NEWTOOL = GetSelectedTool()If GetSelectedTool = GetCurrentTool Then  ' If the tool called for is the same as already in then toolchange ignored End End If If GetSelectedTool > 8 Then            'If tool called is greater than 8 then code is stopped and message telling you why is displayed DoOemButton(1003)  MsgBox("Tool number too high, file will rewind") DoOemButton(1002) End   End If  If GetSelectedTool < 1 Then            ' If tool called is less than 1 then code is stopped and message telling you why is displayed DoOemButton(1003)  MsgBox("Tool number too low, file will rewind") 'Tool number called is too high so code will stop and rewind so editing can take place DoOemButton(1002)	 End  End If   If GetSelectedTool = 1 ThenCode("G0A0")While IsMoving()WendCode("G0A-358")While IsMoving()WendSetOemDRO(803,1)End If        If GetSelectedTool = 2 ThenCode("G0A45")While IsMoving()WendCode("G0A-43")While IsMoving()WendSetOemDRO(802,2)End If     If GetSelectedTool = 3 ThenCode("G0A90")While IsMoving()WendCode("G0A-88")While IsMoving()WendSetOemDRO(803,3)End If        If GetSelectedTool = 4 ThenCode("G0A135")While IsMoving()WendCode("G0A-133")While IsMoving()WendSetOemDRO(803,4)End If     If GetSelectedTool = 5 ThenCode("G0A180")While IsMoving()WendCode("G0A-178")While IsMoving()WendSetOemDRO(803,5)End If     If GetSelectedTool = 6 ThenCode("G0A225")While IsMoving()WendCode("G0A-223")While IsMoving()WendSetOemDRO(806,6)End If If GetSelectedTool = 7 ThenCode("G0A270")While IsMoving()WendCode("G0A-268")While IsMoving()WendSetOemDRO(803,7)End If  If GetSelectedTool = 8 ThenCode("G0A315")While IsMoving()WendCode("G0A-313")While IsMoving()WendSetOemDRO(803,8)End If      Call SetCurrentTool(NEWTOOL)       ' Set Tool number DRO to new tool                                    
