SpinTool = GetOEMDRO (1200)'Tool in spindle
PotTool = GetOEMDRO (1201) 'Tool in tool changer
If SpinTool <> PotTool Then
   MsgBox("Spindle Tool and Pocket Tool are not the Same")
   Dobutton(21)
   Exit Sub
End If
NewTool = GetSelectedTool() 'Programed tool
If NewTool = SpinTool Then
   Exit Sub
End If
If NewTool = 0 Then
   MsgBox("No Tool Number Given")
   Dobutton(21)
   Exit Sub
End If
If NewTool < 0 Then
   MsgBox("Invalid Tool Number")
   Dobutton(21)
   Exit Sub
End If
If NewTool > 24 Then
   Dobutton(21)
   Exit Sub
End If
DoSpinStop()
ActivateSignal(OUTPUT10)
Code "G01 G53 Z.174 F150."
While IsMoving()
Sleep 100
Wend
'Find shortest route to next tool
ChgTool = (NewTool - SpinTool)
If ChgTool < 0 Then 
   ChgTool = (24 + ChgTool)
End If
If ChgTool > 0 And ChgTool <= 12 Then
   Call CwMove(ChgTool)
   Exit Sub
End If
If ChgTool > 0 And ChgTool > 12 Then
   Call CcwMove(ChgTool)
   Exit Sub
End If
'Clockwise move to next tool
Sub CwMove(ByVal ChgTool As Integer) 
	If IsActive(ZHOME) = False Then
	MsgBox("Z is not Home")
	Dobutton(21)
	Exit Sub
	End If
	If IsActive(OUTPUT10) = True Then
	MsgBox("Spindle is not Orientated")
	Dobutton(21)
	Exit Sub
	End If
	ActivateSignal(OUTPUT3)
	Sleep (2000)
	If IsActive(OEMTRIG9) = False Then
	MsgBox("Mag is not Forward")
	Dobutton(21)
	Exit Sub
	End If	
	ActivateSignal(OUTPUT2)
	Sleep (1500)
	If IsActive(OEMTRIG15) = False Then
	MsgBox("Tool is Clamped")
	Dobutton(21)
	Exit Sub
	End If	
	ActivateSignal(OUTPUT4)
	Sleep (1500)
	If IsActive(OEMTRIG11) = False Then
	MsgBox("Mag is not Down")
	Dobutton(21)
	Exit Sub
	End If
	NewPosition = 0
	Call IndexCW(NewPosition,ChgTool)
End Sub
'Counter Clockwise move to next tool
Sub CcwMove (ByVal ChgTool As Integer)
	ChgTool = (24 - ChgTool)
	Dobutton(21)
	Exit Sub
	End If
	Dobutton(21)
	Exit Sub
	End If
	Sleep (1500)
	Dobutton(21)
	Exit Sub
	End If	
	Sleep (1500)
	Dobutton(21)
	Exit Sub
	End If	
	Sleep (1500)	
	Dobutton(21)
	Exit Sub
	End If
	NewPosition = 0
	Call IndexCCW(NewPosition,ChgTool)
End Sub
Sub IndexCW(ByVal NewPosition,ChgTool As Integer)
	If IsActive(OUTPUT6) = True Then
    	DeactivateSignal(OUTPUT6)
	End If
	ActivateSignal(OUTPUT5)
	Sleep (500)
	Do Until IsActive(OEMTRIG12)
	Loop
	If IsActive(OEMTRIG12) = True Then
	NewPosition = (NewPosition + 1)
	End If
	If NewPosition < ChgTool Then
	Call IndexCW (NewPosition,ChgTool)
	End If
	DeactivateSignal(OUTPUT5)
	If NewPosition = ChgTool Then
	Call ChangeTool()
	End If
End Sub
Sub IndexCCW (ByVal NewPosition,ChgTool As Integer)
	If IsActive(OUTPUT5) = True Then
	End If
	ActivateSignal(OUTPUT6)
	Sleep (500)
	Loop
	End If
	End If
	Call ChangeTool()
	End If
End Sub
Sub ChangeTool
	Dobutton(21)
	Exit Sub
	End If
	Dobutton(21)
	Exit Sub
	End If
	DeactivateSignal(OUTPUT4)
	Sleep (1500)
	If IsActive(OEMTRIG10) = False Then
	MsgBox("Mag is not Up")
	Dobutton(21)
	Exit Sub
	End If
	DeactivateSignal(OUTPUT2)
	Sleep (1500)
	If IsActive(OEMTRIG14) = False Then
	MsgBox("Tool is not Clamped")
	Dobutton(21)
	Exit Sub
	End If
	DeactivateSignal(OUTPUT3)
	Sleep (2000)
	If IsActive(OEMTRIG8) = False Then
	MsgBox("Mag is not Back")
	Dobutton(21)
	Exit Sub
	End If
	DeactivateSignal(OUTPUT10)
	SetOEMDRO (1200,GetSelectedTool())
	SetOEMDRO (1201,GetSelectedTool())
Exit Sub
End Sub  
