Fix log, Newfangled.set
V2.75
10/1/07 Found DRO 1018 duplicated on tool screen and bolt circle- screen 20. Fixed screen 20 to use 1019
10/17/07 Fixed Material screen to read path instead of assuming C:Mach3
10/20/07 Major redesign of tool screen. Added button to read tool table.
V2.76
Fixed thread screens
V2.77
Fixed surface screen
Fixed comp radius in Circle lead in. Was ToolR*1.15, changed to ToolR*1.5
Fixed bug in thread screens
Found some junk in Bitmaps folder, deleted and cut zip file by 300kb
V2.78 April 14, 08
Fixed rotate in Cut Rectangle
Added Gcode window to Preview screen. This was added in an earlier version but somehow got lost
Fixed edit operations on main screen to handle main folder other than C:\Mach3
V2.79 Aug 25, 08
Changed screen layout to show version number ans working units on all screens. HAd to move a few DROss around to clear screens
Fixed tool unit handling. Will now do metric tool units correctly, and will allow mixed units- ie an engish program can specify a metric tool. The 'Continue' button on the tool screen will adjust the units if needed and pop-up a mesage box
V2.80 Nov 24, 08
Fixed Cut Rectangle to include F word after plunge
Fixed inner to actually be inner, was cutting outside when inside requested.
V2.81 Dec 1 08
Fixed preview screen of cut rectangle to match changes to Post
Corrected G41/G42 in cut rectangle and tested all cases. I REALLY think its right now!
Fixed CW/CCw in circular pocket- it was reversed
V2.82 Dec 8, 08
Fixed depth per pass in Preview code for Cut Rectangle, it was using an old DRO value that always had 0.01 instead of the correct value.
Fixed Climb.Conv in circular pocket- label was reversed
Fixed code to support Tormach. Changed pathstrign to use FSO, and fixed tool table to
skip description if pathstring not C:\Mach3
V2.83 March 22, 09
Fixed some problmes caused by new comp code needing to always end on a linear move not an arc.
Fixed thread mill and surface so preview code did not change tool settings.
Fixed Cut rectangle to handle lower right corner rad correctly- was outputing redundant move if no corner radius
V2.84 March 13, 2010
Thread milling for inside, LH thread was not subtracting tool radius.
