--This is the mcUserScript.lua module that goes in the modules folder local mcUserScript = {} function mcUserScript.UserMessage(Message) if (Message == nil) then --No message was passed Message = "No message passed" --If no message is passed this will be the default message end wx.wxMessageBox(Message) end return mcUserScript -- Module End --This is what loads the module above. --Add this to the modules load section of the screen load script so you can call its functions from buttons on the screen. --Add this to the load_modules.mcs file in the macros folder of the profile that will be using it so you can call its functions from M codes. package.loaded.mcUserScript = nil us = require "mcUserScript" --Put this in a buttons clicked script and when you click it a message box will pop up that says... No message passed us.UserMessage() --This is not passing a message for the Message parameter so the message will be the default --m110 goes in the macros folder of the profile that will be using it. It will be named m110.mcs function m110() us.UserMessage("This is my message") --When M110 is executed in Gcode or MDI a message box will pop up that says This is my message. end if (mc.mcInEditor() == 1) then m110() end
