- <profile>
- <Preferences>
  <Syskey1>1</Syskey1> 
  <DefDir>C:\Mach3</DefDir> 
  <Profile>Mill</Profile> 
  <NewPath>0</NewPath> 
  <BR>0.0</BR> 
  <BG>0.0</BG> 
  <BB>0.0</BB> 
  <FR>0.0</FR> 
  <FG>0.0</FG> 
  <FB>1.0</FB> 
  <RR>1.0</RR> 
  <RG>0.0</RG> 
  <RB>0.0</RB> 
  <AR>0.7</AR> 
  <AG>0.2</AG> 
  <AB>0.7</AB> 
  <ER>1.0</ER> 
  <EG>1.0</EG> 
  <EB>0.0</EB> 
  <MatRed>0.</MatRed> 
  <MatGreen>0.1</MatGreen> 
  <MatBlue>0.1</MatBlue> 
  <Running>1</Running> 
  <FirstRun>1</FirstRun> 
  <LastUser>Demo Version.</LastUser> 
  <PulseSpeed>0</PulseSpeed> 
  <Layout>1024.set</Layout> 
  <Units>1</Units> 
  <Motor0Active>1</Motor0Active> 
  <Motor0DirNeg>0</Motor0DirNeg> 
  <Motor0DirPort>1</Motor0DirPort> 
  <Motor0DirPin>2</Motor0DirPin> 
  <Motor0StepNeg>0</Motor0StepNeg> 
  <Motor0StepPort>1</Motor0StepPort> 
  <Motor0StepPin>1</Motor0StepPin> 
  <Motor1Active>1</Motor1Active> 
  <Motor1DirNeg>0</Motor1DirNeg> 
  <Motor1DirPort>1</Motor1DirPort> 
  <Motor1DirPin>4</Motor1DirPin> 
  <Motor1StepNeg>0</Motor1StepNeg> 
  <Motor1StepPort>1</Motor1StepPort> 
  <Motor1StepPin>3</Motor1StepPin> 
  <Motor2Active>1</Motor2Active> 
  <Motor2DirNeg>0</Motor2DirNeg> 
  <Motor2DirPort>1</Motor2DirPort> 
  <Motor2DirPin>6</Motor2DirPin> 
  <Motor2StepNeg>0</Motor2StepNeg> 
  <Motor2StepPort>1</Motor2StepPort> 
  <Motor2StepPin>5</Motor2StepPin> 
  <Motor3Active>0</Motor3Active> 
  <Motor3DirNeg>0</Motor3DirNeg> 
  <Motor3DirPort>0</Motor3DirPort> 
  <Motor3DirPin>0</Motor3DirPin> 
  <Motor3StepNeg>0</Motor3StepNeg> 
  <Motor3StepPort>0</Motor3StepPort> 
  <Motor3StepPin>0</Motor3StepPin> 
  <Motor4Active>0</Motor4Active> 
  <Motor4DirNeg>0</Motor4DirNeg> 
  <Motor4DirPort>0</Motor4DirPort> 
  <Motor4DirPin>0</Motor4DirPin> 
  <Motor4StepNeg>0</Motor4StepNeg> 
  <Motor4StepPort>0</Motor4StepPort> 
  <Motor4StepPin>0</Motor4StepPin> 
  <Motor5Active>0</Motor5Active> 
  <Motor5DirNeg>0</Motor5DirNeg> 
  <Motor5DirPort>0</Motor5DirPort> 
  <Motor5DirPin>0</Motor5DirPin> 
  <Motor5StepNeg>0</Motor5StepNeg> 
  <Motor5StepPort>0</Motor5StepPort> 
  <Motor5StepPin>0</Motor5StepPin> 
  <Motor6Active>0</Motor6Active> 
  <Motor6DirNeg>0</Motor6DirNeg> 
  <Motor6DirPort>0</Motor6DirPort> 
  <Motor6DirPin>0</Motor6DirPin> 
  <Motor6StepNeg>0</Motor6StepNeg> 
  <Motor6StepPort>0</Motor6StepPort> 
  <Motor6StepPin>0</Motor6StepPin> 
  <Serial>0</Serial> 
  <SerialServo>0</SerialServo> 
  <Port2Input>0</Port2Input> 
  <GeckoMode>0</GeckoMode> 
  <USBINPUTS>16</USBINPUTS> 
  <USBOUTPUTS>16</USBOUTPUTS> 
  <Port2On>0</Port2On> 
  <Port1On>1</Port1On> 
  <Port1Add>888</Port1Add> 
  <Port2Add>632</Port2Add> 
  <MaxCL>0</MaxCL> 
  <MaxNC10>0</MaxNC10> 
  <ModPlug>0</ModPlug> 
  <TCPMODBUS>0</TCPMODBUS> 
  <Input0Active>0</Input0Active> 
  <Input0Port>0</Input0Port> 
  <Input0Pin>0</Input0Pin> 
  <Input0Neg>0</Input0Neg> 
  <Input0Emulated>0</Input0Emulated> 
  <Input0EmuKey>0</Input0EmuKey> 
  <Input1Active>0</Input1Active> 
  <Input1Port>0</Input1Port> 
  <Input1Pin>0</Input1Pin> 
  <Input1Neg>0</Input1Neg> 
  <Input1Emulated>0</Input1Emulated> 
  <Input1EmuKey>0</Input1EmuKey> 
  <Input2Active>0</Input2Active> 
  <Input2Port>0</Input2Port> 
  <Input2Pin>0</Input2Pin> 
  <Input2Neg>0</Input2Neg> 
  <Input2Emulated>0</Input2Emulated> 
  <Input2EmuKey>0</Input2EmuKey> 
  <Input3Active>0</Input3Active> 
  <Input3Port>0</Input3Port> 
  <Input3Pin>0</Input3Pin> 
  <Input3Neg>0</Input3Neg> 
  <Input3Emulated>0</Input3Emulated> 
  <Input3EmuKey>0</Input3EmuKey> 
  <Input4Active>0</Input4Active> 
  <Input4Port>0</Input4Port> 
  <Input4Pin>0</Input4Pin> 
  <Input4Neg>0</Input4Neg> 
  <Input4Emulated>0</Input4Emulated> 
  <Input4EmuKey>0</Input4EmuKey> 
  <Input5Active>0</Input5Active> 
  <Input5Port>0</Input5Port> 
  <Input5Pin>0</Input5Pin> 
  <Input5Neg>0</Input5Neg> 
  <Input5Emulated>0</Input5Emulated> 
  <Input5EmuKey>0</Input5EmuKey> 
  <Input6Active>0</Input6Active> 
  <Input6Port>0</Input6Port> 
  <Input6Pin>0</Input6Pin> 
  <Input6Neg>0</Input6Neg> 
  <Input6Emulated>0</Input6Emulated> 
  <Input6EmuKey>0</Input6EmuKey> 
  <Input7Active>0</Input7Active> 
  <Input7Port>0</Input7Port> 
  <Input7Pin>0</Input7Pin> 
  <Input7Neg>0</Input7Neg> 
  <Input7Emulated>0</Input7Emulated> 
  <Input7EmuKey>0</Input7EmuKey> 
  <Input8Active>0</Input8Active> 
  <Input8Port>0</Input8Port> 
  <Input8Pin>0</Input8Pin> 
  <Input8Neg>0</Input8Neg> 
  <Input8Emulated>0</Input8Emulated> 
  <Input8EmuKey>0</Input8EmuKey> 
  <Input9Active>0</Input9Active> 
  <Input9Port>0</Input9Port> 
  <Input9Pin>0</Input9Pin> 
  <Input9Neg>0</Input9Neg> 
  <Input9Emulated>0</Input9Emulated> 
  <Input9EmuKey>0</Input9EmuKey> 
  <Input10Active>0</Input10Active> 
  <Input10Port>0</Input10Port> 
  <Input10Pin>0</Input10Pin> 
  <Input10Neg>0</Input10Neg> 
  <Input10Emulated>0</Input10Emulated> 
  <Input10EmuKey>0</Input10EmuKey> 
  <Input11Active>0</Input11Active> 
  <Input11Port>0</Input11Port> 
  <Input11Pin>0</Input11Pin> 
  <Input11Neg>0</Input11Neg> 
  <Input11Emulated>0</Input11Emulated> 
  <Input11EmuKey>0</Input11EmuKey> 
  <Input12Active>0</Input12Active> 
  <Input12Port>0</Input12Port> 
  <Input12Pin>0</Input12Pin> 
  <Input12Neg>0</Input12Neg> 
  <Input12Emulated>0</Input12Emulated> 
  <Input12EmuKey>0</Input12EmuKey> 
  <Input13Active>0</Input13Active> 
  <Input13Port>0</Input13Port> 
  <Input13Pin>0</Input13Pin> 
  <Input13Neg>0</Input13Neg> 
  <Input13Emulated>0</Input13Emulated> 
  <Input13EmuKey>0</Input13EmuKey> 
  <Input14Active>0</Input14Active> 
  <Input14Port>0</Input14Port> 
  <Input14Pin>0</Input14Pin> 
  <Input14Neg>0</Input14Neg> 
  <Input14Emulated>0</Input14Emulated> 
  <Input14EmuKey>0</Input14EmuKey> 
  <Input15Active>0</Input15Active> 
  <Input15Port>0</Input15Port> 
  <Input15Pin>0</Input15Pin> 
  <Input15Neg>0</Input15Neg> 
  <Input15Emulated>0</Input15Emulated> 
  <Input15EmuKey>0</Input15EmuKey> 
  <Input16Active>0</Input16Active> 
  <Input16Port>0</Input16Port> 
  <Input16Pin>0</Input16Pin> 
  <Input16Neg>0</Input16Neg> 
  <Input16Emulated>0</Input16Emulated> 
  <Input16EmuKey>0</Input16EmuKey> 
  <Input17Active>0</Input17Active> 
  <Input17Port>0</Input17Port> 
  <Input17Pin>0</Input17Pin> 
  <Input17Neg>0</Input17Neg> 
  <Input17Emulated>0</Input17Emulated> 
  <Input17EmuKey>0</Input17EmuKey> 
  <Input18Active>0</Input18Active> 
  <Input18Port>0</Input18Port> 
  <Input18Pin>0</Input18Pin> 
  <Input18Neg>0</Input18Neg> 
  <Input18Emulated>0</Input18Emulated> 
  <Input18EmuKey>0</Input18EmuKey> 
  <Input19Active>0</Input19Active> 
  <Input19Port>0</Input19Port> 
  <Input19Pin>0</Input19Pin> 
  <Input19Neg>0</Input19Neg> 
  <Input19Emulated>0</Input19Emulated> 
  <Input19EmuKey>0</Input19EmuKey> 
  <Input20Active>0</Input20Active> 
  <Input20Port>0</Input20Port> 
  <Input20Pin>0</Input20Pin> 
  <Input20Neg>0</Input20Neg> 
  <Input20Emulated>0</Input20Emulated> 
  <Input20EmuKey>0</Input20EmuKey> 
  <Input21Active>0</Input21Active> 
  <Input21Port>0</Input21Port> 
  <Input21Pin>0</Input21Pin> 
  <Input21Neg>0</Input21Neg> 
  <Input21Emulated>0</Input21Emulated> 
  <Input21EmuKey>0</Input21EmuKey> 
  <Input22Active>0</Input22Active> 
  <Input22Port>0</Input22Port> 
  <Input22Pin>0</Input22Pin> 
  <Input22Neg>0</Input22Neg> 
  <Input22Emulated>0</Input22Emulated> 
  <Input22EmuKey>0</Input22EmuKey> 
  <Input23Active>0</Input23Active> 
  <Input23Port>0</Input23Port> 
  <Input23Pin>0</Input23Pin> 
  <Input23Neg>0</Input23Neg> 
  <Input23Emulated>0</Input23Emulated> 
  <Input23EmuKey>0</Input23EmuKey> 
  <Input24Active>0</Input24Active> 
  <Input24Port>0</Input24Port> 
  <Input24Pin>0</Input24Pin> 
  <Input24Neg>0</Input24Neg> 
  <Input24Emulated>0</Input24Emulated> 
  <Input24EmuKey>0</Input24EmuKey> 
  <Input25Active>1</Input25Active> 
  <Input25Port>0</Input25Port> 
  <Input25Pin>0</Input25Pin> 
  <Input25Neg>1</Input25Neg> 
  <Input25Emulated>0</Input25Emulated> 
  <Input25EmuKey>0</Input25EmuKey> 
  <Input26Active>0</Input26Active> 
  <Input26Port>0</Input26Port> 
  <Input26Pin>0</Input26Pin> 
  <Input26Neg>0</Input26Neg> 
  <Input26Emulated>0</Input26Emulated> 
  <Input26EmuKey>0</Input26EmuKey> 
  <Input27Active>0</Input27Active> 
  <Input27Port>0</Input27Port> 
  <Input27Pin>0</Input27Pin> 
  <Input27Neg>0</Input27Neg> 
  <Input27Emulated>0</Input27Emulated> 
  <Input27EmuKey>0</Input27EmuKey> 
  <Input28Active>0</Input28Active> 
  <Input28Port>0</Input28Port> 
  <Input28Pin>0</Input28Pin> 
  <Input28Neg>0</Input28Neg> 
  <Input28Emulated>0</Input28Emulated> 
  <Input28EmuKey>0</Input28EmuKey> 
  <Input29Active>0</Input29Active> 
  <Input29Port>0</Input29Port> 
  <Input29Pin>0</Input29Pin> 
  <Input29Neg>0</Input29Neg> 
  <Input29Emulated>0</Input29Emulated> 
  <Input29EmuKey>0</Input29EmuKey> 
  <Input30Active>0</Input30Active> 
  <Input30Port>0</Input30Port> 
  <Input30Pin>0</Input30Pin> 
  <Input30Neg>0</Input30Neg> 
  <Input30Emulated>0</Input30Emulated> 
  <Input30EmuKey>0</Input30EmuKey> 
  <Input31Active>0</Input31Active> 
  <Input31Port>0</Input31Port> 
  <Input31Pin>0</Input31Pin> 
  <Input31Neg>0</Input31Neg> 
  <Input31Emulated>0</Input31Emulated> 
  <Input31EmuKey>0</Input31EmuKey> 
  <Input32Active>0</Input32Active> 
  <Input32Port>0</Input32Port> 
  <Input32Pin>0</Input32Pin> 
  <Input32Neg>0</Input32Neg> 
  <Input32Emulated>0</Input32Emulated> 
  <Input32EmuKey>0</Input32EmuKey> 
  <Input33Active>0</Input33Active> 
  <Input33Port>0</Input33Port> 
  <Input33Pin>0</Input33Pin> 
  <Input33Neg>0</Input33Neg> 
  <Input33Emulated>0</Input33Emulated> 
  <Input33EmuKey>0</Input33EmuKey> 
  <Input34Active>0</Input34Active> 
  <Input34Port>0</Input34Port> 
  <Input34Pin>0</Input34Pin> 
  <Input34Neg>0</Input34Neg> 
  <Input34Emulated>0</Input34Emulated> 
  <Input34EmuKey>0</Input34EmuKey> 
  <Input35Active>0</Input35Active> 
  <Input35Port>0</Input35Port> 
  <Input35Pin>0</Input35Pin> 
  <Input35Neg>0</Input35Neg> 
  <Input35Emulated>0</Input35Emulated> 
  <Input35EmuKey>0</Input35EmuKey> 
  <Input36Active>0</Input36Active> 
  <Input36Port>0</Input36Port> 
  <Input36Pin>0</Input36Pin> 
  <Input36Neg>0</Input36Neg> 
  <Input36Emulated>0</Input36Emulated> 
  <Input36EmuKey>0</Input36EmuKey> 
  <Input37Active>0</Input37Active> 
  <Input37Port>0</Input37Port> 
  <Input37Pin>0</Input37Pin> 
  <Input37Neg>0</Input37Neg> 
  <Input37Emulated>0</Input37Emulated> 
  <Input37EmuKey>0</Input37EmuKey> 
  <Input38Active>0</Input38Active> 
  <Input38Port>0</Input38Port> 
  <Input38Pin>0</Input38Pin> 
  <Input38Neg>0</Input38Neg> 
  <Input38Emulated>0</Input38Emulated> 
  <Input38EmuKey>0</Input38EmuKey> 
  <Input39Active>0</Input39Active> 
  <Input39Port>0</Input39Port> 
  <Input39Pin>0</Input39Pin> 
  <Input39Neg>0</Input39Neg> 
  <Input39Emulated>0</Input39Emulated> 
  <Input39EmuKey>0</Input39EmuKey> 
  <Input40Active>0</Input40Active> 
  <Input40Port>0</Input40Port> 
  <Input40Pin>0</Input40Pin> 
  <Input40Neg>0</Input40Neg> 
  <Input40Emulated>0</Input40Emulated> 
  <Input40EmuKey>0</Input40EmuKey> 
  <Input41Active>0</Input41Active> 
  <Input41Port>0</Input41Port> 
  <Input41Pin>0</Input41Pin> 
  <Input41Neg>0</Input41Neg> 
  <Input41Emulated>0</Input41Emulated> 
  <Input41EmuKey>0</Input41EmuKey> 
  <Input42Active>0</Input42Active> 
  <Input42Port>0</Input42Port> 
  <Input42Pin>0</Input42Pin> 
  <Input42Neg>0</Input42Neg> 
  <Input42Emulated>0</Input42Emulated> 
  <Input42EmuKey>0</Input42EmuKey> 
  <Input43Active>0</Input43Active> 
  <Input43Port>0</Input43Port> 
  <Input43Pin>0</Input43Pin> 
  <Input43Neg>0</Input43Neg> 
  <Input43Emulated>0</Input43Emulated> 
  <Input43EmuKey>0</Input43EmuKey> 
  <Input44Active>0</Input44Active> 
  <Input44Port>0</Input44Port> 
  <Input44Pin>0</Input44Pin> 
  <Input44Neg>0</Input44Neg> 
  <Input44Emulated>0</Input44Emulated> 
  <Input44EmuKey>0</Input44EmuKey> 
  <Input45Active>0</Input45Active> 
  <Input45Port>0</Input45Port> 
  <Input45Pin>0</Input45Pin> 
  <Input45Neg>0</Input45Neg> 
  <Input45Emulated>0</Input45Emulated> 
  <Input45EmuKey>0</Input45EmuKey> 
  <Input46Active>0</Input46Active> 
  <Input46Port>0</Input46Port> 
  <Input46Pin>0</Input46Pin> 
  <Input46Neg>0</Input46Neg> 
  <Input46Emulated>0</Input46Emulated> 
  <Input46EmuKey>0</Input46EmuKey> 
  <Input47Active>0</Input47Active> 
  <Input47Port>0</Input47Port> 
  <Input47Pin>0</Input47Pin> 
  <Input47Neg>0</Input47Neg> 
  <Input47Emulated>0</Input47Emulated> 
  <Input47EmuKey>0</Input47EmuKey> 
  <Input48Active>0</Input48Active> 
  <Input48Port>0</Input48Port> 
  <Input48Pin>0</Input48Pin> 
  <Input48Neg>0</Input48Neg> 
  <Input48Emulated>0</Input48Emulated> 
  <Input48EmuKey>0</Input48EmuKey> 
  <Input49Active>0</Input49Active> 
  <Input49Port>0</Input49Port> 
  <Input49Pin>0</Input49Pin> 
  <Input49Neg>0</Input49Neg> 
  <Input49Emulated>0</Input49Emulated> 
  <Input49EmuKey>0</Input49EmuKey> 
  <Input50Active>0</Input50Active> 
  <Input50Port>0</Input50Port> 
  <Input50Pin>0</Input50Pin> 
  <Input50Neg>0</Input50Neg> 
  <Input50Emulated>0</Input50Emulated> 
  <Input50EmuKey>0</Input50EmuKey> 
  <Input51Active>0</Input51Active> 
  <Input51Port>0</Input51Port> 
  <Input51Pin>0</Input51Pin> 
  <Input51Neg>0</Input51Neg> 
  <Input51Emulated>0</Input51Emulated> 
  <Input51EmuKey>0</Input51EmuKey> 
  <Input52Active>0</Input52Active> 
  <Input52Port>0</Input52Port> 
  <Input52Pin>0</Input52Pin> 
  <Input52Neg>0</Input52Neg> 
  <Input52Emulated>0</Input52Emulated> 
  <Input52EmuKey>0</Input52EmuKey> 
  <Output0Active>0</Output0Active> 
  <Output0Port>0</Output0Port> 
  <Output0Pin>0</Output0Pin> 
  <Output0Neg>0</Output0Neg> 
  <Output1Active>0</Output1Active> 
  <Output1Port>1</Output1Port> 
  <Output1Pin>14</Output1Pin> 
  <Output1Neg>0</Output1Neg> 
  <Output2Active>0</Output2Active> 
  <Output2Port>1</Output2Port> 
  <Output2Pin>16</Output2Pin> 
  <Output2Neg>0</Output2Neg> 
  <Output3Active>0</Output3Active> 
  <Output3Port>1</Output3Port> 
  <Output3Pin>17</Output3Pin> 
  <Output3Neg>0</Output3Neg> 
  <Output4Active>0</Output4Active> 
  <Output4Port>0</Output4Port> 
  <Output4Pin>0</Output4Pin> 
  <Output4Neg>0</Output4Neg> 
  <Output5Active>0</Output5Active> 
  <Output5Port>0</Output5Port> 
  <Output5Pin>0</Output5Pin> 
  <Output5Neg>0</Output5Neg> 
  <Output6Active>0</Output6Active> 
  <Output6Port>0</Output6Port> 
  <Output6Pin>0</Output6Pin> 
  <Output6Neg>0</Output6Neg> 
  <Output7Active>0</Output7Active> 
  <Output7Port>0</Output7Port> 
  <Output7Pin>0</Output7Pin> 
  <Output7Neg>0</Output7Neg> 
  <Output8Active>0</Output8Active> 
  <Output8Port>0</Output8Port> 
  <Output8Pin>0</Output8Pin> 
  <Output8Neg>0</Output8Neg> 
  <Output9Active>0</Output9Active> 
  <Output9Port>0</Output9Port> 
  <Output9Pin>0</Output9Pin> 
  <Output9Neg>0</Output9Neg> 
  <Output10Active>0</Output10Active> 
  <Output10Port>0</Output10Port> 
  <Output10Pin>0</Output10Pin> 
  <Output10Neg>0</Output10Neg> 
  <Output11Active>0</Output11Active> 
  <Output11Port>0</Output11Port> 
  <Output11Pin>0</Output11Pin> 
  <Output11Neg>0</Output11Neg> 
  <Output12Active>0</Output12Active> 
  <Output12Port>0</Output12Port> 
  <Output12Pin>0</Output12Pin> 
  <Output12Neg>0</Output12Neg> 
  <Output13Active>0</Output13Active> 
  <Output13Port>0</Output13Port> 
  <Output13Pin>0</Output13Pin> 
  <Output13Neg>0</Output13Neg> 
  <Output14Active>0</Output14Active> 
  <Output14Port>0</Output14Port> 
  <Output14Pin>0</Output14Pin> 
  <Output14Neg>0</Output14Neg> 
  <Output15Active>0</Output15Active> 
  <Output15Port>0</Output15Port> 
  <Output15Pin>0</Output15Pin> 
  <Output15Neg>0</Output15Neg> 
  <Output16Active>0</Output16Active> 
  <Output16Port>0</Output16Port> 
  <Output16Pin>0</Output16Pin> 
  <Output16Neg>0</Output16Neg> 
  <Output17Active>0</Output17Active> 
  <Output17Port>0</Output17Port> 
  <Output17Pin>0</Output17Pin> 
  <Output17Neg>0</Output17Neg> 
  <Output18Active>0</Output18Active> 
  <Output18Port>0</Output18Port> 
  <Output18Pin>0</Output18Pin> 
  <Output18Neg>0</Output18Neg> 
  <Output19Active>0</Output19Active> 
  <Output19Port>0</Output19Port> 
  <Output19Pin>0</Output19Pin> 
  <Output19Neg>0</Output19Neg> 
  <Output20Active>0</Output20Active> 
  <Output20Port>0</Output20Port> 
  <Output20Pin>0</Output20Pin> 
  <Output20Neg>0</Output20Neg> 
  <Output21Active>0</Output21Active> 
  <Output21Port>0</Output21Port> 
  <Output21Pin>0</Output21Pin> 
  <Output21Neg>0</Output21Neg> 
  <Output22Active>0</Output22Active> 
  <Output22Port>0</Output22Port> 
  <Output22Pin>0</Output22Pin> 
  <Output22Neg>0</Output22Neg> 
  <Output23Active>0</Output23Active> 
  <Output23Port>0</Output23Port> 
  <Output23Pin>0</Output23Pin> 
  <Output23Neg>0</Output23Neg> 
  <Output24Active>0</Output24Active> 
  <Output24Port>0</Output24Port> 
  <Output24Pin>0</Output24Pin> 
  <Output24Neg>0</Output24Neg> 
  <Output25Active>0</Output25Active> 
  <Output25Port>0</Output25Port> 
  <Output25Pin>0</Output25Pin> 
  <Output25Neg>0</Output25Neg> 
  <Output26Active>0</Output26Active> 
  <Output26Port>0</Output26Port> 
  <Output26Pin>0</Output26Pin> 
  <Output26Neg>0</Output26Neg> 
  <Output27Active>0</Output27Active> 
  <Output27Port>0</Output27Port> 
  <Output27Pin>0</Output27Pin> 
  <Output27Neg>0</Output27Neg> 
  <Output28Active>0</Output28Active> 
  <Output28Port>0</Output28Port> 
  <Output28Pin>0</Output28Pin> 
  <Output28Neg>0</Output28Neg> 
  <Output29Active>0</Output29Active> 
  <Output29Port>0</Output29Port> 
  <Output29Pin>0</Output29Pin> 
  <Output29Neg>0</Output29Neg> 
  <Configured>1</Configured> 
  <Encoder0Active>0</Encoder0Active> 
  <Encoder0APort>0</Encoder0APort> 
  <Encoder0APin>0</Encoder0APin> 
  <Encoder0BPort>0</Encoder0BPort> 
  <Encoder0BPin>0</Encoder0BPin> 
  <Encoder0Cal>1.000000</Encoder0Cal> 
  <Encoder1Active>0</Encoder1Active> 
  <Encoder1APort>0</Encoder1APort> 
  <Encoder1APin>0</Encoder1APin> 
  <Encoder1BPort>0</Encoder1BPort> 
  <Encoder1BPin>0</Encoder1BPin> 
  <Encoder1Cal>1.000000</Encoder1Cal> 
  <Encoder2Active>0</Encoder2Active> 
  <Encoder2APort>0</Encoder2APort> 
  <Encoder2APin>0</Encoder2APin> 
  <Encoder2BPort>0</Encoder2BPort> 
  <Encoder2BPin>0</Encoder2BPin> 
  <Encoder2Cal>1.000000</Encoder2Cal> 
  <Encoder3Active>0</Encoder3Active> 
  <Encoder3APort>0</Encoder3APort> 
  <Encoder3APin>0</Encoder3APin> 
  <Encoder3BPort>0</Encoder3BPort> 
  <Encoder3BPin>0</Encoder3BPin> 
  <Encoder3Cal>1.000000</Encoder3Cal> 
  <Encoder4Active>0</Encoder4Active> 
  <Encoder4APort>0</Encoder4APort> 
  <Encoder4APin>0</Encoder4APin> 
  <Encoder4BPort>0</Encoder4BPort> 
  <Encoder4BPin>0</Encoder4BPin> 
  <Encoder4Cal>1.</Encoder4Cal> 
  <Encoder5Active>0</Encoder5Active> 
  <Encoder5APort>0</Encoder5APort> 
  <Encoder5APin>0</Encoder5APin> 
  <Encoder5BPort>0</Encoder5BPort> 
  <Encoder5BPin>0</Encoder5BPin> 
  <Encoder5Cal>1.000000</Encoder5Cal> 
  <Encoder6Active>0</Encoder6Active> 
  <Encoder6APort>0</Encoder6APort> 
  <Encoder6APin>0</Encoder6APin> 
  <Encoder6BPort>0</Encoder6BPort> 
  <Encoder6BPin>0</Encoder6BPin> 
  <Encoder6Cal>1.000000</Encoder6Cal> 
  <Encoder7Active>0</Encoder7Active> 
  <Encoder7APort>0</Encoder7APort> 
  <Encoder7APin>0</Encoder7APin> 
  <Encoder7BPort>0</Encoder7BPort> 
  <Encoder7BPin>0</Encoder7BPin> 
  <Encoder7Cal /> 
  <PulseWidth>0</PulseWidth> 
  <DirPulse>0</DirPulse> 
  <MenuOff>0</MenuOff> 
  <Debounce>0</Debounce> 
  <PlasmaMode>0</PlasmaMode> 
  <NoAngle>1</NoAngle> 
  <AAngular>1</AAngular> 
  <BAngular>1</BAngular> 
  <CAngular>1</CAngular> 
  <IndexDebounce>0</IndexDebounce> 
  <DROPERSIST>0</DROPERSIST> 
  <DwellinMilli>0</DwellinMilli> 
  <INIT>G80</INIT> 
  <InitAllResets>0</InitAllResets> 
  <AutoScreens>1</AutoScreens> 
  <M0AutoZero>1</M0AutoZero> 
  <M1AutoZero>1</M1AutoZero> 
  <M2AutoZero>1</M2AutoZero> 
  <M3AutoZero>1</M3AutoZero> 
  <M4AutoZero>1</M4AutoZero> 
  <M5AutoZero>1</M5AutoZero> 
  <m_SafeZ>0.</m_SafeZ> 
  <CVUseAngle>0</CVUseAngle> 
  <CVDegrees>0.</CVDegrees> 
  <Steps6>1.</Steps6> 
  <M9After>0</M9After> 
  <DwellTrigger>0</DwellTrigger> 
  <IgnoreMacros>0</IgnoreMacros> 
  <ZBar>1</ZBar> 
  <ROTSOFT>1</ROTSOFT> 
  <PROBETLO>0</PROBETLO> 
  <SlaveHome>0</SlaveHome> 
  <LockFROs>1</LockFROs> 
  <JogHeat>0</JogHeat> 
  <KeyClick>0</KeyClick> 
  <THC5>0</THC5> 
  <SpinInc>100</SpinInc> 
  <M30SpinOff>1</M30SpinOff> 
  <AutoCalcs>0</AutoCalcs> 
  <Boxed>1</Boxed> 
  <SafeZStop>0</SafeZStop> 
  <SafeZType>0</SafeZType> 
  <UseDiam>0</UseDiam> 
  <ToolLines>0</ToolLines> 
  <NURBS>1</NURBS> 
  <ToolPersist>0</ToolPersist> 
  <KeepRef>0</KeepRef> 
  <TurnRevArc>1</TurnRevArc> 
  <TORCHVON>0</TORCHVON> 
  <TORCHVOLTS>0</TORCHVOLTS> 
  <HWSAFE>1</HWSAFE> 
  <ShortRot>0</ShortRot> 
  <LookAhead>20</LookAhead> 
  <WatchDog>1</WatchDog> 
  <Plane>0</Plane> 
  <MPG1>0</MPG1> 
  <MPG2>0</MPG2> 
  <HotKeysPersist>0</HotKeysPersist> 
  <HoldInput1>0</HoldInput1> 
  <M3s>1</M3s> 
  <HiRes>0</HiRes> 
  <UseCR>0</UseCR> 
  <DelinChar>12</DelinChar> 
  <PlasmaHome>0</PlasmaHome> 
  <Rot360>0</Rot360> 
  <Homann>0</Homann> 
  <UseSLS>0</UseSLS> 
  <UDP>0</UDP> 
  <DROFont>Arial</DROFont> 
  <LabelFont>Arial</LabelFont> 
  <CodeFont>Arial</CodeFont> 
  <ButtonFont>Arial</ButtonFont> 
  <Dist0>47</Dist0> 
  <Dist1>41</Dist1> 
  <Dist2>1.4</Dist2> 
  <Dist3>0.</Dist3> 
  <Dist4>0.</Dist4> 
  <Dist5>0.</Dist5> 
  <OverMode2>0</OverMode2> 
  <BitPack1>0</BitPack1> 
  <BitPack1Reg>16</BitPack1Reg> 
  <BitPackOut>0</BitPackOut> 
  <BitPackOutReg>16</BitPackOutReg> 
  <LaserPort>1</LaserPort> 
  <LaserBaud>9600</LaserBaud> 
  <LaserStops>1</LaserStops> 
  <LaserData>1</LaserData> 
  <LaserInit>></LaserInit> 
  <LaserCommand>></LaserCommand> 
  <MacroPump>0</MacroPump> 
  <PierceDelay>1.</PierceDelay> 
  <M7Delay>0.</M7Delay> 
  <M8Delay>0.</M8Delay> 
  <VelMode>0</VelMode> 
  <VelPer1>5.</VelPer1> 
  <VelPer2>5.</VelPer2> 
  <VelPer3>5.</VelPer3> 
  <TouchX>0.</TouchX> 
  <G20X>0.</G20X> 
  <G20Y>0.</G20Y> 
  <G20Z>0.</G20Z> 
  <G20A>0.</G20A> 
  <G20B>0.</G20B> 
  <G20C>0.</G20C> 
  <MPGFeed>1.e+002</MPGFeed> 
  <ModSpindleCal>1.638e+004</ModSpindleCal> 
  <ModSpindleOn>0</ModSpindleOn> 
  <ModSpindleReg>64</ModSpindleReg> 
  <ShuttleAccel>512000</ShuttleAccel> 
  <Flash>1</Flash> 
  <ImmediateOff>0</ImmediateOff> 
  <UseSafeZ>0</UseSafeZ> 
  <AdvancedComp>1</AdvancedComp> 
  <TorchOff>0</TorchOff> 
  <LaserStandby>0</LaserStandby> 
  <RaiseLower>0</RaiseLower> 
  <OEMDUAL>0</OEMDUAL> 
  <IncBuffer>5</IncBuffer> 
  <Formula0>x</Formula0> 
  <Formula1>y</Formula1> 
  <Formula2>z</Formula2> 
  <Formula3>a</Formula3> 
  <Formula4>b</Formula4> 
  <Formula5>c</Formula5> 
  <Formular>0</Formular> 
  <PanelOut>350</PanelOut> 
  <nModBusReg>0</nModBusReg> 
  <ModBusRegOn>0</ModBusRegOn> 
  <Tool>0</Tool> 
  <Sherline>0</Sherline> 
  <ToolPost>1</ToolPost> 
  <RapidOverRide>0</RapidOverRide> 
  <XCLength>1.3e+003</XCLength> 
  <YCLength>1.3e+003</YCLength> 
  <ZCLength>1.3e+003</ZCLength> 
  <ToolPostOffset>0.</ToolPostOffset> 
  <FrontRear>0.</FrontRear> 
  <OEM1>-1</OEM1> 
  <OEM2>-1</OEM2> 
  <OEM3>-1</OEM3> 
  <OEM4>-1</OEM4> 
  <OEM5>-1</OEM5> 
  <OEM6>-1</OEM6> 
  <OEM7>-1</OEM7> 
  <OEM8>-1</OEM8> 
  <OEM9>-1</OEM9> 
  <OEM10>-1</OEM10> 
  <OEM11>-1</OEM11> 
  <OEM12>-1</OEM12> 
  <OEM13>-1</OEM13> 
  <OEM14>-1</OEM14> 
  <OEM15>-1</OEM15> 
  <MPGVel0>1.e+002</MPGVel0> 
  <MPGVel1>1.e+002</MPGVel1> 
  <MPGVel2>1.e+002</MPGVel2> 
  <MPGVel3>1.e+002</MPGVel3> 
  <MPGVel4>1.e+002</MPGVel4> 
  <MPGVel5>1.e+002</MPGVel5> 
  <MPGVel6>1.e+002</MPGVel6> 
  <ByPassFeed>1.e+003</ByPassFeed> 
  <XMapOn>0</XMapOn> 
  <YMapOn>0</YMapOn> 
  <ZMapOn>0</ZMapOn> 
  <SecondsOn>16657</SecondsOn> 
  <SerialType>0</SerialType> 
  <SpinAverage>1</SpinAverage> 
  <Dig4Axis>0</Dig4Axis> 
  <DigLetter>0</DigLetter> 
  <CutType>0</CutType> 
  <InfeedType>0</InfeedType> 
  <LastWizard>None</LastWizard> 
  <Z25D>0</Z25D> 
  <ModBus>0</ModBus> 
  <ChargeAlwaysOn>0</ChargeAlwaysOn> 
  <ToolFlip>0</ToolFlip> 
  <SpinCCW>7</SpinCCW> 
  <SpinCW>8</SpinCW> 
  <Flood>9</Flood> 
  <Mist>10</Mist> 
  <SpinActual>0</SpinActual> 
  <SpinDelayCW>1.</SpinDelayCW> 
  <SpinDelayCCW>1.</SpinDelayCCW> 
  <SpinDownCW>1.</SpinDownCW> 
  <SpinDownCCW>1.</SpinDownCCW> 
  <StockSize>50</StockSize> 
  <ShowSolid>1</ShowSolid> 
  <RapidFeed>1.e+003</RapidFeed> 
  <SpinP>0.25</SpinP> 
  <SpinI>1.</SpinI> 
  <SpinD>0.3</SpinD> 
  <SpinClosed>0</SpinClosed> 
  <MinPerPass>0.1</MinPerPass> 
  <NoSpindle>1</NoSpindle> 
  <NoFlood>1</NoFlood> 
  <PWMin>0</PWMin> 
  <PULLEY>3</PULLEY> 
  <PWM>0</PWM> 
  <SPEED1>25000</SPEED1> 
  <LSPEED1>0</LSPEED1> 
  <SPINREV1>0</SPINREV1> 
  <SPINRATIO1>1.</SPINRATIO1> 
  <SPEED2>25000</SPEED2> 
  <LSPEED2>0</LSPEED2> 
  <SPINREV2>0</SPINREV2> 
  <SPINRATIO2>1.</SPINRATIO2> 
  <SPEED3>25000</SPEED3> 
  <LSPEED3>0</LSPEED3> 
  <SPINREV3>0</SPINREV3> 
  <SPINRATIO3>1.</SPINRATIO3> 
  <SPEED4>25000</SPEED4> 
  <LSPEED4>0</LSPEED4> 
  <SPINREV4>0</SPINREV4> 
  <SPINRATIO4>1.</SPINRATIO4> 
  <SPEED5>25000</SPEED5> 
  <LSPEED5>0</LSPEED5> 
  <SPINREV5>0</SPINREV5> 
  <SPINRATIO5>1.</SPINRATIO5> 
  <SPEED6>25000</SPEED6> 
  <LSPEED6>0</LSPEED6> 
  <SPINREV6>0</SPINREV6> 
  <SPINRATIO6>1.</SPINRATIO6> 
  <SPEED7>25000</SPEED7> 
  <LSPEED7>0</LSPEED7> 
  <SPINREV7>0</SPINREV7> 
  <SPINRATIO7>1.</SPINRATIO7> 
  <SPEED8>25000</SPEED8> 
  <LSPEED8>0</LSPEED8> 
  <SPINREV8>0</SPINREV8> 
  <SPINRATIO8>1.</SPINRATIO8> 
  <SPEED9>25000</SPEED9> 
  <LSPEED9>0</LSPEED9> 
  <SPINREV9>0</SPINREV9> 
  <SPINRATIO9>1.</SPINRATIO9> 
  <SPEED10>25000</SPEED10> 
  <LSPEED10>0</LSPEED10> 
  <SPINREV10>0</SPINREV10> 
  <SPINRATIO10>1.</SPINRATIO10> 
  <SPEED11>25000</SPEED11> 
  <LSPEED11>0</LSPEED11> 
  <SPINREV11>0</SPINREV11> 
  <SPINRATIO11>1.</SPINRATIO11> 
  <SPEED12>25000</SPEED12> 
  <LSPEED12>0</LSPEED12> 
  <SPINREV12>0</SPINREV12> 
  <SPINRATIO12>1.</SPINRATIO12> 
  <SPEED13>25000</SPEED13> 
  <LSPEED13>0</LSPEED13> 
  <SPINREV13>0</SPINREV13> 
  <SPINRATIO13>1.</SPINRATIO13> 
  <SPEED14>25000</SPEED14> 
  <LSPEED14>0</LSPEED14> 
  <SPINREV14>0</SPINREV14> 
  <SPINRATIO14>1.</SPINRATIO14> 
  <SPEED15>25000</SPEED15> 
  <LSPEED15>0</LSPEED15> 
  <SPINREV15>0</SPINREV15> 
  <SPINRATIO15>1.</SPINRATIO15> 
  <SPEED16>25000</SPEED16> 
  <LSPEED16>0</LSPEED16> 
  <SPINREV16>0</SPINREV16> 
  <SPINRATIO16>1.</SPINRATIO16> 
  <SPEED17>25000</SPEED17> 
  <LSPEED17>0</LSPEED17> 
  <SPINREV17>0</SPINREV17> 
  <SPINRATIO17>1.</SPINRATIO17> 
  <SPEED18>25000</SPEED18> 
  <LSPEED18>0</LSPEED18> 
  <SPINREV18>0</SPINREV18> 
  <SPINRATIO18>1.</SPINRATIO18> 
  <SPEED19>25000</SPEED19> 
  <LSPEED19>0</LSPEED19> 
  <SPINREV19>0</SPINREV19> 
  <SPINRATIO19>1.</SPINRATIO19> 
  <SPEED20>25000</SPEED20> 
  <LSPEED20>0</LSPEED20> 
  <SPINREV20>0</SPINREV20> 
  <SPINRATIO20>1.</SPINRATIO20> 
  <SPEED21>25000</SPEED21> 
  <LSPEED21>0</LSPEED21> 
  <SPINREV21>0</SPINREV21> 
  <SPINRATIO21>1.</SPINRATIO21> 
  <SPEED22>25000</SPEED22> 
  <LSPEED22>0</LSPEED22> 
  <SPINREV22>0</SPINREV22> 
  <SPINRATIO22>1.</SPINRATIO22> 
  <SPEED23>25000</SPEED23> 
  <LSPEED23>0</LSPEED23> 
  <SPINREV23>0</SPINREV23> 
  <SPINRATIO23>1.</SPINRATIO23> 
  <SPEED24>25000</SPEED24> 
  <LSPEED24>0</LSPEED24> 
  <SPINREV24>0</SPINREV24> 
  <SPINRATIO24>1.</SPINRATIO24> 
  <SPEED25>25000</SPEED25> 
  <LSPEED25>0</LSPEED25> 
  <SPINREV25>0</SPINREV25> 
  <SPINRATIO25>1.</SPINRATIO25> 
  <RefSpeed0>20</RefSpeed0> 
  <RefSpeed1>20</RefSpeed1> 
  <RefSpeed2>20</RefSpeed2> 
  <RefSpeed3>20</RefSpeed3> 
  <RefSpeed4>20</RefSpeed4> 
  <RefSpeed5>20</RefSpeed5> 
  <M0SoftRamp>1.</M0SoftRamp> 
  <M1SoftRamp>1.</M1SoftRamp> 
  <M2SoftRamp>1.</M2SoftRamp> 
  <M3SoftRamp>1.</M3SoftRamp> 
  <M4SoftRamp>1.</M4SoftRamp> 
  <M5SoftRamp>1.</M5SoftRamp> 
  <FeedInc>5.</FeedInc> 
  <DepthLastPass>0.</DepthLastPass> 
  <InFeed>29.5</InFeed> 
  <Spring>1.</Spring> 
  <MinDepth>1.e-003</MinDepth> 
  <XClear>0.1</XClear> 
  <ZClear>0.1</ZClear> 
  <CutDepth>0.1</CutDepth> 
  <Chamfer>0.</Chamfer> 
  <DepthFirstPass>0.1</DepthFirstPass> 
  <M0Max>8.</M0Max> 
  <M1Max>6.</M1Max> 
  <M2Max>4.</M2Max> 
  <M3Max>100.</M3Max> 
  <M4Max>100.</M4Max> 
  <M5Max>100.</M5Max> 
  <M0Min>-8.</M0Min> 
  <M1Min>-6.</M1Min> 
  <M2Min>-4.</M2Min> 
  <M3Min>-100.</M3Min> 
  <M4Min>-100.</M4Min> 
  <M5Min>-100.</M5Min> 
  <M0Neg>0</M0Neg> 
  <M1Neg>0</M1Neg> 
  <M2Neg>0</M2Neg> 
  <M3Neg>0</M3Neg> 
  <M4Neg>0</M4Neg> 
  <M5Neg>0</M5Neg> 
  <M0Rev>0</M0Rev> 
  <M1Rev>0</M1Rev> 
  <M2Rev>0</M2Rev> 
  <M3Rev>0</M3Rev> 
  <M4Rev>0</M4Rev> 
  <M5Rev>0</M5Rev> 
  <M6Rev>0</M6Rev> 
  <OffPersist>1</OffPersist> 
  <Diameter>0</Diameter> 
  <OffDialogs>1</OffDialogs> 
  <G54Back>0</G54Back> 
  <GougeCheck>1</GougeCheck> 
  <AxisToMotor0>0</AxisToMotor0> 
  <AxisToMotor1>1</AxisToMotor1> 
  <AxisToMotor2>2</AxisToMotor2> 
  <AxisToMotor3>3</AxisToMotor3> 
  <AxisToMotor4>4</AxisToMotor4> 
  <AxisToMotor5>5</AxisToMotor5> 
  <AxisToMotor6>6</AxisToMotor6> 
  <JogActive>1</JogActive> 
  <BLState0>0</BLState0> 
  <BLState1>0</BLState1> 
  <BLState2>0</BLState2> 
  <BLState3>0</BLState3> 
  <BLState4>0</BLState4> 
  <BLState5>0</BLState5> 
  <SlowMode>0</SlowMode> 
  <JogPersist>1</JogPersist> 
  <ToolRotations>0</ToolRotations> 
  <SoftLimit>0</SoftLimit> 
  <JogMode>0</JogMode> 
  <EncJogAxis1>0</EncJogAxis1> 
  <EncJogAxis2>1</EncJogAxis2> 
  <EncJogAxis3>2</EncJogAxis3> 
  <TaperRatio>1.</TaperRatio> 
  <XStart>0</XStart> 
  <YStart>0</YStart> 
  <ZStart>0</ZStart> 
  <AStart>0</AStart> 
  <BStart>0</BStart> 
  <CStart>0</CStart> 
  <OVSpinInc>10</OVSpinInc> 
  <Enc0>0.</Enc0> 
  <Enc1>0.</Enc1> 
  <Enc2>0.</Enc2> 
  <Enc3>0.</Enc3> 
  <TangentalControl>0</TangentalControl> 
  <BaudRate>9600</BaudRate> 
  <ComPort>1</ComPort> 
  <NoPlunge>0</NoPlunge> 
  <PlungeLimit>60</PlungeLimit> 
  <AutoTool>0</AutoTool> 
  <AutoSpindle>0</AutoSpindle> 
  <LaserMode>0</LaserMode> 
  <FeedMode>0</FeedMode> 
  <OriginSphere>0</OriginSphere> 
  <m_3dCompass>1</m_3dCompass> 
  <Boundries>0</Boundries> 
  <ToolPosition>1</ToolPosition> 
  <AParallel>0</AParallel> 
  <ZINHPersist>0</ZINHPersist> 
  <OVPersist>1</OVPersist> 
  <BacklashOn>0</BacklashOn> 
  <ThrottleFunc>2</ThrottleFunc> 
  <JoyOn>0</JoyOn> 
  <PWMBase>5000</PWMBase> 
  <JogSpeed>60.</JogSpeed> 
  <G73PullBack>0.1</G73PullBack> 
  <CVFeedOn>0</CVFeedOn> 
  <CVFeedRate>1.</CVFeedRate> 
  <AtoX>0.</AtoX> 
  <AtoY>0.</AtoY> 
  <AtoZ>0.</AtoZ> 
  <OEMDRO0>0.</OEMDRO0> 
  <OEMLED0>0</OEMLED0> 
  <OEMDRO1>0.</OEMDRO1> 
  <OEMLED1>0</OEMLED1> 
  <OEMDRO2>0.</OEMDRO2> 
  <OEMLED2>0</OEMLED2> 
  <OEMDRO3>0.</OEMDRO3> 
  <OEMLED3>0</OEMLED3> 
  <OEMDRO4>0.</OEMDRO4> 
  <OEMLED4>0</OEMLED4> 
  <OEMDRO5>0.</OEMDRO5> 
  <OEMLED5>0</OEMLED5> 
  <OEMDRO6>0.</OEMDRO6> 
  <OEMLED6>0</OEMLED6> 
  <OEMDRO7>0.</OEMDRO7> 
  <OEMLED7>0</OEMLED7> 
  <OEMDRO8>0.</OEMDRO8> 
  <OEMLED8>0</OEMLED8> 
  <OEMDRO9>0.</OEMDRO9> 
  <OEMLED9>0</OEMLED9> 
  <OEMDRO10>0.</OEMDRO10> 
  <OEMLED10>0</OEMLED10> 
  <OEMDRO11>0.</OEMDRO11> 
  <OEMLED11>0</OEMLED11> 
  <OEMDRO12>0.</OEMDRO12> 
  <OEMLED12>0</OEMLED12> 
  <OEMDRO13>0.</OEMDRO13> 
  <OEMLED13>0</OEMLED13> 
  <OEMDRO14>0.</OEMDRO14> 
  <OEMLED14>0</OEMLED14> 
  <OEMDRO15>0.</OEMDRO15> 
  <OEMLED15>0</OEMLED15> 
  <OEMDRO16>0.</OEMDRO16> 
  <OEMLED16>0</OEMLED16> 
  <OEMDRO17>0.</OEMDRO17> 
  <OEMLED17>0</OEMLED17> 
  <OEMDRO18>0.</OEMDRO18> 
  <OEMLED18>0</OEMLED18> 
  <OEMDRO19>0.</OEMDRO19> 
  <OEMLED19>0</OEMLED19> 
  <OEMDRO20>0.</OEMDRO20> 
  <OEMLED20>0</OEMLED20> 
  <OEMDRO21>0.</OEMDRO21> 
  <OEMLED21>0</OEMLED21> 
  <OEMDRO22>0.</OEMDRO22> 
  <OEMLED22>0</OEMLED22> 
  <OEMDRO23>0.</OEMDRO23> 
  <OEMLED23>0</OEMLED23> 
  <OEMDRO24>0.</OEMDRO24> 
  <OEMLED24>0</OEMLED24> 
  <OEMDRO25>0.</OEMDRO25> 
  <OEMLED25>0</OEMLED25> 
  <OEMDRO26>0.</OEMDRO26> 
  <OEMLED26>0</OEMLED26> 
  <OEMDRO27>0.</OEMDRO27> 
  <OEMLED27>0</OEMLED27> 
  <OEMDRO28>0.</OEMDRO28> 
  <OEMLED28>0</OEMLED28> 
  <OEMDRO29>0.</OEMDRO29> 
  <OEMLED29>0</OEMLED29> 
  <OEMDRO30>0.</OEMDRO30> 
  <OEMLED30>0</OEMLED30> 
  <OEMDRO31>0.</OEMDRO31> 
  <OEMLED31>0</OEMLED31> 
  <OEMDRO32>0.</OEMDRO32> 
  <OEMLED32>0</OEMLED32> 
  <OEMDRO33>0.</OEMDRO33> 
  <OEMLED33>0</OEMLED33> 
  <OEMDRO34>0.</OEMDRO34> 
  <OEMLED34>0</OEMLED34> 
  <OEMDRO35>0.</OEMDRO35> 
  <OEMLED35>0</OEMLED35> 
  <OEMDRO36>0.</OEMDRO36> 
  <OEMLED36>0</OEMLED36> 
  <OEMDRO37>0.</OEMDRO37> 
  <OEMLED37>0</OEMLED37> 
  <OEMDRO38>0.</OEMDRO38> 
  <OEMLED38>0</OEMLED38> 
  <OEMDRO39>0.</OEMDRO39> 
  <OEMLED39>0</OEMLED39> 
  <OEMDRO40>0.</OEMDRO40> 
  <OEMLED40>0</OEMLED40> 
  <OEMDRO41>0.</OEMDRO41> 
  <OEMLED41>0</OEMLED41> 
  <OEMDRO42>0.</OEMDRO42> 
  <OEMLED42>0</OEMLED42> 
  <OEMDRO43>0.</OEMDRO43> 
  <OEMLED43>0</OEMLED43> 
  <OEMDRO44>0.</OEMDRO44> 
  <OEMLED44>0</OEMLED44> 
  <OEMDRO45>0.</OEMDRO45> 
  <OEMLED45>0</OEMLED45> 
  <OEMDRO46>0.</OEMDRO46> 
  <OEMLED46>0</OEMLED46> 
  <OEMDRO47>0.</OEMDRO47> 
  <OEMLED47>0</OEMLED47> 
  <OEMDRO48>0.</OEMDRO48> 
  <OEMLED48>0</OEMLED48> 
  <OEMDRO49>0.</OEMDRO49> 
  <OEMLED49>0</OEMLED49> 
  <OEMDRO50>0.</OEMDRO50> 
  <OEMLED50>0</OEMLED50> 
  <OEMDRO51>0.</OEMDRO51> 
  <OEMLED51>0</OEMLED51> 
  <OEMDRO52>0.</OEMDRO52> 
  <OEMLED52>0</OEMLED52> 
  <OEMDRO53>0.</OEMDRO53> 
  <OEMLED53>0</OEMLED53> 
  <OEMDRO54>0.</OEMDRO54> 
  <OEMLED54>0</OEMLED54> 
  <OEMDRO55>0.</OEMDRO55> 
  <OEMLED55>0</OEMLED55> 
  <OEMDRO56>0.</OEMDRO56> 
  <OEMLED56>0</OEMLED56> 
  <OEMDRO57>0.</OEMDRO57> 
  <OEMLED57>0</OEMLED57> 
  <OEMDRO58>0.</OEMDRO58> 
  <OEMLED58>0</OEMLED58> 
  <OEMDRO59>0.</OEMDRO59> 
  <OEMLED59>0</OEMLED59> 
  <OEMDRO60>0.</OEMDRO60> 
  <OEMLED60>0</OEMLED60> 
  <OEMDRO61>0.</OEMDRO61> 
  <OEMLED61>0</OEMLED61> 
  <OEMDRO62>0.</OEMDRO62> 
  <OEMLED62>0</OEMLED62> 
  <OEMDRO63>0.</OEMDRO63> 
  <OEMLED63>0</OEMLED63> 
  <OEMDRO64>0.</OEMDRO64> 
  <OEMLED64>0</OEMLED64> 
  <OEMDRO65>0.</OEMDRO65> 
  <OEMLED65>0</OEMLED65> 
  <OEMDRO66>0.</OEMDRO66> 
  <OEMLED66>0</OEMLED66> 
  <OEMDRO67>0.</OEMDRO67> 
  <OEMLED67>0</OEMLED67> 
  <OEMDRO68>0.</OEMDRO68> 
  <OEMLED68>0</OEMLED68> 
  <OEMDRO69>0.</OEMDRO69> 
  <OEMLED69>0</OEMLED69> 
  <OEMDRO70>0.</OEMDRO70> 
  <OEMLED70>0</OEMLED70> 
  <OEMDRO71>0.</OEMDRO71> 
  <OEMLED71>0</OEMLED71> 
  <OEMDRO72>0.</OEMDRO72> 
  <OEMLED72>0</OEMLED72> 
  <OEMDRO73>0.</OEMDRO73> 
  <OEMLED73>0</OEMLED73> 
  <OEMDRO74>0.</OEMDRO74> 
  <OEMLED74>0</OEMLED74> 
  <OEMDRO75>0.</OEMDRO75> 
  <OEMLED75>0</OEMLED75> 
  <OEMDRO76>0.</OEMDRO76> 
  <OEMLED76>0</OEMLED76> 
  <OEMDRO77>0.</OEMDRO77> 
  <OEMLED77>0</OEMLED77> 
  <OEMDRO78>0.</OEMDRO78> 
  <OEMLED78>0</OEMLED78> 
  <OEMDRO79>0.</OEMDRO79> 
  <OEMLED79>0</OEMLED79> 
  <OEMDRO80>0.</OEMDRO80> 
  <OEMLED80>0</OEMLED80> 
  <OEMDRO81>0.</OEMDRO81> 
  <OEMLED81>0</OEMLED81> 
  <OEMDRO82>0.</OEMDRO82> 
  <OEMLED82>0</OEMLED82> 
  <OEMDRO83>0.</OEMDRO83> 
  <OEMLED83>0</OEMLED83> 
  <OEMDRO84>0.</OEMDRO84> 
  <OEMLED84>0</OEMLED84> 
  <OEMDRO85>0.</OEMDRO85> 
  <OEMLED85>0</OEMLED85> 
  <OEMDRO86>0.</OEMDRO86> 
  <OEMLED86>0</OEMLED86> 
  <OEMDRO87>0.</OEMDRO87> 
  <OEMLED87>0</OEMLED87> 
  <OEMDRO88>0.</OEMDRO88> 
  <OEMLED88>0</OEMLED88> 
  <OEMDRO89>0.</OEMDRO89> 
  <OEMLED89>0</OEMLED89> 
  <OEMDRO90>0.</OEMDRO90> 
  <OEMLED90>0</OEMLED90> 
  <OEMDRO91>0.</OEMDRO91> 
  <OEMLED91>0</OEMLED91> 
  <OEMDRO92>0.</OEMDRO92> 
  <OEMLED92>0</OEMLED92> 
  <OEMDRO93>0.</OEMDRO93> 
  <OEMLED93>0</OEMLED93> 
  <OEMDRO94>0.</OEMDRO94> 
  <OEMLED94>0</OEMLED94> 
  <OEMDRO95>0.</OEMDRO95> 
  <OEMLED95>0</OEMLED95> 
  <OEMDRO96>0.</OEMDRO96> 
  <OEMLED96>0</OEMLED96> 
  <OEMDRO97>0.</OEMDRO97> 
  <OEMLED97>0</OEMLED97> 
  <OEMDRO98>0.</OEMDRO98> 
  <OEMLED98>0</OEMLED98> 
  <OEMDRO99>0.</OEMDRO99> 
  <OEMLED99>0</OEMLED99> 
  <OEMDRO100>0.</OEMDRO100> 
  <OEMLED100>0</OEMLED100> 
  <OEMDRO101>0.</OEMDRO101> 
  <OEMLED101>0</OEMLED101> 
  <OEMDRO102>0.</OEMDRO102> 
  <OEMLED102>0</OEMLED102> 
  <OEMDRO103>0.</OEMDRO103> 
  <OEMLED103>0</OEMLED103> 
  <OEMDRO104>0.</OEMDRO104> 
  <OEMLED104>0</OEMLED104> 
  <OEMDRO105>0.</OEMDRO105> 
  <OEMLED105>0</OEMLED105> 
  <OEMDRO106>0.</OEMDRO106> 
  <OEMLED106>0</OEMLED106> 
  <OEMDRO107>0.</OEMDRO107> 
  <OEMLED107>0</OEMLED107> 
  <OEMDRO108>0.</OEMDRO108> 
  <OEMLED108>0</OEMLED108> 
  <OEMDRO109>0.</OEMDRO109> 
  <OEMLED109>0</OEMLED109> 
  <OEMDRO110>0.</OEMDRO110> 
  <OEMLED110>0</OEMLED110> 
  <OEMDRO111>0.</OEMDRO111> 
  <OEMLED111>0</OEMLED111> 
  <OEMDRO112>0.</OEMDRO112> 
  <OEMLED112>0</OEMLED112> 
  <OEMDRO113>0.</OEMDRO113> 
  <OEMLED113>0</OEMLED113> 
  <OEMDRO114>0.</OEMDRO114> 
  <OEMLED114>0</OEMLED114> 
  <OEMDRO115>0.</OEMDRO115> 
  <OEMLED115>0</OEMLED115> 
  <OEMDRO116>0.</OEMDRO116> 
  <OEMLED116>0</OEMLED116> 
  <OEMDRO117>0.</OEMDRO117> 
  <OEMLED117>0</OEMLED117> 
  <OEMDRO118>0.</OEMDRO118> 
  <OEMLED118>0</OEMLED118> 
  <OEMDRO119>0.</OEMDRO119> 
  <OEMLED119>0</OEMLED119> 
  <OEMDRO120>0.</OEMDRO120> 
  <OEMLED120>0</OEMLED120> 
  <OEMDRO121>0.</OEMDRO121> 
  <OEMLED121>0</OEMLED121> 
  <OEMDRO122>0.</OEMDRO122> 
  <OEMLED122>0</OEMLED122> 
  <OEMDRO123>0.</OEMDRO123> 
  <OEMLED123>0</OEMLED123> 
  <OEMDRO124>0.</OEMDRO124> 
  <OEMLED124>0</OEMLED124> 
  <OEMDRO125>0.</OEMDRO125> 
  <OEMLED125>0</OEMLED125> 
  <OEMDRO126>0.</OEMDRO126> 
  <OEMLED126>0</OEMLED126> 
  <OEMDRO127>0.</OEMDRO127> 
  <OEMLED127>0</OEMLED127> 
  <OEMDRO128>0.</OEMDRO128> 
  <OEMLED128>0</OEMLED128> 
  <OEMDRO129>0.</OEMDRO129> 
  <OEMLED129>0</OEMLED129> 
  <OEMDRO130>0.</OEMDRO130> 
  <OEMLED130>0</OEMLED130> 
  <OEMDRO131>0.</OEMDRO131> 
  <OEMLED131>0</OEMLED131> 
  <OEMDRO132>0.</OEMDRO132> 
  <OEMLED132>0</OEMLED132> 
  <OEMDRO133>0.</OEMDRO133> 
  <OEMLED133>0</OEMLED133> 
  <OEMDRO134>0.</OEMDRO134> 
  <OEMLED134>0</OEMLED134> 
  <OEMDRO135>0.</OEMDRO135> 
  <OEMLED135>0</OEMLED135> 
  <OEMDRO136>0.</OEMDRO136> 
  <OEMLED136>0</OEMLED136> 
  <OEMDRO137>0.</OEMDRO137> 
  <OEMLED137>0</OEMLED137> 
  <OEMDRO138>0.</OEMDRO138> 
  <OEMLED138>0</OEMLED138> 
  <OEMDRO139>0.</OEMDRO139> 
  <OEMLED139>0</OEMLED139> 
  <OEMDRO140>0.</OEMDRO140> 
  <OEMLED140>0</OEMLED140> 
  <OEMDRO141>0.</OEMDRO141> 
  <OEMLED141>0</OEMLED141> 
  <OEMDRO142>0.</OEMDRO142> 
  <OEMLED142>0</OEMLED142> 
  <OEMDRO143>0.</OEMDRO143> 
  <OEMLED143>0</OEMLED143> 
  <OEMDRO144>0.</OEMDRO144> 
  <OEMLED144>0</OEMLED144> 
  <OEMDRO145>0.</OEMDRO145> 
  <OEMLED145>0</OEMLED145> 
  <OEMDRO146>0.</OEMDRO146> 
  <OEMLED146>0</OEMLED146> 
  <OEMDRO147>0.</OEMDRO147> 
  <OEMLED147>0</OEMLED147> 
  <OEMDRO148>0.</OEMDRO148> 
  <OEMLED148>0</OEMLED148> 
  <OEMDRO149>0.</OEMDRO149> 
  <OEMLED149>0</OEMLED149> 
  <OEMDRO150>0.</OEMDRO150> 
  <OEMLED150>0</OEMLED150> 
  <OEMDRO151>0.</OEMDRO151> 
  <OEMLED151>0</OEMLED151> 
  <OEMDRO152>0.</OEMDRO152> 
  <OEMLED152>0</OEMLED152> 
  <OEMDRO153>0.</OEMDRO153> 
  <OEMLED153>0</OEMLED153> 
  <OEMDRO154>0.</OEMDRO154> 
  <OEMLED154>0</OEMLED154> 
  <OEMDRO155>0.</OEMDRO155> 
  <OEMLED155>0</OEMLED155> 
  <OEMDRO156>0.</OEMDRO156> 
  <OEMLED156>0</OEMLED156> 
  <OEMDRO157>0.</OEMDRO157> 
  <OEMLED157>0</OEMLED157> 
  <OEMDRO158>0.</OEMDRO158> 
  <OEMLED158>0</OEMLED158> 
  <OEMDRO159>0.</OEMDRO159> 
  <OEMLED159>0</OEMLED159> 
  <OEMDRO160>0.</OEMDRO160> 
  <OEMLED160>0</OEMLED160> 
  <OEMDRO161>0.</OEMDRO161> 
  <OEMLED161>0</OEMLED161> 
  <OEMDRO162>0.</OEMDRO162> 
  <OEMLED162>0</OEMLED162> 
  <OEMDRO163>0.</OEMDRO163> 
  <OEMLED163>0</OEMLED163> 
  <OEMDRO164>0.</OEMDRO164> 
  <OEMLED164>0</OEMLED164> 
  <OEMDRO165>0.</OEMDRO165> 
  <OEMLED165>0</OEMLED165> 
  <OEMDRO166>0.</OEMDRO166> 
  <OEMLED166>0</OEMLED166> 
  <OEMDRO167>0.</OEMDRO167> 
  <OEMLED167>0</OEMLED167> 
  <OEMDRO168>0.</OEMDRO168> 
  <OEMLED168>0</OEMLED168> 
  <OEMDRO169>0.</OEMDRO169> 
  <OEMLED169>0</OEMLED169> 
  <OEMDRO170>0.</OEMDRO170> 
  <OEMLED170>0</OEMLED170> 
  <OEMDRO171>0.</OEMDRO171> 
  <OEMLED171>0</OEMLED171> 
  <OEMDRO172>0.</OEMDRO172> 
  <OEMLED172>0</OEMLED172> 
  <OEMDRO173>0.</OEMDRO173> 
  <OEMLED173>0</OEMLED173> 
  <OEMDRO174>0.</OEMDRO174> 
  <OEMLED174>0</OEMLED174> 
  <OEMDRO175>0.</OEMDRO175> 
  <OEMLED175>0</OEMLED175> 
  <OEMDRO176>0.</OEMDRO176> 
  <OEMLED176>0</OEMLED176> 
  <OEMDRO177>0.</OEMDRO177> 
  <OEMLED177>0</OEMLED177> 
  <OEMDRO178>0.</OEMDRO178> 
  <OEMLED178>0</OEMLED178> 
  <OEMDRO179>0.</OEMDRO179> 
  <OEMLED179>0</OEMLED179> 
  <OEMDRO180>0.</OEMDRO180> 
  <OEMLED180>0</OEMLED180> 
  <OEMDRO181>0.</OEMDRO181> 
  <OEMLED181>0</OEMLED181> 
  <OEMDRO182>0.</OEMDRO182> 
  <OEMLED182>0</OEMLED182> 
  <OEMDRO183>0.</OEMDRO183> 
  <OEMLED183>0</OEMLED183> 
  <OEMDRO184>0.</OEMDRO184> 
  <OEMLED184>0</OEMLED184> 
  <OEMDRO185>0.</OEMDRO185> 
  <OEMLED185>0</OEMLED185> 
  <OEMDRO186>0.</OEMDRO186> 
  <OEMLED186>0</OEMLED186> 
  <OEMDRO187>0.</OEMDRO187> 
  <OEMLED187>0</OEMLED187> 
  <OEMDRO188>0.</OEMDRO188> 
  <OEMLED188>0</OEMLED188> 
  <OEMDRO189>0.</OEMDRO189> 
  <OEMLED189>0</OEMLED189> 
  <OEMDRO190>0.</OEMDRO190> 
  <OEMLED190>0</OEMLED190> 
  <OEMDRO191>0.</OEMDRO191> 
  <OEMLED191>0</OEMLED191> 
  <OEMDRO192>0.</OEMDRO192> 
  <OEMLED192>0</OEMLED192> 
  <OEMDRO193>0.</OEMDRO193> 
  <OEMLED193>0</OEMLED193> 
  <OEMDRO194>0.</OEMDRO194> 
  <OEMLED194>0</OEMLED194> 
  <OEMDRO195>0.</OEMDRO195> 
  <OEMLED195>0</OEMLED195> 
  <OEMDRO196>0.</OEMDRO196> 
  <OEMLED196>0</OEMLED196> 
  <OEMDRO197>0.</OEMDRO197> 
  <OEMLED197>0</OEMLED197> 
  <OEMDRO198>0.</OEMDRO198> 
  <OEMLED198>0</OEMLED198> 
  <OEMDRO199>0.</OEMDRO199> 
  <OEMLED199>0</OEMLED199> 
  <OEMDRO200>0.</OEMDRO200> 
  <OEMLED200>0</OEMLED200> 
  <OEMDRO201>0.</OEMDRO201> 
  <OEMLED201>0</OEMLED201> 
  <OEMDRO202>0.</OEMDRO202> 
  <OEMLED202>0</OEMLED202> 
  <OEMDRO203>0.</OEMDRO203> 
  <OEMLED203>0</OEMLED203> 
  <OEMDRO204>0.</OEMDRO204> 
  <OEMLED204>0</OEMLED204> 
  <OEMDRO205>0.</OEMDRO205> 
  <OEMLED205>0</OEMLED205> 
  <OEMDRO206>0.</OEMDRO206> 
  <OEMLED206>0</OEMLED206> 
  <OEMDRO207>0.</OEMDRO207> 
  <OEMLED207>0</OEMLED207> 
  <OEMDRO208>0.</OEMDRO208> 
  <OEMLED208>0</OEMLED208> 
  <OEMDRO209>0.</OEMDRO209> 
  <OEMLED209>0</OEMLED209> 
  <OEMDRO210>0.</OEMDRO210> 
  <OEMLED210>0</OEMLED210> 
  <OEMDRO211>0.</OEMDRO211> 
  <OEMLED211>0</OEMLED211> 
  <OEMDRO212>0.</OEMDRO212> 
  <OEMLED212>0</OEMLED212> 
  <OEMDRO213>0.</OEMDRO213> 
  <OEMLED213>0</OEMLED213> 
  <OEMDRO214>0.</OEMDRO214> 
  <OEMLED214>0</OEMLED214> 
  <OEMDRO215>0.</OEMDRO215> 
  <OEMLED215>0</OEMLED215> 
  <OEMDRO216>0.</OEMDRO216> 
  <OEMLED216>0</OEMLED216> 
  <OEMDRO217>0.</OEMDRO217> 
  <OEMLED217>0</OEMLED217> 
  <OEMDRO218>0.</OEMDRO218> 
  <OEMLED218>0</OEMLED218> 
  <OEMDRO219>0.</OEMDRO219> 
  <OEMLED219>0</OEMLED219> 
  <OEMDRO220>0.</OEMDRO220> 
  <OEMLED220>0</OEMLED220> 
  <OEMDRO221>0.</OEMDRO221> 
  <OEMLED221>0</OEMLED221> 
  <OEMDRO222>0.</OEMDRO222> 
  <OEMLED222>0</OEMLED222> 
  <OEMDRO223>0.</OEMDRO223> 
  <OEMLED223>0</OEMLED223> 
  <OEMDRO224>0.</OEMDRO224> 
  <OEMLED224>0</OEMLED224> 
  <OEMDRO225>0.</OEMDRO225> 
  <OEMLED225>0</OEMLED225> 
  <OEMDRO226>0.</OEMDRO226> 
  <OEMLED226>0</OEMLED226> 
  <OEMDRO227>0.</OEMDRO227> 
  <OEMLED227>0</OEMLED227> 
  <OEMDRO228>0.</OEMDRO228> 
  <OEMLED228>0</OEMLED228> 
  <OEMDRO229>0.</OEMDRO229> 
  <OEMLED229>0</OEMLED229> 
  <OEMDRO230>0.</OEMDRO230> 
  <OEMLED230>0</OEMLED230> 
  <OEMDRO231>0.</OEMDRO231> 
  <OEMLED231>0</OEMLED231> 
  <OEMDRO232>0.</OEMDRO232> 
  <OEMLED232>0</OEMLED232> 
  <OEMDRO233>0.</OEMDRO233> 
  <OEMLED233>0</OEMLED233> 
  <OEMDRO234>0.</OEMDRO234> 
  <OEMLED234>0</OEMLED234> 
  <OEMDRO235>0.</OEMDRO235> 
  <OEMLED235>0</OEMLED235> 
  <OEMDRO236>0.</OEMDRO236> 
  <OEMLED236>0</OEMLED236> 
  <OEMDRO237>0.</OEMDRO237> 
  <OEMLED237>0</OEMLED237> 
  <OEMDRO238>0.</OEMDRO238> 
  <OEMLED238>0</OEMLED238> 
  <OEMDRO239>0.</OEMDRO239> 
  <OEMLED239>0</OEMLED239> 
  <OEMDRO240>0.</OEMDRO240> 
  <OEMLED240>0</OEMLED240> 
  <OEMDRO241>0.</OEMDRO241> 
  <OEMLED241>0</OEMLED241> 
  <OEMDRO242>0.</OEMDRO242> 
  <OEMLED242>0</OEMLED242> 
  <OEMDRO243>0.</OEMDRO243> 
  <OEMLED243>0</OEMLED243> 
  <OEMDRO244>0.</OEMDRO244> 
  <OEMLED244>0</OEMLED244> 
  <OEMDRO245>0.</OEMDRO245> 
  <OEMLED245>0</OEMLED245> 
  <OEMDRO246>0.</OEMDRO246> 
  <OEMLED246>0</OEMLED246> 
  <OEMDRO247>0.</OEMDRO247> 
  <OEMLED247>0</OEMLED247> 
  <OEMDRO248>0.</OEMDRO248> 
  <OEMLED248>0</OEMLED248> 
  <OEMDRO249>0.</OEMDRO249> 
  <OEMLED249>0</OEMLED249> 
  <OEMDRO250>0.</OEMDRO250> 
  <OEMLED250>0</OEMLED250> 
  <OEMDRO251>0.</OEMDRO251> 
  <OEMLED251>0</OEMLED251> 
  <OEMDRO252>0.</OEMDRO252> 
  <OEMLED252>0</OEMLED252> 
  <OEMDRO253>0.</OEMDRO253> 
  <OEMLED253>0</OEMLED253> 
  <OEMDRO254>0.</OEMDRO254> 
  <OEMLED254>0</OEMLED254> 
  <OEMDRO255>0.</OEMDRO255> 
  <OEMLED255>0</OEMLED255> 
  <OEMDRO2_0>0.</OEMDRO2_0> 
  <OEMLED2_0>0</OEMLED2_0> 
  <OEMDRO2_1>0.</OEMDRO2_1> 
  <OEMLED2_1>0</OEMLED2_1> 
  <OEMDRO2_2>0.</OEMDRO2_2> 
  <OEMLED2_2>0</OEMLED2_2> 
  <OEMDRO2_3>0.</OEMDRO2_3> 
  <OEMLED2_3>0</OEMLED2_3> 
  <OEMDRO2_4>0.</OEMDRO2_4> 
  <OEMLED2_4>0</OEMLED2_4> 
  <OEMDRO2_5>0.</OEMDRO2_5> 
  <OEMLED2_5>0</OEMLED2_5> 
  <OEMDRO2_6>0.</OEMDRO2_6> 
  <OEMLED2_6>0</OEMLED2_6> 
  <OEMDRO2_7>0.</OEMDRO2_7> 
  <OEMLED2_7>0</OEMLED2_7> 
  <OEMDRO2_8>0.</OEMDRO2_8> 
  <OEMLED2_8>0</OEMLED2_8> 
  <OEMDRO2_9>0.</OEMDRO2_9> 
  <OEMLED2_9>0</OEMLED2_9> 
  <OEMDRO2_10>0.</OEMDRO2_10> 
  <OEMLED2_10>0</OEMLED2_10> 
  <OEMDRO2_11>0.</OEMDRO2_11> 
  <OEMLED2_11>0</OEMLED2_11> 
  <OEMDRO2_12>0.</OEMDRO2_12> 
  <OEMLED2_12>0</OEMLED2_12> 
  <OEMDRO2_13>0.</OEMDRO2_13> 
  <OEMLED2_13>0</OEMLED2_13> 
  <OEMDRO2_14>0.</OEMDRO2_14> 
  <OEMLED2_14>0</OEMLED2_14> 
  <OEMDRO2_15>0.</OEMDRO2_15> 
  <OEMLED2_15>0</OEMLED2_15> 
  <OEMDRO2_16>0.</OEMDRO2_16> 
  <OEMLED2_16>0</OEMLED2_16> 
  <OEMDRO2_17>0.</OEMDRO2_17> 
  <OEMLED2_17>0</OEMLED2_17> 
  <OEMDRO2_18>0.</OEMDRO2_18> 
  <OEMLED2_18>0</OEMLED2_18> 
  <OEMDRO2_19>0.</OEMDRO2_19> 
  <OEMLED2_19>0</OEMLED2_19> 
  <OEMDRO2_20>0.</OEMDRO2_20> 
  <OEMLED2_20>0</OEMLED2_20> 
  <OEMDRO2_21>0.</OEMDRO2_21> 
  <OEMLED2_21>0</OEMLED2_21> 
  <OEMDRO2_22>0.</OEMDRO2_22> 
  <OEMLED2_22>0</OEMLED2_22> 
  <OEMDRO2_23>0.</OEMDRO2_23> 
  <OEMLED2_23>0</OEMLED2_23> 
  <OEMDRO2_24>0.</OEMDRO2_24> 
  <OEMLED2_24>0</OEMLED2_24> 
  <OEMDRO2_25>0.</OEMDRO2_25> 
  <OEMLED2_25>0</OEMLED2_25> 
  <OEMDRO2_26>0.</OEMDRO2_26> 
  <OEMLED2_26>0</OEMLED2_26> 
  <OEMDRO2_27>0.</OEMDRO2_27> 
  <OEMLED2_27>0</OEMLED2_27> 
  <OEMDRO2_28>0.</OEMDRO2_28> 
  <OEMLED2_28>0</OEMLED2_28> 
  <OEMDRO2_29>0.</OEMDRO2_29> 
  <OEMLED2_29>0</OEMLED2_29> 
  <OEMDRO2_30>0.</OEMDRO2_30> 
  <OEMLED2_30>0</OEMLED2_30> 
  <OEMDRO2_31>0.</OEMDRO2_31> 
  <OEMLED2_31>0</OEMLED2_31> 
  <OEMDRO2_32>0.</OEMDRO2_32> 
  <OEMLED2_32>0</OEMLED2_32> 
  <OEMDRO2_33>0.</OEMDRO2_33> 
  <OEMLED2_33>0</OEMLED2_33> 
  <OEMDRO2_34>0.</OEMDRO2_34> 
  <OEMLED2_34>0</OEMLED2_34> 
  <OEMDRO2_35>0.</OEMDRO2_35> 
  <OEMLED2_35>0</OEMLED2_35> 
  <OEMDRO2_36>0.</OEMDRO2_36> 
  <OEMLED2_36>0</OEMLED2_36> 
  <OEMDRO2_37>0.</OEMDRO2_37> 
  <OEMLED2_37>0</OEMLED2_37> 
  <OEMDRO2_38>0.</OEMDRO2_38> 
  <OEMLED2_38>0</OEMLED2_38> 
  <OEMDRO2_39>0.</OEMDRO2_39> 
  <OEMLED2_39>0</OEMLED2_39> 
  <OEMDRO2_40>0.</OEMDRO2_40> 
  <OEMLED2_40>0</OEMLED2_40> 
  <OEMDRO2_41>0.</OEMDRO2_41> 
  <OEMLED2_41>0</OEMLED2_41> 
  <OEMDRO2_42>0.</OEMDRO2_42> 
  <OEMLED2_42>0</OEMLED2_42> 
  <OEMDRO2_43>0.</OEMDRO2_43> 
  <OEMLED2_43>0</OEMLED2_43> 
  <OEMDRO2_44>0.</OEMDRO2_44> 
  <OEMLED2_44>0</OEMLED2_44> 
  <OEMDRO2_45>0.</OEMDRO2_45> 
  <OEMLED2_45>0</OEMLED2_45> 
  <OEMDRO2_46>0.</OEMDRO2_46> 
  <OEMLED2_46>0</OEMLED2_46> 
  <OEMDRO2_47>0.</OEMDRO2_47> 
  <OEMLED2_47>0</OEMLED2_47> 
  <OEMDRO2_48>0.</OEMDRO2_48> 
  <OEMLED2_48>0</OEMLED2_48> 
  <OEMDRO2_49>0.</OEMDRO2_49> 
  <OEMLED2_49>0</OEMLED2_49> 
  <OEMDRO2_50>0.</OEMDRO2_50> 
  <OEMLED2_50>0</OEMLED2_50> 
  <OEMDRO2_51>0.</OEMDRO2_51> 
  <OEMLED2_51>0</OEMLED2_51> 
  <OEMDRO2_52>0.</OEMDRO2_52> 
  <OEMLED2_52>0</OEMLED2_52> 
  <OEMDRO2_53>0.</OEMDRO2_53> 
  <OEMLED2_53>0</OEMLED2_53> 
  <OEMDRO2_54>0.</OEMDRO2_54> 
  <OEMLED2_54>0</OEMLED2_54> 
  <OEMDRO2_55>0.</OEMDRO2_55> 
  <OEMLED2_55>0</OEMLED2_55> 
  <OEMDRO2_56>0.</OEMDRO2_56> 
  <OEMLED2_56>0</OEMLED2_56> 
  <OEMDRO2_57>0.</OEMDRO2_57> 
  <OEMLED2_57>0</OEMLED2_57> 
  <OEMDRO2_58>0.</OEMDRO2_58> 
  <OEMLED2_58>0</OEMLED2_58> 
  <OEMDRO2_59>0.</OEMDRO2_59> 
  <OEMLED2_59>0</OEMLED2_59> 
  <OEMDRO2_60>0.</OEMDRO2_60> 
  <OEMLED2_60>0</OEMLED2_60> 
  <OEMDRO2_61>0.</OEMDRO2_61> 
  <OEMLED2_61>0</OEMLED2_61> 
  <OEMDRO2_62>0.</OEMDRO2_62> 
  <OEMLED2_62>0</OEMLED2_62> 
  <OEMDRO2_63>0.</OEMDRO2_63> 
  <OEMLED2_63>0</OEMLED2_63> 
  <OEMDRO2_64>0.</OEMDRO2_64> 
  <OEMLED2_64>0</OEMLED2_64> 
  <OEMDRO2_65>0.</OEMDRO2_65> 
  <OEMLED2_65>0</OEMLED2_65> 
  <OEMDRO2_66>0.</OEMDRO2_66> 
  <OEMLED2_66>0</OEMLED2_66> 
  <OEMDRO2_67>0.</OEMDRO2_67> 
  <OEMLED2_67>0</OEMLED2_67> 
  <OEMDRO2_68>0.</OEMDRO2_68> 
  <OEMLED2_68>0</OEMLED2_68> 
  <OEMDRO2_69>0.</OEMDRO2_69> 
  <OEMLED2_69>0</OEMLED2_69> 
  <OEMDRO2_70>0.</OEMDRO2_70> 
  <OEMLED2_70>0</OEMLED2_70> 
  <OEMDRO2_71>0.</OEMDRO2_71> 
  <OEMLED2_71>0</OEMLED2_71> 
  <OEMDRO2_72>0.</OEMDRO2_72> 
  <OEMLED2_72>0</OEMLED2_72> 
  <OEMDRO2_73>0.</OEMDRO2_73> 
  <OEMLED2_73>0</OEMLED2_73> 
  <OEMDRO2_74>0.</OEMDRO2_74> 
  <OEMLED2_74>0</OEMLED2_74> 
  <OEMDRO2_75>0.</OEMDRO2_75> 
  <OEMLED2_75>0</OEMLED2_75> 
  <OEMDRO2_76>0.</OEMDRO2_76> 
  <OEMLED2_76>0</OEMLED2_76> 
  <OEMDRO2_77>0.</OEMDRO2_77> 
  <OEMLED2_77>0</OEMLED2_77> 
  <OEMDRO2_78>0.</OEMDRO2_78> 
  <OEMLED2_78>0</OEMLED2_78> 
  <OEMDRO2_79>0.</OEMDRO2_79> 
  <OEMLED2_79>0</OEMLED2_79> 
  <OEMDRO2_80>0.</OEMDRO2_80> 
  <OEMLED2_80>0</OEMLED2_80> 
  <OEMDRO2_81>0.</OEMDRO2_81> 
  <OEMLED2_81>0</OEMLED2_81> 
  <OEMDRO2_82>0.</OEMDRO2_82> 
  <OEMLED2_82>0</OEMLED2_82> 
  <OEMDRO2_83>0.</OEMDRO2_83> 
  <OEMLED2_83>0</OEMLED2_83> 
  <OEMDRO2_84>0.</OEMDRO2_84> 
  <OEMLED2_84>0</OEMLED2_84> 
  <OEMDRO2_85>0.</OEMDRO2_85> 
  <OEMLED2_85>0</OEMLED2_85> 
  <OEMDRO2_86>0.</OEMDRO2_86> 
  <OEMLED2_86>0</OEMLED2_86> 
  <OEMDRO2_87>0.</OEMDRO2_87> 
  <OEMLED2_87>0</OEMLED2_87> 
  <OEMDRO2_88>0.</OEMDRO2_88> 
  <OEMLED2_88>0</OEMLED2_88> 
  <OEMDRO2_89>0.</OEMDRO2_89> 
  <OEMLED2_89>0</OEMLED2_89> 
  <OEMDRO2_90>0.</OEMDRO2_90> 
  <OEMLED2_90>0</OEMLED2_90> 
  <OEMDRO2_91>0.</OEMDRO2_91> 
  <OEMLED2_91>0</OEMLED2_91> 
  <OEMDRO2_92>0.</OEMDRO2_92> 
  <OEMLED2_92>0</OEMLED2_92> 
  <OEMDRO2_93>0.</OEMDRO2_93> 
  <OEMLED2_93>0</OEMLED2_93> 
  <OEMDRO2_94>0.</OEMDRO2_94> 
  <OEMLED2_94>0</OEMLED2_94> 
  <OEMDRO2_95>0.</OEMDRO2_95> 
  <OEMLED2_95>0</OEMLED2_95> 
  <OEMDRO2_96>0.</OEMDRO2_96> 
  <OEMLED2_96>0</OEMLED2_96> 
  <OEMDRO2_97>0.</OEMDRO2_97> 
  <OEMLED2_97>0</OEMLED2_97> 
  <OEMDRO2_98>0.</OEMDRO2_98> 
  <OEMLED2_98>0</OEMLED2_98> 
  <OEMDRO2_99>0.</OEMDRO2_99> 
  <OEMLED2_99>0</OEMLED2_99> 
  <OEMDRO2_100>0.</OEMDRO2_100> 
  <OEMLED2_100>0</OEMLED2_100> 
  <OEMDRO2_101>0.</OEMDRO2_101> 
  <OEMLED2_101>0</OEMLED2_101> 
  <OEMDRO2_102>0.</OEMDRO2_102> 
  <OEMLED2_102>0</OEMLED2_102> 
  <OEMDRO2_103>0.</OEMDRO2_103> 
  <OEMLED2_103>0</OEMLED2_103> 
  <OEMDRO2_104>0.</OEMDRO2_104> 
  <OEMLED2_104>0</OEMLED2_104> 
  <OEMDRO2_105>0.</OEMDRO2_105> 
  <OEMLED2_105>0</OEMLED2_105> 
  <OEMDRO2_106>0.</OEMDRO2_106> 
  <OEMLED2_106>0</OEMLED2_106> 
  <OEMDRO2_107>0.</OEMDRO2_107> 
  <OEMLED2_107>0</OEMLED2_107> 
  <OEMDRO2_108>0.</OEMDRO2_108> 
  <OEMLED2_108>0</OEMLED2_108> 
  <OEMDRO2_109>0.</OEMDRO2_109> 
  <OEMLED2_109>0</OEMLED2_109> 
  <OEMDRO2_110>0.</OEMDRO2_110> 
  <OEMLED2_110>0</OEMLED2_110> 
  <OEMDRO2_111>0.</OEMDRO2_111> 
  <OEMLED2_111>0</OEMLED2_111> 
  <OEMDRO2_112>0.</OEMDRO2_112> 
  <OEMLED2_112>0</OEMLED2_112> 
  <OEMDRO2_113>0.</OEMDRO2_113> 
  <OEMLED2_113>0</OEMLED2_113> 
  <OEMDRO2_114>0.</OEMDRO2_114> 
  <OEMLED2_114>0</OEMLED2_114> 
  <OEMDRO2_115>0.</OEMDRO2_115> 
  <OEMLED2_115>0</OEMLED2_115> 
  <OEMDRO2_116>0.</OEMDRO2_116> 
  <OEMLED2_116>0</OEMLED2_116> 
  <OEMDRO2_117>0.</OEMDRO2_117> 
  <OEMLED2_117>0</OEMLED2_117> 
  <OEMDRO2_118>0.</OEMDRO2_118> 
  <OEMLED2_118>0</OEMLED2_118> 
  <OEMDRO2_119>0.</OEMDRO2_119> 
  <OEMLED2_119>0</OEMLED2_119> 
  <OEMDRO2_120>0.</OEMDRO2_120> 
  <OEMLED2_120>0</OEMLED2_120> 
  <OEMDRO2_121>0.</OEMDRO2_121> 
  <OEMLED2_121>0</OEMLED2_121> 
  <OEMDRO2_122>0.</OEMDRO2_122> 
  <OEMLED2_122>0</OEMLED2_122> 
  <OEMDRO2_123>0.</OEMDRO2_123> 
  <OEMLED2_123>0</OEMLED2_123> 
  <OEMDRO2_124>0.</OEMDRO2_124> 
  <OEMLED2_124>0</OEMLED2_124> 
  <OEMDRO2_125>0.</OEMDRO2_125> 
  <OEMLED2_125>0</OEMLED2_125> 
  <OEMDRO2_126>0.</OEMDRO2_126> 
  <OEMLED2_126>0</OEMLED2_126> 
  <OEMDRO2_127>0.</OEMDRO2_127> 
  <OEMLED2_127>0</OEMLED2_127> 
  <OEMDRO2_128>0.</OEMDRO2_128> 
  <OEMLED2_128>0</OEMLED2_128> 
  <OEMDRO2_129>0.</OEMDRO2_129> 
  <OEMLED2_129>0</OEMLED2_129> 
  <OEMDRO2_130>0.</OEMDRO2_130> 
  <OEMLED2_130>0</OEMLED2_130> 
  <OEMDRO2_131>0.</OEMDRO2_131> 
  <OEMLED2_131>0</OEMLED2_131> 
  <OEMDRO2_132>0.</OEMDRO2_132> 
  <OEMLED2_132>0</OEMLED2_132> 
  <OEMDRO2_133>0.</OEMDRO2_133> 
  <OEMLED2_133>0</OEMLED2_133> 
  <OEMDRO2_134>0.</OEMDRO2_134> 
  <OEMLED2_134>0</OEMLED2_134> 
  <OEMDRO2_135>0.</OEMDRO2_135> 
  <OEMLED2_135>0</OEMLED2_135> 
  <OEMDRO2_136>0.</OEMDRO2_136> 
  <OEMLED2_136>0</OEMLED2_136> 
  <OEMDRO2_137>0.</OEMDRO2_137> 
  <OEMLED2_137>0</OEMLED2_137> 
  <OEMDRO2_138>0.</OEMDRO2_138> 
  <OEMLED2_138>0</OEMLED2_138> 
  <OEMDRO2_139>0.</OEMDRO2_139> 
  <OEMLED2_139>0</OEMLED2_139> 
  <OEMDRO2_140>0.</OEMDRO2_140> 
  <OEMLED2_140>0</OEMLED2_140> 
  <OEMDRO2_141>0.</OEMDRO2_141> 
  <OEMLED2_141>0</OEMLED2_141> 
  <OEMDRO2_142>0.</OEMDRO2_142> 
  <OEMLED2_142>0</OEMLED2_142> 
  <OEMDRO2_143>0.</OEMDRO2_143> 
  <OEMLED2_143>0</OEMLED2_143> 
  <OEMDRO2_144>0.</OEMDRO2_144> 
  <OEMLED2_144>0</OEMLED2_144> 
  <OEMDRO2_145>0.</OEMDRO2_145> 
  <OEMLED2_145>0</OEMLED2_145> 
  <OEMDRO2_146>0.</OEMDRO2_146> 
  <OEMLED2_146>0</OEMLED2_146> 
  <OEMDRO2_147>0.</OEMDRO2_147> 
  <OEMLED2_147>0</OEMLED2_147> 
  <OEMDRO2_148>0.</OEMDRO2_148> 
  <OEMLED2_148>0</OEMLED2_148> 
  <OEMDRO2_149>0.</OEMDRO2_149> 
  <OEMLED2_149>0</OEMLED2_149> 
  <OEMDRO2_150>0.</OEMDRO2_150> 
  <OEMLED2_150>0</OEMLED2_150> 
  <OEMDRO2_151>0.</OEMDRO2_151> 
  <OEMLED2_151>0</OEMLED2_151> 
  <OEMDRO2_152>0.</OEMDRO2_152> 
  <OEMLED2_152>0</OEMLED2_152> 
  <OEMDRO2_153>0.</OEMDRO2_153> 
  <OEMLED2_153>0</OEMLED2_153> 
  <OEMDRO2_154>0.</OEMDRO2_154> 
  <OEMLED2_154>0</OEMLED2_154> 
  <OEMDRO2_155>0.</OEMDRO2_155> 
  <OEMLED2_155>0</OEMLED2_155> 
  <OEMDRO2_156>0.</OEMDRO2_156> 
  <OEMLED2_156>0</OEMLED2_156> 
  <OEMDRO2_157>0.</OEMDRO2_157> 
  <OEMLED2_157>0</OEMLED2_157> 
  <OEMDRO2_158>0.</OEMDRO2_158> 
  <OEMLED2_158>0</OEMLED2_158> 
  <OEMDRO2_159>0.</OEMDRO2_159> 
  <OEMLED2_159>0</OEMLED2_159> 
  <OEMDRO2_160>0.</OEMDRO2_160> 
  <OEMLED2_160>0</OEMLED2_160> 
  <OEMDRO2_161>0.</OEMDRO2_161> 
  <OEMLED2_161>0</OEMLED2_161> 
  <OEMDRO2_162>0.</OEMDRO2_162> 
  <OEMLED2_162>0</OEMLED2_162> 
  <OEMDRO2_163>0.</OEMDRO2_163> 
  <OEMLED2_163>0</OEMLED2_163> 
  <OEMDRO2_164>0.</OEMDRO2_164> 
  <OEMLED2_164>0</OEMLED2_164> 
  <OEMDRO2_165>0.</OEMDRO2_165> 
  <OEMLED2_165>0</OEMLED2_165> 
  <OEMDRO2_166>0.</OEMDRO2_166> 
  <OEMLED2_166>0</OEMLED2_166> 
  <OEMDRO2_167>0.</OEMDRO2_167> 
  <OEMLED2_167>0</OEMLED2_167> 
  <OEMDRO2_168>0.</OEMDRO2_168> 
  <OEMLED2_168>0</OEMLED2_168> 
  <OEMDRO2_169>0.</OEMDRO2_169> 
  <OEMLED2_169>0</OEMLED2_169> 
  <OEMDRO2_170>0.</OEMDRO2_170> 
  <OEMLED2_170>0</OEMLED2_170> 
  <OEMDRO2_171>0.</OEMDRO2_171> 
  <OEMLED2_171>0</OEMLED2_171> 
  <OEMDRO2_172>0.</OEMDRO2_172> 
  <OEMLED2_172>0</OEMLED2_172> 
  <OEMDRO2_173>0.</OEMDRO2_173> 
  <OEMLED2_173>0</OEMLED2_173> 
  <OEMDRO2_174>0.</OEMDRO2_174> 
  <OEMLED2_174>0</OEMLED2_174> 
  <OEMDRO2_175>0.</OEMDRO2_175> 
  <OEMLED2_175>0</OEMLED2_175> 
  <OEMDRO2_176>0.</OEMDRO2_176> 
  <OEMLED2_176>0</OEMLED2_176> 
  <OEMDRO2_177>0.</OEMDRO2_177> 
  <OEMLED2_177>0</OEMLED2_177> 
  <OEMDRO2_178>0.</OEMDRO2_178> 
  <OEMLED2_178>0</OEMLED2_178> 
  <OEMDRO2_179>0.</OEMDRO2_179> 
  <OEMLED2_179>0</OEMLED2_179> 
  <OEMDRO2_180>0.</OEMDRO2_180> 
  <OEMLED2_180>0</OEMLED2_180> 
  <OEMDRO2_181>0.</OEMDRO2_181> 
  <OEMLED2_181>0</OEMLED2_181> 
  <OEMDRO2_182>0.</OEMDRO2_182> 
  <OEMLED2_182>0</OEMLED2_182> 
  <OEMDRO2_183>0.</OEMDRO2_183> 
  <OEMLED2_183>0</OEMLED2_183> 
  <OEMDRO2_184>0.</OEMDRO2_184> 
  <OEMLED2_184>0</OEMLED2_184> 
  <OEMDRO2_185>0.</OEMDRO2_185> 
  <OEMLED2_185>0</OEMLED2_185> 
  <OEMDRO2_186>0.</OEMDRO2_186> 
  <OEMLED2_186>0</OEMLED2_186> 
  <OEMDRO2_187>0.</OEMDRO2_187> 
  <OEMLED2_187>0</OEMLED2_187> 
  <OEMDRO2_188>0.</OEMDRO2_188> 
  <OEMLED2_188>0</OEMLED2_188> 
  <OEMDRO2_189>0.</OEMDRO2_189> 
  <OEMLED2_189>0</OEMLED2_189> 
  <OEMDRO2_190>0.</OEMDRO2_190> 
  <OEMLED2_190>0</OEMLED2_190> 
  <OEMDRO2_191>0.</OEMDRO2_191> 
  <OEMLED2_191>0</OEMLED2_191> 
  <OEMDRO2_192>0.</OEMDRO2_192> 
  <OEMLED2_192>0</OEMLED2_192> 
  <OEMDRO2_193>0.</OEMDRO2_193> 
  <OEMLED2_193>0</OEMLED2_193> 
  <OEMDRO2_194>0.</OEMDRO2_194> 
  <OEMLED2_194>0</OEMLED2_194> 
  <OEMDRO2_195>0.</OEMDRO2_195> 
  <OEMLED2_195>0</OEMLED2_195> 
  <OEMDRO2_196>0.</OEMDRO2_196> 
  <OEMLED2_196>0</OEMLED2_196> 
  <OEMDRO2_197>0.</OEMDRO2_197> 
  <OEMLED2_197>0</OEMLED2_197> 
  <OEMDRO2_198>0.</OEMDRO2_198> 
  <OEMLED2_198>0</OEMLED2_198> 
  <OEMDRO2_199>0.</OEMDRO2_199> 
  <OEMLED2_199>0</OEMLED2_199> 
  <OEMDRO2_200>0.</OEMDRO2_200> 
  <OEMLED2_200>0</OEMLED2_200> 
  <OEMDRO2_201>0.</OEMDRO2_201> 
  <OEMLED2_201>0</OEMLED2_201> 
  <OEMDRO2_202>0.</OEMDRO2_202> 
  <OEMLED2_202>0</OEMLED2_202> 
  <OEMDRO2_203>0.</OEMDRO2_203> 
  <OEMLED2_203>0</OEMLED2_203> 
  <OEMDRO2_204>0.</OEMDRO2_204> 
  <OEMLED2_204>0</OEMLED2_204> 
  <OEMDRO2_205>0.</OEMDRO2_205> 
  <OEMLED2_205>0</OEMLED2_205> 
  <OEMDRO2_206>0.</OEMDRO2_206> 
  <OEMLED2_206>0</OEMLED2_206> 
  <OEMDRO2_207>0.</OEMDRO2_207> 
  <OEMLED2_207>0</OEMLED2_207> 
  <OEMDRO2_208>0.</OEMDRO2_208> 
  <OEMLED2_208>0</OEMLED2_208> 
  <OEMDRO2_209>0.</OEMDRO2_209> 
  <OEMLED2_209>0</OEMLED2_209> 
  <OEMDRO2_210>0.</OEMDRO2_210> 
  <OEMLED2_210>0</OEMLED2_210> 
  <OEMDRO2_211>0.</OEMDRO2_211> 
  <OEMLED2_211>0</OEMLED2_211> 
  <OEMDRO2_212>0.</OEMDRO2_212> 
  <OEMLED2_212>0</OEMLED2_212> 
  <OEMDRO2_213>0.</OEMDRO2_213> 
  <OEMLED2_213>0</OEMLED2_213> 
  <OEMDRO2_214>0.</OEMDRO2_214> 
  <OEMLED2_214>0</OEMLED2_214> 
  <OEMDRO2_215>0.</OEMDRO2_215> 
  <OEMLED2_215>0</OEMLED2_215> 
  <OEMDRO2_216>0.</OEMDRO2_216> 
  <OEMLED2_216>0</OEMLED2_216> 
  <OEMDRO2_217>0.</OEMDRO2_217> 
  <OEMLED2_217>0</OEMLED2_217> 
  <OEMDRO2_218>0.</OEMDRO2_218> 
  <OEMLED2_218>0</OEMLED2_218> 
  <OEMDRO2_219>0.</OEMDRO2_219> 
  <OEMLED2_219>0</OEMLED2_219> 
  <OEMDRO2_220>0.</OEMDRO2_220> 
  <OEMLED2_220>0</OEMLED2_220> 
  <OEMDRO2_221>0.</OEMDRO2_221> 
  <OEMLED2_221>0</OEMLED2_221> 
  <OEMDRO2_222>0.</OEMDRO2_222> 
  <OEMLED2_222>0</OEMLED2_222> 
  <OEMDRO2_223>0.</OEMDRO2_223> 
  <OEMLED2_223>0</OEMLED2_223> 
  <OEMDRO2_224>0.</OEMDRO2_224> 
  <OEMLED2_224>0</OEMLED2_224> 
  <OEMDRO2_225>0.</OEMDRO2_225> 
  <OEMLED2_225>0</OEMLED2_225> 
  <OEMDRO2_226>0.</OEMDRO2_226> 
  <OEMLED2_226>0</OEMLED2_226> 
  <OEMDRO2_227>0.</OEMDRO2_227> 
  <OEMLED2_227>0</OEMLED2_227> 
  <OEMDRO2_228>0.</OEMDRO2_228> 
  <OEMLED2_228>0</OEMLED2_228> 
  <OEMDRO2_229>0.</OEMDRO2_229> 
  <OEMLED2_229>0</OEMLED2_229> 
  <OEMDRO2_230>0.</OEMDRO2_230> 
  <OEMLED2_230>0</OEMLED2_230> 
  <OEMDRO2_231>0.</OEMDRO2_231> 
  <OEMLED2_231>0</OEMLED2_231> 
  <OEMDRO2_232>0.</OEMDRO2_232> 
  <OEMLED2_232>0</OEMLED2_232> 
  <OEMDRO2_233>0.</OEMDRO2_233> 
  <OEMLED2_233>0</OEMLED2_233> 
  <OEMDRO2_234>0.</OEMDRO2_234> 
  <OEMLED2_234>0</OEMLED2_234> 
  <OEMDRO2_235>0.</OEMDRO2_235> 
  <OEMLED2_235>0</OEMLED2_235> 
  <OEMDRO2_236>0.</OEMDRO2_236> 
  <OEMLED2_236>0</OEMLED2_236> 
  <OEMDRO2_237>0.</OEMDRO2_237> 
  <OEMLED2_237>0</OEMLED2_237> 
  <OEMDRO2_238>0.</OEMDRO2_238> 
  <OEMLED2_238>0</OEMLED2_238> 
  <OEMDRO2_239>0.</OEMDRO2_239> 
  <OEMLED2_239>0</OEMLED2_239> 
  <OEMDRO2_240>0.</OEMDRO2_240> 
  <OEMLED2_240>0</OEMLED2_240> 
  <OEMDRO2_241>0.</OEMDRO2_241> 
  <OEMLED2_241>0</OEMLED2_241> 
  <OEMDRO2_242>0.</OEMDRO2_242> 
  <OEMLED2_242>0</OEMLED2_242> 
  <OEMDRO2_243>0.</OEMDRO2_243> 
  <OEMLED2_243>0</OEMLED2_243> 
  <OEMDRO2_244>0.</OEMDRO2_244> 
  <OEMLED2_244>0</OEMLED2_244> 
  <OEMDRO2_245>0.</OEMDRO2_245> 
  <OEMLED2_245>0</OEMLED2_245> 
  <OEMDRO2_246>0.</OEMDRO2_246> 
  <OEMLED2_246>0</OEMLED2_246> 
  <OEMDRO2_247>0.</OEMDRO2_247> 
  <OEMLED2_247>0</OEMLED2_247> 
  <OEMDRO2_248>0.</OEMDRO2_248> 
  <OEMLED2_248>0</OEMLED2_248> 
  <OEMDRO2_249>0.</OEMDRO2_249> 
  <OEMLED2_249>0</OEMLED2_249> 
  <OEMDRO2_250>0.</OEMDRO2_250> 
  <OEMLED2_250>0</OEMLED2_250> 
  <OEMDRO2_251>0.</OEMDRO2_251> 
  <OEMLED2_251>0</OEMLED2_251> 
  <OEMDRO2_252>0.</OEMDRO2_252> 
  <OEMLED2_252>0</OEMLED2_252> 
  <OEMDRO2_253>0.</OEMDRO2_253> 
  <OEMLED2_253>0</OEMLED2_253> 
  <OEMDRO2_254>0.</OEMDRO2_254> 
  <OEMLED2_254>0</OEMLED2_254> 
  <OEMDRO2_255>0.</OEMDRO2_255> 
  <OEMLED2_255>0</OEMLED2_255> 
  <OEMDRO2_256>0.</OEMDRO2_256> 
  <OEMLED2_256>0</OEMLED2_256> 
  <OEMDRO2_257>0.</OEMDRO2_257> 
  <OEMLED2_257>0</OEMLED2_257> 
  <OEMDRO2_258>0.</OEMDRO2_258> 
  <OEMLED2_258>0</OEMLED2_258> 
  <OEMDRO2_259>0.</OEMDRO2_259> 
  <OEMLED2_259>0</OEMLED2_259> 
  <OEMDRO2_260>0.</OEMDRO2_260> 
  <OEMLED2_260>0</OEMLED2_260> 
  <OEMDRO2_261>0.</OEMDRO2_261> 
  <OEMLED2_261>0</OEMLED2_261> 
  <OEMDRO2_262>0.</OEMDRO2_262> 
  <OEMLED2_262>0</OEMLED2_262> 
  <OEMDRO2_263>0.</OEMDRO2_263> 
  <OEMLED2_263>0</OEMLED2_263> 
  <OEMDRO2_264>0.</OEMDRO2_264> 
  <OEMLED2_264>0</OEMLED2_264> 
  <OEMDRO2_265>0.</OEMDRO2_265> 
  <OEMLED2_265>0</OEMLED2_265> 
  <OEMDRO2_266>0.</OEMDRO2_266> 
  <OEMLED2_266>0</OEMLED2_266> 
  <OEMDRO2_267>0.</OEMDRO2_267> 
  <OEMLED2_267>0</OEMLED2_267> 
  <OEMDRO2_268>0.</OEMDRO2_268> 
  <OEMLED2_268>0</OEMLED2_268> 
  <OEMDRO2_269>0.</OEMDRO2_269> 
  <OEMLED2_269>0</OEMLED2_269> 
  <OEMDRO2_270>0.</OEMDRO2_270> 
  <OEMLED2_270>0</OEMLED2_270> 
  <OEMDRO2_271>0.</OEMDRO2_271> 
  <OEMLED2_271>0</OEMLED2_271> 
  <OEMDRO2_272>0.</OEMDRO2_272> 
  <OEMLED2_272>0</OEMLED2_272> 
  <OEMDRO2_273>0.</OEMDRO2_273> 
  <OEMLED2_273>0</OEMLED2_273> 
  <OEMDRO2_274>0.</OEMDRO2_274> 
  <OEMLED2_274>0</OEMLED2_274> 
  <OEMDRO2_275>0.</OEMDRO2_275> 
  <OEMLED2_275>0</OEMLED2_275> 
  <OEMDRO2_276>0.</OEMDRO2_276> 
  <OEMLED2_276>0</OEMLED2_276> 
  <OEMDRO2_277>0.</OEMDRO2_277> 
  <OEMLED2_277>0</OEMLED2_277> 
  <OEMDRO2_278>0.</OEMDRO2_278> 
  <OEMLED2_278>0</OEMLED2_278> 
  <OEMDRO2_279>0.</OEMDRO2_279> 
  <OEMLED2_279>0</OEMLED2_279> 
  <OEMDRO2_280>0.</OEMDRO2_280> 
  <OEMLED2_280>0</OEMLED2_280> 
  <OEMDRO2_281>0.</OEMDRO2_281> 
  <OEMLED2_281>0</OEMLED2_281> 
  <OEMDRO2_282>0.</OEMDRO2_282> 
  <OEMLED2_282>0</OEMLED2_282> 
  <OEMDRO2_283>0.</OEMDRO2_283> 
  <OEMLED2_283>0</OEMLED2_283> 
  <OEMDRO2_284>0.</OEMDRO2_284> 
  <OEMLED2_284>0</OEMLED2_284> 
  <OEMDRO2_285>0.</OEMDRO2_285> 
  <OEMLED2_285>0</OEMLED2_285> 
  <OEMDRO2_286>0.</OEMDRO2_286> 
  <OEMLED2_286>0</OEMLED2_286> 
  <OEMDRO2_287>0.</OEMDRO2_287> 
  <OEMLED2_287>0</OEMLED2_287> 
  <OEMDRO2_288>0.</OEMDRO2_288> 
  <OEMLED2_288>0</OEMLED2_288> 
  <OEMDRO2_289>0.</OEMDRO2_289> 
  <OEMLED2_289>0</OEMLED2_289> 
  <OEMDRO2_290>0.</OEMDRO2_290> 
  <OEMLED2_290>0</OEMLED2_290> 
  <OEMDRO2_291>0.</OEMDRO2_291> 
  <OEMLED2_291>0</OEMLED2_291> 
  <OEMDRO2_292>0.</OEMDRO2_292> 
  <OEMLED2_292>0</OEMLED2_292> 
  <OEMDRO2_293>0.</OEMDRO2_293> 
  <OEMLED2_293>0</OEMLED2_293> 
  <OEMDRO2_294>0.</OEMDRO2_294> 
  <OEMLED2_294>0</OEMLED2_294> 
  <OEMDRO2_295>0.</OEMDRO2_295> 
  <OEMLED2_295>0</OEMLED2_295> 
  <OEMDRO2_296>0.</OEMDRO2_296> 
  <OEMLED2_296>0</OEMLED2_296> 
  <OEMDRO2_297>0.</OEMDRO2_297> 
  <OEMLED2_297>0</OEMLED2_297> 
  <OEMDRO2_298>0.</OEMDRO2_298> 
  <OEMLED2_298>0</OEMLED2_298> 
  <OEMDRO2_299>0.</OEMDRO2_299> 
  <OEMLED2_299>0</OEMLED2_299> 
  <OEMDRO2_300>0.</OEMDRO2_300> 
  <OEMLED2_300>0</OEMLED2_300> 
  <OEMDRO2_301>0.</OEMDRO2_301> 
  <OEMLED2_301>0</OEMLED2_301> 
  <OEMDRO2_302>0.</OEMDRO2_302> 
  <OEMLED2_302>0</OEMLED2_302> 
  <OEMDRO2_303>0.</OEMDRO2_303> 
  <OEMLED2_303>0</OEMLED2_303> 
  <OEMDRO2_304>0.</OEMDRO2_304> 
  <OEMLED2_304>0</OEMLED2_304> 
  <OEMDRO2_305>0.</OEMDRO2_305> 
  <OEMLED2_305>0</OEMLED2_305> 
  <OEMDRO2_306>0.</OEMDRO2_306> 
  <OEMLED2_306>0</OEMLED2_306> 
  <OEMDRO2_307>0.</OEMDRO2_307> 
  <OEMLED2_307>0</OEMLED2_307> 
  <OEMDRO2_308>0.</OEMDRO2_308> 
  <OEMLED2_308>0</OEMLED2_308> 
  <OEMDRO2_309>0.</OEMDRO2_309> 
  <OEMLED2_309>0</OEMLED2_309> 
  <OEMDRO2_310>0.</OEMDRO2_310> 
  <OEMLED2_310>0</OEMLED2_310> 
  <OEMDRO2_311>0.</OEMDRO2_311> 
  <OEMLED2_311>0</OEMLED2_311> 
  <OEMDRO2_312>0.</OEMDRO2_312> 
  <OEMLED2_312>0</OEMLED2_312> 
  <OEMDRO2_313>0.</OEMDRO2_313> 
  <OEMLED2_313>0</OEMLED2_313> 
  <OEMDRO2_314>0.</OEMDRO2_314> 
  <OEMLED2_314>0</OEMLED2_314> 
  <OEMDRO2_315>0.</OEMDRO2_315> 
  <OEMLED2_315>0</OEMLED2_315> 
  <OEMDRO2_316>0.</OEMDRO2_316> 
  <OEMLED2_316>0</OEMLED2_316> 
  <OEMDRO2_317>0.</OEMDRO2_317> 
  <OEMLED2_317>0</OEMLED2_317> 
  <OEMDRO2_318>0.</OEMDRO2_318> 
  <OEMLED2_318>0</OEMLED2_318> 
  <OEMDRO2_319>0.</OEMDRO2_319> 
  <OEMLED2_319>0</OEMLED2_319> 
  <OEMDRO2_320>0.</OEMDRO2_320> 
  <OEMLED2_320>0</OEMLED2_320> 
  <OEMDRO2_321>0.</OEMDRO2_321> 
  <OEMLED2_321>0</OEMLED2_321> 
  <OEMDRO2_322>0.</OEMDRO2_322> 
  <OEMLED2_322>0</OEMLED2_322> 
  <OEMDRO2_323>0.</OEMDRO2_323> 
  <OEMLED2_323>0</OEMLED2_323> 
  <OEMDRO2_324>0.</OEMDRO2_324> 
  <OEMLED2_324>0</OEMLED2_324> 
  <OEMDRO2_325>0.</OEMDRO2_325> 
  <OEMLED2_325>0</OEMLED2_325> 
  <OEMDRO2_326>0.</OEMDRO2_326> 
  <OEMLED2_326>0</OEMLED2_326> 
  <OEMDRO2_327>0.</OEMDRO2_327> 
  <OEMLED2_327>0</OEMLED2_327> 
  <OEMDRO2_328>0.</OEMDRO2_328> 
  <OEMLED2_328>0</OEMLED2_328> 
  <OEMDRO2_329>0.</OEMDRO2_329> 
  <OEMLED2_329>0</OEMLED2_329> 
  <OEMDRO2_330>0.</OEMDRO2_330> 
  <OEMLED2_330>0</OEMLED2_330> 
  <OEMDRO2_331>0.</OEMDRO2_331> 
  <OEMLED2_331>0</OEMLED2_331> 
  <OEMDRO2_332>0.</OEMDRO2_332> 
  <OEMLED2_332>0</OEMLED2_332> 
  <OEMDRO2_333>0.</OEMDRO2_333> 
  <OEMLED2_333>0</OEMLED2_333> 
  <OEMDRO2_334>0.</OEMDRO2_334> 
  <OEMLED2_334>0</OEMLED2_334> 
  <OEMDRO2_335>0.</OEMDRO2_335> 
  <OEMLED2_335>0</OEMLED2_335> 
  <OEMDRO2_336>0.</OEMDRO2_336> 
  <OEMLED2_336>0</OEMLED2_336> 
  <OEMDRO2_337>0.</OEMDRO2_337> 
  <OEMLED2_337>0</OEMLED2_337> 
  <OEMDRO2_338>0.</OEMDRO2_338> 
  <OEMLED2_338>0</OEMLED2_338> 
  <OEMDRO2_339>0.</OEMDRO2_339> 
  <OEMLED2_339>0</OEMLED2_339> 
  <OEMDRO2_340>0.</OEMDRO2_340> 
  <OEMLED2_340>0</OEMLED2_340> 
  <OEMDRO2_341>0.</OEMDRO2_341> 
  <OEMLED2_341>0</OEMLED2_341> 
  <OEMDRO2_342>0.</OEMDRO2_342> 
  <OEMLED2_342>0</OEMLED2_342> 
  <OEMDRO2_343>0.</OEMDRO2_343> 
  <OEMLED2_343>0</OEMLED2_343> 
  <OEMDRO2_344>0.</OEMDRO2_344> 
  <OEMLED2_344>0</OEMLED2_344> 
  <OEMDRO2_345>0.</OEMDRO2_345> 
  <OEMLED2_345>0</OEMLED2_345> 
  <OEMDRO2_346>0.</OEMDRO2_346> 
  <OEMLED2_346>0</OEMLED2_346> 
  <OEMDRO2_347>0.</OEMDRO2_347> 
  <OEMLED2_347>0</OEMLED2_347> 
  <OEMDRO2_348>0.</OEMDRO2_348> 
  <OEMLED2_348>0</OEMLED2_348> 
  <OEMDRO2_349>0.</OEMDRO2_349> 
  <OEMLED2_349>0</OEMLED2_349> 
  <OEMDRO2_350>0.</OEMDRO2_350> 
  <OEMLED2_350>0</OEMLED2_350> 
  <OEMDRO2_351>0.</OEMDRO2_351> 
  <OEMLED2_351>0</OEMLED2_351> 
  <OEMDRO2_352>0.</OEMDRO2_352> 
  <OEMLED2_352>0</OEMLED2_352> 
  <OEMDRO2_353>0.</OEMDRO2_353> 
  <OEMLED2_353>0</OEMLED2_353> 
  <OEMDRO2_354>0.</OEMDRO2_354> 
  <OEMLED2_354>0</OEMLED2_354> 
  <OEMDRO2_355>0.</OEMDRO2_355> 
  <OEMLED2_355>0</OEMLED2_355> 
  <OEMDRO2_356>0.</OEMDRO2_356> 
  <OEMLED2_356>0</OEMLED2_356> 
  <OEMDRO2_357>0.</OEMDRO2_357> 
  <OEMLED2_357>0</OEMLED2_357> 
  <OEMDRO2_358>0.</OEMDRO2_358> 
  <OEMLED2_358>0</OEMLED2_358> 
  <OEMDRO2_359>0.</OEMDRO2_359> 
  <OEMLED2_359>0</OEMLED2_359> 
  <OEMDRO2_360>0.</OEMDRO2_360> 
  <OEMLED2_360>0</OEMLED2_360> 
  <OEMDRO2_361>0.</OEMDRO2_361> 
  <OEMLED2_361>0</OEMLED2_361> 
  <OEMDRO2_362>0.</OEMDRO2_362> 
  <OEMLED2_362>0</OEMLED2_362> 
  <OEMDRO2_363>0.</OEMDRO2_363> 
  <OEMLED2_363>0</OEMLED2_363> 
  <OEMDRO2_364>0.</OEMDRO2_364> 
  <OEMLED2_364>0</OEMLED2_364> 
  <OEMDRO2_365>0.</OEMDRO2_365> 
  <OEMLED2_365>0</OEMLED2_365> 
  <OEMDRO2_366>0.</OEMDRO2_366> 
  <OEMLED2_366>0</OEMLED2_366> 
  <OEMDRO2_367>0.</OEMDRO2_367> 
  <OEMLED2_367>0</OEMLED2_367> 
  <OEMDRO2_368>0.</OEMDRO2_368> 
  <OEMLED2_368>0</OEMLED2_368> 
  <OEMDRO2_369>0.</OEMDRO2_369> 
  <OEMLED2_369>0</OEMLED2_369> 
  <OEMDRO2_370>0.</OEMDRO2_370> 
  <OEMLED2_370>0</OEMLED2_370> 
  <OEMDRO2_371>0.</OEMDRO2_371> 
  <OEMLED2_371>0</OEMLED2_371> 
  <OEMDRO2_372>0.</OEMDRO2_372> 
  <OEMLED2_372>0</OEMLED2_372> 
  <OEMDRO2_373>0.</OEMDRO2_373> 
  <OEMLED2_373>0</OEMLED2_373> 
  <OEMDRO2_374>0.</OEMDRO2_374> 
  <OEMLED2_374>0</OEMLED2_374> 
  <OEMDRO2_375>0.</OEMDRO2_375> 
  <OEMLED2_375>0</OEMLED2_375> 
  <OEMDRO2_376>0.</OEMDRO2_376> 
  <OEMLED2_376>0</OEMLED2_376> 
  <OEMDRO2_377>0.</OEMDRO2_377> 
  <OEMLED2_377>0</OEMLED2_377> 
  <OEMDRO2_378>0.</OEMDRO2_378> 
  <OEMLED2_378>0</OEMLED2_378> 
  <OEMDRO2_379>0.</OEMDRO2_379> 
  <OEMLED2_379>0</OEMLED2_379> 
  <OEMDRO2_380>0.</OEMDRO2_380> 
  <OEMLED2_380>0</OEMLED2_380> 
  <OEMDRO2_381>0.</OEMDRO2_381> 
  <OEMLED2_381>0</OEMLED2_381> 
  <OEMDRO2_382>0.</OEMDRO2_382> 
  <OEMLED2_382>0</OEMLED2_382> 
  <OEMDRO2_383>0.</OEMDRO2_383> 
  <OEMLED2_383>0</OEMLED2_383> 
  <OEMDRO2_384>0.</OEMDRO2_384> 
  <OEMLED2_384>0</OEMLED2_384> 
  <OEMDRO2_385>0.</OEMDRO2_385> 
  <OEMLED2_385>0</OEMLED2_385> 
  <OEMDRO2_386>0.</OEMDRO2_386> 
  <OEMLED2_386>0</OEMLED2_386> 
  <OEMDRO2_387>0.</OEMDRO2_387> 
  <OEMLED2_387>0</OEMLED2_387> 
  <OEMDRO2_388>0.</OEMDRO2_388> 
  <OEMLED2_388>0</OEMLED2_388> 
  <OEMDRO2_389>0.</OEMDRO2_389> 
  <OEMLED2_389>0</OEMLED2_389> 
  <OEMDRO2_390>0.</OEMDRO2_390> 
  <OEMLED2_390>0</OEMLED2_390> 
  <OEMDRO2_391>0.</OEMDRO2_391> 
  <OEMLED2_391>0</OEMLED2_391> 
  <OEMDRO2_392>0.</OEMDRO2_392> 
  <OEMLED2_392>0</OEMLED2_392> 
  <OEMDRO2_393>0.</OEMDRO2_393> 
  <OEMLED2_393>0</OEMLED2_393> 
  <OEMDRO2_394>0.</OEMDRO2_394> 
  <OEMLED2_394>0</OEMLED2_394> 
  <OEMDRO2_395>0.</OEMDRO2_395> 
  <OEMLED2_395>0</OEMLED2_395> 
  <OEMDRO2_396>0.</OEMDRO2_396> 
  <OEMLED2_396>0</OEMLED2_396> 
  <OEMDRO2_397>0.</OEMDRO2_397> 
  <OEMLED2_397>0</OEMLED2_397> 
  <OEMDRO2_398>0.</OEMDRO2_398> 
  <OEMLED2_398>0</OEMLED2_398> 
  <OEMDRO2_399>0.</OEMDRO2_399> 
  <OEMLED2_399>0</OEMLED2_399> 
  <OEMDRO2_400>0.</OEMDRO2_400> 
  <OEMLED2_400>0</OEMLED2_400> 
  <OEMDRO2_401>0.</OEMDRO2_401> 
  <OEMLED2_401>0</OEMLED2_401> 
  <OEMDRO2_402>0.</OEMDRO2_402> 
  <OEMLED2_402>0</OEMLED2_402> 
  <OEMDRO2_403>0.</OEMDRO2_403> 
  <OEMLED2_403>0</OEMLED2_403> 
  <OEMDRO2_404>0.</OEMDRO2_404> 
  <OEMLED2_404>0</OEMLED2_404> 
  <OEMDRO2_405>0.</OEMDRO2_405> 
  <OEMLED2_405>0</OEMLED2_405> 
  <OEMDRO2_406>0.</OEMDRO2_406> 
  <OEMLED2_406>0</OEMLED2_406> 
  <OEMDRO2_407>0.</OEMDRO2_407> 
  <OEMLED2_407>0</OEMLED2_407> 
  <OEMDRO2_408>0.</OEMDRO2_408> 
  <OEMLED2_408>0</OEMLED2_408> 
  <OEMDRO2_409>0.</OEMDRO2_409> 
  <OEMLED2_409>0</OEMLED2_409> 
  <OEMDRO2_410>0.</OEMDRO2_410> 
  <OEMLED2_410>0</OEMLED2_410> 
  <OEMDRO2_411>0.</OEMDRO2_411> 
  <OEMLED2_411>0</OEMLED2_411> 
  <OEMDRO2_412>0.</OEMDRO2_412> 
  <OEMLED2_412>0</OEMLED2_412> 
  <OEMDRO2_413>0.</OEMDRO2_413> 
  <OEMLED2_413>0</OEMLED2_413> 
  <OEMDRO2_414>0.</OEMDRO2_414> 
  <OEMLED2_414>0</OEMLED2_414> 
  <OEMDRO2_415>0.</OEMDRO2_415> 
  <OEMLED2_415>0</OEMLED2_415> 
  <OEMDRO2_416>0.</OEMDRO2_416> 
  <OEMLED2_416>0</OEMLED2_416> 
  <OEMDRO2_417>0.</OEMDRO2_417> 
  <OEMLED2_417>0</OEMLED2_417> 
  <OEMDRO2_418>0.</OEMDRO2_418> 
  <OEMLED2_418>0</OEMLED2_418> 
  <OEMDRO2_419>0.</OEMDRO2_419> 
  <OEMLED2_419>0</OEMLED2_419> 
  <OEMDRO2_420>0.</OEMDRO2_420> 
  <OEMLED2_420>0</OEMLED2_420> 
  <OEMDRO2_421>0.</OEMDRO2_421> 
  <OEMLED2_421>0</OEMLED2_421> 
  <OEMDRO2_422>0.</OEMDRO2_422> 
  <OEMLED2_422>0</OEMLED2_422> 
  <OEMDRO2_423>0.</OEMDRO2_423> 
  <OEMLED2_423>0</OEMLED2_423> 
  <OEMDRO2_424>0.</OEMDRO2_424> 
  <OEMLED2_424>0</OEMLED2_424> 
  <OEMDRO2_425>0.</OEMDRO2_425> 
  <OEMLED2_425>0</OEMLED2_425> 
  <OEMDRO2_426>0.</OEMDRO2_426> 
  <OEMLED2_426>0</OEMLED2_426> 
  <OEMDRO2_427>0.</OEMDRO2_427> 
  <OEMLED2_427>0</OEMLED2_427> 
  <OEMDRO2_428>0.</OEMDRO2_428> 
  <OEMLED2_428>0</OEMLED2_428> 
  <OEMDRO2_429>0.</OEMDRO2_429> 
  <OEMLED2_429>0</OEMLED2_429> 
  <OEMDRO2_430>0.</OEMDRO2_430> 
  <OEMLED2_430>0</OEMLED2_430> 
  <OEMDRO2_431>0.</OEMDRO2_431> 
  <OEMLED2_431>0</OEMLED2_431> 
  <OEMDRO2_432>0.</OEMDRO2_432> 
  <OEMLED2_432>0</OEMLED2_432> 
  <OEMDRO2_433>0.</OEMDRO2_433> 
  <OEMLED2_433>0</OEMLED2_433> 
  <OEMDRO2_434>0.</OEMDRO2_434> 
  <OEMLED2_434>0</OEMLED2_434> 
  <OEMDRO2_435>0.</OEMDRO2_435> 
  <OEMLED2_435>0</OEMLED2_435> 
  <OEMDRO2_436>0.</OEMDRO2_436> 
  <OEMLED2_436>0</OEMLED2_436> 
  <OEMDRO2_437>0.</OEMDRO2_437> 
  <OEMLED2_437>0</OEMLED2_437> 
  <OEMDRO2_438>0.</OEMDRO2_438> 
  <OEMLED2_438>0</OEMLED2_438> 
  <OEMDRO2_439>0.</OEMDRO2_439> 
  <OEMLED2_439>0</OEMLED2_439> 
  <OEMDRO2_440>0.</OEMDRO2_440> 
  <OEMLED2_440>0</OEMLED2_440> 
  <OEMDRO2_441>0.</OEMDRO2_441> 
  <OEMLED2_441>0</OEMLED2_441> 
  <OEMDRO2_442>0.</OEMDRO2_442> 
  <OEMLED2_442>0</OEMLED2_442> 
  <OEMDRO2_443>0.</OEMDRO2_443> 
  <OEMLED2_443>0</OEMLED2_443> 
  <OEMDRO2_444>0.</OEMDRO2_444> 
  <OEMLED2_444>0</OEMLED2_444> 
  <OEMDRO2_445>0.</OEMDRO2_445> 
  <OEMLED2_445>0</OEMLED2_445> 
  <OEMDRO2_446>0.</OEMDRO2_446> 
  <OEMLED2_446>0</OEMLED2_446> 
  <OEMDRO2_447>0.</OEMDRO2_447> 
  <OEMLED2_447>0</OEMLED2_447> 
  <OEMDRO2_448>0.</OEMDRO2_448> 
  <OEMLED2_448>0</OEMLED2_448> 
  <OEMDRO2_449>0.</OEMDRO2_449> 
  <OEMLED2_449>0</OEMLED2_449> 
  <OEMDRO2_450>0.</OEMDRO2_450> 
  <OEMLED2_450>0</OEMLED2_450> 
  <OEMDRO2_451>0.</OEMDRO2_451> 
  <OEMLED2_451>0</OEMLED2_451> 
  <OEMDRO2_452>0.</OEMDRO2_452> 
  <OEMLED2_452>0</OEMLED2_452> 
  <OEMDRO2_453>0.</OEMDRO2_453> 
  <OEMLED2_453>0</OEMLED2_453> 
  <OEMDRO2_454>0.</OEMDRO2_454> 
  <OEMLED2_454>0</OEMLED2_454> 
  <OEMDRO2_455>0.</OEMDRO2_455> 
  <OEMLED2_455>0</OEMLED2_455> 
  <OEMDRO2_456>0.</OEMDRO2_456> 
  <OEMLED2_456>0</OEMLED2_456> 
  <OEMDRO2_457>0.</OEMDRO2_457> 
  <OEMLED2_457>0</OEMLED2_457> 
  <OEMDRO2_458>0.</OEMDRO2_458> 
  <OEMLED2_458>0</OEMLED2_458> 
  <OEMDRO2_459>0.</OEMDRO2_459> 
  <OEMLED2_459>0</OEMLED2_459> 
  <OEMDRO2_460>0.</OEMDRO2_460> 
  <OEMLED2_460>0</OEMLED2_460> 
  <OEMDRO2_461>0.</OEMDRO2_461> 
  <OEMLED2_461>0</OEMLED2_461> 
  <OEMDRO2_462>0.</OEMDRO2_462> 
  <OEMLED2_462>0</OEMLED2_462> 
  <OEMDRO2_463>0.</OEMDRO2_463> 
  <OEMLED2_463>0</OEMLED2_463> 
  <OEMDRO2_464>0.</OEMDRO2_464> 
  <OEMLED2_464>0</OEMLED2_464> 
  <OEMDRO2_465>0.</OEMDRO2_465> 
  <OEMLED2_465>0</OEMLED2_465> 
  <OEMDRO2_466>0.</OEMDRO2_466> 
  <OEMLED2_466>0</OEMLED2_466> 
  <OEMDRO2_467>0.</OEMDRO2_467> 
  <OEMLED2_467>0</OEMLED2_467> 
  <OEMDRO2_468>0.</OEMDRO2_468> 
  <OEMLED2_468>0</OEMLED2_468> 
  <OEMDRO2_469>0.</OEMDRO2_469> 
  <OEMLED2_469>0</OEMLED2_469> 
  <OEMDRO2_470>0.</OEMDRO2_470> 
  <OEMLED2_470>0</OEMLED2_470> 
  <OEMDRO2_471>0.</OEMDRO2_471> 
  <OEMLED2_471>0</OEMLED2_471> 
  <OEMDRO2_472>0.</OEMDRO2_472> 
  <OEMLED2_472>0</OEMLED2_472> 
  <OEMDRO2_473>0.</OEMDRO2_473> 
  <OEMLED2_473>0</OEMLED2_473> 
  <OEMDRO2_474>0.</OEMDRO2_474> 
  <OEMLED2_474>0</OEMLED2_474> 
  <OEMDRO2_475>0.</OEMDRO2_475> 
  <OEMLED2_475>0</OEMLED2_475> 
  <OEMDRO2_476>0.</OEMDRO2_476> 
  <OEMLED2_476>0</OEMLED2_476> 
  <OEMDRO2_477>0.</OEMDRO2_477> 
  <OEMLED2_477>0</OEMLED2_477> 
  <OEMDRO2_478>0.</OEMDRO2_478> 
  <OEMLED2_478>0</OEMLED2_478> 
  <OEMDRO2_479>0.</OEMDRO2_479> 
  <OEMLED2_479>0</OEMLED2_479> 
  <OEMDRO2_480>0.</OEMDRO2_480> 
  <OEMLED2_480>0</OEMLED2_480> 
  <OEMDRO2_481>0.</OEMDRO2_481> 
  <OEMLED2_481>0</OEMLED2_481> 
  <OEMDRO2_482>0.</OEMDRO2_482> 
  <OEMLED2_482>0</OEMLED2_482> 
  <OEMDRO2_483>0.</OEMDRO2_483> 
  <OEMLED2_483>0</OEMLED2_483> 
  <OEMDRO2_484>0.</OEMDRO2_484> 
  <OEMLED2_484>0</OEMLED2_484> 
  <OEMDRO2_485>0.</OEMDRO2_485> 
  <OEMLED2_485>0</OEMLED2_485> 
  <OEMDRO2_486>0.</OEMDRO2_486> 
  <OEMLED2_486>0</OEMLED2_486> 
  <OEMDRO2_487>0.</OEMDRO2_487> 
  <OEMLED2_487>0</OEMLED2_487> 
  <OEMDRO2_488>0.</OEMDRO2_488> 
  <OEMLED2_488>0</OEMLED2_488> 
  <OEMDRO2_489>0.</OEMDRO2_489> 
  <OEMLED2_489>0</OEMLED2_489> 
  <OEMDRO2_490>0.</OEMDRO2_490> 
  <OEMLED2_490>0</OEMLED2_490> 
  <OEMDRO2_491>0.</OEMDRO2_491> 
  <OEMLED2_491>0</OEMLED2_491> 
  <OEMDRO2_492>0.</OEMDRO2_492> 
  <OEMLED2_492>0</OEMLED2_492> 
  <OEMDRO2_493>0.</OEMDRO2_493> 
  <OEMLED2_493>0</OEMLED2_493> 
  <OEMDRO2_494>0.</OEMDRO2_494> 
  <OEMLED2_494>0</OEMLED2_494> 
  <OEMDRO2_495>0.</OEMDRO2_495> 
  <OEMLED2_495>0</OEMLED2_495> 
  <OEMDRO2_496>0.</OEMDRO2_496> 
  <OEMLED2_496>0</OEMLED2_496> 
  <OEMDRO2_497>0.</OEMDRO2_497> 
  <OEMLED2_497>0</OEMLED2_497> 
  <OEMDRO2_498>0.</OEMDRO2_498> 
  <OEMLED2_498>0</OEMLED2_498> 
  <OEMDRO2_499>0.</OEMDRO2_499> 
  <OEMLED2_499>0</OEMLED2_499> 
  <OEMDRO2_500>0.</OEMDRO2_500> 
  <OEMLED2_500>0</OEMLED2_500> 
  <OEMDRO2_501>0.</OEMDRO2_501> 
  <OEMLED2_501>0</OEMLED2_501> 
  <OEMDRO2_502>0.</OEMDRO2_502> 
  <OEMLED2_502>0</OEMLED2_502> 
  <OEMDRO2_503>0.</OEMDRO2_503> 
  <OEMLED2_503>0</OEMLED2_503> 
  <OEMDRO2_504>0.</OEMDRO2_504> 
  <OEMLED2_504>0</OEMLED2_504> 
  <OEMDRO2_505>0.</OEMDRO2_505> 
  <OEMLED2_505>0</OEMLED2_505> 
  <OEMDRO2_506>0.</OEMDRO2_506> 
  <OEMLED2_506>0</OEMLED2_506> 
  <OEMDRO2_507>0.</OEMDRO2_507> 
  <OEMLED2_507>0</OEMLED2_507> 
  <OEMDRO2_508>0.</OEMDRO2_508> 
  <OEMLED2_508>0</OEMLED2_508> 
  <OEMDRO2_509>0.</OEMDRO2_509> 
  <OEMLED2_509>0</OEMLED2_509> 
  <OEMDRO2_510>0.</OEMDRO2_510> 
  <OEMLED2_510>0</OEMLED2_510> 
  <OEMDRO2_511>0.</OEMDRO2_511> 
  <OEMLED2_511>0</OEMLED2_511> 
  <OEMDRO2_512>0.</OEMDRO2_512> 
  <OEMLED2_512>0</OEMLED2_512> 
  <OEMDRO2_513>0.</OEMDRO2_513> 
  <OEMLED2_513>0</OEMLED2_513> 
  <OEMDRO2_514>0.</OEMDRO2_514> 
  <OEMLED2_514>0</OEMLED2_514> 
  <OEMDRO2_515>0.</OEMDRO2_515> 
  <OEMLED2_515>0</OEMLED2_515> 
  <OEMDRO2_516>0.</OEMDRO2_516> 
  <OEMLED2_516>0</OEMLED2_516> 
  <OEMDRO2_517>0.</OEMDRO2_517> 
  <OEMLED2_517>0</OEMLED2_517> 
  <OEMDRO2_518>0.</OEMDRO2_518> 
  <OEMLED2_518>0</OEMLED2_518> 
  <OEMDRO2_519>0.</OEMDRO2_519> 
  <OEMLED2_519>0</OEMLED2_519> 
  <OEMDRO2_520>0.</OEMDRO2_520> 
  <OEMLED2_520>0</OEMLED2_520> 
  <OEMDRO2_521>0.</OEMDRO2_521> 
  <OEMLED2_521>0</OEMLED2_521> 
  <OEMDRO2_522>0.</OEMDRO2_522> 
  <OEMLED2_522>0</OEMLED2_522> 
  <OEMDRO2_523>0.</OEMDRO2_523> 
  <OEMLED2_523>0</OEMLED2_523> 
  <OEMDRO2_524>0.</OEMDRO2_524> 
  <OEMLED2_524>0</OEMLED2_524> 
  <OEMDRO2_525>0.</OEMDRO2_525> 
  <OEMLED2_525>0</OEMLED2_525> 
  <OEMDRO2_526>0.</OEMDRO2_526> 
  <OEMLED2_526>0</OEMLED2_526> 
  <OEMDRO2_527>0.</OEMDRO2_527> 
  <OEMLED2_527>0</OEMLED2_527> 
  <OEMDRO2_528>0.</OEMDRO2_528> 
  <OEMLED2_528>0</OEMLED2_528> 
  <OEMDRO2_529>0.</OEMDRO2_529> 
  <OEMLED2_529>0</OEMLED2_529> 
  <OEMDRO2_530>0.</OEMDRO2_530> 
  <OEMLED2_530>0</OEMLED2_530> 
  <OEMDRO2_531>0.</OEMDRO2_531> 
  <OEMLED2_531>0</OEMLED2_531> 
  <OEMDRO2_532>0.</OEMDRO2_532> 
  <OEMLED2_532>0</OEMLED2_532> 
  <OEMDRO2_533>0.</OEMDRO2_533> 
  <OEMLED2_533>0</OEMLED2_533> 
  <OEMDRO2_534>0.</OEMDRO2_534> 
  <OEMLED2_534>0</OEMLED2_534> 
  <OEMDRO2_535>0.</OEMDRO2_535> 
  <OEMLED2_535>0</OEMLED2_535> 
  <OEMDRO2_536>0.</OEMDRO2_536> 
  <OEMLED2_536>0</OEMLED2_536> 
  <OEMDRO2_537>0.</OEMDRO2_537> 
  <OEMLED2_537>0</OEMLED2_537> 
  <OEMDRO2_538>0.</OEMDRO2_538> 
  <OEMLED2_538>0</OEMLED2_538> 
  <OEMDRO2_539>0.</OEMDRO2_539> 
  <OEMLED2_539>0</OEMLED2_539> 
  <OEMDRO2_540>0.</OEMDRO2_540> 
  <OEMLED2_540>0</OEMLED2_540> 
  <OEMDRO2_541>0.</OEMDRO2_541> 
  <OEMLED2_541>0</OEMLED2_541> 
  <OEMDRO2_542>0.</OEMDRO2_542> 
  <OEMLED2_542>0</OEMLED2_542> 
  <OEMDRO2_543>0.</OEMDRO2_543> 
  <OEMLED2_543>0</OEMLED2_543> 
  <OEMDRO2_544>0.</OEMDRO2_544> 
  <OEMLED2_544>0</OEMLED2_544> 
  <OEMDRO2_545>0.</OEMDRO2_545> 
  <OEMLED2_545>0</OEMLED2_545> 
  <OEMDRO2_546>0.</OEMDRO2_546> 
  <OEMLED2_546>0</OEMLED2_546> 
  <OEMDRO2_547>0.</OEMDRO2_547> 
  <OEMLED2_547>0</OEMLED2_547> 
  <OEMDRO2_548>0.</OEMDRO2_548> 
  <OEMLED2_548>0</OEMLED2_548> 
  <OEMDRO2_549>0.</OEMDRO2_549> 
  <OEMLED2_549>0</OEMLED2_549> 
  <OEMDRO2_550>0.</OEMDRO2_550> 
  <OEMLED2_550>0</OEMLED2_550> 
  <OEMDRO2_551>0.</OEMDRO2_551> 
  <OEMLED2_551>0</OEMLED2_551> 
  <OEMDRO2_552>0.</OEMDRO2_552> 
  <OEMLED2_552>0</OEMLED2_552> 
  <OEMDRO2_553>0.</OEMDRO2_553> 
  <OEMLED2_553>0</OEMLED2_553> 
  <OEMDRO2_554>0.</OEMDRO2_554> 
  <OEMLED2_554>0</OEMLED2_554> 
  <OEMDRO2_555>0.</OEMDRO2_555> 
  <OEMLED2_555>0</OEMLED2_555> 
  <OEMDRO2_556>0.</OEMDRO2_556> 
  <OEMLED2_556>0</OEMLED2_556> 
  <OEMDRO2_557>0.</OEMDRO2_557> 
  <OEMLED2_557>0</OEMLED2_557> 
  <OEMDRO2_558>0.</OEMDRO2_558> 
  <OEMLED2_558>0</OEMLED2_558> 
  <OEMDRO2_559>0.</OEMDRO2_559> 
  <OEMLED2_559>0</OEMLED2_559> 
  <OEMDRO2_560>0.</OEMDRO2_560> 
  <OEMLED2_560>0</OEMLED2_560> 
  <OEMDRO2_561>0.</OEMDRO2_561> 
  <OEMLED2_561>0</OEMLED2_561> 
  <OEMDRO2_562>0.</OEMDRO2_562> 
  <OEMLED2_562>0</OEMLED2_562> 
  <OEMDRO2_563>0.</OEMDRO2_563> 
  <OEMLED2_563>0</OEMLED2_563> 
  <OEMDRO2_564>0.</OEMDRO2_564> 
  <OEMLED2_564>0</OEMLED2_564> 
  <OEMDRO2_565>0.</OEMDRO2_565> 
  <OEMLED2_565>0</OEMLED2_565> 
  <OEMDRO2_566>0.</OEMDRO2_566> 
  <OEMLED2_566>0</OEMLED2_566> 
  <OEMDRO2_567>0.</OEMDRO2_567> 
  <OEMLED2_567>0</OEMLED2_567> 
  <OEMDRO2_568>0.</OEMDRO2_568> 
  <OEMLED2_568>0</OEMLED2_568> 
  <OEMDRO2_569>0.</OEMDRO2_569> 
  <OEMLED2_569>0</OEMLED2_569> 
  <OEMDRO2_570>0.</OEMDRO2_570> 
  <OEMLED2_570>0</OEMLED2_570> 
  <OEMDRO2_571>0.</OEMDRO2_571> 
  <OEMLED2_571>0</OEMLED2_571> 
  <OEMDRO2_572>0.</OEMDRO2_572> 
  <OEMLED2_572>0</OEMLED2_572> 
  <OEMDRO2_573>0.</OEMDRO2_573> 
  <OEMLED2_573>0</OEMLED2_573> 
  <OEMDRO2_574>0.</OEMDRO2_574> 
  <OEMLED2_574>0</OEMLED2_574> 
  <OEMDRO2_575>0.</OEMDRO2_575> 
  <OEMLED2_575>0</OEMLED2_575> 
  <OEMDRO2_576>0.</OEMDRO2_576> 
  <OEMLED2_576>0</OEMLED2_576> 
  <OEMDRO2_577>0.</OEMDRO2_577> 
  <OEMLED2_577>0</OEMLED2_577> 
  <OEMDRO2_578>0.</OEMDRO2_578> 
  <OEMLED2_578>0</OEMLED2_578> 
  <OEMDRO2_579>0.</OEMDRO2_579> 
  <OEMLED2_579>0</OEMLED2_579> 
  <OEMDRO2_580>0.</OEMDRO2_580> 
  <OEMLED2_580>0</OEMLED2_580> 
  <OEMDRO2_581>0.</OEMDRO2_581> 
  <OEMLED2_581>0</OEMLED2_581> 
  <OEMDRO2_582>0.</OEMDRO2_582> 
  <OEMLED2_582>0</OEMLED2_582> 
  <OEMDRO2_583>0.</OEMDRO2_583> 
  <OEMLED2_583>0</OEMLED2_583> 
  <OEMDRO2_584>0.</OEMDRO2_584> 
  <OEMLED2_584>0</OEMLED2_584> 
  <OEMDRO2_585>0.</OEMDRO2_585> 
  <OEMLED2_585>0</OEMLED2_585> 
  <OEMDRO2_586>0.</OEMDRO2_586> 
  <OEMLED2_586>0</OEMLED2_586> 
  <OEMDRO2_587>0.</OEMDRO2_587> 
  <OEMLED2_587>0</OEMLED2_587> 
  <OEMDRO2_588>0.</OEMDRO2_588> 
  <OEMLED2_588>0</OEMLED2_588> 
  <OEMDRO2_589>0.</OEMDRO2_589> 
  <OEMLED2_589>0</OEMLED2_589> 
  <OEMDRO2_590>0.</OEMDRO2_590> 
  <OEMLED2_590>0</OEMLED2_590> 
  <OEMDRO2_591>0.</OEMDRO2_591> 
  <OEMLED2_591>0</OEMLED2_591> 
  <OEMDRO2_592>0.</OEMDRO2_592> 
  <OEMLED2_592>0</OEMLED2_592> 
  <OEMDRO2_593>0.</OEMDRO2_593> 
  <OEMLED2_593>0</OEMLED2_593> 
  <OEMDRO2_594>0.</OEMDRO2_594> 
  <OEMLED2_594>0</OEMLED2_594> 
  <OEMDRO2_595>0.</OEMDRO2_595> 
  <OEMLED2_595>0</OEMLED2_595> 
  <OEMDRO2_596>0.</OEMDRO2_596> 
  <OEMLED2_596>0</OEMLED2_596> 
  <OEMDRO2_597>0.</OEMDRO2_597> 
  <OEMLED2_597>0</OEMLED2_597> 
  <OEMDRO2_598>0.</OEMDRO2_598> 
  <OEMLED2_598>0</OEMLED2_598> 
  <OEMDRO2_599>0.</OEMDRO2_599> 
  <OEMLED2_599>0</OEMLED2_599> 
  <OEMDRO2_600>0.</OEMDRO2_600> 
  <OEMLED2_600>0</OEMLED2_600> 
  <OEMDRO2_601>0.</OEMDRO2_601> 
  <OEMLED2_601>0</OEMLED2_601> 
  <OEMDRO2_602>0.</OEMDRO2_602> 
  <OEMLED2_602>0</OEMLED2_602> 
  <OEMDRO2_603>0.</OEMDRO2_603> 
  <OEMLED2_603>0</OEMLED2_603> 
  <OEMDRO2_604>0.</OEMDRO2_604> 
  <OEMLED2_604>0</OEMLED2_604> 
  <OEMDRO2_605>0.</OEMDRO2_605> 
  <OEMLED2_605>0</OEMLED2_605> 
  <OEMDRO2_606>0.</OEMDRO2_606> 
  <OEMLED2_606>0</OEMLED2_606> 
  <OEMDRO2_607>0.</OEMDRO2_607> 
  <OEMLED2_607>0</OEMLED2_607> 
  <OEMDRO2_608>0.</OEMDRO2_608> 
  <OEMLED2_608>0</OEMLED2_608> 
  <OEMDRO2_609>0.</OEMDRO2_609> 
  <OEMLED2_609>0</OEMLED2_609> 
  <OEMDRO2_610>0.</OEMDRO2_610> 
  <OEMLED2_610>0</OEMLED2_610> 
  <OEMDRO2_611>0.</OEMDRO2_611> 
  <OEMLED2_611>0</OEMLED2_611> 
  <OEMDRO2_612>0.</OEMDRO2_612> 
  <OEMLED2_612>0</OEMLED2_612> 
  <OEMDRO2_613>0.</OEMDRO2_613> 
  <OEMLED2_613>0</OEMLED2_613> 
  <OEMDRO2_614>0.</OEMDRO2_614> 
  <OEMLED2_614>0</OEMLED2_614> 
  <OEMDRO2_615>0.</OEMDRO2_615> 
  <OEMLED2_615>0</OEMLED2_615> 
  <OEMDRO2_616>0.</OEMDRO2_616> 
  <OEMLED2_616>0</OEMLED2_616> 
  <OEMDRO2_617>0.</OEMDRO2_617> 
  <OEMLED2_617>0</OEMLED2_617> 
  <OEMDRO2_618>0.</OEMDRO2_618> 
  <OEMLED2_618>0</OEMLED2_618> 
  <OEMDRO2_619>0.</OEMDRO2_619> 
  <OEMLED2_619>0</OEMLED2_619> 
  <OEMDRO2_620>0.</OEMDRO2_620> 
  <OEMLED2_620>0</OEMLED2_620> 
  <OEMDRO2_621>0.</OEMDRO2_621> 
  <OEMLED2_621>0</OEMLED2_621> 
  <OEMDRO2_622>0.</OEMDRO2_622> 
  <OEMLED2_622>0</OEMLED2_622> 
  <OEMDRO2_623>0.</OEMDRO2_623> 
  <OEMLED2_623>0</OEMLED2_623> 
  <OEMDRO2_624>0.</OEMDRO2_624> 
  <OEMLED2_624>0</OEMLED2_624> 
  <OEMDRO2_625>0.</OEMDRO2_625> 
  <OEMLED2_625>0</OEMLED2_625> 
  <OEMDRO2_626>0.</OEMDRO2_626> 
  <OEMLED2_626>0</OEMLED2_626> 
  <OEMDRO2_627>0.</OEMDRO2_627> 
  <OEMLED2_627>0</OEMLED2_627> 
  <OEMDRO2_628>0.</OEMDRO2_628> 
  <OEMLED2_628>0</OEMLED2_628> 
  <OEMDRO2_629>0.</OEMDRO2_629> 
  <OEMLED2_629>0</OEMLED2_629> 
  <OEMDRO2_630>0.</OEMDRO2_630> 
  <OEMLED2_630>0</OEMLED2_630> 
  <OEMDRO2_631>0.</OEMDRO2_631> 
  <OEMLED2_631>0</OEMLED2_631> 
  <OEMDRO2_632>0.</OEMDRO2_632> 
  <OEMLED2_632>0</OEMLED2_632> 
  <OEMDRO2_633>0.</OEMDRO2_633> 
  <OEMLED2_633>0</OEMLED2_633> 
  <OEMDRO2_634>0.</OEMDRO2_634> 
  <OEMLED2_634>0</OEMLED2_634> 
  <OEMDRO2_635>0.</OEMDRO2_635> 
  <OEMLED2_635>0</OEMLED2_635> 
  <OEMDRO2_636>0.</OEMDRO2_636> 
  <OEMLED2_636>0</OEMLED2_636> 
  <OEMDRO2_637>0.</OEMDRO2_637> 
  <OEMLED2_637>0</OEMLED2_637> 
  <OEMDRO2_638>0.</OEMDRO2_638> 
  <OEMLED2_638>0</OEMLED2_638> 
  <OEMDRO2_639>0.</OEMDRO2_639> 
  <OEMLED2_639>0</OEMLED2_639> 
  <OEMDRO2_640>0.</OEMDRO2_640> 
  <OEMLED2_640>0</OEMLED2_640> 
  <OEMDRO2_641>0.</OEMDRO2_641> 
  <OEMLED2_641>0</OEMLED2_641> 
  <OEMDRO2_642>0.</OEMDRO2_642> 
  <OEMLED2_642>0</OEMLED2_642> 
  <OEMDRO2_643>0.</OEMDRO2_643> 
  <OEMLED2_643>0</OEMLED2_643> 
  <OEMDRO2_644>0.</OEMDRO2_644> 
  <OEMLED2_644>0</OEMLED2_644> 
  <OEMDRO2_645>0.</OEMDRO2_645> 
  <OEMLED2_645>0</OEMLED2_645> 
  <OEMDRO2_646>0.</OEMDRO2_646> 
  <OEMLED2_646>0</OEMLED2_646> 
  <OEMDRO2_647>0.</OEMDRO2_647> 
  <OEMLED2_647>0</OEMLED2_647> 
  <OEMDRO2_648>0.</OEMDRO2_648> 
  <OEMLED2_648>0</OEMLED2_648> 
  <OEMDRO2_649>0.</OEMDRO2_649> 
  <OEMLED2_649>0</OEMLED2_649> 
  <OEMDRO2_650>0.</OEMDRO2_650> 
  <OEMLED2_650>0</OEMLED2_650> 
  <OEMDRO2_651>0.</OEMDRO2_651> 
  <OEMLED2_651>0</OEMLED2_651> 
  <OEMDRO2_652>0.</OEMDRO2_652> 
  <OEMLED2_652>0</OEMLED2_652> 
  <OEMDRO2_653>0.</OEMDRO2_653> 
  <OEMLED2_653>0</OEMLED2_653> 
  <OEMDRO2_654>0.</OEMDRO2_654> 
  <OEMLED2_654>0</OEMLED2_654> 
  <OEMDRO2_655>0.</OEMDRO2_655> 
  <OEMLED2_655>0</OEMLED2_655> 
  <OEMDRO2_656>0.</OEMDRO2_656> 
  <OEMLED2_656>0</OEMLED2_656> 
  <OEMDRO2_657>0.</OEMDRO2_657> 
  <OEMLED2_657>0</OEMLED2_657> 
  <OEMDRO2_658>0.</OEMDRO2_658> 
  <OEMLED2_658>0</OEMLED2_658> 
  <OEMDRO2_659>0.</OEMDRO2_659> 
  <OEMLED2_659>0</OEMLED2_659> 
  <OEMDRO2_660>0.</OEMDRO2_660> 
  <OEMLED2_660>0</OEMLED2_660> 
  <OEMDRO2_661>0.</OEMDRO2_661> 
  <OEMLED2_661>0</OEMLED2_661> 
  <OEMDRO2_662>0.</OEMDRO2_662> 
  <OEMLED2_662>0</OEMLED2_662> 
  <OEMDRO2_663>0.</OEMDRO2_663> 
  <OEMLED2_663>0</OEMLED2_663> 
  <OEMDRO2_664>0.</OEMDRO2_664> 
  <OEMLED2_664>0</OEMLED2_664> 
  <OEMDRO2_665>0.</OEMDRO2_665> 
  <OEMLED2_665>0</OEMLED2_665> 
  <OEMDRO2_666>0.</OEMDRO2_666> 
  <OEMLED2_666>0</OEMLED2_666> 
  <OEMDRO2_667>0.</OEMDRO2_667> 
  <OEMLED2_667>0</OEMLED2_667> 
  <OEMDRO2_668>0.</OEMDRO2_668> 
  <OEMLED2_668>0</OEMLED2_668> 
  <OEMDRO2_669>0.</OEMDRO2_669> 
  <OEMLED2_669>0</OEMLED2_669> 
  <OEMDRO2_670>0.</OEMDRO2_670> 
  <OEMLED2_670>0</OEMLED2_670> 
  <OEMDRO2_671>0.</OEMDRO2_671> 
  <OEMLED2_671>0</OEMLED2_671> 
  <OEMDRO2_672>0.</OEMDRO2_672> 
  <OEMLED2_672>0</OEMLED2_672> 
  <OEMDRO2_673>0.</OEMDRO2_673> 
  <OEMLED2_673>0</OEMLED2_673> 
  <OEMDRO2_674>0.</OEMDRO2_674> 
  <OEMLED2_674>0</OEMLED2_674> 
  <OEMDRO2_675>0.</OEMDRO2_675> 
  <OEMLED2_675>0</OEMLED2_675> 
  <OEMDRO2_676>0.</OEMDRO2_676> 
  <OEMLED2_676>0</OEMLED2_676> 
  <OEMDRO2_677>0.</OEMDRO2_677> 
  <OEMLED2_677>0</OEMLED2_677> 
  <OEMDRO2_678>0.</OEMDRO2_678> 
  <OEMLED2_678>0</OEMLED2_678> 
  <OEMDRO2_679>0.</OEMDRO2_679> 
  <OEMLED2_679>0</OEMLED2_679> 
  <OEMDRO2_680>0.</OEMDRO2_680> 
  <OEMLED2_680>0</OEMLED2_680> 
  <OEMDRO2_681>0.</OEMDRO2_681> 
  <OEMLED2_681>0</OEMLED2_681> 
  <OEMDRO2_682>0.</OEMDRO2_682> 
  <OEMLED2_682>0</OEMLED2_682> 
  <OEMDRO2_683>0.</OEMDRO2_683> 
  <OEMLED2_683>0</OEMLED2_683> 
  <OEMDRO2_684>0.</OEMDRO2_684> 
  <OEMLED2_684>0</OEMLED2_684> 
  <OEMDRO2_685>0.</OEMDRO2_685> 
  <OEMLED2_685>0</OEMLED2_685> 
  <OEMDRO2_686>0.</OEMDRO2_686> 
  <OEMLED2_686>0</OEMLED2_686> 
  <OEMDRO2_687>0.</OEMDRO2_687> 
  <OEMLED2_687>0</OEMLED2_687> 
  <OEMDRO2_688>0.</OEMDRO2_688> 
  <OEMLED2_688>0</OEMLED2_688> 
  <OEMDRO2_689>0.</OEMDRO2_689> 
  <OEMLED2_689>0</OEMLED2_689> 
  <OEMDRO2_690>0.</OEMDRO2_690> 
  <OEMLED2_690>0</OEMLED2_690> 
  <OEMDRO2_691>0.</OEMDRO2_691> 
  <OEMLED2_691>0</OEMLED2_691> 
  <OEMDRO2_692>0.</OEMDRO2_692> 
  <OEMLED2_692>0</OEMLED2_692> 
  <OEMDRO2_693>0.</OEMDRO2_693> 
  <OEMLED2_693>0</OEMLED2_693> 
  <OEMDRO2_694>0.</OEMDRO2_694> 
  <OEMLED2_694>0</OEMLED2_694> 
  <OEMDRO2_695>0.</OEMDRO2_695> 
  <OEMLED2_695>0</OEMLED2_695> 
  <OEMDRO2_696>0.</OEMDRO2_696> 
  <OEMLED2_696>0</OEMLED2_696> 
  <OEMDRO2_697>0.</OEMDRO2_697> 
  <OEMLED2_697>0</OEMLED2_697> 
  <OEMDRO2_698>0.</OEMDRO2_698> 
  <OEMLED2_698>0</OEMLED2_698> 
  <OEMDRO2_699>0.</OEMDRO2_699> 
  <OEMLED2_699>0</OEMLED2_699> 
  <OEMDRO2_700>0.</OEMDRO2_700> 
  <OEMLED2_700>0</OEMLED2_700> 
  <OEMDRO2_701>0.</OEMDRO2_701> 
  <OEMLED2_701>0</OEMLED2_701> 
  <OEMDRO2_702>0.</OEMDRO2_702> 
  <OEMLED2_702>0</OEMLED2_702> 
  <OEMDRO2_703>0.</OEMDRO2_703> 
  <OEMLED2_703>0</OEMLED2_703> 
  <OEMDRO2_704>0.</OEMDRO2_704> 
  <OEMLED2_704>0</OEMLED2_704> 
  <OEMDRO2_705>0.</OEMDRO2_705> 
  <OEMLED2_705>0</OEMLED2_705> 
  <OEMDRO2_706>0.</OEMDRO2_706> 
  <OEMLED2_706>0</OEMLED2_706> 
  <OEMDRO2_707>0.</OEMDRO2_707> 
  <OEMLED2_707>0</OEMLED2_707> 
  <OEMDRO2_708>0.</OEMDRO2_708> 
  <OEMLED2_708>0</OEMLED2_708> 
  <OEMDRO2_709>0.</OEMDRO2_709> 
  <OEMLED2_709>0</OEMLED2_709> 
  <OEMDRO2_710>0.</OEMDRO2_710> 
  <OEMLED2_710>0</OEMLED2_710> 
  <OEMDRO2_711>0.</OEMDRO2_711> 
  <OEMLED2_711>0</OEMLED2_711> 
  <OEMDRO2_712>0.</OEMDRO2_712> 
  <OEMLED2_712>0</OEMLED2_712> 
  <OEMDRO2_713>0.</OEMDRO2_713> 
  <OEMLED2_713>0</OEMLED2_713> 
  <OEMDRO2_714>0.</OEMDRO2_714> 
  <OEMLED2_714>0</OEMLED2_714> 
  <OEMDRO2_715>0.</OEMDRO2_715> 
  <OEMLED2_715>0</OEMLED2_715> 
  <OEMDRO2_716>0.</OEMDRO2_716> 
  <OEMLED2_716>0</OEMLED2_716> 
  <OEMDRO2_717>0.</OEMDRO2_717> 
  <OEMLED2_717>0</OEMLED2_717> 
  <OEMDRO2_718>0.</OEMDRO2_718> 
  <OEMLED2_718>0</OEMLED2_718> 
  <OEMDRO2_719>0.</OEMDRO2_719> 
  <OEMLED2_719>0</OEMLED2_719> 
  <OEMDRO2_720>0.</OEMDRO2_720> 
  <OEMLED2_720>0</OEMLED2_720> 
  <OEMDRO2_721>0.</OEMDRO2_721> 
  <OEMLED2_721>0</OEMLED2_721> 
  <OEMDRO2_722>0.</OEMDRO2_722> 
  <OEMLED2_722>0</OEMLED2_722> 
  <OEMDRO2_723>0.</OEMDRO2_723> 
  <OEMLED2_723>0</OEMLED2_723> 
  <OEMDRO2_724>0.</OEMDRO2_724> 
  <OEMLED2_724>0</OEMLED2_724> 
  <OEMDRO2_725>0.</OEMDRO2_725> 
  <OEMLED2_725>0</OEMLED2_725> 
  <OEMDRO2_726>0.</OEMDRO2_726> 
  <OEMLED2_726>0</OEMLED2_726> 
  <OEMDRO2_727>0.</OEMDRO2_727> 
  <OEMLED2_727>0</OEMLED2_727> 
  <OEMDRO2_728>0.</OEMDRO2_728> 
  <OEMLED2_728>0</OEMLED2_728> 
  <OEMDRO2_729>0.</OEMDRO2_729> 
  <OEMLED2_729>0</OEMLED2_729> 
  <OEMDRO2_730>0.</OEMDRO2_730> 
  <OEMLED2_730>0</OEMLED2_730> 
  <OEMDRO2_731>0.</OEMDRO2_731> 
  <OEMLED2_731>0</OEMLED2_731> 
  <OEMDRO2_732>0.</OEMDRO2_732> 
  <OEMLED2_732>0</OEMLED2_732> 
  <OEMDRO2_733>0.</OEMDRO2_733> 
  <OEMLED2_733>0</OEMLED2_733> 
  <OEMDRO2_734>0.</OEMDRO2_734> 
  <OEMLED2_734>0</OEMLED2_734> 
  <OEMDRO2_735>0.</OEMDRO2_735> 
  <OEMLED2_735>0</OEMLED2_735> 
  <OEMDRO2_736>0.</OEMDRO2_736> 
  <OEMLED2_736>0</OEMLED2_736> 
  <OEMDRO2_737>0.</OEMDRO2_737> 
  <OEMLED2_737>0</OEMLED2_737> 
  <OEMDRO2_738>0.</OEMDRO2_738> 
  <OEMLED2_738>0</OEMLED2_738> 
  <OEMDRO2_739>0.</OEMDRO2_739> 
  <OEMLED2_739>0</OEMLED2_739> 
  <OEMDRO2_740>0.</OEMDRO2_740> 
  <OEMLED2_740>0</OEMLED2_740> 
  <OEMDRO2_741>0.</OEMDRO2_741> 
  <OEMLED2_741>0</OEMLED2_741> 
  <OEMDRO2_742>0.</OEMDRO2_742> 
  <OEMLED2_742>0</OEMLED2_742> 
  <OEMDRO2_743>0.</OEMDRO2_743> 
  <OEMLED2_743>0</OEMLED2_743> 
  <OEMDRO2_744>0.</OEMDRO2_744> 
  <OEMLED2_744>0</OEMLED2_744> 
  <OEMDRO2_745>0.</OEMDRO2_745> 
  <OEMLED2_745>0</OEMLED2_745> 
  <OEMDRO2_746>0.</OEMDRO2_746> 
  <OEMLED2_746>0</OEMLED2_746> 
  <OEMDRO2_747>0.</OEMDRO2_747> 
  <OEMLED2_747>0</OEMLED2_747> 
  <OEMDRO2_748>0.</OEMDRO2_748> 
  <OEMLED2_748>0</OEMLED2_748> 
  <OEMDRO2_749>0.</OEMDRO2_749> 
  <OEMLED2_749>0</OEMLED2_749> 
  <OEMDRO2_750>0.</OEMDRO2_750> 
  <OEMLED2_750>0</OEMLED2_750> 
  <OEMDRO2_751>0.</OEMDRO2_751> 
  <OEMLED2_751>0</OEMLED2_751> 
  <OEMDRO2_752>0.</OEMDRO2_752> 
  <OEMLED2_752>0</OEMLED2_752> 
  <OEMDRO2_753>0.</OEMDRO2_753> 
  <OEMLED2_753>0</OEMLED2_753> 
  <OEMDRO2_754>0.</OEMDRO2_754> 
  <OEMLED2_754>0</OEMLED2_754> 
  <OEMDRO2_755>0.</OEMDRO2_755> 
  <OEMLED2_755>0</OEMLED2_755> 
  <OEMDRO2_756>0.</OEMDRO2_756> 
  <OEMLED2_756>0</OEMLED2_756> 
  <OEMDRO2_757>0.</OEMDRO2_757> 
  <OEMLED2_757>0</OEMLED2_757> 
  <OEMDRO2_758>0.</OEMDRO2_758> 
  <OEMLED2_758>0</OEMLED2_758> 
  <OEMDRO2_759>0.</OEMDRO2_759> 
  <OEMLED2_759>0</OEMLED2_759> 
  <OEMDRO2_760>0.</OEMDRO2_760> 
  <OEMLED2_760>0</OEMLED2_760> 
  <OEMDRO2_761>0.</OEMDRO2_761> 
  <OEMLED2_761>0</OEMLED2_761> 
  <OEMDRO2_762>0.</OEMDRO2_762> 
  <OEMLED2_762>0</OEMLED2_762> 
  <OEMDRO2_763>0.</OEMDRO2_763> 
  <OEMLED2_763>0</OEMLED2_763> 
  <OEMDRO2_764>0.</OEMDRO2_764> 
  <OEMLED2_764>0</OEMLED2_764> 
  <OEMDRO2_765>0.</OEMDRO2_765> 
  <OEMLED2_765>0</OEMLED2_765> 
  <OEMDRO2_766>0.</OEMDRO2_766> 
  <OEMLED2_766>0</OEMLED2_766> 
  <OEMDRO2_767>0.</OEMDRO2_767> 
  <OEMLED2_767>0</OEMLED2_767> 
  <OEMDRO2_768>0.</OEMDRO2_768> 
  <OEMLED2_768>0</OEMLED2_768> 
  <OEMDRO2_769>0.</OEMDRO2_769> 
  <OEMLED2_769>0</OEMLED2_769> 
  <OEMDRO2_770>0.</OEMDRO2_770> 
  <OEMLED2_770>0</OEMLED2_770> 
  <OEMDRO2_771>0.</OEMDRO2_771> 
  <OEMLED2_771>0</OEMLED2_771> 
  <OEMDRO2_772>0.</OEMDRO2_772> 
  <OEMLED2_772>0</OEMLED2_772> 
  <OEMDRO2_773>0.</OEMDRO2_773> 
  <OEMLED2_773>0</OEMLED2_773> 
  <OEMDRO2_774>0.</OEMDRO2_774> 
  <OEMLED2_774>0</OEMLED2_774> 
  <OEMDRO2_775>0.</OEMDRO2_775> 
  <OEMLED2_775>0</OEMLED2_775> 
  <OEMDRO2_776>0.</OEMDRO2_776> 
  <OEMLED2_776>0</OEMLED2_776> 
  <OEMDRO2_777>0.</OEMDRO2_777> 
  <OEMLED2_777>0</OEMLED2_777> 
  <OEMDRO2_778>0.</OEMDRO2_778> 
  <OEMLED2_778>0</OEMLED2_778> 
  <OEMDRO2_779>0.</OEMDRO2_779> 
  <OEMLED2_779>0</OEMLED2_779> 
  <OEMDRO2_780>0.</OEMDRO2_780> 
  <OEMLED2_780>0</OEMLED2_780> 
  <OEMDRO2_781>0.</OEMDRO2_781> 
  <OEMLED2_781>0</OEMLED2_781> 
  <OEMDRO2_782>0.</OEMDRO2_782> 
  <OEMLED2_782>0</OEMLED2_782> 
  <OEMDRO2_783>0.</OEMDRO2_783> 
  <OEMLED2_783>0</OEMLED2_783> 
  <OEMDRO2_784>0.</OEMDRO2_784> 
  <OEMLED2_784>0</OEMLED2_784> 
  <OEMDRO2_785>0.</OEMDRO2_785> 
  <OEMLED2_785>0</OEMLED2_785> 
  <OEMDRO2_786>0.</OEMDRO2_786> 
  <OEMLED2_786>0</OEMLED2_786> 
  <OEMDRO2_787>0.</OEMDRO2_787> 
  <OEMLED2_787>0</OEMLED2_787> 
  <OEMDRO2_788>0.</OEMDRO2_788> 
  <OEMLED2_788>0</OEMLED2_788> 
  <OEMDRO2_789>0.</OEMDRO2_789> 
  <OEMLED2_789>0</OEMLED2_789> 
  <OEMDRO2_790>0.</OEMDRO2_790> 
  <OEMLED2_790>0</OEMLED2_790> 
  <OEMDRO2_791>0.</OEMDRO2_791> 
  <OEMLED2_791>0</OEMLED2_791> 
  <OEMDRO2_792>0.</OEMDRO2_792> 
  <OEMLED2_792>0</OEMLED2_792> 
  <OEMDRO2_793>0.</OEMDRO2_793> 
  <OEMLED2_793>0</OEMLED2_793> 
  <OEMDRO2_794>0.</OEMDRO2_794> 
  <OEMLED2_794>0</OEMLED2_794> 
  <OEMDRO2_795>0.</OEMDRO2_795> 
  <OEMLED2_795>0</OEMLED2_795> 
  <OEMDRO2_796>0.</OEMDRO2_796> 
  <OEMLED2_796>0</OEMLED2_796> 
  <OEMDRO2_797>0.</OEMDRO2_797> 
  <OEMLED2_797>0</OEMLED2_797> 
  <OEMDRO2_798>0.</OEMDRO2_798> 
  <OEMLED2_798>0</OEMLED2_798> 
  <OEMDRO2_799>0.</OEMDRO2_799> 
  <OEMLED2_799>0</OEMLED2_799> 
  <OEMDRO2_800>0.</OEMDRO2_800> 
  <OEMLED2_800>0</OEMLED2_800> 
  <OEMDRO2_801>0.</OEMDRO2_801> 
  <OEMLED2_801>0</OEMLED2_801> 
  <OEMDRO2_802>0.</OEMDRO2_802> 
  <OEMLED2_802>0</OEMLED2_802> 
  <OEMDRO2_803>0.</OEMDRO2_803> 
  <OEMLED2_803>0</OEMLED2_803> 
  <OEMDRO2_804>0.</OEMDRO2_804> 
  <OEMLED2_804>0</OEMLED2_804> 
  <OEMDRO2_805>0.</OEMDRO2_805> 
  <OEMLED2_805>0</OEMLED2_805> 
  <OEMDRO2_806>0.</OEMDRO2_806> 
  <OEMLED2_806>0</OEMLED2_806> 
  <OEMDRO2_807>0.</OEMDRO2_807> 
  <OEMLED2_807>0</OEMLED2_807> 
  <OEMDRO2_808>0.</OEMDRO2_808> 
  <OEMLED2_808>0</OEMLED2_808> 
  <OEMDRO2_809>0.</OEMDRO2_809> 
  <OEMLED2_809>0</OEMLED2_809> 
  <OEMDRO2_810>0.</OEMDRO2_810> 
  <OEMLED2_810>0</OEMLED2_810> 
  <OEMDRO2_811>0.</OEMDRO2_811> 
  <OEMLED2_811>0</OEMLED2_811> 
  <OEMDRO2_812>0.</OEMDRO2_812> 
  <OEMLED2_812>0</OEMLED2_812> 
  <OEMDRO2_813>0.</OEMDRO2_813> 
  <OEMLED2_813>0</OEMLED2_813> 
  <OEMDRO2_814>0.</OEMDRO2_814> 
  <OEMLED2_814>0</OEMLED2_814> 
  <OEMDRO2_815>0.</OEMDRO2_815> 
  <OEMLED2_815>0</OEMLED2_815> 
  <OEMDRO2_816>0.</OEMDRO2_816> 
  <OEMLED2_816>0</OEMLED2_816> 
  <OEMDRO2_817>0.</OEMDRO2_817> 
  <OEMLED2_817>0</OEMLED2_817> 
  <OEMDRO2_818>0.</OEMDRO2_818> 
  <OEMLED2_818>0</OEMLED2_818> 
  <OEMDRO2_819>0.</OEMDRO2_819> 
  <OEMLED2_819>0</OEMLED2_819> 
  <OEMDRO2_820>0.</OEMDRO2_820> 
  <OEMLED2_820>0</OEMLED2_820> 
  <OEMDRO2_821>0.</OEMDRO2_821> 
  <OEMLED2_821>0</OEMLED2_821> 
  <OEMDRO2_822>0.</OEMDRO2_822> 
  <OEMLED2_822>0</OEMLED2_822> 
  <OEMDRO2_823>0.</OEMDRO2_823> 
  <OEMLED2_823>0</OEMLED2_823> 
  <OEMDRO2_824>0.</OEMDRO2_824> 
  <OEMLED2_824>0</OEMLED2_824> 
  <OEMDRO2_825>0.</OEMDRO2_825> 
  <OEMLED2_825>0</OEMLED2_825> 
  <OEMDRO2_826>0.</OEMDRO2_826> 
  <OEMLED2_826>0</OEMLED2_826> 
  <OEMDRO2_827>0.</OEMDRO2_827> 
  <OEMLED2_827>0</OEMLED2_827> 
  <OEMDRO2_828>0.</OEMDRO2_828> 
  <OEMLED2_828>0</OEMLED2_828> 
  <OEMDRO2_829>0.</OEMDRO2_829> 
  <OEMLED2_829>0</OEMLED2_829> 
  <OEMDRO2_830>0.</OEMDRO2_830> 
  <OEMLED2_830>0</OEMLED2_830> 
  <OEMDRO2_831>0.</OEMDRO2_831> 
  <OEMLED2_831>0</OEMLED2_831> 
  <OEMDRO2_832>0.</OEMDRO2_832> 
  <OEMLED2_832>0</OEMLED2_832> 
  <OEMDRO2_833>0.</OEMDRO2_833> 
  <OEMLED2_833>0</OEMLED2_833> 
  <OEMDRO2_834>0.</OEMDRO2_834> 
  <OEMLED2_834>0</OEMLED2_834> 
  <OEMDRO2_835>0.</OEMDRO2_835> 
  <OEMLED2_835>0</OEMLED2_835> 
  <OEMDRO2_836>0.</OEMDRO2_836> 
  <OEMLED2_836>0</OEMLED2_836> 
  <OEMDRO2_837>0.</OEMDRO2_837> 
  <OEMLED2_837>0</OEMLED2_837> 
  <OEMDRO2_838>0.</OEMDRO2_838> 
  <OEMLED2_838>0</OEMLED2_838> 
  <OEMDRO2_839>0.</OEMDRO2_839> 
  <OEMLED2_839>0</OEMLED2_839> 
  <OEMDRO2_840>0.</OEMDRO2_840> 
  <OEMLED2_840>0</OEMLED2_840> 
  <OEMDRO2_841>0.</OEMDRO2_841> 
  <OEMLED2_841>0</OEMLED2_841> 
  <OEMDRO2_842>0.</OEMDRO2_842> 
  <OEMLED2_842>0</OEMLED2_842> 
  <OEMDRO2_843>0.</OEMDRO2_843> 
  <OEMLED2_843>0</OEMLED2_843> 
  <OEMDRO2_844>0.</OEMDRO2_844> 
  <OEMLED2_844>0</OEMLED2_844> 
  <OEMDRO2_845>0.</OEMDRO2_845> 
  <OEMLED2_845>0</OEMLED2_845> 
  <OEMDRO2_846>0.</OEMDRO2_846> 
  <OEMLED2_846>0</OEMLED2_846> 
  <OEMDRO2_847>0.</OEMDRO2_847> 
  <OEMLED2_847>0</OEMLED2_847> 
  <OEMDRO2_848>0.</OEMDRO2_848> 
  <OEMLED2_848>0</OEMLED2_848> 
  <OEMDRO2_849>0.</OEMDRO2_849> 
  <OEMLED2_849>0</OEMLED2_849> 
  <OEMDRO2_850>0.</OEMDRO2_850> 
  <OEMLED2_850>0</OEMLED2_850> 
  <OEMDRO2_851>0.</OEMDRO2_851> 
  <OEMLED2_851>0</OEMLED2_851> 
  <OEMDRO2_852>0.</OEMDRO2_852> 
  <OEMLED2_852>0</OEMLED2_852> 
  <OEMDRO2_853>0.</OEMDRO2_853> 
  <OEMLED2_853>0</OEMLED2_853> 
  <OEMDRO2_854>0.</OEMDRO2_854> 
  <OEMLED2_854>0</OEMLED2_854> 
  <OEMDRO2_855>0.</OEMDRO2_855> 
  <OEMLED2_855>0</OEMLED2_855> 
  <OEMDRO2_856>0.</OEMDRO2_856> 
  <OEMLED2_856>0</OEMLED2_856> 
  <OEMDRO2_857>0.</OEMDRO2_857> 
  <OEMLED2_857>0</OEMLED2_857> 
  <OEMDRO2_858>0.</OEMDRO2_858> 
  <OEMLED2_858>0</OEMLED2_858> 
  <OEMDRO2_859>0.</OEMDRO2_859> 
  <OEMLED2_859>0</OEMLED2_859> 
  <OEMDRO2_860>0.</OEMDRO2_860> 
  <OEMLED2_860>0</OEMLED2_860> 
  <OEMDRO2_861>0.</OEMDRO2_861> 
  <OEMLED2_861>0</OEMLED2_861> 
  <OEMDRO2_862>0.</OEMDRO2_862> 
  <OEMLED2_862>0</OEMLED2_862> 
  <OEMDRO2_863>0.</OEMDRO2_863> 
  <OEMLED2_863>0</OEMLED2_863> 
  <OEMDRO2_864>0.</OEMDRO2_864> 
  <OEMLED2_864>0</OEMLED2_864> 
  <OEMDRO2_865>0.</OEMDRO2_865> 
  <OEMLED2_865>0</OEMLED2_865> 
  <OEMDRO2_866>0.</OEMDRO2_866> 
  <OEMLED2_866>0</OEMLED2_866> 
  <OEMDRO2_867>0.</OEMDRO2_867> 
  <OEMLED2_867>0</OEMLED2_867> 
  <OEMDRO2_868>0.</OEMDRO2_868> 
  <OEMLED2_868>0</OEMLED2_868> 
  <OEMDRO2_869>0.</OEMDRO2_869> 
  <OEMLED2_869>0</OEMLED2_869> 
  <OEMDRO2_870>0.</OEMDRO2_870> 
  <OEMLED2_870>0</OEMLED2_870> 
  <OEMDRO2_871>0.</OEMDRO2_871> 
  <OEMLED2_871>0</OEMLED2_871> 
  <OEMDRO2_872>0.</OEMDRO2_872> 
  <OEMLED2_872>0</OEMLED2_872> 
  <OEMDRO2_873>0.</OEMDRO2_873> 
  <OEMLED2_873>0</OEMLED2_873> 
  <OEMDRO2_874>0.</OEMDRO2_874> 
  <OEMLED2_874>0</OEMLED2_874> 
  <OEMDRO2_875>0.</OEMDRO2_875> 
  <OEMLED2_875>0</OEMLED2_875> 
  <OEMDRO2_876>0.</OEMDRO2_876> 
  <OEMLED2_876>0</OEMLED2_876> 
  <OEMDRO2_877>0.</OEMDRO2_877> 
  <OEMLED2_877>0</OEMLED2_877> 
  <OEMDRO2_878>0.</OEMDRO2_878> 
  <OEMLED2_878>0</OEMLED2_878> 
  <OEMDRO2_879>0.</OEMDRO2_879> 
  <OEMLED2_879>0</OEMLED2_879> 
  <OEMDRO2_880>0.</OEMDRO2_880> 
  <OEMLED2_880>0</OEMLED2_880> 
  <OEMDRO2_881>0.</OEMDRO2_881> 
  <OEMLED2_881>0</OEMLED2_881> 
  <OEMDRO2_882>0.</OEMDRO2_882> 
  <OEMLED2_882>0</OEMLED2_882> 
  <OEMDRO2_883>0.</OEMDRO2_883> 
  <OEMLED2_883>0</OEMLED2_883> 
  <OEMDRO2_884>0.</OEMDRO2_884> 
  <OEMLED2_884>0</OEMLED2_884> 
  <OEMDRO2_885>0.</OEMDRO2_885> 
  <OEMLED2_885>0</OEMLED2_885> 
  <OEMDRO2_886>0.</OEMDRO2_886> 
  <OEMLED2_886>0</OEMLED2_886> 
  <OEMDRO2_887>0.</OEMDRO2_887> 
  <OEMLED2_887>0</OEMLED2_887> 
  <OEMDRO2_888>0.</OEMDRO2_888> 
  <OEMLED2_888>0</OEMLED2_888> 
  <OEMDRO2_889>0.</OEMDRO2_889> 
  <OEMLED2_889>0</OEMLED2_889> 
  <OEMDRO2_890>0.</OEMDRO2_890> 
  <OEMLED2_890>0</OEMLED2_890> 
  <OEMDRO2_891>0.</OEMDRO2_891> 
  <OEMLED2_891>0</OEMLED2_891> 
  <OEMDRO2_892>0.</OEMDRO2_892> 
  <OEMLED2_892>0</OEMLED2_892> 
  <OEMDRO2_893>0.</OEMDRO2_893> 
  <OEMLED2_893>0</OEMLED2_893> 
  <OEMDRO2_894>0.</OEMDRO2_894> 
  <OEMLED2_894>0</OEMLED2_894> 
  <OEMDRO2_895>0.</OEMDRO2_895> 
  <OEMLED2_895>0</OEMLED2_895> 
  <OEMDRO2_896>0.</OEMDRO2_896> 
  <OEMLED2_896>0</OEMLED2_896> 
  <OEMDRO2_897>0.</OEMDRO2_897> 
  <OEMLED2_897>0</OEMLED2_897> 
  <OEMDRO2_898>0.</OEMDRO2_898> 
  <OEMLED2_898>0</OEMLED2_898> 
  <OEMDRO2_899>0.</OEMDRO2_899> 
  <OEMLED2_899>0</OEMLED2_899> 
  <OEMDRO2_900>0.</OEMDRO2_900> 
  <OEMLED2_900>0</OEMLED2_900> 
  <OEMDRO2_901>0.</OEMDRO2_901> 
  <OEMLED2_901>0</OEMLED2_901> 
  <OEMDRO2_902>0.</OEMDRO2_902> 
  <OEMLED2_902>0</OEMLED2_902> 
  <OEMDRO2_903>0.</OEMDRO2_903> 
  <OEMLED2_903>0</OEMLED2_903> 
  <OEMDRO2_904>0.</OEMDRO2_904> 
  <OEMLED2_904>0</OEMLED2_904> 
  <OEMDRO2_905>0.</OEMDRO2_905> 
  <OEMLED2_905>0</OEMLED2_905> 
  <OEMDRO2_906>0.</OEMDRO2_906> 
  <OEMLED2_906>0</OEMLED2_906> 
  <OEMDRO2_907>0.</OEMDRO2_907> 
  <OEMLED2_907>0</OEMLED2_907> 
  <OEMDRO2_908>0.</OEMDRO2_908> 
  <OEMLED2_908>0</OEMLED2_908> 
  <OEMDRO2_909>0.</OEMDRO2_909> 
  <OEMLED2_909>0</OEMLED2_909> 
  <OEMDRO2_910>0.</OEMDRO2_910> 
  <OEMLED2_910>0</OEMLED2_910> 
  <OEMDRO2_911>0.</OEMDRO2_911> 
  <OEMLED2_911>0</OEMLED2_911> 
  <OEMDRO2_912>0.</OEMDRO2_912> 
  <OEMLED2_912>0</OEMLED2_912> 
  <OEMDRO2_913>0.</OEMDRO2_913> 
  <OEMLED2_913>0</OEMLED2_913> 
  <OEMDRO2_914>0.</OEMDRO2_914> 
  <OEMLED2_914>0</OEMLED2_914> 
  <OEMDRO2_915>0.</OEMDRO2_915> 
  <OEMLED2_915>0</OEMLED2_915> 
  <OEMDRO2_916>0.</OEMDRO2_916> 
  <OEMLED2_916>0</OEMLED2_916> 
  <OEMDRO2_917>0.</OEMDRO2_917> 
  <OEMLED2_917>0</OEMLED2_917> 
  <OEMDRO2_918>0.</OEMDRO2_918> 
  <OEMLED2_918>0</OEMLED2_918> 
  <OEMDRO2_919>0.</OEMDRO2_919> 
  <OEMLED2_919>0</OEMLED2_919> 
  <OEMDRO2_920>0.</OEMDRO2_920> 
  <OEMLED2_920>0</OEMLED2_920> 
  <OEMDRO2_921>0.</OEMDRO2_921> 
  <OEMLED2_921>0</OEMLED2_921> 
  <OEMDRO2_922>0.</OEMDRO2_922> 
  <OEMLED2_922>0</OEMLED2_922> 
  <OEMDRO2_923>0.</OEMDRO2_923> 
  <OEMLED2_923>0</OEMLED2_923> 
  <OEMDRO2_924>0.</OEMDRO2_924> 
  <OEMLED2_924>0</OEMLED2_924> 
  <OEMDRO2_925>0.</OEMDRO2_925> 
  <OEMLED2_925>0</OEMLED2_925> 
  <OEMDRO2_926>0.</OEMDRO2_926> 
  <OEMLED2_926>0</OEMLED2_926> 
  <OEMDRO2_927>0.</OEMDRO2_927> 
  <OEMLED2_927>0</OEMLED2_927> 
  <OEMDRO2_928>0.</OEMDRO2_928> 
  <OEMLED2_928>0</OEMLED2_928> 
  <OEMDRO2_929>0.</OEMDRO2_929> 
  <OEMLED2_929>0</OEMLED2_929> 
  <OEMDRO2_930>0.</OEMDRO2_930> 
  <OEMLED2_930>0</OEMLED2_930> 
  <OEMDRO2_931>0.</OEMDRO2_931> 
  <OEMLED2_931>0</OEMLED2_931> 
  <OEMDRO2_932>0.</OEMDRO2_932> 
  <OEMLED2_932>0</OEMLED2_932> 
  <OEMDRO2_933>0.</OEMDRO2_933> 
  <OEMLED2_933>0</OEMLED2_933> 
  <OEMDRO2_934>0.</OEMDRO2_934> 
  <OEMLED2_934>0</OEMLED2_934> 
  <OEMDRO2_935>0.</OEMDRO2_935> 
  <OEMLED2_935>0</OEMLED2_935> 
  <OEMDRO2_936>0.</OEMDRO2_936> 
  <OEMLED2_936>0</OEMLED2_936> 
  <OEMDRO2_937>0.</OEMDRO2_937> 
  <OEMLED2_937>0</OEMLED2_937> 
  <OEMDRO2_938>0.</OEMDRO2_938> 
  <OEMLED2_938>0</OEMLED2_938> 
  <OEMDRO2_939>0.</OEMDRO2_939> 
  <OEMLED2_939>0</OEMLED2_939> 
  <OEMDRO2_940>0.</OEMDRO2_940> 
  <OEMLED2_940>0</OEMLED2_940> 
  <OEMDRO2_941>0.</OEMDRO2_941> 
  <OEMLED2_941>0</OEMLED2_941> 
  <OEMDRO2_942>0.</OEMDRO2_942> 
  <OEMLED2_942>0</OEMLED2_942> 
  <OEMDRO2_943>0.</OEMDRO2_943> 
  <OEMLED2_943>0</OEMLED2_943> 
  <OEMDRO2_944>0.</OEMDRO2_944> 
  <OEMLED2_944>0</OEMLED2_944> 
  <OEMDRO2_945>0.</OEMDRO2_945> 
  <OEMLED2_945>0</OEMLED2_945> 
  <OEMDRO2_946>0.</OEMDRO2_946> 
  <OEMLED2_946>0</OEMLED2_946> 
  <OEMDRO2_947>0.</OEMDRO2_947> 
  <OEMLED2_947>0</OEMLED2_947> 
  <OEMDRO2_948>0.</OEMDRO2_948> 
  <OEMLED2_948>0</OEMLED2_948> 
  <OEMDRO2_949>0.</OEMDRO2_949> 
  <OEMLED2_949>0</OEMLED2_949> 
  <OEMDRO2_950>0.</OEMDRO2_950> 
  <OEMLED2_950>0</OEMLED2_950> 
  <OEMDRO2_951>0.</OEMDRO2_951> 
  <OEMLED2_951>0</OEMLED2_951> 
  <OEMDRO2_952>0.</OEMDRO2_952> 
  <OEMLED2_952>0</OEMLED2_952> 
  <OEMDRO2_953>0.</OEMDRO2_953> 
  <OEMLED2_953>0</OEMLED2_953> 
  <OEMDRO2_954>0.</OEMDRO2_954> 
  <OEMLED2_954>0</OEMLED2_954> 
  <OEMDRO2_955>0.</OEMDRO2_955> 
  <OEMLED2_955>0</OEMLED2_955> 
  <OEMDRO2_956>0.</OEMDRO2_956> 
  <OEMLED2_956>0</OEMLED2_956> 
  <OEMDRO2_957>0.</OEMDRO2_957> 
  <OEMLED2_957>0</OEMLED2_957> 
  <OEMDRO2_958>0.</OEMDRO2_958> 
  <OEMLED2_958>0</OEMLED2_958> 
  <OEMDRO2_959>0.</OEMDRO2_959> 
  <OEMLED2_959>0</OEMLED2_959> 
  <OEMDRO2_960>0.</OEMDRO2_960> 
  <OEMLED2_960>0</OEMLED2_960> 
  <OEMDRO2_961>0.</OEMDRO2_961> 
  <OEMLED2_961>0</OEMLED2_961> 
  <OEMDRO2_962>0.</OEMDRO2_962> 
  <OEMLED2_962>0</OEMLED2_962> 
  <OEMDRO2_963>0.</OEMDRO2_963> 
  <OEMLED2_963>0</OEMLED2_963> 
  <OEMDRO2_964>0.</OEMDRO2_964> 
  <OEMLED2_964>0</OEMLED2_964> 
  <OEMDRO2_965>0.</OEMDRO2_965> 
  <OEMLED2_965>0</OEMLED2_965> 
  <OEMDRO2_966>0.</OEMDRO2_966> 
  <OEMLED2_966>0</OEMLED2_966> 
  <OEMDRO2_967>0.</OEMDRO2_967> 
  <OEMLED2_967>0</OEMLED2_967> 
  <OEMDRO2_968>0.</OEMDRO2_968> 
  <OEMLED2_968>0</OEMLED2_968> 
  <OEMDRO2_969>0.</OEMDRO2_969> 
  <OEMLED2_969>0</OEMLED2_969> 
  <OEMDRO2_970>0.</OEMDRO2_970> 
  <OEMLED2_970>0</OEMLED2_970> 
  <OEMDRO2_971>0.</OEMDRO2_971> 
  <OEMLED2_971>0</OEMLED2_971> 
  <OEMDRO2_972>0.</OEMDRO2_972> 
  <OEMLED2_972>0</OEMLED2_972> 
  <OEMDRO2_973>0.</OEMDRO2_973> 
  <OEMLED2_973>0</OEMLED2_973> 
  <OEMDRO2_974>0.</OEMDRO2_974> 
  <OEMLED2_974>0</OEMLED2_974> 
  <OEMDRO2_975>0.</OEMDRO2_975> 
  <OEMLED2_975>0</OEMLED2_975> 
  <OEMDRO2_976>0.</OEMDRO2_976> 
  <OEMLED2_976>0</OEMLED2_976> 
  <OEMDRO2_977>0.</OEMDRO2_977> 
  <OEMLED2_977>0</OEMLED2_977> 
  <OEMDRO2_978>0.</OEMDRO2_978> 
  <OEMLED2_978>0</OEMLED2_978> 
  <OEMDRO2_979>0.</OEMDRO2_979> 
  <OEMLED2_979>0</OEMLED2_979> 
  <OEMDRO2_980>0.</OEMDRO2_980> 
  <OEMLED2_980>0</OEMLED2_980> 
  <OEMDRO2_981>0.</OEMDRO2_981> 
  <OEMLED2_981>0</OEMLED2_981> 
  <OEMDRO2_982>0.</OEMDRO2_982> 
  <OEMLED2_982>0</OEMLED2_982> 
  <OEMDRO2_983>0.</OEMDRO2_983> 
  <OEMLED2_983>0</OEMLED2_983> 
  <OEMDRO2_984>0.</OEMDRO2_984> 
  <OEMLED2_984>0</OEMLED2_984> 
  <OEMDRO2_985>0.</OEMDRO2_985> 
  <OEMLED2_985>0</OEMLED2_985> 
  <OEMDRO2_986>0.</OEMDRO2_986> 
  <OEMLED2_986>0</OEMLED2_986> 
  <OEMDRO2_987>0.</OEMDRO2_987> 
  <OEMLED2_987>0</OEMLED2_987> 
  <OEMDRO2_988>0.</OEMDRO2_988> 
  <OEMLED2_988>0</OEMLED2_988> 
  <OEMDRO2_989>0.</OEMDRO2_989> 
  <OEMLED2_989>0</OEMLED2_989> 
  <OEMDRO2_990>0.</OEMDRO2_990> 
  <OEMLED2_990>0</OEMLED2_990> 
  <OEMDRO2_991>0.</OEMDRO2_991> 
  <OEMLED2_991>0</OEMLED2_991> 
  <OEMDRO2_992>0.</OEMDRO2_992> 
  <OEMLED2_992>0</OEMLED2_992> 
  <OEMDRO2_993>0.</OEMDRO2_993> 
  <OEMLED2_993>0</OEMLED2_993> 
  <OEMDRO2_994>0.</OEMDRO2_994> 
  <OEMLED2_994>0</OEMLED2_994> 
  <OEMDRO2_995>0.</OEMDRO2_995> 
  <OEMLED2_995>0</OEMLED2_995> 
  <OEMDRO2_996>0.</OEMDRO2_996> 
  <OEMLED2_996>0</OEMLED2_996> 
  <OEMDRO2_997>0.</OEMDRO2_997> 
  <OEMLED2_997>0</OEMLED2_997> 
  <OEMDRO2_998>0.</OEMDRO2_998> 
  <OEMLED2_998>0</OEMLED2_998> 
  <OEMDRO2_999>0.</OEMDRO2_999> 
  <OEMLED2_999>0</OEMLED2_999> 
  <JogInc>1.e-003</JogInc> 
  <JogSlide>0.1</JogSlide> 
  <THCMax>1.</THCMax> 
  <THCMin>0.2</THCMin> 
  <RadiusA>0.</RadiusA> 
  <RadiusB>0.</RadiusB> 
  <RadiusC>0.</RadiusC> 
  <LiftLevel>1.</LiftLevel> 
  <LiftAngle>45.</LiftAngle> 
  <InhibitDepth>0.</InhibitDepth> 
  <LaserXGrid>0.</LaserXGrid> 
  <LaserYGrid>0.</LaserYGrid> 
  <LaserAGrid>0.</LaserAGrid> 
  <JogInc0>1.</JogInc0> 
  <JogInc1>0.1</JogInc1> 
  <JogInc2>1.e-002</JogInc2> 
  <JogInc3>1.e-003</JogInc3> 
  <JogInc4>1.e-004</JogInc4> 
  <JogInc5>1.</JogInc5> 
  <JogInc6>0.1</JogInc6> 
  <JogInc7>1.e-002</JogInc7> 
  <JogInc8>1.e-003</JogInc8> 
  <JogInc9>1.e-004</JogInc9> 
  <THCSpeed>20.</THCSpeed> 
  <BlendFactor>180.</BlendFactor> 
  <M0RefHome>0</M0RefHome> 
  <M1RefHome>0</M1RefHome> 
  <M2RefHome>0</M2RefHome> 
  <M3RefHome>0</M3RefHome> 
  <M4RefHome>0</M4RefHome> 
  <M5RefHome>0</M5RefHome> 
  <AxisKeys0>38</AxisKeys0> 
  <AxisKeys1>40</AxisKeys1> 
  <AxisKeys2>37</AxisKeys2> 
  <AxisKeys3>39</AxisKeys3> 
  <AxisKeys4>33</AxisKeys4> 
  <AxisKeys5>34</AxisKeys5> 
  <AxisKeys6>999</AxisKeys6> 
  <AxisKeys7>999</AxisKeys7> 
  <AxisKeys8>999</AxisKeys8> 
  <AxisKeys9>999</AxisKeys9> 
  <AxisKeys10>999</AxisKeys10> 
  <AxisKeys11>999</AxisKeys11> 
  <DROHotKey>999</DROHotKey> 
  <ListKey>999</ListKey> 
  <MDIHotKey>999</MDIHotKey> 
  <GCodeHotKey>999</GCodeHotKey> 
  <Vel0>0.25</Vel0> 
  <Acc0>20.0625</Acc0> 
  <Steps0>2000.</Steps0> 
  <Vel1>0.175</Vel1> 
  <Acc1>30.</Acc1> 
  <Steps1>2000.</Steps1> 
  <Vel2>0.25</Vel2> 
  <Acc2>20.0625</Acc2> 
  <Steps2>2000.</Steps2> 
  <GExt>*.tap</GExt> 
  <GPath>C:\Mach3\GCode\roadrunner.tap</GPath> 
  <MRU10>None</MRU10> 
  <MRU9>None</MRU9> 
  <MRU8>None</MRU8> 
  <MRU7>None</MRU7> 
  <MRU6>None</MRU6> 
  <MRU5>None</MRU5> 
  <MRU4>None</MRU4> 
  <MRU3>None</MRU3> 
  <MRU2>None</MRU2> 
  <MRU1>C:\Mach3\GCode\roadrunner.tap</MRU1> 
  </Preferences>
- <GCodeVar>
  <GVar500>0.</GVar500> 
  <GVar501>0.</GVar501> 
  <GVar502>0.</GVar502> 
  <GVar503>0.</GVar503> 
  <GVar504>0.</GVar504> 
  <GVar505>0.</GVar505> 
  <GVar506>0.</GVar506> 
  <GVar507>0.</GVar507> 
  <GVar508>0.</GVar508> 
  <GVar509>0.</GVar509> 
  <GVar510>0.</GVar510> 
  <GVar511>0.</GVar511> 
  <GVar512>0.</GVar512> 
  <GVar513>0.</GVar513> 
  <GVar514>0.</GVar514> 
  <GVar515>0.</GVar515> 
  <GVar516>0.</GVar516> 
  <GVar517>0.</GVar517> 
  <GVar518>0.</GVar518> 
  <GVar519>0.</GVar519> 
  <GVar520>0.</GVar520> 
  <GVar521>0.</GVar521> 
  <GVar522>0.</GVar522> 
  <GVar523>0.</GVar523> 
  <GVar524>0.</GVar524> 
  <GVar525>0.</GVar525> 
  <GVar526>0.</GVar526> 
  <GVar527>0.</GVar527> 
  <GVar528>0.</GVar528> 
  <GVar529>0.</GVar529> 
  <GVar530>0.</GVar530> 
  <GVar531>0.</GVar531> 
  <GVar532>0.</GVar532> 
  <GVar533>0.</GVar533> 
  <GVar534>0.</GVar534> 
  <GVar535>0.</GVar535> 
  <GVar536>0.</GVar536> 
  <GVar537>0.</GVar537> 
  <GVar538>0.</GVar538> 
  <GVar539>0.</GVar539> 
  <GVar540>0.</GVar540> 
  <GVar541>0.</GVar541> 
  <GVar542>0.</GVar542> 
  <GVar543>0.</GVar543> 
  <GVar544>0.</GVar544> 
  <GVar545>0.</GVar545> 
  <GVar546>0.</GVar546> 
  <GVar547>0.</GVar547> 
  <GVar548>0.</GVar548> 
  <GVar549>0.</GVar549> 
  <GVar550>0.</GVar550> 
  <GVar551>0.</GVar551> 
  <GVar552>0.</GVar552> 
  <GVar553>0.</GVar553> 
  <GVar554>0.</GVar554> 
  <GVar555>0.</GVar555> 
  <GVar556>0.</GVar556> 
  <GVar557>0.</GVar557> 
  <GVar558>0.</GVar558> 
  <GVar559>0.</GVar559> 
  <GVar560>0.</GVar560> 
  <GVar561>0.</GVar561> 
  <GVar562>0.</GVar562> 
  <GVar563>0.</GVar563> 
  <GVar564>0.</GVar564> 
  <GVar565>0.</GVar565> 
  <GVar566>0.</GVar566> 
  <GVar567>0.</GVar567> 
  <GVar568>0.</GVar568> 
  <GVar569>0.</GVar569> 
  <GVar570>0.</GVar570> 
  <GVar571>0.</GVar571> 
  <GVar572>0.</GVar572> 
  <GVar573>0.</GVar573> 
  <GVar574>0.</GVar574> 
  <GVar575>0.</GVar575> 
  <GVar576>0.</GVar576> 
  <GVar577>0.</GVar577> 
  <GVar578>0.</GVar578> 
  <GVar579>0.</GVar579> 
  <GVar580>0.</GVar580> 
  <GVar581>0.</GVar581> 
  <GVar582>0.</GVar582> 
  <GVar583>0.</GVar583> 
  <GVar584>0.</GVar584> 
  <GVar585>0.</GVar585> 
  <GVar586>0.</GVar586> 
  <GVar587>0.</GVar587> 
  <GVar588>0.</GVar588> 
  <GVar589>0.</GVar589> 
  <GVar590>0.</GVar590> 
  <GVar591>0.</GVar591> 
  <GVar592>0.</GVar592> 
  <GVar593>0.</GVar593> 
  <GVar594>0.</GVar594> 
  <GVar595>0.</GVar595> 
  <GVar596>0.</GVar596> 
  <GVar597>0.</GVar597> 
  <GVar598>0.</GVar598> 
  <GVar599>0.</GVar599> 
  <GVar600>0.</GVar600> 
  </GCodeVar>
- <VideoPlugIn>
  <DROcolor>1178909</DROcolor> 
  <TOOLcolor>255</TOOLcolor> 
  <CROSScolor>16777215</CROSScolor> 
  <ShowTool>0</ShowTool> 
  <ShowMousePos>0</ShowMousePos> 
  <ShowAxisPos>0</ShowAxisPos> 
  <FlipAxis>0</FlipAxis> 
  <ToolDia>0.5</ToolDia> 
  <ScaleFactor>2.e-003</ScaleFactor> 
  </VideoPlugIn>
  </profile>
