<profile>
	<Preferences>
		<PulseSpeed>0</PulseSpeed>
		<Profile>Mach3Mill</Profile>
		<Layout>1024.set</Layout>
		<FirstRun>1</FirstRun>
		<Units>1</Units>
		<Serial>0</Serial>
		<Port2Input>0</Port2Input>
		<GeckoMode>0</GeckoMode>
		<USBINPUTS>16</USBINPUTS>
		<USBOUTPUTS>16</USBOUTPUTS>
		<Port2On>0</Port2On>
		<Port1On>0</Port1On>
		<Port1Add>888</Port1Add>
		<Port2Add>632</Port2Add>
		<MaxCL>0</MaxCL>
		<MaxNC10>0</MaxNC10>
		<Motor0Active>1</Motor0Active>
		<Motor0DirNeg>1</Motor0DirNeg>
		<Motor0DirPort>1</Motor0DirPort>
		<Motor0DirPin>3</Motor0DirPin>
		<Motor0StepNeg>0</Motor0StepNeg>
		<Motor0StepPort>1</Motor0StepPort>
		<Motor0StepPin>2</Motor0StepPin>
		<Motor1Active>1</Motor1Active>
		<Motor1DirNeg>1</Motor1DirNeg>
		<Motor1DirPort>1</Motor1DirPort>
		<Motor1DirPin>5</Motor1DirPin>
		<Motor1StepNeg>0</Motor1StepNeg>
		<Motor1StepPort>1</Motor1StepPort>
		<Motor1StepPin>4</Motor1StepPin>
		<Motor2Active>1</Motor2Active>
		<Motor2DirNeg>1</Motor2DirNeg>
		<Motor2DirPort>1</Motor2DirPort>
		<Motor2DirPin>7</Motor2DirPin>
		<Motor2StepNeg>0</Motor2StepNeg>
		<Motor2StepPort>1</Motor2StepPort>
		<Motor2StepPin>6</Motor2StepPin>
		<Motor3Active>0</Motor3Active>
		<Motor3DirNeg>0</Motor3DirNeg>
		<Motor3DirPort>0</Motor3DirPort>
		<Motor3DirPin>0</Motor3DirPin>
		<Motor3StepNeg>0</Motor3StepNeg>
		<Motor3StepPort>0</Motor3StepPort>
		<Motor3StepPin>0</Motor3StepPin>
		<Motor4Active>0</Motor4Active>
		<Motor4DirNeg>0</Motor4DirNeg>
		<Motor4DirPort>0</Motor4DirPort>
		<Motor4DirPin>0</Motor4DirPin>
		<Motor4StepNeg>0</Motor4StepNeg>
		<Motor4StepPort>0</Motor4StepPort>
		<Motor4StepPin>0</Motor4StepPin>
		<Motor5Active>0</Motor5Active>
		<Motor5DirNeg>0</Motor5DirNeg>
		<Motor5DirPort>0</Motor5DirPort>
		<Motor5DirPin>0</Motor5DirPin>
		<Motor5StepNeg>0</Motor5StepNeg>
		<Motor5StepPort>0</Motor5StepPort>
		<Motor5StepPin>0</Motor5StepPin>
		<Motor6Active>0</Motor6Active>
		<Motor6DirNeg>0</Motor6DirNeg>
		<Motor6DirPort>0</Motor6DirPort>
		<Motor6DirPin>0</Motor6DirPin>
		<Motor6StepNeg>0</Motor6StepNeg>
		<Motor6StepPort>0</Motor6StepPort>
		<Motor6StepPin>0</Motor6StepPin>
		<Input0Active>1</Input0Active>
		<Input0Port>1</Input0Port>
		<Input0Pin>13</Input0Pin>
		<Input0Neg>0</Input0Neg>
		<Input0Emulated>0</Input0Emulated>
		<Input0EmuKey>0</Input0EmuKey>
		<Input1Active>1</Input1Active>
		<Input1Port>1</Input1Port>
		<Input1Pin>10</Input1Pin>
		<Input1Neg>0</Input1Neg>
		<Input1Emulated>0</Input1Emulated>
		<Input1EmuKey>0</Input1EmuKey>
		<Input2Active>1</Input2Active>
		<Input2Port>1</Input2Port>
		<Input2Pin>10</Input2Pin>
		<Input2Neg>0</Input2Neg>
		<Input2Emulated>0</Input2Emulated>
		<Input2EmuKey>0</Input2EmuKey>
		<Input3Active>1</Input3Active>
		<Input3Port>1</Input3Port>
		<Input3Pin>13</Input3Pin>
		<Input3Neg>0</Input3Neg>
		<Input3Emulated>0</Input3Emulated>
		<Input3EmuKey>0</Input3EmuKey>
		<Input4Active>1</Input4Active>
		<Input4Port>1</Input4Port>
		<Input4Pin>11</Input4Pin>
		<Input4Neg>0</Input4Neg>
		<Input4Emulated>0</Input4Emulated>
		<Input4EmuKey>0</Input4EmuKey>
		<Input5Active>1</Input5Active>
		<Input5Port>1</Input5Port>
		<Input5Pin>11</Input5Pin>
		<Input5Neg>0</Input5Neg>
		<Input5Emulated>0</Input5Emulated>
		<Input5EmuKey>0</Input5EmuKey>
		<Input6Active>1</Input6Active>
		<Input6Port>1</Input6Port>
		<Input6Pin>12</Input6Pin>
		<Input6Neg>0</Input6Neg>
		<Input6Emulated>0</Input6Emulated>
		<Input6EmuKey>0</Input6EmuKey>
		<Input7Active>1</Input7Active>
		<Input7Port>1</Input7Port>
		<Input7Pin>13</Input7Pin>
		<Input7Neg>0</Input7Neg>
		<Input7Emulated>0</Input7Emulated>
		<Input7EmuKey>0</Input7EmuKey>
		<Input8Active>1</Input8Active>
		<Input8Port>1</Input8Port>
		<Input8Pin>12</Input8Pin>
		<Input8Neg>0</Input8Neg>
		<Input8Emulated>0</Input8Emulated>
		<Input8EmuKey>0</Input8EmuKey>
		<Input9Active>0</Input9Active>
		<Input9Port>1</Input9Port>
		<Input9Pin>0</Input9Pin>
		<Input9Neg>0</Input9Neg>
		<Input9Emulated>0</Input9Emulated>
		<Input9EmuKey>0</Input9EmuKey>
		<Input10Active>0</Input10Active>
		<Input10Port>1</Input10Port>
		<Input10Pin>0</Input10Pin>
		<Input10Neg>0</Input10Neg>
		<Input10Emulated>0</Input10Emulated>
		<Input10EmuKey>0</Input10EmuKey>
		<Input11Active>0</Input11Active>
		<Input11Port>1</Input11Port>
		<Input11Pin>0</Input11Pin>
		<Input11Neg>0</Input11Neg>
		<Input11Emulated>0</Input11Emulated>
		<Input11EmuKey>0</Input11EmuKey>
		<Input12Active>0</Input12Active>
		<Input12Port>1</Input12Port>
		<Input12Pin>0</Input12Pin>
		<Input12Neg>0</Input12Neg>
		<Input12Emulated>0</Input12Emulated>
		<Input12EmuKey>0</Input12EmuKey>
		<Input13Active>0</Input13Active>
		<Input13Port>1</Input13Port>
		<Input13Pin>0</Input13Pin>
		<Input13Neg>0</Input13Neg>
		<Input13Emulated>0</Input13Emulated>
		<Input13EmuKey>0</Input13EmuKey>
		<Input14Active>0</Input14Active>
		<Input14Port>1</Input14Port>
		<Input14Pin>0</Input14Pin>
		<Input14Neg>0</Input14Neg>
		<Input14Emulated>0</Input14Emulated>
		<Input14EmuKey>0</Input14EmuKey>
		<Input15Active>0</Input15Active>
		<Input15Port>1</Input15Port>
		<Input15Pin>0</Input15Pin>
		<Input15Neg>0</Input15Neg>
		<Input15Emulated>0</Input15Emulated>
		<Input15EmuKey>0</Input15EmuKey>
		<Input16Active>0</Input16Active>
		<Input16Port>1</Input16Port>
		<Input16Pin>0</Input16Pin>
		<Input16Neg>0</Input16Neg>
		<Input16Emulated>0</Input16Emulated>
		<Input16EmuKey>0</Input16EmuKey>
		<Input17Active>0</Input17Active>
		<Input17Port>1</Input17Port>
		<Input17Pin>0</Input17Pin>
		<Input17Neg>0</Input17Neg>
		<Input17Emulated>0</Input17Emulated>
		<Input17EmuKey>0</Input17EmuKey>
		<Input18Active>0</Input18Active>
		<Input18Port>1</Input18Port>
		<Input18Pin>0</Input18Pin>
		<Input18Neg>0</Input18Neg>
		<Input18Emulated>0</Input18Emulated>
		<Input18EmuKey>0</Input18EmuKey>
		<Input19Active>0</Input19Active>
		<Input19Port>1</Input19Port>
		<Input19Pin>0</Input19Pin>
		<Input19Neg>0</Input19Neg>
		<Input19Emulated>0</Input19Emulated>
		<Input19EmuKey>0</Input19EmuKey>
		<Input20Active>0</Input20Active>
		<Input20Port>1</Input20Port>
		<Input20Pin>0</Input20Pin>
		<Input20Neg>0</Input20Neg>
		<Input20Emulated>0</Input20Emulated>
		<Input20EmuKey>0</Input20EmuKey>
		<Input21Active>0</Input21Active>
		<Input21Port>1</Input21Port>
		<Input21Pin>0</Input21Pin>
		<Input21Neg>0</Input21Neg>
		<Input21Emulated>0</Input21Emulated>
		<Input21EmuKey>0</Input21EmuKey>
		<Input22Active>0</Input22Active>
		<Input22Port>1</Input22Port>
		<Input22Pin>0</Input22Pin>
		<Input22Neg>0</Input22Neg>
		<Input22Emulated>0</Input22Emulated>
		<Input22EmuKey>0</Input22EmuKey>
		<Input23Active>0</Input23Active>
		<Input23Port>1</Input23Port>
		<Input23Pin>0</Input23Pin>
		<Input23Neg>0</Input23Neg>
		<Input23Emulated>0</Input23Emulated>
		<Input23EmuKey>0</Input23EmuKey>
		<Input24Active>0</Input24Active>
		<Input24Port>1</Input24Port>
		<Input24Pin>0</Input24Pin>
		<Input24Neg>0</Input24Neg>
		<Input24Emulated>0</Input24Emulated>
		<Input24EmuKey>0</Input24EmuKey>
		<Input25Active>1</Input25Active>
		<Input25Port>1</Input25Port>
		<Input25Pin>15</Input25Pin>
		<Input25Neg>1</Input25Neg>
		<Input25Emulated>1</Input25Emulated>
		<Input25EmuKey>0</Input25EmuKey>
		<Input26Active>0</Input26Active>
		<Input26Port>1</Input26Port>
		<Input26Pin>0</Input26Pin>
		<Input26Neg>0</Input26Neg>
		<Input26Emulated>0</Input26Emulated>
		<Input26EmuKey>0</Input26EmuKey>
		<Input27Active>0</Input27Active>
		<Input27Port>1</Input27Port>
		<Input27Pin>0</Input27Pin>
		<Input27Neg>0</Input27Neg>
		<Input27Emulated>0</Input27Emulated>
		<Input27EmuKey>0</Input27EmuKey>
		<Input28Active>0</Input28Active>
		<Input28Port>1</Input28Port>
		<Input28Pin>0</Input28Pin>
		<Input28Neg>0</Input28Neg>
		<Input28Emulated>0</Input28Emulated>
		<Input28EmuKey>0</Input28EmuKey>
		<Input29Active>0</Input29Active>
		<Input29Port>1</Input29Port>
		<Input29Pin>0</Input29Pin>
		<Input29Neg>0</Input29Neg>
		<Input29Emulated>0</Input29Emulated>
		<Input29EmuKey>0</Input29EmuKey>
		<Input30Active>0</Input30Active>
		<Input30Port>1</Input30Port>
		<Input30Pin>0</Input30Pin>
		<Input30Neg>0</Input30Neg>
		<Input30Emulated>0</Input30Emulated>
		<Input30EmuKey>0</Input30EmuKey>
		<Input31Active>0</Input31Active>
		<Input31Port>1</Input31Port>
		<Input31Pin>0</Input31Pin>
		<Input31Neg>0</Input31Neg>
		<Input31Emulated>0</Input31Emulated>
		<Input31EmuKey>0</Input31EmuKey>
		<Input32Active>0</Input32Active>
		<Input32Port>1</Input32Port>
		<Input32Pin>0</Input32Pin>
		<Input32Neg>0</Input32Neg>
		<Input32Emulated>0</Input32Emulated>
		<Input32EmuKey>0</Input32EmuKey>
		<Input33Active>0</Input33Active>
		<Input33Port>1</Input33Port>
		<Input33Pin>0</Input33Pin>
		<Input33Neg>0</Input33Neg>
		<Input33Emulated>0</Input33Emulated>
		<Input33EmuKey>0</Input33EmuKey>
		<Input34Active>0</Input34Active>
		<Input34Port>0</Input34Port>
		<Input34Pin>0</Input34Pin>
		<Input34Neg>0</Input34Neg>
		<Input34Emulated>0</Input34Emulated>
		<Input34EmuKey>0</Input34EmuKey>
		<Input35Active>0</Input35Active>
		<Input35Port>0</Input35Port>
		<Input35Pin>0</Input35Pin>
		<Input35Neg>0</Input35Neg>
		<Input35Emulated>0</Input35Emulated>
		<Input35EmuKey>0</Input35EmuKey>
		<Input36Active>0</Input36Active>
		<Input36Port>0</Input36Port>
		<Input36Pin>0</Input36Pin>
		<Input36Neg>0</Input36Neg>
		<Input36Emulated>0</Input36Emulated>
		<Input36EmuKey>0</Input36EmuKey>
		<Input37Active>0</Input37Active>
		<Input37Port>0</Input37Port>
		<Input37Pin>0</Input37Pin>
		<Input37Neg>0</Input37Neg>
		<Input37Emulated>0</Input37Emulated>
		<Input37EmuKey>0</Input37EmuKey>
		<Input38Active>0</Input38Active>
		<Input38Port>0</Input38Port>
		<Input38Pin>0</Input38Pin>
		<Input38Neg>0</Input38Neg>
		<Input38Emulated>0</Input38Emulated>
		<Input38EmuKey>0</Input38EmuKey>
		<Input39Active>0</Input39Active>
		<Input39Port>0</Input39Port>
		<Input39Pin>0</Input39Pin>
		<Input39Neg>0</Input39Neg>
		<Input39Emulated>0</Input39Emulated>
		<Input39EmuKey>0</Input39EmuKey>
		<Input40Active>0</Input40Active>
		<Input40Port>0</Input40Port>
		<Input40Pin>0</Input40Pin>
		<Input40Neg>0</Input40Neg>
		<Input40Emulated>0</Input40Emulated>
		<Input40EmuKey>0</Input40EmuKey>
		<Input41Active>0</Input41Active>
		<Input41Port>0</Input41Port>
		<Input41Pin>0</Input41Pin>
		<Input41Neg>0</Input41Neg>
		<Input41Emulated>0</Input41Emulated>
		<Input41EmuKey>0</Input41EmuKey>
		<Input42Active>0</Input42Active>
		<Input42Port>0</Input42Port>
		<Input42Pin>0</Input42Pin>
		<Input42Neg>0</Input42Neg>
		<Input42Emulated>0</Input42Emulated>
		<Input42EmuKey>0</Input42EmuKey>
		<Input43Active>0</Input43Active>
		<Input43Port>0</Input43Port>
		<Input43Pin>0</Input43Pin>
		<Input43Neg>0</Input43Neg>
		<Input43Emulated>0</Input43Emulated>
		<Input43EmuKey>0</Input43EmuKey>
		<Input44Active>0</Input44Active>
		<Input44Port>0</Input44Port>
		<Input44Pin>0</Input44Pin>
		<Input44Neg>0</Input44Neg>
		<Input44Emulated>0</Input44Emulated>
		<Input44EmuKey>0</Input44EmuKey>
		<Input45Active>0</Input45Active>
		<Input45Port>0</Input45Port>
		<Input45Pin>0</Input45Pin>
		<Input45Neg>0</Input45Neg>
		<Input45Emulated>0</Input45Emulated>
		<Input45EmuKey>0</Input45EmuKey>
		<Input46Active>0</Input46Active>
		<Input46Port>0</Input46Port>
		<Input46Pin>0</Input46Pin>
		<Input46Neg>0</Input46Neg>
		<Input46Emulated>0</Input46Emulated>
		<Input46EmuKey>0</Input46EmuKey>
		<Input47Active>0</Input47Active>
		<Input47Port>0</Input47Port>
		<Input47Pin>0</Input47Pin>
		<Input47Neg>0</Input47Neg>
		<Input47Emulated>0</Input47Emulated>
		<Input47EmuKey>0</Input47EmuKey>
		<Input48Active>0</Input48Active>
		<Input48Port>0</Input48Port>
		<Input48Pin>0</Input48Pin>
		<Input48Neg>0</Input48Neg>
		<Input48Emulated>0</Input48Emulated>
		<Input48EmuKey>0</Input48EmuKey>
		<Input49Active>0</Input49Active>
		<Input49Port>0</Input49Port>
		<Input49Pin>0</Input49Pin>
		<Input49Neg>0</Input49Neg>
		<Input49Emulated>0</Input49Emulated>
		<Input49EmuKey>0</Input49EmuKey>
		<Input50Active>0</Input50Active>
		<Input50Port>0</Input50Port>
		<Input50Pin>0</Input50Pin>
		<Input50Neg>0</Input50Neg>
		<Input50Emulated>0</Input50Emulated>
		<Input50EmuKey>0</Input50EmuKey>
		<Input51Active>0</Input51Active>
		<Input51Port>0</Input51Port>
		<Input51Pin>0</Input51Pin>
		<Input51Neg>0</Input51Neg>
		<Input51Emulated>0</Input51Emulated>
		<Input51EmuKey>0</Input51EmuKey>
		<Input52Active>0</Input52Active>
		<Input52Port>0</Input52Port>
		<Input52Pin>0</Input52Pin>
		<Input52Neg>0</Input52Neg>
		<Input52Emulated>0</Input52Emulated>
		<Input52EmuKey>0</Input52EmuKey>
		<Output0Active>0</Output0Active>
		<Output0Port>1</Output0Port>
		<Output0Pin>0</Output0Pin>
		<Output0Neg>0</Output0Neg>
		<Output1Active>0</Output1Active>
		<Output1Port>1</Output1Port>
		<Output1Pin>0</Output1Pin>
		<Output1Neg>0</Output1Neg>
		<Output2Active>0</Output2Active>
		<Output2Port>1</Output2Port>
		<Output2Pin>0</Output2Pin>
		<Output2Neg>0</Output2Neg>
		<Output3Active>0</Output3Active>
		<Output3Port>1</Output3Port>
		<Output3Pin>0</Output3Pin>
		<Output3Neg>0</Output3Neg>
		<Output4Active>0</Output4Active>
		<Output4Port>1</Output4Port>
		<Output4Pin>0</Output4Pin>
		<Output4Neg>0</Output4Neg>
		<Output5Active>0</Output5Active>
		<Output5Port>1</Output5Port>
		<Output5Pin>0</Output5Pin>
		<Output5Neg>0</Output5Neg>
		<Output6Active>0</Output6Active>
		<Output6Port>1</Output6Port>
		<Output6Pin>0</Output6Pin>
		<Output6Neg>0</Output6Neg>
		<Output7Active>1</Output7Active>
		<Output7Port>1</Output7Port>
		<Output7Pin>17</Output7Pin>
		<Output7Neg>0</Output7Neg>
		<Output8Active>0</Output8Active>
		<Output8Port>1</Output8Port>
		<Output8Pin>0</Output8Pin>
		<Output8Neg>0</Output8Neg>
		<Output9Active>0</Output9Active>
		<Output9Port>1</Output9Port>
		<Output9Pin>0</Output9Pin>
		<Output9Neg>0</Output9Neg>
		<Output10Active>0</Output10Active>
		<Output10Port>1</Output10Port>
		<Output10Pin>0</Output10Pin>
		<Output10Neg>0</Output10Neg>
		<Output11Active>0</Output11Active>
		<Output11Port>1</Output11Port>
		<Output11Pin>0</Output11Pin>
		<Output11Neg>0</Output11Neg>
		<Output12Active>0</Output12Active>
		<Output12Port>1</Output12Port>
		<Output12Pin>0</Output12Pin>
		<Output12Neg>0</Output12Neg>
		<Output13Active>1</Output13Active>
		<Output13Port>1</Output13Port>
		<Output13Pin>16</Output13Pin>
		<Output13Neg>0</Output13Neg>
		<Output14Active>0</Output14Active>
		<Output14Port>1</Output14Port>
		<Output14Pin>0</Output14Pin>
		<Output14Neg>0</Output14Neg>
		<Output15Active>0</Output15Active>
		<Output15Port>1</Output15Port>
		<Output15Pin>0</Output15Pin>
		<Output15Neg>0</Output15Neg>
		<Output16Active>0</Output16Active>
		<Output16Port>1</Output16Port>
		<Output16Pin>0</Output16Pin>
		<Output16Neg>0</Output16Neg>
		<Output17Active>0</Output17Active>
		<Output17Port>1</Output17Port>
		<Output17Pin>0</Output17Pin>
		<Output17Neg>0</Output17Neg>
		<Output18Active>0</Output18Active>
		<Output18Port>1</Output18Port>
		<Output18Pin>0</Output18Pin>
		<Output18Neg>0</Output18Neg>
		<Output19Active>0</Output19Active>
		<Output19Port>1</Output19Port>
		<Output19Pin>0</Output19Pin>
		<Output19Neg>0</Output19Neg>
		<Output20Active>0</Output20Active>
		<Output20Port>1</Output20Port>
		<Output20Pin>0</Output20Pin>
		<Output20Neg>0</Output20Neg>
		<Output21Active>0</Output21Active>
		<Output21Port>1</Output21Port>
		<Output21Pin>0</Output21Pin>
		<Output21Neg>0</Output21Neg>
		<Output22Active>0</Output22Active>
		<Output22Port>1</Output22Port>
		<Output22Pin>0</Output22Pin>
		<Output22Neg>0</Output22Neg>
		<Output23Active>0</Output23Active>
		<Output23Port>1</Output23Port>
		<Output23Pin>0</Output23Pin>
		<Output23Neg>0</Output23Neg>
		<Output24Active>0</Output24Active>
		<Output24Port>1</Output24Port>
		<Output24Pin>0</Output24Pin>
		<Output24Neg>0</Output24Neg>
		<Output25Active>0</Output25Active>
		<Output25Port>1</Output25Port>
		<Output25Pin>0</Output25Pin>
		<Output25Neg>0</Output25Neg>
		<Output26Active>0</Output26Active>
		<Output26Port>1</Output26Port>
		<Output26Pin>0</Output26Pin>
		<Output26Neg>0</Output26Neg>
		<Output27Active>0</Output27Active>
		<Output27Port>1</Output27Port>
		<Output27Pin>0</Output27Pin>
		<Output27Neg>0</Output27Neg>
		<Output28Active>0</Output28Active>
		<Output28Port>1</Output28Port>
		<Output28Pin>0</Output28Pin>
		<Output28Neg>0</Output28Neg>
		<Output29Active>0</Output29Active>
		<Output29Port>1</Output29Port>
		<Output29Pin>0</Output29Pin>
		<Output29Neg>0</Output29Neg>
		<Output30Active>0</Output30Active>
		<Output30Port>0</Output30Port>
		<Output30Pin>0</Output30Pin>
		<Output30Neg>0</Output30Neg>
		<Encoder0Active>0</Encoder0Active>
		<Encoder0APort>0</Encoder0APort>
		<Encoder0APin>0</Encoder0APin>
		<Encoder0BPort>0</Encoder0BPort>
		<Encoder0BPin>0</Encoder0BPin>
		<Encoder0Cal>1.000000</Encoder0Cal>
		<Encoder1Active>0</Encoder1Active>
		<Encoder1APort>0</Encoder1APort>
		<Encoder1APin>0</Encoder1APin>
		<Encoder1BPort>0</Encoder1BPort>
		<Encoder1BPin>0</Encoder1BPin>
		<Encoder1Cal>1.000000</Encoder1Cal>
		<Encoder2Active>0</Encoder2Active>
		<Encoder2APort>0</Encoder2APort>
		<Encoder2APin>0</Encoder2APin>
		<Encoder2BPort>0</Encoder2BPort>
		<Encoder2BPin>0</Encoder2BPin>
		<Encoder2Cal>1.000000</Encoder2Cal>
		<Encoder3Active>0</Encoder3Active>
		<Encoder3APort>0</Encoder3APort>
		<Encoder3APin>0</Encoder3APin>
		<Encoder3BPort>0</Encoder3BPort>
		<Encoder3BPin>0</Encoder3BPin>
		<Encoder3Cal>1.000000</Encoder3Cal>
		<Encoder4Active>0</Encoder4Active>
		<Encoder4APort>0</Encoder4APort>
		<Encoder4APin>0</Encoder4APin>
		<Encoder4BPort>0</Encoder4BPort>
		<Encoder4BPin>0</Encoder4BPin>
		<Encoder4Cal>1.000000</Encoder4Cal>
		<Encoder5Active>0</Encoder5Active>
		<Encoder5APort>0</Encoder5APort>
		<Encoder5APin>0</Encoder5APin>
		<Encoder5BPort>0</Encoder5BPort>
		<Encoder5BPin>0</Encoder5BPin>
		<Encoder5Cal>1.000000</Encoder5Cal>
		<Encoder6Active>0</Encoder6Active>
		<Encoder6APort>0</Encoder6APort>
		<Encoder6APin>0</Encoder6APin>
		<Encoder6BPort>0</Encoder6BPort>
		<Encoder6BPin>0</Encoder6BPin>
		<Encoder6Cal>1.000000</Encoder6Cal>
		<Encoder7Active>0</Encoder7Active>
		<Encoder7APort>0</Encoder7APort>
		<Encoder7APin>0</Encoder7APin>
		<Encoder7BPort>0</Encoder7BPort>
		<Encoder7BPin>0</Encoder7BPin>
		<Encoder7Cal>
		</Encoder7Cal>
		<Configured>1</Configured>
		<SlavePrim>0</SlavePrim>
		<Slave>-1</Slave>
		<AxisKeys0>39</AxisKeys0>
		<AxisKeys1>37</AxisKeys1>
		<AxisKeys2>38</AxisKeys2>
		<AxisKeys3>40</AxisKeys3>
		<AxisKeys4>33</AxisKeys4>
		<AxisKeys5>34</AxisKeys5>
		<AxisKeys6>999</AxisKeys6>
		<AxisKeys7>999</AxisKeys7>
		<AxisKeys8>999</AxisKeys8>
		<AxisKeys9>999</AxisKeys9>
		<AxisKeys10>999</AxisKeys10>
		<AxisKeys11>999</AxisKeys11>
		<DROHotKey>999</DROHotKey>
		<ListKey>999</ListKey>
		<MDIHotKey>999</MDIHotKey>
		<GCodeHotKey>999</GCodeHotKey>
		<OEM1>-1</OEM1>
		<OEM2>-1</OEM2>
		<OEM3>-1</OEM3>
		<OEM4>-1</OEM4>
		<OEM5>-1</OEM5>
		<OEM6>-1</OEM6>
		<PulseWidth>0</PulseWidth>
		<DirPulse>0</DirPulse>
		<BackX>0.</BackX>
		<BackY>0.</BackY>
		<BackZ>0.</BackZ>
		<BackA>0.</BackA>
		<BackB>0.</BackB>
		<BackC>0.</BackC>
		<BackSpeed>20.</BackSpeed>
		<BB>0.0</BB>
		<BR>0.0</BR>
		<BG>0.0</BG>
		<FB>1.0</FB>
		<FR>0.0</FR>
		<FG>0.0</FG>
		<RB>0.0</RB>
		<RR>1.0</RR>
		<RG>0.0</RG>
		<AB>0.7</AB>
		<AR>0.7</AR>
		<AG>0.2</AG>
		<EG>1.0</EG>
		<ER>1.0</ER>
		<EB>0.0</EB>
		<JogFollow>0</JogFollow>
		<G92Off>1</G92Off>
		<RadiusCompOff>1</RadiusCompOff>
		<Debounce>0</Debounce>
		<PlasmaMode>0</PlasmaMode>
		<NoAngle>0</NoAngle>
		<AAngular>1</AAngular>
		<BAngular>1</BAngular>
		<CAngular>1</CAngular>
		<IndexDebounce>0</IndexDebounce>
		<DROPERSIST>1</DROPERSIST>
		<DwellinMilli>0</DwellinMilli>
		<IJMode>1</IJMode>
		<INIT>G80</INIT>
		<InitAllResets>0</InitAllResets>
		<AutoScreens>1</AutoScreens>
		<TORCHVON>0</TORCHVON>
		<TORCHVOLTS>0</TORCHVOLTS>
		<HWSAFE>1</HWSAFE>
		<ShortRot>0</ShortRot>
		<LookAhead>20</LookAhead>
		<WatchDog>0</WatchDog>
		<Plane>0</Plane>
		<MPG1>0</MPG1>
		<MPG2>0</MPG2>
		<HotKeysPersist>0</HotKeysPersist>
		<HoldInput1>0</HoldInput1>
		<M3s>17</M3s>
		<UseCR>0</UseCR>
		<PlasmaHome>0</PlasmaHome>
		<Homann>0</Homann>
		<UseSLS>0</UseSLS>
		<Dist0>1.9e+002</Dist0>
		<Dist1>1.4e+002</Dist1>
		<Dist2>23</Dist2>
		<Dist3>0.</Dist3>
		<Dist4>0.</Dist4>
		<Dist5>0.</Dist5>
		<OverMode2>0</OverMode2>
		<BitPack1>0</BitPack1>
		<BitPack1Reg>16</BitPack1Reg>
		<BitPackOut>0</BitPackOut>
		<BitPackOutReg>16</BitPackOutReg>
		<LaserPort>1</LaserPort>
		<LaserBaud>9600</LaserBaud>
		<LaserStops>1</LaserStops>
		<LaserData>1</LaserData>
		<LaserInit>&gt;</LaserInit>
		<LaserCommand>&gt;</LaserCommand>
		<MacroPump>0</MacroPump>
		<VelMode>0</VelMode>
		<VelPer1>5.</VelPer1>
		<VelPer2>5.</VelPer2>
		<MPGFeed>1.e+002</MPGFeed>
		<ModSpindleCal>1.638e+004</ModSpindleCal>
		<ModSpindleOn>0</ModSpindleOn>
		<ModSpindleReg>64</ModSpindleReg>
		<ShuttleAccel>8192</ShuttleAccel>
		<Flash>1</Flash>
		<ImmediateOff>0</ImmediateOff>
		<UseSafeZ>0</UseSafeZ>
		<AdvancedComp>1</AdvancedComp>
		<TorchOff>0</TorchOff>
		<LaserStandby>0</LaserStandby>
		<RaiseLower>0</RaiseLower>
		<OEMDUAL>0</OEMDUAL>
		<IncBuffer>5</IncBuffer>
		<Formula0>x</Formula0>
		<Formula1>y</Formula1>
		<Formula2>z</Formula2>
		<Formula3>a</Formula3>
		<Formula4>b</Formula4>
		<Formula5>c</Formula5>
		<Formular>0</Formular>
		<PanelOut>350</PanelOut>
		<nModBusReg>0</nModBusReg>
		<ModBusRegOn>0</ModBusRegOn>
		<Tool>0</Tool>
		<Sherline>0</Sherline>
		<ToolPost>1</ToolPost>
		<RapidOverRide>0</RapidOverRide>
		<XCLength>1.3e+003</XCLength>
		<YCLength>1.3e+003</YCLength>
		<ZCLength>1.3e+003</ZCLength>
		<ToolPostOffset>0.</ToolPostOffset>
		<OEM7>-1</OEM7>
		<OEM8>-1</OEM8>
		<OEM9>-1</OEM9>
		<OEM10>-1</OEM10>
		<OEM11>-1</OEM11>
		<OEM12>-1</OEM12>
		<OEM13>-1</OEM13>
		<OEM14>-1</OEM14>
		<OEM15>-1</OEM15>
		<MPGVel0>1.e+002</MPGVel0>
		<MPGVel1>1.e+002</MPGVel1>
		<MPGVel2>1.e+002</MPGVel2>
		<MPGVel3>1.e+002</MPGVel3>
		<MPGVel4>1.e+002</MPGVel4>
		<MPGVel5>1.e+002</MPGVel5>
		<MPGVel6>1.e+002</MPGVel6>
		<ByPassFeed>1.e+003</ByPassFeed>
		<XMapOn>0</XMapOn>
		<YMapOn>0</YMapOn>
		<ZMapOn>0</ZMapOn>
		<SecondsOn>186340</SecondsOn>
		<SerialType>0</SerialType>
		<SpinAverage>0</SpinAverage>
		<Dig4Axis>0</Dig4Axis>
		<DigLetter>0</DigLetter>
		<CutType>0</CutType>
		<InfeedType>0</InfeedType>
		<LastWizard>C:\Mach3\Addons\Surface\Surface.set</LastWizard>
		<Z25D>0</Z25D>
		<ModBus>0</ModBus>
		<ChargeAlwaysOn>0</ChargeAlwaysOn>
		<ToolFlip>0</ToolFlip>
		<SpinCCW>7</SpinCCW>
		<SpinCW>7</SpinCW>
		<Flood>9</Flood>
		<Mist>10</Mist>
		<SpinActual>0</SpinActual>
		<SpinDelayCW>1.</SpinDelayCW>
		<SpinDelayCCW>1.</SpinDelayCCW>
		<SpinDownCW>1.</SpinDownCW>
		<SpinDownCCW>1.</SpinDownCCW>
		<StockSize>50</StockSize>
		<ShowSolid>0</ShowSolid>
		<RapidFeed>1.e+003</RapidFeed>
		<MatRed>0.</MatRed>
		<MatGreen>0.1</MatGreen>
		<MatBlue>0.1</MatBlue>
		<SpinP>0.25</SpinP>
		<SpinI>1.</SpinI>
		<SpinD>0.3</SpinD>
		<SpinClosed>0</SpinClosed>
		<MinPerPass>0.1</MinPerPass>
		<NoSpindle>0</NoSpindle>
		<NoFlood>1</NoFlood>
		<PWMin>0</PWMin>
		<PULLEY>3</PULLEY>
		<SPEED1>1000</SPEED1>
		<SPEED2>2000</SPEED2>
		<SPEED3>4000</SPEED3>
		<SPEED4>8000</SPEED4>
		<LSPEED1>0</LSPEED1>
		<LSPEED2>0</LSPEED2>
		<LSPEED3>0</LSPEED3>
		<LSPEED4>0</LSPEED4>
		<PWM>0</PWM>
		<RefSpeed0>20</RefSpeed0>
		<RefSpeed1>20</RefSpeed1>
		<RefSpeed2>20</RefSpeed2>
		<RefSpeed3>20</RefSpeed3>
		<RefSpeed4>20</RefSpeed4>
		<RefSpeed5>20</RefSpeed5>
		<M0SoftRamp>1.</M0SoftRamp>
		<M1SoftRamp>1.</M1SoftRamp>
		<M2SoftRamp>1.</M2SoftRamp>
		<M3SoftRamp>1.</M3SoftRamp>
		<M4SoftRamp>1.</M4SoftRamp>
		<M5SoftRamp>1.</M5SoftRamp>
		<FeedInc>5.</FeedInc>
		<DepthLastPass>0.</DepthLastPass>
		<InFeed>29.5</InFeed>
		<Spring>1.</Spring>
		<MinDepth>1.e-003</MinDepth>
		<XClear>0.1</XClear>
		<ZClear>0.1</ZClear>
		<CutDepth>0.1</CutDepth>
		<Chamfer>0.</Chamfer>
		<DepthFirstPass>0.1</DepthFirstPass>
		<M0Max>100.</M0Max>
		<M1Max>100.</M1Max>
		<M2Max>0.</M2Max>
		<M3Max>100.</M3Max>
		<M4Max>100.</M4Max>
		<M5Max>100.</M5Max>
		<M0Min>0.</M0Min>
		<M1Min>0.</M1Min>
		<M2Min>-200.</M2Min>
		<M3Min>-100.</M3Min>
		<M4Min>-100.</M4Min>
		<M5Min>-100.</M5Min>
		<M0Neg>1</M0Neg>
		<M1Neg>1</M1Neg>
		<M2Neg>1</M2Neg>
		<M3Neg>0</M3Neg>
		<M4Neg>0</M4Neg>
		<M5Neg>0</M5Neg>
		<M0AutoZero>0</M0AutoZero>
		<M1AutoZero>0</M1AutoZero>
		<M2AutoZero>0</M2AutoZero>
		<M3AutoZero>0</M3AutoZero>
		<M4AutoZero>0</M4AutoZero>
		<M5AutoZero>0</M5AutoZero>
		<M0Rev>1</M0Rev>
		<M1Rev>1</M1Rev>
		<M2Rev>1</M2Rev>
		<M3Rev>0</M3Rev>
		<M4Rev>0</M4Rev>
		<M5Rev>0</M5Rev>
		<M6Rev>0</M6Rev>
		<OffPersist>1</OffPersist>
		<Diameter>0</Diameter>
		<OffDialogs>1</OffDialogs>
		<G54Back>0</G54Back>
		<GougeCheck>0</GougeCheck>
		<AxisToMotor0>0</AxisToMotor0>
		<AxisToMotor1>1</AxisToMotor1>
		<AxisToMotor2>2</AxisToMotor2>
		<AxisToMotor3>3</AxisToMotor3>
		<AxisToMotor4>4</AxisToMotor4>
		<AxisToMotor5>5</AxisToMotor5>
		<AxisToMotor6>6</AxisToMotor6>
		<JogActive>1</JogActive>
		<BLState0>1</BLState0>
		<BLState1>0</BLState1>
		<BLState2>1</BLState2>
		<BLState3>0</BLState3>
		<BLState4>0</BLState4>
		<BLState5>0</BLState5>
		<SlowMode>0</SlowMode>
		<JogPersist>1</JogPersist>
		<ToolRotations>0</ToolRotations>
		<SoftLimit>0</SoftLimit>
		<JogMode>0</JogMode>
		<JogMode2>0</JogMode2>
		<EncJogAxis2>2</EncJogAxis2>
		<TaperRatio>1.</TaperRatio>
		<XStart>-90023</XStart>
		<YStart>-22736</YStart>
		<ZStart>21455</ZStart>
		<AStart>0</AStart>
		<BStart>0</BStart>
		<CStart>0</CStart>
		<SpinInc>10</SpinInc>
		<Enc0>0.</Enc0>
		<Enc1>0.</Enc1>
		<Enc2>4.</Enc2>
		<Enc3>0.</Enc3>
		<TangentalControl>0</TangentalControl>
		<BaudRate>9600</BaudRate>
		<ComPort>1</ComPort>
		<NoPlunge>0</NoPlunge>
		<PlungeLimit>60</PlungeLimit>
		<AutoTool>0</AutoTool>
		<AutoSpindle>0</AutoSpindle>
		<LaserMode>0</LaserMode>
		<FeedMode>0</FeedMode>
		<OriginSphere>0</OriginSphere>
		<m_3dCompass>1</m_3dCompass>
		<Boundries>1</Boundries>
		<ToolPosition>1</ToolPosition>
		<AParallel>0</AParallel>
		<ZINHPersist>0</ZINHPersist>
		<OVPersist>1</OVPersist>
		<BacklashOn>0</BacklashOn>
		<PathMode>2</PathMode>
		<ThrottleFunc>2</ThrottleFunc>
		<JoyOn>0</JoyOn>
		<PWMBase>5000</PWMBase>
		<JogSpeed>100.</JogSpeed>
		<G73PullBack>0.1</G73PullBack>
		<CVFeedOn>0</CVFeedOn>
		<CVFeedRate>1.</CVFeedRate>
		<AtoX>0.</AtoX>
		<AtoY>0.</AtoY>
		<AtoZ>0.</AtoZ>
		<OEMDRO0>0.</OEMDRO0>
		<OEMLED0>0</OEMLED0>
		<OEMDRO1>100.</OEMDRO1>
		<OEMLED1>1</OEMLED1>
		<OEMDRO2>100.</OEMDRO2>
		<OEMLED2>0</OEMLED2>
		<OEMDRO3>6.</OEMDRO3>
		<OEMLED3>0</OEMLED3>
		<OEMDRO4>0.</OEMDRO4>
		<OEMLED4>0</OEMLED4>
		<OEMDRO5>1.</OEMDRO5>
		<OEMLED5>0</OEMLED5>
		<OEMDRO6>1.</OEMDRO6>
		<OEMLED6>0</OEMLED6>
		<OEMDRO7>30005.</OEMDRO7>
		<OEMLED7>0</OEMLED7>
		<OEMDRO8>60.</OEMDRO8>
		<OEMLED8>0</OEMLED8>
		<OEMDRO9>0.</OEMDRO9>
		<OEMLED9>0</OEMLED9>
		<OEMDRO10>0.</OEMDRO10>
		<OEMLED10>0</OEMLED10>
		<OEMDRO11>0.</OEMDRO11>
		<OEMLED11>0</OEMLED11>
		<OEMDRO12>0.</OEMDRO12>
		<OEMLED12>0</OEMLED12>
		<OEMDRO13>0.</OEMDRO13>
		<OEMLED13>0</OEMLED13>
		<OEMDRO14>0.</OEMDRO14>
		<OEMLED14>0</OEMLED14>
		<OEMDRO15>0.</OEMDRO15>
		<OEMLED15>0</OEMLED15>
		<OEMDRO16>0.</OEMDRO16>
		<OEMLED16>0</OEMLED16>
		<OEMDRO17>0.</OEMDRO17>
		<OEMLED17>0</OEMLED17>
		<OEMDRO18>0.</OEMDRO18>
		<OEMLED18>0</OEMLED18>
		<OEMDRO19>0.</OEMDRO19>
		<OEMLED19>0</OEMLED19>
		<OEMDRO20>0.</OEMDRO20>
		<OEMLED20>0</OEMLED20>
		<OEMDRO21>0.</OEMDRO21>
		<OEMLED21>0</OEMLED21>
		<OEMDRO22>0.</OEMDRO22>
		<OEMLED22>0</OEMLED22>
		<OEMDRO23>0.</OEMDRO23>
		<OEMLED23>0</OEMLED23>
		<OEMDRO24>0.</OEMDRO24>
		<OEMLED24>1</OEMLED24>
		<OEMDRO25>0.</OEMDRO25>
		<OEMLED25>0</OEMLED25>
		<OEMDRO26>0.</OEMDRO26>
		<OEMLED26>0</OEMLED26>
		<OEMDRO27>0.</OEMDRO27>
		<OEMLED27>0</OEMLED27>
		<OEMDRO28>0.</OEMDRO28>
		<OEMLED28>0</OEMLED28>
		<OEMDRO29>0.</OEMDRO29>
		<OEMLED29>0</OEMLED29>
		<OEMDRO30>0.</OEMDRO30>
		<OEMLED30>0</OEMLED30>
		<OEMDRO31>0.</OEMDRO31>
		<OEMLED31>0</OEMLED31>
		<OEMDRO32>0.</OEMDRO32>
		<OEMLED32>1</OEMLED32>
		<OEMDRO33>0.</OEMDRO33>
		<OEMLED33>0</OEMLED33>
		<OEMDRO34>0.</OEMDRO34>
		<OEMLED34>0</OEMLED34>
		<OEMDRO35>0.</OEMDRO35>
		<OEMLED35>0</OEMLED35>
		<OEMDRO36>0.</OEMDRO36>
		<OEMLED36>0</OEMLED36>
		<OEMDRO37>0.</OEMDRO37>
		<OEMLED37>0</OEMLED37>
		<OEMDRO38>0.</OEMDRO38>
		<OEMLED38>0</OEMLED38>
		<OEMDRO39>0.</OEMDRO39>
		<OEMLED39>0</OEMLED39>
		<OEMDRO40>0.</OEMDRO40>
		<OEMLED40>0</OEMLED40>
		<OEMDRO41>0.</OEMDRO41>
		<OEMLED41>0</OEMLED41>
		<OEMDRO42>0.</OEMDRO42>
		<OEMLED42>0</OEMLED42>
		<OEMDRO43>0.</OEMDRO43>
		<OEMLED43>0</OEMLED43>
		<OEMDRO44>0.</OEMDRO44>
		<OEMLED44>0</OEMLED44>
		<OEMDRO45>0.</OEMDRO45>
		<OEMLED45>0</OEMLED45>
		<OEMDRO46>0.</OEMDRO46>
		<OEMLED46>0</OEMLED46>
		<OEMDRO47>0.</OEMDRO47>
		<OEMLED47>0</OEMLED47>
		<OEMDRO48>0.</OEMDRO48>
		<OEMLED48>0</OEMLED48>
		<OEMDRO49>0.</OEMDRO49>
		<OEMLED49>0</OEMLED49>
		<OEMDRO50>10.</OEMDRO50>
		<OEMLED50>0</OEMLED50>
		<OEMDRO51>10.</OEMDRO51>
		<OEMLED51>1</OEMLED51>
		<OEMDRO52>10.</OEMDRO52>
		<OEMLED52>0</OEMLED52>
		<OEMDRO53>-1.</OEMDRO53>
		<OEMLED53>0</OEMLED53>
		<OEMDRO54>1.</OEMDRO54>
		<OEMLED54>0</OEMLED54>
		<OEMDRO55>1.</OEMDRO55>
		<OEMLED55>0</OEMLED55>
		<OEMDRO56>1.</OEMDRO56>
		<OEMLED56>0</OEMLED56>
		<OEMDRO57>2.</OEMDRO57>
		<OEMLED57>0</OEMLED57>
		<OEMDRO58>5.</OEMDRO58>
		<OEMLED58>0</OEMLED58>
		<OEMDRO59>0.</OEMDRO59>
		<OEMLED59>0</OEMLED59>
		<OEMDRO60>0.</OEMDRO60>
		<OEMLED60>0</OEMLED60>
		<OEMDRO61>0.</OEMDRO61>
		<OEMLED61>0</OEMLED61>
		<OEMDRO62>0.</OEMDRO62>
		<OEMLED62>0</OEMLED62>
		<OEMDRO63>0.</OEMDRO63>
		<OEMLED63>0</OEMLED63>
		<OEMDRO64>0.</OEMDRO64>
		<OEMLED64>0</OEMLED64>
		<OEMDRO65>0.</OEMDRO65>
		<OEMLED65>0</OEMLED65>
		<OEMDRO66>0.</OEMDRO66>
		<OEMLED66>0</OEMLED66>
		<OEMDRO67>0.</OEMDRO67>
		<OEMLED67>0</OEMLED67>
		<OEMDRO68>0.</OEMDRO68>
		<OEMLED68>0</OEMLED68>
		<OEMDRO69>0.</OEMDRO69>
		<OEMLED69>0</OEMLED69>
		<OEMDRO70>3.</OEMDRO70>
		<OEMLED70>0</OEMLED70>
		<OEMDRO71>0.5</OEMDRO71>
		<OEMLED71>0</OEMLED71>
		<OEMDRO72>0.</OEMDRO72>
		<OEMLED72>0</OEMLED72>
		<OEMDRO73>0.</OEMDRO73>
		<OEMLED73>0</OEMLED73>
		<OEMDRO74>0.</OEMDRO74>
		<OEMLED74>0</OEMLED74>
		<OEMDRO75>-2.</OEMDRO75>
		<OEMLED75>0</OEMLED75>
		<OEMDRO76>-0.8</OEMDRO76>
		<OEMLED76>0</OEMLED76>
		<OEMDRO77>0.</OEMDRO77>
		<OEMLED77>0</OEMLED77>
		<OEMDRO78>5.</OEMDRO78>
		<OEMLED78>0</OEMLED78>
		<OEMDRO79>0.1</OEMDRO79>
		<OEMLED79>0</OEMLED79>
		<OEMDRO80>3.</OEMDRO80>
		<OEMLED80>0</OEMLED80>
		<OEMDRO81>5.</OEMDRO81>
		<OEMLED81>0</OEMLED81>
		<OEMDRO82>1235.</OEMDRO82>
		<OEMLED82>0</OEMLED82>
		<OEMDRO83>0.</OEMDRO83>
		<OEMLED83>0</OEMLED83>
		<OEMDRO84>0.</OEMDRO84>
		<OEMLED84>0</OEMLED84>
		<OEMDRO85>0.</OEMDRO85>
		<OEMLED85>0</OEMLED85>
		<OEMDRO86>0.</OEMDRO86>
		<OEMLED86>0</OEMLED86>
		<OEMDRO87>0.</OEMDRO87>
		<OEMLED87>0</OEMLED87>
		<OEMDRO88>0.</OEMDRO88>
		<OEMLED88>0</OEMLED88>
		<OEMDRO89>0.</OEMDRO89>
		<OEMLED89>0</OEMLED89>
		<OEMDRO90>2.</OEMDRO90>
		<OEMLED90>0</OEMLED90>
		<OEMDRO91>0.</OEMDRO91>
		<OEMLED91>0</OEMLED91>
		<OEMDRO92>0.</OEMDRO92>
		<OEMLED92>0</OEMLED92>
		<OEMDRO93>0.</OEMDRO93>
		<OEMLED93>0</OEMLED93>
		<OEMDRO94>0.</OEMDRO94>
		<OEMLED94>0</OEMLED94>
		<OEMDRO95>-0.5</OEMDRO95>
		<OEMLED95>0</OEMLED95>
		<OEMDRO96>55.</OEMDRO96>
		<OEMLED96>0</OEMLED96>
		<OEMDRO97>0.</OEMDRO97>
		<OEMLED97>0</OEMLED97>
		<OEMDRO98>0.</OEMDRO98>
		<OEMLED98>0</OEMLED98>
		<OEMDRO99>0.</OEMDRO99>
		<OEMLED99>0</OEMLED99>
		<OEMDRO100>0.</OEMDRO100>
		<OEMLED100>0</OEMLED100>
		<OEMDRO101>0.</OEMDRO101>
		<OEMLED101>0</OEMLED101>
		<OEMDRO102>0.</OEMDRO102>
		<OEMLED102>0</OEMLED102>
		<OEMDRO103>0.</OEMDRO103>
		<OEMLED103>0</OEMLED103>
		<OEMDRO104>0.</OEMDRO104>
		<OEMLED104>0</OEMLED104>
		<OEMDRO105>0.</OEMDRO105>
		<OEMLED105>0</OEMLED105>
		<OEMDRO106>0.</OEMDRO106>
		<OEMLED106>0</OEMLED106>
		<OEMDRO107>0.</OEMDRO107>
		<OEMLED107>0</OEMLED107>
		<OEMDRO108>0.</OEMDRO108>
		<OEMLED108>0</OEMLED108>
		<OEMDRO109>0.</OEMDRO109>
		<OEMLED109>0</OEMLED109>
		<OEMDRO110>0.</OEMDRO110>
		<OEMLED110>0</OEMLED110>
		<OEMDRO111>0.</OEMDRO111>
		<OEMLED111>0</OEMLED111>
		<OEMDRO112>0.</OEMDRO112>
		<OEMLED112>0</OEMLED112>
		<OEMDRO113>0.</OEMDRO113>
		<OEMLED113>0</OEMLED113>
		<OEMDRO114>0.</OEMDRO114>
		<OEMLED114>0</OEMLED114>
		<OEMDRO115>0.</OEMDRO115>
		<OEMLED115>0</OEMLED115>
		<OEMDRO116>0.</OEMDRO116>
		<OEMLED116>0</OEMLED116>
		<OEMDRO117>0.</OEMDRO117>
		<OEMLED117>0</OEMLED117>
		<OEMDRO118>0.</OEMDRO118>
		<OEMLED118>0</OEMLED118>
		<OEMDRO119>0.</OEMDRO119>
		<OEMLED119>0</OEMLED119>
		<OEMDRO120>0.</OEMDRO120>
		<OEMLED120>0</OEMLED120>
		<OEMDRO121>0.</OEMDRO121>
		<OEMLED121>0</OEMLED121>
		<OEMDRO122>0.</OEMDRO122>
		<OEMLED122>0</OEMLED122>
		<OEMDRO123>0.</OEMDRO123>
		<OEMLED123>0</OEMLED123>
		<OEMDRO124>0.</OEMDRO124>
		<OEMLED124>0</OEMLED124>
		<OEMDRO125>0.</OEMDRO125>
		<OEMLED125>0</OEMLED125>
		<OEMDRO126>0.</OEMDRO126>
		<OEMLED126>0</OEMLED126>
		<OEMDRO127>0.</OEMDRO127>
		<OEMLED127>0</OEMLED127>
		<OEMDRO128>0.</OEMDRO128>
		<OEMLED128>0</OEMLED128>
		<OEMDRO129>0.</OEMDRO129>
		<OEMLED129>0</OEMLED129>
		<OEMDRO130>0.</OEMDRO130>
		<OEMLED130>0</OEMLED130>
		<OEMDRO131>0.</OEMDRO131>
		<OEMLED131>0</OEMLED131>
		<OEMDRO132>0.</OEMDRO132>
		<OEMLED132>1</OEMLED132>
		<OEMDRO133>0.</OEMDRO133>
		<OEMLED133>0</OEMLED133>
		<OEMDRO134>0.</OEMDRO134>
		<OEMLED134>0</OEMLED134>
		<OEMDRO135>0.</OEMDRO135>
		<OEMLED135>0</OEMLED135>
		<OEMDRO136>0.</OEMDRO136>
		<OEMLED136>1</OEMLED136>
		<OEMDRO137>0.</OEMDRO137>
		<OEMLED137>0</OEMLED137>
		<OEMDRO138>0.</OEMDRO138>
		<OEMLED138>0</OEMLED138>
		<OEMDRO139>0.</OEMDRO139>
		<OEMLED139>0</OEMLED139>
		<OEMDRO140>0.</OEMDRO140>
		<OEMLED140>0</OEMLED140>
		<OEMDRO141>0.</OEMDRO141>
		<OEMLED141>0</OEMLED141>
		<OEMDRO142>0.</OEMDRO142>
		<OEMLED142>0</OEMLED142>
		<OEMDRO143>0.</OEMDRO143>
		<OEMLED143>0</OEMLED143>
		<OEMDRO144>0.</OEMDRO144>
		<OEMLED144>0</OEMLED144>
		<OEMDRO145>0.</OEMDRO145>
		<OEMLED145>0</OEMLED145>
		<OEMDRO146>0.</OEMDRO146>
		<OEMLED146>0</OEMLED146>
		<OEMDRO147>0.</OEMDRO147>
		<OEMLED147>0</OEMLED147>
		<OEMDRO148>0.</OEMDRO148>
		<OEMLED148>0</OEMLED148>
		<OEMDRO149>0.</OEMDRO149>
		<OEMLED149>0</OEMLED149>
		<OEMDRO150>0.</OEMDRO150>
		<OEMLED150>0</OEMLED150>
		<OEMDRO151>0.</OEMDRO151>
		<OEMLED151>0</OEMLED151>
		<OEMDRO152>0.</OEMDRO152>
		<OEMLED152>0</OEMLED152>
		<OEMDRO153>0.</OEMDRO153>
		<OEMLED153>0</OEMLED153>
		<OEMDRO154>0.</OEMDRO154>
		<OEMLED154>0</OEMLED154>
		<OEMDRO155>0.</OEMDRO155>
		<OEMLED155>0</OEMLED155>
		<OEMDRO156>0.</OEMDRO156>
		<OEMLED156>0</OEMLED156>
		<OEMDRO157>0.</OEMDRO157>
		<OEMLED157>0</OEMLED157>
		<OEMDRO158>0.</OEMDRO158>
		<OEMLED158>0</OEMLED158>
		<OEMDRO159>0.</OEMDRO159>
		<OEMLED159>0</OEMLED159>
		<OEMDRO160>0.</OEMDRO160>
		<OEMLED160>0</OEMLED160>
		<OEMDRO161>0.</OEMDRO161>
		<OEMLED161>0</OEMLED161>
		<OEMDRO162>0.</OEMDRO162>
		<OEMLED162>0</OEMLED162>
		<OEMDRO163>0.</OEMDRO163>
		<OEMLED163>0</OEMLED163>
		<OEMDRO164>0.</OEMDRO164>
		<OEMLED164>0</OEMLED164>
		<OEMDRO165>0.</OEMDRO165>
		<OEMLED165>0</OEMLED165>
		<OEMDRO166>0.</OEMDRO166>
		<OEMLED166>0</OEMLED166>
		<OEMDRO167>0.</OEMDRO167>
		<OEMLED167>0</OEMLED167>
		<OEMDRO168>0.</OEMDRO168>
		<OEMLED168>0</OEMLED168>
		<OEMDRO169>0.</OEMDRO169>
		<OEMLED169>0</OEMLED169>
		<OEMDRO170>0.</OEMDRO170>
		<OEMLED170>0</OEMLED170>
		<OEMDRO171>0.</OEMDRO171>
		<OEMLED171>0</OEMLED171>
		<OEMDRO172>0.</OEMDRO172>
		<OEMLED172>0</OEMLED172>
		<OEMDRO173>0.</OEMDRO173>
		<OEMLED173>0</OEMLED173>
		<OEMDRO174>0.</OEMDRO174>
		<OEMLED174>0</OEMLED174>
		<OEMDRO175>0.</OEMDRO175>
		<OEMLED175>0</OEMLED175>
		<OEMDRO176>0.</OEMDRO176>
		<OEMLED176>0</OEMLED176>
		<OEMDRO177>0.</OEMDRO177>
		<OEMLED177>0</OEMLED177>
		<OEMDRO178>0.</OEMDRO178>
		<OEMLED178>0</OEMLED178>
		<OEMDRO179>0.</OEMDRO179>
		<OEMLED179>0</OEMLED179>
		<OEMDRO180>0.</OEMDRO180>
		<OEMLED180>0</OEMLED180>
		<OEMDRO181>0.</OEMDRO181>
		<OEMLED181>0</OEMLED181>
		<OEMDRO182>0.</OEMDRO182>
		<OEMLED182>0</OEMLED182>
		<OEMDRO183>0.</OEMDRO183>
		<OEMLED183>0</OEMLED183>
		<OEMDRO184>0.</OEMDRO184>
		<OEMLED184>0</OEMLED184>
		<OEMDRO185>0.</OEMDRO185>
		<OEMLED185>0</OEMLED185>
		<OEMDRO186>0.</OEMDRO186>
		<OEMLED186>0</OEMLED186>
		<OEMDRO187>0.</OEMDRO187>
		<OEMLED187>0</OEMLED187>
		<OEMDRO188>0.</OEMDRO188>
		<OEMLED188>0</OEMLED188>
		<OEMDRO189>0.</OEMDRO189>
		<OEMLED189>0</OEMLED189>
		<OEMDRO190>0.</OEMDRO190>
		<OEMLED190>0</OEMLED190>
		<OEMDRO191>0.</OEMDRO191>
		<OEMLED191>0</OEMLED191>
		<OEMDRO192>0.</OEMDRO192>
		<OEMLED192>0</OEMLED192>
		<OEMDRO193>0.</OEMDRO193>
		<OEMLED193>0</OEMLED193>
		<OEMDRO194>0.</OEMDRO194>
		<OEMLED194>0</OEMLED194>
		<OEMDRO195>0.</OEMDRO195>
		<OEMLED195>0</OEMLED195>
		<OEMDRO196>0.</OEMDRO196>
		<OEMLED196>0</OEMLED196>
		<OEMDRO197>0.</OEMDRO197>
		<OEMLED197>0</OEMLED197>
		<OEMDRO198>0.</OEMDRO198>
		<OEMLED198>0</OEMLED198>
		<OEMDRO199>0.</OEMDRO199>
		<OEMLED199>0</OEMLED199>
		<OEMDRO200>0.</OEMDRO200>
		<OEMLED200>0</OEMLED200>
		<OEMDRO201>0.</OEMDRO201>
		<OEMLED201>0</OEMLED201>
		<OEMDRO202>0.</OEMDRO202>
		<OEMLED202>0</OEMLED202>
		<OEMDRO203>0.</OEMDRO203>
		<OEMLED203>0</OEMLED203>
		<OEMDRO204>0.</OEMDRO204>
		<OEMLED204>0</OEMLED204>
		<OEMDRO205>0.</OEMDRO205>
		<OEMLED205>0</OEMLED205>
		<OEMDRO206>0.</OEMDRO206>
		<OEMLED206>0</OEMLED206>
		<OEMDRO207>0.</OEMDRO207>
		<OEMLED207>0</OEMLED207>
		<OEMDRO208>0.</OEMDRO208>
		<OEMLED208>0</OEMLED208>
		<OEMDRO209>0.</OEMDRO209>
		<OEMLED209>0</OEMLED209>
		<OEMDRO210>0.</OEMDRO210>
		<OEMLED210>0</OEMLED210>
		<OEMDRO211>0.</OEMDRO211>
		<OEMLED211>0</OEMLED211>
		<OEMDRO212>0.</OEMDRO212>
		<OEMLED212>0</OEMLED212>
		<OEMDRO213>0.</OEMDRO213>
		<OEMLED213>0</OEMLED213>
		<OEMDRO214>0.</OEMDRO214>
		<OEMLED214>0</OEMLED214>
		<OEMDRO215>0.</OEMDRO215>
		<OEMLED215>0</OEMLED215>
		<OEMDRO216>0.</OEMDRO216>
		<OEMLED216>0</OEMLED216>
		<OEMDRO217>0.</OEMDRO217>
		<OEMLED217>0</OEMLED217>
		<OEMDRO218>0.</OEMDRO218>
		<OEMLED218>0</OEMLED218>
		<OEMDRO219>0.</OEMDRO219>
		<OEMLED219>0</OEMLED219>
		<OEMDRO220>0.</OEMDRO220>
		<OEMLED220>0</OEMLED220>
		<OEMDRO221>0.</OEMDRO221>
		<OEMLED221>0</OEMLED221>
		<OEMDRO222>0.</OEMDRO222>
		<OEMLED222>0</OEMLED222>
		<OEMDRO223>0.</OEMDRO223>
		<OEMLED223>0</OEMLED223>
		<OEMDRO224>0.</OEMDRO224>
		<OEMLED224>0</OEMLED224>
		<OEMDRO225>0.</OEMDRO225>
		<OEMLED225>0</OEMLED225>
		<OEMDRO226>0.</OEMDRO226>
		<OEMLED226>0</OEMLED226>
		<OEMDRO227>0.</OEMDRO227>
		<OEMLED227>0</OEMLED227>
		<OEMDRO228>0.</OEMDRO228>
		<OEMLED228>0</OEMLED228>
		<OEMDRO229>0.</OEMDRO229>
		<OEMLED229>0</OEMLED229>
		<OEMDRO230>0.</OEMDRO230>
		<OEMLED230>0</OEMLED230>
		<OEMDRO231>0.</OEMDRO231>
		<OEMLED231>0</OEMLED231>
		<OEMDRO232>0.</OEMDRO232>
		<OEMLED232>0</OEMLED232>
		<OEMDRO233>0.</OEMDRO233>
		<OEMLED233>0</OEMLED233>
		<OEMDRO234>0.</OEMDRO234>
		<OEMLED234>0</OEMLED234>
		<OEMDRO235>0.</OEMDRO235>
		<OEMLED235>0</OEMLED235>
		<OEMDRO236>0.</OEMDRO236>
		<OEMLED236>0</OEMLED236>
		<OEMDRO237>0.</OEMDRO237>
		<OEMLED237>0</OEMLED237>
		<OEMDRO238>0.</OEMDRO238>
		<OEMLED238>0</OEMLED238>
		<OEMDRO239>0.</OEMDRO239>
		<OEMLED239>0</OEMLED239>
		<OEMDRO240>0.</OEMDRO240>
		<OEMLED240>0</OEMLED240>
		<OEMDRO241>0.</OEMDRO241>
		<OEMLED241>0</OEMLED241>
		<OEMDRO242>0.</OEMDRO242>
		<OEMLED242>0</OEMLED242>
		<OEMDRO243>0.</OEMDRO243>
		<OEMLED243>0</OEMLED243>
		<OEMDRO244>0.</OEMDRO244>
		<OEMLED244>0</OEMLED244>
		<OEMDRO245>0.</OEMDRO245>
		<OEMLED245>0</OEMLED245>
		<OEMDRO246>0.</OEMDRO246>
		<OEMLED246>0</OEMLED246>
		<OEMDRO247>0.</OEMDRO247>
		<OEMLED247>0</OEMLED247>
		<OEMDRO248>0.</OEMDRO248>
		<OEMLED248>0</OEMLED248>
		<OEMDRO249>0.</OEMDRO249>
		<OEMLED249>0</OEMLED249>
		<OEMDRO250>0.</OEMDRO250>
		<OEMLED250>0</OEMLED250>
		<OEMDRO251>0.</OEMDRO251>
		<OEMLED251>0</OEMLED251>
		<OEMDRO252>0.</OEMDRO252>
		<OEMLED252>0</OEMLED252>
		<OEMDRO253>0.</OEMDRO253>
		<OEMLED253>0</OEMLED253>
		<OEMDRO254>0.</OEMDRO254>
		<OEMLED254>0</OEMLED254>
		<OEMDRO255>0.</OEMDRO255>
		<OEMLED255>0</OEMLED255>
		<JogInc>1.e-003</JogInc>
		<JogSlide>0.1</JogSlide>
		<THCMax>1.</THCMax>
		<THCMin>0.2</THCMin>
		<RadiusA>0.</RadiusA>
		<RadiusB>0.</RadiusB>
		<RadiusC>0.</RadiusC>
		<LiftLevel>1.</LiftLevel>
		<LiftAngle>45.</LiftAngle>
		<InhibitDepth>0.</InhibitDepth>
		<LaserXGrid>0.</LaserXGrid>
		<LaserYGrid>0.</LaserYGrid>
		<LaserAGrid>0.</LaserAGrid>
		<JogInc0>1.</JogInc0>
		<JogInc1>0.1</JogInc1>
		<JogInc2>1.e-002</JogInc2>
		<JogInc3>1.e-003</JogInc3>
		<JogInc4>1.e-004</JogInc4>
		<JogInc5>1.</JogInc5>
		<JogInc6>0.1</JogInc6>
		<JogInc7>1.e-002</JogInc7>
		<JogInc8>1.e-003</JogInc8>
		<JogInc9>1.e-004</JogInc9>
		<THCSpeed>20.</THCSpeed>
		<BlendFactor>180.</BlendFactor>
		<M0RefHome>0</M0RefHome>
		<M1RefHome>0</M1RefHome>
		<M2RefHome>0</M2RefHome>
		<M3RefHome>0</M3RefHome>
		<M4RefHome>0</M4RefHome>
		<M5RefHome>0</M5RefHome>
		<MRU10>None</MRU10>
		<MRU9>None</MRU9>
		<MRU8>None</MRU8>
		<MRU7>None</MRU7>
		<MRU6>None</MRU6>
		<MRU5>None</MRU5>
		<MRU4>None</MRU4>
		<MRU3>C:\Mach3\GCode\Cutpocket.tap</MRU3>
		<MRU2>C:\Mach3\GCode\CutCircle.tap</MRU2>
		<MRU1>C:\Mach3\GCode\roadrunner.tap</MRU1>
		<ToolPersist>0</ToolPersist>
		<KeepRef>0</KeepRef>
		<TurnRevArc>1</TurnRevArc>
		<DROFont>Arial</DROFont>
		<LabelFont>Arial</LabelFont>
		<CodeFont>Arial</CodeFont>
		<PierceDelay>1.</PierceDelay>
		<VelPer3>5.</VelPer3>
		<TouchX>0.</TouchX>
		<G20X>0.</G20X>
		<G20Y>0.</G20Y>
		<G20Z>0.</G20Z>
		<G20A>0.</G20A>
		<G20B>0.</G20B>
		<G20C>0.</G20C>
		<FrontRear>0.</FrontRear>
		<EncJogAxis3>2</EncJogAxis3>
		<WarnOnReset>0</WarnOnReset>
		<NURBS>0</NURBS>
		<HiRes>0</HiRes>
		<DelinChar>12</DelinChar>
		<Rot360>0</Rot360>
		<SerialServo>0</SerialServo>
		<ToolLines>0</ToolLines>
		<UDP>0</UDP>
		<DefDir>C:\Mach3</DefDir>
		<NewPath>0</NewPath>
		<SafeZStop>0</SafeZStop>
		<SafeZType>0</SafeZType>
		<UseDiam>0</UseDiam>
		<SPINREV1>0</SPINREV1>
		<SPINREV2>0</SPINREV2>
		<SPINREV3>0</SPINREV3>
		<SPINREV4>0</SPINREV4>
		<SPEED5>25000</SPEED5>
		<LSPEED5>0</LSPEED5>
		<SPINREV5>0</SPINREV5>
		<SPEED6>25000</SPEED6>
		<LSPEED6>0</LSPEED6>
		<SPINREV6>0</SPINREV6>
		<SPEED7>25000</SPEED7>
		<LSPEED7>0</LSPEED7>
		<SPINREV7>0</SPINREV7>
		<SPEED8>25000</SPEED8>
		<LSPEED8>0</LSPEED8>
		<SPINREV8>0</SPINREV8>
		<SPEED9>25000</SPEED9>
		<LSPEED9>0</LSPEED9>
		<SPINREV9>0</SPINREV9>
		<SPEED10>25000</SPEED10>
		<LSPEED10>0</LSPEED10>
		<SPINREV10>0</SPINREV10>
		<SPEED11>25000</SPEED11>
		<LSPEED11>0</LSPEED11>
		<SPINREV11>0</SPINREV11>
		<SPEED12>25000</SPEED12>
		<LSPEED12>0</LSPEED12>
		<SPINREV12>0</SPINREV12>
		<SPEED13>25000</SPEED13>
		<LSPEED13>0</LSPEED13>
		<SPINREV13>0</SPINREV13>
		<SPEED14>25000</SPEED14>
		<LSPEED14>0</LSPEED14>
		<SPINREV14>0</SPINREV14>
		<SPEED15>25000</SPEED15>
		<LSPEED15>0</LSPEED15>
		<SPINREV15>0</SPINREV15>
		<SPEED16>25000</SPEED16>
		<LSPEED16>0</LSPEED16>
		<SPINREV16>0</SPINREV16>
		<SPEED17>25000</SPEED17>
		<LSPEED17>0</LSPEED17>
		<SPINREV17>0</SPINREV17>
		<SPEED18>25000</SPEED18>
		<LSPEED18>0</LSPEED18>
		<SPINREV18>0</SPINREV18>
		<SPEED19>25000</SPEED19>
		<LSPEED19>0</LSPEED19>
		<SPINREV19>0</SPINREV19>
		<SPEED20>25000</SPEED20>
		<LSPEED20>0</LSPEED20>
		<SPINREV20>0</SPINREV20>
		<SPEED21>25000</SPEED21>
		<LSPEED21>0</LSPEED21>
		<SPINREV21>0</SPINREV21>
		<SPEED22>25000</SPEED22>
		<LSPEED22>0</LSPEED22>
		<SPINREV22>0</SPINREV22>
		<SPEED23>25000</SPEED23>
		<LSPEED23>0</LSPEED23>
		<SPINREV23>0</SPINREV23>
		<SPEED24>25000</SPEED24>
		<LSPEED24>0</LSPEED24>
		<SPINREV24>0</SPINREV24>
		<SPEED25>25000</SPEED25>
		<LSPEED25>0</LSPEED25>
		<SPINREV25>0</SPINREV25>
		<m_SafeZ>0.</m_SafeZ>
		<EncJogAxis1>0</EncJogAxis1>
		<AutoCalcs>0</AutoCalcs>
		<CVUseAngle>0</CVUseAngle>
		<CVDegrees>0.</CVDegrees>
		<M30SpinOff>1</M30SpinOff>
		<Boxed>1</Boxed>
		<ButtonFont>Arial</ButtonFont>
		<OVSpinInc>10</OVSpinInc>
		<Syskey1>1</Syskey1>
		<ModPlug>0</ModPlug>
		<KeyClick>0</KeyClick>
		<THC5>0</THC5>
		<ModPort>1</ModPort>
		<AutoBaud>57600</AutoBaud>
		<AutoType1>0</AutoType1>
		<AutoType2>0</AutoType2>
		<AutoType3>0</AutoType3>
		<AutoType4>0</AutoType4>
		<AutoOn1>0</AutoOn1>
		<AutoOn2>0</AutoOn2>
		<AutoOn3>0</AutoOn3>
		<AutoOn4>0</AutoOn4>
		<AutoSlave1>0</AutoSlave1>
		<AutoSlave2>0</AutoSlave2>
		<AutoSlave3>0</AutoSlave3>
		<AutoSlave4>0</AutoSlave4>
		<AutoStart1>0</AutoStart1>
		<AutoStart2>0</AutoStart2>
		<AutoStart3>0</AutoStart3>
		<AutoStart4>0</AutoStart4>
		<AutoEnd1>0</AutoEnd1>
		<AutoEnd2>0</AutoEnd2>
		<AutoEnd3>0</AutoEnd3>
		<AutoEnd4>0</AutoEnd4>
		<RTSON>0</RTSON>
		<TIMEOUT>100</TIMEOUT>
		<Hertz>50</Hertz>
		<Prot>3</Prot>
		<ID>None</ID>
		<LastUser>Demo Version.</LastUser>
		<ROTSOFT>1</ROTSOFT>
		<PROBETLO>0</PROBETLO>
		<SlaveHome>0</SlaveHome>
		<JogHeat>0</JogHeat>
		<SPINRATIO1>1.</SPINRATIO1>
		<SPINRATIO2>1.</SPINRATIO2>
		<SPINRATIO3>1.</SPINRATIO3>
		<SPINRATIO4>1.</SPINRATIO4>
		<SPINRATIO5>1.</SPINRATIO5>
		<SPINRATIO6>1.</SPINRATIO6>
		<SPINRATIO7>1.</SPINRATIO7>
		<SPINRATIO8>1.</SPINRATIO8>
		<SPINRATIO9>1.</SPINRATIO9>
		<SPINRATIO10>1.</SPINRATIO10>
		<SPINRATIO11>1.</SPINRATIO11>
		<SPINRATIO12>1.</SPINRATIO12>
		<SPINRATIO13>1.</SPINRATIO13>
		<SPINRATIO14>1.</SPINRATIO14>
		<SPINRATIO15>1.</SPINRATIO15>
		<SPINRATIO16>1.</SPINRATIO16>
		<SPINRATIO17>1.</SPINRATIO17>
		<SPINRATIO18>1.</SPINRATIO18>
		<SPINRATIO19>1.</SPINRATIO19>
		<SPINRATIO20>1.</SPINRATIO20>
		<SPINRATIO21>1.</SPINRATIO21>
		<SPINRATIO22>1.</SPINRATIO22>
		<SPINRATIO23>1.</SPINRATIO23>
		<SPINRATIO24>1.</SPINRATIO24>
		<SPINRATIO25>1.</SPINRATIO25>
		<Running>1</Running>
		<TCPMODBUS>0</TCPMODBUS>
		<MenuOff>0</MenuOff>
		<ZBar>1</ZBar>
		<IgnoreMacros>0</IgnoreMacros>
		<DwellTrigger>0</DwellTrigger>
		<M7Delay>0.</M7Delay>
		<M8Delay>0.</M8Delay>
		<Encoder0>0</Encoder0>
		<Encoder1>0</Encoder1>
		<Encoder2>4</Encoder2>
		<Encoder3>0</Encoder3>
		<Encoder4>0</Encoder4>
		<Encoder5>0</Encoder5>
		<Encoder6>0</Encoder6>
		<M9After>0</M9After>
		<Steps6>1.</Steps6>
		<LockFROs>1</LockFROs>
		<OEMDRO256>0.</OEMDRO256>
		<OEMLED256>0</OEMLED256>
		<OEMDRO257>0.</OEMDRO257>
		<OEMLED257>0</OEMLED257>
		<OEMDRO258>0.</OEMDRO258>
		<OEMLED258>0</OEMLED258>
		<OEMDRO259>0.</OEMDRO259>
		<OEMLED259>0</OEMLED259>
		<OEMDRO260>0.</OEMDRO260>
		<OEMLED260>0</OEMLED260>
		<OEMDRO261>0.</OEMDRO261>
		<OEMLED261>0</OEMLED261>
		<OEMDRO262>0.</OEMDRO262>
		<OEMLED262>0</OEMLED262>
		<OEMDRO263>0.</OEMDRO263>
		<OEMLED263>0</OEMLED263>
		<OEMDRO264>0.</OEMDRO264>
		<OEMLED264>0</OEMLED264>
		<OEMDRO265>0.</OEMDRO265>
		<OEMLED265>0</OEMLED265>
		<OEMDRO266>0.</OEMDRO266>
		<OEMLED266>0</OEMLED266>
		<OEMDRO267>0.</OEMDRO267>
		<OEMLED267>0</OEMLED267>
		<OEMDRO268>0.</OEMDRO268>
		<OEMLED268>0</OEMLED268>
		<OEMDRO269>0.</OEMDRO269>
		<OEMLED269>0</OEMLED269>
		<OEMDRO270>0.</OEMDRO270>
		<OEMLED270>0</OEMLED270>
		<OEMDRO271>0.</OEMDRO271>
		<OEMLED271>0</OEMLED271>
		<OEMDRO272>0.</OEMDRO272>
		<OEMLED272>0</OEMLED272>
		<OEMDRO273>0.</OEMDRO273>
		<OEMLED273>0</OEMLED273>
		<OEMDRO274>0.</OEMDRO274>
		<OEMLED274>0</OEMLED274>
		<OEMDRO275>0.</OEMDRO275>
		<OEMLED275>0</OEMLED275>
		<OEMDRO276>0.</OEMDRO276>
		<OEMLED276>0</OEMLED276>
		<OEMDRO277>0.</OEMDRO277>
		<OEMLED277>0</OEMLED277>
		<OEMDRO278>0.</OEMDRO278>
		<OEMLED278>0</OEMLED278>
		<OEMDRO279>0.</OEMDRO279>
		<OEMLED279>0</OEMLED279>
		<OEMDRO280>0.</OEMDRO280>
		<OEMLED280>0</OEMLED280>
		<OEMDRO281>0.</OEMDRO281>
		<OEMLED281>0</OEMLED281>
		<OEMDRO282>0.</OEMDRO282>
		<OEMLED282>0</OEMLED282>
		<OEMDRO283>0.</OEMDRO283>
		<OEMLED283>0</OEMLED283>
		<OEMDRO284>0.</OEMDRO284>
		<OEMLED284>0</OEMLED284>
		<OEMDRO285>0.</OEMDRO285>
		<OEMLED285>0</OEMLED285>
		<OEMDRO286>0.</OEMDRO286>
		<OEMLED286>0</OEMLED286>
		<OEMDRO287>0.</OEMDRO287>
		<OEMLED287>0</OEMLED287>
		<OEMDRO288>0.</OEMDRO288>
		<OEMLED288>0</OEMLED288>
		<OEMDRO289>0.</OEMDRO289>
		<OEMLED289>0</OEMLED289>
		<OEMDRO290>0.</OEMDRO290>
		<OEMLED290>0</OEMLED290>
		<OEMDRO291>0.</OEMDRO291>
		<OEMLED291>0</OEMLED291>
		<OEMDRO292>0.</OEMDRO292>
		<OEMLED292>0</OEMLED292>
		<OEMDRO293>0.</OEMDRO293>
		<OEMLED293>0</OEMLED293>
		<OEMDRO294>0.</OEMDRO294>
		<OEMLED294>0</OEMLED294>
		<OEMDRO295>0.</OEMDRO295>
		<OEMLED295>0</OEMLED295>
		<OEMDRO296>0.</OEMDRO296>
		<OEMLED296>0</OEMLED296>
		<OEMDRO297>0.</OEMDRO297>
		<OEMLED297>0</OEMLED297>
		<OEMDRO298>0.</OEMDRO298>
		<OEMLED298>0</OEMLED298>
		<OEMDRO299>0.</OEMDRO299>
		<OEMLED299>0</OEMLED299>
		<OEMDRO2100>0.</OEMDRO2100>
		<OEMLED2100>0</OEMLED2100>
		<OEMDRO2101>0.</OEMDRO2101>
		<OEMLED2101>0</OEMLED2101>
		<OEMDRO2102>0.</OEMDRO2102>
		<OEMLED2102>0</OEMLED2102>
		<OEMDRO2103>0.</OEMDRO2103>
		<OEMLED2103>0</OEMLED2103>
		<OEMDRO2104>0.</OEMDRO2104>
		<OEMLED2104>0</OEMLED2104>
		<OEMDRO2105>0.</OEMDRO2105>
		<OEMLED2105>0</OEMLED2105>
		<OEMDRO2106>0.</OEMDRO2106>
		<OEMLED2106>0</OEMLED2106>
		<OEMDRO2107>0.</OEMDRO2107>
		<OEMLED2107>0</OEMLED2107>
		<OEMDRO2108>0.</OEMDRO2108>
		<OEMLED2108>0</OEMLED2108>
		<OEMDRO2109>0.</OEMDRO2109>
		<OEMLED2109>0</OEMLED2109>
		<OEMDRO2110>0.</OEMDRO2110>
		<OEMLED2110>0</OEMLED2110>
		<OEMDRO2111>0.</OEMDRO2111>
		<OEMLED2111>0</OEMLED2111>
		<OEMDRO2112>0.</OEMDRO2112>
		<OEMLED2112>0</OEMLED2112>
		<OEMDRO2113>0.</OEMDRO2113>
		<OEMLED2113>0</OEMLED2113>
		<OEMDRO2114>0.</OEMDRO2114>
		<OEMLED2114>0</OEMLED2114>
		<OEMDRO2115>0.</OEMDRO2115>
		<OEMLED2115>0</OEMLED2115>
		<OEMDRO2116>0.</OEMDRO2116>
		<OEMLED2116>0</OEMLED2116>
		<OEMDRO2117>0.</OEMDRO2117>
		<OEMLED2117>0</OEMLED2117>
		<OEMDRO2118>0.</OEMDRO2118>
		<OEMLED2118>0</OEMLED2118>
		<OEMDRO2119>0.</OEMDRO2119>
		<OEMLED2119>0</OEMLED2119>
		<OEMDRO2120>0.</OEMDRO2120>
		<OEMLED2120>0</OEMLED2120>
		<OEMDRO2121>0.</OEMDRO2121>
		<OEMLED2121>0</OEMLED2121>
		<OEMDRO2122>0.</OEMDRO2122>
		<OEMLED2122>0</OEMLED2122>
		<OEMDRO2123>0.</OEMDRO2123>
		<OEMLED2123>0</OEMLED2123>
		<OEMDRO2124>0.</OEMDRO2124>
		<OEMLED2124>0</OEMLED2124>
		<OEMDRO2125>0.</OEMDRO2125>
		<OEMLED2125>0</OEMLED2125>
		<OEMDRO2126>0.</OEMDRO2126>
		<OEMLED2126>0</OEMLED2126>
		<OEMDRO2127>0.</OEMDRO2127>
		<OEMLED2127>0</OEMLED2127>
		<OEMDRO2128>0.</OEMDRO2128>
		<OEMLED2128>0</OEMLED2128>
		<OEMDRO2129>0.</OEMDRO2129>
		<OEMLED2129>0</OEMLED2129>
		<OEMDRO2130>0.</OEMDRO2130>
		<OEMLED2130>0</OEMLED2130>
		<OEMDRO2131>0.</OEMDRO2131>
		<OEMLED2131>0</OEMLED2131>
		<OEMDRO2132>0.</OEMDRO2132>
		<OEMLED2132>0</OEMLED2132>
		<OEMDRO2133>0.</OEMDRO2133>
		<OEMLED2133>0</OEMLED2133>
		<OEMDRO2134>0.</OEMDRO2134>
		<OEMLED2134>0</OEMLED2134>
		<OEMDRO2135>0.</OEMDRO2135>
		<OEMLED2135>0</OEMLED2135>
		<OEMDRO2136>0.</OEMDRO2136>
		<OEMLED2136>0</OEMLED2136>
		<OEMDRO2137>0.</OEMDRO2137>
		<OEMLED2137>0</OEMLED2137>
		<OEMDRO2138>0.</OEMDRO2138>
		<OEMLED2138>0</OEMLED2138>
		<OEMDRO2139>0.</OEMDRO2139>
		<OEMLED2139>0</OEMLED2139>
		<OEMDRO2140>0.</OEMDRO2140>
		<OEMLED2140>0</OEMLED2140>
		<OEMDRO2141>0.</OEMDRO2141>
		<OEMLED2141>0</OEMLED2141>
		<OEMDRO2142>0.</OEMDRO2142>
		<OEMLED2142>0</OEMLED2142>
		<OEMDRO2143>0.</OEMDRO2143>
		<OEMLED2143>0</OEMLED2143>
		<OEMDRO2144>0.</OEMDRO2144>
		<OEMLED2144>0</OEMLED2144>
		<OEMDRO2145>0.</OEMDRO2145>
		<OEMLED2145>0</OEMLED2145>
		<OEMDRO2146>0.</OEMDRO2146>
		<OEMLED2146>0</OEMLED2146>
		<OEMDRO2147>0.</OEMDRO2147>
		<OEMLED2147>0</OEMLED2147>
		<OEMDRO2148>0.</OEMDRO2148>
		<OEMLED2148>0</OEMLED2148>
		<OEMDRO2149>0.</OEMDRO2149>
		<OEMLED2149>0</OEMLED2149>
		<OEMDRO2150>0.</OEMDRO2150>
		<OEMLED2150>0</OEMLED2150>
		<OEMDRO2151>0.</OEMDRO2151>
		<OEMLED2151>0</OEMLED2151>
		<OEMDRO2152>0.</OEMDRO2152>
		<OEMLED2152>0</OEMLED2152>
		<OEMDRO2153>0.</OEMDRO2153>
		<OEMLED2153>0</OEMLED2153>
		<OEMDRO2154>0.</OEMDRO2154>
		<OEMLED2154>0</OEMLED2154>
		<OEMDRO2155>0.</OEMDRO2155>
		<OEMLED2155>0</OEMLED2155>
		<OEMDRO2156>0.</OEMDRO2156>
		<OEMLED2156>0</OEMLED2156>
		<OEMDRO2157>0.</OEMDRO2157>
		<OEMLED2157>0</OEMLED2157>
		<OEMDRO2158>0.</OEMDRO2158>
		<OEMLED2158>0</OEMLED2158>
		<OEMDRO2159>0.</OEMDRO2159>
		<OEMLED2159>0</OEMLED2159>
		<OEMDRO2160>0.</OEMDRO2160>
		<OEMLED2160>0</OEMLED2160>
		<OEMDRO2161>0.</OEMDRO2161>
		<OEMLED2161>0</OEMLED2161>
		<OEMDRO2162>0.</OEMDRO2162>
		<OEMLED2162>0</OEMLED2162>
		<OEMDRO2163>0.</OEMDRO2163>
		<OEMLED2163>0</OEMLED2163>
		<OEMDRO2164>0.</OEMDRO2164>
		<OEMLED2164>0</OEMLED2164>
		<OEMDRO2165>0.</OEMDRO2165>
		<OEMLED2165>0</OEMLED2165>
		<OEMDRO2166>0.</OEMDRO2166>
		<OEMLED2166>0</OEMLED2166>
		<OEMDRO2167>0.</OEMDRO2167>
		<OEMLED2167>0</OEMLED2167>
		<OEMDRO2168>0.</OEMDRO2168>
		<OEMLED2168>0</OEMLED2168>
		<OEMDRO2169>0.</OEMDRO2169>
		<OEMLED2169>0</OEMLED2169>
		<OEMDRO2170>0.</OEMDRO2170>
		<OEMLED2170>0</OEMLED2170>
		<OEMDRO2171>0.</OEMDRO2171>
		<OEMLED2171>0</OEMLED2171>
		<OEMDRO2172>0.</OEMDRO2172>
		<OEMLED2172>0</OEMLED2172>
		<OEMDRO2173>0.</OEMDRO2173>
		<OEMLED2173>0</OEMLED2173>
		<OEMDRO2174>0.</OEMDRO2174>
		<OEMLED2174>0</OEMLED2174>
		<OEMDRO2175>0.</OEMDRO2175>
		<OEMLED2175>0</OEMLED2175>
		<OEMDRO2176>0.</OEMDRO2176>
		<OEMLED2176>0</OEMLED2176>
		<OEMDRO2177>0.</OEMDRO2177>
		<OEMLED2177>0</OEMLED2177>
		<OEMDRO2178>0.</OEMDRO2178>
		<OEMLED2178>0</OEMLED2178>
		<OEMDRO2179>0.</OEMDRO2179>
		<OEMLED2179>0</OEMLED2179>
		<OEMDRO2180>0.</OEMDRO2180>
		<OEMLED2180>0</OEMLED2180>
		<OEMDRO2181>0.</OEMDRO2181>
		<OEMLED2181>0</OEMLED2181>
		<OEMDRO2182>0.</OEMDRO2182>
		<OEMLED2182>0</OEMLED2182>
		<OEMDRO2183>0.</OEMDRO2183>
		<OEMLED2183>0</OEMLED2183>
		<OEMDRO2184>0.</OEMDRO2184>
		<OEMLED2184>0</OEMLED2184>
		<OEMDRO2185>0.</OEMDRO2185>
		<OEMLED2185>0</OEMLED2185>
		<OEMDRO2186>0.</OEMDRO2186>
		<OEMLED2186>0</OEMLED2186>
		<OEMDRO2187>0.</OEMDRO2187>
		<OEMLED2187>0</OEMLED2187>
		<OEMDRO2188>0.</OEMDRO2188>
		<OEMLED2188>0</OEMLED2188>
		<OEMDRO2189>0.</OEMDRO2189>
		<OEMLED2189>0</OEMLED2189>
		<OEMDRO2190>0.</OEMDRO2190>
		<OEMLED2190>0</OEMLED2190>
		<OEMDRO2191>0.</OEMDRO2191>
		<OEMLED2191>0</OEMLED2191>
		<OEMDRO2192>0.</OEMDRO2192>
		<OEMLED2192>0</OEMLED2192>
		<OEMDRO2193>0.</OEMDRO2193>
		<OEMLED2193>0</OEMLED2193>
		<OEMDRO2194>0.</OEMDRO2194>
		<OEMLED2194>0</OEMLED2194>
		<OEMDRO2195>0.</OEMDRO2195>
		<OEMLED2195>0</OEMLED2195>
		<OEMDRO2196>0.</OEMDRO2196>
		<OEMLED2196>0</OEMLED2196>
		<OEMDRO2197>0.</OEMDRO2197>
		<OEMLED2197>0</OEMLED2197>
		<OEMDRO2198>0.</OEMDRO2198>
		<OEMLED2198>0</OEMLED2198>
		<OEMDRO2199>0.</OEMDRO2199>
		<OEMLED2199>0</OEMLED2199>
		<OEMDRO2200>0.</OEMDRO2200>
		<OEMLED2200>0</OEMLED2200>
		<OEMDRO2201>0.</OEMDRO2201>
		<OEMLED2201>0</OEMLED2201>
		<OEMDRO2202>0.</OEMDRO2202>
		<OEMLED2202>0</OEMLED2202>
		<OEMDRO2203>0.</OEMDRO2203>
		<OEMLED2203>0</OEMLED2203>
		<OEMDRO2204>0.</OEMDRO2204>
		<OEMLED2204>0</OEMLED2204>
		<OEMDRO2205>0.</OEMDRO2205>
		<OEMLED2205>0</OEMLED2205>
		<OEMDRO2206>0.</OEMDRO2206>
		<OEMLED2206>0</OEMLED2206>
		<OEMDRO2207>0.</OEMDRO2207>
		<OEMLED2207>0</OEMLED2207>
		<OEMDRO2208>0.</OEMDRO2208>
		<OEMLED2208>0</OEMLED2208>
		<OEMDRO2209>0.</OEMDRO2209>
		<OEMLED2209>0</OEMLED2209>
		<OEMDRO2210>0.</OEMDRO2210>
		<OEMLED2210>0</OEMLED2210>
		<OEMDRO2211>0.</OEMDRO2211>
		<OEMLED2211>0</OEMLED2211>
		<OEMDRO2212>0.</OEMDRO2212>
		<OEMLED2212>0</OEMLED2212>
		<OEMDRO2213>0.</OEMDRO2213>
		<OEMLED2213>0</OEMLED2213>
		<OEMDRO2214>0.</OEMDRO2214>
		<OEMLED2214>0</OEMLED2214>
		<OEMDRO2215>0.</OEMDRO2215>
		<OEMLED2215>0</OEMLED2215>
		<OEMDRO2216>0.</OEMDRO2216>
		<OEMLED2216>0</OEMLED2216>
		<OEMDRO2217>0.</OEMDRO2217>
		<OEMLED2217>0</OEMLED2217>
		<OEMDRO2218>0.</OEMDRO2218>
		<OEMLED2218>0</OEMLED2218>
		<OEMDRO2219>0.</OEMDRO2219>
		<OEMLED2219>0</OEMLED2219>
		<OEMDRO2220>0.</OEMDRO2220>
		<OEMLED2220>0</OEMLED2220>
		<OEMDRO2221>0.</OEMDRO2221>
		<OEMLED2221>0</OEMLED2221>
		<OEMDRO2222>0.</OEMDRO2222>
		<OEMLED2222>0</OEMLED2222>
		<OEMDRO2223>0.</OEMDRO2223>
		<OEMLED2223>0</OEMLED2223>
		<OEMDRO2224>0.</OEMDRO2224>
		<OEMLED2224>0</OEMLED2224>
		<OEMDRO2225>0.</OEMDRO2225>
		<OEMLED2225>0</OEMLED2225>
		<OEMDRO2226>0.</OEMDRO2226>
		<OEMLED2226>0</OEMLED2226>
		<OEMDRO2227>0.</OEMDRO2227>
		<OEMLED2227>0</OEMLED2227>
		<OEMDRO2228>0.</OEMDRO2228>
		<OEMLED2228>0</OEMLED2228>
		<OEMDRO2229>0.</OEMDRO2229>
		<OEMLED2229>0</OEMLED2229>
		<OEMDRO2230>0.</OEMDRO2230>
		<OEMLED2230>0</OEMLED2230>
		<OEMDRO2231>0.</OEMDRO2231>
		<OEMLED2231>0</OEMLED2231>
		<OEMDRO2232>0.</OEMDRO2232>
		<OEMLED2232>0</OEMLED2232>
		<OEMDRO2233>0.</OEMDRO2233>
		<OEMLED2233>0</OEMLED2233>
		<OEMDRO2234>0.</OEMDRO2234>
		<OEMLED2234>0</OEMLED2234>
		<OEMDRO2235>0.</OEMDRO2235>
		<OEMLED2235>0</OEMLED2235>
		<OEMDRO2236>0.</OEMDRO2236>
		<OEMLED2236>0</OEMLED2236>
		<OEMDRO2237>0.</OEMDRO2237>
		<OEMLED2237>0</OEMLED2237>
		<OEMDRO2238>0.</OEMDRO2238>
		<OEMLED2238>0</OEMLED2238>
		<OEMDRO2239>0.</OEMDRO2239>
		<OEMLED2239>0</OEMLED2239>
		<OEMDRO2240>0.</OEMDRO2240>
		<OEMLED2240>0</OEMLED2240>
		<OEMDRO2241>0.</OEMDRO2241>
		<OEMLED2241>0</OEMLED2241>
		<OEMDRO2242>0.</OEMDRO2242>
		<OEMLED2242>0</OEMLED2242>
		<OEMDRO2243>0.</OEMDRO2243>
		<OEMLED2243>0</OEMLED2243>
		<OEMDRO2244>0.</OEMDRO2244>
		<OEMLED2244>0</OEMLED2244>
		<OEMDRO2245>0.</OEMDRO2245>
		<OEMLED2245>0</OEMLED2245>
		<OEMDRO2246>0.</OEMDRO2246>
		<OEMLED2246>0</OEMLED2246>
		<OEMDRO2247>0.</OEMDRO2247>
		<OEMLED2247>0</OEMLED2247>
		<OEMDRO2248>0.</OEMDRO2248>
		<OEMLED2248>0</OEMLED2248>
		<OEMDRO2249>0.</OEMDRO2249>
		<OEMLED2249>0</OEMLED2249>
		<OEMDRO2250>0.</OEMDRO2250>
		<OEMLED2250>0</OEMLED2250>
		<OEMDRO2251>0.</OEMDRO2251>
		<OEMLED2251>0</OEMLED2251>
		<OEMDRO2252>0.</OEMDRO2252>
		<OEMLED2252>0</OEMLED2252>
		<OEMDRO2253>0.</OEMDRO2253>
		<OEMLED2253>0</OEMLED2253>
		<OEMDRO2254>0.</OEMDRO2254>
		<OEMLED2254>0</OEMLED2254>
		<OEMDRO2255>0.</OEMDRO2255>
		<OEMLED2255>0</OEMLED2255>
		<OEMDRO2256>0.</OEMDRO2256>
		<OEMLED2256>0</OEMLED2256>
		<OEMDRO2257>0.</OEMDRO2257>
		<OEMLED2257>0</OEMLED2257>
		<OEMDRO2258>0.</OEMDRO2258>
		<OEMLED2258>0</OEMLED2258>
		<OEMDRO2259>0.</OEMDRO2259>
		<OEMLED2259>0</OEMLED2259>
		<OEMDRO2260>0.</OEMDRO2260>
		<OEMLED2260>0</OEMLED2260>
		<OEMDRO2261>0.</OEMDRO2261>
		<OEMLED2261>0</OEMLED2261>
		<OEMDRO2262>0.</OEMDRO2262>
		<OEMLED2262>0</OEMLED2262>
		<OEMDRO2263>0.</OEMDRO2263>
		<OEMLED2263>0</OEMLED2263>
		<OEMDRO2264>0.</OEMDRO2264>
		<OEMLED2264>0</OEMLED2264>
		<OEMDRO2265>0.</OEMDRO2265>
		<OEMLED2265>0</OEMLED2265>
		<OEMDRO2266>0.</OEMDRO2266>
		<OEMLED2266>0</OEMLED2266>
		<OEMDRO2267>0.</OEMDRO2267>
		<OEMLED2267>0</OEMLED2267>
		<OEMDRO2268>0.</OEMDRO2268>
		<OEMLED2268>0</OEMLED2268>
		<OEMDRO2269>0.</OEMDRO2269>
		<OEMLED2269>0</OEMLED2269>
		<OEMDRO2270>0.</OEMDRO2270>
		<OEMLED2270>0</OEMLED2270>
		<OEMDRO2271>0.</OEMDRO2271>
		<OEMLED2271>0</OEMLED2271>
		<OEMDRO2272>0.</OEMDRO2272>
		<OEMLED2272>0</OEMLED2272>
		<OEMDRO2273>0.</OEMDRO2273>
		<OEMLED2273>0</OEMLED2273>
		<OEMDRO2274>0.</OEMDRO2274>
		<OEMLED2274>0</OEMLED2274>
		<OEMDRO2275>0.</OEMDRO2275>
		<OEMLED2275>0</OEMLED2275>
		<OEMDRO2276>0.</OEMDRO2276>
		<OEMLED2276>0</OEMLED2276>
		<OEMDRO2277>0.</OEMDRO2277>
		<OEMLED2277>0</OEMLED2277>
		<OEMDRO2278>0.</OEMDRO2278>
		<OEMLED2278>0</OEMLED2278>
		<OEMDRO2279>0.</OEMDRO2279>
		<OEMLED2279>0</OEMLED2279>
		<OEMDRO2280>0.</OEMDRO2280>
		<OEMLED2280>0</OEMLED2280>
		<OEMDRO2281>0.</OEMDRO2281>
		<OEMLED2281>0</OEMLED2281>
		<OEMDRO2282>0.</OEMDRO2282>
		<OEMLED2282>0</OEMLED2282>
		<OEMDRO2283>0.</OEMDRO2283>
		<OEMLED2283>0</OEMLED2283>
		<OEMDRO2284>0.</OEMDRO2284>
		<OEMLED2284>0</OEMLED2284>
		<OEMDRO2285>0.</OEMDRO2285>
		<OEMLED2285>0</OEMLED2285>
		<OEMDRO2286>0.</OEMDRO2286>
		<OEMLED2286>0</OEMLED2286>
		<OEMDRO2287>0.</OEMDRO2287>
		<OEMLED2287>0</OEMLED2287>
		<OEMDRO2288>0.</OEMDRO2288>
		<OEMLED2288>0</OEMLED2288>
		<OEMDRO2289>0.</OEMDRO2289>
		<OEMLED2289>0</OEMLED2289>
		<OEMDRO2290>0.</OEMDRO2290>
		<OEMLED2290>0</OEMLED2290>
		<OEMDRO2291>0.</OEMDRO2291>
		<OEMLED2291>0</OEMLED2291>
		<OEMDRO2292>0.</OEMDRO2292>
		<OEMLED2292>0</OEMLED2292>
		<OEMDRO2293>0.</OEMDRO2293>
		<OEMLED2293>0</OEMLED2293>
		<OEMDRO2294>0.</OEMDRO2294>
		<OEMLED2294>0</OEMLED2294>
		<OEMDRO2295>0.</OEMDRO2295>
		<OEMLED2295>0</OEMLED2295>
		<OEMDRO2296>0.</OEMDRO2296>
		<OEMLED2296>0</OEMLED2296>
		<OEMDRO2297>0.</OEMDRO2297>
		<OEMLED2297>0</OEMLED2297>
		<OEMDRO2298>0.</OEMDRO2298>
		<OEMLED2298>0</OEMLED2298>
		<OEMDRO2299>0.</OEMDRO2299>
		<OEMLED2299>0</OEMLED2299>
		<OEMDRO2300>0.</OEMDRO2300>
		<OEMLED2300>0</OEMLED2300>
		<OEMDRO2301>0.</OEMDRO2301>
		<OEMLED2301>0</OEMLED2301>
		<OEMDRO2302>0.</OEMDRO2302>
		<OEMLED2302>0</OEMLED2302>
		<OEMDRO2303>0.</OEMDRO2303>
		<OEMLED2303>0</OEMLED2303>
		<OEMDRO2304>0.</OEMDRO2304>
		<OEMLED2304>0</OEMLED2304>
		<OEMDRO2305>0.</OEMDRO2305>
		<OEMLED2305>0</OEMLED2305>
		<OEMDRO2306>0.</OEMDRO2306>
		<OEMLED2306>0</OEMLED2306>
		<OEMDRO2307>0.</OEMDRO2307>
		<OEMLED2307>0</OEMLED2307>
		<OEMDRO2308>0.</OEMDRO2308>
		<OEMLED2308>0</OEMLED2308>
		<OEMDRO2309>0.</OEMDRO2309>
		<OEMLED2309>0</OEMLED2309>
		<OEMDRO2310>0.</OEMDRO2310>
		<OEMLED2310>0</OEMLED2310>
		<OEMDRO2311>0.</OEMDRO2311>
		<OEMLED2311>0</OEMLED2311>
		<OEMDRO2312>0.</OEMDRO2312>
		<OEMLED2312>0</OEMLED2312>
		<OEMDRO2313>0.</OEMDRO2313>
		<OEMLED2313>0</OEMLED2313>
		<OEMDRO2314>0.</OEMDRO2314>
		<OEMLED2314>0</OEMLED2314>
		<OEMDRO2315>0.</OEMDRO2315>
		<OEMLED2315>0</OEMLED2315>
		<OEMDRO2316>0.</OEMDRO2316>
		<OEMLED2316>0</OEMLED2316>
		<OEMDRO2317>0.</OEMDRO2317>
		<OEMLED2317>0</OEMLED2317>
		<OEMDRO2318>0.</OEMDRO2318>
		<OEMLED2318>0</OEMLED2318>
		<OEMDRO2319>0.</OEMDRO2319>
		<OEMLED2319>0</OEMLED2319>
		<OEMDRO2320>0.</OEMDRO2320>
		<OEMLED2320>0</OEMLED2320>
		<OEMDRO2321>0.</OEMDRO2321>
		<OEMLED2321>0</OEMLED2321>
		<OEMDRO2322>0.</OEMDRO2322>
		<OEMLED2322>0</OEMLED2322>
		<OEMDRO2323>0.</OEMDRO2323>
		<OEMLED2323>0</OEMLED2323>
		<OEMDRO2324>0.</OEMDRO2324>
		<OEMLED2324>0</OEMLED2324>
		<OEMDRO2325>0.</OEMDRO2325>
		<OEMLED2325>0</OEMLED2325>
		<OEMDRO2326>0.</OEMDRO2326>
		<OEMLED2326>0</OEMLED2326>
		<OEMDRO2327>0.</OEMDRO2327>
		<OEMLED2327>0</OEMLED2327>
		<OEMDRO2328>0.</OEMDRO2328>
		<OEMLED2328>0</OEMLED2328>
		<OEMDRO2329>0.</OEMDRO2329>
		<OEMLED2329>0</OEMLED2329>
		<OEMDRO2330>0.</OEMDRO2330>
		<OEMLED2330>0</OEMLED2330>
		<OEMDRO2331>0.</OEMDRO2331>
		<OEMLED2331>0</OEMLED2331>
		<OEMDRO2332>0.</OEMDRO2332>
		<OEMLED2332>0</OEMLED2332>
		<OEMDRO2333>0.</OEMDRO2333>
		<OEMLED2333>0</OEMLED2333>
		<OEMDRO2334>0.</OEMDRO2334>
		<OEMLED2334>0</OEMLED2334>
		<OEMDRO2335>0.</OEMDRO2335>
		<OEMLED2335>0</OEMLED2335>
		<OEMDRO2336>0.</OEMDRO2336>
		<OEMLED2336>0</OEMLED2336>
		<OEMDRO2337>0.</OEMDRO2337>
		<OEMLED2337>0</OEMLED2337>
		<OEMDRO2338>0.</OEMDRO2338>
		<OEMLED2338>0</OEMLED2338>
		<OEMDRO2339>0.</OEMDRO2339>
		<OEMLED2339>0</OEMLED2339>
		<OEMDRO2340>0.</OEMDRO2340>
		<OEMLED2340>0</OEMLED2340>
		<OEMDRO2341>0.</OEMDRO2341>
		<OEMLED2341>0</OEMLED2341>
		<OEMDRO2342>0.</OEMDRO2342>
		<OEMLED2342>0</OEMLED2342>
		<OEMDRO2343>0.</OEMDRO2343>
		<OEMLED2343>0</OEMLED2343>
		<OEMDRO2344>0.</OEMDRO2344>
		<OEMLED2344>0</OEMLED2344>
		<OEMDRO2345>0.</OEMDRO2345>
		<OEMLED2345>0</OEMLED2345>
		<OEMDRO2346>0.</OEMDRO2346>
		<OEMLED2346>0</OEMLED2346>
		<OEMDRO2347>0.</OEMDRO2347>
		<OEMLED2347>0</OEMLED2347>
		<OEMDRO2348>0.</OEMDRO2348>
		<OEMLED2348>0</OEMLED2348>
		<OEMDRO2349>0.</OEMDRO2349>
		<OEMLED2349>0</OEMLED2349>
		<OEMDRO2350>0.</OEMDRO2350>
		<OEMLED2350>0</OEMLED2350>
		<OEMDRO2351>0.</OEMDRO2351>
		<OEMLED2351>0</OEMLED2351>
		<OEMDRO2352>0.</OEMDRO2352>
		<OEMLED2352>0</OEMLED2352>
		<OEMDRO2353>0.</OEMDRO2353>
		<OEMLED2353>0</OEMLED2353>
		<OEMDRO2354>0.</OEMDRO2354>
		<OEMLED2354>0</OEMLED2354>
		<OEMDRO2355>0.</OEMDRO2355>
		<OEMLED2355>0</OEMLED2355>
		<OEMDRO2356>0.</OEMDRO2356>
		<OEMLED2356>0</OEMLED2356>
		<OEMDRO2357>0.</OEMDRO2357>
		<OEMLED2357>0</OEMLED2357>
		<OEMDRO2358>0.</OEMDRO2358>
		<OEMLED2358>0</OEMLED2358>
		<OEMDRO2359>0.</OEMDRO2359>
		<OEMLED2359>0</OEMLED2359>
		<OEMDRO2360>0.</OEMDRO2360>
		<OEMLED2360>0</OEMLED2360>
		<OEMDRO2361>0.</OEMDRO2361>
		<OEMLED2361>0</OEMLED2361>
		<OEMDRO2362>0.</OEMDRO2362>
		<OEMLED2362>0</OEMLED2362>
		<OEMDRO2363>0.</OEMDRO2363>
		<OEMLED2363>0</OEMLED2363>
		<OEMDRO2364>0.</OEMDRO2364>
		<OEMLED2364>0</OEMLED2364>
		<OEMDRO2365>0.</OEMDRO2365>
		<OEMLED2365>0</OEMLED2365>
		<OEMDRO2366>0.</OEMDRO2366>
		<OEMLED2366>0</OEMLED2366>
		<OEMDRO2367>0.</OEMDRO2367>
		<OEMLED2367>0</OEMLED2367>
		<OEMDRO2368>0.</OEMDRO2368>
		<OEMLED2368>0</OEMLED2368>
		<OEMDRO2369>0.</OEMDRO2369>
		<OEMLED2369>0</OEMLED2369>
		<OEMDRO2370>0.</OEMDRO2370>
		<OEMLED2370>0</OEMLED2370>
		<OEMDRO2371>0.</OEMDRO2371>
		<OEMLED2371>0</OEMLED2371>
		<OEMDRO2372>0.</OEMDRO2372>
		<OEMLED2372>0</OEMLED2372>
		<OEMDRO2373>0.</OEMDRO2373>
		<OEMLED2373>0</OEMLED2373>
		<OEMDRO2374>0.</OEMDRO2374>
		<OEMLED2374>0</OEMLED2374>
		<OEMDRO2375>0.</OEMDRO2375>
		<OEMLED2375>0</OEMLED2375>
		<OEMDRO2376>0.</OEMDRO2376>
		<OEMLED2376>0</OEMLED2376>
		<OEMDRO2377>0.</OEMDRO2377>
		<OEMLED2377>0</OEMLED2377>
		<OEMDRO2378>0.</OEMDRO2378>
		<OEMLED2378>0</OEMLED2378>
		<OEMDRO2379>0.</OEMDRO2379>
		<OEMLED2379>0</OEMLED2379>
		<OEMDRO2380>0.</OEMDRO2380>
		<OEMLED2380>0</OEMLED2380>
		<OEMDRO2381>0.</OEMDRO2381>
		<OEMLED2381>0</OEMLED2381>
		<OEMDRO2382>0.</OEMDRO2382>
		<OEMLED2382>0</OEMLED2382>
		<OEMDRO2383>0.</OEMDRO2383>
		<OEMLED2383>0</OEMLED2383>
		<OEMDRO2384>0.</OEMDRO2384>
		<OEMLED2384>0</OEMLED2384>
		<OEMDRO2385>0.</OEMDRO2385>
		<OEMLED2385>0</OEMLED2385>
		<OEMDRO2386>0.</OEMDRO2386>
		<OEMLED2386>0</OEMLED2386>
		<OEMDRO2387>0.</OEMDRO2387>
		<OEMLED2387>0</OEMLED2387>
		<OEMDRO2388>0.</OEMDRO2388>
		<OEMLED2388>0</OEMLED2388>
		<OEMDRO2389>0.</OEMDRO2389>
		<OEMLED2389>0</OEMLED2389>
		<OEMDRO2390>0.</OEMDRO2390>
		<OEMLED2390>0</OEMLED2390>
		<OEMDRO2391>0.</OEMDRO2391>
		<OEMLED2391>0</OEMLED2391>
		<OEMDRO2392>0.</OEMDRO2392>
		<OEMLED2392>0</OEMLED2392>
		<OEMDRO2393>0.</OEMDRO2393>
		<OEMLED2393>0</OEMLED2393>
		<OEMDRO2394>0.</OEMDRO2394>
		<OEMLED2394>0</OEMLED2394>
		<OEMDRO2395>0.</OEMDRO2395>
		<OEMLED2395>0</OEMLED2395>
		<OEMDRO2396>0.</OEMDRO2396>
		<OEMLED2396>0</OEMLED2396>
		<OEMDRO2397>0.</OEMDRO2397>
		<OEMLED2397>0</OEMLED2397>
		<OEMDRO2398>0.</OEMDRO2398>
		<OEMLED2398>0</OEMLED2398>
		<OEMDRO2399>0.</OEMDRO2399>
		<OEMLED2399>0</OEMLED2399>
		<OEMDRO2400>0.</OEMDRO2400>
		<OEMLED2400>0</OEMLED2400>
		<OEMDRO2401>0.</OEMDRO2401>
		<OEMLED2401>0</OEMLED2401>
		<OEMDRO2402>0.</OEMDRO2402>
		<OEMLED2402>0</OEMLED2402>
		<OEMDRO2403>0.</OEMDRO2403>
		<OEMLED2403>0</OEMLED2403>
		<OEMDRO2404>0.</OEMDRO2404>
		<OEMLED2404>0</OEMLED2404>
		<OEMDRO2405>0.</OEMDRO2405>
		<OEMLED2405>0</OEMLED2405>
		<OEMDRO2406>0.</OEMDRO2406>
		<OEMLED2406>0</OEMLED2406>
		<OEMDRO2407>0.</OEMDRO2407>
		<OEMLED2407>0</OEMLED2407>
		<OEMDRO2408>0.</OEMDRO2408>
		<OEMLED2408>0</OEMLED2408>
		<OEMDRO2409>0.</OEMDRO2409>
		<OEMLED2409>0</OEMLED2409>
		<OEMDRO2410>0.</OEMDRO2410>
		<OEMLED2410>0</OEMLED2410>
		<OEMDRO2411>0.</OEMDRO2411>
		<OEMLED2411>0</OEMLED2411>
		<OEMDRO2412>0.</OEMDRO2412>
		<OEMLED2412>0</OEMLED2412>
		<OEMDRO2413>0.</OEMDRO2413>
		<OEMLED2413>0</OEMLED2413>
		<OEMDRO2414>0.</OEMDRO2414>
		<OEMLED2414>0</OEMLED2414>
		<OEMDRO2415>0.</OEMDRO2415>
		<OEMLED2415>0</OEMLED2415>
		<OEMDRO2416>0.</OEMDRO2416>
		<OEMLED2416>0</OEMLED2416>
		<OEMDRO2417>0.</OEMDRO2417>
		<OEMLED2417>0</OEMLED2417>
		<OEMDRO2418>0.</OEMDRO2418>
		<OEMLED2418>0</OEMLED2418>
		<OEMDRO2419>0.</OEMDRO2419>
		<OEMLED2419>0</OEMLED2419>
		<OEMDRO2420>0.</OEMDRO2420>
		<OEMLED2420>0</OEMLED2420>
		<OEMDRO2421>0.</OEMDRO2421>
		<OEMLED2421>0</OEMLED2421>
		<OEMDRO2422>0.</OEMDRO2422>
		<OEMLED2422>0</OEMLED2422>
		<OEMDRO2423>0.</OEMDRO2423>
		<OEMLED2423>0</OEMLED2423>
		<OEMDRO2424>0.</OEMDRO2424>
		<OEMLED2424>0</OEMLED2424>
		<OEMDRO2425>0.</OEMDRO2425>
		<OEMLED2425>0</OEMLED2425>
		<OEMDRO2426>0.</OEMDRO2426>
		<OEMLED2426>0</OEMLED2426>
		<OEMDRO2427>0.</OEMDRO2427>
		<OEMLED2427>0</OEMLED2427>
		<OEMDRO2428>0.</OEMDRO2428>
		<OEMLED2428>0</OEMLED2428>
		<OEMDRO2429>0.</OEMDRO2429>
		<OEMLED2429>0</OEMLED2429>
		<OEMDRO2430>0.</OEMDRO2430>
		<OEMLED2430>0</OEMLED2430>
		<OEMDRO2431>0.</OEMDRO2431>
		<OEMLED2431>0</OEMLED2431>
		<OEMDRO2432>0.</OEMDRO2432>
		<OEMLED2432>0</OEMLED2432>
		<OEMDRO2433>0.</OEMDRO2433>
		<OEMLED2433>0</OEMLED2433>
		<OEMDRO2434>0.</OEMDRO2434>
		<OEMLED2434>0</OEMLED2434>
		<OEMDRO2435>0.</OEMDRO2435>
		<OEMLED2435>0</OEMLED2435>
		<OEMDRO2436>0.</OEMDRO2436>
		<OEMLED2436>0</OEMLED2436>
		<OEMDRO2437>0.</OEMDRO2437>
		<OEMLED2437>0</OEMLED2437>
		<OEMDRO2438>0.</OEMDRO2438>
		<OEMLED2438>0</OEMLED2438>
		<OEMDRO2439>0.</OEMDRO2439>
		<OEMLED2439>0</OEMLED2439>
		<OEMDRO2440>0.</OEMDRO2440>
		<OEMLED2440>0</OEMLED2440>
		<OEMDRO2441>0.</OEMDRO2441>
		<OEMLED2441>0</OEMLED2441>
		<OEMDRO2442>0.</OEMDRO2442>
		<OEMLED2442>0</OEMLED2442>
		<OEMDRO2443>0.</OEMDRO2443>
		<OEMLED2443>0</OEMLED2443>
		<OEMDRO2444>0.</OEMDRO2444>
		<OEMLED2444>0</OEMLED2444>
		<OEMDRO2445>0.</OEMDRO2445>
		<OEMLED2445>0</OEMLED2445>
		<OEMDRO2446>0.</OEMDRO2446>
		<OEMLED2446>0</OEMLED2446>
		<OEMDRO2447>0.</OEMDRO2447>
		<OEMLED2447>0</OEMLED2447>
		<OEMDRO2448>0.</OEMDRO2448>
		<OEMLED2448>0</OEMLED2448>
		<OEMDRO2449>0.</OEMDRO2449>
		<OEMLED2449>0</OEMLED2449>
		<OEMDRO2450>0.</OEMDRO2450>
		<OEMLED2450>0</OEMLED2450>
		<OEMDRO2451>0.</OEMDRO2451>
		<OEMLED2451>0</OEMLED2451>
		<OEMDRO2452>0.</OEMDRO2452>
		<OEMLED2452>0</OEMLED2452>
		<OEMDRO2453>0.</OEMDRO2453>
		<OEMLED2453>0</OEMLED2453>
		<OEMDRO2454>0.</OEMDRO2454>
		<OEMLED2454>0</OEMLED2454>
		<OEMDRO2455>0.</OEMDRO2455>
		<OEMLED2455>0</OEMLED2455>
		<OEMDRO2456>0.</OEMDRO2456>
		<OEMLED2456>0</OEMLED2456>
		<OEMDRO2457>0.</OEMDRO2457>
		<OEMLED2457>0</OEMLED2457>
		<OEMDRO2458>0.</OEMDRO2458>
		<OEMLED2458>0</OEMLED2458>
		<OEMDRO2459>0.</OEMDRO2459>
		<OEMLED2459>0</OEMLED2459>
		<OEMDRO2460>0.</OEMDRO2460>
		<OEMLED2460>0</OEMLED2460>
		<OEMDRO2461>0.</OEMDRO2461>
		<OEMLED2461>0</OEMLED2461>
		<OEMDRO2462>0.</OEMDRO2462>
		<OEMLED2462>0</OEMLED2462>
		<OEMDRO2463>0.</OEMDRO2463>
		<OEMLED2463>0</OEMLED2463>
		<OEMDRO2464>0.</OEMDRO2464>
		<OEMLED2464>0</OEMLED2464>
		<OEMDRO2465>0.</OEMDRO2465>
		<OEMLED2465>0</OEMLED2465>
		<OEMDRO2466>0.</OEMDRO2466>
		<OEMLED2466>0</OEMLED2466>
		<OEMDRO2467>0.</OEMDRO2467>
		<OEMLED2467>0</OEMLED2467>
		<OEMDRO2468>0.</OEMDRO2468>
		<OEMLED2468>0</OEMLED2468>
		<OEMDRO2469>0.</OEMDRO2469>
		<OEMLED2469>0</OEMLED2469>
		<OEMDRO2470>0.</OEMDRO2470>
		<OEMLED2470>0</OEMLED2470>
		<OEMDRO2471>0.</OEMDRO2471>
		<OEMLED2471>0</OEMLED2471>
		<OEMDRO2472>0.</OEMDRO2472>
		<OEMLED2472>0</OEMLED2472>
		<OEMDRO2473>0.</OEMDRO2473>
		<OEMLED2473>0</OEMLED2473>
		<OEMDRO2474>0.</OEMDRO2474>
		<OEMLED2474>0</OEMLED2474>
		<OEMDRO2475>0.</OEMDRO2475>
		<OEMLED2475>0</OEMLED2475>
		<OEMDRO2476>0.</OEMDRO2476>
		<OEMLED2476>0</OEMLED2476>
		<OEMDRO2477>0.</OEMDRO2477>
		<OEMLED2477>0</OEMLED2477>
		<OEMDRO2478>0.</OEMDRO2478>
		<OEMLED2478>0</OEMLED2478>
		<OEMDRO2479>0.</OEMDRO2479>
		<OEMLED2479>0</OEMLED2479>
		<OEMDRO2480>0.</OEMDRO2480>
		<OEMLED2480>0</OEMLED2480>
		<OEMDRO2481>0.</OEMDRO2481>
		<OEMLED2481>0</OEMLED2481>
		<OEMDRO2482>0.</OEMDRO2482>
		<OEMLED2482>0</OEMLED2482>
		<OEMDRO2483>0.</OEMDRO2483>
		<OEMLED2483>0</OEMLED2483>
		<OEMDRO2484>0.</OEMDRO2484>
		<OEMLED2484>0</OEMLED2484>
		<OEMDRO2485>0.</OEMDRO2485>
		<OEMLED2485>0</OEMLED2485>
		<OEMDRO2486>0.</OEMDRO2486>
		<OEMLED2486>0</OEMLED2486>
		<OEMDRO2487>0.</OEMDRO2487>
		<OEMLED2487>0</OEMLED2487>
		<OEMDRO2488>0.</OEMDRO2488>
		<OEMLED2488>0</OEMLED2488>
		<OEMDRO2489>0.</OEMDRO2489>
		<OEMLED2489>0</OEMLED2489>
		<OEMDRO2490>0.</OEMDRO2490>
		<OEMLED2490>0</OEMLED2490>
		<OEMDRO2491>0.</OEMDRO2491>
		<OEMLED2491>0</OEMLED2491>
		<OEMDRO2492>0.</OEMDRO2492>
		<OEMLED2492>0</OEMLED2492>
		<OEMDRO2493>0.</OEMDRO2493>
		<OEMLED2493>0</OEMLED2493>
		<OEMDRO2494>0.</OEMDRO2494>
		<OEMLED2494>0</OEMLED2494>
		<OEMDRO2495>0.</OEMDRO2495>
		<OEMLED2495>0</OEMLED2495>
		<OEMDRO2496>0.</OEMDRO2496>
		<OEMLED2496>0</OEMLED2496>
		<OEMDRO2497>0.</OEMDRO2497>
		<OEMLED2497>0</OEMLED2497>
		<OEMDRO2498>0.</OEMDRO2498>
		<OEMLED2498>0</OEMLED2498>
		<OEMDRO2499>0.</OEMDRO2499>
		<OEMLED2499>0</OEMLED2499>
		<OEMDRO2500>0.</OEMDRO2500>
		<OEMLED2500>0</OEMLED2500>
		<OEMDRO2501>0.</OEMDRO2501>
		<OEMLED2501>0</OEMLED2501>
		<OEMDRO2502>0.</OEMDRO2502>
		<OEMLED2502>0</OEMLED2502>
		<OEMDRO2503>0.</OEMDRO2503>
		<OEMLED2503>0</OEMLED2503>
		<OEMDRO2504>0.</OEMDRO2504>
		<OEMLED2504>0</OEMLED2504>
		<OEMDRO2505>0.</OEMDRO2505>
		<OEMLED2505>0</OEMLED2505>
		<OEMDRO2506>0.</OEMDRO2506>
		<OEMLED2506>0</OEMLED2506>
		<OEMDRO2507>0.</OEMDRO2507>
		<OEMLED2507>0</OEMLED2507>
		<OEMDRO2508>0.</OEMDRO2508>
		<OEMLED2508>0</OEMLED2508>
		<OEMDRO2509>0.</OEMDRO2509>
		<OEMLED2509>0</OEMLED2509>
		<OEMDRO2510>0.</OEMDRO2510>
		<OEMLED2510>0</OEMLED2510>
		<OEMDRO2511>0.</OEMDRO2511>
		<OEMLED2511>0</OEMLED2511>
		<OEMDRO2512>0.</OEMDRO2512>
		<OEMLED2512>0</OEMLED2512>
		<OEMDRO2513>0.</OEMDRO2513>
		<OEMLED2513>0</OEMLED2513>
		<OEMDRO2514>0.</OEMDRO2514>
		<OEMLED2514>0</OEMLED2514>
		<OEMDRO2515>0.</OEMDRO2515>
		<OEMLED2515>0</OEMLED2515>
		<OEMDRO2516>0.</OEMDRO2516>
		<OEMLED2516>0</OEMLED2516>
		<OEMDRO2517>0.</OEMDRO2517>
		<OEMLED2517>0</OEMLED2517>
		<OEMDRO2518>0.</OEMDRO2518>
		<OEMLED2518>0</OEMLED2518>
		<OEMDRO2519>0.</OEMDRO2519>
		<OEMLED2519>0</OEMLED2519>
		<OEMDRO2520>0.</OEMDRO2520>
		<OEMLED2520>0</OEMLED2520>
		<OEMDRO2521>0.</OEMDRO2521>
		<OEMLED2521>0</OEMLED2521>
		<OEMDRO2522>0.</OEMDRO2522>
		<OEMLED2522>0</OEMLED2522>
		<OEMDRO2523>0.</OEMDRO2523>
		<OEMLED2523>0</OEMLED2523>
		<OEMDRO2524>0.</OEMDRO2524>
		<OEMLED2524>0</OEMLED2524>
		<OEMDRO2525>0.</OEMDRO2525>
		<OEMLED2525>0</OEMLED2525>
		<OEMDRO2526>0.</OEMDRO2526>
		<OEMLED2526>0</OEMLED2526>
		<OEMDRO2527>0.</OEMDRO2527>
		<OEMLED2527>0</OEMLED2527>
		<OEMDRO2528>0.</OEMDRO2528>
		<OEMLED2528>0</OEMLED2528>
		<OEMDRO2529>0.</OEMDRO2529>
		<OEMLED2529>0</OEMLED2529>
		<OEMDRO2530>0.</OEMDRO2530>
		<OEMLED2530>0</OEMLED2530>
		<OEMDRO2531>0.</OEMDRO2531>
		<OEMLED2531>0</OEMLED2531>
		<OEMDRO2532>0.</OEMDRO2532>
		<OEMLED2532>0</OEMLED2532>
		<OEMDRO2533>0.</OEMDRO2533>
		<OEMLED2533>0</OEMLED2533>
		<OEMDRO2534>0.</OEMDRO2534>
		<OEMLED2534>0</OEMLED2534>
		<OEMDRO2535>0.</OEMDRO2535>
		<OEMLED2535>0</OEMLED2535>
		<OEMDRO2536>0.</OEMDRO2536>
		<OEMLED2536>0</OEMLED2536>
		<OEMDRO2537>0.</OEMDRO2537>
		<OEMLED2537>0</OEMLED2537>
		<OEMDRO2538>0.</OEMDRO2538>
		<OEMLED2538>0</OEMLED2538>
		<OEMDRO2539>0.</OEMDRO2539>
		<OEMLED2539>0</OEMLED2539>
		<OEMDRO2540>0.</OEMDRO2540>
		<OEMLED2540>0</OEMLED2540>
		<OEMDRO2541>0.</OEMDRO2541>
		<OEMLED2541>0</OEMLED2541>
		<OEMDRO2542>0.</OEMDRO2542>
		<OEMLED2542>0</OEMLED2542>
		<OEMDRO2543>0.</OEMDRO2543>
		<OEMLED2543>0</OEMLED2543>
		<OEMDRO2544>0.</OEMDRO2544>
		<OEMLED2544>0</OEMLED2544>
		<OEMDRO2545>0.</OEMDRO2545>
		<OEMLED2545>0</OEMLED2545>
		<OEMDRO2546>0.</OEMDRO2546>
		<OEMLED2546>0</OEMLED2546>
		<OEMDRO2547>0.</OEMDRO2547>
		<OEMLED2547>0</OEMLED2547>
		<OEMDRO2548>0.</OEMDRO2548>
		<OEMLED2548>0</OEMLED2548>
		<OEMDRO2549>0.</OEMDRO2549>
		<OEMLED2549>0</OEMLED2549>
		<OEMDRO2550>0.</OEMDRO2550>
		<OEMLED2550>0</OEMLED2550>
		<OEMDRO2551>0.</OEMDRO2551>
		<OEMLED2551>0</OEMLED2551>
		<OEMDRO2552>0.</OEMDRO2552>
		<OEMLED2552>0</OEMLED2552>
		<OEMDRO2553>0.</OEMDRO2553>
		<OEMLED2553>0</OEMLED2553>
		<OEMDRO2554>0.</OEMDRO2554>
		<OEMLED2554>0</OEMLED2554>
		<OEMDRO2555>0.</OEMDRO2555>
		<OEMLED2555>0</OEMLED2555>
		<OEMDRO2556>0.</OEMDRO2556>
		<OEMLED2556>0</OEMLED2556>
		<OEMDRO2557>0.</OEMDRO2557>
		<OEMLED2557>0</OEMLED2557>
		<OEMDRO2558>0.</OEMDRO2558>
		<OEMLED2558>0</OEMLED2558>
		<OEMDRO2559>0.</OEMDRO2559>
		<OEMLED2559>0</OEMLED2559>
		<OEMDRO2560>0.</OEMDRO2560>
		<OEMLED2560>0</OEMLED2560>
		<OEMDRO2561>0.</OEMDRO2561>
		<OEMLED2561>0</OEMLED2561>
		<OEMDRO2562>0.</OEMDRO2562>
		<OEMLED2562>0</OEMLED2562>
		<OEMDRO2563>0.</OEMDRO2563>
		<OEMLED2563>0</OEMLED2563>
		<OEMDRO2564>0.</OEMDRO2564>
		<OEMLED2564>0</OEMLED2564>
		<OEMDRO2565>0.</OEMDRO2565>
		<OEMLED2565>0</OEMLED2565>
		<OEMDRO2566>0.</OEMDRO2566>
		<OEMLED2566>0</OEMLED2566>
		<OEMDRO2567>0.</OEMDRO2567>
		<OEMLED2567>0</OEMLED2567>
		<OEMDRO2568>0.</OEMDRO2568>
		<OEMLED2568>0</OEMLED2568>
		<OEMDRO2569>0.</OEMDRO2569>
		<OEMLED2569>0</OEMLED2569>
		<OEMDRO2570>0.</OEMDRO2570>
		<OEMLED2570>0</OEMLED2570>
		<OEMDRO2571>0.</OEMDRO2571>
		<OEMLED2571>0</OEMLED2571>
		<OEMDRO2572>0.</OEMDRO2572>
		<OEMLED2572>0</OEMLED2572>
		<OEMDRO2573>0.</OEMDRO2573>
		<OEMLED2573>0</OEMLED2573>
		<OEMDRO2574>0.</OEMDRO2574>
		<OEMLED2574>0</OEMLED2574>
		<OEMDRO2575>0.</OEMDRO2575>
		<OEMLED2575>0</OEMLED2575>
		<OEMDRO2576>0.</OEMDRO2576>
		<OEMLED2576>0</OEMLED2576>
		<OEMDRO2577>0.</OEMDRO2577>
		<OEMLED2577>0</OEMLED2577>
		<OEMDRO2578>0.</OEMDRO2578>
		<OEMLED2578>0</OEMLED2578>
		<OEMDRO2579>0.</OEMDRO2579>
		<OEMLED2579>0</OEMLED2579>
		<OEMDRO2580>0.</OEMDRO2580>
		<OEMLED2580>0</OEMLED2580>
		<OEMDRO2581>0.</OEMDRO2581>
		<OEMLED2581>0</OEMLED2581>
		<OEMDRO2582>0.</OEMDRO2582>
		<OEMLED2582>0</OEMLED2582>
		<OEMDRO2583>0.</OEMDRO2583>
		<OEMLED2583>0</OEMLED2583>
		<OEMDRO2584>0.</OEMDRO2584>
		<OEMLED2584>0</OEMLED2584>
		<OEMDRO2585>0.</OEMDRO2585>
		<OEMLED2585>0</OEMLED2585>
		<OEMDRO2586>0.</OEMDRO2586>
		<OEMLED2586>0</OEMLED2586>
		<OEMDRO2587>0.</OEMDRO2587>
		<OEMLED2587>0</OEMLED2587>
		<OEMDRO2588>0.</OEMDRO2588>
		<OEMLED2588>0</OEMLED2588>
		<OEMDRO2589>0.</OEMDRO2589>
		<OEMLED2589>0</OEMLED2589>
		<OEMDRO2590>0.</OEMDRO2590>
		<OEMLED2590>0</OEMLED2590>
		<OEMDRO2591>0.</OEMDRO2591>
		<OEMLED2591>0</OEMLED2591>
		<OEMDRO2592>0.</OEMDRO2592>
		<OEMLED2592>0</OEMLED2592>
		<OEMDRO2593>0.</OEMDRO2593>
		<OEMLED2593>0</OEMLED2593>
		<OEMDRO2594>0.</OEMDRO2594>
		<OEMLED2594>0</OEMLED2594>
		<OEMDRO2595>0.</OEMDRO2595>
		<OEMLED2595>0</OEMLED2595>
		<OEMDRO2596>0.</OEMDRO2596>
		<OEMLED2596>0</OEMLED2596>
		<OEMDRO2597>0.</OEMDRO2597>
		<OEMLED2597>0</OEMLED2597>
		<OEMDRO2598>0.</OEMDRO2598>
		<OEMLED2598>0</OEMLED2598>
		<OEMDRO2599>0.</OEMDRO2599>
		<OEMLED2599>0</OEMLED2599>
		<OEMDRO2600>0.</OEMDRO2600>
		<OEMLED2600>0</OEMLED2600>
		<OEMDRO2601>0.</OEMDRO2601>
		<OEMLED2601>0</OEMLED2601>
		<OEMDRO2602>0.</OEMDRO2602>
		<OEMLED2602>0</OEMLED2602>
		<OEMDRO2603>0.</OEMDRO2603>
		<OEMLED2603>0</OEMLED2603>
		<OEMDRO2604>0.</OEMDRO2604>
		<OEMLED2604>0</OEMLED2604>
		<OEMDRO2605>0.</OEMDRO2605>
		<OEMLED2605>0</OEMLED2605>
		<OEMDRO2606>0.</OEMDRO2606>
		<OEMLED2606>0</OEMLED2606>
		<OEMDRO2607>0.</OEMDRO2607>
		<OEMLED2607>0</OEMLED2607>
		<OEMDRO2608>0.</OEMDRO2608>
		<OEMLED2608>0</OEMLED2608>
		<OEMDRO2609>0.</OEMDRO2609>
		<OEMLED2609>0</OEMLED2609>
		<OEMDRO2610>0.</OEMDRO2610>
		<OEMLED2610>0</OEMLED2610>
		<OEMDRO2611>0.</OEMDRO2611>
		<OEMLED2611>0</OEMLED2611>
		<OEMDRO2612>0.</OEMDRO2612>
		<OEMLED2612>0</OEMLED2612>
		<OEMDRO2613>0.</OEMDRO2613>
		<OEMLED2613>0</OEMLED2613>
		<OEMDRO2614>0.</OEMDRO2614>
		<OEMLED2614>0</OEMLED2614>
		<OEMDRO2615>0.</OEMDRO2615>
		<OEMLED2615>0</OEMLED2615>
		<OEMDRO2616>0.</OEMDRO2616>
		<OEMLED2616>0</OEMLED2616>
		<OEMDRO2617>0.</OEMDRO2617>
		<OEMLED2617>0</OEMLED2617>
		<OEMDRO2618>0.</OEMDRO2618>
		<OEMLED2618>0</OEMLED2618>
		<OEMDRO2619>0.</OEMDRO2619>
		<OEMLED2619>0</OEMLED2619>
		<OEMDRO2620>0.</OEMDRO2620>
		<OEMLED2620>0</OEMLED2620>
		<OEMDRO2621>0.</OEMDRO2621>
		<OEMLED2621>0</OEMLED2621>
		<OEMDRO2622>0.</OEMDRO2622>
		<OEMLED2622>0</OEMLED2622>
		<OEMDRO2623>0.</OEMDRO2623>
		<OEMLED2623>0</OEMLED2623>
		<OEMDRO2624>0.</OEMDRO2624>
		<OEMLED2624>0</OEMLED2624>
		<OEMDRO2625>0.</OEMDRO2625>
		<OEMLED2625>0</OEMLED2625>
		<OEMDRO2626>0.</OEMDRO2626>
		<OEMLED2626>0</OEMLED2626>
		<OEMDRO2627>0.</OEMDRO2627>
		<OEMLED2627>0</OEMLED2627>
		<OEMDRO2628>0.</OEMDRO2628>
		<OEMLED2628>0</OEMLED2628>
		<OEMDRO2629>0.</OEMDRO2629>
		<OEMLED2629>0</OEMLED2629>
		<OEMDRO2630>0.</OEMDRO2630>
		<OEMLED2630>0</OEMLED2630>
		<OEMDRO2631>0.</OEMDRO2631>
		<OEMLED2631>0</OEMLED2631>
		<OEMDRO2632>0.</OEMDRO2632>
		<OEMLED2632>0</OEMLED2632>
		<OEMDRO2633>0.</OEMDRO2633>
		<OEMLED2633>0</OEMLED2633>
		<OEMDRO2634>0.</OEMDRO2634>
		<OEMLED2634>0</OEMLED2634>
		<OEMDRO2635>0.</OEMDRO2635>
		<OEMLED2635>0</OEMLED2635>
		<OEMDRO2636>0.</OEMDRO2636>
		<OEMLED2636>0</OEMLED2636>
		<OEMDRO2637>0.</OEMDRO2637>
		<OEMLED2637>0</OEMLED2637>
		<OEMDRO2638>0.</OEMDRO2638>
		<OEMLED2638>0</OEMLED2638>
		<OEMDRO2639>0.</OEMDRO2639>
		<OEMLED2639>0</OEMLED2639>
		<OEMDRO2640>0.</OEMDRO2640>
		<OEMLED2640>0</OEMLED2640>
		<OEMDRO2641>0.</OEMDRO2641>
		<OEMLED2641>0</OEMLED2641>
		<OEMDRO2642>0.</OEMDRO2642>
		<OEMLED2642>0</OEMLED2642>
		<OEMDRO2643>0.</OEMDRO2643>
		<OEMLED2643>0</OEMLED2643>
		<OEMDRO2644>0.</OEMDRO2644>
		<OEMLED2644>0</OEMLED2644>
		<OEMDRO2645>0.</OEMDRO2645>
		<OEMLED2645>0</OEMLED2645>
		<OEMDRO2646>0.</OEMDRO2646>
		<OEMLED2646>0</OEMLED2646>
		<OEMDRO2647>0.</OEMDRO2647>
		<OEMLED2647>0</OEMLED2647>
		<OEMDRO2648>0.</OEMDRO2648>
		<OEMLED2648>0</OEMLED2648>
		<OEMDRO2649>0.</OEMDRO2649>
		<OEMLED2649>0</OEMLED2649>
		<OEMDRO2650>0.</OEMDRO2650>
		<OEMLED2650>0</OEMLED2650>
		<OEMDRO2651>0.</OEMDRO2651>
		<OEMLED2651>0</OEMLED2651>
		<OEMDRO2652>0.</OEMDRO2652>
		<OEMLED2652>0</OEMLED2652>
		<OEMDRO2653>0.</OEMDRO2653>
		<OEMLED2653>0</OEMLED2653>
		<OEMDRO2654>0.</OEMDRO2654>
		<OEMLED2654>0</OEMLED2654>
		<OEMDRO2655>0.</OEMDRO2655>
		<OEMLED2655>0</OEMLED2655>
		<OEMDRO2656>0.</OEMDRO2656>
		<OEMLED2656>0</OEMLED2656>
		<OEMDRO2657>0.</OEMDRO2657>
		<OEMLED2657>0</OEMLED2657>
		<OEMDRO2658>0.</OEMDRO2658>
		<OEMLED2658>0</OEMLED2658>
		<OEMDRO2659>0.</OEMDRO2659>
		<OEMLED2659>0</OEMLED2659>
		<OEMDRO2660>0.</OEMDRO2660>
		<OEMLED2660>0</OEMLED2660>
		<OEMDRO2661>0.</OEMDRO2661>
		<OEMLED2661>0</OEMLED2661>
		<OEMDRO2662>0.</OEMDRO2662>
		<OEMLED2662>0</OEMLED2662>
		<OEMDRO2663>0.</OEMDRO2663>
		<OEMLED2663>0</OEMLED2663>
		<OEMDRO2664>0.</OEMDRO2664>
		<OEMLED2664>0</OEMLED2664>
		<OEMDRO2665>0.</OEMDRO2665>
		<OEMLED2665>0</OEMLED2665>
		<OEMDRO2666>0.</OEMDRO2666>
		<OEMLED2666>0</OEMLED2666>
		<OEMDRO2667>0.</OEMDRO2667>
		<OEMLED2667>0</OEMLED2667>
		<OEMDRO2668>0.</OEMDRO2668>
		<OEMLED2668>0</OEMLED2668>
		<OEMDRO2669>0.</OEMDRO2669>
		<OEMLED2669>0</OEMLED2669>
		<OEMDRO2670>0.</OEMDRO2670>
		<OEMLED2670>0</OEMLED2670>
		<OEMDRO2671>0.</OEMDRO2671>
		<OEMLED2671>0</OEMLED2671>
		<OEMDRO2672>0.</OEMDRO2672>
		<OEMLED2672>0</OEMLED2672>
		<OEMDRO2673>0.</OEMDRO2673>
		<OEMLED2673>0</OEMLED2673>
		<OEMDRO2674>0.</OEMDRO2674>
		<OEMLED2674>0</OEMLED2674>
		<OEMDRO2675>0.</OEMDRO2675>
		<OEMLED2675>0</OEMLED2675>
		<OEMDRO2676>0.</OEMDRO2676>
		<OEMLED2676>0</OEMLED2676>
		<OEMDRO2677>0.</OEMDRO2677>
		<OEMLED2677>0</OEMLED2677>
		<OEMDRO2678>0.</OEMDRO2678>
		<OEMLED2678>0</OEMLED2678>
		<OEMDRO2679>0.</OEMDRO2679>
		<OEMLED2679>0</OEMLED2679>
		<OEMDRO2680>0.</OEMDRO2680>
		<OEMLED2680>0</OEMLED2680>
		<OEMDRO2681>0.</OEMDRO2681>
		<OEMLED2681>0</OEMLED2681>
		<OEMDRO2682>0.</OEMDRO2682>
		<OEMLED2682>0</OEMLED2682>
		<OEMDRO2683>0.</OEMDRO2683>
		<OEMLED2683>0</OEMLED2683>
		<OEMDRO2684>0.</OEMDRO2684>
		<OEMLED2684>0</OEMLED2684>
		<OEMDRO2685>0.</OEMDRO2685>
		<OEMLED2685>0</OEMLED2685>
		<OEMDRO2686>0.</OEMDRO2686>
		<OEMLED2686>0</OEMLED2686>
		<OEMDRO2687>0.</OEMDRO2687>
		<OEMLED2687>0</OEMLED2687>
		<OEMDRO2688>0.</OEMDRO2688>
		<OEMLED2688>0</OEMLED2688>
		<OEMDRO2689>0.</OEMDRO2689>
		<OEMLED2689>0</OEMLED2689>
		<OEMDRO2690>0.</OEMDRO2690>
		<OEMLED2690>0</OEMLED2690>
		<OEMDRO2691>0.</OEMDRO2691>
		<OEMLED2691>0</OEMLED2691>
		<OEMDRO2692>0.</OEMDRO2692>
		<OEMLED2692>0</OEMLED2692>
		<OEMDRO2693>0.</OEMDRO2693>
		<OEMLED2693>0</OEMLED2693>
		<OEMDRO2694>0.</OEMDRO2694>
		<OEMLED2694>0</OEMLED2694>
		<OEMDRO2695>0.</OEMDRO2695>
		<OEMLED2695>0</OEMLED2695>
		<OEMDRO2696>0.</OEMDRO2696>
		<OEMLED2696>0</OEMLED2696>
		<OEMDRO2697>0.</OEMDRO2697>
		<OEMLED2697>0</OEMLED2697>
		<OEMDRO2698>0.</OEMDRO2698>
		<OEMLED2698>0</OEMLED2698>
		<OEMDRO2699>0.</OEMDRO2699>
		<OEMLED2699>0</OEMLED2699>
		<OEMDRO2700>0.</OEMDRO2700>
		<OEMLED2700>0</OEMLED2700>
		<OEMDRO2701>0.</OEMDRO2701>
		<OEMLED2701>0</OEMLED2701>
		<OEMDRO2702>0.</OEMDRO2702>
		<OEMLED2702>0</OEMLED2702>
		<OEMDRO2703>0.</OEMDRO2703>
		<OEMLED2703>0</OEMLED2703>
		<OEMDRO2704>0.</OEMDRO2704>
		<OEMLED2704>0</OEMLED2704>
		<OEMDRO2705>0.</OEMDRO2705>
		<OEMLED2705>0</OEMLED2705>
		<OEMDRO2706>0.</OEMDRO2706>
		<OEMLED2706>0</OEMLED2706>
		<OEMDRO2707>0.</OEMDRO2707>
		<OEMLED2707>0</OEMLED2707>
		<OEMDRO2708>0.</OEMDRO2708>
		<OEMLED2708>0</OEMLED2708>
		<OEMDRO2709>0.</OEMDRO2709>
		<OEMLED2709>0</OEMLED2709>
		<OEMDRO2710>0.</OEMDRO2710>
		<OEMLED2710>0</OEMLED2710>
		<OEMDRO2711>0.</OEMDRO2711>
		<OEMLED2711>0</OEMLED2711>
		<OEMDRO2712>0.</OEMDRO2712>
		<OEMLED2712>0</OEMLED2712>
		<OEMDRO2713>0.</OEMDRO2713>
		<OEMLED2713>0</OEMLED2713>
		<OEMDRO2714>0.</OEMDRO2714>
		<OEMLED2714>0</OEMLED2714>
		<OEMDRO2715>0.</OEMDRO2715>
		<OEMLED2715>0</OEMLED2715>
		<OEMDRO2716>0.</OEMDRO2716>
		<OEMLED2716>0</OEMLED2716>
		<OEMDRO2717>0.</OEMDRO2717>
		<OEMLED2717>0</OEMLED2717>
		<OEMDRO2718>0.</OEMDRO2718>
		<OEMLED2718>0</OEMLED2718>
		<OEMDRO2719>0.</OEMDRO2719>
		<OEMLED2719>0</OEMLED2719>
		<OEMDRO2720>0.</OEMDRO2720>
		<OEMLED2720>0</OEMLED2720>
		<OEMDRO2721>0.</OEMDRO2721>
		<OEMLED2721>0</OEMLED2721>
		<OEMDRO2722>0.</OEMDRO2722>
		<OEMLED2722>0</OEMLED2722>
		<OEMDRO2723>0.</OEMDRO2723>
		<OEMLED2723>0</OEMLED2723>
		<OEMDRO2724>0.</OEMDRO2724>
		<OEMLED2724>0</OEMLED2724>
		<OEMDRO2725>0.</OEMDRO2725>
		<OEMLED2725>0</OEMLED2725>
		<OEMDRO2726>0.</OEMDRO2726>
		<OEMLED2726>0</OEMLED2726>
		<OEMDRO2727>0.</OEMDRO2727>
		<OEMLED2727>0</OEMLED2727>
		<OEMDRO2728>0.</OEMDRO2728>
		<OEMLED2728>0</OEMLED2728>
		<OEMDRO2729>0.</OEMDRO2729>
		<OEMLED2729>0</OEMLED2729>
		<OEMDRO2730>0.</OEMDRO2730>
		<OEMLED2730>0</OEMLED2730>
		<OEMDRO2731>0.</OEMDRO2731>
		<OEMLED2731>0</OEMLED2731>
		<OEMDRO2732>0.</OEMDRO2732>
		<OEMLED2732>0</OEMLED2732>
		<OEMDRO2733>0.</OEMDRO2733>
		<OEMLED2733>0</OEMLED2733>
		<OEMDRO2734>0.</OEMDRO2734>
		<OEMLED2734>0</OEMLED2734>
		<OEMDRO2735>0.</OEMDRO2735>
		<OEMLED2735>0</OEMLED2735>
		<OEMDRO2736>0.</OEMDRO2736>
		<OEMLED2736>0</OEMLED2736>
		<OEMDRO2737>0.</OEMDRO2737>
		<OEMLED2737>0</OEMLED2737>
		<OEMDRO2738>0.</OEMDRO2738>
		<OEMLED2738>0</OEMLED2738>
		<OEMDRO2739>0.</OEMDRO2739>
		<OEMLED2739>0</OEMLED2739>
		<OEMDRO2740>0.</OEMDRO2740>
		<OEMLED2740>0</OEMLED2740>
		<OEMDRO2741>0.</OEMDRO2741>
		<OEMLED2741>0</OEMLED2741>
		<OEMDRO2742>0.</OEMDRO2742>
		<OEMLED2742>0</OEMLED2742>
		<OEMDRO2743>0.</OEMDRO2743>
		<OEMLED2743>0</OEMLED2743>
		<OEMDRO2744>0.</OEMDRO2744>
		<OEMLED2744>0</OEMLED2744>
		<OEMDRO2745>0.</OEMDRO2745>
		<OEMLED2745>0</OEMLED2745>
		<OEMDRO2746>0.</OEMDRO2746>
		<OEMLED2746>0</OEMLED2746>
		<OEMDRO2747>0.</OEMDRO2747>
		<OEMLED2747>0</OEMLED2747>
		<OEMDRO2748>0.</OEMDRO2748>
		<OEMLED2748>0</OEMLED2748>
		<OEMDRO2749>0.</OEMDRO2749>
		<OEMLED2749>0</OEMLED2749>
		<OEMDRO2750>0.</OEMDRO2750>
		<OEMLED2750>0</OEMLED2750>
		<OEMDRO2751>0.</OEMDRO2751>
		<OEMLED2751>0</OEMLED2751>
		<OEMDRO2752>0.</OEMDRO2752>
		<OEMLED2752>0</OEMLED2752>
		<OEMDRO2753>0.</OEMDRO2753>
		<OEMLED2753>0</OEMLED2753>
		<OEMDRO2754>0.</OEMDRO2754>
		<OEMLED2754>0</OEMLED2754>
		<OEMDRO2755>0.</OEMDRO2755>
		<OEMLED2755>0</OEMLED2755>
		<OEMDRO2756>0.</OEMDRO2756>
		<OEMLED2756>0</OEMLED2756>
		<OEMDRO2757>0.</OEMDRO2757>
		<OEMLED2757>0</OEMLED2757>
		<OEMDRO2758>0.</OEMDRO2758>
		<OEMLED2758>0</OEMLED2758>
		<OEMDRO2759>0.</OEMDRO2759>
		<OEMLED2759>0</OEMLED2759>
		<OEMDRO2760>0.</OEMDRO2760>
		<OEMLED2760>0</OEMLED2760>
		<OEMDRO2761>0.</OEMDRO2761>
		<OEMLED2761>0</OEMLED2761>
		<OEMDRO2762>0.</OEMDRO2762>
		<OEMLED2762>0</OEMLED2762>
		<OEMDRO2763>0.</OEMDRO2763>
		<OEMLED2763>0</OEMLED2763>
		<OEMDRO2764>0.</OEMDRO2764>
		<OEMLED2764>0</OEMLED2764>
		<OEMDRO2765>0.</OEMDRO2765>
		<OEMLED2765>0</OEMLED2765>
		<OEMDRO2766>0.</OEMDRO2766>
		<OEMLED2766>0</OEMLED2766>
		<OEMDRO2767>0.</OEMDRO2767>
		<OEMLED2767>0</OEMLED2767>
		<OEMDRO2768>0.</OEMDRO2768>
		<OEMLED2768>0</OEMLED2768>
		<OEMDRO2769>0.</OEMDRO2769>
		<OEMLED2769>0</OEMLED2769>
		<OEMDRO2770>0.</OEMDRO2770>
		<OEMLED2770>0</OEMLED2770>
		<OEMDRO2771>0.</OEMDRO2771>
		<OEMLED2771>0</OEMLED2771>
		<OEMDRO2772>0.</OEMDRO2772>
		<OEMLED2772>0</OEMLED2772>
		<OEMDRO2773>0.</OEMDRO2773>
		<OEMLED2773>0</OEMLED2773>
		<OEMDRO2774>0.</OEMDRO2774>
		<OEMLED2774>0</OEMLED2774>
		<OEMDRO2775>0.</OEMDRO2775>
		<OEMLED2775>0</OEMLED2775>
		<OEMDRO2776>0.</OEMDRO2776>
		<OEMLED2776>0</OEMLED2776>
		<OEMDRO2777>0.</OEMDRO2777>
		<OEMLED2777>0</OEMLED2777>
		<OEMDRO2778>0.</OEMDRO2778>
		<OEMLED2778>0</OEMLED2778>
		<OEMDRO2779>0.</OEMDRO2779>
		<OEMLED2779>0</OEMLED2779>
		<OEMDRO2780>0.</OEMDRO2780>
		<OEMLED2780>0</OEMLED2780>
		<OEMDRO2781>0.</OEMDRO2781>
		<OEMLED2781>0</OEMLED2781>
		<OEMDRO2782>0.</OEMDRO2782>
		<OEMLED2782>0</OEMLED2782>
		<OEMDRO2783>0.</OEMDRO2783>
		<OEMLED2783>0</OEMLED2783>
		<OEMDRO2784>0.</OEMDRO2784>
		<OEMLED2784>0</OEMLED2784>
		<OEMDRO2785>0.</OEMDRO2785>
		<OEMLED2785>0</OEMLED2785>
		<OEMDRO2786>0.</OEMDRO2786>
		<OEMLED2786>0</OEMLED2786>
		<OEMDRO2787>0.</OEMDRO2787>
		<OEMLED2787>0</OEMLED2787>
		<OEMDRO2788>0.</OEMDRO2788>
		<OEMLED2788>0</OEMLED2788>
		<OEMDRO2789>0.</OEMDRO2789>
		<OEMLED2789>0</OEMLED2789>
		<OEMDRO2790>0.</OEMDRO2790>
		<OEMLED2790>0</OEMLED2790>
		<OEMDRO2791>0.</OEMDRO2791>
		<OEMLED2791>0</OEMLED2791>
		<OEMDRO2792>0.</OEMDRO2792>
		<OEMLED2792>0</OEMLED2792>
		<OEMDRO2793>0.</OEMDRO2793>
		<OEMLED2793>0</OEMLED2793>
		<OEMDRO2794>0.</OEMDRO2794>
		<OEMLED2794>0</OEMLED2794>
		<OEMDRO2795>0.</OEMDRO2795>
		<OEMLED2795>0</OEMLED2795>
		<OEMDRO2796>0.</OEMDRO2796>
		<OEMLED2796>0</OEMLED2796>
		<OEMDRO2797>0.</OEMDRO2797>
		<OEMLED2797>0</OEMLED2797>
		<OEMDRO2798>0.</OEMDRO2798>
		<OEMLED2798>0</OEMLED2798>
		<OEMDRO2799>0.</OEMDRO2799>
		<OEMLED2799>0</OEMLED2799>
		<OEMDRO2800>0.</OEMDRO2800>
		<OEMLED2800>0</OEMLED2800>
		<OEMDRO2801>0.</OEMDRO2801>
		<OEMLED2801>0</OEMLED2801>
		<OEMDRO2802>0.</OEMDRO2802>
		<OEMLED2802>0</OEMLED2802>
		<OEMDRO2803>0.</OEMDRO2803>
		<OEMLED2803>0</OEMLED2803>
		<OEMDRO2804>0.</OEMDRO2804>
		<OEMLED2804>0</OEMLED2804>
		<OEMDRO2805>0.</OEMDRO2805>
		<OEMLED2805>0</OEMLED2805>
		<OEMDRO2806>0.</OEMDRO2806>
		<OEMLED2806>0</OEMLED2806>
		<OEMDRO2807>0.</OEMDRO2807>
		<OEMLED2807>0</OEMLED2807>
		<OEMDRO2808>0.</OEMDRO2808>
		<OEMLED2808>0</OEMLED2808>
		<OEMDRO2809>0.</OEMDRO2809>
		<OEMLED2809>0</OEMLED2809>
		<OEMDRO2810>0.</OEMDRO2810>
		<OEMLED2810>0</OEMLED2810>
		<OEMDRO2811>0.</OEMDRO2811>
		<OEMLED2811>0</OEMLED2811>
		<OEMDRO2812>0.</OEMDRO2812>
		<OEMLED2812>0</OEMLED2812>
		<OEMDRO2813>0.</OEMDRO2813>
		<OEMLED2813>0</OEMLED2813>
		<OEMDRO2814>0.</OEMDRO2814>
		<OEMLED2814>0</OEMLED2814>
		<OEMDRO2815>0.</OEMDRO2815>
		<OEMLED2815>0</OEMLED2815>
		<OEMDRO2816>0.</OEMDRO2816>
		<OEMLED2816>0</OEMLED2816>
		<OEMDRO2817>0.</OEMDRO2817>
		<OEMLED2817>0</OEMLED2817>
		<OEMDRO2818>0.</OEMDRO2818>
		<OEMLED2818>0</OEMLED2818>
		<OEMDRO2819>0.</OEMDRO2819>
		<OEMLED2819>0</OEMLED2819>
		<OEMDRO2820>0.</OEMDRO2820>
		<OEMLED2820>0</OEMLED2820>
		<OEMDRO2821>0.</OEMDRO2821>
		<OEMLED2821>0</OEMLED2821>
		<OEMDRO2822>0.</OEMDRO2822>
		<OEMLED2822>0</OEMLED2822>
		<OEMDRO2823>0.</OEMDRO2823>
		<OEMLED2823>0</OEMLED2823>
		<OEMDRO2824>0.</OEMDRO2824>
		<OEMLED2824>0</OEMLED2824>
		<OEMDRO2825>0.</OEMDRO2825>
		<OEMLED2825>0</OEMLED2825>
		<OEMDRO2826>0.</OEMDRO2826>
		<OEMLED2826>0</OEMLED2826>
		<OEMDRO2827>0.</OEMDRO2827>
		<OEMLED2827>0</OEMLED2827>
		<OEMDRO2828>0.</OEMDRO2828>
		<OEMLED2828>0</OEMLED2828>
		<OEMDRO2829>0.</OEMDRO2829>
		<OEMLED2829>0</OEMLED2829>
		<OEMDRO2830>0.</OEMDRO2830>
		<OEMLED2830>0</OEMLED2830>
		<OEMDRO2831>0.</OEMDRO2831>
		<OEMLED2831>0</OEMLED2831>
		<OEMDRO2832>0.</OEMDRO2832>
		<OEMLED2832>0</OEMLED2832>
		<OEMDRO2833>0.</OEMDRO2833>
		<OEMLED2833>0</OEMLED2833>
		<OEMDRO2834>0.</OEMDRO2834>
		<OEMLED2834>0</OEMLED2834>
		<OEMDRO2835>0.</OEMDRO2835>
		<OEMLED2835>0</OEMLED2835>
		<OEMDRO2836>0.</OEMDRO2836>
		<OEMLED2836>0</OEMLED2836>
		<OEMDRO2837>0.</OEMDRO2837>
		<OEMLED2837>0</OEMLED2837>
		<OEMDRO2838>0.</OEMDRO2838>
		<OEMLED2838>0</OEMLED2838>
		<OEMDRO2839>0.</OEMDRO2839>
		<OEMLED2839>0</OEMLED2839>
		<OEMDRO2840>0.</OEMDRO2840>
		<OEMLED2840>0</OEMLED2840>
		<OEMDRO2841>0.</OEMDRO2841>
		<OEMLED2841>0</OEMLED2841>
		<OEMDRO2842>0.</OEMDRO2842>
		<OEMLED2842>0</OEMLED2842>
		<OEMDRO2843>0.</OEMDRO2843>
		<OEMLED2843>0</OEMLED2843>
		<OEMDRO2844>0.</OEMDRO2844>
		<OEMLED2844>0</OEMLED2844>
		<OEMDRO2845>0.</OEMDRO2845>
		<OEMLED2845>0</OEMLED2845>
		<OEMDRO2846>0.</OEMDRO2846>
		<OEMLED2846>0</OEMLED2846>
		<OEMDRO2847>0.</OEMDRO2847>
		<OEMLED2847>0</OEMLED2847>
		<OEMDRO2848>0.</OEMDRO2848>
		<OEMLED2848>0</OEMLED2848>
		<OEMDRO2849>0.</OEMDRO2849>
		<OEMLED2849>0</OEMLED2849>
		<OEMDRO2850>0.</OEMDRO2850>
		<OEMLED2850>0</OEMLED2850>
		<OEMDRO2851>0.</OEMDRO2851>
		<OEMLED2851>0</OEMLED2851>
		<OEMDRO2852>0.</OEMDRO2852>
		<OEMLED2852>0</OEMLED2852>
		<OEMDRO2853>0.</OEMDRO2853>
		<OEMLED2853>0</OEMLED2853>
		<OEMDRO2854>0.</OEMDRO2854>
		<OEMLED2854>0</OEMLED2854>
		<OEMDRO2855>0.</OEMDRO2855>
		<OEMLED2855>0</OEMLED2855>
		<OEMDRO2856>0.</OEMDRO2856>
		<OEMLED2856>0</OEMLED2856>
		<OEMDRO2857>0.</OEMDRO2857>
		<OEMLED2857>0</OEMLED2857>
		<OEMDRO2858>0.</OEMDRO2858>
		<OEMLED2858>0</OEMLED2858>
		<OEMDRO2859>0.</OEMDRO2859>
		<OEMLED2859>0</OEMLED2859>
		<OEMDRO2860>0.</OEMDRO2860>
		<OEMLED2860>0</OEMLED2860>
		<OEMDRO2861>0.</OEMDRO2861>
		<OEMLED2861>0</OEMLED2861>
		<OEMDRO2862>0.</OEMDRO2862>
		<OEMLED2862>0</OEMLED2862>
		<OEMDRO2863>0.</OEMDRO2863>
		<OEMLED2863>0</OEMLED2863>
		<OEMDRO2864>0.</OEMDRO2864>
		<OEMLED2864>0</OEMLED2864>
		<OEMDRO2865>0.</OEMDRO2865>
		<OEMLED2865>0</OEMLED2865>
		<OEMDRO2866>0.</OEMDRO2866>
		<OEMLED2866>0</OEMLED2866>
		<OEMDRO2867>0.</OEMDRO2867>
		<OEMLED2867>0</OEMLED2867>
		<OEMDRO2868>0.</OEMDRO2868>
		<OEMLED2868>0</OEMLED2868>
		<OEMDRO2869>0.</OEMDRO2869>
		<OEMLED2869>0</OEMLED2869>
		<OEMDRO2870>0.</OEMDRO2870>
		<OEMLED2870>0</OEMLED2870>
		<OEMDRO2871>0.</OEMDRO2871>
		<OEMLED2871>0</OEMLED2871>
		<OEMDRO2872>0.</OEMDRO2872>
		<OEMLED2872>0</OEMLED2872>
		<OEMDRO2873>0.</OEMDRO2873>
		<OEMLED2873>0</OEMLED2873>
		<OEMDRO2874>0.</OEMDRO2874>
		<OEMLED2874>0</OEMLED2874>
		<OEMDRO2875>0.</OEMDRO2875>
		<OEMLED2875>0</OEMLED2875>
		<OEMDRO2876>0.</OEMDRO2876>
		<OEMLED2876>0</OEMLED2876>
		<OEMDRO2877>0.</OEMDRO2877>
		<OEMLED2877>0</OEMLED2877>
		<OEMDRO2878>0.</OEMDRO2878>
		<OEMLED2878>0</OEMLED2878>
		<OEMDRO2879>0.</OEMDRO2879>
		<OEMLED2879>0</OEMLED2879>
		<OEMDRO2880>0.</OEMDRO2880>
		<OEMLED2880>0</OEMLED2880>
		<OEMDRO2881>0.</OEMDRO2881>
		<OEMLED2881>0</OEMLED2881>
		<OEMDRO2882>0.</OEMDRO2882>
		<OEMLED2882>0</OEMLED2882>
		<OEMDRO2883>0.</OEMDRO2883>
		<OEMLED2883>0</OEMLED2883>
		<OEMDRO2884>0.</OEMDRO2884>
		<OEMLED2884>0</OEMLED2884>
		<OEMDRO2885>0.</OEMDRO2885>
		<OEMLED2885>0</OEMLED2885>
		<OEMDRO2886>0.</OEMDRO2886>
		<OEMLED2886>0</OEMLED2886>
		<OEMDRO2887>0.</OEMDRO2887>
		<OEMLED2887>0</OEMLED2887>
		<OEMDRO2888>0.</OEMDRO2888>
		<OEMLED2888>0</OEMLED2888>
		<OEMDRO2889>0.</OEMDRO2889>
		<OEMLED2889>0</OEMLED2889>
		<OEMDRO2890>0.</OEMDRO2890>
		<OEMLED2890>0</OEMLED2890>
		<OEMDRO2891>0.</OEMDRO2891>
		<OEMLED2891>0</OEMLED2891>
		<OEMDRO2892>0.</OEMDRO2892>
		<OEMLED2892>0</OEMLED2892>
		<OEMDRO2893>0.</OEMDRO2893>
		<OEMLED2893>0</OEMLED2893>
		<OEMDRO2894>0.</OEMDRO2894>
		<OEMLED2894>0</OEMLED2894>
		<OEMDRO2895>0.</OEMDRO2895>
		<OEMLED2895>0</OEMLED2895>
		<OEMDRO2896>0.</OEMDRO2896>
		<OEMLED2896>0</OEMLED2896>
		<OEMDRO2897>0.</OEMDRO2897>
		<OEMLED2897>0</OEMLED2897>
		<OEMDRO2898>0.</OEMDRO2898>
		<OEMLED2898>0</OEMLED2898>
		<OEMDRO2899>0.</OEMDRO2899>
		<OEMLED2899>0</OEMLED2899>
		<OEMDRO2900>0.</OEMDRO2900>
		<OEMLED2900>0</OEMLED2900>
		<OEMDRO2901>0.</OEMDRO2901>
		<OEMLED2901>0</OEMLED2901>
		<OEMDRO2902>0.</OEMDRO2902>
		<OEMLED2902>0</OEMLED2902>
		<OEMDRO2903>0.</OEMDRO2903>
		<OEMLED2903>0</OEMLED2903>
		<OEMDRO2904>0.</OEMDRO2904>
		<OEMLED2904>0</OEMLED2904>
		<OEMDRO2905>0.</OEMDRO2905>
		<OEMLED2905>0</OEMLED2905>
		<OEMDRO2906>0.</OEMDRO2906>
		<OEMLED2906>0</OEMLED2906>
		<OEMDRO2907>0.</OEMDRO2907>
		<OEMLED2907>0</OEMLED2907>
		<OEMDRO2908>0.</OEMDRO2908>
		<OEMLED2908>0</OEMLED2908>
		<OEMDRO2909>0.</OEMDRO2909>
		<OEMLED2909>0</OEMLED2909>
		<OEMDRO2910>0.</OEMDRO2910>
		<OEMLED2910>0</OEMLED2910>
		<OEMDRO2911>0.</OEMDRO2911>
		<OEMLED2911>0</OEMLED2911>
		<OEMDRO2912>0.</OEMDRO2912>
		<OEMLED2912>0</OEMLED2912>
		<OEMDRO2913>0.</OEMDRO2913>
		<OEMLED2913>0</OEMLED2913>
		<OEMDRO2914>0.</OEMDRO2914>
		<OEMLED2914>0</OEMLED2914>
		<OEMDRO2915>0.</OEMDRO2915>
		<OEMLED2915>0</OEMLED2915>
		<OEMDRO2916>0.</OEMDRO2916>
		<OEMLED2916>0</OEMLED2916>
		<OEMDRO2917>0.</OEMDRO2917>
		<OEMLED2917>0</OEMLED2917>
		<OEMDRO2918>0.</OEMDRO2918>
		<OEMLED2918>0</OEMLED2918>
		<OEMDRO2919>0.</OEMDRO2919>
		<OEMLED2919>0</OEMLED2919>
		<OEMDRO2920>0.</OEMDRO2920>
		<OEMLED2920>0</OEMLED2920>
		<OEMDRO2921>0.</OEMDRO2921>
		<OEMLED2921>0</OEMLED2921>
		<OEMDRO2922>0.</OEMDRO2922>
		<OEMLED2922>0</OEMLED2922>
		<OEMDRO2923>0.</OEMDRO2923>
		<OEMLED2923>0</OEMLED2923>
		<OEMDRO2924>0.</OEMDRO2924>
		<OEMLED2924>0</OEMLED2924>
		<OEMDRO2925>0.</OEMDRO2925>
		<OEMLED2925>0</OEMLED2925>
		<OEMDRO2926>0.</OEMDRO2926>
		<OEMLED2926>0</OEMLED2926>
		<OEMDRO2927>0.</OEMDRO2927>
		<OEMLED2927>0</OEMLED2927>
		<OEMDRO2928>0.</OEMDRO2928>
		<OEMLED2928>0</OEMLED2928>
		<OEMDRO2929>0.</OEMDRO2929>
		<OEMLED2929>0</OEMLED2929>
		<OEMDRO2930>0.</OEMDRO2930>
		<OEMLED2930>0</OEMLED2930>
		<OEMDRO2931>0.</OEMDRO2931>
		<OEMLED2931>0</OEMLED2931>
		<OEMDRO2932>0.</OEMDRO2932>
		<OEMLED2932>0</OEMLED2932>
		<OEMDRO2933>0.</OEMDRO2933>
		<OEMLED2933>0</OEMLED2933>
		<OEMDRO2934>0.</OEMDRO2934>
		<OEMLED2934>0</OEMLED2934>
		<OEMDRO2935>0.</OEMDRO2935>
		<OEMLED2935>0</OEMLED2935>
		<OEMDRO2936>0.</OEMDRO2936>
		<OEMLED2936>0</OEMLED2936>
		<OEMDRO2937>0.</OEMDRO2937>
		<OEMLED2937>0</OEMLED2937>
		<OEMDRO2938>0.</OEMDRO2938>
		<OEMLED2938>0</OEMLED2938>
		<OEMDRO2939>0.</OEMDRO2939>
		<OEMLED2939>0</OEMLED2939>
		<OEMDRO2940>0.</OEMDRO2940>
		<OEMLED2940>0</OEMLED2940>
		<OEMDRO2941>0.</OEMDRO2941>
		<OEMLED2941>0</OEMLED2941>
		<OEMDRO2942>0.</OEMDRO2942>
		<OEMLED2942>0</OEMLED2942>
		<OEMDRO2943>0.</OEMDRO2943>
		<OEMLED2943>0</OEMLED2943>
		<OEMDRO2944>0.</OEMDRO2944>
		<OEMLED2944>0</OEMLED2944>
		<OEMDRO2945>0.</OEMDRO2945>
		<OEMLED2945>0</OEMLED2945>
		<OEMDRO2946>0.</OEMDRO2946>
		<OEMLED2946>0</OEMLED2946>
		<OEMDRO2947>0.</OEMDRO2947>
		<OEMLED2947>0</OEMLED2947>
		<OEMDRO2948>0.</OEMDRO2948>
		<OEMLED2948>0</OEMLED2948>
		<OEMDRO2949>0.</OEMDRO2949>
		<OEMLED2949>0</OEMLED2949>
		<OEMDRO2950>0.</OEMDRO2950>
		<OEMLED2950>0</OEMLED2950>
		<OEMDRO2951>0.</OEMDRO2951>
		<OEMLED2951>0</OEMLED2951>
		<OEMDRO2952>0.</OEMDRO2952>
		<OEMLED2952>0</OEMLED2952>
		<OEMDRO2953>0.</OEMDRO2953>
		<OEMLED2953>0</OEMLED2953>
		<OEMDRO2954>0.</OEMDRO2954>
		<OEMLED2954>0</OEMLED2954>
		<OEMDRO2955>0.</OEMDRO2955>
		<OEMLED2955>0</OEMLED2955>
		<OEMDRO2956>0.</OEMDRO2956>
		<OEMLED2956>0</OEMLED2956>
		<OEMDRO2957>0.</OEMDRO2957>
		<OEMLED2957>0</OEMLED2957>
		<OEMDRO2958>0.</OEMDRO2958>
		<OEMLED2958>0</OEMLED2958>
		<OEMDRO2959>0.</OEMDRO2959>
		<OEMLED2959>0</OEMLED2959>
		<OEMDRO2960>0.</OEMDRO2960>
		<OEMLED2960>0</OEMLED2960>
		<OEMDRO2961>0.</OEMDRO2961>
		<OEMLED2961>0</OEMLED2961>
		<OEMDRO2962>0.</OEMDRO2962>
		<OEMLED2962>0</OEMLED2962>
		<OEMDRO2963>0.</OEMDRO2963>
		<OEMLED2963>0</OEMLED2963>
		<OEMDRO2964>0.</OEMDRO2964>
		<OEMLED2964>0</OEMLED2964>
		<OEMDRO2965>0.</OEMDRO2965>
		<OEMLED2965>0</OEMLED2965>
		<OEMDRO2966>0.</OEMDRO2966>
		<OEMLED2966>0</OEMLED2966>
		<OEMDRO2967>0.</OEMDRO2967>
		<OEMLED2967>0</OEMLED2967>
		<OEMDRO2968>0.</OEMDRO2968>
		<OEMLED2968>0</OEMLED2968>
		<OEMDRO2969>0.</OEMDRO2969>
		<OEMLED2969>0</OEMLED2969>
		<OEMDRO2970>0.</OEMDRO2970>
		<OEMLED2970>0</OEMLED2970>
		<OEMDRO2971>0.</OEMDRO2971>
		<OEMLED2971>0</OEMLED2971>
		<OEMDRO2972>0.</OEMDRO2972>
		<OEMLED2972>0</OEMLED2972>
		<OEMDRO2973>0.</OEMDRO2973>
		<OEMLED2973>0</OEMLED2973>
		<OEMDRO2974>0.</OEMDRO2974>
		<OEMLED2974>0</OEMLED2974>
		<OEMDRO2975>0.</OEMDRO2975>
		<OEMLED2975>0</OEMLED2975>
		<OEMDRO2976>0.</OEMDRO2976>
		<OEMLED2976>0</OEMLED2976>
		<OEMDRO2977>0.</OEMDRO2977>
		<OEMLED2977>0</OEMLED2977>
		<OEMDRO2978>0.</OEMDRO2978>
		<OEMLED2978>0</OEMLED2978>
		<OEMDRO2979>0.</OEMDRO2979>
		<OEMLED2979>0</OEMLED2979>
		<OEMDRO2980>0.</OEMDRO2980>
		<OEMLED2980>0</OEMLED2980>
		<OEMDRO2981>0.</OEMDRO2981>
		<OEMLED2981>0</OEMLED2981>
		<OEMDRO2982>0.</OEMDRO2982>
		<OEMLED2982>0</OEMLED2982>
		<OEMDRO2983>0.</OEMDRO2983>
		<OEMLED2983>0</OEMLED2983>
		<OEMDRO2984>0.</OEMDRO2984>
		<OEMLED2984>0</OEMLED2984>
		<OEMDRO2985>0.</OEMDRO2985>
		<OEMLED2985>0</OEMLED2985>
		<OEMDRO2986>0.</OEMDRO2986>
		<OEMLED2986>0</OEMLED2986>
		<OEMDRO2987>0.</OEMDRO2987>
		<OEMLED2987>0</OEMLED2987>
		<OEMDRO2988>0.</OEMDRO2988>
		<OEMLED2988>0</OEMLED2988>
		<OEMDRO2989>0.</OEMDRO2989>
		<OEMLED2989>0</OEMLED2989>
		<OEMDRO2990>0.</OEMDRO2990>
		<OEMLED2990>0</OEMLED2990>
		<OEMDRO2991>0.</OEMDRO2991>
		<OEMLED2991>0</OEMLED2991>
		<OEMDRO2992>0.</OEMDRO2992>
		<OEMLED2992>0</OEMLED2992>
		<OEMDRO2993>0.</OEMDRO2993>
		<OEMLED2993>0</OEMLED2993>
		<OEMDRO2994>0.</OEMDRO2994>
		<OEMLED2994>0</OEMLED2994>
		<OEMDRO2995>0.</OEMDRO2995>
		<OEMLED2995>0</OEMLED2995>
		<OEMDRO2996>0.</OEMDRO2996>
		<OEMLED2996>0</OEMLED2996>
		<OEMDRO2997>0.</OEMDRO2997>
		<OEMLED2997>0</OEMLED2997>
		<OEMDRO2998>0.</OEMDRO2998>
		<OEMLED2998>0</OEMLED2998>
		<OEMDRO2999>0.</OEMDRO2999>
		<OEMLED2999>0</OEMLED2999>
		<Slave0>3</Slave0>
		<Slave1>3</Slave1>
		<Slave2>3</Slave2>
		<OEMDRO2_0>0.</OEMDRO2_0>
		<OEMLED2_0>0</OEMLED2_0>
		<OEMDRO2_1>0.</OEMDRO2_1>
		<OEMLED2_1>0</OEMLED2_1>
		<OEMDRO2_2>0.</OEMDRO2_2>
		<OEMLED2_2>0</OEMLED2_2>
		<OEMDRO2_3>0.</OEMDRO2_3>
		<OEMLED2_3>0</OEMLED2_3>
		<OEMDRO2_4>0.</OEMDRO2_4>
		<OEMLED2_4>0</OEMLED2_4>
		<OEMDRO2_5>0.</OEMDRO2_5>
		<OEMLED2_5>0</OEMLED2_5>
		<OEMDRO2_6>0.</OEMDRO2_6>
		<OEMLED2_6>0</OEMLED2_6>
		<OEMDRO2_7>0.</OEMDRO2_7>
		<OEMLED2_7>0</OEMLED2_7>
		<OEMDRO2_8>0.</OEMDRO2_8>
		<OEMLED2_8>0</OEMLED2_8>
		<OEMDRO2_9>0.</OEMDRO2_9>
		<OEMLED2_9>0</OEMLED2_9>
		<OEMDRO2_10>0.</OEMDRO2_10>
		<OEMLED2_10>0</OEMLED2_10>
		<OEMDRO2_11>0.</OEMDRO2_11>
		<OEMLED2_11>0</OEMLED2_11>
		<OEMDRO2_12>0.</OEMDRO2_12>
		<OEMLED2_12>0</OEMLED2_12>
		<OEMDRO2_13>0.</OEMDRO2_13>
		<OEMLED2_13>0</OEMLED2_13>
		<OEMDRO2_14>0.</OEMDRO2_14>
		<OEMLED2_14>0</OEMLED2_14>
		<OEMDRO2_15>0.</OEMDRO2_15>
		<OEMLED2_15>0</OEMLED2_15>
		<OEMDRO2_16>0.</OEMDRO2_16>
		<OEMLED2_16>0</OEMLED2_16>
		<OEMDRO2_17>0.</OEMDRO2_17>
		<OEMLED2_17>0</OEMLED2_17>
		<OEMDRO2_18>0.</OEMDRO2_18>
		<OEMLED2_18>0</OEMLED2_18>
		<OEMDRO2_19>0.</OEMDRO2_19>
		<OEMLED2_19>0</OEMLED2_19>
		<OEMDRO2_20>0.</OEMDRO2_20>
		<OEMLED2_20>0</OEMLED2_20>
		<OEMDRO2_21>0.</OEMDRO2_21>
		<OEMLED2_21>0</OEMLED2_21>
		<OEMDRO2_22>0.</OEMDRO2_22>
		<OEMLED2_22>0</OEMLED2_22>
		<OEMDRO2_23>0.</OEMDRO2_23>
		<OEMLED2_23>0</OEMLED2_23>
		<OEMDRO2_24>0.</OEMDRO2_24>
		<OEMLED2_24>0</OEMLED2_24>
		<OEMDRO2_25>0.</OEMDRO2_25>
		<OEMLED2_25>0</OEMLED2_25>
		<OEMDRO2_26>0.</OEMDRO2_26>
		<OEMLED2_26>0</OEMLED2_26>
		<OEMDRO2_27>0.</OEMDRO2_27>
		<OEMLED2_27>0</OEMLED2_27>
		<OEMDRO2_28>0.</OEMDRO2_28>
		<OEMLED2_28>0</OEMLED2_28>
		<OEMDRO2_29>0.</OEMDRO2_29>
		<OEMLED2_29>0</OEMLED2_29>
		<OEMDRO2_30>0.</OEMDRO2_30>
		<OEMLED2_30>0</OEMLED2_30>
		<OEMDRO2_31>0.</OEMDRO2_31>
		<OEMLED2_31>0</OEMLED2_31>
		<OEMDRO2_32>0.</OEMDRO2_32>
		<OEMLED2_32>0</OEMLED2_32>
		<OEMDRO2_33>0.</OEMDRO2_33>
		<OEMLED2_33>0</OEMLED2_33>
		<OEMDRO2_34>0.</OEMDRO2_34>
		<OEMLED2_34>0</OEMLED2_34>
		<OEMDRO2_35>0.</OEMDRO2_35>
		<OEMLED2_35>0</OEMLED2_35>
		<OEMDRO2_36>0.</OEMDRO2_36>
		<OEMLED2_36>0</OEMLED2_36>
		<OEMDRO2_37>0.</OEMDRO2_37>
		<OEMLED2_37>0</OEMLED2_37>
		<OEMDRO2_38>0.</OEMDRO2_38>
		<OEMLED2_38>0</OEMLED2_38>
		<OEMDRO2_39>0.</OEMDRO2_39>
		<OEMLED2_39>0</OEMLED2_39>
		<OEMDRO2_40>0.</OEMDRO2_40>
		<OEMLED2_40>0</OEMLED2_40>
		<OEMDRO2_41>0.</OEMDRO2_41>
		<OEMLED2_41>0</OEMLED2_41>
		<OEMDRO2_42>0.</OEMDRO2_42>
		<OEMLED2_42>0</OEMLED2_42>
		<OEMDRO2_43>0.</OEMDRO2_43>
		<OEMLED2_43>0</OEMLED2_43>
		<OEMDRO2_44>0.</OEMDRO2_44>
		<OEMLED2_44>0</OEMLED2_44>
		<OEMDRO2_45>0.</OEMDRO2_45>
		<OEMLED2_45>0</OEMLED2_45>
		<OEMDRO2_46>0.</OEMDRO2_46>
		<OEMLED2_46>0</OEMLED2_46>
		<OEMDRO2_47>0.</OEMDRO2_47>
		<OEMLED2_47>0</OEMLED2_47>
		<OEMDRO2_48>0.</OEMDRO2_48>
		<OEMLED2_48>0</OEMLED2_48>
		<OEMDRO2_49>0.</OEMDRO2_49>
		<OEMLED2_49>0</OEMLED2_49>
		<OEMDRO2_50>0.</OEMDRO2_50>
		<OEMLED2_50>0</OEMLED2_50>
		<OEMDRO2_51>0.</OEMDRO2_51>
		<OEMLED2_51>0</OEMLED2_51>
		<OEMDRO2_52>0.</OEMDRO2_52>
		<OEMLED2_52>0</OEMLED2_52>
		<OEMDRO2_53>0.</OEMDRO2_53>
		<OEMLED2_53>0</OEMLED2_53>
		<OEMDRO2_54>0.</OEMDRO2_54>
		<OEMLED2_54>0</OEMLED2_54>
		<OEMDRO2_55>0.</OEMDRO2_55>
		<OEMLED2_55>0</OEMLED2_55>
		<OEMDRO2_56>0.</OEMDRO2_56>
		<OEMLED2_56>0</OEMLED2_56>
		<OEMDRO2_57>0.</OEMDRO2_57>
		<OEMLED2_57>0</OEMLED2_57>
		<OEMDRO2_58>0.</OEMDRO2_58>
		<OEMLED2_58>0</OEMLED2_58>
		<OEMDRO2_59>0.</OEMDRO2_59>
		<OEMLED2_59>0</OEMLED2_59>
		<OEMDRO2_60>0.</OEMDRO2_60>
		<OEMLED2_60>0</OEMLED2_60>
		<OEMDRO2_61>0.</OEMDRO2_61>
		<OEMLED2_61>0</OEMLED2_61>
		<OEMDRO2_62>0.</OEMDRO2_62>
		<OEMLED2_62>0</OEMLED2_62>
		<OEMDRO2_63>0.</OEMDRO2_63>
		<OEMLED2_63>0</OEMLED2_63>
		<OEMDRO2_64>0.</OEMDRO2_64>
		<OEMLED2_64>0</OEMLED2_64>
		<OEMDRO2_65>0.</OEMDRO2_65>
		<OEMLED2_65>0</OEMLED2_65>
		<OEMDRO2_66>0.</OEMDRO2_66>
		<OEMLED2_66>0</OEMLED2_66>
		<OEMDRO2_67>0.</OEMDRO2_67>
		<OEMLED2_67>0</OEMLED2_67>
		<OEMDRO2_68>0.</OEMDRO2_68>
		<OEMLED2_68>0</OEMLED2_68>
		<OEMDRO2_69>0.</OEMDRO2_69>
		<OEMLED2_69>0</OEMLED2_69>
		<OEMDRO2_70>0.</OEMDRO2_70>
		<OEMLED2_70>0</OEMLED2_70>
		<OEMDRO2_71>0.</OEMDRO2_71>
		<OEMLED2_71>0</OEMLED2_71>
		<OEMDRO2_72>0.</OEMDRO2_72>
		<OEMLED2_72>0</OEMLED2_72>
		<OEMDRO2_73>0.</OEMDRO2_73>
		<OEMLED2_73>0</OEMLED2_73>
		<OEMDRO2_74>0.</OEMDRO2_74>
		<OEMLED2_74>0</OEMLED2_74>
		<OEMDRO2_75>0.</OEMDRO2_75>
		<OEMLED2_75>0</OEMLED2_75>
		<OEMDRO2_76>0.</OEMDRO2_76>
		<OEMLED2_76>0</OEMLED2_76>
		<OEMDRO2_77>0.</OEMDRO2_77>
		<OEMLED2_77>0</OEMLED2_77>
		<OEMDRO2_78>0.</OEMDRO2_78>
		<OEMLED2_78>0</OEMLED2_78>
		<OEMDRO2_79>0.</OEMDRO2_79>
		<OEMLED2_79>0</OEMLED2_79>
		<OEMDRO2_80>0.</OEMDRO2_80>
		<OEMLED2_80>0</OEMLED2_80>
		<OEMDRO2_81>0.</OEMDRO2_81>
		<OEMLED2_81>0</OEMLED2_81>
		<OEMDRO2_82>0.</OEMDRO2_82>
		<OEMLED2_82>0</OEMLED2_82>
		<OEMDRO2_83>0.</OEMDRO2_83>
		<OEMLED2_83>0</OEMLED2_83>
		<OEMDRO2_84>0.</OEMDRO2_84>
		<OEMLED2_84>0</OEMLED2_84>
		<OEMDRO2_85>0.</OEMDRO2_85>
		<OEMLED2_85>0</OEMLED2_85>
		<OEMDRO2_86>0.</OEMDRO2_86>
		<OEMLED2_86>0</OEMLED2_86>
		<OEMDRO2_87>0.</OEMDRO2_87>
		<OEMLED2_87>0</OEMLED2_87>
		<OEMDRO2_88>0.</OEMDRO2_88>
		<OEMLED2_88>0</OEMLED2_88>
		<OEMDRO2_89>0.</OEMDRO2_89>
		<OEMLED2_89>0</OEMLED2_89>
		<OEMDRO2_90>0.</OEMDRO2_90>
		<OEMLED2_90>0</OEMLED2_90>
		<OEMDRO2_91>0.</OEMDRO2_91>
		<OEMLED2_91>0</OEMLED2_91>
		<OEMDRO2_92>0.</OEMDRO2_92>
		<OEMLED2_92>0</OEMLED2_92>
		<OEMDRO2_93>0.</OEMDRO2_93>
		<OEMLED2_93>0</OEMLED2_93>
		<OEMDRO2_94>0.</OEMDRO2_94>
		<OEMLED2_94>0</OEMLED2_94>
		<OEMDRO2_95>0.</OEMDRO2_95>
		<OEMLED2_95>0</OEMLED2_95>
		<OEMDRO2_96>0.</OEMDRO2_96>
		<OEMLED2_96>0</OEMLED2_96>
		<OEMDRO2_97>0.</OEMDRO2_97>
		<OEMLED2_97>0</OEMLED2_97>
		<OEMDRO2_98>0.</OEMDRO2_98>
		<OEMLED2_98>0</OEMLED2_98>
		<OEMDRO2_99>0.</OEMDRO2_99>
		<OEMLED2_99>0</OEMLED2_99>
		<OEMDRO2_100>0.</OEMDRO2_100>
		<OEMLED2_100>0</OEMLED2_100>
		<OEMDRO2_101>0.</OEMDRO2_101>
		<OEMLED2_101>0</OEMLED2_101>
		<OEMDRO2_102>0.</OEMDRO2_102>
		<OEMLED2_102>0</OEMLED2_102>
		<OEMDRO2_103>0.</OEMDRO2_103>
		<OEMLED2_103>0</OEMLED2_103>
		<OEMDRO2_104>0.</OEMDRO2_104>
		<OEMLED2_104>0</OEMLED2_104>
		<OEMDRO2_105>0.</OEMDRO2_105>
		<OEMLED2_105>0</OEMLED2_105>
		<OEMDRO2_106>0.</OEMDRO2_106>
		<OEMLED2_106>0</OEMLED2_106>
		<OEMDRO2_107>0.</OEMDRO2_107>
		<OEMLED2_107>0</OEMLED2_107>
		<OEMDRO2_108>0.</OEMDRO2_108>
		<OEMLED2_108>0</OEMLED2_108>
		<OEMDRO2_109>0.</OEMDRO2_109>
		<OEMLED2_109>0</OEMLED2_109>
		<OEMDRO2_110>0.</OEMDRO2_110>
		<OEMLED2_110>0</OEMLED2_110>
		<OEMDRO2_111>0.</OEMDRO2_111>
		<OEMLED2_111>0</OEMLED2_111>
		<OEMDRO2_112>0.</OEMDRO2_112>
		<OEMLED2_112>0</OEMLED2_112>
		<OEMDRO2_113>0.</OEMDRO2_113>
		<OEMLED2_113>0</OEMLED2_113>
		<OEMDRO2_114>0.</OEMDRO2_114>
		<OEMLED2_114>0</OEMLED2_114>
		<OEMDRO2_115>0.</OEMDRO2_115>
		<OEMLED2_115>0</OEMLED2_115>
		<OEMDRO2_116>0.</OEMDRO2_116>
		<OEMLED2_116>0</OEMLED2_116>
		<OEMDRO2_117>0.</OEMDRO2_117>
		<OEMLED2_117>0</OEMLED2_117>
		<OEMDRO2_118>0.</OEMDRO2_118>
		<OEMLED2_118>0</OEMLED2_118>
		<OEMDRO2_119>0.</OEMDRO2_119>
		<OEMLED2_119>0</OEMLED2_119>
		<OEMDRO2_120>0.</OEMDRO2_120>
		<OEMLED2_120>0</OEMLED2_120>
		<OEMDRO2_121>0.</OEMDRO2_121>
		<OEMLED2_121>0</OEMLED2_121>
		<OEMDRO2_122>0.</OEMDRO2_122>
		<OEMLED2_122>0</OEMLED2_122>
		<OEMDRO2_123>0.</OEMDRO2_123>
		<OEMLED2_123>0</OEMLED2_123>
		<OEMDRO2_124>0.</OEMDRO2_124>
		<OEMLED2_124>0</OEMLED2_124>
		<OEMDRO2_125>0.</OEMDRO2_125>
		<OEMLED2_125>0</OEMLED2_125>
		<OEMDRO2_126>0.</OEMDRO2_126>
		<OEMLED2_126>0</OEMLED2_126>
		<OEMDRO2_127>0.</OEMDRO2_127>
		<OEMLED2_127>0</OEMLED2_127>
		<OEMDRO2_128>0.</OEMDRO2_128>
		<OEMLED2_128>0</OEMLED2_128>
		<OEMDRO2_129>0.</OEMDRO2_129>
		<OEMLED2_129>0</OEMLED2_129>
		<OEMDRO2_130>0.</OEMDRO2_130>
		<OEMLED2_130>0</OEMLED2_130>
		<OEMDRO2_131>0.</OEMDRO2_131>
		<OEMLED2_131>0</OEMLED2_131>
		<OEMDRO2_132>0.</OEMDRO2_132>
		<OEMLED2_132>0</OEMLED2_132>
		<OEMDRO2_133>0.</OEMDRO2_133>
		<OEMLED2_133>0</OEMLED2_133>
		<OEMDRO2_134>0.</OEMDRO2_134>
		<OEMLED2_134>0</OEMLED2_134>
		<OEMDRO2_135>0.</OEMDRO2_135>
		<OEMLED2_135>0</OEMLED2_135>
		<OEMDRO2_136>0.</OEMDRO2_136>
		<OEMLED2_136>0</OEMLED2_136>
		<OEMDRO2_137>0.</OEMDRO2_137>
		<OEMLED2_137>0</OEMLED2_137>
		<OEMDRO2_138>0.</OEMDRO2_138>
		<OEMLED2_138>0</OEMLED2_138>
		<OEMDRO2_139>0.</OEMDRO2_139>
		<OEMLED2_139>0</OEMLED2_139>
		<OEMDRO2_140>0.</OEMDRO2_140>
		<OEMLED2_140>0</OEMLED2_140>
		<OEMDRO2_141>0.</OEMDRO2_141>
		<OEMLED2_141>0</OEMLED2_141>
		<OEMDRO2_142>0.</OEMDRO2_142>
		<OEMLED2_142>0</OEMLED2_142>
		<OEMDRO2_143>0.</OEMDRO2_143>
		<OEMLED2_143>0</OEMLED2_143>
		<OEMDRO2_144>0.</OEMDRO2_144>
		<OEMLED2_144>0</OEMLED2_144>
		<OEMDRO2_145>0.</OEMDRO2_145>
		<OEMLED2_145>0</OEMLED2_145>
		<OEMDRO2_146>0.</OEMDRO2_146>
		<OEMLED2_146>0</OEMLED2_146>
		<OEMDRO2_147>0.</OEMDRO2_147>
		<OEMLED2_147>0</OEMLED2_147>
		<OEMDRO2_148>0.</OEMDRO2_148>
		<OEMLED2_148>0</OEMLED2_148>
		<OEMDRO2_149>0.</OEMDRO2_149>
		<OEMLED2_149>0</OEMLED2_149>
		<OEMDRO2_150>0.</OEMDRO2_150>
		<OEMLED2_150>0</OEMLED2_150>
		<OEMDRO2_151>0.</OEMDRO2_151>
		<OEMLED2_151>0</OEMLED2_151>
		<OEMDRO2_152>0.</OEMDRO2_152>
		<OEMLED2_152>0</OEMLED2_152>
		<OEMDRO2_153>0.</OEMDRO2_153>
		<OEMLED2_153>0</OEMLED2_153>
		<OEMDRO2_154>0.</OEMDRO2_154>
		<OEMLED2_154>0</OEMLED2_154>
		<OEMDRO2_155>0.</OEMDRO2_155>
		<OEMLED2_155>0</OEMLED2_155>
		<OEMDRO2_156>0.</OEMDRO2_156>
		<OEMLED2_156>0</OEMLED2_156>
		<OEMDRO2_157>0.</OEMDRO2_157>
		<OEMLED2_157>0</OEMLED2_157>
		<OEMDRO2_158>0.</OEMDRO2_158>
		<OEMLED2_158>0</OEMLED2_158>
		<OEMDRO2_159>0.</OEMDRO2_159>
		<OEMLED2_159>0</OEMLED2_159>
		<OEMDRO2_160>0.</OEMDRO2_160>
		<OEMLED2_160>0</OEMLED2_160>
		<OEMDRO2_161>0.</OEMDRO2_161>
		<OEMLED2_161>0</OEMLED2_161>
		<OEMDRO2_162>0.</OEMDRO2_162>
		<OEMLED2_162>0</OEMLED2_162>
		<OEMDRO2_163>0.</OEMDRO2_163>
		<OEMLED2_163>0</OEMLED2_163>
		<OEMDRO2_164>0.</OEMDRO2_164>
		<OEMLED2_164>0</OEMLED2_164>
		<OEMDRO2_165>0.</OEMDRO2_165>
		<OEMLED2_165>0</OEMLED2_165>
		<OEMDRO2_166>0.</OEMDRO2_166>
		<OEMLED2_166>0</OEMLED2_166>
		<OEMDRO2_167>0.</OEMDRO2_167>
		<OEMLED2_167>0</OEMLED2_167>
		<OEMDRO2_168>0.</OEMDRO2_168>
		<OEMLED2_168>0</OEMLED2_168>
		<OEMDRO2_169>0.</OEMDRO2_169>
		<OEMLED2_169>0</OEMLED2_169>
		<OEMDRO2_170>0.</OEMDRO2_170>
		<OEMLED2_170>0</OEMLED2_170>
		<OEMDRO2_171>0.</OEMDRO2_171>
		<OEMLED2_171>0</OEMLED2_171>
		<OEMDRO2_172>0.</OEMDRO2_172>
		<OEMLED2_172>0</OEMLED2_172>
		<OEMDRO2_173>0.</OEMDRO2_173>
		<OEMLED2_173>0</OEMLED2_173>
		<OEMDRO2_174>0.</OEMDRO2_174>
		<OEMLED2_174>0</OEMLED2_174>
		<OEMDRO2_175>0.</OEMDRO2_175>
		<OEMLED2_175>0</OEMLED2_175>
		<OEMDRO2_176>0.</OEMDRO2_176>
		<OEMLED2_176>0</OEMLED2_176>
		<OEMDRO2_177>0.</OEMDRO2_177>
		<OEMLED2_177>0</OEMLED2_177>
		<OEMDRO2_178>0.</OEMDRO2_178>
		<OEMLED2_178>0</OEMLED2_178>
		<OEMDRO2_179>0.</OEMDRO2_179>
		<OEMLED2_179>0</OEMLED2_179>
		<OEMDRO2_180>0.</OEMDRO2_180>
		<OEMLED2_180>0</OEMLED2_180>
		<OEMDRO2_181>0.</OEMDRO2_181>
		<OEMLED2_181>0</OEMLED2_181>
		<OEMDRO2_182>0.</OEMDRO2_182>
		<OEMLED2_182>0</OEMLED2_182>
		<OEMDRO2_183>0.</OEMDRO2_183>
		<OEMLED2_183>0</OEMLED2_183>
		<OEMDRO2_184>0.</OEMDRO2_184>
		<OEMLED2_184>0</OEMLED2_184>
		<OEMDRO2_185>0.</OEMDRO2_185>
		<OEMLED2_185>0</OEMLED2_185>
		<OEMDRO2_186>0.</OEMDRO2_186>
		<OEMLED2_186>0</OEMLED2_186>
		<OEMDRO2_187>0.</OEMDRO2_187>
		<OEMLED2_187>0</OEMLED2_187>
		<OEMDRO2_188>0.</OEMDRO2_188>
		<OEMLED2_188>0</OEMLED2_188>
		<OEMDRO2_189>0.</OEMDRO2_189>
		<OEMLED2_189>0</OEMLED2_189>
		<OEMDRO2_190>0.</OEMDRO2_190>
		<OEMLED2_190>0</OEMLED2_190>
		<OEMDRO2_191>0.</OEMDRO2_191>
		<OEMLED2_191>0</OEMLED2_191>
		<OEMDRO2_192>0.</OEMDRO2_192>
		<OEMLED2_192>0</OEMLED2_192>
		<OEMDRO2_193>0.</OEMDRO2_193>
		<OEMLED2_193>0</OEMLED2_193>
		<OEMDRO2_194>0.</OEMDRO2_194>
		<OEMLED2_194>0</OEMLED2_194>
		<OEMDRO2_195>0.</OEMDRO2_195>
		<OEMLED2_195>0</OEMLED2_195>
		<OEMDRO2_196>0.</OEMDRO2_196>
		<OEMLED2_196>0</OEMLED2_196>
		<OEMDRO2_197>0.</OEMDRO2_197>
		<OEMLED2_197>0</OEMLED2_197>
		<OEMDRO2_198>0.</OEMDRO2_198>
		<OEMLED2_198>0</OEMLED2_198>
		<OEMDRO2_199>0.</OEMDRO2_199>
		<OEMLED2_199>0</OEMLED2_199>
		<OEMDRO2_200>0.</OEMDRO2_200>
		<OEMLED2_200>0</OEMLED2_200>
		<OEMDRO2_201>0.</OEMDRO2_201>
		<OEMLED2_201>0</OEMLED2_201>
		<OEMDRO2_202>0.</OEMDRO2_202>
		<OEMLED2_202>0</OEMLED2_202>
		<OEMDRO2_203>0.</OEMDRO2_203>
		<OEMLED2_203>0</OEMLED2_203>
		<OEMDRO2_204>0.</OEMDRO2_204>
		<OEMLED2_204>0</OEMLED2_204>
		<OEMDRO2_205>0.</OEMDRO2_205>
		<OEMLED2_205>0</OEMLED2_205>
		<OEMDRO2_206>0.</OEMDRO2_206>
		<OEMLED2_206>0</OEMLED2_206>
		<OEMDRO2_207>0.</OEMDRO2_207>
		<OEMLED2_207>0</OEMLED2_207>
		<OEMDRO2_208>0.</OEMDRO2_208>
		<OEMLED2_208>0</OEMLED2_208>
		<OEMDRO2_209>0.</OEMDRO2_209>
		<OEMLED2_209>0</OEMLED2_209>
		<OEMDRO2_210>0.</OEMDRO2_210>
		<OEMLED2_210>0</OEMLED2_210>
		<OEMDRO2_211>0.</OEMDRO2_211>
		<OEMLED2_211>0</OEMLED2_211>
		<OEMDRO2_212>0.</OEMDRO2_212>
		<OEMLED2_212>0</OEMLED2_212>
		<OEMDRO2_213>0.</OEMDRO2_213>
		<OEMLED2_213>0</OEMLED2_213>
		<OEMDRO2_214>0.</OEMDRO2_214>
		<OEMLED2_214>0</OEMLED2_214>
		<OEMDRO2_215>0.</OEMDRO2_215>
		<OEMLED2_215>0</OEMLED2_215>
		<OEMDRO2_216>0.</OEMDRO2_216>
		<OEMLED2_216>0</OEMLED2_216>
		<OEMDRO2_217>0.</OEMDRO2_217>
		<OEMLED2_217>0</OEMLED2_217>
		<OEMDRO2_218>0.</OEMDRO2_218>
		<OEMLED2_218>0</OEMLED2_218>
		<OEMDRO2_219>0.</OEMDRO2_219>
		<OEMLED2_219>0</OEMLED2_219>
		<OEMDRO2_220>0.</OEMDRO2_220>
		<OEMLED2_220>0</OEMLED2_220>
		<OEMDRO2_221>0.</OEMDRO2_221>
		<OEMLED2_221>0</OEMLED2_221>
		<OEMDRO2_222>0.</OEMDRO2_222>
		<OEMLED2_222>0</OEMLED2_222>
		<OEMDRO2_223>0.</OEMDRO2_223>
		<OEMLED2_223>0</OEMLED2_223>
		<OEMDRO2_224>0.</OEMDRO2_224>
		<OEMLED2_224>0</OEMLED2_224>
		<OEMDRO2_225>0.</OEMDRO2_225>
		<OEMLED2_225>0</OEMLED2_225>
		<OEMDRO2_226>0.</OEMDRO2_226>
		<OEMLED2_226>0</OEMLED2_226>
		<OEMDRO2_227>0.</OEMDRO2_227>
		<OEMLED2_227>0</OEMLED2_227>
		<OEMDRO2_228>0.</OEMDRO2_228>
		<OEMLED2_228>0</OEMLED2_228>
		<OEMDRO2_229>0.</OEMDRO2_229>
		<OEMLED2_229>0</OEMLED2_229>
		<OEMDRO2_230>0.</OEMDRO2_230>
		<OEMLED2_230>0</OEMLED2_230>
		<OEMDRO2_231>0.</OEMDRO2_231>
		<OEMLED2_231>0</OEMLED2_231>
		<OEMDRO2_232>0.</OEMDRO2_232>
		<OEMLED2_232>0</OEMLED2_232>
		<OEMDRO2_233>0.</OEMDRO2_233>
		<OEMLED2_233>0</OEMLED2_233>
		<OEMDRO2_234>0.</OEMDRO2_234>
		<OEMLED2_234>0</OEMLED2_234>
		<OEMDRO2_235>0.</OEMDRO2_235>
		<OEMLED2_235>0</OEMLED2_235>
		<OEMDRO2_236>0.</OEMDRO2_236>
		<OEMLED2_236>0</OEMLED2_236>
		<OEMDRO2_237>0.</OEMDRO2_237>
		<OEMLED2_237>0</OEMLED2_237>
		<OEMDRO2_238>0.</OEMDRO2_238>
		<OEMLED2_238>0</OEMLED2_238>
		<OEMDRO2_239>0.</OEMDRO2_239>
		<OEMLED2_239>0</OEMLED2_239>
		<OEMDRO2_240>0.</OEMDRO2_240>
		<OEMLED2_240>0</OEMLED2_240>
		<OEMDRO2_241>0.</OEMDRO2_241>
		<OEMLED2_241>0</OEMLED2_241>
		<OEMDRO2_242>0.</OEMDRO2_242>
		<OEMLED2_242>0</OEMLED2_242>
		<OEMDRO2_243>0.</OEMDRO2_243>
		<OEMLED2_243>0</OEMLED2_243>
		<OEMDRO2_244>0.</OEMDRO2_244>
		<OEMLED2_244>0</OEMLED2_244>
		<OEMDRO2_245>0.</OEMDRO2_245>
		<OEMLED2_245>0</OEMLED2_245>
		<OEMDRO2_246>0.</OEMDRO2_246>
		<OEMLED2_246>0</OEMLED2_246>
		<OEMDRO2_247>0.</OEMDRO2_247>
		<OEMLED2_247>0</OEMLED2_247>
		<OEMDRO2_248>0.</OEMDRO2_248>
		<OEMLED2_248>0</OEMLED2_248>
		<OEMDRO2_249>0.</OEMDRO2_249>
		<OEMLED2_249>0</OEMLED2_249>
		<OEMDRO2_250>0.</OEMDRO2_250>
		<OEMLED2_250>0</OEMLED2_250>
		<OEMDRO2_251>0.</OEMDRO2_251>
		<OEMLED2_251>0</OEMLED2_251>
		<OEMDRO2_252>0.</OEMDRO2_252>
		<OEMLED2_252>0</OEMLED2_252>
		<OEMDRO2_253>0.</OEMDRO2_253>
		<OEMLED2_253>0</OEMLED2_253>
		<OEMDRO2_254>0.</OEMDRO2_254>
		<OEMLED2_254>0</OEMLED2_254>
		<OEMDRO2_255>0.</OEMDRO2_255>
		<OEMLED2_255>0</OEMLED2_255>
		<OEMDRO2_256>0.</OEMDRO2_256>
		<OEMLED2_256>0</OEMLED2_256>
		<OEMDRO2_257>0.</OEMDRO2_257>
		<OEMLED2_257>0</OEMLED2_257>
		<OEMDRO2_258>0.</OEMDRO2_258>
		<OEMLED2_258>0</OEMLED2_258>
		<OEMDRO2_259>0.</OEMDRO2_259>
		<OEMLED2_259>0</OEMLED2_259>
		<OEMDRO2_260>0.</OEMDRO2_260>
		<OEMLED2_260>0</OEMLED2_260>
		<OEMDRO2_261>0.</OEMDRO2_261>
		<OEMLED2_261>0</OEMLED2_261>
		<OEMDRO2_262>0.</OEMDRO2_262>
		<OEMLED2_262>0</OEMLED2_262>
		<OEMDRO2_263>0.</OEMDRO2_263>
		<OEMLED2_263>0</OEMLED2_263>
		<OEMDRO2_264>0.</OEMDRO2_264>
		<OEMLED2_264>0</OEMLED2_264>
		<OEMDRO2_265>0.</OEMDRO2_265>
		<OEMLED2_265>0</OEMLED2_265>
		<OEMDRO2_266>0.</OEMDRO2_266>
		<OEMLED2_266>0</OEMLED2_266>
		<OEMDRO2_267>0.</OEMDRO2_267>
		<OEMLED2_267>0</OEMLED2_267>
		<OEMDRO2_268>0.</OEMDRO2_268>
		<OEMLED2_268>0</OEMLED2_268>
		<OEMDRO2_269>0.</OEMDRO2_269>
		<OEMLED2_269>0</OEMLED2_269>
		<OEMDRO2_270>0.</OEMDRO2_270>
		<OEMLED2_270>0</OEMLED2_270>
		<OEMDRO2_271>0.</OEMDRO2_271>
		<OEMLED2_271>0</OEMLED2_271>
		<OEMDRO2_272>0.</OEMDRO2_272>
		<OEMLED2_272>0</OEMLED2_272>
		<OEMDRO2_273>0.</OEMDRO2_273>
		<OEMLED2_273>0</OEMLED2_273>
		<OEMDRO2_274>0.</OEMDRO2_274>
		<OEMLED2_274>0</OEMLED2_274>
		<OEMDRO2_275>0.</OEMDRO2_275>
		<OEMLED2_275>0</OEMLED2_275>
		<OEMDRO2_276>0.</OEMDRO2_276>
		<OEMLED2_276>0</OEMLED2_276>
		<OEMDRO2_277>0.</OEMDRO2_277>
		<OEMLED2_277>0</OEMLED2_277>
		<OEMDRO2_278>0.</OEMDRO2_278>
		<OEMLED2_278>0</OEMLED2_278>
		<OEMDRO2_279>0.</OEMDRO2_279>
		<OEMLED2_279>0</OEMLED2_279>
		<OEMDRO2_280>0.</OEMDRO2_280>
		<OEMLED2_280>0</OEMLED2_280>
		<OEMDRO2_281>0.</OEMDRO2_281>
		<OEMLED2_281>0</OEMLED2_281>
		<OEMDRO2_282>0.</OEMDRO2_282>
		<OEMLED2_282>0</OEMLED2_282>
		<OEMDRO2_283>0.</OEMDRO2_283>
		<OEMLED2_283>0</OEMLED2_283>
		<OEMDRO2_284>0.</OEMDRO2_284>
		<OEMLED2_284>0</OEMLED2_284>
		<OEMDRO2_285>0.</OEMDRO2_285>
		<OEMLED2_285>0</OEMLED2_285>
		<OEMDRO2_286>0.</OEMDRO2_286>
		<OEMLED2_286>0</OEMLED2_286>
		<OEMDRO2_287>0.</OEMDRO2_287>
		<OEMLED2_287>0</OEMLED2_287>
		<OEMDRO2_288>0.</OEMDRO2_288>
		<OEMLED2_288>0</OEMLED2_288>
		<OEMDRO2_289>0.</OEMDRO2_289>
		<OEMLED2_289>0</OEMLED2_289>
		<OEMDRO2_290>0.</OEMDRO2_290>
		<OEMLED2_290>0</OEMLED2_290>
		<OEMDRO2_291>0.</OEMDRO2_291>
		<OEMLED2_291>0</OEMLED2_291>
		<OEMDRO2_292>0.</OEMDRO2_292>
		<OEMLED2_292>0</OEMLED2_292>
		<OEMDRO2_293>0.</OEMDRO2_293>
		<OEMLED2_293>0</OEMLED2_293>
		<OEMDRO2_294>0.</OEMDRO2_294>
		<OEMLED2_294>0</OEMLED2_294>
		<OEMDRO2_295>0.</OEMDRO2_295>
		<OEMLED2_295>0</OEMLED2_295>
		<OEMDRO2_296>0.</OEMDRO2_296>
		<OEMLED2_296>0</OEMLED2_296>
		<OEMDRO2_297>0.</OEMDRO2_297>
		<OEMLED2_297>0</OEMLED2_297>
		<OEMDRO2_298>0.</OEMDRO2_298>
		<OEMLED2_298>0</OEMLED2_298>
		<OEMDRO2_299>0.</OEMDRO2_299>
		<OEMLED2_299>0</OEMLED2_299>
		<OEMDRO2_300>0.</OEMDRO2_300>
		<OEMLED2_300>0</OEMLED2_300>
		<OEMDRO2_301>0.</OEMDRO2_301>
		<OEMLED2_301>0</OEMLED2_301>
		<OEMDRO2_302>0.</OEMDRO2_302>
		<OEMLED2_302>0</OEMLED2_302>
		<OEMDRO2_303>0.</OEMDRO2_303>
		<OEMLED2_303>0</OEMLED2_303>
		<OEMDRO2_304>0.</OEMDRO2_304>
		<OEMLED2_304>0</OEMLED2_304>
		<OEMDRO2_305>0.</OEMDRO2_305>
		<OEMLED2_305>0</OEMLED2_305>
		<OEMDRO2_306>0.</OEMDRO2_306>
		<OEMLED2_306>0</OEMLED2_306>
		<OEMDRO2_307>0.</OEMDRO2_307>
		<OEMLED2_307>0</OEMLED2_307>
		<OEMDRO2_308>0.</OEMDRO2_308>
		<OEMLED2_308>0</OEMLED2_308>
		<OEMDRO2_309>0.</OEMDRO2_309>
		<OEMLED2_309>0</OEMLED2_309>
		<OEMDRO2_310>0.</OEMDRO2_310>
		<OEMLED2_310>0</OEMLED2_310>
		<OEMDRO2_311>0.</OEMDRO2_311>
		<OEMLED2_311>0</OEMLED2_311>
		<OEMDRO2_312>0.</OEMDRO2_312>
		<OEMLED2_312>0</OEMLED2_312>
		<OEMDRO2_313>0.</OEMDRO2_313>
		<OEMLED2_313>0</OEMLED2_313>
		<OEMDRO2_314>0.</OEMDRO2_314>
		<OEMLED2_314>0</OEMLED2_314>
		<OEMDRO2_315>0.</OEMDRO2_315>
		<OEMLED2_315>0</OEMLED2_315>
		<OEMDRO2_316>0.</OEMDRO2_316>
		<OEMLED2_316>0</OEMLED2_316>
		<OEMDRO2_317>0.</OEMDRO2_317>
		<OEMLED2_317>0</OEMLED2_317>
		<OEMDRO2_318>0.</OEMDRO2_318>
		<OEMLED2_318>0</OEMLED2_318>
		<OEMDRO2_319>0.</OEMDRO2_319>
		<OEMLED2_319>0</OEMLED2_319>
		<OEMDRO2_320>0.</OEMDRO2_320>
		<OEMLED2_320>0</OEMLED2_320>
		<OEMDRO2_321>0.</OEMDRO2_321>
		<OEMLED2_321>0</OEMLED2_321>
		<OEMDRO2_322>0.</OEMDRO2_322>
		<OEMLED2_322>0</OEMLED2_322>
		<OEMDRO2_323>0.</OEMDRO2_323>
		<OEMLED2_323>0</OEMLED2_323>
		<OEMDRO2_324>0.</OEMDRO2_324>
		<OEMLED2_324>0</OEMLED2_324>
		<OEMDRO2_325>0.</OEMDRO2_325>
		<OEMLED2_325>0</OEMLED2_325>
		<OEMDRO2_326>0.</OEMDRO2_326>
		<OEMLED2_326>0</OEMLED2_326>
		<OEMDRO2_327>0.</OEMDRO2_327>
		<OEMLED2_327>0</OEMLED2_327>
		<OEMDRO2_328>0.</OEMDRO2_328>
		<OEMLED2_328>0</OEMLED2_328>
		<OEMDRO2_329>0.</OEMDRO2_329>
		<OEMLED2_329>0</OEMLED2_329>
		<OEMDRO2_330>0.</OEMDRO2_330>
		<OEMLED2_330>0</OEMLED2_330>
		<OEMDRO2_331>0.</OEMDRO2_331>
		<OEMLED2_331>0</OEMLED2_331>
		<OEMDRO2_332>0.</OEMDRO2_332>
		<OEMLED2_332>0</OEMLED2_332>
		<OEMDRO2_333>0.</OEMDRO2_333>
		<OEMLED2_333>0</OEMLED2_333>
		<OEMDRO2_334>0.</OEMDRO2_334>
		<OEMLED2_334>0</OEMLED2_334>
		<OEMDRO2_335>0.</OEMDRO2_335>
		<OEMLED2_335>0</OEMLED2_335>
		<OEMDRO2_336>0.</OEMDRO2_336>
		<OEMLED2_336>0</OEMLED2_336>
		<OEMDRO2_337>0.</OEMDRO2_337>
		<OEMLED2_337>0</OEMLED2_337>
		<OEMDRO2_338>0.</OEMDRO2_338>
		<OEMLED2_338>0</OEMLED2_338>
		<OEMDRO2_339>0.</OEMDRO2_339>
		<OEMLED2_339>0</OEMLED2_339>
		<OEMDRO2_340>0.</OEMDRO2_340>
		<OEMLED2_340>0</OEMLED2_340>
		<OEMDRO2_341>0.</OEMDRO2_341>
		<OEMLED2_341>0</OEMLED2_341>
		<OEMDRO2_342>0.</OEMDRO2_342>
		<OEMLED2_342>0</OEMLED2_342>
		<OEMDRO2_343>0.</OEMDRO2_343>
		<OEMLED2_343>0</OEMLED2_343>
		<OEMDRO2_344>0.</OEMDRO2_344>
		<OEMLED2_344>0</OEMLED2_344>
		<OEMDRO2_345>0.</OEMDRO2_345>
		<OEMLED2_345>0</OEMLED2_345>
		<OEMDRO2_346>0.</OEMDRO2_346>
		<OEMLED2_346>0</OEMLED2_346>
		<OEMDRO2_347>0.</OEMDRO2_347>
		<OEMLED2_347>0</OEMLED2_347>
		<OEMDRO2_348>0.</OEMDRO2_348>
		<OEMLED2_348>0</OEMLED2_348>
		<OEMDRO2_349>0.</OEMDRO2_349>
		<OEMLED2_349>0</OEMLED2_349>
		<OEMDRO2_350>0.</OEMDRO2_350>
		<OEMLED2_350>0</OEMLED2_350>
		<OEMDRO2_351>0.</OEMDRO2_351>
		<OEMLED2_351>0</OEMLED2_351>
		<OEMDRO2_352>0.</OEMDRO2_352>
		<OEMLED2_352>0</OEMLED2_352>
		<OEMDRO2_353>0.</OEMDRO2_353>
		<OEMLED2_353>0</OEMLED2_353>
		<OEMDRO2_354>0.</OEMDRO2_354>
		<OEMLED2_354>0</OEMLED2_354>
		<OEMDRO2_355>0.</OEMDRO2_355>
		<OEMLED2_355>0</OEMLED2_355>
		<OEMDRO2_356>0.</OEMDRO2_356>
		<OEMLED2_356>0</OEMLED2_356>
		<OEMDRO2_357>0.</OEMDRO2_357>
		<OEMLED2_357>0</OEMLED2_357>
		<OEMDRO2_358>0.</OEMDRO2_358>
		<OEMLED2_358>0</OEMLED2_358>
		<OEMDRO2_359>0.</OEMDRO2_359>
		<OEMLED2_359>0</OEMLED2_359>
		<OEMDRO2_360>0.</OEMDRO2_360>
		<OEMLED2_360>0</OEMLED2_360>
		<OEMDRO2_361>0.</OEMDRO2_361>
		<OEMLED2_361>0</OEMLED2_361>
		<OEMDRO2_362>0.</OEMDRO2_362>
		<OEMLED2_362>0</OEMLED2_362>
		<OEMDRO2_363>0.</OEMDRO2_363>
		<OEMLED2_363>0</OEMLED2_363>
		<OEMDRO2_364>0.</OEMDRO2_364>
		<OEMLED2_364>0</OEMLED2_364>
		<OEMDRO2_365>0.</OEMDRO2_365>
		<OEMLED2_365>0</OEMLED2_365>
		<OEMDRO2_366>0.</OEMDRO2_366>
		<OEMLED2_366>0</OEMLED2_366>
		<OEMDRO2_367>0.</OEMDRO2_367>
		<OEMLED2_367>0</OEMLED2_367>
		<OEMDRO2_368>0.</OEMDRO2_368>
		<OEMLED2_368>0</OEMLED2_368>
		<OEMDRO2_369>0.</OEMDRO2_369>
		<OEMLED2_369>0</OEMLED2_369>
		<OEMDRO2_370>0.</OEMDRO2_370>
		<OEMLED2_370>0</OEMLED2_370>
		<OEMDRO2_371>0.</OEMDRO2_371>
		<OEMLED2_371>0</OEMLED2_371>
		<OEMDRO2_372>0.</OEMDRO2_372>
		<OEMLED2_372>0</OEMLED2_372>
		<OEMDRO2_373>0.</OEMDRO2_373>
		<OEMLED2_373>0</OEMLED2_373>
		<OEMDRO2_374>0.</OEMDRO2_374>
		<OEMLED2_374>0</OEMLED2_374>
		<OEMDRO2_375>0.</OEMDRO2_375>
		<OEMLED2_375>0</OEMLED2_375>
		<OEMDRO2_376>0.</OEMDRO2_376>
		<OEMLED2_376>0</OEMLED2_376>
		<OEMDRO2_377>0.</OEMDRO2_377>
		<OEMLED2_377>0</OEMLED2_377>
		<OEMDRO2_378>0.</OEMDRO2_378>
		<OEMLED2_378>0</OEMLED2_378>
		<OEMDRO2_379>0.</OEMDRO2_379>
		<OEMLED2_379>0</OEMLED2_379>
		<OEMDRO2_380>0.</OEMDRO2_380>
		<OEMLED2_380>0</OEMLED2_380>
		<OEMDRO2_381>0.</OEMDRO2_381>
		<OEMLED2_381>0</OEMLED2_381>
		<OEMDRO2_382>0.</OEMDRO2_382>
		<OEMLED2_382>0</OEMLED2_382>
		<OEMDRO2_383>0.</OEMDRO2_383>
		<OEMLED2_383>0</OEMLED2_383>
		<OEMDRO2_384>0.</OEMDRO2_384>
		<OEMLED2_384>0</OEMLED2_384>
		<OEMDRO2_385>0.</OEMDRO2_385>
		<OEMLED2_385>0</OEMLED2_385>
		<OEMDRO2_386>0.</OEMDRO2_386>
		<OEMLED2_386>0</OEMLED2_386>
		<OEMDRO2_387>0.</OEMDRO2_387>
		<OEMLED2_387>0</OEMLED2_387>
		<OEMDRO2_388>0.</OEMDRO2_388>
		<OEMLED2_388>0</OEMLED2_388>
		<OEMDRO2_389>0.</OEMDRO2_389>
		<OEMLED2_389>0</OEMLED2_389>
		<OEMDRO2_390>0.</OEMDRO2_390>
		<OEMLED2_390>0</OEMLED2_390>
		<OEMDRO2_391>0.</OEMDRO2_391>
		<OEMLED2_391>0</OEMLED2_391>
		<OEMDRO2_392>0.</OEMDRO2_392>
		<OEMLED2_392>0</OEMLED2_392>
		<OEMDRO2_393>0.</OEMDRO2_393>
		<OEMLED2_393>0</OEMLED2_393>
		<OEMDRO2_394>0.</OEMDRO2_394>
		<OEMLED2_394>0</OEMLED2_394>
		<OEMDRO2_395>0.</OEMDRO2_395>
		<OEMLED2_395>0</OEMLED2_395>
		<OEMDRO2_396>0.</OEMDRO2_396>
		<OEMLED2_396>0</OEMLED2_396>
		<OEMDRO2_397>0.</OEMDRO2_397>
		<OEMLED2_397>0</OEMLED2_397>
		<OEMDRO2_398>0.</OEMDRO2_398>
		<OEMLED2_398>0</OEMLED2_398>
		<OEMDRO2_399>0.</OEMDRO2_399>
		<OEMLED2_399>0</OEMLED2_399>
		<OEMDRO2_400>0.</OEMDRO2_400>
		<OEMLED2_400>0</OEMLED2_400>
		<OEMDRO2_401>0.</OEMDRO2_401>
		<OEMLED2_401>0</OEMLED2_401>
		<OEMDRO2_402>0.</OEMDRO2_402>
		<OEMLED2_402>0</OEMLED2_402>
		<OEMDRO2_403>0.</OEMDRO2_403>
		<OEMLED2_403>0</OEMLED2_403>
		<OEMDRO2_404>0.</OEMDRO2_404>
		<OEMLED2_404>0</OEMLED2_404>
		<OEMDRO2_405>0.</OEMDRO2_405>
		<OEMLED2_405>0</OEMLED2_405>
		<OEMDRO2_406>0.</OEMDRO2_406>
		<OEMLED2_406>0</OEMLED2_406>
		<OEMDRO2_407>0.</OEMDRO2_407>
		<OEMLED2_407>0</OEMLED2_407>
		<OEMDRO2_408>0.</OEMDRO2_408>
		<OEMLED2_408>0</OEMLED2_408>
		<OEMDRO2_409>0.</OEMDRO2_409>
		<OEMLED2_409>0</OEMLED2_409>
		<OEMDRO2_410>0.</OEMDRO2_410>
		<OEMLED2_410>0</OEMLED2_410>
		<OEMDRO2_411>0.</OEMDRO2_411>
		<OEMLED2_411>0</OEMLED2_411>
		<OEMDRO2_412>0.</OEMDRO2_412>
		<OEMLED2_412>0</OEMLED2_412>
		<OEMDRO2_413>0.</OEMDRO2_413>
		<OEMLED2_413>0</OEMLED2_413>
		<OEMDRO2_414>0.</OEMDRO2_414>
		<OEMLED2_414>0</OEMLED2_414>
		<OEMDRO2_415>0.</OEMDRO2_415>
		<OEMLED2_415>0</OEMLED2_415>
		<OEMDRO2_416>0.</OEMDRO2_416>
		<OEMLED2_416>0</OEMLED2_416>
		<OEMDRO2_417>0.</OEMDRO2_417>
		<OEMLED2_417>0</OEMLED2_417>
		<OEMDRO2_418>0.</OEMDRO2_418>
		<OEMLED2_418>0</OEMLED2_418>
		<OEMDRO2_419>0.</OEMDRO2_419>
		<OEMLED2_419>0</OEMLED2_419>
		<OEMDRO2_420>0.</OEMDRO2_420>
		<OEMLED2_420>0</OEMLED2_420>
		<OEMDRO2_421>0.</OEMDRO2_421>
		<OEMLED2_421>0</OEMLED2_421>
		<OEMDRO2_422>0.</OEMDRO2_422>
		<OEMLED2_422>0</OEMLED2_422>
		<OEMDRO2_423>0.</OEMDRO2_423>
		<OEMLED2_423>0</OEMLED2_423>
		<OEMDRO2_424>0.</OEMDRO2_424>
		<OEMLED2_424>0</OEMLED2_424>
		<OEMDRO2_425>0.</OEMDRO2_425>
		<OEMLED2_425>0</OEMLED2_425>
		<OEMDRO2_426>0.</OEMDRO2_426>
		<OEMLED2_426>0</OEMLED2_426>
		<OEMDRO2_427>0.</OEMDRO2_427>
		<OEMLED2_427>0</OEMLED2_427>
		<OEMDRO2_428>0.</OEMDRO2_428>
		<OEMLED2_428>0</OEMLED2_428>
		<OEMDRO2_429>0.</OEMDRO2_429>
		<OEMLED2_429>0</OEMLED2_429>
		<OEMDRO2_430>0.</OEMDRO2_430>
		<OEMLED2_430>0</OEMLED2_430>
		<OEMDRO2_431>0.</OEMDRO2_431>
		<OEMLED2_431>0</OEMLED2_431>
		<OEMDRO2_432>0.</OEMDRO2_432>
		<OEMLED2_432>0</OEMLED2_432>
		<OEMDRO2_433>0.</OEMDRO2_433>
		<OEMLED2_433>0</OEMLED2_433>
		<OEMDRO2_434>0.</OEMDRO2_434>
		<OEMLED2_434>0</OEMLED2_434>
		<OEMDRO2_435>0.</OEMDRO2_435>
		<OEMLED2_435>0</OEMLED2_435>
		<OEMDRO2_436>0.</OEMDRO2_436>
		<OEMLED2_436>0</OEMLED2_436>
		<OEMDRO2_437>0.</OEMDRO2_437>
		<OEMLED2_437>0</OEMLED2_437>
		<OEMDRO2_438>0.</OEMDRO2_438>
		<OEMLED2_438>0</OEMLED2_438>
		<OEMDRO2_439>0.</OEMDRO2_439>
		<OEMLED2_439>0</OEMLED2_439>
		<OEMDRO2_440>0.</OEMDRO2_440>
		<OEMLED2_440>0</OEMLED2_440>
		<OEMDRO2_441>0.</OEMDRO2_441>
		<OEMLED2_441>0</OEMLED2_441>
		<OEMDRO2_442>0.</OEMDRO2_442>
		<OEMLED2_442>0</OEMLED2_442>
		<OEMDRO2_443>0.</OEMDRO2_443>
		<OEMLED2_443>0</OEMLED2_443>
		<OEMDRO2_444>0.</OEMDRO2_444>
		<OEMLED2_444>0</OEMLED2_444>
		<OEMDRO2_445>0.</OEMDRO2_445>
		<OEMLED2_445>0</OEMLED2_445>
		<OEMDRO2_446>0.</OEMDRO2_446>
		<OEMLED2_446>0</OEMLED2_446>
		<OEMDRO2_447>0.</OEMDRO2_447>
		<OEMLED2_447>0</OEMLED2_447>
		<OEMDRO2_448>0.</OEMDRO2_448>
		<OEMLED2_448>0</OEMLED2_448>
		<OEMDRO2_449>0.</OEMDRO2_449>
		<OEMLED2_449>0</OEMLED2_449>
		<OEMDRO2_450>0.</OEMDRO2_450>
		<OEMLED2_450>0</OEMLED2_450>
		<OEMDRO2_451>0.</OEMDRO2_451>
		<OEMLED2_451>0</OEMLED2_451>
		<OEMDRO2_452>0.</OEMDRO2_452>
		<OEMLED2_452>0</OEMLED2_452>
		<OEMDRO2_453>0.</OEMDRO2_453>
		<OEMLED2_453>0</OEMLED2_453>
		<OEMDRO2_454>0.</OEMDRO2_454>
		<OEMLED2_454>0</OEMLED2_454>
		<OEMDRO2_455>0.</OEMDRO2_455>
		<OEMLED2_455>0</OEMLED2_455>
		<OEMDRO2_456>0.</OEMDRO2_456>
		<OEMLED2_456>0</OEMLED2_456>
		<OEMDRO2_457>0.</OEMDRO2_457>
		<OEMLED2_457>0</OEMLED2_457>
		<OEMDRO2_458>0.</OEMDRO2_458>
		<OEMLED2_458>0</OEMLED2_458>
		<OEMDRO2_459>0.</OEMDRO2_459>
		<OEMLED2_459>0</OEMLED2_459>
		<OEMDRO2_460>0.</OEMDRO2_460>
		<OEMLED2_460>0</OEMLED2_460>
		<OEMDRO2_461>0.</OEMDRO2_461>
		<OEMLED2_461>0</OEMLED2_461>
		<OEMDRO2_462>0.</OEMDRO2_462>
		<OEMLED2_462>0</OEMLED2_462>
		<OEMDRO2_463>0.</OEMDRO2_463>
		<OEMLED2_463>0</OEMLED2_463>
		<OEMDRO2_464>0.</OEMDRO2_464>
		<OEMLED2_464>0</OEMLED2_464>
		<OEMDRO2_465>0.</OEMDRO2_465>
		<OEMLED2_465>0</OEMLED2_465>
		<OEMDRO2_466>0.</OEMDRO2_466>
		<OEMLED2_466>0</OEMLED2_466>
		<OEMDRO2_467>0.</OEMDRO2_467>
		<OEMLED2_467>0</OEMLED2_467>
		<OEMDRO2_468>0.</OEMDRO2_468>
		<OEMLED2_468>0</OEMLED2_468>
		<OEMDRO2_469>0.</OEMDRO2_469>
		<OEMLED2_469>0</OEMLED2_469>
		<OEMDRO2_470>0.</OEMDRO2_470>
		<OEMLED2_470>0</OEMLED2_470>
		<OEMDRO2_471>0.</OEMDRO2_471>
		<OEMLED2_471>0</OEMLED2_471>
		<OEMDRO2_472>0.</OEMDRO2_472>
		<OEMLED2_472>0</OEMLED2_472>
		<OEMDRO2_473>0.</OEMDRO2_473>
		<OEMLED2_473>0</OEMLED2_473>
		<OEMDRO2_474>0.</OEMDRO2_474>
		<OEMLED2_474>0</OEMLED2_474>
		<OEMDRO2_475>0.</OEMDRO2_475>
		<OEMLED2_475>0</OEMLED2_475>
		<OEMDRO2_476>0.</OEMDRO2_476>
		<OEMLED2_476>0</OEMLED2_476>
		<OEMDRO2_477>0.</OEMDRO2_477>
		<OEMLED2_477>0</OEMLED2_477>
		<OEMDRO2_478>0.</OEMDRO2_478>
		<OEMLED2_478>0</OEMLED2_478>
		<OEMDRO2_479>0.</OEMDRO2_479>
		<OEMLED2_479>0</OEMLED2_479>
		<OEMDRO2_480>0.</OEMDRO2_480>
		<OEMLED2_480>0</OEMLED2_480>
		<OEMDRO2_481>0.</OEMDRO2_481>
		<OEMLED2_481>0</OEMLED2_481>
		<OEMDRO2_482>0.</OEMDRO2_482>
		<OEMLED2_482>0</OEMLED2_482>
		<OEMDRO2_483>0.</OEMDRO2_483>
		<OEMLED2_483>0</OEMLED2_483>
		<OEMDRO2_484>0.</OEMDRO2_484>
		<OEMLED2_484>0</OEMLED2_484>
		<OEMDRO2_485>0.</OEMDRO2_485>
		<OEMLED2_485>0</OEMLED2_485>
		<OEMDRO2_486>0.</OEMDRO2_486>
		<OEMLED2_486>0</OEMLED2_486>
		<OEMDRO2_487>0.</OEMDRO2_487>
		<OEMLED2_487>0</OEMLED2_487>
		<OEMDRO2_488>0.</OEMDRO2_488>
		<OEMLED2_488>0</OEMLED2_488>
		<OEMDRO2_489>0.</OEMDRO2_489>
		<OEMLED2_489>0</OEMLED2_489>
		<OEMDRO2_490>0.</OEMDRO2_490>
		<OEMLED2_490>0</OEMLED2_490>
		<OEMDRO2_491>0.</OEMDRO2_491>
		<OEMLED2_491>0</OEMLED2_491>
		<OEMDRO2_492>0.</OEMDRO2_492>
		<OEMLED2_492>0</OEMLED2_492>
		<OEMDRO2_493>0.</OEMDRO2_493>
		<OEMLED2_493>0</OEMLED2_493>
		<OEMDRO2_494>0.</OEMDRO2_494>
		<OEMLED2_494>0</OEMLED2_494>
		<OEMDRO2_495>0.</OEMDRO2_495>
		<OEMLED2_495>0</OEMLED2_495>
		<OEMDRO2_496>0.</OEMDRO2_496>
		<OEMLED2_496>0</OEMLED2_496>
		<OEMDRO2_497>0.</OEMDRO2_497>
		<OEMLED2_497>0</OEMLED2_497>
		<OEMDRO2_498>0.</OEMDRO2_498>
		<OEMLED2_498>0</OEMLED2_498>
		<OEMDRO2_499>0.</OEMDRO2_499>
		<OEMLED2_499>0</OEMLED2_499>
		<OEMDRO2_500>0.</OEMDRO2_500>
		<OEMLED2_500>0</OEMLED2_500>
		<OEMDRO2_501>0.</OEMDRO2_501>
		<OEMLED2_501>0</OEMLED2_501>
		<OEMDRO2_502>0.</OEMDRO2_502>
		<OEMLED2_502>0</OEMLED2_502>
		<OEMDRO2_503>0.</OEMDRO2_503>
		<OEMLED2_503>0</OEMLED2_503>
		<OEMDRO2_504>0.</OEMDRO2_504>
		<OEMLED2_504>0</OEMLED2_504>
		<OEMDRO2_505>0.</OEMDRO2_505>
		<OEMLED2_505>0</OEMLED2_505>
		<OEMDRO2_506>0.</OEMDRO2_506>
		<OEMLED2_506>0</OEMLED2_506>
		<OEMDRO2_507>0.</OEMDRO2_507>
		<OEMLED2_507>0</OEMLED2_507>
		<OEMDRO2_508>0.</OEMDRO2_508>
		<OEMLED2_508>0</OEMLED2_508>
		<OEMDRO2_509>0.</OEMDRO2_509>
		<OEMLED2_509>0</OEMLED2_509>
		<OEMDRO2_510>0.</OEMDRO2_510>
		<OEMLED2_510>0</OEMLED2_510>
		<OEMDRO2_511>0.</OEMDRO2_511>
		<OEMLED2_511>0</OEMLED2_511>
		<OEMDRO2_512>0.</OEMDRO2_512>
		<OEMLED2_512>0</OEMLED2_512>
		<OEMDRO2_513>0.</OEMDRO2_513>
		<OEMLED2_513>0</OEMLED2_513>
		<OEMDRO2_514>0.</OEMDRO2_514>
		<OEMLED2_514>0</OEMLED2_514>
		<OEMDRO2_515>0.</OEMDRO2_515>
		<OEMLED2_515>0</OEMLED2_515>
		<OEMDRO2_516>0.</OEMDRO2_516>
		<OEMLED2_516>0</OEMLED2_516>
		<OEMDRO2_517>0.</OEMDRO2_517>
		<OEMLED2_517>0</OEMLED2_517>
		<OEMDRO2_518>0.</OEMDRO2_518>
		<OEMLED2_518>0</OEMLED2_518>
		<OEMDRO2_519>0.</OEMDRO2_519>
		<OEMLED2_519>0</OEMLED2_519>
		<OEMDRO2_520>0.</OEMDRO2_520>
		<OEMLED2_520>0</OEMLED2_520>
		<OEMDRO2_521>0.</OEMDRO2_521>
		<OEMLED2_521>0</OEMLED2_521>
		<OEMDRO2_522>0.</OEMDRO2_522>
		<OEMLED2_522>0</OEMLED2_522>
		<OEMDRO2_523>0.</OEMDRO2_523>
		<OEMLED2_523>0</OEMLED2_523>
		<OEMDRO2_524>0.</OEMDRO2_524>
		<OEMLED2_524>0</OEMLED2_524>
		<OEMDRO2_525>0.</OEMDRO2_525>
		<OEMLED2_525>0</OEMLED2_525>
		<OEMDRO2_526>0.</OEMDRO2_526>
		<OEMLED2_526>0</OEMLED2_526>
		<OEMDRO2_527>0.</OEMDRO2_527>
		<OEMLED2_527>0</OEMLED2_527>
		<OEMDRO2_528>0.</OEMDRO2_528>
		<OEMLED2_528>0</OEMLED2_528>
		<OEMDRO2_529>0.</OEMDRO2_529>
		<OEMLED2_529>0</OEMLED2_529>
		<OEMDRO2_530>0.</OEMDRO2_530>
		<OEMLED2_530>0</OEMLED2_530>
		<OEMDRO2_531>0.</OEMDRO2_531>
		<OEMLED2_531>0</OEMLED2_531>
		<OEMDRO2_532>0.</OEMDRO2_532>
		<OEMLED2_532>0</OEMLED2_532>
		<OEMDRO2_533>0.</OEMDRO2_533>
		<OEMLED2_533>0</OEMLED2_533>
		<OEMDRO2_534>0.</OEMDRO2_534>
		<OEMLED2_534>0</OEMLED2_534>
		<OEMDRO2_535>0.</OEMDRO2_535>
		<OEMLED2_535>0</OEMLED2_535>
		<OEMDRO2_536>0.</OEMDRO2_536>
		<OEMLED2_536>0</OEMLED2_536>
		<OEMDRO2_537>0.</OEMDRO2_537>
		<OEMLED2_537>0</OEMLED2_537>
		<OEMDRO2_538>0.</OEMDRO2_538>
		<OEMLED2_538>0</OEMLED2_538>
		<OEMDRO2_539>0.</OEMDRO2_539>
		<OEMLED2_539>0</OEMLED2_539>
		<OEMDRO2_540>0.</OEMDRO2_540>
		<OEMLED2_540>0</OEMLED2_540>
		<OEMDRO2_541>0.</OEMDRO2_541>
		<OEMLED2_541>0</OEMLED2_541>
		<OEMDRO2_542>0.</OEMDRO2_542>
		<OEMLED2_542>0</OEMLED2_542>
		<OEMDRO2_543>0.</OEMDRO2_543>
		<OEMLED2_543>0</OEMLED2_543>
		<OEMDRO2_544>0.</OEMDRO2_544>
		<OEMLED2_544>0</OEMLED2_544>
		<OEMDRO2_545>0.</OEMDRO2_545>
		<OEMLED2_545>0</OEMLED2_545>
		<OEMDRO2_546>0.</OEMDRO2_546>
		<OEMLED2_546>0</OEMLED2_546>
		<OEMDRO2_547>0.</OEMDRO2_547>
		<OEMLED2_547>0</OEMLED2_547>
		<OEMDRO2_548>0.</OEMDRO2_548>
		<OEMLED2_548>0</OEMLED2_548>
		<OEMDRO2_549>0.</OEMDRO2_549>
		<OEMLED2_549>0</OEMLED2_549>
		<OEMDRO2_550>0.</OEMDRO2_550>
		<OEMLED2_550>0</OEMLED2_550>
		<OEMDRO2_551>0.</OEMDRO2_551>
		<OEMLED2_551>0</OEMLED2_551>
		<OEMDRO2_552>0.</OEMDRO2_552>
		<OEMLED2_552>0</OEMLED2_552>
		<OEMDRO2_553>0.</OEMDRO2_553>
		<OEMLED2_553>0</OEMLED2_553>
		<OEMDRO2_554>0.</OEMDRO2_554>
		<OEMLED2_554>0</OEMLED2_554>
		<OEMDRO2_555>0.</OEMDRO2_555>
		<OEMLED2_555>0</OEMLED2_555>
		<OEMDRO2_556>0.</OEMDRO2_556>
		<OEMLED2_556>0</OEMLED2_556>
		<OEMDRO2_557>0.</OEMDRO2_557>
		<OEMLED2_557>0</OEMLED2_557>
		<OEMDRO2_558>0.</OEMDRO2_558>
		<OEMLED2_558>0</OEMLED2_558>
		<OEMDRO2_559>0.</OEMDRO2_559>
		<OEMLED2_559>0</OEMLED2_559>
		<OEMDRO2_560>0.</OEMDRO2_560>
		<OEMLED2_560>0</OEMLED2_560>
		<OEMDRO2_561>0.</OEMDRO2_561>
		<OEMLED2_561>0</OEMLED2_561>
		<OEMDRO2_562>0.</OEMDRO2_562>
		<OEMLED2_562>0</OEMLED2_562>
		<OEMDRO2_563>0.</OEMDRO2_563>
		<OEMLED2_563>0</OEMLED2_563>
		<OEMDRO2_564>0.</OEMDRO2_564>
		<OEMLED2_564>0</OEMLED2_564>
		<OEMDRO2_565>0.</OEMDRO2_565>
		<OEMLED2_565>0</OEMLED2_565>
		<OEMDRO2_566>0.</OEMDRO2_566>
		<OEMLED2_566>0</OEMLED2_566>
		<OEMDRO2_567>0.</OEMDRO2_567>
		<OEMLED2_567>0</OEMLED2_567>
		<OEMDRO2_568>0.</OEMDRO2_568>
		<OEMLED2_568>0</OEMLED2_568>
		<OEMDRO2_569>0.</OEMDRO2_569>
		<OEMLED2_569>0</OEMLED2_569>
		<OEMDRO2_570>0.</OEMDRO2_570>
		<OEMLED2_570>0</OEMLED2_570>
		<OEMDRO2_571>0.</OEMDRO2_571>
		<OEMLED2_571>0</OEMLED2_571>
		<OEMDRO2_572>0.</OEMDRO2_572>
		<OEMLED2_572>0</OEMLED2_572>
		<OEMDRO2_573>0.</OEMDRO2_573>
		<OEMLED2_573>0</OEMLED2_573>
		<OEMDRO2_574>0.</OEMDRO2_574>
		<OEMLED2_574>0</OEMLED2_574>
		<OEMDRO2_575>0.</OEMDRO2_575>
		<OEMLED2_575>0</OEMLED2_575>
		<OEMDRO2_576>0.</OEMDRO2_576>
		<OEMLED2_576>0</OEMLED2_576>
		<OEMDRO2_577>0.</OEMDRO2_577>
		<OEMLED2_577>0</OEMLED2_577>
		<OEMDRO2_578>0.</OEMDRO2_578>
		<OEMLED2_578>0</OEMLED2_578>
		<OEMDRO2_579>0.</OEMDRO2_579>
		<OEMLED2_579>0</OEMLED2_579>
		<OEMDRO2_580>0.</OEMDRO2_580>
		<OEMLED2_580>0</OEMLED2_580>
		<OEMDRO2_581>0.</OEMDRO2_581>
		<OEMLED2_581>0</OEMLED2_581>
		<OEMDRO2_582>0.</OEMDRO2_582>
		<OEMLED2_582>0</OEMLED2_582>
		<OEMDRO2_583>0.</OEMDRO2_583>
		<OEMLED2_583>0</OEMLED2_583>
		<OEMDRO2_584>0.</OEMDRO2_584>
		<OEMLED2_584>0</OEMLED2_584>
		<OEMDRO2_585>0.</OEMDRO2_585>
		<OEMLED2_585>0</OEMLED2_585>
		<OEMDRO2_586>0.</OEMDRO2_586>
		<OEMLED2_586>0</OEMLED2_586>
		<OEMDRO2_587>0.</OEMDRO2_587>
		<OEMLED2_587>0</OEMLED2_587>
		<OEMDRO2_588>0.</OEMDRO2_588>
		<OEMLED2_588>0</OEMLED2_588>
		<OEMDRO2_589>0.</OEMDRO2_589>
		<OEMLED2_589>0</OEMLED2_589>
		<OEMDRO2_590>0.</OEMDRO2_590>
		<OEMLED2_590>0</OEMLED2_590>
		<OEMDRO2_591>0.</OEMDRO2_591>
		<OEMLED2_591>0</OEMLED2_591>
		<OEMDRO2_592>0.</OEMDRO2_592>
		<OEMLED2_592>0</OEMLED2_592>
		<OEMDRO2_593>0.</OEMDRO2_593>
		<OEMLED2_593>0</OEMLED2_593>
		<OEMDRO2_594>0.</OEMDRO2_594>
		<OEMLED2_594>0</OEMLED2_594>
		<OEMDRO2_595>0.</OEMDRO2_595>
		<OEMLED2_595>0</OEMLED2_595>
		<OEMDRO2_596>0.</OEMDRO2_596>
		<OEMLED2_596>0</OEMLED2_596>
		<OEMDRO2_597>0.</OEMDRO2_597>
		<OEMLED2_597>0</OEMLED2_597>
		<OEMDRO2_598>0.</OEMDRO2_598>
		<OEMLED2_598>0</OEMLED2_598>
		<OEMDRO2_599>0.</OEMDRO2_599>
		<OEMLED2_599>0</OEMLED2_599>
		<OEMDRO2_600>0.</OEMDRO2_600>
		<OEMLED2_600>0</OEMLED2_600>
		<OEMDRO2_601>0.</OEMDRO2_601>
		<OEMLED2_601>0</OEMLED2_601>
		<OEMDRO2_602>0.</OEMDRO2_602>
		<OEMLED2_602>0</OEMLED2_602>
		<OEMDRO2_603>0.</OEMDRO2_603>
		<OEMLED2_603>0</OEMLED2_603>
		<OEMDRO2_604>0.</OEMDRO2_604>
		<OEMLED2_604>0</OEMLED2_604>
		<OEMDRO2_605>0.</OEMDRO2_605>
		<OEMLED2_605>0</OEMLED2_605>
		<OEMDRO2_606>0.</OEMDRO2_606>
		<OEMLED2_606>0</OEMLED2_606>
		<OEMDRO2_607>0.</OEMDRO2_607>
		<OEMLED2_607>0</OEMLED2_607>
		<OEMDRO2_608>0.</OEMDRO2_608>
		<OEMLED2_608>0</OEMLED2_608>
		<OEMDRO2_609>0.</OEMDRO2_609>
		<OEMLED2_609>0</OEMLED2_609>
		<OEMDRO2_610>0.</OEMDRO2_610>
		<OEMLED2_610>0</OEMLED2_610>
		<OEMDRO2_611>0.</OEMDRO2_611>
		<OEMLED2_611>0</OEMLED2_611>
		<OEMDRO2_612>0.</OEMDRO2_612>
		<OEMLED2_612>0</OEMLED2_612>
		<OEMDRO2_613>0.</OEMDRO2_613>
		<OEMLED2_613>0</OEMLED2_613>
		<OEMDRO2_614>0.</OEMDRO2_614>
		<OEMLED2_614>0</OEMLED2_614>
		<OEMDRO2_615>0.</OEMDRO2_615>
		<OEMLED2_615>0</OEMLED2_615>
		<OEMDRO2_616>0.</OEMDRO2_616>
		<OEMLED2_616>0</OEMLED2_616>
		<OEMDRO2_617>0.</OEMDRO2_617>
		<OEMLED2_617>0</OEMLED2_617>
		<OEMDRO2_618>0.</OEMDRO2_618>
		<OEMLED2_618>0</OEMLED2_618>
		<OEMDRO2_619>0.</OEMDRO2_619>
		<OEMLED2_619>0</OEMLED2_619>
		<OEMDRO2_620>0.</OEMDRO2_620>
		<OEMLED2_620>0</OEMLED2_620>
		<OEMDRO2_621>0.</OEMDRO2_621>
		<OEMLED2_621>0</OEMLED2_621>
		<OEMDRO2_622>0.</OEMDRO2_622>
		<OEMLED2_622>0</OEMLED2_622>
		<OEMDRO2_623>0.</OEMDRO2_623>
		<OEMLED2_623>0</OEMLED2_623>
		<OEMDRO2_624>0.</OEMDRO2_624>
		<OEMLED2_624>0</OEMLED2_624>
		<OEMDRO2_625>0.</OEMDRO2_625>
		<OEMLED2_625>0</OEMLED2_625>
		<OEMDRO2_626>0.</OEMDRO2_626>
		<OEMLED2_626>0</OEMLED2_626>
		<OEMDRO2_627>0.</OEMDRO2_627>
		<OEMLED2_627>0</OEMLED2_627>
		<OEMDRO2_628>0.</OEMDRO2_628>
		<OEMLED2_628>0</OEMLED2_628>
		<OEMDRO2_629>0.</OEMDRO2_629>
		<OEMLED2_629>0</OEMLED2_629>
		<OEMDRO2_630>0.</OEMDRO2_630>
		<OEMLED2_630>0</OEMLED2_630>
		<OEMDRO2_631>0.</OEMDRO2_631>
		<OEMLED2_631>0</OEMLED2_631>
		<OEMDRO2_632>0.</OEMDRO2_632>
		<OEMLED2_632>0</OEMLED2_632>
		<OEMDRO2_633>0.</OEMDRO2_633>
		<OEMLED2_633>0</OEMLED2_633>
		<OEMDRO2_634>0.</OEMDRO2_634>
		<OEMLED2_634>0</OEMLED2_634>
		<OEMDRO2_635>0.</OEMDRO2_635>
		<OEMLED2_635>0</OEMLED2_635>
		<OEMDRO2_636>0.</OEMDRO2_636>
		<OEMLED2_636>0</OEMLED2_636>
		<OEMDRO2_637>0.</OEMDRO2_637>
		<OEMLED2_637>0</OEMLED2_637>
		<OEMDRO2_638>0.</OEMDRO2_638>
		<OEMLED2_638>0</OEMLED2_638>
		<OEMDRO2_639>0.</OEMDRO2_639>
		<OEMLED2_639>0</OEMLED2_639>
		<OEMDRO2_640>0.</OEMDRO2_640>
		<OEMLED2_640>0</OEMLED2_640>
		<OEMDRO2_641>0.</OEMDRO2_641>
		<OEMLED2_641>0</OEMLED2_641>
		<OEMDRO2_642>0.</OEMDRO2_642>
		<OEMLED2_642>0</OEMLED2_642>
		<OEMDRO2_643>0.</OEMDRO2_643>
		<OEMLED2_643>0</OEMLED2_643>
		<OEMDRO2_644>0.</OEMDRO2_644>
		<OEMLED2_644>0</OEMLED2_644>
		<OEMDRO2_645>0.</OEMDRO2_645>
		<OEMLED2_645>0</OEMLED2_645>
		<OEMDRO2_646>0.</OEMDRO2_646>
		<OEMLED2_646>0</OEMLED2_646>
		<OEMDRO2_647>0.</OEMDRO2_647>
		<OEMLED2_647>0</OEMLED2_647>
		<OEMDRO2_648>0.</OEMDRO2_648>
		<OEMLED2_648>0</OEMLED2_648>
		<OEMDRO2_649>0.</OEMDRO2_649>
		<OEMLED2_649>0</OEMLED2_649>
		<OEMDRO2_650>0.</OEMDRO2_650>
		<OEMLED2_650>0</OEMLED2_650>
		<OEMDRO2_651>0.</OEMDRO2_651>
		<OEMLED2_651>0</OEMLED2_651>
		<OEMDRO2_652>0.</OEMDRO2_652>
		<OEMLED2_652>0</OEMLED2_652>
		<OEMDRO2_653>0.</OEMDRO2_653>
		<OEMLED2_653>0</OEMLED2_653>
		<OEMDRO2_654>0.</OEMDRO2_654>
		<OEMLED2_654>0</OEMLED2_654>
		<OEMDRO2_655>0.</OEMDRO2_655>
		<OEMLED2_655>0</OEMLED2_655>
		<OEMDRO2_656>0.</OEMDRO2_656>
		<OEMLED2_656>0</OEMLED2_656>
		<OEMDRO2_657>0.</OEMDRO2_657>
		<OEMLED2_657>0</OEMLED2_657>
		<OEMDRO2_658>0.</OEMDRO2_658>
		<OEMLED2_658>0</OEMLED2_658>
		<OEMDRO2_659>0.</OEMDRO2_659>
		<OEMLED2_659>0</OEMLED2_659>
		<OEMDRO2_660>0.</OEMDRO2_660>
		<OEMLED2_660>0</OEMLED2_660>
		<OEMDRO2_661>0.</OEMDRO2_661>
		<OEMLED2_661>0</OEMLED2_661>
		<OEMDRO2_662>0.</OEMDRO2_662>
		<OEMLED2_662>0</OEMLED2_662>
		<OEMDRO2_663>0.</OEMDRO2_663>
		<OEMLED2_663>0</OEMLED2_663>
		<OEMDRO2_664>0.</OEMDRO2_664>
		<OEMLED2_664>0</OEMLED2_664>
		<OEMDRO2_665>0.</OEMDRO2_665>
		<OEMLED2_665>0</OEMLED2_665>
		<OEMDRO2_666>0.</OEMDRO2_666>
		<OEMLED2_666>0</OEMLED2_666>
		<OEMDRO2_667>0.</OEMDRO2_667>
		<OEMLED2_667>0</OEMLED2_667>
		<OEMDRO2_668>0.</OEMDRO2_668>
		<OEMLED2_668>0</OEMLED2_668>
		<OEMDRO2_669>0.</OEMDRO2_669>
		<OEMLED2_669>0</OEMLED2_669>
		<OEMDRO2_670>0.</OEMDRO2_670>
		<OEMLED2_670>0</OEMLED2_670>
		<OEMDRO2_671>0.</OEMDRO2_671>
		<OEMLED2_671>0</OEMLED2_671>
		<OEMDRO2_672>0.</OEMDRO2_672>
		<OEMLED2_672>0</OEMLED2_672>
		<OEMDRO2_673>0.</OEMDRO2_673>
		<OEMLED2_673>0</OEMLED2_673>
		<OEMDRO2_674>0.</OEMDRO2_674>
		<OEMLED2_674>0</OEMLED2_674>
		<OEMDRO2_675>0.</OEMDRO2_675>
		<OEMLED2_675>0</OEMLED2_675>
		<OEMDRO2_676>0.</OEMDRO2_676>
		<OEMLED2_676>0</OEMLED2_676>
		<OEMDRO2_677>0.</OEMDRO2_677>
		<OEMLED2_677>0</OEMLED2_677>
		<OEMDRO2_678>0.</OEMDRO2_678>
		<OEMLED2_678>0</OEMLED2_678>
		<OEMDRO2_679>0.</OEMDRO2_679>
		<OEMLED2_679>0</OEMLED2_679>
		<OEMDRO2_680>0.</OEMDRO2_680>
		<OEMLED2_680>0</OEMLED2_680>
		<OEMDRO2_681>0.</OEMDRO2_681>
		<OEMLED2_681>0</OEMLED2_681>
		<OEMDRO2_682>0.</OEMDRO2_682>
		<OEMLED2_682>0</OEMLED2_682>
		<OEMDRO2_683>0.</OEMDRO2_683>
		<OEMLED2_683>0</OEMLED2_683>
		<OEMDRO2_684>0.</OEMDRO2_684>
		<OEMLED2_684>0</OEMLED2_684>
		<OEMDRO2_685>0.</OEMDRO2_685>
		<OEMLED2_685>0</OEMLED2_685>
		<OEMDRO2_686>0.</OEMDRO2_686>
		<OEMLED2_686>0</OEMLED2_686>
		<OEMDRO2_687>0.</OEMDRO2_687>
		<OEMLED2_687>0</OEMLED2_687>
		<OEMDRO2_688>0.</OEMDRO2_688>
		<OEMLED2_688>0</OEMLED2_688>
		<OEMDRO2_689>0.</OEMDRO2_689>
		<OEMLED2_689>0</OEMLED2_689>
		<OEMDRO2_690>0.</OEMDRO2_690>
		<OEMLED2_690>0</OEMLED2_690>
		<OEMDRO2_691>0.</OEMDRO2_691>
		<OEMLED2_691>0</OEMLED2_691>
		<OEMDRO2_692>0.</OEMDRO2_692>
		<OEMLED2_692>0</OEMLED2_692>
		<OEMDRO2_693>0.</OEMDRO2_693>
		<OEMLED2_693>0</OEMLED2_693>
		<OEMDRO2_694>0.</OEMDRO2_694>
		<OEMLED2_694>0</OEMLED2_694>
		<OEMDRO2_695>0.</OEMDRO2_695>
		<OEMLED2_695>0</OEMLED2_695>
		<OEMDRO2_696>0.</OEMDRO2_696>
		<OEMLED2_696>0</OEMLED2_696>
		<OEMDRO2_697>0.</OEMDRO2_697>
		<OEMLED2_697>0</OEMLED2_697>
		<OEMDRO2_698>0.</OEMDRO2_698>
		<OEMLED2_698>0</OEMLED2_698>
		<OEMDRO2_699>0.</OEMDRO2_699>
		<OEMLED2_699>0</OEMLED2_699>
		<OEMDRO2_700>0.</OEMDRO2_700>
		<OEMLED2_700>0</OEMLED2_700>
		<OEMDRO2_701>0.</OEMDRO2_701>
		<OEMLED2_701>0</OEMLED2_701>
		<OEMDRO2_702>0.</OEMDRO2_702>
		<OEMLED2_702>0</OEMLED2_702>
		<OEMDRO2_703>0.</OEMDRO2_703>
		<OEMLED2_703>0</OEMLED2_703>
		<OEMDRO2_704>0.</OEMDRO2_704>
		<OEMLED2_704>0</OEMLED2_704>
		<OEMDRO2_705>0.</OEMDRO2_705>
		<OEMLED2_705>0</OEMLED2_705>
		<OEMDRO2_706>0.</OEMDRO2_706>
		<OEMLED2_706>0</OEMLED2_706>
		<OEMDRO2_707>0.</OEMDRO2_707>
		<OEMLED2_707>0</OEMLED2_707>
		<OEMDRO2_708>0.</OEMDRO2_708>
		<OEMLED2_708>0</OEMLED2_708>
		<OEMDRO2_709>0.</OEMDRO2_709>
		<OEMLED2_709>0</OEMLED2_709>
		<OEMDRO2_710>0.</OEMDRO2_710>
		<OEMLED2_710>0</OEMLED2_710>
		<OEMDRO2_711>0.</OEMDRO2_711>
		<OEMLED2_711>0</OEMLED2_711>
		<OEMDRO2_712>0.</OEMDRO2_712>
		<OEMLED2_712>0</OEMLED2_712>
		<OEMDRO2_713>0.</OEMDRO2_713>
		<OEMLED2_713>0</OEMLED2_713>
		<OEMDRO2_714>0.</OEMDRO2_714>
		<OEMLED2_714>0</OEMLED2_714>
		<OEMDRO2_715>0.</OEMDRO2_715>
		<OEMLED2_715>0</OEMLED2_715>
		<OEMDRO2_716>0.</OEMDRO2_716>
		<OEMLED2_716>0</OEMLED2_716>
		<OEMDRO2_717>0.</OEMDRO2_717>
		<OEMLED2_717>0</OEMLED2_717>
		<OEMDRO2_718>0.</OEMDRO2_718>
		<OEMLED2_718>0</OEMLED2_718>
		<OEMDRO2_719>0.</OEMDRO2_719>
		<OEMLED2_719>0</OEMLED2_719>
		<OEMDRO2_720>0.</OEMDRO2_720>
		<OEMLED2_720>0</OEMLED2_720>
		<OEMDRO2_721>0.</OEMDRO2_721>
		<OEMLED2_721>0</OEMLED2_721>
		<OEMDRO2_722>0.</OEMDRO2_722>
		<OEMLED2_722>0</OEMLED2_722>
		<OEMDRO2_723>0.</OEMDRO2_723>
		<OEMLED2_723>0</OEMLED2_723>
		<OEMDRO2_724>0.</OEMDRO2_724>
		<OEMLED2_724>0</OEMLED2_724>
		<OEMDRO2_725>0.</OEMDRO2_725>
		<OEMLED2_725>0</OEMLED2_725>
		<OEMDRO2_726>0.</OEMDRO2_726>
		<OEMLED2_726>0</OEMLED2_726>
		<OEMDRO2_727>0.</OEMDRO2_727>
		<OEMLED2_727>0</OEMLED2_727>
		<OEMDRO2_728>0.</OEMDRO2_728>
		<OEMLED2_728>0</OEMLED2_728>
		<OEMDRO2_729>0.</OEMDRO2_729>
		<OEMLED2_729>0</OEMLED2_729>
		<OEMDRO2_730>0.</OEMDRO2_730>
		<OEMLED2_730>0</OEMLED2_730>
		<OEMDRO2_731>0.</OEMDRO2_731>
		<OEMLED2_731>0</OEMLED2_731>
		<OEMDRO2_732>0.</OEMDRO2_732>
		<OEMLED2_732>0</OEMLED2_732>
		<OEMDRO2_733>0.</OEMDRO2_733>
		<OEMLED2_733>0</OEMLED2_733>
		<OEMDRO2_734>0.</OEMDRO2_734>
		<OEMLED2_734>0</OEMLED2_734>
		<OEMDRO2_735>0.</OEMDRO2_735>
		<OEMLED2_735>0</OEMLED2_735>
		<OEMDRO2_736>0.</OEMDRO2_736>
		<OEMLED2_736>0</OEMLED2_736>
		<OEMDRO2_737>0.</OEMDRO2_737>
		<OEMLED2_737>0</OEMLED2_737>
		<OEMDRO2_738>0.</OEMDRO2_738>
		<OEMLED2_738>0</OEMLED2_738>
		<OEMDRO2_739>0.</OEMDRO2_739>
		<OEMLED2_739>0</OEMLED2_739>
		<OEMDRO2_740>0.</OEMDRO2_740>
		<OEMLED2_740>0</OEMLED2_740>
		<OEMDRO2_741>0.</OEMDRO2_741>
		<OEMLED2_741>0</OEMLED2_741>
		<OEMDRO2_742>0.</OEMDRO2_742>
		<OEMLED2_742>0</OEMLED2_742>
		<OEMDRO2_743>0.</OEMDRO2_743>
		<OEMLED2_743>0</OEMLED2_743>
		<OEMDRO2_744>0.</OEMDRO2_744>
		<OEMLED2_744>0</OEMLED2_744>
		<OEMDRO2_745>0.</OEMDRO2_745>
		<OEMLED2_745>0</OEMLED2_745>
		<OEMDRO2_746>0.</OEMDRO2_746>
		<OEMLED2_746>0</OEMLED2_746>
		<OEMDRO2_747>0.</OEMDRO2_747>
		<OEMLED2_747>0</OEMLED2_747>
		<OEMDRO2_748>0.</OEMDRO2_748>
		<OEMLED2_748>0</OEMLED2_748>
		<OEMDRO2_749>0.</OEMDRO2_749>
		<OEMLED2_749>0</OEMLED2_749>
		<OEMDRO2_750>0.</OEMDRO2_750>
		<OEMLED2_750>0</OEMLED2_750>
		<OEMDRO2_751>0.</OEMDRO2_751>
		<OEMLED2_751>0</OEMLED2_751>
		<OEMDRO2_752>0.</OEMDRO2_752>
		<OEMLED2_752>0</OEMLED2_752>
		<OEMDRO2_753>0.</OEMDRO2_753>
		<OEMLED2_753>0</OEMLED2_753>
		<OEMDRO2_754>0.</OEMDRO2_754>
		<OEMLED2_754>0</OEMLED2_754>
		<OEMDRO2_755>0.</OEMDRO2_755>
		<OEMLED2_755>0</OEMLED2_755>
		<OEMDRO2_756>0.</OEMDRO2_756>
		<OEMLED2_756>0</OEMLED2_756>
		<OEMDRO2_757>0.</OEMDRO2_757>
		<OEMLED2_757>0</OEMLED2_757>
		<OEMDRO2_758>0.</OEMDRO2_758>
		<OEMLED2_758>0</OEMLED2_758>
		<OEMDRO2_759>0.</OEMDRO2_759>
		<OEMLED2_759>0</OEMLED2_759>
		<OEMDRO2_760>0.</OEMDRO2_760>
		<OEMLED2_760>0</OEMLED2_760>
		<OEMDRO2_761>0.</OEMDRO2_761>
		<OEMLED2_761>0</OEMLED2_761>
		<OEMDRO2_762>0.</OEMDRO2_762>
		<OEMLED2_762>0</OEMLED2_762>
		<OEMDRO2_763>0.</OEMDRO2_763>
		<OEMLED2_763>0</OEMLED2_763>
		<OEMDRO2_764>0.</OEMDRO2_764>
		<OEMLED2_764>0</OEMLED2_764>
		<OEMDRO2_765>0.</OEMDRO2_765>
		<OEMLED2_765>0</OEMLED2_765>
		<OEMDRO2_766>0.</OEMDRO2_766>
		<OEMLED2_766>0</OEMLED2_766>
		<OEMDRO2_767>0.</OEMDRO2_767>
		<OEMLED2_767>0</OEMLED2_767>
		<OEMDRO2_768>0.</OEMDRO2_768>
		<OEMLED2_768>0</OEMLED2_768>
		<OEMDRO2_769>0.</OEMDRO2_769>
		<OEMLED2_769>0</OEMLED2_769>
		<OEMDRO2_770>0.</OEMDRO2_770>
		<OEMLED2_770>0</OEMLED2_770>
		<OEMDRO2_771>0.</OEMDRO2_771>
		<OEMLED2_771>0</OEMLED2_771>
		<OEMDRO2_772>0.</OEMDRO2_772>
		<OEMLED2_772>0</OEMLED2_772>
		<OEMDRO2_773>0.</OEMDRO2_773>
		<OEMLED2_773>0</OEMLED2_773>
		<OEMDRO2_774>0.</OEMDRO2_774>
		<OEMLED2_774>0</OEMLED2_774>
		<OEMDRO2_775>0.</OEMDRO2_775>
		<OEMLED2_775>0</OEMLED2_775>
		<OEMDRO2_776>0.</OEMDRO2_776>
		<OEMLED2_776>0</OEMLED2_776>
		<OEMDRO2_777>0.</OEMDRO2_777>
		<OEMLED2_777>0</OEMLED2_777>
		<OEMDRO2_778>0.</OEMDRO2_778>
		<OEMLED2_778>0</OEMLED2_778>
		<OEMDRO2_779>0.</OEMDRO2_779>
		<OEMLED2_779>0</OEMLED2_779>
		<OEMDRO2_780>0.</OEMDRO2_780>
		<OEMLED2_780>0</OEMLED2_780>
		<OEMDRO2_781>0.</OEMDRO2_781>
		<OEMLED2_781>0</OEMLED2_781>
		<OEMDRO2_782>0.</OEMDRO2_782>
		<OEMLED2_782>0</OEMLED2_782>
		<OEMDRO2_783>0.</OEMDRO2_783>
		<OEMLED2_783>0</OEMLED2_783>
		<OEMDRO2_784>0.</OEMDRO2_784>
		<OEMLED2_784>0</OEMLED2_784>
		<OEMDRO2_785>0.</OEMDRO2_785>
		<OEMLED2_785>0</OEMLED2_785>
		<OEMDRO2_786>0.</OEMDRO2_786>
		<OEMLED2_786>0</OEMLED2_786>
		<OEMDRO2_787>0.</OEMDRO2_787>
		<OEMLED2_787>0</OEMLED2_787>
		<OEMDRO2_788>0.</OEMDRO2_788>
		<OEMLED2_788>0</OEMLED2_788>
		<OEMDRO2_789>0.</OEMDRO2_789>
		<OEMLED2_789>0</OEMLED2_789>
		<OEMDRO2_790>0.</OEMDRO2_790>
		<OEMLED2_790>0</OEMLED2_790>
		<OEMDRO2_791>0.</OEMDRO2_791>
		<OEMLED2_791>0</OEMLED2_791>
		<OEMDRO2_792>0.</OEMDRO2_792>
		<OEMLED2_792>0</OEMLED2_792>
		<OEMDRO2_793>0.</OEMDRO2_793>
		<OEMLED2_793>0</OEMLED2_793>
		<OEMDRO2_794>0.</OEMDRO2_794>
		<OEMLED2_794>0</OEMLED2_794>
		<OEMDRO2_795>0.</OEMDRO2_795>
		<OEMLED2_795>0</OEMLED2_795>
		<OEMDRO2_796>0.</OEMDRO2_796>
		<OEMLED2_796>0</OEMLED2_796>
		<OEMDRO2_797>0.</OEMDRO2_797>
		<OEMLED2_797>0</OEMLED2_797>
		<OEMDRO2_798>0.</OEMDRO2_798>
		<OEMLED2_798>0</OEMLED2_798>
		<OEMDRO2_799>0.</OEMDRO2_799>
		<OEMLED2_799>0</OEMLED2_799>
		<OEMDRO2_800>0.</OEMDRO2_800>
		<OEMLED2_800>0</OEMLED2_800>
		<OEMDRO2_801>0.</OEMDRO2_801>
		<OEMLED2_801>0</OEMLED2_801>
		<OEMDRO2_802>0.</OEMDRO2_802>
		<OEMLED2_802>0</OEMLED2_802>
		<OEMDRO2_803>0.</OEMDRO2_803>
		<OEMLED2_803>0</OEMLED2_803>
		<OEMDRO2_804>0.</OEMDRO2_804>
		<OEMLED2_804>0</OEMLED2_804>
		<OEMDRO2_805>0.</OEMDRO2_805>
		<OEMLED2_805>0</OEMLED2_805>
		<OEMDRO2_806>0.</OEMDRO2_806>
		<OEMLED2_806>0</OEMLED2_806>
		<OEMDRO2_807>0.</OEMDRO2_807>
		<OEMLED2_807>0</OEMLED2_807>
		<OEMDRO2_808>0.</OEMDRO2_808>
		<OEMLED2_808>0</OEMLED2_808>
		<OEMDRO2_809>0.</OEMDRO2_809>
		<OEMLED2_809>0</OEMLED2_809>
		<OEMDRO2_810>0.</OEMDRO2_810>
		<OEMLED2_810>0</OEMLED2_810>
		<OEMDRO2_811>0.</OEMDRO2_811>
		<OEMLED2_811>0</OEMLED2_811>
		<OEMDRO2_812>0.</OEMDRO2_812>
		<OEMLED2_812>0</OEMLED2_812>
		<OEMDRO2_813>0.</OEMDRO2_813>
		<OEMLED2_813>0</OEMLED2_813>
		<OEMDRO2_814>0.</OEMDRO2_814>
		<OEMLED2_814>0</OEMLED2_814>
		<OEMDRO2_815>0.</OEMDRO2_815>
		<OEMLED2_815>0</OEMLED2_815>
		<OEMDRO2_816>0.</OEMDRO2_816>
		<OEMLED2_816>0</OEMLED2_816>
		<OEMDRO2_817>0.</OEMDRO2_817>
		<OEMLED2_817>0</OEMLED2_817>
		<OEMDRO2_818>0.</OEMDRO2_818>
		<OEMLED2_818>0</OEMLED2_818>
		<OEMDRO2_819>0.</OEMDRO2_819>
		<OEMLED2_819>0</OEMLED2_819>
		<OEMDRO2_820>0.</OEMDRO2_820>
		<OEMLED2_820>0</OEMLED2_820>
		<OEMDRO2_821>0.</OEMDRO2_821>
		<OEMLED2_821>0</OEMLED2_821>
		<OEMDRO2_822>0.</OEMDRO2_822>
		<OEMLED2_822>0</OEMLED2_822>
		<OEMDRO2_823>0.</OEMDRO2_823>
		<OEMLED2_823>0</OEMLED2_823>
		<OEMDRO2_824>0.</OEMDRO2_824>
		<OEMLED2_824>0</OEMLED2_824>
		<OEMDRO2_825>0.</OEMDRO2_825>
		<OEMLED2_825>0</OEMLED2_825>
		<OEMDRO2_826>0.</OEMDRO2_826>
		<OEMLED2_826>0</OEMLED2_826>
		<OEMDRO2_827>0.</OEMDRO2_827>
		<OEMLED2_827>0</OEMLED2_827>
		<OEMDRO2_828>0.</OEMDRO2_828>
		<OEMLED2_828>0</OEMLED2_828>
		<OEMDRO2_829>0.</OEMDRO2_829>
		<OEMLED2_829>0</OEMLED2_829>
		<OEMDRO2_830>0.</OEMDRO2_830>
		<OEMLED2_830>0</OEMLED2_830>
		<OEMDRO2_831>0.</OEMDRO2_831>
		<OEMLED2_831>0</OEMLED2_831>
		<OEMDRO2_832>0.</OEMDRO2_832>
		<OEMLED2_832>0</OEMLED2_832>
		<OEMDRO2_833>0.</OEMDRO2_833>
		<OEMLED2_833>0</OEMLED2_833>
		<OEMDRO2_834>0.</OEMDRO2_834>
		<OEMLED2_834>0</OEMLED2_834>
		<OEMDRO2_835>0.</OEMDRO2_835>
		<OEMLED2_835>0</OEMLED2_835>
		<OEMDRO2_836>0.</OEMDRO2_836>
		<OEMLED2_836>0</OEMLED2_836>
		<OEMDRO2_837>0.</OEMDRO2_837>
		<OEMLED2_837>0</OEMLED2_837>
		<OEMDRO2_838>0.</OEMDRO2_838>
		<OEMLED2_838>0</OEMLED2_838>
		<OEMDRO2_839>0.</OEMDRO2_839>
		<OEMLED2_839>0</OEMLED2_839>
		<OEMDRO2_840>0.</OEMDRO2_840>
		<OEMLED2_840>0</OEMLED2_840>
		<OEMDRO2_841>0.</OEMDRO2_841>
		<OEMLED2_841>0</OEMLED2_841>
		<OEMDRO2_842>0.</OEMDRO2_842>
		<OEMLED2_842>0</OEMLED2_842>
		<OEMDRO2_843>0.</OEMDRO2_843>
		<OEMLED2_843>0</OEMLED2_843>
		<OEMDRO2_844>0.</OEMDRO2_844>
		<OEMLED2_844>0</OEMLED2_844>
		<OEMDRO2_845>0.</OEMDRO2_845>
		<OEMLED2_845>0</OEMLED2_845>
		<OEMDRO2_846>0.</OEMDRO2_846>
		<OEMLED2_846>0</OEMLED2_846>
		<OEMDRO2_847>0.</OEMDRO2_847>
		<OEMLED2_847>0</OEMLED2_847>
		<OEMDRO2_848>0.</OEMDRO2_848>
		<OEMLED2_848>0</OEMLED2_848>
		<OEMDRO2_849>0.</OEMDRO2_849>
		<OEMLED2_849>0</OEMLED2_849>
		<OEMDRO2_850>0.</OEMDRO2_850>
		<OEMLED2_850>0</OEMLED2_850>
		<OEMDRO2_851>0.</OEMDRO2_851>
		<OEMLED2_851>0</OEMLED2_851>
		<OEMDRO2_852>0.</OEMDRO2_852>
		<OEMLED2_852>0</OEMLED2_852>
		<OEMDRO2_853>0.</OEMDRO2_853>
		<OEMLED2_853>0</OEMLED2_853>
		<OEMDRO2_854>0.</OEMDRO2_854>
		<OEMLED2_854>0</OEMLED2_854>
		<OEMDRO2_855>0.</OEMDRO2_855>
		<OEMLED2_855>0</OEMLED2_855>
		<OEMDRO2_856>0.</OEMDRO2_856>
		<OEMLED2_856>0</OEMLED2_856>
		<OEMDRO2_857>0.</OEMDRO2_857>
		<OEMLED2_857>0</OEMLED2_857>
		<OEMDRO2_858>0.</OEMDRO2_858>
		<OEMLED2_858>0</OEMLED2_858>
		<OEMDRO2_859>0.</OEMDRO2_859>
		<OEMLED2_859>0</OEMLED2_859>
		<OEMDRO2_860>0.</OEMDRO2_860>
		<OEMLED2_860>0</OEMLED2_860>
		<OEMDRO2_861>0.</OEMDRO2_861>
		<OEMLED2_861>0</OEMLED2_861>
		<OEMDRO2_862>0.</OEMDRO2_862>
		<OEMLED2_862>0</OEMLED2_862>
		<OEMDRO2_863>0.</OEMDRO2_863>
		<OEMLED2_863>0</OEMLED2_863>
		<OEMDRO2_864>0.</OEMDRO2_864>
		<OEMLED2_864>0</OEMLED2_864>
		<OEMDRO2_865>0.</OEMDRO2_865>
		<OEMLED2_865>0</OEMLED2_865>
		<OEMDRO2_866>0.</OEMDRO2_866>
		<OEMLED2_866>0</OEMLED2_866>
		<OEMDRO2_867>0.</OEMDRO2_867>
		<OEMLED2_867>0</OEMLED2_867>
		<OEMDRO2_868>0.</OEMDRO2_868>
		<OEMLED2_868>0</OEMLED2_868>
		<OEMDRO2_869>0.</OEMDRO2_869>
		<OEMLED2_869>0</OEMLED2_869>
		<OEMDRO2_870>0.</OEMDRO2_870>
		<OEMLED2_870>0</OEMLED2_870>
		<OEMDRO2_871>0.</OEMDRO2_871>
		<OEMLED2_871>0</OEMLED2_871>
		<OEMDRO2_872>0.</OEMDRO2_872>
		<OEMLED2_872>0</OEMLED2_872>
		<OEMDRO2_873>0.</OEMDRO2_873>
		<OEMLED2_873>0</OEMLED2_873>
		<OEMDRO2_874>0.</OEMDRO2_874>
		<OEMLED2_874>0</OEMLED2_874>
		<OEMDRO2_875>0.</OEMDRO2_875>
		<OEMLED2_875>0</OEMLED2_875>
		<OEMDRO2_876>0.</OEMDRO2_876>
		<OEMLED2_876>0</OEMLED2_876>
		<OEMDRO2_877>0.</OEMDRO2_877>
		<OEMLED2_877>0</OEMLED2_877>
		<OEMDRO2_878>0.</OEMDRO2_878>
		<OEMLED2_878>0</OEMLED2_878>
		<OEMDRO2_879>0.</OEMDRO2_879>
		<OEMLED2_879>0</OEMLED2_879>
		<OEMDRO2_880>0.</OEMDRO2_880>
		<OEMLED2_880>0</OEMLED2_880>
		<OEMDRO2_881>0.</OEMDRO2_881>
		<OEMLED2_881>0</OEMLED2_881>
		<OEMDRO2_882>0.</OEMDRO2_882>
		<OEMLED2_882>0</OEMLED2_882>
		<OEMDRO2_883>0.</OEMDRO2_883>
		<OEMLED2_883>0</OEMLED2_883>
		<OEMDRO2_884>0.</OEMDRO2_884>
		<OEMLED2_884>0</OEMLED2_884>
		<OEMDRO2_885>0.</OEMDRO2_885>
		<OEMLED2_885>0</OEMLED2_885>
		<OEMDRO2_886>0.</OEMDRO2_886>
		<OEMLED2_886>0</OEMLED2_886>
		<OEMDRO2_887>0.</OEMDRO2_887>
		<OEMLED2_887>0</OEMLED2_887>
		<OEMDRO2_888>0.</OEMDRO2_888>
		<OEMLED2_888>0</OEMLED2_888>
		<OEMDRO2_889>0.</OEMDRO2_889>
		<OEMLED2_889>0</OEMLED2_889>
		<OEMDRO2_890>0.</OEMDRO2_890>
		<OEMLED2_890>0</OEMLED2_890>
		<OEMDRO2_891>0.</OEMDRO2_891>
		<OEMLED2_891>0</OEMLED2_891>
		<OEMDRO2_892>0.</OEMDRO2_892>
		<OEMLED2_892>0</OEMLED2_892>
		<OEMDRO2_893>0.</OEMDRO2_893>
		<OEMLED2_893>0</OEMLED2_893>
		<OEMDRO2_894>0.</OEMDRO2_894>
		<OEMLED2_894>0</OEMLED2_894>
		<OEMDRO2_895>0.</OEMDRO2_895>
		<OEMLED2_895>0</OEMLED2_895>
		<OEMDRO2_896>0.</OEMDRO2_896>
		<OEMLED2_896>0</OEMLED2_896>
		<OEMDRO2_897>0.</OEMDRO2_897>
		<OEMLED2_897>0</OEMLED2_897>
		<OEMDRO2_898>0.</OEMDRO2_898>
		<OEMLED2_898>0</OEMLED2_898>
		<OEMDRO2_899>0.</OEMDRO2_899>
		<OEMLED2_899>0</OEMLED2_899>
		<OEMDRO2_900>0.</OEMDRO2_900>
		<OEMLED2_900>0</OEMLED2_900>
		<OEMDRO2_901>0.</OEMDRO2_901>
		<OEMLED2_901>0</OEMLED2_901>
		<OEMDRO2_902>0.</OEMDRO2_902>
		<OEMLED2_902>0</OEMLED2_902>
		<OEMDRO2_903>0.</OEMDRO2_903>
		<OEMLED2_903>0</OEMLED2_903>
		<OEMDRO2_904>0.</OEMDRO2_904>
		<OEMLED2_904>0</OEMLED2_904>
		<OEMDRO2_905>0.</OEMDRO2_905>
		<OEMLED2_905>0</OEMLED2_905>
		<OEMDRO2_906>0.</OEMDRO2_906>
		<OEMLED2_906>0</OEMLED2_906>
		<OEMDRO2_907>0.</OEMDRO2_907>
		<OEMLED2_907>0</OEMLED2_907>
		<OEMDRO2_908>0.</OEMDRO2_908>
		<OEMLED2_908>0</OEMLED2_908>
		<OEMDRO2_909>0.</OEMDRO2_909>
		<OEMLED2_909>0</OEMLED2_909>
		<OEMDRO2_910>0.</OEMDRO2_910>
		<OEMLED2_910>0</OEMLED2_910>
		<OEMDRO2_911>0.</OEMDRO2_911>
		<OEMLED2_911>0</OEMLED2_911>
		<OEMDRO2_912>0.</OEMDRO2_912>
		<OEMLED2_912>0</OEMLED2_912>
		<OEMDRO2_913>0.</OEMDRO2_913>
		<OEMLED2_913>0</OEMLED2_913>
		<OEMDRO2_914>0.</OEMDRO2_914>
		<OEMLED2_914>0</OEMLED2_914>
		<OEMDRO2_915>0.</OEMDRO2_915>
		<OEMLED2_915>0</OEMLED2_915>
		<OEMDRO2_916>0.</OEMDRO2_916>
		<OEMLED2_916>0</OEMLED2_916>
		<OEMDRO2_917>0.</OEMDRO2_917>
		<OEMLED2_917>0</OEMLED2_917>
		<OEMDRO2_918>0.</OEMDRO2_918>
		<OEMLED2_918>0</OEMLED2_918>
		<OEMDRO2_919>0.</OEMDRO2_919>
		<OEMLED2_919>0</OEMLED2_919>
		<OEMDRO2_920>0.</OEMDRO2_920>
		<OEMLED2_920>0</OEMLED2_920>
		<OEMDRO2_921>0.</OEMDRO2_921>
		<OEMLED2_921>0</OEMLED2_921>
		<OEMDRO2_922>0.</OEMDRO2_922>
		<OEMLED2_922>0</OEMLED2_922>
		<OEMDRO2_923>0.</OEMDRO2_923>
		<OEMLED2_923>0</OEMLED2_923>
		<OEMDRO2_924>0.</OEMDRO2_924>
		<OEMLED2_924>0</OEMLED2_924>
		<OEMDRO2_925>0.</OEMDRO2_925>
		<OEMLED2_925>0</OEMLED2_925>
		<OEMDRO2_926>0.</OEMDRO2_926>
		<OEMLED2_926>0</OEMLED2_926>
		<OEMDRO2_927>0.</OEMDRO2_927>
		<OEMLED2_927>0</OEMLED2_927>
		<OEMDRO2_928>0.</OEMDRO2_928>
		<OEMLED2_928>0</OEMLED2_928>
		<OEMDRO2_929>0.</OEMDRO2_929>
		<OEMLED2_929>0</OEMLED2_929>
		<OEMDRO2_930>0.</OEMDRO2_930>
		<OEMLED2_930>0</OEMLED2_930>
		<OEMDRO2_931>0.</OEMDRO2_931>
		<OEMLED2_931>0</OEMLED2_931>
		<OEMDRO2_932>0.</OEMDRO2_932>
		<OEMLED2_932>0</OEMLED2_932>
		<OEMDRO2_933>0.</OEMDRO2_933>
		<OEMLED2_933>0</OEMLED2_933>
		<OEMDRO2_934>0.</OEMDRO2_934>
		<OEMLED2_934>0</OEMLED2_934>
		<OEMDRO2_935>0.</OEMDRO2_935>
		<OEMLED2_935>0</OEMLED2_935>
		<OEMDRO2_936>0.</OEMDRO2_936>
		<OEMLED2_936>0</OEMLED2_936>
		<OEMDRO2_937>0.</OEMDRO2_937>
		<OEMLED2_937>0</OEMLED2_937>
		<OEMDRO2_938>0.</OEMDRO2_938>
		<OEMLED2_938>0</OEMLED2_938>
		<OEMDRO2_939>0.</OEMDRO2_939>
		<OEMLED2_939>0</OEMLED2_939>
		<OEMDRO2_940>0.</OEMDRO2_940>
		<OEMLED2_940>0</OEMLED2_940>
		<OEMDRO2_941>0.</OEMDRO2_941>
		<OEMLED2_941>0</OEMLED2_941>
		<OEMDRO2_942>0.</OEMDRO2_942>
		<OEMLED2_942>0</OEMLED2_942>
		<OEMDRO2_943>0.</OEMDRO2_943>
		<OEMLED2_943>0</OEMLED2_943>
		<OEMDRO2_944>0.</OEMDRO2_944>
		<OEMLED2_944>0</OEMLED2_944>
		<OEMDRO2_945>0.</OEMDRO2_945>
		<OEMLED2_945>0</OEMLED2_945>
		<OEMDRO2_946>0.</OEMDRO2_946>
		<OEMLED2_946>0</OEMLED2_946>
		<OEMDRO2_947>0.</OEMDRO2_947>
		<OEMLED2_947>0</OEMLED2_947>
		<OEMDRO2_948>0.</OEMDRO2_948>
		<OEMLED2_948>0</OEMLED2_948>
		<OEMDRO2_949>0.</OEMDRO2_949>
		<OEMLED2_949>0</OEMLED2_949>
		<OEMDRO2_950>0.</OEMDRO2_950>
		<OEMLED2_950>0</OEMLED2_950>
		<OEMDRO2_951>0.</OEMDRO2_951>
		<OEMLED2_951>0</OEMLED2_951>
		<OEMDRO2_952>0.</OEMDRO2_952>
		<OEMLED2_952>0</OEMLED2_952>
		<OEMDRO2_953>0.</OEMDRO2_953>
		<OEMLED2_953>0</OEMLED2_953>
		<OEMDRO2_954>0.</OEMDRO2_954>
		<OEMLED2_954>0</OEMLED2_954>
		<OEMDRO2_955>0.</OEMDRO2_955>
		<OEMLED2_955>0</OEMLED2_955>
		<OEMDRO2_956>0.</OEMDRO2_956>
		<OEMLED2_956>0</OEMLED2_956>
		<OEMDRO2_957>0.</OEMDRO2_957>
		<OEMLED2_957>0</OEMLED2_957>
		<OEMDRO2_958>0.</OEMDRO2_958>
		<OEMLED2_958>0</OEMLED2_958>
		<OEMDRO2_959>0.</OEMDRO2_959>
		<OEMLED2_959>0</OEMLED2_959>
		<OEMDRO2_960>0.</OEMDRO2_960>
		<OEMLED2_960>0</OEMLED2_960>
		<OEMDRO2_961>0.</OEMDRO2_961>
		<OEMLED2_961>0</OEMLED2_961>
		<OEMDRO2_962>0.</OEMDRO2_962>
		<OEMLED2_962>0</OEMLED2_962>
		<OEMDRO2_963>0.</OEMDRO2_963>
		<OEMLED2_963>0</OEMLED2_963>
		<OEMDRO2_964>0.</OEMDRO2_964>
		<OEMLED2_964>0</OEMLED2_964>
		<OEMDRO2_965>0.</OEMDRO2_965>
		<OEMLED2_965>0</OEMLED2_965>
		<OEMDRO2_966>0.</OEMDRO2_966>
		<OEMLED2_966>0</OEMLED2_966>
		<OEMDRO2_967>0.</OEMDRO2_967>
		<OEMLED2_967>0</OEMLED2_967>
		<OEMDRO2_968>0.</OEMDRO2_968>
		<OEMLED2_968>0</OEMLED2_968>
		<OEMDRO2_969>0.</OEMDRO2_969>
		<OEMLED2_969>0</OEMLED2_969>
		<OEMDRO2_970>0.</OEMDRO2_970>
		<OEMLED2_970>0</OEMLED2_970>
		<OEMDRO2_971>0.</OEMDRO2_971>
		<OEMLED2_971>0</OEMLED2_971>
		<OEMDRO2_972>0.</OEMDRO2_972>
		<OEMLED2_972>0</OEMLED2_972>
		<OEMDRO2_973>0.</OEMDRO2_973>
		<OEMLED2_973>0</OEMLED2_973>
		<OEMDRO2_974>0.</OEMDRO2_974>
		<OEMLED2_974>0</OEMLED2_974>
		<OEMDRO2_975>0.</OEMDRO2_975>
		<OEMLED2_975>0</OEMLED2_975>
		<OEMDRO2_976>0.</OEMDRO2_976>
		<OEMLED2_976>0</OEMLED2_976>
		<OEMDRO2_977>0.</OEMDRO2_977>
		<OEMLED2_977>0</OEMLED2_977>
		<OEMDRO2_978>0.</OEMDRO2_978>
		<OEMLED2_978>0</OEMLED2_978>
		<OEMDRO2_979>0.</OEMDRO2_979>
		<OEMLED2_979>0</OEMLED2_979>
		<OEMDRO2_980>0.</OEMDRO2_980>
		<OEMLED2_980>0</OEMLED2_980>
		<OEMDRO2_981>0.</OEMDRO2_981>
		<OEMLED2_981>0</OEMLED2_981>
		<OEMDRO2_982>0.</OEMDRO2_982>
		<OEMLED2_982>0</OEMLED2_982>
		<OEMDRO2_983>0.</OEMDRO2_983>
		<OEMLED2_983>0</OEMLED2_983>
		<OEMDRO2_984>0.</OEMDRO2_984>
		<OEMLED2_984>0</OEMLED2_984>
		<OEMDRO2_985>0.</OEMDRO2_985>
		<OEMLED2_985>0</OEMLED2_985>
		<OEMDRO2_986>0.</OEMDRO2_986>
		<OEMLED2_986>0</OEMLED2_986>
		<OEMDRO2_987>0.</OEMDRO2_987>
		<OEMLED2_987>0</OEMLED2_987>
		<OEMDRO2_988>0.</OEMDRO2_988>
		<OEMLED2_988>0</OEMLED2_988>
		<OEMDRO2_989>0.</OEMDRO2_989>
		<OEMLED2_989>0</OEMLED2_989>
		<OEMDRO2_990>0.</OEMDRO2_990>
		<OEMLED2_990>0</OEMLED2_990>
		<OEMDRO2_991>0.</OEMDRO2_991>
		<OEMLED2_991>0</OEMLED2_991>
		<OEMDRO2_992>0.</OEMDRO2_992>
		<OEMLED2_992>0</OEMLED2_992>
		<OEMDRO2_993>0.</OEMDRO2_993>
		<OEMLED2_993>0</OEMLED2_993>
		<OEMDRO2_994>0.</OEMDRO2_994>
		<OEMLED2_994>0</OEMLED2_994>
		<OEMDRO2_995>0.</OEMDRO2_995>
		<OEMLED2_995>0</OEMLED2_995>
		<OEMDRO2_996>0.</OEMDRO2_996>
		<OEMLED2_996>0</OEMLED2_996>
		<OEMDRO2_997>0.</OEMDRO2_997>
		<OEMLED2_997>0</OEMLED2_997>
		<OEMDRO2_998>0.</OEMDRO2_998>
		<OEMLED2_998>0</OEMLED2_998>
		<OEMDRO2_999>0.</OEMDRO2_999>
		<OEMLED2_999>0</OEMLED2_999>
		<ACLength>50</ACLength>
		<BCLength>50</BCLength>
		<CCLength>50</CCLength>
		<AMapOn>0</AMapOn>
		<BMapOn>0</BMapOn>
		<CMapOn>0</CMapOn>
		<THC_Delay_Check>0.</THC_Delay_Check>
		<GExt>*.tap</GExt>
		<GPath>C:\Mach3\GCode\roadrunner.tap</GPath>
		<Vel0>5.</Vel0>
		<Acc0>9.375</Acc0>
		<Steps0>1600.</Steps0>
		<Vel1>5.</Vel1>
		<Acc1>4.</Acc1>
		<Steps1>1600.</Steps1>
		<Vel2>2.</Vel2>
		<Acc2>4.</Acc2>
		<Steps2>1600.</Steps2>
		<AutoLimit>1</AutoLimit>
		<EnableResetHotKey>999</EnableResetHotKey>
	</Preferences>
	<Mach3Mill>
		<WPVB>500</WPVB>
		<WPVT>100</WPVT>
		<WPVL>50</WPVL>
		<WPVR>400</WPVR>
	</Mach3Mill>
	<Control>
		<Device>UC100-CNC-motion-controller-V2.151</Device>
	</Control>
	<VideoPlugIn>
		<DROcolor>0</DROcolor>
		<TOOLcolor>8421440</TOOLcolor>
		<CROSScolor>4194304</CROSScolor>
		<ShowTool>1</ShowTool>
		<ShowMousePos>1</ShowMousePos>
		<ShowAxisPos>1</ShowAxisPos>
		<ToolDia>0.5</ToolDia>
		<ScaleFactor>2.e-003</ScaleFactor>
		<FlipAxis>0</FlipAxis>
	</VideoPlugIn>
	<GCodeVar>
		<GVar500>0.</GVar500>
		<GVar501>0.</GVar501>
		<GVar502>0.</GVar502>
		<GVar503>0.</GVar503>
		<GVar504>0.</GVar504>
		<GVar505>0.</GVar505>
		<GVar506>0.</GVar506>
		<GVar507>0.</GVar507>
		<GVar508>0.</GVar508>
		<GVar509>0.</GVar509>
		<GVar510>0.</GVar510>
		<GVar511>0.</GVar511>
		<GVar512>0.</GVar512>
		<GVar513>0.</GVar513>
		<GVar514>0.</GVar514>
		<GVar515>0.</GVar515>
		<GVar516>0.</GVar516>
		<GVar517>0.</GVar517>
		<GVar518>0.</GVar518>
		<GVar519>0.</GVar519>
		<GVar520>0.</GVar520>
		<GVar521>0.</GVar521>
		<GVar522>0.</GVar522>
		<GVar523>0.</GVar523>
		<GVar524>0.</GVar524>
		<GVar525>0.</GVar525>
		<GVar526>0.</GVar526>
		<GVar527>0.</GVar527>
		<GVar528>0.</GVar528>
		<GVar529>0.</GVar529>
		<GVar530>0.</GVar530>
		<GVar531>0.</GVar531>
		<GVar532>0.</GVar532>
		<GVar533>0.</GVar533>
		<GVar534>0.</GVar534>
		<GVar535>0.</GVar535>
		<GVar536>0.</GVar536>
		<GVar537>0.</GVar537>
		<GVar538>0.</GVar538>
		<GVar539>0.</GVar539>
		<GVar540>0.</GVar540>
		<GVar541>0.</GVar541>
		<GVar542>0.</GVar542>
		<GVar543>0.</GVar543>
		<GVar544>0.</GVar544>
		<GVar545>0.</GVar545>
		<GVar546>0.</GVar546>
		<GVar547>0.</GVar547>
		<GVar548>0.</GVar548>
		<GVar549>0.</GVar549>
		<GVar550>0.</GVar550>
		<GVar551>0.</GVar551>
		<GVar552>0.</GVar552>
		<GVar553>0.</GVar553>
		<GVar554>0.</GVar554>
		<GVar555>0.</GVar555>
		<GVar556>0.</GVar556>
		<GVar557>0.</GVar557>
		<GVar558>0.</GVar558>
		<GVar559>0.</GVar559>
		<GVar560>0.</GVar560>
		<GVar561>0.</GVar561>
		<GVar562>0.</GVar562>
		<GVar563>0.</GVar563>
		<GVar564>0.</GVar564>
		<GVar565>0.</GVar565>
		<GVar566>0.</GVar566>
		<GVar567>0.</GVar567>
		<GVar568>0.</GVar568>
		<GVar569>0.</GVar569>
		<GVar570>0.</GVar570>
		<GVar571>0.</GVar571>
		<GVar572>0.</GVar572>
		<GVar573>0.</GVar573>
		<GVar574>0.</GVar574>
		<GVar575>0.</GVar575>
		<GVar576>0.</GVar576>
		<GVar577>0.</GVar577>
		<GVar578>0.</GVar578>
		<GVar579>0.</GVar579>
		<GVar580>0.</GVar580>
		<GVar581>0.</GVar581>
		<GVar582>0.</GVar582>
		<GVar583>0.</GVar583>
		<GVar584>0.</GVar584>
		<GVar585>0.</GVar585>
		<GVar586>0.</GVar586>
		<GVar587>0.</GVar587>
		<GVar588>0.</GVar588>
		<GVar589>0.</GVar589>
		<GVar590>0.</GVar590>
		<GVar591>0.</GVar591>
		<GVar592>0.</GVar592>
		<GVar593>0.</GVar593>
		<GVar594>0.</GVar594>
		<GVar595>0.</GVar595>
		<GVar596>0.</GVar596>
		<GVar597>0.</GVar597>
		<GVar598>0.</GVar598>
		<GVar599>0.</GVar599>
		<GVar600>0.</GVar600>
	</GCodeVar>
	<Normals>
		<Distance>0.</Distance>
		<ZInhibit>0.</ZInhibit>
		<Axis0>1.</Axis0>
		<Axis1>1.</Axis1>
		<Axis2>1.</Axis2>
		<Axis3>0.</Axis3>
		<Axis4>0.</Axis4>
		<Axis5>0.</Axis5>
		<Axis6>0.</Axis6>
		<CV>2.</CV>
		<XScale>1.</XScale>
		<YScale>1.</YScale>
		<ZScale>1.</ZScale>
		<AScale>1.</AScale>
		<BScale>1.</BScale>
		<CScale>1.</CScale>
		<OffLine>0.</OffLine>
		<IJ>1.</IJ>
		<RefX>0.</RefX>
		<RefY>0.</RefY>
		<RefZ>0.</RefZ>
		<RefA>0.</RefA>
		<RefB>0.</RefB>
		<RefC>0.</RefC>
		<System>1.</System>
		<Rotation>0.</Rotation>
		<Plane>1.</Plane>
	</Normals>
	<UC100>
		<MaxStepRate>1</MaxStepRate>
		<IndexPrescale>1</IndexPrescale>
		<THCDwellEnable>False</THCDwellEnable>
		<DereferenceAxisOnEstop>True</DereferenceAxisOnEstop>
	</UC100>
</profile>
