<profile>
  <Preferences>
    <PulseSpeed>2</PulseSpeed>
    <Profile>Mach3Mill</Profile>
    <Layout>1024.set</Layout>
    <FirstRun>1</FirstRun>
    <Units>1</Units>
    <Serial>0</Serial>
    <Port2Input>0</Port2Input>
    <GeckoMode>0</GeckoMode>
    <USBINPUTS>16</USBINPUTS>
    <USBOUTPUTS>16</USBOUTPUTS>
    <Port2On>0</Port2On>
    <Port1On>1</Port1On>
    <Port1Add>888</Port1Add>
    <Port2Add>632</Port2Add>
    <MaxCL>0</MaxCL>
    <MaxNC10>0</MaxNC10>
    <Motor0Active>1</Motor0Active>
    <Motor0DirNeg>1</Motor0DirNeg>
    <Motor0DirPort>1</Motor0DirPort>
    <Motor0DirPin>5</Motor0DirPin>
    <Motor0StepNeg>0</Motor0StepNeg>
    <Motor0StepPort>1</Motor0StepPort>
    <Motor0StepPin>4</Motor0StepPin>
    <Motor1Active>1</Motor1Active>
    <Motor1DirNeg>0</Motor1DirNeg>
    <Motor1DirPort>1</Motor1DirPort>
    <Motor1DirPin>7</Motor1DirPin>
    <Motor1StepNeg>0</Motor1StepNeg>
    <Motor1StepPort>1</Motor1StepPort>
    <Motor1StepPin>6</Motor1StepPin>
    <Motor2Active>1</Motor2Active>
    <Motor2DirNeg>0</Motor2DirNeg>
    <Motor2DirPort>1</Motor2DirPort>
    <Motor2DirPin>3</Motor2DirPin>
    <Motor2StepNeg>0</Motor2StepNeg>
    <Motor2StepPort>1</Motor2StepPort>
    <Motor2StepPin>2</Motor2StepPin>
    <Motor3Active>1</Motor3Active>
    <Motor3DirNeg>0</Motor3DirNeg>
    <Motor3DirPort>1</Motor3DirPort>
    <Motor3DirPin>8</Motor3DirPin>
    <Motor3StepNeg>1</Motor3StepNeg>
    <Motor3StepPort>1</Motor3StepPort>
    <Motor3StepPin>9</Motor3StepPin>
    <Motor4Active>0</Motor4Active>
    <Motor4DirNeg>0</Motor4DirNeg>
    <Motor4DirPort>0</Motor4DirPort>
    <Motor4DirPin>0</Motor4DirPin>
    <Motor4StepNeg>0</Motor4StepNeg>
    <Motor4StepPort>0</Motor4StepPort>
    <Motor4StepPin>0</Motor4StepPin>
    <Motor5Active>0</Motor5Active>
    <Motor5DirNeg>0</Motor5DirNeg>
    <Motor5DirPort>0</Motor5DirPort>
    <Motor5DirPin>0</Motor5DirPin>
    <Motor5StepNeg>0</Motor5StepNeg>
    <Motor5StepPort>0</Motor5StepPort>
    <Motor5StepPin>0</Motor5StepPin>
    <Motor6Active>0</Motor6Active>
    <Motor6DirNeg>0</Motor6DirNeg>
    <Motor6DirPort>0</Motor6DirPort>
    <Motor6DirPin>0</Motor6DirPin>
    <Motor6StepNeg>0</Motor6StepNeg>
    <Motor6StepPort>0</Motor6StepPort>
    <Motor6StepPin>0</Motor6StepPin>
    <Input0Active>0</Input0Active>
    <Input0Port>1</Input0Port>
    <Input0Pin>0</Input0Pin>
    <Input0Neg>0</Input0Neg>
    <Input0Emulated>0</Input0Emulated>
    <Input0EmuKey>0</Input0EmuKey>
    <Input1Active>0</Input1Active>
    <Input1Port>1</Input1Port>
    <Input1Pin>0</Input1Pin>
    <Input1Neg>0</Input1Neg>
    <Input1Emulated>0</Input1Emulated>
    <Input1EmuKey>0</Input1EmuKey>
    <Input2Active>0</Input2Active>
    <Input2Port>1</Input2Port>
    <Input2Pin>0</Input2Pin>
    <Input2Neg>0</Input2Neg>
    <Input2Emulated>0</Input2Emulated>
    <Input2EmuKey>0</Input2EmuKey>
    <Input3Active>0</Input3Active>
    <Input3Port>1</Input3Port>
    <Input3Pin>0</Input3Pin>
    <Input3Neg>0</Input3Neg>
    <Input3Emulated>0</Input3Emulated>
    <Input3EmuKey>0</Input3EmuKey>
    <Input4Active>0</Input4Active>
    <Input4Port>1</Input4Port>
    <Input4Pin>0</Input4Pin>
    <Input4Neg>0</Input4Neg>
    <Input4Emulated>0</Input4Emulated>
    <Input4EmuKey>0</Input4EmuKey>
    <Input5Active>0</Input5Active>
    <Input5Port>1</Input5Port>
    <Input5Pin>0</Input5Pin>
    <Input5Neg>0</Input5Neg>
    <Input5Emulated>0</Input5Emulated>
    <Input5EmuKey>0</Input5EmuKey>
    <Input6Active>0</Input6Active>
    <Input6Port>1</Input6Port>
    <Input6Pin>0</Input6Pin>
    <Input6Neg>0</Input6Neg>
    <Input6Emulated>0</Input6Emulated>
    <Input6EmuKey>0</Input6EmuKey>
    <Input7Active>0</Input7Active>
    <Input7Port>1</Input7Port>
    <Input7Pin>0</Input7Pin>
    <Input7Neg>0</Input7Neg>
    <Input7Emulated>0</Input7Emulated>
    <Input7EmuKey>0</Input7EmuKey>
    <Input8Active>0</Input8Active>
    <Input8Port>1</Input8Port>
    <Input8Pin>0</Input8Pin>
    <Input8Neg>0</Input8Neg>
    <Input8Emulated>0</Input8Emulated>
    <Input8EmuKey>0</Input8EmuKey>
    <Input9Active>0</Input9Active>
    <Input9Port>1</Input9Port>
    <Input9Pin>0</Input9Pin>
    <Input9Neg>0</Input9Neg>
    <Input9Emulated>0</Input9Emulated>
    <Input9EmuKey>0</Input9EmuKey>
    <Input10Active>0</Input10Active>
    <Input10Port>1</Input10Port>
    <Input10Pin>0</Input10Pin>
    <Input10Neg>0</Input10Neg>
    <Input10Emulated>0</Input10Emulated>
    <Input10EmuKey>0</Input10EmuKey>
    <Input11Active>0</Input11Active>
    <Input11Port>1</Input11Port>
    <Input11Pin>0</Input11Pin>
    <Input11Neg>0</Input11Neg>
    <Input11Emulated>0</Input11Emulated>
    <Input11EmuKey>0</Input11EmuKey>
    <Input12Active>0</Input12Active>
    <Input12Port>1</Input12Port>
    <Input12Pin>0</Input12Pin>
    <Input12Neg>0</Input12Neg>
    <Input12Emulated>0</Input12Emulated>
    <Input12EmuKey>0</Input12EmuKey>
    <Input13Active>0</Input13Active>
    <Input13Port>1</Input13Port>
    <Input13Pin>0</Input13Pin>
    <Input13Neg>0</Input13Neg>
    <Input13Emulated>0</Input13Emulated>
    <Input13EmuKey>0</Input13EmuKey>
    <Input14Active>0</Input14Active>
    <Input14Port>1</Input14Port>
    <Input14Pin>0</Input14Pin>
    <Input14Neg>0</Input14Neg>
    <Input14Emulated>0</Input14Emulated>
    <Input14EmuKey>0</Input14EmuKey>
    <Input15Active>0</Input15Active>
    <Input15Port>1</Input15Port>
    <Input15Pin>0</Input15Pin>
    <Input15Neg>0</Input15Neg>
    <Input15Emulated>0</Input15Emulated>
    <Input15EmuKey>0</Input15EmuKey>
    <Input16Active>0</Input16Active>
    <Input16Port>1</Input16Port>
    <Input16Pin>0</Input16Pin>
    <Input16Neg>0</Input16Neg>
    <Input16Emulated>0</Input16Emulated>
    <Input16EmuKey>0</Input16EmuKey>
    <Input17Active>0</Input17Active>
    <Input17Port>1</Input17Port>
    <Input17Pin>0</Input17Pin>
    <Input17Neg>0</Input17Neg>
    <Input17Emulated>0</Input17Emulated>
    <Input17EmuKey>0</Input17EmuKey>
    <Input18Active>0</Input18Active>
    <Input18Port>1</Input18Port>
    <Input18Pin>0</Input18Pin>
    <Input18Neg>0</Input18Neg>
    <Input18Emulated>0</Input18Emulated>
    <Input18EmuKey>0</Input18EmuKey>
    <Input19Active>0</Input19Active>
    <Input19Port>1</Input19Port>
    <Input19Pin>0</Input19Pin>
    <Input19Neg>0</Input19Neg>
    <Input19Emulated>0</Input19Emulated>
    <Input19EmuKey>0</Input19EmuKey>
    <Input20Active>0</Input20Active>
    <Input20Port>1</Input20Port>
    <Input20Pin>0</Input20Pin>
    <Input20Neg>0</Input20Neg>
    <Input20Emulated>0</Input20Emulated>
    <Input20EmuKey>0</Input20EmuKey>
    <Input21Active>0</Input21Active>
    <Input21Port>1</Input21Port>
    <Input21Pin>0</Input21Pin>
    <Input21Neg>0</Input21Neg>
    <Input21Emulated>0</Input21Emulated>
    <Input21EmuKey>0</Input21EmuKey>
    <Input22Active>0</Input22Active>
    <Input22Port>1</Input22Port>
    <Input22Pin>0</Input22Pin>
    <Input22Neg>0</Input22Neg>
    <Input22Emulated>0</Input22Emulated>
    <Input22EmuKey>0</Input22EmuKey>
    <Input23Active>0</Input23Active>
    <Input23Port>1</Input23Port>
    <Input23Pin>0</Input23Pin>
    <Input23Neg>0</Input23Neg>
    <Input23Emulated>0</Input23Emulated>
    <Input23EmuKey>0</Input23EmuKey>
    <Input24Active>0</Input24Active>
    <Input24Port>1</Input24Port>
    <Input24Pin>0</Input24Pin>
    <Input24Neg>0</Input24Neg>
    <Input24Emulated>0</Input24Emulated>
    <Input24EmuKey>0</Input24EmuKey>
    <Input25Active>1</Input25Active>
    <Input25Port>1</Input25Port>
    <Input25Pin>10</Input25Pin>
    <Input25Neg>1</Input25Neg>
    <Input25Emulated>0</Input25Emulated>
    <Input25EmuKey>0</Input25EmuKey>
    <Input26Active>0</Input26Active>
    <Input26Port>1</Input26Port>
    <Input26Pin>0</Input26Pin>
    <Input26Neg>0</Input26Neg>
    <Input26Emulated>0</Input26Emulated>
    <Input26EmuKey>0</Input26EmuKey>
    <Input27Active>0</Input27Active>
    <Input27Port>1</Input27Port>
    <Input27Pin>0</Input27Pin>
    <Input27Neg>0</Input27Neg>
    <Input27Emulated>0</Input27Emulated>
    <Input27EmuKey>0</Input27EmuKey>
    <Input28Active>0</Input28Active>
    <Input28Port>1</Input28Port>
    <Input28Pin>0</Input28Pin>
    <Input28Neg>0</Input28Neg>
    <Input28Emulated>0</Input28Emulated>
    <Input28EmuKey>0</Input28EmuKey>
    <Input29Active>0</Input29Active>
    <Input29Port>1</Input29Port>
    <Input29Pin>0</Input29Pin>
    <Input29Neg>0</Input29Neg>
    <Input29Emulated>0</Input29Emulated>
    <Input29EmuKey>0</Input29EmuKey>
    <Input30Active>0</Input30Active>
    <Input30Port>1</Input30Port>
    <Input30Pin>0</Input30Pin>
    <Input30Neg>0</Input30Neg>
    <Input30Emulated>0</Input30Emulated>
    <Input30EmuKey>0</Input30EmuKey>
    <Input31Active>0</Input31Active>
    <Input31Port>1</Input31Port>
    <Input31Pin>0</Input31Pin>
    <Input31Neg>0</Input31Neg>
    <Input31Emulated>0</Input31Emulated>
    <Input31EmuKey>0</Input31EmuKey>
    <Input32Active>0</Input32Active>
    <Input32Port>1</Input32Port>
    <Input32Pin>0</Input32Pin>
    <Input32Neg>0</Input32Neg>
    <Input32Emulated>0</Input32Emulated>
    <Input32EmuKey>0</Input32EmuKey>
    <Input33Active>0</Input33Active>
    <Input33Port>1</Input33Port>
    <Input33Pin>0</Input33Pin>
    <Input33Neg>0</Input33Neg>
    <Input33Emulated>0</Input33Emulated>
    <Input33EmuKey>0</Input33EmuKey>
    <Input34Active>0</Input34Active>
    <Input34Port>0</Input34Port>
    <Input34Pin>0</Input34Pin>
    <Input34Neg>0</Input34Neg>
    <Input34Emulated>0</Input34Emulated>
    <Input34EmuKey>0</Input34EmuKey>
    <Input35Active>0</Input35Active>
    <Input35Port>0</Input35Port>
    <Input35Pin>0</Input35Pin>
    <Input35Neg>0</Input35Neg>
    <Input35Emulated>0</Input35Emulated>
    <Input35EmuKey>0</Input35EmuKey>
    <Input36Active>0</Input36Active>
    <Input36Port>0</Input36Port>
    <Input36Pin>0</Input36Pin>
    <Input36Neg>0</Input36Neg>
    <Input36Emulated>0</Input36Emulated>
    <Input36EmuKey>0</Input36EmuKey>
    <Input37Active>0</Input37Active>
    <Input37Port>0</Input37Port>
    <Input37Pin>0</Input37Pin>
    <Input37Neg>0</Input37Neg>
    <Input37Emulated>0</Input37Emulated>
    <Input37EmuKey>0</Input37EmuKey>
    <Input38Active>0</Input38Active>
    <Input38Port>0</Input38Port>
    <Input38Pin>0</Input38Pin>
    <Input38Neg>0</Input38Neg>
    <Input38Emulated>0</Input38Emulated>
    <Input38EmuKey>0</Input38EmuKey>
    <Input39Active>0</Input39Active>
    <Input39Port>0</Input39Port>
    <Input39Pin>0</Input39Pin>
    <Input39Neg>0</Input39Neg>
    <Input39Emulated>0</Input39Emulated>
    <Input39EmuKey>0</Input39EmuKey>
    <Input40Active>0</Input40Active>
    <Input40Port>0</Input40Port>
    <Input40Pin>0</Input40Pin>
    <Input40Neg>0</Input40Neg>
    <Input40Emulated>0</Input40Emulated>
    <Input40EmuKey>0</Input40EmuKey>
    <Input41Active>0</Input41Active>
    <Input41Port>0</Input41Port>
    <Input41Pin>0</Input41Pin>
    <Input41Neg>0</Input41Neg>
    <Input41Emulated>0</Input41Emulated>
    <Input41EmuKey>0</Input41EmuKey>
    <Input42Active>0</Input42Active>
    <Input42Port>0</Input42Port>
    <Input42Pin>0</Input42Pin>
    <Input42Neg>0</Input42Neg>
    <Input42Emulated>0</Input42Emulated>
    <Input42EmuKey>0</Input42EmuKey>
    <Input43Active>0</Input43Active>
    <Input43Port>0</Input43Port>
    <Input43Pin>0</Input43Pin>
    <Input43Neg>0</Input43Neg>
    <Input43Emulated>0</Input43Emulated>
    <Input43EmuKey>0</Input43EmuKey>
    <Input44Active>0</Input44Active>
    <Input44Port>0</Input44Port>
    <Input44Pin>0</Input44Pin>
    <Input44Neg>0</Input44Neg>
    <Input44Emulated>0</Input44Emulated>
    <Input44EmuKey>0</Input44EmuKey>
    <Input45Active>0</Input45Active>
    <Input45Port>0</Input45Port>
    <Input45Pin>0</Input45Pin>
    <Input45Neg>0</Input45Neg>
    <Input45Emulated>0</Input45Emulated>
    <Input45EmuKey>0</Input45EmuKey>
    <Input46Active>0</Input46Active>
    <Input46Port>0</Input46Port>
    <Input46Pin>0</Input46Pin>
    <Input46Neg>0</Input46Neg>
    <Input46Emulated>0</Input46Emulated>
    <Input46EmuKey>0</Input46EmuKey>
    <Input47Active>0</Input47Active>
    <Input47Port>0</Input47Port>
    <Input47Pin>0</Input47Pin>
    <Input47Neg>0</Input47Neg>
    <Input47Emulated>0</Input47Emulated>
    <Input47EmuKey>0</Input47EmuKey>
    <Input48Active>0</Input48Active>
    <Input48Port>0</Input48Port>
    <Input48Pin>0</Input48Pin>
    <Input48Neg>0</Input48Neg>
    <Input48Emulated>0</Input48Emulated>
    <Input48EmuKey>0</Input48EmuKey>
    <Input49Active>0</Input49Active>
    <Input49Port>0</Input49Port>
    <Input49Pin>0</Input49Pin>
    <Input49Neg>0</Input49Neg>
    <Input49Emulated>0</Input49Emulated>
    <Input49EmuKey>0</Input49EmuKey>
    <Input50Active>0</Input50Active>
    <Input50Port>0</Input50Port>
    <Input50Pin>0</Input50Pin>
    <Input50Neg>0</Input50Neg>
    <Input50Emulated>0</Input50Emulated>
    <Input50EmuKey>0</Input50EmuKey>
    <Input51Active>0</Input51Active>
    <Input51Port>0</Input51Port>
    <Input51Pin>0</Input51Pin>
    <Input51Neg>0</Input51Neg>
    <Input51Emulated>0</Input51Emulated>
    <Input51EmuKey>0</Input51EmuKey>
    <Input52Active>0</Input52Active>
    <Input52Port>0</Input52Port>
    <Input52Pin>0</Input52Pin>
    <Input52Neg>0</Input52Neg>
    <Input52Emulated>0</Input52Emulated>
    <Input52EmuKey>0</Input52EmuKey>
    <Output0Active>0</Output0Active>
    <Output0Port>1</Output0Port>
    <Output0Pin>0</Output0Pin>
    <Output0Neg>0</Output0Neg>
    <Output1Active>0</Output1Active>
    <Output1Port>1</Output1Port>
    <Output1Pin>0</Output1Pin>
    <Output1Neg>0</Output1Neg>
    <Output2Active>0</Output2Active>
    <Output2Port>1</Output2Port>
    <Output2Pin>0</Output2Pin>
    <Output2Neg>0</Output2Neg>
    <Output3Active>0</Output3Active>
    <Output3Port>1</Output3Port>
    <Output3Pin>0</Output3Pin>
    <Output3Neg>0</Output3Neg>
    <Output4Active>0</Output4Active>
    <Output4Port>1</Output4Port>
    <Output4Pin>0</Output4Pin>
    <Output4Neg>0</Output4Neg>
    <Output5Active>0</Output5Active>
    <Output5Port>1</Output5Port>
    <Output5Pin>0</Output5Pin>
    <Output5Neg>0</Output5Neg>
    <Output6Active>0</Output6Active>
    <Output6Port>1</Output6Port>
    <Output6Pin>0</Output6Pin>
    <Output6Neg>0</Output6Neg>
    <Output7Active>1</Output7Active>
    <Output7Port>1</Output7Port>
    <Output7Pin>0</Output7Pin>
    <Output7Neg>0</Output7Neg>
    <Output8Active>0</Output8Active>
    <Output8Port>1</Output8Port>
    <Output8Pin>0</Output8Pin>
    <Output8Neg>0</Output8Neg>
    <Output9Active>0</Output9Active>
    <Output9Port>1</Output9Port>
    <Output9Pin>0</Output9Pin>
    <Output9Neg>0</Output9Neg>
    <Output10Active>0</Output10Active>
    <Output10Port>1</Output10Port>
    <Output10Pin>0</Output10Pin>
    <Output10Neg>0</Output10Neg>
    <Output11Active>0</Output11Active>
    <Output11Port>1</Output11Port>
    <Output11Pin>0</Output11Pin>
    <Output11Neg>0</Output11Neg>
    <Output12Active>0</Output12Active>
    <Output12Port>1</Output12Port>
    <Output12Pin>0</Output12Pin>
    <Output12Neg>0</Output12Neg>
    <Output13Active>0</Output13Active>
    <Output13Port>1</Output13Port>
    <Output13Pin>0</Output13Pin>
    <Output13Neg>0</Output13Neg>
    <Output14Active>0</Output14Active>
    <Output14Port>1</Output14Port>
    <Output14Pin>0</Output14Pin>
    <Output14Neg>0</Output14Neg>
    <Output15Active>0</Output15Active>
    <Output15Port>1</Output15Port>
    <Output15Pin>0</Output15Pin>
    <Output15Neg>0</Output15Neg>
    <Output16Active>0</Output16Active>
    <Output16Port>1</Output16Port>
    <Output16Pin>0</Output16Pin>
    <Output16Neg>0</Output16Neg>
    <Output17Active>0</Output17Active>
    <Output17Port>1</Output17Port>
    <Output17Pin>0</Output17Pin>
    <Output17Neg>0</Output17Neg>
    <Output18Active>0</Output18Active>
    <Output18Port>1</Output18Port>
    <Output18Pin>0</Output18Pin>
    <Output18Neg>0</Output18Neg>
    <Output19Active>0</Output19Active>
    <Output19Port>1</Output19Port>
    <Output19Pin>0</Output19Pin>
    <Output19Neg>0</Output19Neg>
    <Output20Active>0</Output20Active>
    <Output20Port>1</Output20Port>
    <Output20Pin>0</Output20Pin>
    <Output20Neg>0</Output20Neg>
    <Output21Active>0</Output21Active>
    <Output21Port>1</Output21Port>
    <Output21Pin>0</Output21Pin>
    <Output21Neg>0</Output21Neg>
    <Output22Active>0</Output22Active>
    <Output22Port>1</Output22Port>
    <Output22Pin>0</Output22Pin>
    <Output22Neg>0</Output22Neg>
    <Output23Active>0</Output23Active>
    <Output23Port>1</Output23Port>
    <Output23Pin>0</Output23Pin>
    <Output23Neg>0</Output23Neg>
    <Output24Active>0</Output24Active>
    <Output24Port>1</Output24Port>
    <Output24Pin>0</Output24Pin>
    <Output24Neg>0</Output24Neg>
    <Output25Active>0</Output25Active>
    <Output25Port>1</Output25Port>
    <Output25Pin>0</Output25Pin>
    <Output25Neg>0</Output25Neg>
    <Output26Active>0</Output26Active>
    <Output26Port>1</Output26Port>
    <Output26Pin>0</Output26Pin>
    <Output26Neg>0</Output26Neg>
    <Output27Active>0</Output27Active>
    <Output27Port>1</Output27Port>
    <Output27Pin>0</Output27Pin>
    <Output27Neg>0</Output27Neg>
    <Output28Active>0</Output28Active>
    <Output28Port>1</Output28Port>
    <Output28Pin>0</Output28Pin>
    <Output28Neg>0</Output28Neg>
    <Output29Active>0</Output29Active>
    <Output29Port>1</Output29Port>
    <Output29Pin>0</Output29Pin>
    <Output29Neg>0</Output29Neg>
    <Output30Active>0</Output30Active>
    <Output30Port>0</Output30Port>
    <Output30Pin>0</Output30Pin>
    <Output30Neg>0</Output30Neg>
    <Encoder0Active>0</Encoder0Active>
    <Encoder0APort>0</Encoder0APort>
    <Encoder0APin>0</Encoder0APin>
    <Encoder0BPort>0</Encoder0BPort>
    <Encoder0BPin>0</Encoder0BPin>
    <Encoder0Cal>1.000000</Encoder0Cal>
    <Encoder1Active>0</Encoder1Active>
    <Encoder1APort>0</Encoder1APort>
    <Encoder1APin>0</Encoder1APin>
    <Encoder1BPort>0</Encoder1BPort>
    <Encoder1BPin>0</Encoder1BPin>
    <Encoder1Cal>1.000000</Encoder1Cal>
    <Encoder2Active>0</Encoder2Active>
    <Encoder2APort>0</Encoder2APort>
    <Encoder2APin>0</Encoder2APin>
    <Encoder2BPort>0</Encoder2BPort>
    <Encoder2BPin>0</Encoder2BPin>
    <Encoder2Cal>1.000000</Encoder2Cal>
    <Encoder3Active>0</Encoder3Active>
    <Encoder3APort>0</Encoder3APort>
    <Encoder3APin>0</Encoder3APin>
    <Encoder3BPort>0</Encoder3BPort>
    <Encoder3BPin>0</Encoder3BPin>
    <Encoder3Cal>1.000000</Encoder3Cal>
    <Encoder4Active>0</Encoder4Active>
    <Encoder4APort>0</Encoder4APort>
    <Encoder4APin>0</Encoder4APin>
    <Encoder4BPort>0</Encoder4BPort>
    <Encoder4BPin>0</Encoder4BPin>
    <Encoder4Cal>1.000000</Encoder4Cal>
    <Encoder5Active>0</Encoder5Active>
    <Encoder5APort>0</Encoder5APort>
    <Encoder5APin>0</Encoder5APin>
    <Encoder5BPort>0</Encoder5BPort>
    <Encoder5BPin>0</Encoder5BPin>
    <Encoder5Cal>1.000000</Encoder5Cal>
    <Encoder6Active>0</Encoder6Active>
    <Encoder6APort>0</Encoder6APort>
    <Encoder6APin>0</Encoder6APin>
    <Encoder6BPort>0</Encoder6BPort>
    <Encoder6BPin>0</Encoder6BPin>
    <Encoder6Cal>1.000000</Encoder6Cal>
    <Encoder7Active>0</Encoder7Active>
    <Encoder7APort>0</Encoder7APort>
    <Encoder7APin>0</Encoder7APin>
    <Encoder7BPort>0</Encoder7BPort>
    <Encoder7BPin>0</Encoder7BPin>
    <Encoder7Cal></Encoder7Cal>
    <Configured>1</Configured>
    <SlavePrim>0</SlavePrim>
    <Slave>-1</Slave>
    <AxisKeys0>39</AxisKeys0>
    <AxisKeys1>37</AxisKeys1>
    <AxisKeys2>38</AxisKeys2>
    <AxisKeys3>40</AxisKeys3>
    <AxisKeys4>33</AxisKeys4>
    <AxisKeys5>34</AxisKeys5>
    <AxisKeys6>45</AxisKeys6>
    <AxisKeys7>46</AxisKeys7>
    <AxisKeys8>999</AxisKeys8>
    <AxisKeys9>999</AxisKeys9>
    <AxisKeys10>999</AxisKeys10>
    <AxisKeys11>999</AxisKeys11>
    <DROHotKey>999</DROHotKey>
    <ListKey>999</ListKey>
    <MDIHotKey>999</MDIHotKey>
    <GCodeHotKey>999</GCodeHotKey>
    <OEM1>-1</OEM1>
    <OEM2>-1</OEM2>
    <OEM3>-1</OEM3>
    <OEM4>-1</OEM4>
    <OEM5>-1</OEM5>
    <OEM6>-1</OEM6>
    <PulseWidth>2392</PulseWidth>
    <DirPulse>0</DirPulse>
    <BackX>1.e-003</BackX>
    <BackY>3.e-003</BackY>
    <BackZ>1.e-003</BackZ>
    <BackA>0.</BackA>
    <BackB>0.</BackB>
    <BackC>0.</BackC>
    <BackSpeed>100.</BackSpeed>
    <BB>0.</BB>
    <BR>0.</BR>
    <BG>0.</BG>
    <FB>1.</FB>
    <FR>0.</FR>
    <FG>0.</FG>
    <RB>0.</RB>
    <RR>1.</RR>
    <RG>0.</RG>
    <AB>0.7</AB>
    <AR>0.7</AR>
    <AG>0.2</AG>
    <EG>1.</EG>
    <ER>1.</ER>
    <EB>0.</EB>
    <JogFollow>0</JogFollow>
    <G92Off>1</G92Off>
    <RadiusCompOff>1</RadiusCompOff>
    <Debounce>0</Debounce>
    <PlasmaMode>0</PlasmaMode>
    <NoAngle>0</NoAngle>
    <AAngular>1</AAngular>
    <BAngular>1</BAngular>
    <CAngular>1</CAngular>
    <IndexDebounce>0</IndexDebounce>
    <DROPERSIST>1</DROPERSIST>
    <DwellinMilli>0</DwellinMilli>
    <IJMode>0</IJMode>
    <INIT>G80</INIT>
    <InitAllResets>0</InitAllResets>
    <AutoScreens>0</AutoScreens>
    <TORCHVON>0</TORCHVON>
    <TORCHVOLTS>1000</TORCHVOLTS>
    <HWSAFE>1</HWSAFE>
    <ShortRot>0</ShortRot>
    <LookAhead>20</LookAhead>
    <WatchDog>1</WatchDog>
    <Plane>0</Plane>
    <MPG1>0</MPG1>
    <MPG2>0</MPG2>
    <HotKeysPersist>0</HotKeysPersist>
    <HoldInput1>0</HoldInput1>
    <M3s>1458</M3s>
    <UseCR>0</UseCR>
    <PlasmaHome>0</PlasmaHome>
    <Homann>0</Homann>
    <UseSLS>0</UseSLS>
    <Dist0>6.5e+004</Dist0>
    <Dist1>1.7e+004</Dist1>
    <Dist2>1.e+004</Dist2>
    <Dist3>5.7e+004</Dist3>
    <Dist4>0.</Dist4>
    <Dist5>0.</Dist5>
    <OverMode2>0</OverMode2>
    <BitPack1>0</BitPack1>
    <BitPack1Reg>16</BitPack1Reg>
    <BitPackOut>0</BitPackOut>
    <BitPackOutReg>16</BitPackOutReg>
    <LaserPort>1</LaserPort>
    <LaserBaud>9600</LaserBaud>
    <LaserStops>1</LaserStops>
    <LaserData>1</LaserData>
    <LaserInit>&gt;</LaserInit>
    <LaserCommand>&gt;</LaserCommand>
    <MacroPump>0</MacroPump>
    <VelMode>0</VelMode>
    <VelPer1>5.</VelPer1>
    <VelPer2>5.</VelPer2>
    <MPGFeed>1.</MPGFeed>
    <ModSpindleCal>1.638e+004</ModSpindleCal>
    <ModSpindleOn>0</ModSpindleOn>
    <ModSpindleReg>64</ModSpindleReg>
    <ShuttleAccel>409600</ShuttleAccel>
    <Flash>1</Flash>
    <ImmediateOff>0</ImmediateOff>
    <UseSafeZ>0</UseSafeZ>
    <AdvancedComp>1</AdvancedComp>
    <TorchOff>0</TorchOff>
    <LaserStandby>0</LaserStandby>
    <RaiseLower>0</RaiseLower>
    <OEMDUAL>0</OEMDUAL>
    <IncBuffer>5</IncBuffer>
    <Formula0>x</Formula0>
    <Formula1>y</Formula1>
    <Formula2>z</Formula2>
    <Formula3>a</Formula3>
    <Formula4>b</Formula4>
    <Formula5>c</Formula5>
    <Formular>0</Formular>
    <PanelOut>249</PanelOut>
    <nModBusReg>0</nModBusReg>
    <ModBusRegOn>0</ModBusRegOn>
    <Tool>0</Tool>
    <Sherline>0</Sherline>
    <ToolPost>1</ToolPost>
    <RapidOverRide>0</RapidOverRide>
    <XCLength>1.3e+003</XCLength>
    <YCLength>1.3e+003</YCLength>
    <ZCLength>1.3e+003</ZCLength>
    <ToolPostOffset>0.</ToolPostOffset>
    <OEM7>-1</OEM7>
    <OEM8>-1</OEM8>
    <OEM9>-1</OEM9>
    <OEM10>-1</OEM10>
    <OEM11>-1</OEM11>
    <OEM12>-1</OEM12>
    <OEM13>-1</OEM13>
    <OEM14>-1</OEM14>
    <OEM15>-1</OEM15>
    <MPGVel0>1.e+002</MPGVel0>
    <MPGVel1>1.e+002</MPGVel1>
    <MPGVel2>1.e+002</MPGVel2>
    <MPGVel3>1.e+002</MPGVel3>
    <MPGVel4>1.e+002</MPGVel4>
    <MPGVel5>1.e+002</MPGVel5>
    <MPGVel6>1.e+002</MPGVel6>
    <ByPassFeed>1.e+003</ByPassFeed>
    <XMapOn>0</XMapOn>
    <YMapOn>0</YMapOn>
    <ZMapOn>0</ZMapOn>
    <SecondsOn>1551243</SecondsOn>
    <SerialType>0</SerialType>
    <SpinAverage>0</SpinAverage>
    <Dig4Axis>0</Dig4Axis>
    <DigLetter>0</DigLetter>
    <CutType>0</CutType>
    <InfeedType>0</InfeedType>
    <LastWizard>C:\Mach3\Addons\Write\Write.set</LastWizard>
    <Z25D>0</Z25D>
    <ModBus>0</ModBus>
    <ChargeAlwaysOn>0</ChargeAlwaysOn>
    <ToolFlip>0</ToolFlip>
    <SpinCCW>7</SpinCCW>
    <SpinCW>7</SpinCW>
    <Flood>9</Flood>
    <Mist>10</Mist>
    <SpinActual>0</SpinActual>
    <SpinDelayCW>1.</SpinDelayCW>
    <SpinDelayCCW>1.</SpinDelayCCW>
    <SpinDownCW>1.</SpinDownCW>
    <SpinDownCCW>1.</SpinDownCCW>
    <StockSize>50</StockSize>
    <ShowSolid>0</ShowSolid>
    <RapidFeed>1.e+003</RapidFeed>
    <MatRed>0.</MatRed>
    <MatGreen>0.1</MatGreen>
    <MatBlue>0.1</MatBlue>
    <SpinP>0.25</SpinP>
    <SpinI>1.</SpinI>
    <SpinD>0.3</SpinD>
    <SpinClosed>0</SpinClosed>
    <MinPerPass>0.1</MinPerPass>
    <NoSpindle>0</NoSpindle>
    <NoFlood>1</NoFlood>
    <PWMin>0</PWMin>
    <PULLEY>3</PULLEY>
    <SPEED1>1000</SPEED1>
    <SPEED2>2000</SPEED2>
    <SPEED3>4000</SPEED3>
    <SPEED4>8000</SPEED4>
    <LSPEED1>0</LSPEED1>
    <LSPEED2>0</LSPEED2>
    <LSPEED3>0</LSPEED3>
    <LSPEED4>0</LSPEED4>
    <PWM>0</PWM>
    <RefSpeed0>20</RefSpeed0>
    <RefSpeed1>20</RefSpeed1>
    <RefSpeed2>20</RefSpeed2>
    <RefSpeed3>20</RefSpeed3>
    <RefSpeed4>20</RefSpeed4>
    <RefSpeed5>20</RefSpeed5>
    <M0SoftRamp>1.</M0SoftRamp>
    <M1SoftRamp>1.</M1SoftRamp>
    <M2SoftRamp>1.</M2SoftRamp>
    <M3SoftRamp>1.</M3SoftRamp>
    <M4SoftRamp>1.</M4SoftRamp>
    <M5SoftRamp>1.</M5SoftRamp>
    <FeedInc>5.</FeedInc>
    <DepthLastPass>0.</DepthLastPass>
    <InFeed>29.5</InFeed>
    <Spring>1.</Spring>
    <MinDepth>1.e-003</MinDepth>
    <XClear>0.1</XClear>
    <ZClear>0.1</ZClear>
    <CutDepth>0.1</CutDepth>
    <Chamfer>0.</Chamfer>
    <DepthFirstPass>0.1</DepthFirstPass>
    <M0Max>100.</M0Max>
    <M1Max>100.</M1Max>
    <M2Max>100.</M2Max>
    <M3Max>100.</M3Max>
    <M4Max>100.</M4Max>
    <M5Max>100.</M5Max>
    <M0Min>-100.</M0Min>
    <M1Min>-100.</M1Min>
    <M2Min>-100.</M2Min>
    <M3Min>-100.</M3Min>
    <M4Min>-100.</M4Min>
    <M5Min>-100.</M5Min>
    <M0Neg>0</M0Neg>
    <M1Neg>0</M1Neg>
    <M2Neg>0</M2Neg>
    <M3Neg>0</M3Neg>
    <M4Neg>0</M4Neg>
    <M5Neg>0</M5Neg>
    <M0AutoZero>1</M0AutoZero>
    <M1AutoZero>1</M1AutoZero>
    <M2AutoZero>1</M2AutoZero>
    <M3AutoZero>1</M3AutoZero>
    <M4AutoZero>1</M4AutoZero>
    <M5AutoZero>1</M5AutoZero>
    <M0Rev>0</M0Rev>
    <M1Rev>0</M1Rev>
    <M2Rev>0</M2Rev>
    <M3Rev>0</M3Rev>
    <M4Rev>0</M4Rev>
    <M5Rev>0</M5Rev>
    <M6Rev>0</M6Rev>
    <OffPersist>1</OffPersist>
    <Diameter>0</Diameter>
    <OffDialogs>1</OffDialogs>
    <G54Back>0</G54Back>
    <GougeCheck>0</GougeCheck>
    <AxisToMotor0>0</AxisToMotor0>
    <AxisToMotor1>1</AxisToMotor1>
    <AxisToMotor2>2</AxisToMotor2>
    <AxisToMotor3>3</AxisToMotor3>
    <AxisToMotor4>4</AxisToMotor4>
    <AxisToMotor5>5</AxisToMotor5>
    <AxisToMotor6>6</AxisToMotor6>
    <JogActive>1</JogActive>
    <BLState0>1</BLState0>
    <BLState1>1</BLState1>
    <BLState2>0</BLState2>
    <BLState3>1</BLState3>
    <BLState4>0</BLState4>
    <BLState5>0</BLState5>
    <SlowMode>0</SlowMode>
    <JogPersist>1</JogPersist>
    <ToolRotations>1</ToolRotations>
    <SoftLimit>0</SoftLimit>
    <JogMode>0</JogMode>
    <JogMode2>0</JogMode2>
    <EncJogAxis2>2</EncJogAxis2>
    <TaperRatio>1.</TaperRatio>
    <XStart>-30642</XStart>
    <YStart>-14655</YStart>
    <ZStart>-67948</ZStart>
    <AStart>38802</AStart>
    <BStart>0</BStart>
    <CStart>0</CStart>
    <SpinInc>10</SpinInc>
    <Enc0>0.</Enc0>
    <Enc1>0.</Enc1>
    <Enc2>0.</Enc2>
    <Enc3>0.</Enc3>
    <TangentalControl>0</TangentalControl>
    <BaudRate>9600</BaudRate>
    <ComPort>1</ComPort>
    <NoPlunge>0</NoPlunge>
    <PlungeLimit>60</PlungeLimit>
    <AutoTool>0</AutoTool>
    <AutoSpindle>0</AutoSpindle>
    <LaserMode>0</LaserMode>
    <FeedMode>0</FeedMode>
    <OriginSphere>0</OriginSphere>
    <m_3dCompass>1</m_3dCompass>
    <Boundries>0</Boundries>
    <ToolPosition>1</ToolPosition>
    <AParallel>0</AParallel>
    <ZINHPersist>0</ZINHPersist>
    <OVPersist>1</OVPersist>
    <BacklashOn>0</BacklashOn>
    <PathMode>2</PathMode>
    <ThrottleFunc>2</ThrottleFunc>
    <JoyOn>0</JoyOn>
    <PWMBase>5000</PWMBase>
    <JogSpeed>100.</JogSpeed>
    <G73PullBack>0.1</G73PullBack>
    <CVFeedOn>0</CVFeedOn>
    <CVFeedRate>1.</CVFeedRate>
    <AtoX>0.</AtoX>
    <AtoY>0.</AtoY>
    <AtoZ>0.</AtoZ>
    <OEMDRO0>0.</OEMDRO0>
    <OEMLED0>0</OEMLED0>
    <OEMDRO1>0.</OEMDRO1>
    <OEMLED1>0</OEMLED1>
    <OEMDRO2>0.</OEMDRO2>
    <OEMLED2>0</OEMLED2>
    <OEMDRO3>0.</OEMDRO3>
    <OEMLED3>0</OEMLED3>
    <OEMDRO4>0.</OEMDRO4>
    <OEMLED4>0</OEMLED4>
    <OEMDRO5>0.</OEMDRO5>
    <OEMLED5>0</OEMLED5>
    <OEMDRO6>0.</OEMDRO6>
    <OEMLED6>0</OEMLED6>
    <OEMDRO7>0.</OEMDRO7>
    <OEMLED7>0</OEMLED7>
    <OEMDRO8>0.</OEMDRO8>
    <OEMLED8>0</OEMLED8>
    <OEMDRO9>0.</OEMDRO9>
    <OEMLED9>0</OEMLED9>
    <OEMDRO10>0.</OEMDRO10>
    <OEMLED10>0</OEMLED10>
    <OEMDRO11>0.</OEMDRO11>
    <OEMLED11>0</OEMLED11>
    <OEMDRO12>0.</OEMDRO12>
    <OEMLED12>0</OEMLED12>
    <OEMDRO13>0.</OEMDRO13>
    <OEMLED13>0</OEMLED13>
    <OEMDRO14>0.</OEMDRO14>
    <OEMLED14>0</OEMLED14>
    <OEMDRO15>0.</OEMDRO15>
    <OEMLED15>0</OEMLED15>
    <OEMDRO16>0.</OEMDRO16>
    <OEMLED16>0</OEMLED16>
    <OEMDRO17>0.</OEMDRO17>
    <OEMLED17>0</OEMLED17>
    <OEMDRO18>0.</OEMDRO18>
    <OEMLED18>0</OEMLED18>
    <OEMDRO19>0.</OEMDRO19>
    <OEMLED19>0</OEMLED19>
    <OEMDRO20>0.</OEMDRO20>
    <OEMLED20>0</OEMLED20>
    <OEMDRO21>0.</OEMDRO21>
    <OEMLED21>0</OEMLED21>
    <OEMDRO22>0.</OEMDRO22>
    <OEMLED22>0</OEMLED22>
    <OEMDRO23>0.</OEMDRO23>
    <OEMLED23>0</OEMLED23>
    <OEMDRO24>0.</OEMDRO24>
    <OEMLED24>0</OEMLED24>
    <OEMDRO25>0.</OEMDRO25>
    <OEMLED25>0</OEMLED25>
    <OEMDRO26>0.</OEMDRO26>
    <OEMLED26>0</OEMLED26>
    <OEMDRO27>0.</OEMDRO27>
    <OEMLED27>0</OEMLED27>
    <OEMDRO28>0.</OEMDRO28>
    <OEMLED28>0</OEMLED28>
    <OEMDRO29>0.</OEMDRO29>
    <OEMLED29>0</OEMLED29>
    <OEMDRO30>0.</OEMDRO30>
    <OEMLED30>0</OEMLED30>
    <OEMDRO31>0.</OEMDRO31>
    <OEMLED31>0</OEMLED31>
    <OEMDRO32>0.</OEMDRO32>
    <OEMLED32>0</OEMLED32>
    <OEMDRO33>0.</OEMDRO33>
    <OEMLED33>0</OEMLED33>
    <OEMDRO34>0.</OEMDRO34>
    <OEMLED34>0</OEMLED34>
    <OEMDRO35>0.</OEMDRO35>
    <OEMLED35>0</OEMLED35>
    <OEMDRO36>0.</OEMDRO36>
    <OEMLED36>0</OEMLED36>
    <OEMDRO37>0.</OEMDRO37>
    <OEMLED37>0</OEMLED37>
    <OEMDRO38>0.</OEMDRO38>
    <OEMLED38>0</OEMLED38>
    <OEMDRO39>0.</OEMDRO39>
    <OEMLED39>0</OEMLED39>
    <OEMDRO40>0.</OEMDRO40>
    <OEMLED40>0</OEMLED40>
    <OEMDRO41>0.</OEMDRO41>
    <OEMLED41>0</OEMLED41>
    <OEMDRO42>0.</OEMDRO42>
    <OEMLED42>0</OEMLED42>
    <OEMDRO43>0.</OEMDRO43>
    <OEMLED43>0</OEMLED43>
    <OEMDRO44>0.</OEMDRO44>
    <OEMLED44>0</OEMLED44>
    <OEMDRO45>0.</OEMDRO45>
    <OEMLED45>0</OEMLED45>
    <OEMDRO46>0.</OEMDRO46>
    <OEMLED46>0</OEMLED46>
    <OEMDRO47>0.</OEMDRO47>
    <OEMLED47>0</OEMLED47>
    <OEMDRO48>0.</OEMDRO48>
    <OEMLED48>0</OEMLED48>
    <OEMDRO49>0.</OEMDRO49>
    <OEMLED49>0</OEMLED49>
    <OEMDRO50>0.</OEMDRO50>
    <OEMLED50>0</OEMLED50>
    <OEMDRO51>0.</OEMDRO51>
    <OEMLED51>0</OEMLED51>
    <OEMDRO52>0.</OEMDRO52>
    <OEMLED52>0</OEMLED52>
    <OEMDRO53>0.</OEMDRO53>
    <OEMLED53>0</OEMLED53>
    <OEMDRO54>0.</OEMDRO54>
    <OEMLED54>0</OEMLED54>
    <OEMDRO55>0.</OEMDRO55>
    <OEMLED55>0</OEMLED55>
    <OEMDRO56>0.</OEMDRO56>
    <OEMLED56>0</OEMLED56>
    <OEMDRO57>0.</OEMDRO57>
    <OEMLED57>0</OEMLED57>
    <OEMDRO58>0.</OEMDRO58>
    <OEMLED58>0</OEMLED58>
    <OEMDRO59>0.</OEMDRO59>
    <OEMLED59>0</OEMLED59>
    <OEMDRO60>0.</OEMDRO60>
    <OEMLED60>0</OEMLED60>
    <OEMDRO61>0.</OEMDRO61>
    <OEMLED61>0</OEMLED61>
    <OEMDRO62>0.</OEMDRO62>
    <OEMLED62>0</OEMLED62>
    <OEMDRO63>0.</OEMDRO63>
    <OEMLED63>0</OEMLED63>
    <OEMDRO64>0.</OEMDRO64>
    <OEMLED64>0</OEMLED64>
    <OEMDRO65>0.</OEMDRO65>
    <OEMLED65>0</OEMLED65>
    <OEMDRO66>0.</OEMDRO66>
    <OEMLED66>0</OEMLED66>
    <OEMDRO67>0.</OEMDRO67>
    <OEMLED67>0</OEMLED67>
    <OEMDRO68>0.</OEMDRO68>
    <OEMLED68>0</OEMLED68>
    <OEMDRO69>0.</OEMDRO69>
    <OEMLED69>0</OEMLED69>
    <OEMDRO70>0.</OEMDRO70>
    <OEMLED70>0</OEMLED70>
    <OEMDRO71>0.</OEMDRO71>
    <OEMLED71>0</OEMLED71>
    <OEMDRO72>0.</OEMDRO72>
    <OEMLED72>0</OEMLED72>
    <OEMDRO73>0.</OEMDRO73>
    <OEMLED73>0</OEMLED73>
    <OEMDRO74>0.</OEMDRO74>
    <OEMLED74>0</OEMLED74>
    <OEMDRO75>0.</OEMDRO75>
    <OEMLED75>0</OEMLED75>
    <OEMDRO76>0.</OEMDRO76>
    <OEMLED76>0</OEMLED76>
    <OEMDRO77>0.</OEMDRO77>
    <OEMLED77>0</OEMLED77>
    <OEMDRO78>0.</OEMDRO78>
    <OEMLED78>0</OEMLED78>
    <OEMDRO79>0.</OEMDRO79>
    <OEMLED79>0</OEMLED79>
    <OEMDRO80>0.</OEMDRO80>
    <OEMLED80>0</OEMLED80>
    <OEMDRO81>0.</OEMDRO81>
    <OEMLED81>0</OEMLED81>
    <OEMDRO82>0.</OEMDRO82>
    <OEMLED82>0</OEMLED82>
    <OEMDRO83>0.</OEMDRO83>
    <OEMLED83>0</OEMLED83>
    <OEMDRO84>0.</OEMDRO84>
    <OEMLED84>0</OEMLED84>
    <OEMDRO85>0.</OEMDRO85>
    <OEMLED85>0</OEMLED85>
    <OEMDRO86>0.</OEMDRO86>
    <OEMLED86>0</OEMLED86>
    <OEMDRO87>0.</OEMDRO87>
    <OEMLED87>0</OEMLED87>
    <OEMDRO88>0.</OEMDRO88>
    <OEMLED88>0</OEMLED88>
    <OEMDRO89>0.</OEMDRO89>
    <OEMLED89>0</OEMLED89>
    <OEMDRO90>0.</OEMDRO90>
    <OEMLED90>0</OEMLED90>
    <OEMDRO91>0.</OEMDRO91>
    <OEMLED91>0</OEMLED91>
    <OEMDRO92>0.</OEMDRO92>
    <OEMLED92>0</OEMLED92>
    <OEMDRO93>0.</OEMDRO93>
    <OEMLED93>0</OEMLED93>
    <OEMDRO94>0.</OEMDRO94>
    <OEMLED94>0</OEMLED94>
    <OEMDRO95>0.</OEMDRO95>
    <OEMLED95>0</OEMLED95>
    <OEMDRO96>0.</OEMDRO96>
    <OEMLED96>0</OEMLED96>
    <OEMDRO97>0.</OEMDRO97>
    <OEMLED97>0</OEMLED97>
    <OEMDRO98>0.</OEMDRO98>
    <OEMLED98>0</OEMLED98>
    <OEMDRO99>0.</OEMDRO99>
    <OEMLED99>0</OEMLED99>
    <OEMDRO100>0.</OEMDRO100>
    <OEMLED100>0</OEMLED100>
    <OEMDRO101>0.</OEMDRO101>
    <OEMLED101>0</OEMLED101>
    <OEMDRO102>0.</OEMDRO102>
    <OEMLED102>0</OEMLED102>
    <OEMDRO103>0.</OEMDRO103>
    <OEMLED103>0</OEMLED103>
    <OEMDRO104>0.</OEMDRO104>
    <OEMLED104>0</OEMLED104>
    <OEMDRO105>0.</OEMDRO105>
    <OEMLED105>0</OEMLED105>
    <OEMDRO106>0.</OEMDRO106>
    <OEMLED106>0</OEMLED106>
    <OEMDRO107>0.</OEMDRO107>
    <OEMLED107>0</OEMLED107>
    <OEMDRO108>0.</OEMDRO108>
    <OEMLED108>0</OEMLED108>
    <OEMDRO109>0.</OEMDRO109>
    <OEMLED109>0</OEMLED109>
    <OEMDRO110>0.</OEMDRO110>
    <OEMLED110>0</OEMLED110>
    <OEMDRO111>0.</OEMDRO111>
    <OEMLED111>0</OEMLED111>
    <OEMDRO112>0.</OEMDRO112>
    <OEMLED112>0</OEMLED112>
    <OEMDRO113>0.</OEMDRO113>
    <OEMLED113>0</OEMLED113>
    <OEMDRO114>0.</OEMDRO114>
    <OEMLED114>0</OEMLED114>
    <OEMDRO115>0.</OEMDRO115>
    <OEMLED115>0</OEMLED115>
    <OEMDRO116>0.</OEMDRO116>
    <OEMLED116>0</OEMLED116>
    <OEMDRO117>0.</OEMDRO117>
    <OEMLED117>0</OEMLED117>
    <OEMDRO118>0.</OEMDRO118>
    <OEMLED118>0</OEMLED118>
    <OEMDRO119>0.</OEMDRO119>
    <OEMLED119>0</OEMLED119>
    <OEMDRO120>0.</OEMDRO120>
    <OEMLED120>0</OEMLED120>
    <OEMDRO121>0.</OEMDRO121>
    <OEMLED121>0</OEMLED121>
    <OEMDRO122>0.</OEMDRO122>
    <OEMLED122>0</OEMLED122>
    <OEMDRO123>0.</OEMDRO123>
    <OEMLED123>0</OEMLED123>
    <OEMDRO124>0.</OEMDRO124>
    <OEMLED124>0</OEMLED124>
    <OEMDRO125>0.</OEMDRO125>
    <OEMLED125>0</OEMLED125>
    <OEMDRO126>0.</OEMDRO126>
    <OEMLED126>0</OEMLED126>
    <OEMDRO127>0.</OEMDRO127>
    <OEMLED127>0</OEMLED127>
    <OEMDRO128>0.</OEMDRO128>
    <OEMLED128>0</OEMLED128>
    <OEMDRO129>0.</OEMDRO129>
    <OEMLED129>0</OEMLED129>
    <OEMDRO130>0.</OEMDRO130>
    <OEMLED130>0</OEMLED130>
    <OEMDRO131>0.</OEMDRO131>
    <OEMLED131>0</OEMLED131>
    <OEMDRO132>0.</OEMDRO132>
    <OEMLED132>0</OEMLED132>
    <OEMDRO133>0.</OEMDRO133>
    <OEMLED133>0</OEMLED133>
    <OEMDRO134>0.</OEMDRO134>
    <OEMLED134>0</OEMLED134>
    <OEMDRO135>0.</OEMDRO135>
    <OEMLED135>0</OEMLED135>
    <OEMDRO136>0.</OEMDRO136>
    <OEMLED136>0</OEMLED136>
    <OEMDRO137>0.</OEMDRO137>
    <OEMLED137>0</OEMLED137>
    <OEMDRO138>0.</OEMDRO138>
    <OEMLED138>0</OEMLED138>
    <OEMDRO139>0.</OEMDRO139>
    <OEMLED139>0</OEMLED139>
    <OEMDRO140>0.</OEMDRO140>
    <OEMLED140>0</OEMLED140>
    <OEMDRO141>0.</OEMDRO141>
    <OEMLED141>0</OEMLED141>
    <OEMDRO142>0.</OEMDRO142>
    <OEMLED142>0</OEMLED142>
    <OEMDRO143>0.</OEMDRO143>
    <OEMLED143>0</OEMLED143>
    <OEMDRO144>0.</OEMDRO144>
    <OEMLED144>0</OEMLED144>
    <OEMDRO145>0.</OEMDRO145>
    <OEMLED145>0</OEMLED145>
    <OEMDRO146>0.</OEMDRO146>
    <OEMLED146>0</OEMLED146>
    <OEMDRO147>0.</OEMDRO147>
    <OEMLED147>0</OEMLED147>
    <OEMDRO148>0.</OEMDRO148>
    <OEMLED148>0</OEMLED148>
    <OEMDRO149>0.</OEMDRO149>
    <OEMLED149>0</OEMLED149>
    <OEMDRO150>0.</OEMDRO150>
    <OEMLED150>0</OEMLED150>
    <OEMDRO151>0.</OEMDRO151>
    <OEMLED151>0</OEMLED151>
    <OEMDRO152>0.</OEMDRO152>
    <OEMLED152>0</OEMLED152>
    <OEMDRO153>0.</OEMDRO153>
    <OEMLED153>0</OEMLED153>
    <OEMDRO154>0.</OEMDRO154>
    <OEMLED154>0</OEMLED154>
    <OEMDRO155>0.</OEMDRO155>
    <OEMLED155>0</OEMLED155>
    <OEMDRO156>0.</OEMDRO156>
    <OEMLED156>0</OEMLED156>
    <OEMDRO157>0.</OEMDRO157>
    <OEMLED157>0</OEMLED157>
    <OEMDRO158>0.</OEMDRO158>
    <OEMLED158>0</OEMLED158>
    <OEMDRO159>0.</OEMDRO159>
    <OEMLED159>0</OEMLED159>
    <OEMDRO160>0.</OEMDRO160>
    <OEMLED160>0</OEMLED160>
    <OEMDRO161>0.</OEMDRO161>
    <OEMLED161>0</OEMLED161>
    <OEMDRO162>0.</OEMDRO162>
    <OEMLED162>0</OEMLED162>
    <OEMDRO163>0.</OEMDRO163>
    <OEMLED163>0</OEMLED163>
    <OEMDRO164>0.</OEMDRO164>
    <OEMLED164>0</OEMLED164>
    <OEMDRO165>0.</OEMDRO165>
    <OEMLED165>0</OEMLED165>
    <OEMDRO166>0.</OEMDRO166>
    <OEMLED166>0</OEMLED166>
    <OEMDRO167>0.</OEMDRO167>
    <OEMLED167>0</OEMLED167>
    <OEMDRO168>0.</OEMDRO168>
    <OEMLED168>0</OEMLED168>
    <OEMDRO169>0.</OEMDRO169>
    <OEMLED169>0</OEMLED169>
    <OEMDRO170>0.</OEMDRO170>
    <OEMLED170>0</OEMLED170>
    <OEMDRO171>0.</OEMDRO171>
    <OEMLED171>0</OEMLED171>
    <OEMDRO172>0.</OEMDRO172>
    <OEMLED172>0</OEMLED172>
    <OEMDRO173>0.</OEMDRO173>
    <OEMLED173>0</OEMLED173>
    <OEMDRO174>0.</OEMDRO174>
    <OEMLED174>0</OEMLED174>
    <OEMDRO175>0.</OEMDRO175>
    <OEMLED175>0</OEMLED175>
    <OEMDRO176>0.</OEMDRO176>
    <OEMLED176>0</OEMLED176>
    <OEMDRO177>0.</OEMDRO177>
    <OEMLED177>0</OEMLED177>
    <OEMDRO178>0.</OEMDRO178>
    <OEMLED178>0</OEMLED178>
    <OEMDRO179>0.</OEMDRO179>
    <OEMLED179>0</OEMLED179>
    <OEMDRO180>0.</OEMDRO180>
    <OEMLED180>0</OEMLED180>
    <OEMDRO181>0.</OEMDRO181>
    <OEMLED181>0</OEMLED181>
    <OEMDRO182>0.</OEMDRO182>
    <OEMLED182>0</OEMLED182>
    <OEMDRO183>0.</OEMDRO183>
    <OEMLED183>0</OEMLED183>
    <OEMDRO184>0.</OEMDRO184>
    <OEMLED184>0</OEMLED184>
    <OEMDRO185>0.</OEMDRO185>
    <OEMLED185>0</OEMLED185>
    <OEMDRO186>0.</OEMDRO186>
    <OEMLED186>0</OEMLED186>
    <OEMDRO187>0.</OEMDRO187>
    <OEMLED187>0</OEMLED187>
    <OEMDRO188>0.</OEMDRO188>
    <OEMLED188>0</OEMLED188>
    <OEMDRO189>0.</OEMDRO189>
    <OEMLED189>0</OEMLED189>
    <OEMDRO190>0.</OEMDRO190>
    <OEMLED190>0</OEMLED190>
    <OEMDRO191>0.</OEMDRO191>
    <OEMLED191>0</OEMLED191>
    <OEMDRO192>0.</OEMDRO192>
    <OEMLED192>0</OEMLED192>
    <OEMDRO193>0.</OEMDRO193>
    <OEMLED193>0</OEMLED193>
    <OEMDRO194>0.</OEMDRO194>
    <OEMLED194>0</OEMLED194>
    <OEMDRO195>0.</OEMDRO195>
    <OEMLED195>0</OEMLED195>
    <OEMDRO196>0.</OEMDRO196>
    <OEMLED196>0</OEMLED196>
    <OEMDRO197>0.</OEMDRO197>
    <OEMLED197>0</OEMLED197>
    <OEMDRO198>0.</OEMDRO198>
    <OEMLED198>0</OEMLED198>
    <OEMDRO199>0.</OEMDRO199>
    <OEMLED199>0</OEMLED199>
    <OEMDRO200>0.</OEMDRO200>
    <OEMLED200>0</OEMLED200>
    <OEMDRO201>0.</OEMDRO201>
    <OEMLED201>0</OEMLED201>
    <OEMDRO202>0.</OEMDRO202>
    <OEMLED202>0</OEMLED202>
    <OEMDRO203>0.</OEMDRO203>
    <OEMLED203>0</OEMLED203>
    <OEMDRO204>0.</OEMDRO204>
    <OEMLED204>0</OEMLED204>
    <OEMDRO205>0.</OEMDRO205>
    <OEMLED205>0</OEMLED205>
    <OEMDRO206>0.</OEMDRO206>
    <OEMLED206>0</OEMLED206>
    <OEMDRO207>0.</OEMDRO207>
    <OEMLED207>0</OEMLED207>
    <OEMDRO208>0.</OEMDRO208>
    <OEMLED208>0</OEMLED208>
    <OEMDRO209>0.</OEMDRO209>
    <OEMLED209>0</OEMLED209>
    <OEMDRO210>0.</OEMDRO210>
    <OEMLED210>0</OEMLED210>
    <OEMDRO211>0.</OEMDRO211>
    <OEMLED211>0</OEMLED211>
    <OEMDRO212>0.</OEMDRO212>
    <OEMLED212>0</OEMLED212>
    <OEMDRO213>0.</OEMDRO213>
    <OEMLED213>0</OEMLED213>
    <OEMDRO214>0.</OEMDRO214>
    <OEMLED214>0</OEMLED214>
    <OEMDRO215>0.</OEMDRO215>
    <OEMLED215>0</OEMLED215>
    <OEMDRO216>0.</OEMDRO216>
    <OEMLED216>0</OEMLED216>
    <OEMDRO217>0.</OEMDRO217>
    <OEMLED217>0</OEMLED217>
    <OEMDRO218>0.</OEMDRO218>
    <OEMLED218>0</OEMLED218>
    <OEMDRO219>0.</OEMDRO219>
    <OEMLED219>0</OEMLED219>
    <OEMDRO220>0.</OEMDRO220>
    <OEMLED220>0</OEMLED220>
    <OEMDRO221>0.</OEMDRO221>
    <OEMLED221>0</OEMLED221>
    <OEMDRO222>0.</OEMDRO222>
    <OEMLED222>0</OEMLED222>
    <OEMDRO223>0.</OEMDRO223>
    <OEMLED223>0</OEMLED223>
    <OEMDRO224>0.</OEMDRO224>
    <OEMLED224>0</OEMLED224>
    <OEMDRO225>0.</OEMDRO225>
    <OEMLED225>0</OEMLED225>
    <OEMDRO226>0.</OEMDRO226>
    <OEMLED226>0</OEMLED226>
    <OEMDRO227>0.</OEMDRO227>
    <OEMLED227>0</OEMLED227>
    <OEMDRO228>0.</OEMDRO228>
    <OEMLED228>0</OEMLED228>
    <OEMDRO229>0.</OEMDRO229>
    <OEMLED229>0</OEMLED229>
    <OEMDRO230>0.</OEMDRO230>
    <OEMLED230>0</OEMLED230>
    <OEMDRO231>0.</OEMDRO231>
    <OEMLED231>0</OEMLED231>
    <OEMDRO232>0.</OEMDRO232>
    <OEMLED232>0</OEMLED232>
    <OEMDRO233>0.</OEMDRO233>
    <OEMLED233>0</OEMLED233>
    <OEMDRO234>0.</OEMDRO234>
    <OEMLED234>0</OEMLED234>
    <OEMDRO235>0.</OEMDRO235>
    <OEMLED235>0</OEMLED235>
    <OEMDRO236>0.</OEMDRO236>
    <OEMLED236>0</OEMLED236>
    <OEMDRO237>0.</OEMDRO237>
    <OEMLED237>0</OEMLED237>
    <OEMDRO238>0.</OEMDRO238>
    <OEMLED238>0</OEMLED238>
    <OEMDRO239>0.</OEMDRO239>
    <OEMLED239>0</OEMLED239>
    <OEMDRO240>0.</OEMDRO240>
    <OEMLED240>0</OEMLED240>
    <OEMDRO241>0.</OEMDRO241>
    <OEMLED241>0</OEMLED241>
    <OEMDRO242>0.</OEMDRO242>
    <OEMLED242>0</OEMLED242>
    <OEMDRO243>0.</OEMDRO243>
    <OEMLED243>0</OEMLED243>
    <OEMDRO244>0.</OEMDRO244>
    <OEMLED244>0</OEMLED244>
    <OEMDRO245>0.</OEMDRO245>
    <OEMLED245>0</OEMLED245>
    <OEMDRO246>0.</OEMDRO246>
    <OEMLED246>0</OEMLED246>
    <OEMDRO247>0.</OEMDRO247>
    <OEMLED247>0</OEMLED247>
    <OEMDRO248>0.</OEMDRO248>
    <OEMLED248>0</OEMLED248>
    <OEMDRO249>0.</OEMDRO249>
    <OEMLED249>0</OEMLED249>
    <OEMDRO250>0.</OEMDRO250>
    <OEMLED250>0</OEMLED250>
    <OEMDRO251>0.</OEMDRO251>
    <OEMLED251>0</OEMLED251>
    <OEMDRO252>0.</OEMDRO252>
    <OEMLED252>0</OEMLED252>
    <OEMDRO253>0.</OEMDRO253>
    <OEMLED253>0</OEMLED253>
    <OEMDRO254>0.</OEMDRO254>
    <OEMLED254>0</OEMLED254>
    <OEMDRO255>0.</OEMDRO255>
    <OEMLED255>0</OEMLED255>
    <JogInc>1.e-003</JogInc>
    <JogSlide>0.1</JogSlide>
    <THCMax>1.</THCMax>
    <THCMin>0.2</THCMin>
    <RadiusA>1.878</RadiusA>
    <RadiusB>0.</RadiusB>
    <RadiusC>0.</RadiusC>
    <LiftLevel>1.</LiftLevel>
    <LiftAngle>45.</LiftAngle>
    <InhibitDepth>0.</InhibitDepth>
    <LaserXGrid>0.</LaserXGrid>
    <LaserYGrid>0.</LaserYGrid>
    <LaserAGrid>0.</LaserAGrid>
    <JogInc0>1.</JogInc0>
    <JogInc1>0.1</JogInc1>
    <JogInc2>1.e-002</JogInc2>
    <JogInc3>1.e-003</JogInc3>
    <JogInc4>1.e-004</JogInc4>
    <JogInc5>1.</JogInc5>
    <JogInc6>0.1</JogInc6>
    <JogInc7>1.e-002</JogInc7>
    <JogInc8>1.e-003</JogInc8>
    <JogInc9>1.e-004</JogInc9>
    <THCSpeed>20.</THCSpeed>
    <BlendFactor>180.</BlendFactor>
    <M0RefHome>0</M0RefHome>
    <M1RefHome>0</M1RefHome>
    <M2RefHome>0</M2RefHome>
    <M3RefHome>0</M3RefHome>
    <M4RefHome>0</M4RefHome>
    <M5RefHome>0</M5RefHome>
    <MRU10>E:\Metalworking\CAD\G0704 CNC Mounts\POST\z ballscrew mount jig 2.txt</MRU10>
    <MRU9>E:\Metalworking\CAD\G0704 CNC Mounts\POST\z ballscrew mount jig 3.txt</MRU9>
    <MRU8>E:\Metalworking\CAD\G0704 CNC Mounts\POST\z ballscrew mount profile.txt</MRU8>
    <MRU7>C:\Documents and Settings\Administrator\Desktop\stemholes.txt</MRU7>
    <MRU6>C:\Documents and Settings\Administrator\Desktop\slot test.txt</MRU6>
    <MRU5>C:\Documents and Settings\Administrator\Desktop\slot.txt</MRU5>
    <MRU4>C:\Documents and Settings\Administrator\Desktop\SHOULDERS TOP.txt</MRU4>
    <MRU3>C:\Documents and Settings\Administrator\Desktop\flats.txt</MRU3>
    <MRU2>C:\Documents and Settings\Administrator\Desktop\zbrackethole.txt</MRU2>
    <MRU1>C:\Documents and Settings\Administrator\Desktop\fanpost.txt</MRU1>
    <ToolPersist>0</ToolPersist>
    <KeepRef>0</KeepRef>
    <TurnRevArc>1</TurnRevArc>
    <DROFont>Arial</DROFont>
    <LabelFont>Arial</LabelFont>
    <CodeFont>Arial</CodeFont>
    <PierceDelay>1.</PierceDelay>
    <VelPer3>5.</VelPer3>
    <TouchX>0.</TouchX>
    <G20X>0.</G20X>
    <G20Y>0.</G20Y>
    <G20Z>0.</G20Z>
    <G20A>0.</G20A>
    <G20B>0.</G20B>
    <G20C>0.</G20C>
    <FrontRear>0.</FrontRear>
    <EncJogAxis3>2</EncJogAxis3>
    <WarnOnReset>0</WarnOnReset>
    <NURBS>0</NURBS>
    <HiRes>0</HiRes>
    <DelinChar>12</DelinChar>
    <Rot360>0</Rot360>
    <SerialServo>0</SerialServo>
    <ToolLines>0</ToolLines>
    <UDP>0</UDP>
    <DefDir>C:\Mach3</DefDir>
    <NewPath>0</NewPath>
    <SafeZStop>0</SafeZStop>
    <SafeZType>0</SafeZType>
    <UseDiam>1</UseDiam>
    <SPINREV1>0</SPINREV1>
    <SPINREV2>0</SPINREV2>
    <SPINREV3>0</SPINREV3>
    <SPINREV4>0</SPINREV4>
    <SPEED5>25000</SPEED5>
    <LSPEED5>0</LSPEED5>
    <SPINREV5>0</SPINREV5>
    <SPEED6>25000</SPEED6>
    <LSPEED6>0</LSPEED6>
    <SPINREV6>0</SPINREV6>
    <SPEED7>25000</SPEED7>
    <LSPEED7>0</LSPEED7>
    <SPINREV7>0</SPINREV7>
    <SPEED8>25000</SPEED8>
    <LSPEED8>0</LSPEED8>
    <SPINREV8>0</SPINREV8>
    <SPEED9>25000</SPEED9>
    <LSPEED9>0</LSPEED9>
    <SPINREV9>0</SPINREV9>
    <SPEED10>25000</SPEED10>
    <LSPEED10>0</LSPEED10>
    <SPINREV10>0</SPINREV10>
    <SPEED11>25000</SPEED11>
    <LSPEED11>0</LSPEED11>
    <SPINREV11>0</SPINREV11>
    <SPEED12>25000</SPEED12>
    <LSPEED12>0</LSPEED12>
    <SPINREV12>0</SPINREV12>
    <SPEED13>25000</SPEED13>
    <LSPEED13>0</LSPEED13>
    <SPINREV13>0</SPINREV13>
    <SPEED14>25000</SPEED14>
    <LSPEED14>0</LSPEED14>
    <SPINREV14>0</SPINREV14>
    <SPEED15>25000</SPEED15>
    <LSPEED15>0</LSPEED15>
    <SPINREV15>0</SPINREV15>
    <SPEED16>25000</SPEED16>
    <LSPEED16>0</LSPEED16>
    <SPINREV16>0</SPINREV16>
    <SPEED17>25000</SPEED17>
    <LSPEED17>0</LSPEED17>
    <SPINREV17>0</SPINREV17>
    <SPEED18>25000</SPEED18>
    <LSPEED18>0</LSPEED18>
    <SPINREV18>0</SPINREV18>
    <SPEED19>25000</SPEED19>
    <LSPEED19>0</LSPEED19>
    <SPINREV19>0</SPINREV19>
    <SPEED20>25000</SPEED20>
    <LSPEED20>0</LSPEED20>
    <SPINREV20>0</SPINREV20>
    <SPEED21>25000</SPEED21>
    <LSPEED21>0</LSPEED21>
    <SPINREV21>0</SPINREV21>
    <SPEED22>25000</SPEED22>
    <LSPEED22>0</LSPEED22>
    <SPINREV22>0</SPINREV22>
    <SPEED23>25000</SPEED23>
    <LSPEED23>0</LSPEED23>
    <SPINREV23>0</SPINREV23>
    <SPEED24>25000</SPEED24>
    <LSPEED24>0</LSPEED24>
    <SPINREV24>0</SPINREV24>
    <SPEED25>25000</SPEED25>
    <LSPEED25>0</LSPEED25>
    <SPINREV25>0</SPINREV25>
    <m_SafeZ>0.</m_SafeZ>
    <EncJogAxis1>0</EncJogAxis1>
    <AutoCalcs>0</AutoCalcs>
    <CVUseAngle>0</CVUseAngle>
    <CVDegrees>0.</CVDegrees>
    <M30SpinOff>1</M30SpinOff>
    <Boxed>1</Boxed>
    <ButtonFont>Arial</ButtonFont>
    <OVSpinInc>10</OVSpinInc>
    <Syskey1>1</Syskey1>
    <ModPlug>0</ModPlug>
    <KeyClick>1</KeyClick>
    <THC5>0</THC5>
    <ModPort>1</ModPort>
    <AutoBaud>57600</AutoBaud>
    <AutoType1>0</AutoType1>
    <AutoType2>0</AutoType2>
    <AutoType3>0</AutoType3>
    <AutoType4>0</AutoType4>
    <AutoOn1>0</AutoOn1>
    <AutoOn2>0</AutoOn2>
    <AutoOn3>0</AutoOn3>
    <AutoOn4>0</AutoOn4>
    <AutoSlave1>0</AutoSlave1>
    <AutoSlave2>0</AutoSlave2>
    <AutoSlave3>0</AutoSlave3>
    <AutoSlave4>0</AutoSlave4>
    <AutoStart1>0</AutoStart1>
    <AutoStart2>0</AutoStart2>
    <AutoStart3>0</AutoStart3>
    <AutoStart4>0</AutoStart4>
    <AutoEnd1>0</AutoEnd1>
    <AutoEnd2>0</AutoEnd2>
    <AutoEnd3>0</AutoEnd3>
    <AutoEnd4>0</AutoEnd4>
    <RTSON>0</RTSON>
    <TIMEOUT>100</TIMEOUT>
    <Hertz>50</Hertz>
    <Prot>3</Prot>
    <ID>None</ID>
    <LastUser>Kevin Gregg</LastUser>
    <ROTSOFT>1</ROTSOFT>
    <PROBETLO>0</PROBETLO>
    <SlaveHome>0</SlaveHome>
    <JogHeat>0</JogHeat>
    <SPINRATIO1>1.</SPINRATIO1>
    <SPINRATIO2>1.</SPINRATIO2>
    <SPINRATIO3>1.</SPINRATIO3>
    <SPINRATIO4>1.</SPINRATIO4>
    <SPINRATIO5>1.</SPINRATIO5>
    <SPINRATIO6>1.</SPINRATIO6>
    <SPINRATIO7>1.</SPINRATIO7>
    <SPINRATIO8>1.</SPINRATIO8>
    <SPINRATIO9>1.</SPINRATIO9>
    <SPINRATIO10>1.</SPINRATIO10>
    <SPINRATIO11>1.</SPINRATIO11>
    <SPINRATIO12>1.</SPINRATIO12>
    <SPINRATIO13>1.</SPINRATIO13>
    <SPINRATIO14>1.</SPINRATIO14>
    <SPINRATIO15>1.</SPINRATIO15>
    <SPINRATIO16>1.</SPINRATIO16>
    <SPINRATIO17>1.</SPINRATIO17>
    <SPINRATIO18>1.</SPINRATIO18>
    <SPINRATIO19>1.</SPINRATIO19>
    <SPINRATIO20>1.</SPINRATIO20>
    <SPINRATIO21>1.</SPINRATIO21>
    <SPINRATIO22>1.</SPINRATIO22>
    <SPINRATIO23>1.</SPINRATIO23>
    <SPINRATIO24>1.</SPINRATIO24>
    <SPINRATIO25>1.</SPINRATIO25>
    <Running>0</Running>
    <TCPMODBUS>0</TCPMODBUS>
    <MenuOff>0</MenuOff>
    <ZBar>1</ZBar>
    <IgnoreMacros>0</IgnoreMacros>
    <DwellTrigger>0</DwellTrigger>
    <M7Delay>0.</M7Delay>
    <M8Delay>0.</M8Delay>
    <Encoder0>0</Encoder0>
    <Encoder1>0</Encoder1>
    <Encoder2>0</Encoder2>
    <Encoder3>0</Encoder3>
    <Encoder4>0</Encoder4>
    <Encoder5>0</Encoder5>
    <Encoder6>0</Encoder6>
    <M9After>0</M9After>
    <Vel0>3.333</Vel0>
    <Acc0>50.</Acc0>
    <Steps0>8000.</Steps0>
    <Vel1>2.5</Vel1>
    <Acc1>50.</Acc1>
    <Steps1>8000.</Steps1>
    <Vel2>2.</Vel2>
    <Acc2>50.</Acc2>
    <Steps2>8000.22439</Steps2>
    <DistanceMode>0</DistanceMode>
    <GExt>*.txt</GExt>
    <GPath>C:\Documents and Settings\Administrator\Desktop\fanpost.txt</GPath>
    <IGNORETOOL>1</IGNORETOOL>
    <Vel3>1406</Vel3>
    <Acc3>12000.</Acc3>
    <Steps3>17.77777778</Steps3>
  </Preferences>
  <Mach3Mill>
    <WPVB>500</WPVB>
    <WPVT>100</WPVT>
    <WPVL>50</WPVL>
    <WPVR>400</WPVR>
  </Mach3Mill>
  <Control>
    <Device>Printer</Device>
  </Control>
  <VideoPlugIn>
    <DROcolor>0</DROcolor>
    <TOOLcolor>8421440</TOOLcolor>
    <CROSScolor>4194304</CROSScolor>
    <ShowTool>1</ShowTool>
    <ShowMousePos>1</ShowMousePos>
    <ShowAxisPos>1</ShowAxisPos>
    <ToolDia>0.5</ToolDia>
    <ScaleFactor>2.e-003</ScaleFactor>
    <FlipAxis>0</FlipAxis>
  </VideoPlugIn>
</profile>
