textFilePath = "C:\mach3\LATHE TOOL TABLE\ToolInfo_LATHE.txt"Set objFSO = CreateObject("Scripting.FileSystemObject")Set objTextFile = objFSO.CreateTextFile(textFilePath)Do Until num=225num=num+1N = GetToolDesc(num)D = GetToolParam(num,1)L = GetToolParam(num,2)WD= Gettoolparam(num,3)WL= Gettoolparam(num,4)WX= Gettoolparam(num,5)WZ= Gettoolparam(num,6)Dt= Date()Tm= Time()If N <>"Empty" ThenobjTextFile.WriteLine("*Tool"& num &" * "& N &"*TIP RAD "& L &" *X OFFSET "&WD &" *Z OFFSET "&WL &"*XWEAR "& WX &" *ZWEAR "& WZ & Chr(13) & Chr(10))ElseEnd IfLoopobjTextFile.WriteLine("**")objTextFile.WriteLine(" Date: " &Dt &" Time: " &Tm)objTextFile.CloseDim sCOMMAND As StringsCOMMAND="print c:\mach3\LATHE TOOL TABLE\ToolInfo_LATHE.txt"Shell("c:\WINDOWS\system32\cmd.exe /c" & sCOMMAND)End  
