<profile><Preferences><PulseSpeed>0</PulseSpeed><Profile>4axisTB6560</Profile><Layout>1024.set</Layout><FirstRun>1</FirstRun><Units>1</Units><Serial>0</Serial><Port2Input>0</Port2Input><GeckoMode>0</GeckoMode><USBINPUTS>16</USBINPUTS><USBOUTPUTS>16</USBOUTPUTS><Port2On>0</Port2On><Port1On>1</Port1On><Port1Add>888</Port1Add><Port2Add>632</Port2Add><MaxCL>0</MaxCL><MaxNC10>0</MaxNC10><Motor0Active>1</Motor0Active><Motor0DirNeg>0</Motor0DirNeg><Motor0DirPort>1</Motor0DirPort><Motor0DirPin>1</Motor0DirPin><Motor0StepNeg>0</Motor0StepNeg><Motor0StepPort>1</Motor0StepPort><Motor0StepPin>16</Motor0StepPin><Motor1Active>1</Motor1Active><Motor1DirNeg>0</Motor1DirNeg><Motor1DirPort>1</Motor1DirPort><Motor1DirPin>7</Motor1DirPin><Motor1StepNeg>0</Motor1StepNeg><Motor1StepPort>1</Motor1StepPort><Motor1StepPin>14</Motor1StepPin><Motor2Active>1</Motor2Active><Motor2DirNeg>0</Motor2DirNeg><Motor2DirPort>1</Motor2DirPort><Motor2DirPin>6</Motor2DirPin><Motor2StepNeg>0</Motor2StepNeg><Motor2StepPort>1</Motor2StepPort><Motor2StepPin>3</Motor2StepPin><Motor3Active>1</Motor3Active><Motor3DirNeg>0</Motor3DirNeg><Motor3DirPort>1</Motor3DirPort><Motor3DirPin>8</Motor3DirPin><Motor3StepNeg>0</Motor3StepNeg><Motor3StepPort>1</Motor3StepPort><Motor3StepPin>9</Motor3StepPin><Motor4Active>0</Motor4Active><Motor4DirNeg>0</Motor4DirNeg><Motor4DirPort>0</Motor4DirPort><Motor4DirPin>0</Motor4DirPin><Motor4StepNeg>0</Motor4StepNeg><Motor4StepPort>0</Motor4StepPort><Motor4StepPin>0</Motor4StepPin><Motor5Active>0</Motor5Active><Motor5DirNeg>0</Motor5DirNeg><Motor5DirPort>0</Motor5DirPort><Motor5DirPin>0</Motor5DirPin><Motor5StepNeg>0</Motor5StepNeg><Motor5StepPort>0</Motor5StepPort><Motor5StepPin>0</Motor5StepPin><Motor6Active>0</Motor6Active><Motor6DirNeg>0</Motor6DirNeg><Motor6DirPort>0</Motor6DirPort><Motor6DirPin>0</Motor6DirPin><Motor6StepNeg>0</Motor6StepNeg><Motor6StepPort>0</Motor6StepPort><Motor6StepPin>0</Motor6StepPin><Input0Active>1</Input0Active><Input0Port>1</Input0Port><Input0Pin>10</Input0Pin><Input0Neg>1</Input0Neg><Input0Emulated>0</Input0Emulated><Input0EmuKey>0</Input0EmuKey><Input1Active>0</Input1Active><Input1Port>1</Input1Port><Input1Pin>0</Input1Pin><Input1Neg>0</Input1Neg><Input1Emulated>0</Input1Emulated><Input1EmuKey>0</Input1EmuKey><Input2Active>0</Input2Active><Input2Port>1</Input2Port><Input2Pin>0</Input2Pin><Input2Neg>0</Input2Neg><Input2Emulated>0</Input2Emulated><Input2EmuKey>0</Input2EmuKey><Input3Active>0</Input3Active><Input3Port>1</Input3Port><Input3Pin>0</Input3Pin><Input3Neg>0</Input3Neg><Input3Emulated>0</Input3Emulated><Input3EmuKey>0</Input3EmuKey><Input4Active>0</Input4Active><Input4Port>1</Input4Port><Input4Pin>0</Input4Pin><Input4Neg>0</Input4Neg><Input4Emulated>0</Input4Emulated><Input4EmuKey>0</Input4EmuKey><Input5Active>0</Input5Active><Input5Port>1</Input5Port><Input5Pin>0</Input5Pin><Input5Neg>0</Input5Neg><Input5Emulated>0</Input5Emulated><Input5EmuKey>0</Input5EmuKey><Input6Active>0</Input6Active><Input6Port>1</Input6Port><Input6Pin>0</Input6Pin><Input6Neg>0</Input6Neg><Input6Emulated>0</Input6Emulated><Input6EmuKey>0</Input6EmuKey><Input7Active>0</Input7Active><Input7Port>1</Input7Port><Input7Pin>0</Input7Pin><Input7Neg>0</Input7Neg><Input7Emulated>0</Input7Emulated><Input7EmuKey>0</Input7EmuKey><Input8Active>0</Input8Active><Input8Port>1</Input8Port><Input8Pin>0</Input8Pin><Input8Neg>0</Input8Neg><Input8Emulated>0</Input8Emulated><Input8EmuKey>0</Input8EmuKey><Input9Active>0</Input9Active><Input9Port>1</Input9Port><Input9Pin>0</Input9Pin><Input9Neg>0</Input9Neg><Input9Emulated>0</Input9Emulated><Input9EmuKey>0</Input9EmuKey><Input10Active>0</Input10Active><Input10Port>1</Input10Port><Input10Pin>0</Input10Pin><Input10Neg>0</Input10Neg><Input10Emulated>0</Input10Emulated><Input10EmuKey>0</Input10EmuKey><Input11Active>0</Input11Active><Input11Port>1</Input11Port><Input11Pin>0</Input11Pin><Input11Neg>0</Input11Neg><Input11Emulated>0</Input11Emulated><Input11EmuKey>0</Input11EmuKey><Input12Active>0</Input12Active><Input12Port>1</Input12Port><Input12Pin>0</Input12Pin><Input12Neg>0</Input12Neg><Input12Emulated>0</Input12Emulated><Input12EmuKey>0</Input12EmuKey><Input13Active>0</Input13Active><Input13Port>1</Input13Port><Input13Pin>0</Input13Pin><Input13Neg>0</Input13Neg><Input13Emulated>0</Input13Emulated><Input13EmuKey>0</Input13EmuKey><Input14Active>0</Input14Active><Input14Port>1</Input14Port><Input14Pin>0</Input14Pin><Input14Neg>0</Input14Neg><Input14Emulated>0</Input14Emulated><Input14EmuKey>0</Input14EmuKey><Input15Active>0</Input15Active><Input15Port>1</Input15Port><Input15Pin>0</Input15Pin><Input15Neg>0</Input15Neg><Input15Emulated>0</Input15Emulated><Input15EmuKey>0</Input15EmuKey><Input16Active>0</Input16Active><Input16Port>1</Input16Port><Input16Pin>0</Input16Pin><Input16Neg>0</Input16Neg><Input16Emulated>0</Input16Emulated><Input16EmuKey>0</Input16EmuKey><Input17Active>0</Input17Active><Input17Port>1</Input17Port><Input17Pin>0</Input17Pin><Input17Neg>0</Input17Neg><Input17Emulated>0</Input17Emulated><Input17EmuKey>0</Input17EmuKey><Input18Active>0</Input18Active><Input18Port>1</Input18Port><Input18Pin>0</Input18Pin><Input18Neg>0</Input18Neg><Input18Emulated>0</Input18Emulated><Input18EmuKey>0</Input18EmuKey><Input19Active>0</Input19Active><Input19Port>1</Input19Port><Input19Pin>0</Input19Pin><Input19Neg>0</Input19Neg><Input19Emulated>0</Input19Emulated><Input19EmuKey>0</Input19EmuKey><Input20Active>0</Input20Active><Input20Port>1</Input20Port><Input20Pin>0</Input20Pin><Input20Neg>0</Input20Neg><Input20Emulated>0</Input20Emulated><Input20EmuKey>0</Input20EmuKey><Input21Active>0</Input21Active><Input21Port>1</Input21Port><Input21Pin>0</Input21Pin><Input21Neg>0</Input21Neg><Input21Emulated>0</Input21Emulated><Input21EmuKey>0</Input21EmuKey><Input22Active>1</Input22Active><Input22Port>1</Input22Port><Input22Pin>0</Input22Pin><Input22Neg>0</Input22Neg><Input22Emulated>0</Input22Emulated><Input22EmuKey>0</Input22EmuKey><Input23Active>0</Input23Active><Input23Port>1</Input23Port><Input23Pin>0</Input23Pin><Input23Neg>0</Input23Neg><Input23Emulated>0</Input23Emulated><Input23EmuKey>0</Input23EmuKey><Input24Active>0</Input24Active><Input24Port>1</Input24Port><Input24Pin>0</Input24Pin><Input24Neg>0</Input24Neg><Input24Emulated>0</Input24Emulated><Input24EmuKey>0</Input24EmuKey><Input25Active>1</Input25Active><Input25Port>0</Input25Port><Input25Pin>10</Input25Pin><Input25Neg>0</Input25Neg><Input25Emulated>0</Input25Emulated><Input25EmuKey>0</Input25EmuKey><Input26Active>0</Input26Active><Input26Port>1</Input26Port><Input26Pin>0</Input26Pin><Input26Neg>0</Input26Neg><Input26Emulated>0</Input26Emulated><Input26EmuKey>0</Input26EmuKey><Input27Active>0</Input27Active><Input27Port>1</Input27Port><Input27Pin>0</Input27Pin><Input27Neg>0</Input27Neg><Input27Emulated>0</Input27Emulated><Input27EmuKey>0</Input27EmuKey><Input28Active>0</Input28Active><Input28Port>1</Input28Port><Input28Pin>0</Input28Pin><Input28Neg>0</Input28Neg><Input28Emulated>0</Input28Emulated><Input28EmuKey>0</Input28EmuKey><Input29Active>0</Input29Active><Input29Port>1</Input29Port><Input29Pin>0</Input29Pin><Input29Neg>0</Input29Neg><Input29Emulated>0</Input29Emulated><Input29EmuKey>0</Input29EmuKey><Input30Active>0</Input30Active><Input30Port>1</Input30Port><Input30Pin>0</Input30Pin><Input30Neg>0</Input30Neg><Input30Emulated>0</Input30Emulated><Input30EmuKey>0</Input30EmuKey><Input31Active>0</Input31Active><Input31Port>1</Input31Port><Input31Pin>0</Input31Pin><Input31Neg>0</Input31Neg><Input31Emulated>0</Input31Emulated><Input31EmuKey>0</Input31EmuKey><Input32Active>0</Input32Active><Input32Port>1</Input32Port><Input32Pin>0</Input32Pin><Input32Neg>0</Input32Neg><Input32Emulated>0</Input32Emulated><Input32EmuKey>0</Input32EmuKey><Input33Active>0</Input33Active><Input33Port>1</Input33Port><Input33Pin>0</Input33Pin><Input33Neg>0</Input33Neg><Input33Emulated>0</Input33Emulated><Input33EmuKey>0</Input33EmuKey><Input34Active>0</Input34Active><Input34Port>0</Input34Port><Input34Pin>0</Input34Pin><Input34Neg>0</Input34Neg><Input34Emulated>0</Input34Emulated><Input34EmuKey>0</Input34EmuKey><Input35Active>0</Input35Active><Input35Port>0</Input35Port><Input35Pin>0</Input35Pin><Input35Neg>0</Input35Neg><Input35Emulated>0</Input35Emulated><Input35EmuKey>0</Input35EmuKey><Input36Active>0</Input36Active><Input36Port>0</Input36Port><Input36Pin>0</Input36Pin><Input36Neg>0</Input36Neg><Input36Emulated>0</Input36Emulated><Input36EmuKey>0</Input36EmuKey><Input37Active>0</Input37Active><Input37Port>0</Input37Port><Input37Pin>0</Input37Pin><Input37Neg>0</Input37Neg><Input37Emulated>0</Input37Emulated><Input37EmuKey>0</Input37EmuKey><Input38Active>0</Input38Active><Input38Port>0</Input38Port><Input38Pin>0</Input38Pin><Input38Neg>0</Input38Neg><Input38Emulated>0</Input38Emulated><Input38EmuKey>0</Input38EmuKey><Input39Active>0</Input39Active><Input39Port>0</Input39Port><Input39Pin>0</Input39Pin><Input39Neg>0</Input39Neg><Input39Emulated>0</Input39Emulated><Input39EmuKey>0</Input39EmuKey><Input40Active>0</Input40Active><Input40Port>0</Input40Port><Input40Pin>0</Input40Pin><Input40Neg>0</Input40Neg><Input40Emulated>0</Input40Emulated><Input40EmuKey>0</Input40EmuKey><Input41Active>0</Input41Active><Input41Port>0</Input41Port><Input41Pin>0</Input41Pin><Input41Neg>0</Input41Neg><Input41Emulated>0</Input41Emulated><Input41EmuKey>0</Input41EmuKey><Input42Active>0</Input42Active><Input42Port>0</Input42Port><Input42Pin>0</Input42Pin><Input42Neg>0</Input42Neg><Input42Emulated>0</Input42Emulated><Input42EmuKey>0</Input42EmuKey><Input43Active>0</Input43Active><Input43Port>0</Input43Port><Input43Pin>0</Input43Pin><Input43Neg>0</Input43Neg><Input43Emulated>0</Input43Emulated><Input43EmuKey>0</Input43EmuKey><Input44Active>0</Input44Active><Input44Port>0</Input44Port><Input44Pin>0</Input44Pin><Input44Neg>0</Input44Neg><Input44Emulated>0</Input44Emulated><Input44EmuKey>0</Input44EmuKey><Input45Active>0</Input45Active><Input45Port>0</Input45Port><Input45Pin>0</Input45Pin><Input45Neg>0</Input45Neg><Input45Emulated>0</Input45Emulated><Input45EmuKey>0</Input45EmuKey><Input46Active>0</Input46Active><Input46Port>0</Input46Port><Input46Pin>0</Input46Pin><Input46Neg>0</Input46Neg><Input46Emulated>0</Input46Emulated><Input46EmuKey>0</Input46EmuKey><Input47Active>0</Input47Active><Input47Port>0</Input47Port><Input47Pin>0</Input47Pin><Input47Neg>0</Input47Neg><Input47Emulated>0</Input47Emulated><Input47EmuKey>0</Input47EmuKey><Input48Active>0</Input48Active><Input48Port>0</Input48Port><Input48Pin>0</Input48Pin><Input48Neg>0</Input48Neg><Input48Emulated>0</Input48Emulated><Input48EmuKey>0</Input48EmuKey><Input49Active>0</Input49Active><Input49Port>0</Input49Port><Input49Pin>0</Input49Pin><Input49Neg>0</Input49Neg><Input49Emulated>0</Input49Emulated><Input49EmuKey>0</Input49EmuKey><Input50Active>0</Input50Active><Input50Port>0</Input50Port><Input50Pin>0</Input50Pin><Input50Neg>0</Input50Neg><Input50Emulated>0</Input50Emulated><Input50EmuKey>0</Input50EmuKey><Input51Active>0</Input51Active><Input51Port>0</Input51Port><Input51Pin>0</Input51Pin><Input51Neg>0</Input51Neg><Input51Emulated>0</Input51Emulated><Input51EmuKey>0</Input51EmuKey><Input52Active>0</Input52Active><Input52Port>0</Input52Port><Input52Pin>0</Input52Pin><Input52Neg>0</Input52Neg><Input52Emulated>0</Input52Emulated><Input52EmuKey>0</Input52EmuKey><Output0Active>0</Output0Active><Output0Port>1</Output0Port><Output0Pin>1</Output0Pin><Output0Neg>0</Output0Neg><Output1Active>1</Output1Active><Output1Port>1</Output1Port><Output1Pin>4</Output1Pin><Output1Neg>0</Output1Neg><Output2Active>1</Output2Active><Output2Port>1</Output2Port><Output2Pin>17</Output2Pin><Output2Neg>0</Output2Neg><Output3Active>1</Output3Active><Output3Port>1</Output3Port><Output3Pin>5</Output3Pin><Output3Neg>0</Output3Neg><Output4Active>1</Output4Active><Output4Port>1</Output4Port><Output4Pin>5</Output4Pin><Output4Neg>0</Output4Neg><Output5Active>0</Output5Active><Output5Port>1</Output5Port><Output5Pin>0</Output5Pin><Output5Neg>0</Output5Neg><Output6Active>0</Output6Active><Output6Port>1</Output6Port><Output6Pin>0</Output6Pin><Output6Neg>0</Output6Neg><Output7Active>0</Output7Active><Output7Port>1</Output7Port><Output7Pin>0</Output7Pin><Output7Neg>0</Output7Neg><Output8Active>0</Output8Active><Output8Port>1</Output8Port><Output8Pin>0</Output8Pin><Output8Neg>0</Output8Neg><Output9Active>0</Output9Active><Output9Port>1</Output9Port><Output9Pin>0</Output9Pin><Output9Neg>0</Output9Neg><Output10Active>0</Output10Active><Output10Port>1</Output10Port><Output10Pin>0</Output10Pin><Output10Neg>0</Output10Neg><Output11Active>0</Output11Active><Output11Port>1</Output11Port><Output11Pin>0</Output11Pin><Output11Neg>0</Output11Neg><Output12Active>0</Output12Active><Output12Port>1</Output12Port><Output12Pin>0</Output12Pin><Output12Neg>0</Output12Neg><Output13Active>0</Output13Active><Output13Port>1</Output13Port><Output13Pin>0</Output13Pin><Output13Neg>0</Output13Neg><Output14Active>0</Output14Active><Output14Port>1</Output14Port><Output14Pin>0</Output14Pin><Output14Neg>0</Output14Neg><Output15Active>0</Output15Active><Output15Port>1</Output15Port><Output15Pin>0</Output15Pin><Output15Neg>0</Output15Neg><Output16Active>0</Output16Active><Output16Port>1</Output16Port><Output16Pin>0</Output16Pin><Output16Neg>0</Output16Neg><Output17Active>0</Output17Active><Output17Port>1</Output17Port><Output17Pin>0</Output17Pin><Output17Neg>0</Output17Neg><Output18Active>0</Output18Active><Output18Port>1</Output18Port><Output18Pin>0</Output18Pin><Output18Neg>0</Output18Neg><Output19Active>0</Output19Active><Output19Port>1</Output19Port><Output19Pin>0</Output19Pin><Output19Neg>0</Output19Neg><Output20Active>0</Output20Active><Output20Port>1</Output20Port><Output20Pin>0</Output20Pin><Output20Neg>0</Output20Neg><Output21Active>0</Output21Active><Output21Port>1</Output21Port><Output21Pin>0</Output21Pin><Output21Neg>0</Output21Neg><Output22Active>0</Output22Active><Output22Port>1</Output22Port><Output22Pin>0</Output22Pin><Output22Neg>0</Output22Neg><Output23Active>0</Output23Active><Output23Port>1</Output23Port><Output23Pin>0</Output23Pin><Output23Neg>0</Output23Neg><Output24Active>0</Output24Active><Output24Port>1</Output24Port><Output24Pin>0</Output24Pin><Output24Neg>0</Output24Neg><Output25Active>0</Output25Active><Output25Port>1</Output25Port><Output25Pin>0</Output25Pin><Output25Neg>0</Output25Neg><Output26Active>0</Output26Active><Output26Port>1</Output26Port><Output26Pin>0</Output26Pin><Output26Neg>0</Output26Neg><Output27Active>0</Output27Active><Output27Port>1</Output27Port><Output27Pin>0</Output27Pin><Output27Neg>0</Output27Neg><Output28Active>0</Output28Active><Output28Port>1</Output28Port><Output28Pin>0</Output28Pin><Output28Neg>0</Output28Neg><Output29Active>0</Output29Active><Output29Port>1</Output29Port><Output29Pin>0</Output29Pin><Output29Neg>0</Output29Neg><Output30Active>0</Output30Active><Output30Port>0</Output30Port><Output30Pin>0</Output30Pin><Output30Neg>0</Output30Neg><Encoder0Active>0</Encoder0Active><Encoder0APort>0</Encoder0APort><Encoder0APin>0</Encoder0APin><Encoder0BPort>0</Encoder0BPort><Encoder0BPin>0</Encoder0BPin><Encoder0Cal>1.00</Encoder0Cal><Encoder1Active>0</Encoder1Active><Encoder1APort>0</Encoder1APort><Encoder1APin>0</Encoder1APin><Encoder1BPort>0</Encoder1BPort><Encoder1BPin>0</Encoder1BPin><Encoder1Cal>1.00</Encoder1Cal><Encoder2Active>0</Encoder2Active><Encoder2APort>0</Encoder2APort><Encoder2APin>0</Encoder2APin><Encoder2BPort>0</Encoder2BPort><Encoder2BPin>0</Encoder2BPin><Encoder2Cal>1.00</Encoder2Cal><Encoder3Active>0</Encoder3Active><Encoder3APort>0</Encoder3APort><Encoder3APin>0</Encoder3APin><Encoder3BPort>0</Encoder3BPort><Encoder3BPin>0</Encoder3BPin><Encoder3Cal>1.00</Encoder3Cal><Encoder4Active>0</Encoder4Active><Encoder4APort>0</Encoder4APort><Encoder4APin>0</Encoder4APin><Encoder4BPort>0</Encoder4BPort><Encoder4BPin>0</Encoder4BPin><Encoder4Cal>1.00</Encoder4Cal><Encoder5Active>0</Encoder5Active><Encoder5APort>0</Encoder5APort><Encoder5APin>0</Encoder5APin><Encoder5BPort>0</Encoder5BPort><Encoder5BPin>0</Encoder5BPin><Encoder5Cal>1.00</Encoder5Cal><Encoder6Active>0</Encoder6Active><Encoder6APort>0</Encoder6APort><Encoder6APin>0</Encoder6APin><Encoder6BPort>0</Encoder6BPort><Encoder6BPin>0</Encoder6BPin><Encoder6Cal>1.00</Encoder6Cal><Encoder7Active>0</Encoder7Active><Encoder7APort>0</Encoder7APort><Encoder7APin>0</Encoder7APin><Encoder7BPort>0</Encoder7BPort><Encoder7BPin>0</Encoder7BPin><Encoder7Cal></Encoder7Cal><Configured>1</Configured><SlavePrim>0</SlavePrim><Slave>-1</Slave><AxisKeys0>39</AxisKeys0><AxisKeys1>37</AxisKeys1><AxisKeys2>38</AxisKeys2><AxisKeys3>40</AxisKeys3><AxisKeys4>33</AxisKeys4><AxisKeys5>34</AxisKeys5><AxisKeys6>999</AxisKeys6><AxisKeys7>999</AxisKeys7><AxisKeys8>999</AxisKeys8><AxisKeys9>999</AxisKeys9><AxisKeys10>999</AxisKeys10><AxisKeys11>999</AxisKeys11><DROHotKey>999</DROHotKey><ListKey>999</ListKey><MDIHotKey>999</MDIHotKey><GCodeHotKey>999</GCodeHotKey><OEM1>-1</OEM1><OEM2>-1</OEM2><OEM3>-1</OEM3><OEM4>-1</OEM4><OEM5>-1</OEM5><OEM6>-1</OEM6><PulseWidth>17000</PulseWidth><DirPulse>17000</DirPulse><BackX>0.</BackX><BackY>0.</BackY><BackZ>0.</BackZ><BackA>0.</BackA><BackB>0.</BackB><BackC>0.</BackC><BackSpeed>20.</BackSpeed><BB>0.0</BB><BR>0.0</BR><BG>0.0</BG><FB>1.0</FB><FR>0.0</FR><FG>0.0</FG><RB>0.0</RB><RR>1.0</RR><RG>0.0</RG><AB>0.7</AB><AR>0.7</AR><AG>0.2</AG><EG>1.0</EG><ER>1.0</ER><EB>0.0</EB><JogFollow>0</JogFollow><G92Off>1</G92Off><RadiusCompOff>1</RadiusCompOff><Debounce>0</Debounce><PlasmaMode>0</PlasmaMode><NoAngle>1</NoAngle><AAngular>1</AAngular><BAngular>1</BAngular><CAngular>1</CAngular><IndexDebounce>0</IndexDebounce><DROPERSIST>0</DROPERSIST><DwellinMilli>0</DwellinMilli><IJMode>1</IJMode><INIT>G80</INIT><InitAllResets>0</InitAllResets><AutoScreens>0</AutoScreens><TORCHVON>0</TORCHVON><TORCHVOLTS>0</TORCHVOLTS><HWSAFE>1</HWSAFE><ShortRot>0</ShortRot><LookAhead>20</LookAhead><WatchDog>1</WatchDog><Plane>0</Plane><MPG1>0</MPG1><MPG2>0</MPG2><HotKeysPersist>0</HotKeysPersist><HoldInput1>0</HoldInput1><M3s>28</M3s><UseCR>0</UseCR><PlasmaHome>0</PlasmaHome><Homann>0</Homann><UseSLS>0</UseSLS><Dist0>1.5e+003</Dist0><Dist1>3.2e+002</Dist1><Dist2>35</Dist2><Dist3>0.</Dist3><Dist4>0.</Dist4><Dist5>0.</Dist5><OverMode2>0</OverMode2><BitPack1>0</BitPack1><BitPack1Reg>16</BitPack1Reg><BitPackOut>0</BitPackOut><BitPackOutReg>16</BitPackOutReg><LaserPort>1</LaserPort><LaserBaud>9600</LaserBaud><LaserStops>1</LaserStops><LaserData>1</LaserData><LaserInit>&gt;</LaserInit><LaserCommand>&gt;</LaserCommand><MacroPump>0</MacroPump><VelMode>0</VelMode><VelPer1>5.</VelPer1><VelPer2>5.</VelPer2><MPGFeed>1.e+002</MPGFeed><ModSpindleCal>1.638e+004</ModSpindleCal><ModSpindleOn>0</ModSpindleOn><ModSpindleReg>64</ModSpindleReg><ShuttleAccel>8192</ShuttleAccel><Flash>1</Flash><ImmediateOff>0</ImmediateOff><UseSafeZ>0</UseSafeZ><AdvancedComp>1</AdvancedComp><TorchOff>0</TorchOff><LaserStandby>0</LaserStandby><RaiseLower>0</RaiseLower><OEMDUAL>0</OEMDUAL><IncBuffer>5</IncBuffer><Formula0>x</Formula0><Formula1>y</Formula1><Formula2>z</Formula2><Formula3>a</Formula3><Formula4>b</Formula4><Formula5>c</Formula5><Formular>0</Formular><PanelOut>350</PanelOut><nModBusReg>0</nModBusReg><ModBusRegOn>0</ModBusRegOn><Tool>0</Tool><Sherline>0</Sherline><ToolPost>1</ToolPost><RapidOverRide>0</RapidOverRide><XCLength>1.3e+003</XCLength><YCLength>1.3e+003</YCLength><ZCLength>1.3e+003</ZCLength><ToolPostOffset>0.</ToolPostOffset><OEM7>-1</OEM7><OEM8>-1</OEM8><OEM9>-1</OEM9><OEM10>-1</OEM10><OEM11>-1</OEM11><OEM12>-1</OEM12><OEM13>-1</OEM13><OEM14>-1</OEM14><OEM15>-1</OEM15><MPGVel0>1.e+002</MPGVel0><MPGVel1>1.e+002</MPGVel1><MPGVel2>1.e+002</MPGVel2><MPGVel3>1.e+002</MPGVel3><MPGVel4>1.e+002</MPGVel4><MPGVel5>1.e+002</MPGVel5><MPGVel6>1.e+002</MPGVel6><ByPassFeed>1.e+003</ByPassFeed><XMapOn>0</XMapOn><YMapOn>0</YMapOn><ZMapOn>0</ZMapOn><SecondsOn>6024897</SecondsOn><SerialType>0</SerialType><SpinAverage>0</SpinAverage><Dig4Axis>0</Dig4Axis><DigLetter>0</DigLetter><CutType>0</CutType><InfeedType>0</InfeedType><LastWizard>C:\Mach3\Addons\Digitize Wizard\digitize.set</LastWizard><Z25D>0</Z25D><ModBus>0</ModBus><ChargeAlwaysOn>0</ChargeAlwaysOn><ToolFlip>0</ToolFlip><SpinCCW>7</SpinCCW><SpinCW>7</SpinCW><Flood>9</Flood><Mist>10</Mist><SpinActual>0</SpinActual><SpinDelayCW>1.</SpinDelayCW><SpinDelayCCW>1.</SpinDelayCCW><SpinDownCW>1.</SpinDownCW><SpinDownCCW>1.</SpinDownCCW><StockSize>50</StockSize><ShowSolid>0</ShowSolid><RapidFeed>1.e+003</RapidFeed><MatRed>0.</MatRed><MatGreen>0.1</MatGreen><MatBlue>0.1</MatBlue><SpinP>0.25</SpinP><SpinI>1.</SpinI><SpinD>0.3</SpinD><SpinClosed>0</SpinClosed><MinPerPass>0.1</MinPerPass><NoSpindle>0</NoSpindle><NoFlood>1</NoFlood><PWMin>0</PWMin><PULLEY>3</PULLEY><SPEED1>1000</SPEED1><SPEED2>2000</SPEED2><SPEED3>4000</SPEED3><SPEED4>8000</SPEED4><LSPEED1>0</LSPEED1><LSPEED2>0</LSPEED2><LSPEED3>0</LSPEED3><LSPEED4>0</LSPEED4><PWM>0</PWM><RefSpeed0>20</RefSpeed0><RefSpeed1>20</RefSpeed1><RefSpeed2>20</RefSpeed2><RefSpeed3>20</RefSpeed3><RefSpeed4>20</RefSpeed4><RefSpeed5>20</RefSpeed5><M0SoftRamp>1.</M0SoftRamp><M1SoftRamp>1.</M1SoftRamp><M2SoftRamp>1.</M2SoftRamp><M3SoftRamp>1.</M3SoftRamp><M4SoftRamp>1.</M4SoftRamp><M5SoftRamp>1.</M5SoftRamp><FeedInc>5.</FeedInc><DepthLastPass>0.</DepthLastPass><InFeed>29.5</InFeed><Spring>1.</Spring><MinDepth>1.e-003</MinDepth><XClear>0.1</XClear><ZClear>0.1</ZClear><CutDepth>0.1</CutDepth><Chamfer>0.</Chamfer><DepthFirstPass>0.1</DepthFirstPass><M0Max>100.</M0Max><M1Max>100.</M1Max><M2Max>100.</M2Max><M3Max>100.</M3Max><M4Max>100.</M4Max><M5Max>100.</M5Max><M0Min>-100.</M0Min><M1Min>-100.</M1Min><M2Min>-100.</M2Min><M3Min>-100.</M3Min><M4Min>-100.</M4Min><M5Min>-100.</M5Min><M0Neg>0</M0Neg><M1Neg>0</M1Neg><M2Neg>0</M2Neg><M3Neg>0</M3Neg><M4Neg>0</M4Neg><M5Neg>0</M5Neg><M0AutoZero>1</M0AutoZero><M1AutoZero>1</M1AutoZero><M2AutoZero>1</M2AutoZero><M3AutoZero>1</M3AutoZero><M4AutoZero>1</M4AutoZero><M5AutoZero>1</M5AutoZero><M0Rev>0</M0Rev><M1Rev>0</M1Rev><M2Rev>0</M2Rev><M3Rev>0</M3Rev><M4Rev>0</M4Rev><M5Rev>0</M5Rev><M6Rev>0</M6Rev><OffPersist>1</OffPersist><Diameter>0</Diameter><OffDialogs>1</OffDialogs><G54Back>1</G54Back><GougeCheck>0</GougeCheck><AxisToMotor0>0</AxisToMotor0><AxisToMotor1>1</AxisToMotor1><AxisToMotor2>2</AxisToMotor2><AxisToMotor3>3</AxisToMotor3><AxisToMotor4>4</AxisToMotor4><AxisToMotor5>5</AxisToMotor5><AxisToMotor6>6</AxisToMotor6><JogActive>0</JogActive><BLState0>0</BLState0><BLState1>0</BLState1><BLState2>0</BLState2><BLState3>0</BLState3><BLState4>0</BLState4><BLState5>0</BLState5><SlowMode>0</SlowMode><JogPersist>1</JogPersist><ToolRotations>0</ToolRotations><SoftLimit>0</SoftLimit><JogMode>0</JogMode><JogMode2>0</JogMode2><EncJogAxis2>2</EncJogAxis2><TaperRatio>1.</TaperRatio><XStart>0</XStart><YStart>0</YStart><ZStart>0</ZStart><AStart>0</AStart><BStart>0</BStart><CStart>0</CStart><SpinInc>10</SpinInc><Enc0>0.</Enc0><Enc1>0.</Enc1><Enc2>0.</Enc2><Enc3>0.</Enc3><TangentalControl>0</TangentalControl><BaudRate>9600</BaudRate><ComPort>1</ComPort><NoPlunge>0</NoPlunge><PlungeLimit>60</PlungeLimit><AutoTool>0</AutoTool><AutoSpindle>0</AutoSpindle><LaserMode>0</LaserMode><FeedMode>0</FeedMode><OriginSphere>0</OriginSphere><m_3dCompass>1</m_3dCompass><Boundries>0</Boundries><ToolPosition>1</ToolPosition><AParallel>0</AParallel><ZINHPersist>0</ZINHPersist><OVPersist>1</OVPersist><BacklashOn>0</BacklashOn><PathMode>2</PathMode><ThrottleFunc>2</ThrottleFunc><JoyOn>0</JoyOn><PWMBase>5000</PWMBase><JogSpeed>100.</JogSpeed><G73PullBack>0.1</G73PullBack><CVFeedOn>1</CVFeedOn><CVFeedRate>1.</CVFeedRate><AtoX>0.</AtoX><AtoY>0.</AtoY><AtoZ>0.</AtoZ><OEMDRO0>-6.2774386e+066</OEMDRO0><OEMLED0>1</OEMLED0><OEMDRO1>10.</OEMDRO1><OEMLED1>1</OEMLED1><OEMDRO2>10.</OEMDRO2><OEMLED2>1</OEMLED2><OEMDRO3>5.</OEMDRO3><OEMLED3>1</OEMLED3><OEMDRO4>-6.2774386e+066</OEMDRO4><OEMLED4>1</OEMLED4><OEMDRO5>4.e-003</OEMDRO5><OEMLED5>1</OEMLED5><OEMDRO6>1.</OEMDRO6><OEMLED6>1</OEMLED6><OEMDRO7>75005.</OEMDRO7><OEMLED7>1</OEMLED7><OEMDRO8>100.</OEMDRO8><OEMLED8>1</OEMLED8><OEMDRO9>-6.2774386e+066</OEMDRO9><OEMLED9>1</OEMLED9><OEMDRO10>-6.2774386e+066</OEMDRO10><OEMLED10>1</OEMLED10><OEMDRO11>-6.2774386e+066</OEMDRO11><OEMLED11>1</OEMLED11><OEMDRO12>-6.2774386e+066</OEMDRO12><OEMLED12>1</OEMLED12><OEMDRO13>-6.2774386e+066</OEMDRO13><OEMLED13>1</OEMLED13><OEMDRO14>-6.2774386e+066</OEMDRO14><OEMLED14>1</OEMLED14><OEMDRO15>-6.2774386e+066</OEMDRO15><OEMLED15>1</OEMLED15><OEMDRO16>-6.2774386e+066</OEMDRO16><OEMLED16>1</OEMLED16><OEMDRO17>-6.2774386e+066</OEMDRO17><OEMLED17>1</OEMLED17><OEMDRO18>-6.2774386e+066</OEMDRO18><OEMLED18>1</OEMLED18><OEMDRO19>-6.2774386e+066</OEMDRO19><OEMLED19>1</OEMLED19><OEMDRO20>-6.2774386e+066</OEMDRO20><OEMLED20>1</OEMLED20><OEMDRO21>-6.2774386e+066</OEMDRO21><OEMLED21>1</OEMLED21><OEMDRO22>-6.2774386e+066</OEMDRO22><OEMLED22>1</OEMLED22><OEMDRO23>-6.2774386e+066</OEMDRO23><OEMLED23>1</OEMLED23><OEMDRO24>-6.2774386e+066</OEMDRO24><OEMLED24>1</OEMLED24><OEMDRO25>-6.2774386e+066</OEMDRO25><OEMLED25>1</OEMLED25><OEMDRO26>-6.2774386e+066</OEMDRO26><OEMLED26>1</OEMLED26><OEMDRO27>-6.2774386e+066</OEMDRO27><OEMLED27>1</OEMLED27><OEMDRO28>-6.2774386e+066</OEMDRO28><OEMLED28>1</OEMLED28><OEMDRO29>-6.2774386e+066</OEMDRO29><OEMLED29>1</OEMLED29><OEMDRO30>-6.2774386e+066</OEMDRO30><OEMLED30>1</OEMLED30><OEMDRO31>-6.2774386e+066</OEMDRO31><OEMLED31>1</OEMLED31><OEMDRO32>-6.2774386e+066</OEMDRO32><OEMLED32>1</OEMLED32><OEMDRO33>-6.2774386e+066</OEMDRO33><OEMLED33>1</OEMLED33><OEMDRO34>-6.2774386e+066</OEMDRO34><OEMLED34>1</OEMLED34><OEMDRO35>-6.2774386e+066</OEMDRO35><OEMLED35>1</OEMLED35><OEMDRO36>-6.2774386e+066</OEMDRO36><OEMLED36>1</OEMLED36><OEMDRO37>-6.2774386e+066</OEMDRO37><OEMLED37>1</OEMLED37><OEMDRO38>-6.2774386e+066</OEMDRO38><OEMLED38>1</OEMLED38><OEMDRO39>-6.2774386e+066</OEMDRO39><OEMLED39>1</OEMLED39><OEMDRO40>-6.2774386e+066</OEMDRO40><OEMLED40>1</OEMLED40><OEMDRO41>-6.2774386e+066</OEMDRO41><OEMLED41>1</OEMLED41><OEMDRO42>-6.2774386e+066</OEMDRO42><OEMLED42>1</OEMLED42><OEMDRO43>-6.2774386e+066</OEMDRO43><OEMLED43>1</OEMLED43><OEMDRO44>-6.2774386e+066</OEMDRO44><OEMLED44>1</OEMLED44><OEMDRO45>-6.2774386e+066</OEMDRO45><OEMLED45>1</OEMLED45><OEMDRO46>-6.2774386e+066</OEMDRO46><OEMLED46>1</OEMLED46><OEMDRO47>-6.2774386e+066</OEMDRO47><OEMLED47>1</OEMLED47><OEMDRO48>-6.2774386e+066</OEMDRO48><OEMLED48>1</OEMLED48><OEMDRO49>-6.2774386e+066</OEMDRO49><OEMLED49>1</OEMLED49><OEMDRO50>-6.2774386e+066</OEMDRO50><OEMLED50>1</OEMLED50><OEMDRO51>-6.2774386e+066</OEMDRO51><OEMLED51>1</OEMLED51><OEMDRO52>-6.2774386e+066</OEMDRO52><OEMLED52>1</OEMLED52><OEMDRO53>-6.2774386e+066</OEMDRO53><OEMLED53>1</OEMLED53><OEMDRO54>-6.2774386e+066</OEMDRO54><OEMLED54>1</OEMLED54><OEMDRO55>-6.2774386e+066</OEMDRO55><OEMLED55>1</OEMLED55><OEMDRO56>-6.2774386e+066</OEMDRO56><OEMLED56>1</OEMLED56><OEMDRO57>-6.2774386e+066</OEMDRO57><OEMLED57>1</OEMLED57><OEMDRO58>-6.2774386e+066</OEMDRO58><OEMLED58>1</OEMLED58><OEMDRO59>-6.2774386e+066</OEMDRO59><OEMLED59>1</OEMLED59><OEMDRO60>-6.2774386e+066</OEMDRO60><OEMLED60>1</OEMLED60><OEMDRO61>-6.2774386e+066</OEMDRO61><OEMLED61>1</OEMLED61><OEMDRO62>-6.2774386e+066</OEMDRO62><OEMLED62>1</OEMLED62><OEMDRO63>-6.2774386e+066</OEMDRO63><OEMLED63>1</OEMLED63><OEMDRO64>-6.2774386e+066</OEMDRO64><OEMLED64>1</OEMLED64><OEMDRO65>-6.2774386e+066</OEMDRO65><OEMLED65>1</OEMLED65><OEMDRO66>-6.2774386e+066</OEMDRO66><OEMLED66>1</OEMLED66><OEMDRO67>-6.2774386e+066</OEMDRO67><OEMLED67>1</OEMLED67><OEMDRO68>-6.2774386e+066</OEMDRO68><OEMLED68>1</OEMLED68><OEMDRO69>-6.2774386e+066</OEMDRO69><OEMLED69>1</OEMLED69><OEMDRO70>-6.2774386e+066</OEMDRO70><OEMLED70>1</OEMLED70><OEMDRO71>-6.2774386e+066</OEMDRO71><OEMLED71>1</OEMLED71><OEMDRO72>-6.2774386e+066</OEMDRO72><OEMLED72>1</OEMLED72><OEMDRO73>-6.2774386e+066</OEMDRO73><OEMLED73>1</OEMLED73><OEMDRO74>-6.2774386e+066</OEMDRO74><OEMLED74>1</OEMLED74><OEMDRO75>-6.2774386e+066</OEMDRO75><OEMLED75>1</OEMLED75><OEMDRO76>-6.2774386e+066</OEMDRO76><OEMLED76>1</OEMLED76><OEMDRO77>-6.2774386e+066</OEMDRO77><OEMLED77>1</OEMLED77><OEMDRO78>-6.2774386e+066</OEMDRO78><OEMLED78>1</OEMLED78><OEMDRO79>-6.2774386e+066</OEMDRO79><OEMLED79>1</OEMLED79><OEMDRO80>-6.2774386e+066</OEMDRO80><OEMLED80>1</OEMLED80><OEMDRO81>-6.2774386e+066</OEMDRO81><OEMLED81>1</OEMLED81><OEMDRO82>-6.2774386e+066</OEMDRO82><OEMLED82>1</OEMLED82><OEMDRO83>-6.2774386e+066</OEMDRO83><OEMLED83>1</OEMLED83><OEMDRO84>-6.2774386e+066</OEMDRO84><OEMLED84>1</OEMLED84><OEMDRO85>-6.2774386e+066</OEMDRO85><OEMLED85>1</OEMLED85><OEMDRO86>-6.2774386e+066</OEMDRO86><OEMLED86>1</OEMLED86><OEMDRO87>-6.2774386e+066</OEMDRO87><OEMLED87>1</OEMLED87><OEMDRO88>-6.2774386e+066</OEMDRO88><OEMLED88>1</OEMLED88><OEMDRO89>-6.2774386e+066</OEMDRO89><OEMLED89>1</OEMLED89><OEMDRO90>-6.2774386e+066</OEMDRO90><OEMLED90>1</OEMLED90><OEMDRO91>-6.2774386e+066</OEMDRO91><OEMLED91>1</OEMLED91><OEMDRO92>-6.2774386e+066</OEMDRO92><OEMLED92>1</OEMLED92><OEMDRO93>-6.2774386e+066</OEMDRO93><OEMLED93>1</OEMLED93><OEMDRO94>-6.2774386e+066</OEMDRO94><OEMLED94>1</OEMLED94><OEMDRO95>-6.2774386e+066</OEMDRO95><OEMLED95>1</OEMLED95><OEMDRO96>-6.2774386e+066</OEMDRO96><OEMLED96>1</OEMLED96><OEMDRO97>-6.2774386e+066</OEMDRO97><OEMLED97>1</OEMLED97><OEMDRO98>-6.2774386e+066</OEMDRO98><OEMLED98>1</OEMLED98><OEMDRO99>-6.2774386e+066</OEMDRO99><OEMLED99>1</OEMLED99><OEMDRO100>-6.2774386e+066</OEMDRO100><OEMLED100>1</OEMLED100><OEMDRO101>-6.2774386e+066</OEMDRO101><OEMLED101>1</OEMLED101><OEMDRO102>-6.2774386e+066</OEMDRO102><OEMLED102>1</OEMLED102><OEMDRO103>-6.2774386e+066</OEMDRO103><OEMLED103>1</OEMLED103><OEMDRO104>-6.2774386e+066</OEMDRO104><OEMLED104>1</OEMLED104><OEMDRO105>-6.2774386e+066</OEMDRO105><OEMLED105>1</OEMLED105><OEMDRO106>-6.2774386e+066</OEMDRO106><OEMLED106>1</OEMLED106><OEMDRO107>-6.2774386e+066</OEMDRO107><OEMLED107>1</OEMLED107><OEMDRO108>-6.2774386e+066</OEMDRO108><OEMLED108>1</OEMLED108><OEMDRO109>-6.2774386e+066</OEMDRO109><OEMLED109>1</OEMLED109><OEMDRO110>-6.2774386e+066</OEMDRO110><OEMLED110>1</OEMLED110><OEMDRO111>-6.2774386e+066</OEMDRO111><OEMLED111>1</OEMLED111><OEMDRO112>-6.2774386e+066</OEMDRO112><OEMLED112>1</OEMLED112><OEMDRO113>-6.2774386e+066</OEMDRO113><OEMLED113>1</OEMLED113><OEMDRO114>-6.2774386e+066</OEMDRO114><OEMLED114>1</OEMLED114><OEMDRO115>-6.2774386e+066</OEMDRO115><OEMLED115>1</OEMLED115><OEMDRO116>-6.2774386e+066</OEMDRO116><OEMLED116>1</OEMLED116><OEMDRO117>-6.2774386e+066</OEMDRO117><OEMLED117>1</OEMLED117><OEMDRO118>-6.2774386e+066</OEMDRO118><OEMLED118>1</OEMLED118><OEMDRO119>-6.2774386e+066</OEMDRO119><OEMLED119>1</OEMLED119><OEMDRO120>-6.2774386e+066</OEMDRO120><OEMLED120>1</OEMLED120><OEMDRO121>-6.2774386e+066</OEMDRO121><OEMLED121>1</OEMLED121><OEMDRO122>-6.2774386e+066</OEMDRO122><OEMLED122>1</OEMLED122><OEMDRO123>-6.2774386e+066</OEMDRO123><OEMLED123>1</OEMLED123><OEMDRO124>-6.2774386e+066</OEMDRO124><OEMLED124>1</OEMLED124><OEMDRO125>-6.2774386e+066</OEMDRO125><OEMLED125>1</OEMLED125><OEMDRO126>-6.2774386e+066</OEMDRO126><OEMLED126>1</OEMLED126><OEMDRO127>-6.2774386e+066</OEMDRO127><OEMLED127>1</OEMLED127><OEMDRO128>-6.2774386e+066</OEMDRO128><OEMLED128>1</OEMLED128><OEMDRO129>-6.2774386e+066</OEMDRO129><OEMLED129>1</OEMLED129><OEMDRO130>-6.2774386e+066</OEMDRO130><OEMLED130>1</OEMLED130><OEMDRO131>-6.2774386e+066</OEMDRO131><OEMLED131>1</OEMLED131><OEMDRO132>-6.2774386e+066</OEMDRO132><OEMLED132>1</OEMLED132><OEMDRO133>-6.2774386e+066</OEMDRO133><OEMLED133>1</OEMLED133><OEMDRO134>-6.2774386e+066</OEMDRO134><OEMLED134>1</OEMLED134><OEMDRO135>-6.2774386e+066</OEMDRO135><OEMLED135>1</OEMLED135><OEMDRO136>-6.2774386e+066</OEMDRO136><OEMLED136>1</OEMLED136><OEMDRO137>-6.2774386e+066</OEMDRO137><OEMLED137>1</OEMLED137><OEMDRO138>-6.2774386e+066</OEMDRO138><OEMLED138>1</OEMLED138><OEMDRO139>-6.2774386e+066</OEMDRO139><OEMLED139>1</OEMLED139><OEMDRO140>-6.2774386e+066</OEMDRO140><OEMLED140>1</OEMLED140><OEMDRO141>-6.2774386e+066</OEMDRO141><OEMLED141>1</OEMLED141><OEMDRO142>-6.2774386e+066</OEMDRO142><OEMLED142>1</OEMLED142><OEMDRO143>-6.2774386e+066</OEMDRO143><OEMLED143>1</OEMLED143><OEMDRO144>-6.2774386e+066</OEMDRO144><OEMLED144>1</OEMLED144><OEMDRO145>-6.2774386e+066</OEMDRO145><OEMLED145>1</OEMLED145><OEMDRO146>-6.2774386e+066</OEMDRO146><OEMLED146>1</OEMLED146><OEMDRO147>-6.2774386e+066</OEMDRO147><OEMLED147>1</OEMLED147><OEMDRO148>-6.2774386e+066</OEMDRO148><OEMLED148>1</OEMLED148><OEMDRO149>-6.2774386e+066</OEMDRO149><OEMLED149>1</OEMLED149><OEMDRO150>-6.2774386e+066</OEMDRO150><OEMLED150>1</OEMLED150><OEMDRO151>-6.2774386e+066</OEMDRO151><OEMLED151>1</OEMLED151><OEMDRO152>-6.2774386e+066</OEMDRO152><OEMLED152>1</OEMLED152><OEMDRO153>-6.2774386e+066</OEMDRO153><OEMLED153>1</OEMLED153><OEMDRO154>-6.2774386e+066</OEMDRO154><OEMLED154>1</OEMLED154><OEMDRO155>-6.2774386e+066</OEMDRO155><OEMLED155>1</OEMLED155><OEMDRO156>-6.2774386e+066</OEMDRO156><OEMLED156>1</OEMLED156><OEMDRO157>-6.2774386e+066</OEMDRO157><OEMLED157>1</OEMLED157><OEMDRO158>-6.2774386e+066</OEMDRO158><OEMLED158>1</OEMLED158><OEMDRO159>-6.2774386e+066</OEMDRO159><OEMLED159>1</OEMLED159><OEMDRO160>-6.2774386e+066</OEMDRO160><OEMLED160>1</OEMLED160><OEMDRO161>-6.2774386e+066</OEMDRO161><OEMLED161>1</OEMLED161><OEMDRO162>-6.2774386e+066</OEMDRO162><OEMLED162>1</OEMLED162><OEMDRO163>-6.2774386e+066</OEMDRO163><OEMLED163>1</OEMLED163><OEMDRO164>-6.2774386e+066</OEMDRO164><OEMLED164>1</OEMLED164><OEMDRO165>-6.2774386e+066</OEMDRO165><OEMLED165>1</OEMLED165><OEMDRO166>-6.2774386e+066</OEMDRO166><OEMLED166>1</OEMLED166><OEMDRO167>-6.2774386e+066</OEMDRO167><OEMLED167>1</OEMLED167><OEMDRO168>-6.2774386e+066</OEMDRO168><OEMLED168>1</OEMLED168><OEMDRO169>-6.2774386e+066</OEMDRO169><OEMLED169>1</OEMLED169><OEMDRO170>-6.2774386e+066</OEMDRO170><OEMLED170>1</OEMLED170><OEMDRO171>-6.2774386e+066</OEMDRO171><OEMLED171>1</OEMLED171><OEMDRO172>-6.2774386e+066</OEMDRO172><OEMLED172>1</OEMLED172><OEMDRO173>-6.2774386e+066</OEMDRO173><OEMLED173>1</OEMLED173><OEMDRO174>-6.2774386e+066</OEMDRO174><OEMLED174>1</OEMLED174><OEMDRO175>-6.2774386e+066</OEMDRO175><OEMLED175>1</OEMLED175><OEMDRO176>-6.2774386e+066</OEMDRO176><OEMLED176>1</OEMLED176><OEMDRO177>-6.2774386e+066</OEMDRO177><OEMLED177>1</OEMLED177><OEMDRO178>-6.2774386e+066</OEMDRO178><OEMLED178>1</OEMLED178><OEMDRO179>-6.2774386e+066</OEMDRO179><OEMLED179>1</OEMLED179><OEMDRO180>-6.2774386e+066</OEMDRO180><OEMLED180>1</OEMLED180><OEMDRO181>-6.2774386e+066</OEMDRO181><OEMLED181>1</OEMLED181><OEMDRO182>-6.2774386e+066</OEMDRO182><OEMLED182>1</OEMLED182><OEMDRO183>-6.2774386e+066</OEMDRO183><OEMLED183>1</OEMLED183><OEMDRO184>-6.2774386e+066</OEMDRO184><OEMLED184>1</OEMLED184><OEMDRO185>-6.2774386e+066</OEMDRO185><OEMLED185>1</OEMLED185><OEMDRO186>-6.2774386e+066</OEMDRO186><OEMLED186>1</OEMLED186><OEMDRO187>-6.2774386e+066</OEMDRO187><OEMLED187>1</OEMLED187><OEMDRO188>-6.2774386e+066</OEMDRO188><OEMLED188>1</OEMLED188><OEMDRO189>-6.2774386e+066</OEMDRO189><OEMLED189>1</OEMLED189><OEMDRO190>-6.2774386e+066</OEMDRO190><OEMLED190>1</OEMLED190><OEMDRO191>-6.2774386e+066</OEMDRO191><OEMLED191>1</OEMLED191><OEMDRO192>-6.2774386e+066</OEMDRO192><OEMLED192>1</OEMLED192><OEMDRO193>-6.2774386e+066</OEMDRO193><OEMLED193>1</OEMLED193><OEMDRO194>-6.2774386e+066</OEMDRO194><OEMLED194>1</OEMLED194><OEMDRO195>-6.2774386e+066</OEMDRO195><OEMLED195>1</OEMLED195><OEMDRO196>-6.2774386e+066</OEMDRO196><OEMLED196>1</OEMLED196><OEMDRO197>-6.2774386e+066</OEMDRO197><OEMLED197>1</OEMLED197><OEMDRO198>-6.2774386e+066</OEMDRO198><OEMLED198>1</OEMLED198><OEMDRO199>-6.2774386e+066</OEMDRO199><OEMLED199>1</OEMLED199><OEMDRO200>0.</OEMDRO200><OEMLED200>0</OEMLED200><OEMDRO201>0.</OEMDRO201><OEMLED201>0</OEMLED201><OEMDRO202>0.</OEMDRO202><OEMLED202>0</OEMLED202><OEMDRO203>0.</OEMDRO203><OEMLED203>0</OEMLED203><OEMDRO204>0.</OEMDRO204><OEMLED204>0</OEMLED204><OEMDRO205>0.</OEMDRO205><OEMLED205>0</OEMLED205><OEMDRO206>0.</OEMDRO206><OEMLED206>0</OEMLED206><OEMDRO207>0.</OEMDRO207><OEMLED207>0</OEMLED207><OEMDRO208>0.</OEMDRO208><OEMLED208>0</OEMLED208><OEMDRO209>0.</OEMDRO209><OEMLED209>0</OEMLED209><OEMDRO210>0.</OEMDRO210><OEMLED210>0</OEMLED210><OEMDRO211>0.</OEMDRO211><OEMLED211>0</OEMLED211><OEMDRO212>0.</OEMDRO212><OEMLED212>0</OEMLED212><OEMDRO213>0.</OEMDRO213><OEMLED213>0</OEMLED213><OEMDRO214>0.</OEMDRO214><OEMLED214>0</OEMLED214><OEMDRO215>0.</OEMDRO215><OEMLED215>0</OEMLED215><OEMDRO216>0.</OEMDRO216><OEMLED216>0</OEMLED216><OEMDRO217>0.</OEMDRO217><OEMLED217>0</OEMLED217><OEMDRO218>0.</OEMDRO218><OEMLED218>0</OEMLED218><OEMDRO219>0.</OEMDRO219><OEMLED219>0</OEMLED219><OEMDRO220>0.</OEMDRO220><OEMLED220>0</OEMLED220><OEMDRO221>0.</OEMDRO221><OEMLED221>0</OEMLED221><OEMDRO222>0.</OEMDRO222><OEMLED222>0</OEMLED222><OEMDRO223>0.</OEMDRO223><OEMLED223>0</OEMLED223><OEMDRO224>0.</OEMDRO224><OEMLED224>0</OEMLED224><OEMDRO225>0.</OEMDRO225><OEMLED225>0</OEMLED225><OEMDRO226>0.</OEMDRO226><OEMLED226>0</OEMLED226><OEMDRO227>0.</OEMDRO227><OEMLED227>0</OEMLED227><OEMDRO228>0.</OEMDRO228><OEMLED228>0</OEMLED228><OEMDRO229>0.</OEMDRO229><OEMLED229>0</OEMLED229><OEMDRO230>0.</OEMDRO230><OEMLED230>0</OEMLED230><OEMDRO231>0.</OEMDRO231><OEMLED231>0</OEMLED231><OEMDRO232>0.</OEMDRO232><OEMLED232>0</OEMLED232><OEMDRO233>0.</OEMDRO233><OEMLED233>0</OEMLED233><OEMDRO234>0.</OEMDRO234><OEMLED234>0</OEMLED234><OEMDRO235>0.</OEMDRO235><OEMLED235>0</OEMLED235><OEMDRO236>0.</OEMDRO236><OEMLED236>0</OEMLED236><OEMDRO237>0.</OEMDRO237><OEMLED237>0</OEMLED237><OEMDRO238>0.</OEMDRO238><OEMLED238>0</OEMLED238><OEMDRO239>0.</OEMDRO239><OEMLED239>0</OEMLED239><OEMDRO240>0.</OEMDRO240><OEMLED240>0</OEMLED240><OEMDRO241>0.</OEMDRO241><OEMLED241>0</OEMLED241><OEMDRO242>0.</OEMDRO242><OEMLED242>0</OEMLED242><OEMDRO243>0.</OEMDRO243><OEMLED243>0</OEMLED243><OEMDRO244>0.</OEMDRO244><OEMLED244>0</OEMLED244><OEMDRO245>0.</OEMDRO245><OEMLED245>0</OEMLED245><OEMDRO246>0.</OEMDRO246><OEMLED246>0</OEMLED246><OEMDRO247>0.</OEMDRO247><OEMLED247>0</OEMLED247><OEMDRO248>0.</OEMDRO248><OEMLED248>0</OEMLED248><OEMDRO249>0.</OEMDRO249><OEMLED249>0</OEMLED249><OEMDRO250>0.</OEMDRO250><OEMLED250>0</OEMLED250><OEMDRO251>0.</OEMDRO251><OEMLED251>0</OEMLED251><OEMDRO252>0.</OEMDRO252><OEMLED252>0</OEMLED252><OEMDRO253>0.</OEMDRO253><OEMLED253>0</OEMLED253><OEMDRO254>0.</OEMDRO254><OEMLED254>0</OEMLED254><OEMDRO255>0.</OEMDRO255><OEMLED255>0</OEMLED255><JogInc>1.</JogInc><JogSlide>0.1</JogSlide><THCMax>1.</THCMax><THCMin>0.2</THCMin><RadiusA>0.</RadiusA><RadiusB>0.</RadiusB><RadiusC>0.</RadiusC><LiftLevel>1.</LiftLevel><LiftAngle>45.</LiftAngle><InhibitDepth>0.</InhibitDepth><LaserXGrid>0.</LaserXGrid><LaserYGrid>0.</LaserYGrid><LaserAGrid>0.</LaserAGrid><JogInc0>1.</JogInc0><JogInc1>0.1</JogInc1><JogInc2>1.e-002</JogInc2><JogInc3>1.e-003</JogInc3><JogInc4>1.e-004</JogInc4><JogInc5>1.</JogInc5><JogInc6>0.1</JogInc6><JogInc7>1.e-002</JogInc7><JogInc8>1.e-003</JogInc8><JogInc9>1.e-004</JogInc9><THCSpeed>20.</THCSpeed><BlendFactor>180.</BlendFactor><M0RefHome>0</M0RefHome><M1RefHome>0</M1RefHome><M2RefHome>0</M2RefHome><M3RefHome>0</M3RefHome><M4RefHome>0</M4RefHome><M5RefHome>0</M5RefHome><MRU10>None</MRU10><MRU9>None</MRU9><MRU8>None</MRU8><MRU7>None</MRU7><MRU6>None</MRU6><MRU5>C:\Mach3\GCode\Cutpocket.tap</MRU5><MRU4>C:\Mach3\GCode\CutCircle.tap</MRU4><MRU3>C:\Mach3\singleLine.txt</MRU3><MRU2>C:\Mach3\GCode\roadrunner.tap</MRU2><MRU1>C:\Mach3\GCode\ACtest-BH1.tap.txt</MRU1><ToolPersist>0</ToolPersist><KeepRef>0</KeepRef><TurnRevArc>1</TurnRevArc><DROFont>Arial</DROFont><LabelFont>Arial</LabelFont><CodeFont>Arial</CodeFont><PierceDelay>1.</PierceDelay><VelPer3>5.</VelPer3><TouchX>0.</TouchX><G20X>0.</G20X><G20Y>0.</G20Y><G20Z>0.</G20Z><G20A>0.</G20A><G20B>0.</G20B><G20C>0.</G20C><FrontRear>0.</FrontRear><EncJogAxis3>2</EncJogAxis3><WarnOnReset>0</WarnOnReset><NURBS>1</NURBS><HiRes>0</HiRes><DelinChar>12</DelinChar><Rot360>0</Rot360><SerialServo>0</SerialServo><ToolLines>0</ToolLines><UDP>0</UDP><DefDir>C:\Mach3</DefDir><NewPath>0</NewPath><SafeZStop>0</SafeZStop><SafeZType>0</SafeZType><UseDiam>0</UseDiam><SPINREV1>0</SPINREV1><SPINREV2>0</SPINREV2><SPINREV3>0</SPINREV3><SPINREV4>0</SPINREV4><SPEED5>25000</SPEED5><LSPEED5>0</LSPEED5><SPINREV5>0</SPINREV5><SPEED6>25000</SPEED6><LSPEED6>0</LSPEED6><SPINREV6>0</SPINREV6><SPEED7>25000</SPEED7><LSPEED7>0</LSPEED7><SPINREV7>0</SPINREV7><SPEED8>25000</SPEED8><LSPEED8>0</LSPEED8><SPINREV8>0</SPINREV8><SPEED9>25000</SPEED9><LSPEED9>0</LSPEED9><SPINREV9>0</SPINREV9><SPEED10>25000</SPEED10><LSPEED10>0</LSPEED10><SPINREV10>0</SPINREV10><SPEED11>25000</SPEED11><LSPEED11>0</LSPEED11><SPINREV11>0</SPINREV11><SPEED12>25000</SPEED12><LSPEED12>0</LSPEED12><SPINREV12>0</SPINREV12><SPEED13>25000</SPEED13><LSPEED13>0</LSPEED13><SPINREV13>0</SPINREV13><SPEED14>25000</SPEED14><LSPEED14>0</LSPEED14><SPINREV14>0</SPINREV14><SPEED15>25000</SPEED15><LSPEED15>0</LSPEED15><SPINREV15>0</SPINREV15><SPEED16>25000</SPEED16><LSPEED16>0</LSPEED16><SPINREV16>0</SPINREV16><SPEED17>25000</SPEED17><LSPEED17>0</LSPEED17><SPINREV17>0</SPINREV17><SPEED18>25000</SPEED18><LSPEED18>0</LSPEED18><SPINREV18>0</SPINREV18><SPEED19>25000</SPEED19><LSPEED19>0</LSPEED19><SPINREV19>0</SPINREV19><SPEED20>25000</SPEED20><LSPEED20>0</LSPEED20><SPINREV20>0</SPINREV20><SPEED21>25000</SPEED21><LSPEED21>0</LSPEED21><SPINREV21>0</SPINREV21><SPEED22>25000</SPEED22><LSPEED22>0</LSPEED22><SPINREV22>0</SPINREV22><SPEED23>25000</SPEED23><LSPEED23>0</LSPEED23><SPINREV23>0</SPINREV23><SPEED24>25000</SPEED24><LSPEED24>0</LSPEED24><SPINREV24>0</SPINREV24><SPEED25>25000</SPEED25><LSPEED25>0</LSPEED25><SPINREV25>0</SPINREV25><m_SafeZ>0.</m_SafeZ><EncJogAxis1>0</EncJogAxis1><AutoCalcs>0</AutoCalcs><CVUseAngle>0</CVUseAngle><CVDegrees>0.</CVDegrees><M30SpinOff>1</M30SpinOff><Boxed>1</Boxed><ButtonFont>Arial</ButtonFont><OVSpinInc>10</OVSpinInc><Syskey1>1</Syskey1><ModPlug>0</ModPlug><KeyClick>1</KeyClick><THC5>0</THC5><ModPort>1</ModPort><AutoBaud>57600</AutoBaud><AutoType1>0</AutoType1><AutoType2>0</AutoType2><AutoType3>0</AutoType3><AutoType4>0</AutoType4><AutoOn1>0</AutoOn1><AutoOn2>0</AutoOn2><AutoOn3>0</AutoOn3><AutoOn4>0</AutoOn4><AutoSlave1>0</AutoSlave1><AutoSlave2>0</AutoSlave2><AutoSlave3>0</AutoSlave3><AutoSlave4>0</AutoSlave4><AutoStart1>0</AutoStart1><AutoStart2>0</AutoStart2><AutoStart3>0</AutoStart3><AutoStart4>0</AutoStart4><AutoEnd1>0</AutoEnd1><AutoEnd2>0</AutoEnd2><AutoEnd3>0</AutoEnd3><AutoEnd4>0</AutoEnd4><RTSON>0</RTSON><TIMEOUT>100</TIMEOUT><Hertz>50</Hertz><Prot>3</Prot><ID>None</ID><LastUser>Demo Version.</LastUser><ROTSOFT>1</ROTSOFT><PROBETLO>0</PROBETLO><SlaveHome>0</SlaveHome><JogHeat>0</JogHeat><SPINRATIO1>1.</SPINRATIO1><SPINRATIO2>1.</SPINRATIO2><SPINRATIO3>1.</SPINRATIO3><SPINRATIO4>1.</SPINRATIO4><SPINRATIO5>1.</SPINRATIO5><SPINRATIO6>1.</SPINRATIO6><SPINRATIO7>1.</SPINRATIO7><SPINRATIO8>1.</SPINRATIO8><SPINRATIO9>1.</SPINRATIO9><SPINRATIO10>1.</SPINRATIO10><SPINRATIO11>1.</SPINRATIO11><SPINRATIO12>1.</SPINRATIO12><SPINRATIO13>1.</SPINRATIO13><SPINRATIO14>1.</SPINRATIO14><SPINRATIO15>1.</SPINRATIO15><SPINRATIO16>1.</SPINRATIO16><SPINRATIO17>1.</SPINRATIO17><SPINRATIO18>1.</SPINRATIO18><SPINRATIO19>1.</SPINRATIO19><SPINRATIO20>1.</SPINRATIO20><SPINRATIO21>1.</SPINRATIO21><SPINRATIO22>1.</SPINRATIO22><SPINRATIO23>1.</SPINRATIO23><SPINRATIO24>1.</SPINRATIO24><SPINRATIO25>1.</SPINRATIO25><Running>0</Running><TCPMODBUS>0</TCPMODBUS><MenuOff>0</MenuOff><ZBar>1</ZBar><IgnoreMacros>0</IgnoreMacros><GExt>*.txt</GExt><GPath>C:\Mach3\GCode\ACtest-BH1.tap.txt</GPath><AutoTurnOff>0</AutoTurnOff><Vel0>0.3333</Vel0><Acc0>10.</Acc0><Steps0>2000.</Steps0><Vel2>0.3333</Vel2><Acc2>10.</Acc2><Steps2>2000.</Steps2><Vel1>0.3333</Vel1><Acc1>10.</Acc1><Steps1>2000.</Steps1><Vel3>0.3333</Vel3><Acc3>10.</Acc3><Steps3>2000.</Steps3></Preferences><Mach3Mill><WPVB>500</WPVB><WPVT>100</WPVT><WPVL>50</WPVL><WPVR>400</WPVR></Mach3Mill><Control><Device>Printer</Device></Control><VideoPlugIn><DROcolor>0</DROcolor><TOOLcolor>8421440</TOOLcolor><CROSScolor>4194304</CROSScolor><ShowTool>1</ShowTool><ShowMousePos>1</ShowMousePos><ShowAxisPos>1</ShowAxisPos><ToolDia>0.5</ToolDia><ScaleFactor>2.e-003</ScaleFactor><FlipAxis>0</FlipAxis></VideoPlugIn><PlugIns><Probing-3d-Digitising-Fenerty-Barker-Version-2.00.046>1</Probing-3d-Digitising-Fenerty-Barker-Version-2.00.046><SystemTest>1</SystemTest></PlugIns><Probe3d><Length>10.</Length><Width>10.</Width><XGrid>1.</XGrid><YGrid>1.</YGrid><ProbeDia>0.</ProbeDia><ProbeDepth>-1.</ProbeDepth><Clearance>0.1</Clearance><FeedRate>60.</FeedRate><ProbeStuck>0.</ProbeStuck></Probe3d></profile>
