1.31 First Release
1.32 Added Drive selection in file load screen
     Added fonts in distribution
1.33 New and modified Macros: RefX,RefY,RefZ, M6Start, M1001
     Some corrections to the toolchange slider
     Correction to the bottom bar
     Added Estimate time in the load screen
     Added diagnostics screen.
     Some leds can be changed by clicling on them or their label
     Added optional stop feature.
     To make an optional stop code must have 2 consucutive lines:
	M1001
        M01
     Could not do it through M01 alone because theres no optional stop led for it.
     Added rapids override button on feed override slider.
     I may change its location in the future because it does not work while part is running
1.34 Corrected a bug found by Fabrice Engel.
     when a wizard was posted, the values where taken from dros without being validated.
     This caused the screen to crash when the values had never been edited.
     I have added validation, but still some combination of values may lead to crash,
     specially when generating too many lines of code.
     Corrected graphic problem with depth in straight cut wizard and list of holes in holes wizard
1.35 Changed the "Go Zero" button for "Go Pos".
     The new button opens a slider that allows going to zero or any other position.
     Added macro: GoCoord
     RUCONFIG: New GoZeroTimeout and GoCoordTimeout parameters
     Some Work on optional stop
1.37 GCode now loads asynchronous to allow for long programs without crashing mach
        Up and down code arrows now have a different behavior to traverse long programs more easily
