Rem VBScript To touch off X Y ZIf GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faultyCode "(Probe plate is grounded, check connection and try again)"ElseFeedCurrent = GetOemDRO(818) 'Get the current settingsXCurrent = GetDro(0)YCurrent = GetDro(1)ZCurrent = GetDro(2)ToolDia  = GetOEMDro(105)ToolRad = ToolDia/2Code "G4 P1" 'Pause 1 second to give time to position probe plateCode "F4" 'slow feed rate to 4 ipmRem Probe XXNew = Xcurrent - 1 'move left 1 inchCode "G31 X" &XNewWhile IsMoving() 'wait for the move to finishWendSetDro(0,ToolRad)Code "G0 X0,5" 'rapid move back off plateRem Probe YYNew = YCurrent - 1Code "G31 Y" &YNewWhile IsMoving()WendSetDro(1,ToolRad)Code "G0 Y0,5" 'rapid move back off plateRem Probe ZZNew = ZCurrent - 1Code "G31 Y" &ZNewWhile IsMoving()WendSetDro(2,0)Code "G0 Z0.5"  'rapid move back off plateCode "F" &FeedCurrent 'restore starting feed rateEnd If 
