If IsLoading() Then'Do Nothing, program loadingElse' Dim VariablesDim Num_Tools As IntegerDim CW_Steps_Per_Tool As IntegerDim CCW_Steps As IntegerDim HoldingDRO As IntegerDim Requested_Tool As IntegerDim Current_Tool As IntegerDim CW_Feed As IntegerDim CCW_Feed As IntegerDim moves As IntegerDim total_move As Integer' set up some varsNum_Tools = 6CW_Move_Per_Tool = 360/Num_ToolsCCW_Move = 10HoldingDRO = 1050Requested_Tool = GetSelectedTool()Current_Tool = GetUserDRO(holdingDRO)CW_Feed = 3000CCW_Feed = 2000Current_Feed = GetOEMDRO(818)' start tool changeMessage ("Requested Tool No=" & Requested_Tool)If Requested_Tool > Num_Tools ThenMessage "Requested Tool No. too high, program stopped."Code "M30"EndEnd IfIf Requested_Tool < 1 Then'Message "Requested Tool No. too low, program stopped."Code "M30"EndEnd IfIf Requested_Tool = Current_Tool Then' do nothingElse' lets do some changingIf Requested_Tool > Current_Tool Then moves = Requested_Tool -Current_ToolIf Requested_Tool < Current_Tool Then moves = Num_Tools - Current_Tool +Requested_Tooltotal_move = (moves * CW_Move_Per_Tool)+(CCW_Move/2)'Move to safe positionCode "G0 G53 Z-2 X-2"'Pause for 1/2 secondCode "G04 P0.5"Code "G91 G94" 'incremental & Feed per minuteCode "G01 A" & total_move & " F" & CW_FeedCode "G01 A-" & CCW_Move & " F" & CCW_FeedWhile IsMoving()sleep(10)WendSetCurrentTool Requested_ToolSetUserDRO HoldingDRO, Requested_ToolCode "G90" ' back to absolute movementCode "F" & Current_FeedEnd IfEnd If' end of tool change
