<profile>
	<Preferences>
		<PulseSpeed>0</PulseSpeed>
		<Profile>Thermwood</Profile>
		<Layout>1024.set</Layout>
		<FirstRun>1</FirstRun>
		<Units>1</Units>
		<Serial>0</Serial>
		<Port2Input>0</Port2Input>
		<GeckoMode>0</GeckoMode>
		<USBINPUTS>16</USBINPUTS>
		<USBOUTPUTS>16</USBOUTPUTS>
		<Port2On>0</Port2On>
		<Port1On>0</Port1On>
		<Port1Add>888</Port1Add>
		<Port2Add>744</Port2Add>
		<MaxCL>0</MaxCL>
		<MaxNC10>0</MaxNC10>
		<Motor0Active>1</Motor0Active>
		<Motor0DirNeg>0</Motor0DirNeg>
		<Motor0DirPort>0</Motor0DirPort>
		<Motor0DirPin>0</Motor0DirPin>
		<Motor0StepNeg>0</Motor0StepNeg>
		<Motor0StepPort>0</Motor0StepPort>
		<Motor0StepPin>0</Motor0StepPin>
		<Motor1Active>1</Motor1Active>
		<Motor1DirNeg>0</Motor1DirNeg>
		<Motor1DirPort>0</Motor1DirPort>
		<Motor1DirPin>0</Motor1DirPin>
		<Motor1StepNeg>0</Motor1StepNeg>
		<Motor1StepPort>0</Motor1StepPort>
		<Motor1StepPin>0</Motor1StepPin>
		<Motor2Active>1</Motor2Active>
		<Motor2DirNeg>0</Motor2DirNeg>
		<Motor2DirPort>0</Motor2DirPort>
		<Motor2DirPin>0</Motor2DirPin>
		<Motor2StepNeg>0</Motor2StepNeg>
		<Motor2StepPort>0</Motor2StepPort>
		<Motor2StepPin>0</Motor2StepPin>
		<Motor3Active>1</Motor3Active>
		<Motor3DirNeg>0</Motor3DirNeg>
		<Motor3DirPort>0</Motor3DirPort>
		<Motor3DirPin>0</Motor3DirPin>
		<Motor3StepNeg>0</Motor3StepNeg>
		<Motor3StepPort>0</Motor3StepPort>
		<Motor3StepPin>0</Motor3StepPin>
		<Motor4Active>1</Motor4Active>
		<Motor4DirNeg>0</Motor4DirNeg>
		<Motor4DirPort>0</Motor4DirPort>
		<Motor4DirPin>0</Motor4DirPin>
		<Motor4StepNeg>0</Motor4StepNeg>
		<Motor4StepPort>0</Motor4StepPort>
		<Motor4StepPin>0</Motor4StepPin>
		<Motor5Active>1</Motor5Active>
		<Motor5DirNeg>0</Motor5DirNeg>
		<Motor5DirPort>0</Motor5DirPort>
		<Motor5DirPin>0</Motor5DirPin>
		<Motor5StepNeg>0</Motor5StepNeg>
		<Motor5StepPort>0</Motor5StepPort>
		<Motor5StepPin>0</Motor5StepPin>
		<Motor6Active>1</Motor6Active>
		<Motor6DirNeg>0</Motor6DirNeg>
		<Motor6DirPort>0</Motor6DirPort>
		<Motor6DirPin>0</Motor6DirPin>
		<Motor6StepNeg>0</Motor6StepNeg>
		<Motor6StepPort>0</Motor6StepPort>
		<Motor6StepPin>0</Motor6StepPin>
		<Input0Active>0</Input0Active>
		<Input0Port>1</Input0Port>
		<Input0Pin>4</Input0Pin>
		<Input0Neg>1</Input0Neg>
		<Input0Emulated>0</Input0Emulated>
		<Input0EmuKey>0</Input0EmuKey>
		<Input1Active>0</Input1Active>
		<Input1Port>1</Input1Port>
		<Input1Pin>3</Input1Pin>
		<Input1Neg>1</Input1Neg>
		<Input1Emulated>0</Input1Emulated>
		<Input1EmuKey>0</Input1EmuKey>
		<Input2Active>1</Input2Active>
		<Input2Port>1</Input2Port>
		<Input2Pin>17</Input2Pin>
		<Input2Neg>1</Input2Neg>
		<Input2Emulated>0</Input2Emulated>
		<Input2EmuKey>0</Input2EmuKey>
		<Input3Active>0</Input3Active>
		<Input3Port>1</Input3Port>
		<Input3Pin>6</Input3Pin>
		<Input3Neg>1</Input3Neg>
		<Input3Emulated>0</Input3Emulated>
		<Input3EmuKey>0</Input3EmuKey>
		<Input4Active>0</Input4Active>
		<Input4Port>1</Input4Port>
		<Input4Pin>5</Input4Pin>
		<Input4Neg>1</Input4Neg>
		<Input4Emulated>0</Input4Emulated>
		<Input4EmuKey>0</Input4EmuKey>
		<Input5Active>1</Input5Active>
		<Input5Port>1</Input5Port>
		<Input5Pin>18</Input5Pin>
		<Input5Neg>1</Input5Neg>
		<Input5Emulated>0</Input5Emulated>
		<Input5EmuKey>0</Input5EmuKey>
		<Input6Active>0</Input6Active>
		<Input6Port>1</Input6Port>
		<Input6Pin>2</Input6Pin>
		<Input6Neg>1</Input6Neg>
		<Input6Emulated>0</Input6Emulated>
		<Input6EmuKey>0</Input6EmuKey>
		<Input7Active>0</Input7Active>
		<Input7Port>1</Input7Port>
		<Input7Pin>1</Input7Pin>
		<Input7Neg>1</Input7Neg>
		<Input7Emulated>0</Input7Emulated>
		<Input7EmuKey>0</Input7EmuKey>
		<Input8Active>1</Input8Active>
		<Input8Port>1</Input8Port>
		<Input8Pin>19</Input8Pin>
		<Input8Neg>1</Input8Neg>
		<Input8Emulated>0</Input8Emulated>
		<Input8EmuKey>0</Input8EmuKey>
		<Input9Active>0</Input9Active>
		<Input9Port>0</Input9Port>
		<Input9Pin>0</Input9Pin>
		<Input9Neg>0</Input9Neg>
		<Input9Emulated>0</Input9Emulated>
		<Input9EmuKey>0</Input9EmuKey>
		<Input10Active>0</Input10Active>
		<Input10Port>0</Input10Port>
		<Input10Pin>0</Input10Pin>
		<Input10Neg>0</Input10Neg>
		<Input10Emulated>0</Input10Emulated>
		<Input10EmuKey>0</Input10EmuKey>
		<Input11Active>0</Input11Active>
		<Input11Port>0</Input11Port>
		<Input11Pin>0</Input11Pin>
		<Input11Neg>0</Input11Neg>
		<Input11Emulated>0</Input11Emulated>
		<Input11EmuKey>0</Input11EmuKey>
		<Input12Active>0</Input12Active>
		<Input12Port>0</Input12Port>
		<Input12Pin>0</Input12Pin>
		<Input12Neg>0</Input12Neg>
		<Input12Emulated>0</Input12Emulated>
		<Input12EmuKey>0</Input12EmuKey>
		<Input13Active>0</Input13Active>
		<Input13Port>0</Input13Port>
		<Input13Pin>0</Input13Pin>
		<Input13Neg>0</Input13Neg>
		<Input13Emulated>0</Input13Emulated>
		<Input13EmuKey>0</Input13EmuKey>
		<Input14Active>0</Input14Active>
		<Input14Port>0</Input14Port>
		<Input14Pin>0</Input14Pin>
		<Input14Neg>0</Input14Neg>
		<Input14Emulated>0</Input14Emulated>
		<Input14EmuKey>0</Input14EmuKey>
		<Input15Active>0</Input15Active>
		<Input15Port>0</Input15Port>
		<Input15Pin>0</Input15Pin>
		<Input15Neg>0</Input15Neg>
		<Input15Emulated>0</Input15Emulated>
		<Input15EmuKey>0</Input15EmuKey>
		<Input16Active>0</Input16Active>
		<Input16Port>0</Input16Port>
		<Input16Pin>0</Input16Pin>
		<Input16Neg>0</Input16Neg>
		<Input16Emulated>0</Input16Emulated>
		<Input16EmuKey>0</Input16EmuKey>
		<Input17Active>0</Input17Active>
		<Input17Port>0</Input17Port>
		<Input17Pin>0</Input17Pin>
		<Input17Neg>0</Input17Neg>
		<Input17Emulated>0</Input17Emulated>
		<Input17EmuKey>0</Input17EmuKey>
		<Input18Active>0</Input18Active>
		<Input18Port>0</Input18Port>
		<Input18Pin>0</Input18Pin>
		<Input18Neg>0</Input18Neg>
		<Input18Emulated>0</Input18Emulated>
		<Input18EmuKey>0</Input18EmuKey>
		<Input19Active>0</Input19Active>
		<Input19Port>0</Input19Port>
		<Input19Pin>0</Input19Pin>
		<Input19Neg>0</Input19Neg>
		<Input19Emulated>0</Input19Emulated>
		<Input19EmuKey>0</Input19EmuKey>
		<Input20Active>0</Input20Active>
		<Input20Port>0</Input20Port>
		<Input20Pin>0</Input20Pin>
		<Input20Neg>0</Input20Neg>
		<Input20Emulated>0</Input20Emulated>
		<Input20EmuKey>0</Input20EmuKey>
		<Input21Active>0</Input21Active>
		<Input21Port>0</Input21Port>
		<Input21Pin>0</Input21Pin>
		<Input21Neg>0</Input21Neg>
		<Input21Emulated>0</Input21Emulated>
		<Input21EmuKey>0</Input21EmuKey>
		<Input22Active>0</Input22Active>
		<Input22Port>0</Input22Port>
		<Input22Pin>0</Input22Pin>
		<Input22Neg>0</Input22Neg>
		<Input22Emulated>0</Input22Emulated>
		<Input22EmuKey>0</Input22EmuKey>
		<Input23Active>0</Input23Active>
		<Input23Port>0</Input23Port>
		<Input23Pin>0</Input23Pin>
		<Input23Neg>0</Input23Neg>
		<Input23Emulated>0</Input23Emulated>
		<Input23EmuKey>0</Input23EmuKey>
		<Input24Active>0</Input24Active>
		<Input24Port>0</Input24Port>
		<Input24Pin>0</Input24Pin>
		<Input24Neg>0</Input24Neg>
		<Input24Emulated>0</Input24Emulated>
		<Input24EmuKey>0</Input24EmuKey>
		<Input25Active>1</Input25Active>
		<Input25Port>1</Input25Port>
		<Input25Pin>16</Input25Pin>
		<Input25Neg>0</Input25Neg>
		<Input25Emulated>0</Input25Emulated>
		<Input25EmuKey>0</Input25EmuKey>
		<Input26Active>0</Input26Active>
		<Input26Port>0</Input26Port>
		<Input26Pin>0</Input26Pin>
		<Input26Neg>0</Input26Neg>
		<Input26Emulated>0</Input26Emulated>
		<Input26EmuKey>0</Input26EmuKey>
		<Input27Active>0</Input27Active>
		<Input27Port>0</Input27Port>
		<Input27Pin>0</Input27Pin>
		<Input27Neg>0</Input27Neg>
		<Input27Emulated>0</Input27Emulated>
		<Input27EmuKey>0</Input27EmuKey>
		<Input28Active>0</Input28Active>
		<Input28Port>0</Input28Port>
		<Input28Pin>0</Input28Pin>
		<Input28Neg>0</Input28Neg>
		<Input28Emulated>0</Input28Emulated>
		<Input28EmuKey>0</Input28EmuKey>
		<Input29Active>0</Input29Active>
		<Input29Port>0</Input29Port>
		<Input29Pin>0</Input29Pin>
		<Input29Neg>0</Input29Neg>
		<Input29Emulated>0</Input29Emulated>
		<Input29EmuKey>0</Input29EmuKey>
		<Input30Active>0</Input30Active>
		<Input30Port>0</Input30Port>
		<Input30Pin>0</Input30Pin>
		<Input30Neg>0</Input30Neg>
		<Input30Emulated>0</Input30Emulated>
		<Input30EmuKey>0</Input30EmuKey>
		<Input31Active>0</Input31Active>
		<Input31Port>0</Input31Port>
		<Input31Pin>0</Input31Pin>
		<Input31Neg>0</Input31Neg>
		<Input31Emulated>0</Input31Emulated>
		<Input31EmuKey>0</Input31EmuKey>
		<Input32Active>0</Input32Active>
		<Input32Port>0</Input32Port>
		<Input32Pin>0</Input32Pin>
		<Input32Neg>0</Input32Neg>
		<Input32Emulated>0</Input32Emulated>
		<Input32EmuKey>0</Input32EmuKey>
		<Input33Active>0</Input33Active>
		<Input33Port>0</Input33Port>
		<Input33Pin>0</Input33Pin>
		<Input33Neg>0</Input33Neg>
		<Input33Emulated>0</Input33Emulated>
		<Input33EmuKey>0</Input33EmuKey>
		<Input34Active>0</Input34Active>
		<Input34Port>0</Input34Port>
		<Input34Pin>0</Input34Pin>
		<Input34Neg>0</Input34Neg>
		<Input34Emulated>0</Input34Emulated>
		<Input34EmuKey>0</Input34EmuKey>
		<Input35Active>0</Input35Active>
		<Input35Port>0</Input35Port>
		<Input35Pin>0</Input35Pin>
		<Input35Neg>0</Input35Neg>
		<Input35Emulated>0</Input35Emulated>
		<Input35EmuKey>0</Input35EmuKey>
		<Input36Active>0</Input36Active>
		<Input36Port>0</Input36Port>
		<Input36Pin>0</Input36Pin>
		<Input36Neg>0</Input36Neg>
		<Input36Emulated>0</Input36Emulated>
		<Input36EmuKey>0</Input36EmuKey>
		<Input37Active>0</Input37Active>
		<Input37Port>0</Input37Port>
		<Input37Pin>0</Input37Pin>
		<Input37Neg>0</Input37Neg>
		<Input37Emulated>0</Input37Emulated>
		<Input37EmuKey>0</Input37EmuKey>
		<Input38Active>0</Input38Active>
		<Input38Port>0</Input38Port>
		<Input38Pin>0</Input38Pin>
		<Input38Neg>0</Input38Neg>
		<Input38Emulated>0</Input38Emulated>
		<Input38EmuKey>0</Input38EmuKey>
		<Input39Active>0</Input39Active>
		<Input39Port>0</Input39Port>
		<Input39Pin>0</Input39Pin>
		<Input39Neg>0</Input39Neg>
		<Input39Emulated>0</Input39Emulated>
		<Input39EmuKey>0</Input39EmuKey>
		<Input40Active>0</Input40Active>
		<Input40Port>0</Input40Port>
		<Input40Pin>0</Input40Pin>
		<Input40Neg>0</Input40Neg>
		<Input40Emulated>0</Input40Emulated>
		<Input40EmuKey>0</Input40EmuKey>
		<Input41Active>0</Input41Active>
		<Input41Port>0</Input41Port>
		<Input41Pin>0</Input41Pin>
		<Input41Neg>0</Input41Neg>
		<Input41Emulated>0</Input41Emulated>
		<Input41EmuKey>0</Input41EmuKey>
		<Input42Active>0</Input42Active>
		<Input42Port>0</Input42Port>
		<Input42Pin>0</Input42Pin>
		<Input42Neg>0</Input42Neg>
		<Input42Emulated>0</Input42Emulated>
		<Input42EmuKey>0</Input42EmuKey>
		<Input43Active>0</Input43Active>
		<Input43Port>0</Input43Port>
		<Input43Pin>0</Input43Pin>
		<Input43Neg>0</Input43Neg>
		<Input43Emulated>0</Input43Emulated>
		<Input43EmuKey>0</Input43EmuKey>
		<Input44Active>0</Input44Active>
		<Input44Port>0</Input44Port>
		<Input44Pin>0</Input44Pin>
		<Input44Neg>0</Input44Neg>
		<Input44Emulated>0</Input44Emulated>
		<Input44EmuKey>0</Input44EmuKey>
		<Input45Active>0</Input45Active>
		<Input45Port>0</Input45Port>
		<Input45Pin>0</Input45Pin>
		<Input45Neg>0</Input45Neg>
		<Input45Emulated>0</Input45Emulated>
		<Input45EmuKey>0</Input45EmuKey>
		<Input46Active>0</Input46Active>
		<Input46Port>0</Input46Port>
		<Input46Pin>0</Input46Pin>
		<Input46Neg>0</Input46Neg>
		<Input46Emulated>0</Input46Emulated>
		<Input46EmuKey>0</Input46EmuKey>
		<Input47Active>0</Input47Active>
		<Input47Port>0</Input47Port>
		<Input47Pin>0</Input47Pin>
		<Input47Neg>0</Input47Neg>
		<Input47Emulated>0</Input47Emulated>
		<Input47EmuKey>0</Input47EmuKey>
		<Input48Active>0</Input48Active>
		<Input48Port>0</Input48Port>
		<Input48Pin>0</Input48Pin>
		<Input48Neg>0</Input48Neg>
		<Input48Emulated>0</Input48Emulated>
		<Input48EmuKey>0</Input48EmuKey>
		<Input49Active>0</Input49Active>
		<Input49Port>0</Input49Port>
		<Input49Pin>0</Input49Pin>
		<Input49Neg>0</Input49Neg>
		<Input49Emulated>0</Input49Emulated>
		<Input49EmuKey>0</Input49EmuKey>
		<Input50Active>0</Input50Active>
		<Input50Port>0</Input50Port>
		<Input50Pin>0</Input50Pin>
		<Input50Neg>0</Input50Neg>
		<Input50Emulated>0</Input50Emulated>
		<Input50EmuKey>0</Input50EmuKey>
		<Input51Active>0</Input51Active>
		<Input51Port>0</Input51Port>
		<Input51Pin>0</Input51Pin>
		<Input51Neg>0</Input51Neg>
		<Input51Emulated>0</Input51Emulated>
		<Input51EmuKey>0</Input51EmuKey>
		<Input52Active>0</Input52Active>
		<Input52Port>0</Input52Port>
		<Input52Pin>0</Input52Pin>
		<Input52Neg>0</Input52Neg>
		<Input52Emulated>0</Input52Emulated>
		<Input52EmuKey>0</Input52EmuKey>
		<Output0Active>0</Output0Active>
		<Output0Port>0</Output0Port>
		<Output0Pin>0</Output0Pin>
		<Output0Neg>0</Output0Neg>
		<Output1Active>0</Output1Active>
		<Output1Port>0</Output1Port>
		<Output1Pin>0</Output1Pin>
		<Output1Neg>0</Output1Neg>
		<Output2Active>0</Output2Active>
		<Output2Port>0</Output2Port>
		<Output2Pin>0</Output2Pin>
		<Output2Neg>0</Output2Neg>
		<Output3Active>0</Output3Active>
		<Output3Port>0</Output3Port>
		<Output3Pin>0</Output3Pin>
		<Output3Neg>0</Output3Neg>
		<Output4Active>0</Output4Active>
		<Output4Port>0</Output4Port>
		<Output4Pin>0</Output4Pin>
		<Output4Neg>0</Output4Neg>
		<Output5Active>0</Output5Active>
		<Output5Port>0</Output5Port>
		<Output5Pin>0</Output5Pin>
		<Output5Neg>0</Output5Neg>
		<Output6Active>0</Output6Active>
		<Output6Port>0</Output6Port>
		<Output6Pin>0</Output6Pin>
		<Output6Neg>0</Output6Neg>
		<Output7Active>1</Output7Active>
		<Output7Port>1</Output7Port>
		<Output7Pin>1</Output7Pin>
		<Output7Neg>0</Output7Neg>
		<Output8Active>1</Output8Active>
		<Output8Port>1</Output8Port>
		<Output8Pin>2</Output8Pin>
		<Output8Neg>0</Output8Neg>
		<Output9Active>1</Output9Active>
		<Output9Port>1</Output9Port>
		<Output9Pin>3</Output9Pin>
		<Output9Neg>0</Output9Neg>
		<Output10Active>0</Output10Active>
		<Output10Port>1</Output10Port>
		<Output10Pin>4</Output10Pin>
		<Output10Neg>0</Output10Neg>
		<Output11Active>0</Output11Active>
		<Output11Port>1</Output11Port>
		<Output11Pin>5</Output11Pin>
		<Output11Neg>0</Output11Neg>
		<Output12Active>0</Output12Active>
		<Output12Port>1</Output12Port>
		<Output12Pin>6</Output12Pin>
		<Output12Neg>0</Output12Neg>
		<Output13Active>1</Output13Active>
		<Output13Port>1</Output13Port>
		<Output13Pin>17</Output13Pin>
		<Output13Neg>0</Output13Neg>
		<Output14Active>0</Output14Active>
		<Output14Port>0</Output14Port>
		<Output14Pin>0</Output14Pin>
		<Output14Neg>0</Output14Neg>
		<Output15Active>0</Output15Active>
		<Output15Port>0</Output15Port>
		<Output15Pin>0</Output15Pin>
		<Output15Neg>0</Output15Neg>
		<Output16Active>0</Output16Active>
		<Output16Port>0</Output16Port>
		<Output16Pin>0</Output16Pin>
		<Output16Neg>0</Output16Neg>
		<Output17Active>0</Output17Active>
		<Output17Port>0</Output17Port>
		<Output17Pin>0</Output17Pin>
		<Output17Neg>0</Output17Neg>
		<Output18Active>0</Output18Active>
		<Output18Port>0</Output18Port>
		<Output18Pin>0</Output18Pin>
		<Output18Neg>0</Output18Neg>
		<Output19Active>0</Output19Active>
		<Output19Port>0</Output19Port>
		<Output19Pin>0</Output19Pin>
		<Output19Neg>0</Output19Neg>
		<Output20Active>0</Output20Active>
		<Output20Port>0</Output20Port>
		<Output20Pin>0</Output20Pin>
		<Output20Neg>0</Output20Neg>
		<Output21Active>0</Output21Active>
		<Output21Port>0</Output21Port>
		<Output21Pin>0</Output21Pin>
		<Output21Neg>0</Output21Neg>
		<Output22Active>0</Output22Active>
		<Output22Port>0</Output22Port>
		<Output22Pin>0</Output22Pin>
		<Output22Neg>0</Output22Neg>
		<Output23Active>0</Output23Active>
		<Output23Port>0</Output23Port>
		<Output23Pin>0</Output23Pin>
		<Output23Neg>0</Output23Neg>
		<Output24Active>0</Output24Active>
		<Output24Port>0</Output24Port>
		<Output24Pin>0</Output24Pin>
		<Output24Neg>0</Output24Neg>
		<Output25Active>0</Output25Active>
		<Output25Port>0</Output25Port>
		<Output25Pin>0</Output25Pin>
		<Output25Neg>0</Output25Neg>
		<Output26Active>0</Output26Active>
		<Output26Port>0</Output26Port>
		<Output26Pin>0</Output26Pin>
		<Output26Neg>0</Output26Neg>
		<Output27Active>0</Output27Active>
		<Output27Port>0</Output27Port>
		<Output27Pin>0</Output27Pin>
		<Output27Neg>0</Output27Neg>
		<Output28Active>0</Output28Active>
		<Output28Port>0</Output28Port>
		<Output28Pin>0</Output28Pin>
		<Output28Neg>0</Output28Neg>
		<Output29Active>0</Output29Active>
		<Output29Port>0</Output29Port>
		<Output29Pin>0</Output29Pin>
		<Output29Neg>0</Output29Neg>
		<Output30Active>0</Output30Active>
		<Output30Port>0</Output30Port>
		<Output30Pin>0</Output30Pin>
		<Output30Neg>0</Output30Neg>
		<Encoder0Active>0</Encoder0Active>
		<Encoder0APort>0</Encoder0APort>
		<Encoder0APin>0</Encoder0APin>
		<Encoder0BPort>0</Encoder0BPort>
		<Encoder0BPin>0</Encoder0BPin>
		<Encoder0Cal>1.000000</Encoder0Cal>
		<Encoder1Active>0</Encoder1Active>
		<Encoder1APort>0</Encoder1APort>
		<Encoder1APin>0</Encoder1APin>
		<Encoder1BPort>0</Encoder1BPort>
		<Encoder1BPin>0</Encoder1BPin>
		<Encoder1Cal>1.000000</Encoder1Cal>
		<Encoder2Active>0</Encoder2Active>
		<Encoder2APort>0</Encoder2APort>
		<Encoder2APin>0</Encoder2APin>
		<Encoder2BPort>0</Encoder2BPort>
		<Encoder2BPin>0</Encoder2BPin>
		<Encoder2Cal>1.000000</Encoder2Cal>
		<Encoder3Active>0</Encoder3Active>
		<Encoder3APort>0</Encoder3APort>
		<Encoder3APin>0</Encoder3APin>
		<Encoder3BPort>0</Encoder3BPort>
		<Encoder3BPin>0</Encoder3BPin>
		<Encoder3Cal>1.000000</Encoder3Cal>
		<Encoder4Active>0</Encoder4Active>
		<Encoder4APort>0</Encoder4APort>
		<Encoder4APin>0</Encoder4APin>
		<Encoder4BPort>0</Encoder4BPort>
		<Encoder4BPin>0</Encoder4BPin>
		<Encoder4Cal>1.000000</Encoder4Cal>
		<Encoder5Active>0</Encoder5Active>
		<Encoder5APort>0</Encoder5APort>
		<Encoder5APin>0</Encoder5APin>
		<Encoder5BPort>0</Encoder5BPort>
		<Encoder5BPin>0</Encoder5BPin>
		<Encoder5Cal>1.000000</Encoder5Cal>
		<Encoder6Active>0</Encoder6Active>
		<Encoder6APort>0</Encoder6APort>
		<Encoder6APin>0</Encoder6APin>
		<Encoder6BPort>0</Encoder6BPort>
		<Encoder6BPin>0</Encoder6BPin>
		<Encoder6Cal>1.000000</Encoder6Cal>
		<Encoder7Active>0</Encoder7Active>
		<Encoder7APort>0</Encoder7APort>
		<Encoder7APin>0</Encoder7APin>
		<Encoder7BPort>0</Encoder7BPort>
		<Encoder7BPin>0</Encoder7BPin>
		<Encoder7Cal></Encoder7Cal>
		<Configured>1</Configured>
		<SlavePrim>0</SlavePrim>
		<Slave>-1</Slave>
		<AxisKeys0>39</AxisKeys0>
		<AxisKeys1>37</AxisKeys1>
		<AxisKeys2>38</AxisKeys2>
		<AxisKeys3>40</AxisKeys3>
		<AxisKeys4>33</AxisKeys4>
		<AxisKeys5>34</AxisKeys5>
		<AxisKeys6>999</AxisKeys6>
		<AxisKeys7>999</AxisKeys7>
		<AxisKeys8>999</AxisKeys8>
		<AxisKeys9>999</AxisKeys9>
		<AxisKeys10>999</AxisKeys10>
		<AxisKeys11>999</AxisKeys11>
		<DROHotKey>999</DROHotKey>
		<ListKey>999</ListKey>
		<MDIHotKey>999</MDIHotKey>
		<GCodeHotKey>999</GCodeHotKey>
		<OEM1>-1</OEM1>
		<OEM2>-1</OEM2>
		<OEM3>-1</OEM3>
		<OEM4>-1</OEM4>
		<OEM5>-1</OEM5>
		<OEM6>-1</OEM6>
		<PulseWidth>0</PulseWidth>
		<DirPulse>0</DirPulse>
		<BackX>0.</BackX>
		<BackY>0.</BackY>
		<BackZ>0.</BackZ>
		<BackA>0.</BackA>
		<BackB>0.</BackB>
		<BackC>0.</BackC>
		<BackSpeed>20.</BackSpeed>
		<BB>0.</BB>
		<BR>0.</BR>
		<BG>0.</BG>
		<FB>1.</FB>
		<FR>0.</FR>
		<FG>0.</FG>
		<RB>0.</RB>
		<RR>1.</RR>
		<RG>0.</RG>
		<AB>0.7</AB>
		<AR>0.7</AR>
		<AG>0.2</AG>
		<EG>1.</EG>
		<ER>1.</ER>
		<EB>0.</EB>
		<JogFollow>0</JogFollow>
		<G92Off>1</G92Off>
		<RadiusCompOff>1</RadiusCompOff>
		<Debounce>1500</Debounce>
		<PlasmaMode>0</PlasmaMode>
		<NoAngle>0</NoAngle>
		<AAngular>1</AAngular>
		<BAngular>1</BAngular>
		<CAngular>1</CAngular>
		<IndexDebounce>1</IndexDebounce>
		<DROPERSIST>1</DROPERSIST>
		<DwellinMilli>0</DwellinMilli>
		<IJMode>1</IJMode>
		<INIT>G20</INIT>
		<InitAllResets>0</InitAllResets>
		<AutoScreens>1</AutoScreens>
		<TORCHVON>0</TORCHVON>
		<TORCHVOLTS>1000</TORCHVOLTS>
		<HWSAFE>1</HWSAFE>
		<ShortRot>0</ShortRot>
		<LookAhead>100</LookAhead>
		<WatchDog>1</WatchDog>
		<Plane>1</Plane>
		<MPG1>0</MPG1>
		<MPG2>0</MPG2>
		<HotKeysPersist>0</HotKeysPersist>
		<HoldInput1>0</HoldInput1>
		<M3s>380</M3s>
		<UseCR>0</UseCR>
		<PlasmaHome>0</PlasmaHome>
		<Homann>0</Homann>
		<UseSLS>0</UseSLS>
		<Dist0>9.3e+003</Dist0>
		<Dist1>5.6e+003</Dist1>
		<Dist2>1.1e+003</Dist2>
		<Dist3>0.</Dist3>
		<Dist4>0.</Dist4>
		<Dist5>0.</Dist5>
		<OverMode2>0</OverMode2>
		<BitPack1>0</BitPack1>
		<BitPack1Reg>16</BitPack1Reg>
		<BitPackOut>0</BitPackOut>
		<BitPackOutReg>16</BitPackOutReg>
		<LaserPort>1</LaserPort>
		<LaserBaud>9600</LaserBaud>
		<LaserStops>1</LaserStops>
		<LaserData>1</LaserData>
		<LaserInit>&gt;</LaserInit>
		<LaserCommand>&gt;</LaserCommand>
		<MacroPump>0</MacroPump>
		<VelMode>2</VelMode>
		<VelPer1>5.</VelPer1>
		<VelPer2>5.</VelPer2>
		<MPGFeed>2.e+002</MPGFeed>
		<ModSpindleCal>1.638e+004</ModSpindleCal>
		<ModSpindleOn>0</ModSpindleOn>
		<ModSpindleReg>64</ModSpindleReg>
		<ShuttleAccel>2048</ShuttleAccel>
		<Flash>1</Flash>
		<ImmediateOff>0</ImmediateOff>
		<UseSafeZ>1</UseSafeZ>
		<AdvancedComp>1</AdvancedComp>
		<TorchOff>0</TorchOff>
		<LaserStandby>0</LaserStandby>
		<RaiseLower>0</RaiseLower>
		<OEMDUAL>0</OEMDUAL>
		<IncBuffer>5</IncBuffer>
		<Formula0>x</Formula0>
		<Formula1>y</Formula1>
		<Formula2>z</Formula2>
		<Formula3>a</Formula3>
		<Formula4>b</Formula4>
		<Formula5>c</Formula5>
		<Formular>0</Formular>
		<PanelOut>350</PanelOut>
		<nModBusReg>0</nModBusReg>
		<ModBusRegOn>0</ModBusRegOn>
		<Tool>0</Tool>
		<Sherline>0</Sherline>
		<ToolPost>1</ToolPost>
		<RapidOverRide>0</RapidOverRide>
		<XCLength>1.3e+003</XCLength>
		<YCLength>1.3e+003</YCLength>
		<ZCLength>1.3e+003</ZCLength>
		<ToolPostOffset>0.</ToolPostOffset>
		<OEM7>-1</OEM7>
		<OEM8>-1</OEM8>
		<OEM9>-1</OEM9>
		<OEM10>-1</OEM10>
		<OEM11>-1</OEM11>
		<OEM12>-1</OEM12>
		<OEM13>-1</OEM13>
		<OEM14>-1</OEM14>
		<OEM15>-1</OEM15>
		<MPGVel0>1.e+002</MPGVel0>
		<MPGVel1>1.e+002</MPGVel1>
		<MPGVel2>1.e+002</MPGVel2>
		<MPGVel3>1.e+002</MPGVel3>
		<MPGVel4>1.e+002</MPGVel4>
		<MPGVel5>1.e+002</MPGVel5>
		<MPGVel6>1.e+002</MPGVel6>
		<ByPassFeed>1.e+003</ByPassFeed>
		<XMapOn>0</XMapOn>
		<YMapOn>0</YMapOn>
		<ZMapOn>0</ZMapOn>
		<SecondsOn>396666</SecondsOn>
		<SerialType>0</SerialType>
		<SpinAverage>0</SpinAverage>
		<Dig4Axis>0</Dig4Axis>
		<DigLetter>0</DigLetter>
		<CutType>0</CutType>
		<InfeedType>0</InfeedType>
		<LastWizard>C:\Mach3\Addons\Newfangled\newfangled.set</LastWizard>
		<Z25D>0</Z25D>
		<ModBus>0</ModBus>
		<ChargeAlwaysOn>0</ChargeAlwaysOn>
		<ToolFlip>1</ToolFlip>
		<SpinCCW>8</SpinCCW>
		<SpinCW>7</SpinCW>
		<Flood>8</Flood>
		<Mist>7</Mist>
		<SpinActual>0</SpinActual>
		<SpinDelayCW>1.</SpinDelayCW>
		<SpinDelayCCW>1.</SpinDelayCCW>
		<SpinDownCW>1.</SpinDownCW>
		<SpinDownCCW>1.</SpinDownCCW>
		<StockSize>50</StockSize>
		<ShowSolid>1</ShowSolid>
		<RapidFeed>10</RapidFeed>
		<MatRed>0.</MatRed>
		<MatGreen>0.1</MatGreen>
		<MatBlue>0.1</MatBlue>
		<SpinP>4.</SpinP>
		<SpinI>1.</SpinI>
		<SpinD>0.</SpinD>
		<SpinClosed>0</SpinClosed>
		<MinPerPass>0.1</MinPerPass>
		<NoSpindle>0</NoSpindle>
		<NoFlood>1</NoFlood>
		<PWMin>0</PWMin>
		<PULLEY>0</PULLEY>
		<SPEED1>22000</SPEED1>
		<SPEED2>2000</SPEED2>
		<SPEED3>4000</SPEED3>
		<SPEED4>21000</SPEED4>
		<LSPEED1>0</LSPEED1>
		<LSPEED2>0</LSPEED2>
		<LSPEED3>0</LSPEED3>
		<LSPEED4>0</LSPEED4>
		<PWM>1</PWM>
		<RefSpeed0>20</RefSpeed0>
		<RefSpeed1>20</RefSpeed1>
		<RefSpeed2>20</RefSpeed2>
		<RefSpeed3>20</RefSpeed3>
		<RefSpeed4>20</RefSpeed4>
		<RefSpeed5>20</RefSpeed5>
		<M0SoftRamp>0.5</M0SoftRamp>
		<M1SoftRamp>0.5</M1SoftRamp>
		<M2SoftRamp>0.5</M2SoftRamp>
		<M3SoftRamp>1.</M3SoftRamp>
		<M4SoftRamp>1.</M4SoftRamp>
		<M5SoftRamp>1.</M5SoftRamp>
		<FeedInc>5.</FeedInc>
		<DepthLastPass>0.</DepthLastPass>
		<InFeed>29.5</InFeed>
		<Spring>1.</Spring>
		<MinDepth>1.e-003</MinDepth>
		<XClear>0.1</XClear>
		<ZClear>0.1</ZClear>
		<CutDepth>0.1</CutDepth>
		<Chamfer>0.</Chamfer>
		<DepthFirstPass>0.1</DepthFirstPass>
		<M0Max>100.</M0Max>
		<M1Max>50.</M1Max>
		<M2Max>6.75</M2Max>
		<M3Max>150.</M3Max>
		<M4Max>150.</M4Max>
		<M5Max>150.</M5Max>
		<M0Min>0.</M0Min>
		<M1Min>0.</M1Min>
		<M2Min>0.</M2Min>
		<M3Min>-150.</M3Min>
		<M4Min>-150.</M4Min>
		<M5Min>-150.</M5Min>
		<M0Neg>0</M0Neg>
		<M1Neg>0</M1Neg>
		<M2Neg>0</M2Neg>
		<M3Neg>0</M3Neg>
		<M4Neg>0</M4Neg>
		<M5Neg>0</M5Neg>
		<M0AutoZero>1</M0AutoZero>
		<M1AutoZero>1</M1AutoZero>
		<M2AutoZero>1</M2AutoZero>
		<M3AutoZero>1</M3AutoZero>
		<M4AutoZero>1</M4AutoZero>
		<M5AutoZero>1</M5AutoZero>
		<M0Rev>0</M0Rev>
		<M1Rev>1</M1Rev>
		<M2Rev>1</M2Rev>
		<M3Rev>0</M3Rev>
		<M4Rev>0</M4Rev>
		<M5Rev>0</M5Rev>
		<M6Rev>0</M6Rev>
		<OffPersist>1</OffPersist>
		<Diameter>0</Diameter>
		<OffDialogs>1</OffDialogs>
		<G54Back>1</G54Back>
		<GougeCheck>0</GougeCheck>
		<AxisToMotor0>0</AxisToMotor0>
		<AxisToMotor1>1</AxisToMotor1>
		<AxisToMotor2>2</AxisToMotor2>
		<AxisToMotor3>3</AxisToMotor3>
		<AxisToMotor4>4</AxisToMotor4>
		<AxisToMotor5>5</AxisToMotor5>
		<AxisToMotor6>6</AxisToMotor6>
		<JogActive>1</JogActive>
		<BLState0>0</BLState0>
		<BLState1>1</BLState1>
		<BLState2>0</BLState2>
		<BLState3>0</BLState3>
		<BLState4>0</BLState4>
		<BLState5>0</BLState5>
		<SlowMode>0</SlowMode>
		<JogPersist>1</JogPersist>
		<ToolRotations>1</ToolRotations>
		<SoftLimit>0</SoftLimit>
		<JogMode>0</JogMode>
		<JogMode2>0</JogMode2>
		<EncJogAxis2>2</EncJogAxis2>
		<TaperRatio>1.</TaperRatio>
		<XStart>0</XStart>
		<YStart>26</YStart>
		<ZStart>0</ZStart>
		<AStart>0</AStart>
		<BStart>0</BStart>
		<CStart>0</CStart>
		<SpinInc>10</SpinInc>
		<Enc0>0.</Enc0>
		<Enc1>0.</Enc1>
		<Enc2>0.</Enc2>
		<Enc3>0.</Enc3>
		<TangentalControl>0</TangentalControl>
		<BaudRate>9600</BaudRate>
		<ComPort>1</ComPort>
		<NoPlunge>0</NoPlunge>
		<PlungeLimit>60</PlungeLimit>
		<AutoTool>0</AutoTool>
		<AutoSpindle>0</AutoSpindle>
		<LaserMode>0</LaserMode>
		<FeedMode>0</FeedMode>
		<OriginSphere>1</OriginSphere>
		<m_3dCompass>1</m_3dCompass>
		<Boundries>0</Boundries>
		<ToolPosition>1</ToolPosition>
		<AParallel>0</AParallel>
		<ZINHPersist>0</ZINHPersist>
		<OVPersist>1</OVPersist>
		<BacklashOn>0</BacklashOn>
		<PathMode>2</PathMode>
		<ThrottleFunc>2</ThrottleFunc>
		<JoyOn>0</JoyOn>
		<PWMBase>416</PWMBase>
		<JogSpeed>90.</JogSpeed>
		<G73PullBack>0.1</G73PullBack>
		<CVFeedOn>0</CVFeedOn>
		<CVFeedRate>1.</CVFeedRate>
		<AtoX>0.</AtoX>
		<AtoY>0.</AtoY>
		<AtoZ>0.</AtoZ>
		<OEMDRO0>0.</OEMDRO0>
		<OEMLED0>0</OEMLED0>
		<OEMDRO1>0.</OEMDRO1>
		<OEMLED1>0</OEMLED1>
		<OEMDRO2>0.</OEMDRO2>
		<OEMLED2>0</OEMLED2>
		<OEMDRO3>0.</OEMDRO3>
		<OEMLED3>0</OEMLED3>
		<OEMDRO4>0.</OEMDRO4>
		<OEMLED4>0</OEMLED4>
		<OEMDRO5>0.</OEMDRO5>
		<OEMLED5>0</OEMLED5>
		<OEMDRO6>0.</OEMDRO6>
		<OEMLED6>0</OEMLED6>
		<OEMDRO7>0.</OEMDRO7>
		<OEMLED7>0</OEMLED7>
		<OEMDRO8>0.</OEMDRO8>
		<OEMLED8>0</OEMLED8>
		<OEMDRO9>0.</OEMDRO9>
		<OEMLED9>0</OEMLED9>
		<OEMDRO10>0.</OEMDRO10>
		<OEMLED10>0</OEMLED10>
		<OEMDRO11>0.</OEMDRO11>
		<OEMLED11>0</OEMLED11>
		<OEMDRO12>0.</OEMDRO12>
		<OEMLED12>0</OEMLED12>
		<OEMDRO13>0.</OEMDRO13>
		<OEMLED13>0</OEMLED13>
		<OEMDRO14>0.</OEMDRO14>
		<OEMLED14>0</OEMLED14>
		<OEMDRO15>0.</OEMDRO15>
		<OEMLED15>0</OEMLED15>
		<OEMDRO16>0.</OEMDRO16>
		<OEMLED16>0</OEMLED16>
		<OEMDRO17>0.</OEMDRO17>
		<OEMLED17>0</OEMLED17>
		<OEMDRO18>0.</OEMDRO18>
		<OEMLED18>0</OEMLED18>
		<OEMDRO19>0.</OEMDRO19>
		<OEMLED19>0</OEMLED19>
		<OEMDRO20>0.</OEMDRO20>
		<OEMLED20>0</OEMLED20>
		<OEMDRO21>0.</OEMDRO21>
		<OEMLED21>0</OEMLED21>
		<OEMDRO22>0.</OEMDRO22>
		<OEMLED22>0</OEMLED22>
		<OEMDRO23>0.</OEMDRO23>
		<OEMLED23>0</OEMLED23>
		<OEMDRO24>0.</OEMDRO24>
		<OEMLED24>0</OEMLED24>
		<OEMDRO25>0.</OEMDRO25>
		<OEMLED25>0</OEMLED25>
		<OEMDRO26>0.</OEMDRO26>
		<OEMLED26>0</OEMLED26>
		<OEMDRO27>0.</OEMDRO27>
		<OEMLED27>0</OEMLED27>
		<OEMDRO28>0.</OEMDRO28>
		<OEMLED28>0</OEMLED28>
		<OEMDRO29>0.</OEMDRO29>
		<OEMLED29>0</OEMLED29>
		<OEMDRO30>0.</OEMDRO30>
		<OEMLED30>0</OEMLED30>
		<OEMDRO31>0.</OEMDRO31>
		<OEMLED31>0</OEMLED31>
		<OEMDRO32>0.</OEMDRO32>
		<OEMLED32>0</OEMLED32>
		<OEMDRO33>0.</OEMDRO33>
		<OEMLED33>0</OEMLED33>
		<OEMDRO34>0.</OEMDRO34>
		<OEMLED34>0</OEMLED34>
		<OEMDRO35>0.</OEMDRO35>
		<OEMLED35>0</OEMLED35>
		<OEMDRO36>0.</OEMDRO36>
		<OEMLED36>0</OEMLED36>
		<OEMDRO37>0.</OEMDRO37>
		<OEMLED37>0</OEMLED37>
		<OEMDRO38>0.</OEMDRO38>
		<OEMLED38>0</OEMLED38>
		<OEMDRO39>0.</OEMDRO39>
		<OEMLED39>0</OEMLED39>
		<OEMDRO40>0.</OEMDRO40>
		<OEMLED40>0</OEMLED40>
		<OEMDRO41>0.</OEMDRO41>
		<OEMLED41>0</OEMLED41>
		<OEMDRO42>0.</OEMDRO42>
		<OEMLED42>0</OEMLED42>
		<OEMDRO43>0.</OEMDRO43>
		<OEMLED43>0</OEMLED43>
		<OEMDRO44>0.</OEMDRO44>
		<OEMLED44>0</OEMLED44>
		<OEMDRO45>0.</OEMDRO45>
		<OEMLED45>0</OEMLED45>
		<OEMDRO46>0.</OEMDRO46>
		<OEMLED46>0</OEMLED46>
		<OEMDRO47>0.</OEMDRO47>
		<OEMLED47>0</OEMLED47>
		<OEMDRO48>0.</OEMDRO48>
		<OEMLED48>0</OEMLED48>
		<OEMDRO49>0.</OEMDRO49>
		<OEMLED49>0</OEMLED49>
		<OEMDRO50>0.</OEMDRO50>
		<OEMLED50>0</OEMLED50>
		<OEMDRO51>0.</OEMDRO51>
		<OEMLED51>0</OEMLED51>
		<OEMDRO52>0.</OEMDRO52>
		<OEMLED52>0</OEMLED52>
		<OEMDRO53>0.</OEMDRO53>
		<OEMLED53>0</OEMLED53>
		<OEMDRO54>0.</OEMDRO54>
		<OEMLED54>0</OEMLED54>
		<OEMDRO55>0.</OEMDRO55>
		<OEMLED55>0</OEMLED55>
		<OEMDRO56>0.</OEMDRO56>
		<OEMLED56>0</OEMLED56>
		<OEMDRO57>0.</OEMDRO57>
		<OEMLED57>0</OEMLED57>
		<OEMDRO58>0.</OEMDRO58>
		<OEMLED58>0</OEMLED58>
		<OEMDRO59>0.</OEMDRO59>
		<OEMLED59>0</OEMLED59>
		<OEMDRO60>0.</OEMDRO60>
		<OEMLED60>0</OEMLED60>
		<OEMDRO61>0.</OEMDRO61>
		<OEMLED61>0</OEMLED61>
		<OEMDRO62>0.</OEMDRO62>
		<OEMLED62>0</OEMLED62>
		<OEMDRO63>0.</OEMDRO63>
		<OEMLED63>0</OEMLED63>
		<OEMDRO64>0.</OEMDRO64>
		<OEMLED64>0</OEMLED64>
		<OEMDRO65>0.</OEMDRO65>
		<OEMLED65>0</OEMLED65>
		<OEMDRO66>0.</OEMDRO66>
		<OEMLED66>0</OEMLED66>
		<OEMDRO67>0.</OEMDRO67>
		<OEMLED67>0</OEMLED67>
		<OEMDRO68>0.</OEMDRO68>
		<OEMLED68>0</OEMLED68>
		<OEMDRO69>0.</OEMDRO69>
		<OEMLED69>0</OEMLED69>
		<OEMDRO70>0.</OEMDRO70>
		<OEMLED70>0</OEMLED70>
		<OEMDRO71>0.</OEMDRO71>
		<OEMLED71>0</OEMLED71>
		<OEMDRO72>0.</OEMDRO72>
		<OEMLED72>0</OEMLED72>
		<OEMDRO73>0.</OEMDRO73>
		<OEMLED73>0</OEMLED73>
		<OEMDRO74>0.</OEMDRO74>
		<OEMLED74>0</OEMLED74>
		<OEMDRO75>0.</OEMDRO75>
		<OEMLED75>0</OEMLED75>
		<OEMDRO76>0.</OEMDRO76>
		<OEMLED76>0</OEMLED76>
		<OEMDRO77>0.</OEMDRO77>
		<OEMLED77>0</OEMLED77>
		<OEMDRO78>0.</OEMDRO78>
		<OEMLED78>0</OEMLED78>
		<OEMDRO79>0.</OEMDRO79>
		<OEMLED79>0</OEMLED79>
		<OEMDRO80>0.</OEMDRO80>
		<OEMLED80>0</OEMLED80>
		<OEMDRO81>0.</OEMDRO81>
		<OEMLED81>0</OEMLED81>
		<OEMDRO82>0.</OEMDRO82>
		<OEMLED82>0</OEMLED82>
		<OEMDRO83>0.</OEMDRO83>
		<OEMLED83>0</OEMLED83>
		<OEMDRO84>0.</OEMDRO84>
		<OEMLED84>0</OEMLED84>
		<OEMDRO85>0.</OEMDRO85>
		<OEMLED85>0</OEMLED85>
		<OEMDRO86>0.</OEMDRO86>
		<OEMLED86>0</OEMLED86>
		<OEMDRO87>0.</OEMDRO87>
		<OEMLED87>0</OEMLED87>
		<OEMDRO88>0.</OEMDRO88>
		<OEMLED88>0</OEMLED88>
		<OEMDRO89>0.</OEMDRO89>
		<OEMLED89>0</OEMLED89>
		<OEMDRO90>0.</OEMDRO90>
		<OEMLED90>0</OEMLED90>
		<OEMDRO91>0.</OEMDRO91>
		<OEMLED91>0</OEMLED91>
		<OEMDRO92>0.</OEMDRO92>
		<OEMLED92>0</OEMLED92>
		<OEMDRO93>0.</OEMDRO93>
		<OEMLED93>0</OEMLED93>
		<OEMDRO94>0.</OEMDRO94>
		<OEMLED94>0</OEMLED94>
		<OEMDRO95>0.</OEMDRO95>
		<OEMLED95>0</OEMLED95>
		<OEMDRO96>0.</OEMDRO96>
		<OEMLED96>0</OEMLED96>
		<OEMDRO97>0.</OEMDRO97>
		<OEMLED97>0</OEMLED97>
		<OEMDRO98>0.</OEMDRO98>
		<OEMLED98>0</OEMLED98>
		<OEMDRO99>0.</OEMDRO99>
		<OEMLED99>0</OEMLED99>
		<OEMDRO100>0.</OEMDRO100>
		<OEMLED100>0</OEMLED100>
		<OEMDRO101>0.</OEMDRO101>
		<OEMLED101>0</OEMLED101>
		<OEMDRO102>0.</OEMDRO102>
		<OEMLED102>0</OEMLED102>
		<OEMDRO103>0.</OEMDRO103>
		<OEMLED103>0</OEMLED103>
		<OEMDRO104>0.</OEMDRO104>
		<OEMLED104>0</OEMLED104>
		<OEMDRO105>0.</OEMDRO105>
		<OEMLED105>0</OEMLED105>
		<OEMDRO106>0.</OEMDRO106>
		<OEMLED106>0</OEMLED106>
		<OEMDRO107>0.</OEMDRO107>
		<OEMLED107>0</OEMLED107>
		<OEMDRO108>0.</OEMDRO108>
		<OEMLED108>0</OEMLED108>
		<OEMDRO109>0.</OEMDRO109>
		<OEMLED109>0</OEMLED109>
		<OEMDRO110>0.</OEMDRO110>
		<OEMLED110>0</OEMLED110>
		<OEMDRO111>0.</OEMDRO111>
		<OEMLED111>0</OEMLED111>
		<OEMDRO112>0.</OEMDRO112>
		<OEMLED112>0</OEMLED112>
		<OEMDRO113>0.</OEMDRO113>
		<OEMLED113>0</OEMLED113>
		<OEMDRO114>0.</OEMDRO114>
		<OEMLED114>0</OEMLED114>
		<OEMDRO115>0.</OEMDRO115>
		<OEMLED115>0</OEMLED115>
		<OEMDRO116>0.</OEMDRO116>
		<OEMLED116>0</OEMLED116>
		<OEMDRO117>0.</OEMDRO117>
		<OEMLED117>0</OEMLED117>
		<OEMDRO118>0.</OEMDRO118>
		<OEMLED118>0</OEMLED118>
		<OEMDRO119>0.</OEMDRO119>
		<OEMLED119>0</OEMLED119>
		<OEMDRO120>0.</OEMDRO120>
		<OEMLED120>0</OEMLED120>
		<OEMDRO121>0.</OEMDRO121>
		<OEMLED121>0</OEMLED121>
		<OEMDRO122>0.</OEMDRO122>
		<OEMLED122>0</OEMLED122>
		<OEMDRO123>0.</OEMDRO123>
		<OEMLED123>0</OEMLED123>
		<OEMDRO124>0.</OEMDRO124>
		<OEMLED124>0</OEMLED124>
		<OEMDRO125>0.</OEMDRO125>
		<OEMLED125>0</OEMLED125>
		<OEMDRO126>0.</OEMDRO126>
		<OEMLED126>0</OEMLED126>
		<OEMDRO127>0.</OEMDRO127>
		<OEMLED127>0</OEMLED127>
		<OEMDRO128>0.</OEMDRO128>
		<OEMLED128>0</OEMLED128>
		<OEMDRO129>0.</OEMDRO129>
		<OEMLED129>0</OEMLED129>
		<OEMDRO130>0.</OEMDRO130>
		<OEMLED130>0</OEMLED130>
		<OEMDRO131>0.</OEMDRO131>
		<OEMLED131>0</OEMLED131>
		<OEMDRO132>0.</OEMDRO132>
		<OEMLED132>0</OEMLED132>
		<OEMDRO133>0.</OEMDRO133>
		<OEMLED133>0</OEMLED133>
		<OEMDRO134>0.</OEMDRO134>
		<OEMLED134>0</OEMLED134>
		<OEMDRO135>0.</OEMDRO135>
		<OEMLED135>0</OEMLED135>
		<OEMDRO136>0.</OEMDRO136>
		<OEMLED136>0</OEMLED136>
		<OEMDRO137>0.</OEMDRO137>
		<OEMLED137>0</OEMLED137>
		<OEMDRO138>0.</OEMDRO138>
		<OEMLED138>0</OEMLED138>
		<OEMDRO139>0.</OEMDRO139>
		<OEMLED139>0</OEMLED139>
		<OEMDRO140>0.</OEMDRO140>
		<OEMLED140>0</OEMLED140>
		<OEMDRO141>0.</OEMDRO141>
		<OEMLED141>0</OEMLED141>
		<OEMDRO142>0.</OEMDRO142>
		<OEMLED142>0</OEMLED142>
		<OEMDRO143>0.</OEMDRO143>
		<OEMLED143>0</OEMLED143>
		<OEMDRO144>0.</OEMDRO144>
		<OEMLED144>0</OEMLED144>
		<OEMDRO145>0.</OEMDRO145>
		<OEMLED145>0</OEMLED145>
		<OEMDRO146>0.</OEMDRO146>
		<OEMLED146>0</OEMLED146>
		<OEMDRO147>0.</OEMDRO147>
		<OEMLED147>0</OEMLED147>
		<OEMDRO148>0.</OEMDRO148>
		<OEMLED148>0</OEMLED148>
		<OEMDRO149>0.</OEMDRO149>
		<OEMLED149>0</OEMLED149>
		<OEMDRO150>0.</OEMDRO150>
		<OEMLED150>0</OEMLED150>
		<OEMDRO151>0.</OEMDRO151>
		<OEMLED151>0</OEMLED151>
		<OEMDRO152>0.</OEMDRO152>
		<OEMLED152>0</OEMLED152>
		<OEMDRO153>0.</OEMDRO153>
		<OEMLED153>0</OEMLED153>
		<OEMDRO154>0.</OEMDRO154>
		<OEMLED154>0</OEMLED154>
		<OEMDRO155>0.</OEMDRO155>
		<OEMLED155>0</OEMLED155>
		<OEMDRO156>0.</OEMDRO156>
		<OEMLED156>0</OEMLED156>
		<OEMDRO157>0.</OEMDRO157>
		<OEMLED157>0</OEMLED157>
		<OEMDRO158>0.</OEMDRO158>
		<OEMLED158>0</OEMLED158>
		<OEMDRO159>0.</OEMDRO159>
		<OEMLED159>0</OEMLED159>
		<OEMDRO160>0.</OEMDRO160>
		<OEMLED160>0</OEMLED160>
		<OEMDRO161>0.</OEMDRO161>
		<OEMLED161>0</OEMLED161>
		<OEMDRO162>0.</OEMDRO162>
		<OEMLED162>0</OEMLED162>
		<OEMDRO163>0.</OEMDRO163>
		<OEMLED163>0</OEMLED163>
		<OEMDRO164>0.</OEMDRO164>
		<OEMLED164>0</OEMLED164>
		<OEMDRO165>0.</OEMDRO165>
		<OEMLED165>0</OEMLED165>
		<OEMDRO166>0.</OEMDRO166>
		<OEMLED166>0</OEMLED166>
		<OEMDRO167>0.</OEMDRO167>
		<OEMLED167>0</OEMLED167>
		<OEMDRO168>0.</OEMDRO168>
		<OEMLED168>0</OEMLED168>
		<OEMDRO169>0.</OEMDRO169>
		<OEMLED169>0</OEMLED169>
		<OEMDRO170>0.</OEMDRO170>
		<OEMLED170>0</OEMLED170>
		<OEMDRO171>0.</OEMDRO171>
		<OEMLED171>0</OEMLED171>
		<OEMDRO172>0.</OEMDRO172>
		<OEMLED172>0</OEMLED172>
		<OEMDRO173>0.</OEMDRO173>
		<OEMLED173>0</OEMLED173>
		<OEMDRO174>0.</OEMDRO174>
		<OEMLED174>0</OEMLED174>
		<OEMDRO175>0.</OEMDRO175>
		<OEMLED175>0</OEMLED175>
		<OEMDRO176>0.</OEMDRO176>
		<OEMLED176>0</OEMLED176>
		<OEMDRO177>0.</OEMDRO177>
		<OEMLED177>0</OEMLED177>
		<OEMDRO178>0.</OEMDRO178>
		<OEMLED178>0</OEMLED178>
		<OEMDRO179>0.</OEMDRO179>
		<OEMLED179>0</OEMLED179>
		<OEMDRO180>0.</OEMDRO180>
		<OEMLED180>0</OEMLED180>
		<OEMDRO181>0.</OEMDRO181>
		<OEMLED181>0</OEMLED181>
		<OEMDRO182>0.</OEMDRO182>
		<OEMLED182>0</OEMLED182>
		<OEMDRO183>0.</OEMDRO183>
		<OEMLED183>0</OEMLED183>
		<OEMDRO184>0.</OEMDRO184>
		<OEMLED184>0</OEMLED184>
		<OEMDRO185>0.</OEMDRO185>
		<OEMLED185>0</OEMLED185>
		<OEMDRO186>0.</OEMDRO186>
		<OEMLED186>0</OEMLED186>
		<OEMDRO187>0.</OEMDRO187>
		<OEMLED187>0</OEMLED187>
		<OEMDRO188>0.</OEMDRO188>
		<OEMLED188>0</OEMLED188>
		<OEMDRO189>0.</OEMDRO189>
		<OEMLED189>0</OEMLED189>
		<OEMDRO190>0.</OEMDRO190>
		<OEMLED190>0</OEMLED190>
		<OEMDRO191>0.</OEMDRO191>
		<OEMLED191>0</OEMLED191>
		<OEMDRO192>0.</OEMDRO192>
		<OEMLED192>0</OEMLED192>
		<OEMDRO193>0.</OEMDRO193>
		<OEMLED193>0</OEMLED193>
		<OEMDRO194>0.</OEMDRO194>
		<OEMLED194>0</OEMLED194>
		<OEMDRO195>0.</OEMDRO195>
		<OEMLED195>0</OEMLED195>
		<OEMDRO196>0.</OEMDRO196>
		<OEMLED196>0</OEMLED196>
		<OEMDRO197>0.</OEMDRO197>
		<OEMLED197>0</OEMLED197>
		<OEMDRO198>0.</OEMDRO198>
		<OEMLED198>0</OEMLED198>
		<OEMDRO199>0.</OEMDRO199>
		<OEMLED199>0</OEMLED199>
		<OEMDRO200>10.</OEMDRO200>
		<OEMLED200>0</OEMLED200>
		<OEMDRO201>10.</OEMDRO201>
		<OEMLED201>0</OEMLED201>
		<OEMDRO202>0.</OEMDRO202>
		<OEMLED202>0</OEMLED202>
		<OEMDRO203>0.</OEMDRO203>
		<OEMLED203>0</OEMLED203>
		<OEMDRO204>0.</OEMDRO204>
		<OEMLED204>0</OEMLED204>
		<OEMDRO205>0.</OEMDRO205>
		<OEMLED205>0</OEMLED205>
		<OEMDRO206>0.</OEMDRO206>
		<OEMLED206>0</OEMLED206>
		<OEMDRO207>0.</OEMDRO207>
		<OEMLED207>0</OEMLED207>
		<OEMDRO208>0.</OEMDRO208>
		<OEMLED208>0</OEMLED208>
		<OEMDRO209>0.</OEMDRO209>
		<OEMLED209>0</OEMLED209>
		<OEMDRO210>0.</OEMDRO210>
		<OEMLED210>0</OEMLED210>
		<OEMDRO211>0.</OEMDRO211>
		<OEMLED211>0</OEMLED211>
		<OEMDRO212>0.</OEMDRO212>
		<OEMLED212>0</OEMLED212>
		<OEMDRO213>0.</OEMDRO213>
		<OEMLED213>0</OEMLED213>
		<OEMDRO214>0.</OEMDRO214>
		<OEMLED214>0</OEMLED214>
		<OEMDRO215>0.</OEMDRO215>
		<OEMLED215>0</OEMLED215>
		<OEMDRO216>0.</OEMDRO216>
		<OEMLED216>0</OEMLED216>
		<OEMDRO217>0.</OEMDRO217>
		<OEMLED217>0</OEMLED217>
		<OEMDRO218>0.</OEMDRO218>
		<OEMLED218>0</OEMLED218>
		<OEMDRO219>0.</OEMDRO219>
		<OEMLED219>0</OEMLED219>
		<OEMDRO220>0.</OEMDRO220>
		<OEMLED220>0</OEMLED220>
		<OEMDRO221>0.</OEMDRO221>
		<OEMLED221>0</OEMLED221>
		<OEMDRO222>0.</OEMDRO222>
		<OEMLED222>0</OEMLED222>
		<OEMDRO223>0.</OEMDRO223>
		<OEMLED223>0</OEMLED223>
		<OEMDRO224>0.</OEMDRO224>
		<OEMLED224>0</OEMLED224>
		<OEMDRO225>0.</OEMDRO225>
		<OEMLED225>0</OEMLED225>
		<OEMDRO226>0.</OEMDRO226>
		<OEMLED226>0</OEMLED226>
		<OEMDRO227>0.</OEMDRO227>
		<OEMLED227>0</OEMLED227>
		<OEMDRO228>0.</OEMDRO228>
		<OEMLED228>0</OEMLED228>
		<OEMDRO229>0.</OEMDRO229>
		<OEMLED229>0</OEMLED229>
		<OEMDRO230>0.</OEMDRO230>
		<OEMLED230>0</OEMLED230>
		<OEMDRO231>0.</OEMDRO231>
		<OEMLED231>0</OEMLED231>
		<OEMDRO232>0.</OEMDRO232>
		<OEMLED232>0</OEMLED232>
		<OEMDRO233>0.</OEMDRO233>
		<OEMLED233>0</OEMLED233>
		<OEMDRO234>0.</OEMDRO234>
		<OEMLED234>0</OEMLED234>
		<OEMDRO235>0.</OEMDRO235>
		<OEMLED235>0</OEMLED235>
		<OEMDRO236>0.</OEMDRO236>
		<OEMLED236>0</OEMLED236>
		<OEMDRO237>0.</OEMDRO237>
		<OEMLED237>0</OEMLED237>
		<OEMDRO238>0.</OEMDRO238>
		<OEMLED238>0</OEMLED238>
		<OEMDRO239>0.</OEMDRO239>
		<OEMLED239>0</OEMLED239>
		<OEMDRO240>0.</OEMDRO240>
		<OEMLED240>0</OEMLED240>
		<OEMDRO241>0.</OEMDRO241>
		<OEMLED241>0</OEMLED241>
		<OEMDRO242>0.</OEMDRO242>
		<OEMLED242>0</OEMLED242>
		<OEMDRO243>0.</OEMDRO243>
		<OEMLED243>0</OEMLED243>
		<OEMDRO244>0.</OEMDRO244>
		<OEMLED244>0</OEMLED244>
		<OEMDRO245>0.</OEMDRO245>
		<OEMLED245>0</OEMLED245>
		<OEMDRO246>0.</OEMDRO246>
		<OEMLED246>0</OEMLED246>
		<OEMDRO247>0.</OEMDRO247>
		<OEMLED247>0</OEMLED247>
		<OEMDRO248>0.</OEMDRO248>
		<OEMLED248>0</OEMLED248>
		<OEMDRO249>0.</OEMDRO249>
		<OEMLED249>0</OEMLED249>
		<OEMDRO250>0.</OEMDRO250>
		<OEMLED250>0</OEMLED250>
		<OEMDRO251>0.</OEMDRO251>
		<OEMLED251>0</OEMLED251>
		<OEMDRO252>0.</OEMDRO252>
		<OEMLED252>0</OEMLED252>
		<OEMDRO253>0.</OEMDRO253>
		<OEMLED253>0</OEMLED253>
		<OEMDRO254>0.</OEMDRO254>
		<OEMLED254>0</OEMLED254>
		<OEMDRO255>0.</OEMDRO255>
		<OEMLED255>0</OEMLED255>
		<JogInc>1.e-002</JogInc>
		<JogSlide>0.1</JogSlide>
		<THCMax>1.</THCMax>
		<THCMin>0.2</THCMin>
		<RadiusA>0.</RadiusA>
		<RadiusB>0.</RadiusB>
		<RadiusC>0.</RadiusC>
		<LiftLevel>0.1</LiftLevel>
		<LiftAngle>45.</LiftAngle>
		<InhibitDepth>0.</InhibitDepth>
		<LaserXGrid>0.</LaserXGrid>
		<LaserYGrid>0.</LaserYGrid>
		<LaserAGrid>0.</LaserAGrid>
		<JogInc0>1.</JogInc0>
		<JogInc1>0.1</JogInc1>
		<JogInc2>1.e-002</JogInc2>
		<JogInc3>1.e-003</JogInc3>
		<JogInc4>1.e-004</JogInc4>
		<JogInc5>1.</JogInc5>
		<JogInc6>0.1</JogInc6>
		<JogInc7>1.e-002</JogInc7>
		<JogInc8>1.e-003</JogInc8>
		<JogInc9>1.e-004</JogInc9>
		<THCSpeed>20.</THCSpeed>
		<BlendFactor>180.</BlendFactor>
		<M0RefHome>0</M0RefHome>
		<M1RefHome>0</M1RefHome>
		<M2RefHome>0</M2RefHome>
		<M3RefHome>0</M3RefHome>
		<M4RefHome>0</M4RefHome>
		<M5RefHome>0</M5RefHome>
		<MRU10>E:\__Documents Administrator\Cad\____TESTER.ncc</MRU10>
		<MRU9>E:\__Documents Administrator\Cad\rottest.ncc</MRU9>
		<MRU9>E:\__Documents Administrator\Cad\_old\___TC2_OffsetsNo.ncc</MRU9>
		<MRU8>C:\Users\Administrator\Desktop\CNC TEMP 2007-06\4thAxis_Helix.ncc</MRU8>
		<MRU7>C:\Users\Administrator\Desktop\4thAxis_PM0_arcs.ncc</MRU7>
		<MRU6>C:\Users\Administrator\Desktop\4thAxis_PM0.ncc</MRU6>
		<MRU5>C:\Users\Administrator\Desktop\CNC TEMP 2007-06\CNC 4th AXIS\rottest.ncc</MRU5>
		<MRU4>None</MRU4>
		<MRU1>C:\Users\Administrator\Desktop\CNC TEMP 2007-06\MACH BLOWS\PM0_2.ncc</MRU1>
		<SerialServo>0</SerialServo>
		<ToolLines>0</ToolLines>
		<NURBS>0</NURBS>
		<ToolPersist>0</ToolPersist>
		<KeepRef>0</KeepRef>
		<TurnRevArc>1</TurnRevArc>
		<HiRes>1</HiRes>
		<DelinChar>12</DelinChar>
		<Rot360>0</Rot360>
		<UDP>0</UDP>
		<DROFont>Arial</DROFont>
		<LabelFont>Arial</LabelFont>
		<CodeFont>Arial</CodeFont>
		<PierceDelay>1.</PierceDelay>
		<VelPer3>5.</VelPer3>
		<TouchX>0.</TouchX>
		<G20X>0.</G20X>
		<G20Y>0.</G20Y>
		<G20Z>0.</G20Z>
		<G20A>0.</G20A>
		<G20B>0.</G20B>
		<G20C>0.</G20C>
		<FrontRear>0.</FrontRear>
		<EncJogAxis3>2</EncJogAxis3>
		<Voices>0</Voices>
		<Sounds>0</Sounds>
		<IGNORETOOL>1</IGNORETOOL>
		<Vel0>4.167</Vel0>
		<Acc0>9.</Acc0>
		<Steps0>4000.</Steps0>
		<Vel1>4.167</Vel1>
		<Acc1>9.</Acc1>
		<Steps1>4000.</Steps1>
		<Vel2>3.333</Vel2>
		<Acc2>30.</Acc2>
		<Steps2>4000.</Steps2>
		<WarnOnReset>0</WarnOnReset>
		<GExt>*.ncc</GExt>
		<GPath>C:\Users\Administrator\Desktop\CNC TEMP 2007-06\MACH BLOWS\PM0_2.ncc</GPath>
		<Boxed>0</Boxed>
		<DefDir>C:\Mach3</DefDir>
		<NewPath>0</NewPath>
		<UseDiam>1</UseDiam>
		<ModPlug>0</ModPlug>
		<m_SafeZ>0.</m_SafeZ>
		<AutoCalcs>0</AutoCalcs>
		<SafeZStop>0</SafeZStop>
		<SafeZType>0</SafeZType>
		<SPINREV1>0</SPINREV1>
		<SPINREV2>0</SPINREV2>
		<SPINREV3>0</SPINREV3>
		<SPINREV4>0</SPINREV4>
		<SPEED5>25000</SPEED5>
		<LSPEED5>0</LSPEED5>
		<SPINREV5>0</SPINREV5>
		<SPEED6>25000</SPEED6>
		<LSPEED6>0</LSPEED6>
		<SPINREV6>0</SPINREV6>
		<SPEED7>25000</SPEED7>
		<LSPEED7>0</LSPEED7>
		<SPINREV7>0</SPINREV7>
		<SPEED8>25000</SPEED8>
		<LSPEED8>0</LSPEED8>
		<SPINREV8>0</SPINREV8>
		<SPEED9>25000</SPEED9>
		<LSPEED9>0</LSPEED9>
		<SPINREV9>0</SPINREV9>
		<SPEED10>25000</SPEED10>
		<LSPEED10>0</LSPEED10>
		<SPINREV10>0</SPINREV10>
		<SPEED11>25000</SPEED11>
		<LSPEED11>0</LSPEED11>
		<SPINREV11>0</SPINREV11>
		<SPEED12>25000</SPEED12>
		<LSPEED12>0</LSPEED12>
		<SPINREV12>0</SPINREV12>
		<SPEED13>25000</SPEED13>
		<LSPEED13>0</LSPEED13>
		<SPINREV13>0</SPINREV13>
		<SPEED14>25000</SPEED14>
		<LSPEED14>0</LSPEED14>
		<SPINREV14>0</SPINREV14>
		<SPEED15>25000</SPEED15>
		<LSPEED15>0</LSPEED15>
		<SPINREV15>0</SPINREV15>
		<SPEED16>25000</SPEED16>
		<LSPEED16>0</LSPEED16>
		<SPINREV16>0</SPINREV16>
		<SPEED17>25000</SPEED17>
		<LSPEED17>0</LSPEED17>
		<SPINREV17>0</SPINREV17>
		<SPEED18>25000</SPEED18>
		<LSPEED18>0</LSPEED18>
		<SPINREV18>0</SPINREV18>
		<SPEED19>25000</SPEED19>
		<LSPEED19>0</LSPEED19>
		<SPINREV19>0</SPINREV19>
		<SPEED20>25000</SPEED20>
		<LSPEED20>0</LSPEED20>
		<SPINREV20>0</SPINREV20>
		<SPEED21>25000</SPEED21>
		<LSPEED21>0</LSPEED21>
		<SPINREV21>0</SPINREV21>
		<SPEED22>25000</SPEED22>
		<LSPEED22>0</LSPEED22>
		<SPINREV22>0</SPINREV22>
		<SPEED23>25000</SPEED23>
		<LSPEED23>0</LSPEED23>
		<SPINREV23>0</SPINREV23>
		<SPEED24>25000</SPEED24>
		<LSPEED24>0</LSPEED24>
		<SPINREV24>0</SPINREV24>
		<SPEED25>25000</SPEED25>
		<LSPEED25>0</LSPEED25>
		<SPINREV25>0</SPINREV25>
		<EncJogAxis1>0</EncJogAxis1>
		<Syskey1>1</Syskey1>
		<CVUseAngle>0</CVUseAngle>
		<CVDegrees>0.</CVDegrees>
		<KeyClick>1</KeyClick>
		<THC5>0</THC5>
		<M30SpinOff>1</M30SpinOff>
		<ButtonFont>Arial</ButtonFont>
		<OVSpinInc>10</OVSpinInc>
		<Encoder0>0</Encoder0>
		<Encoder1>0</Encoder1>
		<Encoder2>0</Encoder2>
		<Encoder3>0</Encoder3>
		<Encoder4>0</Encoder4>
		<Encoder5>0</Encoder5>
		<Encoder6>0</Encoder6>
		<AutoLimit>0</AutoLimit>
		<MenuOff>0</MenuOff>
		<Slave0>3</Slave0>
		<Slave1>3</Slave1>
		<Slave2>3</Slave2>
		<MRU3>C:\Users\Administrator\Desktop\4thAxis_PM0 YYY.ncc</MRU3><ID>None</ID><JogHeat>0</JogHeat><DROLOCK>1</DROLOCK><LastUser>Whiteriver Mfg</LastUser><Vel4>1.65</Vel4><Acc4>9.</Acc4><Steps4>999.</Steps4><Vel3>62.26</Vel3><Acc3>500.</Acc3><Steps3>500.</Steps3><ROTSOFT>1</ROTSOFT><PROBETLO>0</PROBETLO><SlaveHome>0</SlaveHome><SPINRATIO1>1.</SPINRATIO1><SPINRATIO2>1.</SPINRATIO2><SPINRATIO3>1.</SPINRATIO3><SPINRATIO4>1.</SPINRATIO4><SPINRATIO5>1.</SPINRATIO5><SPINRATIO6>1.</SPINRATIO6><SPINRATIO7>1.</SPINRATIO7><SPINRATIO8>1.</SPINRATIO8><SPINRATIO9>1.</SPINRATIO9><SPINRATIO10>1.</SPINRATIO10><SPINRATIO11>1.</SPINRATIO11><SPINRATIO12>1.</SPINRATIO12><SPINRATIO13>1.</SPINRATIO13><SPINRATIO14>1.</SPINRATIO14><SPINRATIO15>1.</SPINRATIO15><SPINRATIO16>1.</SPINRATIO16><SPINRATIO17>1.</SPINRATIO17><SPINRATIO18>1.</SPINRATIO18><SPINRATIO19>1.</SPINRATIO19><SPINRATIO20>1.</SPINRATIO20><SPINRATIO21>1.</SPINRATIO21><SPINRATIO22>1.</SPINRATIO22><SPINRATIO23>1.</SPINRATIO23><SPINRATIO24>1.</SPINRATIO24><SPINRATIO25>1.</SPINRATIO25><Vel5>1.65</Vel5><Acc5>9.</Acc5><Steps5>999.</Steps5><MRU2>C:\Users\Administrator\Desktop\CNC TEMP 2007-06\MACH BLOWS\Helix.ncc</MRU2></Preferences>
	<PlugIns>
		<ShuttlePro-Contour-Shuttle-Pendents---A.Fenerty-Ver-1.90.081a>1</ShuttlePro-Contour-Shuttle-Pendents---A.Fenerty-Ver-1.90.081a>
		<SystemTest>1</SystemTest>
		<G100---Xarach-Controls-V2.1>1</G100---Xarach-Controls-V2.1><DeskPod-NcPod-Movement-PlugIn---A.Fenerty>0</DeskPod-NcPod-Movement-PlugIn---A.Fenerty><ShuttlePro_v2.00.079-Contour-Shuttle-Pendents---A.Fenerty-Ver-2.00.080>1</ShuttlePro_v2.00.079-Contour-Shuttle-Pendents---A.Fenerty-Ver-2.00.080></PlugIns>
	<Shuttle>
		<BUTTON0>1</BUTTON0>
		<BUTTON1>2</BUTTON1>
		<BUTTON2>3</BUTTON2>
		<BUTTON3>4</BUTTON3>
		<BUTTON4>20</BUTTON4>
		<BUTTON5>21</BUTTON5>
		<BUTTON6>22</BUTTON6>
		<BUTTON7>46</BUTTON7>
		<BUTTON8>31</BUTTON8>
		<BUTTON9>15</BUTTON9>
		<BUTTON10>13</BUTTON10>
		<BUTTON11>50</BUTTON11>
		<BUTTON12>49</BUTTON12>
		<BUTTON13>12</BUTTON13>
		<BUTTON14>11</BUTTON14>
		<Product>48</Product>
		<Macro1>0</Macro1><Macro2>0</Macro2></Shuttle>
	<Mach3Mill>
		<WPVB>726</WPVB>
		<WPVT>236</WPVT>
		<WPVL>29</WPVL>
		<WPVR>1003</WPVR>
	</Mach3Mill>
	<Control>
		<Default>1</Default>
		<Device>G100---Xarach-Controls-V2.69</Device></Control>
	<Normals><Distance>0.</Distance><ZInhibit>0.</ZInhibit><Axis0>1.</Axis0><Axis1>1.</Axis1><Axis2>1.</Axis2><Axis3>1.</Axis3><Axis4>1.</Axis4><Axis5>1.</Axis5><Axis6>1.</Axis6><CV>2.</CV><XScale>1.</XScale><YScale>1.</YScale><ZScale>1.</ZScale><AScale>1.</AScale><BScale>1.</BScale><CScale>1.</CScale><OffLine>0.</OffLine><IJ>1.</IJ><RefX>0.</RefX><RefY>0.</RefY><RefZ>0.</RefZ><RefA>0.</RefA><RefB>0.</RefB><RefC>0.</RefC><System>1.</System><Rotation>0.</Rotation><Plane>1.</Plane></Normals><G100Param><AnaSel>3</AnaSel><SpinAnaOff>0</SpinAnaOff><CVRadiusOff>0.</CVRadiusOff><IPAddress>-1442942767</IPAddress><MPG0>0</MPG0><MPG1>0</MPG1><MPG2>0</MPG2><LOOKAHEAD>10</LOOKAHEAD><ASC>0.</ASC></G100Param><JogPlugIn><JogPlugHoriz>0</JogPlugHoriz><JogPlugVert>1</JogPlugVert><JogStartEnabled>0</JogStartEnabled></JogPlugIn></profile>
