Copy all the files here into the plugins folder, including the GSimSupport folder as a folder.
Tooltables will be stored int eh GSimSupport folder. These tools may be exported to Gearotic, or
Gearotics tools may be imported to Mach4 by the Toolbox command in the plugin.
  Once installed, just turn on the plugin in the Plugin Config in Mach4, then restart. To
Simulate a job, simply load it into Mach4, and then select "Diagnostics/GSim Job Simulator".
IMPORTANT:
Note:
 1)     Tooltables GCode number entries must be proper, and no two tools should share a Gcode number.
 2)     If you use Metric, you should have G21 in your init string in Mach3, if inch, you should have G20
        in that init string.
    You may watch the video on youtube for tooltable use, its the same tooltable used by Gearotics
Workbench CNC module.
