'------------------------------------------------------------------------------' Updated: 29Apr16 - 08:26'' CS-Lab s.c.' Toolchanger VB macro (MILL - Flat ATC with toolholders on the work table)' v1.3' '------------------------------------------------------------------------------' Gcodes, LEDs, Buttons'------------------------------------------------------------------------------' Gcode		G43=		G53=' LED 		11=Spindle	23=SoftLimits	806=Tool Change	807=X-Ref	808=Y-Ref	809=Z-Ref' Button	1002=Rewind	1003=Stop	1021=Reset	1029=SoftLimitToggle'------------------------------------------------------------------------------' Digital outputs CONFIG'------------------------------------------------------------------------------Const OUT_OPENCOLLET	=	10	' open collet CSMIO output'------------------------------------------------------------------------------' Digital inputs CONFIG'------------------------------------------------------------------------------Const IN_COLLETOPENED	=	21		' collet open sensor CSMIO input'------------------------------------------------------------------------------' variables declaration - don't modify'------------------------------------------------------------------------------Dim Z_TOOLGET, Z_SAFE, Y_BASE, Y_TOOLOFFSET, TOOLCOUNTDim ToolNew, ToolOldDim SoftLimitsState As Boolean'------------------------------------------------------------------------------' CONFIG data'------------------------------------------------------------------------------	X_BASE = 258.668		' X position of first tool	Y_BASE = 22.75			' Y position of first tool	Z_SAFE = -5				' Safe Z for safe moving above tool holders		Y_TOOLOFFSET = 24.800	' Distance between tools	Z_TOOLGET = -71.500		' Z position (abs) of tool get/release. Final Z_TOOLGET=59	TOOLCOUNT = 5			' Max. tool number			SENS_X = 260			' Tool length sensor X	SENS_Y = 147			' Tool length sensor Y'------------------------------------------------------------------------------'--------------------------- MACRO START --------------------------------------      ' Slow down spindle and stop before getting to tool holder	Message( "Stopping spindle ..." )	Code("G0G53 Z" & Z_SAFE)	WaitForMove	    Code("S500")	Sleep (2000)	Code("M05")	Sleep(3000)		' Get the current tool # and new tool #	ToolOld = GetCurrentTool()	ToolNew = GetSelectedTool()		' save softlimits state	If(GetOEMLED(23)) Then		SoftLimitsState = true	Else		SoftLimitsState = false	End If		' turn off softlimits - toolholders can be outside normal work area	SoftLimitsOff		' check XYZ are the axes referenced	If GetOEMLed(807) Then		SetCurrentTool( ToolOld )		DoOEMButton(1003)		DoOEMButton(1002)		Sleep(150)		Message( "Machine X is not referenced" )		Sleep(150)		' restore softlimit		SetSoftLimits(SoftLimitsState)		End	End If	If GetOEMLed(808) Then		SetCurrentTool( ToolOld )		DoOEMButton(1003)		DoOEMButton(1002)		Sleep(150)		Message( "Machine Y is not referenced" )		Sleep(150)		' restore softlimit		SetSoftLimits(SoftLimitsState)		End	End If	If GetOEMLed(809) Then		SetCurrentTool( ToolOld )		DoOEMButton(1003)		DoOEMButton(1002)		Sleep(150)		Message( "Machine Z is not referenced" )		Sleep(150)		' restore softlimit		SetSoftLimits(SoftLimitsState)		End	End If	If GetOEMLed(11) Then		SetCurrentTool( ToolOld )		DoOEMButton(1003)		DoOEMButton(1002)		Sleep(150)		Message( "Spindle is still running. Toolchange failed." )		Sleep(150)		' restore softlimit		SetSoftLimits(SoftLimitsState)		End	End If 		' tool requested already in spindle	If (ToolNew = ToolOld) Then		SetCurrentTool( ToolOld )		Sleep(150)		Message("Tool is already in spindle.")		Sleep(150)		' restore softlimit		SetSoftLimits(SoftLimitsState)		End	End If		' New tool # must be <= TOOLCOUNT	If (ToolNew > TOOLCOUNT) Then		SetCurrentTool( ToolOld )		DoOEMButton(1003)		DoOEMButton(1002)		Sleep(150)		Message("There is no such a tool.")		Sleep(150)		' restore softlimit		SetSoftLimits(SoftLimitsState)		End	End If		' New tool pickup ok - continue	Code("G0G53 Z" & Z_SAFE)	' Z up to safe	WaitForMove			' if current tool > 0 put it first into the holder	' Tool already in holder so unload	If (ToolOld > 0) Then		' move to the toolholder		Code("G0G53 X"& X_BASE &" Y" & (Y_BASE + (Y_TOOLOFFSET * (ToolOld-1))))		WaitForMove						Code("G0G53 Z" & Z_TOOLGET)		WaitForMove				ColletOpen		Sleep(1000)		' move down and pickup tool		Code("G0G53 Z" & Z_SAFE)		WaitForMove				ColletClose	End If	' If newtool = 0, there is no need to get new tool	If (ToolNew = 0) Then		Code("G0G53 Z" & Z_SAFE)		WaitForMove		SetCurrentTool( ToolNew )		Message("Tool loaded : " & ToolNew)		Code("G43T" & ToolNew)	' G43 to sync tool length in system		Code("G43H" & ToolNew)	' G43 to sync tool length in system		WaitForMove		' restore softlimits		SetSoftLimits(SoftLimitsState)				Code("G0G53 X" & SENS_X &" Y" & SENS_Y)	  End	End If	' move to the new tool position	Code("G0G53 X" & X_BASE &" Y" & (Y_BASE + (Y_TOOLOFFSET * (ToolNew-1))))	WaitForMove		ColletOpen	Sleep(1000)    ' put tool in collect		Code("G0G53 Z" & (Z_TOOLGET))	WaitForMove		' collet close	ColletClose	Sleep(1000)			' lift from toolholder position	Code("G0G53 Z" & Z_SAFE)	WaitForMove	Sleep(1000)		SetCurrentTool( ToolNew )	Message("Tool Loaded: " & ToolNew)	Code("G43T" & ToolNew)	' G43 to sync tool length in system	Code("G43H" & ToolNew)	' G43 to sync tool length in system	WaitForMove		' restore softlimit	SetSoftLimits(SoftLimitsState)		' Does this fix Z moving randomly?	Code("G0G53 X" & SENS_X &" Y" & SENS_Y)	End 	' -----------------------------------------------------------------------------' Procedures & Functions' -----------------------------------------------------------------------------Sub ColletClose ()	Call SetCsmioOut(OUT_OPENCOLLET, false)End Sub' -----------------------------------------------------------------------------Sub ColletOpen ()	Call SetCsmioOut(OUT_OPENCOLLET, true)End Sub' -----------------------------------------------------------------------------Sub SoftLimitsOff ()	If(GetOEMLED(23)) Then		DoOEMButton(1029)	End IfEnd Sub' -----------------------------------------------------------------------------Sub SetSoftLimits (state As Boolean)	If(state) Then		If(GetOEMLED(23) = 0) Then			DoOEMButton(1029)		End If	Else		If(GetOEMLED(23)) Then			DoOEMButton(1029)		End If	End IfEnd Sub' -----------------------------------------------------------------------------Sub WaitForMove ()	While IsMoving() 		Sleep(15) 	WendEnd Sub' -----------------------------------------------------------------------------Public Function GetCsmioIn (n As Integer) As Boolean	Dim reg As Integer		If(n < 16) Then		reg = 90	Else		reg = 91		n = n - 16	End If		If(GetInBit(reg, n)) Then		GetCsmioIn = true	Else		GetCsmioIn = false	End If	Exit FunctionEnd Function ' -----------------------------------------------------------------------------Public Sub SetCsmioOut (ByVal n As Integer, ByVal state As Boolean)	If(state) Then		SetOutBit(90, n)	Else		ResetOutBit(90, n)	End IfEnd Sub' -----------------------------------------------------------------------------                                              
