'M2227 Gear/Spline cutting Macro with Incremental Tooth Profiling Sub Main() 'MsgBox(" In CONFIG set {ROT 360 rollover} & {Ang Short Rot on G0}") Setvar(1,Question("Number of Teeth/Splines?")) Setvar(8,Question("Tooth/Spline DEPTH?")) Setvar(10,Question("# of steps to depth")) Setvar(5,Question("X End of CUT?")) Setvar(7,Question(" INFEED Feedrate")) Setvar(9,Question(" CUTTING Feedrate")) N0: Setvar(20,Question("Infeed AXIS?.... Y(0).... Z(1)")) Setvar(2,(360/Getvar(1))) '(angle To turn chuck) Setvar(3,-.1) '(y clearance) Setvar(4,0) '(X start of cut) Setvar(6,0) '(starting A position) Setvar(11,(Getvar(8)/Getvar(10))) ' Step value Setvar(12,0) 'Current depth '********** If Getvar(20)=0 Then GoTo n1 If Getvar(20)=1 Then GoTo n11 If Getvar(20)>1 Then MsgBox" Selection MUST be 0 or 1,,, Restart MACRO" GoTo n0 '***Y Infeed*** N1: CODE"G0 X#4 Y#3 Z0" While ISMOVING() Wend CODE"G0 Z0" While ISMOVING() Wend CODE"G0 A0" While ISMOVING() Wend Code"#6=0" Code"#12=[#12+#11]" '********** N2: Do While Getvar(6) <= 359.9 CODE"G1 Y[#12-.010] F#7" While ISMOVING() Wend CODE"G1 X#5 F#9" While ISMOVING() Wend CODE"G1 Y#12" While ISMOVING() Wend CODE"G1 X#4 F100" While ISMOVING() Wend CODE"G0 Y#3" While ISMOVING() Wend CODE"G0 X#4" While ISMOVING() Wend CODE"#6=[#6+#2]" While ISMOVING() Wend CODE"G0 A#6" While ISMOVING() Wend GoTo N2: Exit Do Loop '********** If Getvar(12) < Getvar(8) Then GoTo N1 Else GoTo n10 '***Z infeed*** N11: '********** CODE"G0 X#4 Y0" While ISMOVING() Wend CODE"G0 Z#3" While ISMOVING() Wend CODE"G0 A0" While ISMOVING() Wend Code"#6=0" Code"#12=[#12+#11]" '*********** N21: '*********** Do While Getvar(6) <= 359.9 CODE"G1 Z[#12-.010] F#7" While ISMOVING() Wend CODE"G1 X#5 F#9" While ISMOVING() Wend CODE"G1 Z#12" While ISMOVING() Wend CODE"G1 X#4 F100" While ISMOVING() Wend CODE"G0 Z#3" While ISMOVING() Wend CODE"G0 X#4" While ISMOVING() Wend CODE"#6=[#6+#2]" While ISMOVING() Wend CODE"G0 A#6" While ISMOVING() Wend GoTo N21: Exit Do Loop '********** If Getvar(12) < Getvar(8) Then GoTo N11 else goto n10 '********** N10: Code"M5 M9" End Sub End
