'chengdu xhc tec. probe z surface macro FeedCurrent = GetOemDRO(818) 	'Get the current settings, OEM DROs (818)=Feedrate DROZCurrent = GetOemDro(802)	'OEM DROs (802)=Z DROGageH = GetOEMDRO(1001)	'OEMDRO(1001)=Gage Block HeightZNew = ZCurrent - 300		'probe down 20 mmCode "G90F200"			'slow feed rate to 100 MM/MINSetOemDRO(818,200) Rem Code "G4 P1"		'Pause 1 second to give time to position probe plateCode "G31 Z" &ZNewWhile IsMoving()Sleep(10)WendCall SetDro (2,50)		'DRO(2)=Z DROFinalMove = 50 + 10Code  "G0 Z" &FinalMoveCode "F" &FeedCurrent  		'restore starting feed rate    SetOemDRO(818,FeedCurrent)  
