' Macro for consecutive S/N engraving from MACH
Main
End
Sub main
Dim A As String
Dim Ch As String
Dim Cnt As Integer
Dim Value As String
SetVar(1303 , .250)  'LetterSpacing
Setvar(1300 , -0.005) ' Z Depth cutting
Setvar(1200 , 0.050) ' Safe Z 
'CPx= Getoemdro(0)
'CPy= Getoemdro(1)
SETIJMODE(1)
Setvar(1301, getdro(0))
Setvar(1302, getdro(1))
Value = Question( "What is the value ??" )   
Message(Value) 
A = Value
For Cnt=1 To Len(A)
  Ch=Mid(A,Cnt,1)
  Select Case Ch
    Case "0" ZERO
    Case "1" ONE
    Case "2" TWO
    Case "3" THREE
    Case "4" FOUR
    Case "5" FIVE
    Case "6" SIX
    Case "7" SEVEN
    Case "8" EIGHT
    Case "9" NINE
  End Select
Next
SETIJMODE(1)
While IsMoving()
Wend   
End Sub
Sub ZERO 
message "Zero"
Code "G91X.025"
Code "G91X.0419 Y.013"
Code "Z-.2"
Code "G1 Z-.06 F10."
Code "G91G3 Y.0539 I-.0741 J.027"
Code "G91X-.0374 I-.0187 J-.0066"
Code "G91Y-.0539 I.0741 J-.0269"
Code "G91X.0374 I.0187 J.0067"
Code "G0 Z.26"
Code "G91X.0045 Y-.013"
While IsMoving()
Wend 
End Sub 
Sub ONE
message "One"
Code "G91X.025"
Code "G91Y.0685"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91X.0114 Y.0115"
Code "G91Y-.08"
Code "G0 Z.26"
Code "G91X-.0114"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91X.0229"
Code "G0 Z.26"
While IsMoving()
Wend 
End Sub
Sub TWO 
message "Two"
Code "G91X.025"
Code "G91X.0017 Y.0685"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G2 X.0444 Y-.0104 I.0205 J-.0123"
Code "G91X-.0059 Y-.0143 I-.0228 J.0011"
Code "G91X-.0206 Y-.0153 I-.1236 J.1441"
Code "G91G3 X-.0196 Y-.0285 I.0186 J-.0339"
Code "G91G1 X.0478"
Code "G0 Z.26"
While IsMoving()
Wend   
End Sub
Sub THREE
message "Three"
Code "G91X.025"
Code "G91X.0011 Y.0685"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G2 X.0395 Y.0052 I.0221 J-.0151"
Code "G91X-.0164 Y-.0337 I-.0135 J-.0142"
Code "G91G0 Z.26"
Code "G91X.0057"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G2 X.0119 Y-.0338 I-.0017 J-.0196"
Code "G91X-.0418 Y.0052 I-.0185 J.0222"
Code "G0 Z.26"
Code "G91X.048 Y-.0114"
While IsMoving()
Wend  
End Sub
Sub FOUR
message "Four"
Code "G91X.025"
Code "G91X.0414"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91Y.08"
Code "G91X-.0414 Y-.0612"
Code "G91X.0531"
Code "G0 Z.26"
Code "G91Y-.0188"
While IsMoving()
Wend   
End Sub
Sub FIVE
message "Five"
Code "G91X.025"
Code "G91X.0484 Y.0801"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91X-.0484"
Code "G91Y-.0355"
Code "G91G2 X.0458 Y-.0045 I.0205 J-.0268"
Code "G91X-.0245 Y-.0401 I-.0214 J-.0145"
Code "G91X-.0213 Y.0114 I0. J.0254"
Code "G0 Z.26"
Code "G91X.0501 Y-.0114"
While IsMoving()
Wend   
End Sub
Sub SIX 
message "Six"
Code "G91X.025"
Code "G91X.048 Y.068"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G3 X-.0434 Y-.0043 I-.0208 J-.0116"
Code "G91X-.0016 Y-.0457 I.0667 J-.0252"
Code "G91X.0457 Y-.0016 I.0231 J.0057"
Code "G91X-.0457 Y.0016 I-.0226 J.0073"
Code "G0 Z.26"
Code "G91X.0468 Y-.018"
While IsMoving()
Wend   
End Sub 
Sub SEVEN
message "Seven"
Code "G91X.025"
Code "G91Y.08"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91X.048"
Code "G91G3 X-.024 Y-.08 I.1214 J-.0801"
Code "G0 Z.26"
Code "G91X.024"
While IsMoving()
Wend   
End Sub
Sub EIGHT 
message "Eight"
Code "g90 G0  Z#1200 X[#1301 + .2250] Y#1302 "
Code "G91X.025"
Code "G91X.0214 Y.0428"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G2 Y.0372 I0. J.0186"
Code "G91X.0237 Y-.0186 I.004 J-.0193"
Code "G91X-.0237 Y-.0186 I-.0195 J.0005"
Code "G91G3 Y-.0428 I0. J-.0214"
Code "G91X.0266 Y.0214 I.0042 J.0219"
Code "G91X-.0214 Y.0214 I-.0214 J0."
Code "G0 Z.26"
Code "G91X.0214 Y-.0428"
While IsMoving()
Wend   
End Sub
Sub NINE 
message "Nine"
Code "G91X.025"
Code "G91X.0018 Y.0122"
Code "Z-.03"
Code "G1 Z-.23"
Code "G91G3 X.0434 Y.0043 I.0208 J.0116"
Code "G91X.0016 Y.0457 I-.0667 J.0252"
Code "G91X-.0457 Y.0016 I-.0231 J-.0057"
Code "G91X.0457 Y-.0016 I.0226 J-.0073"
Code "G0 Z.26"
Code "G91X.003 Y-.0622"
While IsMoving()
Wend 
End Sub 
SETIJMODE(0)
CODE"G90"
CODE"M30"                
