------------------------------------------------------------------------------ -- Name: Touch Off -- Author: B Price -- Modified by: CNCRP (03/25/2019) -- Created: 05/17/2016 -- Copyright: (c) 2016 Newfangled Solutions. All rights reserved. -- License: BSD license - This header can not be removed -- Thanks go to the following for helping with this project in one form or another. -- Brian Barker, Steve Murphree, Todd Monto, Jim Dingus, Rob Gaudette, T Lamontagne, Steve Stallings, Chris Buchanan, J Thacher ------------------------------------------------------------------------------ local mcTouchOff = {} inst = mc.mcGetInstance() local ToffPlateWidth = 2.205 -- Inside width of CRP Touch Plate local ToffWallThickness = 0.3125 -- Wall thickness of CRP Touch Plate -- Get current mode and feed rate so we can set them back at the end of each function or after an error. function GetPreState() m_CurFeed = mc.mcCntlGetPoundVar(inst, mc.SV_FEEDRATE) --Feed rate m_CurAbsMode = mc.mcCntlGetPoundVar(inst, mc.SV_MOD_GROUP_3) --G90, G91 end --------------------- Get the values from the ini. DO NOT EDIT THESE VALUES HERE!!! ---------------------------- function ReadIni() ToffProbeRate = mc.mcProfileGetString(inst, 'ToffParams', 'ToffProbeRate', '5.0000') -- Get the Value from the profile ini. If none exist use 5.0000 ToffProbeRate = math.abs (ToffProbeRate) --Make sure value is unsigned ToffRetractDistance = mc.mcProfileGetString(inst, 'ToffParams', 'ToffRetractDistance', '.1000') -- Get the Value from the profile ini. If none exist use .1000 ToffRetractDistance = math.abs (tonumber(ToffRetractDistance)) --Make sure value is unsigned ToffPrepRate = mc.mcProfileGetString(inst, 'ToffParams', 'ToffPrepRate', '60.0000') -- Get the Value from the profile ini. If none exist use 60.000 ToffPrepRate = math.abs (ToffPrepRate) --Make sure value is unsigned ToffPrepDistance = mc.mcProfileGetString(inst, 'ToffParams', 'ToffPrepDistance', '0.5000') -- Get the Value from the profile ini. If none exist use 0.5000 ToffPrepDistance = math.abs (ToffPrepDistance) --Make sure value is unsigned ToffPlate = mc.mcProfileGetString(inst, 'ToffParams', 'ToffPlate', '.2500') -- Get the Value from the profile ini. If none exist use .2500 ToffPlate = math.abs (ToffPlate) --Make sure value is unsigned ToffToolDiam = mc.mcProfileGetString(inst, 'ToffParams', 'ToffToolDiam', '.5000') -- Get the Value from the profile ini. If none exist use .5000 ToffToolDiam = math.abs (ToffToolDiam) --Make sure value is unsigned ToffToolRadius = (ToffToolDiam /2) ToffCornerOption = mc.mcProfileGetString(inst, 'ToffParams', 'ToffCornerOption', '0'); -- Get the Value from the profile ini. If none exist use 0 ToffCornerOption = math.abs (ToffCornerOption) --Make sure value is unsigned ToffCenterOption = mc.mcProfileGetString(inst, 'ToffParams', 'ToffCenterOption', '0'); -- Get the Value from the profile ini. If none exist use 0 ToffCenterOption = math.abs (ToffCenterOption) --Make sure value is unsigned ToffProbeCode = mc.mcProfileGetString(inst, 'ToffParams', 'ToffProbeCode', '31'); -- Get the Value from the profile ini. If none exist use 31 ToffProbeCode = math.abs (ToffProbeCode) --Make sure value is unsigned end ----------- Check Probe State ----------- --We can use this function to return the current state CheckProbe() --or check it for active CheckProbe(1) --or check it for inactive CheckProbe(0) function CheckProbe(state) ----- Select probe signal depending on probe code selected ProbeSig = mc.ISIG_PROBE --Default probe signal, G31 if ToffProbeCode == 31.1 then ProbeSig = mc.ISIG_PROBE1 elseif ToffProbeCode == 31.2 then ProbeSig = mc.ISIG_PROBE2 elseif ToffProbeCode == 31.3 then ProbeSig = mc.ISIG_PROBE3 end local check = true --Default value of check local hsig = mc.mcSignalGetHandle(inst, ProbeSig) local ProbeState = mc.mcSignalGetState(hsig) local errmsg = 'ERROR: No contact with probe' --Default error message if (ProbeState == 1) then --Change the error message errmsg = 'ERROR: Unexpected probe touch' end if (state == nil) then --We did not specify the value of the state parameter so lets return ProbeState if (ProbeState == 1) then return (true); else return (false); end end if (ProbeState ~= state) then --CheckProbe failed mc.mcCntlSetLastError(inst, errmsg) mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back wx.wxMilliSleep(20) check = false m_CheckProbe = false mc.mcCntlEStop(inst) end wx.wxMilliSleep(20) return check end --------- Get machine position -------------- function GetMachPos(Axis) if (Axis == 'X') then XMach = mc.mcAxisGetMachinePos(inst, mc.X_AXIS) elseif (Axis == 'Y') then YMach = mc.mcAxisGetMachinePos(inst, mc.Y_AXIS) elseif (Axis == 'Z') then ZMach = mc.mcAxisGetMachinePos(inst, mc.Z_AXIS) end end --------- Go to machine position ------------- --This will move the axis to the position that was got using the GetMachPos function. function ToMachPos(Axis) mc.mcCntlSetLastError(inst, string.format(Axis .. ' axis is moving to a requested machine position.')) -- Tell the operator the axis is moving to a machine position. if (Axis == 'X') then Code(string.format('G90 G53 X ' .. XMach .. 'F ' .. ToffPrepRate)) elseif (Axis == 'Y') then Code(string.format('G90 G53 Y ' .. YMach .. 'F ' .. ToffPrepRate)) elseif (Axis == 'Z') then Code(string.format('G90 G53 Z ' .. ZMach .. 'F ' .. ToffPrepRate)) end end ------------- Get Fixture Offset Values ----------- function GetFixOffsetValues() XVar, YVar, ZVar = GetFixOffsetVars() --Get the fixture offset pound variables. XSet = mc.mcCntlGetPoundVar(inst, XVar) --Get the value of the # variable YSet = mc.mcCntlGetPoundVar(inst, YVar) --Get the value of the # variable ZSet = mc.mcCntlGetPoundVar(inst, ZVar) --Get the value of the # variable return XSet, YSet, ZSet end ---------- Get fixture offset pound variables function ------------- function GetFixOffsetVars() --Function GetFixOffsetVars() may also be in the ScreenLoad script local FixOffset = mc.mcCntlGetPoundVar(inst, mc.SV_MOD_GROUP_14) local Pval = mc.mcCntlGetPoundVar(inst, mc.SV_BUFP) local FixNum, whole, frac if (FixOffset ~= 54.1) then --G54 through G59 whole, frac = math.modf (FixOffset) FixNum = (whole - 53) PoundVarX = ((mc.SV_FIXTURES_START - mc.SV_FIXTURES_INC) + (FixNum * mc.SV_FIXTURES_INC)) CurrentFixture = string.format('G' .. tostring(FixOffset)) else --G54.1 P1 through G54.1 P100 FixNum = (Pval + 6) CurrentFixture = string.format('G54.1 P' .. tostring(Pval)) if (Pval > 0) and (Pval < 51) then -- G54.1 P1 through G54.1 P50 PoundVarX = ((mc.SV_FIXTURE_EXPAND - mc.SV_FIXTURES_INC) + (Pval * mc.SV_FIXTURES_INC)) elseif (Pval > 50) and (Pval < 101) then -- G54.1 P51 through G54.1 P100 PoundVarX = ((mc.SV_FIXTURE_EXPAND2 - mc.SV_FIXTURES_INC) + (Pval * mc.SV_FIXTURES_INC)) end end PoundVarY = (PoundVarX + 1) PoundVarZ = (PoundVarX + 2) return PoundVarX, PoundVarY, PoundVarZ, FixNum, CurrentFixture --PoundVar(Axis) returns the pound variable for the current fixture for that axis (not the pound variables value). --CurrentFixture returned as a string (examples G54, G59, G54.1 P12). --FixNum returns a simple number (1-106) for current fixture (examples G54 = 1, G59 = 6, G54.1 P1 = 7, etc). end ---------- Set Fixture Offset -------- function SetFixOffset(Axis, Direction, Level) if (Axis == 'X') and (Level == 1) then Pos = mc.mcAxisGetProbePos(inst, mc.X_AXIS, 1) OffsetVal = (((ToffWallThickness + ToffToolRadius) * Direction) + Pos) elseif (Axis == 'X') then Pos = mc.mcAxisGetProbePos(inst, mc.X_AXIS, 1) OffsetVal = ((-1 * (ToffPlateWidth - ToffToolRadius) * Direction) + Pos) elseif (Axis == 'Y') and (Level == 1) then Pos = mc.mcAxisGetProbePos(inst, mc.Y_AXIS, 1) OffsetVal = (((ToffWallThickness + ToffToolRadius) * Direction) + Pos) elseif (Axis == 'Y') then Pos = mc.mcAxisGetProbePos(inst, mc.Y_AXIS, 1) OffsetVal = ((-1 * (ToffPlateWidth - ToffToolRadius) * Direction) + Pos) elseif (Axis == 'Z') then Pos = mc.mcAxisGetProbePos(inst, mc.Z_AXIS, 1) OffsetVal = ((ToffPlate * Direction) + Pos) end XVar, YVar, ZVar, FixNum, CurrentFixture = GetFixOffsetVars() -- Get the fixture offset pound variables. Function GetFixOffsetVars() may also be in the ScreenLoad script if (Axis == 'X') then mc.mcCntlSetPoundVar(inst, XVar, OffsetVal) --Code(string.format('G10 L2 P' .. CurrentFixture .. 'X' .. OffsetVal), true) elseif (Axis == 'Y') then mc.mcCntlSetPoundVar(inst, YVar, OffsetVal) elseif (Axis == 'Z') then mc.mcCntlSetPoundVar(inst, ZVar, OffsetVal) end mc.mcCntlSetLastError(inst, string.format(Axis .. ' Axis Offset Set to: ' .. OffsetVal .. '.')) -- Tell the operator what we set the offset to end ------------- Code ----------- -- This function condenses the way you can execute Gcode and will pause processing until the Gcode is finished being executed. -- See the function frameMainOnUpdateUI() for other essential bits that allows this to work. function Code(Gcode, ProbeActive) m_CheckProbe = false local rc = mc.mcCntlGcodeExecute(inst, Gcode) if (ProbeActive ~= true) then ProbeActive = false; end coroutine.yield(rc, ProbeActive) end ---------- Touch Off Function -------- function TouchOff(Axis, Direction) -- Get the values from the Touch Off Parameters and manipulate them for this function as needed here. local PrepDistance if (Axis == 'X' or Axis == 'Y') then --Sets the maximum distance a touch move will travel and the + or - direction. PrepDistance = (2 * Direction) elseif (Axis == 'Z') then PrepDistance = ((ToffPrepDistance + ToffToolDiam) * Direction) end mc.mcCntlSetLastError(inst, string.format(Axis .. ' axis is performing a touch move.')) -- Tell the operator the axis is doing a touch move Code(string.format('G91 G' .. ToffProbeCode .. ' ' .. Axis .. ' ' .. PrepDistance .. 'F' .. ToffProbeRate), true) -- Probe and make sure probe is active (true) when motion stops. end ------------- Touch Retract ----------- function TouchRetract(Axis, Direction, Level) -- added level arguement for CRP Touchplate multi axis probe sequences local TouchRetract if ( (Axis == 'X') or (Axis == 'Y') ) and ( Level == 1 ) then TouchRetract = ( (1.1025 - ToffToolRadius) * Direction) elseif (Axis == 'Z') and (Level == 1) then TouchRetract = (0.125 * Direction) elseif (Level == 3) then TouchRetract = (0.5 * Direction) else TouchRetract = (ToffRetractDistance * Direction) -- Retract distance for Z, set by user in GUI end mc.mcCntlSetLastError(inst, 'Retracting') Code(string.format('G91 G1 ' .. Axis .. ' ' .. TouchRetract .. 'F' .. ToffPrepRate)) -- Retract. This is the only move not done as a probe move because the probe will already be active. end ------------ Pause for user input (multi-axis probes only) ----------------- function TouchNextAxis(Axis) msg = "Orient the flutes in-line with the " .. Axis .. " Axis " ans = wx.wxMessageBox( msg, "Probe Next Axis", wx.wxOK + wx.wxCANCEL + wx.wxICON_EXCLAMATION ) if ans == wx.wxCANCEL then mc.mcCntlSetLastError(inst, "Probing sequence canceled" ) co = nil coroutine.yield() end end ------- Prep move function ----------------- -- Example syntax to use this function: PrepMove ('Z', -1, 3) -- This will give you a Z Axis (Z, needs to be in quotes) move in the negative direction (-1, 1 would be positive) the distance defined by Level 3 (3) -- You can edit the way this function works by altering Levels or adding your own function PrepMove(Axis, Direction, Level) --, Multiplier) -- Get the values from the Touch Off Parameters and manipulate them for this function as needed here. local PrepDistance = ToffPrepDistance local RetractDistance = ToffRetractDistance local TouchPlate = ToffPlate if Level == 0 then PrepDistance = RetractDistance elseif Level == 1 then PrepDistance = (RetractDistance * 2) elseif Level == 2 then PrepDistance = PrepDistance elseif Level == 3 then PrepDistance = (PrepDistance + RetractDistance + TouchPlate) elseif Level == 4 then -- used for Z on multi axis probe if Z retracted full RetractDistance PrepDistance = (RetractDistance - 0.125) elseif Level == 5 then PrepDistance = 0.375 end -- Set Direction if Direction < 1 then PrepDistance = (PrepDistance * -1) end mc.mcCntlSetLastError(inst, string.format(Axis .. ' axis is performing a Level ' .. Level .. ' prep move.')) -- Tell the operator the axis is doing a touch move Code(string.format('G91 G' .. ToffProbeCode .. ' ' .. Axis .. ' ' .. PrepDistance .. 'F' .. ToffPrepRate)) -- Execute a probe move as Gcode. The reason we do this as a probe move is an unexpected touch will stop motion. end ------------- Finish Move ----------- function FinishMove() mc.mcCntlSetLastError(inst, 'Moving to X0 Y0.') -- Tell the operator we are moving to X and Y zero. Code(string.format('G90 G' .. ToffProbeCode .. 'X0 Y0 F' .. ToffPrepRate)) -- Do a probe move to X0 Y0 at the prep rate end ------- Single Axis Touch Functions ---------- ------------------ X ------------------------- function TouchOffXPos0() --Left GetPreState() TouchOff('Z', -1) TouchRetract('Z', 1, 1) TouchNextAxis('X') TouchOff('X', 1) -- Do a touch move in the X positive direction SetFixOffset('X', 1, 1) TouchRetract('X', -1, 1) PrepMove('Z', 1, 0) -- Do a Level 3 prep move in the Z positive direction (Axis, Direction, Level) GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch is finished. X axis set to ' .. XSet) -- Tell the operator what we set the offset/s to. mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end function TouchOffXNeg0() --Right GetPreState() TouchOff('Z', -1) TouchRetract('Z', 1, 1) TouchNextAxis('X') TouchOff('X', -1) -- Do a touch move in the X negative direction SetFixOffset('X', -1, 1) TouchRetract('X', 1, 1) PrepMove('Z', 1, 0) -- Do a Level 3 prep move in the Z positive direction (Axis, Direction, Level) GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch is finished. X axis set to ' .. XSet) -- Tell the operator what we set the offset/s to. mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ------------------ Y ------------------------- function TouchOffYNeg0() --Top GetPreState() TouchOff('Z', -1) TouchRetract('Z', 1, 1) TouchNextAxis('Y') TouchOff('Y', -1) -- Do a touch move in the Y negative direction SetFixOffset('Y', -1, 1) TouchRetract('Y', 1, 1) PrepMove('Z', 1, 0) -- Do a Level 3 prep move in the Z positive direction (Axis, Direction, Level) GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch is finished. Y axis set to ' .. YSet) -- Tell the operator what we set the offset/s to. mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end function TouchOffYPos0() --Bottom GetPreState() TouchOff('Z', -1) TouchRetract('Z', 1, 1) TouchNextAxis('Y') TouchOff('Y', 1) -- Do a touch move in the Y positive direction SetFixOffset('Y', 1, 1) TouchRetract('Y', -1, 1) PrepMove('Z', 1, 0) -- Do a Level 3 prep move in the Z positive direction (Axis, Direction, Level) GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch is finished. Y axis set to ' .. YSet) -- Tell the operator what we set the offset/s to. mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ------------------ Z ------------------------- function TouchOffZNeg0() --Set work zero to material top GetPreState() TouchOff('Z', -1) -- Do a touch move in the Z negative direction SetFixOffset('Z', -1) TouchRetract('Z', 1) GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch is finished. Z axis set to ' .. ZSet) -- Tell the operator what we set the offset/s to. mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ------- Multi Axis Touch Functions ---------- ------------------ Top Left ------------------ function TouchZnegYnegXpos0() -- Top left Outside with Z GetPreState() -- So we can set them back when finished with this routine. TouchOff('Z', -1) -- Do a touch move in the Z negative direction SetFixOffset('Z', -1) --Set the fixture offset TouchRetract('Z', 1, 1) --Retract TouchNextAxis('Y') TouchOff('Y', -1) -- Do a touch move in the Y negative direction SetFixOffset('Y', -1) --Set the fixture offset TouchRetract('Y', 1, 1) --Retract TouchNextAxis('X') TouchOff('X', 1) -- Do a touch move in the X positive direction SetFixOffset('X', 1) --Set the fixture offset TouchRetract('X', -1, 1) --Retract PrepMove('Z', 1, 0) -- Do a Level 3 prep move in the Z positive direction (Axis, Direction, Level) GetFixOffsetValues() --For our message mc.mcCntlSetLastError(inst, 'Touch combination is finished. X axis set to ' .. XSet .. ' Y axis set to ' .. YSet .. ' Z axis set to ' .. ZSet) -- Tell the operator the touch combination function is finished and what all the fixture offsets were set to. mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ------------------ Top Right ------------------ function TouchZnegYnegXneg0() -- Top right Outside with Z GetPreState() TouchOff('Z', -1) SetFixOffset('Z', -1) TouchRetract('Z', 1, 1) TouchNextAxis('Y') TouchOff('Y', -1) SetFixOffset('Y', -1) TouchRetract('Y', 1, 1) TouchNextAxis('X') TouchOff('X', -1) SetFixOffset('X', -1) TouchRetract('X', 1, 1) PrepMove('Z', 1, 0) GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch combination is finished. X axis set to ' .. XSet .. ' Y axis set to ' .. YSet .. ' Z axis set to ' .. ZSet) -- Tell the operator the touch combination function is finished mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ------------------ Bottom Left ---------------- function TouchZnegYposXpos0() -- Bottom left Outside with Z GetPreState() TouchOff('Z', -1) SetFixOffset('Z', -1) TouchRetract('Z', 1, 1) TouchNextAxis('Y') TouchOff('Y', 1) SetFixOffset('Y', 1) TouchRetract('Y', -1, 1) TouchNextAxis('X') TouchOff('X', 1) SetFixOffset('X', 1) TouchRetract('X', -1, 1) PrepMove('Z', 1, 0) GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch combination is finished. X axis set to ' .. XSet .. ' Y axis set to ' .. YSet .. ' Z axis set to ' .. ZSet) -- Tell the operator the touch combination function is finished mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ------------------ Bottom Right --------------- function TouchZnegYposXneg0() -- Bottom right Outside with Z GetPreState() TouchOff('Z', -1) SetFixOffset('Z', -1) TouchRetract('Z', 1, 1) TouchNextAxis('Y') TouchOff('Y', 1) SetFixOffset('Y', 1) TouchRetract('Y', -1, 1) TouchNextAxis('X') TouchOff('X', -1) SetFixOffset('X', -1) TouchRetract('X', 1, 1) PrepMove('Z', 1, 0) GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch combination is finished. X axis set to ' .. XSet .. ' Y axis set to ' .. YSet .. ' Z axis set to ' .. ZSet) -- Tell the operator the touch combination function is finished mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ------------------ Center Touch Functions --------------------- function TouchCenter0() -- Center Inside No Z XVar, YVar, ZVar = GetFixOffsetVars() -- Get the fixture offset pound variables. Function GetFixOffsetVars() may also be in the ScreenLoad script GetPreState() GetMachPos('X') TouchOff('X', -1) -- Do a touch move in the X negative direction local Pos1 = mc.mcAxisGetProbePos(inst, mc.X_AXIS, 1) ToMachPos('X') TouchOff('X', 1) -- Do a touch move in the X positive direction local Pos2 = mc.mcAxisGetProbePos(inst, mc.X_AXIS, 1) ToMachPos('X') GetMachPos('Y') TouchOff('Y', -1) -- Do a touch move in the Y negative direction local Pos3 = mc.mcAxisGetProbePos(inst, mc.Y_AXIS, 1) ToMachPos('Y') TouchOff('Y', 1) -- Do a touch move in the Y positive direction local Pos4 = mc.mcAxisGetProbePos(inst, mc.Y_AXIS, 1) ToMachPos('Y') local XCenter = (Pos1 + Pos2) / 2 local YCenter = (Pos3 + Pos4) / 2 mc.mcCntlSetPoundVar(inst, XVar, XCenter) mc.mcCntlSetPoundVar(inst, YVar, YCenter) FinishMove() GetFixOffsetValues() mc.mcCntlSetLastError(inst, 'Touch combination is finished. X axis set to ' .. XSet .. ' Y axis set to ' .. YSet) -- Overwrite the message generated in the FinishMove function. mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ------------------ Angle Touch Function --------------------- function Angle0() GetPreState() Code(string.format('G69')) -- Cancel any previously set G68 angle. rc = UI.m_choiceMeasureAngle:GetSelection() --0 = X+, 1 = X-, 2 = Y+, 3 = Y- if (rc < 2) then TouchAxis = 'X' PrepAxis = 'Y' else TouchAxis = 'Y' PrepAxis = 'X' end if (rc == 0) or (rc == 2) then TouchDirection = 1 else TouchDirection = -1 end RetractDirection = TouchDirection * -1 GetMachPos((TouchAxis)) TouchOff((TouchAxis), (TouchDirection)) -- Do a touch move in the X positive direction local X1 = mc.mcAxisGetProbePos(inst, mc.X_AXIS, 1) --Last parameter is 1 for machine position 0 would get work position local Y1 = mc.mcAxisGetProbePos(inst, mc.Y_AXIS, 1) --Last parameter is 1 for machine position 0 would get work position ToMachPos(TouchAxis) mc.mcCntlSetLastError(inst, 'Moving to position for second touch.') Code(string.format('G91 G' .. ToffProbeCode .. PrepAxis .. ToffPrepDistance .. 'F' .. ToffPrepRate)) -- Probe GetMachPos((TouchAxis)) TouchOff((TouchAxis), (TouchDirection)) -- Do a touch move in the X positive direction local X2 = mc.mcAxisGetProbePos(inst, mc.X_AXIS, 1) local Y2 = mc.mcAxisGetProbePos(inst, mc.Y_AXIS, 1) ToMachPos(TouchAxis) --Subtract the start from the end point local xDelta = X2 - X1 local yDelta = Y2 - Y1 local angle = math.atan2 (yDelta, xDelta) angle = angle * 180 / math.pi if TouchAxis == 'X' then angle = angle - 90.0 end mc.mcCntlSetLastError(inst, 'Angle (G68) has been set to ' .. tostring(angle)) Code(string.format('G68 R' .. angle)) --Rotate coordinate system mc.mcCntlGcodeExecute(inst, string.format('G ' .. m_CurAbsMode .. '\nF ' .. m_CurFeed)) --Set mode and feed back end ReadIni() ------------------ Dialog --------------------- function mcTouchOff.Dialog() UI = {} -- create frameMain UI.frameMain = wx.wxFrame (wx.NULL, wx.wxID_ANY, "TouchOff UI", wx.wxDefaultPosition, wx.wxSize( 900,530 ), wx.wxCAPTION + wx.wxCLOSE_BOX + wx.wxRESIZE_BORDER ) UI.frameMain:SetSizeHints( wx.wxSize( 900,530 ), wx.wxDefaultSize ) UI.frameMain :SetBackgroundColour( wx.wxColour( 255, 255, 255 ) ) UI.m_menubar1 = wx.wxMenuBar( 0 ) UI.m_menuHelp = wx.wxMenu() UI.m_menuItemDocs = wx.wxMenuItem( UI.m_menuHelp, wx.wxID_ANY, "Docs", "", wx.wxITEM_NORMAL ) UI.m_menuHelp:Append( UI.m_menuItemDocs ) UI.m_menubar1:Append( UI.m_menuHelp, "Help" ) UI.frameMain:SetMenuBar( UI.m_menubar1 ) UI.bSizerFrame = wx.wxBoxSizer( wx.wxVERTICAL ) UI.fgSizerFrame = wx.wxFlexGridSizer( 0, 3, 0, 0 ) UI.fgSizerFrame:AddGrowableCol( 0 ) UI.fgSizerFrame:AddGrowableCol( 1 ) UI.fgSizerFrame:AddGrowableCol( 2 ) UI.fgSizerFrame:AddGrowableRow( 0 ) UI.fgSizerFrame:SetFlexibleDirection( wx.wxBOTH ) UI.fgSizerFrame:SetNonFlexibleGrowMode( wx.wxFLEX_GROWMODE_SPECIFIED ) UI.sbSizerSettings = wx.wxStaticBoxSizer( wx.wxStaticBox( UI.frameMain, wx.wxID_ANY, "Settings/Options" ), wx.wxHORIZONTAL ) UI.fgSizerSettings = wx.wxFlexGridSizer( 12, 2, 0, 0 ) UI.fgSizerSettings:AddGrowableCol( 0 ) UI.fgSizerSettings:AddGrowableCol( 1 ) UI.fgSizerSettings:AddGrowableRow( 0 ) UI.fgSizerSettings:AddGrowableRow( 1 ) UI.fgSizerSettings:AddGrowableRow( 2 ) UI.fgSizerSettings:AddGrowableRow( 3 ) UI.fgSizerSettings:AddGrowableRow( 4 ) UI.fgSizerSettings:AddGrowableRow( 5 ) UI.fgSizerSettings:AddGrowableRow( 6 ) UI.fgSizerSettings:AddGrowableRow( 7 ) UI.fgSizerSettings:AddGrowableRow( 8 ) UI.fgSizerSettings:AddGrowableRow( 9 ) UI.fgSizerSettings:AddGrowableRow( 10 ) UI.fgSizerSettings:AddGrowableRow( 11 ) UI.fgSizerSettings:SetFlexibleDirection( wx.wxBOTH ) UI.fgSizerSettings:SetNonFlexibleGrowMode( wx.wxFLEX_GROWMODE_SPECIFIED ) UI.m_staticTextProbeFeedRate = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Probe Feed Rate", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextProbeFeedRate:Wrap( -1 ) UI.m_staticTextProbeFeedRate:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextProbeFeedRate, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlProbeFeedRate = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_textCtrlProbeFeedRate:SetToolTip( "Probe Feed Rate is the rate (speed) the axes will move at during a probe move. This is typically very slow. Setting it too high could result in chipped tools, bent probes, etc. All machines are different and it is the operators responsibility to set this to something acceptable for their machine." ) UI.fgSizerSettings:Add( UI.m_textCtrlProbeFeedRate, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextRetractDistance = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Retract Distance", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextRetractDistance:Wrap( -1 ) UI.m_staticTextRetractDistance:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextRetractDistance, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlRetractDistance = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_textCtrlRetractDistance:SetToolTip( "Retract Distance is the distance the axis will retract after it touches." ) UI.fgSizerSettings:Add( UI.m_textCtrlRetractDistance, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextPrepFeedRate = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Prep. Feed Rate", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextPrepFeedRate:Wrap( -1 ) UI.m_staticTextPrepFeedRate:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextPrepFeedRate, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlPrepFeedRate = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_textCtrlPrepFeedRate:SetToolTip( "Prep. Feed Rate is the rate (speed) the axes will move at during a preparation move." ) UI.fgSizerSettings:Add( UI.m_textCtrlPrepFeedRate, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextPrepDistance = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Prep. Distance", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextPrepDistance:Wrap( -1 ) UI.m_staticTextPrepDistance:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextPrepDistance, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlPrepDistance = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_textCtrlPrepDistance:SetToolTip( "Prep. Distance is a variable that is used to calculate the distance axes will move in a preparation move. If a touch is detected in the preparation move you will get a \"ERROR: Unexpected probe touch\" error message in the status bar, motion will stop and Mach will be disabled." ) UI.fgSizerSettings:Add( UI.m_textCtrlPrepDistance, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextToolDiam = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Tool or Probe Diameter", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextToolDiam:Wrap( -1 ) UI.m_staticTextToolDiam:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextToolDiam, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlToolDiam = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_textCtrlToolDiam:SetToolTip( "Tool or Probe Diameter is the diameter of the tool or probe being used in the touch function." ) UI.fgSizerSettings:Add( UI.m_textCtrlToolDiam, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextTouchPlateHeight = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Touch Plate Height", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextTouchPlateHeight:Wrap( -1 ) UI.m_staticTextTouchPlateHeight:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextTouchPlateHeight, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlTouchPlateHeight = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_textCtrlTouchPlateHeight:SetToolTip( "Touch Plate Height is the thickness of the touch plate. A touch plate capable of setting more than one axis must be the same thickness on all planes it is capable of being used to set in a single function." ) UI.fgSizerSettings:Add( UI.m_textCtrlTouchPlateHeight, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextProbeCode = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Probe Code Options", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextProbeCode:Wrap( -1 ) UI.m_staticTextProbeCode:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextProbeCode, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_choiceProbeCodeChoices = { "G31 (Probe)", "G31.1 (Probe 1)", "G31.2 (Probe 2)", "G31.3 (Probe 3)" } UI.m_choiceProbeCode = wx.wxChoice( UI.frameMain, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxDefaultSize, UI.m_choiceProbeCodeChoices, 0 ) UI.m_choiceProbeCode:SetSelection( 0 ) UI.m_choiceProbeCode:SetToolTip( "Probe Code Options sets the option for the probe being used. \n\nProbe Code is the Gcode that will be executed when a touch function is used. This does not change the motion the machine will make during any function. It only changes which input the function is looking at to detect a touch. Mach4 has 4 probe inputs and the options are limited to those 4.\n\nG31 = Probe\nG31.1 = Probe 1\nG31.2 = Probe 2\nG31.3 = Probe 3" ) UI.fgSizerSettings:Add( UI.m_choiceProbeCode, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextCornerTouchOptions = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Corner Touch Options", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextCornerTouchOptions:Wrap( -1 ) UI.m_staticTextCornerTouchOptions:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextCornerTouchOptions, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_choiceCornerTouchChoices = { "Outside With Z" } UI.m_choiceCornerTouch = wx.wxChoice( UI.frameMain, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxDefaultSize, UI.m_choiceCornerTouchChoices, 0 ) UI.m_choiceCornerTouch:SetSelection( 0 ) UI.m_choiceCornerTouch:SetToolTip( "Corner Touch Options sets the option for a corner touch. \n\nOutside With Z description:\nJog to point where the tool or probe is just above the Z and close enough to the corner your touching that the Prep. Distance will get you past the edge of the part but not so far that when probing (Prep. Distance + Tool Diameter) it will not make contact with the probe." ) UI.fgSizerSettings:Add( UI.m_choiceCornerTouch, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextCenterTouchOptions = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Center Touch Options", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextCenterTouchOptions:Wrap( -1 ) UI.m_staticTextCenterTouchOptions:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.fgSizerSettings:Add( UI.m_staticTextCenterTouchOptions, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_choiceCenterTouchChoices = { "Inside No Z" } UI.m_choiceCenterTouch = wx.wxChoice( UI.frameMain, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxDefaultSize, UI.m_choiceCenterTouchChoices, 0 ) UI.m_choiceCenterTouch:SetSelection( 0 ) UI.m_choiceCenterTouch:SetToolTip( "Center Touch Options sets the options for a center touch. \n\nInside No Z description:\nJog to a point where the tool or probe is deep enough inside the bore, square or rectangle to touch four points. This will set the work coordinates to 0 at the center of the feature. This action does not provoke any Z axis movement and will not alter the fixture offset for the Z axis." ) UI.fgSizerSettings:Add( UI.m_choiceCenterTouch, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextMeasureAngleOptions = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Measure Angle Options", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextMeasureAngleOptions:Wrap( -1 ) UI.fgSizerSettings:Add( UI.m_staticTextMeasureAngleOptions, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_choiceMeasureAngleChoices = { "X++", "X--", "Y++", "Y--" } UI.m_choiceMeasureAngle = wx.wxChoice( UI.frameMain, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxDefaultSize, UI.m_choiceMeasureAngleChoices, 0 ) UI.m_choiceMeasureAngle:SetSelection( 0 ) UI.m_choiceMeasureAngle:SetToolTip( "Measure Angle Options sets the option for the axis and direction to probe in to find an angle and performs a G68 (which rotates the coordinate system)." ) UI.fgSizerSettings:Add( UI.m_choiceMeasureAngle, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextZOnlyOptions = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Z Only Options", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_RIGHT ) UI.m_staticTextZOnlyOptions:Wrap( -1 ) UI.fgSizerSettings:Add( UI.m_staticTextZOnlyOptions, 1, wx.wxALIGN_RIGHT + wx.wxALL + wx.wxEXPAND, 5 ) UI.m_choiceZOnlyChoices = { "Material Top", "Tool Length (TLO)" } UI.m_choiceZOnly = wx.wxChoice( UI.frameMain, wx.wxID_ANY, wx.wxDefaultPosition, wx.wxDefaultSize, UI.m_choiceZOnlyChoices, 0 ) UI.m_choiceZOnly:SetSelection( 0 ) UI.m_choiceZOnly:SetToolTip( "Z Only Options sets the option of what it is your trying to find the Z value for.\n\nMaterial Top:\nUsed to find the top of the material being machined. It sets the current fixtures Z work offset to 0.0000 (zero) at the top of the material.\n\nTool Length (TLO):\nWill set the length offset for the current tool. Make sure you have called the tool offset you want to set through MDI or Gcode before performing this function." ) UI.fgSizerSettings:Add( UI.m_choiceZOnly, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.sbSizerSettings:Add( UI.fgSizerSettings, 1, wx.wxALL + wx.wxEXPAND, 0 ) UI.fgSizerFrame:Add( UI.sbSizerSettings, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.sbSizerStatus = wx.wxStaticBoxSizer( wx.wxStaticBox( UI.frameMain, wx.wxID_ANY, "Status" ), wx.wxHORIZONTAL ) UI.fgSizerStatus = wx.wxFlexGridSizer( 6, 2, 10, 10 ) UI.fgSizerStatus:AddGrowableCol( 0 ) UI.fgSizerStatus:AddGrowableCol( 1 ) UI.fgSizerStatus:AddGrowableRow( 0 ) UI.fgSizerStatus:AddGrowableRow( 1 ) UI.fgSizerStatus:AddGrowableRow( 2 ) UI.fgSizerStatus:AddGrowableRow( 3 ) UI.fgSizerStatus:AddGrowableRow( 4 ) UI.fgSizerStatus:AddGrowableRow( 5 ) UI.fgSizerStatus:SetFlexibleDirection( wx.wxBOTH ) UI.fgSizerStatus:SetNonFlexibleGrowMode( wx.wxFLEX_GROWMODE_SPECIFIED ) UI.m_staticTextX = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "X", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_staticTextX:Wrap( -1 ) UI.m_staticTextX:SetFont( wx.wxFont( 24, 70, 90, 90, False, "" ) ) UI.fgSizerStatus:Add( UI.m_staticTextX, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlX = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "0.0000", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxTE_RIGHT ) UI.m_textCtrlX:SetFont( wx.wxFont( 18, 70, 90, 92, False, "" ) ) UI.fgSizerStatus:Add( UI.m_textCtrlX, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextY = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Y", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_staticTextY:Wrap( -1 ) UI.m_staticTextY:SetFont( wx.wxFont( 24, 70, 90, 90, False, "" ) ) UI.fgSizerStatus:Add( UI.m_staticTextY, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlY = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "0.0000", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxTE_RIGHT ) UI.m_textCtrlY:SetFont( wx.wxFont( 18, 70, 90, 92, False, "" ) ) UI.fgSizerStatus:Add( UI.m_textCtrlY, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_staticTextZ = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "Z", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_staticTextZ:Wrap( -1 ) UI.m_staticTextZ:SetFont( wx.wxFont( 24, 70, 90, 90, False, "" ) ) UI.fgSizerStatus:Add( UI.m_staticTextZ, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_textCtrlZ = wx.wxTextCtrl( UI.frameMain, wx.wxID_ANY, "0.0000", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxTE_RIGHT ) UI.m_textCtrlZ:SetFont( wx.wxFont( 18, 70, 90, 92, False, "" ) ) UI.fgSizerStatus:Add( UI.m_textCtrlZ, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.fgSizerStatus:Add( 0, 0, 1, wx.wxEXPAND, 5 ) UI.m_buttonMachineWork = wx.wxButton( UI.frameMain, wx.wxID_ANY, "Work/Machine Toggle\nCurrently Displaying\nWork Coordinates", wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_buttonMachineWork:SetFont( wx.wxFont( 12, 70, 90, 92, False, "" ) ) UI.m_buttonMachineWork:SetForegroundColour( wx.wxColour( 255, 255, 255 ) ) UI.m_buttonMachineWork:SetBackgroundColour( wx.wxColour( 0, 0, 0 ) ) UI.m_buttonMachineWork:SetToolTip( "Machine/Work Toggle. This toggle button selects which units are displayed in the TouchOff UI DROs. The options are Work or Machine. Each click will change the currently displayed units to the other. Choosing to display machine coordinates is not a retained setting. By default the TouchOff UI is opened each time displaying work coordinates." ) UI.fgSizerStatus:Add( UI.m_buttonMachineWork, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.fgSizerStatus:Add( 0, 0, 1, wx.wxALL, 5 ) UI.m_staticTextProbeStatus = wx.wxStaticText( UI.frameMain, wx.wxID_ANY, "\nSelected Probe Is\nCurrently Inactive", wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxALIGN_CENTRE + wx.wxST_NO_AUTORESIZE+wx.wxSUNKEN_BORDER ) UI.m_staticTextProbeStatus:Wrap( -1 ) UI.m_staticTextProbeStatus:SetFont( wx.wxFont( 12, 70, 90, 92, False, "" ) ) UI.m_staticTextProbeStatus:SetForegroundColour( wx.wxColour( 255, 255, 255 ) ) UI.m_staticTextProbeStatus:SetBackgroundColour( wx.wxColour( 0, 0, 0 ) ) UI.m_staticTextProbeStatus:SetToolTip( "This is an indicator for the current status (active or inactive) of the selected probe input." ) UI.fgSizerStatus:Add( UI.m_staticTextProbeStatus, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.sbSizerStatus:Add( UI.fgSizerStatus, 1, wx.wxALL + wx.wxEXPAND, 0 ) UI.fgSizerFrame:Add( UI.sbSizerStatus, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.sbSizerFunctions = wx.wxStaticBoxSizer( wx.wxStaticBox( UI.frameMain, wx.wxID_ANY, "Functions" ), wx.wxHORIZONTAL ) UI.fgSizerFunctions = wx.wxFlexGridSizer( 4, 3, 40, 40 ) UI.fgSizerFunctions:AddGrowableCol( 0 ) UI.fgSizerFunctions:AddGrowableCol( 1 ) UI.fgSizerFunctions:AddGrowableCol( 2 ) UI.fgSizerFunctions:AddGrowableRow( 0 ) UI.fgSizerFunctions:AddGrowableRow( 1 ) UI.fgSizerFunctions:AddGrowableRow( 2 ) UI.fgSizerFunctions:AddGrowableRow( 3 ) UI.fgSizerFunctions:SetFlexibleDirection( wx.wxBOTH ) UI.fgSizerFunctions:SetNonFlexibleGrowMode( wx.wxFLEX_GROWMODE_SPECIFIED ) UI.m_bpButtonTopLeft = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageTopLeft())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonTopLeft = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonTopLeft:SetToolTip( "Find top left corner:\n\nThis will find the top left corner. Corner touch options selection can modify the behavior." ) UI.fgSizerFunctions:Add( UI.m_bpButtonTopLeft, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonTop = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageTop())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonTop = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonTop:SetToolTip( "Find Y++:\n\nThis will find the Y positive edge. The probe move will be a Y-- move." ) UI.fgSizerFunctions:Add( UI.m_bpButtonTop, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonTopRight = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageTopRight())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonTopRight = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonTopRight:SetToolTip( "Find top right corner:\n\nThis will find the top right corner. Corner touch options selection can modify the behavior." ) UI.fgSizerFunctions:Add( UI.m_bpButtonTopRight, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonLeft = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageLeft())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonLeft = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonLeft:SetToolTip( "Find X--:\n\nThis will find the X negative edge. The probe move will be a X++ move." ) UI.fgSizerFunctions:Add( UI.m_bpButtonLeft, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonCenter = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageCenter())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonCenter = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonCenter:SetToolTip( "Find center:\n\nThis will find the center of a square, circle or rectangle. Center touch options selection can modify the behavior." ) UI.fgSizerFunctions:Add( UI.m_bpButtonCenter, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonRight = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageRight())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonRight = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonRight:SetToolTip( "Find X++:\n\nThis will find the X positive edge. The probe move will be a X-- move." ) UI.fgSizerFunctions:Add( UI.m_bpButtonRight, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonBottomLeft = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageBottomLeft())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonBottomLeft = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonBottomLeft:SetToolTip( "Find bottom left corner:\n\nThis will find the bottom left corner. Corner touch options selection can modify the behavior." ) UI.fgSizerFunctions:Add( UI.m_bpButtonBottomLeft, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonBottom = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageBottom())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonBottom = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonBottom:SetToolTip( "Find Y--:\n\nThis will find the Y negative edge. The probe move will be a Y++ move." ) UI.fgSizerFunctions:Add( UI.m_bpButtonBottom, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonBottomRight = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageBottomRight())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonBottomRight = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonBottomRight:SetToolTip( "Find bottom right corner:\n\nThis will find the bottom right corner. Corner touch options selection can modify the behavior." ) UI.fgSizerFunctions:Add( UI.m_bpButtonBottomRight, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonMeasureAngle = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageMeasureAngle())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonMeasureAngle = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonMeasureAngle:SetToolTip( "Find angle:\n\nThis will find the angle of an edge and rotate the coordinate system with a G68 by this amount. The measure angle option selection will dictate the direction of travel during a probe move." ) UI.fgSizerFunctions:Add( UI.m_bpButtonMeasureAngle, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bitmap1 = wx.wxStaticBitmap( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageCompass())), wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) --UI.m_bitmap1 = wx.wxStaticBitmap( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, 0 ) UI.m_bitmap1:SetToolTip( "This simply shows the direction an axis will be moving in to make a X or Y positive or negative move." ) UI.fgSizerFunctions:Add( UI.m_bitmap1, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.m_bpButtonZOnly = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, (wx.wxBitmap(ImageZOnly())), wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) --UI.m_bpButtonZOnly = wx.wxBitmapButton( UI.frameMain, wx.wxID_ANY, wx.wxNullBitmap, wx.wxDefaultPosition, wx.wxDefaultSize, wx.wxBU_AUTODRAW ) UI.m_bpButtonZOnly:SetToolTip( "Find Z:\n\nThis will only probe with the Z axis. The Z only option selection will dictate what is set using the probe contact position." ) UI.fgSizerFunctions:Add( UI.m_bpButtonZOnly, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.sbSizerFunctions:Add( UI.fgSizerFunctions, 1, wx.wxALL + wx.wxEXPAND, 0 ) UI.fgSizerFrame:Add( UI.sbSizerFunctions, 1, wx.wxALL + wx.wxEXPAND, 5 ) UI.bSizerFrame:Add( UI.fgSizerFrame, 1, wx.wxEXPAND, 0 ) UI.frameMain:SetSizer( UI.bSizerFrame ) UI.frameMain:Layout() UI.frameMain:Centre( wx.wxBOTH ) -- Connect Events UI.frameMain:Connect( wx.wxEVT_ACTIVATE, function(event) frameMainOnActivate() event:Skip() end ) UI.frameMain:Connect( wx.wxEVT_CLOSE_WINDOW, function(event) frameMainOnClose() end ) UI.frameMain:Connect( wx.wxEVT_UPDATE_UI, function(event) frameMainOnUpdateUI() event:Skip() end ) UI.frameMain:Connect( wx.wxID_ANY ,wx.wxEVT_COMMAND_MENU_SELECTED , function(event) m_menuItemDocsOnMenuSelection() --event:Skip() end ) UI.m_textCtrlProbeFeedRate:Connect( wx.wxEVT_KILL_FOCUS, function(event) m_textCtrlProbeFeedRateOnKillFocus() event:Skip() end ) UI.m_textCtrlProbeFeedRate:Connect( wx.wxEVT_COMMAND_TEXT_ENTER, function(event) m_textCtrlProbeFeedRateOnKillFocus() event:Skip() end ) UI.m_textCtrlRetractDistance:Connect( wx.wxEVT_KILL_FOCUS, function(event) m_textCtrlRetractDistanceOnKillFocus() event:Skip() end ) UI.m_textCtrlRetractDistance:Connect( wx.wxEVT_COMMAND_TEXT_ENTER, function(event) m_textCtrlRetractDistanceOnKillFocus() event:Skip() end ) UI.m_textCtrlPrepFeedRate:Connect( wx.wxEVT_KILL_FOCUS, function(event) m_textCtrlPrepFeedRateOnKillFocus() event:Skip() end ) UI.m_textCtrlPrepFeedRate:Connect( wx.wxEVT_COMMAND_TEXT_ENTER, function(event) m_textCtrlPrepFeedRateOnKillFocus() event:Skip() end ) UI.m_textCtrlPrepDistance:Connect( wx.wxEVT_KILL_FOCUS, function(event) m_textCtrlPrepDistanceOnKillFocus() event:Skip() end ) UI.m_textCtrlPrepDistance:Connect( wx.wxEVT_COMMAND_TEXT_ENTER, function(event) m_textCtrlPrepDistanceOnKillFocus() event:Skip() end ) UI.m_textCtrlToolDiam:Connect( wx.wxEVT_KILL_FOCUS, function(event) m_textCtrlToolDiamOnKillFocus() event:Skip() end ) UI.m_textCtrlToolDiam:Connect( wx.wxEVT_COMMAND_TEXT_ENTER, function(event) m_textCtrlToolDiamOnKillFocus() event:Skip() end ) UI.m_textCtrlTouchPlateHeight:Connect( wx.wxEVT_KILL_FOCUS, function(event) m_textCtrlTouchPlateHeightOnKillFocus() event:Skip() end ) UI.m_textCtrlTouchPlateHeight:Connect( wx.wxEVT_COMMAND_TEXT_ENTER, function(event) m_textCtrlTouchPlateHeightOnKillFocus() event:Skip() end ) UI.m_choiceProbeCode:Connect( wx. wxEVT_COMMAND_CHOICE_SELECTED, function(event) m_choiceProbeCodeOnChoice() event:Skip() end ) UI.m_choiceCornerTouch:Connect( wx. wxEVT_COMMAND_CHOICE_SELECTED, function(event) m_choiceCornerTouchOnChoice() event:Skip() end ) UI.m_choiceCenterTouch:Connect( wx. wxEVT_COMMAND_CHOICE_SELECTED, function(event) m_choiceCenterTouchOnChoice() event:Skip() end ) UI.m_choiceMeasureAngle:Connect( wx. wxEVT_COMMAND_CHOICE_SELECTED, function(event) m_choiceMeasureAngleOnChoice() event:Skip() end ) UI.m_choiceZOnly:Connect( wx. wxEVT_COMMAND_CHOICE_SELECTED, function(event) m_choiceZOnlyOnChoice() event:Skip() end ) UI.m_buttonMachineWork:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_buttonMachineWorkOnButtonClick() --event:Skip() end ) UI.m_bpButtonTopLeft:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonTopLeftOnButtonClick() --event:Skip() end ) UI.m_bpButtonTop:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonTopOnButtonClick() --event:Skip() end ) UI.m_bpButtonTopRight:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonTopRightOnButtonClick() --event:Skip() end ) UI.m_bpButtonLeft:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonLeftOnButtonClick() --event:Skip() end ) UI.m_bpButtonCenter:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonCenterOnButtonClick() --event:Skip() end ) UI.m_bpButtonRight:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonRightOnButtonClick() --event:Skip() end ) UI.m_bpButtonBottomLeft:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonBottomLeftOnButtonClick() --event:Skip() end ) UI.m_bpButtonBottom:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonBottomOnButtonClick() --event:Skip() end ) UI.m_bpButtonBottomRight:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonBottomRightOnButtonClick() --event:Skip() end ) UI.m_bpButtonMeasureAngle:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonMeasureAngleOnButtonClick() --event:Skip() end ) UI.m_bpButtonZOnly:Connect( wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) m_bpButtonZOnlyOnButtonClick() --event:Skip() end ) UI.frameMain:Show(true) --Show the frame return (UI.frameMain) end -- User Interface --Functions for connect events function frameMainOnActivate() MachWorkDRO = true --Sets UI DROs to work coordinates as default local GetProbeRate = mc.mcProfileGetString(inst, 'ToffParams', 'ToffProbeRate', '5.0') -- Get the Value from the profile ini. UI.m_textCtrlProbeFeedRate:SetValue(tostring (GetProbeRate)) --local GetRetractDistance = mc.mcProfileGetString(inst, 'ToffParams', 'ToffRetractDistance', '0.1') -- Get the Value from the profile ini. --UI.m_textCtrlRetractDistance:SetValue(tostring (GetRetractDistance)) mc.mcProfileWriteString(inst, 'ToffParams', 'ToffRetractDistance', '1') UI.m_textCtrlRetractDistance:SetValue(tostring (1)) local GetPrepFeedRate = mc.mcProfileGetString(inst, 'ToffParams', 'ToffPrepRate', '60') -- Get the Value from the profile ini. UI.m_textCtrlPrepFeedRate:SetValue(tostring (GetPrepFeedRate)) local GetPrepDistance = mc.mcProfileGetString(inst, 'ToffParams', 'ToffPrepDistance', '0.5') -- Get the Value from the profile ini. UI.m_textCtrlPrepDistance:SetValue(tostring (GetPrepDistance)) local GetTouchToolDiam = mc.mcProfileGetString(inst, 'ToffParams', 'ToffToolDiam', '0.25') -- Get the Value from the profile ini. UI.m_textCtrlToolDiam:SetValue(tostring (GetTouchToolDiam)) local GetTouchPlate = mc.mcProfileGetString(inst, 'ToffParams', 'ToffPlate', '0.2') -- Get the Value from the profile ini. --UI.m_textCtrlTouchPlateHeight:SetValue(tostring (GetTouchPlate)) mc.mcProfileWriteString(inst, 'ToffParams', 'ToffPlate', '1') UI.m_textCtrlTouchPlateHeight:SetValue(tostring (1)) --UI.m_choiceProbeCode local GetProbeCode = mc.mcProfileGetString(inst, 'ToffParams', 'ToffProbeCode', '31'); -- Get the Value from the profile ini. if tonumber (GetProbeCode) == 31 then UI.m_choiceProbeCode:SetSelection(0) elseif tonumber (GetProbeCode) == 31.1 then UI.m_choiceProbeCode:SetSelection(1) elseif tonumber (GetProbeCode) == 31.2 then UI.m_choiceProbeCode:SetSelection(2) elseif tonumber (GetProbeCode) == 31.3 then UI.m_choiceProbeCode:SetSelection(3) end local GetCornerOption = mc.mcProfileGetString(inst, 'ToffParams', 'ToffCornerOption', '0'); -- Get the Value from the profile ini. UI.m_choiceCornerTouch:SetSelection(tonumber (GetCornerOption)) local GetCenterOption = mc.mcProfileGetString(inst, 'ToffParams', 'ToffCenterOption', '0'); -- Get the Value from the profile ini. UI.m_choiceCenterTouch:SetSelection(tonumber (GetCenterOption)) local GetMeasureAngleOptions = mc.mcProfileGetString(inst, 'ToffParams', 'ToffAngleOption', '0'); -- Get the Value from the profile ini. UI.m_bpButtonMeasureAngle:SetBitmapLabel(wx.wxBitmap(ImageMeasureAngle(GetMeasureAngleOptions))) UI.m_choiceMeasureAngle:SetSelection(tonumber (GetMeasureAngleOptions)) local GetZOnlyOption = mc.mcProfileGetString(inst, 'ToffParams', 'ToffZOnlyOption', '0'); -- Get the Value from the profile ini. UI.m_bpButtonZOnly:SetBitmapLabel(wx.wxBitmap(ImageZOnly(GetZOnlyOption))) UI.m_choiceZOnly:SetSelection(tonumber (GetZOnlyOption)) end function frameMainOnClose() UI.frameMain:Hide() --Hide the frame co = nil end function frameMainOnUpdateUI() mcState, rc = mc.mcCntlGetState(inst) if (co ~= nil) and (mcState == 0) then local state = coroutine.status(co) if state == "suspended" then --We are about to run some more code so check to see if we have to check the probe state local IsOk = true; if ( m_CheckProbe == true) then --The probe should be active at the end of the move IsOk = CheckProbe(1) else IsOk = CheckProbe(0) --The probe should NOT be active at the end of the move end if ( IsOk == false ) then --If the check failed lets kill the Coroutine co = nil IsOk = true else coerrorcheck, rc, m_CheckProbe = coroutine.resume(co) if(coerrorcheck == false) then --Something happened here to the coroutine so kill it co = nil end if(rc < 0) then --Something happened in the Gcode and we have an error So Kill the coroutine co = nil end end end if state == "dead" then --Kill the coroutine co = nil end end if mcState ~= 0 then --Disable input fields, selections and buttons if not in idle state UI.m_menuItemDocs:Enable(false) UI.m_textCtrlProbeFeedRate:Enable(false) UI.m_textCtrlRetractDistance:Enable(false) UI.m_textCtrlPrepFeedRate:Enable(false) UI.m_textCtrlPrepDistance:Enable(false) UI.m_textCtrlToolDiam:Enable(false) UI.m_textCtrlTouchPlateHeight:Enable(false) UI.m_choiceProbeCode:Enable(false) UI.m_choiceCornerTouch:Enable(false) UI.m_choiceCenterTouch:Enable(false) UI.m_choiceMeasureAngle:Enable(false) UI.m_choiceZOnly:Enable(false) UI.m_bpButtonTopLeft:Enable(false) UI.m_bpButtonTop:Enable(false) UI.m_bpButtonTopRight:Enable(false) UI.m_bpButtonLeft:Enable(false) UI.m_bpButtonCenter:Enable(false) UI.m_bpButtonRight:Enable(false) UI.m_bpButtonBottomLeft:Enable(false) UI.m_bpButtonBottom:Enable(false) UI.m_bpButtonBottomRight:Enable(false) UI.m_bpButtonMeasureAngle:Enable(false) UI.m_bpButtonZOnly:Enable(false) else --Enable input fields, selections and buttons if in idle state UI.m_menuItemDocs:Enable(true) UI.m_textCtrlProbeFeedRate:Enable(true) UI.m_textCtrlRetractDistance:Enable(true) UI.m_textCtrlPrepFeedRate:Enable(true) UI.m_textCtrlPrepDistance:Enable(true) UI.m_textCtrlToolDiam:Enable(true) UI.m_textCtrlTouchPlateHeight:Enable(true) UI.m_choiceProbeCode:Enable(false) UI.m_choiceCornerTouch:Enable(false) UI.m_choiceCenterTouch:Enable(false) UI.m_choiceMeasureAngle:Enable(false) UI.m_choiceZOnly:Enable(false) UI.m_bpButtonTopLeft:Enable(true) UI.m_bpButtonTop:Enable(true) UI.m_bpButtonTopRight:Enable(true) UI.m_bpButtonLeft:Enable(true) UI.m_bpButtonCenter:Enable(false) UI.m_bpButtonRight:Enable(true) UI.m_bpButtonBottomLeft:Enable(true) UI.m_bpButtonBottom:Enable(true) UI.m_bpButtonBottomRight:Enable(true) UI.m_bpButtonMeasureAngle:Enable(false) UI.m_bpButtonZOnly:Enable(true) end -- Set Machine/Work DROs to requested coordinates if MachWorkDRO == (true) then --Set Machine/Work DROs to work coordinates xmachine = mc.mcAxisGetPos(inst, mc.X_AXIS) ymachine = mc.mcAxisGetPos(inst, mc.Y_AXIS) zmachine = mc.mcAxisGetPos(inst, mc.Z_AXIS) else --Set Machine/Work DROs to machine coordinates xmachine = mc.mcAxisGetMachinePos(inst, mc.X_AXIS) ymachine = mc.mcAxisGetMachinePos(inst, mc.Y_AXIS) zmachine = mc.mcAxisGetMachinePos(inst, mc.Z_AXIS) end UI.m_textCtrlX:SetValue (string.format ('%0.4f', xmachine)) UI.m_textCtrlY:SetValue (string.format ('%0.4f', ymachine)) UI.m_textCtrlZ:SetValue (string.format ('%0.4f', zmachine)) -- Set Probe LED state -- Select probe signal depending on probe code selected ReadIni() ProbeSignal = mc.ISIG_PROBE --Default probe signal, probe (G31) if ToffProbeCode == 31.1 then ProbeSignal = mc.ISIG_PROBE1 elseif ToffProbeCode == 31.2 then ProbeSignal = mc.ISIG_PROBE2 elseif ToffProbeCode == 31.3 then ProbeSignal = mc.ISIG_PROBE3 end local hsig = mc.mcSignalGetHandle(inst, ProbeSignal) local ProbeState = (mc.mcSignalGetState(hsig)) if (ProbeState ~= LastCheck) then --The probe input status has changed if (ProbeState == 1) then --The probe input is active UI.m_staticTextProbeStatus:SetBackgroundColour( wx.wxColour( 130, 180, 224) ) UI.m_staticTextProbeStatus:SetLabel("\nSelected Probe Is\nCurrently Active") else UI.m_staticTextProbeStatus:SetBackgroundColour( wx.wxColour( 0, 0, 0 ) ) UI.m_staticTextProbeStatus:SetLabel("\nSelected Probe Is\nCurrently Inactive") end UI.m_staticTextProbeStatus:Refresh() end LastCheck = ProbeState --Set LastCheck so we only run this statement once for each probe state change. end function m_menuItemDocsOnMenuSelection() local major, minor = wx.wxGetOsVersion() local dir = mc.mcCntlGetMachDir(inst); local cmd = "explorer.exe /open," .. dir .. "\\Docs\\TouchOffHelp.pdf" if(minor <= 5) then -- Xp we don't need the /open cmd = "explorer.exe ," .. dir .. "\\Docs\\TouchOffHelp.pdf" end wx.wxExecute(cmd); end function m_textCtrlProbeFeedRateOnKillFocus() local SetProbeRate = UI.m_textCtrlProbeFeedRate:GetValue() SetProbeRate = math.abs (SetProbeRate) --Make sure value is unsigned mc.mcProfileWriteString(inst, 'ToffParams', 'ToffProbeRate', tostring (SetProbeRate)) end function m_textCtrlRetractDistanceOnKillFocus() local SetRetractDistance = UI.m_textCtrlRetractDistance:GetValue() SetRetractDistance = math.abs (SetRetractDistance) --Make sure value is unsigned mc.mcProfileWriteString(inst, 'ToffParams', 'ToffRetractDistance', tostring (SetRetractDistance)) end function m_textCtrlPrepFeedRateOnKillFocus() local SetPrepFeedRate = UI.m_textCtrlPrepFeedRate:GetValue() SetPrepFeedRate = math.abs (SetPrepFeedRate) --Make sure value is unsigned mc.mcProfileWriteString(inst, 'ToffParams', 'ToffPrepRate', tostring (SetPrepFeedRate)) end function m_textCtrlPrepDistanceOnKillFocus() local SetPrepDistance = UI.m_textCtrlPrepDistance:GetValue() SetPrepDistance = math.abs (SetPrepDistance) --Make sure value is unsigned mc.mcProfileWriteString(inst, 'ToffParams', 'ToffPrepDistance', tostring (SetPrepDistance)) end function m_textCtrlToolDiamOnKillFocus() local SetTouchToolDiam = UI.m_textCtrlToolDiam:GetValue() SetTouchToolDiam = math.abs (SetTouchToolDiam) --Make sure value is unsigned mc.mcProfileWriteString(inst, 'ToffParams', 'ToffToolDiam', tostring (SetTouchToolDiam)) end function m_textCtrlTouchPlateHeightOnKillFocus() local SetTouchPlate = UI.m_textCtrlTouchPlateHeight:GetValue() SetTouchPlate = math.abs (SetTouchPlate) --Make sure value is unsigned mc.mcProfileWriteString(inst, 'ToffParams', 'ToffPlate', tostring (SetTouchPlate)) end function m_choiceProbeCodeOnChoice() rc = UI.m_choiceProbeCode:GetSelection() if rc == 0 then mc.mcProfileWriteString(inst, 'ToffParams', 'ToffProbeCode', '31') elseif rc == 1 then mc.mcProfileWriteString(inst, 'ToffParams', 'ToffProbeCode', '31.1') elseif rc == 2 then mc.mcProfileWriteString(inst, 'ToffParams', 'ToffProbeCode', '31.2') elseif rc == 3 then mc.mcProfileWriteString(inst, 'ToffParams', 'ToffProbeCode', '31.3') end end function m_choiceCornerTouchOnChoice() rc = UI.m_choiceCornerTouch:GetSelection() mc.mcProfileWriteString(inst, 'ToffParams', 'ToffCornerOption', tostring(rc)) UI.m_bpButtonTopLeft:SetBitmapLabel(wx.wxBitmap(ImageTopLeft(tostring(rc)))) --Set button image based on selected option. UI.m_bpButtonTopRight:SetBitmapLabel(wx.wxBitmap(ImageTopRight(tostring(rc)))) --Set button image based on selected option. UI.m_bpButtonBottomLeft:SetBitmapLabel(wx.wxBitmap(ImageBottomLeft(tostring(rc)))) --Set button image based on selected option. UI.m_bpButtonBottomRight:SetBitmapLabel(wx.wxBitmap(ImageBottomRight(tostring(rc)))) --Set button image based on selected option. end function m_choiceCenterTouchOnChoice() rc = UI.m_choiceCenterTouch:GetSelection() mc.mcProfileWriteString(inst, 'ToffParams', 'ToffCenterOption', tostring(rc)) UI.m_bpButtonCenter:SetBitmapLabel(wx.wxBitmap(ImageCenter(tostring(rc)))) --Set button image based on selected option. end function m_choiceMeasureAngleOnChoice() rc = UI.m_choiceMeasureAngle:GetSelection() mc.mcProfileWriteString(inst, 'ToffParams', 'ToffAngleOption', (tostring(rc))) UI.m_bpButtonMeasureAngle:SetBitmapLabel(wx.wxBitmap(ImageMeasureAngle(tostring(rc)))) --Set button image based on selected option. end function m_choiceZOnlyOnChoice() rc = UI.m_choiceZOnly:GetSelection() mc.mcProfileWriteString(inst, 'ToffParams', 'ToffZOnlyOption', (tostring(rc))) UI.m_bpButtonZOnly:SetBitmapLabel(wx.wxBitmap(ImageZOnly(tostring(rc)))) --Set button image based on selected option. end function m_buttonMachineWorkOnButtonClick() --Toggle if MachWorkDRO == (true) then MachWorkDRO = false else MachWorkDRO = true end if MachWorkDRO == (true) then --Set Machine/Work to work coordinates UI.m_buttonMachineWork:SetBackgroundColour( wx.wxColour( 0, 0, 0 ) ) UI.m_buttonMachineWork:SetForegroundColour( wx.wxColour( 255, 255, 255 ) ) UI.m_buttonMachineWork:SetLabel( "Work/Machine Toggle\nCurrently Displaying\nWork Coordinates" ) else --Set Machine/Work to machine coordinates UI.m_buttonMachineWork:SetBackgroundColour( wx.wxColour( 255, 0, 0 ) ) UI.m_buttonMachineWork:SetForegroundColour( wx.wxColour( 0, 0, 0 ) ) UI.m_buttonMachineWork:SetLabel( "Work/Machine Toggle\nCurrently Displaying\nMachine Coordinates" ) end end function m_bpButtonTopLeftOnButtonClick() --rc = UI.m_choiceCornerTouch:GetSelection() --if rc == 0 then co = coroutine.create (TouchZnegYnegXpos0) --elseif rc == 1 then --co = coroutine.create (TouchZnegYnegXpos1) --elseif rc == 2 then --co = coroutine.create (TouchZnegYnegXpos2) --elseif rc == 3 then --co = coroutine.create (TouchZnegYnegXpos3) --end end function m_bpButtonTopOnButtonClick() co = coroutine.create (TouchOffYNeg0) end function m_bpButtonTopRightOnButtonClick() --rc = UI.m_choiceCornerTouch:GetSelection() --if rc == 0 then co = coroutine.create (TouchZnegYnegXneg0) --elseif rc == 1 then --co = coroutine.create (TouchZnegYnegXneg1) --elseif rc == 2 then --co = coroutine.create (TouchZnegYnegXneg2) --elseif rc == 3 then --co = coroutine.create (TouchZnegYnegXneg3) --end end function m_bpButtonLeftOnButtonClick() co = coroutine.create (TouchOffXPos0) end function m_bpButtonCenterOnButtonClick() --rc = UI.m_choiceCenterTouch:GetSelection() --if rc == 0 then co = coroutine.create (TouchCenter0) --elseif rc == 1 then --co = coroutine.create (TouchCenter1) --elseif rc == 2 then --co = coroutine.create (TouchCenter2) --elseif rc == 3 then --co = coroutine.create (TouchCenter3) --end end function m_bpButtonRightOnButtonClick() co = coroutine.create (TouchOffXNeg0) end function m_bpButtonBottomLeftOnButtonClick() --rc = UI.m_choiceCornerTouch:GetSelection() --if rc == 0 then co = coroutine.create (TouchZnegYposXpos0) --elseif rc == 1 then --co = coroutine.create (TouchZnegYposXpos1) --elseif rc == 2 then --co = coroutine.create (TouchZnegYposXpos2) --elseif rc == 3 then --co = coroutine.create (TouchZnegYposXpos3) --end end function m_bpButtonBottomOnButtonClick() co = coroutine.create (TouchOffYPos0) end function m_bpButtonBottomRightOnButtonClick() --rc = UI.m_choiceCornerTouch:GetSelection() --if rc == 0 then co = coroutine.create (TouchZnegYposXneg0) --elseif rc == 1 then --co = coroutine.create (TouchZnegYposXneg1) --elseif rc == 2 then --co = coroutine.create (TouchZnegYposXneg2) --elseif rc == 3 then --co = coroutine.create (TouchZnegYposXneg3) --end end function m_bpButtonMeasureAngleOnButtonClick() --rc = UI.m_choiceMeasureAngle:GetSelection() --if rc == 0 then --Find X+ angle co = coroutine.create (Angle0) --elseif rc == 1 then --Find X- angle --co = coroutine.create (Angle1) --elseif rc == 2 then --Find Y+ angle --co = coroutine.create (Angle2) --elseif rc == 3 then --Find Y- angle --co = coroutine.create (Angle3) --end end function m_bpButtonZOnlyOnButtonClick() co = coroutine.create (TouchOffZNeg0) --[[ rc = UI.m_choiceZOnly:GetSelection() if rc == 0 then --Material top co = coroutine.create (TouchOffZNeg0) elseif rc == 1 then --TLO co = coroutine.create (TouchOffZNeg1) --elseif rc == 2 then --Material bottom --co = coroutine.create (TouchOffZNeg2) --elseif rc == 3 then --Material thickness --co = coroutine.create (TouchOffZNeg3) end --]] end ------------ Embedded Images ---------------------- function ImageTopLeft(pic) if (pic == nil) then pic = '0' end if pic == '0' then Image = { "60 60 282 2", " c None", ". c #9F9F9F", "+ c #989898", "@ c #929292", "# c #8C8C8C", "$ c #898989", "% c #878787", "& c #888888", "* c #939393", "= c #FFFFFF", "- c #8E8E8E", "; c #EDEDED", "> c #EEEEEE", ", c #EBEBEB", "' c #8F8F8F", ") c #EFEFEF", "! c #FCFCFC", "~ c #FDFDFD", "{ c #ECECEC", "] c #F4F4F4", "^ c #000000", "/ c #EAEAEA", "( c #8D8D8D", "_ c #F0F0F0", ": c #161616", "< c #FBFBFB", "[ c #E8E8E8", "} c #909090", "| c #FAFAFA", "1 c #E9E9E9", "2 c #E7E7E7", "3 c #F8F8F8", "4 c #FEFEFE", "5 c #E6E6E6", "6 c #F9F9F9", "7 c #E5E5E5", "8 c #E4E4E4", "9 c #919191", "0 c #F5F5F5", "a c #515151", "b c #090909", "c c #525252", "d c #E3E3E3", "e c #F2F2F2", "f c #656565", "g c #111111", "h c #E2E2E2", "i c #F1F1F1", "j c #575757", "k c #E1E1E1", "l c #4D4D4D", "m c #121212", "n c #4E4E4E", "o c #404040", "p c #020202", "q c #010101", "r c #424242", "s c #DFDFDF", "t c #E0E0E0", "u c #363636", "v c #030303", "w c #131313", "x c #373737", "y c #F7F7F7", "z c #F3F3F3", "A c #2D2D2D", "B c #040404", "C c #DDDDDD", "D c #DEDEDE", "E c #242424", "F c #050505", "G c #272727", "H c #DBDBDB", "I c #DCDCDC", "J c #1B1B1B", "K c #D7D7D7", "L c #CFCFCF", "M c #CBCBCB", "N c #949494", "O c #DADADA", "P c #D8D8D8", "Q c #D9D9D9", "R c #222222", "S c #D6D6D6", "T c #D0D0D0", "U c #979797", "V c #D5D5D5", "W c #D4D4D4", "X c #D2D2D2", "Y c #CDCDCD", "Z c #C9C9C9", "` c #D3D3D3", " . c #CCCCCC", ".. c #C8C8C8", "+. c #ACACAC", "@. c #535353", "#. c #2A2A2A", "$. c #232323", "%. c #252525", "&. c #282828", "*. c #2C2C2C", "=. c #303030", "-. c #333333", ";. c #383838", ">. c #3C3C3C", ",. c #474747", "'. c #4C4C4C", "). c #545454", "!. c #585858", "~. c #5A5A5A", "{. c #5E5E5E", "]. c #5F5F5F", "^. c #616161", "/. c #626262", "(. c #686868", "_. c #828282", ":. c #BBBBBB", "<. c #C7C7C7", "[. c #7F7F7F", "}. c #353535", "|. c #3F3F3F", "1. c #414141", "2. c #444444", "3. c #484848", "4. c #4B4B4B", "5. c #666666", "6. c #696969", "7. c #6C6C6C", "8. c #6F6F6F", "9. c #717171", "0. c #747474", "a. c #9E9E9E", "b. c #CACACA", "c. c #C5C5C5", "d. c #AEAEAE", "e. c #292929", "f. c #3A3A3A", "g. c #3E3E3E", "h. c #454545", "i. c #464646", "j. c #494949", "k. c #505050", "l. c #6D6D6D", "m. c #727272", "n. c #757575", "o. c #767676", "p. c #BABABA", "q. c #423F3D", "r. c #453E37", "s. c #4C4033", "t. c #4F4131", "u. c #524435", "v. c #52493F", "w. c #534F4B", "x. c #555453", "y. c #646464", "z. c #6E6E6E", "A. c #707070", "B. c #737373", "C. c #777777", "D. c #848484", "E. c #3F3E3D", "F. c #423B34", "G. c #493825", "H. c #2E5075", "I. c #1B5FAB", "J. c #1269C8", "K. c #136ACA", "L. c #2A5C94", "M. c #504E4B", "N. c #5B5043", "O. c #5A5652", "P. c #5D5D5D", "Q. c #6B6B6B", "R. c #41403F", "S. c #453B31", "T. c #3F3D3A", "U. c #066EE2", "V. c #007EFF", "W. c #007AFF", "X. c #0079FF", "Y. c #007DFF", "Z. c #2D619B", "`. c #625444", " + c #5E5B57", ".+ c #606060", "++ c #676767", "@+ c #6A6A6A", "#+ c #434343", "$+ c #453F37", "%+ c #403E3D", "&+ c #0081FF", "*+ c #0076FA", "=+ c #0176F8", "-+ c #0077FD", ";+ c #2F639B", ">+ c #63574A", ",+ c #5F5E5E", "'+ c #636363", ")+ c #464441", "!+ c #4D3C2A", "~+ c #076FE3", "{+ c #007BFF", "]+ c #5A5651", "^+ c #625C56", "/+ c #555555", "(+ c #4B443C", "_+ c #315379", ":+ c #0078FF", "<+ c #156DCE", "[+ c #65584A", "}+ c #4A4A4A", "|+ c #504436", "1+ c #1D61AC", "2+ c #0076FC", "3+ c #0076FD", "4+ c #68543F", "5+ c #343434", "6+ c #554635", "7+ c #0671E7", "8+ c #0076F9", "9+ c #007CFF", "0+ c #665037", "a+ c #5B5B5B", "b+ c #0A0A0A", "c+ c #393939", "d+ c #594B3B", "e+ c #156BCA", "f+ c #624D35", "g+ c #595959", "h+ c #5C5C5C", "i+ c #5A5146", "j+ c #2E6099", "k+ c #5D4C39", "l+ c #5B5652", "m+ c #575552", "n+ c #285C96", "o+ c #544A40", "p+ c #565656", "q+ c #060606", "r+ c #1A1A1A", "s+ c #5C5B5A", "t+ c #31659F", "u+ c #066FE4", "v+ c #503E2A", "w+ c #4D4A46", "x+ c #615E5A", "y+ c #695A4A", "z+ c #3165A0", "A+ c #3D3D3D", "B+ c #463F38", "C+ c #64615D", "D+ c #695D50", "E+ c #5F5B56", "F+ c #166ECF", "G+ c #0075FC", "H+ c #0870E4", "I+ c #295D96", "J+ c #453E36", "K+ c #3D3C3B", "L+ c #656463", "M+ c #655F59", "N+ c #685C4E", "O+ c #6B5843", "P+ c #68523A", "Q+ c #644F38", "R+ c #4C4845", "S+ c #4F4F4F", "T+ c #313131", "U+ c #2B2B2B", "V+ c #262626", "W+ c #838383", "X+ c #ADADAD", "Y+ c #D1D1D1", "Z+ c #CECECE", "`+ c #C6C6C6", " @ c #C3C3C3", ".@ c #C0C0C0", "+@ c #999999", "@@ c #9B9B9B", "#@ c #969696", "$@ c #9D9D9D", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ", ". + @ # # # # $ $ $ $ $ $ $ % $ $ % $ $ % $ $ $ $ & & & $ % $ % $ % $ $ $ $ $ $ & & & & $ $ $ $ % $ $ $ $ $ % # # @ + . ", ". * = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = @ . ", ". - = ; ; ; > > ; ; ; ; ; ; ; ; ; > > ; > ; > ; ; ; > > > ; > > > > ; ; ; ; ; > > > ; ; ; ; > > ; ; > ; ; ; ; > , = # . ", ". ' = ; ; ; ; ; ; ; ; ; ; ) ) ; ) ; ; ) ; ; ; ; ; ; ) ; ; ; ; ; ; > ! = = = = = = = = = ! > ; ; ; ; ; ; ; ; ; ; , = # . ", ". ' ~ { { { { { { { { { { > > { > { { { { { { { { { { > { { { { { > ] ^ ^ ^ ^ ^ ^ ^ ^ ^ ] > { { { { { { { { { { / = ( . ", ". ' ~ ; ; , ; , , ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; , , , ; ; ; ; _ = ^ : : : : : : : ^ = _ ; ; ; ; ; , ; ; ; ; / = ( . ", ". ' < / / / / / / / { / / { { / / / / / { / / { / / / / / / / / / ) = ^ : : : : : : : ^ = ; / / / / { { / / { / [ = ( . ", ". } | 1 1 , 1 , 1 1 1 1 , , 1 1 / / 1 , 1 1 1 1 , 1 / 1 , , 1 1 1 { = ^ : : : : : : : ^ = { 1 , 1 1 1 1 1 , , 1 2 = ( . ", ". } 3 [ [ [ / / [ [ [ [ / / [ [ [ [ [ / [ [ / [ [ [ [ [ [ [ [ / / , 4 ^ : : : : : : : ^ 4 , [ / [ [ [ [ [ / / [ 5 = ( . ", ". } 6 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 1 1 1 1 1 1 1 1 1 1 , 4 ^ : : : : : : : ^ 4 , 1 2 1 1 1 1 1 1 1 1 5 = - . ", ". } ] 7 [ 5 5 5 [ 7 5 5 5 5 [ 5 5 [ 5 5 [ 5 5 [ 8 [ [ [ 5 ; ~ = = = = ^ : : : : : : : ^ = = = = ~ ; 5 5 [ [ 5 5 8 = - . ", ". 9 0 7 2 7 5 7 7 2 5 5 7 7 2 7 7 2 7 7 7 7 7 2 2 2 2 7 2 ; a ^ ^ ^ ^ b : : : : : : : b ^ ^ ^ ^ c ; 5 7 7 7 7 5 d = - . ", ". 9 e 8 8 8 7 8 5 8 8 7 8 5 8 8 8 5 8 7 7 7 8 8 8 8 8 8 7 { = f ^ g : : : : : : : : : : : g ^ f = { 7 7 7 7 7 7 h = - . ", ". 9 i d d d d d d d d d d d d d d d d d d d d d d 8 d 8 h 8 , = j ^ g : : : : : : : : : g ^ j = , d d d d d d d k = ' . ", ". 9 i 8 8 8 8 h 8 8 8 8 h h h 8 8 k 8 8 8 8 8 8 h d h 8 h 8 8 { 4 l ^ m : : : : : : : m ^ n = { 8 8 8 8 8 h h 8 h = ' . ", ". 9 _ d d d k k d d d k k d k k d k d d k d d k k k k k k d d k { < o p m : : : : : m q r | / d d k k d d d k k s = ' . ", ". @ ; h t t t t t t t t t h t t t h h t t t t h t t h h t t t t h { 6 u v w : : : w v x y , h h h t t h h h t h t 4 ' . ", ". @ { k s t s s s s s s k s s t s s s s t t s s s s s k k s t s s t / z A B w : w B A z / k s s k k s s s s s s C < } . ", ". @ , D D D D t D D t D D D D D D D D D D s s s s s s s s s s s s s t , ) E F g F G ) , s s s s s s s s s s s t t ~ @ . ", ". @ , s s s s s s s C s s s s s s s s s C D C H H I I I I I I I I I I I [ 5 J ^ J 5 [ I I I I I I I I I I I H K L M N . ", ". @ 2 D D D I I I D I D D D I D D D I D C I H O P Q K K K K K K K Q Q Q O 5 H R C 5 P K Q Q Q Q Q K K K K Q P S T M U . ", ". * 5 H C H C C C C H H H H C C C H H C O O K S V W W V V V V V W W W W W V s t s S W W W W W W W W V V W W V X Y Z U . ", ". * 5 O O O I I I O O O O O I I O O O H O K V ` X W H 8 , ; ; ; ; { { ; { , , / 1 2 5 7 7 8 7 7 d d k C K ` X T ...U . ", ". * 7 H H H H H H H H H H H H H H H H H P S W X S k +.@.#.$.E %.&.#.*.=.-.;.>.r ,.'.a ).!.~.{.].^./.(._.:.H W L M <.+ . ", ". * d Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q O Q K ` W k [.G }.>.|.1.r r 2.3.4.l c ).~.{./.5.6.7.8.9.9.0.0.0.8.(.a.O L b.c.+ . ", ". * 7 O O O O O O O O O O O O O O O O O K V ` H d.e.f.g.g.g.|.r r h.i.j.n k.).~.{./.5.6.7.l.9.m.m.n.o.n.0.(.p.W b.c.+ . ", ". * 7 O O O O O O O O O O O O O O O O O P S W 8 ).u o o g.g.o q.r.s.t.u.v.w.x.!.{./.y.6.7.z.A.m.B.B.0.o.C.9.D.Q b.c.+ . ", ". * 7 O O O O O O O O O O O O O O O O O P S W , *.g.1.|.o E.F.G.H.I.J.K.L.M.N.O.P.^.f (.Q.z.A.A.B.0.n.o.n.n.7.C b.c.+ . ", ". * 7 O O O O O O O O t t t O O O O O O P S W ; %.1.r o R.S.T.U.V.W.X.X.W.Y.Z.`. +.+y.++@+l.8.9.m.m.B.n.o.n.y.s b.c.+ . ", ". * 7 O O O O O O O O ; n 0 k O O O O O P S W ; &.2.r #+$+%+&+W.*+=+=+=+=+-+W.;+>+,+'+5.6.7.z.A.A.B.m.B.n.0.f t b.c.+ . ", ". * 7 O O O O O O O O | ^ .+] h O O O O P S W { #.i.2.)+!+~+X.=+=+=+=+=+=+=+-+{+]+^+.+f (.Q.l.8.8.m.B.m.0.B.'+t b.c.+ . ", ". * 7 O O O O O O O O = ^ ^ /+] h O O O P S W { *.3.i.(+_+Y.*+=+=+=+=+=+=+=+=+:+<+[+.+'+f 6.7.7.8.8.A.m.B.B.^.t b.c.+ . ", ". * 7 O O H I I I I I = ^ g ^ }+i d O O P S W , =.4.j.|+1+W.=+=+=+=+=+=+=+=+=+2+3+4+{.^.f 5.@+7.7.8.A.9.A.m..+t b.c.+ . ", ". * 7 O 2 t > > > > > = ^ : g q 1.) 8 O P S W , 5+n '.6+7+:+=+=+=+=+=+=+=+=+=+8+9+0+a+]./.f (.@+7.l.z.8.A.A.].k b.c.+ . ", ". * 7 O ] ^ ^ ^ ^ ^ ^ ^ b+: : m p u ; 7 P S W / c+k.a d+e+:+=+=+=+=+=+=+=+=+=+*+Y.f+g+h+.+'+f 5.(.Q.7.l.z.z.a+k b.c.+ . ", ". * 7 O = ^ : : : : : : : : : : m v *.1 8 K W 1 g.)./+i+j+X.=+=+=+=+=+=+=+=+=+:+~+k+).g+P..+^.f ++(.@+Q.Q.7.g+k b.c.+ . ", ". * 7 O = ^ : : : : : : : : : : : w B G k d V 1 r !.g+l+m+{+-+=+=+=+=+=+=+=+*+9+n+o+c p+!.P.]..+y.f f 5.++6./+h b.c.+ . ", ". * 7 O = ^ : : : : : : : : : : : : w q+r+Q D [ ,.{.P.s+>+t+X.3+=+=+=+=+=+*+W.u+v+w+l c p+g+~.{..+/.'+y.f 5.a d b.c.+ . ", ". * 7 O = ^ : : : : : : : : : : : : : m ^ R s 2 './.^..+x+y+z+W.:+2+8+*+:+9+u+A+B+,.4.l c /+!.~.h+{.]..+^./.'.d b.c.+ . ", ". * 7 O = ^ : : : : : : : : : : : : w q+r+K D 5 a 5.f y.'+C+D+E+F+G+{+9+H+I+v+J+K+r ,.4.n a ).p+!.~.a+h+P.{.3.8 b.c.+ . ", ". * 7 O = ^ : : : : : : : : : : : w B $.h d V 5 ).6.++5.f f L+M+N+O+P+Q+k+o+R+i.|.g.r ,.}+l n c ).).j !.g+!.#+7 b.c.+ . ", ". * 7 O = ^ : : : : : : : : : : m v A 1 8 K W 7 !.7.Q.Q.@+(.++f ^..+P.g+).c '.j.2.o g.r h.3.'.n k.c @.)./+).g.5 b.c.+ . ", ". * 7 O ] ^ ^ ^ ^ ^ ^ ^ b+: : m p 5+{ 7 P S W 7 ~.z.z.l.7.Q.(.5.f '+.+h+g+@.S+'.3.#+g.|.r i.,.j.4.n n S+a k.c+5 b.c.+ . ", ". * 7 O 2 t > > > > > = ^ : g q |.) 8 H P S W 8 {.A.A.8.z.l.7.@+(.f /.].a+j @.S+j.h.r A+|.#+2.i.j.j.'.4.'.n 5+2 b.c.+ . ", ". * 7 O O H I I I I I = ^ g ^ }+i d O O P S W 8 ].m.A.9.A.8.7.7.@+5.f ^.{.~.).a l j.2.1.A+|.#+h.h.i.,.3.j.4.T+[ b.c.+ . ", ". * 7 O O O O O O O O = ^ ^ @.] h O O O P S W 8 .+B.B.m.A.8.8.7.7.6.f '+.+h+!.c S+4.i.2.o g.|.1.2.h.i.,.i.3.A [ b.c.+ . ", ". * 7 O O O O O O O O | ^ .+] h O O O O P S W d '+B.0.m.B.m.8.8.l.Q.(.f .+{.!./+a l j.i.#+|.g.|.r #+2.h.2.i.U+1 b.c.+ . ", ". * 7 O O O O O O O O ; n z k O O O O O P S W d y.0.n.B.m.B.A.A.z.7.6.5.'+].a+/+a n j.,.#+r |.g.|.o 1.#+r 2.e.1 b.c.+ . ", ". * 7 O O O O O O O O t t t O O O O O O P S W d '+n.o.n.B.m.m.9.8.l.@+++y..+h+!.c S+}+3.2.#+o g.g.|.1.o r 1.V+1 b.c.+ . ", ". * 7 O O O O O O O O O O O O O O O O O P S W k Q.n.n.o.n.0.B.A.A.z.Q.(.f ^.P.j @.k.4.j.h.2.r |.g.g.o |.1.g.A 2 b.c.+ . ", ". * 7 O O O O O O O O O O O O O O O O O P S W C W+9.C.o.0.B.B.m.A.z.7.6.y./.{.!./+a '.}+,.h.1.1.o g.g.o o u /+t b.c.+ . ", ". * 7 O O O O O O O O O O O O O O O O O P S W K p.(.0.n.o.n.m.m.9.l.7.6.5./.{.~.).k.n j.i.h.r r |.g.g.g.f.e.X+P b.c.+ . ", ". * 7 O O O O O O O O O O O O O O O O O P S W ` H a.6.A.0.0.0.9.9.8.7.6.5./.{.~.).c l 4.3.2.r r 1.|.>.}.G [.k Y+b.c.+ . ", ". * 7 O O O O O O O O O O O O O O O O O K V ` X W O p.W+6.'+/.].].a+!./+a '.3.#+A+c+5+T+A U+e.V+%.$.e.).+.k V Z+M `++ . ", ". * 7 O O O O O O O O O O O O O O O O H ` X Y+L L T W O D s t t k k k h d d 8 7 5 2 2 [ [ 1 1 / / / 2 k P Y+Z+ .Z @+ . ", ". * 7 O O O O O O O O O O O O O O O O I M .M b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.b.M Z c..@+@. ", ". U ; 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 2 c.`+<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.<.`+c..@:.@@. ", ". @@U * * * * * * * * * * * * * * * * N #@+ + + + + + + + + + + + + + + + + + + + + + + + + + + + + + + + + + + +@@@$@. ", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . "}; elseif pic == '1' then Image = { "60 60 126 2", " c #ACACAC", ". c #ADADAD", "+ c #A5A5A5", "@ c #9E9E9E", "# c #9D9D9D", "$ c #9C9C9C", "% c #F2F2F2", "& c #FFFFFF", "* c #B8B8B8", "= c #B3B3B3", "- c #F1F1F1", "; c #F0F0F0", "> c #FDFDFD", ", c #C5C5C5", "' c #BDBDBD", ") c #AEAEAE", "! c #ECECEC", "~ c #EEEEEE", "{ c #EFEFEF", "] c #FBFBFB", "^ c #C3C3C3", "/ c #AFAFAF", "( c #EBEBEB", "_ c #EDEDED", ": c #FAFAFA", "< c #C2C2C2", "[ c #C0C0C0", "} c #EAEAEA", "| c #F9F9F9", "1 c #BFBFBF", "2 c #B0B0B0", "3 c #E9E9E9", "4 c #F8F8F8", "5 c #F7F7F7", "6 c #C1C1C1", "7 c #E8E8E8", "8 c #F6F6F6", "9 c #E7E7E7", "0 c #E6E6E6", "a c #F3F3F3", "b c #E5E5E5", "c c #E4E4E4", "d c #E3E3E3", "e c #E2E2E2", "f c #BEBEBE", "g c #E1E1E1", "h c #ABABAB", "i c #161616", "j c #E0E0E0", "k c #AAAAAA", "l c #DFDFDF", "m c #A9A9A9", "n c #DEDEDE", "o c #DCDCDC", "p c #DDDDDD", "q c #BBBBBB", "r c #DBDBDB", "s c #A8A8A8", "t c #A7A7A7", "u c #A6A6A6", "v c #DADADA", "w c #D8D8D8", "x c #D9D9D9", "y c #B9B9B9", "z c #D6D6D6", "A c #D7D7D7", "B c #7C7C7C", "C c #434343", "D c #373737", "E c #444444", "F c #CDCDCD", "G c #C8C8C8", "H c #C9C9C9", "I c #CACACA", "J c #C4C4C4", "K c #D2D2D2", "L c #B4B4B4", "M c #CCCCCC", "N c #C7C7C7", "O c #3B3B3B", "P c #3C3C3C", "Q c #CFCFCF", "R c #B1B1B1", "S c #C6C6C6", "T c #BCBCBC", "U c #363636", "V c #D0D0D0", "W c #B7B7B7", "X c #2E2E2E", "Y c #B2B2B2", "Z c #2A2A2A", "` c #252525", " . c #CBCBCB", ".. c #212121", "+. c #9F9F9F", "@. c #1D1D1D", "#. c #1E1E1E", "$. c #979797", "%. c #1A1A1A", "&. c #1B1B1B", "*. c #989898", "=. c #CECECE", "-. c #8F8F8F", ";. c #181818", ">. c #868686", ",. c #171717", "'. c #7D7D7D", "). c #727272", "!. c #737373", "~. c #313131", "{. c #333333", "]. c #494949", "^. c #555555", "/. c #535353", "(. c #525252", "_. c #3F3F3F", ":. c #6C6C6C", "<. c #484848", "[. c #545454", "}. c #515151", "|. c #464646", "1. c #323232", "2. c #717171", "3. c #A1A1A1", "4. c #A0A0A0", "5. c #A2A2A2", " . . . . . . . . . . . . . . . . . . . . ", " + @ # # # # # # # # # # $ # # $ # # $ # # # # $ $ $ # $ # $ # $ # # # # # # $ $ $ $ # # # # $ # # # # # $ # # . . ", " % & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & * = ", "= - - ; ; ; - - ; ; ; ; ; ; ; ; ; - - ; - ; - ; ; ; - - - ; - - - - ; ; ; ; ; - - - ; ; ; ; - - ; ; - ; ; ; ; - ; > , ' ", ") ! ; ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ { ~ ~ { ~ ~ ~ ~ ~ ~ { ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ] ^ ' ", "/ ( ~ _ _ _ _ _ _ _ _ _ _ ~ ~ _ ~ _ _ _ _ _ _ _ _ _ _ ~ _ _ _ _ _ _ _ _ ~ ~ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ : < [ ", "/ } ~ _ _ ! _ ! ! _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! ! ! _ _ _ _ _ _ _ _ _ ! _ _ _ _ _ _ _ _ _ _ _ _ ! _ _ _ _ _ | < 1 ", "2 3 ! ( ( ( ( ( ( ( ! ( ( ! ! ( ( ( ( ( ! ( ( ! ( ( ( ( ( ( ( ( ( ! ( ( ( ( ( ( ( ( ( ! ( ( ( ( ( ( ! ! ( ( ! ( ( 4 < 1 ", "/ 3 ( } } ( } ( } } } } ( ( } } } } } ( } } } } ( } } } ( ( } } } } } } } } } } } } ( } } } } ( } } } } } ( ( } } 5 6 1 ", "/ 7 } 3 3 3 } } 3 3 3 3 } } 3 3 3 3 3 } 3 3 } 3 3 3 3 3 3 3 3 } } 3 3 } 3 3 3 3 3 3 3 3 3 3 3 } 3 3 3 3 3 } } 3 3 8 6 1 ", "/ 9 } 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 7 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 7 3 3 3 3 3 3 3 3 3 8 6 1 ", "2 0 9 0 7 9 9 9 7 0 9 9 9 9 7 9 9 7 9 9 7 9 9 7 0 7 7 7 9 9 7 7 0 7 7 9 7 7 7 9 9 7 9 9 9 7 7 9 7 9 9 9 7 7 9 9 9 a [ [ ", "/ b 9 0 9 0 0 0 0 9 0 0 0 0 9 0 0 9 0 0 0 0 0 9 9 9 9 0 9 0 0 0 0 0 9 0 0 0 9 0 0 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 % 1 1 ", "/ c b b b b b b 0 b b b b 0 b b b 0 b b b b b b b b b b b b b b b b b b b b b b b b b 0 b b b b b b b b b b b b b % 1 [ ", "2 d c c c c c c c c c c c c c c c c c c c c c c c c c c d c c c c c c c c c c c c c c c c c d c c c c c c c c c c ; 1 [ ", "/ d c c c c c d c c c c d d d c c e c c c c c c d d d c d c c c d d c c c c c d c c c c d c c c c c c c c d d c c ~ f [ ", "2 e d d d d e e d d d e e d e e d e d d e d d e e e e e e d d e d d d e e e d d d e e d e e e d d e e d d d e e e ~ f 6 ", "/ g g e g g g g g g g g g e g g g e e g g g g e h i i i i i i i i i i i i h g e g g g g g g e e e g g e e e g e e _ ' 6 ", "/ j j g j j j j j j j j g j j j j j j j j j j j k i i i i i i i i i i i i k j j j g j j j g j j g g j j j j j j j ( ' 6 ", "2 l l l l l l j l l j l l l l l l l l l l l l l m i i i i i i i i i i i i m l l l j l l l l l l l l l l l l l l l } ' 6 ", "/ l l l l l l l l l n l l l l l l l l l l l l l m i i i i i i i i i i i i m l l l n l l l l l l l l l n l l l l l 3 ' 6 ", "2 n o n n n p p p n p n n n p n n n p n n n n n m i i i i i i i i i i i i m n n p n n p n n n n p p p p p p p p n 7 q 6 ", "2 p r o p o p p p p o o o o p p p o o p p o o o s i i i i i i i i i i i i t o o p p p p p p o o p p o p p p o o p 9 q < ", "/ o r r r r o o o r r r r r o o r r r r r r o o u i i i i i i i i i i i i u r r o r r o r o r r r o r o o o r r r 0 q < ", "2 r v r r r r r r r r r r r r r r r r r r r r r u i i i i i i i i i i i i u r r r r r r r r r r r r r r r r r r r c q < ", "/ v w x x x v v x x v v v v x v v v v v v x x x u i i i i i i i i i i i i + x x x x v v v v x w x x v v x x x x x d q < ", "2 v x x w w x x w x x x x x x x x x x x x x x w + i i i i i i i i i i i i + x x x v x x x v w x x x x x w x x w w d y < ", "2 x z A A A A z A w w z z A A A z z B C C C C C D i i i i i i i i i i i i D E C C C C B A A A A A A w z z w A z A j y ^ ", "2 F G H H I I H I I I I I I I I I I J C i i i i i i i i i i i i i i i i i i i i i i C J I I I I I I I H I I I I I K L , ", "2 M , N G H N N H N N H G N H N H H G f O i i i i i i i i i i i i i i i i i i i i P 1 G H G N G G G N N G G G G G Q = J ", "R M S H H G H H G G H H H G G H G G G G T U i i i i i i i i i i i i i i i i i i U q G H H G G H G H H G G H G G H V = , ", "R M , H G G H H G G G G H H G G H H G H H W X i i i i i i i i i i i i i i i i X W H G G G G H H G G H H H G G H H V = , ", "R M , G G H G H G G G G G H G G H G G H H G Y Z i i i i i i i i i i i i i i Z = H G G G H H H H G H H G G H H H H V = J ", "R M S G H G H G H H G H G H G H H G H H H G H ` i i i i i i i i i i i i ` H H G H H H G G H H H H G H H H H H V = , ", "2 .J N G N N G N N N N N N N G G N G G N N G N + ..i i i i i i i i i i ..u N N N N G G N N N N G G N N G N G N N Q Y , ", "2 .J N N N N N N G N N N N N N N G N N N N G N N +.@.i i i i i i i i #.+.N N G G N N N N N N N N N N N N N G G N Q = , ", "R M , N G N N N N N N N G G N G G N G N N N N N N G $.%.i i i i i i &.*.G N N N N N N G N N N G N N N G G G N N G =.= , ", "R .J N N N N N G G N N N N N N N N N N G N G N N N N -.;.i i i i ;.-.N N N N G G N N N N N G N N N N N G N N N N =.= , ", "2 ., N N N N N N N N N N G G N N N N G G G N N N N N N >.,.i i ,.>.G G N N N G N N N N N N N G G G N N G N N N N Q = , ", "2 .J N N N N N N N N N N N N N N N N N N N N N N N N N N '.i i '.N N N N N N N N N N N N N N N N N N N N N N N N =.Y , ", "2 I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S ).!.S S S S S S S S S S S S S S S S S S S S S S S S S F Y S ", "R I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "2 I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "2 I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "R I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "2 I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "2 H < , , J , , , , , , , , J ~.~.~.{.].^./.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.^.(._.~.~.D :.^ , , , , , , , M Y , ", "R H < , , , J , , , , , , J , ~.~.~.{.<.[.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.(.}.|.O 1.D 2.J , , , , , , , M Y , ", "2 H < , , J , , , , , , , , , ~.~.~.{.<.[.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.(.}.|.O 1.D 2., , , , , , J , M R S ", "2 H < , , , , J J , , J , , , , , , , , , , , J , , , , , , , , , , , , , , , , , , , , , , , , , J , , , , , , , .R S ", "2 G < , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , J J , , , , , , , , J J , , , , , , , , , , , , M Y , ", "R H [ J J ^ J J J J J ^ J J J J J J J J J J J ^ J J J J J J J J J , , ^ J J J J J J J , , J J J J J J J J J J ^ J .R , ", "2 H < , , J , , , , , , , , , , , , , , , , , J J , , , J , , , , , , , , , J , , , , , , J J , , , , , , , , J , M Y J ", "2 H < , , , , J J , , J , , , , , , , , , , , J , , , , , , , , , , , , , , , , , , , , , , , , , J , , , , , , , .Y < ", "2 G < , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , J J , , , , , , , , J J , , , , , , , , , , , , M Y T ", "2 H [ J J ^ J J J J J ^ J J J J J J J J J J J ^ J J J J J J J J J , , ^ J J J J J J J , , J J J J J J J J J J ^ J . = ", "2 H q [ [ [ [ [ [ 1 [ [ 1 [ [ 1 [ [ 1 [ [ [ 1 [ 1 [ [ [ [ [ [ [ 1 [ [ [ [ [ 1 [ 1 [ [ [ [ [ [ 1 1 1 [ [ 1 [ 1 [ [ , ) ", "2 H g l n n l n n l l l l n n l l n n n l n n l n n n l l n l n n n n l l n n n l n n l l l l n l l n n n l n l l _ ", "2 m 3.3.3.3.3.3.3.4.3.4.4.4.3.4.3.5.3.3.3.3.3.3.3.3.4.3.4.3.3.3.3.4.4.3.4.3.4.4.3.4.3.3.4.3.3.3.3.3.3.4.4.4.4.3. ", "2 2 2 . . . . . . . . . . . . . . . . . "}; end return Image end function ImageTop(pic) local Image = { "60 60 126 2", " c #ACACAC", ". c #ADADAD", "+ c #A5A5A5", "@ c #9E9E9E", "# c #9D9D9D", "$ c #9C9C9C", "% c #F2F2F2", "& c #FFFFFF", "* c #B8B8B8", "= c #B3B3B3", "- c #F1F1F1", "; c #F0F0F0", "> c #FDFDFD", ", c #C5C5C5", "' c #BDBDBD", ") c #AEAEAE", "! c #ECECEC", "~ c #EEEEEE", "{ c #EFEFEF", "] c #FBFBFB", "^ c #C3C3C3", "/ c #AFAFAF", "( c #EBEBEB", "_ c #EDEDED", ": c #FAFAFA", "< c #C2C2C2", "[ c #C0C0C0", "} c #EAEAEA", "| c #F9F9F9", "1 c #BFBFBF", "2 c #B0B0B0", "3 c #E9E9E9", "4 c #F8F8F8", "5 c #F7F7F7", "6 c #C1C1C1", "7 c #E8E8E8", "8 c #F6F6F6", "9 c #E7E7E7", "0 c #E6E6E6", "a c #F3F3F3", "b c #E5E5E5", "c c #E4E4E4", "d c #E3E3E3", "e c #E2E2E2", "f c #BEBEBE", "g c #E1E1E1", "h c #ABABAB", "i c #161616", "j c #E0E0E0", "k c #AAAAAA", "l c #DFDFDF", "m c #A9A9A9", "n c #DEDEDE", "o c #DCDCDC", "p c #DDDDDD", "q c #BBBBBB", "r c #DBDBDB", "s c #A8A8A8", "t c #A7A7A7", "u c #A6A6A6", "v c #DADADA", "w c #D8D8D8", "x c #D9D9D9", "y c #B9B9B9", "z c #D6D6D6", "A c #D7D7D7", "B c #7C7C7C", "C c #434343", "D c #373737", "E c #444444", "F c #CDCDCD", "G c #C8C8C8", "H c #C9C9C9", "I c #CACACA", "J c #C4C4C4", "K c #D2D2D2", "L c #B4B4B4", "M c #CCCCCC", "N c #C7C7C7", "O c #3B3B3B", "P c #3C3C3C", "Q c #CFCFCF", "R c #B1B1B1", "S c #C6C6C6", "T c #BCBCBC", "U c #363636", "V c #D0D0D0", "W c #B7B7B7", "X c #2E2E2E", "Y c #B2B2B2", "Z c #2A2A2A", "` c #252525", " . c #CBCBCB", ".. c #212121", "+. c #9F9F9F", "@. c #1D1D1D", "#. c #1E1E1E", "$. c #979797", "%. c #1A1A1A", "&. c #1B1B1B", "*. c #989898", "=. c #CECECE", "-. c #8F8F8F", ";. c #181818", ">. c #868686", ",. c #171717", "'. c #7D7D7D", "). c #727272", "!. c #737373", "~. c #313131", "{. c #333333", "]. c #494949", "^. c #555555", "/. c #535353", "(. c #525252", "_. c #3F3F3F", ":. c #6C6C6C", "<. c #484848", "[. c #545454", "}. c #515151", "|. c #464646", "1. c #323232", "2. c #717171", "3. c #A1A1A1", "4. c #A0A0A0", "5. c #A2A2A2", " . . . . . . . . . . . . . . . . . . . . ", " + @ # # # # # # # # # # $ # # $ # # $ # # # # $ $ $ # $ # $ # $ # # # # # # $ $ $ $ # # # # $ # # # # # $ # # . . ", " % & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & * = ", "= - - ; ; ; - - ; ; ; ; ; ; ; ; ; - - ; - ; - ; ; ; - - - ; - - - - ; ; ; ; ; - - - ; ; ; ; - - ; ; - ; ; ; ; - ; > , ' ", ") ! ; ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ { ~ ~ { ~ ~ ~ ~ ~ ~ { ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ] ^ ' ", "/ ( ~ _ _ _ _ _ _ _ _ _ _ ~ ~ _ ~ _ _ _ _ _ _ _ _ _ _ ~ _ _ _ _ _ _ _ _ ~ ~ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ : < [ ", "/ } ~ _ _ ! _ ! ! _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! ! ! _ _ _ _ _ _ _ _ _ ! _ _ _ _ _ _ _ _ _ _ _ _ ! _ _ _ _ _ | < 1 ", "2 3 ! ( ( ( ( ( ( ( ! ( ( ! ! ( ( ( ( ( ! ( ( ! ( ( ( ( ( ( ( ( ( ! ( ( ( ( ( ( ( ( ( ! ( ( ( ( ( ( ! ! ( ( ! ( ( 4 < 1 ", "/ 3 ( } } ( } ( } } } } ( ( } } } } } ( } } } } ( } } } ( ( } } } } } } } } } } } } ( } } } } ( } } } } } ( ( } } 5 6 1 ", "/ 7 } 3 3 3 } } 3 3 3 3 } } 3 3 3 3 3 } 3 3 } 3 3 3 3 3 3 3 3 } } 3 3 } 3 3 3 3 3 3 3 3 3 3 3 } 3 3 3 3 3 } } 3 3 8 6 1 ", "/ 9 } 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 7 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 7 3 3 3 3 3 3 3 3 3 8 6 1 ", "2 0 9 0 7 9 9 9 7 0 9 9 9 9 7 9 9 7 9 9 7 9 9 7 0 7 7 7 9 9 7 7 0 7 7 9 7 7 7 9 9 7 9 9 9 7 7 9 7 9 9 9 7 7 9 9 9 a [ [ ", "/ b 9 0 9 0 0 0 0 9 0 0 0 0 9 0 0 9 0 0 0 0 0 9 9 9 9 0 9 0 0 0 0 0 9 0 0 0 9 0 0 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 % 1 1 ", "/ c b b b b b b 0 b b b b 0 b b b 0 b b b b b b b b b b b b b b b b b b b b b b b b b 0 b b b b b b b b b b b b b % 1 [ ", "2 d c c c c c c c c c c c c c c c c c c c c c c c c c c d c c c c c c c c c c c c c c c c c d c c c c c c c c c c ; 1 [ ", "/ d c c c c c d c c c c d d d c c e c c c c c c d d d c d c c c d d c c c c c d c c c c d c c c c c c c c d d c c ~ f [ ", "2 e d d d d e e d d d e e d e e d e d d e d d e e e e e e d d e d d d e e e d d d e e d e e e d d e e d d d e e e ~ f 6 ", "/ g g e g g g g g g g g g e g g g e e g g g g e h i i i i i i i i i i i i h g e g g g g g g e e e g g e e e g e e _ ' 6 ", "/ j j g j j j j j j j j g j j j j j j j j j j j k i i i i i i i i i i i i k j j j g j j j g j j g g j j j j j j j ( ' 6 ", "2 l l l l l l j l l j l l l l l l l l l l l l l m i i i i i i i i i i i i m l l l j l l l l l l l l l l l l l l l } ' 6 ", "/ l l l l l l l l l n l l l l l l l l l l l l l m i i i i i i i i i i i i m l l l n l l l l l l l l l n l l l l l 3 ' 6 ", "2 n o n n n p p p n p n n n p n n n p n n n n n m i i i i i i i i i i i i m n n p n n p n n n n p p p p p p p p n 7 q 6 ", "2 p r o p o p p p p o o o o p p p o o p p o o o s i i i i i i i i i i i i t o o p p p p p p o o p p o p p p o o p 9 q < ", "/ o r r r r o o o r r r r r o o r r r r r r o o u i i i i i i i i i i i i u r r o r r o r o r r r o r o o o r r r 0 q < ", "2 r v r r r r r r r r r r r r r r r r r r r r r u i i i i i i i i i i i i u r r r r r r r r r r r r r r r r r r r c q < ", "/ v w x x x v v x x v v v v x v v v v v v x x x u i i i i i i i i i i i i + x x x x v v v v x w x x v v x x x x x d q < ", "2 v x x w w x x w x x x x x x x x x x x x x x w + i i i i i i i i i i i i + x x x v x x x v w x x x x x w x x w w d y < ", "2 x z A A A A z A w w z z A A A z z B C C C C C D i i i i i i i i i i i i D E C C C C B A A A A A A w z z w A z A j y ^ ", "2 F G H H I I H I I I I I I I I I I J C i i i i i i i i i i i i i i i i i i i i i i C J I I I I I I I H I I I I I K L , ", "2 M , N G H N N H N N H G N H N H H G f O i i i i i i i i i i i i i i i i i i i i P 1 G H G N G G G N N G G G G G Q = J ", "R M S H H G H H G G H H H G G H G G G G T U i i i i i i i i i i i i i i i i i i U q G H H G G H G H H G G H G G H V = , ", "R M , H G G H H G G G G H H G G H H G H H W X i i i i i i i i i i i i i i i i X W H G G G G H H G G H H H G G H H V = , ", "R M , G G H G H G G G G G H G G H G G H H G Y Z i i i i i i i i i i i i i i Z = H G G G H H H H G H H G G H H H H V = J ", "R M S G H G H G H H G H G H G H H G H H H G H ` i i i i i i i i i i i i ` H H G H H H G G H H H H G H H H H H V = , ", "2 .J N G N N G N N N N N N N G G N G G N N G N + ..i i i i i i i i i i ..u N N N N G G N N N N G G N N G N G N N Q Y , ", "2 .J N N N N N N G N N N N N N N G N N N N G N N +.@.i i i i i i i i #.+.N N G G N N N N N N N N N N N N N G G N Q = , ", "R M , N G N N N N N N N G G N G G N G N N N N N N G $.%.i i i i i i &.*.G N N N N N N G N N N G N N N G G G N N G =.= , ", "R .J N N N N N G G N N N N N N N N N N G N G N N N N -.;.i i i i ;.-.N N N N G G N N N N N G N N N N N G N N N N =.= , ", "2 ., N N N N N N N N N N G G N N N N G G G N N N N N N >.,.i i ,.>.G G N N N G N N N N N N N G G G N N G N N N N Q = , ", "2 .J N N N N N N N N N N N N N N N N N N N N N N N N N N '.i i '.N N N N N N N N N N N N N N N N N N N N N N N N =.Y , ", "2 I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S ).!.S S S S S S S S S S S S S S S S S S S S S S S S S F Y S ", "R I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "2 I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "2 I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "R I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "2 I ^ S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S F Y , ", "2 H < , , J , , , , , , , , J ~.~.~.{.].^./.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.^.(._.~.~.D :.^ , , , , , , , M Y , ", "R H < , , , J , , , , , , J , ~.~.~.{.<.[.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.(.}.|.O 1.D 2.J , , , , , , , M Y , ", "2 H < , , J , , , , , , , , , ~.~.~.{.<.[.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.}.(.}.|.O 1.D 2., , , , , , J , M R S ", "2 H < , , , , J J , , J , , , , , , , , , , , J , , , , , , , , , , , , , , , , , , , , , , , , , J , , , , , , , .R S ", "2 G < , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , J J , , , , , , , , J J , , , , , , , , , , , , M Y , ", "R H [ J J ^ J J J J J ^ J J J J J J J J J J J ^ J J J J J J J J J , , ^ J J J J J J J , , J J J J J J J J J J ^ J .R , ", "2 H < , , J , , , , , , , , , , , , , , , , , J J , , , J , , , , , , , , , J , , , , , , J J , , , , , , , , J , M Y J ", "2 H < , , , , J J , , J , , , , , , , , , , , J , , , , , , , , , , , , , , , , , , , , , , , , , J , , , , , , , .Y < ", "2 G < , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , J J , , , , , , , , J J , , , , , , , , , , , , M Y T ", "2 H [ J J ^ J J J J J ^ J J J J J J J J J J J ^ J J J J J J J J J , , ^ J J J J J J J , , J J J J J J J J J J ^ J . = ", "2 H q [ [ [ [ [ [ 1 [ [ 1 [ [ 1 [ [ 1 [ [ [ 1 [ 1 [ [ [ [ [ [ [ 1 [ [ [ [ [ 1 [ 1 [ [ [ [ [ [ 1 1 1 [ [ 1 [ 1 [ [ , ) ", "2 H g l n n l n n l l l l n n l l n n n l n n l n n n l l n l n n n n l l n n n l n n l l l l n l l n n n l n l l _ ", "2 m 3.3.3.3.3.3.3.4.3.4.4.4.3.4.3.5.3.3.3.3.3.3.3.3.4.3.4.3.3.3.3.4.4.3.4.3.4.4.3.4.3.3.4.3.3.3.3.3.3.4.4.4.4.3. ", "2 2 2 . . . . . . . . . . . . . . . . . "}; return Image end function ImageTopRight(pic) if (pic == nil) then pic = '0' end if pic == '0' then Image = { "60 60 288 2", " c None", ". c #9F9F9F", "+ c #9B9B9B", "@ c #979797", "# c #939393", "$ c #929292", "% c #919191", "& c #909090", "* c #8F8F8F", "= c #8E8E8E", "- c #989898", "; c #EDEDED", "> c #E5E5E5", ", c #E3E3E3", "' c #E6E6E6", ") c #E7E7E7", "! c #EBEBEB", "~ c #ECECEC", "{ c #F0F0F0", "] c #F1F1F1", "^ c #F2F2F2", "/ c #F5F5F5", "( c #F4F4F4", "_ c #F9F9F9", ": c #F8F8F8", "< c #FAFAFA", "[ c #FBFBFB", "} c #FDFDFD", "| c #FFFFFF", "1 c #DADADA", "2 c #D9D9D9", "3 c #DBDBDB", "4 c #DEDEDE", "5 c #DFDFDF", "6 c #E1E1E1", "7 c #E2E2E2", "8 c #E4E4E4", "9 c #E9E9E9", "0 c #E8E8E8", "a c #EAEAEA", "b c #8C8C8C", "c c #DDDDDD", "d c #E0E0E0", "e c #000000", "f c #DCDCDC", "g c #EEEEEE", "h c #161616", "i c #898989", "j c #4E4E4E", "k c #0A0A0A", "l c #F3F3F3", "m c #606060", "n c #111111", "o c #EFEFEF", "p c #535353", "q c #555555", "r c #878787", "s c #4A4A4A", "t c #010101", "u c #121212", "v c #3F3F3F", "w c #020202", "x c #414141", "y c #343434", "z c #030303", "A c #131313", "B c #363636", "C c #2D2D2D", "D c #040404", "E c #2C2C2C", "F c #949494", "G c #232323", "H c #060606", "I c #272727", "J c #969696", "K c #C5C5C5", "L c #CBCBCB", "M c #D3D3D3", "N c #D7D7D7", "O c #D8D8D8", "P c #1A1A1A", "Q c #C6C6C6", "R c #CCCCCC", "S c #D2D2D2", "T c #D5D5D5", "U c #D6D6D6", "V c #222222", "W c #C7C7C7", "X c #D1D1D1", "Y c #D4D4D4", "Z c #CACACA", "` c #CFCFCF", " . c #BABABA", ".. c #838383", "+. c #6B6B6B", "@. c #636363", "#. c #646464", "$. c #5F5F5F", "%. c #5E5E5E", "&. c #5A5A5A", "*. c #585858", "=. c #545454", "-. c #515151", ";. c #4C4C4C", ">. c #474747", ",. c #424242", "'. c #3E3E3E", "). c #393939", "!. c #303030", "~. c #2A2A2A", "{. c #282828", "]. c #252525", "^. c #AEAEAE", "/. c #D0D0D0", "(. c #9E9E9E", "_. c #686868", ":. c #717171", "<. c #757575", "[. c #747474", "}. c #737373", "|. c #727272", "1. c #707070", "2. c #6E6E6E", "3. c #6C6C6C", "4. c #696969", "5. c #666666", "6. c #626262", "7. c #505050", "8. c #4B4B4B", "9. c #484848", "0. c #464646", "a. c #444444", "b. c #292929", "c. c #7F7F7F", "d. c #888888", "e. c #777777", "f. c #767676", "g. c #676767", "h. c #656565", "i. c #616161", "j. c #5D5D5D", "k. c #595959", "l. c #494949", "m. c #404040", "n. c #3A3A3A", "o. c #ACACAC", "p. c #6F6F6F", "q. c #6D6D6D", "r. c #5D5B58", "s. c #5C564E", "t. c #5C5043", "u. c #594B3B", "v. c #544638", "w. c #4E453B", "x. c #494540", "y. c #454443", "z. c #434343", "A. c #353535", "B. c #6A6A6A", "C. c #636362", "D. c #645D56", "E. c #675644", "F. c #3D5F84", "G. c #2266B2", "H. c #156BCA", "I. c #146BCB", "J. c #285A91", "K. c #464441", "L. c #4A3F31", "M. c #43403C", "N. c #3C3C3C", "O. c #656463", "P. c #696056", "Q. c #5E5C59", "R. c #0871E5", "S. c #007AFF", "T. c #0079FF", "U. c #0078FF", "V. c #007BFF", "W. c #007FFF", "X. c #245892", "Y. c #483A2A", "Z. c #413E3A", "`. c #69635B", " + c #605E5B", ".+ c #0077FF", "++ c #0076FA", "@+ c #0176F8", "#+ c #0077FE", "$+ c #007DFF", "%+ c #245690", "&+ c #44392C", "*+ c #3F3E3D", "=+ c #242424", "-+ c #676462", ";+ c #6E5D4A", ">+ c #0971E5", ",+ c #0078FE", "'+ c #403C37", ")+ c #433D36", "!+ c #676059", "~+ c #42648A", "{+ c #1068C9", "]+ c #493C2E", "^+ c #FEFEFE", "/+ c #575757", "(+ c #5B5B5B", "_+ c #6A5D4F", ":+ c #2769B4", "<+ c #0077FD", "[+ c #4F3B26", "}+ c #454545", "|+ c #4D4D4D", "1+ c #685948", "2+ c #0771E7", "3+ c #0076F9", "4+ c #523C24", "5+ c #FCFCFC", "6+ c #5C5C5C", "7+ c #635545", "8+ c #166CCD", "9+ c #554029", "0+ c #090909", "a+ c #5B5247", "b+ c #2E5F97", "c+ c #0770E4", "d+ c #564532", "e+ c #333333", "f+ c #55514C", "g+ c #4E4C49", "h+ c #007EFF", "i+ c #2B5F98", "j+ c #564C42", "k+ c #525252", "l+ c #383838", "m+ c #4F4F4F", "n+ c #4D4C4B", "o+ c #514538", "p+ c #265A93", "q+ c #0870E5", "r+ c #5E4D39", "s+ c #56524F", "t+ c #1B1B1B", "u+ c #050505", "v+ c #484441", "w+ c #493B2B", "x+ c #21558E", "y+ c #0771E6", "z+ c #5D564E", "A+ c #3D3D3D", "B+ c #3E3B37", "C+ c #493D30", "D+ c #47433E", "E+ c #116ACB", "F+ c #0076FD", "G+ c #007CFF", "H+ c #30649C", "I+ c #655340", "J+ c #605951", "K+ c #5C5B5B", "L+ c #474645", "M+ c #4F4942", "N+ c #56493B", "O+ c #5F4B36", "P+ c #624C34", "Q+ c #655039", "R+ c #665542", "S+ c #63594F", "T+ c #605D59", "U+ c #313131", "V+ c #565656", "W+ c #373737", "X+ c #F7F7F7", "Y+ c #2B2B2B", "Z+ c #262626", "`+ c #828282", " @ c #BBBBBB", ".@ c #CECECE", "+@ c #ADADAD", "@@ c #848484", "#@ c #C9C9C9", "$@ c #999999", "%@ c #C0C0C0", "&@ c #CDCDCD", "*@ c #C3C3C3", "=@ c #C8C8C8", "-@ c #9D9D9D", ";@ c #8D8D8D", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ", ". + @ # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # $ $ $ $ $ % % % % % & & & & * * * * = # - . ", ". @ ; > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > , > ' ' ) ! ! ~ ; { ] ] ^ / ( _ : < [ } } | | | $ . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 3 1 3 4 5 4 6 7 , 8 , 8 > > 9 0 9 a ; ~ ; ; | b . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 1 ) ( | | | | | | | ( ) 1 1 1 1 1 1 1 1 2 3 1 c 4 5 4 5 d , 8 , 8 ) 0 9 0 9 a ; ~ ; ; | b . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 3 d e e e e e e e e e d 3 1 1 1 1 1 1 1 2 3 1 3 4 5 4 d d , 8 , 8 > ' 9 0 ! a ! ~ ; ; | b . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 f g e h h h h h h h e g f 1 1 1 1 1 1 1 2 3 f c f 5 4 5 d 6 8 , > ' ' 9 a 9 a ; ~ ; g | b . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 f g e h h h h h h h e g f 1 1 1 1 1 1 1 2 3 f c f 5 d 5 d 6 7 , 8 > ' 9 a ! a ! ~ ; g | i . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 f g e h h h h h h h e g f 1 1 1 1 1 1 1 2 3 f c f 5 4 5 d , 8 , ' > 0 9 0 9 a ! ~ ; ; | i . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 f g e h h h h h h h e g f 1 1 1 1 1 1 1 2 3 1 c 4 5 4 5 d , 8 , 8 ) > 9 0 9 a ; ~ ; ; | i . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 f g e h h h h h h h e g f 1 1 1 1 1 1 1 2 3 1 3 f c d 5 d , 8 , 8 ' ' 9 0 9 ~ ; ~ ; ; | i . ", ". # > 1 1 1 1 1 1 1 d ; < | | | e h h h h h h h e | | | < ; d 1 1 1 2 3 1 3 4 5 4 5 d 6 8 , > ' ' 9 0 9 a ; ~ ; ; | i . ", ". # > 1 1 1 1 1 1 1 d j e e e e k h h h h h h h k e e e e j d 1 1 1 2 3 1 3 4 5 4 6 d 6 7 , 8 > ' 9 a ! a ; ~ ; ; | i . ", ". # > 1 1 1 1 1 1 1 d l m e n h h h h h h h h h h h n e m / d 1 1 1 2 3 1 3 4 5 4 5 7 , 7 , ' > ' 9 a ! ~ ; g o ; | i . ", ". # > 1 1 1 1 1 1 1 1 6 ( p e n h h h h h h h h h n e q ( 6 1 1 1 1 2 3 f c f 5 4 5 d 6 7 , 8 ) 0 9 0 9 ~ ; g o ; | r . ", ". # > 1 1 1 1 1 1 1 1 1 7 ( s t u h h h h h h h u t s ( 7 1 1 1 1 1 2 3 f c 4 5 4 d d 6 8 , 8 > ' 9 0 9 a ; ~ ; ; | i . ", ". # > 1 1 1 1 1 1 1 1 1 1 7 ] v w u h h h h h u w x ] 7 1 1 1 1 1 1 2 3 1 c 4 5 4 5 d , 8 , 8 > ' 9 0 a a ; g o ; | i . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 , o y z A h h h A z B o , 1 1 1 1 1 1 1 2 3 1 3 4 5 4 5 7 6 6 , ' ) 0 9 0 a a ; ~ ; g | r . ", ". # > 1 1 1 1 1 1 1 1 1 1 1 1 8 ~ C D A h A D E ; 8 1 1 1 1 1 1 1 1 2 3 1 3 f 5 4 5 7 , 8 , 8 > ' 9 0 9 a ; ~ ; g | i . ", ". F ) f 3 1 1 1 1 1 1 1 1 1 1 3 > 9 G H u H I 9 > 1 1 1 1 1 1 1 1 1 1 3 3 c 4 5 4 5 d , 8 , > > ' 9 a ! a ; ~ o ; | i . ", ". J K L M N O O O O O O O O O O O 8 7 P e P 6 8 O O O O O O O O O N 2 O 1 1 c c 4 d d 6 8 , > > 0 9 0 9 ~ ; ~ ; g | r . ", ". - Q R S T U U U U U U U U U U U N , N V 2 , N U U U U U U U U U T N U N 1 f 4 5 d d , 8 , > > ' 9 0 9 a ; ~ ; ; | i . ", ". - W L X M Y Y Y Y Y Y Y Y Y Y Y Y T 4 5 4 T Y Y Y Y Y Y Y Y Y Y M M Y T N 3 c 5 5 d , 8 , 8 > ' ) a 9 a ; ~ ; g | i . ", ". - W Z ` S M N c 6 , , , 8 8 8 > > ' ' ) 0 9 9 a ! ! ~ ~ ; ; ! 8 3 Y S M U 1 3 5 5 7 6 8 , 8 ) 0 9 0 9 ~ ; ~ ; ; | i . ", ". - W Z ` Y 3 ...+.@.#.@.m $.%.&.*.=.-.;.>.,.'.).y !.E ~.{.].E =.^.6 U S T O 3 5 5 d 6 7 , 8 ) 8 9 0 ! a ; ~ ; ; | i . ", ". - W Z /.1 (._.:.<.<.[.}.}.|.1.2.3.4.5.6.%.*.=.7.j 8.9.0.a.x '.B b.c.6 Y Y 2 f 5 5 d 6 , 8 8 ) 0 9 0 9 a ; ~ ; ; | d.. ", ". - W Z Y .4.[.e.<.f.<.[.}.1.1.2.+.g.h.i.j.k.q -.;.l.0.a.,.,.x m.n.I o.3 Y N f 5 5 7 6 7 , 8 ) 0 9 0 a a ! ~ o g | d.. ", ". - W Z 1 ..1.<.f.f.<.}.|.|.:.p.q.+.5.#.m r.s.t.u.v.w.x.y.z.m.v m.'.A.p 8 T N f 5 6 7 6 8 8 8 > 0 9 0 9 a ! g ; g | d.. ", ". - W Z 4 4.[.f.[.<.}.|.}.1.1.2.3.B.h.C.D.E.F.G.H.I.J.K.L.M.x m.'.'.N.~.! T N f 5 6 d 6 7 7 > ) ' 9 0 ! a ! ~ ; g | i . ", ". - W Z 5 @.[.<.}.[.|.}.|.p.p.q.+._.O.P.Q.R.S.T.U.T.V.W.X.Y.Z.'.'.'.v G ; T N f 5 5 d , 8 8 ~ ; ; 9 0 ! a ; ~ ; ; | r . ", ". - W Z d 6.[.|.}.}.|.1.p.p.3.3._.g.`. +S..+++@+@+@+@+#+$+%+&+*+m.v x =+; T N f 5 d d , 8 ! | -.} 9 0 9 a ; ~ ; g | i . ", ". - W Z d $.:.|.|.1.:.1.p.3.3.B.5.-+;+>+.+@+@+@+@+@+@+@+,+W.'+)+x ,.,.].; T N f 5 5 d 6 ~ | h.e | 9 a 9 a ; ~ ; g | r . ", ". - W Z 6 $.:.:.1.1.p.2.q.3.B._.h.!+~+T.++@+@+@+@+@+@+@+@+S.{+]+x ,.,.{.; Y N f 5 5 7 ~ ^+/+e e | 9 a 9 a ; ~ ; g | i . ", ". - W Z 6 (+p.q.2.2.q.3.+.4.5.h.@._+:+U.@+@+@+@+@+@+@+@+@+<+.+[+}+}+a.~.~ Y 2 f 5 d ~ [ |+e n e | ! ! ~ o { g g g | r . ", ". - W Z 6 *.3.3.3.+.B.4._.h.h.6.m 1+2+.+@+@+@+@+@+@+@+@+@+3+W.4+>.0.9.E ~ Y 2 f d a _ m.e n h e | ^+^+| | | ( 5+; | i . ", ". - W Z 7 q 4.4.4._.g.5.h.@.i.$.6+7+8+U.@+@+@+@+@+@+@+@+@+++W.9+s l.8.!.; Y 2 f ! l B w u h h 0+e e e e e e e | ; | i . ", ". - W Z , -.5.5.#.h.#.@.m m %.(+k.a+b+S.@+@+@+@+@+@+@+@+@+U.c+d+;.j |+e+~ Y 1 0 o C z u h h h h h h h h h h e | ; | i . ", ". - W Z , ;.6.6.6.i.m $.%.6+&./+p f+g+h+#+@+@+@+@+@+@+@+++S.i+j+-.7.k+l+! T ' ' =+D A h h h h h h h h h h h e | ; | i . ", ". - W Z 8 9.%.%.%.j.6+(+*.*.=.p m+n+o+p+$+,+@+@+@+@+@+++U.q+r+s+q =.=.N.! 5 3 t+u+A h h h h h h h h h h h h e | ; | i . ", ". - W Z > z.&.&.*./+*.q q k+-.m+;.l.v+w+x+W.S.<+3+++.+S.y+=.z+/+*.&.&.,.a d V e n h h h h h h h h h h h h h e | g | i . ", ". - W Z ' A+=.=.q p k+-.-.m+|+l.9.a.v B+C+D+E+F+G+G+c+H+I+J+K+j.%.%.%.>.9 5 c t+u+A h h h h h h h h h h h h e | g | d.. ", ". - W Z ) ).k+7.-.7.m+j |+8.l.}+z.m.'.,.L+M+N+O+P+Q+R+S+T+$.m i.6.6.6.;.) U ' ' I D A h h h h h h h h h h h e | g | d.. ", ". - W Z ) y |+j ;.8.s l.l.0.a.,.'.'.,.>.8.|+k+=.k.(+%.m m @.#.h.#.5.5.-.' Y O 0 o C z u h h h h h h h h h h e | ; | d.. ", ". - W Z 0 U+8.l.s l.9.>.0.a.x A+v ,.>.8.|+k+V+k.6+$.i.@.h.5.g._.4.4.4.=.> Y N f ! l W+t u h h 0+e e e e e e e | ; | d.. ", ". - W Z 0 C 9.0.>.}+a.z.z.m.A+v ,.}+s j k+V+*.j.m 6.h.h._.4.B.+.3.3.3.*.> Y 2 f 5 a X+,.e n h e | ^+^+| | | ( 5+; | i . ", ". - W Z 9 Y+a.}+}+a.z.,.v '.v z.0.9.|+-.q k.j.m @.h.5.4.+.3.q.2.2.q.p.&.8 Y 2 f 5 6 ! < j e n e | ! ! ~ ; { g g ; | i . ", ". - W Z 9 b.,.,.x ,.m.v '.v z.a.>.;.j =.*.&.$.i.h._.B.3.q.2.p.1.1.:.:.%.> Y 2 f 5 5 7 a | /+e e | 9 0 9 a ; ~ ; g | i . ", ". - W Z a Z+,.,.x v '.'.v x }+0.l.j k+V+&.%.m h.5.B.3.3.p.1.:.1.|.|.:.$.> Y 2 f 5 5 7 , ~ | h.e | ) a ! a ; ~ ; g | i . ", ". - W Z a ].x v m.'.'.v ,.a.}+l.8.7.=.*.6+m #.g._.3.3.p.p.1.|.}.}.|.[.i., Y 2 f 5 6 7 , 8 ! | k+} 9 0 9 a ; ~ ; ; | r . ", ". - W Z a G v '.'.'.v m.z.}+0.l.j 7.=.&.%.6.h._.+.q.p.p.|.}.|.[.}.<.[.6., Y N f 5 6 d 6 8 , ~ ; ; 9 0 9 a ; ~ ; ; | i . ", ". - W Z ) b.N.'.'.m.x x a.0.>.;.m+p /+(+$.@.h.B.3.2.1.1.}.|.}.<.[.f.[._.6 T N f 5 5 d 6 8 , > ' ' 9 0 9 ~ ; ~ ; g | i . ", ". - W Z 6 =.A.'.m.v m.z.}+>.9.8.m+=.*.6+m #.5.+.q.p.:.|.|.}.<.f.f.<.p.`+c T N f 5 5 7 , 8 , > > ' 9 0 9 ~ ! ~ ; ; | i . ", ". - W Z O o.I n.m.x ,.,.a.0.l.;.-.q k.j.i.h.g.+.2.1.1.}.[.<.f.<.e.[._. @N Y N f 5 5 7 , 8 , > > 0 9 0 9 a ; ~ ; ; | i . ", ". - W Z X 6 c.b.B '.x a.0.9.8.j 7.=.*.%.6.5.4.3.2.1.|.}.}.[.<.<.:._.(.3 M Y 2 f 5 5 7 , 7 , > > 0 9 a ! a ; ~ ; ; | i . ", ". - Q L .@T 6 +@q C Z+b.Y+C U+y ).'.z.9.;.-.q k.(+$.m i.@.h.#.3.@@ .1 Y S T O 3 5 5 d 6 7 , > > ' 9 a ! ~ ; ~ ; ; | r . ", ". - K #@R .@X O d ) 9 9 9 0 0 ) ' ' > 8 , , 7 6 6 6 d d d d 5 c 2 Y ` ` /.S U N d 5 7 6 8 , > ' ' 9 0 9 a ; ~ ; g | b . ", ". $@%@K #@L Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z Z L R &@/.` d c d 5 7 6 7 , 8 ' ' ) 0 a a ! ! | b . ", ". + @%@*@Q K K K K K K K K K K K K K K K K K K K K K K K K K K K K K W =@#@L L } [ ^+| | | | | | | | | | | | | | | $ . ", ". -@+ $@- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - @ @ @ F $ & * * * * = = = = ;@;@;@;@;@b b $ - . ", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . "}; elseif pic == '1' then Image = { --XpmImage Here }; end return Image end function ImageLeft(pic) local Image = { "60 60 143 2", " c #ACACAC", ". c #ADADAD", "+ c #A5A5A5", "@ c #9E9E9E", "# c #9D9D9D", "$ c #9C9C9C", "% c #F2F2F2", "& c #FFFFFF", "* c #B8B8B8", "= c #B3B3B3", "- c #F1F1F1", "; c #F0F0F0", "> c #FDFDFD", ", c #C5C5C5", "' c #BDBDBD", ") c #AEAEAE", "! c #ECECEC", "~ c #EEEEEE", "{ c #EFEFEF", "] c #FBFBFB", "^ c #C3C3C3", "/ c #AFAFAF", "( c #EBEBEB", "_ c #EDEDED", ": c #FAFAFA", "< c #C2C2C2", "[ c #C0C0C0", "} c #EAEAEA", "| c #F9F9F9", "1 c #BFBFBF", "2 c #B0B0B0", "3 c #E9E9E9", "4 c #F8F8F8", "5 c #F7F7F7", "6 c #C1C1C1", "7 c #E8E8E8", "8 c #F6F6F6", "9 c #E7E7E7", "0 c #E6E6E6", "a c #E5E5E5", "b c #F3F3F3", "c c #797979", "d c #808080", "e c #E4E4E4", "f c #383838", "g c #393939", "h c #E3E3E3", "i c #313131", "j c #323232", "k c #E2E2E2", "l c #3D3D3D", "m c #BEBEBE", "n c #424242", "o c #4B4B4B", "p c #E1E1E1", "q c #818181", "r c #DADADA", "s c #595959", "t c #585858", "u c #E0E0E0", "v c #464646", "w c #494949", "x c #D6D6D6", "y c #5B5B5B", "z c #DFDFDF", "A c #454545", "B c #161616", "C c #414141", "D c #D1D1D1", "E c #565656", "F c #DEDEDE", "G c #CCCCCC", "H c #DCDCDC", "I c #DDDDDD", "J c #BBBBBB", "K c #DBDBDB", "L c #2C2C2C", "M c #A6A6A6", "N c #A7A7A7", "O c #272727", "P c #B5B5B5", "Q c #575757", "R c #222222", "S c #D8D8D8", "T c #D9D9D9", "U c #1E1E1E", "V c #555555", "W c #1B1B1B", "X c #9B9B9B", "Y c #B9B9B9", "Z c #D7D7D7", "` c #181818", " . c #919191", ".. c #CDCDCD", "+. c #C8C8C8", "@. c #C9C9C9", "#. c #CACACA", "$. c #171717", "%. c #7F7F7F", "&. c #CBCBCB", "*. c #535353", "=. c #525252", "-. c #D2D2D2", ";. c #B4B4B4", ">. c #C7C7C7", ",. c #747474", "'. c #515151", "). c #CFCFCF", "!. c #C4C4C4", "~. c #B1B1B1", "{. c #C6C6C6", "]. c #737373", "^. c #D0D0D0", "/. c #888888", "(. c #1A1A1A", "_. c #909090", ":. c #1D1D1D", "<. c #969696", "[. c #B2B2B2", "}. c #212121", "|. c #9F9F9F", "1. c #989898", "2. c #999999", "3. c #353535", "4. c #252525", "5. c #CECECE", "6. c #404040", "7. c #292929", "8. c #ABABAB", "9. c #2E2E2E", "0. c #B6B6B6", "a. c #3F3F3F", "b. c #3B3B3B", "c. c #BABABA", "d. c #545454", "e. c #4A4A4A", "f. c #484848", "g. c #333333", "h. c #BCBCBC", "i. c #A9A9A9", "j. c #A1A1A1", "k. c #A0A0A0", "l. c #A2A2A2", " . . . . . . . . . . . . . . . . . . . . ", " + @ # # # # # # # # # # $ # # $ # # $ # # # # $ $ $ # $ # $ # $ # # # # # # $ $ $ $ # # # # $ # # # # # $ # # . . ", " % & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & * = ", "= - - ; ; ; - - ; ; ; ; ; ; ; ; ; - - ; - ; - ; ; ; - - - ; - - - - ; ; ; ; ; - - - ; ; ; ; - - ; ; - ; ; ; ; - ; > , ' ", ") ! ; ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ { ~ ~ { ~ ~ ~ ~ ~ ~ { ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ] ^ ' ", "/ ( ~ _ _ _ _ _ _ _ _ _ _ ~ ~ _ ~ _ _ _ _ _ _ _ _ _ _ ~ _ _ _ _ _ _ _ _ ~ ~ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ : < [ ", "/ } ~ _ _ ! _ ! ! _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! ! ! _ _ _ _ _ _ _ _ _ ! _ _ _ _ _ _ _ _ _ _ _ _ ! _ _ _ _ _ | < 1 ", "2 3 ! ( ( ( ( ( ( ( ! ( ( ! ! ( ( ( ( ( ! ( ( ! ( ( ( ( ( ( ( ( ( ! ( ( ( ( ( ( ( ( ( ! ( ( ( ( ( ( ! ! ( ( ! ( ( 4 < 1 ", "/ 3 ( } } ( } ( } } } } ( ( } } } } } ( } } } } ( } } } ( ( } } } } } } } } } } } } ( } } } } ( } } } } } ( ( } } 5 6 1 ", "/ 7 } 3 3 3 } } 3 3 3 3 } } 3 3 3 3 3 } 3 3 } 3 3 3 3 3 3 3 3 } } 3 3 } 3 3 3 3 3 3 3 3 3 3 3 } 3 3 3 3 3 } } 3 3 8 6 1 ", "/ 9 } 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 7 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 7 3 3 3 3 3 3 3 3 3 8 6 1 ", "2 0 9 0 7 9 9 9 7 0 9 9 9 9 7 9 9 7 9 9 7 9 9 7 0 7 7 7 9 9 7 7 0 7 7 9 7 7 7 9 9 7 9 9 9 7 7 9 a 0 9 9 7 7 9 9 9 b [ [ ", "/ a 9 0 9 0 0 0 0 9 0 0 0 0 9 0 0 9 0 0 0 0 0 9 9 9 9 0 9 0 0 0 0 0 9 0 0 0 9 0 0 9 0 0 0 0 0 0 c d d 0 0 0 0 0 0 % 1 1 ", "/ e a a a a a a 0 a a a a 0 a a a 0 a a a a a a a a a a a a a a a a a a a a a a a a a 0 a a a a f g g a a a a a a % 1 [ ", "2 h e e e e e e e e e e e e e e e e e e e e e e e e e e h e e e e e e e e e e e e e e e e e h e i j j e e e e e e ; 1 [ ", "/ h e e e e e h e e e e h h h e e k e e e e e e h h h e h e e e h h e e e e e h e e e e h e e e i l l e e h h e e ~ m [ ", "2 k h h h h k k h h h k k h k k h k h h k h h k k k k k k h h k h h h k k k h h h k k h k k k h n o o h h h k k k ~ m 6 ", "/ p p k p p p p p p p p p k p p p k k p p p p k p p k k p q r p k k k k p p p k p p p p p p k k s t t k k k p k k _ ' 6 ", "/ u u p u u u u u u u u p u u u u u u u u u u u u u u p p v w x u u u u u u u u u p u u u p u u y s s u u u u u u ( ' 6 ", "2 z z z z z z u z z u z z z z z z z z z z z z z z z z z z A B C D z z z z z z z z u z z z z z z t E E z z z z z z } ' 6 ", "/ z z z z z z z z z F z z z z z z z z z z z z z z z F z z A B B g G z F z z z z z F z z z z z z t E E F z z z z z 3 ' 6 ", "2 F H F F F I I I F I F F F I F F F I F F F F F F F I I I A B B B i , I F F F F I F F I F F F F t E E I I I I I F 7 J 6 ", "2 I K H I H I I I I H H H H I I I H H I I H H H I I I I H A B B B B L m H H H H I I I I I I H H t E E I I I H H I 9 J < ", "/ H K K K K H H H K K K K K H H K K K M M M N N M M N N M f B B B B B O P K K K H K K H K H K K Q E E H H H K K K 0 J < ", "2 K r K K K K K K K K K K K K K K K K B B B B B B B B B B B B B B B B B R ) K K K K K K K K K K Q E E K K K K K K e J < ", "/ r S T T T r r T T r r r r T r r r r B B B B B B B B B B B B B B B B B B U + T T T r r r r T S Q V V r T T T T T h J < ", "2 r T T S S T T S T T T T T T T T T T B B B B B B B B B B B B B B B B B B B W X T r T T T r S T Q V V T S T T S S h Y < ", "2 T x Z Z Z Z x Z S S x x Z Z Z x x Z B B B B B B B B B B B B B B B B B B B B ` .Z x Z Z Z Z Z E V V x x S Z x Z u Y ^ ", "2 ..+.@.@.#.#.@.#.#.#.#.#.#.#.#.#.#.#.B B B B B B B B B B B B B B B B B B B B B $.%.&.#.#.#.#.#.*.=.=.@.#.#.#.#.#.-.;., ", "2 G , >.+.@.>.>.@.>.>.@.+.>.@.>.@.@.+.B B B B B B B B B B B B B B B B B B B B B B B ,.+.@.+.>.+.*.'.'.>.+.+.+.+.+.).= !.", "~.G {.@.@.+.@.@.+.+.@.@.@.+.+.@.+.+.+.B B B B B B B B B B B B B B B B B B B B B B B ].@.@.+.+.@.*.=.=.+.+.@.+.+.@.^.= , ", "~.G , @.+.+.@.@.+.+.+.+.@.@.+.+.@.@.+.B B B B B B B B B B B B B B B B B B B B B $.%.+.+.+.+.@.@.*.'.=.@.@.+.+.@.@.^.= , ", "~.G , +.+.@.+.@.+.+.+.+.+.@.+.+.@.+.+.B B B B B B B B B B B B B B B B B B B B ` /.+.+.+.@.@.@.@.*.=.=.+.+.@.@.@.@.^.= !.", "~.G {.+.@.+.@.+.@.@.+.@.+.@.+.@.@.+.@.B B B B B B B B B B B B B B B B B B B (._.@.+.@.@.@.+.+.@.*.=.=.+.@.@.@.@.@.^.= , ", "2 &.!.>.+.>.>.+.>.>.>.>.>.>.>.+.+.>.+.B B B B B B B B B B B B B B B B B B :.<.>.>.>.+.+.>.>.>.>.*.'.'.>.+.>.+.>.>.).[., ", "2 &.!.>.>.>.>.>.>.+.>.>.>.>.>.>.>.+.>.B B B B B B B B B B B B B B B B B }.|.>.+.+.>.>.>.>.>.>.>.*.'.'.>.>.>.+.+.>.).= , ", "~.G , >.+.>.>.>.>.>.>.>.+.+.>.+.+.>.+.1.1.1.1.1.1.2.2.1.1.3.B B B B B 4.M >.>.>.>.>.>.+.>.>.>.+.*.'.'.+.+.+.>.>.+.5.= , ", "~.&.!.>.>.>.>.>.+.+.>.>.>.>.>.>.>.>.>.>.+.>.+.>.>.>.>.>.>.6.B B B B 7.8.>.>.>.+.+.>.>.>.>.>.+.>.*.'.'.>.+.>.>.>.>.5.= , ", "2 &., >.>.>.>.>.>.>.>.>.>.+.+.>.>.>.>.+.+.+.>.>.>.>.>.>.>.6.B B B 9.[.+.>.>.>.+.>.>.>.>.>.>.>.+.*.'.'.>.+.>.>.>.>.).= , ", "2 &.!.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.6.B B 3.0.>.>.>.>.>.>.>.>.>.>.>.>.>.>.*.=.=.>.>.>.>.>.>.5.[., ", "2 #.^ {.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.a.B b.c.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.V d.d.{.{.{.{.{.{...[.{.", "~.#.^ {.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.a.n ' {.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.e.f.f.{.{.{.{.{.{...[., ", "2 #.^ {.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.].[ {.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.g.g.g.{.{.{.{.{.{...[., ", "2 #.^ {.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.i i i {.{.{.{.{.{...[., ", "~.#.^ {.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.i i i {.{.{.{.{.{...[., ", "2 #.^ {.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.{.i i i {.{.{.{.{.{...[., ", "2 @.< , , !., , , , , , , , !.!.!., , !., , !., , , , , , , !., !., !., !.!., , , !., , , , !., , , , , , , , , , G [., ", "~.@.< , , , !., , , , , , !., , !., , , , , , , , !.!.!., , , , , , , , , , , , !., !.!.!.!., !., , , , , , , , , G [., ", "2 @.< , , !., , , , , , , , , , , , , , , , , !.!., , , !., , , , , , , , , !., , , , , , !.!., , , , , , , , !., G ~.{.", "2 @.< , , , , !.!., , !., , , , , , , , , , , !., , , , , , , , , , , , , , , , , , , , , , , , , !., , , , , , , &.~.{.", "2 +.< , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , !.!., , , , , , , , !.!., , , , , , , , , , , , G [., ", "~.@.[ !.!.^ !.!.!.!.!.^ !.!.!.!.!.!.!.!.!.!.!.^ !.!.!.!.!.!.!.!.!., , ^ !.!.!.!.!.!.!., , !.!.!.!.!.!.!.!.!.!.^ !.&.~., ", "2 @.< , , !., , , , , , , , , , , , , , , , , !.!., , , !., , , , , , , , , !., , , , , , !.!., , , , , , , , !., G [.!.", "2 @.< , , , , !.!., , !., , , , , , , , , , , !., , , , , , , , , , , , , , , , , , , , , , , , , !., , , , , , , &.[.< ", "2 +.< , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , !.!., , , , , , , , !.!., , , , , , , , , , , , G [.h.", "2 @.[ !.!.^ !.!.!.!.!.^ !.!.!.!.!.!.!.!.!.!.!.^ !.!.!.!.!.!.!.!.!., , ^ !.!.!.!.!.!.!., , !.!.!.!.!.!.!.!.!.!.^ !.&. = ", "2 @.J [ [ [ [ [ [ 1 [ [ 1 [ [ 1 [ [ 1 [ [ [ 1 [ 1 [ [ [ [ [ [ [ 1 [ [ [ [ [ 1 [ 1 [ [ [ [ [ [ 1 1 1 [ [ 1 [ 1 [ [ , ) ", "2 @.p z F F z F F z z z z F F z z F F F z F F z F F F z z F z F F F F z z F F F z F F z z z z F z z F F F z F z z _ ", "2 i.j.j.j.j.j.j.j.k.j.k.k.k.j.k.j.l.j.j.j.j.j.j.j.j.k.j.k.j.j.j.j.k.k.j.k.j.k.k.j.k.j.j.k.j.j.j.j.j.j.k.k.k.k.j. ", "2 2 2 . . . . . . . . . . . . . . . . . "}; return Image end function ImageCenter(pic) if (pic == nil) then pic = '0' end if pic == '0' then Image = { "60 60 240 2", " c #9F9F9F", ". c #9D9D9D", "+ c #9C9C9C", "@ c #FFFFFF", "# c #F1F1F1", "$ c #242424", "% c #2C2C2C", "& c #2B2B2B", "* c #2A2A2A", "= c #292929", "- c #282828", "; c #323232", "> c #383838", ", c #363636", "' c #2F2F2F", ") c #2D2D2D", "! c #1A1A1A", "~ c #181818", "{ c #191919", "] c #2E2E2E", "^ c #353535", "/ c #3A3A3A", "( c #303030", "_ c #252525", ": c #FDFDFD", "< c #F0F0F0", "[ c #D2D2D2", "} c #D1D1D1", "| c #CFCFCF", "1 c #CDCDCD", "2 c #CACACA", "3 c #C5C5C5", "4 c #BFBFBF", "5 c #B8B8B8", "6 c #B1B1B1", "7 c #AFAFAF", "8 c #B3B3B3", "9 c #B7B7B7", "0 c #BABABA", "a c #BDBDBD", "b c #BEBEBE", "c c #B9B9B9", "d c #979797", "e c #7D7D7D", "f c #656565", "g c #5E5E5E", "h c #3B3B3B", "i c #454545", "j c #171717", "k c #141414", "l c #434343", "m c #3C3C3C", "n c #606060", "o c #676767", "p c #7F7F7F", "q c #959595", "r c #B6B6B6", "s c #CCCCCC", "t c #CECECE", "u c #D5D5D5", "v c #D9D9D9", "w c #DCDCDC", "x c #DFDFDF", "y c #E2E2E2", "z c #E4E4E4", "A c #E6E6E6", "B c #E7E7E7", "C c #E8E8E8", "D c #FBFBFB", "E c #EEEEEE", "F c #DADADA", "G c #D8D8D8", "H c #C4C4C4", "I c #B5B5B5", "J c #B0B0B0", "K c #B2B2B2", "L c #7C7C7C", "M c #6C6C6C", "N c #333333", "O c #101010", "P c #313131", "Q c #3E3E3E", "R c #373737", "S c #767676", "T c #646464", "U c #0C0C0C", "V c #0A0A0A", "W c #5B5B5B", "X c #3F3F3F", "Y c #1F1F1F", "Z c #6D6D6D", "` c #7E7E7E", " . c #D0D0D0", ".. c #D4D4D4", "+. c #DDDDDD", "@. c #E1E1E1", "#. c #E5E5E5", "$. c #E9E9E9", "%. c #EAEAEA", "&. c #FAFAFA", "*. c #E0E0E0", "=. c #DEDEDE", "-. c #C7C7C7", ";. c #AEAEAE", ">. c #4C4C4C", ",. c #828282", "'. c #343434", "). c #080808", "!. c #555555", "~. c #0E0E0E", "{. c #737373", "]. c #C9C9C9", "^. c #EBEBEB", "/. c #F9F9F9", "(. c #ECECEC", "_. c #E3E3E3", ":. c #C0C0C0", "<. c #888888", "[. c #484848", "}. c #070707", "|. c #414141", "1. c #8D8D8D", "2. c #A4A4A4", "3. c #929292", "4. c #8B8B8B", "5. c #AAAAAA", "6. c #747474", "7. c #ADADAD", "8. c #919191", "9. c #A1A1A1", "0. c #A3A3A3", "a. c #585858", "b. c #717171", "c. c #D7D7D7", "d. c #F8F8F8", "e. c #595959", "f. c #7A7A7A", "g. c #A6A6A6", "h. c #8F8F8F", "i. c #909090", "j. c #949494", "k. c #969696", "l. c #939393", "m. c #A5A5A5", "n. c #BBBBBB", "o. c #C8C8C8", "p. c #EDEDED", "q. c #F7F7F7", "r. c #151515", "s. c #8C8C8C", "t. c #707070", "u. c #0D0D0D", "v. c #6A6A6A", "w. c #9E9E9E", "x. c #F6F6F6", "y. c #232323", "z. c #8E8E8E", "A. c #A7A7A7", "B. c #A2A2A2", "C. c #9A9A9A", "D. c #989898", "E. c #626262", "F. c #A9A9A9", "G. c #121212", "H. c #0F0F0F", "I. c #A8A8A8", "J. c #999999", "K. c #ABABAB", "L. c #696969", "M. c #F3F3F3", "N. c #797979", "O. c #9B9B9B", "P. c #F2F2F2", "Q. c #D3D3D3", "R. c #0B0B0B", "S. c #727272", "T. c #878787", "U. c #EFEFEF", "V. c #111111", "W. c #787878", "X. c #1B1B1B", "Y. c #6F6F6F", "Z. c #A0A0A0", "`. c #202020", " + c #DBDBDB", ".+ c #ACACAC", "++ c #808080", "@+ c #464646", "#+ c #404040", "$+ c #B4B4B4", "%+ c #1E1E1E", "&+ c #CBCBCB", "*+ c #4F4F4F", "=+ c #C1C1C1", "-+ c #C3C3C3", ";+ c #474747", ">+ c #BCBCBC", ",+ c #4D4D4D", "'+ c #C6C6C6", ")+ c #262626", "!+ c #131313", "~+ c #C2C2C2", "{+ c #3D3D3D", "]+ c #5A5A5A", "^+ c #393939", "/+ c #858585", "(+ c #444444", "_+ c #4A4A4A", ":+ c #090909", "<+ c #1D1D1D", "[+ c #505050", "}+ c #6E6E6E", "|+ c #757575", "1+ c #161616", "2+ c #5D5D5D", "3+ c #6B6B6B", "4+ c #838383", "5+ c #7B7B7B", "6+ c #545454", "7+ c #777777", "8+ c #515151", "9+ c #898989", "0+ c #4E4E4E", "a+ c #222222", "b+ c #424242", "c+ c #494949", "d+ c #D6D6D6", "e+ c #616161", "f+ c #636363", "g+ c #1C1C1C", "h+ c #212121", "i+ c #5F5F5F", "j+ c #8A8A8A", "k+ c #525252", "l+ c #5C5C5C", "m+ c #666666", "n+ c #4B4B4B", "o+ c #686868", "p+ c #818181", "q+ c #272727", " ", " . . . . . . . + . . + . . + . . . . + + + . + . + . + . . . . . . + + + + . . . . + . . . . . + ", " @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ ", " # $ % % % % % & & & * * = - = * & * & & ; > , ' ) ! ~ ~ ~ { ! % ] ^ / , ] ) ) ] ] ' ' ' ( ( ( ( ( ( ( ( ( ( _ : ", " < * [ [ [ [ } | 1 2 3 4 5 6 7 8 9 0 a b c d e f g h i j k l m n o p q r 2 s t [ u v w x y z A B C C C C C C ] D ", " E ' F F F F v G u } s H a I J 7 K I L M N O P Q R S T U V W p Q X / ! Y Z ` 6 s ...v +.@.#.B C $.$.%.%.%.%.P &. ", " E ( @.@.*.*.=.+.F u t -.b 5 K ;.e ; V / >.,.9 9 9 5 '.).).% 5 5 c c !.Q k ~.{.].| u F x z B C $.%.^.^.^.^.P /. ", " (.( #.#.#.z _.*.+.G } ].:.c <.[.}.|.1.6 K 2.3.4.5.6.~.).).U Z 7.1.8.9.5 0 0.a.V - b. .c.+.y A C %.^.(.(.(.(.; d. ", " ^.P C C C B A _.x F [ 2 :.e.).m f.;.g.1.1.h.i.j.K ( }.}.}.}.% ;.k.3.l.3.3.m.n.. n ).> o.F *.#.C %.^.(.p.p.p.; q. ", " %.P %.%.$.C B #.*.F [ :.( r.f.7.7.i.s.h.8.8.1.7.t.u.}.}.}.}.U v.;.h.3.l.q l.q 7.a w.& $ 3 =.z C %.(.(.p.E E ; x. ", " %.P ^.^.^.$.C A @.F a y.) 0.6 k.1.z.z.h.h.h.k.A.N }.}.}.}.}.}.) B.C.i.3.3.q q q D.8 9 E.= <.y B $.(.p.E E E ; x. ", " B P (.(.(.^.$.A @.H y.X I F.3.8.3.h.h.z.h.z.A.T k G.G.V ).H.G.k n I.h.3.3.l.q k.d J.K.:.L.Y 4.B $.(.p.E E E ; M. ", " B P p.p.(.^.$.B 1 $ L.9 A.D.q l.3.i.h.z.h.z.3.j.. 9.2.; U N.2.w.j.j.h.8.3.3.l.q d O.+ I.a w._ 8.$.^.p.E E E P P. ", " #.P E p.p.(.$.Q.~ |.:.K.w.J.q 3.3.8.h.z.z.z.z.8.8.i.g.( R.S. i.i.h.i.i.8.3.l.q k.J.. B.7.H T.Y 4 ^.p.E E U.P P. ", " z P E E p.(.B ] ( .9 m. J.k.l.3.i.i.h.h.z.h.h.h.z.2.] R.t.+ z.h.h.i.i.8.3.3.l.q D.+ B.F.8 .o V.t p.E E U.P < ", " _.P E E p.(.W.X.[ o.K.m. D.k.j.8.8.i.h.z.h.z.z.h.z.2.' R.Y.+ 1.h.z.h.i.i.8.8.l.j.d O.Z.I.7.:.G , `.c.E E U.P E ", " y P E E E r V + +6 .+m. C.k.j.3.i.i.i.h.h.z.z.z.s.0.] R.Y.O.1.h.h.h.h.i.8.3.l.j.d C. g.;.6 Q.v { ++E E U.P E ", " @.P U.E E @+#+z b 8 7.m. J.q j.3.i.8.i.h.h.z.z.z.1.0.] R.Y.O.1.h.h.h.h.h.8.3.3.q k.C. g.;.$+r C ,.%+t E U.P p. ", " @.P U.E 7 R.F.z r I 7.m. J.k.l.3.3.8.h.z.h.z.z.z.s.0.' R.Y.O.1.z.z.h.h.h.8.3.3.l.k.C. m.7.$+9 &+G %+<.E U.P ^. ", " x P U.$.> *+#.=+5 I 7.m.w.C.k.j.3.3.8.i.h.z.z.z.z.1.0.] R.Y.O.s.z.h.z.h.i.8.3.3.j.k.C. m.7.I 0 n.$.l.! n.U.P %. ", " w P U.g.u.n.+.0 0 I 7.m. C.k.l.3.3.i.i.h.h.h.z.z.1.0.] R.Y.O.s.z.h.h.h.i.i.3.3.j.k.C. m.7.$+c a -+%.h 4.U.( o. ", " G P U.T.;+(.a b 0 I 7.m. C.q j.3.3.8.i.z.h.z.z.z.s.0.] R.Y.O.1.z.h.h.h.i.i.3.3.j.k.C. m.7.I 0 4 >+(.f ,+%.R '+ ", " u > B Q T (.a 4 0 I .+m. C.k.l.3.3.8.i.z.h.h.z.z.1.0.' R.Y.O.1.z.z.h.h.h.8.3.3.j.k.C. m.7.I 0 b :.Q.9 )+=+X H ", " [ #+:.!+7.G :.b 5 8 K.m.w.J.k.j.3.3.8.i.h.h.h.z.z.1.0.' R.Y.O.s.z.h.h.h.i.8.8.3.l.k.J. m..+K 5 b ~+>+E m g.X -+ ", " } {+ / E :.:.0 =+ .6 m.w.J.k.j.3.8.i.i.z.z.z.z.z.1.2.' R.Y.O.1.z.z.h.z.h.8.3.3.j.k.C.w.m.6 } ~+0 :.b (.]+W - ~+ ", " .^+j.>.E r -+A c.` K A. C.k.j.3.8.8.i.h.z.h.z.z.s.0.] R.Y.O.1.z.h.h.h.h.8.8.3.j.k.C. A.K e c.A -+0 +.C.'.r.=+ ", " .^ /+(+E z ^.i._+:+>+I.w.C.q j.3.3.i.i.h.h.z.z.z.s.0.] R.Y.O.1.z.z.h.h.i.8.8.3.j.k.C. I.>+:+_+8.^._.c.i.i j =+ ", " .<+[++ E h._+V :+!+3 g.+ D.j.3.i.i.h.h.z.1.z.1.s.s.0.' R.}+C.s.s.1.1.1.z.h.i.i.3.q D.. m.3 !+:+V _+d E v m r.=+ ", " .! e.|+Q ~.V V :+1+o.=+r 6 .+5.I.A.g.m.2.2.2.0.0.0.7.N U f..+B.0.m.2.2.m.g.A.I.5..+J r :.o.1+:+V V O ^+&+l r.=+ ", " .{ X.R.V V V V :+u.{+R N ; P P ' ' ' ' ' ' ] ] ] ' N k :+)+; ) ' ' ' ' ' ' ' ( P P ; N R {+u.:+V V V V 1+O r.=+ ", " .~ { V V V V V :+V H.u.U U R.R.R.R.R.R.R.R.R.R.R.R.U :+}.V U R.R.R.R.R.R.R.R.R.R.R.U U u.H.V :+V V V V ~.H.r.=+ ", " .X.2+3+^+H.V V :+G.8.4+L W.|+{.S.b.b.b.Y.t.Y.Y.Y.}+5+)+R.6+S Y.Y.Y.t.t.b.t.b.S.{.|+W.L 4+8.G.:+V V V ^ 7.m r.=+ ", " .! (+g.E l.i V :+k &+9 .+A.0.9.Z.w.. + + + + O.O.J.7.; U 7+A.C.O.+ + + + w. Z.9.0.A..+9 &+r.:+V |.,.(.%.R r.=+ ", " .) }+8+E #.C 9+l :+n.A.+ D.j.3.8.i.h.h.1.z.z.1.s.4.B.] R.Y.J.4.1.z.z.z.h.h.i.i.3.q D.. g.>+:+m ,.@.(.u 0.h r.=+ ", " ./ + >.E 9 '+C .7+K A. C.k.j.3.3.8.i.h.z.h.z.z.1.0.' R.Y.O.1.z.h.h.h.i.8.3.3.l.q C. A.$+S 2 C -.n.G 9.X r.=+ ", " .{+9.0+E n.:.0 H Q.6 m.w.C.k.j.3.3.8.i.z.z.h.z.z.1.0.' R.Y.O.1.z.z.h.z.i.8.3.3.j.q C. m.6 Q.-.0 4 b $.6.,+a+=+ ", " .|.I ~ -. .:.b 5 8 .+m. C.k.j.3.3.8.i.z.h.h.z.z.1.0.] R.Y.O.s.z.h.h.h.i.8.3.3.l.k.C. m.K.K 5 b ~+a E |.C.m =+ ", " .h v a+Y.^.a 4 0 I 7.m.w.C.k.l.3.3.8.h.z.z.h.z.z.1.0.' R.Y.O.s.z.h.z.h.i.8.3.3.l.q C. m.7.I 0 b :.1 } $ 0 b+=+ ", " .P U.,._+(.a b 0 I .+m. C.k.j.3.8.i.i.h.h.h.z.z.s.0.] R.Y.O.s.z.z.h.h.i.8.3.3.j.q C. m.7.I c 4 a C ++`.} h =+ ", " .( U.+ j t Q.>+0 $+7.m. C.k.j.3.3.8.i.h.h.z.z.z.s.0.' R.Y.O.1.z.h.z.h.i.8.3.3.j.k.J.w.m.7.I 0 a a (.c+M U.N =+ ", " .( U.2 { Y.^.n.c $+7.m. C.k.j.3.3.8.h.z.z.z.z.z.s.0.' R.Y.O.1.z.h.h.z.i.8.3.3.j.q C.w.m..+I 0 0 w 3 { I.U.( =+ ", " .( U.E D.U -+d+r I 7.m. C.k.j.3.3.8.i.h.h.h.z.z.1.0.] R.Y.O.1.z.h.h.h.h.i.3.3.j.k.C. m.7.I c -+_.h #+E U.( =+ ", " .( U.E y %+e+C 5 $+;.g. C.d q 3.3.8.i.z.h.z.z.z.s.0.' R.Y.O.s.z.h.h.z.h.8.8.3.l.q J. m.7.I r B 0.U a E U.( =+ ", " .( U.E E k.V -.v J 7.g. O.d q 3.8.i.i.h.h.h.h.z.1.0.] R.Y.O.s.z.z.h.z.i.i.8.3.j.k.J.w.m.7.6 '+C ) ,+E E E ( =+ ", " .( U.E E #.'.; u ~+.+A.Z.O.d q l.8.i.h.h.h.z.h.h.z.2.] R.Y.+ z.z.z.h.h.h.h.i.3.l.k.J.w.m.K.5 d+T { -+p.E E ( =+ ", " .( U.E E p.c.O f+u 8 I.B.O.D.q j.3.3.8.i.i.h.z.z.z.2.' R.t.+ z.z.h.z.h.h.i.8.3.l.q D. m.7.| 0.V K.(.p.E E ( =+ ", " .( U.E E p.^.s = Y.-+.+B.. J.q q l.3.8.8.i.h.i.8.8.g.' R.b. 8.i.z.h.z.h.h.8.3.l.q J. m.a 0.g+f.$.(.p.p.E ( =+ ", " .( E E E p.^.$.l.%+w.4 A.. O.D.q l.3.8.i.i.l.j. 9.2.; U N.2.w.q 3.z.h.z.h.h.3.3.q D. I 5 h+|.A $.^.(.p.p.( =+ ", " .( E E E p.(.$.B 4.y.p a F.J.D.q q l.3.8.h.I.n k G.G.V ).H.G.G.i+F.1.h.z.h.i.8.3.l.+ r k.h+|. +A $.^.(.(.(.( =+ ", " .( E E E p.(.$.B y 9+<+f+c 7 d q q q l.3.h.J.B.) }.}.}.}.}.}.- + J.z.i.h.z.z.i.h. 7 j+! {+c.@.A C $.^.^.^.' =+ ", " .( E E p.(.(.%.C z =.I.%+> K b 2.q j.q l.3.h.7 v.U }.}.}.}.V T 7 1.i.8.i.z.s.l.J $+k+).v.[ F *.#.B C $.%.%.' =+ ", " .( p.p.p.(.^.%.C #.*.F 4 % V.M .+c D.3.l.q 3.k.7.) }.}.}.}.)+I.d 8.3.i.1.s.g.K.|+'.j ` 2 [ F x _.A B C C C ' =+ ", " .( (.(.(.(.^.%.C A y +.c.t l+{ `.|+>+0 m.l.3.z.J m+R.).).u.v.6 z.8.i.C.J J l.> }.n+m.:.].} G +.*._.z #.#.#.] =+ ", " .' ^.^.^.^.%.$.C B z x F u | >+o+r.R 0+l.0 c K.F.6 Y ).).y.r 2.m.K r 9.n {+!+m /+K 5 b -.t u F +.=.*.*.@.@.] =+ ", " .' %.%.%.%.$.$.C B #.@.+.v .. .s 2.7+b+h+, c+e 6.a 3.u.V.C.a ` p+2+, %+X.]+` K 7 J I a H s } u G v F F F F ) =+ ", " t ' C c.G c.c.d+u ....[ | 1 o.'+-+t s '+w.T./ = - = '.R.U , % * ] P 6.h.I.a 0 7 A.B.m.5.K 9 0 4 =+~+~+~+3 -.- 4 ", " 2 h+] * * * * * = = = = = - - - q+q+- ' R ^ `.!+!+!+!+!+!+!+!+!+!+! P , N = _ _ $ y.y.y.$ _ )+)+)+)+)+)+)+q+Y >+ ", " ~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+~+=+:.>+r ", " ", " "}; elseif pic == '1' then Image = { --XpmImage Here }; end return Image end function ImageRight(pic) local Image = { "60 60 143 2", " c #ACACAC", ". c #ADADAD", "+ c #9D9D9D", "@ c #9C9C9C", "# c #9E9E9E", "$ c #A5A5A5", "% c #B3B3B3", "& c #B8B8B8", "* c #FFFFFF", "= c #F2F2F2", "- c #BDBDBD", "; c #C5C5C5", "> c #FDFDFD", ", c #F0F0F0", "' c #F1F1F1", ") c #C3C3C3", "! c #FBFBFB", "~ c #EEEEEE", "{ c #EFEFEF", "] c #ECECEC", "^ c #AEAEAE", "/ c #C0C0C0", "( c #C2C2C2", "_ c #FAFAFA", ": c #EDEDED", "< c #EBEBEB", "[ c #AFAFAF", "} c #BFBFBF", "| c #F9F9F9", "1 c #EAEAEA", "2 c #F8F8F8", "3 c #E9E9E9", "4 c #B0B0B0", "5 c #C1C1C1", "6 c #F7F7F7", "7 c #F6F6F6", "8 c #E8E8E8", "9 c #E7E7E7", "0 c #F3F3F3", "a c #E6E6E6", "b c #E5E5E5", "c c #808080", "d c #797979", "e c #393939", "f c #383838", "g c #E4E4E4", "h c #323232", "i c #313131", "j c #E3E3E3", "k c #BEBEBE", "l c #3D3D3D", "m c #E2E2E2", "n c #4B4B4B", "o c #424242", "p c #E1E1E1", "q c #585858", "r c #595959", "s c #DADADA", "t c #818181", "u c #E0E0E0", "v c #5B5B5B", "w c #D6D6D6", "x c #494949", "y c #464646", "z c #DFDFDF", "A c #565656", "B c #D1D1D1", "C c #414141", "D c #161616", "E c #454545", "F c #DEDEDE", "G c #CCCCCC", "H c #BBBBBB", "I c #DDDDDD", "J c #DCDCDC", "K c #2C2C2C", "L c #DBDBDB", "M c #575757", "N c #B5B5B5", "O c #272727", "P c #A6A6A6", "Q c #A7A7A7", "R c #222222", "S c #D9D9D9", "T c #555555", "U c #D8D8D8", "V c #1E1E1E", "W c #B9B9B9", "X c #9B9B9B", "Y c #1B1B1B", "Z c #D7D7D7", "` c #919191", " . c #181818", ".. c #B4B4B4", "+. c #D2D2D2", "@. c #CACACA", "#. c #C9C9C9", "$. c #525252", "%. c #535353", "&. c #CBCBCB", "*. c #7F7F7F", "=. c #171717", "-. c #C8C8C8", ";. c #CDCDCD", ">. c #C4C4C4", ",. c #CFCFCF", "'. c #C7C7C7", "). c #515151", "!. c #747474", "~. c #D0D0D0", "{. c #737373", "]. c #C6C6C6", "^. c #B1B1B1", "/. c #888888", "(. c #909090", "_. c #1A1A1A", ":. c #B2B2B2", "<. c #969696", "[. c #1D1D1D", "}. c #9F9F9F", "|. c #212121", "1. c #CECECE", "2. c #252525", "3. c #353535", "4. c #989898", "5. c #999999", "6. c #ABABAB", "7. c #292929", "8. c #404040", "9. c #2E2E2E", "0. c #B6B6B6", "a. c #545454", "b. c #BABABA", "c. c #3B3B3B", "d. c #3F3F3F", "e. c #484848", "f. c #4A4A4A", "g. c #333333", "h. c #BCBCBC", "i. c #A1A1A1", "j. c #A0A0A0", "k. c #A2A2A2", "l. c #A9A9A9", " . . . . . . . . . . . . . . . . . . . . ", ". . + + @ + + + + + @ + + + + @ @ @ @ + + + + + + @ + @ + @ + @ @ @ + + + + @ + + @ + + @ + + + + + + + + + + # $ ", "% & * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * = ", "- ; > , ' , , , , ' , , ' ' , , , , ' ' ' , , , , , ' ' ' ' , ' ' ' , , , ' , ' , ' ' , , , , , , , , , ' ' , , , ' ' % ", "- ) ! ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ ~ ~ ~ ~ ~ ~ ~ ~ { ~ ~ ~ ~ ~ ~ { ~ ~ { ~ { { ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ , ] ^ ", "/ ( _ : : : : : : : : : : : : : : : : : : : ~ ~ : : : : : : : : ~ : : : : : : : : : : ~ : ~ ~ : : : : : : : : : : ~ < [ ", "} ( | : : : : : ] : : : : : : : : : : : : ] : : : : : : : : : ] ] ] : : : : : : : : : : : : : : : : : ] ] : ] : : ~ 1 [ ", "} ( 2 < < ] < < ] ] < < < < < < ] < < < < < < < < < ] < < < < < < < < < ] < < ] < < < < < ] ] < < ] < < < < < < < ] 3 4 ", "} 5 6 1 1 < < 1 1 1 1 1 < 1 1 1 1 < 1 1 1 1 1 1 1 1 1 1 1 1 < < 1 1 1 < 1 1 1 1 < 1 1 1 1 1 < < 1 1 1 1 < 1 < 1 1 < 3 [ ", "} 5 7 3 3 1 1 3 3 3 3 3 1 3 3 3 3 3 3 3 3 3 3 3 1 3 3 1 1 3 3 3 3 3 3 3 3 1 3 3 1 3 3 3 3 3 1 1 3 3 3 3 1 1 3 3 3 1 8 [ ", "} 5 7 3 3 3 3 3 3 3 3 3 8 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 8 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1 9 [ ", "/ / 0 9 9 9 8 8 9 9 a b 9 8 8 9 9 9 8 9 9 8 8 8 9 8 8 a 8 8 9 9 8 8 8 a 8 9 9 8 9 9 8 9 9 8 9 9 9 9 a 8 9 9 9 8 a 9 a 4 ", "} } = a a a a a a c c d a a a a a a 9 a a 9 a a a 9 a a a a a 9 a 9 9 9 9 a a a a a 9 a a 9 a a a a 9 a a a a 9 a 9 b [ ", "/ } = b b b b b b e e f b b b b a b b b b b b b b b b b b b b b b b b b b b b b b b a b b b a b b b b a b b b b b b g [ ", "/ } , g g g g g g h h i g j g g g g g g g g g g g g g g g g g j g g g g g g g g g g g g g g g g g g g g g g g g g g j 4 ", "/ k ~ g g j j g g l l i g g g j g g g g j g g g g g j j g g g j g j j j g g g g g g m g g j j j g g g g j g g g g g j [ ", "5 k ~ m m m j j j n n o j m m m j m m j j j m m m j j j m j j m m m m m m j j m j j m j m m j m m j j j m m j j j j m 4 ", "5 - : m m p m m m q q r m m p p p p p p m p p p m m m m p s t p m m p p m p p p p m m p p p m p p p p p p p p p m p p [ ", "5 - < u u u u u u r r v u u p u u u p u u u u u u u u u w x y p p u u u u u u u u u u u u u u p u u u u u u u u p u u [ ", "5 - 1 z z z z z z A A q z z z z z z u z z z z z z z z B C D E z z z z z z z z z z z z z z z z z z u z z u z z z z z z 4 ", "5 - 3 z z z z z F A A q z z z z z z F z z z z z F z G e D D E z z F z z z z z z z z z z z z z z z F z z z z z z z z z [ ", "5 H 8 F I I I I I A A q F F F F I F F I F F F F I ; i D D D E I I I F F F F F F F I F F F I F F F I F I I I F F F J F 4 ", "( H 9 I J J I I I A A q J J I I I I I I J J J J k K D D D D E J I I I I J J J I I J J I I I J J J J I I I I J I J L I 4 ", "( H a L L L J J J A A M L L J L J L L J L L L N O D D D D D f P Q Q P P Q Q P P P L L L J J L L L L L J J J L L L L J [ ", "( H g L L L L L L A A M L L L L L L L L L L ^ R D D D D D D D D D D D D D D D D D L L L L L L L L L L L L L L L L s L 4 ", "( H j S S S S S s T T M U S s s s s S S S $ V D D D D D D D D D D D D D D D D D D s s s s S s s s s S S s s S S S U s [ ", "( W j U U S S U S T T M S U s S S S s S X Y D D D D D D D D D D D D D D D D D D D S S S S S S S S S S U S S U U S S s 4 ", ") W u Z w Z U w w T T A Z Z Z Z Z w Z ` .D D D D D D D D D D D D D D D D D D D D Z w w Z Z Z w w U U Z w Z Z Z Z w S 4 ", "; ..+.@.@.@.@.@.#.$.$.%.@.@.@.@.@.&.*.=.D D D D D D D D D D D D D D D D D D D D D @.@.@.@.@.@.@.@.@.@.@.#.@.@.#.#.-.;.4 ", ">.% ,.-.-.-.-.-.'.).).%.-.'.-.#.-.!.D D D D D D D D D D D D D D D D D D D D D D D -.#.#.'.#.'.-.#.'.'.#.'.'.#.-.'.; G 4 ", "; % ~.#.-.-.#.-.-.$.$.%.#.-.-.#.#.{.D D D D D D D D D D D D D D D D D D D D D D D -.-.-.#.-.-.#.#.#.-.-.#.#.-.#.#.].G ^.", "; % ~.#.#.-.-.#.#.$.).%.#.#.-.-.-.-.*.=.D D D D D D D D D D D D D D D D D D D D D -.#.#.-.-.#.#.-.-.-.-.#.#.-.-.#.; G ^.", ">.% ~.#.#.#.#.-.-.$.$.%.#.#.#.#.-.-.-./. .D D D D D D D D D D D D D D D D D D D D -.-.#.-.-.#.-.-.-.-.-.#.-.#.-.-.; G ^.", "; % ~.#.#.#.#.#.-.$.$.%.#.-.-.#.#.#.-.#.(._.D D D D D D D D D D D D D D D D D D D #.-.#.#.-.#.-.#.-.#.#.-.#.-.#.-.].G ^.", "; :.,.'.'.-.'.-.'.).).%.'.'.'.'.-.-.'.'.'.<.[.D D D D D D D D D D D D D D D D D D -.'.-.-.'.'.'.'.'.'.'.-.'.'.-.'.>.&.4 ", "; % ,.'.-.-.'.'.'.).).%.'.'.'.'.'.'.'.-.-.'.}.|.D D D D D D D D D D D D D D D D D '.-.'.'.'.'.'.'.'.-.'.'.'.'.'.'.>.&.4 ", "; % 1.-.'.'.-.-.-.).).%.-.'.'.'.-.'.'.'.'.'.'.P 2.D D D D D 3.4.4.5.5.4.4.4.4.4.4.-.'.-.-.'.-.-.'.'.'.'.'.'.'.-.'.; G ^.", "; % 1.'.'.'.'.-.'.).).%.'.-.'.'.'.'.'.-.-.'.'.'.6.7.D D D D 8.'.'.'.'.'.'.-.'.-.'.'.'.'.'.'.'.'.'.'.-.-.'.'.'.'.'.>.&.^.", "; % ,.'.'.'.'.-.'.).).%.-.'.'.'.'.'.'.'.-.'.'.'.-.:.9.D D D 8.'.'.'.'.'.'.'.-.-.-.'.'.'.'.-.-.'.'.'.'.'.'.'.'.'.'.; &.4 ", "; :.1.'.'.'.'.'.'.$.$.%.'.'.'.'.'.'.'.'.'.'.'.'.'.'.0.3.D D 8.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.'.>.&.4 ", "].:.;.].].].].].].a.a.T ].].].].].].].].].].].].].].].b.c.D d.].].].].].].].].].].].].].].].].].].].].].].].].].].) @.4 ", "; :.;.].].].].].].e.e.f.].].].].].].].].].].].].].].].].- o d.].].].].].].].].].].].].].].].].].].].].].].].].].].) @.^.", "; :.;.].].].].].].g.g.g.].].].].].].].].].].].].].].].].]./ {.].].].].].].].].].].].].].].].].].].].].].].].].].].) @.4 ", "; :.;.].].].].].].i i i ].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].) @.4 ", "; :.;.].].].].].].i i i ].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].) @.^.", "; :.;.].].].].].].i i i ].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].].) @.4 ", "; :.G ; ; ; ; ; ; ; ; ; ; >.; ; ; ; >.; ; ; >.>.; >.; >.; >.; ; ; ; ; ; ; >.; ; >.; ; >.>.>.; ; ; ; ; ; ; ; >.; ; ( #.4 ", "; :.G ; ; ; ; ; ; ; ; ; >.; >.>.>.>.; >.; ; ; ; ; ; ; ; ; ; ; ; >.>.>.; ; ; ; ; ; ; ; >.; ; >.; ; ; ; ; ; >.; ; ; ( #.^.", "].^.G ; >.; ; ; ; ; ; ; ; >.>.; ; ; ; ; ; >.; ; ; ; ; ; ; ; ; >.; ; ; >.>.; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; >.; ; ( #.4 ", "].^.&.; ; ; ; ; ; ; >.; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; >.; ; ; ; ; ; ; ; ; ; ; >.; ; >.>.; ; ; ; ( #.4 ", "; :.G ; ; ; ; ; ; ; ; ; ; ; ; >.>.; ; ; ; ; ; ; ; >.>.; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ( -.4 ", "; ^.&.>.) >.>.>.>.>.>.>.>.>.>.; ; >.>.>.>.>.>.>.) ; ; >.>.>.>.>.>.>.>.>.) >.>.>.>.>.>.>.>.>.>.>.) >.>.>.>.>.) >.>./ #.^.", ">.:.G ; >.; ; ; ; ; ; ; ; >.>.; ; ; ; ; ; >.; ; ; ; ; ; ; ; ; >.; ; ; >.>.; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; >.; ; ( #.4 ", "( :.&.; ; ; ; ; ; ; >.; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; >.; ; ; ; ; ; ; ; ; ; ; >.; ; >.>.; ; ; ; ( #.4 ", "h.:.G ; ; ; ; ; ; ; ; ; ; ; ; >.>.; ; ; ; ; ; ; ; >.>.; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ( -.4 ", "% &.>.) >.>.>.>.>.>.>.>.>.>.; ; >.>.>.>.>.>.>.) ; ; >.>.>.>.>.>.>.>.>.) >.>.>.>.>.>.>.>.>.>.>.) >.>.>.>.>.) >.>./ #.4 ", "^ ; / / } / } / / } } } / / / / / / } / } / / / / / } / / / / / / / } / } / / / } / / } / / } / / } / / / / / / H #.4 ", " : z z F z F F F z z F z z z z F F z F F F z z F F F F z F z z F F F z F F z F F F z z F F z z z z F F z F F z p #.4 ", " i.j.j.j.j.i.i.i.i.i.i.j.i.i.j.i.j.j.i.j.i.j.j.i.i.i.i.j.i.j.i.i.i.i.i.i.i.i.k.i.j.i.j.j.j.i.j.i.i.i.i.i.i.i.l. 4 ", " . . . . . . . . . . . . . . . . . 4 4 4 "}; return Image end function ImageBottomLeft(pic) if (pic == nil) then pic = '0' end if pic == '0' then Image = { "60 60 289 2", " c None", ". c #9F9F9F", "+ c #989898", "@ c #929292", "# c #8C8C8C", "$ c #8D8D8D", "% c #8E8E8E", "& c #8F8F8F", "* c #909090", "= c #949494", "- c #979797", "; c #999999", "> c #9B9B9B", ", c #9D9D9D", "' c #FFFFFF", ") c #FEFEFE", "! c #FBFBFB", "~ c #FDFDFD", "{ c #CBCBCB", "] c #C9C9C9", "^ c #C8C8C8", "/ c #C7C7C7", "( c #C5C5C5", "_ c #C6C6C6", ": c #C3C3C3", "< c #C0C0C0", "[ c #BBBBBB", "} c #EBEBEB", "| c #EAEAEA", "1 c #E8E8E8", "2 c #E7E7E7", "3 c #E6E6E6", "4 c #E4E4E4", "5 c #E3E3E3", "6 c #E2E2E2", "7 c #E1E1E1", "8 c #DFDFDF", "9 c #E0E0E0", "0 c #DDDDDD", "a c #CFCFCF", "b c #D0D0D0", "c c #CDCDCD", "d c #CCCCCC", "e c #CACACA", "f c #EEEEEE", "g c #EDEDED", "h c #ECECEC", "i c #E9E9E9", "j c #E5E5E5", "k c #D7D7D7", "l c #D6D6D6", "m c #D2D2D2", "n c #D4D4D4", "o c #D9D9D9", "p c #D8D8D8", "q c #D1D1D1", "r c #CECECE", "s c #878787", "t c #DBDBDB", "u c #D5D5D5", "v c #DADADA", "w c #BABABA", "x c #848484", "y c #6C6C6C", "z c #646464", "A c #656565", "B c #636363", "C c #616161", "D c #606060", "E c #5F5F5F", "F c #5B5B5B", "G c #595959", "H c #555555", "I c #515151", "J c #4C4C4C", "K c #484848", "L c #434343", "M c #3E3E3E", "N c #393939", "O c #343434", "P c #313131", "Q c #2D2D2D", "R c #2B2B2B", "S c #292929", "T c #262626", "U c #ADADAD", "V c #898989", "W c #DCDCDC", "X c #D3D3D3", "Y c #9E9E9E", "Z c #686868", "` c #717171", " . c #757575", ".. c #747474", "+. c #737373", "@. c #727272", "#. c #707070", "$. c #6E6E6E", "%. c #696969", "&. c #666666", "*. c #626262", "=. c #5E5E5E", "-. c #585858", ";. c #545454", ">. c #505050", ",. c #4E4E4E", "'. c #4B4B4B", "). c #464646", "!. c #444444", "~. c #414141", "{. c #363636", "]. c #7F7F7F", "^. c #777777", "/. c #767676", "(. c #6B6B6B", "_. c #676767", ":. c #5D5D5D", "<. c #494949", "[. c #424242", "}. c #404040", "|. c #3A3A3A", "1. c #272727", "2. c #ACACAC", "3. c #828282", "4. c #6F6F6F", "5. c #6D6D6D", "6. c #5C5C5C", "7. c #4F4F4F", "8. c #474747", "9. c #454545", "0. c #3F3F3F", "a. c #353535", "b. c #6A6A6A", "c. c #575757", "d. c #535353", "e. c #3C3C3C", "f. c #5A5A5A", "g. c #232323", "h. c #525252", "i. c #252525", "j. c #000000", "k. c #565656", "l. c #F0F0F0", "m. c #111111", "n. c #FAFAFA", "o. c #4D4D4D", "p. c #FCFCFC", "q. c #F4F4F4", "r. c #161616", "s. c #F7F7F7", "t. c #4A4A4A", "u. c #3D3D3D", "v. c #888888", "w. c #090909", "x. c #121212", "y. c #010101", "z. c #373737", "A. c #F3F3F3", "B. c #030303", "C. c #EFEFEF", "D. c #62605D", "E. c #655E57", "F. c #675B4E", "G. c #655747", "H. c #635546", "I. c #5B5247", "J. c #54504C", "K. c #4E4D4C", "L. c #131313", "M. c #040404", "N. c #605F5E", "O. c #645D56", "P. c #6B5A47", "Q. c #3F6188", "R. c #2468B4", "S. c #156CCC", "T. c #146BCD", "U. c #2E5F97", "V. c #4E4C49", "W. c #524639", "X. c #494542", "Y. c #050505", "Z. c #1B1B1B", "`. c #5D5C5C", " + c #62594F", ".+ c #5C5856", "++ c #0871E5", "@+ c #007AFF", "#+ c #0078FF", "$+ c #007EFF", "%+ c #265A93", "&+ c #4A3C2C", "*+ c #3E3B37", "=+ c #222222", "-+ c #5C554E", ";+ c #585653", ">+ c #007CFF", ",+ c #0076FA", "'+ c #0176F8", ")+ c #0077FE", "!+ c #007DFF", "~+ c #21558E", "{+ c #473C2F", "]+ c #464544", "^+ c #565451", "/+ c #5F4E3B", "(+ c #0078FE", "_+ c #007FFF", ":+ c #47433E", "<+ c #4D4741", "[+ c #242424", "}+ c #383838", "|+ c #554E47", "1+ c #375980", "2+ c #007BFF", "3+ c #116ACC", "4+ c #56493B", "5+ c #333333", "6+ c #55483A", "7+ c #1F63AE", "8+ c #0079FF", "9+ c #0077FD", "0+ c #0076FD", "a+ c #5F4B36", "b+ c #020202", "c+ c #303030", "d+ c #534433", "e+ c #0770E6", "f+ c #0076F9", "g+ c #654F37", "h+ c #F9F9F9", "i+ c #2C2C2C", "j+ c #4F4131", "k+ c #1269C8", "l+ c #68533B", "m+ c #2A2A2A", "n+ c #4A4137", "o+ c #26598F", "p+ c #0077FF", "q+ c #6A5946", "r+ c #282828", "s+ c #443F3B", "t+ c #423F3C", "u+ c #0080FF", "v+ c #32649E", "w+ c #665C52", "x+ c #41403F", "y+ c #463A2D", "z+ c #22568F", "A+ c #0771E6", "B+ c #6B5A46", "C+ c #63605C", "D+ c #403D39", "E+ c #463828", "F+ c #235690", "G+ c #0871E6", "H+ c #5B5A5B", "I+ c #413E3A", "J+ c #473B2E", "K+ c #44403B", "L+ c #1068CB", "M+ c #0076FE", "N+ c #0770E4", "O+ c #2E629C", "P+ c #675541", "Q+ c #635C55", "R+ c #626261", "S+ c #424140", "T+ c #47413B", "U+ c #4D4032", "V+ c #53402A", "W+ c #5A442B", "X+ c #5C4730", "Y+ c #5E4D3B", "Z+ c #5D544A", "`+ c #5D5A56", " @ c #DEDEDE", ".@ c #838383", "+@ c #AEAEAE", "@@ c #1A1A1A", "#@ c #969696", "$@ c #060606", "%@ c #939393", "&@ c #F1F1F1", "*@ c #F5F5F5", "=@ c #0A0A0A", "-@ c #F8F8F8", ";@ c #F2F2F2", ">@ c #919191", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ", ". + @ # # $ $ $ $ $ % % % % & & & & * @ = - - - + + + + + + + + + + + + + + + + + + + + + + + + + + + + + + + + ; > , . ", ". @ ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ) ! ~ { { ] ^ / ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( _ : < [ > . ", ". # ' } } | | 1 2 3 3 4 5 6 7 6 8 9 0 9 a b c d { e e e e e e e e e e e e e e e e e e e e e e e e e e e e e { ] ( < ; . ", ". # ' f g h g | i 1 i 3 3 j 5 4 7 6 8 9 k l m b a a n o 0 8 9 9 9 9 7 7 7 6 5 5 4 j 3 3 2 1 1 i i i 2 9 p q r d ] ( + . ", ". s ' g g h g h } | i 3 j j 5 6 7 9 8 8 t p u m n v w x y z A B C D E F G H I J K L M N O P Q R S T Q H U 7 u r { _ + . ", ". V ' g g h g | } | i 1 j j 5 6 5 6 8 8 W o n X t Y Z ` . ...+.+.@.#.$.y %.&.*.=.-.;.>.,.'.K ).!.~.M {.S ].7 q e / + . ", ". V ' g g h g | i 1 i 1 j j 5 4 5 6 8 8 W k n k [ Z ..^. ./. ...+.#.#.$.(._.A C :.G H I J <.).!.[.[.~.}.|.1.2.p e / + . ", ". V ' g g h } h i 1 i 3 j j 5 4 5 6 8 8 W k u 0 3.4. ././. .+.@.@.` 4.5.(.&.z D 6.-.;.7.'.K 8.9.L }.0.}.M a.;.7 e / + . ", ". V ' f g h g h i 1 i 3 3 j 5 4 7 9 8 8 W k u 7 Z ../... .+.@.+.#.#.$.y b.A B E F c.d.7.J 8.).!.~.~.}.M M e.S 2 e / + . ", ". V ' g g h g | i 1 i g g h 5 4 7 9 7 8 W k n 5 *... .+...@.+.@.4.4.5.(.Z A *.=.f.;.>.,.<.).9.L }.0.M M M 0.g.| e / + . ", ". s ' g g h g | i 1 i ~ h.' } 4 5 6 7 8 W o n 5 C ..@.+.+.@.#.4.4.y y Z _.z D 6.-.;.>.'.<.9.!.[.0.M M }.0.~.i.| e / + . ", ". V ' f g h g | } | 2 ' j.A ' h 5 6 8 8 W o n j E ` @.@.#.` #.4.y y b.&.A D =.f.k.h.,.<.).9.~.0.M M 0.~.[.[.T | e / + . ", ". V ' f g h g | i 1 i ' j.j.c.' | 6 8 8 W o n j =.` ` #.#.4.$.5.y b.Z A C E f.-.;.,.J 8.!.L 0.M 0.}.[.~.[.[.S i e / + . ", ". V ' g f f l.g h } } ' j.m.j.,.n.} 7 8 W o n 4 f.4.5.$.$.5.y (.%.&.A B D :.G H I o.K ).L 0.M 0.[.L !.9.9.!.R i e / + . ", ". V ' g p.q.' ' ' ) ) ' j.r.m.j.[.s.| 8 W o n j -.y y y (.b.%.Z A A *.D :.-.k.h.,.t.9.[.0.u.}.L L !.9.8.).K Q 1 e / + . ", ". v.' g ' j.j.j.j.j.j.j.w.r.r.x.y.z.A.} W k n j ;.%.%.%.Z _.&.A B C E 6.G k.h.o.'.8.[.0.u.~.!.).8.K <.t.<.'.P 1 e / + . ", ". v.' g ' j.r.r.r.r.r.r.r.r.r.r.x.B.Q C.1 p n 3 I &.&.z A z B D.E.F.G.H.I.J.K.'.8.[.M M [.!.).<.<.t.'.J ,.o.O 2 e / + . ", ". v.' f ' j.r.r.r.r.r.r.r.r.r.r.r.L.M.1.3 3 l 2 J *.*.*.C N.O.P.Q.R.S.T.U.V.W.X.[.M }.L 9.<.'.o.,.7.>.I >.h.N 2 e / + . ", ". v.' f ' j.r.r.r.r.r.r.r.r.r.r.r.r.L.Y.Z.0 8 i 8.=.=.=.`. +.+++@+#+#+#+@+$+%+&+*+0.!.K <.o.7.I I h.d.H ;.;.u.3 e / + . ", ". V ' f ' j.r.r.r.r.r.r.r.r.r.r.r.r.r.m.j.=+9 | [.f.f.-.-+;+>+#+,+'+'+'+'+)+!+~+{+]+<.J 7.I h.H H -.c.-.f.f.L j e / + . ", ". V ' g ' j.r.r.r.r.r.r.r.r.r.r.r.r.L.Y.Z.t 8 } e.;.;.^+/+++#+'+'+'+'+'+'+'+(+_+:+<+J 7.d.;.-.-.F 6.:.=.=.=.K 4 e / + . ", ". V ' g ' j.r.r.r.r.r.r.r.r.r.r.r.L.M.[+3 3 u } }+h.>.|+1+2+,+'+'+'+'+'+'+'+'+@+3+4+h.d.c.f.6.=.E D C *.*.*.J 5 e / + . ", ". V ' g ' j.r.r.r.r.r.r.r.r.r.r.x.B.Q C.1 v n h 5+o.,.6+7+8+'+'+'+'+'+'+'+'+'+9+0+a+;.G F =.D D B z A z &.&.I 5 e / + . ", ". V ' g ' j.j.j.j.j.j.j.w.r.r.x.b+{.A.} W o n g c+'.<.d+e+#+'+'+'+'+'+'+'+'+'+f+>+g+G 6.E C B A &._.Z %.%.%.H 6 e / + . ", ". V ' g p.q.' ' ' ) ) ' j.r.m.j.}.h+| 9 W o n h i+K ).j+k+8+'+'+'+'+'+'+'+'+'+,+>+l+:.D *.A A Z %.b.(.y y y -.7 e / + . ", ". s ' f f f l.C.h } } ' j.m.j.o.! h 9 8 W o n h m+!.9.n+o+2+'+'+'+'+'+'+'+'+'+p+++q+D B A &.%.(.y 5.$.$.5.4.F 7 e / + . ", ". V ' f g h g | i | i ' j.j.c.) h 6 8 8 W k n g r+[.[.s+t+u+(+'+'+'+'+'+'+'+,+8+v+w+C A Z b.y 5.$.4.#.#.` ` E 7 e / + . ", ". s ' f g h g | i | i ' j.A ' h 7 9 8 8 W k u g i.[.[.x+y+z+!+(+'+'+'+'+'+,+#+A+B+C+A &.b.y y 4.#.` #.@.@.` E 9 e / + . ", ". V ' f g h g | i 1 i ~ I ' } 4 5 9 9 8 W k u g [+~.0.}.D+E+F+_+@+9+f+,+p+@+G+H+E.z _.Z y y 4.4.#.@.+.+.@...*.9 e / + . ", ". s ' g g h g | } 1 i g g h 4 4 5 9 8 8 W k u g g.0.M M M I+J+K+L+M+$+$+N+O+P+Q+R+A Z (.5.4.4.@.+.@...+. ...B 8 e / + . ", ". V ' f g h } | } 1 i 3 2 j 6 6 7 9 7 8 W k u } m+e.M M }.~.S+T+U+V+W+X+Y+Z+`+E B A b.y $.#.#.+.@.+. .../...%. @e / + . ", ". v.' f g f } | i 1 i 1 j 4 4 4 7 6 7 8 W k u 4 d.a.M }.0.}.L 9.8.K '.7.;.-.6.D z &.(.5.4.` @.@.+. ././. .#..@v e / + . ", ". v.' f C.h } | | 1 i 1 2 4 5 6 7 6 8 8 W k n t 2.1.|.}.~.[.[.!.).<.J I H G :.C A _.(.$.#.#.+... ./. .^...%.w n e / + . ", ". v.' g g h g | i 1 i 1 2 4 4 5 7 9 8 8 W o n n 7 ].S {.M ~.!.).K '.,.>.;.-.=.*.&.%.y $.#.@.+.+... . .` Z Y v b e / + . ", ". V ' g g h g | } 1 i 4 2 4 5 6 7 9 8 8 t p u m l 7 +@;.i+i.r+m+i+c+O N M [.8.J I ;.-.f.=.E D B z B (..@w t n a e / + . ", ". V ' g g h g h i 1 i 1 2 4 5 4 7 6 8 8 t v l X m n t 4 } g g h h } } | i i 1 2 3 3 j j 4 4 4 5 5 5 7 0 k X m a e / + . ", ". V ' f g h g | i | 2 3 j 4 5 4 5 9 8 8 0 t k u n X X n n n n n n n n n n u @8 @u n n n n n n n n n n n n X q { / + . ", ". V ' g g h g | i 1 i 3 j j 5 4 5 9 9 8 @W v k l k u l l l l l l l l l k 5 o =+k 5 k l l l l l l l l l l l u m d _ + . ", ". s ' f g h g h i 1 i 1 j j 5 4 7 9 9 @0 0 v v p o k p p p p p p p p p 4 7 @@j.@@6 4 p p p p p p p p p p p k X { ( #@. ", ". V ' g C.h g | } | i 3 j j 5 4 5 9 8 @8 @0 t t v v v v v v v v v v j i 1.$@x.$@g.i j t v v v v v v v v v v t W 2 = . ", ". V ' f g h g | i 1 i 3 j 4 5 4 5 6 8 @8 W t v t o v v v v v v v v 4 g i+M.L.r.L.M.Q h 4 v v v v v v v v v v v v j %@. ", ". s ' f g h g | | 1 i 1 2 3 5 7 7 6 8 @8 @t v t o v v v v v v v 5 C.{.B.L.r.r.r.L.B.O C.5 v v v v v v v v v v v j %@. ", ". V ' g C.f g | | 1 i 3 j 4 5 4 5 9 8 @8 @0 v t o v v v v v v 6 &@~.b+x.r.r.r.r.r.x.b+0.&@6 v v v v v v v v v v j %@. ", ". V ' g g h g | i 1 i 3 j 4 5 4 7 9 9 @8 @0 W t o v v v v v 6 q.t.y.x.r.r.r.r.r.r.r.x.y.t.q.6 v v v v v v v v v j %@. ", ". s ' g C.f g h i 1 i 1 2 4 5 6 7 9 8 @8 W 0 W t o v v v v 7 q.H j.m.r.r.r.r.r.r.r.r.r.m.j.d.q.7 v v v v v v v v j %@. ", ". V ' g C.f g h } | i 3 j 3 5 6 5 6 8 @8 @t v t o v v v 9 *@D j.m.r.r.r.r.r.r.r.r.r.r.r.m.j.D A.9 v v v v v v v j %@. ", ". V ' g g h g | } | i 3 j 4 5 6 7 9 7 @8 @t v t o v v v 9 ,.j.j.j.j.=@r.r.r.r.r.r.r.=@j.j.j.j.,.9 v v v v v v v j %@. ", ". V ' g g h g | i 1 i 3 3 j 5 4 7 9 8 @8 @t v t o v v v 9 g n.' ' ' j.r.r.r.r.r.r.r.j.' ' ' n.g 9 v v v v v v v j %@. ", ". V ' g g h g h i 1 i 3 3 4 5 4 5 9 8 9 0 W t v t o v v v v v v v W f j.r.r.r.r.r.r.r.j.f W v v v v v v v v v v v j %@. ", ". V ' g g h g | i 1 i j 2 4 5 4 5 9 8 @8 @0 v t o v v v v v v v W f j.r.r.r.r.r.r.r.j.f W v v v v v v v v v v v j %@. ", ". V ' g g h } | i 1 i 1 j 3 5 4 5 9 8 @8 W 0 W t o v v v v v v v W f j.r.r.r.r.r.r.r.j.f W v v v v v v v v v v v j %@. ", ". V ' f g h } | } | i 3 j 4 5 6 7 9 8 9 8 W 0 W t o v v v v v v v W f j.r.r.r.r.r.r.r.j.f W v v v v v v v v v v v j %@. ", ". # ' f g h g | i | i 3 3 j 5 4 7 9 8 @8 W 0 W t o v v v v v v v W f j.r.r.r.r.r.r.r.j.f W v v v v v v v v v v v j %@. ", ". # ' g g h } | } 1 i 3 j 4 5 4 5 9 9 @8 @t v t o v v v v v v v t 9 j.j.j.j.j.j.j.j.j.9 t v v v v v v v v v v v j %@. ", ". # ' g g h g | i 1 i 1 2 4 5 4 5 9 8 @8 @0 v t o v v v v v v v v 2 q.' ' ' ' ' ' ' q.2 v v v v v v v v v v v v j %@. ", ". # ' g g h g | i 1 i j j 4 5 4 5 6 7 @8 @t v t o v v v v v v v v v v v v v v v v v v v v v v v v v v v v v v v j %@. ", ". @ ' ' ' ~ ~ ! n.-@h+q.*@;@&@&@l.g h } } 2 3 3 j 5 j j j j j j j j j j j j j j j j j j j j j j j j j j j j j j j g - . ", ". + %@% & & & & * * * * >@>@>@>@>@@ @ @ @ @ %@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@%@- > . ", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . "}; elseif pic == '1' then Image = { --XpmImage Here }; end return Image end function ImageBottom(pic) local Image = { "60 60 122 2", " c #ACACAC", ". c #ADADAD", "+ c #A5A5A5", "@ c #9E9E9E", "# c #9D9D9D", "$ c #9C9C9C", "% c #F2F2F2", "& c #FFFFFF", "* c #B8B8B8", "= c #B3B3B3", "- c #F1F1F1", "; c #F0F0F0", "> c #FDFDFD", ", c #C5C5C5", "' c #BDBDBD", ") c #AEAEAE", "! c #ECECEC", "~ c #EEEEEE", "{ c #EFEFEF", "] c #FBFBFB", "^ c #C3C3C3", "/ c #AFAFAF", "( c #EBEBEB", "_ c #EDEDED", ": c #FAFAFA", "< c #C2C2C2", "[ c #C0C0C0", "} c #EAEAEA", "| c #F9F9F9", "1 c #BFBFBF", "2 c #B0B0B0", "3 c #E9E9E9", "4 c #F8F8F8", "5 c #828282", "6 c #393939", "7 c #323232", "8 c #3D3D3D", "9 c #4C4C4C", "0 c #5A5A5A", "a c #5B5B5B", "b c #595959", "c c #5D5D5D", "d c #4E4E4E", "e c #343434", "f c #313131", "g c #F7F7F7", "h c #C1C1C1", "i c #E8E8E8", "j c #818181", "k c #5C5C5C", "l c #F6F6F6", "m c #E7E7E7", "n c #E6E6E6", "o c #7A7A7A", "p c #383838", "q c #434343", "r c #5E5E5E", "s c #4F4F4F", "t c #F3F3F3", "u c #E5E5E5", "v c #E4E4E4", "w c #E3E3E3", "x c #E2E2E2", "y c #BEBEBE", "z c #E1E1E1", "A c #8D8D8D", "B c #161616", "C c #E0E0E0", "D c #969696", "E c #171717", "F c #DFDFDF", "G c #9F9F9F", "H c #181818", "I c #DEDEDE", "J c #A9A9A9", "K c #1C1C1C", "L c #1B1B1B", "M c #A8A8A8", "N c #DCDCDC", "O c #DDDDDD", "P c #1F1F1F", "Q c #1E1E1E", "R c #B1B1B1", "S c #BBBBBB", "T c #DBDBDB", "U c #B7B7B7", "V c #222222", "W c #B6B6B6", "X c #BCBCBC", "Y c #272727", "Z c #DADADA", "` c #2C2C2C", " . c #D8D8D8", ".. c #D9D9D9", "+. c #C7C7C7", "@. c #C6C6C6", "#. c #CBCBCB", "$. c #B9B9B9", "%. c #D6D6D6", "&. c #D7D7D7", "*. c #CDCDCD", "=. c #3F3F3F", "-. c #C8C8C8", ";. c #C9C9C9", ">. c #CACACA", ",. c #C4C4C4", "'. c #D2D2D2", "). c #B4B4B4", "!. c #CCCCCC", "~. c #747474", "{. c #404040", "]. c #353535", "^. c #757575", "/. c #CFCFCF", "(. c #999999", "_. c #D0D0D0", ":. c #989898", "<. c #B2B2B2", "[. c #CECECE", "}. c #A1A1A1", "|. c #A0A0A0", "1. c #A2A2A2", " . . . . . . . . . . . . . . . . . . . . ", " + @ # # # # # # # # # # $ # # $ # # $ # # # # $ $ $ # $ # $ # $ # # # # # # $ $ $ $ # # # # $ # # # # # $ # # . . ", " % & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & & * = ", "= - - ; ; ; - - ; ; ; ; ; ; ; ; ; - - ; - ; - ; ; ; - - - ; - - - - ; ; ; ; ; - - - ; ; ; ; - - ; ; - ; ; ; ; - ; > , ' ", ") ! ; ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ { ~ ~ { ~ ~ ~ ~ ~ ~ { ~ ~ ~ ~ ~ ~ ~ ~ ~ { { ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ] ^ ' ", "/ ( ~ _ _ _ _ _ _ _ _ _ _ ~ ~ _ ~ _ _ _ _ _ _ _ _ _ _ ~ _ _ _ _ _ _ _ _ ~ ~ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ : < [ ", "/ } ~ _ _ ! _ ! ! _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! ! ! _ _ _ _ _ _ _ _ _ ! _ _ _ _ _ _ _ _ _ _ _ _ ! _ _ _ _ _ | < 1 ", "2 3 ! ( ( ( ( ( ( ( ! ( ( ! ! ( ( ( ( ( ! ( ( ! ( ( ( ( ( ( ( ( ( ! ( ( ( ( ( ( ( ( ( ! ( ( ( ( ( ( ! ! ( ( ! ( ( 4 < 1 ", "/ 3 ( } } ( } ( } } } } ( ( 5 6 7 8 9 0 a b b b b b b b b b b b b b b b b b b b b 0 c d e f f f } } } } } ( ( } } g h 1 ", "/ i } 3 3 3 } } 3 3 3 3 } 3 j 6 7 8 9 0 a b b b b b b b b b b b b b b b b b b b b b k d e f f f 3 3 3 3 3 } } 3 3 l h 1 ", "/ m } 3 3 3 3 3 3 3 3 3 3 n o p f f q 0 c 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 a r s e f f f 3 3 3 3 3 3 3 3 3 l h 1 ", "2 n m n i m m m i n m m m m i m m i m m i m m i n i i i m m i i n i i m i i i m m i m m m i i m i m m m i i m m m t [ [ ", "/ u m n m n n n n m n n n n m n n m n n n n n m m m m n m n n n n n m n n n m n n m n n n n n n n n n n n n n n n % 1 1 ", "/ v u u u u u u n u u u u n u u u n u u u u u u u u u u u u u u u u u u u u u u u u u n u u u u u u u u u u u u u % 1 [ ", "2 w v v v v v v v v v v v v v v v v v v v v v v v v v v w v v v v v v v v v v v v v v v v v w v v v v v v v v v v ; 1 [ ", "/ w v v v v v w v v v v w w w v v x v v v v v v w w w v w v v v w w v v v v v w v v v v w v v v v v v v v w w v v ~ y [ ", "2 x w w w w x x w w w x x w x x w x w w x w w x x x x x x w w 5 j w w x x x w w w x x w x x x w w x x w w w x x x ~ y h ", "/ z z x z z z z z z z z z x z z z x x z z z z x z z x x z z A B B A x x z z z x z z z z z z x x x z z x x x z x x _ ' h ", "/ C C z C C C C C C C C z C C C C C C C C C C C C C C z z D E B B E D C C C C C C z C C C z C C z z C C C C C C C ( ' h ", "2 F F F F F F C F F C F F F F F F F F F F F F F F F F F G H B B B B H G F F F F F C F F F F F F F F F F F F F F F } ' h ", "/ F F F F F F F F F I F F F F F F F F F F F F F F F I J K B B B B B B L M F F F F I F F F F F F F F F I F F F F F 3 ' h ", "2 I N I I I O O O I O I I I O I I I O I I I I I I I 2 P B B B B B B B B Q R I I O I I O I I I I O O O O O O O O I i S h ", "2 O T N O N O O O O N N N N O O O N N O O N N N O U V B B B B B B B B B B V W N O O O O O O N N O O N O O O N N O m S < ", "/ N T T T T N N N T T T T T N N T T T T T T N N X Y B B B B B B B B B B B B Y X N T T N T N T T T N T N N N T T T n S < ", "2 T Z T T T T T T T T T T T T T T T T T T T T < ` B B B B B B B B B B B B B B ` < T T T T T T T T T T T T T T T T v S < ", "/ Z .......Z Z ....Z Z Z Z ..Z Z Z Z Z Z ..+.f B B B B B B B B B B B B B B B B f @.Z Z Z Z .. .....Z Z ..........w S < ", "2 Z .... . ..... .........................#.p B B B B B B B B B B B B B B B B B B 6 #.....Z ........... ..... . .w $.< ", "2 ..%.&.&.&.&.%.&. . .%.%.&.&.&.%.%.&.&.*.=.B B B B B B B B B B B B B B B B B B B B =.*.&.&.&.&.&.&. .%.%. .&.%.&.C $.^ ", "2 *.-.;.;.>.>.;.>.>.>.>.>.>.>.>.>.>.>.,.q B B B B B B B B B B B B B B B B B B B B B B q ,.>.>.>.>.>.>.;.>.>.>.>.>.'.)., ", "2 !., +.-.;.+.+.;.+.+.;.-.+.;.+.;.;.-.~.{.{.{.{.{.].B B B B B B B B B B B B ].{.{.{.{.{.^.-.+.-.-.-.+.+.-.-.-.-.-./.= ,.", "R !.@.;.;.-.;.;.-.-.;.;.;.-.-.;.-.-.-.-.;.;.-.;.-.(.B B B B B B B B B B B B (.-.;.-.-.;.;.-.-.;.-.;.;.-.-.;.-.-.;._.= , ", "R !., ;.-.-.;.;.-.-.-.-.;.;.-.-.;.;.-.;.;.;.-.;.;.(.B B B B B B B B B B B B (.-.-.;.-.-.-.-.;.;.-.-.;.;.;.-.-.;.;._.= , ", "R !., -.-.;.-.;.-.-.-.-.-.;.-.-.;.-.-.;.;.-.-.-.;.(.B B B B B B B B B B B B (.;.;.-.-.-.;.;.;.;.-.;.;.-.-.;.;.;.;._.= ,.", "R !.@.-.;.-.;.-.;.;.-.;.-.;.-.;.;.-.;.;.;.-.;.-.;.(.B B B B B B B B B B B B (.;.;.-.;.;.;.-.-.;.;.;.;.-.;.;.;.;.;._.= , ", "2 #.,.+.-.+.+.-.+.+.+.+.+.+.+.-.-.+.-.-.+.+.-.+.+.:.B B B B B B B B B B B B :.+.+.+.-.-.+.+.+.+.-.-.+.+.-.+.-.+.+./.<., ", "2 #.,.+.+.+.+.+.+.-.+.+.+.+.+.+.+.-.+.+.+.+.-.+.+.:.B B B B B B B B B B B B :.-.-.+.+.+.+.+.+.+.+.+.+.+.+.+.-.-.+./.= , ", "R !., +.-.+.+.+.+.+.+.+.-.-.+.-.-.+.-.+.+.+.+.+.+.(.B B B B B B B B B B B B :.+.+.+.+.-.+.+.+.-.+.+.+.-.-.-.+.+.-.[.= , ", "R #.,.+.+.+.+.+.-.-.+.+.+.+.+.+.+.+.+.+.-.+.-.+.+.:.B B B B B B B B B B B B :.-.-.+.+.+.+.+.-.+.+.+.+.+.-.+.+.+.+.[.= , ", "2 #., +.+.+.+.+.+.+.+.+.+.-.-.+.+.+.+.-.-.-.+.+.+.:.B B B B B B B B B B B B :.-.+.+.+.+.+.+.+.-.-.-.+.+.-.+.+.+.+./.= , ", "2 #.,.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.:.B B B B B B B B B B B B :.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.+.[.<., ", "2 >.^ @.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.*.<.@.", "R >.^ @.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.*.<., ", "2 >.^ @.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.*.<., ", "2 >.^ @.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.*.<., ", "R >.^ @.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.*.<., ", "2 >.^ @.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.*.<., ", "2 ;.< , , ,., , , , , , , , ,.,.,., , ,., , ,., , , , , , , ,., ,., ,., ,.,., , , ,., , , , ,., , , , , , , , , , !.<., ", "R ;.< , , , ,., , , , , , ,., , ,., , , , , , , , ,.,.,., , , , , , , , , , , , ,., ,.,.,.,., ,., , , , , , , , , !.<., ", "2 ;.< , , ,., , , , , , , , , , , , , , , , , ,.,., , , ,., , , , , , , , , ,., , , , , , ,.,., , , , , , , , ,., !.R @.", "2 ;.< , , , , ,.,., , ,., , , , , , , , , , , ,., , , , , , , , , , , , , , , , , , , , , , , , , ,., , , , , , , #.R @.", "2 -.< , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , ,.,., , , , , , , , ,.,., , , , , , , , , , , , !.<., ", "R ;.[ ,.,.^ ,.,.,.,.,.^ ,.,.,.,.,.,.,.,.,.,.,.^ ,.,.,.,.,.,.,.,.,., , ^ ,.,.,.,.,.,.,., , ,.,.,.,.,.,.,.,.,.,.^ ,.#.R , ", "2 ;.< , , ,., , , , , , , , , , , , , , , , , ,.,., , , ,., , , , , , , , , ,., , , , , , ,.,., , , , , , , , ,., !.<.,.", "2 ;.< , , , , ,.,., , ,., , , , , , , , , , , ,., , , , , , , , , , , , , , , , , , , , , , , , , ,., , , , , , , #.<.< ", "2 -.< , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , ,.,., , , , , , , , ,.,., , , , , , , , , , , , !.<.X ", "2 ;.[ ,.,.^ ,.,.,.,.,.^ ,.,.,.,.,.,.,.,.,.,.,.^ ,.,.,.,.,.,.,.,.,., , ^ ,.,.,.,.,.,.,., , ,.,.,.,.,.,.,.,.,.,.^ ,.#. = ", "2 ;.S [ [ [ [ [ [ 1 [ [ 1 [ [ 1 [ [ 1 [ [ [ 1 [ 1 [ [ [ [ [ [ [ 1 [ [ [ [ [ 1 [ 1 [ [ [ [ [ [ 1 1 1 [ [ 1 [ 1 [ [ , ) ", "2 ;.z F I I F I I F F F F I I F F I I I F I I F I I I F F I F I I I I F F I I I F I I F F F F I F F I I I F I F F _ ", "2 J }.}.}.}.}.}.}.|.}.|.|.|.}.|.}.1.}.}.}.}.}.}.}.}.|.}.|.}.}.}.}.|.|.}.|.}.|.|.}.|.}.}.|.}.}.}.}.}.}.|.|.|.|.}. ", "2 2 2 . . . . . . . . . . . . . . . . . "}; return Image end function ImageBottomRight(pic) if (pic == nil) then pic = '0' end if pic == '0' then Image = { "60 60 288 2", " c None", ". c #9F9F9F", "+ c #9D9D9D", "@ c #9B9B9B", "# c #999999", "$ c #989898", "% c #969696", "& c #949494", "* c #939393", "= c #979797", "- c #BBBBBB", "; c #C0C0C0", "> c #C5C5C5", ", c #C6C6C6", "' c #C7C7C7", ") c #E7E7E7", "! c #E5E5E5", "~ c #EDEDED", "{ c #C9C9C9", "] c #CBCBCB", "^ c #CACACA", "/ c #CCCCCC", "( c #DCDCDC", "_ c #DADADA", ": c #C3C3C3", "< c #CECECE", "[ c #D1D1D1", "} c #D8D8D8", "| c #E1E1E1", "1 c #EAEAEA", "2 c #E9E9E9", "3 c #E8E8E8", "4 c #E6E6E6", "5 c #E4E4E4", "6 c #E3E3E3", "7 c #E2E2E2", "8 c #E0E0E0", "9 c #DFDFDF", "0 c #DEDEDE", "a c #D4D4D4", "b c #D0D0D0", "c c #CFCFCF", "d c #D2D2D2", "e c #D3D3D3", "f c #DBDBDB", "g c #D5D5D5", "h c #ACACAC", "i c #545454", "j c #292929", "k c #232323", "l c #252525", "m c #262626", "n c #2B2B2B", "o c #2D2D2D", "p c #313131", "q c #343434", "r c #393939", "s c #3D3D3D", "t c #434343", "u c #484848", "v c #4C4C4C", "w c #515151", "x c #555555", "y c #585858", "z c #5B5B5B", "A c #5F5F5F", "B c #626262", "C c #636363", "D c #696969", "E c #838383", "F c #BABABA", "G c #D7D7D7", "H c #7F7F7F", "I c #272727", "J c #353535", "K c #3C3C3C", "L c #3F3F3F", "M c #414141", "N c #424242", "O c #444444", "P c #4B4B4B", "Q c #4D4D4D", "R c #525252", "S c #5A5A5A", "T c #5E5E5E", "U c #666666", "V c #6C6C6C", "W c #6F6F6F", "X c #717171", "Y c #747474", "Z c #707070", "` c #9E9E9E", " . c #D6D6D6", ".. c #ADADAD", "+. c #3A3A3A", "@. c #3E3E3E", "#. c #454545", "$. c #464646", "%. c #494949", "&. c #4E4E4E", "*. c #505050", "=. c #6D6D6D", "-. c #727272", ";. c #757575", ">. c #767676", ",. c #686868", "'. c #363636", "). c #404040", "!. c #474747", "~. c #4A4A4A", "{. c #646464", "]. c #6E6E6E", "^. c #737373", "/. c #777777", "(. c #DDDDDD", "_. c #535353", ":. c #575757", "<. c #5D5D5D", "[. c #616161", "}. c #656565", "|. c #6B6B6B", "1. c #4F4F4F", "2. c #5C5C5C", "3. c #606060", "4. c #676767", "5. c #6A6A6A", "6. c #F3F3F3", "7. c #F4F4F4", "8. c #000000", "9. c #FAFAFA", "0. c #FFFFFF", "a. c #F1F1F1", "b. c #111111", "c. c #EFEFEF", "d. c #010101", "e. c #161616", "f. c #EEEEEE", "g. c #595959", "h. c #ECECEC", "i. c #020202", "j. c #121212", "k. c #0A0A0A", "l. c #4E4C49", "m. c #575048", "n. c #5D5144", "o. c #635545", "p. c #67594A", "q. c #675E53", "r. c #65615C", "s. c #666564", "t. c #030303", "u. c #403F3E", "v. c #4A433B", "w. c #544330", "x. c #36587E", "y. c #2265B0", "z. c #166CCD", "A. c #166DCE", "B. c #34679D", "C. c #5F5D5A", "D. c #6A5E51", "E. c #67635F", "F. c #040404", "G. c #131313", "H. c #565656", "I. c #434241", "J. c #42382E", "K. c #413F3C", "L. c #0770E4", "M. c #007CFF", "N. c #0079FF", "O. c #0078FF", "P. c #007AFF", "Q. c #3367A1", "R. c #6B5C4C", "S. c #64615D", "T. c #1A1A1A", "U. c #060606", "V. c #4B443C", "W. c #42403D", "X. c #0081FF", "Y. c #0076FA", "Z. c #0176F8", "`. c #0076FD", " + c #3266A0", ".+ c #675B4E", "++ c #5F5E5D", "@+ c #222222", "#+ c #4F4C4A", "$+ c #554432", "%+ c #076FE3", "&+ c #5C5853", "*+ c #5F5952", "=+ c #D9D9D9", "-+ c #564F48", ";+ c #36587D", ">+ c #156DCE", ",+ c #605345", "'+ c #5D5143", ")+ c #2264AF", "!+ c #0077FC", "~+ c #0075FE", "{+ c #604D37", "]+ c #2C2C2C", "^+ c #645544", "/+ c #0771E7", "(+ c #0076F9", "_+ c #007DFF", ":+ c #5D472F", "<+ c #655747", "[+ c #156CCC", "}+ c #007EFF", "|+ c #59442D", "1+ c #EBEBEB", "2+ c #655C51", "3+ c #32649C", "4+ c #52412E", "5+ c #303030", "6+ c #635F5A", "7+ c #5D5957", "8+ c #007BFF", "9+ c #0077FD", "0+ c #255993", "a+ c #4B4237", "b+ c #61605F", "c+ c #31639D", "d+ c #0670E5", "e+ c #4D3B27", "f+ c #46423E", "g+ c #2A2A2A", "h+ c #615E5A", "i+ c #2F639B", "j+ c #056FE4", "k+ c #3F3E3F", "l+ c #443D36", "m+ c #282828", "n+ c #F5F5F5", "o+ c #5E5B57", "p+ c #605447", "q+ c #534F4C", "r+ c #136CCC", "s+ c #0077FE", "t+ c #007FFF", "u+ c #0080FF", "v+ c #066FE3", "w+ c #235791", "x+ c #483622", "y+ c #423B34", "z+ c #585756", "A+ c #57524B", "B+ c #584B3D", "C+ c #58442F", "D+ c #564027", "E+ c #523D25", "F+ c #4D3C2A", "G+ c #473E33", "H+ c #413E3A", "I+ c #848484", "J+ c #AEAEAE", "K+ c #828282", "L+ c #383838", "M+ c #333333", "N+ c #242424", "O+ c #C8C8C8", "P+ c #CDCDCD", "Q+ c #929292", "R+ c #1B1B1B", "S+ c #FDFDFD", "T+ c #050505", "U+ c #909090", "V+ c #FBFBFB", "W+ c #8F8F8F", "X+ c #FEFEFE", "Y+ c #F7F7F7", "Z+ c #373737", "`+ c #F9F9F9", " @ c #F0F0F0", ".@ c #919191", "+@ c #8E8E8E", "@@ c #F2F2F2", "#@ c #090909", "$@ c #8D8D8D", "%@ c #F8F8F8", "&@ c #8C8C8C", "*@ c #FCFCFC", "=@ c #878787", "-@ c #898989", ";@ c #888888", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ", ". + @ # $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ $ % & * * * * * * * * * * * * * * * * = @ . ", ". @ - ; > , ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' , > ) ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ~ = . ", ". # ; > { ] ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ] / ] ( _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ : { / < [ } | ) 1 1 1 2 2 3 3 ) ) 4 ! 5 6 6 7 | | | 8 8 9 0 _ a b c c [ d e f _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ , ] < g | h i j k l m j n o p q r s t u v w x y z A A B C D E F _ a d e g G _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ [ | H I J K L M N N O u P Q R i S T B U D V W X X Y Y Y Z D ` f e a .} _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ } ..j +.@.@.@.L N N #.$.%.&.*.i S T B U D V =.X -.-.;.>.;.Y ,.F G a .} _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 8 x '.).).@.@.).M M #.!.~.v w x y T B {.D V ].Z -.^.^.Y >./.X E (.a .} _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ ) o @.M L ).@.@.L N O #.%.P *._.:.<.[.}.,.|.].Z Z ^.Y ;.>.;.;.|.| a .} _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 2 m M N ).M L @.@.).t O u ~.1.R y 2.3.{.4.5.=.W X -.-.^.;.>.;.C 6 a .} _ _ _ _ _ _ 8 8 8 _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 2 j O N t M ).L @.L N t !.%.&.w x z A C U D V ].Z Z ^.-.^.;.Y {.6 a .} _ _ _ _ _ | 6.&.~ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 2 n $.O #.O t N L @.L t $.%.Q w x y T 3.}.,.|.=.W W -.^.-.Y ^.C 6 a .} _ _ _ _ 7 7.3.8.9._ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 3 o u $.!.$.#.O M L @.).O $.P 1.R y 2.3.C }.D V V W W Z -.^.^.3.5 a .} _ _ _ 7 7._.8.8.0._ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 3 p P %.u !.$.#.#.t L s M O %.Q w i S T [.}.U 5.V V W Z X Z -.A 5 a .} _ _ 6 a.~.8.b.8.0.( ( ( ( ( f _ _ ! * . ", ". $ > ^ ) q &.v P v %.%.$.O t L s N #.%.1._.:.z A B }.,.5.V =.].W Z Z T 5 a .} f 5 c.L d.b.e.8.0.f.f.f.f.f.8 ) _ ! * . ", ". $ > ^ 4 r *.w 1.&.&.P %.!.$.N L @.t u v 1._.g.2.3.C }.U ,.|.V =.].].S ! a .} ! h.q i.j.e.e.k.8.8.8.8.8.8.8.7._ ! * . ", ". $ > ^ 4 @.i x i _.R *.&.v u #.N @.).O %.l.m.n.o.p.q.r.s.4.,.5.|.|.V y ! a G 5 2 o t.j.e.e.e.e.e.e.e.e.e.e.8.0._ ! * . ", ". $ > ^ ! t y g.y :.i i R &.Q ~.!.N @.u.v.w.x.y.z.A.B.C.D.E.}.}.U 4.D i 4 g 6 7 k F.G.e.e.e.e.e.e.e.e.e.e.e.8.0._ ! * . ", ". $ > ^ 5 u T <.2.z S y H.i w &.P !.I.J.K.L.M.N.O.O.O.P.Q.R.S.C {.}.U w 4 0 G T.U.G.e.e.e.e.e.e.e.e.e.e.e.e.8.0._ ! * . ", ". $ > ^ 6 v B [.3.A T 2.S y x R Q P V.W.X.N.Y.Z.Z.Z.Z.`.N. +.+++3.[.B v ) 9 @+8.j.e.e.e.e.e.e.e.e.e.e.e.e.e.8.0._ ! * . ", ". $ > ^ 6 w U }.{.C B 3.T S g.H.R #+$+%+N.Z.Z.Z.Z.Z.Z.Z.`.P.&+*+2.<.T !.3 0 =+T.U.G.e.e.e.e.e.e.e.e.e.e.e.e.8.0._ ! * . ", ". $ > ^ 7 x D 4.U }.}.{.3.A <.y H.-+;+M.Y.Z.Z.Z.Z.Z.Z.Z.Z.O.>+,+y g.y N 2 g 6 | I F.G.e.e.e.e.e.e.e.e.e.e.e.8.0._ ! * . ", ". $ > ^ | g.V |.|.5.,.4.}.[.3.<.g.'+)+N.Z.Z.Z.Z.Z.Z.Z.Z.Z.!+~+{+i x i @.2 a G 5 2 ]+t.j.e.e.e.e.e.e.e.e.e.e.8.0._ ! * . ", ". $ > ^ | z ].].=.V |.,.U }.C 3.2.^+/+O.Z.Z.Z.Z.Z.Z.Z.Z.Z.(+_+:+1.w *.r 1 a .} ! ~ '.i.j.e.e.k.8.8.8.8.8.8.8.7._ ! * . ", ". $ > ^ | A Z Z W ].=.V 5.,.}.B A <+[+O.Z.Z.Z.Z.Z.Z.Z.Z.Z.Y.}+|+P v &.q 1+a .} _ 5 c.M d.b.e.8.0.f.f.f.f.f.8 ) _ ! * . ", ". $ > ^ 8 3.-.Z X Z W V V 5.U }.[.2+3+N.Z.Z.Z.Z.Z.Z.Z.Z.Z.O.%+4+u %.P 5+1+a .} _ _ 6 a.~.8.b.8.0.( ( ( ( ( f _ _ ! * . ", ". $ > ^ 8 [.^.^.-.Z W W V V D }.C 6+7+8+9+Z.Z.Z.Z.Z.Z.Z.Y.M.0+a+!.$.u ]+h.a .} _ _ _ 7 7.x 8.8.0._ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 8 C ^.Y -.^.-.W W =.|.,.}.b+.+c+P.9+Z.Z.Z.Z.Z.Y.P.d+e+f+#.O $.g+h.a .} _ _ _ _ 7 7.3.8.9._ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 8 }.Y ;.^.-.^.Z Z ].V D U C h+<+i+M.N.9+(+Y.O._+j+k+l+M t N O m+~ a .} _ _ _ _ _ | n+&.~ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ 9 {.;.>.;.^.-.-.X W =.5.4.{.3.o+p+q+r+s+t+u+v+w+x+y+u.M ).N M l ~ a .} _ _ _ _ _ _ 8 8 8 _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ (.V ;.;.>.;.Y ^.Z Z ].|.,.}.[.<.z+A+B+C+D+E+F+G+H+@.@.).L M @.]+1+a .} _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ =+I+X /.>.Y ^.^.-.Z ].V D {.B T y x w v ~.!.#.M M ).@.@.).).'.i 5 a .} _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ a F ,.Y ;.>.;.-.-.X =.V D U B T S i *.&.%.$.#.N N L @.@.@.+.j J+f e g G _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ ! * . ", ". $ > ^ c _ ` ,.W Y Y Y X X W V D U B T S i R Q P u O N N M L K J I H | a e G =+_ =+=+=+=+=+=+=+=+=+=+=+=+=+=+=+=+6 * . ", ". $ ' ] c a f - K+,.B [.A T S y i w v !.N K L+M+5+]+g+m+l N+k g+_.h | .d a .} f f f f f f f f f f f f f f f f f ! * . ", ". = O+/ b d e G (.| 6 6 ! ! 5 ! ! 4 ) 2 1 1+1+h.~ h.h.~ ~ ~ ~ 1+5 f a d e g G _ f _ _ _ ( ( _ _ _ _ _ ( ( ( _ _ _ 4 * . ", ". = { P+d g a a g g a a a a a a a a .9 8 9 g a a a a a g g g g g a a g .G _ _ (.f f (.(.(.f f f f (.(.(.(.f (.f 4 * . ", ". = ] b .} =+G G G G =+=+=+=+=+G } 4 (.@+f 4 _ =+=+=+G G G G G G G =+} _ f ( (.0 ( 0 0 0 ( 0 0 0 ( 0 ( ( ( 0 0 0 ) Q+. ", ". & ] c G f ( ( ( ( ( ( ( ( ( ( ( 3 4 R+8.R+4 3 ( ( ( ( ( ( ( ( ( ( ( f f (.0 (.9 9 9 9 9 9 9 9 9 (.9 9 9 9 9 9 9 1+Q+. ", ". Q+S+8 8 9 9 9 9 9 9 9 9 9 9 9 1+c.I T+b.T+N+c.1+8 9 9 9 9 9 9 9 9 9 9 9 9 9 0 0 0 0 0 0 0 0 0 0 8 0 0 8 0 0 0 0 1+Q+. ", ". U+V+(.9 9 9 9 9 9 | | 9 9 | 1 6.o F.G.e.G.F.o 6.1 8 9 9 8 9 | | 9 9 9 9 9 8 8 9 9 9 9 8 9 9 | 9 9 9 9 9 9 8 9 | h.Q+. ", ". W+X+8 7 8 7 7 7 8 8 7 7 7 1+Y+Z+t.G.e.e.e.G.t.'.`+h.7 8 8 8 8 7 7 8 8 7 8 8 8 8 7 7 8 8 8 7 8 8 8 8 8 8 8 8 8 7 ~ Q+. ", ". W+0.9 | | 6 6 6 | | 6 6 1 9.N d.j.e.e.e.e.e.j.i.).V+h.| 6 6 | | | | | | 6 6 | 6 6 | 6 | | 6 | | 6 6 6 | | 6 6 6 @.@. ", ". W+0.7 5 7 7 5 5 5 5 5 h.0.&.8.j.e.e.e.e.e.e.e.j.8.Q X+h.5 5 7 5 7 6 7 5 5 5 5 5 5 | 5 5 7 7 7 5 5 5 5 7 5 5 5 5 a..@. ", ". W+0.| 6 6 6 6 6 6 6 1+0.:.8.b.e.e.e.e.e.e.e.e.e.b.8.:.0.1+5 7 5 6 5 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 a..@. ", ". +@0.7 ! ! ! ! ! ! h.0.}.8.b.e.e.e.e.e.e.e.e.e.e.e.b.8.}.0.h.! 5 5 5 5 5 5 ! ! ! 5 4 5 5 5 4 5 ! 5 5 4 5 ! 5 5 5 @@.@. ", ". +@0.6 4 ! ! ! ! 4 ~ R 8.8.8.8.#@e.e.e.e.e.e.e.#@8.8.8.8.w ~ ) ! ) ) ) ) ! ! ! ! ! ) ! ! ) ! ! 4 4 ) ! ! 4 ! ) ! n+.@. ", ". +@0.5 4 4 3 3 4 4 ~ S+0.0.0.0.8.e.e.e.e.e.e.e.8.0.0.0.0.S+~ 4 3 3 3 5 3 4 4 3 4 4 3 4 4 3 4 4 4 4 ! 3 4 4 4 3 ! 7.U+. ", ". +@0.4 2 2 2 2 2 2 2 2 ) 2 1+X+8.e.e.e.e.e.e.e.8.X+1+2 2 2 2 2 2 2 2 2 2 ) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 `+U+. ", ". $@0.4 3 1 1 3 3 3 3 3 1 3 1+X+8.e.e.e.e.e.e.e.8.X+1+1 1 3 3 3 3 3 3 3 3 1 3 3 1 3 3 3 3 3 1 1 3 3 3 3 1 1 3 3 3 %@U+. ", ". $@0.) 2 1+1+2 2 2 2 2 1+2 h.0.8.e.e.e.e.e.e.e.8.0.h.2 2 2 1+1+2 1 2 1+2 2 2 2 1+2 1 1 2 2 1+1+2 2 2 2 1+2 1+2 2 9.U+. ", ". $@0.3 1 h.1 1 h.h.1 1 1 1 ~ 0.8.e.e.e.e.e.e.e.8.0.c.1 1 1 1 1 1 1 1 1 h.1 1 h.1 1 1 1 1 h.h.1 1 h.1 1 1 1 1 1 1 V+W+. ", ". $@0.1 ~ ~ ~ ~ 1+~ ~ ~ ~ ~ @0.8.e.e.e.e.e.e.e.8.0. @~ ~ ~ ~ 1+1+1+~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ 1+1+~ 1+~ ~ S+W+. ", ". $@0.1 h.h.h.h.h.h.h.h.h.h.f.7.8.8.8.8.8.8.8.8.8.7.f.h.h.h.h.h.f.h.h.h.h.h.h.h.h.h.h.f.h.f.f.h.h.h.h.h.h.h.h.h.h.S+W+. ", ". &@0.1+~ ~ ~ ~ ~ ~ ~ ~ ~ ~ f.*@0.0.0.0.0.0.0.0.0.*@f.~ ~ ~ ~ ~ ~ c.~ ~ ~ ~ ~ ~ c.~ ~ c.~ c.c.~ ~ ~ ~ ~ ~ ~ ~ ~ ~ 0.W+. ", ". &@0.1+f.~ ~ ~ ~ f.~ ~ f.f.~ ~ ~ ~ f.f.f.~ ~ ~ ~ ~ f.f.f.f.~ f.f.f.~ ~ ~ f.~ f.~ f.f.~ ~ ~ ~ ~ ~ ~ ~ ~ f.f.~ ~ ~ 0.+@. ", ". Q+0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.* . ", ". $ Q+&@&@=@-@-@-@-@-@=@-@-@-@-@;@;@;@;@-@-@-@-@-@-@=@-@=@-@=@-@;@;@;@-@-@-@-@=@-@-@=@-@-@=@-@-@-@-@-@-@-@&@&@&@&@Q+$ . ", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . "}; elseif pic == '1' then Image = { --XpmImage Here }; end return Image end function ImageMeasureAngle(pic) --local pic = mc.mcProfileGetString(inst, 'ToffParams', 'ToffAngleOption', 'Value') if (pic == nil) then pic = '0' end if pic == '0' then Image = { "60 60 209 2", " c #9F9F9F", ". c #9D9D9D", "+ c #9C9C9C", "@ c #FFFFFF", "# c #F1F1F1", "$ c #F0F0F0", "% c #FDFDFD", "& c #EEEEEE", "* c #EFEFEF", "= c #FBFBFB", "- c #EDEDED", "; c #EAEAEA", "> c #E8E8E8", ", c #EBEBEB", "' c #FAFAFA", ") c #ECECEC", "! c #E9E9E9", "~ c #828282", "{ c #383838", "] c #E5E5E5", "^ c #525252", "/ c #8D8D8D", "( c #F9F9F9", "_ c #E4E4E4", ": c #3E3E3E", "< c #030303", "[ c #AFAFAF", "} c #D1D1D1", "| c #050505", "1 c #393939", "2 c #F8F8F8", "3 c #797979", "4 c #8E8E8E", "5 c #060606", "6 c #5F5F5F", "7 c #7E7E7E", "8 c #909090", "9 c #F7F7F7", "0 c #161616", "a c #6E6E6E", "b c #121212", "c c #181818", "d c #DCDCDC", "e c #2C2C2C", "f c #0E0E0E", "g c #DFDFDF", "h c #E7E7E7", "i c #F6F6F6", "j c #656565", "k c #E3E3E3", "l c #DEDEDE", "m c #545454", "n c #BDBDBD", "o c #0D0D0D", "p c #E6E6E6", "q c #5C5C5C", "r c #E2E2E2", "s c #E1E1E1", "t c #DDDDDD", "u c #D7D7D7", "v c #9E9E9E", "w c #555555", "x c #6D6D6D", "y c #111111", "z c #A5A5A5", "A c #F3F3F3", "B c #D8D8D8", "C c #D9D9D9", "D c #535353", "E c #E0E0E0", "F c #D5D5D5", "G c #252525", "H c #1D1D1D", "I c #282828", "J c #242424", "K c #D2D2D2", "L c #F2F2F2", "M c #4B4B4B", "N c #DBDBDB", "O c #DADADA", "P c #CBCBCB", "Q c #D0D0D0", "R c #696969", "S c #1A1A1A", "T c #8F8F8F", "U c #A9A9A9", "V c #1B1B1B", "W c #D3D3D3", "X c #434343", "Y c #D6D6D6", "Z c #C8C8C8", "` c #ACACAC", " . c #1F1F1F", ".. c #4D4D4D", "+. c #626262", "@. c #B6B6B6", "#. c #CDCDCD", "$. c #C9C9C9", "%. c #C3C3C3", "&. c #3B3B3B", "*. c #2A2A2A", "=. c #C4C4C4", "-. c #363636", ";. c #D4D4D4", ">. c #CACACA", ",. c #7C7C7C", "'. c #272727", "). c #858585", "!. c #989898", "~. c #B7B7B7", "{. c #2B2B2B", "]. c #494949", "^. c #585858", "/. c #C5C5C5", "(. c #CFCFCF", "_. c #C6C6C6", ":. c #C0C0C0", "<. c #505050", "[. c #2D2D2D", "}. c #B4B4B4", "|. c #2E2E2E", "1. c #C1C1C1", "2. c #C7C7C7", "3. c #CECECE", "4. c #8B8B8B", "5. c #2F2F2F", "6. c #898989", "7. c #919191", "8. c #414141", "9. c #333333", "0. c #4C4C4C", "a. c #343434", "b. c #BFBFBF", "c. c #474747", "d. c #BBBBBB", "e. c #C2C2C2", "f. c #5B5B5B", "g. c #303030", "h. c #A2A2A2", "i. c #B1B1B1", "j. c #616161", "k. c #CCCCCC", "l. c #B9B9B9", "m. c #BABABA", "n. c #313131", "o. c #6A6A6A", "p. c #767676", "q. c #999999", "r. c #646464", "s. c #9B9B9B", "t. c #636363", "u. c #BCBCBC", "v. c #B5B5B5", "w. c #969696", "x. c #6C6C6C", "y. c #B2B2B2", "z. c #3F3F3F", "A. c #B3B3B3", "B. c #4F4F4F", "C. c #717171", "D. c #A6A6A6", "E. c #B8B8B8", "F. c #424242", "G. c #464646", "H. c #292929", "I. c #262626", "J. c #676767", "K. c #A3A3A3", "L. c #8A8A8A", "M. c #212121", "N. c #4E4E4E", "O. c #8C8C8C", "P. c #878787", "Q. c #565656", "R. c #ADADAD", "S. c #AEAEAE", "T. c #ABABAB", "U. c #454545", "V. c #191919", "W. c #9A9A9A", "X. c #AAAAAA", "Y. c #3A3A3A", "Z. c #151515", "`. c #6F6F6F", " + c #959595", ".+ c #929292", "++ c #131313", "@+ c #A8A8A8", "#+ c #B0B0B0", "$+ c #0F0F0F", "%+ c #101010", "&+ c #5E5E5E", "*+ c #202020", "=+ c #222222", "-+ c #7A7A7A", ";+ c #0C0C0C", ">+ c #BEBEBE", ",+ c #444444", "'+ c #0A0A0A", ")+ c #070707", "!+ c #3C3C3C", "~+ c #A7A7A7", "{+ c #757575", "]+ c #A1A1A1", "^+ c #232323", "/+ c #848484", "(+ c #020202", "_+ c #A0A0A0", ":+ c #939393", " ", " . . . . . . . + . . + . . + . . . . + + + . + . + . + . . . . . . + + + + . . . . + . . . . . + ", " @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ ", " # $ $ $ # # $ $ $ $ $ $ $ $ $ # # $ # $ # $ $ $ # # # $ # # # # $ $ $ $ $ # # # $ $ $ $ # # $ $ # $ $ $ $ # $ % ", " $ & & & & & & & & & & * * & * & & * & & & & & & * & & & & & & & & & * * & & & & & & & & & & & & & & & & & & & = ", " & - - - - - - - - - - & & - & - - - - - - - ; > , & - - - - - - - - & & - - & $ * - - - - - - - - - - - - - - ' ", " & - - ) - ) ) - - - - - - - - - - - - - - ! ~ { ] ) ) - - - - - - - - - ) - $ ^ / * - - - - - - - ) - - - - - ( ", " ) , , , , , , , ) , , ) ) , , , , , ) , , _ : < [ ; , , , , , ) , , , , , ) } | 1 $ , , , , , , ) ) , , ) , , 2 ", " , ; ; , ; , ; ; ; ; 3 , ; ; ; ; ; , ; ; ; ] 4 5 6 ] , , ; ; ; ; ; ; ; ; ; , 7 5 8 ) ; ; ; , ; ; ; ; ; , , ; ; 9 ", " ; ! ! ! ; ; ! ! ! ! 0 a > ! ! ! ! ; ! > > ] } b c d > ! ! ; ; ! ! ; ! ! > ) e f g h > > ! ; ! ! ! ! ! ; ; ! ! i ", " ; ! ! ! ! ! ! ! ! ! 0 0 j h ! ! ! ! ! h _ k l m f _ > ! ! ! ! ! ! ! > > n o m ; _ ] h ! > ! ! ! ! ! ! ! ! ! i ", " h p > h h h > p h h 0 0 0 q r > h h h _ s t u v b w g ] > > p > > h > h h x y z g d s ] h h > h h h > > h h h A ", " h p h B B B B C B B 0 0 0 0 D E p p ] r t u } F G H } k ] p p p h p p k _ I J ] K u t r ] p p p p p p p p p p L ", " ] ] ] 0 0 0 0 0 0 0 0 0 0 0 0 M N ] _ s O K P Q R S T g _ ] ] ] ] ] _ r U V x d P W O s _ ] ] ] ] ] ] ] ] ] ] L ", " _ _ _ 0 0 0 0 0 0 0 0 0 0 0 0 0 X Y k E C Q Z Z ` ...O r _ _ _ _ _ r s +. .@.#.Z Q C E r _ _ _ _ _ _ _ _ _ _ $ ", " k _ _ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 : Q E N K $.%.K &.J %.g k k k _ k s B *.&._ =.$.K O E k _ _ _ _ _ _ k k _ _ & ", " r k k 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 -.P N ;.>.=.>.,.'.).N s k k k s l !.'.~ W %.>.;.N g r k k r r k k k r r r & ", " s s s 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 M t Y #.=.%.~.{.].Y l r r r E d ^.*.=./.=.#.Y d g r r r s s r r r s r r - ", " s E E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 -.$.t u (._.:.P <.[.}.N g E g t _.|.^ B 1.2.(.u t E E E s s E E E E E E E , ", " g g g 0 0 0 0 0 0 0 0 0 0 0 0 0 0 &.3.g t C } 2.1.=.4.5.3 Y t g l C 6.5.7.P 1.Z } B t g g g g g g g g g g g g ; ", " d d d 0 0 0 0 0 0 0 0 0 0 0 0 0 8.(.d d N B K Z :.n n 9.8.#.C N C ;.0.a.$.b.:.Z } B N d d d d d d d d d N B K Z ", " B B B 0 0 0 0 0 0 0 0 0 0 0 0 c.(.C C C B Y } $.:.d.e.f.g.h.K u F i.g.j.k.d.:.$.Q F B C C C C B B B B C B Y Q _. ", " F F F Z Z Z Z Z Z Z 0 0 0 0 ..3.F F F F F W (.$.b.l.m.8 n.o.P K #.p.n.q.b.l.b.$.(.W F F F F F F F F F F F K #.=. ", " K K K K K K K W W W 0 0 0 m (.W W W K K W K (.$.1.l.}.m.{ { b.#./.: { _.@.l.1.Z 3.} K K W W K K K K K K K Q k.%. ", " } } } } } } } } } } 0 0 f.(.} } } } } } } } (.>.e.m.}.m.r.g.7.2.s.g.o.1.}.m.e.>.(.} } } } } } } } } } } } (.P e. ", " Q Q Q Q Q Q Q Q Q Q 0 t.(.Q Q Q Q Q Q Q Q Q 3.P /.u.}.v.w.5.f.e.r.5.v ~.}.u./.P 3.Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q x.(.Q Q Q Q Q Q Q Q Q Q (.#.2.b.~.y.m.&.n.[ a.z.%.A.~.b.2.#.(.Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.e.l.A.@.x.[.B.[.C.d.}.m.e.>.3.Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.P /.n v.A.v e {.e D.v.v.n /.P 3.Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q (.#.Z :.~.y.E.F.{.G.d.y.E.:.Z #.(.Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.%.m.}.}.R H.o.~.}.m.%.>.3.Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q (.P /.n v.v.F.'.z.m.v.n /.k.(.Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q (.#.Z 1.~.s.I.I.I.. l.1.Z #.(.Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.%.@.J.J c.G j m.=.>.3.Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q x Q Q Q Q Q Q Q Q Q Q Q Q Q Q (.k._.[ 9.I K.G g.~._.k.(.Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q 0 t.(.Q Q Q Q Q Q Q Q Q Q Q Q (.#.1.L.M.w i.N.M.O.=.#.(.Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q 0 0 f.3.Q Q Q Q Q Q Q Q Q Q Q Q 3.~.w .P.[ ~ .Q.n 3.Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q 0 0 0 m k.Q Q Q Q Q Q Q Q Q Q (.k.z G {.R.` R.G J [ k.(.Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q =.=.=.=.=.=.=.0 0 0 0 ..$.Q Q Q Q Q Q Q Q Q (.:.3 V q S.T.[ Q.V 7 =.(.Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 U.2.Q Q Q Q Q Q Q Q 3.i.X V.T ` T.R.6.V.U.m.3.Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 0 z.=.Q Q Q Q Q Q (.$.W.V.5.T.T.X.T.S.I S D.P (.Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Y.:.Q Q Q Q Q (.m.J.0 t.` ` T.` [ q Z.`.1.(.Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9.n Q Q Q Q 3.X.n.Z. +[ S.[ S.[ .+++a.~.3.Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 G.Q Q Q (._.4.y -.@+#+i.A.i.#+R.[.y !.$.(.Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9.u.Q Q Q 3.}.w $+R ` A.v.~.v.y.[ r.%+&+n 3.Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 0 0 { :.Q Q Q Q 3.. *+b q.i.v.m.u.l.}.i.q.$+=+S.3.Q Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 0 z.=.Q Q Q Q (.1.-+;+: D.A.E.>+1.>+E.y.` a.;+L._.(.Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q 0 0 0 0 0 0 0 0 0 0 0 0 U.2.Q Q Q Q Q 3.S.,+'+C.` }.u.e./.e.d.}.S.x.'+..m.3.Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q =.=.=.=.=.=.=.0 0 0 0 0.$.Q Q Q Q Q Q #.w.y Z.W.y.~.b._.Z /.>+@.i. f 0 U #.Q Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q 0 0 0 D k.Q Q Q Q Q Q (.d.o.)+G.z }.l.e.$.P $.1.E.A.T.!+)+3 e.(.Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q 0 0 f.3.Q Q Q Q Q Q Q 3.~+9.5 -+R.v.n /.P #.>./.u.}.S.{+| : @.3.Q Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q 0 t.(.Q Q Q Q Q Q Q (.$.4 )+S v y.~.:.2.#.3.k.2.b.~.y.h.%+'+]+P (.Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q x.(.Q Q Q Q Q Q Q Q (.~.f.< N.D.}.m.%.>.3.(.3.>.e.l.A.X.U.< o.b.(.Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 3.K.^+< /+[ v.n /.P (.Q 3.P /.n }.S.7 (+[.i.3.Q Q Q Q Q Q Q Q Q Q 3.>.1. ", " Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q (.#.}.^.9.]+A.E.1.Z #.(.Q (.#.2.:.~.y.h.I &+m.#.(.Q Q Q Q Q Q Q Q Q 3.>.1. ", " 3.3.3.3.3.3.3.3.3.3.3.3.3.3.3.3.3.3.3.k.$.%.T._+U y.l.1.Z k.3.3.3.k.Z :.E.y.T.D.i.%.$.#.3.3.3.3.3.3.3.3.3.k.Z b. ", " >.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.>.Z =.n v.S.R.i.l.1._.$.>.>.>.$./.:.E.#+R.S.v.n =.Z >.>.>.>.>.>.>.>.>.Z =.u. ", " e.e.e.e.e.e.e.e.e.e.e.e.e.e.e.e.e.e.1.b.m.A.T.~+~+` }.d.:.1.e.e.e.1.b.m.A.T.D.D.T.A.m.b.1.e.e.e.e.e.e.e.1.:.u.@. ", " v + !.7.O.6.4.8 w.s.v v s. +T L.6.O.7.!.+ v ", " v + !..+/ O.4 :+!.+ v v + !..+O.4./ .+!.+ v "}; elseif pic == '1' then Image = { "60 60 218 2", " c #9F9F9F", ". c #9D9D9D", "+ c #9C9C9C", "@ c #FFFFFF", "# c #F1F1F1", "$ c #F0F0F0", "% c #FDFDFD", "& c #EEEEEE", "* c #EFEFEF", "= c #FBFBFB", "- c #EDEDED", "; c #EBEBEB", "> c #E8E8E8", ", c #FAFAFA", "' c #ECECEC", ") c #E9E9E9", "! c #838383", "~ c #383838", "{ c #E5E5E5", "] c #515151", "^ c #8D8D8D", "/ c #F9F9F9", "( c #E3E3E3", "_ c #3D3D3D", ": c #040404", "< c #AFAFAF", "[ c #EAEAEA", "} c #D1D1D1", "| c #393939", "1 c #F8F8F8", "2 c #060606", "3 c #5F5F5F", "4 c #E6E6E6", "5 c #7E7E7E", "6 c #909090", "7 c #787878", "8 c #F7F7F7", "9 c #E7E7E7", "0 c #111111", "a c #191919", "b c #DDDDDD", "c c #2C2C2C", "d c #0F0F0F", "e c #DFDFDF", "f c #6E6E6E", "g c #161616", "h c #F6F6F6", "i c #DEDEDE", "j c #545454", "k c #0D0D0D", "l c #E4E4E4", "m c #BDBDBD", "n c #646464", "o c #E2E2E2", "p c #DCDCDC", "q c #D8D8D8", "r c #9E9E9E", "s c #121212", "t c #E0E0E0", "u c #6D6D6D", "v c #A5A5A5", "w c #5B5B5B", "x c #F3F3F3", "y c #D6D6D6", "z c #D0D0D0", "A c #D5D5D5", "B c #252525", "C c #1C1C1C", "D c #282828", "E c #242424", "F c #D3D3D3", "G c #D7D7D7", "H c #525252", "I c #F2F2F2", "J c #DADADA", "K c #D2D2D2", "L c #CBCBCB", "M c #6A6A6A", "N c #1B1B1B", "O c #8F8F8F", "P c #A9A9A9", "Q c #1A1A1A", "R c #E1E1E1", "S c #4A4A4A", "T c #D9D9D9", "U c #C8C8C8", "V c #ACACAC", "W c #1F1F1F", "X c #4D4D4D", "Y c #626262", "Z c #B6B6B6", "` c #CDCDCD", " . c #434343", ".. c #DBDBDB", "+. c #C9C9C9", "@. c #C3C3C3", "#. c #3B3B3B", "$. c #2B2B2B", "%. c #3C3C3C", "&. c #D4D4D4", "*. c #CACACA", "=. c #C4C4C4", "-. c #7C7C7C", ";. c #272727", ">. c #858585", ",. c #999999", "'. c #818181", "). c #363636", "!. c #B7B7B7", "~. c #494949", "{. c #585858", "]. c #2A2A2A", "^. c #C6C6C6", "/. c #C5C5C5", "(. c #CECECE", "_. c #CFCFCF", ":. c #C0C0C0", "<. c #505050", "[. c #2D2D2D", "}. c #B4B4B4", "|. c #C7C7C7", "1. c #2E2E2E", "2. c #C1C1C1", "3. c #8B8B8B", "4. c #303030", "5. c #797979", "6. c #898989", "7. c #929292", "8. c #333333", "9. c #424242", "0. c #BFBFBF", "a. c #414141", "b. c #BBBBBB", "c. c #5C5C5C", "d. c #313131", "e. c #A3A3A3", "f. c #B1B1B1", "g. c #606060", "h. c #BABABA", "i. c #484848", "j. c #B9B9B9", "k. c #767676", "l. c #4E4E4E", "m. c #3E3E3E", "n. c #B5B5B5", "o. c #B8B8B8", "p. c #555555", "q. c #CCCCCC", "r. c #C2C2C2", "s. c #2F2F2F", "t. c #9B9B9B", "u. c #BCBCBC", "v. c #969696", "w. c #636363", "x. c #B2B2B2", "y. c #353535", "z. c #3F3F3F", "A. c #B3B3B3", "B. c #6C6C6C", "C. c #4F4F4F", "D. c #717171", "E. c #A6A6A6", "F. c #464646", "G. c #696969", "H. c #292929", "I. c #6B6B6B", "J. c #262626", "K. c #676767", "L. c #474747", "M. c #666666", "N. c #323232", "O. c #8A8A8A", "P. c #212121", "Q. c #878787", "R. c #828282", "S. c #565656", "T. c #ADADAD", "U. c #535353", "V. c #AEAEAE", "W. c #ABABAB", "X. c #4C4C4C", "Y. c #454545", "Z. c #9A9A9A", "`. c #AAAAAA", " + c #151515", ".+ c #6F6F6F", "++ c #141414", "@+ c #959595", "#+ c #131313", "$+ c #343434", "%+ c #A8A8A8", "&+ c #B0B0B0", "*+ c #5E5E5E", "=+ c #202020", "-+ c #232323", ";+ c #3A3A3A", ">+ c #7A7A7A", ",+ c #0C0C0C", "'+ c #BEBEBE", ")+ c #444444", "!+ c #0A0A0A", "~+ c #0E0E0E", "{+ c #070707", "]+ c #050505", "^+ c #757575", "/+ c #8E8E8E", "(+ c #A2A2A2", "_+ c #101010", ":+ c #030303", "<+ c #848484", "[+ c #020202", "}+ c #A1A1A1", "|+ c #A0A0A0", "1+ c #A7A7A7", "2+ c #989898", "3+ c #919191", "4+ c #8C8C8C", "5+ c #939393", " ", " . . . . . . . + . . + . . + . . . . + + + . + . + . + . . . . . . + + + + . . . . + . . . . . + ", " @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ ", " # $ $ $ # # $ $ $ $ $ $ $ $ $ # # $ # $ # $ $ $ # # # $ # # # # $ $ $ $ $ # # # $ $ $ $ # # $ $ # $ $ $ $ # $ % ", " $ & & & & & & & & & & * * & * & & * & & & & & & * & & & & & & & & & * * & & & & & & & & & & & & & & & & & & & = ", " & - - - - - - - - - - & & - ; > ; - - - - - - - - & - - - - & $ * - & & - - - - - - - - - - - - - - - - - - - , ", " & - - ' - ' ' - - - - - - ) ! ~ { - - - - - - - ' ' ' - - - $ ] ^ * - - ' - - - - - - - - - - - - ' - - - - - / ", " ' ; ; ; ; ; ; ; ' ; ; ' ' ( _ : < [ ' ; ; ' ; ; ; ; ; ; ; ' } : | * ; ; ; ; ; ; ; ' ; ; ; ; ; ; ' ' ; ; ' ; ; 1 ", " ; [ [ ; [ ; [ [ [ [ ; ; [ { ^ 2 3 4 [ [ [ [ ; [ [ [ ; ; [ ; 5 2 6 ' [ [ [ [ [ [ ; [ [ ) 7 ; [ [ [ [ [ ; ; [ [ 8 ", " [ ) ) ) [ [ ) ) ) ) [ ) 9 { } 0 a b > ) [ ) ) ) ) ) ) ) > - c d e > > > ) ) ) ) ) ) > f g [ ) ) ) ) ) [ [ ) ) h ", " [ ) ) ) ) ) ) ) ) ) ) 9 { ( i j k l > > ) ) ) ) ) ) > > m k j [ l { 9 ) ) ) ) ) 9 n g g > ) ) ) ) ) ) ) ) ) h ", " 9 4 > 9 9 9 > 4 9 9 4 l o p q r s j t { 9 > 4 > > > 9 4 9 u 0 v t p o { 9 9 9 > o w g g g 9 > 9 9 9 > > 9 9 9 x ", " 9 4 9 4 4 4 4 9 4 4 { o i y z A B C z ( { 9 9 9 9 4 9 ( ( D E l F G b o 4 4 4 t H g g g g q q q q q q q 4 4 4 I ", " { { { { { { 4 { { { l o J K L } M N O e l { { { { { l o P Q u p L K J R l { J S g g g g g g g g g g g g { { { I ", " l l l l l l l l l l ( t T z U U V W X J o l l l l l R R Y W Z ` U z T t ( y .g g g g g g g g g g g g g l l l $ ", " ( l l l ( ( l l l l ( e ..K +.@.K #.E @.e ( l l ( ( t q $.#.( @.+.K ..t } %.g g g g g g g g g g g g g g ( l l & ", " o ( ( o ( ( ( o o o ( t p &.*.=.*.-.;.>.J R o ( ( o i ,.;.'.F =.L F ..+.).g g g g g g g g g g g g g g g o o o & ", " R R R R o o o o R R R R p y ` =.@.!.$.~.y i R R o e p {.].=.^./.(.G p S g g g g g g g g g g g g g g g g R o o - ", " R t t t t t t t t t t e b G _.^.:.L <.[.}...e t e b |.1.H q 2.^._.G b L ).g g g g g g g g g g g g g g g t t t ; ", " e e e e e e e e e e e e b T } |.2.=.3.4.5.y b e i T 6.4.7.L 2.|.} q b e (._ g g g g g g g g g g g g g g e e e [ ", " p p p p p p p p p p p p ..q K U :.m m 8.9.` T ..T &.X 8.+.0.:.U } q ..p p _.a.g g g g g g g g g g g g g ..q K U ", " q q q q q T T T T T T T q y } +.:.b.@.c.d.e.F G A f.4.g.L h.0.+.} y q T T T z i.g g g g g g g g g g g g q y z ^. ", " A A A A A A A A A A A A A F _.+.0.j.h.6 d.M L K ` k.4.,.0.j.0.+._.F A A A A A (.l.g g g g U U U U U U U A K ` =. ", " K K K K K K K F F F F F F K _.+.2.j.}.h.~ ~ :.(.^.m.~ /.n.o.:.U (.K F F F F F K (.p.g g g F K K K K K K K z q.@. ", " } } } } } } } } } } } } } } _.*.r.h.}.h.n s.6 |.t.4.M 2.}.h.r.*._.} } } } } } } } _.c.g g } } } } } } } } _.L r. ", " z z z z z z z z z z z z z z (.L /.u.}.n.v.s.w r.n s.r !.}.u./.L (.z z z z z z z z z _.w.g z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z _.` |.0.!.x.h.#.d.< y.z.@.A.!.0.|.` _.z z z z z z z z z z z u z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z (.*.r.j.A.Z B.[.C.[.D.b.}.h.r.*.(.z z z z z z z z z z z z z z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z (.L /.m n.A.r c c c E.n.n.m /.L (.z z z z z z z z z z z z z z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z _.` U :.!.x.o.a.].F.b.x.o.:.U ` _.z z z z z z z z z z z z z z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z (.*.@.h.}.}.G.H.I.!.}.h.@.*.(.z z z z z z z z z z z z z z z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z _.L /.m n.n.9.;.z.h.n.m /.q._.z z z z z z z z z z z z z z z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z _.` U 2.!.t.J.J.J.+ j.2.U ` _.z z z z z z z z z z z z z z z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z z (.*.@.Z K.B L.E M.h.=.*.(.z z z z z z z z z z z z z z z z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z z _.q.^.< N.D e.B 4.!.^.q._.z z z z z z z z z z z z z _.B.z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z z _.` 2.O.P.p.f.l.P.^ =.` _.z z z z z z z z z z z z _.w.g z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z z z (.!.p.W Q.< R.W S.m (.z z z z z z z z z z z z (.w g g z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z z _.q.v B $.T.V T.B E < q._.z z z z z z z z z z q.U.g g g z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z z z z z _.:.5.N w V.W.< S.N 5 =._.z z z z z z z z z +.X.g g g g =.=.=.=.=.=.=.z (.*.2. ", " z z z z z z z z z z z z z z z z z (.f. .a O V W.T.6.a Y.h.(.z z z z z z z z |.Y.g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z z z _.+.Z.a s.W.W.`.W.V.D a E.L _.z z z z z z =.z.g g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z z z _.h.K. +Y V V W.V < c. +.+2._.z z z z z :.~ g g g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z z z (.`.d.++@+< V.< V.< 7.#+$+!.(.z z z z u.8.g g g g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z z _.^.3.0 ).%+&+f.A.f.&+T.[.s ,.+._.z z z F.g g g g g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z z (.}.p.d G.V A.n.!.n.x.< n d *+m (.z z z m 8.g g g g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z z (.. =+#+,.f.n.h.u.j.}.f.,.d -+V.(.z z z z :.;+g g g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z _.2.>+,+_ E.A.o.'+2.'+o.x.V y.,+O.^._.z z z z =.z.g g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z (.V.)+!+D.V }.u.r./.r.b.}.V.B.!+l.h.(.z z z z z |.Y.g g g g g g g g g g g g z (.*.2. ", " z z z z z z z z z z z z z z ` v.s ++Z.x.!.0.^.U /.'+Z f. ~+g P ` z z z z z z +.X g g g g =.=.=.=.=.=.=.z (.*.2. ", " z z z z z z z z z z z z z _.b.M {+F.v }.j.r.+.L +.2.o.A.W.%.{+>+r._.z z z z z z q.j g g g z z z z z z z z (.*.2. ", " z z z z z z z z z z z z z (.%+8.]+>+T.n.m /.L ` *./.u.}.V.^+2 m.Z (.z z z z z z z (.w g g z z z z z z z z (.*.2. ", " z z z z z z z z z z z z _.+./+{+Q r x.!.:.|.` (.q.|.0.!.x.(+_+!+(+L _.z z z z z z z _.w.g z z z z z z z z (.*.2. ", " z z z z z z z z z z z z _.!.w :+C.E.}.h.@.*.(._.(.*.r.j.A.`.Y.:+M 0._.z z z z z z z z z u z z z z z z z z (.*.2. ", " z z z z z z z z z z z z (.e.E :+<+< n.m /.L _.z (.L /.m }.V.5 [+1.f.(.z z z z z z z z z z z z z z z z z z (.*.2. ", " z z z z z z z z z z z _.` }.{.N.}+A.o.2.U ` _.z _.` |.:.!.x.(+H.3 h.` _.z z z z z z z z z z z z z z z z z (.*.2. ", " (.(.(.(.(.(.(.(.(.(.(.q.+.@.V |+P x.j.2.U q.(.(.(.q.U :.o.x.W.E.f.@.+.` (.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.(.q.U 0. ", " *.*.*.*.*.*.*.*.*.*.*.U =.m n.V.T.f.j.2.^.+.*.*.*.+./.:.o.&+T.V.n.m =.U *.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.*.U =.u. ", " r.r.r.r.r.r.r.r.r.r.2.0.h.A.W.1+1+V }.b.:.2.r.r.r.2.0.h.A.W.E.E.W.A.h.0.2.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.2.:.u.Z ", " r + 2+3+4+6.3.6 v.t.r r t.@+O O.6.4+3+2++ r ", " r + 2+7.^ 4+/+5+2++ r r + 2+7.4+3.^ 7.2++ r "}; elseif pic == '2' then Image = { "60 60 211 2", " c #9F9F9F", ". c #9D9D9D", "+ c #9C9C9C", "@ c #FFFFFF", "# c #F1F1F1", "$ c #F0F0F0", "% c #FDFDFD", "& c #EEEEEE", "* c #EFEFEF", "= c #FBFBFB", "- c #EDEDED", "; c #FAFAFA", "> c #ECECEC", ", c #F9F9F9", "' c #EBEBEB", ") c #F8F8F8", "! c #EAEAEA", "~ c #F7F7F7", "{ c #E9E9E9", "] c #F6F6F6", "^ c #E8E8E8", "/ c #E7E7E7", "( c #E6E6E6", "_ c #F3F3F3", ": c #F2F2F2", "< c #E5E5E5", "[ c #E4E4E4", "} c #E3E3E3", "| c #E2E2E2", "1 c #CFCFCF", "2 c #C0C0C0", "3 c #D1D1D1", "4 c #E0E0E0", "5 c #E1E1E1", "6 c #CDCDCD", "7 c #686868", "8 c #2A2A2A", "9 c #6B6B6B", "0 c #AAAAAA", "a c #C5C5C5", "b c #D4D4D4", "c c #DDDDDD", "d c #939393", "e c #3F3F3F", "f c #868686", "g c #BFBFBF", "h c #090909", "i c #080808", "j c #0D0D0D", "k c #3E3E3E", "l c #7E7E7E", "m c #B3B3B3", "n c #C9C9C9", "o c #D7D7D7", "p c #A5A5A5", "q c #555555", "r c #101010", "s c #3D3D3D", "t c #DFDFDF", "u c #BEBEBE", "v c #9A9A9A", "w c #636363", "x c #121212", "y c #1E1E1E", "z c #545454", "A c #919191", "B c #B9B9B9", "C c #DADADA", "D c #B4B4B4", "E c #232323", "F c #222222", "G c #696969", "H c #B6B6B6", "I c #DBDBDB", "J c #D9D9D9", "K c #D2D2D2", "L c #C3C3C3", "M c #B5B5B5", "N c #909090", "O c #5C5C5C", "P c #1D1D1D", "Q c #303030", "R c #A1A1A1", "S c #C1C1C1", "T c #CECECE", "U c #DCDCDC", "V c #7D7D7D", "W c #383838", "X c #242424", "Y c #5F5F5F", "Z c #A6A6A6", "` c #D8D8D8", " . c #D6D6D6", ".. c #C8C8C8", "+. c #D5D5D5", "@. c #D0D0D0", "#. c #CACACA", "$. c #ACACAC", "%. c #878787", "&. c #565656", "*. c #2D2D2D", "=. c #282828", "-. c #292929", ";. c #464646", ">. c #7A7A7A", ",. c #ADADAD", "'. c #C4C4C4", "). c #C6C6C6", "!. c #8C8C8C", "~. c #4E4E4E", "{. c #989898", "]. c #D3D3D3", "^. c #9E9E9E", "/. c #CBCBCB", "(. c #C7C7C7", "_. c #CCCCCC", ":. c #A7A7A7", "<. c #505050", "[. c #313131", "}. c #333333", "|. c #575757", "1. c #898989", "2. c #979797", "3. c #5E5E5E", "4. c #2F2F2F", "5. c #4C4C4C", "6. c #BABABA", "7. c #BDBDBD", "8. c #747474", "9. c #393939", "0. c #969696", "a. c #424242", "b. c #BCBCBC", "c. c #C2C2C2", "d. c #B8B8B8", "e. c #BBBBBB", "f. c #3C3C3C", "g. c #707070", "h. c #A3A3A3", "i. c #A4A4A4", "j. c #6A6A6A", "k. c #B7B7B7", "l. c #B2B2B2", "m. c #B0B0B0", "n. c #8D8D8D", "o. c #5D5D5D", "p. c #2E2E2E", "q. c #484848", "r. c #6D6D6D", "s. c #444444", "t. c #929292", "u. c #2B2B2B", "v. c #4D4D4D", "w. c #AEAEAE", "x. c #ABABAB", "y. c #838383", "z. c #515151", "A. c #262626", "B. c #676767", "C. c #414141", "D. c #272727", "E. c #A9A9A9", "F. c #585858", "G. c #626262", "H. c #323232", "I. c #B1B1B1", "J. c #A8A8A8", "K. c #8E8E8E", "L. c #949494", "M. c #5A5A5A", "N. c #777777", "O. c #181818", "P. c #1A1A1A", "Q. c #767676", "R. c #AFAFAF", "S. c #858585", "T. c #494949", "U. c #1B1B1B", "V. c #454545", "W. c #959595", "X. c #373737", "Y. c #141414", "Z. c #131313", "`. c #656565", " + c #999999", ".+ c #191919", "++ c #525252", "@+ c #6F6F6F", "#+ c #0E0E0E", "$+ c #8B8B8B", "%+ c #252525", "&+ c #0F0F0F", "*+ c #434343", "=+ c #0A0A0A", "-+ c #151515", ";+ c #474747", ">+ c #7C7C7C", ",+ c #161616", "'+ c #6E6E6E", ")+ c #060606", "!+ c #050505", "~+ c #8A8A8A", "{+ c #0B0B0B", "]+ c #606060", "^+ c #8F8F8F", "/+ c #797979", "(+ c #363636", "_+ c #4B4B4B", ":+ c #535353", "<+ c #5B5B5B", "[+ c #6C6C6C", " ", " . . . . . . . + . . + . . + . . . . + + + . + . + . + . . . . . . + + + + . . . . + . . . . . + ", " @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ ", " # $ $ $ # # $ $ $ $ $ $ $ $ $ # # $ # $ # $ $ $ # # # $ # # # # $ $ $ $ $ # # # $ $ $ $ # # $ $ # $ $ $ $ # $ % ", " $ & & & & & & & & & & * * & * & & * & & & & & & * & & & & & & & & & * * & & & & & & & & & & & & & & & & & & & = ", " & - - - - - - - - - - & & - & - - - - - - - - - - & - - - - - - - - & & - - - - - - - - - - - - - - - - - - - ; ", " & - - > - > > - - - - - - - - - - - - - - - - - > > > - - - - - - - - - > - - - - - - - - - - - - > - - - - - , ", " > ' ' ' ' ' ' ' > ' ' > > ' ' ' ' ' > ' ' > ' ' ' ' ' ' ' ' ' > ' ' ' ' ' ' ' ' ' > ' ' ' ' ' ' > > ' ' > ' ' ) ", " ' ! ! ' ! ' ! ! ! ! ' ' ! ! ! ! ! ' ! ! ! ! ' ! ! ! ' ' ! ! ! ! ! ! ! ! ! ! ! ! ' ! ! ! ! ' ! ! ! ! ! ' ' ! ! ~ ", " ! { { { ! ! { { { { ! ! { { { { { ! { { ! { { { { { { { { ! ! { { ! { { { { { { { { { { { ! { { { { { ! ! { { ] ", " ! { { { { { { { { { { { { { { { { { { { ^ { { { { { { { { { { { { { { { { { { { { { { { { ^ { { { { { { { { { ] ", " / ( ^ / / / ^ ( / / / / ^ / / ^ / / ^ / / ^ ( ^ ^ ^ / / ^ ^ ( ^ ^ / ^ ^ ^ / / ^ / / / ^ ^ / ^ / / / ^ ^ / / / _ ", " / ( / ( ( ( ( / ( ( ( ( / ( ( / ( ( ( ( ( / / / / ( / ( ( ( ( ( / ( ( ( / ( ( / ( ( ( ( ( ( ( ( ( ( ( ( ( ( ( : ", " < < < < < < ( < < < < ( < < < ( < < < < < < < < < < < < < < < < < < < < < < < < < ( < < < < < < < < < < < < < : ", " [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ } [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ [ } [ [ [ [ [ [ [ [ [ [ $ ", " } [ [ [ } } [ [ [ [ [ } [ [ [ [ } [ } [ [ [ [ [ } [ } [ [ [ } } [ [ [ [ [ } [ [ [ [ } [ [ [ [ [ [ [ [ } } [ [ & ", " | } } 1 2 3 4 | | | } } } | | } } } } } | | | } } } | } } | } } } | | | } } } | | } | | | } } | | ( { ( | | | & ", " 5 5 6 7 8 9 0 a b 4 5 | 5 5 5 5 | 5 | | | 5 5 5 | 5 5 5 5 5 | | | | 5 5 5 | 5 5 5 5 5 5 | | [ ( c d e f [ | | - ", " 5 4 g e h i j k l m n o 4 4 4 4 4 4 4 4 4 4 4 4 4 4 5 4 4 4 4 4 4 4 4 4 4 4 4 5 4 4 4 | } | p q r i i s ( 4 4 ' ", " t t 3 u v w 8 x x y z A B 6 C t t t t t t t t t t t t t t t t t t t t t t t t 4 t 4 5 D 9 E x x F G H / | t t ! ", " I C J J K L M N O 8 P y Q G R S T J U U U U U U U U U U U U U U U U U U U U I I 2 V W P P X Y Z t t I J ` .3 .. ", " o +.K @.T 1 3 #.u $.%.&.*.=.-.;.>.,.'.1 ` J J J J J ` ` ` ` ` J J J J o +.).!.~.=.=.-.q {.].I +.@.T T 3 K ].T ). ", " ^.].@./.(.'.L '.(.#._.'.B :.l <.[.Q }.|.1.M a 1 +.+.+.+.+.+.+.+.+.K 1 (.2.3.}.Q 4.5.1.'. .].T #...'.'.'.)./._./.L ", " ^.1 /.a g 6.B B 7.g L )...n S H R 8.;.Q Q 9.w 0.6.(.1 K K K 1 #.'.^.7 W [.[.a.>.D @.1 _...).L g b.B B 6.u '.n n c. ", " ^.T #.L 7.d.D D D H B e.u c.a (.(.u M {.G f.Q Q e g.h.2 ).c.i.g.k Q Q 9.j.h./.6 /.(.a c.g b.B H D m D k.b.c.(...S ", " ^.T #.a u B M m l.l.m D M d.e.u S a (.a b.m.n.o.}.p.*.q.r.s.*.p.Q O t.2 n n (.a S g b.d.H D l.l.l.l.D d.7.L (.(.2 ", " ^.T _.n a 2 b.d.H D m l.l.m D H B b.g c.a (.c.e.i.5.8 u.u.u.u.v.w.'.....a c.g b.B H D m l.l.l.D M d.e.g L ..n ..2 ", " 1 T _.#.(.a S u e.d.M D l.l.l.m D k.H D x.y.z.8 A.A.k B.C.A.D.*.o.0.S S e.k.D m l.l.l.m D k.6.7.2 L ).n _._.n S ", " @.1 T T _.#.n ).L S 7.6.k.M D m.,.E.1.F.8 F F 4.G.0.B u b. j.}.F F H.G p c.b.M m D k.B 7.2 c.a ..#._.T T 6 #.S ", " @.@.@.@.1 T T _.#...a L 7.I.J.K.o.p.P P X z.f w.H b.2 S 2 b.6.e.L.M.A.P P 9.N.m '.S 2 c.a (.#./.6 T 1 1 @.T #.S ", " @.@.@.@.@.@.1 1 T #.6.x.t.w [.O.O.P.C.Q.p ,.R.m.m D H k.H D l.m.m d.d.S.T.U.O.P.V.S.2 /./.6 T 1 1 @.@.@.@.T #.S ", " @.@.@.@.@.@.1 2 ,.W.G X.Y.Z.Z.[.`. +$.m.I.w.$.x.$.w.R.m.R.w.$.x.$.w.I.d.u l.N.W Z.Z..+++L...1 @.@.@.@.@.@.T #.S ", " @.@.@.@.L R.2.@+f.x #+#+F &.$+0 H u b.k.m R.x.0 x.x.$.,.$.x.x.0 x.R.m k.b.S L '.:.B.%+#+&+y 3.p 1 @.@.@.@.T #.S ", " @.@.b.2.N.*+Z.h =+-+;+>+. D L a c.u B M I.w.$.x.$.w.R.m.R.w.$.x.$.w.I.M 6.u c.)...(.'. +&.,+h h =.'+H 3 3 T #.S ", " @.@.p =.)+!+=+W r.2.R.2 (.a S u e.d.D l.m.m.m.m.l.D H k.H D m m.m.m.m.m M d.b.g c.a (.n n L ~+*+{+)+)+;+3 T #.S ", " @.@.d.|.-.]+^+E.e.).a c.g b.d.H D l.l.l.l.D M d.e.7.2 S 2 7.e.d.M D l.l.l.m D k.B 7.2 L a ..n /.7./+Q /+@.T #.S ", " @.1 6 k.Z k.a a c.2 7.B k.D m l.l.l.m M k.6.7.S L ).......).'.S 7.6.d.M D m l.l.D M k.6.7.S L ).n #._.T T 6 #.S ", " 1 T _.n ).L 2 7.6.k.D m l.l.l.m D k.B 7.2 L a ..#._.6 T 6 _.#...a L 2 7.6.k.D m l.l.l.D M d.e.u S a (.#._._.n S ", " ^.T /...L g e.d.M D l.I.l.m i.e :.b.g c.a ..#./.6 T 1 1 @.1 1 T 6 _.#...a c.g b.J.e h.m l.l.m D H d.b.2 a n #...2 ", " ^.6 n L 7.d.D l.l.l.l.D M 0 Q ,+[.H (.#./.6 T 1 1 @.@.@.@.@.@.@.1 1 T 6 /.#.(.H [.,+Q 0 M D m l.l.m M B u a ....2 ", " ^.6 ..S e.H m l.D M d.6.l.X.,+,+,+X.S T T 1 @.@.@.@.@.@.@.@.@.@.@.@.@.1 T T S 9.,+,+,+(+l.6.d.M D m D k.b.c.(.(.2 ", " ^.6 n c.7.d.k.d.6.7.2 e.s ,+,+,+,+,+e (.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.(.e ,+,+,+,+,+f.6.2 7.6.d.k.d.7.L (.(.2 ", " ^.T #.).S g u 2 L a c.s.,+,+,+,+,+,+,+V.n @.@.@.@.@.@.@.@.@.@.@.@.@.@.@.n V.,+,+,+,+,+,+,+*+c.a c.2 u g c.).n ..2 ", " T 6 #...).)...#.(.5.,+,+,+,+,+,+,+,+,+5._.@.@.@.@.@.@.@.@.@.@.@.@.@._.v.,+,+,+,+,+,+,+,+,+_+(.#...).)...#./.n S ", " 1 T T 6 _._.6 _.z ,+,+,+,+,+,+,+,+,+,+,+:+T @.@.@.@.@.@.@.@.@.@.@.T z ,+,+,+,+,+,+,+,+,+,+,+:+_.6 _._.6 T _.n S ", " @.@.1 1 1 1 T <+,+,+,+,+,+,+,+,+,+,+,+,+,+<+1 @.@.@.@.@.@.@.@.@.1 <+,+,+,+,+,+,+,+,+,+,+,+,+,+<+T 1 1 1 1 T #.S ", " @.@.@.@.@.@.w ,+,+,+,+,+,+,+,+,+,+,+,+,+,+,+w 1 @.@.@.@.@.@.@.@.w ,+,+,+,+,+,+,+,+,+,+,+,+,+,+,+w 1 @.@.@.T #.S ", " @.@.@.@.@.r.,+,+,+,+,+,+,+,+,+,+,+,+,+,+,+,+,+[+@.@.@.@.@.@.@.r.,+,+,+,+,+,+,+,+,+,+,+,+,+,+,+,+,+[+@.@.@.T #.S ", " @.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.T #.S ", " @.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.T #.S ", " @.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.T #.S ", " @.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.T #.S ", " @.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.T #.S ", " @.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.T #.S ", " @.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.'.,+,+,+,+,+,+,+,+,+'.@.@.@.@.@.@.@.T #.S ", " T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T _...g ", " #.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#...'.b. ", " c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.c.S 2 b.H ", " ", " "}; elseif pic == '3' then Image = { "60 60 212 2", " c #9F9F9F", ". c #9D9D9D", "+ c #9C9C9C", "@ c #FFFFFF", "# c #F1F1F1", "$ c #F0F0F0", "% c #FDFDFD", "& c #EEEEEE", "* c #EFEFEF", "= c #FBFBFB", "- c #EDEDED", "; c #DFDFDF", "> c #161616", ", c #E0E0E0", "' c #FAFAFA", ") c #ECECEC", "! c #F9F9F9", "~ c #EBEBEB", "{ c #DDDDDD", "] c #F8F8F8", "^ c #EAEAEA", "/ c #DCDCDC", "( c #F7F7F7", "_ c #E9E9E9", ": c #DBDBDB", "< c #F6F6F6", "[ c #E8E8E8", "} c #DADADA", "| c #E7E7E7", "1 c #E6E6E6", "2 c #D9D9D9", "3 c #F3F3F3", "4 c #767676", "5 c #787878", "6 c #777777", "7 c #F2F2F2", "8 c #E5E5E5", "9 c #E4E4E4", "0 c #6C6C6C", "a c #E3E3E3", "b c #626262", "c c #636363", "d c #E2E2E2", "e c #5A5A5A", "f c #5B5B5B", "g c #515151", "h c #525252", "i c #DEDEDE", "j c #E1E1E1", "k c #494949", "l c #4A4A4A", "m c #D6D6D6", "n c #424242", "o c #434343", "p c #D2D2D2", "q c #3B3B3B", "r c #3D3D3D", "s c #CBCBCB", "t c #353535", "u c #D8D8D8", "v c #C8C8C8", "w c #C4C4C4", "x c #484848", "y c #C5C5C5", "z c #D0D0D0", "A c #C6C6C6", "B c #D5D5D5", "C c #CDCDCD", "D c #C0C0C0", "E c #B3B3B3", "F c #C2C2C2", "G c #CFCFCF", "H c #D3D3D3", "I c #D7D7D7", "J c #CCCCCC", "K c #C3C3C3", "L c #D1D1D1", "M c #BFBFBF", "N c #616161", "O c #272727", "P c #646464", "Q c #9E9E9E", "R c #B7B7B7", "S c #D4D4D4", "T c #8B8B8B", "U c #3C3C3C", "V c #7F7F7F", "W c #B2B2B2", "X c #090909", "Y c #080808", "Z c #0C0C0C", "` c #3A3A3A", " . c #A7A7A7", ".. c #BCBCBC", "+. c #0F0F0F", "@. c #CECECE", "#. c #CACACA", "$. c #C1C1C1", "%. c #B1B1B1", "&. c #919191", "*. c #5D5D5D", "=. c #282828", "-. c #121212", ";. c #1C1C1C", ">. c #505050", ",. c #888888", "'. c #AEAEAE", "). c #ABABAB", "!. c #666666", "~. c #222222", "{. c #212121", "]. c #656565", "^. c #ADADAD", "/. c #C7C7C7", "(. c #B8B8B8", "_. c #ACACAC", ":. c #898989", "<. c #585858", "[. c #2A2A2A", "}. c #1E1E1E", "|. c #1D1D1D", "1. c #2F2F2F", "2. c #999999", "3. c #B9B9B9", "4. c #373737", "5. c #242424", "6. c #A0A0A0", "7. c #C9C9C9", "8. c #B6B6B6", "9. c #A5A5A5", "0. c #838383", "a. c #545454", "b. c #2D2D2D", "c. c #444444", "d. c #4D4D4D", "e. c #292929", "f. c #535353", "g. c #939393", "h. c #BEBEBE", "i. c #B5B5B5", "j. c #A4A4A4", "k. c #7C7C7C", "l. c #4F4F4F", "m. c #313131", "n. c #323232", "o. c #565656", "p. c #868686", "q. c #949494", "r. c #303030", "s. c #4C4C4C", "t. c #878787", "u. c #BDBDBD", "v. c #BABABA", "w. c #B4B4B4", "x. c #747474", "y. c #464646", "z. c #393939", "A. c #686868", "B. c #797979", "C. c #979797", "D. c #6A6A6A", "E. c #3F3F3F", "F. c #707070", "G. c #A3A3A3", "H. c #3E3E3E", "I. c #696969", "J. c #A2A2A2", "K. c #BBBBBB", "L. c #B0B0B0", "M. c #8D8D8D", "N. c #5E5E5E", "O. c #333333", "P. c #6D6D6D", "Q. c #929292", "R. c #2B2B2B", "S. c #262626", "T. c #676767", "U. c #969696", "V. c #A9A9A9", "W. c #A8A8A8", "X. c #8E8E8E", "Y. c #181818", "Z. c #1A1A1A", "`. c #414141", " + c #AFAFAF", ".+ c #858585", "++ c #1B1B1B", "@+ c #191919", "#+ c #454545", "$+ c #959595", "%+ c #141414", "&+ c #131313", "*+ c #383838", "=+ c #6F6F6F", "-+ c #0E0E0E", ";+ c #AAAAAA", ">+ c #252525", ",+ c #0A0A0A", "'+ c #151515", ")+ c #474747", "!+ c #555555", "~+ c #171717", "{+ c #6E6E6E", "]+ c #060606", "^+ c #050505", "/+ c #0B0B0B", "(+ c #8A8A8A", "_+ c #070707", ":+ c #575757", "<+ c #606060", "[+ c #8F8F8F", "}+ c #A6A6A6", " ", " . . . . . . . + . . + . . + . . . . + + + . + . + . + . . . . . . + + + + . . . . + . . . . . + ", " @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ @ ", " # $ $ $ # # $ $ $ $ $ $ $ $ $ # # $ # $ # $ $ $ # # # $ # # # # $ $ $ $ $ # # # $ $ $ $ # # $ $ # $ $ $ $ # $ % ", " $ & & & & & & & & & & * * & * & & * & & & & & & * & & & & & & & & & * * & & & & & & & & & & & & & & & & & & & = ", " & - - - - - - - - ; > > > > > > > > > ; - - - - - & - - - - - - - - & , > > > > > > > > > ; - - - - - - - - - ' ", " & - - ) - ) ) - - ; > > > > > > > > > ; - - - - ) ) ) - - - - - - - - ; > > > > > > > > > ; - - - ) - - - - - ! ", " ) ~ ~ ~ ~ ~ ~ ~ ) { > > > > > > > > > { ~ ) ~ ~ ~ ~ ~ ~ ~ ~ ~ ) ~ ~ ~ { > > > > > > > > > { ~ ~ ) ) ~ ~ ) ~ ~ ] ", " ~ ^ ^ ~ ^ ~ ^ ^ ^ / > > > > > > > > > / ^ ^ ~ ^ ^ ^ ~ ~ ^ ^ ^ ^ ^ ^ ^ / > > > > > > > > > { ^ ^ ^ ^ ^ ~ ~ ^ ^ ( ", " ^ _ _ _ ^ ^ _ _ _ : > > > > > > > > > : ^ _ _ _ _ _ _ _ _ ^ ^ _ _ ^ _ : > > > > > > > > > / _ _ _ _ _ ^ ^ _ _ < ", " ^ _ _ _ _ _ _ _ _ : > > > > > > > > > : [ _ _ _ _ _ _ _ _ _ _ _ _ _ _ : > > > > > > > > > } _ _ _ _ _ _ _ _ _ < ", " | 1 [ | | | [ 1 | 2 > > > > > > > > > 2 | [ 1 [ [ [ | | [ [ 1 [ [ | [ } > > > > > > > > > 2 [ | | | [ [ | | | 3 ", " | 1 | 1 1 4 > > > > > > > > > > > > > > > > > 5 | 1 | 1 1 1 1 4 > > > > > > > > > > > > > > > > > 6 1 1 1 1 1 7 ", " 8 8 8 8 8 9 0 > > > > > > > > > > > > > > > 0 8 8 8 8 8 8 8 8 9 0 > > > > > > > > > > > > > > > 0 8 8 8 8 8 8 7 ", " 9 9 9 9 9 9 a b > > > > > > > > > > > > > c a 9 9 9 a 9 9 9 9 9 a b > > > > > > > > > > > > > c a 9 9 9 9 9 9 $ ", " a 9 9 9 a a 9 d e > > > > > > > > > > > f d 9 9 a 9 a 9 9 9 a a 9 d e > > > > > > > > > > > f d 9 9 9 a a 9 9 & ", " d a a d a a a d { g > > > > > > > > > h { d d a a a d a a d a a a d { g > > > > > > > > > h i d d a a a d d d & ", " j j j j d d d d j } k > > > > > > > l : d j j j d j j j j j d d d d j } k > > > > > > > l : d j j d d d j d d - ", " j , , , , , , , , , m n > > > > > n m , , , , , , , j , , , , , , , , , m n > > > > > o m , j j , , , , , , , ~ ", " ; ; ; ; ; ; ; ; ; ; ; p q > > > r p ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; ; p q > > > r p ; ; ; ; ; ; ; ; ; ; ; ^ ", " / / / / / / / / / / / / s t > t s / / / / / / / / / / / / / / / / / / / / / s t > t s / / / / / / / / / : u p v ", " u u u u u 2 2 2 2 2 2 2 2 w x y 2 2 2 2 2 2 2 2 2 2 u u u u u 2 2 2 2 2 2 2 2 w x w 2 2 2 2 2 u u u u 2 u m z A ", " B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B B p C w ", " p p p D E F G H H H H H H H H H H H p p H H H H H H p p p p p p p H H H H H H p p p p p H H p p H m : I p z J K ", " L L M N O P Q R y z L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L S 2 p T U V m G s F ", " z z W q X Y Z ` 4 ...v z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z p B m + g +.Y Y ` } @.#.$. ", " z z K %.&.*.=.-.-.;.>.,.'.D s z z z z z z z z z z z z z z z z z z z z z z z z z L H B ).!.~.-.-.{.].^./ S @.#.$. ", " G @.@.C /.(._.:.<.[.}.|.1.].2.(.w @.z z z z z z z z z z z z z z z z z z z z z p 3.5 4.}.|.5.f 6.m B z C @.J 7.$. ", " G C #.v A A v F 8.9.0.a.b.=.=.c.6 .../.G z z z z z z z z z z z z z z G G $.,.d.=.e.[.f.g.C S G v A A v #.s v $. ", " Q @.s A F M h.D F y /.D i.j.k.l.m.1.n.o.p.%.D #.z z z z z z z z z C s w q.*.n.1.r.s.t.D p @.7.y K D M M $.A v v D ", " Q C 7.K u.(.R (.v.u.D K y A h.w. x.y.m.r.z.c q.(.w J z z z C 7.F . A.4.r.r.n B.E G C #.A K $.u.v.(.R (.u.F /./.D ", " Q C 7.F ..R w.E w.i.(.v.u.$.w A A u.w.C.D.U r.r.E.F.G.D y $.G.F.H.r.1.z.I.J.#.J #.A w $.h.K.(.i.w.W E 8.K.$.A /.D ", " Q @.#.y h.3.i.E W W E w.i.(.K.h.$.y /.y ..L.M.N.O.b.b.x P.c.b.b.r.f Q.D 7.7./.y $.M ..(.8.w.W W W W w.(.u.K /./.D ", " Q @.J 7.y D ..(.8.w.E W W E w.8.3...M F y /.F K.j.s.R.[.[.R.[.d.'.w v v y F M ..3.8.w.E W W W w.i.(.K.M K v 7.v D ", " G @.J #./.y $.h.K.(.i.w.W W W E w.R 8.w.).0.h R.S.S.r T.n O O b.*.U.$.$.K.R w.E W W W E w.R v.u.D K A 7.J J 7.$. ", " z G @.@.J #.7.A K $.u.v.R i.w.L.^.V.:.<.e.~.~.1.b U.3.h... D.O.~.~.n.I.9.F ..i.E w.R 3.u.D F y v #.J @.@.C #.$. ", " z z z z G @.@.J #.v y K u.%.W.X.*.b.}.|.5.g p.'.8...D $.D ..v.K.q.e S.|.}.z.6 E w $.D F y /.#.s C @.G G z @.#.$. ", " z z z z z z G G @.#.v.).Q.c m.Y.Y.Z.`.4 9.^. +L.E w.8.R 8.w.W L.E (.(..+k ++@+@+#+.+D s s C @.G G z z z z @.#.$. ", " z z z z z z G D ^.$+I.4.%+&+&+m.].2._.L.%.'._.)._.'. +L. +'._.)._.'.%.(.h.W 6 *+&+&+@+g q.v G z z z z z z @.#.$. ", " z z z z K +C.=+U -.+.-+~.o.T ;+8.h...R E +).;+).)._.^._.).).;+). +E R ..$.K w .T.>+-+-+}.N.9.G z z z z @.#.$. ", " z z ..C.6 c.%+,+X '+)+k.. w.K y F h.3.i.%.'._.)._.'. +L. +'._.)._.'.%.i.v.h.F A v /.w 2.!+~+X ,+=.{+8.L L @.#.$. ", " z z 9.=.]+^+/+4.P.C. +D /.y $.h.K.(.w.W L.L.L.L.W w.8.R 8.w.E L.L.L.L.E i.(...M F y /.7.7.K (+o /+]+_+x L @.#.$. ", " z z (.:+[.<+[+V.K.A y F M ..(.8.w.W W W W w.i.(.K.u.D $.D u.K.(.i.w.W W W E w.R 3.u.D K y v 7.s u.B.m.B.z @.#.$. ", " z G C R }+R y y F D u.3.R w.E W W W E i.R v.u.$.K A v v v A w $.u.v.(.i.w.E W W w.i.R v.u.$.K A 7.#.J @.@.C #.$. ", " G @.J 7.A K D u.v.R w.E W W W E w.R 3.u.D K y v #.J C @.C J #.v y K D u.v.R w.E W W W w.i.(.K.h.$.y /.#.J J 7.$. ", " Q @.s v K M K.(.i.w.W %.W E w.8.3...M F y v #.s C @.G G z G G @.C J #.v y F M ..3.8.w.E W W E w.8.(...D y 7.#.v D ", " Q C 7.K u.(.w.W W W W w.i.(.K.h.$.y /.#.s C @.G G z z z z z z z G G @.C s #./.y $.h.K.(.i.w.E W W E i.3.h.y v v D ", " Q C v $.K.8.E W w.i.(.v.u.$.w A 7.s C @.@.G z z z z z z z z z z z z z G @.@.C s 7.A w $.u.v.(.i.w.E w.R ..F /./.D ", " Q C 7.F u.(.R (.v.u.D K A v #.J @.@.G z z z z z z z z z z z z z z z z z z z G @.@.J #.v y K D u.v.(.R (.u.K /./.D ", " Q @.#.A $.M h.D K y v #.J C @.G z z z z z z z z z z z z z z z z z z z z z z z z z G @.C J #.v y F D h.M F A 7.v D ", " @.C #.v A A v #.s C @.G G z z z z z z z z z z z z z z z z z z z z z z z z z z z z z G G @.C s #.v A A v #.s 7.$. ", " G @.@.C J J C @.G G z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z G @.@.C J J C @.J 7.$. ", " z z G G G G G z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z G G G G G @.#.$. ", " z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z @.#.$. ", " z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z z @.#.$. ", " @.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.@.J v M ", " #.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.#.v w .. ", " F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F $.D ..8. ", " ", " "}; end return Image end function ImageZOnly(pic) if (pic == nil) then pic = '0' end if pic == '0' then Image = { "60 60 417 2", " c None", ". c #A0A0A0", "+ c #9B9B9B", "@ c #979797", "# c #939393", "$ c #959595", "% c #989898", "& c #9C9C9C", "* c #9F9F9F", "= c #A1A1A1", "- c #A2A2A2", "; c #A2A2A3", "> c #A4A4A4", ", c #A5A5A6", "' c #A6A6A6", ") c #999999", "! c #F7F7F7", "~ c #EEEEEE", "{ c #F1F1F1", "] c #C4C4C5", "^ c #B2B2B0", "/ c #9F9FA0", "( c #8C8D8D", "_ c #8E8D8E", ": c #90908F", "< c #91908F", "[ c #8E8E8B", "} c #797877", "| c #6D6C6B", "1 c #70706F", "2 c #F9F9F9", "3 c #E2E2E2", "4 c #E5E5E5", "5 c #DDDDDD", "6 c #B3B3B2", "7 c #9A9C9A", "8 c #999997", "9 c #959594", "0 c #91928F", "a c #868584", "b c #757573", "c c #727272", "d c #949493", "e c #F0F0F0", "f c #E3E3E3", "g c #BFBFBE", "h c #A5A7A6", "i c #9C9C9B", "j c #989A99", "k c #929190", "l c #878786", "m c #787677", "n c #747473", "o c #80807F", "p c #AEAEAD", "q c #EDEDEE", "r c #E4E4E4", "s c #DFDFDF", "t c #B3B4B3", "u c #A09FA0", "v c #979795", "w c #8A8A8A", "x c #7A7A79", "y c #727270", "z c #808180", "A c #989896", "B c #9C9B9A", "C c #EFEFEF", "D c #E6E6E6", "E c #C1C1C1", "F c #A4A6A4", "G c #9C9E9C", "H c #7F7E7F", "I c #717170", "J c #7D7F7F", "K c #9B9996", "L c #747372", "M c #F2F2F2", "N c #E8E8E8", "O c #BCBCBC", "P c #A8A8A9", "Q c #A6A5A6", "R c #999B9A", "S c #888786", "T c #747474", "U c #7C7D7D", "V c #919191", "W c #9D9C99", "X c #8C8B89", "Y c #656563", "Z c #F5F5F5", "` c #E9E9E9", " . c #F8F8F8", ".. c #FFFFFF", "+. c #C3C3C1", "@. c #ACAEAC", "#. c #A3A3A3", "$. c #7D7F7D", "%. c #787979", "&. c #919192", "*. c #7E7E7C", "=. c #636362", "-. c #F5F5F6", ";. c #5A5A5A", ">. c #000000", ",. c #B4B4B4", "'. c #AFAFAF", "). c #A0A2A0", "!. c #8F9090", "~. c #7D7D7D", "{. c #8C8D8C", "]. c #939391", "^. c #969794", "/. c #898887", "(. c #787776", "_. c #686866", ":. c #717171", "<. c #C5C5C5", "[. c #909090", "}. c #929392", "|. c #949392", "1. c #91918E", "2. c #7C7D7A", "3. c #737372", "4. c #787877", "5. c #DEDEDE", "6. c #B4B4B3", "7. c #90908E", "8. c #838281", "9. c #757574", "0. c #737373", "a. c #9A9A9A", "b. c #A4A5A6", "c. c #999899", "d. c #868683", "e. c #747475", "f. c #848483", "g. c #B1B1B2", "h. c #DCDCDC", "i. c #9EA09E", "j. c #949694", "k. c #878788", "l. c #777776", "m. c #717172", "n. c #848484", "o. c #9A9996", "p. c #8F8F8E", "q. c #EFEFF0", "r. c #E7E7E7", "s. c #BAB9B9", "t. c #A5A6A5", "u. c #9D9D9D", "v. c #7C7C7C", "w. c #818182", "x. c #979796", "y. c #999795", "z. c #6F6E6D", "A. c #F3F3F3", "B. c #B8BAB8", "C. c #AAABAB", "D. c #858585", "E. c #737473", "F. c #828183", "G. c #929291", "H. c #9C9C98", "I. c #878785", "J. c #646362", "K. c #B7B7B7", "L. c #ADAEAF", "M. c #A2A3A2", "N. c #929492", "O. c #949594", "P. c #969594", "Q. c #959492", "R. c #7B7C7B", "S. c #656564", "T. c #B4B4B2", "U. c #A1A0A0", "V. c #8D8D8D", "W. c #7F7E7E", "X. c #939392", "Y. c #959693", "Z. c #858683", "`. c #6B6B6A", " + c #F4F4F4", ".+ c #EAEAEA", "++ c #D1D1D1", "@+ c #AEADAE", "#+ c #909191", "$+ c #8E8C8B", "%+ c #7A7978", "&+ c #727271", "*+ c #838282", "=+ c #3B3B3B", "-+ c #202020", ";+ c #B8B8B8", ">+ c #A2A3A3", ",+ c #989796", "'+ c #8E8D8C", ")+ c #80807D", "!+ c #767775", "~+ c #A3A3A2", "{+ c #161616", "]+ c #010101", "^+ c #C2C2C2", "/+ c #A1A3A1", "(+ c #9B9B9C", "_+ c #989897", ":+ c #8E8E8D", "<+ c #818180", "[+ c #777777", "}+ c #8B8B8A", "|+ c #AFAFAE", "1+ c #EDEDED", "2+ c #D5D5D5", "3+ c #AAAAAC", "4+ c #9E9E9E", "5+ c #9E9F9E", "6+ c #949492", "7+ c #858584", "8+ c #888988", "9+ c #9A9A96", "0+ c #868685", "a+ c #D4D4D4", "b+ c #BFBFBF", "c+ c #797978", "d+ c #878889", "e+ c #92908E", "f+ c #6C6C6B", "g+ c #F3F3F4", "h+ c #F6F6F6", "i+ c #AEAEAE", "j+ c #B9B9B9", "k+ c #A9ABAB", "l+ c #A2A4A2", "m+ c #979695", "n+ c #818281", "o+ c #898A8A", "p+ c #9B9A97", "q+ c #82827F", "r+ c #FBFBFB", "s+ c #838383", "t+ c #646464", "u+ c #FEFEFE", "v+ c #B1B2B1", "w+ c #ACADAC", "x+ c #797A7B", "y+ c #828182", "z+ c #959491", "A+ c #8F8D8D", "B+ c #797977", "C+ c #676766", "D+ c #515151", "E+ c #353535", "F+ c #BBBBBB", "G+ c #ACADAE", "H+ c #9B9D9D", "I+ c #8A8B8B", "J+ c #828383", "K+ c #909290", "L+ c #949292", "M+ c #80817E", "N+ c #EBEBEB", "O+ c #FDFDFD", "P+ c #252525", "Q+ c #0F0F0F", "R+ c #ECECEC", "S+ c #DADADA", "T+ c #989A9A", "U+ c #949394", "V+ c #919390", "W+ c #8F8F8F", "X+ c #888886", "Y+ c #767675", "Z+ c #FAFAFA", "`+ c #C0BEBF", " @ c #A4A4A1", ".@ c #969796", "+@ c #8E908F", "@@ c #8A8B89", "#@ c #858382", "$@ c #767673", "%@ c #696966", "&@ c #6A6A6B", "*@ c #9E9E9C", "=@ c #ECECED", "-@ c #E1E1E1", ";@ c #090909", ">@ c #323232", ",@ c #3A3A3A", "'@ c #4E4E4E", ")@ c #595959", "!@ c #565656", "~@ c #555555", "{@ c #5C5C5C", "]@ c #6D6D6D", "^@ c #7E7E7E", "/@ c #888888", "(@ c #C1C2C2", "_@ c #CCCCCC", ":@ c #D2D2D2", "<@ c #E0E0E0", "[@ c #D9D9D9", "}@ c #141414", "|@ c #3C3C3C", "1@ c #575757", "2@ c #535353", "3@ c #616161", "4@ c #696969", "5@ c #707070", "6@ c #7F7F7F", "7@ c #868686", "8@ c #ACACAC", "9@ c #A8A8A8", "0@ c #B1B1B1", "a@ c #C0C0C0", "b@ c #BDBDBD", "c@ c #C4C4C4", "d@ c #CACACA", "e@ c #DBDBDB", "f@ c #404040", "g@ c #5B5B5B", "h@ c #636363", "i@ c #6B6B6B", "j@ c #686868", "k@ c #6C6C6C", "l@ c #949494", "m@ c #B0B0B0", "n@ c #C7C7C7", "o@ c #CDCDCD", "p@ c #0D0D0D", "q@ c #383838", "r@ c #3F3F3F", "s@ c #5D5D5D", "t@ c #828282", "u@ c #8C8C8C", "v@ c #929292", "w@ c #B3B3B3", "x@ c #B6B6B6", "y@ c #BEBEBE", "z@ c #C9C9C9", "A@ c #040404", "B@ c #303030", "C@ c #4D4D4D", "D@ c #6F6F6F", "E@ c #818181", "F@ c #AAAAAA", "G@ c #C6C6C6", "H@ c #060606", "I@ c #282828", "J@ c #2B2B2B", "K@ c #ABABAB", "L@ c #B2B2B2", "M@ c #242424", "N@ c #626262", "O@ c #6A6A6A", "P@ c #121212", "Q@ c #4C4C4C", "R@ c #545454", "S@ c #6E6E6E", "T@ c #808080", "U@ c #878787", "V@ c #111111", "W@ c #232323", "X@ c #2A2A2A", "Y@ c #2F2F2F", "Z@ c #373737", "`@ c #3D3D3D", " # c #656565", ".# c #262626", "+# c #212121", "@# c #292929", "## c #313131", "$# c #505050", "%# c #4B4B4B", "&# c #0C0C0C", "*# c #363636", "=# c #4F4F4F", "-# c #8B8B8B", ";# c #A9A9A9", "># c #070707", ",# c #393939", "'# c #8E8E8E", ")# c #969696", "!# c #0E0E0E", "~# c #151515", "{# c #606060", "]# c #030303", "^# c #131313", "/# c #1A1A1A", "(# c #222222", "_# c #1F1F1F", ":# c #424242", "<# c #4A4A4A", "[# c #585858", "}# c #797979", "|# c #757575", "1# c #7B7B7B", "2# c #898989", "3# c #A5A5A5", "4# c #BABABA", "5# c #C3C3C3", "6# c #CBCBCB", "7# c #CECECE", "8# c #D0D0D0", "9# c #D3D3D3", "0# c #D6D6D6", "a# c #D8D8D8", "b# c #676767", "c# c #D7D7D7", "d# c #787878", "e# c #7A7A7A", "f# c #767676", "g# c #A7A7A7", "h# c #666666", "i# c #ADADAD", "j# c #C8C8C8", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ", ". + @ # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # $ % & * = - - ; > , ' . ) # # # @ + . ", ". @ ! ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ { ] ^ / ( _ : < [ } | 1 2 ~ ~ ~ ! @ . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 5 6 - 7 8 9 0 a b c d e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 f f g h i j k l m n o p q 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 r s t = u v w x y z A B C 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 D E ' F G : H I J d K L M 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 N O P Q R S T U V W X Y Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ` ........... .` 3 3 3 N +.@.#.$ $.%.&.9 A *.=.-.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 e ;.>.>.>.>.>.;.e 3 3 3 N ,.'.).!.~.{.].^./.(._.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 D <.p * [.}.d |.1.2.3.4.M 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 r 5.6.- & 8 9 7.8.9.0.a.C 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 f f E b.i c.< d.9.e.f.g.~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 4 h.'.. i.j.k.l.m.n.o.p.q.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 r.s.' t.u.p.v.:.w.x.y.z.A.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 ` B.C.F % D.E.F.G.H.I.J.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 ` K.L.M.N.U U O.P.Q.R.S.-.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 N T.'.U.V.W.: X.Y.Z.9.`. +3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .+! ......n.>.>.>.>.>.n....... .C ++@+* #+# d ].$+%+&+*+{ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .+=+>.>.>.>.>.>.>.>.>.>.>.>.>.-+~ 3 ;+>+a.,+d '+)+3.!+~+~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .+2 {+>.>.>.>.>.>.>.>.>.>.>.]+{ ~ f ^+/+(+_+:+<+c [+}+|+~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 C 1+>.>.>.>.>.>.>.>.>.>.>.5.{ D 2+3+4+5+6+7+b T 8+9+0+e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 f M a+>.>.>.>.>.>.>.>.>.b+Z r r.,.> > + }+c+c d+_+e+f+g+3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 r h+i+>.>.>.>.>.>.>.# 2 4 3 ` j+k+l+m+n+T o+X.p+q+S.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 D r+s+>.>.>.>.>.t+u+r.3 3 ` v+w+. !.x+y+9 z+A+B+C+Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 N ..D+>.>.>.E+...+3 3 3 r.F+G+H+I+J+K+[.L+M+3.&+A.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 N+O+P+>.Q+! R+3 3 3 3 4 S+@+T+V U+V+W+X+Y+c p.e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 R+h+..u+....-+Z+..2 ! Z A.A.A.~ `+ @.@+@@@#@$@%@&@*@=@3 3 -@~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ! ;@>@=+,@'@)@!@~@{@)@]@T ^@v./@$ % '.j+K.^+(@_@:@a+<@[@3 R+1+# . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..}@|@'@1@2@{@t+3@4@5@s+6@7@V.$ # + % 8@9@0@;+a@b@c@d@e@f 1+~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..{+f@|@'@1@2@g@h@i@j@5@k@6@D.V.$ l@V ) 8@9@m@;+b+n@o@<@e@[@C # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..p@q@r@|@'@!@s@;.h@i@4@5@t@~.D.V.u@$ v@) 8@w@'.x@y@<.^+z@e@e # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..A@B@q@r@|@C@!@s@;.h@i@j@D@E@/@7@n.V.$ V @ F@0@;+a@b@G@o@5 { # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..H@I@B@q@r@|@C@!@s@;.h@i@j@D@t@6@~.n.u@# a.8@w@'.K.b+n@c@z@M # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..>.J@I@B@q@r@|@C@!@s@;.h@i@j@5@k@6@7@V.$ & % K@L@j+x@b+n@a@A.# . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..>.M@J@I@B@q@r@|@C@!@s@;.N@O@j@5@E@/@n.u@l@+ % K@0@j+x@b+^+ +# . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..>.P@M@J@I@B@q@r@=+Q@R@g@h@k@O@c S@T@U@n.u@l@+ % K@0@j+x@j+Z # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..>.{+V@W@X@>@Y@Z@`@'@!@s@ #h@3@O@:.S@T@U@n.u@l@+ % K@0@j+'.h+# . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..>.p@}@.#+#@###q@r@$#%#R@s@g@)@N@O@:.S@T@U@n.u@l@+ % K@0@0@! # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..>.Q+&#}@P+J@>@Y@*#`@=#%#!@R@{@t+3@4@:.S@T@U@n.-## + % K@;# .# . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..>.>#A@&#V@W@X@##,#*#`@$#C@%#R@{@h@k@4@:.]@6@7@'#)## + @ . 2 # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ..>.>.>#!#~#.#+#@###,#*#r@=+=#%#R@g@h@{#4@5@t@^@D.V.-#l@a.#.Z+# . ", ". # ~ 3 3 3 N ~ A.A.A.M M { { e e C C ~ ~ ~ 1+1+R+R+N+..>.>.>.>.>.>.]#&#;@^#V@/#(#_#>@|@,#:#<#2@$#[#O@j@:.}#[+6@T@Z # . ", ". # ~ 3 3 3 ~ #|#|#}#~.1#t@7@w 2#V.V $ l@+ a.4+= 3#3#K.o@S+5.<@s -@f -@r f ` r..+R+C { C Z ! Z+ .r+O+..u+........{ # . ", ". # ~ 3 3 3 +:.s+U@w 2#u@# )#l@% @ a.4+u.. ' ;#9@8@'.i+0@m@K.4#b@O a@b+5#^+<.6#7#o@8#9#0#5 h.s 3 D 4 f r..+e ~ h+N+# . ", ". # ~ 3 3 3 Z S@T@s+U@w 2#u@v@V $ % + a.4+u.. ' ;#9@8@'.i+L@m@x@4#b@b@O a@5#^+<.6#7#++a+a#:@2+h.s 5 -@4 N r..+e ! N+# . ", ". # ~ 3 3 3 Z b#E@T@s+U@7@2#u@v@V l@% @ + 4+= . ' 3#9@8@'.i+0@;+x@4#j+b@O a@5#G@c@d@7#_@8#a+c#2+h.s 3 -@r N N+.+A.R+# . ", ". # ~ 3 3 3 h+h@1#t@T@n.U@7@2#u@# V $ % @ a.4+= . ' ;#9@8@'.i+0@;+K.x@4#b@O b+^+<._@d@7#++8#9#0#5 e@5.3 4 r N N+R+R+# . ", ". # ~ 3 3 3 h+{#d#v.e#E@n.U@7@2#V.-#v@$ % @ + 4+u.. ' ;#9@8@'.i+L@0@m@x@j+b@a@5#^+<.6#7#o@++a+9#0#h.s 5.3 4 r N 1+1+# . ", ". # ~ 3 3 3 ! {#|#}#v.1#E@n.U@7@w V.u@v@$ l@@ + 4+u.. ' 3#9@8@'.'.i+0@K.4#b@O a@5#G@<.6#7#o@++a+9#0#h.s 5.3 4 r ` 1+# . ", ". # ~ 3 3 3 ! {@f#|#}#v.1#E@n.s+7@w V.u@v@$ l@@ + 4+u.. ' 3#9@8@K@'.L@;+x@4#b@O b+5#G@<.6#7#o@++a+c#0#h.s 5.3 4 4 ~ # . ", ". # ~ 3 3 3 .)@0.c |#}#v.1#E@n.s+7@w V.u@v@$ l@@ + 4+u.. ' ;#9@8@K@i+0@;+x@4#b@O b+5#G@<.6#7#o@8#a+c#0#h.s 5.3 D ~ # . ", ". # ~ 3 3 3 .!@D@0.f#|#}#v.e#E@n.U@7@w V.-#v@$ % @ a.4+= g#3#;#9@8@K@i+L@m@K.4#b@O b+5#G@<.6#7#o@8#a+9#0#h.s 5.3 ~ # . ", ". # ~ 3 3 3 .1@]@D@0.f#|#d#1#t@T@n.U@7@2#u@# V l@% + 4+u.& g#' 3#;#8@K@'.L@m@x@4#b@O a@5#^+<.6#7#o@++a+9#0#h.s 5.C # . ", ". # ~ 3 3 3 .1@]@5@D@c f#}#d#1#E@T@s+U@w '#u@v@$ l@@ + a.u.= . ' 3#9@8@K@'.L@;+x@4#j+O a@5#^+<.6#7#o@++a+9#0#h.s C # . ", ". # ~ 3 3 3 .1@]@]@5@0.c |#}#~.1#E@n./@t@7@2#u@v@$ ) # + 4+4+u.. ' ;#9@8@K@i+0@K.x@4#b@O a@5#^+<.6#d@o@++a+9#0#e@e # . ", ". # ~ 3 3 3 .1@S@]@]@D@0.[+f#T d#1#E@T@s+U@w V.u@v@[.) @ + a.4+u.. ' ;#9@8@K@i+0@K.x@4#b@O a@5#G@<.6#d@o@++8#9#a+e # . ", ". @ ! ~ ~ ~ O+~@t+t+t+h@h# #4@]@:.5@T e#^@~.E@D.2#/@W+v@V )#$ ) u.& . g#' F@i+i#0@,.F+4#y@^+E <.z@j#_@9#c#0#S+5.<@ .@ . ", ". + @ # # # a.- ;#;#;#;#;#;#9@9@g#g#' ' 3#3#> > #.#.- - = = = . . . * * 4+4+u.u.u.& + + a.a.a.) ) % % @ @ )#)#$ l@% + . ", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . "}; elseif pic == '1' then Image = { "60 60 436 2", " c None", ". c #A0A0A0", "+ c #9B9B9B", "@ c #979797", "# c #939393", "$ c #969696", "% c #A2A2A2", "& c #A7A7A7", "* c #ABABAB", "= c #ACACAC", "- c #ACACAD", "; c #ADADAD", "> c #AFAFAF", ", c #B2B2B2", "' c #B3B3B4", ") c #A8A9A9", "! c #9D9D9D", "~ c #F7F7F7", "{ c #EEEEEE", "] c #F2F2F2", "^ c #B1B1B1", "/ c #8D8F8C", "( c #6D6F6E", "_ c #4B4D4D", ": c #4D4E4D", "< c #535351", "[ c #545250", "} c #50504A", "| c #2A2927", "1 c #151312", "2 c #1B1B1A", "3 c #FFFFFF", "4 c #E2E2E2", "5 c #E5E5E5", "6 c #E4E4E4", "7 c #989897", "8 c #7A7B7A", "9 c #6D6E6D", "0 c #6A6967", "a c #626262", "b c #5D5D5A", "c c #484745", "d c #2A2A28", "e c #262625", "f c #636361", "g c #F9F9F9", "h c #E3E3E3", "i c #EFEFEF", "j c #AEAEAD", "k c #818281", "l c #706F6E", "m c #6A6C69", "n c #5D5D5B", "o c #4A4A48", "p c #2F2E2D", "q c #292928", "r c #3E3E3E", "s c #929290", "t c #F5F5F5", "u c #E7E7E7", "v c #989998", "w c #787978", "x c #757675", "y c #676764", "z c #50504F", "A c #333332", "B c #252524", "C c #3E403F", "D c #6A6865", "E c #71706E", "F c #EAEAEA", "G c #E8E8E8", "H c #B1B0B1", "I c #818382", "J c #808180", "K c #717271", "L c #5A5C59", "M c #3C3C3B", "N c #242423", "O c #393B3C", "P c #61615F", "Q c #6D6B65", "R c #2C2A28", "S c #FDFDFD", "T c #3B3B3B", "U c #FAFAFA", "V c #EBEBEB", "W c #ABAAA9", "X c #858685", "Y c #6B6C6B", "Z c #4C4C4B", "` c #292A29", " . c #383A3A", ".. c #5D5D5C", "+. c #71706B", "@. c #54524E", "#. c #11100E", "$. c #000000", "%. c #0F0F0F", "&. c #F3F3F3", "*. c #ECECEC", "=. c #B5B4B3", "-. c #8C8E8C", ";. c #7B7C7D", ">. c #636363", ",. c #3B3C3A", "'. c #303131", "). c #5C5E5E", "!. c #636360", "~. c #696863", "{. c #3B3B38", "]. c #0E0D0A", "^. c #CCCCCC", "/. c #F8F8F8", "(. c #E6E6E6", "_. c #9A9A9A", ":. c #909190", "<. c #797A79", "[. c #58595A", "}. c #393A3A", "|. c #555655", "1. c #5F5F5D", "2. c #676663", "3. c #4E4D4A", "4. c #302F2D", "5. c #151513", "6. c #FCFCFC", "7. c #A5A5A5", "8. c #E9E9E9", "9. c #B9B9B9", "0. c #90908E", "a. c #5A5B5B", "b. c #5E5F5E", "c. c #626260", "d. c #62605E", "e. c #5C5D58", "f. c #373834", "g. c #282726", "h. c #31312F", "i. c #FDFDFE", "j. c #393939", "k. c #515151", "l. c #717171", "m. c #999998", "n. c #797B7B", "o. c #6F706F", "p. c #696968", "q. c #5A5B57", "r. c #444341", "s. c #2B2A29", "t. c #6E6E6D", "u. c #3C3C3C", "v. c #F0F0F0", "w. c #F1F1F1", "x. c #B0B0B0", "y. c #7E8180", "z. c #70706F", "A. c #6B6B6A", "B. c #484846", "C. c #2B2B29", "D. c #2A2A29", "E. c #474745", "F. c #111111", "G. c #929192", "H. c #767776", "I. c #747574", "J. c #636462", "K. c #4D4D4C", "L. c #30302E", "M. c #262627", "N. c #454546", "O. c #6C6965", "P. c #595957", "Q. c #F8F8F9", "R. c #B3B3B3", "S. c #818280", "T. c #585857", "U. c #383837", "V. c #242424", "W. c #404142", "X. c #676765", "Y. c #6A6762", "Z. c #23211F", "`. c #FEFEFF", " + c #212121", ".+ c #B0B2AF", "++ c #898B8A", "@+ c #7E807F", "#+ c #696A69", "$+ c #474847", "%+ c #272927", "&+ c #424244", "*+ c #5D5F5D", "=+ c #706F6A", "-+ c #4B4A47", ";+ c #100E0C", ">+ c #4A4A4A", ",+ c #FBFBFB", "'+ c #8E8F8F", ")+ c #60605F", "!+ c #383939", "~+ c #373838", "{+ c #616362", "]+ c #656360", "^+ c #64615E", "/+ c #373634", "(+ c #12100E", "_+ c #F6F6F6", ":+ c #7A7A7A", "<+ c #8F8F8F", "[+ c #A4A4A4", "}+ c #747474", "|+ c #9A9A98", "1+ c #777879", "2+ c #555657", "3+ c #3C3D3D", "4+ c #5A5A59", "5+ c #60605E", "6+ c #656461", "7+ c #484744", "8+ c #2C2C2A", "9+ c #1C1B1A", "0+ c #EDEDED", "a+ c #A6A6A6", "b+ c #CECECE", "c+ c #908F8E", "d+ c #5B5C5D", "e+ c #616161", "f+ c #61615E", "g+ c #565551", "h+ c #33312F", "i+ c #252525", "j+ c #454443", "k+ c #FBFBFC", "l+ c #C7C7C7", "m+ c #ECECED", "n+ c #A1A1A1", "o+ c #7B7D7C", "p+ c #6C6D6C", "q+ c #676866", "r+ c #585654", "s+ c #3E3D3B", "t+ c #282826", "u+ c #2D2D2C", "v+ c #7F7D7C", "w+ c #030303", "x+ c #E0E0E0", "y+ c #F4F4F4", "z+ c #F0EFEF", "A+ c #B3B2B2", "B+ c #706F70", "C+ c #676966", "D+ c #585856", "E+ c #40403E", "F+ c #272726", "G+ c #2D2F2E", "H+ c #525250", "I+ c #949392", "J+ c #202020", "K+ c #D7D7D7", "L+ c #87898A", "M+ c #737474", "N+ c #737473", "O+ c #474746", "P+ c #2A2A2B", "Q+ c #4D4F4E", "R+ c #6E6C67", "S+ c #F9F9FA", "T+ c #9C9C9C", "U+ c #7E7F7F", "V+ c #6C6E6C", "W+ c #535251", "X+ c #313130", "Y+ c #272627", "Z+ c #6A6A66", "`+ c #5D5C57", " @ c #1B1B19", ".@ c #A4A5A4", "+@ c #878889", "@@ c #7B7C7B", "#@ c #656563", "$@ c #424342", "%@ c #292929", "&@ c #4F5051", "*@ c #6C6B66", "=@ c #43413E", "-@ c #11110F", ";@ c #969796", ">@ c #8C8E8D", ",@ c #767777", "'@ c #333435", ")@ c #414243", "!@ c #626261", "~@ c #63615E", "{@ c #585754", "]@ c #32312F", "^@ c #131411", "/@ c #A9A9A9", "(@ c #8C8F8D", "_@ c #6F6F70", ":@ c #4F5252", "<@ c #424344", "[@ c #5C5D5C", "}@ c #61605D", "|@ c #403E3B", "1@ c #282927", "2@ c #292927", "3@ c #DEDEDE", "4@ c #6A6B6C", "5@ c #606160", "6@ c #5D5E5C", "7@ c #2E2E2C", "8@ c #5C5C59", "9@ c #A09F9F", "0@ c #71716C", "a@ c #5A5B5A", "b@ c #505150", "c@ c #484946", "d@ c #403E3C", "e@ c #252521", "f@ c #0F0F0D", "g@ c #151516", "h@ c #727270", "i@ c #777777", "j@ c #7D7D7D", "k@ c #7C7C7C", "l@ c #818181", "m@ c #878787", "n@ c #858585", "o@ c #8B8B8B", "p@ c #909090", "q@ c #8E8E8E", "r@ c #999999", "s@ c #9E9E9E", "t@ c #A3A3A3", "u@ c #B7B7B7", "v@ c #BEBEBE", "w@ c #CDCDCD", "x@ c #D4D4D5", "y@ c #D5D4D5", "z@ c #DCDCDD", "A@ c #DFDFDF", "B@ c #DCDCDC", "C@ c #E1E1E1", "D@ c #676767", "E@ c #7F7F7F", "F@ c #888888", "G@ c #8C8C8C", "H@ c #919191", "I@ c #959595", "J@ c #989898", "K@ c #B5B5B5", "L@ c #BCBCBC", "M@ c #C1C1C1", "N@ c #C5C5C5", "O@ c #CACACA", "P@ c #CBCBCB", "Q@ c #CFCFCF", "R@ c #D9D9D9", "S@ c #DDDDDD", "T@ c #696969", "U@ c #A8A8A8", "V@ c #B4B4B4", "W@ c #C0C0C0", "X@ c #C9C9C9", "Y@ c #D1D1D1", "Z@ c #DBDBDB", "`@ c #D6D6D6", " # c #8D8D8D", ".# c #929292", "+# c #C2C2C2", "@# c #BFBFBF", "## c #C4C4C4", "$# c #C8C8C8", "%# c #D8D8D8", "&# c #5E5E5E", "*# c #787878", "=# c #AAAAAA", "-# c #BDBDBD", ";# c #5F5F5F", "># c #5A5A5A", ",# c #767676", "'# c #C6C6C6", ")# c #4F4F4F", "!# c #727272", "~# c #949494", "{# c #4B4B4B", "]# c #737373", "^# c #4C4C4C", "/# c #666666", "(# c #757575", "_# c #808080", ":# c #464646", "<# c #646464", "[# c #686868", "}# c #707070", "|# c #797979", "1# c #898989", "2# c #474747", "3# c #BBBBBB", "4# c #484848", "5# c #7E7E7E", "6# c #868686", "7# c #B6B6B6", "8# c #424242", "9# c #5B5B5B", "0# c #656565", "a# c #B8B8B8", "b# c #3A3A3A", "c# c #4E4E4E", "d# c #525252", "e# c #565656", "f# c #6D6D6D", "g# c #7B7B7B", "h# c #828282", "i# c #8A8A8A", "j# c #D4D4D4", "k# c #D2D2D2", "l# c #D5D5D5", "m# c #DADADA", "n# c #FEFEFE", "o# c #838383", "p# c #AEAEAE", "q# c #BABABA", "r# c #C3C3C3", "s# c #D0D0D0", "t# c #D3D3D3", "u# c #6E6E6E", "v# c #848484", "w# c #606060", "x# c #5C5C5C", "y# c #595959", "z# c #6F6F6F", "A# c #575757", "B# c #555555", "C# c #9F9F9F", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ", ". + @ # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # $ + % & * = - ; > , ' ) ! # # # @ + . ", ". @ ~ { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { { ] ^ / ( _ : < [ } | 1 2 3 { { { ~ @ . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 5 6 7 8 9 0 a b c d e f g 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 h i j k l m n o p q r s t 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 5 u v w x y z A B C D E ~ 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 F F F 4 4 4 4 4 4 G H I J K L M N O P Q R S 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 ~ T U i h 4 4 4 4 V W X J Y Z ` ...+.@.#.3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.%.F &.6 4 4 4 *.=.-.;.>.,.'.).!.~.{.].3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.$.$.^./.(.4 4 V _.:.<.[.}.|.1.2.3.4.5.3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 F &.6.6.6.6.6.6.6.6.3 $.$.$.$.7.6.8.4 G 9.0.x a.b.c.d.e.f.g.h.i.4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 g j.k.k.k.k.k.k.k.k.>.$.$.$.$.$.l.3 *.5 (.m.n.o.p.!.q.r.s.q t.~ 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$.u.S v.w.x.y.z.A.b B.C.D.E.7 t 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$.F.8.i G.H.I.J.K.L.M.N.O.P.Q.4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$.%.R.J S.K T.U.V.W.X.Y.Z.`.4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$. +6..+++@+#+$+%+&+*+=+-+;+3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.$.$.$.$.$.$.$.$.$.$.$.$.$.$.$.>+,+g % '+8 )+!+~+{+]+^+/+(+3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 _+:+<+<+<+<+<+<+<+<+[+$.$.$.$.$.}+3 V V |+:.1+2+3+4+5+6+7+8+9+3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 u 0+&.&.&.&.&.&.&.&.3 $.$.$.$.a+6.8.4 u b+c+x d+e+c.f+g+h+i+j+k+4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.$.$.l+/.(.4 4 h m+n+o+p+q+c.r+s+t+u+v+_+4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 $.w+x+y+5 4 4 4 h z+A+8 B+C+D+E+F+G+H+I+t 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 /.J+w.w.h 4 4 4 4 u K+L+M+N+)+O+q P+Q+R+>+S+4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 V *.*.4 4 4 4 4 4 F T+U+U+V+W+X+Y+_ Z+`+ @3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 0+.@+@@@#@$@%@&@)+*@=@-@3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 0+;@>@,@a.'@)@!@~@{@]@^@3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 F /@(@_@:@<@[@n }@|@1@2@3 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 (.3@c+4@d+5@6@4+3.7@e 8@U 4 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 G { &.] ] w.w.v.v.i { { 0+*.0+] 9@0@a@b@c@d@e@f@g@h@] h 4 4 { # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 { e+i@j@k@l@m@n@o@p@q@r@s@t@% * u@v@w@x@y@z@3@5 (.A@A@K+B@C@i # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 t D@E@F@q@G@H@I@# J@T+& 7./@; , x.K@R.v@L@M@N@O@l+P@Q@R@S@4 i # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 t T@l@E@F@q@G@p@I@_.@ T+_.7.U@; , ^ > V@v@L@W@N@X@w@Y@Z@R@`@v.# . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 _+>.j@l@E@F@ #.#p@I@r@J@T+& [+U@; = ^ > V@v@+#@###$#^.O@b+%#v.# . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 _+&#*#j@l@E@F@ #H@p@I@r@@ T+a+=#/@U@; ^ > R.-#M@N@O@$#w@Y@R@w.# . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 ~ ;#}+*#j@l@E@F@ #H@p@I@r@@ + a+7.t@U@= x.V@v@+#@###X@b+P@w@w.# . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 /.>#,#}+*#j@l@E@F@ #H@p@I@r@@ T+_.7./@; ^ K@R.-#M@'###X@w@$#] # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 g )#!#,#}+*#j@l@E@F@ #H@<+~#r@@ T+a+=#U@= ^ K@R.-#M@N@##X@X@&.# . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 U {#D@l.,#]#*#j@l@E@m@G@p@I@_.r@! + 7.=#U@= ^ K@R.-#M@N@####&.# . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 U ^#T@/#l.(#:+i@k@_#F@ #H@$ I@~#r@! + 7.=#U@= ^ K@R.-#M@N@@#y+# . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 U :#<#[#]#}#}+|#j@l@1#m@G@H@p@<+~#r@! + 7.=#U@= ^ K@R.-#M@W@y+# . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 ,+2#/#<#[#!#,#:+i@k@_#1#m@ #G@H@$ # J@! + 7.=#& = x.K@R.-#3#t # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 ,+4#e+;#>.D@l.(#|#5#k@_#1#F@6#G@H@I@_.J@! _.7./@; , x.K@, 7#t # . ", ". # { 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 ,+8#9#e+0#T@]#}#}+|#5#k@l@E@1#6#G@p@I@# J@T+& [+U@; * ^ K@a#_+# . ", ". # { 4 4 4 G { &.&.&.] ] w.w.v.v.i i { { { 0+0+*.*.V 6.b#>+)#c#d#e#e+0#<#T@[#f#l.}#*#E@j@l@6#o@1# #J@$ + . s@% t@] # . ", ". # { 4 4 4 { 0#(#(#|#j@g#h#6#i#1# #H@I@~#+ _.s@n+7.7.^ M@$#^.Q@b+Y@j#k#`@l#Z@m#S@x+h (.6 V 0+w.i ] _+g /.n#3 3 3 i # . ", ". # { 4 4 4 y+l.o#m@i#1#G@# $ ~#J@@ _.s@! . a+/@U@= > p#^ x.u@q#-#L@W@@#r#+#N@P@b+w@s#t#`@S@B@A@4 (.5 h u F v.{ _+V # . ", ". # { 4 4 4 t u#_#o#m@i#1#G@.#H@I@J@+ _.s@! . a+/@U@= > p#, x.7#q#-#-#L@W@r#+#N@P@b+Y@j#%#k#l#B@A@S@C@5 G u F v.~ V # . ", ". # { 4 4 4 t D@l@_#o#m@6#1#G@.#H@~#J@@ + s@n+. a+7.U@= > p#^ a#7#q#9.-#L@W@r#'###O@b+^.s#j#K+l#B@A@4 C@6 G V F &.*.# . ", ". # { 4 4 4 _+>.g#h#_#v#m@6#1#G@# H@I@J@@ _.s@n+. a+/@U@= > p#^ a#u@7#q#-#L@@#+#N@^.O@b+Y@s#t#`@S@Z@3@4 5 6 G V *.*.# . ", ". # { 4 4 4 _+w#*#k@:+l@v#m@6#1# #o@.#I@J@@ + s@! . a+/@U@= > p#, ^ x.7#9.-#W@r#+#N@P@b+w@Y@j#t#`@B@A@3@4 5 6 G 0+0+# . ", ". # { 4 4 4 ~ w#(#|#k@g#l@v#m@6#i# #G@.#I@~#@ + s@! . a+7.U@= > > p#^ u@q#-#L@W@r#'#N@P@b+w@Y@j#t#`@B@A@3@4 5 6 8.0+# . ", ". # { 4 4 4 ~ x#,#(#|#k@g#l@v#o#6#i# #G@.#I@~#@ + s@! . a+7.U@= * > , a#7#q#-#L@@#r#'#N@P@b+w@Y@j#K+`@B@A@3@4 5 5 { # . ", ". # { 4 4 4 /.y#]#!#(#|#k@g#l@v#o#6#i# #G@.#I@~#@ + s@! . a+/@U@= * p#^ a#7#q#-#L@@#r#'#N@P@b+w@s#j#K+`@B@A@3@4 (.{ # . ", ". # { 4 4 4 /.e#z#]#,#(#|#k@:+l@v#m@6#i# #o@.#I@J@@ _.s@n+& 7./@U@= * p#, x.u@q#-#L@@#r#'#N@P@b+w@s#j#t#`@B@A@3@4 { # . ", ". # { 4 4 4 /.A#f#z#]#,#(#*#g#h#_#v#m@6#1#G@# H@~#J@+ s@! T+& a+7./@= * > , x.7#q#-#L@W@r#+#N@P@b+w@Y@j#t#`@B@A@3@i # . ", ". # { 4 4 4 /.A#f#}#z#!#,#|#*#g#l@_#o#m@i#q@G@.#I@~#@ + _.! n+. a+7.U@= * > , a#7#q#9.L@W@r#+#N@P@b+w@Y@j#t#`@B@A@i # . ", ". # { 4 4 4 /.A#f#f#}#]#!#(#|#j@g#l@v#F@h#6#1#G@.#I@r@# + s@s@! . a+/@U@= * p#^ u@7#q#-#L@W@r#+#N@P@O@w@Y@j#t#`@Z@v.# . ", ". # { 4 4 4 /.A#u#f#f#z#]#i@,#}+*#g#l@_#o#m@i# #G@.#p@r@@ + _.s@! . a+/@U@= * p#^ u@7#q#-#L@W@r#'#N@P@O@w@Y@s#t#j#v.# . ", ". @ ~ { { { S B#<#<#<#>./#0#T@f#l.}#}+:+5#j@l@n@1#F@<+.#H@$ I@r@! T+. & a+=#p#; ^ V@3#q#v@+#M@N@X@$#^.t#K+`@m#3@x+/.@ . ", ". + @ # # # _.% /@/@/@/@/@/@U@U@& & a+a+7.7.[+[+t@t@% % n+n+n+. . . C#C#s@s@! ! ! T++ + _._._.r@r@J@J@@ @ $ $ I@~#J@+ . ", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . "}; elseif pic == '2' then Image = { "60 60 430 2", " c None", ". c #A0A0A0", "+ c #9B9B9B", "@ c #979797", "# c #939393", "$ c #959595", "% c #989898", "& c #9C9C9C", "* c #9F9F9F", "= c #A1A1A1", "- c #A2A2A2", "; c #A2A2A3", "> c #A4A4A4", ", c #A5A5A6", "' c #A6A6A6", ") c #999999", "! c #F7F7F7", "~ c #EEEEEE", "{ c #F1F1F1", "] c #C4C4C5", "^ c #B2B2B0", "/ c #9F9FA0", "( c #8C8D8D", "_ c #8E8D8E", ": c #90908F", "< c #91908F", "[ c #8E8E8B", "} c #797877", "| c #6D6C6B", "1 c #70706F", "2 c #F9F9F9", "3 c #E2E2E2", "4 c #E5E5E5", "5 c #DDDDDD", "6 c #B3B3B2", "7 c #9A9C9A", "8 c #999997", "9 c #959594", "0 c #91928F", "a c #868584", "b c #757573", "c c #727272", "d c #949493", "e c #F0F0F0", "f c #E3E3E3", "g c #BFBFBE", "h c #A5A7A6", "i c #9C9C9B", "j c #989A99", "k c #929190", "l c #878786", "m c #787677", "n c #747473", "o c #80807F", "p c #AEAEAD", "q c #EDEDEE", "r c #E4E4E4", "s c #DFDFDF", "t c #B3B4B3", "u c #A09FA0", "v c #979795", "w c #8A8A8A", "x c #7A7A79", "y c #727270", "z c #808180", "A c #989896", "B c #9C9B9A", "C c #EFEFEF", "D c #E6E6E6", "E c #C1C1C1", "F c #A4A6A4", "G c #9C9E9C", "H c #7F7E7F", "I c #717170", "J c #7D7F7F", "K c #9B9996", "L c #747372", "M c #F2F2F2", "N c #E8E8E8", "O c #BCBCBC", "P c #A8A8A9", "Q c #A6A5A6", "R c #999B9A", "S c #888786", "T c #747474", "U c #7C7D7D", "V c #919191", "W c #9D9C99", "X c #8C8B89", "Y c #656563", "Z c #F5F5F5", "` c #C3C3C1", " . c #ACAEAC", ".. c #A3A3A3", "+. c #7D7F7D", "@. c #787979", "#. c #919192", "$. c #7E7E7C", "%. c #636362", "&. c #F5F5F6", "*. c #B4B4B4", "=. c #AFAFAF", "-. c #A0A2A0", ";. c #8F9090", ">. c #7D7D7D", ",. c #8C8D8C", "'. c #939391", "). c #969794", "!. c #898887", "~. c #787776", "{. c #686866", "]. c #C5C5C5", "^. c #909090", "/. c #929392", "(. c #949392", "_. c #91918E", ":. c #7C7D7A", "<. c #737372", "[. c #787877", "}. c #DEDEDE", "|. c #B4B4B3", "1. c #90908E", "2. c #838281", "3. c #757574", "4. c #737373", "5. c #9A9A9A", "6. c #A4A5A6", "7. c #999899", "8. c #868683", "9. c #747475", "0. c #848483", "a. c #B1B1B2", "b. c #DCDCDC", "c. c #9EA09E", "d. c #949694", "e. c #878788", "f. c #777776", "g. c #717172", "h. c #848484", "i. c #9A9996", "j. c #8F8F8E", "k. c #EFEFF0", "l. c #E7E7E7", "m. c #BAB9B9", "n. c #A5A6A5", "o. c #9D9D9D", "p. c #7C7C7C", "q. c #717171", "r. c #818182", "s. c #979796", "t. c #999795", "u. c #6F6E6D", "v. c #F3F3F3", "w. c #E9E9E9", "x. c #B8BAB8", "y. c #AAABAB", "z. c #858585", "A. c #737473", "B. c #828183", "C. c #929291", "D. c #9C9C98", "E. c #878785", "F. c #646362", "G. c #B7B7B7", "H. c #ADAEAF", "I. c #A2A3A2", "J. c #929492", "K. c #949594", "L. c #969594", "M. c #959492", "N. c #7B7C7B", "O. c #656564", "P. c #B4B4B2", "Q. c #A1A0A0", "R. c #8D8D8D", "S. c #7F7E7E", "T. c #939392", "U. c #959693", "V. c #858683", "W. c #6B6B6A", "X. c #F4F4F4", "Y. c #D1D1D1", "Z. c #AEADAE", "`. c #909191", " + c #8E8C8B", ".+ c #7A7978", "++ c #727271", "@+ c #838282", "#+ c #B8B8B8", "$+ c #A2A3A3", "%+ c #989796", "&+ c #8E8D8C", "*+ c #80807D", "=+ c #767775", "-+ c #A3A3A2", ";+ c #C2C2C2", ">+ c #A1A3A1", ",+ c #9B9B9C", "'+ c #989897", ")+ c #8E8E8D", "!+ c #818180", "~+ c #777777", "{+ c #8B8B8A", "]+ c #AFAFAE", "^+ c #D5D5D5", "/+ c #AAAAAC", "(+ c #9E9E9E", "_+ c #9E9F9E", ":+ c #949492", "<+ c #858584", "[+ c #888988", "}+ c #9A9A96", "|+ c #868685", "1+ c #797978", "2+ c #878889", "3+ c #92908E", "4+ c #6C6C6B", "5+ c #F3F3F4", "6+ c #F8F8F8", "7+ c #FFFFFF", "8+ c #B9B9B9", "9+ c #A9ABAB", "0+ c #A2A4A2", "a+ c #979695", "b+ c #818281", "c+ c #898A8A", "d+ c #9B9A97", "e+ c #82827F", "f+ c #5A5A5A", "g+ c #000000", "h+ c #B1B2B1", "i+ c #ACADAC", "j+ c #797A7B", "k+ c #828182", "l+ c #959491", "m+ c #8F8D8D", "n+ c #797977", "o+ c #676766", "p+ c #BBBBBB", "q+ c #ACADAE", "r+ c #9B9D9D", "s+ c #8A8B8B", "t+ c #828383", "u+ c #909290", "v+ c #949292", "w+ c #80817E", "x+ c #DADADA", "y+ c #989A9A", "z+ c #949394", "A+ c #919390", "B+ c #8F8F8F", "C+ c #888886", "D+ c #767675", "E+ c #EDEDED", "F+ c #ECECEC", "G+ c #BBB9B9", "H+ c #A0A09D", "I+ c #8B8D8B", "J+ c #878886", "K+ c #828180", "L+ c #737371", "M+ c #676764", "N+ c #696969", "O+ c #9D9D9C", "P+ c #ECECED", "Q+ c #616161", "R+ c #818181", "S+ c #878787", "T+ c #8B8B8B", "U+ c #8E8E8E", "V+ c #AAAAAA", "W+ c #CBCBCB", "X+ c #CACACA", "Y+ c #D1D1D2", "Z+ c #D8D8D8", "`+ c #D7D7D7", " @ c #E1E1E1", ".@ c #676767", "+@ c #7F7F7F", "@@ c #888888", "#@ c #8C8C8C", "$@ c #A7A7A7", "%@ c #A5A5A5", "&@ c #A9A9A9", "*@ c #ADADAD", "=@ c #B2B2B2", "-@ c #B0B0B0", ";@ c #B5B5B5", ">@ c #B3B3B3", ",@ c #BEBEBE", "'@ c #C7C7C7", ")@ c #CFCFCF", "!@ c #D9D9D9", "~@ c #A8A8A8", "{@ c #B1B1B1", "]@ c #C0C0C0", "^@ c #C9C9C9", "/@ c #CDCDCD", "(@ c #DBDBDB", "_@ c #D6D6D6", ":@ c #F6F6F6", "<@ c #636363", "[@ c #929292", "}@ c #ACACAC", "|@ c #BFBFBF", "1@ c #C4C4C4", "2@ c #C8C8C8", "3@ c #CCCCCC", "4@ c #CECECE", "5@ c #5E5E5E", "6@ c #787878", "7@ c #BDBDBD", "8@ c #EAEAEA", "9@ c #EBEBEB", "0@ c #5F5F5F", "a@ c #3B3B3B", "b@ c #202020", "c@ c #767676", "d@ c #C6C6C6", "e@ c #161616", "f@ c #010101", "g@ c #4F4F4F", "h@ c #949494", "i@ c #FAFAFA", "j@ c #4B4B4B", "k@ c #D4D4D4", "l@ c #4C4C4C", "m@ c #666666", "n@ c #757575", "o@ c #7A7A7A", "p@ c #808080", "q@ c #969696", "r@ c #AEAEAE", "s@ c #464646", "t@ c #646464", "u@ c #686868", "v@ c #707070", "w@ c #797979", "x@ c #898989", "y@ c #FBFBFB", "z@ c #838383", "A@ c #FEFEFE", "B@ c #474747", "C@ c #515151", "D@ c #353535", "E@ c #484848", "F@ c #7E7E7E", "G@ c #868686", "H@ c #B6B6B6", "I@ c #FDFDFD", "J@ c #252525", "K@ c #0F0F0F", "L@ c #424242", "M@ c #5B5B5B", "N@ c #656565", "O@ c #ABABAB", "P@ c #242424", "Q@ c #FCFCFC", "R@ c #454545", "S@ c #545454", "T@ c #595959", "U@ c #575757", "V@ c #5C5C5C", "W@ c #6A6A6A", "X@ c #6E6E6E", "Y@ c #6C6C6C", "Z@ c #6F6F6F", "`@ c #828282", " # c #0A0A0A", ".# c #090909", "+# c #101010", "@# c #141414", "## c #222222", "$# c #272727", "%# c #2F2F2F", "&# c #393939", "*# c #414141", "=# c #3F3F3F", "-# c #4D4D4D", ";# c #585858", "># c #5D5D5D", ",# c #C3C3C3", "'# c #D2D2D2", ")# c #040404", "!# c #2D2D2D", "~# c #333333", "{# c #313131", "]# c #363636", "^# c #434343", "/# c #494949", "(# c #555555", "_# c #535353", ":# c #D3D3D3", "<# c #D0D0D0", "[# c #404040", "}# c #2B2B2B", "|# c #505050", "1# c #626262", "2# c #181818", "3# c #232323", "4# c #282828", "5# c #2C2C2C", "6# c #4A4A4A", "7# c #131313", "8# c #191919", "9# c #373737", "0# c #343434", "a# c #0E0E0E", "b# c #171717", "c# c #2E2E2E", "d# c #323232", "e# c #444444", "f# c #262626", "g# c #6D6D6D", "h# c #080808", "i# c #292929", "j# c #050505", "k# c #0D0D0D", "l# c #565656", "m# c #030303", "n# c #151515", "o# c #121212", "p# c #383838", "q# c #0B0B0B", "r# c #1A1A1A", "s# c #303030", "t# c #212121", "u# c #1B1B1B", "v# c #3A3A3A", "w# c #BABABA", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ", ". + @ # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # $ % & * = - - ; > , ' . ) # # # @ + . ", ". @ ! ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ { ] ^ / ( _ : < [ } | 1 2 ~ ~ ~ ! @ . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 5 6 - 7 8 9 0 a b c d e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 f f g h i j k l m n o p q 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 r s t = u v w x y z A B C 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 D E ' F G : H I J d K L M 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 N O P Q R S T U V W X Y Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 N ` ...$ +.@.#.9 A $.%.&.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 N *.=.-.;.>.,.'.).!.~.{.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 D ].p * ^./.d (._.:.<.[.M 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 r }.|.- & 8 9 1.2.3.4.5.C 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 f f E 6.i 7.< 8.3.9.0.a.~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 b.=.. c.d.e.f.g.h.i.j.k.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 l.m.' n.o.j.p.q.r.s.t.u.v.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 w.x.y.F % z.A.B.C.D.E.F.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 w.G.H.I.J.U U K.L.M.N.O.&.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 N P.=.Q.R.S.: T.U.V.3.W.X.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 D Y.Z.* `.# d '. +.+++@+{ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 f 3 #+$+5.%+d &+*+<.=+-+~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 f f ;+>+,+'+)+!+c ~+{+]+~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 ^+/+(+_+:+<+b T [+}+|+e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 l.*.> > + {+1+c 2+'+3+4+5+3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 w.6+7+7+7+7+7+6+w.3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 w.8+9+0+a+b+T c+T.d+e+O.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 e f+g+g+g+g+g+f+e 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 w.h+i+. ;.j+k+9 l+m+n+o+Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 6+q.g+g+g+g+g+q.6+3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 l.p+q+r+s+t+u+^.v+w+<.++v.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 6+q.g+g+g+g+g+q.6+3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 x+Z.y+V z+A+B+C+D+c j.e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 6+q.g+g+g+g+g+q.6+3 3 3 3 3 N ~ v.M M { { e e C ~ ~ E+F+E+w.G+H+/.I+J+K+L+M+N+O+P+f 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 6+q.g+g+g+g+g+q.6+3 3 3 3 3 ~ Q+~+>.p.R+S+z.T+^.U+) (+..- V+*.G.] W+X+Y.Y+Z+x+Z+b.`+b. @C # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 6+q.g+g+g+g+g+q.6+3 3 3 3 3 Z .@+@@@U+#@V $ # % & $@%@&@*@=@-@;@>@,@O E ].X+'@W+)@!@5 3 C # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 6+q.g+g+g+g+g+q.6+3 3 3 3 3 Z N+R++@@@U+#@^.$ 5.@ & 5.%@~@*@=@{@=.*.,@O ]@].^@/@Y.(@!@_@e # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 6+q.g+g+g+g+g+q.6+3 3 3 3 3 :@<@>.R++@@@R.[@^.$ ) % & $@> ~@*@}@{@=.*.,@;+|@1@2@3@X+4@Z+e # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 6+q.g+g+g+g+g+q.6+3 3 3 3 3 :@5@6@>.R++@@@R.V ^.$ ) @ & ' V+&@~@*@{@=.>@7@E ].X+2@/@Y.!@{ # . ", ". # ~ 3 3 3 3 3 3 8@! 7+7+7+h.g+g+g+g+g+h.7+7+7+6+9@3 ! 0@T 6@>.R++@@@R.V ^.$ ) @ + ' %@..~@}@-@*.,@;+|@1@^@4@W+/@{ # . ", ". # ~ 3 3 3 3 3 3 8@a@g+g+g+g+g+g+g+g+g+g+g+g+g+b@F+3 6+f+c@T 6@>.R++@@@R.V ^.$ ) @ & 5.%@&@*@{@;@>@7@E d@1@^@/@2@M # . ", ". # ~ 3 3 3 3 3 3 8@2 e@g+g+g+g+g+g+g+g+g+g+g+f@{ F+3 2 g@c c@T 6@>.R++@@@R.V B+h@) @ & ' V+~@}@{@;@>@7@E ].1@^@^@v.# . ", ". # ~ 3 3 3 3 3 3 3 C E+g+g+g+g+g+g+g+g+g+g+g+}.{ 3 3 i@j@.@q.c@4.6@>.R++@S+#@^.$ 5.) o.+ %@V+~@}@{@;@>@7@E ].1@1@v.# . ", ". # ~ 3 3 3 3 3 3 3 f M k@g+g+g+g+g+g+g+g+g+|@Z r 3 3 i@l@N+m@q.n@o@~+p.p@@@R.V q@$ h@) o.+ %@V+~@}@{@;@>@7@E ].|@X.# . ", ". # ~ 3 3 3 3 3 3 3 3 r :@r@g+g+g+g+g+g+g+# 2 4 3 3 3 i@s@t@u@4.v@T w@>.R+x@S+#@V ^.B+h@) o.+ %@V+~@}@{@;@>@7@E ]@X.# . ", ". # ~ 3 3 3 3 3 3 3 3 3 D y@z@g+g+g+g+g+t@A@l.3 3 3 3 y@B@m@t@u@c c@o@~+p.p@x@S+R.#@V q@# % o.+ %@V+$@}@-@;@>@7@p+Z # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 N 7+C@g+g+g+D@7+8@3 3 3 3 3 y@E@Q+0@<@.@q.n@w@F@p.p@x@@@G@#@V $ 5.% o.5.%@&@*@=@-@;@=@H@Z # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 9@I@J@g+K@! F+3 3 3 3 3 3 y@L@M@Q+N@N+4.v@T w@F@p.R++@x@G@#@^.$ # % & $@> ~@*@O@{@;@#+:@# . ", ". # ~ 3 3 3 ~ 2 7+7+7+7+7+7+7+7+7+P@I@7+Q@y@i@2 6+! ! 7+R@S@T@U@V@0@W@X@Y@q.Z@T 6@c@+@z.`@S+w B+R.V + ) o.- * > > v.# . ", ". # ~ 3 3 3 i@g+ #.#+#e@@###$#%#&#*#B@L@=#-#j@C@;#5@>#Y@z@x@B+$ # ) * o...= =.}@=@#+7@,#]@/@'#Z+_@b.3 N D v.6+A@y@e # . ", ". # ~ 3 3 3 7+)#$#!#~#{#]#^#B@R@j@/#g@(#_#T@N@W@u@X@4.q.~+n@`@S+#@T+V ^.q@h@5.' O@~@r@>@#+d@,#2@/@:#'#<#^+x+l.r F+F+# . ", ". # ~ 3 3 3 7+g+##$#!#~#{#]#L@[#s@j@C@g@(#_#;#t@W@u@X@4.c 6@n@`@S+R.#@w V q@h@) %@V+-@;@p+{@H@,#2@d@3@'#Z+^+x+l.~ E+# . ", ". # ~ 3 3 3 7+g+P@##$#!#}#{#]#L@[#R@j@/#|#(#f+;#N@1#u@X@4.c ~+h.R+S+G@#@T+V q@+ % %@V+$@r@*.8+H@,#2@4@W+Y.`+b.x+N ~ # . ", ". # ~ 3 3 3 7+g+2#J@3#4#!#5#{#]#^#*#s@j@6#g@(#f+;#N@W@u@X@4.q.~+h.z@R+S+#@w ^.$ 5.$@> V+=.*@>@#+].;+'@/@:#Y.`+b.x+C # . ", ". # ~ 3 3 3 7+g+7#8#e@3#4#!#5#{#9#0#*#s@l@6#|#(#_#;#N@W@u@X@4.q.6@c@T R+G@#@V @ h@) ' O@&@=.;@=@#+1@^@'@/@'#Y.`+b.e # . ", ". # ~ 3 3 3 7+g+a#@#8#b#3#4#c#5#d#9#D@*#s@e#6#|#(#_#;#N@<@u@X@T 4.q.c@z@S+R.T+V q@+ ) %@O@&@=.*.=@G.,#^@'@/@'#Y.^+{ # . ", ". # ~ 3 3 3 7+g++#a#@#8#b#3#4#f#5#d#9#D@*#B@R@6#|#(#_#T@N@<@u@X@g#4.6@h.R+S+#@T+^.q@+ ) %@O@&@=.*.8+G.,#^@'@/@'#4@{ # . ", ". # ~ 3 3 3 7+g+ #h#a#@#8#b#3#i#f#5#d#9#D@*#B@e#6#|#(#_#;#t@N+u@X@g#c ~+h.`@S+#@T+^.q@+ ) %@O@&@r@*.8+G.1@^@'@/@<#M # . ", ". # ~ 3 3 3 7+g+j# #+#a#@#8#e@3#4#c#5#d#9#0#*#s@l@/#g@(#f+m@t@N+u@X@g#c 6@n@`@S+#@T+^.q@+ ) ' O@&@r@*.=@G.1@^@'@^@M # . ", ". # ~ 3 3 3 7+g+g+)# #K@k#7#2#J@##4#!#}#{#]#^#[#R@j@|#l#S@C@m@t@<@N+X@g#4.6@n@`@S+R.T+V q@h@) ' O@&@=.*.=@G.1@^@;+v.# . ", ". # ~ 3 3 3 7+g+g+j#m#.#K@n#o#b#P@##$#!#~#p#]#L@B@e#6#|#g@S@f+;#N@<@u@X@g#4.6@h.R+S+z.T+V q@h@) ' O@&@=.*.=@G.1@1@X.# . ", ". # ~ 3 3 3 7+g+g+g+j#q#h#a#@#r#2#P@i#%#J@}#s#D@*#B@l@^#|#l#(#_#T@N@W@u@X@g#c ~+z@R+S+R.T+V q@h@) ' > &@=.;@>@#+,@Z # . ", ". # ~ 3 3 3 7+g+g+g+g+j# #+#K@k#o#b#P@t#$#!#d#9#D@*#=#l@6#|#g@(#_#;#N@W@u@X@g#c ~+z@R+S+#@T+V q@& ) ' > &@=.*@=@{@:@# . ", ". @ ! ~ ~ ~ 7+g+g+g+g+g+g+g+g+g+g+g+g+ #+#K@n#u###b@c#0#d#v#p#=#s@e#6#;#l#>#t@1#u@X@p.o@R+@@G@R.# [@% %@}@V+{@G.8+Q@@ . ", ". + @ # # # = -@|@|@|@,@,@7@7@O p+w#w##+G.G.H@;@*.>@=@{@{@-@-@=.r@r@*@}@O@V+V+&@~@$@' %@> > ..- - = . * (+o.o.& % 5.+ . ", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . "}; elseif pic == '3' then Image = { "60 60 437 2", " c None", ". c #A0A0A0", "+ c #9B9B9B", "@ c #979797", "# c #939393", "$ c #959595", "% c #989898", "& c #9C9C9C", "* c #9F9F9F", "= c #A1A1A1", "- c #A2A2A2", "; c #A2A2A3", "> c #A4A4A4", ", c #A5A5A6", "' c #A6A6A6", ") c #999999", "! c #F7F7F7", "~ c #EEEEEE", "{ c #F1F1F1", "] c #C4C4C5", "^ c #B2B2B0", "/ c #9F9FA0", "( c #8C8D8D", "_ c #8E8D8E", ": c #90908F", "< c #91908F", "[ c #8E8E8B", "} c #797877", "| c #6D6C6B", "1 c #70706F", "2 c #F9F9F9", "3 c #E2E2E2", "4 c #E5E5E5", "5 c #DDDDDD", "6 c #B3B3B2", "7 c #9A9C9A", "8 c #999997", "9 c #959594", "0 c #91928F", "a c #868584", "b c #757573", "c c #727272", "d c #949493", "e c #F0F0F0", "f c #E3E3E3", "g c #BFBFBE", "h c #A5A7A6", "i c #9C9C9B", "j c #989A99", "k c #929190", "l c #878786", "m c #787677", "n c #747473", "o c #80807F", "p c #AEAEAD", "q c #EDEDEE", "r c #E4E4E4", "s c #DFDFDF", "t c #B3B4B3", "u c #A09FA0", "v c #979795", "w c #8A8A8A", "x c #7A7A79", "y c #727270", "z c #808180", "A c #989896", "B c #9C9B9A", "C c #EFEFEF", "D c #E6E6E6", "E c #C1C1C1", "F c #A4A6A4", "G c #9C9E9C", "H c #7F7E7F", "I c #717170", "J c #7D7F7F", "K c #9B9996", "L c #747372", "M c #F2F2F2", "N c #E8E8E8", "O c #BCBCBC", "P c #A8A8A9", "Q c #A6A5A6", "R c #999B9A", "S c #888786", "T c #747474", "U c #7C7D7D", "V c #919191", "W c #9D9C99", "X c #8C8B89", "Y c #656563", "Z c #F5F5F5", "` c #E9E9E9", " . c #F8F8F8", ".. c #FFFFFF", "+. c #C3C3C1", "@. c #ACAEAC", "#. c #A3A3A3", "$. c #7D7F7D", "%. c #787979", "&. c #919192", "*. c #7E7E7C", "=. c #636362", "-. c #F5F5F6", ";. c #5A5A5A", ">. c #000000", ",. c #B4B4B4", "'. c #AFAFAF", "). c #A0A2A0", "!. c #8F9090", "~. c #7D7D7D", "{. c #8C8D8C", "]. c #939391", "^. c #969794", "/. c #898887", "(. c #787776", "_. c #686866", ":. c #717171", "<. c #C5C5C5", "[. c #909090", "}. c #929392", "|. c #949392", "1. c #91918E", "2. c #7C7D7A", "3. c #737372", "4. c #787877", "5. c #DEDEDE", "6. c #B4B4B3", "7. c #90908E", "8. c #838281", "9. c #757574", "0. c #737373", "a. c #9A9A9A", "b. c #A4A5A6", "c. c #999899", "d. c #868683", "e. c #747475", "f. c #848483", "g. c #B1B1B2", "h. c #DCDCDC", "i. c #9EA09E", "j. c #949694", "k. c #878788", "l. c #777776", "m. c #717172", "n. c #848484", "o. c #9A9996", "p. c #8F8F8E", "q. c #EFEFF0", "r. c #E7E7E7", "s. c #BAB9B9", "t. c #A5A6A5", "u. c #9D9D9D", "v. c #7C7C7C", "w. c #818182", "x. c #979796", "y. c #999795", "z. c #6F6E6D", "A. c #F3F3F3", "B. c #B8BAB8", "C. c #AAABAB", "D. c #858585", "E. c #737473", "F. c #828183", "G. c #929291", "H. c #9C9C98", "I. c #878785", "J. c #646362", "K. c #B7B7B7", "L. c #ADAEAF", "M. c #A2A3A2", "N. c #929492", "O. c #949594", "P. c #969594", "Q. c #959492", "R. c #7B7C7B", "S. c #656564", "T. c #B4B4B2", "U. c #A1A0A0", "V. c #8D8D8D", "W. c #7F7E7E", "X. c #939392", "Y. c #959693", "Z. c #858683", "`. c #6B6B6A", " + c #F4F4F4", ".+ c #EAEAEA", "++ c #D1D1D1", "@+ c #AEADAE", "#+ c #909191", "$+ c #8E8C8B", "%+ c #7A7978", "&+ c #727271", "*+ c #838282", "=+ c #3B3B3B", "-+ c #202020", ";+ c #B8B8B8", ">+ c #A2A3A3", ",+ c #989796", "'+ c #8E8D8C", ")+ c #80807D", "!+ c #767775", "~+ c #A3A3A2", "{+ c #161616", "]+ c #010101", "^+ c #C2C2C2", "/+ c #A1A3A1", "(+ c #9B9B9C", "_+ c #989897", ":+ c #8E8E8D", "<+ c #818180", "[+ c #777777", "}+ c #8B8B8A", "|+ c #AFAFAE", "1+ c #EDEDED", "2+ c #D5D5D5", "3+ c #AAAAAC", "4+ c #9E9E9E", "5+ c #9E9F9E", "6+ c #949492", "7+ c #858584", "8+ c #888988", "9+ c #9A9A96", "0+ c #868685", "a+ c #D4D4D4", "b+ c #BFBFBF", "c+ c #797978", "d+ c #878889", "e+ c #92908E", "f+ c #6C6C6B", "g+ c #F3F3F4", "h+ c #F6F6F6", "i+ c #AEAEAE", "j+ c #B9B9B9", "k+ c #A9ABAB", "l+ c #A2A4A2", "m+ c #979695", "n+ c #818281", "o+ c #898A8A", "p+ c #9B9A97", "q+ c #82827F", "r+ c #FBFBFB", "s+ c #838383", "t+ c #646464", "u+ c #FEFEFE", "v+ c #B1B2B1", "w+ c #ACADAC", "x+ c #797A7B", "y+ c #828182", "z+ c #959491", "A+ c #8F8D8D", "B+ c #797977", "C+ c #676766", "D+ c #515151", "E+ c #353535", "F+ c #BBBBBB", "G+ c #ACADAE", "H+ c #9B9D9D", "I+ c #8A8B8B", "J+ c #828383", "K+ c #909290", "L+ c #949292", "M+ c #80817E", "N+ c #EBEBEB", "O+ c #FDFDFD", "P+ c #252525", "Q+ c #0F0F0F", "R+ c #ECECEC", "S+ c #DADADA", "T+ c #989A9A", "U+ c #949394", "V+ c #919390", "W+ c #8F8F8F", "X+ c #888886", "Y+ c #767675", "Z+ c #FAFAFA", "`+ c #C0BEBF", " @ c #A4A4A1", ".@ c #969796", "+@ c #8E908F", "@@ c #8A8B89", "#@ c #858382", "$@ c #767673", "%@ c #696966", "&@ c #6A6A6B", "*@ c #9E9E9C", "=@ c #ECECED", "-@ c #E1E1E1", ";@ c #090909", ">@ c #323232", ",@ c #3A3A3A", "'@ c #4E4E4E", ")@ c #595959", "!@ c #565656", "~@ c #555555", "{@ c #5C5C5C", "]@ c #6D6D6D", "^@ c #7E7E7E", "/@ c #888888", "(@ c #C1C2C2", "_@ c #CCCCCC", ":@ c #D2D2D2", "<@ c #E0E0E0", "[@ c #D9D9D9", "}@ c #141414", "|@ c #3C3C3C", "1@ c #575757", "2@ c #535353", "3@ c #616161", "4@ c #696969", "5@ c #707070", "6@ c #7F7F7F", "7@ c #868686", "8@ c #ACACAC", "9@ c #A8A8A8", "0@ c #B1B1B1", "a@ c #C0C0C0", "b@ c #BDBDBD", "c@ c #C4C4C4", "d@ c #CACACA", "e@ c #DBDBDB", "f@ c #404040", "g@ c #5B5B5B", "h@ c #636363", "i@ c #6B6B6B", "j@ c #686868", "k@ c #6C6C6C", "l@ c #949494", "m@ c #B0B0B0", "n@ c #C7C7C7", "o@ c #CDCDCD", "p@ c #0D0D0D", "q@ c #383838", "r@ c #3F3F3F", "s@ c #5D5D5D", "t@ c #828282", "u@ c #8C8C8C", "v@ c #929292", "w@ c #B3B3B3", "x@ c #B6B6B6", "y@ c #BEBEBE", "z@ c #C9C9C9", "A@ c #040404", "B@ c #303030", "C@ c #4D4D4D", "D@ c #6F6F6F", "E@ c #818181", "F@ c #AAAAAA", "G@ c #C6C6C6", "H@ c #060606", "I@ c #282828", "J@ c #2B2B2B", "K@ c #ABABAB", "L@ c #B2B2B2", "M@ c #242424", "N@ c #626262", "O@ c #6A6A6A", "P@ c #121212", "Q@ c #4C4C4C", "R@ c #545454", "S@ c #6E6E6E", "T@ c #808080", "U@ c #878787", "V@ c #111111", "W@ c #232323", "X@ c #2A2A2A", "Y@ c #2F2F2F", "Z@ c #373737", "`@ c #3D3D3D", " # c #656565", ".# c #262626", "+# c #212121", "@# c #292929", "## c #313131", "$# c #505050", "%# c #4B4B4B", "&# c #0C0C0C", "*# c #363636", "=# c #4F4F4F", "-# c #8B8B8B", ";# c #A9A9A9", "># c #070707", ",# c #393939", "'# c #8E8E8E", ")# c #969696", "!# c #0E0E0E", "~# c #151515", "{# c #606060", "]# c #FCFCFC", "^# c #1B1B1B", "/# c #181818", "(# c #424242", "_# c #474747", ":# c #7B7B7B", "<# c #787878", "[# c #0A0A0A", "}# c #101010", "|# c #222222", "1# c #272727", "2# c #414141", "3# c #585858", "4# c #5E5E5E", "5# c #BABABA", "6# c #CECECE", "7# c #CBCBCB", "8# c #D8D8D8", "9# c #2D2D2D", "0# c #333333", "a# c #434343", "b# c #454545", "c# c #494949", "d# c #757575", "e# c #C3C3C3", "f# c #C8C8C8", "g# c #D3D3D3", "h# c #D0D0D0", "i# c #464646", "j# c #A5A5A5", "k# c #B5B5B5", "l# c #A7A7A7", "m# c #D7D7D7", "n# c #2C2C2C", "o# c #4A4A4A", "p# c #ADADAD", "q# c #131313", "r# c #191919", "s# c #343434", "t# c #767676", "u# c #171717", "v# c #2E2E2E", "w# c #444444", "x# c #080808", "y# c #050505", "z# c #666666", "A# c #030303", "B# c #0B0B0B", "C# c #1A1A1A", "D# c #7A7A7A", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ", ". + @ # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # # $ % & * = - - ; > , ' . ) # # # @ + . ", ". @ ! ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ { ] ^ / ( _ : < [ } | 1 2 ~ ~ ~ ! @ . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 5 6 - 7 8 9 0 a b c d e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 f f g h i j k l m n o p q 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 r s t = u v w x y z A B C 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 D E ' F G : H I J d K L M 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 N O P Q R S T U V W X Y Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 ` ........... .` 3 3 3 N +.@.#.$ $.%.&.9 A *.=.-.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 e ;.>.>.>.>.>.;.e 3 3 3 N ,.'.).!.~.{.].^./.(._.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 D <.p * [.}.d |.1.2.3.4.M 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 r 5.6.- & 8 9 7.8.9.0.a.C 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 f f E b.i c.< d.9.e.f.g.~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 4 h.'.. i.j.k.l.m.n.o.p.q.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 r.s.' t.u.p.v.:.w.x.y.z.A.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 ` B.C.F % D.E.F.G.H.I.J.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 ` K.L.M.N.U U O.P.Q.R.S.-.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 N T.'.U.V.W.: X.Y.Z.9.`. +3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .+! ......n.>.>.>.>.>.n....... .C ++@+* #+# d ].$+%+&+*+{ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .+=+>.>.>.>.>.>.>.>.>.>.>.>.>.-+~ 3 ;+>+a.,+d '+)+3.!+~+~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 .+2 {+>.>.>.>.>.>.>.>.>.>.>.]+{ ~ f ^+/+(+_+:+<+c [+}+|+~ 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 C 1+>.>.>.>.>.>.>.>.>.>.>.5.{ D 2+3+4+5+6+7+b T 8+9+0+e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 f M a+>.>.>.>.>.>.>.>.>.b+Z r r.,.> > + }+c+c d+_+e+f+g+3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 ` ........... .` 3 3 3 3 3 r h+i+>.>.>.>.>.>.>.# 2 4 3 ` j+k+l+m+n+T o+X.p+q+S.Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 e ;.>.>.>.>.>.;.e 3 3 3 3 3 3 D r+s+>.>.>.>.>.t+u+r.3 3 ` v+w+. !.x+y+9 z+A+B+C+Z 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 3 3 3 3 N ..D+>.>.>.E+...+3 3 3 r.F+G+H+I+J+K+[.L+M+3.&+A.3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 3 3 3 3 3 N+O+P+>.Q+! R+3 3 3 3 4 S+@+T+V U+V+W+X+Y+c p.e 3 3 3 ~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 3 3 R+h+..u+....-+Z+..2 ! Z A.A.A.~ `+ @.@+@@@#@$@%@&@*@=@3 3 -@~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 3 3 ! ;@>@=+,@'@)@!@~@{@)@]@T ^@v./@$ % '.j+K.^+(@_@:@a+<@[@3 R+1+# . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 3 3 ..}@|@'@1@2@{@t+3@4@5@s+6@7@V.$ # + % 8@9@0@;+a@b@c@d@e@f 1+~ # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 3 3 ..{+f@|@'@1@2@g@h@i@j@5@k@6@D.V.$ l@V ) 8@9@m@;+b+n@o@<@e@[@C # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 3 3 ..p@q@r@|@'@!@s@;.h@i@4@5@t@~.D.V.u@$ v@) 8@w@'.x@y@<.^+z@e@e # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 .:.>.>.>.>.>.:. .3 3 3 3 3 ..A@B@q@r@|@C@!@s@;.h@i@j@D@E@/@7@n.V.$ V @ F@0@;+a@b@G@o@5 { # . ", ". # ~ 3 3 3 3 3 3 .+! ......n.>.>.>.>.>.n....... .N+3 ..H@I@B@q@r@|@C@!@s@;.h@i@j@D@t@6@~.n.u@# a.8@w@'.K.b+n@c@z@M # . ", ". # ~ 3 3 3 3 3 3 .+=+>.>.>.>.>.>.>.>.>.>.>.>.>.-+R+3 ..>.J@I@B@q@r@|@C@!@s@;.h@i@j@5@k@6@7@V.$ & % K@L@j+x@b+n@a@A.# . ", ". # ~ 3 3 3 3 3 3 .+2 {+>.>.>.>.>.>.>.>.>.>.>.]+{ R+3 ..>.M@J@I@B@q@r@|@C@!@s@;.N@O@j@5@E@/@n.u@l@+ % K@0@j+x@b+^+ +# . ", ". # ~ 3 3 3 3 3 3 3 C 1+>.>.>.>.>.>.>.>.>.>.>.5.{ 3 3 ..>.P@M@J@I@B@q@r@=+Q@R@g@h@k@O@c S@T@U@n.u@l@+ % K@0@j+x@j+Z # . ", ". # ~ 3 3 3 3 3 3 3 f M a+>.>.>.>.>.>.>.>.>.b+Z r 3 3 ..>.{+V@W@X@>@Y@Z@`@'@!@s@ #h@3@O@:.S@T@U@n.u@l@+ % K@0@j+'.h+# . ", ". # ~ 3 3 3 3 3 3 3 3 r h+i+>.>.>.>.>.>.>.# 2 4 3 3 3 ..>.p@}@.#+#@###q@r@$#%#R@s@g@)@N@O@:.S@T@U@n.u@l@+ % K@0@0@! # . ", ". # ~ 3 3 3 3 3 3 3 3 3 D r+s+>.>.>.>.>.t+u+r.3 3 3 3 ..>.Q+&#}@P+J@>@Y@*#`@=#%#!@R@{@t+3@4@:.S@T@U@n.-## + % K@;# .# . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 N ..D+>.>.>.E+...+3 3 3 3 3 ..>.>#A@&#V@W@X@##,#*#`@$#C@%#R@{@h@k@4@:.]@6@7@'#)## + @ . 2 # . ", ". # ~ 3 3 3 3 3 3 3 3 3 3 3 N+O+P+>.Q+! R+3 3 3 3 3 3 ..>.>.>#!#~#.#+#@###,#*#r@=+=#%#R@g@h@{#4@5@t@^@D.V.-#l@a.#.Z+# . ", ". # ~ 3 3 3 ~ 2 ..................M@O+..]#r+Z+2 .! ! ..>.>.>.>.>.>.&#~#P@^#/#+#@#.#q@(#r@_#'@1@R@g@S@i@0.:#<#T@E@h+# . ", ". # ~ 3 3 3 Z+>.[#;@}#{+}@|#1#Y@,#2#_#(#r@C@%#D+3#4#s@c W++ = ' > ;#i+K@L@m@b@5#b+c@z@6#7#8#h.3 s r .+C 1+2 u+....{ # . ", ". # ~ 3 3 3 ..A@1#9#0###*#a#_#b#%#c#=#~@2@)@ #O@j@S@0.:.[+d#t@U@u@-#V [.)#l@a.' K@9@i+w@;+G@e#f#o@g#:@h#2+S+r.r R+R+# . ", ". # ~ 3 3 3 ..>.|#1#9#0###*#(#f@i#%#D+=#~@2@3#t+O@j@S@0.c <#d#t@U@V.u@w V )#l@) j#F@m@k#F+0@x@e#f#G@_@:@8#2+S+r.~ 1+# . ", ". # ~ 3 3 3 ..>.M@|#1#9#J@##*#(#f@b#%#c#$#~@;.3# #N@j@S@0.c [+n.E@U@7@u@-#V )#+ % j#F@l#i+,.j+x@e#f#6#7#++m#h.S+N ~ # . ", ". # ~ 3 3 3 ..>./#P+W@I@9#n###*#a#2#i#%#o#=#~@;.3# #O@j@S@0.:.[+n.s+E@U@u@w [.$ a.l#> F@'.p#w@;+<.^+n@o@g#++m#h.S+C # . ", ". # ~ 3 3 3 ..>.q#r#{+W@I@9#n###Z@s#2#i#Q@o#$#~@2@3# #O@j@S@0.:.<#t#T E@7@u@V @ l@) ' K@;#'.k#L@;+c@z@n@o@:@++m#h.e # . ", ". # ~ 3 3 3 ..>.!#}@r#u#W@I@v#n#>@Z@E+2#i#w#o#$#~@2@3# #h@j@S@T 0.:.t#s+U@V.-#V )#+ ) j#K@;#'.,.L@K.e#z@n@o@:@++2+{ # . ", ". # ~ 3 3 3 ..>.}#!#}@r#u#W@I@.#n#>@Z@E+2#_#b#o#$#~@2@)@ #h@j@S@]@0.<#n.E@U@u@-#[.)#+ ) j#K@;#'.,.j+K.e#z@n@o@:@6#{ # . ", ". # ~ 3 3 3 ..>.[#x#!#}@r#u#W@@#.#n#>@Z@E+2#_#w#o#$#~@2@3#t+4@j@S@]@c [+n.t@U@u@-#[.)#+ ) j#K@;#i+,.j+K.c@z@n@o@h#M # . ", ". # ~ 3 3 3 ..>.y#[#}#!#}@r#{+W@I@v#n#>@Z@s#2#i#Q@c#=#~@;.z#t+4@j@S@]@c <#d#t@U@u@-#[.)#+ ) ' K@;#i+,.L@K.c@z@n@z@M # . ", ". # ~ 3 3 3 ..>.>.A@[#Q+p@q#/#P+|#I@9#J@##*#a#f@b#%#$#!@R@D+z#t+h@4@S@]@0.<#d#t@U@V.-#V )#l@) ' K@;#'.,.L@K.c@z@^+A.# . ", ". # ~ 3 3 3 ..>.>.y#A#;@Q+~#P@u#M@|#1#9#0#q@*#(#_#w#o#$#=#R@;.3# #h@j@S@]@0.<#n.E@U@D.-#V )#l@) ' K@;#'.,.L@K.c@c@ +# . ", ". # ~ 3 3 3 ..>.>.>.y#B#x#!#}@C#/#M@@#Y@P+J@B@E+2#_#Q@a#$#!@~@2@)@ #O@j@S@]@c [+s+E@U@V.-#V )#l@) ' > ;#'.k#w@;+y@Z # . ", ". # ~ 3 3 3 ..>.>.>.>.y#[#}#Q+p@P@u#M@+#1#9#>@Z@E+2#r@Q@o#$#=#~@2@3# #O@j@S@]@c [+s+E@U@u@-#V )#& ) ' > ;#'.p#L@0@h+# . ", ". @ ! ~ ~ ~ ..>.>.>.>.>.>.>.>.>.>.>.>.[#}#Q+~#^#|#-+v#s#>@,@q@r@i#w#o#3#!@s@t+N@j@S@v.D#E@/@7@V.# v@% j#8@F@0@K.j+]#@ . ", ". + @ # # # = m@b+b+b+y@y@b@b@O F+5#5#;+K.K.x@k#,.w@L@0@0@m@m@'.i+i+p#8@K@F@F@;#9@l#' j#> > #.- - = . * 4+u.u.& % a.+ . ", ". . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . "}; end return Image end function ImageCompass(pic) if (pic == nil) then pic = '0' end if pic == '0' then Image = { "60 60 2 1", " c None", ". c #000000", " ", " ", " ", " ", " . . ", " . . . ", " . . . ", " . .... ", " . . ", " . ", " . ", " ", " ", " ", " .. ", " .. ", " .... ", " .... ", " ...... ", " ...... ", " ........ ", " ........ ", " .......... ", " . ", " . ", " . . . ", " ... . ... ", " . . ..... . ..... . . ", " . . ....... . ....... . . . ", " .. ......... .. ......... ... . ", " . ................................. . .... ", " . . ... ....... . ....... . . . ", " . .. ..... . ..... . .. ", " . . ... . ... . . ", " . . . ", " . ", " . ", " . ", " .......... ", " ........ ", " ........ ", " ...... ", " ...... ", " .... ", " .... ", " .. ", " .. ", " ", " ", " . . ", " . . ", " . . ", " .. ", " . ... ", " . ", " . ", " ", " ", " ", " "}; elseif pic == '1' then Image = { --XPM Image Here }; end return Image end return mcTouchOff -- Module End
