<?xml version="1.0" encoding="UTF-8"?>
<Mach4ScreenInfo>
  <mcNotebookPage>
    <Property name="Name">ToolCarousel</Property>
    <Property name="Enabled">1</Property>
    <Property name="Hidden">0</Property>
    <Property name="Shown">1</Property>
    <Property name="Label">Tool Carousel</Property>
    <Property name="Hide Tab">0</Property>
    <Property name="Bg Color">#C0C0C0</Property>
    <Property name="Background Color">#C0C0C0</Property>
    <Property name="Bg Image"></Property>
    <Property name="Scale Method">0</Property>
    <Property name="Text Height">12</Property>
    <Property name="Global Script"></Property>
    <Event name="On Enter Script"></Event>
    <Event name="On Exit Script"></Event>
    <mcButton>
      <Property name="Name">btnReadTT</Property>
      <Property name="Instance">0</Property>
      <Property name="Top">165</Property>
      <Property name="Left">864</Property>
      <Property name="Height">55</Property>
      <Property name="Width">120</Property>
      <Property name="Enable With Machine">0</Property>
      <Property name="Enabled States">0</Property>
      <Property name="Label">Read From \nTool Table</Property>
      <Property name="Font">1;12;-16;0;0;0;700;0;0;0;1;0;0;2;32;Arial</Property>
      <Property name="Fg Color"></Property>
      <Property name="Text Color"></Property>
      <Property name="Bg Color"></Property>
      <Property name="Button Color"></Property>
      <Property name="Leave Is Up">0</Property>
      <Event name="Left Down Action">0</Event>
      <Event name="Left Up Action">0</Event>
      <Event name="Left Down Script">local inst = mc.mcGetInstance()
for pocketNum = 1, 10 do  -- Iterate through pocket numbers 1-10
    local toolFound = 0  -- Store tool number for this pocket
    for toolNum = 1, 250 do  -- Iterate through possible tool numbers (adjust if needed)
        local pocket = mc.mcToolGetData(inst, mc.MTOOL_MILL_POCKET, toolNum)  -- Get Pocket # for tool
        if pocket == pocketNum then
            toolFound = toolNum
            break  -- Stop searching once a tool is found for this pocket
        end
    end
    -- Define register name
    local regName = string.format("iRegs0/TC/ToolSlots/Slot%d", pocketNum)
    local regNameDesc = string.format("iRegs0/TC/ToolSlots/Slot%dDesc", pocketNum)
    local regNameNotes = string.format("iRegs0/TC/ToolSlots/Slot%dNotes", pocketNum)
    local regNameOffset = string.format("iRegs0/TC/ToolSlots/Slot%dOffset", pocketNum)
    -- Create and store the tool number in the register
    local hRegTnum = mc.mcRegGetHandle(inst, regName)
    mc.mcRegSetValue(hRegTnum, toolFound)
    -- Save description and notes
    if (toolFound &gt; 0 )then
        local hRegDesc = mc.mcRegGetHandle(inst, regNameDesc)
        local iToolDesc = mc.mcToolGetDesc(inst, toolFound)
        mc.mcRegSetValueString(hRegDesc, iToolDesc)
        local hRegNotes = mc.mcRegGetHandle(inst, regNameNotes)
        local iToolNotes = mc.mcToolGetDataExStr(inst, toolFound, "Notes")
        mc.mcRegSetValueString(hRegNotes, iToolNotes)
        local hRegOffset = mc.mcRegGetHandle(inst, regNameOffset)
        local iOffset = mc.mcToolGetData(inst, mc.MTOOL_MILL_HEIGHT, toolFound)
        if (iOffset == 999.999) then
		iOffset = "ToBeMeas"
        else iOffset = (string.format("%.4f",iOffset))
        end
        mc.mcRegSetValueString(hRegOffset, iOffset)
    -- Output message for debugging
        mc.mcCntlSetLastError(inst, string.format("Stored Tool #%d (%s, %s) in %s", toolFound, iToolDesc, iToolNotes, regName))
    else
        mc.mcCntlSetLastError(inst, string.format("No tool found for Slot #%d. Stored 0 in %s", pocketNum, regName))
    end
end</Event>
      <Event name="Left Up Script"></Event>
      <Event name="Clicked Action">0</Event>
      <Event name="Clicked Script"></Event>
      <Event name="Goto Page"></Event>
      <Event name="Run MDI"></Event>
    </mcButton>
    <mcButton>
      <Property name="Name">btnWriteTT</Property>
      <Property name="Top">249</Property>
      <Property name="Label">Write Slots \nTo Tool Table</Property>
-- Function to update tool assignments based on register values
local function UpdateToolPockets()
    -- Step 1: Search for tools currently assigned to pockets 1-10 and clear them
        for toolNum = 1, 250 do -- Adjust tool count if needed
            local currentPocket = mc.mcToolGetData(inst, mc.MTOOL_MILL_POCKET, toolNum)
            if currentPocket == pocketNum then
                mc.mcToolSetData(inst, mc.MTOOL_MILL_POCKET, toolNum, 0) -- Remove pocket assignment
                mc.mcCntlSetLastError(inst, string.format("Cleared Tool #%d from Slot #%d", toolNum, pocketNum))
                break
            end
        end
    end
    -- Step 2: Assign new tools to pockets based on register values
        -- Retrieve tool number from register
        local hReg = mc.mcRegGetHandle(inst, regName)
        local newToolNum = mc.mcRegGetValue(hReg)
        -- Validate tool number before assigning
        if newToolNum and newToolNum &gt; -1 then
            mc.mcToolSetData(inst, mc.MTOOL_MILL_POCKET, newToolNum, pocketNum)
            mc.mcCntlSetLastError(inst, string.format("Assigned Tool #%d to Slot #%d", newToolNum, pocketNum))
        else
            mc.mcCntlSetLastError(inst, string.format("No valid tool found in register for Slot #%d", pocketNum))
        end
    end
    mc.mcCntlSetLastError(inst, "Tool Slot Assignments Updated Successfully")
end
-- Run the function
UpdateToolPockets()</Event>
    </mcButton>
    <mcButton>
      <Property name="Name">btnWriteTTDesc</Property>
      <Property name="Top">333</Property>
      <Property name="Label">Save Notes\nTo Tool Table</Property>
local function UpdateToolNotes()
--    -- Step 1: Search for tools currently assigned to pockets 1-10 and clear them
--    for pocketNum = 1, 10 do
--        for toolNum = 1, 250 do -- Adjust tool count if needed
--            local currentPocket = mc.mcToolGetData(inst, mc.MTOOL_MILL_POCKET, toolNum)
--            if currentPocket == pocketNum then
--                mc.mcToolSetDataExStr(inst, toolNum, "Notes", 0) -- Remove pocket assignment
--                mc.mcCntlSetLastError(inst, string.format("Cleared Tool #%d from Slot #%d", toolNum, pocketNum))
--                break
--            end
--        end
--    end
        local iToolNum = mc.mcRegGetValue(hReg)
        local hReg2 = mc.mcRegGetHandle(inst, regNameNotes)
        local iToolNotes = mc.mcRegGetValueString(hReg2)
        if iToolNum and iToolNum &gt; -1 then
            if iToolNotes then
            mc.mcToolSetDataExStr(inst, iToolNum, "Notes", iToolNotes)
            mc.mcCntlSetLastError(inst, string.format("Notes added to Tool #%d", iToolNum))
            else
            mc.mcCntlSetLastError(inst, string.format("No notes to add to Tool #%d", iToolNum))
            end
        else
        end
    end
    mc.mcCntlSetLastError(inst, "All Tool Notes Updated Successfully")
end
-- Run the function
UpdateToolNotes()
</Event>
    </mcButton>
    <mcGroup>
      <Property name="Name">grpTools</Property>
      <Property name="Top">10</Property>
      <Property name="Left">10</Property>
      <Property name="Height">553</Property>
      <Property name="Width">848</Property>
      <Property name="Label"></Property>
      <Property name="No Border">0</Property>
      <mcTextCtrl>
        <Property name="Name">TRTool1</Property>
        <Property name="Top">51</Property>
        <Property name="Left">55</Property>
        <Property name="Height">40</Property>
        <Property name="Width">55</Property>
        <Property name="Editor">0</Property>
        <Property name="Justify">0</Property>
        <Property name="Border">3</Property>
        <Property name="Font">1;16;-21;0;0;0;700;0;0;0;0;3;2;1;34;Arial</Property>
        <Property name="Fg Color">#00FF00</Property>
        <Property name="Bg Color">#000000</Property>
        <Property name="Value">10</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot1</Property>
        <Event name="On Update Script"></Event>
        <Event name="On Modify Script"></Event>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool2</Property>
        <Property name="Top">102</Property>
        <Property name="Value">9</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot2</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool3</Property>
        <Property name="Top">153</Property>
        <Property name="Value">8</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot3</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool4</Property>
        <Property name="Top">203</Property>
        <Property name="Value">7</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot4</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool5</Property>
        <Property name="Top">253</Property>
        <Property name="Value">6</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot5</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool6</Property>
        <Property name="Top">303</Property>
        <Property name="Value">5</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot6</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool7</Property>
        <Property name="Top">353</Property>
        <Property name="Value">4</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot7</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool8</Property>
        <Property name="Top">403</Property>
        <Property name="Value">3</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot8</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool9</Property>
        <Property name="Top">453</Property>
        <Property name="Value">2</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot9</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool10</Property>
        <Property name="Top">503</Property>
        <Property name="Value">1</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot10</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc1</Property>
        <Property name="Left">123</Property>
        <Property name="Width">280</Property>
        <Property name="Editor">4</Property>
        <Property name="Justify">-1</Property>
        <Property name="Font">1;12;-16;0;0;0;900;0;0;0;0;3;2;1;34;Arial Narrow</Property>
        <Property name="Fg Color">#000000</Property>
        <Property name="Value">sadf</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot1Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc2</Property>
        <Property name="Value">fdeas</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot2Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc3</Property>
        <Property name="Value">efsaz</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot3Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc4</Property>
        <Property name="Value">vsvz</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot4Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc5</Property>
        <Property name="Value">fewsate</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot5Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc6</Property>
        <Property name="Value">aewr </Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot6Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc7</Property>
        <Property name="Value">fsefesa</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot7Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc8</Property>
        <Property name="Value">yea 3</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot8Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc9</Property>
        <Property name="Value">More 2</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot9Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRDesc10</Property>
        <Property name="Font">1;12;-16;0;0;0;700;0;0;0;1;0;0;2;32;Arial Narrow</Property>
        <Property name="Value">Some stuff1</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot10Desc</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool1(Lbl)</Property>
        <Property name="Top">49</Property>
        <Property name="Left">12</Property>
        <Property name="Height">45</Property>
        <Property name="Width">40</Property>
        <Property name="Border">0</Property>
        <Property name="Register"></Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool2(Lbl)</Property>
        <Property name="Top">100</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool3(Lbl)</Property>
        <Property name="Top">150</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool4(Lbl)</Property>
        <Property name="Top">200</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool5(Lbl)</Property>
        <Property name="Top">250</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool6(Lbl)</Property>
        <Property name="Top">300</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool7(Lbl)</Property>
        <Property name="Top">350</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool8(Lbl)</Property>
        <Property name="Top">400</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool9(Lbl)</Property>
        <Property name="Top">450</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRTool10(Lbl)</Property>
        <Property name="Top">500</Property>
        <Property name="Left">6</Property>
        <Property name="Width">47</Property>
      </mcTextCtrl>
      <mcStaticText>
        <Property name="Name">lbl(421)</Property>
        <Property name="Top">20</Property>
        <Property name="Height">25</Property>
        <Property name="Width">50</Property>
        <Property name="Label">Slot</Property>
        <Property name="Lines"></Property>
        <Property name="Font">1;16;-21;0;0;0;700;0;0;0;0;3;2;1;34;Arial Narrow</Property>
        <Property name="Label Code">-1</Property>
        <Property name="SysVar">0</Property>
        <Property name="SysParam">0</Property>
      </mcStaticText>
      <mcStaticText>
        <Property name="Name">lbl(289)</Property>
        <Property name="Left">52</Property>
        <Property name="Width">70</Property>
        <Property name="Label"> Tool #</Property>
      </mcStaticText>
      <mcStaticText>
        <Property name="Name">lbl(290)</Property>
        <Property name="Left">215</Property>
        <Property name="Height">30</Property>
        <Property name="Width">150</Property>
        <Property name="Label">Description</Property>
      </mcStaticText>
      <mcStaticText>
        <Property name="Name">lbl(286)</Property>
        <Property name="Left">498</Property>
        <Property name="Label">Notes</Property>
      </mcStaticText>
      <mcStaticText>
        <Property name="Name">lblOffset</Property>
        <Property name="Left">710</Property>
        <Property name="Width">60</Property>
        <Property name="Label">Offset</Property>
      </mcStaticText>
      <mcTextCtrl>
        <Property name="Name">TRNotes1</Property>
        <Property name="Left">405</Property>
        <Property name="Width">250</Property>
        <Property name="Value">tool 10?</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot1Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes2</Property>
        <Property name="Value"></Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot2Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes3</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot3Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes4</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot4Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes5</Property>
        <Property name="Value">lkjk</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot5Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes6</Property>
        <Property name="Value">bowsers</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot6Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes7</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot7Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes8</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot8Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes9</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot9Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TRNotes10</Property>
        <Property name="Value">25.6789</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot10Notes</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset1</Property>
        <Property name="Left">655</Property>
        <Property name="Width">124</Property>
        <Property name="Font">1;12;-16;0;0;0;400;0;0;0;0;3;2;1;34;Arial Narrow</Property>
        <Property name="Fg Color">#FFFF00</Property>
        <Property name="Value">ToBeMeas</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot1Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset2</Property>
        <Property name="Value">0.0000</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot2Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset3</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot3Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset4</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot4Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset5</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot5Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset6</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot6Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset7</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot7Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset8</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot8Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset9</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot9Offset</Property>
      </mcTextCtrl>
      <mcTextCtrl>
        <Property name="Name">TROffset10</Property>
        <Property name="Value">66.0000</Property>
        <Property name="Register">iRegs0/TC/ToolSlots/Slot10Offset</Property>
      </mcTextCtrl>
      <mcButton>
        <Property name="Name">Rstbtn1</Property>
        <Property name="Left">778</Property>
        <Property name="Label">CLR</Property>
        <Property name="Font">1;18;-24;0;0;0;700;1;0;0;1;0;0;2;32;Arial Narrow</Property>
        <Event name="Left Down Script">--This script takes the offset value for the tool in slot 1 and makes it 999.999 (which will be caught by the M6 as needing to remeasure)
local iSlotNumber = 1
-- Figure out which tool is in the slot
local regName = string.format("iRegs0/TC/ToolSlots/Slot%d", iSlotNumber)
--Go set the value of the offset to trigger a remeasure
mc.mcToolSetData(inst, mc.MTOOL_MILL_HEIGHT, iToolNum, 999.999)
mc.mcCntlSetLastError(inst, string.format("Tool #%d in Slot %d will be remeasured", iToolNum, iSlotNumber))</Event>
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn2</Property>
local iSlotNumber = 2
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn3</Property>
local iSlotNumber = 3
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn4</Property>
local iSlotNumber = 4
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn5</Property>
local iSlotNumber = 5
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn6</Property>
local iSlotNumber = 6
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn7</Property>
local iSlotNumber = 7
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn8</Property>
local iSlotNumber = 8
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn9</Property>
local iSlotNumber = 9
      </mcButton>
      <mcButton>
        <Property name="Name">Rstbtn10</Property>
local iSlotNumber = 10
      </mcButton>
    </mcGroup>
  </mcNotebookPage>
</Mach4ScreenInfo>
