'Tool Height Setting Macro - JLH v1.0 - 2 March 2012'This version has a 2-phase approach, fast for speed & slow for precision.CurrentAbsInc = GetOemLED (48) 'Copy current G90/G91 stateCurrentGMode = GetOemDRO (819) 'Copy current G0/G1 stateCurrentFeed = GetOemDRO (818) 'Copy current feedrateContact = 0 'Clear the contact flagPlateThickness =38.84 'Touch Plate thickness is set hereProbeFeed1 = 100 'Fast probing feedrate is set hereProbeFeed2 = 10 'Slow probing feedrate is set hereSetVar (1, -15) 'Maximum probing distance is set hereSetVar (2, 50) 'Retract height is set hereCode "M5" 'Ensures spindle is not runningCode "G21" 'Ensure metric units are usedZs = GetOemDRO (61) 'Copy current Z-Scale DROCall SetOemDRO (61,1) 'Set Z-Scale DRO to 1Label1: 'Entry point for RetryDoOemButton (1010) 'Zero Z-Axis DROCode "(Setting Tool Zero)" 'Message for status barWhile IsMoving () 'Wait until task has been completedWendIf GetOemLED (825) = 0 Then 'Check to see if touch plate is not already groundedCode "G90 G31 Z #1 F" & ProbeFeed1 'Fast probing moveWhile IsMoving () 'Wait until task has been completedWendIf GetOemLED (825) = True Then 'Check to see if probe has touched plateContact = 1 'Set the contact flagEnd IfDoOemButton (1003) 'Clear a possible feed-hold conditionProbePos = GetVar (2002) 'Exact point probe touchedProbePos = ProbePos + 0.25 'Displace probe position upwards by .25mmCode "G0 Z" & ProbePos 'Lifts probe .25mm above fast feed endpointWhile IsMoving () 'Wait until task has been completedWendCode "G90 G31 Z #1 F" & ProbeFeed2 'Slow probing moveWhile IsMoving () 'Wait until task has been completedWendProbePos = GetVar (2002) 'Exact point probe touchedCode "G0 Z" & ProbePos 'Lifts probe to exact touch positionWhile IsMoving () 'Wait until task has been completedWendIf GetOemLED (825) = True Then 'Check to see if probe has touched plateContact = 1 'Set the contact flagEnd IfCall SetDRO (2,PlateThickness) 'Set Z-Axis DRO to Touch Plate thicknessCode "G0 Z #2" 'Retract off Touch Plate to the set heightWhile IsMoving () 'Wait until task has been completedWendCode "(Z-Axis is now Zeroed.)" 'Message for status barCode "F" & CurrentFeed 'Restore feedrate to original settingIf Contact = 0 Then 'Probe reached max travel without touchingCode "(ERROR - Probe did not touch.)" 'Message for status barResponse = MsgBox ("ERROR - Probe did not touch.",37,"Auto Tool Zero")If (Response = 4) Then 'User chose RetryGoTo Label1 'Retry Probing routineEnd IfEnd IfElseCode "(ERROR - Touch Plate is grounded.)" 'Message for status barResponse = MsgBox ("ERROR - Touch Plate is grounded - Check connection.",16,"Auto Tool Zero")End IfCall SetOemDRO (61,Zs) 'Restore Z-Scale DRO to original settingIf CurrentAbsInc = 0 Then 'If G91 was in effect before then return to itCode "G91"End IfIf CurrentGMode = 0 Then 'If G0 was in effect before then return to itCode "G0"End If   
