<profile><Preferences><PulseSpeed>2</PulseSpeed><Profile>Brad CNC</Profile><Layout>1024.set</Layout><FirstRun>1</FirstRun><Units>0</Units><Serial>0</Serial><Port2Input>0</Port2Input><GeckoMode>0</GeckoMode><USBINPUTS>16</USBINPUTS><USBOUTPUTS>16</USBOUTPUTS><Port2On>0</Port2On><Port1On>1</Port1On><Port1Add>888</Port1Add><Port2Add>632</Port2Add><MaxCL>0</MaxCL><MaxNC10>0</MaxNC10><Motor0Active>1</Motor0Active><Motor0DirNeg>1</Motor0DirNeg><Motor0DirPort>1</Motor0DirPort><Motor0DirPin>3</Motor0DirPin><Motor0StepNeg>1</Motor0StepNeg><Motor0StepPort>1</Motor0StepPort><Motor0StepPin>2</Motor0StepPin><Motor1Active>1</Motor1Active><Motor1DirNeg>1</Motor1DirNeg><Motor1DirPort>1</Motor1DirPort><Motor1DirPin>5</Motor1DirPin><Motor1StepNeg>1</Motor1StepNeg><Motor1StepPort>1</Motor1StepPort><Motor1StepPin>4</Motor1StepPin><Motor2Active>1</Motor2Active><Motor2DirNeg>1</Motor2DirNeg><Motor2DirPort>1</Motor2DirPort><Motor2DirPin>7</Motor2DirPin><Motor2StepNeg>1</Motor2StepNeg><Motor2StepPort>1</Motor2StepPort><Motor2StepPin>6</Motor2StepPin><Motor3Active>1</Motor3Active><Motor3DirNeg>1</Motor3DirNeg><Motor3DirPort>1</Motor3DirPort><Motor3DirPin>9</Motor3DirPin><Motor3StepNeg>1</Motor3StepNeg><Motor3StepPort>1</Motor3StepPort><Motor3StepPin>8</Motor3StepPin><Motor4Active>0</Motor4Active><Motor4DirNeg>0</Motor4DirNeg><Motor4DirPort>0</Motor4DirPort><Motor4DirPin>0</Motor4DirPin><Motor4StepNeg>0</Motor4StepNeg><Motor4StepPort>0</Motor4StepPort><Motor4StepPin>0</Motor4StepPin><Motor5Active>0</Motor5Active><Motor5DirNeg>0</Motor5DirNeg><Motor5DirPort>0</Motor5DirPort><Motor5DirPin>0</Motor5DirPin><Motor5StepNeg>0</Motor5StepNeg><Motor5StepPort>0</Motor5StepPort><Motor5StepPin>0</Motor5StepPin><Motor6Active>1</Motor6Active><Motor6DirNeg>0</Motor6DirNeg><Motor6DirPort>1</Motor6DirPort><Motor6DirPin>1</Motor6DirPin><Motor6StepNeg>0</Motor6StepNeg><Motor6StepPort>1</Motor6StepPort><Motor6StepPin>14</Motor6StepPin><Input0Active>0</Input0Active><Input0Port>1</Input0Port><Input0Pin>0</Input0Pin><Input0Neg>0</Input0Neg><Input0Emulated>0</Input0Emulated><Input0EmuKey>0</Input0EmuKey><Input1Active>0</Input1Active><Input1Port>1</Input1Port><Input1Pin>0</Input1Pin><Input1Neg>0</Input1Neg><Input1Emulated>0</Input1Emulated><Input1EmuKey>0</Input1EmuKey><Input2Active>0</Input2Active><Input2Port>1</Input2Port><Input2Pin>0</Input2Pin><Input2Neg>0</Input2Neg><Input2Emulated>0</Input2Emulated><Input2EmuKey>0</Input2EmuKey><Input3Active>0</Input3Active><Input3Port>1</Input3Port><Input3Pin>0</Input3Pin><Input3Neg>0</Input3Neg><Input3Emulated>0</Input3Emulated><Input3EmuKey>0</Input3EmuKey><Input4Active>0</Input4Active><Input4Port>1</Input4Port><Input4Pin>0</Input4Pin><Input4Neg>0</Input4Neg><Input4Emulated>0</Input4Emulated><Input4EmuKey>0</Input4EmuKey><Input5Active>0</Input5Active><Input5Port>1</Input5Port><Input5Pin>0</Input5Pin><Input5Neg>0</Input5Neg><Input5Emulated>0</Input5Emulated><Input5EmuKey>0</Input5EmuKey><Input6Active>0</Input6Active><Input6Port>1</Input6Port><Input6Pin>0</Input6Pin><Input6Neg>0</Input6Neg><Input6Emulated>0</Input6Emulated><Input6EmuKey>0</Input6EmuKey><Input7Active>0</Input7Active><Input7Port>1</Input7Port><Input7Pin>0</Input7Pin><Input7Neg>0</Input7Neg><Input7Emulated>0</Input7Emulated><Input7EmuKey>0</Input7EmuKey><Input8Active>0</Input8Active><Input8Port>1</Input8Port><Input8Pin>0</Input8Pin><Input8Neg>0</Input8Neg><Input8Emulated>0</Input8Emulated><Input8EmuKey>0</Input8EmuKey><Input9Active>0</Input9Active><Input9Port>1</Input9Port><Input9Pin>0</Input9Pin><Input9Neg>0</Input9Neg><Input9Emulated>0</Input9Emulated><Input9EmuKey>0</Input9EmuKey><Input10Active>0</Input10Active><Input10Port>1</Input10Port><Input10Pin>0</Input10Pin><Input10Neg>0</Input10Neg><Input10Emulated>0</Input10Emulated><Input10EmuKey>0</Input10EmuKey><Input11Active>0</Input11Active><Input11Port>1</Input11Port><Input11Pin>0</Input11Pin><Input11Neg>0</Input11Neg><Input11Emulated>0</Input11Emulated><Input11EmuKey>0</Input11EmuKey><Input12Active>0</Input12Active><Input12Port>1</Input12Port><Input12Pin>0</Input12Pin><Input12Neg>0</Input12Neg><Input12Emulated>0</Input12Emulated><Input12EmuKey>0</Input12EmuKey><Input13Active>0</Input13Active><Input13Port>1</Input13Port><Input13Pin>0</Input13Pin><Input13Neg>0</Input13Neg><Input13Emulated>0</Input13Emulated><Input13EmuKey>0</Input13EmuKey><Input14Active>0</Input14Active><Input14Port>1</Input14Port><Input14Pin>0</Input14Pin><Input14Neg>0</Input14Neg><Input14Emulated>0</Input14Emulated><Input14EmuKey>0</Input14EmuKey><Input15Active>0</Input15Active><Input15Port>1</Input15Port><Input15Pin>0</Input15Pin><Input15Neg>0</Input15Neg><Input15Emulated>0</Input15Emulated><Input15EmuKey>0</Input15EmuKey><Input16Active>0</Input16Active><Input16Port>1</Input16Port><Input16Pin>0</Input16Pin><Input16Neg>0</Input16Neg><Input16Emulated>0</Input16Emulated><Input16EmuKey>0</Input16EmuKey><Input17Active>0</Input17Active><Input17Port>1</Input17Port><Input17Pin>0</Input17Pin><Input17Neg>0</Input17Neg><Input17Emulated>0</Input17Emulated><Input17EmuKey>0</Input17EmuKey><Input18Active>0</Input18Active><Input18Port>1</Input18Port><Input18Pin>0</Input18Pin><Input18Neg>0</Input18Neg><Input18Emulated>0</Input18Emulated><Input18EmuKey>0</Input18EmuKey><Input19Active>0</Input19Active><Input19Port>1</Input19Port><Input19Pin>0</Input19Pin><Input19Neg>0</Input19Neg><Input19Emulated>0</Input19Emulated><Input19EmuKey>0</Input19EmuKey><Input20Active>0</Input20Active><Input20Port>1</Input20Port><Input20Pin>0</Input20Pin><Input20Neg>0</Input20Neg><Input20Emulated>0</Input20Emulated><Input20EmuKey>0</Input20EmuKey><Input21Active>0</Input21Active><Input21Port>1</Input21Port><Input21Pin>0</Input21Pin><Input21Neg>0</Input21Neg><Input21Emulated>0</Input21Emulated><Input21EmuKey>0</Input21EmuKey><Input22Active>0</Input22Active><Input22Port>1</Input22Port><Input22Pin>0</Input22Pin><Input22Neg>0</Input22Neg><Input22Emulated>0</Input22Emulated><Input22EmuKey>0</Input22EmuKey><Input23Active>0</Input23Active><Input23Port>1</Input23Port><Input23Pin>0</Input23Pin><Input23Neg>0</Input23Neg><Input23Emulated>0</Input23Emulated><Input23EmuKey>0</Input23EmuKey><Input24Active>0</Input24Active><Input24Port>1</Input24Port><Input24Pin>0</Input24Pin><Input24Neg>0</Input24Neg><Input24Emulated>0</Input24Emulated><Input24EmuKey>0</Input24EmuKey><Input25Active>1</Input25Active><Input25Port>0</Input25Port><Input25Pin>10</Input25Pin><Input25Neg>0</Input25Neg><Input25Emulated>0</Input25Emulated><Input25EmuKey>0</Input25EmuKey><Input26Active>0</Input26Active><Input26Port>1</Input26Port><Input26Pin>0</Input26Pin><Input26Neg>0</Input26Neg><Input26Emulated>0</Input26Emulated><Input26EmuKey>0</Input26EmuKey><Input27Active>0</Input27Active><Input27Port>1</Input27Port><Input27Pin>0</Input27Pin><Input27Neg>0</Input27Neg><Input27Emulated>0</Input27Emulated><Input27EmuKey>0</Input27EmuKey><Input28Active>0</Input28Active><Input28Port>1</Input28Port><Input28Pin>0</Input28Pin><Input28Neg>0</Input28Neg><Input28Emulated>0</Input28Emulated><Input28EmuKey>0</Input28EmuKey><Input29Active>0</Input29Active><Input29Port>1</Input29Port><Input29Pin>0</Input29Pin><Input29Neg>0</Input29Neg><Input29Emulated>0</Input29Emulated><Input29EmuKey>0</Input29EmuKey><Input30Active>0</Input30Active><Input30Port>1</Input30Port><Input30Pin>0</Input30Pin><Input30Neg>0</Input30Neg><Input30Emulated>0</Input30Emulated><Input30EmuKey>0</Input30EmuKey><Input31Active>0</Input31Active><Input31Port>1</Input31Port><Input31Pin>0</Input31Pin><Input31Neg>0</Input31Neg><Input31Emulated>0</Input31Emulated><Input31EmuKey>0</Input31EmuKey><Input32Active>0</Input32Active><Input32Port>1</Input32Port><Input32Pin>0</Input32Pin><Input32Neg>0</Input32Neg><Input32Emulated>0</Input32Emulated><Input32EmuKey>0</Input32EmuKey><Input33Active>0</Input33Active><Input33Port>1</Input33Port><Input33Pin>0</Input33Pin><Input33Neg>0</Input33Neg><Input33Emulated>0</Input33Emulated><Input33EmuKey>0</Input33EmuKey><Input34Active>0</Input34Active><Input34Port>0</Input34Port><Input34Pin>0</Input34Pin><Input34Neg>0</Input34Neg><Input34Emulated>0</Input34Emulated><Input34EmuKey>0</Input34EmuKey><Input35Active>0</Input35Active><Input35Port>0</Input35Port><Input35Pin>0</Input35Pin><Input35Neg>0</Input35Neg><Input35Emulated>0</Input35Emulated><Input35EmuKey>0</Input35EmuKey><Input36Active>0</Input36Active><Input36Port>0</Input36Port><Input36Pin>0</Input36Pin><Input36Neg>0</Input36Neg><Input36Emulated>0</Input36Emulated><Input36EmuKey>0</Input36EmuKey><Input37Active>0</Input37Active><Input37Port>0</Input37Port><Input37Pin>0</Input37Pin><Input37Neg>0</Input37Neg><Input37Emulated>0</Input37Emulated><Input37EmuKey>0</Input37EmuKey><Input38Active>0</Input38Active><Input38Port>0</Input38Port><Input38Pin>0</Input38Pin><Input38Neg>0</Input38Neg><Input38Emulated>0</Input38Emulated><Input38EmuKey>0</Input38EmuKey><Input39Active>0</Input39Active><Input39Port>0</Input39Port><Input39Pin>0</Input39Pin><Input39Neg>0</Input39Neg><Input39Emulated>0</Input39Emulated><Input39EmuKey>0</Input39EmuKey><Input40Active>0</Input40Active><Input40Port>0</Input40Port><Input40Pin>0</Input40Pin><Input40Neg>0</Input40Neg><Input40Emulated>0</Input40Emulated><Input40EmuKey>0</Input40EmuKey><Input41Active>0</Input41Active><Input41Port>0</Input41Port><Input41Pin>0</Input41Pin><Input41Neg>0</Input41Neg><Input41Emulated>0</Input41Emulated><Input41EmuKey>0</Input41EmuKey><Input42Active>0</Input42Active><Input42Port>0</Input42Port><Input42Pin>0</Input42Pin><Input42Neg>0</Input42Neg><Input42Emulated>0</Input42Emulated><Input42EmuKey>0</Input42EmuKey><Input43Active>0</Input43Active><Input43Port>0</Input43Port><Input43Pin>0</Input43Pin><Input43Neg>0</Input43Neg><Input43Emulated>0</Input43Emulated><Input43EmuKey>0</Input43EmuKey><Input44Active>0</Input44Active><Input44Port>0</Input44Port><Input44Pin>0</Input44Pin><Input44Neg>0</Input44Neg><Input44Emulated>0</Input44Emulated><Input44EmuKey>0</Input44EmuKey><Input45Active>0</Input45Active><Input45Port>0</Input45Port><Input45Pin>0</Input45Pin><Input45Neg>0</Input45Neg><Input45Emulated>0</Input45Emulated><Input45EmuKey>0</Input45EmuKey><Input46Active>0</Input46Active><Input46Port>0</Input46Port><Input46Pin>0</Input46Pin><Input46Neg>0</Input46Neg><Input46Emulated>0</Input46Emulated><Input46EmuKey>0</Input46EmuKey><Input47Active>0</Input47Active><Input47Port>0</Input47Port><Input47Pin>0</Input47Pin><Input47Neg>0</Input47Neg><Input47Emulated>0</Input47Emulated><Input47EmuKey>0</Input47EmuKey><Input48Active>0</Input48Active><Input48Port>0</Input48Port><Input48Pin>0</Input48Pin><Input48Neg>0</Input48Neg><Input48Emulated>0</Input48Emulated><Input48EmuKey>0</Input48EmuKey><Input49Active>0</Input49Active><Input49Port>0</Input49Port><Input49Pin>0</Input49Pin><Input49Neg>0</Input49Neg><Input49Emulated>0</Input49Emulated><Input49EmuKey>0</Input49EmuKey><Input50Active>0</Input50Active><Input50Port>0</Input50Port><Input50Pin>0</Input50Pin><Input50Neg>0</Input50Neg><Input50Emulated>0</Input50Emulated><Input50EmuKey>0</Input50EmuKey><Input51Active>0</Input51Active><Input51Port>0</Input51Port><Input51Pin>0</Input51Pin><Input51Neg>0</Input51Neg><Input51Emulated>0</Input51Emulated><Input51EmuKey>0</Input51EmuKey><Input52Active>0</Input52Active><Input52Port>0</Input52Port><Input52Pin>0</Input52Pin><Input52Neg>0</Input52Neg><Input52Emulated>0</Input52Emulated><Input52EmuKey>0</Input52EmuKey><Output0Active>0</Output0Active><Output0Port>1</Output0Port><Output0Pin>0</Output0Pin><Output0Neg>0</Output0Neg><Output1Active>0</Output1Active><Output1Port>1</Output1Port><Output1Pin>0</Output1Pin><Output1Neg>0</Output1Neg><Output2Active>0</Output2Active><Output2Port>1</Output2Port><Output2Pin>0</Output2Pin><Output2Neg>0</Output2Neg><Output3Active>0</Output3Active><Output3Port>1</Output3Port><Output3Pin>0</Output3Pin><Output3Neg>0</Output3Neg><Output4Active>0</Output4Active><Output4Port>1</Output4Port><Output4Pin>0</Output4Pin><Output4Neg>0</Output4Neg><Output5Active>0</Output5Active><Output5Port>1</Output5Port><Output5Pin>0</Output5Pin><Output5Neg>0</Output5Neg><Output6Active>0</Output6Active><Output6Port>1</Output6Port><Output6Pin>0</Output6Pin><Output6Neg>0</Output6Neg><Output7Active>1</Output7Active><Output7Port>1</Output7Port><Output7Pin>17</Output7Pin><Output7Neg>0</Output7Neg><Output8Active>0</Output8Active><Output8Port>1</Output8Port><Output8Pin>0</Output8Pin><Output8Neg>0</Output8Neg><Output9Active>1</Output9Active><Output9Port>1</Output9Port><Output9Pin>1</Output9Pin><Output9Neg>0</Output9Neg><Output10Active>0</Output10Active><Output10Port>1</Output10Port><Output10Pin>0</Output10Pin><Output10Neg>0</Output10Neg><Output11Active>0</Output11Active><Output11Port>1</Output11Port><Output11Pin>0</Output11Pin><Output11Neg>0</Output11Neg><Output12Active>0</Output12Active><Output12Port>1</Output12Port><Output12Pin>0</Output12Pin><Output12Neg>0</Output12Neg><Output13Active>0</Output13Active><Output13Port>1</Output13Port><Output13Pin>0</Output13Pin><Output13Neg>0</Output13Neg><Output14Active>0</Output14Active><Output14Port>1</Output14Port><Output14Pin>0</Output14Pin><Output14Neg>0</Output14Neg><Output15Active>0</Output15Active><Output15Port>1</Output15Port><Output15Pin>0</Output15Pin><Output15Neg>0</Output15Neg><Output16Active>0</Output16Active><Output16Port>1</Output16Port><Output16Pin>0</Output16Pin><Output16Neg>0</Output16Neg><Output17Active>0</Output17Active><Output17Port>1</Output17Port><Output17Pin>0</Output17Pin><Output17Neg>0</Output17Neg><Output18Active>0</Output18Active><Output18Port>1</Output18Port><Output18Pin>0</Output18Pin><Output18Neg>0</Output18Neg><Output19Active>0</Output19Active><Output19Port>1</Output19Port><Output19Pin>0</Output19Pin><Output19Neg>0</Output19Neg><Output20Active>0</Output20Active><Output20Port>1</Output20Port><Output20Pin>0</Output20Pin><Output20Neg>0</Output20Neg><Output21Active>0</Output21Active><Output21Port>1</Output21Port><Output21Pin>0</Output21Pin><Output21Neg>0</Output21Neg><Output22Active>0</Output22Active><Output22Port>1</Output22Port><Output22Pin>0</Output22Pin><Output22Neg>0</Output22Neg><Output23Active>0</Output23Active><Output23Port>1</Output23Port><Output23Pin>0</Output23Pin><Output23Neg>0</Output23Neg><Output24Active>0</Output24Active><Output24Port>1</Output24Port><Output24Pin>0</Output24Pin><Output24Neg>0</Output24Neg><Output25Active>0</Output25Active><Output25Port>1</Output25Port><Output25Pin>0</Output25Pin><Output25Neg>0</Output25Neg><Output26Active>0</Output26Active><Output26Port>1</Output26Port><Output26Pin>0</Output26Pin><Output26Neg>0</Output26Neg><Output27Active>0</Output27Active><Output27Port>1</Output27Port><Output27Pin>0</Output27Pin><Output27Neg>0</Output27Neg><Output28Active>0</Output28Active><Output28Port>1</Output28Port><Output28Pin>0</Output28Pin><Output28Neg>0</Output28Neg><Output29Active>0</Output29Active><Output29Port>1</Output29Port><Output29Pin>0</Output29Pin><Output29Neg>0</Output29Neg><Output30Active>0</Output30Active><Output30Port>0</Output30Port><Output30Pin>0</Output30Pin><Output30Neg>0</Output30Neg><Encoder0Active>0</Encoder0Active><Encoder0APort>0</Encoder0APort><Encoder0APin>0</Encoder0APin><Encoder0BPort>0</Encoder0BPort><Encoder0BPin>0</Encoder0BPin><Encoder0Cal>1.000000</Encoder0Cal><Encoder1Active>0</Encoder1Active><Encoder1APort>0</Encoder1APort><Encoder1APin>0</Encoder1APin><Encoder1BPort>0</Encoder1BPort><Encoder1BPin>0</Encoder1BPin><Encoder1Cal>1.000000</Encoder1Cal><Encoder2Active>0</Encoder2Active><Encoder2APort>0</Encoder2APort><Encoder2APin>0</Encoder2APin><Encoder2BPort>0</Encoder2BPort><Encoder2BPin>0</Encoder2BPin><Encoder2Cal>1.000000</Encoder2Cal><Encoder3Active>0</Encoder3Active><Encoder3APort>0</Encoder3APort><Encoder3APin>0</Encoder3APin><Encoder3BPort>0</Encoder3BPort><Encoder3BPin>0</Encoder3BPin><Encoder3Cal>1.000000</Encoder3Cal><Encoder4Active>0</Encoder4Active><Encoder4APort>0</Encoder4APort><Encoder4APin>0</Encoder4APin><Encoder4BPort>0</Encoder4BPort><Encoder4BPin>0</Encoder4BPin><Encoder4Cal>1.000000</Encoder4Cal><Encoder5Active>0</Encoder5Active><Encoder5APort>0</Encoder5APort><Encoder5APin>0</Encoder5APin><Encoder5BPort>0</Encoder5BPort><Encoder5BPin>0</Encoder5BPin><Encoder5Cal>1.000000</Encoder5Cal><Encoder6Active>0</Encoder6Active><Encoder6APort>0</Encoder6APort><Encoder6APin>0</Encoder6APin><Encoder6BPort>0</Encoder6BPort><Encoder6BPin>0</Encoder6BPin><Encoder6Cal>1.000000</Encoder6Cal><Encoder7Active>0</Encoder7Active><Encoder7APort>0</Encoder7APort><Encoder7APin>0</Encoder7APin><Encoder7BPort>0</Encoder7BPort><Encoder7BPin>0</Encoder7BPin><Encoder7Cal></Encoder7Cal><Configured>1</Configured><SlavePrim>0</SlavePrim><Slave>-1</Slave><AxisKeys0>39</AxisKeys0><AxisKeys1>37</AxisKeys1><AxisKeys2>38</AxisKeys2><AxisKeys3>40</AxisKeys3><AxisKeys4>33</AxisKeys4><AxisKeys5>34</AxisKeys5><AxisKeys6>999</AxisKeys6><AxisKeys7>999</AxisKeys7><AxisKeys8>999</AxisKeys8><AxisKeys9>999</AxisKeys9><AxisKeys10>999</AxisKeys10><AxisKeys11>999</AxisKeys11><DROHotKey>999</DROHotKey><ListKey>999</ListKey><MDIHotKey>999</MDIHotKey><GCodeHotKey>999</GCodeHotKey><OEM1>-1</OEM1><OEM2>-1</OEM2><OEM3>-1</OEM3><OEM4>-1</OEM4><OEM5>-1</OEM5><OEM6>-1</OEM6><PulseWidth>0</PulseWidth><DirPulse>0</DirPulse><BackX>0.</BackX><BackY>0.</BackY><BackZ>0.</BackZ><BackA>0.</BackA><BackB>0.</BackB><BackC>0.</BackC><BackSpeed>20.</BackSpeed><BB>0.0</BB><BR>0.0</BR><BG>0.0</BG><FB>1.0</FB><FR>0.0</FR><FG>0.0</FG><RB>0.0</RB><RR>1.0</RR><RG>0.0</RG><AB>0.7</AB><AR>0.7</AR><AG>0.2</AG><EG>1.0</EG><ER>1.0</ER><EB>0.0</EB><JogFollow>0</JogFollow><G92Off>1</G92Off><RadiusCompOff>1</RadiusCompOff><Debounce>0</Debounce><PlasmaMode>0</PlasmaMode><NoAngle>0</NoAngle><AAngular>1</AAngular><BAngular>1</BAngular><CAngular>1</CAngular><IndexDebounce>0</IndexDebounce><DROPERSIST>1</DROPERSIST><DwellinMilli>0</DwellinMilli><IJMode>1</IJMode><INIT>G80</INIT><InitAllResets>0</InitAllResets><AutoScreens>0</AutoScreens><TORCHVON>0</TORCHVON><TORCHVOLTS>24000</TORCHVOLTS><HWSAFE>1</HWSAFE><ShortRot>0</ShortRot><LookAhead>20</LookAhead><WatchDog>0</WatchDog><Plane>0</Plane><MPG1>0</MPG1><MPG2>0</MPG2><HotKeysPersist>0</HotKeysPersist><HoldInput1>0</HoldInput1><M3s>325</M3s><UseCR>0</UseCR><PlasmaHome>0</PlasmaHome><Homann>0</Homann><UseSLS>0</UseSLS><Dist0>1.2e+006</Dist0><Dist1>3.3e+005</Dist1><Dist2>1.4e+005</Dist2><Dist3>0.</Dist3><Dist4>0.</Dist4><Dist5>0.</Dist5><OverMode2>0</OverMode2><BitPack1>0</BitPack1><BitPack1Reg>16</BitPack1Reg><BitPackOut>0</BitPackOut><BitPackOutReg>16</BitPackOutReg><LaserPort>1</LaserPort><LaserBaud>9600</LaserBaud><LaserStops>1</LaserStops><LaserData>1</LaserData><LaserInit>&gt;</LaserInit><LaserCommand>&gt;</LaserCommand><MacroPump>0</MacroPump><VelMode>0</VelMode><VelPer1>5.</VelPer1><VelPer2>5.</VelPer2><MPGFeed>1.e+002</MPGFeed><ModSpindleCal>1.638e+004</ModSpindleCal><ModSpindleOn>0</ModSpindleOn><ModSpindleReg>64</ModSpindleReg><ShuttleAccel>8192</ShuttleAccel><Flash>1</Flash><ImmediateOff>0</ImmediateOff><UseSafeZ>0</UseSafeZ><AdvancedComp>1</AdvancedComp><TorchOff>0</TorchOff><LaserStandby>0</LaserStandby><RaiseLower>0</RaiseLower><OEMDUAL>0</OEMDUAL><IncBuffer>5</IncBuffer><Formula0>x</Formula0><Formula1>y</Formula1><Formula2>z</Formula2><Formula3>a</Formula3><Formula4>b</Formula4><Formula5>c</Formula5><Formular>0</Formular><PanelOut>350</PanelOut><nModBusReg>0</nModBusReg><ModBusRegOn>0</ModBusRegOn><Tool>0</Tool><Sherline>0</Sherline><ToolPost>1</ToolPost><RapidOverRide>0</RapidOverRide><XCLength>1.3e+003</XCLength><YCLength>1.3e+003</YCLength><ZCLength>1.3e+003</ZCLength><ToolPostOffset>0.</ToolPostOffset><OEM7>-1</OEM7><OEM8>-1</OEM8><OEM9>-1</OEM9><OEM10>-1</OEM10><OEM11>-1</OEM11><OEM12>-1</OEM12><OEM13>-1</OEM13><OEM14>-1</OEM14><OEM15>-1</OEM15><MPGVel0>1.e+002</MPGVel0><MPGVel1>1.e+002</MPGVel1><MPGVel2>1.e+002</MPGVel2><MPGVel3>1.e+002</MPGVel3><MPGVel4>1.e+002</MPGVel4><MPGVel5>1.e+002</MPGVel5><MPGVel6>1.e+002</MPGVel6><ByPassFeed>1.e+003</ByPassFeed><XMapOn>0</XMapOn><YMapOn>0</YMapOn><ZMapOn>0</ZMapOn><SecondsOn>354988</SecondsOn><SerialType>0</SerialType><SpinAverage>0</SpinAverage><Dig4Axis>0</Dig4Axis><DigLetter>0</DigLetter><CutType>0</CutType><InfeedType>0</InfeedType><LastWizard>C:\Mach3\Addons\Cut Circle\Cut circle.set</LastWizard><Z25D>0</Z25D><ModBus>0</ModBus><ChargeAlwaysOn>0</ChargeAlwaysOn><ToolFlip>0</ToolFlip><SpinCCW>7</SpinCCW><SpinCW>7</SpinCW><Flood>9</Flood><Mist>9</Mist><SpinActual>0</SpinActual><SpinDelayCW>1.</SpinDelayCW><SpinDelayCCW>1.</SpinDelayCCW><SpinDownCW>1.</SpinDownCW><SpinDownCCW>1.</SpinDownCCW><StockSize>50</StockSize><ShowSolid>0</ShowSolid><RapidFeed>1.e+003</RapidFeed><MatRed>0.</MatRed><MatGreen>0.1</MatGreen><MatBlue>0.1</MatBlue><SpinP>0.25</SpinP><SpinI>1.</SpinI><SpinD>0.3</SpinD><SpinClosed>0</SpinClosed><MinPerPass>0.1</MinPerPass><NoSpindle>0</NoSpindle><NoFlood>0</NoFlood><PWMin>0</PWMin><PULLEY>0</PULLEY><SPEED1>24000</SPEED1><SPEED2>2000</SPEED2><SPEED3>4000</SPEED3><SPEED4>8000</SPEED4><LSPEED1>0</LSPEED1><LSPEED2>0</LSPEED2><LSPEED3>0</LSPEED3><LSPEED4>0</LSPEED4><PWM>1</PWM><RefSpeed0>20</RefSpeed0><RefSpeed1>20</RefSpeed1><RefSpeed2>20</RefSpeed2><RefSpeed3>20</RefSpeed3><RefSpeed4>20</RefSpeed4><RefSpeed5>20</RefSpeed5><M0SoftRamp>1.</M0SoftRamp><M1SoftRamp>1.</M1SoftRamp><M2SoftRamp>1.</M2SoftRamp><M3SoftRamp>1.</M3SoftRamp><M4SoftRamp>1.</M4SoftRamp><M5SoftRamp>1.</M5SoftRamp><FeedInc>5.</FeedInc><DepthLastPass>0.</DepthLastPass><InFeed>29.5</InFeed><Spring>1.</Spring><MinDepth>1.e-003</MinDepth><XClear>0.1</XClear><ZClear>0.1</ZClear><CutDepth>0.1</CutDepth><Chamfer>0.</Chamfer><DepthFirstPass>0.1</DepthFirstPass><M0Max>100.</M0Max><M1Max>100.</M1Max><M2Max>100.</M2Max><M3Max>100.</M3Max><M4Max>100.</M4Max><M5Max>100.</M5Max><M0Min>-100.</M0Min><M1Min>-100.</M1Min><M2Min>-100.</M2Min><M3Min>-100.</M3Min><M4Min>-100.</M4Min><M5Min>-100.</M5Min><M0Neg>0</M0Neg><M1Neg>0</M1Neg><M2Neg>0</M2Neg><M3Neg>0</M3Neg><M4Neg>0</M4Neg><M5Neg>0</M5Neg><M0AutoZero>1</M0AutoZero><M1AutoZero>1</M1AutoZero><M2AutoZero>1</M2AutoZero><M3AutoZero>1</M3AutoZero><M4AutoZero>1</M4AutoZero><M5AutoZero>1</M5AutoZero><M0Rev>0</M0Rev><M1Rev>0</M1Rev><M2Rev>1</M2Rev><M3Rev>0</M3Rev><M4Rev>0</M4Rev><M5Rev>0</M5Rev><M6Rev>0</M6Rev><OffPersist>1</OffPersist><Diameter>0</Diameter><OffDialogs>1</OffDialogs><G54Back>0</G54Back><GougeCheck>0</GougeCheck><AxisToMotor0>0</AxisToMotor0><AxisToMotor1>1</AxisToMotor1><AxisToMotor2>2</AxisToMotor2><AxisToMotor3>3</AxisToMotor3><AxisToMotor4>4</AxisToMotor4><AxisToMotor5>5</AxisToMotor5><AxisToMotor6>6</AxisToMotor6><JogActive>1</JogActive><BLState0>0</BLState0><BLState1>1</BLState1><BLState2>1</BLState2><BLState3>1</BLState3><BLState4>0</BLState4><BLState5>0</BLState5><SlowMode>0</SlowMode><JogPersist>1</JogPersist><ToolRotations>0</ToolRotations><SoftLimit>0</SoftLimit><JogMode>0</JogMode><JogMode2>0</JogMode2><EncJogAxis2>2</EncJogAxis2><TaperRatio>1.</TaperRatio><XStart>-10430</XStart><YStart>11942</YStart><ZStart>6443</ZStart><AStart>11942</AStart><BStart>0</BStart><CStart>0</CStart><SpinInc>10</SpinInc><Enc0>0.</Enc0><Enc1>0.</Enc1><Enc2>0.</Enc2><Enc3>0.</Enc3><TangentalControl>0</TangentalControl><BaudRate>9600</BaudRate><ComPort>1</ComPort><NoPlunge>0</NoPlunge><PlungeLimit>60</PlungeLimit><AutoTool>0</AutoTool><AutoSpindle>1</AutoSpindle><LaserMode>0</LaserMode><FeedMode>0</FeedMode><OriginSphere>0</OriginSphere><m_3dCompass>1</m_3dCompass><Boundries>0</Boundries><ToolPosition>1</ToolPosition><AParallel>0</AParallel><ZINHPersist>0</ZINHPersist><OVPersist>1</OVPersist><BacklashOn>0</BacklashOn><PathMode>2</PathMode><ThrottleFunc>2</ThrottleFunc><JoyOn>0</JoyOn><PWMBase>900</PWMBase><JogSpeed>20.</JogSpeed><G73PullBack>0.1</G73PullBack><CVFeedOn>0</CVFeedOn><CVFeedRate>1.</CVFeedRate><AtoX>0.</AtoX><AtoY>0.</AtoY><AtoZ>0.</AtoZ><OEMDRO0>0.</OEMDRO0><OEMLED0>0</OEMLED0><OEMDRO1>0.</OEMDRO1><OEMLED1>0</OEMLED1><OEMDRO2>0.</OEMDRO2><OEMLED2>0</OEMLED2><OEMDRO3>0.</OEMDRO3><OEMLED3>0</OEMLED3><OEMDRO4>0.</OEMDRO4><OEMLED4>0</OEMLED4><OEMDRO5>0.</OEMDRO5><OEMLED5>0</OEMLED5><OEMDRO6>0.</OEMDRO6><OEMLED6>0</OEMLED6><OEMDRO7>0.</OEMDRO7><OEMLED7>0</OEMLED7><OEMDRO8>0.</OEMDRO8><OEMLED8>0</OEMLED8><OEMDRO9>0.</OEMDRO9><OEMLED9>0</OEMLED9><OEMDRO10>0.</OEMDRO10><OEMLED10>0</OEMLED10><OEMDRO11>0.</OEMDRO11><OEMLED11>0</OEMLED11><OEMDRO12>0.</OEMDRO12><OEMLED12>0</OEMLED12><OEMDRO13>0.</OEMDRO13><OEMLED13>0</OEMLED13><OEMDRO14>0.</OEMDRO14><OEMLED14>0</OEMLED14><OEMDRO15>0.</OEMDRO15><OEMLED15>0</OEMLED15><OEMDRO16>0.</OEMDRO16><OEMLED16>0</OEMLED16><OEMDRO17>0.</OEMDRO17><OEMLED17>0</OEMLED17><OEMDRO18>0.</OEMDRO18><OEMLED18>0</OEMLED18><OEMDRO19>0.</OEMDRO19><OEMLED19>0</OEMLED19><OEMDRO20>0.</OEMDRO20><OEMLED20>0</OEMLED20><OEMDRO21>0.</OEMDRO21><OEMLED21>0</OEMLED21><OEMDRO22>0.</OEMDRO22><OEMLED22>0</OEMLED22><OEMDRO23>0.</OEMDRO23><OEMLED23>0</OEMLED23><OEMDRO24>0.</OEMDRO24><OEMLED24>0</OEMLED24><OEMDRO25>0.</OEMDRO25><OEMLED25>0</OEMLED25><OEMDRO26>0.</OEMDRO26><OEMLED26>0</OEMLED26><OEMDRO27>0.</OEMDRO27><OEMLED27>0</OEMLED27><OEMDRO28>0.</OEMDRO28><OEMLED28>0</OEMLED28><OEMDRO29>0.</OEMDRO29><OEMLED29>0</OEMLED29><OEMDRO30>0.</OEMDRO30><OEMLED30>0</OEMLED30><OEMDRO31>0.</OEMDRO31><OEMLED31>0</OEMLED31><OEMDRO32>0.</OEMDRO32><OEMLED32>0</OEMLED32><OEMDRO33>0.</OEMDRO33><OEMLED33>0</OEMLED33><OEMDRO34>0.</OEMDRO34><OEMLED34>0</OEMLED34><OEMDRO35>0.</OEMDRO35><OEMLED35>0</OEMLED35><OEMDRO36>0.</OEMDRO36><OEMLED36>0</OEMLED36><OEMDRO37>0.</OEMDRO37><OEMLED37>0</OEMLED37><OEMDRO38>0.</OEMDRO38><OEMLED38>0</OEMLED38><OEMDRO39>0.</OEMDRO39><OEMLED39>0</OEMLED39><OEMDRO40>0.</OEMDRO40><OEMLED40>0</OEMLED40><OEMDRO41>0.</OEMDRO41><OEMLED41>0</OEMLED41><OEMDRO42>0.</OEMDRO42><OEMLED42>0</OEMLED42><OEMDRO43>0.</OEMDRO43><OEMLED43>0</OEMLED43><OEMDRO44>0.</OEMDRO44><OEMLED44>0</OEMLED44><OEMDRO45>0.</OEMDRO45><OEMLED45>0</OEMLED45><OEMDRO46>0.</OEMDRO46><OEMLED46>0</OEMLED46><OEMDRO47>0.</OEMDRO47><OEMLED47>0</OEMLED47><OEMDRO48>0.</OEMDRO48><OEMLED48>0</OEMLED48><OEMDRO49>0.</OEMDRO49><OEMLED49>0</OEMLED49><OEMDRO50>0.</OEMDRO50><OEMLED50>0</OEMLED50><OEMDRO51>0.</OEMDRO51><OEMLED51>0</OEMLED51><OEMDRO52>0.</OEMDRO52><OEMLED52>0</OEMLED52><OEMDRO53>0.</OEMDRO53><OEMLED53>0</OEMLED53><OEMDRO54>0.</OEMDRO54><OEMLED54>0</OEMLED54><OEMDRO55>0.</OEMDRO55><OEMLED55>0</OEMLED55><OEMDRO56>0.</OEMDRO56><OEMLED56>0</OEMLED56><OEMDRO57>0.</OEMDRO57><OEMLED57>0</OEMLED57><OEMDRO58>0.</OEMDRO58><OEMLED58>0</OEMLED58><OEMDRO59>0.</OEMDRO59><OEMLED59>0</OEMLED59><OEMDRO60>0.</OEMDRO60><OEMLED60>0</OEMLED60><OEMDRO61>0.</OEMDRO61><OEMLED61>0</OEMLED61><OEMDRO62>0.</OEMDRO62><OEMLED62>0</OEMLED62><OEMDRO63>0.</OEMDRO63><OEMLED63>0</OEMLED63><OEMDRO64>0.</OEMDRO64><OEMLED64>0</OEMLED64><OEMDRO65>0.</OEMDRO65><OEMLED65>0</OEMLED65><OEMDRO66>0.</OEMDRO66><OEMLED66>0</OEMLED66><OEMDRO67>0.</OEMDRO67><OEMLED67>0</OEMLED67><OEMDRO68>0.</OEMDRO68><OEMLED68>0</OEMLED68><OEMDRO69>0.</OEMDRO69><OEMLED69>0</OEMLED69><OEMDRO70>0.</OEMDRO70><OEMLED70>0</OEMLED70><OEMDRO71>0.</OEMDRO71><OEMLED71>0</OEMLED71><OEMDRO72>0.</OEMDRO72><OEMLED72>0</OEMLED72><OEMDRO73>0.</OEMDRO73><OEMLED73>0</OEMLED73><OEMDRO74>0.</OEMDRO74><OEMLED74>0</OEMLED74><OEMDRO75>0.</OEMDRO75><OEMLED75>0</OEMLED75><OEMDRO76>0.</OEMDRO76><OEMLED76>0</OEMLED76><OEMDRO77>0.</OEMDRO77><OEMLED77>0</OEMLED77><OEMDRO78>0.</OEMDRO78><OEMLED78>0</OEMLED78><OEMDRO79>0.</OEMDRO79><OEMLED79>0</OEMLED79><OEMDRO80>0.</OEMDRO80><OEMLED80>0</OEMLED80><OEMDRO81>0.</OEMDRO81><OEMLED81>0</OEMLED81><OEMDRO82>0.</OEMDRO82><OEMLED82>0</OEMLED82><OEMDRO83>0.</OEMDRO83><OEMLED83>0</OEMLED83><OEMDRO84>0.</OEMDRO84><OEMLED84>0</OEMLED84><OEMDRO85>0.</OEMDRO85><OEMLED85>0</OEMLED85><OEMDRO86>0.</OEMDRO86><OEMLED86>0</OEMLED86><OEMDRO87>0.</OEMDRO87><OEMLED87>0</OEMLED87><OEMDRO88>0.</OEMDRO88><OEMLED88>0</OEMLED88><OEMDRO89>0.</OEMDRO89><OEMLED89>0</OEMLED89><OEMDRO90>0.</OEMDRO90><OEMLED90>0</OEMLED90><OEMDRO91>0.</OEMDRO91><OEMLED91>0</OEMLED91><OEMDRO92>0.</OEMDRO92><OEMLED92>0</OEMLED92><OEMDRO93>0.</OEMDRO93><OEMLED93>0</OEMLED93><OEMDRO94>0.</OEMDRO94><OEMLED94>0</OEMLED94><OEMDRO95>0.</OEMDRO95><OEMLED95>0</OEMLED95><OEMDRO96>0.</OEMDRO96><OEMLED96>0</OEMLED96><OEMDRO97>0.</OEMDRO97><OEMLED97>0</OEMLED97><OEMDRO98>0.</OEMDRO98><OEMLED98>0</OEMLED98><OEMDRO99>0.</OEMDRO99><OEMLED99>0</OEMLED99><OEMDRO100>0.</OEMDRO100><OEMLED100>0</OEMLED100><OEMDRO101>0.</OEMDRO101><OEMLED101>0</OEMLED101><OEMDRO102>0.</OEMDRO102><OEMLED102>0</OEMLED102><OEMDRO103>0.</OEMDRO103><OEMLED103>0</OEMLED103><OEMDRO104>0.</OEMDRO104><OEMLED104>0</OEMLED104><OEMDRO105>0.</OEMDRO105><OEMLED105>0</OEMLED105><OEMDRO106>0.</OEMDRO106><OEMLED106>0</OEMLED106><OEMDRO107>0.</OEMDRO107><OEMLED107>0</OEMLED107><OEMDRO108>0.</OEMDRO108><OEMLED108>0</OEMLED108><OEMDRO109>0.</OEMDRO109><OEMLED109>0</OEMLED109><OEMDRO110>0.</OEMDRO110><OEMLED110>0</OEMLED110><OEMDRO111>0.</OEMDRO111><OEMLED111>0</OEMLED111><OEMDRO112>0.</OEMDRO112><OEMLED112>0</OEMLED112><OEMDRO113>0.</OEMDRO113><OEMLED113>0</OEMLED113><OEMDRO114>0.</OEMDRO114><OEMLED114>0</OEMLED114><OEMDRO115>0.</OEMDRO115><OEMLED115>0</OEMLED115><OEMDRO116>0.</OEMDRO116><OEMLED116>0</OEMLED116><OEMDRO117>0.</OEMDRO117><OEMLED117>0</OEMLED117><OEMDRO118>0.</OEMDRO118><OEMLED118>0</OEMLED118><OEMDRO119>0.</OEMDRO119><OEMLED119>0</OEMLED119><OEMDRO120>0.</OEMDRO120><OEMLED120>0</OEMLED120><OEMDRO121>0.</OEMDRO121><OEMLED121>0</OEMLED121><OEMDRO122>0.</OEMDRO122><OEMLED122>0</OEMLED122><OEMDRO123>0.</OEMDRO123><OEMLED123>0</OEMLED123><OEMDRO124>0.</OEMDRO124><OEMLED124>0</OEMLED124><OEMDRO125>0.</OEMDRO125><OEMLED125>0</OEMLED125><OEMDRO126>0.</OEMDRO126><OEMLED126>0</OEMLED126><OEMDRO127>0.</OEMDRO127><OEMLED127>0</OEMLED127><OEMDRO128>0.</OEMDRO128><OEMLED128>0</OEMLED128><OEMDRO129>0.</OEMDRO129><OEMLED129>0</OEMLED129><OEMDRO130>0.</OEMDRO130><OEMLED130>0</OEMLED130><OEMDRO131>0.</OEMDRO131><OEMLED131>0</OEMLED131><OEMDRO132>0.</OEMDRO132><OEMLED132>0</OEMLED132><OEMDRO133>0.</OEMDRO133><OEMLED133>0</OEMLED133><OEMDRO134>0.</OEMDRO134><OEMLED134>0</OEMLED134><OEMDRO135>0.</OEMDRO135><OEMLED135>0</OEMLED135><OEMDRO136>0.</OEMDRO136><OEMLED136>0</OEMLED136><OEMDRO137>0.</OEMDRO137><OEMLED137>0</OEMLED137><OEMDRO138>0.</OEMDRO138><OEMLED138>0</OEMLED138><OEMDRO139>0.</OEMDRO139><OEMLED139>0</OEMLED139><OEMDRO140>0.</OEMDRO140><OEMLED140>0</OEMLED140><OEMDRO141>0.</OEMDRO141><OEMLED141>0</OEMLED141><OEMDRO142>0.</OEMDRO142><OEMLED142>0</OEMLED142><OEMDRO143>0.</OEMDRO143><OEMLED143>0</OEMLED143><OEMDRO144>0.</OEMDRO144><OEMLED144>0</OEMLED144><OEMDRO145>0.</OEMDRO145><OEMLED145>0</OEMLED145><OEMDRO146>0.</OEMDRO146><OEMLED146>0</OEMLED146><OEMDRO147>0.</OEMDRO147><OEMLED147>0</OEMLED147><OEMDRO148>0.</OEMDRO148><OEMLED148>0</OEMLED148><OEMDRO149>0.</OEMDRO149><OEMLED149>0</OEMLED149><OEMDRO150>0.</OEMDRO150><OEMLED150>0</OEMLED150><OEMDRO151>0.</OEMDRO151><OEMLED151>0</OEMLED151><OEMDRO152>0.</OEMDRO152><OEMLED152>0</OEMLED152><OEMDRO153>0.</OEMDRO153><OEMLED153>0</OEMLED153><OEMDRO154>0.</OEMDRO154><OEMLED154>0</OEMLED154><OEMDRO155>0.</OEMDRO155><OEMLED155>0</OEMLED155><OEMDRO156>0.</OEMDRO156><OEMLED156>0</OEMLED156><OEMDRO157>0.</OEMDRO157><OEMLED157>0</OEMLED157><OEMDRO158>0.</OEMDRO158><OEMLED158>0</OEMLED158><OEMDRO159>0.</OEMDRO159><OEMLED159>0</OEMLED159><OEMDRO160>0.</OEMDRO160><OEMLED160>0</OEMLED160><OEMDRO161>0.</OEMDRO161><OEMLED161>0</OEMLED161><OEMDRO162>0.</OEMDRO162><OEMLED162>0</OEMLED162><OEMDRO163>0.</OEMDRO163><OEMLED163>0</OEMLED163><OEMDRO164>0.</OEMDRO164><OEMLED164>0</OEMLED164><OEMDRO165>0.</OEMDRO165><OEMLED165>0</OEMLED165><OEMDRO166>0.</OEMDRO166><OEMLED166>0</OEMLED166><OEMDRO167>0.</OEMDRO167><OEMLED167>0</OEMLED167><OEMDRO168>0.</OEMDRO168><OEMLED168>0</OEMLED168><OEMDRO169>0.</OEMDRO169><OEMLED169>0</OEMLED169><OEMDRO170>0.</OEMDRO170><OEMLED170>0</OEMLED170><OEMDRO171>0.</OEMDRO171><OEMLED171>0</OEMLED171><OEMDRO172>0.</OEMDRO172><OEMLED172>0</OEMLED172><OEMDRO173>0.</OEMDRO173><OEMLED173>0</OEMLED173><OEMDRO174>0.</OEMDRO174><OEMLED174>0</OEMLED174><OEMDRO175>0.</OEMDRO175><OEMLED175>0</OEMLED175><OEMDRO176>0.</OEMDRO176><OEMLED176>0</OEMLED176><OEMDRO177>0.</OEMDRO177><OEMLED177>0</OEMLED177><OEMDRO178>0.</OEMDRO178><OEMLED178>0</OEMLED178><OEMDRO179>0.</OEMDRO179><OEMLED179>0</OEMLED179><OEMDRO180>0.</OEMDRO180><OEMLED180>0</OEMLED180><OEMDRO181>0.</OEMDRO181><OEMLED181>0</OEMLED181><OEMDRO182>0.</OEMDRO182><OEMLED182>0</OEMLED182><OEMDRO183>0.</OEMDRO183><OEMLED183>0</OEMLED183><OEMDRO184>0.</OEMDRO184><OEMLED184>0</OEMLED184><OEMDRO185>0.</OEMDRO185><OEMLED185>0</OEMLED185><OEMDRO186>0.</OEMDRO186><OEMLED186>0</OEMLED186><OEMDRO187>0.</OEMDRO187><OEMLED187>0</OEMLED187><OEMDRO188>0.</OEMDRO188><OEMLED188>0</OEMLED188><OEMDRO189>0.</OEMDRO189><OEMLED189>0</OEMLED189><OEMDRO190>0.</OEMDRO190><OEMLED190>0</OEMLED190><OEMDRO191>0.</OEMDRO191><OEMLED191>0</OEMLED191><OEMDRO192>0.</OEMDRO192><OEMLED192>0</OEMLED192><OEMDRO193>0.</OEMDRO193><OEMLED193>0</OEMLED193><OEMDRO194>0.</OEMDRO194><OEMLED194>0</OEMLED194><OEMDRO195>0.</OEMDRO195><OEMLED195>0</OEMLED195><OEMDRO196>0.</OEMDRO196><OEMLED196>0</OEMLED196><OEMDRO197>0.</OEMDRO197><OEMLED197>0</OEMLED197><OEMDRO198>0.</OEMDRO198><OEMLED198>0</OEMLED198><OEMDRO199>0.</OEMDRO199><OEMLED199>0</OEMLED199><OEMDRO200>0.</OEMDRO200><OEMLED200>0</OEMLED200><OEMDRO201>0.</OEMDRO201><OEMLED201>0</OEMLED201><OEMDRO202>0.</OEMDRO202><OEMLED202>0</OEMLED202><OEMDRO203>0.</OEMDRO203><OEMLED203>0</OEMLED203><OEMDRO204>0.</OEMDRO204><OEMLED204>0</OEMLED204><OEMDRO205>0.</OEMDRO205><OEMLED205>0</OEMLED205><OEMDRO206>0.</OEMDRO206><OEMLED206>0</OEMLED206><OEMDRO207>0.</OEMDRO207><OEMLED207>0</OEMLED207><OEMDRO208>0.</OEMDRO208><OEMLED208>0</OEMLED208><OEMDRO209>0.</OEMDRO209><OEMLED209>0</OEMLED209><OEMDRO210>0.</OEMDRO210><OEMLED210>0</OEMLED210><OEMDRO211>0.</OEMDRO211><OEMLED211>0</OEMLED211><OEMDRO212>0.</OEMDRO212><OEMLED212>0</OEMLED212><OEMDRO213>0.</OEMDRO213><OEMLED213>0</OEMLED213><OEMDRO214>0.</OEMDRO214><OEMLED214>0</OEMLED214><OEMDRO215>0.</OEMDRO215><OEMLED215>0</OEMLED215><OEMDRO216>0.</OEMDRO216><OEMLED216>0</OEMLED216><OEMDRO217>0.</OEMDRO217><OEMLED217>0</OEMLED217><OEMDRO218>0.</OEMDRO218><OEMLED218>0</OEMLED218><OEMDRO219>0.</OEMDRO219><OEMLED219>0</OEMLED219><OEMDRO220>0.</OEMDRO220><OEMLED220>0</OEMLED220><OEMDRO221>0.</OEMDRO221><OEMLED221>0</OEMLED221><OEMDRO222>0.</OEMDRO222><OEMLED222>0</OEMLED222><OEMDRO223>0.</OEMDRO223><OEMLED223>0</OEMLED223><OEMDRO224>0.</OEMDRO224><OEMLED224>0</OEMLED224><OEMDRO225>0.</OEMDRO225><OEMLED225>0</OEMLED225><OEMDRO226>0.</OEMDRO226><OEMLED226>0</OEMLED226><OEMDRO227>0.</OEMDRO227><OEMLED227>0</OEMLED227><OEMDRO228>0.</OEMDRO228><OEMLED228>0</OEMLED228><OEMDRO229>0.</OEMDRO229><OEMLED229>0</OEMLED229><OEMDRO230>0.</OEMDRO230><OEMLED230>0</OEMLED230><OEMDRO231>0.</OEMDRO231><OEMLED231>0</OEMLED231><OEMDRO232>0.</OEMDRO232><OEMLED232>0</OEMLED232><OEMDRO233>0.</OEMDRO233><OEMLED233>0</OEMLED233><OEMDRO234>0.</OEMDRO234><OEMLED234>0</OEMLED234><OEMDRO235>0.</OEMDRO235><OEMLED235>0</OEMLED235><OEMDRO236>0.</OEMDRO236><OEMLED236>0</OEMLED236><OEMDRO237>0.</OEMDRO237><OEMLED237>0</OEMLED237><OEMDRO238>0.</OEMDRO238><OEMLED238>0</OEMLED238><OEMDRO239>0.</OEMDRO239><OEMLED239>0</OEMLED239><OEMDRO240>0.</OEMDRO240><OEMLED240>0</OEMLED240><OEMDRO241>0.</OEMDRO241><OEMLED241>0</OEMLED241><OEMDRO242>0.</OEMDRO242><OEMLED242>0</OEMLED242><OEMDRO243>0.</OEMDRO243><OEMLED243>0</OEMLED243><OEMDRO244>0.</OEMDRO244><OEMLED244>0</OEMLED244><OEMDRO245>0.</OEMDRO245><OEMLED245>0</OEMLED245><OEMDRO246>0.</OEMDRO246><OEMLED246>0</OEMLED246><OEMDRO247>0.</OEMDRO247><OEMLED247>0</OEMLED247><OEMDRO248>0.</OEMDRO248><OEMLED248>0</OEMLED248><OEMDRO249>0.</OEMDRO249><OEMLED249>0</OEMLED249><OEMDRO250>0.</OEMDRO250><OEMLED250>0</OEMLED250><OEMDRO251>0.</OEMDRO251><OEMLED251>0</OEMLED251><OEMDRO252>0.</OEMDRO252><OEMLED252>0</OEMLED252><OEMDRO253>0.</OEMDRO253><OEMLED253>0</OEMLED253><OEMDRO254>0.</OEMDRO254><OEMLED254>0</OEMLED254><OEMDRO255>0.</OEMDRO255><OEMLED255>0</OEMLED255><JogInc>1.e-003</JogInc><JogSlide>0.1</JogSlide><THCMax>1.</THCMax><THCMin>0.2</THCMin><RadiusA>0.</RadiusA><RadiusB>0.</RadiusB><RadiusC>0.</RadiusC><LiftLevel>1.</LiftLevel><LiftAngle>45.</LiftAngle><InhibitDepth>0.</InhibitDepth><LaserXGrid>0.</LaserXGrid><LaserYGrid>0.</LaserYGrid><LaserAGrid>0.</LaserAGrid><JogInc0>1.</JogInc0><JogInc1>0.1</JogInc1><JogInc2>1.e-002</JogInc2><JogInc3>1.e-003</JogInc3><JogInc4>1.e-004</JogInc4><JogInc5>1.</JogInc5><JogInc6>0.1</JogInc6><JogInc7>1.e-002</JogInc7><JogInc8>1.e-003</JogInc8><JogInc9>1.e-004</JogInc9><THCSpeed>20.</THCSpeed><BlendFactor>180.</BlendFactor><M0RefHome>0</M0RefHome><M1RefHome>0</M1RefHome><M2RefHome>0</M2RefHome><M3RefHome>0</M3RefHome><M4RefHome>0</M4RefHome><M5RefHome>0</M5RefHome><MRU10>E:\Vac6 1 8 FL .acl</MRU10><MRU9>E:\IM Rough Ear .acl</MRU9><MRU8>E:\IM 1 8 BN 2  Ear .acl</MRU8><MRU7>E:\IM 1 16 BN 3  Ear .acl</MRU7><MRU6>E:\Vac Seal Small 1 8 FN.acl</MRU6><MRU5>C:\Documents and Settings\CNC\My Documents\CNC G-Code\Vac Chamber seal\Seal3.acl</MRU5><MRU4>C:\Documents and Settings\CNC\My Documents\CNC G-Code\Vac Chamber seal\Seal.acl</MRU4><MRU3>C:\Documents and Settings\CNC\My Documents\CNC G-Code\Begins\Fins\Rough.acl</MRU3><MRU2>C:\Documents and Settings\CNC\My Documents\CNC G-Code\Vac Chamber seal\Seal2.acl</MRU2><MRU1>E:\Cap A2 Rough.acl</MRU1><ToolPersist>0</ToolPersist><KeepRef>0</KeepRef><TurnRevArc>1</TurnRevArc><DROFont>Arial</DROFont><LabelFont>Arial</LabelFont><CodeFont>Arial</CodeFont><PierceDelay>1.</PierceDelay><VelPer3>5.</VelPer3><TouchX>0.</TouchX><G20X>0.</G20X><G20Y>0.</G20Y><G20Z>0.</G20Z><G20A>0.</G20A><G20B>0.</G20B><G20C>0.</G20C><FrontRear>0.</FrontRear><EncJogAxis3>2</EncJogAxis3><WarnOnReset>0</WarnOnReset><NURBS>0</NURBS><HiRes>0</HiRes><DelinChar>12</DelinChar><Rot360>0</Rot360><SerialServo>0</SerialServo><ToolLines>0</ToolLines><UDP>0</UDP><DefDir>C:\Mach3</DefDir><NewPath>0</NewPath><SafeZStop>0</SafeZStop><SafeZType>0</SafeZType><UseDiam>0</UseDiam><SPINREV1>0</SPINREV1><SPINREV2>0</SPINREV2><SPINREV3>0</SPINREV3><SPINREV4>0</SPINREV4><SPEED5>25000</SPEED5><LSPEED5>0</LSPEED5><SPINREV5>0</SPINREV5><SPEED6>25000</SPEED6><LSPEED6>0</LSPEED6><SPINREV6>0</SPINREV6><SPEED7>25000</SPEED7><LSPEED7>0</LSPEED7><SPINREV7>0</SPINREV7><SPEED8>25000</SPEED8><LSPEED8>0</LSPEED8><SPINREV8>0</SPINREV8><SPEED9>25000</SPEED9><LSPEED9>0</LSPEED9><SPINREV9>0</SPINREV9><SPEED10>25000</SPEED10><LSPEED10>0</LSPEED10><SPINREV10>0</SPINREV10><SPEED11>25000</SPEED11><LSPEED11>0</LSPEED11><SPINREV11>0</SPINREV11><SPEED12>25000</SPEED12><LSPEED12>0</LSPEED12><SPINREV12>0</SPINREV12><SPEED13>25000</SPEED13><LSPEED13>0</LSPEED13><SPINREV13>0</SPINREV13><SPEED14>25000</SPEED14><LSPEED14>0</LSPEED14><SPINREV14>0</SPINREV14><SPEED15>25000</SPEED15><LSPEED15>0</LSPEED15><SPINREV15>0</SPINREV15><SPEED16>25000</SPEED16><LSPEED16>0</LSPEED16><SPINREV16>0</SPINREV16><SPEED17>25000</SPEED17><LSPEED17>0</LSPEED17><SPINREV17>0</SPINREV17><SPEED18>25000</SPEED18><LSPEED18>0</LSPEED18><SPINREV18>0</SPINREV18><SPEED19>25000</SPEED19><LSPEED19>0</LSPEED19><SPINREV19>0</SPINREV19><SPEED20>25000</SPEED20><LSPEED20>0</LSPEED20><SPINREV20>0</SPINREV20><SPEED21>25000</SPEED21><LSPEED21>0</LSPEED21><SPINREV21>0</SPINREV21><SPEED22>25000</SPEED22><LSPEED22>0</LSPEED22><SPINREV22>0</SPINREV22><SPEED23>25000</SPEED23><LSPEED23>0</LSPEED23><SPINREV23>0</SPINREV23><SPEED24>25000</SPEED24><LSPEED24>0</LSPEED24><SPINREV24>0</SPINREV24><SPEED25>25000</SPEED25><LSPEED25>0</LSPEED25><SPINREV25>0</SPINREV25><m_SafeZ>0.</m_SafeZ><EncJogAxis1>0</EncJogAxis1><AutoCalcs>0</AutoCalcs><CVUseAngle>0</CVUseAngle><CVDegrees>0.</CVDegrees><M30SpinOff>1</M30SpinOff><Boxed>1</Boxed><ButtonFont>Arial</ButtonFont><OVSpinInc>10</OVSpinInc><Syskey1>1</Syskey1><ModPlug>0</ModPlug><KeyClick>1</KeyClick><THC5>0</THC5><ModPort>1</ModPort><AutoBaud>57600</AutoBaud><AutoType1>0</AutoType1><AutoType2>0</AutoType2><AutoType3>0</AutoType3><AutoType4>0</AutoType4><AutoOn1>0</AutoOn1><AutoOn2>0</AutoOn2><AutoOn3>0</AutoOn3><AutoOn4>0</AutoOn4><AutoSlave1>0</AutoSlave1><AutoSlave2>0</AutoSlave2><AutoSlave3>0</AutoSlave3><AutoSlave4>0</AutoSlave4><AutoStart1>0</AutoStart1><AutoStart2>0</AutoStart2><AutoStart3>0</AutoStart3><AutoStart4>0</AutoStart4><AutoEnd1>0</AutoEnd1><AutoEnd2>0</AutoEnd2><AutoEnd3>0</AutoEnd3><AutoEnd4>0</AutoEnd4><RTSON>0</RTSON><TIMEOUT>100</TIMEOUT><Hertz>50</Hertz><Prot>3</Prot><ID>None</ID><LastUser>Brad McDowall</LastUser><ROTSOFT>1</ROTSOFT><PROBETLO>0</PROBETLO><SlaveHome>0</SlaveHome><JogHeat>0</JogHeat><SPINRATIO1>1.</SPINRATIO1><SPINRATIO2>1.</SPINRATIO2><SPINRATIO3>1.</SPINRATIO3><SPINRATIO4>1.</SPINRATIO4><SPINRATIO5>1.</SPINRATIO5><SPINRATIO6>1.</SPINRATIO6><SPINRATIO7>1.</SPINRATIO7><SPINRATIO8>1.</SPINRATIO8><SPINRATIO9>1.</SPINRATIO9><SPINRATIO10>1.</SPINRATIO10><SPINRATIO11>1.</SPINRATIO11><SPINRATIO12>1.</SPINRATIO12><SPINRATIO13>1.</SPINRATIO13><SPINRATIO14>1.</SPINRATIO14><SPINRATIO15>1.</SPINRATIO15><SPINRATIO16>1.</SPINRATIO16><SPINRATIO17>1.</SPINRATIO17><SPINRATIO18>1.</SPINRATIO18><SPINRATIO19>1.</SPINRATIO19><SPINRATIO20>1.</SPINRATIO20><SPINRATIO21>1.</SPINRATIO21><SPINRATIO22>1.</SPINRATIO22><SPINRATIO23>1.</SPINRATIO23><SPINRATIO24>1.</SPINRATIO24><SPINRATIO25>1.</SPINRATIO25><Running>1</Running><TCPMODBUS>0</TCPMODBUS><MenuOff>0</MenuOff><ZBar>1</ZBar><IgnoreMacros>0</IgnoreMacros><DwellTrigger>0</DwellTrigger><M7Delay>0.</M7Delay><M8Delay>0.</M8Delay><Encoder0>0</Encoder0><Encoder1>0</Encoder1><Encoder2>0</Encoder2><Encoder3>0</Encoder3><Encoder4>0</Encoder4><Encoder5>0</Encoder5><Encoder6>0</Encoder6><M9After>0</M9After><Vel0>66.67</Vel0><Acc0>1200.</Acc0><Steps0>400.</Steps0><Vel1>50.</Vel1><Acc1>1200.</Acc1><Steps1>400.</Steps1><Vel2>46.67</Vel2><Acc2>1200.</Acc2><Steps2>400.</Steps2><GExt>*.acl</GExt><GPath>C:\Documents and Settings\CNC\My Documents\CNC G-Code\Vac Chamber seal\Seal3.acl</GPath><Slave0>3</Slave0><Slave1>0</Slave1><Slave2>3</Slave2><Vel3>50.</Vel3><Acc3>1200.</Acc3><Steps3>400.</Steps3><Vel6>20.83</Vel6><Acc6>487.</Acc6><Steps6>800.</Steps6><LockFROs>1</LockFROs><OEMDRO2_0>0.</OEMDRO2_0><OEMLED2_0>0</OEMLED2_0><OEMDRO2_1>0.</OEMDRO2_1><OEMLED2_1>0</OEMLED2_1><OEMDRO2_2>0.</OEMDRO2_2><OEMLED2_2>0</OEMLED2_2><OEMDRO2_3>0.</OEMDRO2_3><OEMLED2_3>0</OEMLED2_3><OEMDRO2_4>0.</OEMDRO2_4><OEMLED2_4>0</OEMLED2_4><OEMDRO2_5>0.</OEMDRO2_5><OEMLED2_5>0</OEMLED2_5><OEMDRO2_6>0.</OEMDRO2_6><OEMLED2_6>0</OEMLED2_6><OEMDRO2_7>0.</OEMDRO2_7><OEMLED2_7>0</OEMLED2_7><OEMDRO2_8>0.</OEMDRO2_8><OEMLED2_8>0</OEMLED2_8><OEMDRO2_9>0.</OEMDRO2_9><OEMLED2_9>0</OEMLED2_9><OEMDRO2_10>0.</OEMDRO2_10><OEMLED2_10>0</OEMLED2_10><OEMDRO2_11>0.</OEMDRO2_11><OEMLED2_11>0</OEMLED2_11><OEMDRO2_12>0.</OEMDRO2_12><OEMLED2_12>0</OEMLED2_12><OEMDRO2_13>0.</OEMDRO2_13><OEMLED2_13>0</OEMLED2_13><OEMDRO2_14>0.</OEMDRO2_14><OEMLED2_14>0</OEMLED2_14><OEMDRO2_15>0.</OEMDRO2_15><OEMLED2_15>0</OEMLED2_15><OEMDRO2_16>0.</OEMDRO2_16><OEMLED2_16>0</OEMLED2_16><OEMDRO2_17>0.</OEMDRO2_17><OEMLED2_17>0</OEMLED2_17><OEMDRO2_18>0.</OEMDRO2_18><OEMLED2_18>0</OEMLED2_18><OEMDRO2_19>0.</OEMDRO2_19><OEMLED2_19>0</OEMLED2_19><OEMDRO2_20>0.</OEMDRO2_20><OEMLED2_20>0</OEMLED2_20><OEMDRO2_21>0.</OEMDRO2_21><OEMLED2_21>0</OEMLED2_21><OEMDRO2_22>0.</OEMDRO2_22><OEMLED2_22>0</OEMLED2_22><OEMDRO2_23>0.</OEMDRO2_23><OEMLED2_23>0</OEMLED2_23><OEMDRO2_24>0.</OEMDRO2_24><OEMLED2_24>0</OEMLED2_24><OEMDRO2_25>0.</OEMDRO2_25><OEMLED2_25>0</OEMLED2_25><OEMDRO2_26>0.</OEMDRO2_26><OEMLED2_26>0</OEMLED2_26><OEMDRO2_27>0.</OEMDRO2_27><OEMLED2_27>0</OEMLED2_27><OEMDRO2_28>0.</OEMDRO2_28><OEMLED2_28>0</OEMLED2_28><OEMDRO2_29>0.</OEMDRO2_29><OEMLED2_29>0</OEMLED2_29><OEMDRO2_30>0.</OEMDRO2_30><OEMLED2_30>0</OEMLED2_30><OEMDRO2_31>0.</OEMDRO2_31><OEMLED2_31>0</OEMLED2_31><OEMDRO2_32>0.</OEMDRO2_32><OEMLED2_32>0</OEMLED2_32><OEMDRO2_33>0.</OEMDRO2_33><OEMLED2_33>0</OEMLED2_33><OEMDRO2_34>0.</OEMDRO2_34><OEMLED2_34>0</OEMLED2_34><OEMDRO2_35>0.</OEMDRO2_35><OEMLED2_35>0</OEMLED2_35><OEMDRO2_36>0.</OEMDRO2_36><OEMLED2_36>0</OEMLED2_36><OEMDRO2_37>0.</OEMDRO2_37><OEMLED2_37>0</OEMLED2_37><OEMDRO2_38>0.</OEMDRO2_38><OEMLED2_38>0</OEMLED2_38><OEMDRO2_39>0.</OEMDRO2_39><OEMLED2_39>0</OEMLED2_39><OEMDRO2_40>0.</OEMDRO2_40><OEMLED2_40>0</OEMLED2_40><OEMDRO2_41>0.</OEMDRO2_41><OEMLED2_41>0</OEMLED2_41><OEMDRO2_42>0.</OEMDRO2_42><OEMLED2_42>0</OEMLED2_42><OEMDRO2_43>0.</OEMDRO2_43><OEMLED2_43>0</OEMLED2_43><OEMDRO2_44>0.</OEMDRO2_44><OEMLED2_44>0</OEMLED2_44><OEMDRO2_45>0.</OEMDRO2_45><OEMLED2_45>0</OEMLED2_45><OEMDRO2_46>0.</OEMDRO2_46><OEMLED2_46>0</OEMLED2_46><OEMDRO2_47>0.</OEMDRO2_47><OEMLED2_47>0</OEMLED2_47><OEMDRO2_48>0.</OEMDRO2_48><OEMLED2_48>0</OEMLED2_48><OEMDRO2_49>0.</OEMDRO2_49><OEMLED2_49>0</OEMLED2_49><OEMDRO2_50>0.</OEMDRO2_50><OEMLED2_50>0</OEMLED2_50><OEMDRO2_51>0.</OEMDRO2_51><OEMLED2_51>0</OEMLED2_51><OEMDRO2_52>0.</OEMDRO2_52><OEMLED2_52>0</OEMLED2_52><OEMDRO2_53>0.</OEMDRO2_53><OEMLED2_53>0</OEMLED2_53><OEMDRO2_54>0.</OEMDRO2_54><OEMLED2_54>0</OEMLED2_54><OEMDRO2_55>0.</OEMDRO2_55><OEMLED2_55>0</OEMLED2_55><OEMDRO2_56>0.</OEMDRO2_56><OEMLED2_56>0</OEMLED2_56><OEMDRO2_57>0.</OEMDRO2_57><OEMLED2_57>0</OEMLED2_57><OEMDRO2_58>0.</OEMDRO2_58><OEMLED2_58>0</OEMLED2_58><OEMDRO2_59>0.</OEMDRO2_59><OEMLED2_59>0</OEMLED2_59><OEMDRO2_60>0.</OEMDRO2_60><OEMLED2_60>0</OEMLED2_60><OEMDRO2_61>0.</OEMDRO2_61><OEMLED2_61>0</OEMLED2_61><OEMDRO2_62>0.</OEMDRO2_62><OEMLED2_62>0</OEMLED2_62><OEMDRO2_63>0.</OEMDRO2_63><OEMLED2_63>0</OEMLED2_63><OEMDRO2_64>0.</OEMDRO2_64><OEMLED2_64>0</OEMLED2_64><OEMDRO2_65>0.</OEMDRO2_65><OEMLED2_65>0</OEMLED2_65><OEMDRO2_66>0.</OEMDRO2_66><OEMLED2_66>0</OEMLED2_66><OEMDRO2_67>0.</OEMDRO2_67><OEMLED2_67>0</OEMLED2_67><OEMDRO2_68>0.</OEMDRO2_68><OEMLED2_68>0</OEMLED2_68><OEMDRO2_69>0.</OEMDRO2_69><OEMLED2_69>0</OEMLED2_69><OEMDRO2_70>0.</OEMDRO2_70><OEMLED2_70>0</OEMLED2_70><OEMDRO2_71>0.</OEMDRO2_71><OEMLED2_71>0</OEMLED2_71><OEMDRO2_72>0.</OEMDRO2_72><OEMLED2_72>0</OEMLED2_72><OEMDRO2_73>0.</OEMDRO2_73><OEMLED2_73>0</OEMLED2_73><OEMDRO2_74>0.</OEMDRO2_74><OEMLED2_74>0</OEMLED2_74><OEMDRO2_75>0.</OEMDRO2_75><OEMLED2_75>0</OEMLED2_75><OEMDRO2_76>0.</OEMDRO2_76><OEMLED2_76>0</OEMLED2_76><OEMDRO2_77>0.</OEMDRO2_77><OEMLED2_77>0</OEMLED2_77><OEMDRO2_78>0.</OEMDRO2_78><OEMLED2_78>0</OEMLED2_78><OEMDRO2_79>0.</OEMDRO2_79><OEMLED2_79>0</OEMLED2_79><OEMDRO2_80>0.</OEMDRO2_80><OEMLED2_80>0</OEMLED2_80><OEMDRO2_81>0.</OEMDRO2_81><OEMLED2_81>0</OEMLED2_81><OEMDRO2_82>0.</OEMDRO2_82><OEMLED2_82>0</OEMLED2_82><OEMDRO2_83>0.</OEMDRO2_83><OEMLED2_83>0</OEMLED2_83><OEMDRO2_84>0.</OEMDRO2_84><OEMLED2_84>0</OEMLED2_84><OEMDRO2_85>0.</OEMDRO2_85><OEMLED2_85>0</OEMLED2_85><OEMDRO2_86>0.</OEMDRO2_86><OEMLED2_86>0</OEMLED2_86><OEMDRO2_87>0.</OEMDRO2_87><OEMLED2_87>0</OEMLED2_87><OEMDRO2_88>0.</OEMDRO2_88><OEMLED2_88>0</OEMLED2_88><OEMDRO2_89>0.</OEMDRO2_89><OEMLED2_89>0</OEMLED2_89><OEMDRO2_90>0.</OEMDRO2_90><OEMLED2_90>0</OEMLED2_90><OEMDRO2_91>0.</OEMDRO2_91><OEMLED2_91>0</OEMLED2_91><OEMDRO2_92>0.</OEMDRO2_92><OEMLED2_92>0</OEMLED2_92><OEMDRO2_93>0.</OEMDRO2_93><OEMLED2_93>0</OEMLED2_93><OEMDRO2_94>0.</OEMDRO2_94><OEMLED2_94>0</OEMLED2_94><OEMDRO2_95>0.</OEMDRO2_95><OEMLED2_95>0</OEMLED2_95><OEMDRO2_96>0.</OEMDRO2_96><OEMLED2_96>0</OEMLED2_96><OEMDRO2_97>0.</OEMDRO2_97><OEMLED2_97>0</OEMLED2_97><OEMDRO2_98>0.</OEMDRO2_98><OEMLED2_98>0</OEMLED2_98><OEMDRO2_99>0.</OEMDRO2_99><OEMLED2_99>0</OEMLED2_99><OEMDRO2_100>0.</OEMDRO2_100><OEMLED2_100>0</OEMLED2_100><OEMDRO2_101>0.</OEMDRO2_101><OEMLED2_101>0</OEMLED2_101><OEMDRO2_102>0.</OEMDRO2_102><OEMLED2_102>0</OEMLED2_102><OEMDRO2_103>0.</OEMDRO2_103><OEMLED2_103>0</OEMLED2_103><OEMDRO2_104>0.</OEMDRO2_104><OEMLED2_104>0</OEMLED2_104><OEMDRO2_105>0.</OEMDRO2_105><OEMLED2_105>0</OEMLED2_105><OEMDRO2_106>0.</OEMDRO2_106><OEMLED2_106>0</OEMLED2_106><OEMDRO2_107>0.</OEMDRO2_107><OEMLED2_107>0</OEMLED2_107><OEMDRO2_108>0.</OEMDRO2_108><OEMLED2_108>0</OEMLED2_108><OEMDRO2_109>0.</OEMDRO2_109><OEMLED2_109>0</OEMLED2_109><OEMDRO2_110>0.</OEMDRO2_110><OEMLED2_110>0</OEMLED2_110><OEMDRO2_111>0.</OEMDRO2_111><OEMLED2_111>0</OEMLED2_111><OEMDRO2_112>0.</OEMDRO2_112><OEMLED2_112>0</OEMLED2_112><OEMDRO2_113>0.</OEMDRO2_113><OEMLED2_113>0</OEMLED2_113><OEMDRO2_114>0.</OEMDRO2_114><OEMLED2_114>0</OEMLED2_114><OEMDRO2_115>0.</OEMDRO2_115><OEMLED2_115>0</OEMLED2_115><OEMDRO2_116>0.</OEMDRO2_116><OEMLED2_116>0</OEMLED2_116><OEMDRO2_117>0.</OEMDRO2_117><OEMLED2_117>0</OEMLED2_117><OEMDRO2_118>0.</OEMDRO2_118><OEMLED2_118>0</OEMLED2_118><OEMDRO2_119>0.</OEMDRO2_119><OEMLED2_119>0</OEMLED2_119><OEMDRO2_120>0.</OEMDRO2_120><OEMLED2_120>0</OEMLED2_120><OEMDRO2_121>0.</OEMDRO2_121><OEMLED2_121>0</OEMLED2_121><OEMDRO2_122>0.</OEMDRO2_122><OEMLED2_122>0</OEMLED2_122><OEMDRO2_123>0.</OEMDRO2_123><OEMLED2_123>0</OEMLED2_123><OEMDRO2_124>0.</OEMDRO2_124><OEMLED2_124>0</OEMLED2_124><OEMDRO2_125>0.</OEMDRO2_125><OEMLED2_125>0</OEMLED2_125><OEMDRO2_126>0.</OEMDRO2_126><OEMLED2_126>0</OEMLED2_126><OEMDRO2_127>0.</OEMDRO2_127><OEMLED2_127>0</OEMLED2_127><OEMDRO2_128>0.</OEMDRO2_128><OEMLED2_128>0</OEMLED2_128><OEMDRO2_129>0.</OEMDRO2_129><OEMLED2_129>0</OEMLED2_129><OEMDRO2_130>0.</OEMDRO2_130><OEMLED2_130>0</OEMLED2_130><OEMDRO2_131>0.</OEMDRO2_131><OEMLED2_131>0</OEMLED2_131><OEMDRO2_132>0.</OEMDRO2_132><OEMLED2_132>0</OEMLED2_132><OEMDRO2_133>0.</OEMDRO2_133><OEMLED2_133>0</OEMLED2_133><OEMDRO2_134>0.</OEMDRO2_134><OEMLED2_134>0</OEMLED2_134><OEMDRO2_135>0.</OEMDRO2_135><OEMLED2_135>0</OEMLED2_135><OEMDRO2_136>0.</OEMDRO2_136><OEMLED2_136>0</OEMLED2_136><OEMDRO2_137>0.</OEMDRO2_137><OEMLED2_137>0</OEMLED2_137><OEMDRO2_138>0.</OEMDRO2_138><OEMLED2_138>0</OEMLED2_138><OEMDRO2_139>0.</OEMDRO2_139><OEMLED2_139>0</OEMLED2_139><OEMDRO2_140>0.</OEMDRO2_140><OEMLED2_140>0</OEMLED2_140><OEMDRO2_141>0.</OEMDRO2_141><OEMLED2_141>0</OEMLED2_141><OEMDRO2_142>0.</OEMDRO2_142><OEMLED2_142>0</OEMLED2_142><OEMDRO2_143>0.</OEMDRO2_143><OEMLED2_143>0</OEMLED2_143><OEMDRO2_144>0.</OEMDRO2_144><OEMLED2_144>0</OEMLED2_144><OEMDRO2_145>0.</OEMDRO2_145><OEMLED2_145>0</OEMLED2_145><OEMDRO2_146>0.</OEMDRO2_146><OEMLED2_146>0</OEMLED2_146><OEMDRO2_147>0.</OEMDRO2_147><OEMLED2_147>0</OEMLED2_147><OEMDRO2_148>0.</OEMDRO2_148><OEMLED2_148>0</OEMLED2_148><OEMDRO2_149>0.</OEMDRO2_149><OEMLED2_149>0</OEMLED2_149><OEMDRO2_150>0.</OEMDRO2_150><OEMLED2_150>0</OEMLED2_150><OEMDRO2_151>0.</OEMDRO2_151><OEMLED2_151>0</OEMLED2_151><OEMDRO2_152>0.</OEMDRO2_152><OEMLED2_152>0</OEMLED2_152><OEMDRO2_153>0.</OEMDRO2_153><OEMLED2_153>0</OEMLED2_153><OEMDRO2_154>0.</OEMDRO2_154><OEMLED2_154>0</OEMLED2_154><OEMDRO2_155>0.</OEMDRO2_155><OEMLED2_155>0</OEMLED2_155><OEMDRO2_156>0.</OEMDRO2_156><OEMLED2_156>0</OEMLED2_156><OEMDRO2_157>0.</OEMDRO2_157><OEMLED2_157>0</OEMLED2_157><OEMDRO2_158>0.</OEMDRO2_158><OEMLED2_158>0</OEMLED2_158><OEMDRO2_159>0.</OEMDRO2_159><OEMLED2_159>0</OEMLED2_159><OEMDRO2_160>0.</OEMDRO2_160><OEMLED2_160>0</OEMLED2_160><OEMDRO2_161>0.</OEMDRO2_161><OEMLED2_161>0</OEMLED2_161><OEMDRO2_162>0.</OEMDRO2_162><OEMLED2_162>0</OEMLED2_162><OEMDRO2_163>0.</OEMDRO2_163><OEMLED2_163>0</OEMLED2_163><OEMDRO2_164>0.</OEMDRO2_164><OEMLED2_164>0</OEMLED2_164><OEMDRO2_165>0.</OEMDRO2_165><OEMLED2_165>0</OEMLED2_165><OEMDRO2_166>0.</OEMDRO2_166><OEMLED2_166>0</OEMLED2_166><OEMDRO2_167>0.</OEMDRO2_167><OEMLED2_167>0</OEMLED2_167><OEMDRO2_168>0.</OEMDRO2_168><OEMLED2_168>0</OEMLED2_168><OEMDRO2_169>0.</OEMDRO2_169><OEMLED2_169>0</OEMLED2_169><OEMDRO2_170>0.</OEMDRO2_170><OEMLED2_170>0</OEMLED2_170><OEMDRO2_171>0.</OEMDRO2_171><OEMLED2_171>0</OEMLED2_171><OEMDRO2_172>0.</OEMDRO2_172><OEMLED2_172>0</OEMLED2_172><OEMDRO2_173>0.</OEMDRO2_173><OEMLED2_173>0</OEMLED2_173><OEMDRO2_174>0.</OEMDRO2_174><OEMLED2_174>0</OEMLED2_174><OEMDRO2_175>0.</OEMDRO2_175><OEMLED2_175>0</OEMLED2_175><OEMDRO2_176>0.</OEMDRO2_176><OEMLED2_176>0</OEMLED2_176><OEMDRO2_177>0.</OEMDRO2_177><OEMLED2_177>0</OEMLED2_177><OEMDRO2_178>0.</OEMDRO2_178><OEMLED2_178>0</OEMLED2_178><OEMDRO2_179>0.</OEMDRO2_179><OEMLED2_179>0</OEMLED2_179><OEMDRO2_180>0.</OEMDRO2_180><OEMLED2_180>0</OEMLED2_180><OEMDRO2_181>0.</OEMDRO2_181><OEMLED2_181>0</OEMLED2_181><OEMDRO2_182>0.</OEMDRO2_182><OEMLED2_182>0</OEMLED2_182><OEMDRO2_183>0.</OEMDRO2_183><OEMLED2_183>0</OEMLED2_183><OEMDRO2_184>0.</OEMDRO2_184><OEMLED2_184>0</OEMLED2_184><OEMDRO2_185>0.</OEMDRO2_185><OEMLED2_185>0</OEMLED2_185><OEMDRO2_186>0.</OEMDRO2_186><OEMLED2_186>0</OEMLED2_186><OEMDRO2_187>0.</OEMDRO2_187><OEMLED2_187>0</OEMLED2_187><OEMDRO2_188>0.</OEMDRO2_188><OEMLED2_188>0</OEMLED2_188><OEMDRO2_189>0.</OEMDRO2_189><OEMLED2_189>0</OEMLED2_189><OEMDRO2_190>0.</OEMDRO2_190><OEMLED2_190>0</OEMLED2_190><OEMDRO2_191>0.</OEMDRO2_191><OEMLED2_191>0</OEMLED2_191><OEMDRO2_192>0.</OEMDRO2_192><OEMLED2_192>0</OEMLED2_192><OEMDRO2_193>0.</OEMDRO2_193><OEMLED2_193>0</OEMLED2_193><OEMDRO2_194>0.</OEMDRO2_194><OEMLED2_194>0</OEMLED2_194><OEMDRO2_195>0.</OEMDRO2_195><OEMLED2_195>0</OEMLED2_195><OEMDRO2_196>0.</OEMDRO2_196><OEMLED2_196>0</OEMLED2_196><OEMDRO2_197>0.</OEMDRO2_197><OEMLED2_197>0</OEMLED2_197><OEMDRO2_198>0.</OEMDRO2_198><OEMLED2_198>0</OEMLED2_198><OEMDRO2_199>0.</OEMDRO2_199><OEMLED2_199>0</OEMLED2_199><OEMDRO2_200>0.</OEMDRO2_200><OEMLED2_200>0</OEMLED2_200><OEMDRO2_201>0.</OEMDRO2_201><OEMLED2_201>0</OEMLED2_201><OEMDRO2_202>0.</OEMDRO2_202><OEMLED2_202>0</OEMLED2_202><OEMDRO2_203>0.</OEMDRO2_203><OEMLED2_203>0</OEMLED2_203><OEMDRO2_204>0.</OEMDRO2_204><OEMLED2_204>0</OEMLED2_204><OEMDRO2_205>0.</OEMDRO2_205><OEMLED2_205>0</OEMLED2_205><OEMDRO2_206>0.</OEMDRO2_206><OEMLED2_206>0</OEMLED2_206><OEMDRO2_207>0.</OEMDRO2_207><OEMLED2_207>0</OEMLED2_207><OEMDRO2_208>0.</OEMDRO2_208><OEMLED2_208>0</OEMLED2_208><OEMDRO2_209>0.</OEMDRO2_209><OEMLED2_209>0</OEMLED2_209><OEMDRO2_210>0.</OEMDRO2_210><OEMLED2_210>0</OEMLED2_210><OEMDRO2_211>0.</OEMDRO2_211><OEMLED2_211>0</OEMLED2_211><OEMDRO2_212>0.</OEMDRO2_212><OEMLED2_212>0</OEMLED2_212><OEMDRO2_213>0.</OEMDRO2_213><OEMLED2_213>0</OEMLED2_213><OEMDRO2_214>0.</OEMDRO2_214><OEMLED2_214>0</OEMLED2_214><OEMDRO2_215>0.</OEMDRO2_215><OEMLED2_215>0</OEMLED2_215><OEMDRO2_216>0.</OEMDRO2_216><OEMLED2_216>0</OEMLED2_216><OEMDRO2_217>0.</OEMDRO2_217><OEMLED2_217>0</OEMLED2_217><OEMDRO2_218>0.</OEMDRO2_218><OEMLED2_218>0</OEMLED2_218><OEMDRO2_219>0.</OEMDRO2_219><OEMLED2_219>0</OEMLED2_219><OEMDRO2_220>0.</OEMDRO2_220><OEMLED2_220>0</OEMLED2_220><OEMDRO2_221>0.</OEMDRO2_221><OEMLED2_221>0</OEMLED2_221><OEMDRO2_222>0.</OEMDRO2_222><OEMLED2_222>0</OEMLED2_222><OEMDRO2_223>0.</OEMDRO2_223><OEMLED2_223>0</OEMLED2_223><OEMDRO2_224>0.</OEMDRO2_224><OEMLED2_224>0</OEMLED2_224><OEMDRO2_225>0.</OEMDRO2_225><OEMLED2_225>0</OEMLED2_225><OEMDRO2_226>0.</OEMDRO2_226><OEMLED2_226>0</OEMLED2_226><OEMDRO2_227>0.</OEMDRO2_227><OEMLED2_227>0</OEMLED2_227><OEMDRO2_228>0.</OEMDRO2_228><OEMLED2_228>0</OEMLED2_228><OEMDRO2_229>0.</OEMDRO2_229><OEMLED2_229>0</OEMLED2_229><OEMDRO2_230>0.</OEMDRO2_230><OEMLED2_230>0</OEMLED2_230><OEMDRO2_231>0.</OEMDRO2_231><OEMLED2_231>0</OEMLED2_231><OEMDRO2_232>0.</OEMDRO2_232><OEMLED2_232>0</OEMLED2_232><OEMDRO2_233>0.</OEMDRO2_233><OEMLED2_233>0</OEMLED2_233><OEMDRO2_234>0.</OEMDRO2_234><OEMLED2_234>0</OEMLED2_234><OEMDRO2_235>0.</OEMDRO2_235><OEMLED2_235>0</OEMLED2_235><OEMDRO2_236>0.</OEMDRO2_236><OEMLED2_236>0</OEMLED2_236><OEMDRO2_237>0.</OEMDRO2_237><OEMLED2_237>0</OEMLED2_237><OEMDRO2_238>0.</OEMDRO2_238><OEMLED2_238>0</OEMLED2_238><OEMDRO2_239>0.</OEMDRO2_239><OEMLED2_239>0</OEMLED2_239><OEMDRO2_240>0.</OEMDRO2_240><OEMLED2_240>0</OEMLED2_240><OEMDRO2_241>0.</OEMDRO2_241><OEMLED2_241>0</OEMLED2_241><OEMDRO2_242>0.</OEMDRO2_242><OEMLED2_242>0</OEMLED2_242><OEMDRO2_243>0.</OEMDRO2_243><OEMLED2_243>0</OEMLED2_243><OEMDRO2_244>0.</OEMDRO2_244><OEMLED2_244>0</OEMLED2_244><OEMDRO2_245>0.</OEMDRO2_245><OEMLED2_245>0</OEMLED2_245><OEMDRO2_246>0.</OEMDRO2_246><OEMLED2_246>0</OEMLED2_246><OEMDRO2_247>0.</OEMDRO2_247><OEMLED2_247>0</OEMLED2_247><OEMDRO2_248>0.</OEMDRO2_248><OEMLED2_248>0</OEMLED2_248><OEMDRO2_249>0.</OEMDRO2_249><OEMLED2_249>0</OEMLED2_249><OEMDRO2_250>0.</OEMDRO2_250><OEMLED2_250>0</OEMLED2_250><OEMDRO2_251>0.</OEMDRO2_251><OEMLED2_251>0</OEMLED2_251><OEMDRO2_252>0.</OEMDRO2_252><OEMLED2_252>0</OEMLED2_252><OEMDRO2_253>0.</OEMDRO2_253><OEMLED2_253>0</OEMLED2_253><OEMDRO2_254>0.</OEMDRO2_254><OEMLED2_254>0</OEMLED2_254><OEMDRO2_255>0.</OEMDRO2_255><OEMLED2_255>0</OEMLED2_255><OEMDRO2_256>0.</OEMDRO2_256><OEMLED2_256>0</OEMLED2_256><OEMDRO2_257>0.</OEMDRO2_257><OEMLED2_257>0</OEMLED2_257><OEMDRO2_258>0.</OEMDRO2_258><OEMLED2_258>0</OEMLED2_258><OEMDRO2_259>0.</OEMDRO2_259><OEMLED2_259>0</OEMLED2_259><OEMDRO2_260>0.</OEMDRO2_260><OEMLED2_260>0</OEMLED2_260><OEMDRO2_261>0.</OEMDRO2_261><OEMLED2_261>0</OEMLED2_261><OEMDRO2_262>0.</OEMDRO2_262><OEMLED2_262>0</OEMLED2_262><OEMDRO2_263>0.</OEMDRO2_263><OEMLED2_263>0</OEMLED2_263><OEMDRO2_264>0.</OEMDRO2_264><OEMLED2_264>0</OEMLED2_264><OEMDRO2_265>0.</OEMDRO2_265><OEMLED2_265>0</OEMLED2_265><OEMDRO2_266>0.</OEMDRO2_266><OEMLED2_266>0</OEMLED2_266><OEMDRO2_267>0.</OEMDRO2_267><OEMLED2_267>0</OEMLED2_267><OEMDRO2_268>0.</OEMDRO2_268><OEMLED2_268>0</OEMLED2_268><OEMDRO2_269>0.</OEMDRO2_269><OEMLED2_269>0</OEMLED2_269><OEMDRO2_270>0.</OEMDRO2_270><OEMLED2_270>0</OEMLED2_270><OEMDRO2_271>0.</OEMDRO2_271><OEMLED2_271>0</OEMLED2_271><OEMDRO2_272>0.</OEMDRO2_272><OEMLED2_272>0</OEMLED2_272><OEMDRO2_273>0.</OEMDRO2_273><OEMLED2_273>0</OEMLED2_273><OEMDRO2_274>0.</OEMDRO2_274><OEMLED2_274>0</OEMLED2_274><OEMDRO2_275>0.</OEMDRO2_275><OEMLED2_275>0</OEMLED2_275><OEMDRO2_276>0.</OEMDRO2_276><OEMLED2_276>0</OEMLED2_276><OEMDRO2_277>0.</OEMDRO2_277><OEMLED2_277>0</OEMLED2_277><OEMDRO2_278>0.</OEMDRO2_278><OEMLED2_278>0</OEMLED2_278><OEMDRO2_279>0.</OEMDRO2_279><OEMLED2_279>0</OEMLED2_279><OEMDRO2_280>0.</OEMDRO2_280><OEMLED2_280>0</OEMLED2_280><OEMDRO2_281>0.</OEMDRO2_281><OEMLED2_281>0</OEMLED2_281><OEMDRO2_282>0.</OEMDRO2_282><OEMLED2_282>0</OEMLED2_282><OEMDRO2_283>0.</OEMDRO2_283><OEMLED2_283>0</OEMLED2_283><OEMDRO2_284>0.</OEMDRO2_284><OEMLED2_284>0</OEMLED2_284><OEMDRO2_285>0.</OEMDRO2_285><OEMLED2_285>0</OEMLED2_285><OEMDRO2_286>0.</OEMDRO2_286><OEMLED2_286>0</OEMLED2_286><OEMDRO2_287>0.</OEMDRO2_287><OEMLED2_287>0</OEMLED2_287><OEMDRO2_288>0.</OEMDRO2_288><OEMLED2_288>0</OEMLED2_288><OEMDRO2_289>0.</OEMDRO2_289><OEMLED2_289>0</OEMLED2_289><OEMDRO2_290>0.</OEMDRO2_290><OEMLED2_290>0</OEMLED2_290><OEMDRO2_291>0.</OEMDRO2_291><OEMLED2_291>0</OEMLED2_291><OEMDRO2_292>0.</OEMDRO2_292><OEMLED2_292>0</OEMLED2_292><OEMDRO2_293>0.</OEMDRO2_293><OEMLED2_293>0</OEMLED2_293><OEMDRO2_294>0.</OEMDRO2_294><OEMLED2_294>0</OEMLED2_294><OEMDRO2_295>0.</OEMDRO2_295><OEMLED2_295>0</OEMLED2_295><OEMDRO2_296>0.</OEMDRO2_296><OEMLED2_296>0</OEMLED2_296><OEMDRO2_297>0.</OEMDRO2_297><OEMLED2_297>0</OEMLED2_297><OEMDRO2_298>0.</OEMDRO2_298><OEMLED2_298>0</OEMLED2_298><OEMDRO2_299>0.</OEMDRO2_299><OEMLED2_299>0</OEMLED2_299><OEMDRO2_300>0.</OEMDRO2_300><OEMLED2_300>0</OEMLED2_300><OEMDRO2_301>0.</OEMDRO2_301><OEMLED2_301>0</OEMLED2_301><OEMDRO2_302>0.</OEMDRO2_302><OEMLED2_302>0</OEMLED2_302><OEMDRO2_303>0.</OEMDRO2_303><OEMLED2_303>0</OEMLED2_303><OEMDRO2_304>0.</OEMDRO2_304><OEMLED2_304>0</OEMLED2_304><OEMDRO2_305>0.</OEMDRO2_305><OEMLED2_305>0</OEMLED2_305><OEMDRO2_306>0.</OEMDRO2_306><OEMLED2_306>0</OEMLED2_306><OEMDRO2_307>0.</OEMDRO2_307><OEMLED2_307>0</OEMLED2_307><OEMDRO2_308>0.</OEMDRO2_308><OEMLED2_308>0</OEMLED2_308><OEMDRO2_309>0.</OEMDRO2_309><OEMLED2_309>0</OEMLED2_309><OEMDRO2_310>0.</OEMDRO2_310><OEMLED2_310>0</OEMLED2_310><OEMDRO2_311>0.</OEMDRO2_311><OEMLED2_311>0</OEMLED2_311><OEMDRO2_312>0.</OEMDRO2_312><OEMLED2_312>0</OEMLED2_312><OEMDRO2_313>0.</OEMDRO2_313><OEMLED2_313>0</OEMLED2_313><OEMDRO2_314>0.</OEMDRO2_314><OEMLED2_314>0</OEMLED2_314><OEMDRO2_315>0.</OEMDRO2_315><OEMLED2_315>0</OEMLED2_315><OEMDRO2_316>0.</OEMDRO2_316><OEMLED2_316>0</OEMLED2_316><OEMDRO2_317>0.</OEMDRO2_317><OEMLED2_317>0</OEMLED2_317><OEMDRO2_318>0.</OEMDRO2_318><OEMLED2_318>0</OEMLED2_318><OEMDRO2_319>0.</OEMDRO2_319><OEMLED2_319>0</OEMLED2_319><OEMDRO2_320>0.</OEMDRO2_320><OEMLED2_320>0</OEMLED2_320><OEMDRO2_321>0.</OEMDRO2_321><OEMLED2_321>0</OEMLED2_321><OEMDRO2_322>0.</OEMDRO2_322><OEMLED2_322>0</OEMLED2_322><OEMDRO2_323>0.</OEMDRO2_323><OEMLED2_323>0</OEMLED2_323><OEMDRO2_324>0.</OEMDRO2_324><OEMLED2_324>0</OEMLED2_324><OEMDRO2_325>0.</OEMDRO2_325><OEMLED2_325>0</OEMLED2_325><OEMDRO2_326>0.</OEMDRO2_326><OEMLED2_326>0</OEMLED2_326><OEMDRO2_327>0.</OEMDRO2_327><OEMLED2_327>0</OEMLED2_327><OEMDRO2_328>0.</OEMDRO2_328><OEMLED2_328>0</OEMLED2_328><OEMDRO2_329>0.</OEMDRO2_329><OEMLED2_329>0</OEMLED2_329><OEMDRO2_330>0.</OEMDRO2_330><OEMLED2_330>0</OEMLED2_330><OEMDRO2_331>0.</OEMDRO2_331><OEMLED2_331>0</OEMLED2_331><OEMDRO2_332>0.</OEMDRO2_332><OEMLED2_332>0</OEMLED2_332><OEMDRO2_333>0.</OEMDRO2_333><OEMLED2_333>0</OEMLED2_333><OEMDRO2_334>0.</OEMDRO2_334><OEMLED2_334>0</OEMLED2_334><OEMDRO2_335>0.</OEMDRO2_335><OEMLED2_335>0</OEMLED2_335><OEMDRO2_336>0.</OEMDRO2_336><OEMLED2_336>0</OEMLED2_336><OEMDRO2_337>0.</OEMDRO2_337><OEMLED2_337>0</OEMLED2_337><OEMDRO2_338>0.</OEMDRO2_338><OEMLED2_338>0</OEMLED2_338><OEMDRO2_339>0.</OEMDRO2_339><OEMLED2_339>0</OEMLED2_339><OEMDRO2_340>0.</OEMDRO2_340><OEMLED2_340>0</OEMLED2_340><OEMDRO2_341>0.</OEMDRO2_341><OEMLED2_341>0</OEMLED2_341><OEMDRO2_342>0.</OEMDRO2_342><OEMLED2_342>0</OEMLED2_342><OEMDRO2_343>0.</OEMDRO2_343><OEMLED2_343>0</OEMLED2_343><OEMDRO2_344>0.</OEMDRO2_344><OEMLED2_344>0</OEMLED2_344><OEMDRO2_345>0.</OEMDRO2_345><OEMLED2_345>0</OEMLED2_345><OEMDRO2_346>0.</OEMDRO2_346><OEMLED2_346>0</OEMLED2_346><OEMDRO2_347>0.</OEMDRO2_347><OEMLED2_347>0</OEMLED2_347><OEMDRO2_348>0.</OEMDRO2_348><OEMLED2_348>0</OEMLED2_348><OEMDRO2_349>0.</OEMDRO2_349><OEMLED2_349>0</OEMLED2_349><OEMDRO2_350>0.</OEMDRO2_350><OEMLED2_350>0</OEMLED2_350><OEMDRO2_351>0.</OEMDRO2_351><OEMLED2_351>0</OEMLED2_351><OEMDRO2_352>0.</OEMDRO2_352><OEMLED2_352>0</OEMLED2_352><OEMDRO2_353>0.</OEMDRO2_353><OEMLED2_353>0</OEMLED2_353><OEMDRO2_354>0.</OEMDRO2_354><OEMLED2_354>0</OEMLED2_354><OEMDRO2_355>0.</OEMDRO2_355><OEMLED2_355>0</OEMLED2_355><OEMDRO2_356>0.</OEMDRO2_356><OEMLED2_356>0</OEMLED2_356><OEMDRO2_357>0.</OEMDRO2_357><OEMLED2_357>0</OEMLED2_357><OEMDRO2_358>0.</OEMDRO2_358><OEMLED2_358>0</OEMLED2_358><OEMDRO2_359>0.</OEMDRO2_359><OEMLED2_359>0</OEMLED2_359><OEMDRO2_360>0.</OEMDRO2_360><OEMLED2_360>0</OEMLED2_360><OEMDRO2_361>0.</OEMDRO2_361><OEMLED2_361>0</OEMLED2_361><OEMDRO2_362>0.</OEMDRO2_362><OEMLED2_362>0</OEMLED2_362><OEMDRO2_363>0.</OEMDRO2_363><OEMLED2_363>0</OEMLED2_363><OEMDRO2_364>0.</OEMDRO2_364><OEMLED2_364>0</OEMLED2_364><OEMDRO2_365>0.</OEMDRO2_365><OEMLED2_365>0</OEMLED2_365><OEMDRO2_366>0.</OEMDRO2_366><OEMLED2_366>0</OEMLED2_366><OEMDRO2_367>0.</OEMDRO2_367><OEMLED2_367>0</OEMLED2_367><OEMDRO2_368>0.</OEMDRO2_368><OEMLED2_368>0</OEMLED2_368><OEMDRO2_369>0.</OEMDRO2_369><OEMLED2_369>0</OEMLED2_369><OEMDRO2_370>0.</OEMDRO2_370><OEMLED2_370>0</OEMLED2_370><OEMDRO2_371>0.</OEMDRO2_371><OEMLED2_371>0</OEMLED2_371><OEMDRO2_372>0.</OEMDRO2_372><OEMLED2_372>0</OEMLED2_372><OEMDRO2_373>0.</OEMDRO2_373><OEMLED2_373>0</OEMLED2_373><OEMDRO2_374>0.</OEMDRO2_374><OEMLED2_374>0</OEMLED2_374><OEMDRO2_375>0.</OEMDRO2_375><OEMLED2_375>0</OEMLED2_375><OEMDRO2_376>0.</OEMDRO2_376><OEMLED2_376>0</OEMLED2_376><OEMDRO2_377>0.</OEMDRO2_377><OEMLED2_377>0</OEMLED2_377><OEMDRO2_378>0.</OEMDRO2_378><OEMLED2_378>0</OEMLED2_378><OEMDRO2_379>0.</OEMDRO2_379><OEMLED2_379>0</OEMLED2_379><OEMDRO2_380>0.</OEMDRO2_380><OEMLED2_380>0</OEMLED2_380><OEMDRO2_381>0.</OEMDRO2_381><OEMLED2_381>0</OEMLED2_381><OEMDRO2_382>0.</OEMDRO2_382><OEMLED2_382>0</OEMLED2_382><OEMDRO2_383>0.</OEMDRO2_383><OEMLED2_383>0</OEMLED2_383><OEMDRO2_384>0.</OEMDRO2_384><OEMLED2_384>0</OEMLED2_384><OEMDRO2_385>0.</OEMDRO2_385><OEMLED2_385>0</OEMLED2_385><OEMDRO2_386>0.</OEMDRO2_386><OEMLED2_386>0</OEMLED2_386><OEMDRO2_387>0.</OEMDRO2_387><OEMLED2_387>0</OEMLED2_387><OEMDRO2_388>0.</OEMDRO2_388><OEMLED2_388>0</OEMLED2_388><OEMDRO2_389>0.</OEMDRO2_389><OEMLED2_389>0</OEMLED2_389><OEMDRO2_390>0.</OEMDRO2_390><OEMLED2_390>0</OEMLED2_390><OEMDRO2_391>0.</OEMDRO2_391><OEMLED2_391>0</OEMLED2_391><OEMDRO2_392>0.</OEMDRO2_392><OEMLED2_392>0</OEMLED2_392><OEMDRO2_393>0.</OEMDRO2_393><OEMLED2_393>0</OEMLED2_393><OEMDRO2_394>0.</OEMDRO2_394><OEMLED2_394>0</OEMLED2_394><OEMDRO2_395>0.</OEMDRO2_395><OEMLED2_395>0</OEMLED2_395><OEMDRO2_396>0.</OEMDRO2_396><OEMLED2_396>0</OEMLED2_396><OEMDRO2_397>0.</OEMDRO2_397><OEMLED2_397>0</OEMLED2_397><OEMDRO2_398>0.</OEMDRO2_398><OEMLED2_398>0</OEMLED2_398><OEMDRO2_399>0.</OEMDRO2_399><OEMLED2_399>0</OEMLED2_399><OEMDRO2_400>0.</OEMDRO2_400><OEMLED2_400>0</OEMLED2_400><OEMDRO2_401>0.</OEMDRO2_401><OEMLED2_401>0</OEMLED2_401><OEMDRO2_402>0.</OEMDRO2_402><OEMLED2_402>0</OEMLED2_402><OEMDRO2_403>0.</OEMDRO2_403><OEMLED2_403>0</OEMLED2_403><OEMDRO2_404>0.</OEMDRO2_404><OEMLED2_404>0</OEMLED2_404><OEMDRO2_405>0.</OEMDRO2_405><OEMLED2_405>0</OEMLED2_405><OEMDRO2_406>0.</OEMDRO2_406><OEMLED2_406>0</OEMLED2_406><OEMDRO2_407>0.</OEMDRO2_407><OEMLED2_407>0</OEMLED2_407><OEMDRO2_408>0.</OEMDRO2_408><OEMLED2_408>0</OEMLED2_408><OEMDRO2_409>0.</OEMDRO2_409><OEMLED2_409>0</OEMLED2_409><OEMDRO2_410>0.</OEMDRO2_410><OEMLED2_410>0</OEMLED2_410><OEMDRO2_411>0.</OEMDRO2_411><OEMLED2_411>0</OEMLED2_411><OEMDRO2_412>0.</OEMDRO2_412><OEMLED2_412>0</OEMLED2_412><OEMDRO2_413>0.</OEMDRO2_413><OEMLED2_413>0</OEMLED2_413><OEMDRO2_414>0.</OEMDRO2_414><OEMLED2_414>0</OEMLED2_414><OEMDRO2_415>0.</OEMDRO2_415><OEMLED2_415>0</OEMLED2_415><OEMDRO2_416>0.</OEMDRO2_416><OEMLED2_416>0</OEMLED2_416><OEMDRO2_417>0.</OEMDRO2_417><OEMLED2_417>0</OEMLED2_417><OEMDRO2_418>0.</OEMDRO2_418><OEMLED2_418>0</OEMLED2_418><OEMDRO2_419>0.</OEMDRO2_419><OEMLED2_419>0</OEMLED2_419><OEMDRO2_420>0.</OEMDRO2_420><OEMLED2_420>0</OEMLED2_420><OEMDRO2_421>0.</OEMDRO2_421><OEMLED2_421>0</OEMLED2_421><OEMDRO2_422>0.</OEMDRO2_422><OEMLED2_422>0</OEMLED2_422><OEMDRO2_423>0.</OEMDRO2_423><OEMLED2_423>0</OEMLED2_423><OEMDRO2_424>0.</OEMDRO2_424><OEMLED2_424>0</OEMLED2_424><OEMDRO2_425>0.</OEMDRO2_425><OEMLED2_425>0</OEMLED2_425><OEMDRO2_426>0.</OEMDRO2_426><OEMLED2_426>0</OEMLED2_426><OEMDRO2_427>0.</OEMDRO2_427><OEMLED2_427>0</OEMLED2_427><OEMDRO2_428>0.</OEMDRO2_428><OEMLED2_428>0</OEMLED2_428><OEMDRO2_429>0.</OEMDRO2_429><OEMLED2_429>0</OEMLED2_429><OEMDRO2_430>0.</OEMDRO2_430><OEMLED2_430>0</OEMLED2_430><OEMDRO2_431>0.</OEMDRO2_431><OEMLED2_431>0</OEMLED2_431><OEMDRO2_432>0.</OEMDRO2_432><OEMLED2_432>0</OEMLED2_432><OEMDRO2_433>0.</OEMDRO2_433><OEMLED2_433>0</OEMLED2_433><OEMDRO2_434>0.</OEMDRO2_434><OEMLED2_434>0</OEMLED2_434><OEMDRO2_435>0.</OEMDRO2_435><OEMLED2_435>0</OEMLED2_435><OEMDRO2_436>0.</OEMDRO2_436><OEMLED2_436>0</OEMLED2_436><OEMDRO2_437>0.</OEMDRO2_437><OEMLED2_437>0</OEMLED2_437><OEMDRO2_438>0.</OEMDRO2_438><OEMLED2_438>0</OEMLED2_438><OEMDRO2_439>0.</OEMDRO2_439><OEMLED2_439>0</OEMLED2_439><OEMDRO2_440>0.</OEMDRO2_440><OEMLED2_440>0</OEMLED2_440><OEMDRO2_441>0.</OEMDRO2_441><OEMLED2_441>0</OEMLED2_441><OEMDRO2_442>0.</OEMDRO2_442><OEMLED2_442>0</OEMLED2_442><OEMDRO2_443>0.</OEMDRO2_443><OEMLED2_443>0</OEMLED2_443><OEMDRO2_444>0.</OEMDRO2_444><OEMLED2_444>0</OEMLED2_444><OEMDRO2_445>0.</OEMDRO2_445><OEMLED2_445>0</OEMLED2_445><OEMDRO2_446>0.</OEMDRO2_446><OEMLED2_446>0</OEMLED2_446><OEMDRO2_447>0.</OEMDRO2_447><OEMLED2_447>0</OEMLED2_447><OEMDRO2_448>0.</OEMDRO2_448><OEMLED2_448>0</OEMLED2_448><OEMDRO2_449>0.</OEMDRO2_449><OEMLED2_449>0</OEMLED2_449><OEMDRO2_450>0.</OEMDRO2_450><OEMLED2_450>0</OEMLED2_450><OEMDRO2_451>0.</OEMDRO2_451><OEMLED2_451>0</OEMLED2_451><OEMDRO2_452>0.</OEMDRO2_452><OEMLED2_452>0</OEMLED2_452><OEMDRO2_453>0.</OEMDRO2_453><OEMLED2_453>0</OEMLED2_453><OEMDRO2_454>0.</OEMDRO2_454><OEMLED2_454>0</OEMLED2_454><OEMDRO2_455>0.</OEMDRO2_455><OEMLED2_455>0</OEMLED2_455><OEMDRO2_456>0.</OEMDRO2_456><OEMLED2_456>0</OEMLED2_456><OEMDRO2_457>0.</OEMDRO2_457><OEMLED2_457>0</OEMLED2_457><OEMDRO2_458>0.</OEMDRO2_458><OEMLED2_458>0</OEMLED2_458><OEMDRO2_459>0.</OEMDRO2_459><OEMLED2_459>0</OEMLED2_459><OEMDRO2_460>0.</OEMDRO2_460><OEMLED2_460>0</OEMLED2_460><OEMDRO2_461>0.</OEMDRO2_461><OEMLED2_461>0</OEMLED2_461><OEMDRO2_462>0.</OEMDRO2_462><OEMLED2_462>0</OEMLED2_462><OEMDRO2_463>0.</OEMDRO2_463><OEMLED2_463>0</OEMLED2_463><OEMDRO2_464>0.</OEMDRO2_464><OEMLED2_464>0</OEMLED2_464><OEMDRO2_465>0.</OEMDRO2_465><OEMLED2_465>0</OEMLED2_465><OEMDRO2_466>0.</OEMDRO2_466><OEMLED2_466>0</OEMLED2_466><OEMDRO2_467>0.</OEMDRO2_467><OEMLED2_467>0</OEMLED2_467><OEMDRO2_468>0.</OEMDRO2_468><OEMLED2_468>0</OEMLED2_468><OEMDRO2_469>0.</OEMDRO2_469><OEMLED2_469>0</OEMLED2_469><OEMDRO2_470>0.</OEMDRO2_470><OEMLED2_470>0</OEMLED2_470><OEMDRO2_471>0.</OEMDRO2_471><OEMLED2_471>0</OEMLED2_471><OEMDRO2_472>0.</OEMDRO2_472><OEMLED2_472>0</OEMLED2_472><OEMDRO2_473>0.</OEMDRO2_473><OEMLED2_473>0</OEMLED2_473><OEMDRO2_474>0.</OEMDRO2_474><OEMLED2_474>0</OEMLED2_474><OEMDRO2_475>0.</OEMDRO2_475><OEMLED2_475>0</OEMLED2_475><OEMDRO2_476>0.</OEMDRO2_476><OEMLED2_476>0</OEMLED2_476><OEMDRO2_477>0.</OEMDRO2_477><OEMLED2_477>0</OEMLED2_477><OEMDRO2_478>0.</OEMDRO2_478><OEMLED2_478>0</OEMLED2_478><OEMDRO2_479>0.</OEMDRO2_479><OEMLED2_479>0</OEMLED2_479><OEMDRO2_480>0.</OEMDRO2_480><OEMLED2_480>0</OEMLED2_480><OEMDRO2_481>0.</OEMDRO2_481><OEMLED2_481>0</OEMLED2_481><OEMDRO2_482>0.</OEMDRO2_482><OEMLED2_482>0</OEMLED2_482><OEMDRO2_483>0.</OEMDRO2_483><OEMLED2_483>0</OEMLED2_483><OEMDRO2_484>0.</OEMDRO2_484><OEMLED2_484>0</OEMLED2_484><OEMDRO2_485>0.</OEMDRO2_485><OEMLED2_485>0</OEMLED2_485><OEMDRO2_486>0.</OEMDRO2_486><OEMLED2_486>0</OEMLED2_486><OEMDRO2_487>0.</OEMDRO2_487><OEMLED2_487>0</OEMLED2_487><OEMDRO2_488>0.</OEMDRO2_488><OEMLED2_488>0</OEMLED2_488><OEMDRO2_489>0.</OEMDRO2_489><OEMLED2_489>0</OEMLED2_489><OEMDRO2_490>0.</OEMDRO2_490><OEMLED2_490>0</OEMLED2_490><OEMDRO2_491>0.</OEMDRO2_491><OEMLED2_491>0</OEMLED2_491><OEMDRO2_492>0.</OEMDRO2_492><OEMLED2_492>0</OEMLED2_492><OEMDRO2_493>0.</OEMDRO2_493><OEMLED2_493>0</OEMLED2_493><OEMDRO2_494>0.</OEMDRO2_494><OEMLED2_494>0</OEMLED2_494><OEMDRO2_495>0.</OEMDRO2_495><OEMLED2_495>0</OEMLED2_495><OEMDRO2_496>0.</OEMDRO2_496><OEMLED2_496>0</OEMLED2_496><OEMDRO2_497>0.</OEMDRO2_497><OEMLED2_497>0</OEMLED2_497><OEMDRO2_498>0.</OEMDRO2_498><OEMLED2_498>0</OEMLED2_498><OEMDRO2_499>0.</OEMDRO2_499><OEMLED2_499>0</OEMLED2_499><OEMDRO2_500>0.</OEMDRO2_500><OEMLED2_500>0</OEMLED2_500><OEMDRO2_501>0.</OEMDRO2_501><OEMLED2_501>0</OEMLED2_501><OEMDRO2_502>0.</OEMDRO2_502><OEMLED2_502>0</OEMLED2_502><OEMDRO2_503>0.</OEMDRO2_503><OEMLED2_503>0</OEMLED2_503><OEMDRO2_504>0.</OEMDRO2_504><OEMLED2_504>0</OEMLED2_504><OEMDRO2_505>0.</OEMDRO2_505><OEMLED2_505>0</OEMLED2_505><OEMDRO2_506>0.</OEMDRO2_506><OEMLED2_506>0</OEMLED2_506><OEMDRO2_507>0.</OEMDRO2_507><OEMLED2_507>0</OEMLED2_507><OEMDRO2_508>0.</OEMDRO2_508><OEMLED2_508>0</OEMLED2_508><OEMDRO2_509>0.</OEMDRO2_509><OEMLED2_509>0</OEMLED2_509><OEMDRO2_510>0.</OEMDRO2_510><OEMLED2_510>0</OEMLED2_510><OEMDRO2_511>0.</OEMDRO2_511><OEMLED2_511>0</OEMLED2_511><OEMDRO2_512>0.</OEMDRO2_512><OEMLED2_512>0</OEMLED2_512><OEMDRO2_513>0.</OEMDRO2_513><OEMLED2_513>0</OEMLED2_513><OEMDRO2_514>0.</OEMDRO2_514><OEMLED2_514>0</OEMLED2_514><OEMDRO2_515>0.</OEMDRO2_515><OEMLED2_515>0</OEMLED2_515><OEMDRO2_516>0.</OEMDRO2_516><OEMLED2_516>0</OEMLED2_516><OEMDRO2_517>0.</OEMDRO2_517><OEMLED2_517>0</OEMLED2_517><OEMDRO2_518>0.</OEMDRO2_518><OEMLED2_518>0</OEMLED2_518><OEMDRO2_519>0.</OEMDRO2_519><OEMLED2_519>0</OEMLED2_519><OEMDRO2_520>0.</OEMDRO2_520><OEMLED2_520>0</OEMLED2_520><OEMDRO2_521>0.</OEMDRO2_521><OEMLED2_521>0</OEMLED2_521><OEMDRO2_522>0.</OEMDRO2_522><OEMLED2_522>0</OEMLED2_522><OEMDRO2_523>0.</OEMDRO2_523><OEMLED2_523>0</OEMLED2_523><OEMDRO2_524>0.</OEMDRO2_524><OEMLED2_524>0</OEMLED2_524><OEMDRO2_525>0.</OEMDRO2_525><OEMLED2_525>0</OEMLED2_525><OEMDRO2_526>0.</OEMDRO2_526><OEMLED2_526>0</OEMLED2_526><OEMDRO2_527>0.</OEMDRO2_527><OEMLED2_527>0</OEMLED2_527><OEMDRO2_528>0.</OEMDRO2_528><OEMLED2_528>0</OEMLED2_528><OEMDRO2_529>0.</OEMDRO2_529><OEMLED2_529>0</OEMLED2_529><OEMDRO2_530>0.</OEMDRO2_530><OEMLED2_530>0</OEMLED2_530><OEMDRO2_531>0.</OEMDRO2_531><OEMLED2_531>0</OEMLED2_531><OEMDRO2_532>0.</OEMDRO2_532><OEMLED2_532>0</OEMLED2_532><OEMDRO2_533>0.</OEMDRO2_533><OEMLED2_533>0</OEMLED2_533><OEMDRO2_534>0.</OEMDRO2_534><OEMLED2_534>0</OEMLED2_534><OEMDRO2_535>0.</OEMDRO2_535><OEMLED2_535>0</OEMLED2_535><OEMDRO2_536>0.</OEMDRO2_536><OEMLED2_536>0</OEMLED2_536><OEMDRO2_537>0.</OEMDRO2_537><OEMLED2_537>0</OEMLED2_537><OEMDRO2_538>0.</OEMDRO2_538><OEMLED2_538>0</OEMLED2_538><OEMDRO2_539>0.</OEMDRO2_539><OEMLED2_539>0</OEMLED2_539><OEMDRO2_540>0.</OEMDRO2_540><OEMLED2_540>0</OEMLED2_540><OEMDRO2_541>0.</OEMDRO2_541><OEMLED2_541>0</OEMLED2_541><OEMDRO2_542>0.</OEMDRO2_542><OEMLED2_542>0</OEMLED2_542><OEMDRO2_543>0.</OEMDRO2_543><OEMLED2_543>0</OEMLED2_543><OEMDRO2_544>0.</OEMDRO2_544><OEMLED2_544>0</OEMLED2_544><OEMDRO2_545>0.</OEMDRO2_545><OEMLED2_545>0</OEMLED2_545><OEMDRO2_546>0.</OEMDRO2_546><OEMLED2_546>0</OEMLED2_546><OEMDRO2_547>0.</OEMDRO2_547><OEMLED2_547>0</OEMLED2_547><OEMDRO2_548>0.</OEMDRO2_548><OEMLED2_548>0</OEMLED2_548><OEMDRO2_549>0.</OEMDRO2_549><OEMLED2_549>0</OEMLED2_549><OEMDRO2_550>0.</OEMDRO2_550><OEMLED2_550>0</OEMLED2_550><OEMDRO2_551>0.</OEMDRO2_551><OEMLED2_551>0</OEMLED2_551><OEMDRO2_552>0.</OEMDRO2_552><OEMLED2_552>0</OEMLED2_552><OEMDRO2_553>0.</OEMDRO2_553><OEMLED2_553>0</OEMLED2_553><OEMDRO2_554>0.</OEMDRO2_554><OEMLED2_554>0</OEMLED2_554><OEMDRO2_555>0.</OEMDRO2_555><OEMLED2_555>0</OEMLED2_555><OEMDRO2_556>0.</OEMDRO2_556><OEMLED2_556>0</OEMLED2_556><OEMDRO2_557>0.</OEMDRO2_557><OEMLED2_557>0</OEMLED2_557><OEMDRO2_558>0.</OEMDRO2_558><OEMLED2_558>0</OEMLED2_558><OEMDRO2_559>0.</OEMDRO2_559><OEMLED2_559>0</OEMLED2_559><OEMDRO2_560>0.</OEMDRO2_560><OEMLED2_560>0</OEMLED2_560><OEMDRO2_561>0.</OEMDRO2_561><OEMLED2_561>0</OEMLED2_561><OEMDRO2_562>0.</OEMDRO2_562><OEMLED2_562>0</OEMLED2_562><OEMDRO2_563>0.</OEMDRO2_563><OEMLED2_563>0</OEMLED2_563><OEMDRO2_564>0.</OEMDRO2_564><OEMLED2_564>0</OEMLED2_564><OEMDRO2_565>0.</OEMDRO2_565><OEMLED2_565>0</OEMLED2_565><OEMDRO2_566>0.</OEMDRO2_566><OEMLED2_566>0</OEMLED2_566><OEMDRO2_567>0.</OEMDRO2_567><OEMLED2_567>0</OEMLED2_567><OEMDRO2_568>0.</OEMDRO2_568><OEMLED2_568>0</OEMLED2_568><OEMDRO2_569>0.</OEMDRO2_569><OEMLED2_569>0</OEMLED2_569><OEMDRO2_570>0.</OEMDRO2_570><OEMLED2_570>0</OEMLED2_570><OEMDRO2_571>0.</OEMDRO2_571><OEMLED2_571>0</OEMLED2_571><OEMDRO2_572>0.</OEMDRO2_572><OEMLED2_572>0</OEMLED2_572><OEMDRO2_573>0.</OEMDRO2_573><OEMLED2_573>0</OEMLED2_573><OEMDRO2_574>0.</OEMDRO2_574><OEMLED2_574>0</OEMLED2_574><OEMDRO2_575>0.</OEMDRO2_575><OEMLED2_575>0</OEMLED2_575><OEMDRO2_576>0.</OEMDRO2_576><OEMLED2_576>0</OEMLED2_576><OEMDRO2_577>0.</OEMDRO2_577><OEMLED2_577>0</OEMLED2_577><OEMDRO2_578>0.</OEMDRO2_578><OEMLED2_578>0</OEMLED2_578><OEMDRO2_579>0.</OEMDRO2_579><OEMLED2_579>0</OEMLED2_579><OEMDRO2_580>0.</OEMDRO2_580><OEMLED2_580>0</OEMLED2_580><OEMDRO2_581>0.</OEMDRO2_581><OEMLED2_581>0</OEMLED2_581><OEMDRO2_582>0.</OEMDRO2_582><OEMLED2_582>0</OEMLED2_582><OEMDRO2_583>0.</OEMDRO2_583><OEMLED2_583>0</OEMLED2_583><OEMDRO2_584>0.</OEMDRO2_584><OEMLED2_584>0</OEMLED2_584><OEMDRO2_585>0.</OEMDRO2_585><OEMLED2_585>0</OEMLED2_585><OEMDRO2_586>0.</OEMDRO2_586><OEMLED2_586>0</OEMLED2_586><OEMDRO2_587>0.</OEMDRO2_587><OEMLED2_587>0</OEMLED2_587><OEMDRO2_588>0.</OEMDRO2_588><OEMLED2_588>0</OEMLED2_588><OEMDRO2_589>0.</OEMDRO2_589><OEMLED2_589>0</OEMLED2_589><OEMDRO2_590>0.</OEMDRO2_590><OEMLED2_590>0</OEMLED2_590><OEMDRO2_591>0.</OEMDRO2_591><OEMLED2_591>0</OEMLED2_591><OEMDRO2_592>0.</OEMDRO2_592><OEMLED2_592>0</OEMLED2_592><OEMDRO2_593>0.</OEMDRO2_593><OEMLED2_593>0</OEMLED2_593><OEMDRO2_594>0.</OEMDRO2_594><OEMLED2_594>0</OEMLED2_594><OEMDRO2_595>0.</OEMDRO2_595><OEMLED2_595>0</OEMLED2_595><OEMDRO2_596>0.</OEMDRO2_596><OEMLED2_596>0</OEMLED2_596><OEMDRO2_597>0.</OEMDRO2_597><OEMLED2_597>0</OEMLED2_597><OEMDRO2_598>0.</OEMDRO2_598><OEMLED2_598>0</OEMLED2_598><OEMDRO2_599>0.</OEMDRO2_599><OEMLED2_599>0</OEMLED2_599><OEMDRO2_600>0.</OEMDRO2_600><OEMLED2_600>0</OEMLED2_600><OEMDRO2_601>0.</OEMDRO2_601><OEMLED2_601>0</OEMLED2_601><OEMDRO2_602>0.</OEMDRO2_602><OEMLED2_602>0</OEMLED2_602><OEMDRO2_603>0.</OEMDRO2_603><OEMLED2_603>0</OEMLED2_603><OEMDRO2_604>0.</OEMDRO2_604><OEMLED2_604>0</OEMLED2_604><OEMDRO2_605>0.</OEMDRO2_605><OEMLED2_605>0</OEMLED2_605><OEMDRO2_606>0.</OEMDRO2_606><OEMLED2_606>0</OEMLED2_606><OEMDRO2_607>0.</OEMDRO2_607><OEMLED2_607>0</OEMLED2_607><OEMDRO2_608>0.</OEMDRO2_608><OEMLED2_608>0</OEMLED2_608><OEMDRO2_609>0.</OEMDRO2_609><OEMLED2_609>0</OEMLED2_609><OEMDRO2_610>0.</OEMDRO2_610><OEMLED2_610>0</OEMLED2_610><OEMDRO2_611>0.</OEMDRO2_611><OEMLED2_611>0</OEMLED2_611><OEMDRO2_612>0.</OEMDRO2_612><OEMLED2_612>0</OEMLED2_612><OEMDRO2_613>0.</OEMDRO2_613><OEMLED2_613>0</OEMLED2_613><OEMDRO2_614>0.</OEMDRO2_614><OEMLED2_614>0</OEMLED2_614><OEMDRO2_615>0.</OEMDRO2_615><OEMLED2_615>0</OEMLED2_615><OEMDRO2_616>0.</OEMDRO2_616><OEMLED2_616>0</OEMLED2_616><OEMDRO2_617>0.</OEMDRO2_617><OEMLED2_617>0</OEMLED2_617><OEMDRO2_618>0.</OEMDRO2_618><OEMLED2_618>0</OEMLED2_618><OEMDRO2_619>0.</OEMDRO2_619><OEMLED2_619>0</OEMLED2_619><OEMDRO2_620>0.</OEMDRO2_620><OEMLED2_620>0</OEMLED2_620><OEMDRO2_621>0.</OEMDRO2_621><OEMLED2_621>0</OEMLED2_621><OEMDRO2_622>0.</OEMDRO2_622><OEMLED2_622>0</OEMLED2_622><OEMDRO2_623>0.</OEMDRO2_623><OEMLED2_623>0</OEMLED2_623><OEMDRO2_624>0.</OEMDRO2_624><OEMLED2_624>0</OEMLED2_624><OEMDRO2_625>0.</OEMDRO2_625><OEMLED2_625>0</OEMLED2_625><OEMDRO2_626>0.</OEMDRO2_626><OEMLED2_626>0</OEMLED2_626><OEMDRO2_627>0.</OEMDRO2_627><OEMLED2_627>0</OEMLED2_627><OEMDRO2_628>0.</OEMDRO2_628><OEMLED2_628>0</OEMLED2_628><OEMDRO2_629>0.</OEMDRO2_629><OEMLED2_629>0</OEMLED2_629><OEMDRO2_630>0.</OEMDRO2_630><OEMLED2_630>0</OEMLED2_630><OEMDRO2_631>0.</OEMDRO2_631><OEMLED2_631>0</OEMLED2_631><OEMDRO2_632>0.</OEMDRO2_632><OEMLED2_632>0</OEMLED2_632><OEMDRO2_633>0.</OEMDRO2_633><OEMLED2_633>0</OEMLED2_633><OEMDRO2_634>0.</OEMDRO2_634><OEMLED2_634>0</OEMLED2_634><OEMDRO2_635>0.</OEMDRO2_635><OEMLED2_635>0</OEMLED2_635><OEMDRO2_636>0.</OEMDRO2_636><OEMLED2_636>0</OEMLED2_636><OEMDRO2_637>0.</OEMDRO2_637><OEMLED2_637>0</OEMLED2_637><OEMDRO2_638>0.</OEMDRO2_638><OEMLED2_638>0</OEMLED2_638><OEMDRO2_639>0.</OEMDRO2_639><OEMLED2_639>0</OEMLED2_639><OEMDRO2_640>0.</OEMDRO2_640><OEMLED2_640>0</OEMLED2_640><OEMDRO2_641>0.</OEMDRO2_641><OEMLED2_641>0</OEMLED2_641><OEMDRO2_642>0.</OEMDRO2_642><OEMLED2_642>0</OEMLED2_642><OEMDRO2_643>0.</OEMDRO2_643><OEMLED2_643>0</OEMLED2_643><OEMDRO2_644>0.</OEMDRO2_644><OEMLED2_644>0</OEMLED2_644><OEMDRO2_645>0.</OEMDRO2_645><OEMLED2_645>0</OEMLED2_645><OEMDRO2_646>0.</OEMDRO2_646><OEMLED2_646>0</OEMLED2_646><OEMDRO2_647>0.</OEMDRO2_647><OEMLED2_647>0</OEMLED2_647><OEMDRO2_648>0.</OEMDRO2_648><OEMLED2_648>0</OEMLED2_648><OEMDRO2_649>0.</OEMDRO2_649><OEMLED2_649>0</OEMLED2_649><OEMDRO2_650>0.</OEMDRO2_650><OEMLED2_650>0</OEMLED2_650><OEMDRO2_651>0.</OEMDRO2_651><OEMLED2_651>0</OEMLED2_651><OEMDRO2_652>0.</OEMDRO2_652><OEMLED2_652>0</OEMLED2_652><OEMDRO2_653>0.</OEMDRO2_653><OEMLED2_653>0</OEMLED2_653><OEMDRO2_654>0.</OEMDRO2_654><OEMLED2_654>0</OEMLED2_654><OEMDRO2_655>0.</OEMDRO2_655><OEMLED2_655>0</OEMLED2_655><OEMDRO2_656>0.</OEMDRO2_656><OEMLED2_656>0</OEMLED2_656><OEMDRO2_657>0.</OEMDRO2_657><OEMLED2_657>0</OEMLED2_657><OEMDRO2_658>0.</OEMDRO2_658><OEMLED2_658>0</OEMLED2_658><OEMDRO2_659>0.</OEMDRO2_659><OEMLED2_659>0</OEMLED2_659><OEMDRO2_660>0.</OEMDRO2_660><OEMLED2_660>0</OEMLED2_660><OEMDRO2_661>0.</OEMDRO2_661><OEMLED2_661>0</OEMLED2_661><OEMDRO2_662>0.</OEMDRO2_662><OEMLED2_662>0</OEMLED2_662><OEMDRO2_663>0.</OEMDRO2_663><OEMLED2_663>0</OEMLED2_663><OEMDRO2_664>0.</OEMDRO2_664><OEMLED2_664>0</OEMLED2_664><OEMDRO2_665>0.</OEMDRO2_665><OEMLED2_665>0</OEMLED2_665><OEMDRO2_666>0.</OEMDRO2_666><OEMLED2_666>0</OEMLED2_666><OEMDRO2_667>0.</OEMDRO2_667><OEMLED2_667>0</OEMLED2_667><OEMDRO2_668>0.</OEMDRO2_668><OEMLED2_668>0</OEMLED2_668><OEMDRO2_669>0.</OEMDRO2_669><OEMLED2_669>0</OEMLED2_669><OEMDRO2_670>0.</OEMDRO2_670><OEMLED2_670>0</OEMLED2_670><OEMDRO2_671>0.</OEMDRO2_671><OEMLED2_671>0</OEMLED2_671><OEMDRO2_672>0.</OEMDRO2_672><OEMLED2_672>0</OEMLED2_672><OEMDRO2_673>0.</OEMDRO2_673><OEMLED2_673>0</OEMLED2_673><OEMDRO2_674>0.</OEMDRO2_674><OEMLED2_674>0</OEMLED2_674><OEMDRO2_675>0.</OEMDRO2_675><OEMLED2_675>0</OEMLED2_675><OEMDRO2_676>0.</OEMDRO2_676><OEMLED2_676>0</OEMLED2_676><OEMDRO2_677>0.</OEMDRO2_677><OEMLED2_677>0</OEMLED2_677><OEMDRO2_678>0.</OEMDRO2_678><OEMLED2_678>0</OEMLED2_678><OEMDRO2_679>0.</OEMDRO2_679><OEMLED2_679>0</OEMLED2_679><OEMDRO2_680>0.</OEMDRO2_680><OEMLED2_680>0</OEMLED2_680><OEMDRO2_681>0.</OEMDRO2_681><OEMLED2_681>0</OEMLED2_681><OEMDRO2_682>0.</OEMDRO2_682><OEMLED2_682>0</OEMLED2_682><OEMDRO2_683>0.</OEMDRO2_683><OEMLED2_683>0</OEMLED2_683><OEMDRO2_684>0.</OEMDRO2_684><OEMLED2_684>0</OEMLED2_684><OEMDRO2_685>0.</OEMDRO2_685><OEMLED2_685>0</OEMLED2_685><OEMDRO2_686>0.</OEMDRO2_686><OEMLED2_686>0</OEMLED2_686><OEMDRO2_687>0.</OEMDRO2_687><OEMLED2_687>0</OEMLED2_687><OEMDRO2_688>0.</OEMDRO2_688><OEMLED2_688>0</OEMLED2_688><OEMDRO2_689>0.</OEMDRO2_689><OEMLED2_689>0</OEMLED2_689><OEMDRO2_690>0.</OEMDRO2_690><OEMLED2_690>0</OEMLED2_690><OEMDRO2_691>0.</OEMDRO2_691><OEMLED2_691>0</OEMLED2_691><OEMDRO2_692>0.</OEMDRO2_692><OEMLED2_692>0</OEMLED2_692><OEMDRO2_693>0.</OEMDRO2_693><OEMLED2_693>0</OEMLED2_693><OEMDRO2_694>0.</OEMDRO2_694><OEMLED2_694>0</OEMLED2_694><OEMDRO2_695>0.</OEMDRO2_695><OEMLED2_695>0</OEMLED2_695><OEMDRO2_696>0.</OEMDRO2_696><OEMLED2_696>0</OEMLED2_696><OEMDRO2_697>0.</OEMDRO2_697><OEMLED2_697>0</OEMLED2_697><OEMDRO2_698>0.</OEMDRO2_698><OEMLED2_698>0</OEMLED2_698><OEMDRO2_699>0.</OEMDRO2_699><OEMLED2_699>0</OEMLED2_699><OEMDRO2_700>0.</OEMDRO2_700><OEMLED2_700>0</OEMLED2_700><OEMDRO2_701>0.</OEMDRO2_701><OEMLED2_701>0</OEMLED2_701><OEMDRO2_702>0.</OEMDRO2_702><OEMLED2_702>0</OEMLED2_702><OEMDRO2_703>0.</OEMDRO2_703><OEMLED2_703>0</OEMLED2_703><OEMDRO2_704>0.</OEMDRO2_704><OEMLED2_704>0</OEMLED2_704><OEMDRO2_705>0.</OEMDRO2_705><OEMLED2_705>0</OEMLED2_705><OEMDRO2_706>0.</OEMDRO2_706><OEMLED2_706>0</OEMLED2_706><OEMDRO2_707>0.</OEMDRO2_707><OEMLED2_707>0</OEMLED2_707><OEMDRO2_708>0.</OEMDRO2_708><OEMLED2_708>0</OEMLED2_708><OEMDRO2_709>0.</OEMDRO2_709><OEMLED2_709>0</OEMLED2_709><OEMDRO2_710>0.</OEMDRO2_710><OEMLED2_710>0</OEMLED2_710><OEMDRO2_711>0.</OEMDRO2_711><OEMLED2_711>0</OEMLED2_711><OEMDRO2_712>0.</OEMDRO2_712><OEMLED2_712>0</OEMLED2_712><OEMDRO2_713>0.</OEMDRO2_713><OEMLED2_713>0</OEMLED2_713><OEMDRO2_714>0.</OEMDRO2_714><OEMLED2_714>0</OEMLED2_714><OEMDRO2_715>0.</OEMDRO2_715><OEMLED2_715>0</OEMLED2_715><OEMDRO2_716>0.</OEMDRO2_716><OEMLED2_716>0</OEMLED2_716><OEMDRO2_717>0.</OEMDRO2_717><OEMLED2_717>0</OEMLED2_717><OEMDRO2_718>0.</OEMDRO2_718><OEMLED2_718>0</OEMLED2_718><OEMDRO2_719>0.</OEMDRO2_719><OEMLED2_719>0</OEMLED2_719><OEMDRO2_720>0.</OEMDRO2_720><OEMLED2_720>0</OEMLED2_720><OEMDRO2_721>0.</OEMDRO2_721><OEMLED2_721>0</OEMLED2_721><OEMDRO2_722>0.</OEMDRO2_722><OEMLED2_722>0</OEMLED2_722><OEMDRO2_723>0.</OEMDRO2_723><OEMLED2_723>0</OEMLED2_723><OEMDRO2_724>0.</OEMDRO2_724><OEMLED2_724>0</OEMLED2_724><OEMDRO2_725>0.</OEMDRO2_725><OEMLED2_725>0</OEMLED2_725><OEMDRO2_726>0.</OEMDRO2_726><OEMLED2_726>0</OEMLED2_726><OEMDRO2_727>0.</OEMDRO2_727><OEMLED2_727>0</OEMLED2_727><OEMDRO2_728>0.</OEMDRO2_728><OEMLED2_728>0</OEMLED2_728><OEMDRO2_729>0.</OEMDRO2_729><OEMLED2_729>0</OEMLED2_729><OEMDRO2_730>0.</OEMDRO2_730><OEMLED2_730>0</OEMLED2_730><OEMDRO2_731>0.</OEMDRO2_731><OEMLED2_731>0</OEMLED2_731><OEMDRO2_732>0.</OEMDRO2_732><OEMLED2_732>0</OEMLED2_732><OEMDRO2_733>0.</OEMDRO2_733><OEMLED2_733>0</OEMLED2_733><OEMDRO2_734>0.</OEMDRO2_734><OEMLED2_734>0</OEMLED2_734><OEMDRO2_735>0.</OEMDRO2_735><OEMLED2_735>0</OEMLED2_735><OEMDRO2_736>0.</OEMDRO2_736><OEMLED2_736>0</OEMLED2_736><OEMDRO2_737>0.</OEMDRO2_737><OEMLED2_737>0</OEMLED2_737><OEMDRO2_738>0.</OEMDRO2_738><OEMLED2_738>0</OEMLED2_738><OEMDRO2_739>0.</OEMDRO2_739><OEMLED2_739>0</OEMLED2_739><OEMDRO2_740>0.</OEMDRO2_740><OEMLED2_740>0</OEMLED2_740><OEMDRO2_741>0.</OEMDRO2_741><OEMLED2_741>0</OEMLED2_741><OEMDRO2_742>0.</OEMDRO2_742><OEMLED2_742>0</OEMLED2_742><OEMDRO2_743>0.</OEMDRO2_743><OEMLED2_743>0</OEMLED2_743><OEMDRO2_744>0.</OEMDRO2_744><OEMLED2_744>0</OEMLED2_744><OEMDRO2_745>0.</OEMDRO2_745><OEMLED2_745>0</OEMLED2_745><OEMDRO2_746>0.</OEMDRO2_746><OEMLED2_746>0</OEMLED2_746><OEMDRO2_747>0.</OEMDRO2_747><OEMLED2_747>0</OEMLED2_747><OEMDRO2_748>0.</OEMDRO2_748><OEMLED2_748>0</OEMLED2_748><OEMDRO2_749>0.</OEMDRO2_749><OEMLED2_749>0</OEMLED2_749><OEMDRO2_750>0.</OEMDRO2_750><OEMLED2_750>0</OEMLED2_750><OEMDRO2_751>0.</OEMDRO2_751><OEMLED2_751>0</OEMLED2_751><OEMDRO2_752>0.</OEMDRO2_752><OEMLED2_752>0</OEMLED2_752><OEMDRO2_753>0.</OEMDRO2_753><OEMLED2_753>0</OEMLED2_753><OEMDRO2_754>0.</OEMDRO2_754><OEMLED2_754>0</OEMLED2_754><OEMDRO2_755>0.</OEMDRO2_755><OEMLED2_755>0</OEMLED2_755><OEMDRO2_756>0.</OEMDRO2_756><OEMLED2_756>0</OEMLED2_756><OEMDRO2_757>0.</OEMDRO2_757><OEMLED2_757>0</OEMLED2_757><OEMDRO2_758>0.</OEMDRO2_758><OEMLED2_758>0</OEMLED2_758><OEMDRO2_759>0.</OEMDRO2_759><OEMLED2_759>0</OEMLED2_759><OEMDRO2_760>0.</OEMDRO2_760><OEMLED2_760>0</OEMLED2_760><OEMDRO2_761>0.</OEMDRO2_761><OEMLED2_761>0</OEMLED2_761><OEMDRO2_762>0.</OEMDRO2_762><OEMLED2_762>0</OEMLED2_762><OEMDRO2_763>0.</OEMDRO2_763><OEMLED2_763>0</OEMLED2_763><OEMDRO2_764>0.</OEMDRO2_764><OEMLED2_764>0</OEMLED2_764><OEMDRO2_765>0.</OEMDRO2_765><OEMLED2_765>0</OEMLED2_765><OEMDRO2_766>0.</OEMDRO2_766><OEMLED2_766>0</OEMLED2_766><OEMDRO2_767>0.</OEMDRO2_767><OEMLED2_767>0</OEMLED2_767><OEMDRO2_768>0.</OEMDRO2_768><OEMLED2_768>0</OEMLED2_768><OEMDRO2_769>0.</OEMDRO2_769><OEMLED2_769>0</OEMLED2_769><OEMDRO2_770>0.</OEMDRO2_770><OEMLED2_770>0</OEMLED2_770><OEMDRO2_771>0.</OEMDRO2_771><OEMLED2_771>0</OEMLED2_771><OEMDRO2_772>0.</OEMDRO2_772><OEMLED2_772>0</OEMLED2_772><OEMDRO2_773>0.</OEMDRO2_773><OEMLED2_773>0</OEMLED2_773><OEMDRO2_774>0.</OEMDRO2_774><OEMLED2_774>0</OEMLED2_774><OEMDRO2_775>0.</OEMDRO2_775><OEMLED2_775>0</OEMLED2_775><OEMDRO2_776>0.</OEMDRO2_776><OEMLED2_776>0</OEMLED2_776><OEMDRO2_777>0.</OEMDRO2_777><OEMLED2_777>0</OEMLED2_777><OEMDRO2_778>0.</OEMDRO2_778><OEMLED2_778>0</OEMLED2_778><OEMDRO2_779>0.</OEMDRO2_779><OEMLED2_779>0</OEMLED2_779><OEMDRO2_780>0.</OEMDRO2_780><OEMLED2_780>0</OEMLED2_780><OEMDRO2_781>0.</OEMDRO2_781><OEMLED2_781>0</OEMLED2_781><OEMDRO2_782>0.</OEMDRO2_782><OEMLED2_782>0</OEMLED2_782><OEMDRO2_783>0.</OEMDRO2_783><OEMLED2_783>0</OEMLED2_783><OEMDRO2_784>0.</OEMDRO2_784><OEMLED2_784>0</OEMLED2_784><OEMDRO2_785>0.</OEMDRO2_785><OEMLED2_785>0</OEMLED2_785><OEMDRO2_786>0.</OEMDRO2_786><OEMLED2_786>0</OEMLED2_786><OEMDRO2_787>0.</OEMDRO2_787><OEMLED2_787>0</OEMLED2_787><OEMDRO2_788>0.</OEMDRO2_788><OEMLED2_788>0</OEMLED2_788><OEMDRO2_789>0.</OEMDRO2_789><OEMLED2_789>0</OEMLED2_789><OEMDRO2_790>0.</OEMDRO2_790><OEMLED2_790>0</OEMLED2_790><OEMDRO2_791>0.</OEMDRO2_791><OEMLED2_791>0</OEMLED2_791><OEMDRO2_792>0.</OEMDRO2_792><OEMLED2_792>0</OEMLED2_792><OEMDRO2_793>0.</OEMDRO2_793><OEMLED2_793>0</OEMLED2_793><OEMDRO2_794>0.</OEMDRO2_794><OEMLED2_794>0</OEMLED2_794><OEMDRO2_795>0.</OEMDRO2_795><OEMLED2_795>0</OEMLED2_795><OEMDRO2_796>0.</OEMDRO2_796><OEMLED2_796>0</OEMLED2_796><OEMDRO2_797>0.</OEMDRO2_797><OEMLED2_797>0</OEMLED2_797><OEMDRO2_798>0.</OEMDRO2_798><OEMLED2_798>0</OEMLED2_798><OEMDRO2_799>0.</OEMDRO2_799><OEMLED2_799>0</OEMLED2_799><OEMDRO2_800>0.</OEMDRO2_800><OEMLED2_800>0</OEMLED2_800><OEMDRO2_801>0.</OEMDRO2_801><OEMLED2_801>0</OEMLED2_801><OEMDRO2_802>0.</OEMDRO2_802><OEMLED2_802>0</OEMLED2_802><OEMDRO2_803>0.</OEMDRO2_803><OEMLED2_803>0</OEMLED2_803><OEMDRO2_804>0.</OEMDRO2_804><OEMLED2_804>0</OEMLED2_804><OEMDRO2_805>0.</OEMDRO2_805><OEMLED2_805>0</OEMLED2_805><OEMDRO2_806>0.</OEMDRO2_806><OEMLED2_806>0</OEMLED2_806><OEMDRO2_807>0.</OEMDRO2_807><OEMLED2_807>0</OEMLED2_807><OEMDRO2_808>0.</OEMDRO2_808><OEMLED2_808>0</OEMLED2_808><OEMDRO2_809>0.</OEMDRO2_809><OEMLED2_809>0</OEMLED2_809><OEMDRO2_810>0.</OEMDRO2_810><OEMLED2_810>0</OEMLED2_810><OEMDRO2_811>0.</OEMDRO2_811><OEMLED2_811>0</OEMLED2_811><OEMDRO2_812>0.</OEMDRO2_812><OEMLED2_812>0</OEMLED2_812><OEMDRO2_813>0.</OEMDRO2_813><OEMLED2_813>0</OEMLED2_813><OEMDRO2_814>0.</OEMDRO2_814><OEMLED2_814>0</OEMLED2_814><OEMDRO2_815>0.</OEMDRO2_815><OEMLED2_815>0</OEMLED2_815><OEMDRO2_816>0.</OEMDRO2_816><OEMLED2_816>0</OEMLED2_816><OEMDRO2_817>0.</OEMDRO2_817><OEMLED2_817>0</OEMLED2_817><OEMDRO2_818>0.</OEMDRO2_818><OEMLED2_818>0</OEMLED2_818><OEMDRO2_819>0.</OEMDRO2_819><OEMLED2_819>0</OEMLED2_819><OEMDRO2_820>0.</OEMDRO2_820><OEMLED2_820>0</OEMLED2_820><OEMDRO2_821>0.</OEMDRO2_821><OEMLED2_821>0</OEMLED2_821><OEMDRO2_822>0.</OEMDRO2_822><OEMLED2_822>0</OEMLED2_822><OEMDRO2_823>0.</OEMDRO2_823><OEMLED2_823>0</OEMLED2_823><OEMDRO2_824>0.</OEMDRO2_824><OEMLED2_824>0</OEMLED2_824><OEMDRO2_825>0.</OEMDRO2_825><OEMLED2_825>0</OEMLED2_825><OEMDRO2_826>0.</OEMDRO2_826><OEMLED2_826>0</OEMLED2_826><OEMDRO2_827>0.</OEMDRO2_827><OEMLED2_827>0</OEMLED2_827><OEMDRO2_828>0.</OEMDRO2_828><OEMLED2_828>0</OEMLED2_828><OEMDRO2_829>0.</OEMDRO2_829><OEMLED2_829>0</OEMLED2_829><OEMDRO2_830>0.</OEMDRO2_830><OEMLED2_830>0</OEMLED2_830><OEMDRO2_831>0.</OEMDRO2_831><OEMLED2_831>0</OEMLED2_831><OEMDRO2_832>0.</OEMDRO2_832><OEMLED2_832>0</OEMLED2_832><OEMDRO2_833>0.</OEMDRO2_833><OEMLED2_833>0</OEMLED2_833><OEMDRO2_834>0.</OEMDRO2_834><OEMLED2_834>0</OEMLED2_834><OEMDRO2_835>0.</OEMDRO2_835><OEMLED2_835>0</OEMLED2_835><OEMDRO2_836>0.</OEMDRO2_836><OEMLED2_836>0</OEMLED2_836><OEMDRO2_837>0.</OEMDRO2_837><OEMLED2_837>0</OEMLED2_837><OEMDRO2_838>0.</OEMDRO2_838><OEMLED2_838>0</OEMLED2_838><OEMDRO2_839>0.</OEMDRO2_839><OEMLED2_839>0</OEMLED2_839><OEMDRO2_840>0.</OEMDRO2_840><OEMLED2_840>0</OEMLED2_840><OEMDRO2_841>0.</OEMDRO2_841><OEMLED2_841>0</OEMLED2_841><OEMDRO2_842>0.</OEMDRO2_842><OEMLED2_842>0</OEMLED2_842><OEMDRO2_843>0.</OEMDRO2_843><OEMLED2_843>0</OEMLED2_843><OEMDRO2_844>0.</OEMDRO2_844><OEMLED2_844>0</OEMLED2_844><OEMDRO2_845>0.</OEMDRO2_845><OEMLED2_845>0</OEMLED2_845><OEMDRO2_846>0.</OEMDRO2_846><OEMLED2_846>0</OEMLED2_846><OEMDRO2_847>0.</OEMDRO2_847><OEMLED2_847>0</OEMLED2_847><OEMDRO2_848>0.</OEMDRO2_848><OEMLED2_848>0</OEMLED2_848><OEMDRO2_849>0.</OEMDRO2_849><OEMLED2_849>0</OEMLED2_849><OEMDRO2_850>0.</OEMDRO2_850><OEMLED2_850>0</OEMLED2_850><OEMDRO2_851>0.</OEMDRO2_851><OEMLED2_851>0</OEMLED2_851><OEMDRO2_852>0.</OEMDRO2_852><OEMLED2_852>0</OEMLED2_852><OEMDRO2_853>0.</OEMDRO2_853><OEMLED2_853>0</OEMLED2_853><OEMDRO2_854>0.</OEMDRO2_854><OEMLED2_854>0</OEMLED2_854><OEMDRO2_855>0.</OEMDRO2_855><OEMLED2_855>0</OEMLED2_855><OEMDRO2_856>0.</OEMDRO2_856><OEMLED2_856>0</OEMLED2_856><OEMDRO2_857>0.</OEMDRO2_857><OEMLED2_857>0</OEMLED2_857><OEMDRO2_858>0.</OEMDRO2_858><OEMLED2_858>0</OEMLED2_858><OEMDRO2_859>0.</OEMDRO2_859><OEMLED2_859>0</OEMLED2_859><OEMDRO2_860>0.</OEMDRO2_860><OEMLED2_860>0</OEMLED2_860><OEMDRO2_861>0.</OEMDRO2_861><OEMLED2_861>0</OEMLED2_861><OEMDRO2_862>0.</OEMDRO2_862><OEMLED2_862>0</OEMLED2_862><OEMDRO2_863>0.</OEMDRO2_863><OEMLED2_863>0</OEMLED2_863><OEMDRO2_864>0.</OEMDRO2_864><OEMLED2_864>0</OEMLED2_864><OEMDRO2_865>0.</OEMDRO2_865><OEMLED2_865>0</OEMLED2_865><OEMDRO2_866>0.</OEMDRO2_866><OEMLED2_866>0</OEMLED2_866><OEMDRO2_867>0.</OEMDRO2_867><OEMLED2_867>0</OEMLED2_867><OEMDRO2_868>0.</OEMDRO2_868><OEMLED2_868>0</OEMLED2_868><OEMDRO2_869>0.</OEMDRO2_869><OEMLED2_869>0</OEMLED2_869><OEMDRO2_870>0.</OEMDRO2_870><OEMLED2_870>0</OEMLED2_870><OEMDRO2_871>0.</OEMDRO2_871><OEMLED2_871>0</OEMLED2_871><OEMDRO2_872>0.</OEMDRO2_872><OEMLED2_872>0</OEMLED2_872><OEMDRO2_873>0.</OEMDRO2_873><OEMLED2_873>0</OEMLED2_873><OEMDRO2_874>0.</OEMDRO2_874><OEMLED2_874>0</OEMLED2_874><OEMDRO2_875>0.</OEMDRO2_875><OEMLED2_875>0</OEMLED2_875><OEMDRO2_876>0.</OEMDRO2_876><OEMLED2_876>0</OEMLED2_876><OEMDRO2_877>0.</OEMDRO2_877><OEMLED2_877>0</OEMLED2_877><OEMDRO2_878>0.</OEMDRO2_878><OEMLED2_878>0</OEMLED2_878><OEMDRO2_879>0.</OEMDRO2_879><OEMLED2_879>0</OEMLED2_879><OEMDRO2_880>0.</OEMDRO2_880><OEMLED2_880>0</OEMLED2_880><OEMDRO2_881>0.</OEMDRO2_881><OEMLED2_881>0</OEMLED2_881><OEMDRO2_882>0.</OEMDRO2_882><OEMLED2_882>0</OEMLED2_882><OEMDRO2_883>0.</OEMDRO2_883><OEMLED2_883>0</OEMLED2_883><OEMDRO2_884>0.</OEMDRO2_884><OEMLED2_884>0</OEMLED2_884><OEMDRO2_885>0.</OEMDRO2_885><OEMLED2_885>0</OEMLED2_885><OEMDRO2_886>0.</OEMDRO2_886><OEMLED2_886>0</OEMLED2_886><OEMDRO2_887>0.</OEMDRO2_887><OEMLED2_887>0</OEMLED2_887><OEMDRO2_888>0.</OEMDRO2_888><OEMLED2_888>0</OEMLED2_888><OEMDRO2_889>0.</OEMDRO2_889><OEMLED2_889>0</OEMLED2_889><OEMDRO2_890>0.</OEMDRO2_890><OEMLED2_890>0</OEMLED2_890><OEMDRO2_891>0.</OEMDRO2_891><OEMLED2_891>0</OEMLED2_891><OEMDRO2_892>0.</OEMDRO2_892><OEMLED2_892>0</OEMLED2_892><OEMDRO2_893>0.</OEMDRO2_893><OEMLED2_893>0</OEMLED2_893><OEMDRO2_894>0.</OEMDRO2_894><OEMLED2_894>0</OEMLED2_894><OEMDRO2_895>0.</OEMDRO2_895><OEMLED2_895>0</OEMLED2_895><OEMDRO2_896>0.</OEMDRO2_896><OEMLED2_896>0</OEMLED2_896><OEMDRO2_897>0.</OEMDRO2_897><OEMLED2_897>0</OEMLED2_897><OEMDRO2_898>0.</OEMDRO2_898><OEMLED2_898>0</OEMLED2_898><OEMDRO2_899>0.</OEMDRO2_899><OEMLED2_899>0</OEMLED2_899><OEMDRO2_900>0.</OEMDRO2_900><OEMLED2_900>0</OEMLED2_900><OEMDRO2_901>0.</OEMDRO2_901><OEMLED2_901>0</OEMLED2_901><OEMDRO2_902>0.</OEMDRO2_902><OEMLED2_902>0</OEMLED2_902><OEMDRO2_903>0.</OEMDRO2_903><OEMLED2_903>0</OEMLED2_903><OEMDRO2_904>0.</OEMDRO2_904><OEMLED2_904>0</OEMLED2_904><OEMDRO2_905>0.</OEMDRO2_905><OEMLED2_905>0</OEMLED2_905><OEMDRO2_906>0.</OEMDRO2_906><OEMLED2_906>0</OEMLED2_906><OEMDRO2_907>0.</OEMDRO2_907><OEMLED2_907>0</OEMLED2_907><OEMDRO2_908>0.</OEMDRO2_908><OEMLED2_908>0</OEMLED2_908><OEMDRO2_909>0.</OEMDRO2_909><OEMLED2_909>0</OEMLED2_909><OEMDRO2_910>0.</OEMDRO2_910><OEMLED2_910>0</OEMLED2_910><OEMDRO2_911>0.</OEMDRO2_911><OEMLED2_911>0</OEMLED2_911><OEMDRO2_912>0.</OEMDRO2_912><OEMLED2_912>0</OEMLED2_912><OEMDRO2_913>0.</OEMDRO2_913><OEMLED2_913>0</OEMLED2_913><OEMDRO2_914>0.</OEMDRO2_914><OEMLED2_914>0</OEMLED2_914><OEMDRO2_915>0.</OEMDRO2_915><OEMLED2_915>0</OEMLED2_915><OEMDRO2_916>0.</OEMDRO2_916><OEMLED2_916>0</OEMLED2_916><OEMDRO2_917>0.</OEMDRO2_917><OEMLED2_917>0</OEMLED2_917><OEMDRO2_918>0.</OEMDRO2_918><OEMLED2_918>0</OEMLED2_918><OEMDRO2_919>0.</OEMDRO2_919><OEMLED2_919>0</OEMLED2_919><OEMDRO2_920>0.</OEMDRO2_920><OEMLED2_920>0</OEMLED2_920><OEMDRO2_921>0.</OEMDRO2_921><OEMLED2_921>0</OEMLED2_921><OEMDRO2_922>0.</OEMDRO2_922><OEMLED2_922>0</OEMLED2_922><OEMDRO2_923>0.</OEMDRO2_923><OEMLED2_923>0</OEMLED2_923><OEMDRO2_924>0.</OEMDRO2_924><OEMLED2_924>0</OEMLED2_924><OEMDRO2_925>0.</OEMDRO2_925><OEMLED2_925>0</OEMLED2_925><OEMDRO2_926>0.</OEMDRO2_926><OEMLED2_926>0</OEMLED2_926><OEMDRO2_927>0.</OEMDRO2_927><OEMLED2_927>0</OEMLED2_927><OEMDRO2_928>0.</OEMDRO2_928><OEMLED2_928>0</OEMLED2_928><OEMDRO2_929>0.</OEMDRO2_929><OEMLED2_929>0</OEMLED2_929><OEMDRO2_930>0.</OEMDRO2_930><OEMLED2_930>0</OEMLED2_930><OEMDRO2_931>0.</OEMDRO2_931><OEMLED2_931>0</OEMLED2_931><OEMDRO2_932>0.</OEMDRO2_932><OEMLED2_932>0</OEMLED2_932><OEMDRO2_933>0.</OEMDRO2_933><OEMLED2_933>0</OEMLED2_933><OEMDRO2_934>0.</OEMDRO2_934><OEMLED2_934>0</OEMLED2_934><OEMDRO2_935>0.</OEMDRO2_935><OEMLED2_935>0</OEMLED2_935><OEMDRO2_936>0.</OEMDRO2_936><OEMLED2_936>0</OEMLED2_936><OEMDRO2_937>0.</OEMDRO2_937><OEMLED2_937>0</OEMLED2_937><OEMDRO2_938>0.</OEMDRO2_938><OEMLED2_938>0</OEMLED2_938><OEMDRO2_939>0.</OEMDRO2_939><OEMLED2_939>0</OEMLED2_939><OEMDRO2_940>0.</OEMDRO2_940><OEMLED2_940>0</OEMLED2_940><OEMDRO2_941>0.</OEMDRO2_941><OEMLED2_941>0</OEMLED2_941><OEMDRO2_942>0.</OEMDRO2_942><OEMLED2_942>0</OEMLED2_942><OEMDRO2_943>0.</OEMDRO2_943><OEMLED2_943>0</OEMLED2_943><OEMDRO2_944>0.</OEMDRO2_944><OEMLED2_944>0</OEMLED2_944><OEMDRO2_945>0.</OEMDRO2_945><OEMLED2_945>0</OEMLED2_945><OEMDRO2_946>0.</OEMDRO2_946><OEMLED2_946>0</OEMLED2_946><OEMDRO2_947>0.</OEMDRO2_947><OEMLED2_947>0</OEMLED2_947><OEMDRO2_948>0.</OEMDRO2_948><OEMLED2_948>0</OEMLED2_948><OEMDRO2_949>0.</OEMDRO2_949><OEMLED2_949>0</OEMLED2_949><OEMDRO2_950>0.</OEMDRO2_950><OEMLED2_950>0</OEMLED2_950><OEMDRO2_951>0.</OEMDRO2_951><OEMLED2_951>0</OEMLED2_951><OEMDRO2_952>0.</OEMDRO2_952><OEMLED2_952>0</OEMLED2_952><OEMDRO2_953>0.</OEMDRO2_953><OEMLED2_953>0</OEMLED2_953><OEMDRO2_954>0.</OEMDRO2_954><OEMLED2_954>0</OEMLED2_954><OEMDRO2_955>0.</OEMDRO2_955><OEMLED2_955>0</OEMLED2_955><OEMDRO2_956>0.</OEMDRO2_956><OEMLED2_956>0</OEMLED2_956><OEMDRO2_957>0.</OEMDRO2_957><OEMLED2_957>0</OEMLED2_957><OEMDRO2_958>0.</OEMDRO2_958><OEMLED2_958>0</OEMLED2_958><OEMDRO2_959>0.</OEMDRO2_959><OEMLED2_959>0</OEMLED2_959><OEMDRO2_960>0.</OEMDRO2_960><OEMLED2_960>0</OEMLED2_960><OEMDRO2_961>0.</OEMDRO2_961><OEMLED2_961>0</OEMLED2_961><OEMDRO2_962>0.</OEMDRO2_962><OEMLED2_962>0</OEMLED2_962><OEMDRO2_963>0.</OEMDRO2_963><OEMLED2_963>0</OEMLED2_963><OEMDRO2_964>0.</OEMDRO2_964><OEMLED2_964>0</OEMLED2_964><OEMDRO2_965>0.</OEMDRO2_965><OEMLED2_965>0</OEMLED2_965><OEMDRO2_966>0.</OEMDRO2_966><OEMLED2_966>0</OEMLED2_966><OEMDRO2_967>0.</OEMDRO2_967><OEMLED2_967>0</OEMLED2_967><OEMDRO2_968>0.</OEMDRO2_968><OEMLED2_968>0</OEMLED2_968><OEMDRO2_969>0.</OEMDRO2_969><OEMLED2_969>0</OEMLED2_969><OEMDRO2_970>0.</OEMDRO2_970><OEMLED2_970>0</OEMLED2_970><OEMDRO2_971>0.</OEMDRO2_971><OEMLED2_971>0</OEMLED2_971><OEMDRO2_972>0.</OEMDRO2_972><OEMLED2_972>0</OEMLED2_972><OEMDRO2_973>0.</OEMDRO2_973><OEMLED2_973>0</OEMLED2_973><OEMDRO2_974>0.</OEMDRO2_974><OEMLED2_974>0</OEMLED2_974><OEMDRO2_975>0.</OEMDRO2_975><OEMLED2_975>0</OEMLED2_975><OEMDRO2_976>0.</OEMDRO2_976><OEMLED2_976>0</OEMLED2_976><OEMDRO2_977>0.</OEMDRO2_977><OEMLED2_977>0</OEMLED2_977><OEMDRO2_978>0.</OEMDRO2_978><OEMLED2_978>0</OEMLED2_978><OEMDRO2_979>0.</OEMDRO2_979><OEMLED2_979>0</OEMLED2_979><OEMDRO2_980>0.</OEMDRO2_980><OEMLED2_980>0</OEMLED2_980><OEMDRO2_981>0.</OEMDRO2_981><OEMLED2_981>0</OEMLED2_981><OEMDRO2_982>0.</OEMDRO2_982><OEMLED2_982>0</OEMLED2_982><OEMDRO2_983>0.</OEMDRO2_983><OEMLED2_983>0</OEMLED2_983><OEMDRO2_984>0.</OEMDRO2_984><OEMLED2_984>0</OEMLED2_984><OEMDRO2_985>0.</OEMDRO2_985><OEMLED2_985>0</OEMLED2_985><OEMDRO2_986>0.</OEMDRO2_986><OEMLED2_986>0</OEMLED2_986><OEMDRO2_987>0.</OEMDRO2_987><OEMLED2_987>0</OEMLED2_987><OEMDRO2_988>0.</OEMDRO2_988><OEMLED2_988>0</OEMLED2_988><OEMDRO2_989>0.</OEMDRO2_989><OEMLED2_989>0</OEMLED2_989><OEMDRO2_990>0.</OEMDRO2_990><OEMLED2_990>0</OEMLED2_990><OEMDRO2_991>0.</OEMDRO2_991><OEMLED2_991>0</OEMLED2_991><OEMDRO2_992>0.</OEMDRO2_992><OEMLED2_992>0</OEMLED2_992><OEMDRO2_993>0.</OEMDRO2_993><OEMLED2_993>0</OEMLED2_993><OEMDRO2_994>0.</OEMDRO2_994><OEMLED2_994>0</OEMLED2_994><OEMDRO2_995>0.</OEMDRO2_995><OEMLED2_995>0</OEMLED2_995><OEMDRO2_996>0.</OEMDRO2_996><OEMLED2_996>0</OEMLED2_996><OEMDRO2_997>0.</OEMDRO2_997><OEMLED2_997>0</OEMLED2_997><OEMDRO2_998>0.</OEMDRO2_998><OEMLED2_998>0</OEMLED2_998><OEMDRO2_999>0.</OEMDRO2_999><OEMLED2_999>0</OEMLED2_999><AutoLimit>0</AutoLimit></Preferences><Mach3Mill><WPVB>500</WPVB><WPVT>100</WPVT><WPVL>50</WPVL><WPVR>400</WPVR></Mach3Mill><Control><Device>Printer</Device></Control><VideoPlugIn><DROcolor>0</DROcolor><TOOLcolor>8421440</TOOLcolor><CROSScolor>4194304</CROSScolor><ShowTool>1</ShowTool><ShowMousePos>1</ShowMousePos><ShowAxisPos>1</ShowAxisPos><ToolDia>0.5</ToolDia><ScaleFactor>2.e-003</ScaleFactor><FlipAxis>0</FlipAxis></VideoPlugIn><GCodeVar><GVar500>0.</GVar500><GVar501>0.</GVar501><GVar502>0.</GVar502><GVar503>0.</GVar503><GVar504>0.</GVar504><GVar505>0.</GVar505><GVar506>0.</GVar506><GVar507>0.</GVar507><GVar508>0.</GVar508><GVar509>0.</GVar509><GVar510>0.</GVar510><GVar511>0.</GVar511><GVar512>0.</GVar512><GVar513>0.</GVar513><GVar514>0.</GVar514><GVar515>0.</GVar515><GVar516>0.</GVar516><GVar517>0.</GVar517><GVar518>0.</GVar518><GVar519>0.</GVar519><GVar520>0.</GVar520><GVar521>0.</GVar521><GVar522>0.</GVar522><GVar523>0.</GVar523><GVar524>0.</GVar524><GVar525>0.</GVar525><GVar526>0.</GVar526><GVar527>0.</GVar527><GVar528>0.</GVar528><GVar529>0.</GVar529><GVar530>0.</GVar530><GVar531>0.</GVar531><GVar532>0.</GVar532><GVar533>0.</GVar533><GVar534>0.</GVar534><GVar535>0.</GVar535><GVar536>0.</GVar536><GVar537>0.</GVar537><GVar538>0.</GVar538><GVar539>0.</GVar539><GVar540>0.</GVar540><GVar541>0.</GVar541><GVar542>0.</GVar542><GVar543>0.</GVar543><GVar544>0.</GVar544><GVar545>0.</GVar545><GVar546>0.</GVar546><GVar547>0.</GVar547><GVar548>0.</GVar548><GVar549>0.</GVar549><GVar550>0.</GVar550><GVar551>0.</GVar551><GVar552>0.</GVar552><GVar553>0.</GVar553><GVar554>0.</GVar554><GVar555>0.</GVar555><GVar556>0.</GVar556><GVar557>0.</GVar557><GVar558>0.</GVar558><GVar559>0.</GVar559><GVar560>0.</GVar560><GVar561>0.</GVar561><GVar562>0.</GVar562><GVar563>0.</GVar563><GVar564>0.</GVar564><GVar565>0.</GVar565><GVar566>0.</GVar566><GVar567>0.</GVar567><GVar568>0.</GVar568><GVar569>0.</GVar569><GVar570>0.</GVar570><GVar571>0.</GVar571><GVar572>0.</GVar572><GVar573>0.</GVar573><GVar574>0.</GVar574><GVar575>0.</GVar575><GVar576>0.</GVar576><GVar577>0.</GVar577><GVar578>0.</GVar578><GVar579>0.</GVar579><GVar580>0.</GVar580><GVar581>0.</GVar581><GVar582>0.</GVar582><GVar583>0.</GVar583><GVar584>0.</GVar584><GVar585>0.</GVar585><GVar586>0.</GVar586><GVar587>0.</GVar587><GVar588>0.</GVar588><GVar589>0.</GVar589><GVar590>0.</GVar590><GVar591>0.</GVar591><GVar592>0.</GVar592><GVar593>0.</GVar593><GVar594>0.</GVar594><GVar595>0.</GVar595><GVar596>0.</GVar596><GVar597>0.</GVar597><GVar598>0.</GVar598><GVar599>0.</GVar599><GVar600>0.</GVar600></GCodeVar></profile>
