----------------------------------------------------------------------------- -- Name: MouseWheel -- Author: B Barker -- Modified by: Ya-Nvr-No 8/28/2014 -- Created: 08/03/2013 -- Copyright: (c) 2013 Newfangled Solutions. All rights reserved. -- Licence: BSD license - This header can not be removed ----------------------------------------------------------------------------- function GetNextID() m_id = m_id+1 return m_id end --global var to hold the frame mainframe = nil panel = nil m_id = 0 m_iniName = "MouseWheelMPG" m_position = 0; m_axis = 0; ID_MPG_X_BUT = GetNextID() ID_MPG_Y_BUT = GetNextID() ID_MPG_Z_BUT = GetNextID() ID_MPG_A_BUT = GetNextID() ID_MPG_B_BUT = GetNextID() ID_MPG_C_BUT = GetNextID() ID_MPG_INC = GetNextID() ID_CLOSE_BUTTON = GetNextID() ID_PANNEL = GetNextID() --m_image = wx.wxGetCwd() .. "\\Wizards\\HolesNew.png" function SelectAxis(axis) if(axis == 'x') then mpgX:SetBackgroundColour(wx.wxColour(0,255, 128)); mc.mcMpgSetAxis(0, 0, 0); m_axis = 0; else mpgX:SetBackgroundColour(wx.wxNullColour) end if(axis == 'y') then mpgY:SetBackgroundColour(wx.wxColour(0,255, 128)); mc.mcMpgSetAxis(0, 0, 1); m_axis = 1; else mpgY:SetBackgroundColour(wx.wxNullColour) end if(axis == 'z') then mpgZ:SetBackgroundColour(wx.wxColour(0,255, 128)); mc.mcMpgSetAxis(0, 0, 2); m_axis = 2; else mpgZ:SetBackgroundColour(wx.wxNullColour) end if(axis == 'a') then mpgA:SetBackgroundColour(wx.wxColour(0,255, 128)); mc.mcMpgSetAxis(0, 0, 3); m_axis = 3; else mpgA:SetBackgroundColour(wx.wxNullColour) end if(axis == 'b') then mpgB:SetBackgroundColour(wx.wxColour(0,255, 128)); mc.mcMpgSetAxis(0, 0, 4); m_axis = 4; else mpgB:SetBackgroundColour(wx.wxNullColour) end if(axis == 'c') then mpgC:SetBackgroundColour(wx.wxColour(0,255, 128)); mc.mcMpgSetAxis(0, 0, 5); m_axis = 5; else mpgC:SetBackgroundColour(wx.wxNullColour) end end function main() if(mcLuaPanelParent == nil)then -- create the wxFrame window mainframe = wx.wxFrame( wx.NULL, -- no parent wx.wxID_ANY, -- whatever for wxWindow ID "Mach4 Mouse Wheel MPG", -- frame caption wx.wxDefaultPosition, -- place the frame in default position wx.wxDefaultSize, -- default frame size wx.wxDEFAULT_FRAME_STYLE ) -- use default frame styles -- create a panel in the frame panel = wx.wxPanel(mainframe, ID_PANNEL) -- create a simple file menu with an exit local fileMenu = wx.wxMenu() fileMenu:Append(wx.wxID_EXIT, "E&xit", "Quit MouseMPG") -- create a simple help menu local helpMenu = wx.wxMenu() helpMenu:Append(wx.wxID_ABOUT, "&About", "About Mouse Wheel MPG") -- create a menu bar and append the file and help menus local menuBar = wx.wxMenuBar() menuBar:Append(helpMenu, "&Help") -- attach the menu bar into the frame mainframe:SetMenuBar(menuBar) -- create a simple status bar mainframe:CreateStatusBar(1) mainframe:SetStatusText("MPG Count: 0") -- connect the selection event of the exit menu item to an -- event handler that closes the window mainframe:Connect(wx.wxID_EXIT, wx.wxEVT_COMMAND_MENU_SELECTED, function (event) mainframe:Close(true) end ) -- connect the selection event of the about menu item mainframe:Connect(wx.wxID_ABOUT, wx.wxEVT_COMMAND_MENU_SELECTED, function (event) wx.wxMessageBox("Mouse Wheel MPG \n\nAuthor: Brian Barker\nDate: 8/3/13\nThis wizard is used to move the machine \nwith the mouse wheel working as an MPG", "About Mouse Wheel", wx.wxOK + wx.wxICON_INFORMATION, mainframe) end ) else panel = mcLuaPanelParent local window = panel:GetParent() local wsize = window:GetSize() panel:SetSize(wsize) end --Set up the main sizer so we can start adding controls local mainSizer = wx.wxBoxSizer(wx.wxVERTICAL) local InputsGridSizer = wx.wxFlexGridSizer( 2, 2, 0, 0 ) InputsGridSizer:AddGrowableCol(1, 0) -- make the buttons mpgX = wx.wxButton( panel, ID_MPG_X_BUT, "&X MPG") InputsGridSizer:Add( mpgX, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) mpgY = wx.wxButton( panel, ID_MPG_Y_BUT, "&Y MPG") InputsGridSizer:Add( mpgY, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) mpgZ = wx.wxButton( panel, ID_MPG_Z_BUT, "&Z MPG") InputsGridSizer:Add( mpgZ, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) mpgA = wx.wxButton( panel, ID_MPG_A_BUT, "&A MPG") InputsGridSizer:Add( mpgA, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) mpgB = wx.wxButton( panel, ID_MPG_B_BUT, "&B MPG") InputsGridSizer:Add( mpgB, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) mpgC = wx.wxButton( panel, ID_MPG_C_BUT, "&C MPG") InputsGridSizer:Add( mpgC, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) m_inc = wx.wxTextCtrl( panel, wx.wxID_ANY, "0.01", wx.wxDefaultPosition, wx.wxSize(50, -1), wx.wxTE_PROCESS_ENTER ,wx.wxTextValidator(wx.wxFILTER_NUMERIC)) InputsGridSizer:Add( m_inc, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) local buttonSizer = wx.wxBoxSizer( wx.wxHORIZONTAL ) if(mcLuaPanelParent == nil)then local closeButton = wx.wxButton( panel, ID_CLOSE_BUTTON, "E&xit") buttonSizer:Add( closeButton, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) end --Set up the sizers mainSizer:Add( InputsGridSizer, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) mainSizer:Add( buttonSizer, 0, wx.wxALIGN_CENTER+wx.wxALL, 2 ) panel:SetSizer( mainSizer ) mc.mcMpgSetAccel(0, 0, 25); mc.mcMpgSetRate(0, 0, 100); mc.mcMpgSetCountsPerDetent(0, 0, 1); SelectAxis('x') panel:Connect(ID_MPG_X_BUT, wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) SelectAxis('x') end) panel:Connect(ID_MPG_Y_BUT, wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) SelectAxis('y') end) panel:Connect(ID_MPG_Z_BUT, wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) SelectAxis('z') end) panel:Connect(ID_MPG_A_BUT, wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) SelectAxis('a') end) panel:Connect(ID_MPG_B_BUT, wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) SelectAxis('b') end) panel:Connect(ID_MPG_C_BUT, wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) SelectAxis('c') end) panel:Connect(wx.wxID_ANY, wx.wxEVT_MOUSEWHEEL, function (event) local inc = m_inc:GetValue() mc.mcMpgSetInc(0, 0, tonumber(inc)); local v = event:GetWheelRotation() m_position = m_position + v/120 if(mcLuaPanelParent == nil)then mainframe:SetStatusText("MPG Count: " .. tostring(m_position) .. " Inc: " .. tostring(inc)) end mc.mcMpgMoveCounts(0, 0, v/120); end ) panel:Fit() panel:SetBackgroundColour(wx.wxColour(232,232,232)) if(mcLuaPanelParent == nil)then panel:Connect(ID_CLOSE_BUTTON, wx.wxEVT_COMMAND_BUTTON_CLICKED, function(event) mainframe:Destroy() end) panel:Fit() mainframe:Fit() mainframe:Show(true) else local window = panel:GetParent() window:Connect(wx.wxID_ANY, wx.wxEVT_SIZE, function(event) local wsize = event:GetSize() panel:SetSize(wsize) panel:FitInside() end) end end main() wx.wxGetApp():MainLoop()
