[Preferences] Profile=Smooth-C32 Screen=wxRouter.set MotionDevice=ESS JogInc=0.0010 JogRate=51.0 AutoCalc=0 JogTrace=0 OpLock=0 SpindleDelay=1.000000 CoolantDelay=1.000000 MistDelay=1.000000 AxisRolloverA=0 AxisRolloverB=0 AxisRolloverC=0 MotorMaxRPM=24000.000000 UseCvAnlge=0 MaxTools=99 SetupUnits=200 LookAhead=20 JogInc1=1 JogInc2=0.1 JogInc3=0.01 JogInc4=0.001 JogInc5=0.0001 JogInc6=1 JogInc7=0.1 JogInc8=0.01 JogInc9=0.001 JogInc10=0.0001 FileExtensions=*.tap; *.nc GcodeEditor=C:\\Mach4\\gcedit CommentsInMessages=0 DerefAxesInEstop=0 StopIsControlled=0 DisableVboToolPath=0 UseAdvGui=1 UseLazyToolPathUpdate=0 SpindleOverrideDelay=25 EnableStepDirRtap=0 EnableSpindleStabilizeWait=0 SpindleStabilizeWaitPercent=90 LastWizard=C:\\Mach4\\Wizards\\CV_Feedrate.mcs LastOpenDir=D:\\Mach3 MRU1=D:\\Mach3\\breadbox Part 3.txt MRU2=D:\\Mach3\\Dinosaurs Express hobbies\\Spiniosaurus_R_1-4inch x 4.txt CustomColor0=#FFFFFF CustomColor1=#FFFFFF CustomColor2=#FFFFFF CustomColor3=#FFFFFF CustomColor4=#FFFFFF CustomColor5=#FFFFFF CustomColor6=#FFFFFF CustomColor7=#FFFFFF CustomColor8=#FFFFFF CustomColor9=#FFFFFF CustomColor10=#FFFFFF CustomColor11=#FFFFFF CustomColor12=#FFFFFF CustomColor13=#FFFFFF CustomColor14=#FFFFFF CustomColor15=#FFFFFF CustomColor0=#FFFFFF CustomColor1=#FFFFFF CustomColor2=#FFFFFF CustomColor3=#FFFFFF CustomColor4=#FFFFFF CustomColor5=#FFFFFF CustomColor6=#FFFFFF CustomColor7=#FFFFFF CustomColor8=#FFFFFF CustomColor9=#FFFFFF CustomColor10=#FFFFFF CustomColor11=#FFFFFF CustomColor12=#FFFFFF CustomColor13=#FFFFFF CustomColor14=#FFFFFF CustomColor15=#FFFFFF UseCvAnlge=0 UseAdvGui=1 UseLazyToolPathUpdate=0 MaxTools=99 SpindleOverrideDelay=25 MRU3=D:\\Mach3\\Randall2.tap [Toolpath] BackgroundTopColor=8404992 BackgroundBottomColor=8404992 RapidColor=255 LineColor=65312 ArcColor=2546003 HighlightColor=16118725 AxisColor=255 LimitColor=65535 ShowLimit=0 [Signal161] ID=161 Type=Input Desc=Probe Enabled=1 Negated=0 Mapping=ESS/Z-Plate [Signal183] ID=183 Type=Input Desc=Probe1 Enabled=0 Negated=0 Mapping=None [Signal184] ID=184 Type=Input Desc=Probe2 Enabled=0 Negated=0 Mapping=None [Signal185] ID=185 Type=Input Desc=Probe3 Enabled=0 Negated=0 Mapping=None [Signal162] ID=162 Type=Input Desc=Index Enabled=0 Negated=0 Mapping=None [Signal1] ID=1 Type=Input Desc=Input #0 Enabled=0 Negated=0 Mapping=None [Signal2] ID=2 Type=Input Desc=Input #1 Enabled=0 Negated=0 Mapping=None [Signal3] ID=3 Type=Input Desc=Input #2 Enabled=0 Negated=0 Mapping=None [Signal4] ID=4 Type=Input Desc=Input #3 Enabled=0 Negated=0 Mapping=None [Signal5] ID=5 Type=Input Desc=Input #4 Enabled=0 Negated=0 Mapping=None [Signal6] ID=6 Type=Input Desc=Input #5 Enabled=0 Negated=0 Mapping=None [Signal7] ID=7 Type=Input Desc=Input #6 Enabled=0 Negated=0 Mapping=None [Signal8] ID=8 Type=Input Desc=Input #7 Enabled=0 Negated=0 Mapping=None [Signal9] ID=9 Type=Input Desc=Input #8 Enabled=0 Negated=0 Mapping=None [Signal10] ID=10 Type=Input Desc=Input #9 Enabled=0 Negated=0 Mapping=None [Signal11] ID=11 Type=Input Desc=Input #10 Enabled=0 Negated=0 Mapping=None [Signal12] ID=12 Type=Input Desc=Input #11 Enabled=0 Negated=0 Mapping=None [Signal13] ID=13 Type=Input Desc=Input #12 Enabled=0 Negated=0 Mapping=None [Signal14] ID=14 Type=Input Desc=Input #13 Enabled=0 Negated=0 Mapping=None [Signal15] ID=15 Type=Input Desc=Input #14 Enabled=0 Negated=0 Mapping=None [Signal16] ID=16 Type=Input Desc=Input #15 Enabled=0 Negated=0 Mapping=None [Signal17] ID=17 Type=Input Desc=Input #16 Enabled=0 Negated=0 Mapping=None [Signal18] ID=18 Type=Input Desc=Input #17 Enabled=0 Negated=0 Mapping=None [Signal19] ID=19 Type=Input Desc=Input #18 Enabled=0 Negated=0 Mapping=None [Signal20] ID=20 Type=Input Desc=Input #19 Enabled=0 Negated=0 Mapping=None [Signal21] ID=21 Type=Input Desc=Input #20 Enabled=0 Negated=0 Mapping=None [Signal22] ID=22 Type=Input Desc=Input #21 Enabled=0 Negated=0 Mapping=None [Signal23] ID=23 Type=Input Desc=Input #22 Enabled=0 Negated=0 Mapping=None [Signal24] ID=24 Type=Input Desc=Input #23 Enabled=0 Negated=0 Mapping=None [Signal25] ID=25 Type=Input Desc=Input #24 Enabled=0 Negated=0 Mapping=None [Signal26] ID=26 Type=Input Desc=Input #25 Enabled=0 Negated=0 Mapping=None [Signal27] ID=27 Type=Input Desc=Input #26 Enabled=0 Negated=0 Mapping=None [Signal28] ID=28 Type=Input Desc=Input #27 Enabled=0 Negated=0 Mapping=None [Signal29] ID=29 Type=Input Desc=Input #28 Enabled=0 Negated=0 Mapping=None [Signal30] ID=30 Type=Input Desc=Input #29 Enabled=0 Negated=0 Mapping=None [Signal31] ID=31 Type=Input Desc=Input #30 Enabled=0 Negated=0 Mapping=None [Signal32] ID=32 Type=Input Desc=Input #31 Enabled=0 Negated=0 Mapping=None [Signal33] ID=33 Type=Input Desc=Input #32 Enabled=0 Negated=0 Mapping=None [Signal34] ID=34 Type=Input Desc=Input #33 Enabled=0 Negated=0 Mapping=None [Signal35] ID=35 Type=Input Desc=Input #34 Enabled=0 Negated=0 Mapping=None [Signal36] ID=36 Type=Input Desc=Input #35 Enabled=0 Negated=0 Mapping=None [Signal37] ID=37 Type=Input Desc=Input #36 Enabled=0 Negated=0 Mapping=None [Signal38] ID=38 Type=Input Desc=Input #37 Enabled=0 Negated=0 Mapping=None [Signal39] ID=39 Type=Input Desc=Input #38 Enabled=0 Negated=0 Mapping=None [Signal40] ID=40 Type=Input Desc=Input #39 Enabled=0 Negated=0 Mapping=None [Signal41] ID=41 Type=Input Desc=Input #40 Enabled=0 Negated=0 Mapping=None [Signal42] ID=42 Type=Input Desc=Input #41 Enabled=0 Negated=0 Mapping=None [Signal43] ID=43 Type=Input Desc=Input #42 Enabled=0 Negated=0 Mapping=None [Signal44] ID=44 Type=Input Desc=Input #43 Enabled=0 Negated=0 Mapping=None [Signal45] ID=45 Type=Input Desc=Input #44 Enabled=0 Negated=0 Mapping=None [Signal46] ID=46 Type=Input Desc=Input #45 Enabled=0 Negated=0 Mapping=None [Signal47] ID=47 Type=Input Desc=Input #46 Enabled=0 Negated=0 Mapping=None [Signal48] ID=48 Type=Input Desc=Input #47 Enabled=0 Negated=0 Mapping=None [Signal49] ID=49 Type=Input Desc=Input #48 Enabled=0 Negated=0 Mapping=None [Signal50] ID=50 Type=Input Desc=Input #49 Enabled=0 Negated=0 Mapping=None [Signal51] ID=51 Type=Input Desc=Input #50 Enabled=0 Negated=0 Mapping=None [Signal52] ID=52 Type=Input Desc=Input #51 Enabled=0 Negated=0 Mapping=None [Signal53] ID=53 Type=Input Desc=Input #52 Enabled=0 Negated=0 Mapping=None [Signal54] ID=54 Type=Input Desc=Input #53 Enabled=0 Negated=0 Mapping=None [Signal55] ID=55 Type=Input Desc=Input #54 Enabled=0 Negated=0 Mapping=None [Signal56] ID=56 Type=Input Desc=Input #55 Enabled=0 Negated=0 Mapping=None [Signal57] ID=57 Type=Input Desc=Input #56 Enabled=0 Negated=0 Mapping=None [Signal58] ID=58 Type=Input Desc=Input #57 Enabled=0 Negated=0 Mapping=None [Signal59] ID=59 Type=Input Desc=Input #58 Enabled=0 Negated=0 Mapping=None [Signal60] ID=60 Type=Input Desc=Input #59 Enabled=0 Negated=0 Mapping=None [Signal61] ID=61 Type=Input Desc=Input #60 Enabled=0 Negated=0 Mapping=None [Signal62] ID=62 Type=Input Desc=Input #61 Enabled=0 Negated=0 Mapping=None [Signal63] ID=63 Type=Input Desc=Input #62 Enabled=0 Negated=0 Mapping=None [Signal64] ID=64 Type=Input Desc=Input #63 Enabled=0 Negated=0 Mapping=None [Signal163] ID=163 Type=Input Desc=Limit Override Enabled=0 Negated=0 Mapping=None [Signal164] ID=164 Type=Input Desc=E-Stop Enabled=1 Negated=0 Mapping=ESS/estop [Signal165] ID=165 Type=Input Desc=THC On Enabled=0 Negated=0 Mapping=None [Signal166] ID=166 Type=Input Desc=THC Up Enabled=0 Negated=0 Mapping=None [Signal167] ID=167 Type=Input Desc=THC Down Enabled=0 Negated=0 Mapping=None [Signal168] ID=168 Type=Input Desc=Timing Enabled=0 Negated=0 Mapping=None [Signal169] ID=169 Type=Input Desc=Jog X+ Enabled=0 Negated=0 Mapping=None [Signal170] ID=170 Type=Input Desc=Jog X- Enabled=0 Negated=0 Mapping=None [Signal171] ID=171 Type=Input Desc=Jog Y+ Enabled=0 Negated=0 Mapping=None [Signal172] ID=172 Type=Input Desc=Jog Y- Enabled=0 Negated=0 Mapping=None [Signal173] ID=173 Type=Input Desc=Jog Z+ Enabled=0 Negated=0 Mapping=None [Signal174] ID=174 Type=Input Desc=Jog Z- Enabled=0 Negated=0 Mapping=None [Signal175] ID=175 Type=Input Desc=Jog A+ Enabled=0 Negated=0 Mapping=None [Signal176] ID=176 Type=Input Desc=Jog A- Enabled=0 Negated=0 Mapping=None [Signal177] ID=177 Type=Input Desc=Jog B+ Enabled=0 Negated=0 Mapping=None [Signal178] ID=178 Type=Input Desc=Jog B- Enabled=0 Negated=0 Mapping=None [Signal179] ID=179 Type=Input Desc=Jog C+ Enabled=0 Negated=0 Mapping=None [Signal180] ID=180 Type=Input Desc=Jog C- Enabled=0 Negated=0 Mapping=None [Signal181] ID=181 Type=Input Desc=Spindle At Speed Enabled=0 Negated=0 Mapping=None [Signal182] ID=182 Type=Input Desc=Spindle At Zero Enabled=0 Negated=0 Mapping=None [Signal186] ID=186 Type=Input Desc=Motion Inhibit Enabled=0 Negated=0 Mapping=None [Signal187] ID=187 Type=Input Desc=Jog Inhibit Enabled=0 Negated=0 Mapping=None [Signal188] ID=188 Type=Input Desc=MPG Inhibit Enabled=0 Negated=0 Mapping=None [Signal65] ID=65 Type=Input Desc=Motor 0 Home Enabled=1 Negated=0 Mapping=ESS/X Home [Signal97] ID=97 Type=Input Desc=Motor 0 ++ Enabled=0 Negated=0 Mapping=None [Signal129] ID=129 Type=Input Desc=Motor 0 -- Enabled=0 Negated=0 Mapping=None [Signal66] ID=66 Type=Input Desc=Motor 1 Home Enabled=1 Negated=0 Mapping=ESS/Y Home [Signal98] ID=98 Type=Input Desc=Motor 1 ++ Enabled=0 Negated=0 Mapping=None [Signal130] ID=130 Type=Input Desc=Motor 1 -- Enabled=0 Negated=0 Mapping=None [Signal67] ID=67 Type=Input Desc=Motor 2 Home Enabled=1 Negated=0 Mapping=ESS/Z Home [Signal99] ID=99 Type=Input Desc=Motor 2 ++ Enabled=0 Negated=0 Mapping=None [Signal131] ID=131 Type=Input Desc=Motor 2 -- Enabled=0 Negated=0 Mapping=None [Signal68] ID=68 Type=Input Desc=Motor 3 Home Enabled=1 Negated=0 Mapping=ESS/A home [Signal100] ID=100 Type=Input Desc=Motor 3 ++ Enabled=0 Negated=0 Mapping=None [Signal132] ID=132 Type=Input Desc=Motor 3 -- Enabled=0 Negated=0 Mapping=None [Signal69] ID=69 Type=Input Desc=Motor 4 Home Enabled=0 Negated=0 Mapping=None [Signal101] ID=101 Type=Input Desc=Motor 4 ++ Enabled=0 Negated=0 Mapping=None [Signal133] ID=133 Type=Input Desc=Motor 4 -- Enabled=0 Negated=0 Mapping=None [Signal70] ID=70 Type=Input Desc=Motor 5 Home Enabled=0 Negated=0 Mapping=None [Signal102] ID=102 Type=Input Desc=Motor 5 ++ Enabled=0 Negated=0 Mapping=None [Signal134] ID=134 Type=Input Desc=Motor 5 -- Enabled=0 Negated=0 Mapping=None [Signal71] ID=71 Type=Input Desc=Motor 6 Home Enabled=0 Negated=0 Mapping=None [Signal103] ID=103 Type=Input Desc=Motor 6 ++ Enabled=0 Negated=0 Mapping=None [Signal135] ID=135 Type=Input Desc=Motor 6 -- Enabled=0 Negated=0 Mapping=None [Signal72] ID=72 Type=Input Desc=Motor 7 Home Enabled=0 Negated=0 Mapping=None [Signal104] ID=104 Type=Input Desc=Motor 7 ++ Enabled=0 Negated=0 Mapping=None [Signal136] ID=136 Type=Input Desc=Motor 7 -- Enabled=0 Negated=0 Mapping=None [Signal73] ID=73 Type=Input Desc=Motor 8 Home Enabled=0 Negated=0 Mapping=None [Signal105] ID=105 Type=Input Desc=Motor 8 ++ Enabled=0 Negated=0 Mapping=None [Signal137] ID=137 Type=Input Desc=Motor 8 -- Enabled=0 Negated=0 Mapping=None [Signal74] ID=74 Type=Input Desc=Motor 9 Home Enabled=0 Negated=0 Mapping=None [Signal106] ID=106 Type=Input Desc=Motor 9 ++ Enabled=0 Negated=0 Mapping=None [Signal138] ID=138 Type=Input Desc=Motor 9 -- Enabled=0 Negated=0 Mapping=None [Signal75] ID=75 Type=Input Desc=Motor 10 Home Enabled=0 Negated=0 Mapping=None [Signal107] ID=107 Type=Input Desc=Motor 10 ++ Enabled=0 Negated=0 Mapping=None [Signal139] ID=139 Type=Input Desc=Motor 10 -- Enabled=0 Negated=0 Mapping=None [Signal76] ID=76 Type=Input Desc=Motor 11 Home Enabled=0 Negated=0 Mapping=None [Signal108] ID=108 Type=Input Desc=Motor 11 ++ Enabled=0 Negated=0 Mapping=None [Signal140] ID=140 Type=Input Desc=Motor 11 -- Enabled=0 Negated=0 Mapping=None [Signal77] ID=77 Type=Input Desc=Motor 12 Home Enabled=0 Negated=0 Mapping=None [Signal109] ID=109 Type=Input Desc=Motor 12 ++ Enabled=0 Negated=0 Mapping=None [Signal141] ID=141 Type=Input Desc=Motor 12 -- Enabled=0 Negated=0 Mapping=None [Signal78] ID=78 Type=Input Desc=Motor 13 Home Enabled=0 Negated=0 Mapping=None [Signal110] ID=110 Type=Input Desc=Motor 13 ++ Enabled=0 Negated=0 Mapping=None [Signal142] ID=142 Type=Input Desc=Motor 13 -- Enabled=0 Negated=0 Mapping=None [Signal79] ID=79 Type=Input Desc=Motor 14 Home Enabled=0 Negated=0 Mapping=None [Signal111] ID=111 Type=Input Desc=Motor 14 ++ Enabled=0 Negated=0 Mapping=None [Signal143] ID=143 Type=Input Desc=Motor 14 -- Enabled=0 Negated=0 Mapping=None [Signal80] ID=80 Type=Input Desc=Motor 15 Home Enabled=0 Negated=0 Mapping=None [Signal112] ID=112 Type=Input Desc=Motor 15 ++ Enabled=0 Negated=0 Mapping=None [Signal144] ID=144 Type=Input Desc=Motor 15 -- Enabled=0 Negated=0 Mapping=None [Signal81] ID=81 Type=Input Desc=Motor 16 Home Enabled=0 Negated=0 Mapping=None [Signal113] ID=113 Type=Input Desc=Motor 16 ++ Enabled=0 Negated=0 Mapping=None [Signal145] ID=145 Type=Input Desc=Motor 16 -- Enabled=0 Negated=0 Mapping=None [Signal82] ID=82 Type=Input Desc=Motor 17 Home Enabled=0 Negated=0 Mapping=None [Signal114] ID=114 Type=Input Desc=Motor 17 ++ Enabled=0 Negated=0 Mapping=None [Signal146] ID=146 Type=Input Desc=Motor 17 -- Enabled=0 Negated=0 Mapping=None [Signal83] ID=83 Type=Input Desc=Motor 18 Home Enabled=0 Negated=0 Mapping=None [Signal115] ID=115 Type=Input Desc=Motor 18 ++ Enabled=0 Negated=0 Mapping=None [Signal147] ID=147 Type=Input Desc=Motor 18 -- Enabled=0 Negated=0 Mapping=None [Signal84] ID=84 Type=Input Desc=Motor 19 Home Enabled=0 Negated=0 Mapping=None [Signal116] ID=116 Type=Input Desc=Motor 19 ++ Enabled=0 Negated=0 Mapping=None [Signal148] ID=148 Type=Input Desc=Motor 19 -- Enabled=0 Negated=0 Mapping=None [Signal85] ID=85 Type=Input Desc=Motor 20 Home Enabled=0 Negated=0 Mapping=None [Signal117] ID=117 Type=Input Desc=Motor 20 ++ Enabled=0 Negated=0 Mapping=None [Signal149] ID=149 Type=Input Desc=Motor 20 -- Enabled=0 Negated=0 Mapping=None [Signal86] ID=86 Type=Input Desc=Motor 21 Home Enabled=0 Negated=0 Mapping=None [Signal118] ID=118 Type=Input Desc=Motor 21 ++ Enabled=0 Negated=0 Mapping=None [Signal150] ID=150 Type=Input Desc=Motor 21 -- Enabled=0 Negated=0 Mapping=None [Signal87] ID=87 Type=Input Desc=Motor 22 Home Enabled=0 Negated=0 Mapping=None [Signal119] ID=119 Type=Input Desc=Motor 22 ++ Enabled=0 Negated=0 Mapping=None [Signal151] ID=151 Type=Input Desc=Motor 22 -- Enabled=0 Negated=0 Mapping=None [Signal88] ID=88 Type=Input Desc=Motor 23 Home Enabled=0 Negated=0 Mapping=None [Signal120] ID=120 Type=Input Desc=Motor 23 ++ Enabled=0 Negated=0 Mapping=None [Signal152] ID=152 Type=Input Desc=Motor 23 -- Enabled=0 Negated=0 Mapping=None [Signal89] ID=89 Type=Input Desc=Motor 24 Home Enabled=0 Negated=0 Mapping=None [Signal121] ID=121 Type=Input Desc=Motor 24 ++ Enabled=0 Negated=0 Mapping=None [Signal153] ID=153 Type=Input Desc=Motor 24 -- Enabled=0 Negated=0 Mapping=None [Signal90] ID=90 Type=Input Desc=Motor 25 Home Enabled=0 Negated=0 Mapping=None [Signal122] ID=122 Type=Input Desc=Motor 25 ++ Enabled=0 Negated=0 Mapping=None [Signal154] ID=154 Type=Input Desc=Motor 25 -- Enabled=0 Negated=0 Mapping=None [Signal91] ID=91 Type=Input Desc=Motor 26 Home Enabled=0 Negated=0 Mapping=None [Signal123] ID=123 Type=Input Desc=Motor 26 ++ Enabled=0 Negated=0 Mapping=None [Signal155] ID=155 Type=Input Desc=Motor 26 -- Enabled=0 Negated=0 Mapping=None [Signal92] ID=92 Type=Input Desc=Motor 27 Home Enabled=0 Negated=0 Mapping=None [Signal124] ID=124 Type=Input Desc=Motor 27 ++ Enabled=0 Negated=0 Mapping=None [Signal156] ID=156 Type=Input Desc=Motor 27 -- Enabled=0 Negated=0 Mapping=None [Signal93] ID=93 Type=Input Desc=Motor 28 Home Enabled=0 Negated=0 Mapping=None [Signal125] ID=125 Type=Input Desc=Motor 28 ++ Enabled=0 Negated=0 Mapping=None [Signal157] ID=157 Type=Input Desc=Motor 28 -- Enabled=0 Negated=0 Mapping=None [Signal94] ID=94 Type=Input Desc=Motor 29 Home Enabled=0 Negated=0 Mapping=None [Signal126] ID=126 Type=Input Desc=Motor 29 ++ Enabled=0 Negated=0 Mapping=None [Signal158] ID=158 Type=Input Desc=Motor 29 -- Enabled=0 Negated=0 Mapping=None [Signal95] ID=95 Type=Input Desc=Motor 30 Home Enabled=0 Negated=0 Mapping=None [Signal127] ID=127 Type=Input Desc=Motor 30 ++ Enabled=0 Negated=0 Mapping=None [Signal159] ID=159 Type=Input Desc=Motor 30 -- Enabled=0 Negated=0 Mapping=None [Signal96] ID=96 Type=Input Desc=Motor 31 Home Enabled=0 Negated=0 Mapping=None [Signal128] ID=128 Type=Input Desc=Motor 31 ++ Enabled=0 Negated=0 Mapping=None [Signal160] ID=160 Type=Input Desc=Motor 31 -- Enabled=0 Negated=0 Mapping=None [Signal1146] ID=1146 Type=Output Desc=Digitize Trigger Enabled=0 Negated=0 Mapping=None [Signal1141] ID=1141 Type=Output Desc=Spindle On Enabled=0 Negated=0 Mapping=None [Signal1142] ID=1142 Type=Output Desc=Spindle Fwd Enabled=1 Negated=0 Mapping=ESS/Motor C Dir [Signal1143] ID=1143 Type=Output Desc=Spindle Rev Enabled=0 Negated=0 Mapping=None [Signal1144] ID=1144 Type=Output Desc=Coolant On Enabled=0 Negated=0 Mapping=None [Signal1145] ID=1145 Type=Output Desc=Mist On Enabled=0 Negated=0 Mapping=None [Signal1138] ID=1138 Type=Output Desc=Reserved #1 Enabled=0 Negated=0 Mapping=None [Signal1139] ID=1139 Type=Output Desc=Reserved #2 Enabled=0 Negated=0 Mapping=None [Signal1140] ID=1140 Type=Output Desc=Current Hi/Low Enabled=0 Negated=0 Mapping=None [Signal1018] ID=1018 Type=Output Desc=Enable #0 Enabled=0 Negated=0 Mapping=None [Signal1019] ID=1019 Type=Output Desc=Enable #1 Enabled=0 Negated=0 Mapping=None [Signal1020] ID=1020 Type=Output Desc=Enable #2 Enabled=0 Negated=0 Mapping=None [Signal1021] ID=1021 Type=Output Desc=Enable #3 Enabled=0 Negated=0 Mapping=None [Signal1022] ID=1022 Type=Output Desc=Enable #4 Enabled=0 Negated=0 Mapping=None [Signal1023] ID=1023 Type=Output Desc=Enable #5 Enabled=0 Negated=0 Mapping=None [Signal1024] ID=1024 Type=Output Desc=Enable #6 Enabled=0 Negated=0 Mapping=None [Signal1025] ID=1025 Type=Output Desc=Enable #7 Enabled=0 Negated=0 Mapping=None [Signal1026] ID=1026 Type=Output Desc=Enable #8 Enabled=0 Negated=0 Mapping=None [Signal1027] ID=1027 Type=Output Desc=Enable #9 Enabled=0 Negated=0 Mapping=None [Signal1028] ID=1028 Type=Output Desc=Enable #10 Enabled=0 Negated=0 Mapping=None [Signal1029] ID=1029 Type=Output Desc=Enable #11 Enabled=0 Negated=0 Mapping=None [Signal1030] ID=1030 Type=Output Desc=Enable #12 Enabled=0 Negated=0 Mapping=None [Signal1031] ID=1031 Type=Output Desc=Enable #13 Enabled=0 Negated=0 Mapping=None [Signal1032] ID=1032 Type=Output Desc=Enable #14 Enabled=0 Negated=0 Mapping=None [Signal1033] ID=1033 Type=Output Desc=Enable #15 Enabled=0 Negated=0 Mapping=None [Signal1034] ID=1034 Type=Output Desc=Enable #16 Enabled=0 Negated=0 Mapping=None [Signal1035] ID=1035 Type=Output Desc=Enable #17 Enabled=0 Negated=0 Mapping=None [Signal1036] ID=1036 Type=Output Desc=Enable #18 Enabled=0 Negated=0 Mapping=None [Signal1037] ID=1037 Type=Output Desc=Enable #19 Enabled=0 Negated=0 Mapping=None [Signal1038] ID=1038 Type=Output Desc=Enable #20 Enabled=0 Negated=0 Mapping=None [Signal1039] ID=1039 Type=Output Desc=Enable #21 Enabled=0 Negated=0 Mapping=None [Signal1040] ID=1040 Type=Output Desc=Enable #22 Enabled=0 Negated=0 Mapping=None [Signal1041] ID=1041 Type=Output Desc=Enable #23 Enabled=0 Negated=0 Mapping=None [Signal1042] ID=1042 Type=Output Desc=Enable #24 Enabled=0 Negated=0 Mapping=None [Signal1043] ID=1043 Type=Output Desc=Enable #25 Enabled=0 Negated=0 Mapping=None [Signal1044] ID=1044 Type=Output Desc=Enable #26 Enabled=0 Negated=0 Mapping=None [Signal1045] ID=1045 Type=Output Desc=Enable #27 Enabled=0 Negated=0 Mapping=None [Signal1046] ID=1046 Type=Output Desc=Enable #28 Enabled=0 Negated=0 Mapping=None [Signal1047] ID=1047 Type=Output Desc=Enable #29 Enabled=0 Negated=0 Mapping=None [Signal1048] ID=1048 Type=Output Desc=Enable #30 Enabled=0 Negated=0 Mapping=None [Signal1049] ID=1049 Type=Output Desc=Enable #31 Enabled=0 Negated=0 Mapping=None [Signal1000] ID=1000 Type=Output Desc=X ++ Enabled=0 Negated=0 Mapping=None [Signal1001] ID=1001 Type=Output Desc=X -- Enabled=0 Negated=0 Mapping=None [Signal1002] ID=1002 Type=Output Desc=X Home Enabled=0 Negated=0 Mapping=None [Signal1003] ID=1003 Type=Output Desc=Y ++ Enabled=0 Negated=0 Mapping=None [Signal1004] ID=1004 Type=Output Desc=Y -- Enabled=0 Negated=0 Mapping=None [Signal1005] ID=1005 Type=Output Desc=Y Home Enabled=0 Negated=0 Mapping=None [Signal1006] ID=1006 Type=Output Desc=Z ++ Enabled=0 Negated=0 Mapping=None [Signal1007] ID=1007 Type=Output Desc=Z -- Enabled=0 Negated=0 Mapping=None [Signal1008] ID=1008 Type=Output Desc=Z Home Enabled=0 Negated=0 Mapping=None [Signal1009] ID=1009 Type=Output Desc=A ++ Enabled=0 Negated=0 Mapping=None [Signal1010] ID=1010 Type=Output Desc=A -- Enabled=0 Negated=0 Mapping=None [Signal1011] ID=1011 Type=Output Desc=A Home Enabled=0 Negated=0 Mapping=None [Signal1012] ID=1012 Type=Output Desc=B ++ Enabled=0 Negated=0 Mapping=None [Signal1013] ID=1013 Type=Output Desc=B -- Enabled=0 Negated=0 Mapping=None [Signal1014] ID=1014 Type=Output Desc=B Home Enabled=0 Negated=0 Mapping=None [Signal1015] ID=1015 Type=Output Desc=C ++ Enabled=0 Negated=0 Mapping=None [Signal1016] ID=1016 Type=Output Desc=C -- Enabled=0 Negated=0 Mapping=None [Signal1017] ID=1017 Type=Output Desc=C Home Enabled=0 Negated=0 Mapping=None [Signal1050] ID=1050 Type=Output Desc=Output #0 Enabled=0 Negated=0 Mapping=None [Signal1051] ID=1051 Type=Output Desc=Output #1 Enabled=0 Negated=0 Mapping=None [Signal1052] ID=1052 Type=Output Desc=Output #2 Enabled=0 Negated=0 Mapping=None [Signal1053] ID=1053 Type=Output Desc=Output #3 Enabled=0 Negated=0 Mapping=None [Signal1054] ID=1054 Type=Output Desc=Output #4 Enabled=0 Negated=0 Mapping=None [Signal1055] ID=1055 Type=Output Desc=Output #5 Enabled=0 Negated=0 Mapping=None [Signal1056] ID=1056 Type=Output Desc=Output #6 Enabled=0 Negated=0 Mapping=None [Signal1057] ID=1057 Type=Output Desc=Output #7 Enabled=0 Negated=0 Mapping=None [Signal1058] ID=1058 Type=Output Desc=Output #8 Enabled=0 Negated=0 Mapping=None [Signal1059] ID=1059 Type=Output Desc=Output #9 Enabled=0 Negated=0 Mapping=None [Signal1060] ID=1060 Type=Output Desc=Output #10 Enabled=0 Negated=0 Mapping=None [Signal1061] ID=1061 Type=Output Desc=Output #11 Enabled=0 Negated=0 Mapping=None [Signal1062] ID=1062 Type=Output Desc=Output #12 Enabled=0 Negated=0 Mapping=None [Signal1063] ID=1063 Type=Output Desc=Output #13 Enabled=0 Negated=0 Mapping=None [Signal1064] ID=1064 Type=Output Desc=Output #14 Enabled=0 Negated=0 Mapping=None [Signal1065] ID=1065 Type=Output Desc=Output #15 Enabled=0 Negated=0 Mapping=None [Signal1066] ID=1066 Type=Output Desc=Output #16 Enabled=0 Negated=0 Mapping=None [Signal1067] ID=1067 Type=Output Desc=Output #17 Enabled=0 Negated=0 Mapping=None [Signal1068] ID=1068 Type=Output Desc=Output #18 Enabled=0 Negated=0 Mapping=None [Signal1069] ID=1069 Type=Output Desc=Output #19 Enabled=0 Negated=0 Mapping=None [Signal1070] ID=1070 Type=Output Desc=Output #20 Enabled=0 Negated=0 Mapping=None [Signal1071] ID=1071 Type=Output Desc=Output #21 Enabled=0 Negated=0 Mapping=None [Signal1072] ID=1072 Type=Output Desc=Output #22 Enabled=0 Negated=0 Mapping=None [Signal1073] ID=1073 Type=Output Desc=Output #23 Enabled=0 Negated=0 Mapping=None [Signal1074] ID=1074 Type=Output Desc=Output #24 Enabled=0 Negated=0 Mapping=None [Signal1075] ID=1075 Type=Output Desc=Output #25 Enabled=0 Negated=0 Mapping=None [Signal1076] ID=1076 Type=Output Desc=Output #26 Enabled=0 Negated=0 Mapping=None [Signal1077] ID=1077 Type=Output Desc=Output #27 Enabled=0 Negated=0 Mapping=None [Signal1078] ID=1078 Type=Output Desc=Output #28 Enabled=0 Negated=0 Mapping=None [Signal1079] ID=1079 Type=Output Desc=Output #29 Enabled=0 Negated=0 Mapping=None [Signal1080] ID=1080 Type=Output Desc=Output #30 Enabled=0 Negated=0 Mapping=None [Signal1081] ID=1081 Type=Output Desc=Output #31 Enabled=0 Negated=0 Mapping=None [Signal1082] ID=1082 Type=Output Desc=Output #32 Enabled=0 Negated=0 Mapping=None [Signal1083] ID=1083 Type=Output Desc=Output #33 Enabled=0 Negated=0 Mapping=None [Signal1084] ID=1084 Type=Output Desc=Output #34 Enabled=0 Negated=0 Mapping=None [Signal1085] ID=1085 Type=Output Desc=Output #35 Enabled=0 Negated=0 Mapping=None [Signal1086] ID=1086 Type=Output Desc=Output #36 Enabled=0 Negated=0 Mapping=None [Signal1087] ID=1087 Type=Output Desc=Output #37 Enabled=0 Negated=0 Mapping=None [Signal1088] ID=1088 Type=Output Desc=Output #38 Enabled=0 Negated=0 Mapping=None [Signal1089] ID=1089 Type=Output Desc=Output #39 Enabled=0 Negated=0 Mapping=None [Signal1090] ID=1090 Type=Output Desc=Output #40 Enabled=0 Negated=0 Mapping=None [Signal1091] ID=1091 Type=Output Desc=Output #41 Enabled=0 Negated=0 Mapping=None [Signal1092] ID=1092 Type=Output Desc=Output #42 Enabled=0 Negated=0 Mapping=None [Signal1093] ID=1093 Type=Output Desc=Output #43 Enabled=0 Negated=0 Mapping=None [Signal1094] ID=1094 Type=Output Desc=Output #44 Enabled=0 Negated=0 Mapping=None [Signal1095] ID=1095 Type=Output Desc=Output #45 Enabled=0 Negated=0 Mapping=None [Signal1096] ID=1096 Type=Output Desc=Output #46 Enabled=0 Negated=0 Mapping=None [Signal1097] ID=1097 Type=Output Desc=Output #47 Enabled=0 Negated=0 Mapping=None [Signal1098] ID=1098 Type=Output Desc=Output #48 Enabled=0 Negated=0 Mapping=None [Signal1099] ID=1099 Type=Output Desc=Output #49 Enabled=0 Negated=0 Mapping=None [Signal1100] ID=1100 Type=Output Desc=Output #50 Enabled=0 Negated=0 Mapping=None [Signal1101] ID=1101 Type=Output Desc=Output #51 Enabled=1 Negated=0 Mapping=ESS/laser On off [Signal1102] ID=1102 Type=Output Desc=Output #52 Enabled=1 Negated=0 Mapping=ESS/Dust Collector [Signal1103] ID=1103 Type=Output Desc=Output #53 Enabled=0 Negated=0 Mapping=None [Signal1104] ID=1104 Type=Output Desc=Output #54 Enabled=0 Negated=0 Mapping=None [Signal1105] ID=1105 Type=Output Desc=Output #55 Enabled=0 Negated=0 Mapping=None [Signal1106] ID=1106 Type=Output Desc=Output #56 Enabled=0 Negated=0 Mapping=None [Signal1107] ID=1107 Type=Output Desc=Output #57 Enabled=0 Negated=0 Mapping=None [Signal1108] ID=1108 Type=Output Desc=Output #58 Enabled=0 Negated=0 Mapping=None [Signal1109] ID=1109 Type=Output Desc=Output #59 Enabled=0 Negated=0 Mapping=None [Signal1110] ID=1110 Type=Output Desc=Output #60 Enabled=0 Negated=0 Mapping=None [Signal1111] ID=1111 Type=Output Desc=Output #61 Enabled=0 Negated=0 Mapping=None [Signal1112] ID=1112 Type=Output Desc=Output #62 Enabled=0 Negated=0 Mapping=None [Signal1113] ID=1113 Type=Output Desc=Output #63 Enabled=0 Negated=0 Mapping=None [Signal1114] ID=1114 Type=Output Desc=Gcode Running Enabled=0 Negated=0 Mapping=None [Signal1115] ID=1115 Type=Output Desc=Feed Hold Enabled=0 Negated=0 Mapping=None [Signal1116] ID=1116 Type=Output Desc=Block Delete Enabled=0 Negated=0 Mapping=None [Signal1117] ID=1117 Type=Output Desc=Single Block Enabled=0 Negated=0 Mapping=None [Signal1118] ID=1118 Type=Output Desc=Reverse Run Enabled=0 Negated=0 Mapping=None [Signal1119] ID=1119 Type=Output Desc=Opt Stop Enabled=0 Negated=0 Mapping=None [Signal1120] ID=1120 Type=Output Desc=Machine Enabled Enabled=0 Negated=0 Mapping=None [Signal1121] ID=1121 Type=Output Desc=Tool Change Enabled=0 Negated=0 Mapping=None [Signal1122] ID=1122 Type=Output Desc=Dist To Go Enabled=0 Negated=0 Mapping=None [Signal1123] ID=1123 Type=Output Desc=Machine Coord Enabled=0 Negated=0 Mapping=None [Signal1124] ID=1124 Type=Output Desc=Softlimits On Enabled=0 Negated=0 Mapping=None [Signal1125] ID=1125 Type=Output Desc=Jog Inc Enabled=0 Negated=0 Mapping=None [Signal1126] ID=1126 Type=Output Desc=Jog Cont Enabled=0 Negated=0 Mapping=None [Signal1127] ID=1127 Type=Output Desc=Jog Enabled Enabled=0 Negated=0 Mapping=None [Signal1128] ID=1128 Type=Output Desc=Jog MPG Enabled=0 Negated=0 Mapping=None [Signal1129] ID=1129 Type=Output Desc=X Homed Enabled=0 Negated=0 Mapping=None [Signal1130] ID=1130 Type=Output Desc=Y Homed Enabled=0 Negated=0 Mapping=None [Signal1131] ID=1131 Type=Output Desc=Z Homed Enabled=0 Negated=0 Mapping=None [Signal1132] ID=1132 Type=Output Desc=A Homed Enabled=0 Negated=0 Mapping=None [Signal1133] ID=1133 Type=Output Desc=B Homed Enabled=0 Negated=0 Mapping=None [Signal1134] ID=1134 Type=Output Desc=C Homed Enabled=0 Negated=0 Mapping=None [Signal1135] ID=1135 Type=Output Desc=Dwell Enabled=0 Negated=0 Mapping=None [Signal1136] ID=1136 Type=Output Desc=Toolpath Mouse Down Enabled=0 Negated=0 Mapping=None [Signal1137] ID=1137 Type=Output Desc=Limit Override Enabled=0 Negated=0 Mapping=None [Signal1147] ID=1147 Type=Output Desc=Alarm Enabled=0 Negated=0 Mapping=None [Signal1148] ID=1148 Type=Output Desc=Parts Finished Enabled=0 Negated=0 Mapping=None [Motor0] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=4172.354000 MaxVelocity=166894.160000 MaxAccel=83447.080000 BacklashAmount=0.000000 SoftMaxLimit=210148.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor1] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=4172.354000 MaxVelocity=166894.160000 MaxAccel=83447.080000 BacklashAmount=0.000000 SoftMaxLimit=408888.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor2] Enabled=1 Reverse=1 CanHome=1 CountsPerUnit=8192.000000 MaxVelocity=109226.666667 MaxAccel=327680.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=-52427.000000 EnableDelay=0 [Motor3] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=4172.354000 MaxVelocity=166894.160000 MaxAccel=83447.080000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor4] Enabled=1 Reverse=0 CanHome=1 CountsPerUnit=1000.000000 MaxVelocity=16.666667 MaxAccel=1000000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Motor5] Enabled=0 Reverse=0 CanHome=1 CountsPerUnit=2000.000000 MaxVelocity=200000.000000 MaxAccel=20000.000000 BacklashAmount=0.000000 SoftMaxLimit=0.000000 SoftMinLimit=0.000000 EnableDelay=0 [Axis0] OutOfBandAxis=0 SpindleAxis=0 Enabled=1 JogWithBuffer=1 HomeOrder=3 HomeDir=-1 HomeOffset=0.000000 HomeSpeedPercent=80.000000 SoftLimitUsed=1 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 ChildMotor0=Motor0 [Axis1] OutOfBandAxis=0 SpindleAxis=0 Enabled=1 JogWithBuffer=1 HomeOrder=2 HomeDir=-1 HomeOffset=0.000000 HomeSpeedPercent=80.000000 SoftLimitUsed=1 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 ChildMotor0=Motor1 ChildMotor1=Motor3 [Axis2] OutOfBandAxis=0 SpindleAxis=0 Enabled=1 JogWithBuffer=1 HomeOrder=1 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=1 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 ChildMotor0=Motor2 [Axis3] OutOfBandAxis=0 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=4 HomeDir=-1 HomeOffset=0.000000 HomeSpeedPercent=80.000000 SoftLimitUsed=1 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis4] OutOfBandAxis=0 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=5 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis5] OutOfBandAxis=0 SpindleAxis=0 Enabled=1 JogWithBuffer=1 HomeOrder=6 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 ChildMotor0=Motor5 [Axis6] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis7] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis8] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis9] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis10] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [Axis11] OutOfBandAxis=1 SpindleAxis=0 Enabled=0 JogWithBuffer=1 HomeOrder=0 HomeDir=1 HomeOffset=0.000000 HomeSpeedPercent=20.000000 SoftLimitUsed=0 HomeInPlace=0 OverrideAxis1=-1 OverrideAxis2=-1 OverrideAxis3=-1 OverrideAxis4=-1 [SpindleRange0] AccelTime=3.000000 DecelTime=3.000000 FeedbackRatio=1.000000 MaxRPM=24000.000000 MinRPM=0.000000 Reversed=0 [SpindleRange1] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange2] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange3] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange4] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange5] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange6] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange7] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange8] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange9] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange10] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange11] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange12] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange13] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange14] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange15] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange16] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange17] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange18] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [SpindleRange19] AccelTime=0.000000 DecelTime=0.000000 FeedbackRatio=1.000000 MaxRPM=0.000000 MinRPM=0.000000 Reversed=0 [Stats] TotalHours=0.000000 SpindleHours=14.000000 DistanceX=0.000000 DistanceY=0.000000 DistanceZ=0.000000 DistanceA=0.000000 DistanceB=0.000000 DistanceC=0.000000 M3=0 M4=0 M6=8 [ARotoryAxisPosition] XAxis=0.000000 YAxis=0.000000 ZAxis=0.000000 RotationAbout=-1 [CVFeedrate] Angle_0=0.000000 Angle_1=0.000000 Angle_2=0.000000 Angle_3=0.000000 Angle_4=0.000000 Angle_5=0.000000 Angle_6=0.000000 Angle_7=0.000000 Angle_8=0.000000 Angle_9=0.000000 Angle_10=0.000000 Angle_11=0.000000 Angle_12=0.000000 Angle_13=0.000000 Angle_14=0.000000 Angle_15=0.000000 Angle_16=0.000000 Angle_17=0.000000 Angle_18=0.000000 Angle_19=0.000000 Angle_20=0.000000 Angle_21=0.000000 Angle_22=0.000000 Angle_23=0.000000 Angle_24=0.000000 Angle_25=0.000000 Angle_26=0.000000 Angle_27=0.000000 Angle_28=0.000000 Angle_29=0.000000 Angle_30=0.000000 Angle_31=0.000000 Angle_32=0.000000 Angle_33=0.000000 Angle_34=0.000000 Angle_35=0.000000 Angle_36=0.000000 Angle_37=0.000000 Angle_38=0.000000 Angle_39=0.000000 Angle_40=0.000000 Angle_41=0.000000 Angle_42=0.000000 Angle_43=0.000000 Angle_44=0.000000 Angle_45=0.000000 Angle_46=0.000000 Angle_47=0.000000 Angle_48=0.000000 Angle_49=0.000000 Angle_50=0.000000 Angle_51=0.000000 Angle_52=0.000000 Angle_53=0.000000 Angle_54=0.000000 Angle_55=0.000000 Angle_56=0.000000 Angle_57=0.000000 Angle_58=0.000000 Angle_59=0.000000 Angle_60=0.000000 Angle_61=0.000000 Angle_62=0.000000 Angle_63=0.000000 Angle_64=0.000000 Angle_65=0.000000 Angle_66=0.000000 Angle_67=0.000000 Angle_68=0.000000 Angle_69=0.000000 Angle_70=0.000000 Angle_71=0.000000 Angle_72=0.000000 Angle_73=0.000000 Angle_74=0.000000 Angle_75=0.000000 Angle_76=0.000000 Angle_77=0.000000 Angle_78=0.000000 Angle_79=0.000000 Angle_80=0.000000 Angle_81=0.000000 Angle_82=0.000000 Angle_83=0.000000 Angle_84=0.000000 Angle_85=0.000000 Angle_86=0.000000 Angle_87=0.000000 Angle_88=0.000000 Angle_89=0.000000 Angle_90=0.000000 Angle_91=0.000000 Angle_92=0.000000 Angle_93=0.000000 Angle_94=0.000000 Angle_95=0.000000 Angle_96=0.000000 Angle_97=0.000000 Angle_98=0.000000 Angle_99=0.000000 Angle_100=0.000000 Angle_101=0.000000 Angle_102=0.000000 Angle_103=0.000000 Angle_104=0.000000 Angle_105=0.000000 Angle_106=0.000000 Angle_107=0.000000 Angle_108=0.000000 Angle_109=0.000000 Angle_110=0.000000 Angle_111=0.000000 Angle_112=0.000000 Angle_113=0.000000 Angle_114=0.000000 Angle_115=0.000000 Angle_116=0.000000 Angle_117=0.000000 Angle_118=0.000000 Angle_119=0.000000 Angle_120=0.000000 Angle_121=0.000000 Angle_122=0.000000 Angle_123=0.000000 Angle_124=0.000000 Angle_125=0.000000 Angle_126=0.000000 Angle_127=0.000000 Angle_128=0.000000 Angle_129=0.000000 Angle_130=0.000000 Angle_131=0.000000 Angle_132=0.000000 Angle_133=0.000000 Angle_134=0.000000 Angle_135=0.000000 Angle_136=0.000000 Angle_137=0.000000 Angle_138=0.000000 Angle_139=0.000000 Angle_140=0.000000 Angle_141=0.000000 Angle_142=0.000000 Angle_143=0.000000 Angle_144=0.000000 Angle_145=0.000000 Angle_146=0.000000 Angle_147=0.000000 Angle_148=0.000000 Angle_149=0.000000 Angle_150=0.000000 Angle_151=0.000000 Angle_152=0.000000 Angle_153=0.000000 Angle_154=0.000000 Angle_155=0.000000 Angle_156=0.000000 Angle_157=0.000000 Angle_158=0.000000 Angle_159=0.000000 Angle_160=0.000000 Angle_161=0.000000 Angle_162=0.000000 Angle_163=0.000000 Angle_164=0.000000 Angle_165=0.000000 Angle_166=0.000000 Angle_167=0.000000 Angle_168=0.000000 Angle_169=0.000000 Angle_170=0.000000 Angle_171=0.000000 Angle_172=0.000000 Angle_173=0.000000 Angle_174=0.000000 Angle_175=0.000000 Angle_176=0.000000 Angle_177=0.000000 Angle_178=0.000000 Angle_179=0.000000 [DefaultMode] ControlMode=0 UnitsMode=G20 TraverseMode=G0 MotionMode=G64 DistanceMode=G90 CenterMode=G91.1 FeedMode=G94 Plane=G17 CanedCycleRetract=G98 SpindleMode=G97S0 UserDefaults1=G80F150S10000M1000 [Plugins] mcKeyboard=1 mcLua=1 mcModbus=0 mcRegfile=0 mcSerial=0 ShuttlePro=1 Sim=0 Warp9Mach4=1 mcX360=1 [Mpg0] Enabled=1 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 RegisterPath=Shuttle0/InnerWheelCount [Mpg1] Enabled=1 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 RegisterPath=Shuttle0/InnerWheelCount [Mpg2] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg3] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg4] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg5] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg6] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg7] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg8] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg9] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg10] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [Mpg11] Enabled=0 CountsPerDetent=1 AccelPercent=0.0 RatePercent=0.0 Reversed=0 [ShuttlePro0] Input0=1 Input1=2 Input2=3 Input3=19 Input4=0 Input5=0 Input6=0 Input7=0 Input8=0 Input9=0 Input10=0 Input11=0 Input12=0 Input13=0 Input14=0 Input15=0 Input16=0 Input17=0 Input18=0 Input19=0 Input20=0 Input21=0 Input22=0 Input23=0 Input24=0 Input25=0 Input26=0 Input27=0 Input28=0 [KeyboardKey0] IO_Name=X+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=39 Function=1 [KeyboardKey1] IO_Name=X- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=37 Function=2 [KeyboardKey2] IO_Name=Y+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=38 Function=7 [KeyboardKey3] IO_Name=Y- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=40 Function=8 [KeyboardKey4] IO_Name=Z+ Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=34 Function=14 [KeyboardKey5] IO_Name=Z- Shift=0 Alt=0 Ctrl=0 Lock=0 KeyCode=33 Function=13 [Sim] ExampleInt=100 [LogWindow] posX=2232 posY=347 width=740 height=300 aot=0 [TOffParams] ToffDialog=1 ToffProbeRate=5 [PersistentDROs] droGageBlock=0.125000 droGageBlockT=0.125000 droEdgeFinder=0.250000 droJogRate=50.000000 [TOffParams] ToffDialog=0 ToffProbeRate=5 ToffProbeCode=31 ToffPlate=0.125 ToffToolDiam=0.25 ToffPrepDistance=4 ToffPrepRate=60 ToffRetractDistance=0.5 ToffZOnlyOption=1 [FixtureWindow] posX=1001 posY=65 width=620 height=400 aot=1 [RegFileDiag] aot=1 x=1036 y=448 w=400 h=350 PoundVarlbound=10400 PoundVarubound=10500 [ToolWindow] posX=660 posY=320 width=600 height=400 aot=0 opt=0 usr=0 sim=0 [RememberPos] X=0 Y=0 Z=0.0845 [AutoToolSetterSettings] SurfaceDistance=6 ProbeHeight=0.125 ToolLength=2 XPosition=0.000 YPosition=0.000 Retract=1.5 GCode=31 ATDialog=0 [ToolChangeSettings] ToolChangeMsgBox=1 [ESS] BoardIpAddr=10.9.9.9 MotionBufferSize=0.18 PluginFrequency=40 Motor-0-Mode=Step/Dir Motor-1-Mode=Step/Dir Motor-2-Mode=Step/Dir Motor-3-Mode=Step/Dir Motor-4-Mode=Step/Dir Motor-5-Mode=Step/Dir Spindle-Mode=PWM SpindlePwmFrequency=1000.00 SpindleStepPulseWidth=4.00 Port2Pins2_9_Direction=Inputs Port3Pins2_9_Direction=Inputs Port1-Pin1-Alias=Motor B Step Port1-Pin1-ActiveLow=0 Port1-Pin1-NoiseFilterValue=0.00 Port1-Pin2-Alias=Motor X Step Port1-Pin2-ActiveLow=0 Port1-Pin2-NoiseFilterValue=0.00 Port1-Pin3-Alias=Motor X Dir Port1-Pin3-ActiveLow=1 Port1-Pin3-NoiseFilterValue=0.00 Port1-Pin4-Alias=Motor Y Step Port1-Pin4-ActiveLow=0 Port1-Pin4-NoiseFilterValue=0.00 Port1-Pin5-Alias=Motor Y Dir Port1-Pin5-ActiveLow=1 Port1-Pin5-NoiseFilterValue=0.00 Port1-Pin6-Alias=Motor Z Step Port1-Pin6-ActiveLow=0 Port1-Pin6-NoiseFilterValue=0.00 Port1-Pin7-Alias=Motor Z Dir Port1-Pin7-ActiveLow=0 Port1-Pin7-NoiseFilterValue=0.00 Port1-Pin8-Alias=Motor A Step Port1-Pin8-ActiveLow=0 Port1-Pin8-NoiseFilterValue=0.00 Port1-Pin9-Alias=Motor A Dir Port1-Pin9-ActiveLow=0 Port1-Pin9-NoiseFilterValue=0.00 Port1-Pin10-Alias=estop Port1-Pin10-ActiveLow=1 Port1-Pin10-NoiseFilterValue=0.00 Port1-Pin11-Alias=A home Port1-Pin11-ActiveLow=1 Port1-Pin11-NoiseFilterValue=0.00 Port1-Pin12-Alias=Y Home Port1-Pin12-ActiveLow=1 Port1-Pin12-NoiseFilterValue=0.00 Port1-Pin13-Alias=Z Home Port1-Pin13-ActiveLow=1 Port1-Pin13-NoiseFilterValue=0.00 Port1-Pin14-Alias=Motor C Step Port1-Pin14-ActiveLow=0 Port1-Pin14-NoiseFilterValue=0.00 Port1-Pin15-Alias=Probe g31 Port1-Pin15-ActiveLow=0 Port1-Pin15-NoiseFilterValue=0.00 Port1-Pin16-Alias=Motor C Dir Port1-Pin16-ActiveLow=0 Port1-Pin16-NoiseFilterValue=0.00 Port1-Pin17-Alias=Motor B Dir Port1-Pin17-ActiveLow=0 Port1-Pin17-NoiseFilterValue=0.00 Port2-Pin1-ActiveLow=0 Port2-Pin1-NoiseFilterValue=0.00 Port2-Pin2-ActiveLow=0 Port2-Pin2-NoiseFilterValue=0.00 Port2-Pin3-ActiveLow=0 Port2-Pin3-NoiseFilterValue=0.00 Port2-Pin4-ActiveLow=0 Port2-Pin4-NoiseFilterValue=0.00 Port2-Pin5-ActiveLow=0 Port2-Pin5-NoiseFilterValue=0.00 Port2-Pin6-ActiveLow=0 Port2-Pin6-NoiseFilterValue=0.00 Port2-Pin7-ActiveLow=0 Port2-Pin7-NoiseFilterValue=0.00 Port2-Pin8-ActiveLow=0 Port2-Pin8-NoiseFilterValue=0.00 Port2-Pin9-ActiveLow=0 Port2-Pin9-NoiseFilterValue=0.00 Port2-Pin10-Alias=X Home Port2-Pin10-ActiveLow=1 Port2-Pin10-NoiseFilterValue=0.00 Port2-Pin11-ActiveLow=0 Port2-Pin11-NoiseFilterValue=0.00 Port2-Pin12-Alias=Z-Plate Port2-Pin12-ActiveLow=1 Port2-Pin12-NoiseFilterValue=0.00 Port2-Pin13-ActiveLow=0 Port2-Pin13-NoiseFilterValue=0.00 Port2-Pin14-ActiveLow=0 Port2-Pin14-NoiseFilterValue=0.00 Port2-Pin15-ActiveLow=0 Port2-Pin15-NoiseFilterValue=0.00 Port2-Pin16-Alias=Dust Collector Port2-Pin16-ActiveLow=0 Port2-Pin16-NoiseFilterValue=0.00 Port2-Pin17-Alias=laser On off Port2-Pin17-ActiveLow=0 Port2-Pin17-NoiseFilterValue=0.00 Port3-Pin1-ActiveLow=0 Port3-Pin1-NoiseFilterValue=0.00 Port3-Pin2-ActiveLow=0 Port3-Pin2-NoiseFilterValue=0.00 Port3-Pin3-ActiveLow=0 Port3-Pin3-NoiseFilterValue=0.00 Port3-Pin4-ActiveLow=0 Port3-Pin4-NoiseFilterValue=0.00 Port3-Pin5-ActiveLow=0 Port3-Pin5-NoiseFilterValue=0.00 Port3-Pin6-ActiveLow=0 Port3-Pin6-NoiseFilterValue=0.00 Port3-Pin7-ActiveLow=0 Port3-Pin7-NoiseFilterValue=0.00 Port3-Pin8-ActiveLow=0 Port3-Pin8-NoiseFilterValue=0.00 Port3-Pin9-ActiveLow=0 Port3-Pin9-NoiseFilterValue=0.00 Port3-Pin10-ActiveLow=0 Port3-Pin10-NoiseFilterValue=0.00 Port3-Pin11-ActiveLow=0 Port3-Pin11-NoiseFilterValue=0.00 Port3-Pin12-ActiveLow=0 Port3-Pin12-NoiseFilterValue=0.00 Port3-Pin13-ActiveLow=0 Port3-Pin13-NoiseFilterValue=0.00 Port3-Pin14-ActiveLow=0 Port3-Pin14-NoiseFilterValue=0.00 Port3-Pin15-ActiveLow=0 Port3-Pin15-NoiseFilterValue=0.00 Port3-Pin16-ActiveLow=0 Port3-Pin16-NoiseFilterValue=0.00 Port3-Pin17-ActiveLow=0 Port3-Pin17-NoiseFilterValue=0.00 ISigMap-EStop-Enable=1 ISigMap-EStop=estop ISigMap-MotionInhibit-Enable=0 ISigMap-LimitOverride-Enable=0 ISigMap-Motor0-PosLimit-Enable=0 ISigMap-Motor1-PosLimit-Enable=0 ISigMap-Motor2-PosLimit-Enable=0 ISigMap-Motor3-PosLimit-Enable=0 ISigMap-Motor4-PosLimit-Enable=0 ISigMap-Motor5-PosLimit-Enable=0 ISigMap-Motor0-NegLimit-Enable=0 ISigMap-Motor1-NegLimit-Enable=0 ISigMap-Motor2-NegLimit-Enable=0 ISigMap-Motor3-NegLimit-Enable=0 ISigMap-Motor4-NegLimit-Enable=0 ISigMap-Motor5-NegLimit-Enable=0 ISigMap-Motor0-Home-Enable=1 ISigMap-Motor0-Home=X Home ISigMap-Motor1-Home-Enable=1 ISigMap-Motor1-Home=Y Home ISigMap-Motor2-Home-Enable=1 ISigMap-Motor2-Home=Z Home ISigMap-Motor3-Home-Enable=1 ISigMap-Motor3-Home=A home ISigMap-Motor4-Home-Enable=0 ISigMap-Motor5-Home-Enable=0 ISigMap-Motor0-Index-Enable=0 ISigMap-Motor1-Index-Enable=0 ISigMap-Motor2-Index-Enable=0 ISigMap-Motor3-Index-Enable=0 ISigMap-Motor4-Index-Enable=0 ISigMap-Motor5-Index-Enable=0 ISigMap-Index-Enable=0 ISigMap-Encoder0-PhaseA-Enable=0 ISigMap-Encoder0-PhaseB-Enable=0 ISigMap-Encoder1-PhaseA-Enable=0 ISigMap-Encoder1-PhaseB-Enable=0 ISigMap-Encoder2-PhaseA-Enable=0 ISigMap-Encoder2-PhaseB-Enable=0 ISigMap-Encoder3-PhaseA-Enable=0 ISigMap-Encoder3-PhaseB-Enable=0 ISigMap-Encoder4-PhaseA-Enable=0 ISigMap-Encoder4-PhaseB-Enable=0 ISigMap-Encoder5-PhaseA-Enable=0 ISigMap-Encoder5-PhaseB-Enable=0 ISigMap-SpindleEncoder-PhaseA-Enable=0 ISigMap-SpindleEncoder-PhaseB-Enable=0 ISigMap-AuxEncoder0-PhaseA-Enable=0 ISigMap-AuxEncoder0-PhaseB-Enable=0 ISigMap-AuxEncoder1-PhaseA-Enable=0 ISigMap-AuxEncoder1-PhaseB-Enable=0 ISigMap-AuxEncoder2-PhaseA-Enable=0 ISigMap-AuxEncoder2-PhaseB-Enable=0 ISigMap-Probe-Enable=1 ISigMap-Probe=Z-Plate ISigMap-Probe1-Enable=0 ISigMap-Probe2-Enable=0 ISigMap-Probe3-Enable=0 ISigMap-THCOn-Enable=0 ISigMap-THCUp-Enable=0 ISigMap-THCDown-Enable=0 ISigMap-JogX-Pos-Enable=0 ISigMap-JogX-Neg-Enable=0 ISigMap-JogY-Pos-Enable=0 ISigMap-JogY-Neg-Enable=0 ISigMap-JogZ-Pos-Enable=0 ISigMap-JogZ-Neg-Enable=0 ISigMap-JogA-Pos-Enable=0 ISigMap-JogA-Neg-Enable=0 ISigMap-JogB-Pos-Enable=0 ISigMap-JogB-Neg-Enable=0 ISigMap-JogC-Pos-Enable=0 ISigMap-JogC-Neg-Enable=0 ISigMap-SpindleAtSpeed-Enable=0 ISigMap-SpindleAtZero-Enable=0 ISigMap-Input0-Enable=0 ISigMap-Input1-Enable=0 ISigMap-Input2-Enable=0 ISigMap-Input3-Enable=0 ISigMap-Input4-Enable=0 ISigMap-Input5-Enable=0 ISigMap-Input6-Enable=0 ISigMap-Input7-Enable=0 ISigMap-Input8-Enable=0 ISigMap-Input9-Enable=0 ISigMap-Input10-Enable=0 ISigMap-Input11-Enable=0 ISigMap-Input12-Enable=0 ISigMap-Input13-Enable=0 ISigMap-Input14-Enable=0 ISigMap-Input15-Enable=0 ISigMap-Input16-Enable=0 ISigMap-Input17-Enable=0 ISigMap-Input18-Enable=0 ISigMap-Input19-Enable=0 ISigMap-Input20-Enable=0 ISigMap-Input21-Enable=0 ISigMap-Input22-Enable=0 ISigMap-Input23-Enable=0 ISigMap-Input24-Enable=0 ISigMap-Input25-Enable=0 ISigMap-Input26-Enable=0 ISigMap-Input27-Enable=0 ISigMap-Input28-Enable=0 ISigMap-Input29-Enable=0 ISigMap-Input30-Enable=0 ISigMap-Input31-Enable=0 ISigMap-Input32-Enable=0 ISigMap-Input33-Enable=0 ISigMap-Input34-Enable=0 ISigMap-Input35-Enable=0 ISigMap-Input36-Enable=0 ISigMap-Input37-Enable=0 ISigMap-Input38-Enable=0 ISigMap-Input39-Enable=0 ISigMap-Input40-Enable=0 ISigMap-Input41-Enable=0 ISigMap-Input42-Enable=0 ISigMap-Input43-Enable=0 ISigMap-Input44-Enable=0 ISigMap-Input45-Enable=0 ISigMap-Input46-Enable=0 ISigMap-Input47-Enable=0 ISigMap-Input48-Enable=0 ISigMap-Input49-Enable=0 ISigMap-Input50-Enable=0 ISigMap-Input51-Enable=0 ISigMap-Input52-Enable=0 ISigMap-Input53-Enable=0 ISigMap-Input54-Enable=0 ISigMap-Input55-Enable=0 ISigMap-Input56-Enable=0 ISigMap-Input57-Enable=0 ISigMap-Input58-Enable=0 ISigMap-Input59-Enable=0 ISigMap-Input60-Enable=0 ISigMap-Input61-Enable=0 ISigMap-Input62-Enable=0 ISigMap-Input63-Enable=0 OSigMap-Motor0-Step-MappedPin0=Motor X Step OSigMap-Motor0-Step-Enable=1 OSigMap-Motor0-Dir-MappedPin0=Motor X Dir OSigMap-Motor0-Dir-Enable=1 OSigMap-Motor1-Step-MappedPin0=Motor Y Step OSigMap-Motor1-Step-Enable=1 OSigMap-Motor1-Dir-MappedPin0=Motor Y Dir OSigMap-Motor1-Dir-Enable=1 OSigMap-Motor2-Step-MappedPin0=Motor Z Step OSigMap-Motor2-Step-Enable=1 OSigMap-Motor2-Dir-MappedPin0=Motor Z Dir OSigMap-Motor2-Dir-Enable=1 OSigMap-Motor3-Step-MappedPin0=Motor A Step OSigMap-Motor3-Step-Enable=1 OSigMap-Motor3-Dir-MappedPin0=Motor A Dir OSigMap-Motor3-Dir-Enable=1 OSigMap-Motor4-Step-MappedPin0=Motor B Step OSigMap-Motor4-Step-Enable=0 OSigMap-Motor4-Dir-MappedPin0=Motor B Dir OSigMap-Motor4-Dir-Enable=0 OSigMap-Motor5-Step-Enable=0 OSigMap-Motor5-Dir-Enable=0 OSigMap-Enable0-Enable=0 OSigMap-Enable1-Enable=0 OSigMap-Enable2-Enable=0 OSigMap-Enable3-Enable=0 OSigMap-Enable4-Enable=0 OSigMap-Enable5-Enable=0 OSigMap-SpindleStepOrPWM-MappedPin0=Motor C Step OSigMap-SpindleStepOrPWM-Enable=1 OSigMap-SpindleDirection-Enable=0 OSigMap-SpindleOn-Enable=0 OSigMap-SpindleFwd-MappedPin0=Motor C Dir OSigMap-SpindleFwd-Enable=1 OSigMap-SpindleRev-Enable=0 OSigMap-IsMoving-Enable=0 OSigMap-XYFeedRatePWM-Enable=0 OSigMap-ChargePump-Enable=0 OSigMap-CoolantOn-Enable=0 OSigMap-MistOn-Enable=0 OSigMap-CurrentHi-Low-Enable=0 OSigMap-DigitizeTrigger-Enable=0 OSigMap-Alarm-Enable=0 OSigMap-LimitOverride-Enable=0 OSigMap-PartsFinished-Enable=0 OSigMap-GcodeRunning-Enable=0 OSigMap-FeedHold-Enable=0 OSigMap-BlockDelete-Enable=0 OSigMap-SingleBlock-Enable=0 OSigMap-ReverseRun-Enable=0 OSigMap-OptStop-Enable=0 OSigMap-MachineEnabled-Enable=0 OSigMap-ToolChange-Enable=0 OSigMap-DistToGo-Enable=0 OSigMap-MachineCoord-Enable=0 OSigMap-SoftlimitsOn-Enable=0 OSigMap-JogInc-Enable=0 OSigMap-JogCont-Enable=0 OSigMap-JogEnabled-Enable=0 OSigMap-JogMPG-Enable=0 OSigMap-XHomed-Enable=0 OSigMap-YHomed-Enable=0 OSigMap-ZHomed-Enable=0 OSigMap-AHomed-Enable=0 OSigMap-BHomed-Enable=0 OSigMap-CHomed-Enable=0 OSigMap-Dwell-Enable=0 OSigMap-ToolpathMouseDown-Enable=0 OSigMap-X-PosLimit-Enable=0 OSigMap-X-NegLimit-Enable=0 OSigMap-X-Home-Enable=0 OSigMap-Y-PosLimit-Enable=0 OSigMap-Y-NegLimit-Enable=0 OSigMap-Y-Home-Enable=0 OSigMap-Z-PosLimit-Enable=0 OSigMap-Z-NegLimit-Enable=0 OSigMap-Z-Home-Enable=0 OSigMap-A-PosLimit-Enable=0 OSigMap-A-NegLimit-Enable=0 OSigMap-A-Home-Enable=0 OSigMap-B-PosLimit-Enable=0 OSigMap-B-NegLimit-Enable=0 OSigMap-B-Home-Enable=0 OSigMap-C-PosLimit-Enable=0 OSigMap-C-NegLimit-Enable=0 OSigMap-C-Home-Enable=0 OSigMap-Output0-Enable=0 OSigMap-Output1-Enable=0 OSigMap-Output2-Enable=0 OSigMap-Output3-Enable=0 OSigMap-Output4-Enable=0 OSigMap-Output5-Enable=0 OSigMap-Output6-Enable=0 OSigMap-Output7-Enable=0 OSigMap-Output8-Enable=0 OSigMap-Output9-Enable=0 OSigMap-Output10-Enable=0 OSigMap-Output11-Enable=0 OSigMap-Output12-Enable=0 OSigMap-Output13-Enable=0 OSigMap-Output14-Enable=0 OSigMap-Output15-Enable=0 OSigMap-Output16-Enable=0 OSigMap-Output17-Enable=0 OSigMap-Output18-Enable=0 OSigMap-Output19-Enable=0 OSigMap-Output20-Enable=0 OSigMap-Output21-Enable=0 OSigMap-Output22-Enable=0 OSigMap-Output23-Enable=0 OSigMap-Output24-Enable=0 OSigMap-Output25-Enable=0 OSigMap-Output26-Enable=0 OSigMap-Output27-Enable=0 OSigMap-Output28-Enable=0 OSigMap-Output29-Enable=0 OSigMap-Output30-Enable=0 OSigMap-Output31-Enable=0 OSigMap-Output32-Enable=0 OSigMap-Output33-Enable=0 OSigMap-Output34-Enable=0 OSigMap-Output35-Enable=0 OSigMap-Output36-Enable=0 OSigMap-Output37-Enable=0 OSigMap-Output38-Enable=0 OSigMap-Output39-Enable=0 OSigMap-Output40-Enable=0 OSigMap-Output41-Enable=0 OSigMap-Output42-Enable=0 OSigMap-Output43-Enable=0 OSigMap-Output44-Enable=0 OSigMap-Output45-Enable=0 OSigMap-Output46-Enable=0 OSigMap-Output47-Enable=0 OSigMap-Output48-Enable=0 OSigMap-Output49-Enable=0 OSigMap-Output50-Enable=0 OSigMap-Output51-MappedPin0=laser On off OSigMap-Output51-Enable=1 OSigMap-Output52-MappedPin0=Dust Collector OSigMap-Output52-Enable=1 OSigMap-Output53-Enable=0 OSigMap-Output54-Enable=0 OSigMap-Output55-Enable=0 OSigMap-Output56-Enable=0 OSigMap-Output57-Enable=0 OSigMap-Output58-Enable=0 OSigMap-Output59-Enable=0 OSigMap-Output60-Enable=0 OSigMap-Output61-Enable=0 OSigMap-Output62-Enable=0 OSigMap-Output63-Enable=0 Homing-Motor-0-IndexHomingEnable=0 Homing-Motor-0-ApproachVelocity=100.0 Homing-Motor-0-BackoffVelocity=10.0 Homing-Motor-0-SlaveMisalignment=0.000000 Homing-Motor-0-MaxMasterSlaveDelta=0.000000 Homing-Motor-1-IndexHomingEnable=0 Homing-Motor-1-ApproachVelocity=100.0 Homing-Motor-1-BackoffVelocity=10.0 Homing-Motor-1-SlaveMisalignment=0.000000 Homing-Motor-1-MaxMasterSlaveDelta=0.000000 Homing-Motor-2-IndexHomingEnable=0 Homing-Motor-2-ApproachVelocity=75.0 Homing-Motor-2-BackoffVelocity=5.0 Homing-Motor-2-SlaveMisalignment=0.000000 Homing-Motor-2-MaxMasterSlaveDelta=0.000000 Homing-Motor-3-IndexHomingEnable=0 Homing-Motor-3-ApproachVelocity=100.0 Homing-Motor-3-BackoffVelocity=10.0 Homing-Motor-3-SlaveMisalignment=0.000000 Homing-Motor-3-MaxMasterSlaveDelta=0.000000 Homing-Motor-4-IndexHomingEnable=0 Homing-Motor-4-ApproachVelocity=1.0 Homing-Motor-4-BackoffVelocity=1.0 Homing-Motor-4-SlaveMisalignment=0.000000 Homing-Motor-4-MaxMasterSlaveDelta=0.000000 Homing-Motor-5-IndexHomingEnable=0 Homing-Motor-5-ApproachVelocity=1.0 Homing-Motor-5-BackoffVelocity=1.0 Homing-Motor-5-SlaveMisalignment=0.000000 Homing-Motor-5-MaxMasterSlaveDelta=0.000000
