Startup of Menu handler Menu at MenuItem: : 6000 Ex Time set to : : 0.0010 Sending Cfg. Done... Axis X, Dir: : Port: 1, Pin: 17, Value: 2, Negated: 1 Axis Z, Dir: : Port: 1, Pin: 16, Value: 6, Negated: 1 Unused: : Port: 1, Pin: 14, Value: 0, Negated: 0 Charge Pump: : Port: 1, Pin: 9, Value: 0, Negated: 1 Axis Y, Dir: : Port: 1, Pin: 8, Value: 4, Negated: 1 Axis X, Step: : Port: 1, Pin: 7, Value: 3, Negated: 1 Axis Y, Step: : Port: 1, Pin: 6, Value: 5, Negated: 1 Axis Z, Step: : Port: 1, Pin: 5, Value: 7, Negated: 1 Unused: : Port: 1, Pin: 4, Value: 0, Negated: 0 GPIO: : Port: 1, Pin: 3, Value: 0, Negated: 1 Axis S, Step: : Port: 1, Pin: 2, Value: 15, Negated: 1 Axis S, Dir: : Port: 1, Pin: 1, Value: 14, Negated: 1 Unused: : Port: 2, Pin: 17, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 16, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 14, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 9, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 8, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 7, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 6, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 5, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 4, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 3, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 2, Value: 0, Negated: 0 Unused: : Port: 2, Pin: 1, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 17, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 16, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 14, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 9, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 8, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 7, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 6, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 5, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 4, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 3, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 2, Value: 0, Negated: 0 Unused: : Port: 3, Pin: 1, Value: 0, Negated: 0 Debounce Enable command : 0 EStop Enable command : 2 Append_SpindleIndexPrescaleValue command : 0 Append_ControlBits_Cmd command : 130 Jog Acc set in init: : 1530857 Jog Acc set in init: : 1530857 Jog Acc set in init: : 1065040 Jog Acc set in init: : 32750 Jog Acc set in init: : 32750 Jog Acc set in init: : 32750 Append_ControlBits_Cmd command : 128 Ethernet SmoothStepper board fully initialised. Run of device begins.
