 ///////////////Configuration Check Facility///////////////////////
 Any obvious errors are checked by this facility, passing does not mean
 you have no errors, but as more error possibilities are found,
 more checks will be added to this facility.
 Currently, the most frequenct tech-support errors are checked for.
 ///////////////LIMIT & HOMING CHECK///////////////////////
Input Pin not 10-13 or 15..
 No Errors Found!
 ////////////////////// End of Homing and Limits Check ///////////////////////////////////
 ///////////////OUTPUT Signals Check///////////////////////
Pin for an Output found as not pins 1 - 9, 14, 16, or 17. Unless using ModBus, this is wrong.
  ///////////////End of OUTPUT Signals Check///////////////////////
 //////////////// Digitising Probe /////////////////////////
 /////////End of Probe Check /////////////////////!.
 /////////Motor Settings - Enabled Motors only are Checked/////////////////////!.
 /////////Motor Settings - End of Motor Checks/////////////////////!.
 Checkup complete , please check any errors listed.
 Thank you for checking your Settings.....
