'M2.m1s rotation testDim spots As IntegerDim move As Integermove = 30Dim T As Integer 'New ToolDim ST As Integer 'Old ToolT = InputBox$("New Tool #","New Tool","")ST =  InputBox$("Old Tool #","Old Tool","")spots = T - ST 'New Tool - Old ToolIf spots > 0 And spots < 7 Then '1 to 6  Select Case spots  Case 1    spots = move  Case 2    spots = move * 2  Case 3    spots = move * 3  Case 4    spots = move * 4  Case 5    spots = move * 5  Case 6    spots = move * 6  End Select  End IfIf spots > 6 And spots < 11 Then '7 to 11  Select Case spots  Case 7    spots = move * -5  Case 8    spots = move * -4  Case 9    spots = move * -3  Case 10    spots = move * -2  Case 11    spots = move * -1  End Select  End IfIf spots > -7 And spots < 0 Then '-1 to -6  Select Case spots  Case -1    spots = move * -1  Case -2    spots = move * -2  Case -3    spots = move * -3  Case -4    spots = move * -4  Case -5    spots = move * -5  Case -6    spots = move * -6  End Select  End IfIf spots < -6 And spots > -12 Then '-7 to -11  Select Case spots  Case -7    spots = move * 5  Case -8    spots = move * 4  Case -9    spots = move * 3  Case -10    spots = move * 2  Case -11    spots = move * 1  End Select  End IfCode ("G91 A" & spots)Code ("G90")   While IsMoving  sleep 100Wend  SetOEMDRO(803, 0) 
