--Signal Script example. This code allows the user to do certain actions when signal changes occur in Mach. --This signal script code must go in the screen load script to work properly. --However, the following code must go in the Signal Script. --if(SigLib[sig] ~= nil)then --SigLib[sig](state); --end SigLib = { --Enable [mc.OSIG_MACHINE_ENABLED] = function (state) machEnabled = state; end, [mc.ISIG_INPUT1] = function (on_off)--mc.ISIG_INPUT1 if( on_off==1 ) then -- On else -- Off end end, [mc.ISIG_INPUT2] = function (state)--mc.ISIG_INPUT2 if( state == 1 ) then -- On else -- Off Call A function here if you wanted end end, --The user can add additional Signal events if they wish by following the same format as above. --[SIGNAL NAME] = function(state) --if(state is active) then -- do active code --else -- do inactive code --end --end, }
