Diam = Param1() * 3.14159265358'Position ' Heigth ' W ' H Begin Dialog Dialog1 120,120,"Set Part Diameter"	OKButton 15,105,40,14	CancelButton 65,105,40,14	GroupBox 12,8,100,90,"Change Part Diameter",.GroupBox1	Text 20,25,90,12,"Current Part Diameter:"	Text 28,75,80,12,"Press OK to continue."	TextBox 30,45,60,12,.WidthEnd Dialog StepsPerAxisY = 1960000 'Steps per rotary turnKernalSpeed = 400000 'Mach3 Kernal Speed in ports and pinsCurStepsPer = GetParam("StepsPerAxisY")If Diam < 0 Then   Dim Dlg1 As Dialog1   Dlg1.Width = Round(StepsPerAxisY / CurStepsPer/3.14159265358,8)   Button = Dialog (Dlg1)   Diam = Dlg1.Width*3.14159265358End If'If Button = 0 Then'   DoOEMButton(1003)'   Exit Sub'Else   NewPPR = StepsPerAxisY / Diam ' New Steps per for motor tuning   NewVel = (KernalSpeed / NewPPR) * 60   Call SetParam("VelocitiesY", (NewVel / 60))   Call SetParam("StepsPerAxisY", NewPPR)   'Message("Part width set... Scaling set to: " & Round(StepsPerAxisX / CurStepsPer,4))'End If	'Must Reset To Update Mach SettingsIf Not GetOEMLED(800) Then   DoButton(21)   Sleep(250)End IfIf GetOEMLED(800) Then   DoButton(21)End If                  
