[Preferences] Profile=New LaserESS Screen=wx4.set MotionDevice=ESS JogInc=1.000000 JogRate=1.000000 SetupUnits=210 LookAhead=20 AxisRolloverA=0 AxisRolloverB=0 AxisRolloverC=0 CoolantDelay=1.0000 MistDelay=1.0000 JogInc1=1 JogInc2=0.1 JogInc3=0.01 JogInc4=0.001 JogInc5=0.0001 JogInc6=1 JogInc7=0.1 JogInc8=0.01 JogInc9=0.001 JogInc10=0.0001 SetvnStart=500 SetvnEnd=549 FileExtensions=*.tap; *.nc GcodeEditor=C:\\Mach4Hobby\\gcedit CommentsInMessages=0 DerefAxesInEstop=0 StopIsControlled=0 UseAdvGui=1 FeedHoldStopsSpindle=0 ExitFeedHoldRestoresSpindle=0 CheckProbeSignalBeforeProbeOp=1 ProbeFollowsUnitsMode=0 UseZeroBrane=1 BackupProfiles=20 MaxTools=99 MotorMaxRPM=0.000000 SpindleOverrideDelay=25 EnableStepDirRtap=0 EnableSpindleStabilizeWait=0 SpindleStabilizeWaitPercent=90 DisableVboToolPath=0 UseLazyToolPathUpdate=0 AutoCalc=0 JogTrace=1 OpLock=0 CustomColor0=#FFFFFF CustomColor1=#FFFFFF CustomColor2=#FFFFFF CustomColor3=#FFFFFF CustomColor4=#FFFFFF CustomColor5=#FFFFFF CustomColor6=#FFFFFF CustomColor7=#FFFFFF CustomColor8=#FFFFFF CustomColor9=#FFFFFF CustomColor10=#FFFFFF CustomColor11=#FFFFFF CustomColor12=#FFFFFF CustomColor13=#FFFFFF CustomColor14=#FFFFFF CustomColor15=#FFFFFF LastOpenDir=C:\\CNC [Motor0] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=1000.000000 CountsPerUnitAux=2100.000000 MaxVelocity=266666.666667 MaxAccel=800000.000000 BacklashAmount=0.000000 SoftMaxLimit=1960000.000000 SoftMinLimit=0.000000 EnableDelay=0 AuxPosEnable=0 AuxPosToPlanner=0 AuxPosEnabled=0 [Motor1] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=1000.000000 CountsPerUnitAux=2100.000000 MaxVelocity=266666.666667 MaxAccel=800000.000000 BacklashAmount=0.000000 SoftMaxLimit=1472000.000000 SoftMinLimit=0.000000 EnableDelay=0 AuxPosEnable=0 AuxPosToPlanner=0 AuxPosEnabled=0 [Motor2] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=800.000000 CountsPerUnitAux=800.000000 MaxVelocity=73333.333333 MaxAccel=1200000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=-308000.000000 EnableDelay=0 AuxPosEnable=0 AuxPosToPlanner=0 AuxPosEnabled=0 [Motor3] Enabled=0 Reverse=0 CanHome=1 CountsPerUnit=20000.000000 CountsPerUnitAux=20000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 AuxPosEnable=0 AuxPosToPlanner=0 AuxPosEnabled=0 [Motor4] Enabled=0 Reverse=0 CanHome=1 CountsPerUnit=20000.000000 CountsPerUnitAux=20000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 AuxPosEnable=0 AuxPosToPlanner=0 AuxPosEnabled=0 [Motor5] Enabled=0 Reverse=0 CanHome=1 CountsPerUnit=20000.000000 CountsPerUnitAux=20000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 AuxPosEnable=0 AuxPosToPlanner=0 AuxPosEnabled=0 [Plugins] Warp9Mach4=1 mcLua=1 mcRegfile=1 Sim=0 TMC3in1=0 WarpRunner=0 mcKeyboard=1 mcModbus=0 mcSerial=0 mcSurfaceMap=0 mcXBox=0 ShuttlePro=0 [Signal161] ID=161 Type=Input Desc=Probe Enabled=1 Negated=0 Mapping=ESS/Probe [Signal183] ID=183 Type=Input Desc=Probe1 Enabled=0 Negated=0 Mapping=None [Signal184] ID=184 Type=Input Desc=Probe2 Enabled=0 Negated=0 Mapping=None [Signal185] ID=185 Type=Input Desc=Probe3 Enabled=0 Negated=0 Mapping=None [Signal208] ID=208 Type=Input Desc=Probe4 Enabled=0 Negated=0 Mapping=None [Signal209] ID=209 Type=Input Desc=Probe5 Enabled=0 Negated=0 Mapping=None [Signal210] ID=210 Type=Input Desc=Probe6 Enabled=0 Negated=0 Mapping=None [Signal211] ID=211 Type=Input Desc=Probe7 Enabled=0 Negated=0 Mapping=None [Signal212] ID=212 Type=Input Desc=Probe8 Enabled=0 Negated=0 Mapping=None [Signal213] ID=213 Type=Input Desc=Probe9 Enabled=0 Negated=0 Mapping=None [Signal162] ID=162 Type=Input Desc=Index Enabled=0 Negated=0 Mapping=None [Signal1] ID=1 Type=Input Desc=Input #0 Enabled=1 Negated=0 Mapping=ESS/OUT0-FH Flyer [Signal2] ID=2 Type=Input Desc=Input #1 Enabled=1 Negated=0 Mapping=ESS/OUT1-FH Flyer [Signal3] ID=3 Type=Input Desc=Input #2 Enabled=1 Negated=0 Mapping=ESS/OUT2-FH Flyer [Signal4] ID=4 Type=Input Desc=Input #3 Enabled=1 Negated=0 Mapping=ESS/OUT3-FH Flyer [Signal5] ID=5 Type=Input Desc=Input #4 Enabled=1 Negated=0 Mapping=ESS/OUT4-FH Flyer [Signal6] ID=6 Type=Input Desc=Input #5 Enabled=0 Negated=0 Mapping=None [Signal7] ID=7 Type=Input Desc=Input #6 Enabled=0 Negated=0 Mapping=None [Signal8] ID=8 Type=Input Desc=Input #7 Enabled=0 Negated=0 Mapping=None [Signal9] ID=9 Type=Input Desc=Input #8 Enabled=0 Negated=0 Mapping=None [Signal10] ID=10 Type=Input Desc=Input #9 Enabled=0 Negated=0 Mapping=None [Signal11] ID=11 Type=Input Desc=Input #10 Enabled=0 Negated=0 Mapping=None [Signal12] ID=12 Type=Input Desc=Input #11 Enabled=0 Negated=0 Mapping=None [Signal13] ID=13 Type=Input Desc=Input #12 Enabled=0 Negated=0 Mapping=None [Signal14] ID=14 Type=Input Desc=Input #13 Enabled=0 Negated=0 Mapping=None [Signal15] ID=15 Type=Input Desc=Input #14 Enabled=0 Negated=0 Mapping=None [Signal16] ID=16 Type=Input Desc=Input #15 Enabled=0 Negated=0 Mapping=None [Signal17] ID=17 Type=Input Desc=Input #16 Enabled=0 Negated=0 Mapping=None [Signal18] ID=18 Type=Input Desc=Input #17 Enabled=0 Negated=0 Mapping=None [Signal19] ID=19 Type=Input Desc=Input #18 Enabled=0 Negated=0 Mapping=None [Signal20] ID=20 Type=Input Desc=Input #19 Enabled=0 Negated=0 Mapping=None [Signal21] ID=21 Type=Input Desc=Input #20 Enabled=0 Negated=0 Mapping=None [Signal22] ID=22 Type=Input Desc=Input #21 Enabled=0 Negated=0 Mapping=None [Signal23] ID=23 Type=Input Desc=Input #22 Enabled=0 Negated=0 Mapping=None [Signal24] ID=24 Type=Input Desc=Input #23 Enabled=0 Negated=0 Mapping=None [Signal25] ID=25 Type=Input Desc=Input #24 Enabled=0 Negated=0 Mapping=None [Signal26] ID=26 Type=Input Desc=Input #25 Enabled=0 Negated=0 Mapping=None [Signal27] ID=27 Type=Input Desc=Input #26 Enabled=0 Negated=0 Mapping=None [Signal28] ID=28 Type=Input Desc=Input #27 Enabled=0 Negated=0 Mapping=None [Signal29] ID=29 Type=Input Desc=Input #28 Enabled=0 Negated=0 Mapping=None [Signal30] ID=30 Type=Input Desc=Input #29 Enabled=0 Negated=0 Mapping=None [Signal31] ID=31 Type=Input Desc=Input #30 Enabled=0 Negated=0 Mapping=None [Signal32] ID=32 Type=Input Desc=Input #31 Enabled=0 Negated=0 Mapping=None [Signal33] ID=33 Type=Input Desc=Input #32 Enabled=0 Negated=0 Mapping=None [Signal34] ID=34 Type=Input Desc=Input #33 Enabled=0 Negated=0 Mapping=None [Signal35] ID=35 Type=Input Desc=Input #34 Enabled=0 Negated=0 Mapping=None [Signal36] ID=36 Type=Input Desc=Input #35 Enabled=0 Negated=0 Mapping=None [Signal37] ID=37 Type=Input Desc=Input #36 Enabled=0 Negated=0 Mapping=None [Signal38] ID=38 Type=Input Desc=Input #37 Enabled=0 Negated=0 Mapping=None [Signal39] ID=39 Type=Input Desc=Input #38 Enabled=0 Negated=0 Mapping=None [Signal40] ID=40 Type=Input Desc=Input #39 Enabled=0 Negated=0 Mapping=None [Signal41] ID=41 Type=Input Desc=Input #40 Enabled=0 Negated=0 Mapping=None [Signal42] ID=42 Type=Input Desc=Input #41 Enabled=0 Negated=0 Mapping=None [Signal43] ID=43 Type=Input Desc=Input #42 Enabled=0 Negated=0 Mapping=None [Signal44] ID=44 Type=Input Desc=Input #43 Enabled=0 Negated=0 Mapping=None [Signal45] ID=45 Type=Input Desc=Input #44 Enabled=0 Negated=0 Mapping=None [Signal46] ID=46 Type=Input Desc=Input #45 Enabled=0 Negated=0 Mapping=None [Signal47] ID=47 Type=Input Desc=Input #46 Enabled=0 Negated=0 Mapping=None [Signal48] ID=48 Type=Input Desc=Input #47 Enabled=0 Negated=0 Mapping=None [Signal49] ID=49 Type=Input Desc=Input #48 Enabled=0 Negated=0 Mapping=None [Signal50] ID=50 Type=Input Desc=Input #49 Enabled=0 Negated=0 Mapping=None [Signal51] ID=51 Type=Input Desc=Input #50 Enabled=0 Negated=0 Mapping=None [Signal52] ID=52 Type=Input Desc=Input #51 Enabled=0 Negated=0 Mapping=None [Signal53] ID=53 Type=Input Desc=Input #52 Enabled=0 Negated=0 Mapping=None [Signal54] ID=54 Type=Input Desc=Input #53 Enabled=0 Negated=0 Mapping=None [Signal55] ID=55 Type=Input Desc=Input #54 Enabled=0 Negated=0 Mapping=None [Signal56] ID=56 Type=Input Desc=Input #55 Enabled=0 Negated=0 Mapping=None [Signal57] ID=57 Type=Input Desc=Input #56 Enabled=0 Negated=0 Mapping=None [Signal58] ID=58 Type=Input Desc=Input #57 Enabled=0 Negated=0 Mapping=None [Signal59] ID=59 Type=Input Desc=Input #58 Enabled=0 Negated=0 Mapping=None [Signal60] ID=60 Type=Input Desc=Input #59 Enabled=0 Negated=0 Mapping=None [Signal61] ID=61 Type=Input Desc=Input #60 Enabled=0 Negated=0 Mapping=None [Signal62] ID=62 Type=Input Desc=Input #61 Enabled=0 Negated=0 Mapping=None [Signal63] ID=63 Type=Input Desc=Input #62 Enabled=0 Negated=0 Mapping=None [Signal64] ID=64 Type=Input Desc=Input #63 Enabled=0 Negated=0 Mapping=None [Signal163] ID=163 Type=Input Desc=Limit Override Enabled=0 Negated=0 Mapping=None [Signal164] ID=164 Type=Input Desc=E-Stop Enabled=1 Negated=0 Mapping=ESS/E-Stop input [Signal165] ID=165 Type=Input Desc=THC On Enabled=0 Negated=0 Mapping=None [Signal166] ID=166 Type=Input Desc=THC Up Enabled=0 Negated=0 Mapping=None [Signal167] ID=167 Type=Input Desc=THC Down Enabled=0 Negated=0 Mapping=None [Signal168] ID=168 Type=Input Desc=Timing Enabled=0 Negated=0 Mapping=None [Signal169] ID=169 Type=Input Desc=Jog X+ Enabled=0 Negated=0 Mapping=None [Signal170] ID=170 Type=Input Desc=Jog X- Enabled=0 Negated=0 Mapping=None [Signal171] ID=171 Type=Input Desc=Jog Y+ Enabled=0 Negated=0 Mapping=None [Signal172] ID=172 Type=Input Desc=Jog Y- Enabled=0 Negated=0 Mapping=None [Signal173] ID=173 Type=Input Desc=Jog Z+ Enabled=0 Negated=0 Mapping=None [Signal174] ID=174 Type=Input Desc=Jog Z- Enabled=0 Negated=0 Mapping=None [Signal175] ID=175 Type=Input Desc=Jog A+ Enabled=0 Negated=0 Mapping=None [Signal176] ID=176 Type=Input Desc=Jog A- Enabled=0 Negated=0 Mapping=None [Signal177] ID=177 Type=Input Desc=Jog B+ Enabled=0 Negated=0 Mapping=None [Signal178] ID=178 Type=Input Desc=Jog B- Enabled=0 Negated=0 Mapping=None [Signal179] ID=179 Type=Input Desc=Jog C+ Enabled=0 Negated=0 Mapping=None [Signal180] ID=180 Type=Input Desc=Jog C- Enabled=0 Negated=0 Mapping=None [Signal196] ID=196 Type=Input Desc=Jog OB1+ Enabled=0 Negated=0 Mapping=None [Signal197] ID=197 Type=Input Desc=Jog OB1- Enabled=0 Negated=0 Mapping=None [Signal198] ID=198 Type=Input Desc=Jog OB2+ Enabled=0 Negated=0 Mapping=None [Signal199] ID=199 Type=Input Desc=Jog OB2- Enabled=0 Negated=0 Mapping=None [Signal200] ID=200 Type=Input Desc=Jog OB3+ Enabled=0 Negated=0 Mapping=None [Signal201] ID=201 Type=Input Desc=Jog OB3- Enabled=0 Negated=0 Mapping=None [Signal202] ID=202 Type=Input Desc=Jog OB4+ Enabled=0 Negated=0 Mapping=None [Signal203] ID=203 Type=Input Desc=Jog OB4- Enabled=0 Negated=0 Mapping=None [Signal204] ID=204 Type=Input Desc=Jog OB5+ Enabled=0 Negated=0 Mapping=None [Signal205] ID=205 Type=Input Desc=Jog OB5- Enabled=0 Negated=0 Mapping=None [Signal206] ID=206 Type=Input Desc=Jog OB6+ Enabled=0 Negated=0 Mapping=None [Signal207] ID=207 Type=Input Desc=Jog OB6- Enabled=0 Negated=0 Mapping=None [Signal181] ID=181 Type=Input Desc=Spindle At Speed Enabled=0 Negated=0 Mapping=None [Signal182] ID=182 Type=Input Desc=Spindle At Zero Enabled=0 Negated=0 Mapping=None [Signal189] ID=189 Type=Input Desc=TLM Tool Skip Enabled=0 Negated=0 Mapping=None [Signal190] ID=190 Type=Input Desc=TLM Override Enabled=0 Negated=0 Mapping=None [Signal191] ID=191 Type=Input Desc=TLM Reset Enabled=0 Negated=0 Mapping=None [Signal192] ID=192 Type=Input Desc=User Interrupt Enabled=0 Negated=0 Mapping=None [Signal193] ID=193 Type=Input Desc=Retract Enabled=0 Negated=0 Mapping=None [Signal194] ID=194 Type=Input Desc=Path Selection Enabled=0 Negated=0 Mapping=None [Signal195] ID=195 Type=Input Desc=No Wait Enabled=0 Negated=0 Mapping=None [Signal186] ID=186 Type=Input Desc=Motion Inhibit Enabled=0 Negated=0 Mapping=None [Signal187] ID=187 Type=Input Desc=Jog Inhibit Enabled=0 Negated=0 Mapping=None [Signal188] ID=188 Type=Input Desc=MPG Inhibit Enabled=0 Negated=0 Mapping=None [Signal65] ID=65 Type=Input Desc=Motor 0 Home Enabled=1 Negated=0 Mapping=ESS/X axis Home [Signal97] ID=97 Type=Input Desc=Motor 0 ++ Enabled=0 Negated=0 Mapping=None [Signal129] ID=129 Type=Input Desc=Motor 0 -- Enabled=0 Negated=0 Mapping=None [Signal66] ID=66 Type=Input Desc=Motor 1 Home Enabled=1 Negated=0 Mapping=ESS/Y Axis Home [Signal98] ID=98 Type=Input Desc=Motor 1 ++ Enabled=0 Negated=0 Mapping=None [Signal130] ID=130 Type=Input Desc=Motor 1 -- Enabled=0 Negated=0 Mapping=None [Signal67] ID=67 Type=Input Desc=Motor 2 Home Enabled=1 Negated=0 Mapping=ESS/Z axis Home [Signal99] ID=99 Type=Input Desc=Motor 2 ++ Enabled=0 Negated=0 Mapping=None [Signal131] ID=131 Type=Input Desc=Motor 2 -- Enabled=0 Negated=0 Mapping=None [Signal68] ID=68 Type=Input Desc=Motor 3 Home Enabled=0 Negated=0 Mapping=None [Signal100] ID=100 Type=Input Desc=Motor 3 ++ Enabled=0 Negated=0 Mapping=None [Signal132] ID=132 Type=Input Desc=Motor 3 -- Enabled=0 Negated=0 Mapping=None [Signal69] ID=69 Type=Input Desc=Motor 4 Home Enabled=0 Negated=0 Mapping=None [Signal101] ID=101 Type=Input Desc=Motor 4 ++ Enabled=0 Negated=0 Mapping=None [Signal133] ID=133 Type=Input Desc=Motor 4 -- Enabled=0 Negated=0 Mapping=None [Signal70] ID=70 Type=Input Desc=Motor 5 Home Enabled=0 Negated=0 Mapping=None [Signal102] ID=102 Type=Input Desc=Motor 5 ++ Enabled=0 Negated=0 Mapping=None [Signal134] ID=134 Type=Input Desc=Motor 5 -- Enabled=0 Negated=0 Mapping=None [Signal71] ID=71 Type=Input Desc=Motor 6 Home Enabled=0 Negated=0 Mapping=None [Signal103] ID=103 Type=Input Desc=Motor 6 ++ Enabled=0 Negated=0 Mapping=None [Signal135] ID=135 Type=Input Desc=Motor 6 -- Enabled=0 Negated=0 Mapping=None [Signal72] ID=72 Type=Input Desc=Motor 7 Home Enabled=0 Negated=0 Mapping=None [Signal104] ID=104 Type=Input Desc=Motor 7 ++ Enabled=0 Negated=0 Mapping=None [Signal136] ID=136 Type=Input Desc=Motor 7 -- Enabled=0 Negated=0 Mapping=None [Signal73] ID=73 Type=Input Desc=Motor 8 Home Enabled=0 Negated=0 Mapping=None [Signal105] ID=105 Type=Input Desc=Motor 8 ++ Enabled=0 Negated=0 Mapping=None [Signal137] ID=137 Type=Input Desc=Motor 8 -- Enabled=0 Negated=0 Mapping=None [Signal74] ID=74 Type=Input Desc=Motor 9 Home Enabled=0 Negated=0 Mapping=None [Signal106] ID=106 Type=Input Desc=Motor 9 ++ Enabled=0 Negated=0 Mapping=None [Signal138] ID=138 Type=Input Desc=Motor 9 -- Enabled=0 Negated=0 Mapping=None [Signal75] ID=75 Type=Input Desc=Motor 10 Home Enabled=0 Negated=0 Mapping=None [Signal107] ID=107 Type=Input Desc=Motor 10 ++ Enabled=0 Negated=0 Mapping=None [Signal139] ID=139 Type=Input Desc=Motor 10 -- Enabled=0 Negated=0 Mapping=None [Signal76] ID=76 Type=Input Desc=Motor 11 Home Enabled=0 Negated=0 Mapping=None [Signal108] ID=108 Type=Input Desc=Motor 11 ++ Enabled=0 Negated=0 Mapping=None [Signal140] ID=140 Type=Input Desc=Motor 11 -- Enabled=0 Negated=0 Mapping=None [Signal77] ID=77 Type=Input Desc=Motor 12 Home Enabled=0 Negated=0 Mapping=None [Signal109] ID=109 Type=Input Desc=Motor 12 ++ Enabled=0 Negated=0 Mapping=None [Signal141] ID=141 Type=Input Desc=Motor 12 -- Enabled=0 Negated=0 Mapping=None [Signal78] ID=78 Type=Input Desc=Motor 13 Home Enabled=0 Negated=0 Mapping=None [Signal110] ID=110 Type=Input Desc=Motor 13 ++ Enabled=0 Negated=0 Mapping=None [Signal142] ID=142 Type=Input Desc=Motor 13 -- Enabled=0 Negated=0 Mapping=None [Signal79] ID=79 Type=Input Desc=Motor 14 Home Enabled=0 Negated=0 Mapping=None [Signal111] ID=111 Type=Input Desc=Motor 14 ++ Enabled=0 Negated=0 Mapping=None [Signal143] ID=143 Type=Input Desc=Motor 14 -- Enabled=0 Negated=0 Mapping=None [Signal80] ID=80 Type=Input Desc=Motor 15 Home Enabled=0 Negated=0 Mapping=None [Signal112] ID=112 Type=Input Desc=Motor 15 ++ Enabled=0 Negated=0 Mapping=None [Signal144] ID=144 Type=Input Desc=Motor 15 -- Enabled=0 Negated=0 Mapping=None [Signal81] ID=81 Type=Input Desc=Motor 16 Home Enabled=0 Negated=0 Mapping=None [Signal113] ID=113 Type=Input Desc=Motor 16 ++ Enabled=0 Negated=0 Mapping=None [Signal145] ID=145 Type=Input Desc=Motor 16 -- Enabled=0 Negated=0 Mapping=None [Signal82] ID=82 Type=Input Desc=Motor 17 Home Enabled=0 Negated=0 Mapping=None [Signal114] ID=114 Type=Input Desc=Motor 17 ++ Enabled=0 Negated=0 Mapping=None [Signal146] ID=146 Type=Input Desc=Motor 17 -- Enabled=0 Negated=0 Mapping=None [Signal83] ID=83 Type=Input Desc=Motor 18 Home Enabled=0 Negated=0 Mapping=None [Signal115] ID=115 Type=Input Desc=Motor 18 ++ Enabled=0 Negated=0 Mapping=None [Signal147] ID=147 Type=Input Desc=Motor 18 -- Enabled=0 Negated=0 Mapping=None [Signal84] ID=84 Type=Input Desc=Motor 19 Home Enabled=0 Negated=0 Mapping=None [Signal116] ID=116 Type=Input Desc=Motor 19 ++ Enabled=0 Negated=0 Mapping=None [Signal148] ID=148 Type=Input Desc=Motor 19 -- Enabled=0 Negated=0 Mapping=None [Signal85] ID=85 Type=Input Desc=Motor 20 Home Enabled=0 Negated=0 Mapping=None [Signal117] ID=117 Type=Input Desc=Motor 20 ++ Enabled=0 Negated=0 Mapping=None [Signal149] ID=149 Type=Input Desc=Motor 20 -- Enabled=0 Negated=0 Mapping=None [Signal86] ID=86 Type=Input Desc=Motor 21 Home Enabled=0 Negated=0 Mapping=None [Signal118] ID=118 Type=Input Desc=Motor 21 ++ Enabled=0 Negated=0 Mapping=None [Signal150] ID=150 Type=Input Desc=Motor 21 -- Enabled=0 Negated=0 Mapping=None [Signal87] ID=87 Type=Input Desc=Motor 22 Home Enabled=0 Negated=0 Mapping=None [Signal119] ID=119 Type=Input Desc=Motor 22 ++ Enabled=0 Negated=0 Mapping=None [Signal151] ID=151 Type=Input Desc=Motor 22 -- Enabled=0 Negated=0 Mapping=None [Signal88] ID=88 Type=Input Desc=Motor 23 Home Enabled=0 Negated=0 Mapping=None [Signal120] ID=120 Type=Input Desc=Motor 23 ++ Enabled=0 Negated=0 Mapping=None [Signal152] ID=152 Type=Input Desc=Motor 23 -- Enabled=0 Negated=0 Mapping=None [Signal89] ID=89 Type=Input Desc=Motor 24 Home Enabled=0 Negated=0 Mapping=None [Signal121] ID=121 Type=Input Desc=Motor 24 ++ Enabled=0 Negated=0 Mapping=None [Signal153] ID=153 Type=Input Desc=Motor 24 -- Enabled=0 Negated=0 Mapping=None [Signal90] ID=90 Type=Input Desc=Motor 25 Home Enabled=0 Negated=0 Mapping=None [Signal122] ID=122 Type=Input Desc=Motor 25 ++ Enabled=0 Negated=0 Mapping=None [Signal154] ID=154 Type=Input Desc=Motor 25 -- Enabled=0 Negated=0 Mapping=None [Signal91] ID=91 Type=Input Desc=Motor 26 Home Enabled=0 Negated=0 Mapping=None [Signal123] ID=123 Type=Input Desc=Motor 26 ++ Enabled=0 Negated=0 Mapping=None [Signal155] ID=155 Type=Input Desc=Motor 26 -- Enabled=0 Negated=0 Mapping=None [Signal92] ID=92 Type=Input Desc=Motor 27 Home Enabled=0 Negated=0 Mapping=None [Signal124] ID=124 Type=Input Desc=Motor 27 ++ Enabled=0 Negated=0 Mapping=None [Signal156] ID=156 Type=Input Desc=Motor 27 -- Enabled=0 Negated=0 Mapping=None [Signal93] ID=93 Type=Input Desc=Motor 28 Home Enabled=0 Negated=0 Mapping=None [Signal125] ID=125 Type=Input Desc=Motor 28 ++ Enabled=0 Negated=0 Mapping=None [Signal157] ID=157 Type=Input Desc=Motor 28 -- Enabled=0 Negated=0 Mapping=None [Signal94] ID=94 Type=Input Desc=Motor 29 Home Enabled=0 Negated=0 Mapping=None [Signal126] ID=126 Type=Input Desc=Motor 29 ++ Enabled=0 Negated=0 Mapping=None [Signal158] ID=158 Type=Input Desc=Motor 29 -- Enabled=0 Negated=0 Mapping=None [Signal95] ID=95 Type=Input Desc=Motor 30 Home Enabled=0 Negated=0 Mapping=None [Signal127] ID=127 Type=Input Desc=Motor 30 ++ Enabled=0 Negated=0 Mapping=None [Signal159] ID=159 Type=Input Desc=Motor 30 -- Enabled=0 Negated=0 Mapping=None [Signal96] ID=96 Type=Input Desc=Motor 31 Home Enabled=0 Negated=0 Mapping=None [Signal128] ID=128 Type=Input Desc=Motor 31 ++ Enabled=0 Negated=0 Mapping=None [Signal160] ID=160 Type=Input Desc=Motor 31 -- Enabled=0 Negated=0 Mapping=None [Signal1146] ID=1146 Type=Output Desc=Digitize Trigger Enabled=0 Negated=0 Mapping=None [Signal1141] ID=1141 Type=Output Desc=Spindle On Enabled=1 Negated=0 Mapping=ESS/Spindle 1 Right [Signal1142] ID=1142 Type=Output Desc=Spindle Fwd Enabled=0 Negated=0 Mapping=None [Signal1143] ID=1143 Type=Output Desc=Spindle Rev Enabled=0 Negated=0 Mapping=None [Signal1144] ID=1144 Type=Output Desc=Coolant On Enabled=1 Negated=0 Mapping=ESS/vysavac externi rele [Signal1145] ID=1145 Type=Output Desc=Mist On Enabled=0 Negated=0 Mapping=None [Signal1138] ID=1138 Type=Output Desc=Reserved #1 Enabled=0 Negated=0 Mapping=None [Signal1139] ID=1139 Type=Output Desc=Reserved #2 Enabled=0 Negated=0 Mapping=None [Signal1140] ID=1140 Type=Output Desc=Current Hi/Low Enabled=0 Negated=0 Mapping=None [Signal1018] ID=1018 Type=Output Desc=Enable #0 Enabled=1 Negated=0 Mapping=ESS/Servo Enable [Signal1019] ID=1019 Type=Output Desc=Enable #1 Enabled=0 Negated=0 Mapping=None [Signal1020] ID=1020 Type=Output Desc=Enable #2 Enabled=0 Negated=0 Mapping=None [Signal1021] ID=1021 Type=Output Desc=Enable #3 Enabled=0 Negated=0 Mapping=None [Signal1022] ID=1022 Type=Output Desc=Enable #4 Enabled=0 Negated=0 Mapping=None [Signal1023] ID=1023 Type=Output Desc=Enable #5 Enabled=0 Negated=0 Mapping=None [Signal1024] ID=1024 Type=Output Desc=Enable #6 Enabled=0 Negated=0 Mapping=None [Signal1025] ID=1025 Type=Output Desc=Enable #7 Enabled=0 Negated=0 Mapping=None [Signal1026] ID=1026 Type=Output Desc=Enable #8 Enabled=0 Negated=0 Mapping=None [Signal1027] ID=1027 Type=Output Desc=Enable #9 Enabled=0 Negated=0 Mapping=None [Signal1028] ID=1028 Type=Output Desc=Enable #10 Enabled=0 Negated=0 Mapping=None [Signal1029] ID=1029 Type=Output Desc=Enable #11 Enabled=0 Negated=0 Mapping=None [Signal1030] ID=1030 Type=Output Desc=Enable #12 Enabled=0 Negated=0 Mapping=None [Signal1031] ID=1031 Type=Output Desc=Enable #13 Enabled=0 Negated=0 Mapping=None [Signal1032] ID=1032 Type=Output Desc=Enable #14 Enabled=0 Negated=0 Mapping=None [Signal1033] ID=1033 Type=Output Desc=Enable #15 Enabled=0 Negated=0 Mapping=None [Signal1034] ID=1034 Type=Output Desc=Enable #16 Enabled=0 Negated=0 Mapping=None [Signal1035] ID=1035 Type=Output Desc=Enable #17 Enabled=0 Negated=0 Mapping=None [Signal1036] ID=1036 Type=Output Desc=Enable #18 Enabled=0 Negated=0 Mapping=None [Signal1037] ID=1037 Type=Output Desc=Enable #19 Enabled=0 Negated=0 Mapping=None [Signal1038] ID=1038 Type=Output Desc=Enable #20 Enabled=0 Negated=0 Mapping=None [Signal1039] ID=1039 Type=Output Desc=Enable #21 Enabled=0 Negated=0 Mapping=None [Signal1040] ID=1040 Type=Output Desc=Enable #22 Enabled=0 Negated=0 Mapping=None [Signal1041] ID=1041 Type=Output Desc=Enable #23 Enabled=0 Negated=0 Mapping=None [Signal1042] ID=1042 Type=Output Desc=Enable #24 Enabled=0 Negated=0 Mapping=None [Signal1043] ID=1043 Type=Output Desc=Enable #25 Enabled=0 Negated=0 Mapping=None [Signal1044] ID=1044 Type=Output Desc=Enable #26 Enabled=0 Negated=0 Mapping=None [Signal1045] ID=1045 Type=Output Desc=Enable #27 Enabled=0 Negated=0 Mapping=None [Signal1046] ID=1046 Type=Output Desc=Enable #28 Enabled=0 Negated=0 Mapping=None [Signal1047] ID=1047 Type=Output Desc=Enable #29 Enabled=0 Negated=0 Mapping=None [Signal1048] ID=1048 Type=Output Desc=Enable #30 Enabled=0 Negated=0 Mapping=None [Signal1049] ID=1049 Type=Output Desc=Enable #31 Enabled=0 Negated=0 Mapping=None [Signal1000] ID=1000 Type=Output Desc=X ++ Enabled=0 Negated=0 Mapping=None [Signal1001] ID=1001 Type=Output Desc=X -- Enabled=0 Negated=0 Mapping=None [Signal1002] ID=1002 Type=Output Desc=X Home Enabled=0 Negated=0 Mapping=None [Signal1003] ID=1003 Type=Output Desc=Y ++ Enabled=0 Negated=0 Mapping=None [Signal1004] ID=1004 Type=Output Desc=Y -- Enabled=0 Negated=0 Mapping=None [Signal1005] ID=1005 Type=Output Desc=Y Home Enabled=0 Negated=0 Mapping=None [Signal1006] ID=1006 Type=Output Desc=Z ++ Enabled=0 Negated=0 Mapping=None [Signal1007] ID=1007 Type=Output Desc=Z -- Enabled=0 Negated=0 Mapping=None [Signal1008] ID=1008 Type=Output Desc=Z Home Enabled=0 Negated=0 Mapping=None [Signal1009] ID=1009 Type=Output Desc=A ++ Enabled=0 Negated=0 Mapping=None [Signal1010] ID=1010 Type=Output Desc=A -- Enabled=0 Negated=0 Mapping=None [Signal1011] ID=1011 Type=Output Desc=A Home Enabled=0 Negated=0 Mapping=None [Signal1012] ID=1012 Type=Output Desc=B ++ Enabled=0 Negated=0 Mapping=None [Signal1013] ID=1013 Type=Output Desc=B -- Enabled=0 Negated=0 Mapping=None [Signal1014] ID=1014 Type=Output Desc=B Home Enabled=0 Negated=0 Mapping=None [Signal1015] ID=1015 Type=Output Desc=C ++ Enabled=0 Negated=0 Mapping=None [Signal1016] ID=1016 Type=Output Desc=C -- Enabled=0 Negated=0 Mapping=None [Signal1017] ID=1017 Type=Output Desc=C Home Enabled=0 Negated=0 Mapping=None [Signal1152] ID=1152 Type=Output Desc=OB1 ++ Enabled=0 Negated=0 Mapping=None [Signal1153] ID=1153 Type=Output Desc=OB1 -- Enabled=0 Negated=0 Mapping=None [Signal1154] ID=1154 Type=Output Desc=OB1 Home Enabled=0 Negated=0 Mapping=None [Signal1155] ID=1155 Type=Output Desc=OB2 ++ Enabled=0 Negated=0 Mapping=None [Signal1156] ID=1156 Type=Output Desc=OB2 -- Enabled=0 Negated=0 Mapping=None [Signal1157] ID=1157 Type=Output Desc=OB2 Home Enabled=0 Negated=0 Mapping=None [Signal1158] ID=1158 Type=Output Desc=OB3 ++ Enabled=0 Negated=0 Mapping=None [Signal1159] ID=1159 Type=Output Desc=OB3 -- Enabled=0 Negated=0 Mapping=None [Signal1160] ID=1160 Type=Output Desc=OB3 Home Enabled=0 Negated=0 Mapping=None [Signal1161] ID=1161 Type=Output Desc=OB4 ++ Enabled=0 Negated=0 Mapping=None [Signal1162] ID=1162 Type=Output Desc=OB4 -- Enabled=0 Negated=0 Mapping=None [Signal1163] ID=1163 Type=Output Desc=OB4 Home Enabled=0 Negated=0 Mapping=None [Signal1164] ID=1164 Type=Output Desc=OB5 ++ Enabled=0 Negated=0 Mapping=None [Signal1165] ID=1165 Type=Output Desc=OB5 -- Enabled=0 Negated=0 Mapping=None [Signal1166] ID=1166 Type=Output Desc=OB5 Home Enabled=0 Negated=0 Mapping=None [Signal1167] ID=1167 Type=Output Desc=OB6 ++ Enabled=0 Negated=0 Mapping=None [Signal1168] ID=1168 Type=Output Desc=OB6 -- Enabled=0 Negated=0 Mapping=None [Signal1169] ID=1169 Type=Output Desc=OB6 Home Enabled=0 Negated=0 Mapping=None [Signal1050] ID=1050 Type=Output Desc=Output #0 Enabled=1 Negated=0 Mapping=ESS/IN0-FH Flyer [Signal1051] ID=1051 Type=Output Desc=Output #1 Enabled=1 Negated=0 Mapping=ESS/IN1-FH Flyer [Signal1052] ID=1052 Type=Output Desc=Output #2 Enabled=1 Negated=0 Mapping=ESS/IN2-FH Flyer [Signal1053] ID=1053 Type=Output Desc=Output #3 Enabled=1 Negated=0 Mapping=ESS/IN3-FH Flyer [Signal1054] ID=1054 Type=Output Desc=Output #4 Enabled=1 Negated=0 Mapping=ESS/IN4-FH Flyer [Signal1055] ID=1055 Type=Output Desc=Output #5 Enabled=1 Negated=0 Mapping=ESS/IN5-FH Flyer [Signal1056] ID=1056 Type=Output Desc=Output #6 Enabled=1 Negated=0 Mapping=ESS/IN6-FH Flyer [Signal1057] ID=1057 Type=Output Desc=Output #7 Enabled=1 Negated=0 Mapping=ESS/Stop Laser [Signal1058] ID=1058 Type=Output Desc=Output #8 Enabled=0 Negated=0 Mapping=None [Signal1059] ID=1059 Type=Output Desc=Output #9 Enabled=0 Negated=0 Mapping=None [Signal1060] ID=1060 Type=Output Desc=Output #10 Enabled=1 Negated=0 Mapping=ESS/Rele Laser [Signal1061] ID=1061 Type=Output Desc=Output #11 Enabled=1 Negated=0 Mapping=ESS/AFAG DOWN [Signal1062] ID=1062 Type=Output Desc=Output #12 Enabled=0 Negated=0 Mapping=None [Signal1063] ID=1063 Type=Output Desc=Output #13 Enabled=1 Negated=0 Mapping=ESS/Pritlak DOWN [Signal1064] ID=1064 Type=Output Desc=Output #14 Enabled=1 Negated=0 Mapping=ESS/Pritlak UP [Signal1065] ID=1065 Type=Output Desc=Output #15 Enabled=0 Negated=0 Mapping=None [Signal1066] ID=1066 Type=Output Desc=Output #16 Enabled=0 Negated=0 Mapping=None [Signal1067] ID=1067 Type=Output Desc=Output #17 Enabled=0 Negated=0 Mapping=None [Signal1068] ID=1068 Type=Output Desc=Output #18 Enabled=0 Negated=0 Mapping=None [Signal1069] ID=1069 Type=Output Desc=Output #19 Enabled=0 Negated=0 Mapping=None [Signal1070] ID=1070 Type=Output Desc=Output #20 Enabled=1 Negated=0 Mapping=ESS/Laser Gate [Signal1071] ID=1071 Type=Output Desc=Output #21 Enabled=0 Negated=0 Mapping=None [Signal1072] ID=1072 Type=Output Desc=Output #22 Enabled=0 Negated=0 Mapping=None [Signal1073] ID=1073 Type=Output Desc=Output #23 Enabled=0 Negated=0 Mapping=None [Signal1074] ID=1074 Type=Output Desc=Output #24 Enabled=0 Negated=0 Mapping=None [Signal1075] ID=1075 Type=Output Desc=Output #25 Enabled=0 Negated=0 Mapping=None [Signal1076] ID=1076 Type=Output Desc=Output #26 Enabled=0 Negated=0 Mapping=None [Signal1077] ID=1077 Type=Output Desc=Output #27 Enabled=0 Negated=0 Mapping=None [Signal1078] ID=1078 Type=Output Desc=Output #28 Enabled=0 Negated=0 Mapping=None [Signal1079] ID=1079 Type=Output Desc=Output #29 Enabled=0 Negated=0 Mapping=None [Signal1080] ID=1080 Type=Output Desc=Output #30 Enabled=0 Negated=0 Mapping=None [Signal1081] ID=1081 Type=Output Desc=Output #31 Enabled=0 Negated=0 Mapping=None [Signal1082] ID=1082 Type=Output Desc=Output #32 Enabled=0 Negated=0 Mapping=None [Signal1083] ID=1083 Type=Output Desc=Output #33 Enabled=0 Negated=0 Mapping=None [Signal1084] ID=1084 Type=Output Desc=Output #34 Enabled=0 Negated=0 Mapping=None [Signal1085] ID=1085 Type=Output Desc=Output #35 Enabled=0 Negated=0 Mapping=None [Signal1086] ID=1086 Type=Output Desc=Output #36 Enabled=0 Negated=0 Mapping=None [Signal1087] ID=1087 Type=Output Desc=Output #37 Enabled=0 Negated=0 Mapping=None [Signal1088] ID=1088 Type=Output Desc=Output #38 Enabled=0 Negated=0 Mapping=None [Signal1089] ID=1089 Type=Output Desc=Output #39 Enabled=0 Negated=0 Mapping=None [Signal1090] ID=1090 Type=Output Desc=Output #40 Enabled=0 Negated=0 Mapping=None [Signal1091] ID=1091 Type=Output Desc=Output #41 Enabled=0 Negated=0 Mapping=None [Signal1092] ID=1092 Type=Output Desc=Output #42 Enabled=0 Negated=0 Mapping=None [Signal1093] ID=1093 Type=Output Desc=Output #43 Enabled=0 Negated=0 Mapping=None [Signal1094] ID=1094 Type=Output Desc=Output #44 Enabled=0 Negated=0 Mapping=None [Signal1095] ID=1095 Type=Output Desc=Output #45 Enabled=0 Negated=0 Mapping=None [Signal1096] ID=1096 Type=Output Desc=Output #46 Enabled=0 Negated=0 Mapping=None [Signal1097] ID=1097 Type=Output Desc=Output #47 Enabled=0 Negated=0 Mapping=None [Signal1098] ID=1098 Type=Output Desc=Output #48 Enabled=0 Negated=0 Mapping=None [Signal1099] ID=1099 Type=Output Desc=Output #49 Enabled=0 Negated=0 Mapping=None [Signal1100] ID=1100 Type=Output Desc=Output #50 Enabled=0 Negated=0 Mapping=None [Signal1101] ID=1101 Type=Output Desc=Output #51 Enabled=0 Negated=0 Mapping=None [Signal1102] ID=1102 Type=Output Desc=Output #52 Enabled=0 Negated=0 Mapping=None [Signal1103] ID=1103 Type=Output Desc=Output #53 Enabled=0 Negated=0 Mapping=None [Signal1104] ID=1104 Type=Output Desc=Output #54 Enabled=0 Negated=0 Mapping=None [Signal1105] ID=1105 Type=Output Desc=Output #55 Enabled=0 Negated=0 Mapping=None [Signal1106] ID=1106 Type=Output Desc=Output #56 Enabled=0 Negated=0 Mapping=None [Signal1107] ID=1107 Type=Output Desc=Output #57 Enabled=0 Negated=0 Mapping=None [Signal1108] ID=1108 Type=Output Desc=Output #58 Enabled=0 Negated=0 Mapping=None [Signal1109] ID=1109 Type=Output Desc=Output #59 Enabled=0 Negated=0 Mapping=None [Signal1110] ID=1110 Type=Output Desc=Output #60 Enabled=0 Negated=0 Mapping=None [Signal1111] ID=1111 Type=Output Desc=Output #61 Enabled=0 Negated=0 Mapping=None [Signal1112] ID=1112 Type=Output Desc=Output #62 Enabled=0 Negated=0 Mapping=None [Signal1113] ID=1113 Type=Output Desc=Output #63 Enabled=0 Negated=0 Mapping=None [Signal1114] ID=1114 Type=Output Desc=Gcode Running Enabled=0 Negated=0 Mapping=None [Signal1115] ID=1115 Type=Output Desc=Feed Hold Enabled=0 Negated=0 Mapping=None [Signal1116] ID=1116 Type=Output Desc=Block Delete Enabled=0 Negated=0 Mapping=None [Signal1117] ID=1117 Type=Output Desc=Single Block Enabled=0 Negated=0 Mapping=None [Signal1118] ID=1118 Type=Output Desc=Reverse Run Enabled=0 Negated=0 Mapping=None [Signal1119] ID=1119 Type=Output Desc=Opt Stop Enabled=0 Negated=0 Mapping=None [Signal1120] ID=1120 Type=Output Desc=Machine Enabled Enabled=0 Negated=0 Mapping=None [Signal1121] ID=1121 Type=Output Desc=Tool Change Enabled=0 Negated=0 Mapping=None [Signal1122] ID=1122 Type=Output Desc=Dist To Go Enabled=0 Negated=0 Mapping=None [Signal1123] ID=1123 Type=Output Desc=Machine Coord Enabled=0 Negated=0 Mapping=None [Signal1124] ID=1124 Type=Output Desc=Softlimits On Enabled=0 Negated=0 Mapping=None [Signal1125] ID=1125 Type=Output Desc=Jog Inc Enabled=0 Negated=0 Mapping=None [Signal1126] ID=1126 Type=Output Desc=Jog Cont Enabled=0 Negated=0 Mapping=None [Signal1127] ID=1127 Type=Output Desc=Jog Enabled Enabled=0 Negated=0 Mapping=None [Signal1128] ID=1128 Type=Output Desc=Jog MPG Enabled=0 Negated=0 Mapping=None [Signal1129] ID=1129 Type=Output Desc=X Homed Enabled=0 Negated=0 Mapping=None [Signal1130] ID=1130 Type=Output Desc=Y Homed Enabled=0 Negated=0 Mapping=None [Signal1131] ID=1131 Type=Output Desc=Z Homed Enabled=0 Negated=0 Mapping=None [Signal1132] ID=1132 Type=Output Desc=A Homed Enabled=0 Negated=0 Mapping=None [Signal1133] ID=1133 Type=Output Desc=B Homed Enabled=0 Negated=0 Mapping=None [Signal1134] ID=1134 Type=Output Desc=C Homed Enabled=0 Negated=0 Mapping=None [Signal1174] ID=1174 Type=Output Desc=OB1 Homed Enabled=0 Negated=0 Mapping=None [Signal1175] ID=1175 Type=Output Desc=OB2 Homed Enabled=0 Negated=0 Mapping=None [Signal1176] ID=1176 Type=Output Desc=OB3 Homed Enabled=0 Negated=0 Mapping=None [Signal1177] ID=1177 Type=Output Desc=OB4 Homed Enabled=0 Negated=0 Mapping=None [Signal1178] ID=1178 Type=Output Desc=OB5 Homed Enabled=0 Negated=0 Mapping=None [Signal1179] ID=1179 Type=Output Desc=OB6 Homed Enabled=0 Negated=0 Mapping=None [Signal1135] ID=1135 Type=Output Desc=Dwell Enabled=0 Negated=0 Mapping=None [Signal1136] ID=1136 Type=Output Desc=Toolpath Mouse Down Enabled=0 Negated=0 Mapping=None [Signal1137] ID=1137 Type=Output Desc=Limit Override Enabled=0 Negated=0 Mapping=None [Signal1147] ID=1147 Type=Output Desc=Alarm Enabled=0 Negated=0 Mapping=None [Signal1148] ID=1148 Type=Output Desc=Parts Finished Enabled=0 Negated=0 Mapping=None [Signal1149] ID=1149 Type=Output Desc=TLM Tool Change Enabled=0 Negated=0 Mapping=None [Signal1150] ID=1150 Type=Output Desc=Waiting Enabled=0 Negated=0 Mapping=None [Signal1151] ID=1151 Type=Output Desc=Retract Enabled=0 Negated=0 Mapping=None [Signal1170] ID=1170 Type=Output Desc=Cut Recovery Enabled=0 Negated=0 Mapping=None [Signal1171] ID=1171 Type=Output Desc=Spindle SpeedCheck Enabled=0 Negated=0 Mapping=None [Signal1172] ID=1172 Type=Output Desc=Machine Idle Enabled=0 Negated=0 Mapping=None [Signal1173] ID=1173 Type=Output Desc=Machine Probing Enabled=0 Negated=0 Mapping=None [Signal1180] ID=1180 Type=Output Desc=Feed Hold Disabled Enabled=0 Negated=0 Mapping=None [Signal1181] ID=1181 Type=Output Desc=Feed Rate Ovr Disabled Enabled=0 Negated=0 Mapping=None [Signal1182] ID=1182 Type=Output Desc=Spindle Ovr Disabled Enabled=0 Negated=0 Mapping=None [Signal1183] ID=1183 Type=Output Desc=Rapid Rate Ovr Enabled=0 Negated=0 Mapping=None [Signal1184] ID=1184 Type=Output Desc=Spindle Ovr Enabled=0 Negated=0 Mapping=None [Signal1185] ID=1185 Type=Output Desc=Feed Rate Ovr Enabled=0 Negated=0 Mapping=None [Stats] TotalHours=0.040261 SpindleHours=0.052873 DistanceX=6494.908724 DistanceY=4202.344500 DistanceZ=1158.448410 DistanceA=0.000000 DistanceB=0.000000 DistanceC=0.000000 M3=0 M4=6 M6=6 [Startup] SetDefaultUnitsOnStart=0 [DefaultMode] ControlMode=0 UnitsMode=G21 TraverseMode=G0 MotionMode=G64 DistanceMode=G90 CenterMode=G91.1 FeedMode=G94 Plane=G17 CanedCycleRetract=G98 SpindleMode=G97S0 JogUnitsMode=0 [Axis0] Enabled=1 HomeDir=-1 HomeOrder=2 HomeOffset=75.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=1 ChildMotor0=Motor0 [Axis1] Enabled=1 HomeDir=1 HomeOrder=3 HomeOffset=1035.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=1 ChildMotor0=Motor1 [Axis2] Enabled=1 HomeDir=1 HomeOrder=1 HomeOffset=-41.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=1 ChildMotor0=Motor2 [Axis3] Enabled=0 HomeDir=1 HomeOrder=4 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 [Axis4] Enabled=0 HomeDir=1 HomeOrder=5 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 [Axis5] Enabled=0 HomeDir=1 HomeOrder=6 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 [Axis6] Enabled=0 HomeDir=1 HomeOrder=0 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 SpindleAxis=0 [Axis7] Enabled=0 HomeDir=1 HomeOrder=0 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 SpindleAxis=0 [Axis8] Enabled=0 HomeDir=1 HomeOrder=0 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 SpindleAxis=0 [Axis9] Enabled=0 HomeDir=1 HomeOrder=0 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 SpindleAxis=0 [Axis10] Enabled=0 HomeDir=1 HomeOrder=0 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 SpindleAxis=0 [Axis11] Enabled=0 HomeDir=1 HomeOrder=0 HomeOffset=0.000000 HomeSpeedPercent=20.000000 HomeInPlace=0 SoftLimitUsed=0 SpindleAxis=0 [Mpg0] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg1] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg2] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg3] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg4] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg5] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg6] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg7] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg8] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg9] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg10] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg11] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [SpindleRange0] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange1] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange2] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange3] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange4] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange5] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange6] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange7] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange8] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange9] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange10] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange11] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange12] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange13] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange14] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange15] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange16] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange17] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange18] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [SpindleRange19] MinRPM=0.000000 MaxRPM=0.000000 AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=0.000000 Reversed=0 [Toolpath] UseFrame=0 LineWidthMode=0 [ARotoryAxisPosition] RotationAbout=-1 [iReg1] Name=nf/TRC/cutDepth Desc=Depth of cuts. InitialValue=-0.05 Persistent=1 Value=-0.05 [iReg2] Name=nf/TRC/materialTop Desc=Top of stock. InitialValue=0 Persistent=0 [iReg3] Name=nf/TRC/plungeRate Desc=Feed rate of a plunge move. InitialValue=15 Persistent=1 Value=15 [iReg4] Name=nf/TRC/safeZ Desc=Safe Z position. InitialValue=0.25 Persistent=1 Value=0.25 [iReg5] Name=nf/TRC/spinRpm Desc=RPM of the spindle. InitialValue=24000 Persistent=1 Value=24000 [iReg6] Name=nf/TRC/subAdd Desc=Subtract or remove material. InitialValue=-1 Persistent=0 [iReg7] Name=nf/TRC/totalDepth Desc=Total depth of cut. InitialValue=-0.1 Persistent=1 Value=-0.1 [KeyboardKey0] IO_Name=X- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=37 Function=2 [KeyboardKey1] IO_Name=X+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=39 Function=1 [KeyboardKey2] IO_Name=Y- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=40 Function=8 [KeyboardKey3] IO_Name=Y+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=38 Function=7 [KeyboardKey4] IO_Name=Z- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=34 Function=14 [KeyboardKey5] IO_Name=Z+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=33 Function=13 [KeyboardKey6] IO_Name=Rapid X- Shift=1 Alt=0 Ctrl=0 Lock=0 KeyCode=37 Function=4 [KeyboardKey7] IO_Name=Rapid X+ Shift=1 Alt=0 Ctrl=0 Lock=0 KeyCode=39 Function=3 [KeyboardKey8] IO_Name=Rapid Y- Shift=1 Alt=0 Ctrl=0 Lock=0 KeyCode=40 Function=10 [KeyboardKey9] IO_Name=Rapid Y+ Shift=1 Alt=0 Ctrl=0 Lock=0 KeyCode=38 Function=9 [KeyboardKey10] IO_Name=Rapid Z- Shift=1 Alt=0 Ctrl=0 Lock=0 KeyCode=34 Function=16 [KeyboardKey11] IO_Name=Rapid Z+ Shift=1 Alt=0 Ctrl=0 Lock=0 KeyCode=33 Function=15 [mcInfo] posX=390 posY=342 width=500 height=300 aot=0 [ESS] iMach4VersionWarning_4612=1 BoardIpAddr=10.9.9.9 MotionBufferSize=0.1800 PluginFrequency=40 ShowHWVelocityFifoErrorWindow=1 ShowSWVelocityFifoErrors=0 ChargePumpRunsInEStop=1 iDisableExpansionPortWithDisable=1 EnableAdvancedLogging=0 iFeedHold_PromptOperatorBeforeTurningOutputOnAgain=1 iFeedHold_PromptOperatorBeforeTurningOutputOffAgain=1 Motor-0-Mode=Step/Dir Motor-0-FeedRateSmoothing=0.100 Motor-1-Mode=Step/Dir Motor-1-FeedRateSmoothing=0.100 Motor-2-Mode=Step/Dir Motor-2-FeedRateSmoothing=0.100 Motor-3-Mode=Step/Dir Motor-3-FeedRateSmoothing=0.100 Motor-4-Mode=Step/Dir Motor-4-FeedRateSmoothing=0.100 Motor-5-Mode=Step/Dir Motor-5-FeedRateSmoothing=0.100 UseAntiClunk=1 iSuppressMotorAssignmentWarnings=1 Spindle-Mode=Relay RPMSourceSpindleIndex=1 RPMSourceSpindleEncoderA=0 PwmDutyCycleZeroAtMinRPM=0 iReportSpindleRPM=0 UseSpindlePID=0 UsePidWhileThreading=0 CreatePidLogFile=0 SpindlePID_Kp=0.0000100 SpindlePID_Ki=0.0000000 SpindlePID_Kd=0.0000000 IndexPulsesPerRev=1 EncoderPrescaler=1 d_SpindleRpmAveraging=1.000 iUseSpindlePidRpmFloor=0 dPidRpmFloorPercentage=0.950 iUseSpindlePidRpmCeiling=0 dPidRpmCeilingPercentage=1.200 PermitLaserTestMode=0 dLaserTestModePowerLevel=15.1 Use5kHzTickle=0 LaserPwmFrequencyMax=20000 LaserAllowsHigherHz=0 iLaserAirAssistOutputNumber=10 LaserPwmFrequencyRaster=20000 LaserGateDelayRaster=20.000 LaserGateDurationRaster=80.000 LaserPwmFrequencyVector=20000 LaserGateDelayVector=20.000 LaserGateDurationVector=80.000 i_LaserShowUsersImage=0 i_LaserShowProcessedImage=0 iVerifyImageSizeAgainstSoftLimtsBeforeRaster=1 LaserFlipImageVertically=1 LaserFlipImageHorizontally=0 LaserInvertImageIntensities=0 LaserCompsForAccelDistanceX=1 iShowStartLaserRasterWindow=1 LaserRasterEvenRowsOnly=0 iEnableLaserVectorSpeedComp=1 dLaserVectorSpeedCompNoBurnPwmPercentage=0.00 iEnableLaserVectorSpeedCompNonLinear=0 iLaserRasterStartingCorner=1 Port2Pins2_9_Direction=Outputs Port3Pins2_9_Direction=Inputs Port1-Pin1-Alias=IN1-FH Flyer Port1-Pin1-ActiveLow=0 Port1-Pin1-NoiseFilterValue=0.00 Port1-Pin1-OutputPinStopState=No Change Port1-Pin1-OutputPinFeedHoldState=No Change Port1-Pin2-Alias=X Step Port1-Pin2-ActiveLow=1 Port1-Pin2-NoiseFilterValue=0.00 Port1-Pin2-OutputPinStopState=No Change Port1-Pin2-OutputPinFeedHoldState=No Change Port1-Pin3-Alias=X Dir Port1-Pin3-ActiveLow=1 Port1-Pin3-NoiseFilterValue=0.00 Port1-Pin3-OutputPinStopState=No Change Port1-Pin3-OutputPinFeedHoldState=No Change Port1-Pin4-Alias=Z Dir Port1-Pin4-ActiveLow=0 Port1-Pin4-NoiseFilterValue=0.00 Port1-Pin4-OutputPinStopState=No Change Port1-Pin4-OutputPinFeedHoldState=No Change Port1-Pin5-Alias=Spindle 1 Right Port1-Pin5-ActiveLow=0 Port1-Pin5-NoiseFilterValue=0.00 Port1-Pin5-OutputPinStopState=No Change Port1-Pin5-OutputPinFeedHoldState=No Change Port1-Pin6-Alias=Charge Pump non working Port1-Pin6-ActiveLow=0 Port1-Pin6-NoiseFilterValue=0.00 Port1-Pin6-OutputPinStopState=No Change Port1-Pin6-OutputPinFeedHoldState=No Change Port1-Pin7-Alias=Servo Enable Port1-Pin7-ActiveLow=0 Port1-Pin7-NoiseFilterValue=0.00 Port1-Pin7-OutputPinStopState=No Change Port1-Pin7-OutputPinFeedHoldState=No Change Port1-Pin8-Alias=Spindle 2 left Port1-Pin8-ActiveLow=0 Port1-Pin8-NoiseFilterValue=0.00 Port1-Pin8-OutputPinStopState=No Change Port1-Pin8-OutputPinFeedHoldState=No Change Port1-Pin9-Alias=Z Step Port1-Pin9-ActiveLow=1 Port1-Pin9-NoiseFilterValue=0.00 Port1-Pin9-OutputPinStopState=No Change Port1-Pin9-OutputPinFeedHoldState=No Change Port1-Pin10-Alias=Y Axis Home Port1-Pin10-ActiveLow=1 Port1-Pin10-NoiseFilterValue=0.00 Port1-Pin10-OutputPinStopState=----- Port1-Pin10-OutputPinFeedHoldState=----- Port1-Pin11-Alias=OUT0-FH Flyer Port1-Pin11-ActiveLow=1 Port1-Pin11-NoiseFilterValue=0.00 Port1-Pin11-OutputPinStopState=----- Port1-Pin11-OutputPinFeedHoldState=----- Port1-Pin12-Alias=OUT1-FH Flyer Port1-Pin12-ActiveLow=1 Port1-Pin12-NoiseFilterValue=0.00 Port1-Pin12-OutputPinStopState=----- Port1-Pin12-OutputPinFeedHoldState=----- Port1-Pin13-Alias=OUT2-FH Flyer Port1-Pin13-ActiveLow=1 Port1-Pin13-NoiseFilterValue=0.00 Port1-Pin13-OutputPinStopState=----- Port1-Pin13-OutputPinFeedHoldState=----- Port1-Pin14-Alias=vysavac externi rele Port1-Pin14-ActiveLow=0 Port1-Pin14-NoiseFilterValue=0.00 Port1-Pin14-OutputPinStopState=No Change Port1-Pin14-OutputPinFeedHoldState=No Change Port1-Pin15-Alias=OUT3-FH Flyer Port1-Pin15-ActiveLow=1 Port1-Pin15-NoiseFilterValue=0.00 Port1-Pin15-OutputPinStopState=----- Port1-Pin15-OutputPinFeedHoldState=----- Port1-Pin16-Alias=Rele Laser Port1-Pin16-ActiveLow=0 Port1-Pin16-NoiseFilterValue=0.00 Port1-Pin16-OutputPinStopState=No Change Port1-Pin16-OutputPinFeedHoldState=No Change Port1-Pin17-Alias=Laser Pin Port1-Pin17-ActiveLow=0 Port1-Pin17-NoiseFilterValue=0.00 Port1-Pin17-OutputPinStopState=No Change Port1-Pin17-OutputPinFeedHoldState=No Change Port2-Pin1-Alias=IN0-FH Flyer Port2-Pin1-ActiveLow=1 Port2-Pin1-NoiseFilterValue=0.00 Port2-Pin1-OutputPinStopState=No Change Port2-Pin1-OutputPinFeedHoldState=No Change Port2-Pin2-Alias=A Dir Port2-Pin2-ActiveLow=0 Port2-Pin2-NoiseFilterValue=0.00 Port2-Pin2-OutputPinStopState=No Change Port2-Pin2-OutputPinFeedHoldState=No Change Port2-Pin3-Alias=A Step Port2-Pin3-ActiveLow=1 Port2-Pin3-NoiseFilterValue=0.00 Port2-Pin3-OutputPinStopState=No Change Port2-Pin3-OutputPinFeedHoldState=No Change Port2-Pin4-Alias=Y Step Port2-Pin4-ActiveLow=1 Port2-Pin4-NoiseFilterValue=0.00 Port2-Pin4-OutputPinStopState=No Change Port2-Pin4-OutputPinFeedHoldState=No Change Port2-Pin5-Alias=AFAG DOWN Port2-Pin5-ActiveLow=0 Port2-Pin5-NoiseFilterValue=0.00 Port2-Pin5-OutputPinStopState=No Change Port2-Pin5-OutputPinFeedHoldState=No Change Port2-Pin6-Alias=IN3-FH Flyer Port2-Pin6-ActiveLow=1 Port2-Pin6-NoiseFilterValue=0.00 Port2-Pin6-OutputPinStopState=No Change Port2-Pin6-OutputPinFeedHoldState=No Change Port2-Pin7-Alias=IN4-FH Flyer Port2-Pin7-ActiveLow=1 Port2-Pin7-NoiseFilterValue=0.00 Port2-Pin7-OutputPinStopState=No Change Port2-Pin7-OutputPinFeedHoldState=No Change Port2-Pin8-Alias=IN5-FH Flyer Port2-Pin8-ActiveLow=1 Port2-Pin8-NoiseFilterValue=0.00 Port2-Pin8-OutputPinStopState=No Change Port2-Pin8-OutputPinFeedHoldState=No Change Port2-Pin9-Alias=Y Dir Port2-Pin9-ActiveLow=0 Port2-Pin9-NoiseFilterValue=0.00 Port2-Pin9-OutputPinStopState=No Change Port2-Pin9-OutputPinFeedHoldState=No Change Port2-Pin10-Alias=OUT4-FH Flyer Port2-Pin10-ActiveLow=1 Port2-Pin10-NoiseFilterValue=0.00 Port2-Pin10-OutputPinStopState=----- Port2-Pin10-OutputPinFeedHoldState=----- Port2-Pin11-Alias=Probe Port2-Pin11-ActiveLow=1 Port2-Pin11-NoiseFilterValue=0.00 Port2-Pin11-OutputPinStopState=----- Port2-Pin11-OutputPinFeedHoldState=----- Port2-Pin12-Alias=Z axis Home Port2-Pin12-ActiveLow=1 Port2-Pin12-NoiseFilterValue=0.00 Port2-Pin12-OutputPinStopState=----- Port2-Pin12-OutputPinFeedHoldState=----- Port2-Pin13-Alias=E-Stop input Port2-Pin13-ActiveLow=1 Port2-Pin13-NoiseFilterValue=0.00 Port2-Pin13-OutputPinStopState=----- Port2-Pin13-OutputPinFeedHoldState=----- Port2-Pin14-Alias=IN6-FH Flyer Port2-Pin14-ActiveLow=1 Port2-Pin14-NoiseFilterValue=0.00 Port2-Pin14-OutputPinStopState=No Change Port2-Pin14-OutputPinFeedHoldState=No Change Port2-Pin15-Alias=X axis Home Port2-Pin15-ActiveLow=1 Port2-Pin15-NoiseFilterValue=0.00 Port2-Pin15-OutputPinStopState=----- Port2-Pin15-OutputPinFeedHoldState=----- Port2-Pin16-Alias=Stop Laser Port2-Pin16-ActiveLow=0 Port2-Pin16-NoiseFilterValue=0.00 Port2-Pin16-OutputPinStopState=No Change Port2-Pin16-OutputPinFeedHoldState=No Change Port2-Pin17-Alias=IN2-FH Flyer Port2-Pin17-ActiveLow=0 Port2-Pin17-NoiseFilterValue=0.00 Port2-Pin17-OutputPinStopState=No Change Port2-Pin17-OutputPinFeedHoldState=No Change Port3-Pin1-Alias={P3-1} Port3-Pin1-ActiveLow=0 Port3-Pin1-NoiseFilterValue=0.00 Port3-Pin1-OutputPinStopState=No Change Port3-Pin1-OutputPinFeedHoldState=No Change Port3-Pin2-Alias={P3-2} Port3-Pin2-ActiveLow=0 Port3-Pin2-NoiseFilterValue=0.00 Port3-Pin2-OutputPinStopState=----- Port3-Pin2-OutputPinFeedHoldState=----- Port3-Pin3-Alias={P3-3} Port3-Pin3-ActiveLow=0 Port3-Pin3-NoiseFilterValue=0.00 Port3-Pin3-OutputPinStopState=----- Port3-Pin3-OutputPinFeedHoldState=----- Port3-Pin4-Alias={P3-4} Port3-Pin4-ActiveLow=0 Port3-Pin4-NoiseFilterValue=0.00 Port3-Pin4-OutputPinStopState=----- Port3-Pin4-OutputPinFeedHoldState=----- Port3-Pin5-Alias={P3-5} Port3-Pin5-ActiveLow=0 Port3-Pin5-NoiseFilterValue=0.00 Port3-Pin5-OutputPinStopState=----- Port3-Pin5-OutputPinFeedHoldState=----- Port3-Pin6-Alias={P3-6} Port3-Pin6-ActiveLow=0 Port3-Pin6-NoiseFilterValue=0.00 Port3-Pin6-OutputPinStopState=----- Port3-Pin6-OutputPinFeedHoldState=----- Port3-Pin7-Alias={P3-7} Port3-Pin7-ActiveLow=0 Port3-Pin7-NoiseFilterValue=0.00 Port3-Pin7-OutputPinStopState=----- Port3-Pin7-OutputPinFeedHoldState=----- Port3-Pin8-Alias={P3-8} Port3-Pin8-ActiveLow=0 Port3-Pin8-NoiseFilterValue=0.00 Port3-Pin8-OutputPinStopState=----- Port3-Pin8-OutputPinFeedHoldState=----- Port3-Pin9-Alias={P3-9} Port3-Pin9-ActiveLow=0 Port3-Pin9-NoiseFilterValue=0.00 Port3-Pin9-OutputPinStopState=----- Port3-Pin9-OutputPinFeedHoldState=----- Port3-Pin10-Alias={P3-10} Port3-Pin10-ActiveLow=0 Port3-Pin10-NoiseFilterValue=0.00 Port3-Pin10-OutputPinStopState=----- Port3-Pin10-OutputPinFeedHoldState=----- Port3-Pin11-Alias={P3-11} Port3-Pin11-ActiveLow=0 Port3-Pin11-NoiseFilterValue=0.00 Port3-Pin11-OutputPinStopState=----- Port3-Pin11-OutputPinFeedHoldState=----- Port3-Pin12-Alias={P3-12} Port3-Pin12-ActiveLow=0 Port3-Pin12-NoiseFilterValue=0.00 Port3-Pin12-OutputPinStopState=----- Port3-Pin12-OutputPinFeedHoldState=----- Port3-Pin13-Alias={P3-13} Port3-Pin13-ActiveLow=0 Port3-Pin13-NoiseFilterValue=0.00 Port3-Pin13-OutputPinStopState=----- Port3-Pin13-OutputPinFeedHoldState=----- Port3-Pin14-Alias=Pritlak DOWN Port3-Pin14-ActiveLow=0 Port3-Pin14-NoiseFilterValue=0.00 Port3-Pin14-OutputPinStopState=No Change Port3-Pin14-OutputPinFeedHoldState=No Change Port3-Pin15-Alias={P3-15} Port3-Pin15-ActiveLow=0 Port3-Pin15-NoiseFilterValue=0.00 Port3-Pin15-OutputPinStopState=----- Port3-Pin15-OutputPinFeedHoldState=----- Port3-Pin16-Alias=Pritlak UP Port3-Pin16-ActiveLow=0 Port3-Pin16-NoiseFilterValue=0.00 Port3-Pin16-OutputPinStopState=No Change Port3-Pin16-OutputPinFeedHoldState=No Change Port3-Pin17-Alias=Laser Gate Port3-Pin17-ActiveLow=0 Port3-Pin17-NoiseFilterValue=0.00 Port3-Pin17-OutputPinStopState=No Change Port3-Pin17-OutputPinFeedHoldState=No Change ISigMap-EStop-Enable=1 ISigMap-EStop=E-Stop input ISigMap-Motor0-Home-Enable=1 ISigMap-Motor0-Home=X axis Home ISigMap-Motor1-Home-Enable=1 ISigMap-Motor1-Home=Y Axis Home ISigMap-Motor2-Home-Enable=1 ISigMap-Motor2-Home=Z axis Home ISigMap-Motor3-Home-Enable=0 ISigMap-Motor4-Home-Enable=0 ISigMap-Motor5-Home-Enable=0 ISigMap-Motor0-PosLimit-Enable=0 ISigMap-Motor1-PosLimit-Enable=0 ISigMap-Motor2-PosLimit-Enable=0 ISigMap-Motor3-PosLimit-Enable=0 ISigMap-Motor4-PosLimit-Enable=0 ISigMap-Motor5-PosLimit-Enable=0 ISigMap-Motor0-NegLimit-Enable=0 ISigMap-Motor1-NegLimit-Enable=0 ISigMap-Motor2-NegLimit-Enable=0 ISigMap-Motor3-NegLimit-Enable=0 ISigMap-Motor4-NegLimit-Enable=0 ISigMap-Motor5-NegLimit-Enable=0 ISigMap-Motor0-Index-Enable=0 ISigMap-Motor1-Index-Enable=0 ISigMap-Motor2-Index-Enable=0 ISigMap-Motor3-Index-Enable=0 ISigMap-Motor4-Index-Enable=0 ISigMap-Motor5-Index-Enable=0 ISigMap-Encoder0-PhaseA-Enable=0 ISigMap-Encoder0-PhaseB-Enable=0 ISigMap-Encoder1-PhaseA-Enable=0 ISigMap-Encoder1-PhaseB-Enable=0 ISigMap-Encoder2-PhaseA-Enable=0 ISigMap-Encoder2-PhaseB-Enable=0 ISigMap-Encoder3-PhaseA-Enable=0 ISigMap-Encoder3-PhaseB-Enable=0 ISigMap-Encoder4-PhaseA-Enable=0 ISigMap-Encoder4-PhaseB-Enable=0 ISigMap-Encoder5-PhaseA-Enable=0 ISigMap-Encoder5-PhaseB-Enable=0 ISigMap-AuxEncoder0-PhaseA-Enable=0 ISigMap-AuxEncoder0-PhaseB-Enable=0 ISigMap-AuxEncoder1-PhaseA-Enable=0 ISigMap-AuxEncoder1-PhaseB-Enable=0 ISigMap-AuxEncoder2-PhaseA-Enable=0 ISigMap-AuxEncoder2-PhaseB-Enable=0 ISigMap-SpindleEncoder-PhaseA-Enable=0 ISigMap-SpindleEncoder-PhaseB-Enable=0 ISigMap-Index-Enable=0 ISigMap-SpindleAtSpeed-Enable=0 ISigMap-SpindleAtZero-Enable=0 ISigMap-Probe-Enable=1 ISigMap-Probe=Probe ISigMap-Probe1-Enable=0 ISigMap-Probe2-Enable=0 ISigMap-Probe3-Enable=0 ISigMap-THCOn-Enable=0 ISigMap-THCUp-Enable=0 ISigMap-THCDown-Enable=0 ISigMap-JogInhibit-Enable=0 ISigMap-MotionInhibit-Enable=0 ISigMap-MpgInhibit-Enable=0 ISigMap-LimitOverride-Enable=0 ISigMap-NoWait-Enable=0 ISigMap-PathSelection-Enable=0 ISigMap-PathSelection2-Enable=0 ISigMap-ToolGroupReset-Enable=0 ISigMap-ToolLifeOverride-Enable=0 ISigMap-ToolRetract-Enable=0 ISigMap-ToolSkip-Enable=0 ISigMap-UserInterrupt-Enable=0 ISigMap-JogX-Pos-Enable=0 ISigMap-JogX-Neg-Enable=0 ISigMap-JogY-Pos-Enable=0 ISigMap-JogY-Neg-Enable=0 ISigMap-JogZ-Pos-Enable=0 ISigMap-JogZ-Neg-Enable=0 ISigMap-JogA-Pos-Enable=0 ISigMap-JogA-Neg-Enable=0 ISigMap-JogB-Pos-Enable=0 ISigMap-JogB-Neg-Enable=0 ISigMap-JogC-Pos-Enable=0 ISigMap-JogC-Neg-Enable=0 ISigMap-JogOB1_Pos-Enable=0 ISigMap-JogOB1_Neg-Enable=0 ISigMap-JogOB2_Pos-Enable=0 ISigMap-JogOB2_Neg-Enable=0 ISigMap-JogOB3_Pos-Enable=0 ISigMap-JogOB3_Neg-Enable=0 ISigMap-JogOB4_Pos-Enable=0 ISigMap-JogOB4_Neg-Enable=0 ISigMap-JogOB5_Pos-Enable=0 ISigMap-JogOB5_Neg-Enable=0 ISigMap-JogOB6_Pos-Enable=0 ISigMap-JogOB6_Neg-Enable=0 ISigMap-Input0-Enable=1 ISigMap-Input0=OUT0-FH Flyer ISigMap-Input1-Enable=1 ISigMap-Input1=OUT1-FH Flyer ISigMap-Input2-Enable=1 ISigMap-Input2=OUT2-FH Flyer ISigMap-Input3-Enable=1 ISigMap-Input3=OUT3-FH Flyer ISigMap-Input4-Enable=1 ISigMap-Input4=OUT4-FH Flyer ISigMap-Input5-Enable=0 ISigMap-Input6-Enable=0 ISigMap-Input7-Enable=0 ISigMap-Input8-Enable=0 ISigMap-Input9-Enable=0 ISigMap-Input10-Enable=0 ISigMap-Input11-Enable=0 ISigMap-Input12-Enable=0 ISigMap-Input13-Enable=0 ISigMap-Input14-Enable=0 ISigMap-Input15-Enable=0 ISigMap-Input16-Enable=0 ISigMap-Input17-Enable=0 ISigMap-Input18-Enable=0 ISigMap-Input19-Enable=0 ISigMap-Input20-Enable=0 ISigMap-Input21-Enable=0 ISigMap-Input22-Enable=0 ISigMap-Input23-Enable=0 ISigMap-Input24-Enable=0 ISigMap-Input25-Enable=0 ISigMap-Input26-Enable=0 ISigMap-Input27-Enable=0 ISigMap-Input28-Enable=0 ISigMap-Input29-Enable=0 ISigMap-Input30-Enable=0 ISigMap-Input31-Enable=0 ISigMap-Input32-Enable=0 ISigMap-Input33-Enable=0 ISigMap-Input34-Enable=0 ISigMap-Input35-Enable=0 ISigMap-Input36-Enable=0 ISigMap-Input37-Enable=0 ISigMap-Input38-Enable=0 ISigMap-Input39-Enable=0 ISigMap-Input40-Enable=0 ISigMap-Input41-Enable=0 ISigMap-Input42-Enable=0 ISigMap-Input43-Enable=0 ISigMap-Input44-Enable=0 ISigMap-Input45-Enable=0 ISigMap-Input46-Enable=0 ISigMap-Input47-Enable=0 ISigMap-Input48-Enable=0 ISigMap-Input49-Enable=0 ISigMap-Input50-Enable=0 ISigMap-Input51-Enable=0 ISigMap-Input52-Enable=0 ISigMap-Input53-Enable=0 ISigMap-Input54-Enable=0 ISigMap-Input55-Enable=0 ISigMap-Input56-Enable=0 ISigMap-Input57-Enable=0 ISigMap-Input58-Enable=0 ISigMap-Input59-Enable=0 ISigMap-Input60-Enable=0 ISigMap-Input61-Enable=0 ISigMap-Input62-Enable=0 ISigMap-Input63-Enable=0 OSigMap-Motor0-Step-MappedPin0=X Step OSigMap-Motor0-Step-Enable=1 OSigMap-Motor0-Dir-MappedPin0=X Dir OSigMap-Motor0-Dir-Enable=1 OSigMap-Motor1-Step-MappedPin0=Y Step OSigMap-Motor1-Step-Enable=1 OSigMap-Motor1-Dir-MappedPin0=Y Dir OSigMap-Motor1-Dir-Enable=1 OSigMap-Motor2-Step-MappedPin0=Z Step OSigMap-Motor2-Step-Enable=1 OSigMap-Motor2-Dir-MappedPin0=Z Dir OSigMap-Motor2-Dir-Enable=1 OSigMap-Motor3-Step-Enable=0 OSigMap-Motor3-Dir-Enable=0 OSigMap-Motor4-Step-Enable=0 OSigMap-Motor4-Dir-Enable=0 OSigMap-Motor5-Step-Enable=0 OSigMap-Motor5-Dir-Enable=0 OSigMap-Enable0-MappedPin0=Servo Enable OSigMap-Enable0-Enable=1 OSigMap-Enable1-Enable=0 OSigMap-Enable2-Enable=0 OSigMap-Enable3-Enable=0 OSigMap-Enable4-Enable=0 OSigMap-Enable5-Enable=0 OSigMap-XYFeedRatePWM-Enable=0 OSigMap-LaserPWM-MappedPin0=Laser Pin OSigMap-LaserPWM-Enable=1 OSigMap-SpindleStepOrPWM-Enable=0 OSigMap-SpindleDirection-Enable=0 OSigMap-SpindleOn-MappedPin0=Spindle 1 Right OSigMap-SpindleOn-Enable=1 OSigMap-SpindleFwd-Enable=0 OSigMap-SpindleRev-Enable=0 OSigMap-Alarm-Enable=0 OSigMap-ChargePump-Enable=0 OSigMap-CoolantOn-MappedPin0=vysavac externi rele OSigMap-CoolantOn-Enable=1 OSigMap-MistOn-Enable=0 OSigMap-CurrentHi-Low-Enable=0 OSigMap-CutRecovery-Enable=0 OSigMap-DigitizeTrigger-Enable=0 OSigMap-DistToGo-Enable=0 OSigMap-Dwell-Enable=0 OSigMap-FeedHold-Enable=0 OSigMap-FeedHoldDisabled-Enable=0 OSigMap-FeedHoldNotAllowed-Enable=0 OSigMap-FeedRateOverride-Enable=0 OSigMap-FeedRateOverrideDisabled-Enable=0 OSigMap-FeedRateOverrideNotAllowed-Enable=0 OSigMap-GcodeRunning-Enable=0 OSigMap-IsMoving-Enable=0 OSigMap-JogCont-Enable=0 OSigMap-JogEnabled-Enable=0 OSigMap-JogInc-Enable=0 OSigMap-JogMPG-Enable=0 OSigMap-LimitOverride-Enable=0 OSigMap-MachineCoord-Enable=0 OSigMap-MachineEnabled-Enable=0 OSigMap-MachineIdle-Enable=0 OSigMap-MachineProbing-Enable=0 OSigMap-PartsFinished-Enable=0 OSigMap-RapidRateOverride-Enable=0 OSigMap-RetractSignal-Enable=0 OSigMap-BlockDelete-Enable=0 OSigMap-OptStop-Enable=0 OSigMap-ReverseRun-Enable=0 OSigMap-SingleBlock-Enable=0 OSigMap-SpindleRateOverride-Enable=0 OSigMap-SpindleRateOverrideDisabled-Enable=0 OSigMap-SpindleRateOverrideNotAllowed-Enable=0 OSigMap-SoftlimitsOn-Enable=0 OSigMap-SpeedCheck-Enable=0 OSigMap-ToolpathMouseDown-Enable=0 OSigMap-ToolChange-Enable=0 OSigMap-ToolChangeB-Enable=0 OSigMap-WaitingOnToolSignal-Enable=0 OSigMap-X-PosLimit-Enable=0 OSigMap-X-NegLimit-Enable=0 OSigMap-X-Home-Enable=0 OSigMap-XHomed-Enable=0 OSigMap-Y-PosLimit-Enable=0 OSigMap-Y-NegLimit-Enable=0 OSigMap-Y-Home-Enable=0 OSigMap-YHomed-Enable=0 OSigMap-Z-PosLimit-Enable=0 OSigMap-Z-NegLimit-Enable=0 OSigMap-Z-Home-Enable=0 OSigMap-ZHomed-Enable=0 OSigMap-A-PosLimit-Enable=0 OSigMap-A-NegLimit-Enable=0 OSigMap-A-Home-Enable=0 OSigMap-AHomed-Enable=0 OSigMap-B-PosLimit-Enable=0 OSigMap-B-NegLimit-Enable=0 OSigMap-B-Home-Enable=0 OSigMap-BHomed-Enable=0 OSigMap-C-PosLimit-Enable=0 OSigMap-C-NegLimit-Enable=0 OSigMap-C-Home-Enable=0 OSigMap-CHomed-Enable=0 OSigMap-OB1_Homed-Enable=0 OSigMap-OB1_Home_Switch_Active-Enable=0 OSigMap-OB1_PosLimit_Switch_Active-Enable=0 OSigMap-OB1_NegLimit_Switch_Active-Enable=0 OSigMap-OB2_Homed-Enable=0 OSigMap-OB2_Home_Switch_Active-Enable=0 OSigMap-OB2_PosLimit_Switch_Active-Enable=0 OSigMap-OB2_NegLimit_Switch_Active-Enable=0 OSigMap-OB3_Homed-Enable=0 OSigMap-OB3_Home_Switch_Active-Enable=0 OSigMap-OB3_PosLimit_Switch_Active-Enable=0 OSigMap-OB3_NegLimit_Switch_Active-Enable=0 OSigMap-OB4_Homed-Enable=0 OSigMap-OB4_Home_Switch_Active-Enable=0 OSigMap-OB4_PosLimit_Switch_Active-Enable=0 OSigMap-OB4_NegLimit_Switch_Active-Enable=0 OSigMap-OB5_Homed-Enable=0 OSigMap-OB5_Home_Switch_Active-Enable=0 OSigMap-OB5_PosLimit_Switch_Active-Enable=0 OSigMap-OB5_NegLimit_Switch_Active-Enable=0 OSigMap-OB6_Homed-Enable=0 OSigMap-OB6_Home_Switch_Active-Enable=0 OSigMap-OB6_PosLimit_Switch_Active-Enable=0 OSigMap-OB6_NegLimit_Switch_Active-Enable=0 OSigMap-Output0-MappedPin0=IN0-FH Flyer OSigMap-Output0-Enable=1 OSigMap-Output1-MappedPin0=IN1-FH Flyer OSigMap-Output1-Enable=1 OSigMap-Output2-MappedPin0=IN2-FH Flyer OSigMap-Output2-Enable=1 OSigMap-Output3-MappedPin0=IN3-FH Flyer OSigMap-Output3-Enable=1 OSigMap-Output4-MappedPin0=IN4-FH Flyer OSigMap-Output4-Enable=1 OSigMap-Output5-MappedPin0=IN5-FH Flyer OSigMap-Output5-Enable=1 OSigMap-Output6-MappedPin0=IN6-FH Flyer OSigMap-Output6-Enable=1 OSigMap-Output7-MappedPin0=Stop Laser OSigMap-Output7-Enable=1 OSigMap-Output8-Enable=0 OSigMap-Output9-Enable=0 OSigMap-Output10-MappedPin0=Rele Laser OSigMap-Output10-Enable=1 OSigMap-Output11-MappedPin0=AFAG DOWN OSigMap-Output11-Enable=1 OSigMap-Output12-Enable=0 OSigMap-Output13-MappedPin0=Pritlak DOWN OSigMap-Output13-Enable=1 OSigMap-Output14-MappedPin0=Pritlak UP OSigMap-Output14-Enable=1 OSigMap-Output15-Enable=0 OSigMap-Output16-Enable=0 OSigMap-Output17-Enable=0 OSigMap-Output18-Enable=0 OSigMap-Output19-Enable=0 OSigMap-Output20-MappedPin0=Laser Gate OSigMap-Output20-Enable=1 OSigMap-Output21-Enable=0 OSigMap-Output22-Enable=0 OSigMap-Output23-Enable=0 OSigMap-Output24-Enable=0 OSigMap-Output25-Enable=0 OSigMap-Output26-Enable=0 OSigMap-Output27-Enable=0 OSigMap-Output28-Enable=0 OSigMap-Output29-Enable=0 OSigMap-Output30-Enable=0 OSigMap-Output31-Enable=0 OSigMap-Output32-Enable=0 OSigMap-Output33-Enable=0 OSigMap-Output34-Enable=0 OSigMap-Output35-Enable=0 OSigMap-Output36-Enable=0 OSigMap-Output37-Enable=0 OSigMap-Output38-Enable=0 OSigMap-Output39-Enable=0 OSigMap-Output40-Enable=0 OSigMap-Output41-Enable=0 OSigMap-Output42-Enable=0 OSigMap-Output43-Enable=0 OSigMap-Output44-Enable=0 OSigMap-Output45-Enable=0 OSigMap-Output46-Enable=0 OSigMap-Output47-Enable=0 OSigMap-Output48-Enable=0 OSigMap-Output49-Enable=0 OSigMap-Output50-Enable=0 OSigMap-Output51-Enable=0 OSigMap-Output52-Enable=0 OSigMap-Output53-Enable=0 OSigMap-Output54-Enable=0 OSigMap-Output55-Enable=0 OSigMap-Output56-Enable=0 OSigMap-Output57-Enable=0 OSigMap-Output58-Enable=0 OSigMap-Output59-Enable=0 OSigMap-Output60-Enable=0 OSigMap-Output61-Enable=0 OSigMap-Output62-Enable=0 OSigMap-Output63-Enable=0 Homing-Motor-0-ApproachVelocity=2500.0 Homing-Motor-0-BackoffVelocity=100.0 Homing-Motor-0-dFinalPosition=0.0000 Homing-Motor-0-IndexHomingEnable=0 Homing-Motor-1-ApproachVelocity=2500.0 Homing-Motor-1-BackoffVelocity=100.0 Homing-Motor-1-dFinalPosition=0.0000 Homing-Motor-1-IndexHomingEnable=0 Homing-Motor-2-ApproachVelocity=500.0 Homing-Motor-2-BackoffVelocity=100.0 Homing-Motor-2-dFinalPosition=0.0000 Homing-Motor-2-IndexHomingEnable=0 Homing-Motor-3-ApproachVelocity=1.0 Homing-Motor-3-BackoffVelocity=1.0 Homing-Motor-3-dFinalPosition=0.0000 Homing-Motor-3-IndexHomingEnable=0 Homing-Motor-4-ApproachVelocity=1.0 Homing-Motor-4-BackoffVelocity=1.0 Homing-Motor-4-dFinalPosition=0.0000 Homing-Motor-4-IndexHomingEnable=0 Homing-Motor-5-ApproachVelocity=1.0 Homing-Motor-5-BackoffVelocity=1.0 Homing-Motor-5-dFinalPosition=0.0000 Homing-Motor-5-IndexHomingEnable=0 IgnoreOtherProbesWhileProbing=1 iProbeFailureDisablesMach=1 iHcMonitorCollisionDetectionProbe0=0 iHcMonitorCollisionDetectionProbe1=0 iHcMonitorCollisionDetectionProbe2=0 iHcMonitorCollisionDetectionProbe3=0 UseBacklashComp=0 ShowBacklashCompLogMessages=0 BacklashCompAffectsCalculations_0=0 BacklashCompUseCustomValue_0=0 BacklashCompCustomVelocity_0=10.0000 BacklashCompCustomAcceleration_0=1.0000 BacklashCompAffectsCalculations_1=0 BacklashCompUseCustomValue_1=0 BacklashCompCustomVelocity_1=10.0000 BacklashCompCustomAcceleration_1=1.0000 BacklashCompAffectsCalculations_2=0 BacklashCompUseCustomValue_2=0 BacklashCompCustomVelocity_2=10.0000 BacklashCompCustomAcceleration_2=1.0000 BacklashCompAffectsCalculations_3=0 BacklashCompUseCustomValue_3=0 BacklashCompCustomVelocity_3=10.0000 BacklashCompCustomAcceleration_3=1.0000 BacklashCompAffectsCalculations_4=0 BacklashCompUseCustomValue_4=0 BacklashCompCustomVelocity_4=10.0000 BacklashCompCustomAcceleration_4=1.0000 BacklashCompAffectsCalculations_5=0 BacklashCompUseCustomValue_5=0 BacklashCompCustomVelocity_5=10.0000 BacklashCompCustomAcceleration_5=1.0000 i_HC_ControlledManually=0 i_HC_ControlledByHardwareUpDownPins=0 i_HC_ControlledByHardwareW9_HC=0 i_HC_UseTorchRelay=0 i_HC_TorchRelayOutputNumber=- i_HC_SendHcToDroZAux=1 i_HC_DisplayDroZAux=0 i_HC_UseLimitSwitchInhibit=0 d_HC_LimitSwitchInhibitTimeAfterArcOkay=1.000 i_HC_LimitMode=0 i_HC_SaveMaxMinValuesOnMachExit=0 d_HC_LimitMax=1.2000 d_HC_LimitMin=-0.0100 d_HC_TorchPierceDelayTimeAfterArcOkay=0.000 i_HC_EnablePierceCountWarning=0 i_HC_PierceCountWarningValue=0 i_HC_UseXYVelocityPWM=0 ShowWarp9SplashScreen=1 i_HC_PierceCountCurrentValue=0
