( fixture offset g59p7 = part 1 , g59p8 = part 2 , g59p9 = part 3 ............. g59p253 = part 247 )
#1=4 ( number of parts to be machined e.g. #1=1 will machine 1 part #1=247 will machine 247 parts ----- max 247 parts ---- )
#2=7           (set parameter #2 to a value of 7 // the first fixture offset g59p7 for the first tool )
t1m6           (toolchange first tool)
m98p1l#1       ( call subprogram o1 and repeat it as many times as the value in #1)
#2=7           (set parameter #2 to a value of 7 // the first fixture offset g59p7 for the second tool )
t2m6           (toolchange second tool)
m98p2l#1       ( call subprogram o2 and repeat it as many times as the value in #1)
#2=7           (set parameter #2 to a value of 7 // the first fixture offset g59p7 for the third tool )
t3m6           (toolchange third tool)
m98p3l#1       ( call subprogram o3 and repeat it as many times as the value in #1)
#2=7           (set parameter #2 to a value of 7 // the first fixture offset g59p7 for the fourth tool )
t4m6           (toolchange fourth tool)
m98p4l#1       ( call subprogram o4 and repeat it as many times as the value in #1)
m30            ( main program end)
o1             (sub with toolpath first tool)
g59p#2         (call the fixture offset g59p and the value of #2)
g90g0x0y0z10   (your toolpath here first line)
g1x10F333      (your toolpath here)
y10            (your toolpath here)
x0             (your toolpath here)
y0             (your toolpath here last line)
#2=[#2+1]      ( count up #2 by a value of 1 for the next part )
m99            ( sub end and back to main program)
o2             (sub with toolpath second tool)
g59p#2
g90g0x0y0z10
g1x8
y8
x0
y0
#2=[#2+1]
m99
o3             (sub with toolpath third tool)
g59p#2
g90g0x0y0z10
g1x6
y6
x0
y0
#2=[#2+1]
m99
o4             (sub with toolpath fourth tool)
g59p#2
g90g0x0y0z10
g1x4
y4
x0
y0
#2=[#2+1]
m99
