630 X1.5524 Z-0.0026 N128640 X1.5535 Z-0.0011 N128650 X1.5546 Z0.0000 N128660 X1.5551 Y1.1856 N128670 X1.5561 Y1.1873 Z-0.0002 N128680 X1.5566 Y1.1882 Z0.0000 N128690 X1.5570 Y1.1890 Z-0.0003 N128700 X1.5574 Y1.1898 Z0.0000 N128710 X1.5563 Z-0.0011 N128720 X1.5409 Z-0.0241 N128730 X1.5288 Z-0.0419 N128740 X1.5167 Z-0.0592 N128750 X1.5156 Z-0.0600 N128760 X1.2176 N128770 X1.2165 Z-0.0585 N128780 X1.1846 Z-0.0033 N128790 X1.1824 Z0.0000 N128800 Y1.1947 N128810 X1.1846 Z-0.0033 N128820 X1.2166 Z-0.0586 N128830 X1.2177 Z-0.0600 N128840 X1.5193 N128850 X1.5204 Z-0.0588 N128860 X1.5325 Z-0.0411 N128870 X1.5457 Z-0.0212 N128880 X1.5578 Z-0.0027 N128890 X1.5600 Z0.0000 N128900 X1.5605 Y1.1956 Z-0.0002 N128910 X1.5609 Y1.1965 Z0.0000 N128920 X1.5614 Y1.1974 Z-0.0006 N128930 X1.5618 Y1.1983 Z0.0000 N128940 X1.5622 Y1.1990 N128950 X1.5625 Y1.1997 Z-0.0005 N128960 X1.5614 Z-0.0011 N128970 X1.5603 Z-0.0025 N128980 X1.5460 Z-0.0246 N128990 X1.5328 Z-0.0446 N129000 X1.5229 Z-0.0594 N129010 X1.5218 Z-0.0600 N129020 X1.2176 N129030 X1.2165 Z-0.0585 N129040 X1.1846 Z-0.0033 N129050 X1.1824 Z0.0000 N129060 Y1.2047 N129070 X1.1846 Z-0.0033 N129080 X1.2165 Z-0.0585 N129090 X1.2176 Z-0.0600 N129100 X1.5252 N129110 X1.5263 Z-0.0586 N129120 X1.5395 Z-0.0385 N129130 X1.5538 Z-0.0163 N129140 X1.5637 Z-0.0008 N129150 X1.5648 Z-0.0003 N129160 X1.5651 Y1.2055 Z0.0000 N129170 X1.5658 Y1.2071 Z-0.0002 N129180 X1.5662 Y1.2079 Z0.0000 N129190 X1.5665 Y1.2087 N129200 X1.5669 Y1.2096 Z-0.0005 N129210 X1.5658 Z-0.0011 N129220 X1.5647 Z-0.0027 N129230 X1.5482 Z-0.0288 N129240 X1.5339 Z-0.0511 N129250 X1.5285 Z-0.0596 N129260 X1.5274 Z-0.0600 N129270 X1.2176 N129280 X1.2165 Z-0.0585 N129290 X1.1846 Z-0.0033 N129300 X1.1824 Z0.0000 N129310 Y1.2146 N129320 X1.1846 Z-0.0033 N129330 X1.2166 Z-0.0586 N129340 X1.2177 Z-0.0600 N129350 X1.5303 N129360 X1.5314 Z-0.0589 N129370 X1.5469 Z-0.0346 N129380 X1.5645 Z-0.0064 N129390 X1.5667 Z-0.0028 N129400 X1.5678 Z-0.0012 N129410 X1.5689 Z0.0000 N129420 X1.5692 Y1.2156 Z-0.0003 N129430 X1.5696 Y1.2166 Z0.0000 N129440 X1.5700 Y1.2176 Z-0.0000 N129450 X1.5703 Y1.2186 Z-0.0003 N129460 X1.5707 Y1.2196 Z0.0000 N129470 X1.5696 Z-0.0013 N129480 X1.5685 Z-0.0030 N129490 X1.5509 Z-0.0315 N129500 X1.5344 Z-0.0578 N129510 X1.5333 Z-0.0596 N129520 X1.5322 Z-0.0600 N129530 X1.2176 N129540 X1.2165 Z-0.0586 N129550 X1.1846 Z-0.0033 N129560 X1.1824 Z0.0000 N129570 Y1.2245 N129580 X1.1846 Z-0.0033 N129590 X1.2165 Z-0.0585 N129600 X1.2176 Z-0.0600 N129610 X1.5340 N129620 X1.5351 Z-0.0598 N129630 X1.5538 Z-0.0296 N129640 X1.5713 Z-0.0009 N129650 X1.5724 Z-0.0002 N129660 X1.5727 Y1.2255 Z0.0000 N129670 X1.5731 Y1.2265 N129680 X1.5737 Y1.2285 Z-0.0003 N129690 X1.5740 Y1.2295 Z0.0000 N129700 X1.5729 Z-0.0013 N129710 X1.5531 Z-0.0339 N129720 X1.5377 Z-0.0591 N129730 X1.5366 Z-0.0600 N129740 X1.2176 N129750 X1.2165 Z-0.0586 N129760 X1.1846 Z-0.0033 N129770 X1.1824 Z0.0000 N129780 Y1.2345 N129790 X1.1846 Z-0.0033 N129800 X1.2166 Z-0.0586 N129810 X1.2177 Z-0.0600 N129820 X1.5380 N129830 X1.5391 Z-0.0594 N129840 X1.5633 Z-0.0194 N129850 X1.5733 Z-0.0029 N129860 X1.5744 Z-0.0013 N129870 X1.5755 Z0.0000 N129880 X1.5757 Y1.2355 Z-0.0003 N129890 X1.5760 Y1.2364 Z0.0000 N129900 X1.5765 Y1.2384 N129910 X1.5768 Y1.2394 Z-0.0004 N129920 X1.5757 Z-0.0012 N129930 X1.5515 Z-0.0416 N129940 X1.5405 Z-0.0598 N129950 X1.5394 Z-0.0600 N129960 X1.2176 N129970 X1.2165 Z-0.0585 N129980 X1.1846 Z-0.0033 N129990 X1.1824 Z0.0000 N130000 Y1.2444 N130010 X1.1846 Z-0.0033 N130020 X1.2165 Z-0.0585 N130030 X1.2176 Z-0.0600 N130040 X1.5407 N130050 X1.5417 Z-0.0598 N130060 X1.5714 Z-0.0101 N130070 X1.5769 Z-0.0009 N130080 X1.5780 Z-0.0004 N130090 X1.5782 Y1.2453 Z0.0000 N130100 X1.5787 Y1.2471 N130110 X1.5788 Y1.2479 Z-0.0002 N130120 X1.5790 Y1.2486 Z-0.0003 N130130 X1.5791 Y1.2494 Z-0.0004 N130140 X1.5780 Z-0.0011 N130150 X1.5505 Z-0.0475 N130160 X1.5440 Z-0.0585 N130170 X1.5429 Z-0.0600 N130180 X1.2176 N130190 X1.2165 Z-0.0585 N130200 X1.1846 Z-0.0033 N130210 X1.1824 Z0.0000 N130220 Y1.2543 N130230 X1.1846 Z-0.0033 N130240 X1.2165 Z-0.0585 N130250 X1.2176 Z-0.0600 N130260 X1.5439 N130270 X1.5450 Z-0.0586 N130280 X1.5791 Z-0.0009 N130290 X1.5802 Z-0.0003 N130300 X1.5805 Y1.2563 Z0.0000 N130310 X1.5809 Y1.2582 N130320 X1.5811 Y1.2593 Z-0.0002 N130330 X1.5800 Z-0.0012 N130340 X1.5480 Z-0.0556 N130350 X1.5458 Z-0.0594 N130360 X1.5447 Z-0.0600 N130370 X1.2177 N130380 X1.2166 Z-0.0587 N130390 X1.1846 Z-0.0033 N130400 X1.1824 Z0.0000 N130410 Y1.2643 N130420 X1.1846 Z-0.0033 N130430 X1.2165 Z-0.0586 N130440 X1.2176 Z-0.0600 N130450 X1.5455 N130460 X1.5466 Z-0.0596 N130470 X1.5797 Z-0.0032 N130480 X1.5808 Z-0.0014 N130490 X1.5819 Z0.0000 N130500 X1.5820 Y1.2654 N130510 X1.5822 Y1.2664 Z-0.0001 N130520 X1.5823 Y1.2674 Z-0.0004 N130530 X1.5825 Y1.2683 Z-0.0003 N130540 X1.5826 Y1.2692 Z-0.0000 N130550 X1.5815 Z-0.0010 N130560 X1.5474 Z-0.0594 N130570 X1.5463 Z-0.0600 N130580 X1.2176 N130590 X1.2165 Z-0.0585 N130600 X1.1846 Z-0.0033 N130610 X1.1824 Z0.0000 N130620 Y1.2742 N130630 X1.1846 Z-0.0033 N130640 X1.2166 Z-0.0586 N130650 X1.2177 Z-0.0600 N130660 X1.5469 N130670 X1.5480 Z-0.0598 N130680 X1.5821 Z-0.0012 N130690 X1.5832 Z-0.0000 N130700 X1.5834 Y1.2761 Z-0.0004 N130710 X1.5835 Y1.2771 Z-0.0004 N130720 X1.5837 Y1.2781 Z-0.0001 N130730 X1.5838 Y1.2792 Z0.0000 N130740 X1.5827 Z-0.0011 N130750 X1.5486 Z-0.0598 N130760 X1.5475 Z-0.0600 N130770 X1.2176 N130780 X1.2165 Z-0.0585 N130790 X1.1846 Z-0.0033 N130800 X1.1824 Z0.0000 N130810 Y1.2841 N130820 X1.1846 Z-0.0033 N130830 X1.2166 Z-0.0586 N130840 X1.2177 Z-0.0600 N130850 X1.5490 N130860 X1.5821 Z-0.0031 N130870 X1.5832 Z-0.0013 N130880 X1.5843 Z-0.0000 N130890 X1.5843 Y1.2853 Z-0.0002 N130900 X1.5844 Y1.2863 N130910 X1.5845 Y1.2882 Z-0.0005 N130920 X1.5846 Y1.2891 Z-0.0005 N130930 X1.5835 Z-0.0011 N130940 X1.5495 Z-0.0599 N130950 X1.5484 Z-0.0600 N130960 X1.2176 N130970 X1.2165 Z-0.0585 N130980 X1.1846 Z-0.0033 N130990 X1.1824 Z0.0000 N131000 Y1.2941 N131010 X1.1846 Z-0.0033 N131020 X1.2165 Z-0.0585 N131030 X1.2176 Z-0.0600 N131040 X1.5497 N131050 X1.5508 Z-0.0583 N131060 X1.5838 Z-0.0012 N131070 X1.5849 Z0.0000 N131080 X1.5852 Y1.2990 N131090 X1.5841 Z-0.0016 N131100 X1.5808 Z-0.0072 N131110 X1.5510 Z-0.0586 N131120 X1.5499 Z-0.0600 N131130 X1.2176 N131140 X1.2165 Z-0.0586 N131150 X1.1846 Z-0.0033 N131160 X1.1824 Z0.0000 N131170 Y1.3040 N131180 X1.1846 Z-0.0033 N131190 X1.2166 Z-0.0586 N131200 X1.2177 Z-0.0600 N131210 X1.5501 N131220 X1.5512 Z-0.0585 N131230 X1.5831 Z-0.0032 N131240 X1.5842 Z-0.0014 N131250 X1.5853 Z0.0000 N131260 X1.5854 Y1.3090 Z-0.0001 N131270 X1.5843 Z-0.0013 N131280 X1.5513 Z-0.0585 N131290 X1.5502 Z-0.0600 N131300 X1.2177 N131310 X1.2166 Z-0.0586 N131320 X1.1846 Z-0.0033 N131330 X1.1824 Z0.0000 N131340 Y1.3139 N131350 X1.1846 Z-0.0033 N131360 X1.2166 Z-0.0586 N131370 X1.2177 Z-0.0600 N131380 X1.5502 N131390 X1.5513 Z-0.0585 N131400 X1.5843 Z-0.0013 N131410 X1.5854 Z-0.0001 N131420 X1.5854 Y1.3189 Z-0.0000 N131430 X1.5843 Z-0.0013 N131440 X1.5512 Z-0.0585 N131450 X1.5501 Z-0.0600 N131460 X1.2177 N131470 X1.2166 Z-0.0586 N131480 X1.1846 Z-0.0033 N131490 X1.1824 Z0.0000 N131500 Y1.3239 N131510 X1.1846 Z-0.0033 N131520 X1.2165 Z-0.0586 N131530 X1.2176 Z-0.0600 N131540 X1.5500 N131550 X1.5511 Z-0.0585 N131560 X1.5830 Z-0.0033 N131570 X1.5852 Z0.0000 N131580 X1.5850 Y1.3289 N131590 X1.5839 Z-0.0013 N131600 X1.5509 Z-0.0584 N131610 X1.5498 Z-0.0600 N131620 X1.2176 N131630 X1.2165 Z-0.0586 N131640 X1.1846 Z-0.0033 N131650 X1.1824 Z0.0000 N131660 Y1.3338 N131670 X1.1846 Z-0.0033 N131680 X1.2165 Z-0.0585 N131690 X1.2176 Z-0.0600 N131700 X1.5484 N131710 X1.5495 Z-0.0598 N131720 X1.5836 Z-0.0010 N131730 X1.5847 Z-0.0003 N131740 X1.5846 Y1.3348 Z-0.0005 N131750 X1.5845 Y1.3357 Z-0.0005 N131760 X1.5843 Y1.3388 Z-0.0000 N131770 X1.5832 Z-0.0013 N131780 X1.5501 Z-0.0583 N131790 X1.5490 Z-0.0600 N131800 X1.2177 N131810 X1.2166 Z-0.0586 N131820 X1.1846 Z-0.0033 N131830 X1.1824 Z0.0000 N131840 Y1.3438 N131850 X1.1846 Z-0.0033 N131860 X1.2165 Z-0.0585 N131870 X1.2176 Z-0.0600 N131880 X1.5475 N131890 X1.5486 Z-0.0597 N131900 X1.5827 Z-0.0010 N131910 X1.5838 Z0.0000 N131920 X1.5837 Y1.3448 Z-0.0001 N131930 X1.5834 Y1.3468 Z-0.0006 N131940 X1.5832 Y1.3487 Z-0.0001 N131950 X1.5821 Z-0.0013 N131960 X1.5480 Z-0.0599 N131970 X1.5469 Z-0.0600 N131980 X1.2177 N131990 X1.2166 Z-0.0586 N132000 X1.1846 Z-0.0033 N132010 X1.1824 Z0.0000 N132020 Y1.3537 N132030 X1.1846 Z-0.0033 N132040 X1.2165 Z-0.0585 N132050 X1.2176 Z-0.0600 N132060 X1.5462 N132070 X1.5473 Z-0.0591 N132080 X1.5814 Z-0.0009 N132090 X1.5825 Z-0.0002 N132100 X1.5824 Y1.3544 Z-0.0005 N132110 X1.5823 Y1.3552 Z-0.0004 N132120 X1.5822 Y1.3559 Z-0.0001 N132130 X1.5820 Y1.3568 Z0.0000 N132140 X1.5817 Y1.3587 N132150 X1.5806 Z-0.0014 N132160 X1.5520 Z-0.0502 N132170 X1.5465 Z-0.0595 N132180 X1.5454 Z-0.0600 N132190 X1.2176 N132200 X1.2165 Z-0.0586 N132210 X1.1846 Z-0.0033 N132220 X1.1824 Z0.0000 N132230 Y1.3636 N132240 X1.1846 Z-0.0033 N132250 X1.2165 Z-0.0586 N132260 X1.2176 Z-0.0600 N132270 X1.5445 N132280 X1.5456 Z-0.0591 N132290 X1.5742 Z-0.0107 N132300 X1.5786 Z-0.0032 N132310 X1.5808 Z0.0000 N132320 X1.5804 Y1.3656 N132330 X1.5802 Y1.3666 Z-0.0004 N132340 X1.5800 Y1.3676 Z-0.0004 N132350 X1.5798 Y1.3686 Z-0.0000 N132360 X1.5787 Z-0.0014 N132370 X1.5776 Z-0.0031 N132380 X1.5512 Z-0.0477 N132390 X1.5446 Z-0.0587 N132400 X1.5435 Z-0.0600 N132410 X1.2177 N132420 X1.2166 Z-0.0586 N132430 X1.1846 Z-0.0033 N132440 X1.1824 Z0.0000 N132450 Y1.3736 N132460 X1.1846 Z-0.0033 N132470 X1.2166 Z-0.0586 N132480 X1.2177 Z-0.0600 N132490 X1.5424 N132500 X1.5435 Z-0.0584 N132510 X1.5666 Z-0.0197 N132520 X1.5765 Z-0.0031 N132530 X1.5776 Z-0.0014 N132540 X1.5787 Z0.0000 N132550 X1.5782 Y1.3755 N132560 X1.5780 Y1.3765 Z-0.0005 N132570 X1.5775 Y1.3785 Z0.0000 N132580 X1.5764 Z-0.0016 N132590 X1.5753 Z-0.0030 N132600 X1.5511 Z-0.0434 N132610 X1.5412 Z-0.0598 N132620 X1.5401 Z-0.0600 N132630 X1.2176 N132640 X1.2165 Z-0.0586 N132650 X1.1846 Z-0.0033 N132660 X1.1824 Z0.0000 N132670 Y1.3835 N132680 X1.1846 Z-0.0033 N132690 X1.2165 Z-0.0585 N132700 X1.2176 Z-0.0600 N132710 X1.5387 N132720 X1.5398 Z-0.0591 N132730 X1.5585 Z-0.0284 N132740 X1.5750 Z-0.0009 N132750 X1.5761 Z0.0000 N132760 X1.5761 Y1.3837 N132770 X1.5758 Y1.3846 Z-0.0004 N132780 X1.5755 Y1.3856 Z0.0000 N132790 X1.5749 Y1.3875 N132800 X1.5746 Y1.3885 Z-0.0006 N132810 X1.5735 Z-0.0010 N132820 X1.5548 Z-0.0317 N132830 X1.5384 Z-0.0584 N132840 X1.5373 Z-0.0600 N132850 X1.2176 N132860 X1.2165 Z-0.0585 N132870 X1.1846 Z-0.0033 N132880 X1.1824 Z0.0000 N132890 Y1.3934 N132900 X1.1846 Z-0.0033 N132910 X1.2165 Z-0.0586 N132920 X1.2176 Z-0.0600 N132930 X1.5345 N132940 X1.5356 Z-0.0600 N132950 X1.5510 Z-0.0353 N132960 X1.5697 Z-0.0048 N132970 X1.5719 Z-0.0012 N132980 X1.5730 Z0.0000 N132990 X1.5728 Y1.3940 N133000 X1.5726 Y1.3946 Z-0.0001 N133010 X1.5723 Y1.3955 Z0.0000 N133020 X1.5716 Y1.3974 N133030 X1.5712 Y1.3984 Z-0.0005 N133040 X1.5701 Z-0.0011 N133050 X1.5690 Z-0.0026 N133060 X1.5526 Z-0.0291 N133070 X1.5372 Z-0.0535 N133080 X1.5339 Z-0.0587 N133090 X1.5328 Z-0.0600 N133100 X1.2176 N133110 X1.2165 Z-0.0584 N133120 X1.1846 Z-0.0033 N133130 X1.1824 Z0.0000 N133140 Y1.4034 N133150 X1.1846 Z-0.0033 N133160 X1.2165 Z-0.0585 N133170 X1.2176 Z-0.0600 N133180 X1.5298 N133190 X1.5309 Z-0.0596 N133200 X1.5452 Z-0.0373 N133210 X1.5616 Z-0.0112 N133220 X1.5682 Z-0.0007 N133230 X1.5693 Z-0.0001 N133240 X1.5690 Y1.4042 Z0.0000 N133250 X1.5683 Y1.4059 N133260 X1.5680 Y1.4067 Z-0.0001 N133270 X1.5676 Y1.4075 Z0.0000 N133280 X1.5673 Y1.4083 N133290 X1.5662 Z-0.0010 N133300 X1.5508 Z-0.0252 N133310 X1.5365 Z-0.0473 N133320 X1.5288 Z-0.0591 N133330 X1.5277 Z-0.0600 N133340 X1.2176 N133350 X1.2165 Z-0.0585 N133360 X1.1846 Z-0.0033 N133370 X1.1824 Z0.0000 N133380 Y1.4133 N133390 X1.1846 Z-0.0033 N133400 X1.2165 Z-0.0585 N133410 X1.2176 Z-0.0600 N133420 X1.5244 N133430 X1.5255 Z-0.0595 N133440 X1.5376 Z-0.0414 N133450 X1.5508 Z-0.0212 N133460 X1.5639 Z-0.0006 N133470 X1.5650 Z0.0000 N133480 X1.5641 Y1.4153 N133490 X1.5638 Y1.4160 Z-0.0003 N133500 X1.5634 Y1.4168 Z0.0000 N133510 X1.5630 Y1.4175 N133520 X1.5626 Y1.4183 Z-0.0004 N133530 X1.5615 Z-0.0007 N133540 X1.5593 Z-0.0039 N133550 X1.5472 Z-0.0224 N133560 X1.5341 Z-0.0421 N133570 X1.5220 Z-0.0598 N133580 X1.5209 Z-0.0600 N133590 X1.2176 N133600 X1.2165 Z-0.0585 N133610 X1.1846 Z-0.0033 N133620 X1.1824 Z0.0000 N133630 Y1.4232 N133640 X1.1846 Z-0.0033 N133650 X1.2166 Z-0.0586 N133660 X1.2177 Z-0.0600 N133670 X1.5182 N133680 X1.5193 Z-0.0592 N133690 X1.5303 Z-0.0435 N133700 X1.5413 Z-0.0274 N133710 X1.5546 Z-0.0076 N133720 X1.5579 Z-0.0026 N133730 X1.5590 Z-0.0012 N133740 X1.5601 Z0.0000 N133750 X1.5591 Y1.4251 Z-0.0000 N133760 X1.5586 Y1.4259 Z0.0000 N133770 X1.5582 Y1.4266 Z-0.0002 N133780 X1.5577 Y1.4274 Z0.0000 N133790 X1.5573 Y1.4282 N133800 X1.5562 Z-0.0005 N133810 X1.5430 Z-0.0200 N133820 X1.5309 Z-0.0375 N133830 X1.5199 Z-0.0530 N133840 X1.5155 Z-0.0591 N133850 X1.5144 Z-0.0600 N133860 X1.2176 N133870 X1.2165 Z-0.0585 N133880 X1.1846 Z-0.0033 N133890 X1.1824 Z0.0000 N133900 Y1.4332 N133910 X1.1846 Z-0.0033 N133920 X1.2165 Z-0.0586 N133930 X1.2176 Z-0.0600 N133940 X1.5103 N133950 X1.5114 Z-0.0595 N133960 X1.5213 Z-0.0462 N133970 X1.5323 Z-0.0309 N133980 X1.5444 Z-0.0137 N133990 X1.5510 Z-0.0041 N134000 X1.5532 Z-0.0009 N134010 X1.5543 Z0.0000 N134020 X1.5539 Y1.4339 Z-0.0001 N134030 X1.5535 Y1.4346 Z0.0000 N134040 X1.5511 Y1.4381 Z-0.0000 N134050 X1.5500 Z-0.0010 N134060 X1.5489 Z-0.0021 N134070 X1.5379 Z-0.0178 N134080 X1.5269 Z-0.0330 N134090 X1.5170 Z-0.0464 N134100 X1.5071 Z-0.0593 N134110 X1.5060 Z-0.0600 N134120 X1.2176 N134130 X1.2165 Z-0.0586 N134140 X1.1846 Z-0.0033 N134150 X1.1824 Z0.0000 N134160 Y1.4431 N134170 X1.1846 Z-0.0033 N134180 X1.2165 Z-0.0586 N134190 X1.2176 Z-0.0600 N134200 X1.5015 N134210 X1.5026 Z-0.0592 N134220 X1.5114 Z-0.0481 N134230 X1.5213 Z-0.0353 N134240 X1.5312 Z-0.0220 N134250 X1.5422 Z-0.0069 N134260 X1.5444 Z-0.0038 N134270 X1.5455 Z-0.0024 N134280 X1.5466 Z-0.0009 N134290 X1.5477 Z0.0000 N134300 X1.5473 Y1.4437 Z-0.0001 N134310 X1.5467 Y1.4446 Z0.0000 N134320 X1.5460 Y1.4454 Z-0.0004 N134330 X1.5454 Y1.4463 Z0.0000 N134340 X1.5441 Y1.4481 N134350 X1.5430 Z-0.0004 N134360 X1.5419 Z-0.0017 N134370 X1.5320 Z-0.0152 N134380 X1.5221 Z-0.0282 N134390 X1.5133 Z-0.0395 N134400 X1.5045 Z-0.0504 N134410 X1.4968 Z-0.0596 N134420 X1.4957 Z-0.0600 N134430 X1.2176 N134440 X1.2165 Z-0.0585 N134450 X1.1846 Z-0.0033 N134460 X1.1824 Z0.0000 N134470 Y1.4530 N134480 X1.1846 Z-0.0033 N134490 X1.2166 Z-0.0586 N134500 X1.2177 Z-0.0600 N134510 X1.4906 N134520 X1.4917 Z-0.0592 N134530 X1.4994 Z-0.0505 N134540 X1.5082 Z-0.0400 N134550 X1.5170 Z-0.0292 N134560 X1.5270 Z-0.0166 N134570 X1.5369 Z-0.0036 N134580 X1.5380 Z-0.0022 N134590 X1.5402 Z0.0000 N134600 X1.5389 Y1.4545 N134610 X1.5383 Y1.4552 Z-0.0001 N134620 X1.5377 Y1.4560 Z0.0000 N134630 X1.5371 Y1.4567 Z-0.0004 N134640 X1.5365 Y1.4574 Z0.0000 N134650 X1.5360 Y1.4580 Z-0.0003 N134660 X1.5349 Z-0.0010 N134670 X1.5338 Z-0.0017 N134680 X1.5239 Z-0.0143 N134690 X1.5140 Z-0.0265 N134700 X1.5052 Z-0.0370 N134710 X1.4964 Z-0.0470 N134720 X1.4877 Z-0.0567 N134730 X1.4855 Z-0.0590 N134740 X1.4844 Z-0.0600 N134750 X1.2176 N134760 X1.2165 Z-0.0584 N134770 X1.1846 Z-0.0033 N134780 X1.1824 Z0.0000 N134790 Y1.4630 N134800 X1.1846 Z-0.0033 N134810 X1.2166 Z-0.0586 N134820 X1.2177 Z-0.0600 N134830 X1.4775 N134840 X1.4786 Z-0.0596 N134850 X1.4863 Z-0.0517 N134860 X1.4951 Z-0.0422 N134870 X1.5050 Z-0.0311 N134880 X1.5138 Z-0.0209 N134890 X1.5238 Z-0.0088 N134900 X1.5293 Z-0.0020 N134910 X1.5304 Z-0.0012 N134920 X1.5315 Z0.0000 N134930 X1.5282 Y1.4664 Z-0.0001 N134940 X1.5267 Y1.4679 Z-0.0001 N134950 X1.5256 Z-0.0004 N134960 X1.5168 Z-0.0110 N134970 X1.5080 Z-0.0212 N134980 X1.4992 Z-0.0310 N134990 X1.4893 Z-0.0416 N135000 X1.4816 Z-0.0495 N135010 X1.4739 Z-0.0571 N135020 X1.4717 Z-0.0592 N135030 X1.4706 Z-0.0600 N135040 X1.2176 N135050 X1.2165 Z-0.0586 N135060 X1.1846 Z-0.0033 N135070 X1.1824 Z0.0000 N135080 Y1.4729 N135090 X1.1846 Z-0.0033 N135100 X1.2166 Z-0.0586 N135110 X1.2177 Z-0.0600 N135120 X1.4621 N135130 X1.4632 Z-0.0598 N135140 X1.4698 Z-0.0538 N135150 X1.4775 Z-0.0466 N135160 X1.4863 Z-0.0379 N135170 X1.4940 Z-0.0299 N135180 X1.5028 Z-0.0205 N135190 X1.5127 Z-0.0094 N135200 X1.5182 Z-0.0031 N135210 X1.5193 Z-0.0020 N135220 X1.5204 Z-0.0012 N135230 X1.5215 Z0.0000 N135240 X1.5209 Y1.4735 Z-0.0001 N135250 X1.5202 Y1.4741 Z0.0000 N135260 X1.5181 Y1.4760 N135270 X1.5174 Y1.4767 Z-0.0005 N135280 X1.5167 Y1.4773 Z0.0000 N135290 X1.5160 Y1.4779 Z-0.0002 N135300 X1.5149 Z-0.0006 N135310 X1.5127 Z-0.0030 N135320 X1.5050 Z-0.0115 N135330 X1.4951 Z-0.0220 N135340 X1.4873 Z-0.0299 N135350 X1.4796 Z-0.0374 N135360 X1.4708 Z-0.0456 N135370 X1.4642 Z-0.0514 N135380 X1.4565 Z-0.0578 N135390 X1.4543 Z-0.0596 N135400 X1.4532 Z-0.0600 N135410 X1.2177 N135420 X1.2166 Z-0.0586 N135430 X1.1846 Z-0.0033 N135440 X1.1824 Z0.0000 N135450 Y1.4828 N135460 X1.1846 Z-0.0033 N135470 X1.2165 Z-0.0585 N135480 X1.2176 Z-0.0600 N135490 X1.4430 N135500 X1.4441 Z-0.0597 N135510 X1.4507 Z-0.0549 N135520 X1.4584 Z-0.0489 N135530 X1.4661 Z-0.0425 N135540 X1.4738 Z-0.0358 N135550 X1.4826 Z-0.0276 N135560 X1.4914 Z-0.0190 N135570 X1.4990 Z-0.0112 N135580 X1.5089 Z-0.0006 N135590 X1.5100 Z0.0000 N135600 X1.5086 Y1.4840 Z-0.0003 N135610 X1.5078 Y1.4846 Z0.0000 N135620 X1.5062 Y1.4859 N135630 X1.5053 Y1.4865 Z-0.0004 N135640 X1.5045 Y1.4872 Z0.0000 N135650 X1.5037 Y1.4878 Z-0.0002 N135660 X1.5026 Z-0.0003 N135670 X1.4949 Z-0.0081 N135680 X1.4872 Z-0.0157 N135690 X1.4784 Z-0.0239 N135700 X1.4707 Z-0.0308 N135710 X1.4630 Z-0.0373 N135720 X1.4553 Z-0.0433 N135730 X1.4487 Z-0.0483 N135740 X1.4410 Z-0.0536 N135750 X1.4333 Z-0.0585 N135760 X1.4311 Z-0.0599 N135770 X1.4300 Z-0.0600 N135780 X1.2176 N135790 X1.2165 Z-0.0586 N135800 X1.1846 Z-0.0033 N135810 X1.1824 Z0.0000 N135820 Y1.4928 N135830 X1.1846 Z-0.0033 N135840 X1.2165 Z-0.0585 N135850 X1.2176 Z-0.0600 N135860 X1.4155 N135870 X1.4166 Z-0.0598 N135880 X1.4221 Z-0.0571 N135890 X1.4298 Z-0.0529 N135900 X1.4364 Z-0.0489 N135910 X1.4430 Z-0.0447 N135920 X1.4507 Z-0.0393 N135930 X1.4573 Z-0.0344 N135940 X1.4650 Z-0.0283 N135950 X1.4727 Z-0.0219 N135960 X1.4804 Z-0.0151 N135970 X1.4891 Z-0.0069 N135980 X1.4946 Z-0.0016 N135990 X1.4957 Z-0.0006 N136000 X1.4968 Z0.0000 N136010 X1.4960 Y1.4934 Z-0.0000 N136020 X1.4951 Y1.4940 Z-0.0001 N136030 X1.4942 Y1.4946 Z0.0000 N136040 X1.4927 Y1.4956 N136050 X1.4919 Y1.4962 Z-0.0002 N136060 X1.4911 Y1.4967 Z-0.0000 N136070 X1.4903 Y1.4972 Z0.0000 N136080 X1.4895 Y1.4977 Z-0.0001 N136090 X1.4884 Z-0.0002 N136100 X1.4807 Z-0.0072 N136110 X1.4730 Z-0.0139 N136120 X1.4653 Z-0.0202 N136130 X1.4576 Z-0.0262 N136140 X1.4510 Z-0.0310 N136150 X1.4443 Z-0.0355 N136160 X1.4366 Z-0.0404 N136170 X1.4300 Z-0.0443 N136180 X1.4234 Z-0.0479 N136190 X1.4168 Z-0.0511 N136200 X1.4102 Z-0.0541 N136210 X1.4025 Z-0.0571 N136220 X1.3959 Z-0.0594 N136230 X1.3948 Z-0.0598 N136240 X1.3937 Z-0.0600 N136250 X1.2176 N136260 X1.2165 Z-0.0586 N136270 X1.1846 Z-0.0033 N136280 X1.1824 Z0.0000 N136290 Y1.5027 N136300 X1.1846 Z-0.0033 N136310 X1.2165 Z-0.0585 N136320 X1.2176 Z-0.0597 N136330 X1.3385 Z-0.0597 N136340 X1.3473 Z-0.0596 N136350 X1.3539 Z-0.0593 N136360 X1.3605 Z-0.0587 N136370 X1.3671 Z-0.0579 N136380 X1.3737 Z-0.0568 N136390 X1.3803 Z-0.0555 N136400 X1.3880 Z-0.0536 N136410 X1.3946 Z-0.0517 N136420 X1.4023 Z-0.0491 N136430 X1.4100 Z-0.0461 N136440 X1.4166 Z-0.0432 N136450 X1.4232 Z-0.0400 N136460 X1.4298 Z-0.0365 N136470 X1.4364 Z-0.0328 N136480 X1.4440 Z-0.0280 N136490 X1.4506 Z-0.0236 N136500 X1.4583 Z-0.0181 N136510 X1.4671 Z-0.0113 N136520 X1.4748 Z-0.0050 N136530 X1.4781 Z-0.0022 N136540 X1.4792 Z-0.0014 N136550 X1.4803 Z-0.0005 N136560 X1.4814 Z0.0000 N136570 X1.4807 Y1.5031 Z-0.0004 N136580 X1.4798 Y1.5037 Z0.0000 N136590 X1.4788 Y1.5042 Z-0.0005 N136600 X1.4779 Y1.5047 Z-0.0001 N136610 X1.4760 Y1.5058 Z0.0000 N136620 X1.4750 Y1.5063 Z-0.0003 N136630 X1.4742 Y1.5068 Z0.0000 N136640 X1.4733 Y1.5072 Z-0.0004 N136650 X1.4725 Y1.5077 Z-0.0001 N136660 X1.4714 N136670 X1.4703 Z-0.0005 N136680 X1.4626 Z-0.0065 N136690 X1.4560 Z-0.0114 N136700 X1.4483 Z-0.0167 N136710 X1.4406 Z-0.0216 N136720 X1.4341 Z-0.0255 N136730 X1.4264 Z-0.0297 N136740 X1.4198 Z-0.0330 N136750 X1.4132 Z-0.0360 N136760 X1.4055 Z-0.0391 N136770 X1.3989 Z-0.0414 N136780 X1.3923 Z-0.0435 N136790 X1.3868 Z-0.0450 N136800 X1.3802 Z-0.0466 N136810 X1.3725 Z-0.0481 N136820 X1.3659 Z-0.0491 N136830 X1.3582 Z-0.0499 N136840 X1.3516 Z-0.0504 N136850 X1.3429 Z-0.0507 N136860 X1.2484 Z-0.0507 N136870 X1.2165 Z-0.0507 N136880 X1.2121 Z-0.0507 N136890 X1.2110 Z-0.0490 N136900 X1.1846 Z-0.0033 N136910 X1.1824 Z0.0000 N136920 Y1.5127 N136930 X1.1846 Z-0.0033 N136940 X1.2066 Z-0.0414 N136950 X1.2077 Z-0.0425 N136960 X1.3209 Z-0.0425 N136970 X1.3406 Z-0.0425 N136980 X1.3483 Z-0.0423 N136990 X1.3549 Z-0.0420 N137000 X1.3615 Z-0.0414 N137010 X1.3681 Z-0.0406 N137020 X1.3747 Z-0.0395 N137030 X1.3813 Z-0.0382 N137040 X1.3890 Z-0.0363 N137050 X1.3956 Z-0.0344 N137060 X1.4033 Z-0.0319 N137070 X1.4098 Z-0.0294 N137080 X1.4164 Z-0.0266 N137090 X1.4241 Z-0.0230 N137100 X1.4307 Z-0.0196 N137110 X1.4384 Z-0.0153 N137120 X1.4461 Z-0.0106 N137130 X1.4527 Z-0.0062 N137140 X1.4593 Z-0.0016 N137150 X1.4604 Z-0.0012 N137160 X1.4615 Z-0.0004 N137170 X1.4626 Z0.0000 N137180 X1.4616 Y1.5131 Z-0.0003 N137190 X1.4607 Y1.5135 Z0.0000 N137200 X1.4598 Y1.5139 Z-0.0003 N137210 X1.4590 Y1.5143 Z-0.0000 N137220 X1.4572 Y1.5151 Z-0.0001 N137230 X1.4555 Y1.5158 Z0.0000 N137240 X1.4546 Y1.5162 Z-0.0005 N137250 X1.4538 Y1.5166 Z0.0000 N137260 X1.4530 Y1.5169 N137270 X1.4521 Y1.5173 Z-0.0003 N137280 X1.4513 Y1.5176 Z-0.0000 N137290 X1.4502 N137300 X1.4469 Z-0.0020 N137310 X1.4403 Z-0.0060 N137320 X1.4326 Z-0.0103 N137330 X1.4260 Z-0.0137 N137340 X1.4184 Z-0.0172 N137350 X1.4118 Z-0.0200 N137360 X1.4052 Z-0.0225 N137370 X1.3986 Z-0.0247 N137380 X1.3920 Z-0.0266 N137390 X1.3832 Z-0.0288 N137400 X1.3756 Z-0.0303 N137410 X1.3690 Z-0.0315 N137420 X1.3613 Z-0.0324 N137430 X1.3536 Z-0.0331 N137440 X1.3459 Z-0.0334 N137450 X1.3382 Z-0.0335 N137460 X1.2384 Z-0.0335 N137470 X1.2044 Z-0.0335 N137480 X1.2022 Z-0.0334 N137490 X1.2011 Z-0.0318 N137500 X1.1846 Z-0.0033 N137510 X1.1824 Z0.0000 N137520 Y1.5226 N137530 X1.1846 Z-0.0033 N137540 X1.1967 Z-0.0242 N137550 X1.1978 Z-0.0252 N137560 X1.3130 Z-0.0252 N137570 X1.3404 Z-0.0252 N137580 X1.3492 Z-0.0250 N137590 X1.3557 Z-0.0247 N137600 X1.3623 Z-0.0241 N137610 X1.3689 Z-0.0233 N137620 X1.3755 Z-0.0222 N137630 X1.3821 Z-0.0209 N137640 X1.3897 Z-0.0190 N137650 X1.3963 Z-0.0172 N137660 X1.4040 Z-0.0147 N137670 X1.4106 Z-0.0122 N137680 X1.4172 Z-0.0096 N137690 X1.4248 Z-0.0061 N137700 X1.4314 Z-0.0028 N137710 X1.4336 Z-0.0016 N137720 X1.4358 Z-0.0013 N137730 X1.4380 Z-0.0001 N137740 X1.4370 Y1.5229 Z-0.0005 N137750 X1.4360 Y1.5232 Z0.0000 N137760 X1.4351 Y1.5236 N137770 X1.4341 Y1.5239 Z-0.0001 N137780 X1.4331 Y1.5242 Z-0.0000 N137790 X1.4322 Y1.5245 Z0.0000 N137800 X1.4313 Y1.5248 Z-0.0001 N137810 X1.4303 Y1.5251 Z-0.0006 N137820 X1.4294 Y1.5254 Z0.0000 N137830 X1.4275 Y1.5259 N137840 X1.4266 Y1.5262 Z-0.0004 N137850 X1.4257 Y1.5264 Z0.0000 N137860 X1.4247 Y1.5267 N137870 X1.4228 Y1.5272 Z-0.0003 N137880 X1.4217 Y1.5276 Z0.0000 N137890 X1.4206 N137900 X1.4195 Z-0.0002 N137910 X1.4184 Z-0.0005 N137920 X1.4107 Z-0.0035 N137930 X1.4042 Z-0.0059 N137940 X1.3965 Z-0.0083 N137950 X1.3899 Z-0.0101 N137960 X1.3833 Z-0.0117 N137970 X1.3767 Z-0.0131 N137980 X1.3690 Z-0.0143 N137990 X1.3603 Z-0.0154 N138000 X1.3537 Z-0.0159 N138010 X1.3460 Z-0.0162 N138020 X1.3372 Z-0.0163 N138030 X1.2241 Z-0.0163 N138040 X1.1923 Z-0.0163 N138050 X1.1912 Z-0.0147 N138060 X1.1846 Z-0.0033 N138070 X1.1824 Z0.0000 N138080 Y1.5325 N138090 X1.1846 Z-0.0033 N138100 X1.1868 Z-0.0071 N138110 X1.1879 Z-0.0080 N138120 X1.3008 Z-0.0080 N138130 X1.3403 Z-0.0080 N138140 X1.3491 Z-0.0078 N138150 X1.3556 Z-0.0075 N138160 X1.3622 Z-0.0069 N138170 X1.3688 Z-0.0061 N138180 X1.3754 Z-0.0051 N138190 X1.3819 Z-0.0039 N138200 X1.3885 Z-0.0024 N138210 X1.3918 Z-0.0016 N138220 X1.3940 Z-0.0013 N138230 X1.3951 N138240 X1.3962 Z-0.0011 N138250 X1.3995 Z-0.0001 N138260 X1.3986 Y1.5327 Z-0.0004 N138270 X1.3976 Y1.5329 Z-0.0004 N138280 X1.3966 Y1.5330 Z-0.0000 N138290 X1.3936 Y1.5335 Z0.0000 N138300 X1.3926 Y1.5337 Z-0.0001 N138310 X1.3916 Y1.5338 Z-0.0004 N138320 X1.3906 Y1.5340 Z-0.0004 N138330 X1.3895 Y1.5341 Z-0.0000 N138340 X1.3855 Y1.5347 Z-0.0000 N138350 X1.3844 Y1.5348 Z-0.0002 N138360 X1.3834 Y1.5350 Z-0.0004 N138370 X1.3824 Y1.5351 Z-0.0004 N138380 X1.3814 Y1.5352 Z-0.0000 N138390 X1.3762 Y1.5358 Z0.0000 N138400 X1.3730 Y1.5361 Z-0.0005 N138410 X1.3699 Y1.5364 Z0.0000 N138420 X1.3634 Y1.5368 N138430 X1.3603 Y1.5370 Z-0.0001 N138440 X1.3555 Y1.5372 Z-0.0005 N138450 X1.3535 Y1.5373 Z-0.0004 N138460 X1.3470 Y1.5374 Z-0.0000 N138470 X1.3368 Y1.5375 Z0.0000 N138480 X1.2240 N138490 X1.1824 N138500 G00 Z0.1000 N138510 G00 X1.2073 Y1.1004 N138520 G01 Z-0.0600 F10.0 N138530 G01 X1.3413 F40.0 N138540 X1.3525 Y1.1005 N138550 G03 X1.3831 Y1.1031 R0.294 N138560 G03 X1.4260 Y1.1129 R0.241 N138570 G03 X1.4974 Y1.1540 R0.203 N138580 G03 X1.5266 Y1.1869 R0.177 N138590 G03 X1.5473 Y1.2279 R0.179 N138600 G03 X1.5566 Y1.2634 R0.217 N138610 G03 X1.5605 Y1.3059 R0.282 N138620 G03 X1.5585 Y1.3457 R0.269 N138630 G03 X1.5505 Y1.3825 R0.205 N138640 G03 X1.5083 Y1.4512 R0.167 N138650 G03 X1.4504 Y1.4909 R0.207 N138660 G03 X1.4006 Y1.5070 R0.227 N138670 G03 X1.3537 Y1.5124 R0.286 N138680 G01 X1.3413 Y1.5126 N138690 X1.2073 Y1.5126 N138700 Y1.1004 N138710 G00 Z0.1000 N138720 G00 X0.8368 Y0.2626 N138730 G01 Z-0.0600 F10.0 N138740 G02 X0.8344 Y0.2859 R0.025 F40.0 N138750 G01 X0.8654 Y0.3619 N138760 G02 X0.8858 Y0.3772 R0.025 N138770 G03 X0.8992 Y0.3787 R0.432 N138780 G03 X0.9277 Y0.3839 R0.267 N138790 G03 X0.9437 Y0.3888 R0.128 N138800 G03 X0.9537 Y0.3938 R0.050 N138810 G03 X0.9565 Y0.3980 R0.016 N138820 G03 X0.9593 Y0.4054 R0.043 N138830 G03 X0.9625 Y0.4235 R0.107 N138840 G03 X0.9636 Y0.4476 R0.237 N138850 G01 Y1.5494 N138860 G03 X0.9631 Y1.5686 R0.316 N138870 G03 X0.9607 Y1.5891 R0.174 N138880 G03 X0.9577 Y1.6008 R0.071 N138890 G03 X0.9555 Y1.6054 R0.020 N138900 G03 X0.9513 Y1.6074 R0.024 N138910 G03 X0.9420 Y1.6104 R0.075 N138920 G03 X0.9225 Y1.6141 R0.188 N138930 G03 X0.8866 Y1.6177 R0.464 N138940 G02 X0.8652 Y1.6336 R0.025 N138950 G01 X0.8342 Y1.7146 N138960 G02 X0.8586 Y1.7483 R0.025 N138970 G01 X1.0270 Y1.7404 N138980 X1.3507 Y1.7403 N138990 G02 X1.3713 Y1.7400 R0.939 N139000 G01 X1.3847 Y1.7394 N139010 G02 X1.4169 Y1.7365 R0.555 N139020 G02 X1.4390 Y1.7334 R0.533 N139030 G02 X1.4607 Y1.7294 R0.514 N139040 G02 X1.4819 Y1.7245 R0.503 N139050 G01 X1.4941 Y1.7212 N139060 X1.5029 Y1.7186 N139070 G02 X1.5233 Y1.7118 R0.473 N139080 G01 X1.5348 Y1.7075 N139090 X1.5433 Y1.7041 N139100 X1.5546 Y1.6993 N139110 X1.5629 Y1.6955 N139120 X1.5739 Y1.6901 N139130 X1.5819 Y1.6859 N139140 X1.5927 Y1.6800 N139150 X1.6006 Y1.6755 N139160 X1.6111 Y1.6690 N139170 X1.6187 Y1.6641 N139180 X1.6290 Y1.6571 N139190 X1.6364 Y1.6518 N139200 X1.6465 Y1.6442 N139210 X1.6537 Y1.6386 N139220 X1.6633 Y1.6306 N139230 X1.6704 Y1.6244 N139240 X1.6798 Y1.6158 N139250 X1.6865 Y1.6093 N139260 X1.6953 Y1.6004 N139270 X1.7016 Y1.5936 N139280 X1.7098 Y1.5844 N139290 X1.7157 Y1.5774 N139300 X1.7233 Y1.5678 N139310 X1.7288 Y1.5606 N139320 X1.7359 Y1.5507 N139330 X1.7409 Y1.5432 N139340 X1.7474 Y1.5330 N139350 X1.7520 Y1.5253 N139360 X1.7579 Y1.5147 N139370 X1.7620 Y1.5068 N139380 X1.7673 Y1.4959 N139390 X1.7710 Y1.4878 N139400 X1.7757 Y1.4766 N139410 X1.7790 Y1.4682 N139420 X1.7831 Y1.4567 N139430 X1.7859 Y1.4481 N139440 X1.7894 Y1.4363 N139450 X1.7917 Y1.4275 N139460 X1.7946 Y1.4153 N139470 X1.7965 Y1.4064 N139480 X1.7988 Y1.3939 N139490 X1.8003 Y1.3847 N139500 X1.8020 Y1.3720 N139510 X1.8030 Y1.3626 N139520 X1.8041 Y1.3495 N139530 X1.8047 Y1.3395 N139540 X1.8051 Y1.3265 N139550 G02 X1.8046 Y1.2900 R0.472 N139560 G02 X1.7701 Y1.1423 R0.430 N139570 G02 X1.7349 Y1.0760 R0.468 N139580 G02 X1.6449 Y0.9737 R0.443 N139590 G02 X1.5621 Y0.9188 R0.457 N139600 G01 X1.9294 Y0.4796 N139610 G03 X1.9350 Y0.4733 R0.162 N139620 G03 X1.9519 Y0.4566 R0.353 N139630 G01 X1.9629 Y0.4465 N139640 G03 X1.9899 Y0.4232 R1.322 N139650 G01 X2.0056 Y0.4100 N139660 G02 X2.0199 Y0.3979 R0.256 N139670 G03 X2.0222 Y0.3962 R0.009 N139680 G03 X2.0373 Y0.3898 R0.103 N139690 G03 X2.0622 Y0.3831 R0.199 N139700 G03 X2.1030 Y0.3772 R0.381 N139710 G02 X2.1234 Y0.3619 R0.025 N139720 G01 X2.1544 Y0.2859 N139730 G02 X2.1314 Y0.2516 R0.025 N139740 G01 X1.8044 N139750 G02 X1.7854 Y0.2605 R0.025 N139760 G01 X1.2699 Y0.8706 N139770 X1.2073 N139780 Y0.4476 N139790 G03 X1.2078 Y0.4281 R0.371 N139800 G03 X1.2098 Y0.4075 R0.186 N139810 G03 X1.2122 Y0.3970 R0.078 N139820 G03 X1.2143 Y0.3919 R0.028 N139830 G01 X1.2151 Y0.3915 N139840 G03 X1.2208 Y0.3894 R0.057 N139850 G03 X1.2371 Y0.3854 R0.149 N139860 G03 X1.2685 Y0.3808 R0.404 N139870 G01 X1.2838 Y0.3792 N139880 G02 X1.3040 Y0.3649 R0.025 N139890 G01 X1.3400 Y0.2869 N139900 G02 X1.3174 Y0.2516 R0.025 N139910 G01 X0.8574 N139920 G02 X0.8368 Y0.2626 R0.025 N139930 G00 Z0.1000 N139940 G00 X0.6590 Y0.8967 N139950 G01 Z-0.0600 F10.0 N139960 G01 X0.6590 Y0.9055 F40.0 N139970 Y1.3304 N139980 X0.6589 Y1.3357 N139990 G03 X0.6582 Y1.3428 R0.070 N140000 G03 X0.6560 Y1.3508 R0.036 N140010 G01 X0.6550 Y1.3528 N140020 X0.6541 Y1.3541 N140030 X0.6510 Y1.3573 N140040 G03 X0.6488 Y1.3588 R0.016 N140050 G03 X0.6438 Y1.3613 R0.035 N140060 G03 X0.6287 Y1.3657 R0.095 N140070 G03 X0.6122 Y1.3687 R0.284 N140080 G02 X0.6050 Y1.3702 R0.026 N140090 G02 X0.5926 Y1.3792 R0.029 N140100 G02 X0.5880 Y1.3865 R0.036 N140110 G01 X0.5866 Y1.3897 N140120 G02 X0.5858 Y1.3925 R0.025 N140130 G01 X0.5841 Y1.3990 N140140 X0.5834 Y1.4031 N140150 G02 X0.5830 Y1.4100 R0.048 N140160 G02 X0.5834 Y1.4145 R0.036 N140170 G01 X0.5841 Y1.4185 N140180 X0.5859 Y1.4260 N140190 G02 X0.5911 Y1.4377 R0.038 N140200 G02 X0.5951 Y1.4424 R0.031 N140210 G02 X0.6047 Y1.4487 R0.028 N140220 G02 X0.6149 Y1.4504 R0.028 N140230 G02 X0.6503 Y1.4497 R1.554 N140240 G01 X0.6872 Y1.4484 N140250 X0.7012 Y1.4474 N140260 G03 X0.7265 Y1.4465 R0.626 N140270 G01 X0.7435 Y1.4464 N140280 X0.7773 Y1.4464 N140290 X0.7944 Y1.4467 N140300 G03 X0.8158 Y1.4476 R0.571 N140310 G01 X0.8243 Y1.4482 N140320 X0.8579 Y1.4495 N140330 G02 X0.8969 Y1.4504 R1.562 N140340 G02 X0.9024 Y1.4502 R0.054 N140350 G02 X0.9125 Y1.4471 R0.026 N140360 G02 X0.9241 Y1.4353 R0.030 N140370 G02 X0.9277 Y1.4267 R0.038 N140380 G02 X0.9301 Y1.4158 R0.132 N140390 G01 X0.9306 Y1.4119 N140400 G02 X0.9296 Y1.4000 R0.041 N140410 G01 X0.9278 Y1.3927 N140420 G02 X0.9236 Y1.3829 R0.038 N140430 G02 X0.9165 Y1.3746 R0.031 N140440 G02 X0.9005 Y1.3686 R0.027 N140450 G03 X0.8857 Y1.3664 R0.255 N140460 G03 X0.8705 Y1.3623 R0.095 N140470 G03 X0.8631 Y1.3586 R0.030 N140480 G03 X0.8599 Y1.3552 R0.028 N140490 G03 X0.8573 Y1.3510 R0.021 N140500 G01 X0.8562 Y1.3483 N140510 G03 X0.8548 Y1.3431 R0.038 N140520 G03 X0.8537 Y1.3303 R0.067 N140530 G01 X0.8537 Y0.9883 N140540 X0.8535 Y0.9730 N140550 G02 X0.8527 Y0.9563 R0.438 N140560 G02 X0.8467 Y0.9092 R0.386 N140570 G02 X0.8353 Y0.8663 R0.302 N140580 G02 X0.8185 Y0.8285 R0.251 N140590 G02 X0.8115 Y0.8166 R0.237 N140600 G02 X0.8039 Y0.8053 R0.233 N140610 G01 X0.7988 Y0.7985 N140620 X0.7957 Y0.7945 N140630 G02 X0.7862 Y0.7838 R0.230 N140640 G02 X0.7765 Y0.7740 R0.204 N140650 G02 X0.7235 Y0.7361 R0.276 N140660 G02 X0.6506 Y0.7089 R0.274 N140670 G02 X0.5965 Y0.7020 R0.313 N140680 G02 X0.5688 Y0.7021 R0.268 N140690 G02 X0.4891 Y0.7239 R0.200 N140700 G02 X0.4703 Y0.7349 R0.195 N140710 G02 X0.4453 Y0.7565 R0.123 N140720 G02 X0.4375 Y0.7668 R0.100 N140730 G02 X0.4337 Y0.7732 R0.092 N140740 G01 X0.4313 Y0.7781 N140750 G02 X0.4250 Y0.7972 R0.087 N140760 G01 X0.4240 Y0.8026 N140770 G02 X0.4232 Y0.8099 R0.097 N140780 G02 X0.4238 Y0.8310 R0.119 N140790 G02 X0.4281 Y0.8506 R0.102 N140800 G01 X0.4303 Y0.8567 N140810 G02 X0.4431 Y0.8784 R0.085 N140820 G02 X0.4500 Y0.8860 R0.086 N140830 G01 X0.4558 Y0.8912 N140840 X0.4599 Y0.8945 N140850 G02 X0.4766 Y0.9044 R0.091 N140860 G02 X0.5003 Y0.9120 R0.104 N140870 G02 X0.5260 Y0.9144 R0.139 N140880 G02 X0.5469 Y0.9122 R0.091 N140890 G02 X0.5776 Y0.8979 R0.080 N140900 G02 X0.5905 Y0.8858 R0.085 N140910 G01 X0.5951 Y0.8802 N140920 G02 X0.6160 Y0.8487 R0.205 N140930 G01 X0.6240 Y0.8330 N140940 X0.6291 Y0.8236 N140950 G03 X0.6417 Y0.8028 R0.309 N140960 G03 X0.6441 Y0.8001 R0.017 N140970 G01 X0.6450 Y0.7994 N140980 X0.6458 Y0.7995 N140990 X0.6467 Y0.8005 N141000 G03 X0.6487 Y0.8037 R0.020 N141010 G03 X0.6518 Y0.8123 R0.045 N141020 G03 X0.6549 Y0.8284 R0.150 N141030 G03 X0.6581 Y0.8643 R0.387 N141040 G03 X0.6590 Y0.8967 R0.845 N141050 G00 Z0.1000 N141060 G00 X0.4054 Y0.2385 N141070 G01 Z-0.0600 F10.0 N141080 G01 X2.1629 Y0.2385 F40.0 N141090 Y1.7571 N141100 X0.4054 N141110 X0.4054 Y0.2385 N141120 G00 Z0.1000 N141130 G00 X0.0000 Y0.0000 Z1.0000 M05 N141150 M09 (Vacuum OFF) N141160 M53 N141170 M30
