[Preferences] Profile=AccuCut Screen=Accu-Cut.set MotionDevice=ESS JogInc=1.000000 JogRate=100.000000 AutoCalc=0 JogTrace=0 OpLock=0 CustomColor0=#D9D9D9 CustomColor1=#FFFFFF CustomColor2=#FFFFFF CustomColor3=#FFFFFF CustomColor4=#FFFFFF CustomColor5=#FFFFFF CustomColor6=#FFFFFF CustomColor7=#FFFFFF CustomColor8=#FFFFFF CustomColor9=#FFFFFF CustomColor10=#FFFFFF CustomColor11=#FFFFFF CustomColor12=#FFFFFF CustomColor13=#FFFFFF CustomColor14=#FFFFFF CustomColor15=#FFFFFF SpindleDelay=1.000000 CoolantDelay=1.0000 MistDelay=1.0000 AxisRolloverA=1 AxisRolloverB=0 AxisRolloverC=0 MotorMaxRPM=21000.000000 UseCvAnlge=1 SetupUnits=200 LookAhead=20 JogInc1=1 JogInc2=0.1 JogInc3=0.01 JogInc4=0.001 JogInc5=0.0001 JogInc6=1 JogInc7=0.1 JogInc8=0.01 JogInc9=0.001 JogInc10=0.0001 SetvnStart=500 SetvnEnd=549 FileExtensions=*.cnc;*.tap; *.nc; *.txt GcodeEditor=C:\\Mach4Hobby\\gcedit CommentsInMessages=0 DerefAxesInEstop=0 StopIsControlled=0 UseAdvGui=1 FeedHoldStopsSpindle=0 ExitFeedHoldRestoresSpindle=0 CheckProbeSignalBeforeProbeOp=1 ProbeFollowsUnitsMode=0 UseZeroBrane=1 BackupProfiles=20 MaxTools=103 SpindleOverrideDelay=25 EnableStepDirRtap=0 EnableSpindleStabilizeWait=0 SpindleStabilizeWaitPercent=90 DisableVboToolPath=0 UseLazyToolPathUpdate=0 LastOpenDir=D:\\Vac Tables\\KR\\5x10 MRU1=D:\\Vac Tables\\KR\\5x10\\5x10 vac holes.cnc MRU2=C:\\Users\\CCI\\Desktop\\test file 250 - neg.cnc MRU3=C:\\Users\\CCI\\Desktop\\test file 250 - Copy.cnc MRU4=C:\\Users\\CCI\\Desktop\\test file 250.cnc MRU5=D:\\testing\\test file 250.cnc MRU6=C:\\Mach4Hobby\\GcodeFiles\\ArcTest.tap MRU7=C:\\Mach4Hobby\\GcodeFiles\\Polar TestFile.tap MRU8=C:\\Mach4Hobby\\GcodeFiles\\outhouse.tap LastWizard=C:\\Mach4Hobby\\Wizards\\CV_Feedrate.mcs MRU9=C:\\Mach4Hobby\\GcodeFiles\\roadrunner.tap [Plugins] Warp9Mach4=1 mcLua=1 mcRegfile=1 Sim=0 TMC3in1=0 mcKeyboard=1 mcModbus=1 mcSerial=0 mcSurfaceMap=0 ShuttlePro=0 Mach4PoKeysPlugin=1 [Signal161] ID=161 Type=Input Desc=Probe Enabled=1 Negated=0 Mapping=ESS/{P1-15} [Signal183] ID=183 Type=Input Desc=Probe1 Enabled=0 Negated=0 Mapping=None [Signal184] ID=184 Type=Input Desc=Probe2 Enabled=0 Negated=0 Mapping=None [Signal185] ID=185 Type=Input Desc=Probe3 Enabled=0 Negated=0 Mapping=None [Signal162] ID=162 Type=Input Desc=Index Enabled=0 Negated=0 Mapping=None [Signal1] ID=1 Type=Input Desc=Input #0 Enabled=1 Negated=1 Mapping=PoKeys_50671/Pin 14 (in) [Signal2] ID=2 Type=Input Desc=Input #1 Enabled=1 Negated=1 Mapping=PoKeys_50671/Pin 15 (in) [Signal3] ID=3 Type=Input Desc=Input #2 Enabled=1 Negated=1 Mapping=PoKeys_50671/Pin 16 (in) [Signal4] ID=4 Type=Input Desc=Input #3 Enabled=1 Negated=1 Mapping=PoKeys_50671/Pin 17 (in) [Signal5] ID=5 Type=Input Desc=Input #4 Enabled=1 Negated=0 Mapping=PoKeys_50671/Pin 44 (in) [Signal6] ID=6 Type=Input Desc=Input #5 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 04 Column 4 [Signal7] ID=7 Type=Input Desc=Input #6 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 03 Column 4 [Signal8] ID=8 Type=Input Desc=Input #7 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 02 Column 4 [Signal9] ID=9 Type=Input Desc=Input #8 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 01 Column 4 [Signal10] ID=10 Type=Input Desc=Input #9 Enabled=0 Negated=0 Mapping=None [Signal11] ID=11 Type=Input Desc=Input #10 Enabled=0 Negated=0 Mapping=None [Signal12] ID=12 Type=Input Desc=Input #11 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 02 Column 3 [Signal13] ID=13 Type=Input Desc=Input #12 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 01 Column 3 [Signal14] ID=14 Type=Input Desc=Input #13 Enabled=0 Negated=0 Mapping=None [Signal15] ID=15 Type=Input Desc=Input #14 Enabled=0 Negated=0 Mapping=None [Signal16] ID=16 Type=Input Desc=Input #15 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 02 Column 2 [Signal17] ID=17 Type=Input Desc=Input #16 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 01 Column 2 [Signal18] ID=18 Type=Input Desc=Input #17 Enabled=0 Negated=0 Mapping=None [Signal19] ID=19 Type=Input Desc=Input #18 Enabled=0 Negated=0 Mapping=None [Signal20] ID=20 Type=Input Desc=Input #19 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 02 Column 1 [Signal21] ID=21 Type=Input Desc=Input #20 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 01 Column 1 [Signal22] ID=22 Type=Input Desc=Input #21 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 04 Column 5 [Signal23] ID=23 Type=Input Desc=Input #22 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 03 Column 5 [Signal24] ID=24 Type=Input Desc=Input #23 Enabled=0 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 02 Column 5 [Signal25] ID=25 Type=Input Desc=Input #24 Enabled=0 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 01 Column 5 [Signal26] ID=26 Type=Input Desc=Input #25 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 04 Column 6 [Signal27] ID=27 Type=Input Desc=Input #26 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 03 Column 6 [Signal28] ID=28 Type=Input Desc=Input #27 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 02 Column 6 [Signal29] ID=29 Type=Input Desc=Input #28 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 01 Column 6 [Signal30] ID=30 Type=Input Desc=Input #29 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 04 Column 7 [Signal31] ID=31 Type=Input Desc=Input #30 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 03 Column 7 [Signal32] ID=32 Type=Input Desc=Input #31 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 02 Column 7 [Signal33] ID=33 Type=Input Desc=Input #32 Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 01 Column 7 [Signal34] ID=34 Type=Input Desc=Input #33 Enabled=0 Negated=0 Mapping=None [Signal35] ID=35 Type=Input Desc=Input #34 Enabled=0 Negated=0 Mapping=None [Signal36] ID=36 Type=Input Desc=Input #35 Enabled=0 Negated=0 Mapping=None [Signal37] ID=37 Type=Input Desc=Input #36 Enabled=0 Negated=0 Mapping=None [Signal38] ID=38 Type=Input Desc=Input #37 Enabled=0 Negated=0 Mapping=None [Signal39] ID=39 Type=Input Desc=Input #38 Enabled=0 Negated=0 Mapping=None [Signal40] ID=40 Type=Input Desc=Input #39 Enabled=0 Negated=0 Mapping=None [Signal41] ID=41 Type=Input Desc=Input #40 Enabled=0 Negated=0 Mapping=None [Signal42] ID=42 Type=Input Desc=Input #41 Enabled=0 Negated=0 Mapping=None [Signal43] ID=43 Type=Input Desc=Input #42 Enabled=0 Negated=0 Mapping=None [Signal44] ID=44 Type=Input Desc=Input #43 Enabled=0 Negated=0 Mapping=None [Signal45] ID=45 Type=Input Desc=Input #44 Enabled=0 Negated=0 Mapping=None [Signal46] ID=46 Type=Input Desc=Input #45 Enabled=0 Negated=0 Mapping=None [Signal47] ID=47 Type=Input Desc=Input #46 Enabled=0 Negated=0 Mapping=None [Signal48] ID=48 Type=Input Desc=Input #47 Enabled=0 Negated=0 Mapping=None [Signal49] ID=49 Type=Input Desc=Input #48 Enabled=0 Negated=0 Mapping=None [Signal50] ID=50 Type=Input Desc=Input #49 Enabled=0 Negated=0 Mapping=None [Signal51] ID=51 Type=Input Desc=Input #50 Enabled=0 Negated=0 Mapping=None [Signal52] ID=52 Type=Input Desc=Input #51 Enabled=0 Negated=0 Mapping=None [Signal53] ID=53 Type=Input Desc=Input #52 Enabled=0 Negated=0 Mapping=None [Signal54] ID=54 Type=Input Desc=Input #53 Enabled=0 Negated=0 Mapping=None [Signal55] ID=55 Type=Input Desc=Input #54 Enabled=0 Negated=0 Mapping=None [Signal56] ID=56 Type=Input Desc=Input #55 Enabled=0 Negated=0 Mapping=None [Signal57] ID=57 Type=Input Desc=Input #56 Enabled=0 Negated=0 Mapping=None [Signal58] ID=58 Type=Input Desc=Input #57 Enabled=0 Negated=0 Mapping=None [Signal59] ID=59 Type=Input Desc=Input #58 Enabled=0 Negated=0 Mapping=None [Signal60] ID=60 Type=Input Desc=Input #59 Enabled=0 Negated=0 Mapping=None [Signal61] ID=61 Type=Input Desc=Input #60 Enabled=0 Negated=0 Mapping=None [Signal62] ID=62 Type=Input Desc=Input #61 Enabled=0 Negated=0 Mapping=None [Signal63] ID=63 Type=Input Desc=Input #62 Enabled=0 Negated=0 Mapping=None [Signal64] ID=64 Type=Input Desc=Input #63 Enabled=0 Negated=0 Mapping=None [Signal163] ID=163 Type=Input Desc=Limit Override Enabled=0 Negated=0 Mapping=None [Signal164] ID=164 Type=Input Desc=E-Stop Enabled=1 Negated=0 Mapping=ESS/{P1-10} [Signal165] ID=165 Type=Input Desc=THC On Enabled=0 Negated=0 Mapping=None [Signal166] ID=166 Type=Input Desc=THC Up Enabled=0 Negated=0 Mapping=None [Signal167] ID=167 Type=Input Desc=THC Down Enabled=0 Negated=0 Mapping=None [Signal168] ID=168 Type=Input Desc=Timing Enabled=0 Negated=0 Mapping=None [Signal169] ID=169 Type=Input Desc=Jog X+ Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 03 Column 1 [Signal170] ID=170 Type=Input Desc=Jog X- Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 04 Column 1 [Signal171] ID=171 Type=Input Desc=Jog Y+ Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 03 Column 2 [Signal172] ID=172 Type=Input Desc=Jog Y- Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 04 Column 2 [Signal173] ID=173 Type=Input Desc=Jog Z+ Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 03 Column 3 [Signal174] ID=174 Type=Input Desc=Jog Z- Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 04 Column 3 [Signal175] ID=175 Type=Input Desc=Jog A+ Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 02 Column 5 [Signal176] ID=176 Type=Input Desc=Jog A- Enabled=1 Negated=0 Mapping=PoKeys_50671 Matrix KB/Row 01 Column 5 [Signal177] ID=177 Type=Input Desc=Jog B+ Enabled=0 Negated=0 Mapping=None [Signal178] ID=178 Type=Input Desc=Jog B- Enabled=0 Negated=0 Mapping=None [Signal179] ID=179 Type=Input Desc=Jog C+ Enabled=0 Negated=0 Mapping=None [Signal180] ID=180 Type=Input Desc=Jog C- Enabled=0 Negated=0 Mapping=None [Signal196] ID=196 Type=Input Desc=Jog OB1+ Enabled=0 Negated=0 Mapping=None [Signal197] ID=197 Type=Input Desc=Jog OB1- Enabled=0 Negated=0 Mapping=None [Signal198] ID=198 Type=Input Desc=Jog OB2+ Enabled=0 Negated=0 Mapping=None [Signal199] ID=199 Type=Input Desc=Jog OB2- Enabled=0 Negated=0 Mapping=None [Signal200] ID=200 Type=Input Desc=Jog OB3+ Enabled=0 Negated=0 Mapping=None [Signal201] ID=201 Type=Input Desc=Jog OB3- Enabled=0 Negated=0 Mapping=None [Signal202] ID=202 Type=Input Desc=Jog OB4+ Enabled=0 Negated=0 Mapping=None [Signal203] ID=203 Type=Input Desc=Jog OB4- Enabled=0 Negated=0 Mapping=None [Signal204] ID=204 Type=Input Desc=Jog OB5+ Enabled=0 Negated=0 Mapping=None [Signal205] ID=205 Type=Input Desc=Jog OB5- Enabled=0 Negated=0 Mapping=None [Signal206] ID=206 Type=Input Desc=Jog OB6+ Enabled=0 Negated=0 Mapping=None [Signal207] ID=207 Type=Input Desc=Jog OB6- Enabled=0 Negated=0 Mapping=None [Signal181] ID=181 Type=Input Desc=Spindle At Speed Enabled=0 Negated=0 Mapping=None [Signal182] ID=182 Type=Input Desc=Spindle At Zero Enabled=0 Negated=0 Mapping=None [Signal189] ID=189 Type=Input Desc=TLM Tool Skip Enabled=0 Negated=0 Mapping=None [Signal190] ID=190 Type=Input Desc=TLM Override Enabled=0 Negated=0 Mapping=None [Signal191] ID=191 Type=Input Desc=TLM Reset Enabled=0 Negated=0 Mapping=None [Signal192] ID=192 Type=Input Desc=User Interrupt Enabled=0 Negated=0 Mapping=None [Signal193] ID=193 Type=Input Desc=Retract Enabled=0 Negated=0 Mapping=None [Signal194] ID=194 Type=Input Desc=Path Selection Enabled=0 Negated=0 Mapping=None [Signal195] ID=195 Type=Input Desc=No Wait Enabled=0 Negated=0 Mapping=None [Signal186] ID=186 Type=Input Desc=Motion Inhibit Enabled=0 Negated=0 Mapping=None [Signal187] ID=187 Type=Input Desc=Jog Inhibit Enabled=0 Negated=0 Mapping=None [Signal188] ID=188 Type=Input Desc=MPG Inhibit Enabled=0 Negated=0 Mapping=None [Signal65] ID=65 Type=Input Desc=Motor 0 Home Enabled=1 Negated=0 Mapping=ESS/{P1-11} [Signal97] ID=97 Type=Input Desc=Motor 0 ++ Enabled=1 Negated=0 Mapping=ESS/{P1-11} [Signal129] ID=129 Type=Input Desc=Motor 0 -- Enabled=1 Negated=0 Mapping=ESS/{P1-11} [Signal66] ID=66 Type=Input Desc=Motor 1 Home Enabled=1 Negated=0 Mapping=ESS/{P1-12} [Signal98] ID=98 Type=Input Desc=Motor 1 ++ Enabled=1 Negated=0 Mapping=ESS/{P1-12} [Signal130] ID=130 Type=Input Desc=Motor 1 -- Enabled=1 Negated=0 Mapping=ESS/{P1-12} [Signal67] ID=67 Type=Input Desc=Motor 2 Home Enabled=1 Negated=0 Mapping=ESS/{P1-13} [Signal99] ID=99 Type=Input Desc=Motor 2 ++ Enabled=1 Negated=0 Mapping=ESS/{P1-13} [Signal131] ID=131 Type=Input Desc=Motor 2 -- Enabled=0 Negated=0 Mapping=None [Signal68] ID=68 Type=Input Desc=Motor 3 Home Enabled=1 Negated=0 Mapping=ESS/{P2-15} [Signal100] ID=100 Type=Input Desc=Motor 3 ++ Enabled=0 Negated=0 Mapping=None [Signal132] ID=132 Type=Input Desc=Motor 3 -- Enabled=0 Negated=0 Mapping=None [Signal69] ID=69 Type=Input Desc=Motor 4 Home Enabled=0 Negated=0 Mapping=None [Signal101] ID=101 Type=Input Desc=Motor 4 ++ Enabled=0 Negated=0 Mapping=None [Signal133] ID=133 Type=Input Desc=Motor 4 -- Enabled=0 Negated=0 Mapping=None [Signal70] ID=70 Type=Input Desc=Motor 5 Home Enabled=0 Negated=0 Mapping=None [Signal102] ID=102 Type=Input Desc=Motor 5 ++ Enabled=0 Negated=0 Mapping=None [Signal134] ID=134 Type=Input Desc=Motor 5 -- Enabled=0 Negated=0 Mapping=None [Signal71] ID=71 Type=Input Desc=Motor 6 Home Enabled=0 Negated=0 Mapping=None [Signal103] ID=103 Type=Input Desc=Motor 6 ++ Enabled=0 Negated=0 Mapping=None [Signal135] ID=135 Type=Input Desc=Motor 6 -- Enabled=0 Negated=0 Mapping=None [Signal72] ID=72 Type=Input Desc=Motor 7 Home Enabled=0 Negated=0 Mapping=None [Signal104] ID=104 Type=Input Desc=Motor 7 ++ Enabled=0 Negated=0 Mapping=None [Signal136] ID=136 Type=Input Desc=Motor 7 -- Enabled=0 Negated=0 Mapping=None [Signal73] ID=73 Type=Input Desc=Motor 8 Home Enabled=0 Negated=0 Mapping=None [Signal105] ID=105 Type=Input Desc=Motor 8 ++ Enabled=0 Negated=0 Mapping=None [Signal137] ID=137 Type=Input Desc=Motor 8 -- Enabled=0 Negated=0 Mapping=None [Signal74] ID=74 Type=Input Desc=Motor 9 Home Enabled=0 Negated=0 Mapping=None [Signal106] ID=106 Type=Input Desc=Motor 9 ++ Enabled=0 Negated=0 Mapping=None [Signal138] ID=138 Type=Input Desc=Motor 9 -- Enabled=0 Negated=0 Mapping=None [Signal75] ID=75 Type=Input Desc=Motor 10 Home Enabled=0 Negated=0 Mapping=None [Signal107] ID=107 Type=Input Desc=Motor 10 ++ Enabled=0 Negated=0 Mapping=None [Signal139] ID=139 Type=Input Desc=Motor 10 -- Enabled=0 Negated=0 Mapping=None [Signal76] ID=76 Type=Input Desc=Motor 11 Home Enabled=0 Negated=0 Mapping=None [Signal108] ID=108 Type=Input Desc=Motor 11 ++ Enabled=0 Negated=0 Mapping=None [Signal140] ID=140 Type=Input Desc=Motor 11 -- Enabled=0 Negated=0 Mapping=None [Signal77] ID=77 Type=Input Desc=Motor 12 Home Enabled=0 Negated=0 Mapping=None [Signal109] ID=109 Type=Input Desc=Motor 12 ++ Enabled=0 Negated=0 Mapping=None [Signal141] ID=141 Type=Input Desc=Motor 12 -- Enabled=0 Negated=0 Mapping=None [Signal78] ID=78 Type=Input Desc=Motor 13 Home Enabled=0 Negated=0 Mapping=None [Signal110] ID=110 Type=Input Desc=Motor 13 ++ Enabled=0 Negated=0 Mapping=None [Signal142] ID=142 Type=Input Desc=Motor 13 -- Enabled=0 Negated=0 Mapping=None [Signal79] ID=79 Type=Input Desc=Motor 14 Home Enabled=0 Negated=0 Mapping=None [Signal111] ID=111 Type=Input Desc=Motor 14 ++ Enabled=0 Negated=0 Mapping=None [Signal143] ID=143 Type=Input Desc=Motor 14 -- Enabled=0 Negated=0 Mapping=None [Signal80] ID=80 Type=Input Desc=Motor 15 Home Enabled=0 Negated=0 Mapping=None [Signal112] ID=112 Type=Input Desc=Motor 15 ++ Enabled=0 Negated=0 Mapping=None [Signal144] ID=144 Type=Input Desc=Motor 15 -- Enabled=0 Negated=0 Mapping=None [Signal81] ID=81 Type=Input Desc=Motor 16 Home Enabled=0 Negated=0 Mapping=None [Signal113] ID=113 Type=Input Desc=Motor 16 ++ Enabled=0 Negated=0 Mapping=None [Signal145] ID=145 Type=Input Desc=Motor 16 -- Enabled=0 Negated=0 Mapping=None [Signal82] ID=82 Type=Input Desc=Motor 17 Home Enabled=0 Negated=0 Mapping=None [Signal114] ID=114 Type=Input Desc=Motor 17 ++ Enabled=0 Negated=0 Mapping=None [Signal146] ID=146 Type=Input Desc=Motor 17 -- Enabled=0 Negated=0 Mapping=None [Signal83] ID=83 Type=Input Desc=Motor 18 Home Enabled=0 Negated=0 Mapping=None [Signal115] ID=115 Type=Input Desc=Motor 18 ++ Enabled=0 Negated=0 Mapping=None [Signal147] ID=147 Type=Input Desc=Motor 18 -- Enabled=0 Negated=0 Mapping=None [Signal84] ID=84 Type=Input Desc=Motor 19 Home Enabled=0 Negated=0 Mapping=None [Signal116] ID=116 Type=Input Desc=Motor 19 ++ Enabled=0 Negated=0 Mapping=None [Signal148] ID=148 Type=Input Desc=Motor 19 -- Enabled=0 Negated=0 Mapping=None [Signal85] ID=85 Type=Input Desc=Motor 20 Home Enabled=0 Negated=0 Mapping=None [Signal117] ID=117 Type=Input Desc=Motor 20 ++ Enabled=0 Negated=0 Mapping=None [Signal149] ID=149 Type=Input Desc=Motor 20 -- Enabled=0 Negated=0 Mapping=None [Signal86] ID=86 Type=Input Desc=Motor 21 Home Enabled=0 Negated=0 Mapping=None [Signal118] ID=118 Type=Input Desc=Motor 21 ++ Enabled=0 Negated=0 Mapping=None [Signal150] ID=150 Type=Input Desc=Motor 21 -- Enabled=0 Negated=0 Mapping=None [Signal87] ID=87 Type=Input Desc=Motor 22 Home Enabled=0 Negated=0 Mapping=None [Signal119] ID=119 Type=Input Desc=Motor 22 ++ Enabled=0 Negated=0 Mapping=None [Signal151] ID=151 Type=Input Desc=Motor 22 -- Enabled=0 Negated=0 Mapping=None [Signal88] ID=88 Type=Input Desc=Motor 23 Home Enabled=0 Negated=0 Mapping=None [Signal120] ID=120 Type=Input Desc=Motor 23 ++ Enabled=0 Negated=0 Mapping=None [Signal152] ID=152 Type=Input Desc=Motor 23 -- Enabled=0 Negated=0 Mapping=None [Signal89] ID=89 Type=Input Desc=Motor 24 Home Enabled=0 Negated=0 Mapping=None [Signal121] ID=121 Type=Input Desc=Motor 24 ++ Enabled=0 Negated=0 Mapping=None [Signal153] ID=153 Type=Input Desc=Motor 24 -- Enabled=0 Negated=0 Mapping=None [Signal90] ID=90 Type=Input Desc=Motor 25 Home Enabled=0 Negated=0 Mapping=None [Signal122] ID=122 Type=Input Desc=Motor 25 ++ Enabled=0 Negated=0 Mapping=None [Signal154] ID=154 Type=Input Desc=Motor 25 -- Enabled=0 Negated=0 Mapping=None [Signal91] ID=91 Type=Input Desc=Motor 26 Home Enabled=0 Negated=0 Mapping=None [Signal123] ID=123 Type=Input Desc=Motor 26 ++ Enabled=0 Negated=0 Mapping=None [Signal155] ID=155 Type=Input Desc=Motor 26 -- Enabled=0 Negated=0 Mapping=None [Signal92] ID=92 Type=Input Desc=Motor 27 Home Enabled=0 Negated=0 Mapping=None [Signal124] ID=124 Type=Input Desc=Motor 27 ++ Enabled=0 Negated=0 Mapping=None [Signal156] ID=156 Type=Input Desc=Motor 27 -- Enabled=0 Negated=0 Mapping=None [Signal93] ID=93 Type=Input Desc=Motor 28 Home Enabled=0 Negated=0 Mapping=None [Signal125] ID=125 Type=Input Desc=Motor 28 ++ Enabled=0 Negated=0 Mapping=None [Signal157] ID=157 Type=Input Desc=Motor 28 -- Enabled=0 Negated=0 Mapping=None [Signal94] ID=94 Type=Input Desc=Motor 29 Home Enabled=0 Negated=0 Mapping=None [Signal126] ID=126 Type=Input Desc=Motor 29 ++ Enabled=0 Negated=0 Mapping=None [Signal158] ID=158 Type=Input Desc=Motor 29 -- Enabled=0 Negated=0 Mapping=None [Signal95] ID=95 Type=Input Desc=Motor 30 Home Enabled=0 Negated=0 Mapping=None [Signal127] ID=127 Type=Input Desc=Motor 30 ++ Enabled=0 Negated=0 Mapping=None [Signal159] ID=159 Type=Input Desc=Motor 30 -- Enabled=0 Negated=0 Mapping=None [Signal96] ID=96 Type=Input Desc=Motor 31 Home Enabled=0 Negated=0 Mapping=None [Signal128] ID=128 Type=Input Desc=Motor 31 ++ Enabled=0 Negated=0 Mapping=None [Signal160] ID=160 Type=Input Desc=Motor 31 -- Enabled=0 Negated=0 Mapping=None [Signal1146] ID=1146 Type=Output Desc=Digitize Trigger Enabled=0 Negated=0 Mapping=None [Signal1141] ID=1141 Type=Output Desc=Spindle On Enabled=1 Negated=0 Mapping=ESS/{P1-1} [Signal1142] ID=1142 Type=Output Desc=Spindle Fwd Enabled=0 Negated=0 Mapping=None [Signal1143] ID=1143 Type=Output Desc=Spindle Rev Enabled=0 Negated=0 Mapping=None [Signal1144] ID=1144 Type=Output Desc=Coolant On Enabled=0 Negated=0 Mapping=None [Signal1145] ID=1145 Type=Output Desc=Mist On Enabled=1 Negated=0 Mapping=ESS/{P1-14} [Signal1138] ID=1138 Type=Output Desc=Reserved #1 Enabled=0 Negated=0 Mapping=None [Signal1139] ID=1139 Type=Output Desc=Reserved #2 Enabled=0 Negated=0 Mapping=None [Signal1140] ID=1140 Type=Output Desc=Current Hi/Low Enabled=0 Negated=0 Mapping=None [Signal1018] ID=1018 Type=Output Desc=Enable #0 Enabled=0 Negated=0 Mapping=None [Signal1019] ID=1019 Type=Output Desc=Enable #1 Enabled=0 Negated=0 Mapping=None [Signal1020] ID=1020 Type=Output Desc=Enable #2 Enabled=0 Negated=0 Mapping=None [Signal1021] ID=1021 Type=Output Desc=Enable #3 Enabled=0 Negated=0 Mapping=None [Signal1022] ID=1022 Type=Output Desc=Enable #4 Enabled=0 Negated=0 Mapping=None [Signal1023] ID=1023 Type=Output Desc=Enable #5 Enabled=0 Negated=0 Mapping=None [Signal1024] ID=1024 Type=Output Desc=Enable #6 Enabled=0 Negated=0 Mapping=None [Signal1025] ID=1025 Type=Output Desc=Enable #7 Enabled=0 Negated=0 Mapping=None [Signal1026] ID=1026 Type=Output Desc=Enable #8 Enabled=0 Negated=0 Mapping=None [Signal1027] ID=1027 Type=Output Desc=Enable #9 Enabled=0 Negated=0 Mapping=None [Signal1028] ID=1028 Type=Output Desc=Enable #10 Enabled=0 Negated=0 Mapping=None [Signal1029] ID=1029 Type=Output Desc=Enable #11 Enabled=0 Negated=0 Mapping=None [Signal1030] ID=1030 Type=Output Desc=Enable #12 Enabled=0 Negated=0 Mapping=None [Signal1031] ID=1031 Type=Output Desc=Enable #13 Enabled=0 Negated=0 Mapping=None [Signal1032] ID=1032 Type=Output Desc=Enable #14 Enabled=0 Negated=0 Mapping=None [Signal1033] ID=1033 Type=Output Desc=Enable #15 Enabled=0 Negated=0 Mapping=None [Signal1034] ID=1034 Type=Output Desc=Enable #16 Enabled=0 Negated=0 Mapping=None [Signal1035] ID=1035 Type=Output Desc=Enable #17 Enabled=0 Negated=0 Mapping=None [Signal1036] ID=1036 Type=Output Desc=Enable #18 Enabled=0 Negated=0 Mapping=None [Signal1037] ID=1037 Type=Output Desc=Enable #19 Enabled=0 Negated=0 Mapping=None [Signal1038] ID=1038 Type=Output Desc=Enable #20 Enabled=0 Negated=0 Mapping=None [Signal1039] ID=1039 Type=Output Desc=Enable #21 Enabled=0 Negated=0 Mapping=None [Signal1040] ID=1040 Type=Output Desc=Enable #22 Enabled=0 Negated=0 Mapping=None [Signal1041] ID=1041 Type=Output Desc=Enable #23 Enabled=0 Negated=0 Mapping=None [Signal1042] ID=1042 Type=Output Desc=Enable #24 Enabled=0 Negated=0 Mapping=None [Signal1043] ID=1043 Type=Output Desc=Enable #25 Enabled=0 Negated=0 Mapping=None [Signal1044] ID=1044 Type=Output Desc=Enable #26 Enabled=0 Negated=0 Mapping=None [Signal1045] ID=1045 Type=Output Desc=Enable #27 Enabled=0 Negated=0 Mapping=None [Signal1046] ID=1046 Type=Output Desc=Enable #28 Enabled=0 Negated=0 Mapping=None [Signal1047] ID=1047 Type=Output Desc=Enable #29 Enabled=0 Negated=0 Mapping=None [Signal1048] ID=1048 Type=Output Desc=Enable #30 Enabled=0 Negated=0 Mapping=None [Signal1049] ID=1049 Type=Output Desc=Enable #31 Enabled=0 Negated=0 Mapping=None [Signal1000] ID=1000 Type=Output Desc=X ++ Enabled=0 Negated=0 Mapping=None [Signal1001] ID=1001 Type=Output Desc=X -- Enabled=0 Negated=0 Mapping=None [Signal1002] ID=1002 Type=Output Desc=X Home Enabled=0 Negated=0 Mapping=None [Signal1003] ID=1003 Type=Output Desc=Y ++ Enabled=0 Negated=0 Mapping=None [Signal1004] ID=1004 Type=Output Desc=Y -- Enabled=0 Negated=0 Mapping=None [Signal1005] ID=1005 Type=Output Desc=Y Home Enabled=0 Negated=0 Mapping=None [Signal1006] ID=1006 Type=Output Desc=Z ++ Enabled=0 Negated=0 Mapping=None [Signal1007] ID=1007 Type=Output Desc=Z -- Enabled=0 Negated=0 Mapping=None [Signal1008] ID=1008 Type=Output Desc=Z Home Enabled=0 Negated=0 Mapping=None [Signal1009] ID=1009 Type=Output Desc=A ++ Enabled=0 Negated=0 Mapping=None [Signal1010] ID=1010 Type=Output Desc=A -- Enabled=0 Negated=0 Mapping=None [Signal1011] ID=1011 Type=Output Desc=A Home Enabled=0 Negated=0 Mapping=None [Signal1012] ID=1012 Type=Output Desc=B ++ Enabled=0 Negated=0 Mapping=None [Signal1013] ID=1013 Type=Output Desc=B -- Enabled=0 Negated=0 Mapping=None [Signal1014] ID=1014 Type=Output Desc=B Home Enabled=0 Negated=0 Mapping=None [Signal1015] ID=1015 Type=Output Desc=C ++ Enabled=0 Negated=0 Mapping=None [Signal1016] ID=1016 Type=Output Desc=C -- Enabled=0 Negated=0 Mapping=None [Signal1017] ID=1017 Type=Output Desc=C Home Enabled=0 Negated=0 Mapping=None [Signal1152] ID=1152 Type=Output Desc=OB1 ++ Enabled=0 Negated=0 Mapping=None [Signal1153] ID=1153 Type=Output Desc=OB1 -- Enabled=0 Negated=0 Mapping=None [Signal1154] ID=1154 Type=Output Desc=OB1 Home Enabled=0 Negated=0 Mapping=None [Signal1155] ID=1155 Type=Output Desc=OB2 ++ Enabled=0 Negated=0 Mapping=None [Signal1156] ID=1156 Type=Output Desc=OB2 -- Enabled=0 Negated=0 Mapping=None [Signal1157] ID=1157 Type=Output Desc=OB2 Home Enabled=0 Negated=0 Mapping=None [Signal1158] ID=1158 Type=Output Desc=OB3 ++ Enabled=0 Negated=0 Mapping=None [Signal1159] ID=1159 Type=Output Desc=OB3 -- Enabled=0 Negated=0 Mapping=None [Signal1160] ID=1160 Type=Output Desc=OB3 Home Enabled=0 Negated=0 Mapping=None [Signal1161] ID=1161 Type=Output Desc=OB4 ++ Enabled=0 Negated=0 Mapping=None [Signal1162] ID=1162 Type=Output Desc=OB4 -- Enabled=0 Negated=0 Mapping=None [Signal1163] ID=1163 Type=Output Desc=OB4 Home Enabled=0 Negated=0 Mapping=None [Signal1164] ID=1164 Type=Output Desc=OB5 ++ Enabled=0 Negated=0 Mapping=None [Signal1165] ID=1165 Type=Output Desc=OB5 -- Enabled=0 Negated=0 Mapping=None [Signal1166] ID=1166 Type=Output Desc=OB5 Home Enabled=0 Negated=0 Mapping=None [Signal1167] ID=1167 Type=Output Desc=OB6 ++ Enabled=0 Negated=0 Mapping=None [Signal1168] ID=1168 Type=Output Desc=OB6 -- Enabled=0 Negated=0 Mapping=None [Signal1169] ID=1169 Type=Output Desc=OB6 Home Enabled=0 Negated=0 Mapping=None [Signal1050] ID=1050 Type=Output Desc=Output #0 Enabled=0 Negated=0 Mapping=None [Signal1051] ID=1051 Type=Output Desc=Output #1 Enabled=0 Negated=0 Mapping=None [Signal1052] ID=1052 Type=Output Desc=Output #2 Enabled=0 Negated=0 Mapping=None [Signal1053] ID=1053 Type=Output Desc=Output #3 Enabled=0 Negated=0 Mapping=None [Signal1054] ID=1054 Type=Output Desc=Output #4 Enabled=1 Negated=0 Mapping=ESS/{P2-1} [Signal1055] ID=1055 Type=Output Desc=Output #5 Enabled=1 Negated=0 Mapping=ESS/{P2-14} [Signal1056] ID=1056 Type=Output Desc=Output #6 Enabled=1 Negated=0 Mapping=ESS/{P2-16} [Signal1057] ID=1057 Type=Output Desc=Output #7 Enabled=1 Negated=0 Mapping=ESS/{P2-17} [Signal1058] ID=1058 Type=Output Desc=Output #8 Enabled=1 Negated=0 Mapping=ESS/{P3-2} [Signal1059] ID=1059 Type=Output Desc=Output #9 Enabled=1 Negated=0 Mapping=ESS/{P3-3} [Signal1060] ID=1060 Type=Output Desc=Output #10 Enabled=0 Negated=0 Mapping=None [Signal1061] ID=1061 Type=Output Desc=Output #11 Enabled=0 Negated=0 Mapping=None [Signal1062] ID=1062 Type=Output Desc=Output #12 Enabled=0 Negated=0 Mapping=None [Signal1063] ID=1063 Type=Output Desc=Output #13 Enabled=0 Negated=0 Mapping=None [Signal1064] ID=1064 Type=Output Desc=Output #14 Enabled=0 Negated=0 Mapping=None [Signal1065] ID=1065 Type=Output Desc=Output #15 Enabled=0 Negated=0 Mapping=None [Signal1066] ID=1066 Type=Output Desc=Output #16 Enabled=0 Negated=0 Mapping=None [Signal1067] ID=1067 Type=Output Desc=Output #17 Enabled=0 Negated=0 Mapping=None [Signal1068] ID=1068 Type=Output Desc=Output #18 Enabled=0 Negated=0 Mapping=None [Signal1069] ID=1069 Type=Output Desc=Output #19 Enabled=0 Negated=0 Mapping=None [Signal1070] ID=1070 Type=Output Desc=Output #20 Enabled=0 Negated=0 Mapping=None [Signal1071] ID=1071 Type=Output Desc=Output #21 Enabled=0 Negated=0 Mapping=None [Signal1072] ID=1072 Type=Output Desc=Output #22 Enabled=0 Negated=0 Mapping=None [Signal1073] ID=1073 Type=Output Desc=Output #23 Enabled=0 Negated=0 Mapping=None [Signal1074] ID=1074 Type=Output Desc=Output #24 Enabled=0 Negated=0 Mapping=None [Signal1075] ID=1075 Type=Output Desc=Output #25 Enabled=0 Negated=0 Mapping=None [Signal1076] ID=1076 Type=Output Desc=Output #26 Enabled=0 Negated=0 Mapping=None [Signal1077] ID=1077 Type=Output Desc=Output #27 Enabled=0 Negated=0 Mapping=None [Signal1078] ID=1078 Type=Output Desc=Output #28 Enabled=0 Negated=0 Mapping=None [Signal1079] ID=1079 Type=Output Desc=Output #29 Enabled=0 Negated=0 Mapping=None [Signal1080] ID=1080 Type=Output Desc=Output #30 Enabled=0 Negated=0 Mapping=None [Signal1081] ID=1081 Type=Output Desc=Output #31 Enabled=0 Negated=0 Mapping=None [Signal1082] ID=1082 Type=Output Desc=Output #32 Enabled=0 Negated=0 Mapping=None [Signal1083] ID=1083 Type=Output Desc=Output #33 Enabled=0 Negated=0 Mapping=None [Signal1084] ID=1084 Type=Output Desc=Output #34 Enabled=0 Negated=0 Mapping=None [Signal1085] ID=1085 Type=Output Desc=Output #35 Enabled=0 Negated=0 Mapping=None [Signal1086] ID=1086 Type=Output Desc=Output #36 Enabled=0 Negated=0 Mapping=None [Signal1087] ID=1087 Type=Output Desc=Output #37 Enabled=0 Negated=0 Mapping=None [Signal1088] ID=1088 Type=Output Desc=Output #38 Enabled=0 Negated=0 Mapping=None [Signal1089] ID=1089 Type=Output Desc=Output #39 Enabled=0 Negated=0 Mapping=None [Signal1090] ID=1090 Type=Output Desc=Output #40 Enabled=0 Negated=0 Mapping=None [Signal1091] ID=1091 Type=Output Desc=Output #41 Enabled=0 Negated=0 Mapping=None [Signal1092] ID=1092 Type=Output Desc=Output #42 Enabled=0 Negated=0 Mapping=None [Signal1093] ID=1093 Type=Output Desc=Output #43 Enabled=0 Negated=0 Mapping=None [Signal1094] ID=1094 Type=Output Desc=Output #44 Enabled=0 Negated=0 Mapping=None [Signal1095] ID=1095 Type=Output Desc=Output #45 Enabled=0 Negated=0 Mapping=None [Signal1096] ID=1096 Type=Output Desc=Output #46 Enabled=0 Negated=0 Mapping=None [Signal1097] ID=1097 Type=Output Desc=Output #47 Enabled=0 Negated=0 Mapping=None [Signal1098] ID=1098 Type=Output Desc=Output #48 Enabled=0 Negated=0 Mapping=None [Signal1099] ID=1099 Type=Output Desc=Output #49 Enabled=0 Negated=0 Mapping=None [Signal1100] ID=1100 Type=Output Desc=Output #50 Enabled=0 Negated=0 Mapping=None [Signal1101] ID=1101 Type=Output Desc=Output #51 Enabled=0 Negated=0 Mapping=None [Signal1102] ID=1102 Type=Output Desc=Output #52 Enabled=0 Negated=0 Mapping=None [Signal1103] ID=1103 Type=Output Desc=Output #53 Enabled=0 Negated=0 Mapping=None [Signal1104] ID=1104 Type=Output Desc=Output #54 Enabled=0 Negated=0 Mapping=None [Signal1105] ID=1105 Type=Output Desc=Output #55 Enabled=0 Negated=0 Mapping=None [Signal1106] ID=1106 Type=Output Desc=Output #56 Enabled=0 Negated=0 Mapping=None [Signal1107] ID=1107 Type=Output Desc=Output #57 Enabled=0 Negated=0 Mapping=None [Signal1108] ID=1108 Type=Output Desc=Output #58 Enabled=0 Negated=0 Mapping=None [Signal1109] ID=1109 Type=Output Desc=Output #59 Enabled=0 Negated=0 Mapping=None [Signal1110] ID=1110 Type=Output Desc=Output #60 Enabled=0 Negated=0 Mapping=None [Signal1111] ID=1111 Type=Output Desc=Output #61 Enabled=0 Negated=0 Mapping=None [Signal1112] ID=1112 Type=Output Desc=Output #62 Enabled=0 Negated=0 Mapping=None [Signal1113] ID=1113 Type=Output Desc=Output #63 Enabled=0 Negated=0 Mapping=None [Signal1114] ID=1114 Type=Output Desc=Gcode Running Enabled=0 Negated=0 Mapping=None [Signal1115] ID=1115 Type=Output Desc=Feed Hold Enabled=0 Negated=0 Mapping=None [Signal1116] ID=1116 Type=Output Desc=Block Delete Enabled=0 Negated=0 Mapping=None [Signal1117] ID=1117 Type=Output Desc=Single Block Enabled=0 Negated=0 Mapping=None [Signal1118] ID=1118 Type=Output Desc=Reverse Run Enabled=0 Negated=0 Mapping=None [Signal1119] ID=1119 Type=Output Desc=Opt Stop Enabled=0 Negated=0 Mapping=None [Signal1120] ID=1120 Type=Output Desc=Machine Enabled Enabled=0 Negated=0 Mapping=None [Signal1121] ID=1121 Type=Output Desc=Tool Change Enabled=0 Negated=0 Mapping=None [Signal1122] ID=1122 Type=Output Desc=Dist To Go Enabled=0 Negated=0 Mapping=None [Signal1123] ID=1123 Type=Output Desc=Machine Coord Enabled=0 Negated=0 Mapping=None [Signal1124] ID=1124 Type=Output Desc=Softlimits On Enabled=0 Negated=0 Mapping=None [Signal1125] ID=1125 Type=Output Desc=Jog Inc Enabled=0 Negated=0 Mapping=None [Signal1126] ID=1126 Type=Output Desc=Jog Cont Enabled=0 Negated=0 Mapping=None [Signal1127] ID=1127 Type=Output Desc=Jog Enabled Enabled=0 Negated=0 Mapping=None [Signal1128] ID=1128 Type=Output Desc=Jog MPG Enabled=0 Negated=0 Mapping=None [Signal1129] ID=1129 Type=Output Desc=X Homed Enabled=0 Negated=0 Mapping=None [Signal1130] ID=1130 Type=Output Desc=Y Homed Enabled=0 Negated=0 Mapping=None [Signal1131] ID=1131 Type=Output Desc=Z Homed Enabled=0 Negated=0 Mapping=None [Signal1132] ID=1132 Type=Output Desc=A Homed Enabled=0 Negated=0 Mapping=None [Signal1133] ID=1133 Type=Output Desc=B Homed Enabled=0 Negated=0 Mapping=None [Signal1134] ID=1134 Type=Output Desc=C Homed Enabled=0 Negated=0 Mapping=None [Signal1135] ID=1135 Type=Output Desc=Dwell Enabled=0 Negated=0 Mapping=None [Signal1136] ID=1136 Type=Output Desc=Toolpath Mouse Down Enabled=0 Negated=0 Mapping=None [Signal1137] ID=1137 Type=Output Desc=Limit Override Enabled=0 Negated=0 Mapping=None [Signal1147] ID=1147 Type=Output Desc=Alarm Enabled=0 Negated=0 Mapping=None [Signal1148] ID=1148 Type=Output Desc=Parts Finished Enabled=0 Negated=0 Mapping=None [Signal1149] ID=1149 Type=Output Desc=TLM Tool Change Enabled=0 Negated=0 Mapping=None [Signal1150] ID=1150 Type=Output Desc=Waiting Enabled=0 Negated=0 Mapping=None [Signal1151] ID=1151 Type=Output Desc=Retract Enabled=0 Negated=0 Mapping=None [Signal1170] ID=1170 Type=Output Desc=Cut Recovery Enabled=0 Negated=0 Mapping=None [Signal1171] ID=1171 Type=Output Desc=Spindle SpeedCheck Enabled=0 Negated=0 Mapping=None [Motor32] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor33] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor34] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor35] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor36] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor37] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor38] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor39] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor40] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor41] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor42] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor43] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Axis0] OutOfBandAxis=0 SpindleAxis=0 Enabled=1 JogWithBuffer=1 HomeOrder=2 HomeDir=-1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 ChildMotor0=Motor0 [Axis1] OutOfBandAxis=0 SpindleAxis=0 Enabled=1 JogWithBuffer=1 HomeOrder=2 HomeDir=-1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 ChildMotor0=Motor1 [Axis2] OutOfBandAxis=0 SpindleAxis=0 Enabled=1 JogWithBuffer=1 HomeOrder=1 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 ChildMotor0=Motor2 [Axis3] OutOfBandAxis=0 SpindleAxis=0 Enabled=1 JogWithBuffer=1 HomeOrder=0 HomeDir=-1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 ChildMotor0=Motor3 [Axis4] OutOfBandAxis=0 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=5 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis5] OutOfBandAxis=0 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=6 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis6] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis7] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis8] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis9] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis10] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis11] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Toolpath] BackgroundTopColor=16751392 BackgroundBottomColor=16442558 RapidColor=255 LineColor=65312 ArcColor=2546003 HighlightColor=16118725 AxisColor=255 LimitColor=65535 ShowLimit=0 UseFrame=0 LineWidthMode=0 [SpindleRange0] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=21600.000000 MinRPM=18000.000000 Reversed=0 [SpindleRange1] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange2] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange3] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange4] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange5] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange6] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange7] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange8] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange9] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange10] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange11] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange12] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange13] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange14] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange15] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange16] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange17] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange18] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange19] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [Stats] TotalHours=21.201023 SpindleHours=0.399795 DistanceX=99665.012585 DistanceY=79364.294333 DistanceZ=12814.395909 DistanceA=212306.990165 DistanceB=0.000000 DistanceC=0.000000 M3=1204 M4=0 M6=962 [ARotoryAxisPosition] XAxis=0.000000 YAxis=0.000000 ZAxis=0.000000 RotationAbout=-1 [CVFeedrate] Angle_0=848.000000 Angle_1=687.000000 Angle_2=343.000000 Angle_3=229.000000 Angle_4=171.000000 Angle_5=137.000000 Angle_6=114.000000 Angle_7=98.000000 Angle_8=85.000000 Angle_9=76.000000 Angle_10=68.000000 Angle_11=62.000000 Angle_12=57.000000 Angle_13=52.000000 Angle_14=48.000000 Angle_15=45.000000 Angle_16=42.000000 Angle_17=40.000000 Angle_18=38.000000 Angle_19=35.000000 Angle_20=34.000000 Angle_21=32.000000 Angle_22=31.000000 Angle_23=29.000000 Angle_24=28.000000 Angle_25=27.000000 Angle_26=26.000000 Angle_27=25.000000 Angle_28=24.000000 Angle_29=23.000000 Angle_30=22.000000 Angle_31=21.000000 Angle_32=21.000000 Angle_33=20.000000 Angle_34=19.000000 Angle_35=19.000000 Angle_36=18.000000 Angle_37=18.000000 Angle_38=17.000000 Angle_39=17.000000 Angle_40=16.000000 Angle_41=16.000000 Angle_42=15.000000 Angle_43=15.000000 Angle_44=15.000000 Angle_45=14.000000 Angle_46=14.000000 Angle_47=14.000000 Angle_48=13.000000 Angle_49=13.000000 Angle_50=13.000000 Angle_51=12.000000 Angle_52=12.000000 Angle_53=12.000000 Angle_54=12.000000 Angle_55=11.000000 Angle_56=11.000000 Angle_57=11.000000 Angle_58=11.000000 Angle_59=10.000000 Angle_60=10.000000 Angle_61=10.000000 Angle_62=10.000000 Angle_63=10.000000 Angle_64=10.000000 Angle_65=9.000000 Angle_66=9.000000 Angle_67=9.000000 Angle_68=9.000000 Angle_69=9.000000 Angle_70=9.000000 Angle_71=8.000000 Angle_72=8.000000 Angle_73=8.000000 Angle_74=8.000000 Angle_75=8.000000 Angle_76=8.000000 Angle_77=8.000000 Angle_78=7.000000 Angle_79=7.000000 Angle_80=7.000000 Angle_81=7.000000 Angle_82=7.000000 Angle_83=7.000000 Angle_84=7.000000 Angle_85=7.000000 Angle_86=7.000000 Angle_87=6.000000 Angle_88=6.000000 Angle_89=6.000000 Angle_90=6.000000 Angle_91=6.000000 Angle_92=6.000000 Angle_93=6.000000 Angle_94=6.000000 Angle_95=6.000000 Angle_96=6.000000 Angle_97=5.000000 Angle_98=5.000000 Angle_99=5.000000 Angle_100=5.000000 Angle_101=5.000000 Angle_102=5.000000 Angle_103=5.000000 Angle_104=5.000000 Angle_105=5.000000 Angle_106=5.000000 Angle_107=5.000000 Angle_108=5.000000 Angle_109=4.000000 Angle_110=4.000000 Angle_111=4.000000 Angle_112=4.000000 Angle_113=4.000000 Angle_114=4.000000 Angle_115=4.000000 Angle_116=4.000000 Angle_117=4.000000 Angle_118=4.000000 Angle_119=4.000000 Angle_120=4.000000 Angle_121=4.000000 Angle_122=4.000000 Angle_123=4.000000 Angle_124=3.000000 Angle_125=3.000000 Angle_126=3.000000 Angle_127=3.000000 Angle_128=3.000000 Angle_129=3.000000 Angle_130=3.000000 Angle_131=3.000000 Angle_132=3.000000 Angle_133=3.000000 Angle_134=3.000000 Angle_135=3.000000 Angle_136=3.000000 Angle_137=3.000000 Angle_138=3.000000 Angle_139=3.000000 Angle_140=3.000000 Angle_141=3.000000 Angle_142=2.000000 Angle_143=2.000000 Angle_144=2.000000 Angle_145=2.000000 Angle_146=2.000000 Angle_147=2.000000 Angle_148=2.000000 Angle_149=2.000000 Angle_150=2.000000 Angle_151=2.000000 Angle_152=2.000000 Angle_153=2.000000 Angle_154=2.000000 Angle_155=2.000000 Angle_156=2.000000 Angle_157=2.000000 Angle_158=2.000000 Angle_159=2.000000 Angle_160=1.000000 Angle_161=1.000000 Angle_162=1.000000 Angle_163=1.000000 Angle_164=1.000000 Angle_165=1.000000 Angle_166=1.000000 Angle_167=1.000000 Angle_168=1.000000 Angle_169=1.000000 Angle_170=1.000000 Angle_171=1.000000 Angle_172=1.000000 Angle_173=1.000000 Angle_174=0.000000 Angle_175=0.000000 Angle_176=0.000000 Angle_177=0.000000 Angle_178=0.000000 Angle_179=0.000000 MaxFeed=356.000000 MaxAngle=43.000000 [Mpg0] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg1] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg2] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg3] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg4] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg5] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg6] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg7] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg8] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg9] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg10] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [Mpg11] CountsPerDetent=1 AccelPercent=0.000000 RatePercent=0.000000 Reversed=0 Enabled=0 [DefaultMode] ControlMode=3 UnitsMode=G20 TraverseMode=G0 MotionMode=G64 DistanceMode=G90 CenterMode=G91.1 FeedMode=G94 Plane=G17 CanedCycleRetract=G98 SpindleMode=G97S0 JogUnitsMode=0 [KeyboardKey0] IO_Name=X+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=39 Function=1 [KeyboardKey1] IO_Name=X- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=37 Function=2 [KeyboardKey2] IO_Name=Y+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=38 Function=7 [KeyboardKey3] IO_Name=Y- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=40 Function=8 [KeyboardKey4] IO_Name=Z+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=33 Function=13 [KeyboardKey5] IO_Name=Z- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=34 Function=14 [RegFileDlg] aot=1 x=548 y=15 w=640 h=480 [PersistentDROs] droGageBlock=1.500000 droSurfZPos=0.000000 droGageBlockT=1.000000 [ToolWindow] posX=617 posY=47 width=600 height=395 aot=1 opt=0 usr=0 sim=0 [ToffParams] ToffProbeRate=20.0 ToffRetractDistance=2.0 ToffZOnlyOption=1 ToffPrepRate=60.0 [RememberPos] X=112.05604324341 Y=41.26316318512 Z=-0.5 [Motor0] Enabled=1 Reverse=1 CanHome=1 CountsPerUnit=5432.303200 MaxVelocity=135807.580000 MaxAccel=271615.160000 BacklashAmount=0.000000 SoftMaxLimit=662737.187788 SoftMinLimit=0.000000 EnableDelay=0 [Motor1] Enabled=1 Reverse=1 CanHome=1 CountsPerUnit=5432.303200 MaxVelocity=135807.580000 MaxAccel=271615.160000 BacklashAmount=0.000000 SoftMaxLimit=336802.255170 SoftMinLimit=0.000000 EnableDelay=0 [Motor2] Enabled=1 Reverse=1 CanHome=1 CountsPerUnit=5336.000000 MaxVelocity=13340.000000 MaxAccel=266800.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor3] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=8.888800 MaxVelocity=5925.866667 MaxAccel=266664.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor4] Enabled=0 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor5] Enabled=0 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Signal208] ID=208 Type=Input Desc=Probe4 Enabled=0 Negated=0 Mapping=None [Signal209] ID=209 Type=Input Desc=Probe5 Enabled=0 Negated=0 Mapping=None [Signal210] ID=210 Type=Input Desc=Probe6 Enabled=0 Negated=0 Mapping=None [Signal211] ID=211 Type=Input Desc=Probe7 Enabled=0 Negated=0 Mapping=None [Signal212] ID=212 Type=Input Desc=Probe8 Enabled=0 Negated=0 Mapping=None [Signal213] ID=213 Type=Input Desc=Probe9 Enabled=0 Negated=0 Mapping=None [Signal1174] ID=1174 Type=Output Desc=OB1 Homed Enabled=0 Negated=0 Mapping=None [Signal1175] ID=1175 Type=Output Desc=OB2 Homed Enabled=0 Negated=0 Mapping=None [Signal1176] ID=1176 Type=Output Desc=OB3 Homed Enabled=0 Negated=0 Mapping=None [Signal1177] ID=1177 Type=Output Desc=OB4 Homed Enabled=0 Negated=0 Mapping=None [Signal1178] ID=1178 Type=Output Desc=OB5 Homed Enabled=0 Negated=0 Mapping=None [Signal1179] ID=1179 Type=Output Desc=OB6 Homed Enabled=0 Negated=0 Mapping=None [Signal1172] ID=1172 Type=Output Desc=Machine Idle Enabled=0 Negated=0 Mapping=None [Signal1173] ID=1173 Type=Output Desc=Machine Probing Enabled=0 Negated=0 Mapping=None [Signal1180] ID=1180 Type=Output Desc=Feed Hold Disabled Enabled=0 Negated=0 Mapping=None [Signal1181] ID=1181 Type=Output Desc=Feed Rate Ovr Disabled Enabled=0 Negated=0 Mapping=None [Signal1182] ID=1182 Type=Output Desc=Spindle Ovr Disabled Enabled=0 Negated=0 Mapping=None [Signal1183] ID=1183 Type=Output Desc=Rapid Rate Ovr Enabled=0 Negated=0 Mapping=None [Signal1184] ID=1184 Type=Output Desc=Spindle Ovr Enabled=0 Negated=0 Mapping=None [Signal1185] ID=1185 Type=Output Desc=Feed Rate Ovr Enabled=0 Negated=0 Mapping=None [RegFileDiag] aot=1 x=931 y=71 w=400 h=423 PoundVarlbound=0 PoundVarubound=0 [FixtureWindow] posX=798 posY=25 width=440 height=329 aot=1 [LogWindow] posX=921 posY=111 width=400 height=300 aot=1 [ModbusSetupDialog] aot=0 x=371 y=9 w=959 h=788 [ModbusDevice] [ModbusDevice/Camera] Type=2 Interval=25 Retry=3 Timeout=1000 EnronMode32=0 SwapIntWords=0 SwapFloatWords=0 UseBaseZero=1 InitialState=1 Desc=Camera IPAddr=10.9.9.2 TcpPort=502 Func0=function0 [ModbusDevice/Camera/function0] Desc=x1 Type=4 SlaveAddr=0 MbAddr=39 NbrRegs=4 BitPack=0 Bits=0 ReadAs=1 InitialState=1 ScanDenominator=1 Res0=x1 Res1=x2 Res2=y1 Res3=y2 [ModbusDevice/Camera/function0/x1] Desc=x1 Type=128 RegIndex=0 BitIndex=0 [ModbusDevice/Camera/function0/x2] Desc=x2 Type=128 RegIndex=0 BitIndex=0 [ModbusDevice/Camera/function0/y1] Desc=y1 Type=128 RegIndex=0 BitIndex=0 [ModbusDevice/Camera/function0/y2] Desc=y2 Type=128 RegIndex=0 BitIndex=0 [PoKeysGeneral] DeviceNames=PoKeys (50671) [PoKeys\ (50671)] DeviceDisplayName=PoKeys_50671 IO_EncodersCount=26 Serial=50575 DeviceType=30 Logging=1 ForceEthernet=0 PinFunction_0=4 PinOK_0=3 Counter_0=0 PinFunction_1=4 PinOK_1=3 Counter_1=0 PinFunction_2=2 PinOK_2=3 Counter_2=0 PinFunction_3=2 PinOK_3=3 Counter_3=0 PinFunction_4=2 PinOK_4=3 Counter_4=0 PinFunction_5=4 PinOK_5=3 Counter_5=0 PinFunction_6=2 PinOK_6=3 Counter_6=0 PinFunction_7=4 PinOK_7=3 Counter_7=0 PinFunction_8=2 PinOK_8=3 Counter_8=0 PinFunction_9=2 PinOK_9=3 Counter_9=0 PinFunction_10=2 PinOK_10=3 Counter_10=0 PinFunction_11=0 PinOK_11=3 Counter_11=0 PinFunction_12=0 PinOK_12=3 Counter_12=0 PinFunction_13=0 PinOK_13=3 Counter_13=0 PinFunction_14=0 PinOK_14=3 Counter_14=0 PinFunction_15=0 PinOK_15=3 Counter_15=0 PinFunction_16=0 PinOK_16=3 Counter_16=0 PinFunction_17=0 PinOK_17=3 Counter_17=0 PinFunction_18=0 PinOK_18=3 Counter_18=0 PinFunction_19=0 PinOK_19=3 Counter_19=0 PinFunction_20=0 PinOK_20=3 Counter_20=0 PinFunction_21=0 PinOK_21=3 Counter_21=0 PinFunction_22=0 PinOK_22=3 Counter_22=0 PinFunction_23=0 PinOK_23=3 Counter_23=0 PinFunction_24=0 PinOK_24=3 Counter_24=0 PinFunction_25=0 PinOK_25=3 Counter_25=0 PinFunction_26=0 PinOK_26=3 Counter_26=0 PinFunction_27=0 PinOK_27=3 Counter_27=0 PinFunction_28=0 PinOK_28=3 Counter_28=0 PinFunction_29=0 PinOK_29=3 Counter_29=0 PinFunction_30=0 PinOK_30=3 Counter_30=0 PinFunction_31=0 PinOK_31=3 Counter_31=0 PinFunction_32=0 PinOK_32=3 Counter_32=0 PinFunction_33=0 PinOK_33=3 Counter_33=0 PinFunction_34=0 PinOK_34=3 Counter_34=0 PinFunction_35=0 PinOK_35=3 Counter_35=0 PinFunction_36=0 PinOK_36=3 Counter_36=0 PinFunction_37=0 PinOK_37=3 Counter_37=0 PinFunction_38=0 PinOK_38=3 Counter_38=0 PinFunction_39=0 PinOK_39=3 Counter_39=0 PinFunction_40=0 PinOK_40=3 Counter_40=0 PinFunction_41=0 PinOK_41=3 Counter_41=0 PinFunction_42=0 PinOK_42=3 Counter_42=0 PinFunction_43=0 PinOK_43=3 Counter_43=0 PinFunction_44=0 PinOK_44=3 Counter_44=0 PinFunction_45=0 PinOK_45=3 Counter_45=0 PinFunction_46=0 PinOK_46=3 Counter_46=0 PinFunction_47=0 PinOK_47=3 Counter_47=0 PinFunction_48=0 PinOK_48=3 Counter_48=0 PinFunction_49=0 PinOK_49=3 Counter_49=0 PinFunction_50=0 PinOK_50=3 Counter_50=0 PinFunction_51=0 PinOK_51=3 Counter_51=0 PinFunction_52=0 PinOK_52=3 Counter_52=0 PinFunction_53=0 PinOK_53=3 Counter_53=0 PinFunction_54=0 PinOK_54=3 Counter_54=0 EncodersFastEnable=0 EncoderUltraFastEnable=0 EncoderUltraFastFilter=10 Encoder_0_enable=0 Encoder_0_invert=0 Encoder_0_4x=0 Encoder_0_pinA=0 Encoder_0_pinB=0 Encoder_1_enable=0 Encoder_1_invert=0 Encoder_1_4x=0 Encoder_1_pinA=0 Encoder_1_pinB=0 Encoder_2_enable=0 Encoder_2_invert=0 Encoder_2_4x=0 Encoder_2_pinA=0 Encoder_2_pinB=0 Encoder_3_enable=0 Encoder_3_invert=0 Encoder_3_4x=0 Encoder_3_pinA=0 Encoder_3_pinB=0 Encoder_4_enable=0 Encoder_4_invert=0 Encoder_4_4x=0 Encoder_4_pinA=0 Encoder_4_pinB=0 Encoder_5_enable=0 Encoder_5_invert=0 Encoder_5_4x=0 Encoder_5_pinA=0 Encoder_5_pinB=0 Encoder_6_enable=0 Encoder_6_invert=0 Encoder_6_4x=0 Encoder_6_pinA=0 Encoder_6_pinB=0 Encoder_7_enable=0 Encoder_7_invert=0 Encoder_7_4x=0 Encoder_7_pinA=0 Encoder_7_pinB=0 Encoder_8_enable=0 Encoder_8_invert=0 Encoder_8_4x=0 Encoder_8_pinA=0 Encoder_8_pinB=0 Encoder_9_enable=0 Encoder_9_invert=0 Encoder_9_4x=0 Encoder_9_pinA=0 Encoder_9_pinB=0 Encoder_10_enable=0 Encoder_10_invert=0 Encoder_10_4x=0 Encoder_10_pinA=0 Encoder_10_pinB=0 Encoder_11_enable=0 Encoder_11_invert=0 Encoder_11_4x=0 Encoder_11_pinA=0 Encoder_11_pinB=0 Encoder_12_enable=0 Encoder_12_invert=0 Encoder_12_4x=0 Encoder_12_pinA=0 Encoder_12_pinB=0 Encoder_13_enable=0 Encoder_13_invert=0 Encoder_13_4x=0 Encoder_13_pinA=0 Encoder_13_pinB=0 Encoder_14_enable=0 Encoder_14_invert=0 Encoder_14_4x=0 Encoder_14_pinA=0 Encoder_14_pinB=0 Encoder_15_enable=0 Encoder_15_invert=0 Encoder_15_4x=0 Encoder_15_pinA=0 Encoder_15_pinB=0 Encoder_16_enable=0 Encoder_16_invert=0 Encoder_16_4x=0 Encoder_16_pinA=0 Encoder_16_pinB=0 Encoder_17_enable=0 Encoder_17_invert=0 Encoder_17_4x=0 Encoder_17_pinA=0 Encoder_17_pinB=0 Encoder_18_enable=0 Encoder_18_invert=0 Encoder_18_4x=0 Encoder_18_pinA=0 Encoder_18_pinB=0 Encoder_19_enable=0 Encoder_19_invert=0 Encoder_19_4x=0 Encoder_19_pinA=0 Encoder_19_pinB=0 Encoder_20_enable=0 Encoder_20_invert=0 Encoder_20_4x=0 Encoder_20_pinA=0 Encoder_20_pinB=0 Encoder_21_enable=0 Encoder_21_invert=0 Encoder_21_4x=0 Encoder_21_pinA=0 Encoder_21_pinB=0 Encoder_22_enable=0 Encoder_22_invert=0 Encoder_22_4x=0 Encoder_22_pinA=0 Encoder_22_pinB=0 Encoder_23_enable=0 Encoder_23_invert=0 Encoder_23_4x=0 Encoder_23_pinA=0 Encoder_23_pinB=0 Encoder_24_enable=0 Encoder_24_invert=0 Encoder_24_4x=0 Encoder_24_pinA=0 Encoder_24_pinB=0 Encoder_25_enable=0 Encoder_25_invert=0 Encoder_25_4x=0 Encoder_25_pinA=0 Encoder_25_pinB=0 MatrixEnabled=1 MatrixRows=3 MatrixColumns=6 MatrixRowPin_0=0 MatrixRowPin_1=1 MatrixRowPin_2=5 MatrixRowPin_3=7 MatrixRowPin_4=0 MatrixRowPin_5=0 MatrixRowPin_6=0 MatrixRowPin_7=0 MatrixRowPin_8=0 MatrixRowPin_9=0 MatrixRowPin_10=0 MatrixRowPin_11=0 MatrixRowPin_12=0 MatrixRowPin_13=0 MatrixRowPin_14=0 MatrixRowPin_15=0 MatrixColumnPin_0=2 MatrixColumnPin_1=3 MatrixColumnPin_2=4 MatrixColumnPin_3=6 MatrixColumnPin_4=8 MatrixColumnPin_5=9 MatrixColumnPin_6=10 MatrixColumnPin_7=0 PendantEnabled=0 MapPendantToMach4=0 EnableKBD48CNC=1 EnableGenericPendant=0 AdjustKBD48CNCBrightness=0 DefaultBKD48CNCBrightness=100 PendantFunc_0_en=0 PendantFunc_0_sw=0 PendantFunc_0_btn=0 PendantFunc_0_LED=0 PendantFunc_0_InInv=0 PendantFunc_0_OutInv=0 PendantFunc_1_en=0 PendantFunc_1_sw=0 PendantFunc_1_btn=0 PendantFunc_1_LED=0 PendantFunc_1_InInv=0 PendantFunc_1_OutInv=0 PendantFunc_2_en=0 PendantFunc_2_sw=0 PendantFunc_2_btn=0 PendantFunc_2_LED=0 PendantFunc_2_InInv=0 PendantFunc_2_OutInv=0 PendantFunc_3_en=0 PendantFunc_3_sw=0 PendantFunc_3_btn=0 PendantFunc_3_LED=0 PendantFunc_3_InInv=0 PendantFunc_3_OutInv=0 PendantFunc_4_en=0 PendantFunc_4_sw=0 PendantFunc_4_btn=0 PendantFunc_4_LED=0 PendantFunc_4_InInv=0 PendantFunc_4_OutInv=0 PendantFunc_5_en=0 PendantFunc_5_sw=0 PendantFunc_5_btn=0 PendantFunc_5_LED=0 PendantFunc_5_InInv=0 PendantFunc_5_OutInv=0 PendantFunc_6_en=0 PendantFunc_6_sw=0 PendantFunc_6_btn=0 PendantFunc_6_LED=0 PendantFunc_6_InInv=0 PendantFunc_6_OutInv=0 PendantFunc_7_en=0 PendantFunc_7_sw=0 PendantFunc_7_btn=0 PendantFunc_7_LED=0 PendantFunc_7_InInv=0 PendantFunc_7_OutInv=0 PendantFunc_8_en=0 PendantFunc_8_sw=0 PendantFunc_8_btn=0 PendantFunc_8_LED=0 PendantFunc_8_InInv=0 PendantFunc_8_OutInv=0 PendantFunc_9_en=0 PendantFunc_9_sw=0 PendantFunc_9_btn=0 PendantFunc_9_LED=0 PendantFunc_9_InInv=0 PendantFunc_9_OutInv=0 PendantFunc_10_en=0 PendantFunc_10_sw=0 PendantFunc_10_btn=0 PendantFunc_10_LED=0 PendantFunc_10_InInv=0 PendantFunc_10_OutInv=0 PendantFunc_11_en=0 PendantFunc_11_sw=0 PendantFunc_11_btn=0 PendantFunc_11_LED=0 PendantFunc_11_InInv=0 PendantFunc_11_OutInv=0 PendantFunc_12_en=0 PendantFunc_12_sw=0 PendantFunc_12_btn=0 PendantFunc_12_LED=0 PendantFunc_12_InInv=0 PendantFunc_12_OutInv=0 PendantFunc_13_en=0 PendantFunc_13_sw=0 PendantFunc_13_btn=0 PendantFunc_13_LED=0 PendantFunc_13_InInv=0 PendantFunc_13_OutInv=0 PendantFunc_14_en=0 PendantFunc_14_sw=0 PendantFunc_14_btn=0 PendantFunc_14_LED=0 PendantFunc_14_InInv=0 PendantFunc_14_OutInv=0 PendantFunc_15_en=0 PendantFunc_15_sw=0 PendantFunc_15_btn=0 PendantFunc_15_LED=0 PendantFunc_15_InInv=0 PendantFunc_15_OutInv=0 PendantFunc_16_en=0 PendantFunc_16_sw=0 PendantFunc_16_btn=0 PendantFunc_16_LED=0 PendantFunc_16_InInv=0 PendantFunc_16_OutInv=0 PendantFunc_17_en=0 PendantFunc_17_sw=0 PendantFunc_17_btn=0 PendantFunc_17_LED=0 PendantFunc_17_InInv=0 PendantFunc_17_OutInv=0 PendantFunc_18_en=0 PendantFunc_18_sw=0 PendantFunc_18_btn=0 PendantFunc_18_LED=0 PendantFunc_18_InInv=0 PendantFunc_18_OutInv=0 PendantFunc_19_en=0 PendantFunc_19_sw=0 PendantFunc_19_btn=0 PendantFunc_19_LED=0 PendantFunc_19_InInv=0 PendantFunc_19_OutInv=0 PendantFunc_20_en=0 PendantFunc_20_sw=0 PendantFunc_20_btn=0 PendantFunc_20_LED=0 PendantFunc_20_InInv=0 PendantFunc_20_OutInv=0 PendantFunc_21_en=0 PendantFunc_21_sw=0 PendantFunc_21_btn=0 PendantFunc_21_LED=0 PendantFunc_21_InInv=0 PendantFunc_21_OutInv=0 PendantFunc_22_en=0 PendantFunc_22_sw=0 PendantFunc_22_btn=0 PendantFunc_22_LED=0 PendantFunc_22_InInv=0 PendantFunc_22_OutInv=0 PendantFunc_23_en=0 PendantFunc_23_sw=0 PendantFunc_23_btn=0 PendantFunc_23_LED=0 PendantFunc_23_InInv=0 PendantFunc_23_OutInv=0 PendantFunc_24_en=0 PendantFunc_24_sw=0 PendantFunc_24_btn=0 PendantFunc_24_LED=0 PendantFunc_24_InInv=0 PendantFunc_24_OutInv=0 PendantFunc_25_en=0 PendantFunc_25_sw=0 PendantFunc_25_btn=0 PendantFunc_25_LED=0 PendantFunc_25_InInv=0 PendantFunc_25_OutInv=0 PendantFunc_26_en=0 PendantFunc_26_sw=0 PendantFunc_26_btn=0 PendantFunc_26_LED=0 PendantFunc_26_InInv=0 PendantFunc_26_OutInv=0 PendantFunc_27_en=0 PendantFunc_27_sw=0 PendantFunc_27_btn=0 PendantFunc_27_LED=0 PendantFunc_27_InInv=0 PendantFunc_27_OutInv=0 PendantFunc_28_en=0 PendantFunc_28_sw=0 PendantFunc_28_btn=0 PendantFunc_28_LED=0 PendantFunc_28_InInv=0 PendantFunc_28_OutInv=0 PendantFunc_29_en=0 PendantFunc_29_sw=0 PendantFunc_29_btn=0 PendantFunc_29_LED=0 PendantFunc_29_InInv=0 PendantFunc_29_OutInv=0 PendantFunc_30_en=0 PendantFunc_30_sw=0 PendantFunc_30_btn=0 PendantFunc_30_LED=0 PendantFunc_30_InInv=0 PendantFunc_30_OutInv=0 PendantFunc_31_en=0 PendantFunc_31_sw=0 PendantFunc_31_btn=0 PendantFunc_31_LED=0 PendantFunc_31_InInv=0 PendantFunc_31_OutInv=0 PendantFunc_32_en=0 PendantFunc_32_sw=0 PendantFunc_32_btn=0 PendantFunc_32_LED=0 PendantFunc_32_InInv=0 PendantFunc_32_OutInv=0 PendantFunc_33_en=0 PendantFunc_33_sw=0 PendantFunc_33_btn=0 PendantFunc_33_LED=0 PendantFunc_33_InInv=0 PendantFunc_33_OutInv=0 PendantFunc_34_en=0 PendantFunc_34_sw=0 PendantFunc_34_btn=0 PendantFunc_34_LED=0 PendantFunc_34_InInv=0 PendantFunc_34_OutInv=0 PendantFunc_35_en=0 PendantFunc_35_sw=0 PendantFunc_35_btn=0 PendantFunc_35_LED=0 PendantFunc_35_InInv=0 PendantFunc_35_OutInv=0 PendantFunc_36_en=0 PendantFunc_36_sw=0 PendantFunc_36_btn=0 PendantFunc_36_LED=0 PendantFunc_36_InInv=0 PendantFunc_36_OutInv=0 PendantFunc_37_en=0 PendantFunc_37_sw=0 PendantFunc_37_btn=0 PendantFunc_37_LED=0 PendantFunc_37_InInv=0 PendantFunc_37_OutInv=0 PendantFunc_38_en=0 PendantFunc_38_sw=0 PendantFunc_38_btn=0 PendantFunc_38_LED=0 PendantFunc_38_InInv=0 PendantFunc_38_OutInv=0 PendantFunc_39_en=0 PendantFunc_39_sw=0 PendantFunc_39_btn=0 PendantFunc_39_LED=0 PendantFunc_39_InInv=0 PendantFunc_39_OutInv=0 PendantFunc_40_en=0 PendantFunc_40_sw=0 PendantFunc_40_btn=0 PendantFunc_40_LED=0 PendantFunc_40_InInv=0 PendantFunc_40_OutInv=0 PendantFunc_41_en=0 PendantFunc_41_sw=0 PendantFunc_41_btn=0 PendantFunc_41_LED=0 PendantFunc_41_InInv=0 PendantFunc_41_OutInv=0 PendantFunc_42_en=0 PendantFunc_42_sw=0 PendantFunc_42_btn=0 PendantFunc_42_LED=0 PendantFunc_42_InInv=0 PendantFunc_42_OutInv=0 PendantFunc_43_en=0 PendantFunc_43_sw=0 PendantFunc_43_btn=0 PendantFunc_43_LED=0 PendantFunc_43_InInv=0 PendantFunc_43_OutInv=0 PendantFunc_44_en=0 PendantFunc_44_sw=0 PendantFunc_44_btn=0 PendantFunc_44_LED=0 PendantFunc_44_InInv=0 PendantFunc_44_OutInv=0 PendantFunc_45_en=0 PendantFunc_45_sw=0 PendantFunc_45_btn=0 PendantFunc_45_LED=0 PendantFunc_45_InInv=0 PendantFunc_45_OutInv=0 PendantFunc_46_en=0 PendantFunc_46_sw=0 PendantFunc_46_btn=0 PendantFunc_46_LED=0 PendantFunc_46_InInv=0 PendantFunc_46_OutInv=0 PendantFunc_47_en=0 PendantFunc_47_sw=0 PendantFunc_47_btn=0 PendantFunc_47_LED=0 PendantFunc_47_InInv=0 PendantFunc_47_OutInv=0 PendantFunc_48_en=0 PendantFunc_48_sw=0 PendantFunc_48_btn=0 PendantFunc_48_LED=0 PendantFunc_48_InInv=0 PendantFunc_48_OutInv=0 PendantFunc_49_en=0 PendantFunc_49_sw=0 PendantFunc_49_btn=0 PendantFunc_49_LED=0 PendantFunc_49_InInv=0 PendantFunc_49_OutInv=0 PendantFunc_50_en=0 PendantFunc_50_sw=0 PendantFunc_50_btn=0 PendantFunc_50_LED=0 PendantFunc_50_InInv=0 PendantFunc_50_OutInv=0 PendantFunc_51_en=0 PendantFunc_51_sw=0 PendantFunc_51_btn=0 PendantFunc_51_LED=0 PendantFunc_51_InInv=0 PendantFunc_51_OutInv=0 PendantFunc_52_en=0 PendantFunc_52_sw=0 PendantFunc_52_btn=0 PendantFunc_52_LED=0 PendantFunc_52_InInv=0 PendantFunc_52_OutInv=0 PendantFunc_53_en=0 PendantFunc_53_sw=0 PendantFunc_53_btn=0 PendantFunc_53_LED=0 PendantFunc_53_InInv=0 PendantFunc_53_OutInv=0 PendantFunc_54_en=0 PendantFunc_54_sw=0 PendantFunc_54_btn=0 PendantFunc_54_LED=0 PendantFunc_54_InInv=0 PendantFunc_54_OutInv=0 PendantFunc_55_en=0 PendantFunc_55_sw=0 PendantFunc_55_btn=0 PendantFunc_55_LED=0 PendantFunc_55_InInv=0 PendantFunc_55_OutInv=0 PendantFunc_56_en=0 PendantFunc_56_sw=0 PendantFunc_56_btn=0 PendantFunc_56_LED=0 PendantFunc_56_InInv=0 PendantFunc_56_OutInv=0 PendantFunc_57_en=0 PendantFunc_57_sw=0 PendantFunc_57_btn=0 PendantFunc_57_LED=0 PendantFunc_57_InInv=0 PendantFunc_57_OutInv=0 PendantFunc_58_en=0 PendantFunc_58_sw=0 PendantFunc_58_btn=0 PendantFunc_58_LED=0 PendantFunc_58_InInv=0 PendantFunc_58_OutInv=0 PendantFunc_59_en=0 PendantFunc_59_sw=0 PendantFunc_59_btn=0 PendantFunc_59_LED=0 PendantFunc_59_InInv=0 PendantFunc_59_OutInv=0 PendantFunc_60_en=0 PendantFunc_60_sw=0 PendantFunc_60_btn=0 PendantFunc_60_LED=0 PendantFunc_60_InInv=0 PendantFunc_60_OutInv=0 PendantFunc_61_en=0 PendantFunc_61_sw=0 PendantFunc_61_btn=0 PendantFunc_61_LED=0 PendantFunc_61_InInv=0 PendantFunc_61_OutInv=0 PendantFunc_62_en=0 PendantFunc_62_sw=0 PendantFunc_62_btn=0 PendantFunc_62_LED=0 PendantFunc_62_InInv=0 PendantFunc_62_OutInv=0 PendantFunc_63_en=0 PendantFunc_63_sw=0 PendantFunc_63_btn=0 PendantFunc_63_LED=0 PendantFunc_63_InInv=0 PendantFunc_63_OutInv=0 PendantFunc_64_en=0 PendantFunc_64_sw=0 PendantFunc_64_btn=0 PendantFunc_64_LED=0 PendantFunc_64_InInv=0 PendantFunc_64_OutInv=0 PendantFunc_65_en=0 PendantFunc_65_sw=0 PendantFunc_65_btn=0 PendantFunc_65_LED=0 PendantFunc_65_InInv=0 PendantFunc_65_OutInv=0 PendantFunc_66_en=0 PendantFunc_66_sw=0 PendantFunc_66_btn=0 PendantFunc_66_LED=0 PendantFunc_66_InInv=0 PendantFunc_66_OutInv=0 PendantFunc_67_en=0 PendantFunc_67_sw=0 PendantFunc_67_btn=0 PendantFunc_67_LED=0 PendantFunc_67_InInv=0 PendantFunc_67_OutInv=0 PendantFunc_68_en=0 PendantFunc_68_sw=0 PendantFunc_68_btn=0 PendantFunc_68_LED=0 PendantFunc_68_InInv=0 PendantFunc_68_OutInv=0 PendantFunc_69_en=0 PendantFunc_69_sw=0 PendantFunc_69_btn=0 PendantFunc_69_LED=0 PendantFunc_69_InInv=0 PendantFunc_69_OutInv=0 PendantFunc_70_en=0 PendantFunc_70_sw=0 PendantFunc_70_btn=0 PendantFunc_70_LED=0 PendantFunc_70_InInv=0 PendantFunc_70_OutInv=0 PendantFunc_71_en=0 PendantFunc_71_sw=0 PendantFunc_71_btn=0 PendantFunc_71_LED=0 PendantFunc_71_InInv=0 PendantFunc_71_OutInv=0 PendantFunc_72_en=0 PendantFunc_72_sw=0 PendantFunc_72_btn=0 PendantFunc_72_LED=0 PendantFunc_72_InInv=0 PendantFunc_72_OutInv=0 PendantFunc_73_en=0 PendantFunc_73_sw=0 PendantFunc_73_btn=0 PendantFunc_73_LED=0 PendantFunc_73_InInv=0 PendantFunc_73_OutInv=0 PendantFunc_74_en=0 PendantFunc_74_sw=0 PendantFunc_74_btn=0 PendantFunc_74_LED=0 PendantFunc_74_InInv=0 PendantFunc_74_OutInv=0 PendantFunc_75_en=0 PendantFunc_75_sw=0 PendantFunc_75_btn=0 PendantFunc_75_LED=0 PendantFunc_75_InInv=0 PendantFunc_75_OutInv=0 PendantFunc_76_en=0 PendantFunc_76_sw=0 PendantFunc_76_btn=0 PendantFunc_76_LED=0 PendantFunc_76_InInv=0 PendantFunc_76_OutInv=0 PendantFunc_77_en=0 PendantFunc_77_sw=0 PendantFunc_77_btn=0 PendantFunc_77_LED=0 PendantFunc_77_InInv=0 PendantFunc_77_OutInv=0 PendantFunc_78_en=0 PendantFunc_78_sw=0 PendantFunc_78_btn=0 PendantFunc_78_LED=0 PendantFunc_78_InInv=0 PendantFunc_78_OutInv=0 PendantFunc_79_en=0 PendantFunc_79_sw=0 PendantFunc_79_btn=0 PendantFunc_79_LED=0 PendantFunc_79_InInv=0 PendantFunc_79_OutInv=0 PendantFunc_80_en=0 PendantFunc_80_sw=0 PendantFunc_80_btn=0 PendantFunc_80_LED=0 PendantFunc_80_InInv=0 PendantFunc_80_OutInv=0 PendantFunc_81_en=0 PendantFunc_81_sw=0 PendantFunc_81_btn=0 PendantFunc_81_LED=0 PendantFunc_81_InInv=0 PendantFunc_81_OutInv=0 PendantFunc_82_en=0 PendantFunc_82_sw=0 PendantFunc_82_btn=0 PendantFunc_82_LED=0 PendantFunc_82_InInv=0 PendantFunc_82_OutInv=0 PendantFunc_83_en=0 PendantFunc_83_sw=0 PendantFunc_83_btn=0 PendantFunc_83_LED=0 PendantFunc_83_InInv=0 PendantFunc_83_OutInv=0 PendantFunc_84_en=0 PendantFunc_84_sw=0 PendantFunc_84_btn=0 PendantFunc_84_LED=0 PendantFunc_84_InInv=0 PendantFunc_84_OutInv=0 PendantFunc_85_en=0 PendantFunc_85_sw=0 PendantFunc_85_btn=0 PendantFunc_85_LED=0 PendantFunc_85_InInv=0 PendantFunc_85_OutInv=0 PendantFunc_86_en=0 PendantFunc_86_sw=0 PendantFunc_86_btn=0 PendantFunc_86_LED=0 PendantFunc_86_InInv=0 PendantFunc_86_OutInv=0 PendantFunc_87_en=0 PendantFunc_87_sw=0 PendantFunc_87_btn=0 PendantFunc_87_LED=0 PendantFunc_87_InInv=0 PendantFunc_87_OutInv=0 PendantFunc_88_en=0 PendantFunc_88_sw=0 PendantFunc_88_btn=0 PendantFunc_88_LED=0 PendantFunc_88_InInv=0 PendantFunc_88_OutInv=0 PendantFunc_89_en=0 PendantFunc_89_sw=0 PendantFunc_89_btn=0 PendantFunc_89_LED=0 PendantFunc_89_InInv=0 PendantFunc_89_OutInv=0 PendantFunc_90_en=0 PendantFunc_90_sw=0 PendantFunc_90_btn=0 PendantFunc_90_LED=0 PendantFunc_90_InInv=0 PendantFunc_90_OutInv=0 PendantFunc_91_en=0 PendantFunc_91_sw=0 PendantFunc_91_btn=0 PendantFunc_91_LED=0 PendantFunc_91_InInv=0 PendantFunc_91_OutInv=0 PendantFunc_92_en=0 PendantFunc_92_sw=0 PendantFunc_92_btn=0 PendantFunc_92_LED=0 PendantFunc_92_InInv=0 PendantFunc_92_OutInv=0 PendantFunc_93_en=0 PendantFunc_93_sw=0 PendantFunc_93_btn=0 PendantFunc_93_LED=0 PendantFunc_93_InInv=0 PendantFunc_93_OutInv=0 PendantFunc_94_en=0 PendantFunc_94_sw=0 PendantFunc_94_btn=0 PendantFunc_94_LED=0 PendantFunc_94_InInv=0 PendantFunc_94_OutInv=0 PendantFunc_95_en=0 PendantFunc_95_sw=0 PendantFunc_95_btn=0 PendantFunc_95_LED=0 PendantFunc_95_InInv=0 PendantFunc_95_OutInv=0 PendantFunc_96_en=0 PendantFunc_96_sw=0 PendantFunc_96_btn=0 PendantFunc_96_LED=0 PendantFunc_96_InInv=0 PendantFunc_96_OutInv=0 PendantFunc_97_en=0 PendantFunc_97_sw=0 PendantFunc_97_btn=0 PendantFunc_97_LED=0 PendantFunc_97_InInv=0 PendantFunc_97_OutInv=0 PendantFunc_98_en=0 PendantFunc_98_sw=0 PendantFunc_98_btn=0 PendantFunc_98_LED=0 PendantFunc_98_InInv=0 PendantFunc_98_OutInv=0 PendantFunc_99_en=0 PendantFunc_99_sw=0 PendantFunc_99_btn=0 PendantFunc_99_LED=0 PendantFunc_99_InInv=0 PendantFunc_99_OutInv=0 PendantMPG_0_en=0 PendantMPG_0_enc=0 PendantMPG_0_deadman=1 PendantMPG_1_en=0 PendantMPG_1_enc=0 PendantMPG_1_deadman=1 PendantMPG_2_en=0 PendantMPG_2_enc=0 PendantMPG_2_deadman=1 PEtype=0 PESwapDirStep=0 PEChargePump=0 PEChargePumpStates=0 PEInvertEmergency=0 PEEmergencyInputPin=1 PEProbingPin=0 PEProbingPinInvert=0 PERegisterSignals=0 PEAllowOutputEnableControl=0 PEBufferSize=0 PEUpdateRAW=0 PEThreadingActivate=0 PEThreadingEnable=0 PEThreadingSensor=0 PEThreadingResolution=512 PESpindleSpeed=0 PEThreadingFilterSpeedGain=64 PEThreadingFilterPositionGain=320 PEBacklashCompensation=0 PEBacklashCompensationAcc=1 PESpindleStepDir=0 PESpindleMotorID=0 PEBackOffDistance=0 PESupportFastOutputs=0 PEEnableOutputPin_0=0 PELimitPinP_0=0 PELimitPinPInvert_0=0 PELimitPinM_0=0 PELimitPinMInvert_0=0 PEHomePin_0=0 PEHomePinInvert_0=0 PEStepInvert_0=0 PEAxisEnabledInvert_0=0 PEHomeAlgorithm_0=0 PEFilterLimitM_0=10 PEFilterLimitP_0=10 PEFilterHome_0=10 PEHomeReducedSpeed_0=0 PEStopOnError_0=0 PEInvertError_0=0 PEAxisMode_0=0 PEEnableOutputPin_1=0 PELimitPinP_1=0 PELimitPinPInvert_1=0 PELimitPinM_1=0 PELimitPinMInvert_1=0 PEHomePin_1=0 PEHomePinInvert_1=0 PEStepInvert_1=0 PEAxisEnabledInvert_1=0 PEHomeAlgorithm_1=0 PEFilterLimitM_1=10 PEFilterLimitP_1=10 PEFilterHome_1=10 PEHomeReducedSpeed_1=0 PEStopOnError_1=0 PEInvertError_1=0 PEAxisMode_1=0 PEEnableOutputPin_2=0 PELimitPinP_2=0 PELimitPinPInvert_2=0 PELimitPinM_2=0 PELimitPinMInvert_2=0 PEHomePin_2=0 PEHomePinInvert_2=0 PEStepInvert_2=0 PEAxisEnabledInvert_2=0 PEHomeAlgorithm_2=0 PEFilterLimitM_2=10 PEFilterLimitP_2=10 PEFilterHome_2=10 PEHomeReducedSpeed_2=0 PEStopOnError_2=0 PEInvertError_2=0 PEAxisMode_2=0 PEEnableOutputPin_3=0 PELimitPinP_3=0 PELimitPinPInvert_3=0 PELimitPinM_3=0 PELimitPinMInvert_3=0 PEHomePin_3=0 PEHomePinInvert_3=0 PEStepInvert_3=0 PEAxisEnabledInvert_3=0 PEHomeAlgorithm_3=0 PEFilterLimitM_3=10 PEFilterLimitP_3=10 PEFilterHome_3=10 PEHomeReducedSpeed_3=0 PEStopOnError_3=0 PEInvertError_3=0 PEAxisMode_3=0 PEEnableOutputPin_4=0 PELimitPinP_4=0 PELimitPinPInvert_4=0 PELimitPinM_4=0 PELimitPinMInvert_4=0 PEHomePin_4=0 PEHomePinInvert_4=0 PEStepInvert_4=0 PEAxisEnabledInvert_4=0 PEHomeAlgorithm_4=0 PEFilterLimitM_4=10 PEFilterLimitP_4=10 PEFilterHome_4=10 PEHomeReducedSpeed_4=0 PEStopOnError_4=0 PEInvertError_4=0 PEAxisMode_4=0 PEEnableOutputPin_5=0 PELimitPinP_5=0 PELimitPinPInvert_5=0 PELimitPinM_5=0 PELimitPinMInvert_5=0 PEHomePin_5=0 PEHomePinInvert_5=0 PEStepInvert_5=0 PEAxisEnabledInvert_5=0 PEHomeAlgorithm_5=0 PEFilterLimitM_5=10 PEFilterLimitP_5=10 PEFilterHome_5=10 PEHomeReducedSpeed_5=0 PEStopOnError_5=0 PEInvertError_5=0 PEAxisMode_5=0 PEEnableOutputPin_6=0 PELimitPinP_6=0 PELimitPinPInvert_6=0 PELimitPinM_6=0 PELimitPinMInvert_6=0 PEHomePin_6=0 PEHomePinInvert_6=0 PEStepInvert_6=0 PEAxisEnabledInvert_6=0 PEHomeAlgorithm_6=0 PEFilterLimitM_6=10 PEFilterLimitP_6=10 PEFilterHome_6=10 PEHomeReducedSpeed_6=0 PEStopOnError_6=0 PEInvertError_6=0 PEAxisMode_6=0 PEEnableOutputPin_7=0 PELimitPinP_7=0 PELimitPinPInvert_7=0 PELimitPinM_7=0 PELimitPinMInvert_7=0 PEHomePin_7=0 PEHomePinInvert_7=0 PEStepInvert_7=0 PEAxisEnabledInvert_7=0 PEHomeAlgorithm_7=0 PEFilterLimitM_7=10 PEFilterLimitP_7=10 PEFilterHome_7=10 PEHomeReducedSpeed_7=0 PEStopOnError_7=0 PEInvertError_7=0 PEAxisMode_7=0 EnableJogFastStop=0 PoExtBusModules=0 WarnOfDisconnected=1 LCDEnabled=0 LCDpins=0 LCDrows=2 LCDcolumns=20 PWMEnabled=0 PWMFrequency=20000 PWMSpindleOutput=0 PWMSpindleOffOption=0 PoILinterchange=0 PWMPin22=0 PWMDefaultDuty22=0 PWMPin21=0 PWMDefaultDuty21=0 PWMPin20=0 PWMDefaultDuty20=0 PWMPin19=0 PWMDefaultDuty19=0 PWMPin18=0 PWMDefaultDuty18=0 PWMPin17=0 PWMDefaultDuty17=0 UpdateRate=0 ConnectionTimeout=0 MatrixLED1Config=0 MatrixLED2Config=0 MatrixLED1Rows=0 MatrixLED1Cols=0 MatrixLED2Rows=0 MatrixLED2Cols=0 PoStepCom=0 EasySensors=0 SpecFuncEnabled0=0 SpecFuncEncoder0=0 SpecFuncAnalog0=0 SpecFuncPin10=0 SpecFuncPin20=0 SpecFuncParam0=0 SpecFuncEnabled1=0 SpecFuncEncoder1=0 SpecFuncAnalog1=0 SpecFuncPin11=0 SpecFuncPin21=0 SpecFuncParam1=0 SpecFuncEnabled2=0 SpecFuncEncoder2=0 SpecFuncAnalog2=0 SpecFuncPin12=0 SpecFuncPin22=0 SpecFuncParam2=0 SpecFuncEnabled3=0 SpecFuncEncoder3=0 SpecFuncAnalog3=0 SpecFuncPin13=0 SpecFuncPin23=0 SpecFuncParam3=0 SpecFuncEnabled4=0 SpecFuncEncoder4=0 SpecFuncAnalog4=0 SpecFuncPin14=0 SpecFuncPin24=0 SpecFuncParam4=0 SpecFuncEnabled5=0 SpecFuncEncoder5=0 SpecFuncAnalog5=0 SpecFuncPin15=0 SpecFuncPin25=0 SpecFuncParam5=0 SpecFuncEnabled6=0 SpecFuncEncoder6=0 SpecFuncAnalog6=0 SpecFuncPin16=0 SpecFuncPin26=0 SpecFuncParam6=0 SpecFuncEnabled7=0 SpecFuncEncoder7=0 SpecFuncAnalog7=0 SpecFuncPin17=0 SpecFuncPin27=0 SpecFuncParam7=0 SpecFuncEnabled8=0 SpecFuncEncoder8=0 SpecFuncAnalog8=0 SpecFuncPin18=0 SpecFuncPin28=0 SpecFuncParam8=0 SpecFuncEnabled9=0 SpecFuncEncoder9=0 SpecFuncAnalog9=0 SpecFuncPin19=0 SpecFuncPin29=0 SpecFuncParam9=0 SpecFuncEnabled10=0 SpecFuncEncoder10=0 SpecFuncAnalog10=0 SpecFuncPin110=0 SpecFuncPin210=0 SpecFuncParam10=0 SpecFuncEnabled11=0 SpecFuncEncoder11=0 SpecFuncAnalog11=0 SpecFuncPin111=0 SpecFuncPin211=0 SpecFuncParam11=0 SpecFuncEnabled12=0 SpecFuncEncoder12=0 SpecFuncAnalog12=0 SpecFuncPin112=0 SpecFuncPin212=0 SpecFuncParam12=0 ReadDeviceLog=1 PEForceParametersUpdateOnHoming=0 [CVBlendRadius] Angle_1=2.629689 Angle_2=0.657422 Angle_3=0.293889 Angle_4=0.164356 Angle_5=0.105800 Angle_6=0.073472 Angle_7=0.054450 Angle_8=0.041089 Angle_9=0.032939 Angle_10=0.026450 Angle_11=0.022050 Angle_12=0.018689 Angle_13=0.015606 Angle_14=0.013339 Angle_15=0.011756 Angle_16=0.010272 Angle_17=0.009339 Angle_18=0.008450 Angle_19=0.007200 Angle_20=0.006806 Angle_21=0.006050 Angle_22=0.005689 Angle_23=0.005000 Angle_24=0.004672 Angle_25=0.004356 Angle_26=0.004050 Angle_27=0.003756 Angle_28=0.003472 Angle_29=0.003200 Angle_30=0.002939 Angle_31=0.002689 Angle_32=0.002689 Angle_33=0.002450 Angle_34=0.002222 Angle_35=0.002222 Angle_36=0.002006 Angle_37=0.002006 Angle_38=0.001800 Angle_39=0.001800 Angle_40=0.001606 Angle_41=0.001606 Angle_42=0.001422 Angle_43=0.001422 Angle_44=0.001422 Angle_45=0.001250 Angle_46=0.001250 Angle_47=0.001250 Angle_48=0.001089 Angle_49=0.001089 Angle_50=0.001089 Angle_51=0.000939 Angle_52=0.000939 Angle_53=0.000939 Angle_54=0.000939 Angle_55=0.000800 Angle_56=0.000800 Angle_57=0.000800 Angle_58=0.000800 Angle_59=0.000672 Angle_60=0.000672 Angle_61=0.000672 Angle_62=0.000672 Angle_63=0.000672 Angle_64=0.000672 Angle_65=0.000556 Angle_66=0.000556 Angle_67=0.000556 Angle_68=0.000556 Angle_69=0.000556 Angle_70=0.000556 Angle_71=0.000450 Angle_72=0.000450 Angle_73=0.000450 Angle_74=0.000450 Angle_75=0.000450 Angle_76=0.000450 Angle_77=0.000450 Angle_78=0.000356 Angle_79=0.000356 Angle_80=0.000356 Angle_81=0.000356 Angle_82=0.000356 Angle_83=0.000356 Angle_84=0.000356 Angle_85=0.000356 Angle_86=0.000356 Angle_87=0.000272 Angle_88=0.000272 Angle_89=0.000272 Angle_90=0.000272 Angle_91=0.000272 Angle_92=0.000272 Angle_93=0.000272 Angle_94=0.000272 Angle_95=0.000272 Angle_96=0.000272 Angle_97=0.000200 Angle_98=0.000200 Angle_99=0.000200 Angle_100=0.000200 Angle_101=0.000200 Angle_102=0.000200 Angle_103=0.000200 Angle_104=0.000200 Angle_105=0.000200 Angle_106=0.000200 Angle_107=0.000200 Angle_108=0.000200 Angle_109=0.000139 Angle_110=0.000139 Angle_111=0.000139 Angle_112=0.000139 Angle_113=0.000139 Angle_114=0.000139 Angle_115=0.000139 Angle_116=0.000139 Angle_117=0.000139 Angle_118=0.000139 Angle_119=0.000139 Angle_120=0.000139 Angle_121=0.000139 Angle_122=0.000139 Angle_123=0.000139 Angle_124=0.000089 Angle_125=0.000089 Angle_126=0.000089 Angle_127=0.000089 Angle_128=0.000089 Angle_129=0.000089 Angle_130=0.000089 Angle_131=0.000089 Angle_132=0.000089 Angle_133=0.000089 Angle_134=0.000089 Angle_135=0.000089 Angle_136=0.000089 Angle_137=0.000089 Angle_138=0.000089 Angle_139=0.000089 Angle_140=0.000089 Angle_141=0.000089 Angle_142=0.000050 Angle_143=0.000050 Angle_144=0.000050 Angle_145=0.000050 Angle_146=0.000050 Angle_147=0.000050 Angle_148=0.000050 Angle_149=0.000050 Angle_150=0.000050 Angle_151=0.000050 Angle_152=0.000050 Angle_153=0.000050 Angle_154=0.000050 Angle_155=0.000050 Angle_156=0.000050 Angle_157=0.000050 Angle_158=0.000050 Angle_159=0.000050 Angle_160=0.000022 Angle_161=0.000022 Angle_162=0.000022 Angle_163=0.000022 Angle_164=0.000022 Angle_165=0.000022 Angle_166=0.000022 Angle_167=0.000022 Angle_168=0.000022 Angle_169=0.000022 Angle_170=0.000022 Angle_171=0.000022 Angle_172=0.000022 Angle_173=0.000022 Angle_174=0.000006 Angle_175=0.000006 Angle_176=0.000006 Angle_177=0.000006 Angle_178=0.000006 Angle_179=0.000006 Angle_0=0.000000 [iReg1] Name=nf/TRC/cutDepth Desc=Depth of cuts. InitialValue=-0.05 Persistent=1 Value=-0.05 [iReg2] Name=nf/TRC/materialTop Desc=Top of stock. InitialValue=0 Persistent=0 [iReg3] Name=nf/TRC/plungeRate Desc=Feed rate of a plunge move. InitialValue=15 Persistent=1 Value=15 [iReg4] Name=nf/TRC/safeZ Desc=Safe Z position. InitialValue=0.25 Persistent=1 Value=0.25 [iReg5] Name=nf/TRC/spinRpm Desc=RPM of the spindle. InitialValue=24000 Persistent=1 Value=24000 [iReg6] Name=nf/TRC/subAdd Desc=Subtract or remove material. InitialValue=-1 Persistent=0 [iReg7] Name=nf/TRC/totalDepth Desc=Total depth of cut. InitialValue=-0.1 Persistent=1 Value=-0.1 [iReg8] Name=SpindleAuto Desc=Set Spindle to Auto on startup InitialValue=2 Persistent=0 [iReg9] Name=MisterAuto Desc=Set Mister to Auto on startup InitialValue=2 Persistent=0 [iReg10] Name=SMOnOff Desc=Sets SM to last setting InitialValue=0 Persistent=1 Value=1 [iReg11] Name=ATCOnOff Desc=Sets ATC to last setting InitialValue=0 Persistent=1 Value=1 [iReg12] Name=TPOnOff Desc=Sets Table Probe to last setting InitialValue=0 Persistent=1 Value=0 [iReg13] Name=MachHmd Desc=Sets Machine Home Reg to 0 InitialValue=0 Persistent=0 [iReg14] Name=TKStdOnOff Desc=Sets TK Standard to Off InitialValue=0 Persistent=0 [iReg15] Name=TKOscOnOff Desc=Sets TK Oscilating to Off InitialValue=0 Persistent=0 [iReg16] Name=CamOnOff Desc=Sets Camera to Off InitialValue=0 Persistent=0 [iReg17] Name=DrillOnOff Desc=Sets Drill to Off InitialValue=0 Persistent=0 [iReg18] Name=LatheOnOff Desc=Sets Lathe to Off InitialValue=0 Persistent=0 [iReg19] Name=PUPUpDn Desc=Sets Pop Up Pins to Off InitialValue=0 Persistent=0 [iReg20] Name=ExtraDepth Desc=Extra Cut Depth InitialValue=0 Persistent=0 [iReg21] Name=ProjHmPos Desc=Sets Project Home Position to 1 on startup InitialValue=1 Persistent=0 [iReg22] Name=ProjHm1Set Desc=Sets Project Home 1 Set to 0 InitialValue=0 Persistent=0 [iReg23] Name=SurfSet Desc=Sets Surface Set to 0 InitialValue=0 Persistent=0 [iReg24] Name=MistWasOn Desc=If mister was on for atc operations InitialValue=0 Persistent=0 [iReg25] Name=SpinWasOn Desc=If spindle was on for atc operations InitialValue=0 Persistent=0 [iReg26] Name=RunningTime Desc=Time Machine Running Last Run InitialValue=0 Persistent=1 Value=104.154 [iReg27] Name=MaxDepth Desc=Max Depth to Cut InitialValue=0 Persistent=1 Value=-22 [iReg28] Name=MaxDepthOnOff Desc=Sets Max Depth On or Off InitialValue=0 Persistent=0 [iReg29] Name=DustOnOff Desc=Sets Dust Collector to Off InitialValue=0 Persistent=0 [iReg30] Name=VacOnOff Desc=Sets Vacuum Table to Off InitialValue=0 Persistent=0 [iReg31] Name=ProjHm1X Desc=Project Home #1 X Value InitialValue=0 Persistent=0 [iReg32] Name=ProjHm1Y Desc=Project Home #1 Y Value InitialValue=0 Persistent=0 [iReg33] Name=ProjHm2X Desc=Project Home #2 X Value InitialValue=0 Persistent=0 [iReg34] Name=ProjHm2Y Desc=Project Home #2 Y Value InitialValue=0 Persistent=0 [iReg35] Name=MaintTime Desc=Acumulated time for maintinance InitialValue=0 Persistent=1 Value=70322.426 [iReg36] Name=ProjHm2Set Desc=Sets Project Home 2 Set to 0 InitialValue=0 Persistent=0 [iReg37] Name=ManToolChg Desc=Manual Tool Change set to 0 InitialValue=0 Persistent=0 [iReg38] Name=ATCZClear Desc=ATC z clearance for toolholders InitialValue=-.25 Persistent=1 Value=-.5 [iReg39] Name=ATCZDown Desc=ATC z to grab and drop tools InitialValue=-3.5 Persistent=1 Value=-3.6727 [iReg40] Name=ATCYPos1 Desc=ATC distance to first tool holder from Mach Hm InitialValue=6.0 Persistent=1 Value=4.4039 [iReg41] Name=ATCYPosDist Desc=ATC distance between tool holders InitialValue=13.0 Persistent=1 Value=13.515 [iReg42] Name=ATCMaxTools Desc=ATC maximum number of tools InitialValue=6 Persistent=1 Value=6 [iReg43] Name=SpindleType Desc=0 = porter 1=colombo 2=atc InitialValue=2 Persistent=1 Value=2 [iReg44] Name=SpinCool Desc=Spindle cool on manually InitialValue=0 Persistent=0 [iReg45] Name=CamShiftX Desc=Shift X distance from spindle to camera InitialValue=1 Persistent=1 Value=-0.385 [iReg46] Name=CamShiftY Desc=Shift Y distance from spindle to camera InitialValue=6 Persistent=1 Value=8.755 [iReg47] Name=TKSShiftX Desc=Shift X distance from spindle to TK Standard InitialValue=2 Persistent=1 Value=-0.47 [iReg48] Name=TKSShiftY Desc=Shift Y distance from spindle to TK Standard InitialValue=5 Persistent=1 Value=-5.79 [iReg49] Name=TKOShiftX Desc=Shift X distance from spindle to TK Oscillating InitialValue=2 Persistent=1 Value=-0.47 [iReg50] Name=TKOShiftY Desc=Shift Y distance from spindle to TK Oscillating InitialValue=8 Persistent=1 Value=-8.39 [iReg51] Name=TKSHomePos Desc=TK Standard home distance from limit InitialValue=180 Persistent=1 Value=186 [iReg52] Name=TKOHomePos Desc=TK Oscillating home distance from limit InitialValue=180 Persistent=1 Value=184.5 [iReg53] Name=MachType Desc=0=kr, 1=xp, 2=xps InitialValue=2 Persistent=1 Value=2 [iReg54] Name=TKOsc Desc=TK Oscillating on manually InitialValue=0 Persistent=0 [iReg55] Name=ATCToolHolder Desc=Holds last ATC tool # when using 100, 101, 102 Persistent=1 Value=1 [iReg56] Name=TKOnOff Desc=Indicates if TK should be on or off InitialValue=0 Persistent=0 [iReg57] Name=Temp1 Desc=Temp number InitialValue=0 Persistent=0 [iReg58] Name=SheetOnOff Desc=Turns Sheetloader on or off InitialValue=0 Persistent=1 Value=0 [iReg59] Name=CamCount Desc=Counts M111 calls for dots etc InitialValue=0 Persistent=0 [iReg60] Name=CamPixels Desc=Pixels per inch - set from Cam Inches InitialValue=0 Persistent=0 [iReg61] Name=CamInches Desc=View of Camera - sets Cam Pixels InitialValue=2.0 Persistent=1 Value=1.542 [iReg62] Name=XScaleAmount Desc=X Scale amount for camera InitialValue=1.0 Persistent=0 [iReg63] Name=YScaleAmount Desc=Y Scale amount for camera InitialValue=1.0 Persistent=0 [iReg64] Name=Rotation Desc=Rotation amount for camera InitialValue=0 Persistent=0 [iReg65] Name=MaxDepth2 Desc=Max Depth Temp InitialValue=-22.0 Persistent=0 [iReg66] Name=Alt Desc=Input for keypad Alt InitialValue=0 Persistent=0 [iReg67] Name=ModGrp13 InitialValue=11 Persistent=1 Value=97 [iReg68] Name=Setup Desc=Set to 1 to setup tk and cam distances InitialValue=0 Persistent=0 [iReg69] Name=FileType Desc=0=All 1=CNC 2=Tap 3=Txt InitialValue=1 Persistent=1 Value=0 [ModubusDaigWin] aot=0 x=383 y=164 w=600 h=400 [ModbusDevices] Dev0=Camera [ESS] BoardIpAddr=10.9.9.9 MotionBufferSize=0.18 PluginFrequency=40 ShowHWVelocityFifoErrorWindow=1 ShowSWVelocityFifoErrors=0 ChargePumpRunsInEStop=1 iDisableExpansionPortWithDisable=1 EnableAdvancedLogging=0 Motor-0-Mode=Step/Dir Motor-%d-FeedRateSmoothing=0.100 Motor-1-Mode=Step/Dir Motor-2-Mode=Step/Dir Motor-3-Mode=Step/Dir Motor-4-Mode=Step/Dir Motor-5-Mode=Step/Dir iEnableXCompensation=0 iXCompensationXStepOffsetWindow=10 UseAntiClunk=0 Spindle-Mode=Relay SpindlePwmFrequency=1000.00 SpindleStepPulseWidth=4.00 iSpindleSSMotorNumber=5 RPMSourceSpindleIndex=1 PwmDutyCycleZeroAtMinRPM=0 iReportSpindleRPM=1 UseSpindlePID=0 UsePidWhileThreading=0 CreatePidLogFile=0 SpindlePID_Kp=0.0000100 SpindlePID_Ki=0.0000000 SpindlePID_Kd=0.0000000 IndexPulsesPerRev=1.0000000 EncoderPrescaler=1 d_SpindleRpmAveraging=1.000 iUseSpindlePidRpmFloor=0 dPidRpmFloorPercentage=0.950 iUseSpindlePidRpmCeiling=0 dPidRpmCeilingPercentage=1.200 PermitLaserTestMode=0 dLaserTestModePowerLevel=15.10 Use5kHzTickle=0 LaserPwmFrequencyMax=20000 LaserAllowsHigherHz=0 LaserOnOffOutputNumber=64 LaserPwmFrequencyRaster=1000.00 LaserGateDelayRaster=20.0000 LaserGateDurationRaster=80.0000 LaserPwmFrequencyVector=1000.00 LaserGateDelayVector=20.0000 LaserGateDurationVector=80.0000 i_LaserShowImage=1 LaserFlipImageVertically=1 LaserFlipImageHorizontally=0 LaserInvertImageIntensities=0 LaserCompsForAccelDistanceX=0 LaserSkipLaserStartWindow=0 LaserRasterEvenRowsOnly=0 iEnableLaserVectorSpeedComp=-1 dLaserVectorSpeedCompNoBurnPwmPercentage=0.00 iEnableLaserVectorSpeedCompNonLinear=1 iLaserRasterStartingCorner=1 Port2Pins2_9_Direction=Inputs Port3Pins2_9_Direction=Outputs Port1-Pin1-Alias={P1-1} Port1-Pin1-ActiveLow=0 Port1-Pin1-NoiseFilterValue=0.00 Port1-Pin1-OutputPinStopState=No Change Port1-Pin1-OutputPinFeedHoldState=No Change Port1-Pin2-Alias={P1-2} Port1-Pin2-ActiveLow=1 Port1-Pin2-NoiseFilterValue=0.00 Port1-Pin2-OutputPinStopState=No Change Port1-Pin2-OutputPinFeedHoldState=No Change Port1-Pin3-Alias={P1-3} Port1-Pin3-ActiveLow=1 Port1-Pin3-NoiseFilterValue=0.00 Port1-Pin3-OutputPinStopState=No Change Port1-Pin3-OutputPinFeedHoldState=No Change Port1-Pin4-Alias={P1-4} Port1-Pin4-ActiveLow=1 Port1-Pin4-NoiseFilterValue=0.00 Port1-Pin4-OutputPinStopState=No Change Port1-Pin4-OutputPinFeedHoldState=No Change Port1-Pin5-Alias={P1-5} Port1-Pin5-ActiveLow=1 Port1-Pin5-NoiseFilterValue=0.00 Port1-Pin5-OutputPinStopState=No Change Port1-Pin5-OutputPinFeedHoldState=No Change Port1-Pin6-Alias={P1-6} Port1-Pin6-ActiveLow=1 Port1-Pin6-NoiseFilterValue=0.00 Port1-Pin6-OutputPinStopState=No Change Port1-Pin6-OutputPinFeedHoldState=No Change Port1-Pin7-Alias={P1-7} Port1-Pin7-ActiveLow=1 Port1-Pin7-NoiseFilterValue=0.00 Port1-Pin7-OutputPinStopState=No Change Port1-Pin7-OutputPinFeedHoldState=No Change Port1-Pin8-Alias={P1-8} Port1-Pin8-ActiveLow=1 Port1-Pin8-NoiseFilterValue=0.00 Port1-Pin8-OutputPinStopState=No Change Port1-Pin8-OutputPinFeedHoldState=No Change Port1-Pin9-Alias={P1-9} Port1-Pin9-ActiveLow=1 Port1-Pin9-NoiseFilterValue=0.00 Port1-Pin9-OutputPinStopState=No Change Port1-Pin9-OutputPinFeedHoldState=No Change Port1-Pin10-Alias={P1-10} Port1-Pin10-ActiveLow=0 Port1-Pin10-NoiseFilterValue=0.00 Port1-Pin10-OutputPinStopState=----- Port1-Pin10-OutputPinFeedHoldState=----- Port1-Pin11-Alias={P1-11} Port1-Pin11-ActiveLow=1 Port1-Pin11-NoiseFilterValue=0.00 Port1-Pin11-OutputPinStopState=----- Port1-Pin11-OutputPinFeedHoldState=----- Port1-Pin12-Alias={P1-12} Port1-Pin12-ActiveLow=1 Port1-Pin12-NoiseFilterValue=0.00 Port1-Pin12-OutputPinStopState=----- Port1-Pin12-OutputPinFeedHoldState=----- Port1-Pin13-Alias={P1-13} Port1-Pin13-ActiveLow=1 Port1-Pin13-NoiseFilterValue=0.00 Port1-Pin13-OutputPinStopState=----- Port1-Pin13-OutputPinFeedHoldState=----- Port1-Pin14-Alias={P1-14} Port1-Pin14-ActiveLow=0 Port1-Pin14-NoiseFilterValue=0.00 Port1-Pin14-OutputPinStopState=No Change Port1-Pin14-OutputPinFeedHoldState=No Change Port1-Pin15-Alias={P1-15} Port1-Pin15-ActiveLow=0 Port1-Pin15-NoiseFilterValue=0.00 Port1-Pin15-OutputPinStopState=----- Port1-Pin15-OutputPinFeedHoldState=----- Port1-Pin16-Alias={P1-16} Port1-Pin16-ActiveLow=0 Port1-Pin16-NoiseFilterValue=0.00 Port1-Pin16-OutputPinStopState=No Change Port1-Pin16-OutputPinFeedHoldState=No Change Port1-Pin17-Alias={P1-17} Port1-Pin17-ActiveLow=0 Port1-Pin17-NoiseFilterValue=0.00 Port1-Pin17-OutputPinStopState=No Change Port1-Pin17-OutputPinFeedHoldState=No Change Port2-Pin1-Alias={P2-1} Port2-Pin1-ActiveLow=0 Port2-Pin1-NoiseFilterValue=0.00 Port2-Pin1-OutputPinStopState=No Change Port2-Pin1-OutputPinFeedHoldState=No Change Port2-Pin2-Alias={P2-2} Port2-Pin2-ActiveLow=0 Port2-Pin2-NoiseFilterValue=0.00 Port2-Pin2-OutputPinStopState=----- Port2-Pin2-OutputPinFeedHoldState=----- Port2-Pin3-Alias={P2-3} Port2-Pin3-ActiveLow=0 Port2-Pin3-NoiseFilterValue=0.00 Port2-Pin3-OutputPinStopState=----- Port2-Pin3-OutputPinFeedHoldState=----- Port2-Pin4-Alias={P2-4} Port2-Pin4-ActiveLow=0 Port2-Pin4-NoiseFilterValue=0.00 Port2-Pin4-OutputPinStopState=----- Port2-Pin4-OutputPinFeedHoldState=----- Port2-Pin5-Alias={P2-5} Port2-Pin5-ActiveLow=0 Port2-Pin5-NoiseFilterValue=0.00 Port2-Pin5-OutputPinStopState=----- Port2-Pin5-OutputPinFeedHoldState=----- Port2-Pin6-Alias={P2-6} Port2-Pin6-ActiveLow=0 Port2-Pin6-NoiseFilterValue=0.00 Port2-Pin6-OutputPinStopState=----- Port2-Pin6-OutputPinFeedHoldState=----- Port2-Pin7-Alias={P2-7} Port2-Pin7-ActiveLow=0 Port2-Pin7-NoiseFilterValue=0.00 Port2-Pin7-OutputPinStopState=----- Port2-Pin7-OutputPinFeedHoldState=----- Port2-Pin8-Alias={P2-8} Port2-Pin8-ActiveLow=0 Port2-Pin8-NoiseFilterValue=0.00 Port2-Pin8-OutputPinStopState=----- Port2-Pin8-OutputPinFeedHoldState=----- Port2-Pin9-Alias={P2-9} Port2-Pin9-ActiveLow=0 Port2-Pin9-NoiseFilterValue=0.00 Port2-Pin9-OutputPinStopState=----- Port2-Pin9-OutputPinFeedHoldState=----- Port2-Pin10-Alias={P2-10} Port2-Pin10-ActiveLow=0 Port2-Pin10-NoiseFilterValue=0.00 Port2-Pin10-OutputPinStopState=----- Port2-Pin10-OutputPinFeedHoldState=----- Port2-Pin11-Alias={P2-11} Port2-Pin11-ActiveLow=0 Port2-Pin11-NoiseFilterValue=0.00 Port2-Pin11-OutputPinStopState=----- Port2-Pin11-OutputPinFeedHoldState=----- Port2-Pin12-Alias={P2-12} Port2-Pin12-ActiveLow=0 Port2-Pin12-NoiseFilterValue=0.00 Port2-Pin12-OutputPinStopState=----- Port2-Pin12-OutputPinFeedHoldState=----- Port2-Pin13-Alias={P2-13} Port2-Pin13-ActiveLow=0 Port2-Pin13-NoiseFilterValue=0.00 Port2-Pin13-OutputPinStopState=----- Port2-Pin13-OutputPinFeedHoldState=----- Port2-Pin14-Alias={P2-14} Port2-Pin14-ActiveLow=0 Port2-Pin14-NoiseFilterValue=0.00 Port2-Pin14-OutputPinStopState=No Change Port2-Pin14-OutputPinFeedHoldState=No Change Port2-Pin15-Alias={P2-15} Port2-Pin15-ActiveLow=1 Port2-Pin15-NoiseFilterValue=0.00 Port2-Pin15-OutputPinStopState=----- Port2-Pin15-OutputPinFeedHoldState=----- Port2-Pin16-Alias={P2-16} Port2-Pin16-ActiveLow=0 Port2-Pin16-NoiseFilterValue=0.00 Port2-Pin16-OutputPinStopState=No Change Port2-Pin16-OutputPinFeedHoldState=No Change Port2-Pin17-Alias={P2-17} Port2-Pin17-ActiveLow=0 Port2-Pin17-NoiseFilterValue=0.00 Port2-Pin17-OutputPinStopState=No Change Port2-Pin17-OutputPinFeedHoldState=No Change Port3-Pin1-Alias={P3-1} Port3-Pin1-ActiveLow=0 Port3-Pin1-NoiseFilterValue=0.00 Port3-Pin1-OutputPinStopState=No Change Port3-Pin1-OutputPinFeedHoldState=No Change Port3-Pin2-Alias={P3-2} Port3-Pin2-ActiveLow=0 Port3-Pin2-NoiseFilterValue=0.00 Port3-Pin2-OutputPinStopState=No Change Port3-Pin2-OutputPinFeedHoldState=No Change Port3-Pin3-Alias={P3-3} Port3-Pin3-ActiveLow=0 Port3-Pin3-NoiseFilterValue=0.00 Port3-Pin3-OutputPinStopState=No Change Port3-Pin3-OutputPinFeedHoldState=No Change Port3-Pin4-Alias={P3-4} Port3-Pin4-ActiveLow=0 Port3-Pin4-NoiseFilterValue=0.00 Port3-Pin4-OutputPinStopState=No Change Port3-Pin4-OutputPinFeedHoldState=No Change Port3-Pin5-Alias={P3-5} Port3-Pin5-ActiveLow=0 Port3-Pin5-NoiseFilterValue=0.00 Port3-Pin5-OutputPinStopState=No Change Port3-Pin5-OutputPinFeedHoldState=No Change Port3-Pin6-Alias={P3-6} Port3-Pin6-ActiveLow=0 Port3-Pin6-NoiseFilterValue=0.00 Port3-Pin6-OutputPinStopState=No Change Port3-Pin6-OutputPinFeedHoldState=No Change Port3-Pin7-Alias={P3-7} Port3-Pin7-ActiveLow=0 Port3-Pin7-NoiseFilterValue=0.00 Port3-Pin7-OutputPinStopState=No Change Port3-Pin7-OutputPinFeedHoldState=No Change Port3-Pin8-Alias={P3-8} Port3-Pin8-ActiveLow=0 Port3-Pin8-NoiseFilterValue=0.00 Port3-Pin8-OutputPinStopState=No Change Port3-Pin8-OutputPinFeedHoldState=No Change Port3-Pin9-Alias={P3-9} Port3-Pin9-ActiveLow=0 Port3-Pin9-NoiseFilterValue=0.00 Port3-Pin9-OutputPinStopState=No Change Port3-Pin9-OutputPinFeedHoldState=No Change Port3-Pin10-Alias={P3-10} Port3-Pin10-ActiveLow=0 Port3-Pin10-NoiseFilterValue=0.00 Port3-Pin10-OutputPinStopState=----- Port3-Pin10-OutputPinFeedHoldState=----- Port3-Pin11-Alias={P3-11} Port3-Pin11-ActiveLow=0 Port3-Pin11-NoiseFilterValue=0.00 Port3-Pin11-OutputPinStopState=----- Port3-Pin11-OutputPinFeedHoldState=----- Port3-Pin12-Alias={P3-12} Port3-Pin12-ActiveLow=0 Port3-Pin12-NoiseFilterValue=0.00 Port3-Pin12-OutputPinStopState=----- Port3-Pin12-OutputPinFeedHoldState=----- Port3-Pin13-Alias={P3-13} Port3-Pin13-ActiveLow=0 Port3-Pin13-NoiseFilterValue=0.00 Port3-Pin13-OutputPinStopState=----- Port3-Pin13-OutputPinFeedHoldState=----- Port3-Pin14-Alias={P3-14} Port3-Pin14-ActiveLow=0 Port3-Pin14-NoiseFilterValue=0.00 Port3-Pin14-OutputPinStopState=No Change Port3-Pin14-OutputPinFeedHoldState=No Change Port3-Pin15-Alias={P3-15} Port3-Pin15-ActiveLow=0 Port3-Pin15-NoiseFilterValue=0.00 Port3-Pin15-OutputPinStopState=----- Port3-Pin15-OutputPinFeedHoldState=----- Port3-Pin16-Alias={P3-16} Port3-Pin16-ActiveLow=0 Port3-Pin16-NoiseFilterValue=0.00 Port3-Pin16-OutputPinStopState=No Change Port3-Pin16-OutputPinFeedHoldState=No Change Port3-Pin17-Alias={P3-17} Port3-Pin17-ActiveLow=0 Port3-Pin17-NoiseFilterValue=0.00 Port3-Pin17-OutputPinStopState=No Change Port3-Pin17-OutputPinFeedHoldState=No Change ISigMap-EStop-Enable=1 ISigMap-EStop={P1-10} ISigMap-Motor0-Home-Enable=1 ISigMap-Motor0-Home={P1-11} ISigMap-Motor1-Home-Enable=1 ISigMap-Motor1-Home={P1-12} ISigMap-Motor2-Home-Enable=1 ISigMap-Motor2-Home={P1-13} ISigMap-Motor3-Home-Enable=1 ISigMap-Motor3-Home={P2-15} ISigMap-Motor4-Home-Enable=0 ISigMap-Motor5-Home-Enable=0 ISigMap-Motor0-PosLimit-Enable=1 ISigMap-Motor0-PosLimit={P1-11} ISigMap-Motor1-PosLimit-Enable=1 ISigMap-Motor1-PosLimit={P1-12} ISigMap-Motor2-PosLimit-Enable=1 ISigMap-Motor2-PosLimit={P1-13} ISigMap-Motor3-PosLimit-Enable=0 ISigMap-Motor4-PosLimit-Enable=0 ISigMap-Motor5-PosLimit-Enable=0 ISigMap-Motor0-NegLimit-Enable=1 ISigMap-Motor0-NegLimit={P1-11} ISigMap-Motor1-NegLimit-Enable=1 ISigMap-Motor1-NegLimit={P1-12} ISigMap-Motor2-NegLimit-Enable=0 ISigMap-Motor3-NegLimit-Enable=0 ISigMap-Motor4-NegLimit-Enable=0 ISigMap-Motor5-NegLimit-Enable=0 ISigMap-Motor0-Index-Enable=0 ISigMap-Motor1-Index-Enable=0 ISigMap-Motor2-Index-Enable=0 ISigMap-Motor3-Index-Enable=0 ISigMap-Motor4-Index-Enable=0 ISigMap-Motor5-Index-Enable=0 ISigMap-Encoder0-PhaseA-Enable=0 ISigMap-Encoder0-PhaseB-Enable=0 ISigMap-Encoder1-PhaseA-Enable=0 ISigMap-Encoder1-PhaseB-Enable=0 ISigMap-Encoder2-PhaseA-Enable=0 ISigMap-Encoder2-PhaseB-Enable=0 ISigMap-Encoder3-PhaseA-Enable=0 ISigMap-Encoder3-PhaseB-Enable=0 ISigMap-Encoder4-PhaseA-Enable=0 ISigMap-Encoder4-PhaseB-Enable=0 ISigMap-Encoder5-PhaseA-Enable=0 ISigMap-Encoder5-PhaseB-Enable=0 ISigMap-AuxEncoder0-PhaseA-Enable=0 ISigMap-AuxEncoder0-PhaseB-Enable=0 ISigMap-AuxEncoder1-PhaseA-Enable=0 ISigMap-AuxEncoder1-PhaseB-Enable=0 ISigMap-AuxEncoder2-PhaseA-Enable=0 ISigMap-AuxEncoder2-PhaseB-Enable=0 ISigMap-SpindleEncoder-PhaseA-Enable=0 ISigMap-SpindleEncoder-PhaseB-Enable=0 ISigMap-Index-Enable=0 ISigMap-SpindleAtSpeed-Enable=0 ISigMap-SpindleAtZero-Enable=0 ISigMap-Probe-Enable=1 ISigMap-Probe={P1-15} ISigMap-Probe1-Enable=0 ISigMap-Probe2-Enable=0 ISigMap-Probe3-Enable=0 ISigMap-THCOn-Enable=0 ISigMap-THCUp-Enable=0 ISigMap-THCDown-Enable=0 ISigMap-JogInhibit-Enable=0 ISigMap-MotionInhibit-Enable=0 ISigMap-MpgInhibit-Enable=0 ISigMap-LimitOverride-Enable=0 ISigMap-NoWait-Enable=0 ISigMap-PathSelection-Enable=0 ISigMap-PathSelection2-Enable=0 ISigMap-ToolGroupReset-Enable=0 ISigMap-ToolLifeOverride-Enable=0 ISigMap-ToolRetract-Enable=0 ISigMap-ToolSkip-Enable=0 ISigMap-UserInterrupt-Enable=0 ISigMap-JogX-Pos-Enable=0 ISigMap-JogX-Neg-Enable=0 ISigMap-JogY-Pos-Enable=0 ISigMap-JogY-Neg-Enable=0 ISigMap-JogZ-Pos-Enable=0 ISigMap-JogZ-Neg-Enable=0 ISigMap-JogA-Pos-Enable=0 ISigMap-JogA-Neg-Enable=0 ISigMap-JogB-Pos-Enable=0 ISigMap-JogB-Neg-Enable=0 ISigMap-JogC-Pos-Enable=0 ISigMap-JogC-Neg-Enable=0 ISigMap-JogOB1_Pos-Enable=0 ISigMap-JogOB1_Neg-Enable=0 ISigMap-JogOB2_Pos-Enable=0 ISigMap-JogOB2_Neg-Enable=0 ISigMap-JogOB3_Pos-Enable=0 ISigMap-JogOB3_Neg-Enable=0 ISigMap-JogOB4_Pos-Enable=0 ISigMap-JogOB4_Neg-Enable=0 ISigMap-JogOB5_Pos-Enable=0 ISigMap-JogOB5_Neg-Enable=0 ISigMap-JogOB6_Pos-Enable=0 ISigMap-JogOB6_Neg-Enable=0 ISigMap-Input0-Enable=0 ISigMap-Input1-Enable=0 ISigMap-Input2-Enable=0 ISigMap-Input3-Enable=0 ISigMap-Input4-Enable=0 ISigMap-Input5-Enable=0 ISigMap-Input6-Enable=0 ISigMap-Input7-Enable=0 ISigMap-Input8-Enable=0 ISigMap-Input9-Enable=0 ISigMap-Input10-Enable=0 ISigMap-Input11-Enable=0 ISigMap-Input12-Enable=0 ISigMap-Input13-Enable=0 ISigMap-Input14-Enable=0 ISigMap-Input15-Enable=0 ISigMap-Input16-Enable=0 ISigMap-Input17-Enable=0 ISigMap-Input18-Enable=0 ISigMap-Input19-Enable=0 ISigMap-Input20-Enable=0 ISigMap-Input21-Enable=0 ISigMap-Input22-Enable=0 ISigMap-Input23-Enable=0 ISigMap-Input24-Enable=0 ISigMap-Input25-Enable=0 ISigMap-Input26-Enable=0 ISigMap-Input27-Enable=0 ISigMap-Input28-Enable=0 ISigMap-Input29-Enable=0 ISigMap-Input30-Enable=0 ISigMap-Input31-Enable=0 ISigMap-Input32-Enable=0 ISigMap-Input33-Enable=0 ISigMap-Input34-Enable=0 ISigMap-Input35-Enable=0 ISigMap-Input36-Enable=0 ISigMap-Input37-Enable=0 ISigMap-Input38-Enable=0 ISigMap-Input39-Enable=0 ISigMap-Input40-Enable=0 ISigMap-Input41-Enable=0 ISigMap-Input42-Enable=0 ISigMap-Input43-Enable=0 ISigMap-Input44-Enable=0 ISigMap-Input45-Enable=0 ISigMap-Input46-Enable=0 ISigMap-Input47-Enable=0 ISigMap-Input48-Enable=0 ISigMap-Input49-Enable=0 ISigMap-Input50-Enable=0 ISigMap-Input51-Enable=0 ISigMap-Input52-Enable=0 ISigMap-Input53-Enable=0 ISigMap-Input54-Enable=0 ISigMap-Input55-Enable=0 ISigMap-Input56-Enable=0 ISigMap-Input57-Enable=0 ISigMap-Input58-Enable=0 ISigMap-Input59-Enable=0 ISigMap-Input60-Enable=0 ISigMap-Input61-Enable=0 ISigMap-Input62-Enable=0 ISigMap-Input63-Enable=0 OSigMap-Motor0-Step-MappedPin0={P1-3} OSigMap-Motor0-Step-Enable=1 OSigMap-Motor0-Dir-MappedPin0={P1-2} OSigMap-Motor0-Dir-Enable=1 OSigMap-Motor1-Step-MappedPin0={P1-5} OSigMap-Motor1-Step-Enable=1 OSigMap-Motor1-Dir-MappedPin0={P1-4} OSigMap-Motor1-Dir-Enable=1 OSigMap-Motor2-Step-MappedPin0={P1-7} OSigMap-Motor2-Step-Enable=1 OSigMap-Motor2-Dir-MappedPin0={P1-6} OSigMap-Motor2-Dir-Enable=1 OSigMap-Motor3-Step-MappedPin0={P1-9} OSigMap-Motor3-Step-Enable=1 OSigMap-Motor3-Dir-MappedPin0={P1-8} OSigMap-Motor3-Dir-Enable=1 OSigMap-Motor4-Step-Enable=0 OSigMap-Motor4-Dir-Enable=0 OSigMap-Motor5-Step-Enable=0 OSigMap-Motor5-Dir-Enable=0 OSigMap-Enable0-Enable=0 OSigMap-Enable1-Enable=0 OSigMap-Enable2-Enable=0 OSigMap-Enable3-Enable=0 OSigMap-Enable4-Enable=0 OSigMap-Enable5-Enable=0 OSigMap-XYFeedRatePWM-Enable=0 OSigMap-LaserPWM-Enable=0 OSigMap-SpindleStepOrPWM-Enable=0 OSigMap-SpindleDirection-Enable=0 OSigMap-SpindleOn-MappedPin0={P1-1} OSigMap-SpindleOn-Enable=1 OSigMap-SpindleFwd-Enable=0 OSigMap-SpindleRev-Enable=0 OSigMap-Alarm-Enable=0 OSigMap-ChargePump-MappedPin0={P1-17} OSigMap-ChargePump-Enable=0 OSigMap-CoolantOn-Enable=0 OSigMap-MistOn-MappedPin0={P1-14} OSigMap-MistOn-Enable=1 OSigMap-CurrentHi-Low-Enable=0 OSigMap-CutRecovery-Enable=0 OSigMap-DigitizeTrigger-Enable=0 OSigMap-DistToGo-Enable=0 OSigMap-Dwell-Enable=0 OSigMap-FeedHold-Enable=0 OSigMap-FeedHoldDisabled-Enable=0 OSigMap-FeedRateOverride-Enable=0 OSigMap-FeedRateOverrideDisabled-Enable=0 OSigMap-GcodeRunning-Enable=0 OSigMap-IsMoving-Enable=0 OSigMap-JogCont-Enable=0 OSigMap-JogEnabled-Enable=0 OSigMap-JogInc-Enable=0 OSigMap-JogMPG-Enable=0 OSigMap-LimitOverride-Enable=0 OSigMap-MachineCoord-Enable=0 OSigMap-MachineEnabled-Enable=0 OSigMap-MachineIdle-Enable=0 OSigMap-MachineProbing-Enable=0 OSigMap-PartsFinished-Enable=0 OSigMap-RapidRateOverride-Enable=0 OSigMap-RetractSignal-Enable=0 OSigMap-BlockDelete-Enable=0 OSigMap-OptStop-Enable=0 OSigMap-ReverseRun-Enable=0 OSigMap-SingleBlock-Enable=0 OSigMap-SpindleRateOverride-Enable=0 OSigMap-SpindleRateOverrideDisabled-Enable=0 OSigMap-SoftlimitsOn-Enable=0 OSigMap-SpeedCheck-Enable=0 OSigMap-ToolpathMouseDown-Enable=0 OSigMap-ToolChange-Enable=0 OSigMap-ToolChangeB-Enable=0 OSigMap-WaitingOnToolSignal-Enable=0 OSigMap-X-PosLimit-Enable=0 OSigMap-X-NegLimit-Enable=0 OSigMap-X-Home-Enable=0 OSigMap-XHomed-Enable=0 OSigMap-Y-PosLimit-Enable=0 OSigMap-Y-NegLimit-Enable=0 OSigMap-Y-Home-Enable=0 OSigMap-YHomed-Enable=0 OSigMap-Z-PosLimit-Enable=0 OSigMap-Z-NegLimit-Enable=0 OSigMap-Z-Home-Enable=0 OSigMap-ZHomed-Enable=0 OSigMap-A-PosLimit-Enable=0 OSigMap-A-NegLimit-Enable=0 OSigMap-A-Home-Enable=0 OSigMap-AHomed-Enable=0 OSigMap-B-PosLimit-Enable=0 OSigMap-B-NegLimit-Enable=0 OSigMap-B-Home-Enable=0 OSigMap-BHomed-Enable=0 OSigMap-C-PosLimit-Enable=0 OSigMap-C-NegLimit-Enable=0 OSigMap-C-Home-Enable=0 OSigMap-CHomed-Enable=0 OSigMap-OB1_Homed-Enable=0 OSigMap-OB1_Home_Switch_Active-Enable=0 OSigMap-OB1_PosLimit_Switch_Active-Enable=0 OSigMap-OB1_NegLimit_Switch_Active-Enable=0 OSigMap-OB2_Homed-Enable=0 OSigMap-OB2_Home_Switch_Active-Enable=0 OSigMap-OB2_PosLimit_Switch_Active-Enable=0 OSigMap-OB2_NegLimit_Switch_Active-Enable=0 OSigMap-OB3_Homed-Enable=0 OSigMap-OB3_Home_Switch_Active-Enable=0 OSigMap-OB3_PosLimit_Switch_Active-Enable=0 OSigMap-OB3_NegLimit_Switch_Active-Enable=0 OSigMap-OB4_Homed-Enable=0 OSigMap-OB4_Home_Switch_Active-Enable=0 OSigMap-OB4_PosLimit_Switch_Active-Enable=0 OSigMap-OB4_NegLimit_Switch_Active-Enable=0 OSigMap-OB5_Homed-Enable=0 OSigMap-OB5_Home_Switch_Active-Enable=0 OSigMap-OB5_PosLimit_Switch_Active-Enable=0 OSigMap-OB5_NegLimit_Switch_Active-Enable=0 OSigMap-OB6_Homed-Enable=0 OSigMap-OB6_Home_Switch_Active-Enable=0 OSigMap-OB6_PosLimit_Switch_Active-Enable=0 OSigMap-OB6_NegLimit_Switch_Active-Enable=0 OSigMap-Output0-Enable=0 OSigMap-Output1-Enable=0 OSigMap-Output2-Enable=0 OSigMap-Output3-Enable=0 OSigMap-Output4-MappedPin0={P2-1} OSigMap-Output4-Enable=1 OSigMap-Output5-MappedPin0={P2-14} OSigMap-Output5-Enable=1 OSigMap-Output6-MappedPin0={P2-16} OSigMap-Output6-Enable=1 OSigMap-Output7-MappedPin0={P2-17} OSigMap-Output7-Enable=1 OSigMap-Output8-MappedPin0={P3-2} OSigMap-Output8-Enable=1 OSigMap-Output9-MappedPin0={P3-3} OSigMap-Output9-Enable=1 OSigMap-Output10-Enable=0 OSigMap-Output11-Enable=0 OSigMap-Output12-Enable=0 OSigMap-Output13-Enable=0 OSigMap-Output14-Enable=0 OSigMap-Output15-Enable=0 OSigMap-Output16-Enable=0 OSigMap-Output17-Enable=0 OSigMap-Output18-Enable=0 OSigMap-Output19-Enable=0 OSigMap-Output20-Enable=0 OSigMap-Output21-Enable=0 OSigMap-Output22-Enable=0 OSigMap-Output23-Enable=0 OSigMap-Output24-Enable=0 OSigMap-Output25-Enable=0 OSigMap-Output26-Enable=0 OSigMap-Output27-Enable=0 OSigMap-Output28-Enable=0 OSigMap-Output29-Enable=0 OSigMap-Output30-Enable=0 OSigMap-Output31-Enable=0 OSigMap-Output32-Enable=0 OSigMap-Output33-Enable=0 OSigMap-Output34-Enable=0 OSigMap-Output35-Enable=0 OSigMap-Output36-Enable=0 OSigMap-Output37-Enable=0 OSigMap-Output38-Enable=0 OSigMap-Output39-Enable=0 OSigMap-Output40-Enable=0 OSigMap-Output41-Enable=0 OSigMap-Output42-Enable=0 OSigMap-Output43-Enable=0 OSigMap-Output44-Enable=0 OSigMap-Output45-Enable=0 OSigMap-Output46-Enable=0 OSigMap-Output47-Enable=0 OSigMap-Output48-Enable=0 OSigMap-Output49-Enable=0 OSigMap-Output50-Enable=0 OSigMap-Output51-Enable=0 OSigMap-Output52-Enable=0 OSigMap-Output53-Enable=0 OSigMap-Output54-Enable=0 OSigMap-Output55-Enable=0 OSigMap-Output56-Enable=0 OSigMap-Output57-Enable=0 OSigMap-Output58-Enable=0 OSigMap-Output59-Enable=0 OSigMap-Output60-Enable=0 OSigMap-Output61-Enable=0 OSigMap-Output62-Enable=0 OSigMap-Output63-Enable=0 Homing-Motor-0-IndexHomingEnable=0 Homing-Motor-0-ApproachVelocity=100.0 Homing-Motor-0-BackoffVelocity=100.0 Homing-Motor-1-IndexHomingEnable=0 Homing-Motor-1-ApproachVelocity=100.0 Homing-Motor-1-BackoffVelocity=100.0 Homing-Motor-2-IndexHomingEnable=0 Homing-Motor-2-ApproachVelocity=20.0 Homing-Motor-2-BackoffVelocity=20.0 Homing-Motor-3-IndexHomingEnable=0 Homing-Motor-3-ApproachVelocity=10000.0 Homing-Motor-3-BackoffVelocity=10000.0 Homing-Motor-4-IndexHomingEnable=0 Homing-Motor-4-ApproachVelocity=1.0 Homing-Motor-4-BackoffVelocity=1.0 Homing-Motor-5-IndexHomingEnable=0 Homing-Motor-5-ApproachVelocity=1.0 Homing-Motor-5-BackoffVelocity=1.0 IgnoreOtherProbesWhileProbing=1 iHcMonitorCollisionDetectionProbe0=0 iHcMonitorCollisionDetectionProbe1=0 iHcMonitorCollisionDetectionProbe2=0 iHcMonitorCollisionDetectionProbe3=0 UseBacklashComp=0 ShowBacklashCompLogMessages=0 BacklashCompAffectsCalculations_0=1 BacklashCompUseCustomValue_0=0 BacklashCompCustomVelocity_0=10.0000 BacklashCompCustomAcceleration_0=1.0000 BacklashCompAffectsCalculations_1=1 BacklashCompUseCustomValue_1=0 BacklashCompCustomVelocity_1=10.0000 BacklashCompCustomAcceleration_1=1.0000 BacklashCompAffectsCalculations_2=1 BacklashCompUseCustomValue_2=0 BacklashCompCustomVelocity_2=10.0000 BacklashCompCustomAcceleration_2=1.0000 BacklashCompAffectsCalculations_3=1 BacklashCompUseCustomValue_3=0 BacklashCompCustomVelocity_3=10.0000 BacklashCompCustomAcceleration_3=1.0000 BacklashCompAffectsCalculations_4=1 BacklashCompUseCustomValue_4=0 BacklashCompCustomVelocity_4=10.0000 BacklashCompCustomAcceleration_4=1.0000 BacklashCompAffectsCalculations_5=1 BacklashCompUseCustomValue_5=0 BacklashCompCustomVelocity_5=10.0000 BacklashCompCustomAcceleration_5=1.0000 i_HC_ManualKeyInputSignalUp=9 i_HC_ManualKeyInputSignalDown=10 i_HC_ControlledManually=0 i_HC_ControlledByHardwareUpDownPins=0 i_HC_ControlledByHardwareTMC3in1=0 i_HC_UseTorchRelay=0 i_HC_TorchRelayOutputNumber=64 i_HC_SendHcToDroZAux=1 i_HC_DisplayDroZAux=0 i_HC_UseLimitSwitchInhibit=0 d_HC_LimitSwitchInhibitTimeAfterArcOkay=1.000 i_HC_LimitMode=0 i_HC_SaveMaxMinValuesOnMachExit=0 d_HC_LimitMax=1.2000 d_HC_LimitMin=-0.0100 d_HC_TorchPierceDelayTimeAfterArcOkay=0.000 i_HC_EnablePierceCountWarning=0 i_HC_PierceCountWarningValue=0 i_HC_UseXYVelocityPWM=0 i_HC_XYVelocityPWMOutputNumberForGate=64 ShowWarp9SplashScreen=1 i_HC_PierceCountCurrentValue=0 [TMC3in1] iLogDataFiles=0 PluginFrequency=10 DropDownTipVoltageDividerRatio=50_1 DropDownTipVoltageSource=Positive dTargetTipVolts=118.100 dTargetBandVolts=1.500 dLinearResponseBandVoltsAbove=25.100 dLinearResponseBandVoltsBelow=15.100 dOffsetVolts=0.001 iAD1DelayAfterArcOkayEnabled=0 dAD1DelayValueAfterArcOkay=1.600 iAD2M62M63Enabled=0 iAD3VelocityEnabled=0 dAD3VelocityPercentage=97.000 iVoltageAD_Enabled=0 iVoltageAD_ATV_BufferSize=800 dVoltageAD_PreconditionWindowPercent=4.000 dAD4VoltageThrottlingPercent=0.000 dVoltageAD5ATV_PercentAboveCurrentTipVolts=15.000 dVoltageAD6ATV_PercentBelowCurrentTipVolts=15.000
