' Emco 8 station turret index' Version 1.0.2' (c) G. Waterworth 11/12/2007Sub Main()If IsLoading() then  ' do nowtElse  OldTurretPos=(GetOEMDRO(824))   'current tool position  NextTool=GetSelectedTool()      'tool to be indexed    'If OldTurretPos<>NextTool Then    ' new tool required    If NextTool<1 Or NextTool>8 Then 'valid tool check      Message("Next Tool out of range")      Exit Sub    End If    ActivateSignal(OUTPUT4)   'rotate Turret     '=== Index Tool ===    Select Case NextTool	Case 1		count=1	Case 2		count=3	Case 3		count=2	Case 4		count=6	Case 5		count=4	Case 6		count=12	Case 7		count=8	Case 8	  	count=9    End Select    thistool=OldTurretPos    While thistool<>count      sensors=0      While sensors=0        if IsActive(OEMTRIG1) then sensors=sensors+1        if IsActive(OEMTRIG2) then sensors=sensors+2        if IsActive(OEMTRIG3) then sensors=sensors+4        if IsActive(OEMTRIG4) then sensors=sensors+8      Wend      thistool=sensors    Wend    Code"G04 P50"    While Ismoving()    Wend      DeActivateSignal(OUTPUT4) 'stop turret rotation    SetCurrentTool(thistool)  'End IfEnd IfEnd Sub            'The actual timings are:-''opto		1	2	3	4'pin 		10	11	12	13'value	1	2	4	8'Tool 1	on	off	off	off'Tool 2	on	on	off	off'Tool 3	off	on	off	off'Tool 4	off	on	on	off'Tool 5	off	off	on	off'Tool 6	off	off	on	on'Tool 7	off	off	off   on'Tool 8	on	off	off	on
