panel = mcLuaPanelParent inst = mc.mcGetInstance() local wxForms = {} function wxForms.CreateCombobox(comboboxID, choices) local sizer = wx.wxBoxSizer(wx.wxHORIZONTAL) local cboSelector = wx.wxComboBox(panel, comboboxID, "", wx.wxDefaultPosition, wx.wxSize(285, 40), choices, wx.wxCB_READONLY) cboSelector:SetFont(wx.wxFont(16, wx.wxMODERN, wx.wxNORMAL, wx.wxNORMAL, 0, "Arial")) sizer:Add(cboSelector, 1, wx.wxALL + wx.wxGROW, 5) panel:SetSizer(sizer) sizer:SetSizeHints(panel) cboSelector:SetSelection(0) cboSelector:Connect(wx.wxEVT_COMMAND_COMBOBOX_SELECTED, function (event) local currSel = cboSelector:GetSelection() local comboBoxSelReg = mc.mcRegGetHandle(inst, "gRegs0/cboSelection") mc.mcRegSetValueLong(comboBoxSelReg, currSel) end) panel:Connect(wx.wxEVT_UPDATE_UI, function (event) local comboBoxSelReg = mc.mcRegGetHandle(inst, "gRegs0/cboSelection") local comboBoxSel = mc.mcRegGetValueLong(comboBoxSelReg) if comboBoxSel == 7777 then cboSelector:SetSelection(0) mc.mcRegSetValueLong(comboBoxSelReg, 0) end end) end function wxForms.CreateListBox() panel:SetSizeHints(wx.wxDefaultSize, wx.wxDefaultSize) gbSizer1 = wx.wxGridBagSizer(0, 0) gbSizer1:SetFlexibleDirection(wx.wxBOTH) gbSizer1:SetNonFlexibleGrowMode(wx.wxFLEX_GROWMODE_SPECIFIED) bSizer1 = wx.wxBoxSizer(wx.wxHORIZONTAL) listboxItems = {} listbox = wx.wxListBox(panel, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxSize(250, 250), listboxItems, 0) listbox:SetFont(wx.wxFont(14, wx.wxMODERN, wx.wxNORMAL, wx.wxNORMAL, 0, "Arial")) bSizer1:Add(listbox, 0, wx.wxALL + wx.wxEXPAND, 5) gbSizer1:Add(bSizer1, wx.wxGBPosition(0, 0), wx.wxGBSpan(1, 1), wx.wxALL, 5) bSizer9 = wx.wxBoxSizer(wx.wxVERTICAL) bSizer2 = wx.wxBoxSizer(wx.wxVERTICAL) btnMoveUp = wx.wxButton(panel, wx.wxID_ANY, "▲", wx.wxDefaultPosition, wx.wxDefaultSize, 0) bSizer2:Add(btnMoveUp, 0, wx.wxALL, 5) bSizer2:Add(0, 50, 1, wx.wxEXPAND, 5) bSizer9:Add(bSizer2, 0, wx.wxEXPAND, 5) bSizer3 = wx.wxBoxSizer(wx.wxVERTICAL) btnAdd = wx.wxButton(panel, wx.wxID_ANY, "Add", wx.wxDefaultPosition, wx.wxDefaultSize, 0) bSizer3:Add(btnAdd, 0, wx.wxALL, 5) bSizer9:Add(bSizer3, 0, wx.wxEXPAND, 5) bSizer5 = wx.wxBoxSizer(wx.wxVERTICAL) btnRemove = wx.wxButton(panel, wx.wxID_ANY, "Remove", wx.wxDefaultPosition, wx.wxDefaultSize, 0) bSizer5:Add(btnRemove, 0, wx.wxALL, 5) bSizer9:Add(bSizer5, 0, wx.wxEXPAND, 5) bSizer7 = wx.wxBoxSizer(wx.wxVERTICAL) bSizer7:Add(0, 50, 1, wx.wxEXPAND, 5) btnMoveDown = wx.wxButton(panel, wx.wxID_ANY, "▼", wx.wxDefaultPosition, wx.wxDefaultSize, 0) bSizer7:Add(btnMoveDown, 0, wx.wxALL, 5) bSizer9:Add(bSizer7, 0, wx.wxEXPAND, 5) gbSizer1:Add(bSizer9, wx.wxGBPosition(0, 1), wx.wxGBSpan(1, 1), wx.wxALIGN_CENTER + wx.wxALL, 5) panel:SetSizer(gbSizer1) panel:Layout() panel:Centre(wx.wxBOTH) btnAdd:Connect(wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) local comboBoxSelReg = mc.mcRegGetHandle(inst, "gRegs0/cboSelection") local comboBoxSel = mc.mcRegGetValueLong(comboBoxSelReg) listbox:Append(string.format("%.0f", comboBoxSel)) table.insert(listboxItems, comboBoxSel) end) btnRemove:Connect(wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) local currSel = listbox:GetSelection() if currSel >= 0 then listbox:Delete(currSel) else wx.wxMessageBox("No item selected from list", "Confirm", wx.wxOK) end end) btnMoveUp:Connect(wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) local currSel = listbox:GetSelection() local currStr = listbox:GetString(currSel) if currSel > 0 then local item = table.remove(listboxItems, currSel + 1) table.insert(listboxItems, currSel, item) listbox:Delete(currSel) listbox:InsertItems({currStr}, currSel - 1) listbox:SetSelection(currSel - 1) end end) btnMoveDown:Connect(wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) local currSel = listbox:GetSelection() local currStr = listbox:GetString(currSel) if currSel < listbox:GetCount() - 1 then local item = table.remove(listboxItems, currSel + 1) table.insert(listboxItems, currSel + 2, item) listbox:Delete(currSel) listbox:InsertItems({currStr}, currSel + 1) listbox:SetSelection(currSel + 1) end end) panel:Connect(wx.wxEVT_UPDATE_UI, function (event) local comboBoxSelReg = mc.mcRegGetHandle(inst, "gRegs0/cboSelection") local comboBoxSel = mc.mcRegGetValueLong(comboBoxSelReg) if comboBoxSel == 9999 then listbox:Set({}) mc.mcRegSetValueLong(comboBoxSelReg, 7777) end end) end return wxForms
