[POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V11.00 E1 P0 T1245093641 M11.00 I0 X0.00 # Post Name : MACH3B # Revised By : Chris Krstanovic # Product : MILL # Machine Name : SMITHY 1220LTD VERTICAL MILL # Control Name : CONTROL # Description : MODIFIED IHS MASTER GENERIC MILL G-CODE POST # 4-axis/Axis subs. : YES # 5-axis : NO # Subprograms : YES # Executable : MP v9.17 # Post Revision : 9.1.03346 (MC_FULL.MC_MINOR.YYDDD) # # WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO # THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE. # # -------------------------------------------------------------------------- # Revision log: # -------------------------------------------------------------------------- # Programmers Note: # CK 12/07/05 - MODIFIED MACH2 POST # -Changed Max/Min spindle speeds to 2000/320RPM # -Modified breakarcs & do_full_arc as per Art # -Outputs MetaCut Tool table at the beginning # -Removed G28 to prevent homeing after toolchanges and after # the end of the program. Renable if needed, or use MACH3 # macro to do this. For details see the following: # --Commented out following lines from psof routine: # pfbld, n, sgabsinc, "G28", "Z0.", e # pfbld, n, "G28", "X0.", "Y0.", e # pfbld, n, "G92", *xh, *yh, *zh, e # --Commented out following lines from ptlchg Tool change routine: # if wcstype = one, #Work coordinate system # [ # pfbld, n, "G28", "X0.", "Y0.", e # pfbld, n, "G92", *xh, *yh, *zh, e # ] # pbld, n, 'G28', protretinc, e # --Commented out following lines from peof End of file # pbld, n, "G28", "X0.", "Y0.", protretinc, e # # IHS 01/30/02 - Mpmaster based on CNC Software's V8/V9 Mpfan, dat # IHS 01/30/02 - Initial post update for V9, dat # IHS 04/01/02 - Comments repeated in translational subs, dat # IHS 05/01/02 - lock_codes logic tweak, dat # IHS 05/07/02 - arccheck set to 3, dat # IHS 05/17/02 - Removed null comment from subs, dat # IHS 05/24/02 - Rotary subprograms mod, dat # IHS 07/17/02 - Incremental drilling calculation mod, dat # IHS 07/25/02 - Switch added to control rotary index move retracts, dat # IHS 10/07/02 - force_dpts switch added, dat # IHS 10/28/02 - Additional rotary sub logic mod, dat # IHS 11/06/02 - Switch added for 4/3 decimal place tapping feeds, dat # IHS 03/10/03 - Synched with updates to Mpfan from V9.1, dat # IHS 04/30/03 - arccheck set to 1, dat # IHS 05/08/03 - A2100-style G18/G19 helical move corrections, dat # IHS 06/27/03 - Initial post update for V9.1 SP1, dat # IHS 10/23/03 - Roughed out auto-launch of HTML.set, dat # IHS 12/12/03 - Comp on arc move warning added, dat # XXX MM/DD/03 - Written for Company X from Mpmaster, xxx # # -------------------------------------------------------------------------- # Features: # -------------------------------------------------------------------------- # This post supports Generic Fanuc code output for 3 and 4 axis milling. # It is designed to support the features of Mastercam Mill V9. # # Following Misc. Integers are used: # mi2 - Absolute or Incremental positioning at top level # 0 = absolute # 1 = incremental # # mi9 - Lock on First WCS - Set in first operation # 0 = No # 1 = Yes # # mi10 - M00 before operation # 0 = No # 1 = Yes # # Work offsets: # wcstype - Work coordinate system # 0 = Reference return is generated and G92 with the # X, Y and Z home positions at file head. # 1 = Reference return is generated and G92 with the # X, Y and Z home positions at each tool. # 2 = WCS of G54, G55.... based on Mastercam settings. # 0 thru 5 = The WCS of G54 thru G59 respectively. # 6 and up = The WCS of G54.1 P1 and up. # 3 = Off # #Canned text: # Entering cantext on a contour point from within Mastercam allows the # following functions to enable/disable. # Cantext value: # 1 = Stop = output the "M00" stop code # 2 = Ostop = output the "M01" optional stop code # 3 = Bld on = turn on block delete codes in NC lines # 4 = bLd off = turn off block delete codes in NC lines # 5 = Dwell = Input G04 P1 command # #Milling toolpaths (4 axis) #Layout: # The term "Reference View" refers to the coordinate system associated # with the Top view (Alt-F9, the upper gnomon of the three displayed). # Create the part drawing with the axis of rotation about the axis # of the "Reference View" according to the setting you entered for # 'vmc' (vertical or horizontal) and 'rot_on_x' (machine relative # axis of rotation). # vmc = 1 (vertical machine) uses the top toolplane as the base machine # view. # vmc = 0 (horizontal machine) uses the front toolplane as the base machine # view. # Relative to the machine matrix - # Rotation zero position is on the Z axis for rotation on X axis. # Rotation zero position is on the Z axis for rotation on Y axis. # Rotation zero position is on the X axis for rotation on Z axis. # The machine view rotated about the selected axis as a "single axis # rotation" are the only legal views for 4 axis milling. Rotation # direction around the part is positive in the CCW direction when # viewed from the plus direction of the rotating axis. Set the variable # 'rot_ccw_pos' to indicate the signed direction. Always set the work # origin at the center of rotation. # #Toolplane Positioning: # Create the Cplane and Tplane as the rotation of the machine view about # the selected axis of rotation. The toolplane is used to calculate # the position of the rotary axis. This is the default setting. # #3 Axis Rotary (Polar) # Polar positioning is offered in Mastercam 3 axis toolpaths through the # rotary axis options dialog. The selected toolpath is converted to angle # and radius position. The axis of rotation is forced to zero. # #Axis substitution: # Use the Rotary axis substitution by drawing the geometry flattened # from the cylinder. The rotary axis button must be active for axis # substitution information to be output to the NCI file. The radius of # the rotary diameter is added to all the Z positions at output. # #Simultaneous 4 Axis (11 gcode): # Full 4 axis toolpaths can be generated from various toolpaths under the # 'multi-axis' selection (i.e. Rotary 4 axis). All 5 axis paths are # converted to 4 axis paths where only the angle about the rotation axis # is resolved. # #Drill: # All drill methods are supported in the post. See Simultaneous 4 Axis. # #Additional Notes: # 1) Disable 4 axis by setting the numbered question 164. to 'n'. # 2) G54 calls are generated where the work offset entry of 0 = G54, # 1 = G55, etc. # 3) Metric is applied from the NCI met_tool variable. # 4) Incremental mode calculates motion from home position at toolchanges. # The home position is used to define the last position of the tool # for all toolchanges. # 5) The variable 'absinc' is now pre-defined, set mi2 (Misc. Integer) for # the 'top level' absolute/incremental program output. Subprograms are # updated through the Mastercam dialog settings for sub-programs. # 6) Always avoid machining to the center of rotation with rotary axis! # 7) Transform subprograms are intended for use with G54.. workshifts. # # END_HEADER$ # # -------------------------------------------------------------------------- # General Output Settings # -------------------------------------------------------------------------- spaces$ : 1 #Number of spaces to add between fields omitseq$ : no$ #Omit sequence numbers? seqmax$ : 99999 #Max. sequence number arcoutput$ : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180 arctype$ : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc. breakarcs$ : 0 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs do_full_arc$ : 1 #Allow full circle output? 0=no, 1=yes helix_arc$ : 1 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only compwarn : 1 #Warn if cutter comp applied on arc, 0=no, 1=yes maxrad$ : 999 #Maximum arc radius hel_2100 : no$ #Acramatic 2100 style helical moves, 0=no, 1=yes usecanned : yes$ #Use canned drilling cycles? Set to no for long output. force_dpts : no$ #Force XY output on all drilling lines including cycle call? wcstype : 3 #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off force_wcs : yes$ #Force WCS output at every toolchange? stagetool : 0 #0 = Do not pre-stage tools, 1 = Stage tools tool_table : 3 #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View output_z : yes$ #Output Z Min and Z Max values (yes or no) cool_zmove : yes$ #Coolant off with last move use_pitch : 0 #0 = Use feed for tapping, 1 = Use pitch for tapping tap_feed : 0 #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places maxfeedpm : 80 #Limit for feed in inch/min maxfeedpm_m : 2000 #Limit for feed in mm/min use_gear : 0 #Output gear selection code, 0=no, 1=yes max_speed : 2000 #Maximum spindle speed min_speed : 320 #Minimum spindle speed sextnc$ .NC #NC extension override # -------------------------------------------------------------------------- # Rotary Axis Settings # -------------------------------------------------------------------------- # Typical Vertical srotary "A" #Rotary axis prefix vmc : 1 #0 = Horizontal Machine, 1 = Vertical Mill rot_on_x : 1 #Default Rotary Axis Orientation, See ques. 164. #0 = Off, 1 = About X, 2 = About Y, 3 = About Z # Typical Horizontal #srotary "B" #Rotary axis prefix #vmc : 0 #0 = Horizontal Machine, 1 = Vertical Mill #rot_on_x : 2 #Default Rotary Axis Orientation, See ques. 164. # #0 = Off, 1 = About X, 2 = About Y, 3 = About Z rot_ccw_pos : 1 #Axis signed dir, 0 = CW positive, 1 = CCW positive ret_on_indx : 1 #Machine home retract on rotary index moves, (0 = no, 1 = yes) index : 0 #Use index positioning, 0 = Full Rotary, 1 = Index only ctable : 5 #Degrees for each index step with indexing spindle one_rev : 0 #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes) lock_codes : 0 #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes) use_frinv : 0 #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes) rot_feed : 1 #Use calculated rotary feed values, (0 = no, 1 = yes) maxfrdeg : 2000 #Limit for feed in deg/min maxfrinv : 999.99#Limit for feed inverse time frc_cinit : 1 #Force C axis reset at toolchange ctol : 225 #Tolerance in deg. before rev flag changes ixtol : 0.01 #Tolerance in deg. for index error frdegstp : 10 #Step limit for rotary feed in deg/min # -------------------------------------------------------------------------- # Debugging and Factory Set Program Switches # -------------------------------------------------------------------------- fastmode$ : yes$ #Posting speed optimizition bug1$ : 2 #0=No display, 1=Generic list box, 2=Editor bug2$ : 60 #Append postline labels, non-zero is column position? bug3$ : 0 #Append whatline no. to each NC line? bug4$ : 0 #Append NCI line no. to each NC line? whatno$ : yes$ #Do not perform whatline branches? (leave as yes) linktolvar$ : 1 #Associate X tolerance variables to V9- variable? linklvar$ : 1 #Associate X lathe specific variables to V9- variable? # -------------------------------------------------------------------------- # Additional General Output Settings # -------------------------------------------------------------------------- nobrk$ : no$ #Omit breakup of x, y & z rapid moves progname$ : 1 #Use uppercase for program name (sprogname) sub_level$ : 1 #Enable automatic subprogram support sub_seq_typ$ : 1 #Enable subprogram sequence number reset at sub call arccheck$ : 1 #Check for small arcs, convert to linear atol$ : 0.01 #Angularity tolerance for arccheck = 2 ltol$ : 0.002 #Length tolerance for arccheck = 1 vtol$ : 0.0001#System tolerance ltol_m : 0.05 #Length tolerance for arccheck = 1, metric vtol_m : 0.0025#System tolerance, metric tooltable$ : 1 #Read for tool table and pwrtt - use tool_table to disable m_one : -1 #Define constant zero : 0 #Define constant one : 1 #Define constant two : 2 #Define constant three : 3 #Define constant four : 4 #Define constant five : 5 #Define constant c9k : 9999 #Define constant skp_lead_flgs$ : 0 #Do NOT use v9 style contour flags get_1004$ : 1 #Find gcode 1004 with getnextop? rpd_typ_v7$ : 0 #Use Version 7 style contour flags/processing? strtool_v7$ : 2 #Use Version 7 toolname? [0=Filename,1=Name,2=Path\Name] tlchng_aft$ : 2 #Delay call to toolchange until move line cant_tlchng$ : 1 #Ignore cantext entry on move with tlchng_aft newglobal$ : 1 #Error checking for global variables getnextop$ : 1 #Build the next variable table error_msg$ : 1 #0=file and prompt, 1=to screen, 2=one to screen err_file$ : 1 #0=fatal, 1=all errors, 2=inc mprint, 3=inc prompts, 4=always # -------------------------------------------------------------------------- # Enable Canned Drill Cycle Switches # -------------------------------------------------------------------------- usecandrill$ : yes$ #Use canned cycle for drill usecanpeck$ : yes$ #Use canned cycle for Peck usecanchip$ : yes$ #Use canned cycle for Chip Break usecantap$ : yes$ #Use canned cycle for Tap usecanbore1$ : yes$ #Use canned cycle for Bore1 usecanbore2$ : yes$ #Use canned cycle for Bore2 usecanmisc1$ : yes$ #Use canned cycle for Misc1 usecanmisc2$ : yes$ #Use canned cycle for Misc2 # -------------------------------------------------------------------------- # Common User-defined Variable Initializations (not switches!) # -------------------------------------------------------------------------- xia : 0 #Formated absolute value for X incremental calculations yia : 0 #Formated absolute value for Y incremental calculations zia : 0 #Formated absolute value for Z incremental calculations cia : 0 #Formated absolute value for C incremental calculations cuttype : 0 #Cut type flag #0 = Tool Plane, 1 = Axis Subs, 2 = Polar, 3 = 4/5 axis bld : 0 #Block delete active result : 0 #Return value for functions sav_spc : 0 #Save spaces sav_gcode : 0 #Gcode saved sav_absinc : 0 #Absolute/Incremental Saved Value sav_coolant : 0 #Coolant saved sav_workofs : 0 #Saved work offset sav_frc_wcs : 0 #Force work offset flag saved sav_progno : 0 #Saved program number #sav_n1 : 0 #Saved sequence number #sav_n2 : 0 #Saved sequence number sav_rot_on_x : 0 #Rotary configuration saved toolchng : 1 #On a toolchange flag spdir2 : 1 #Copy for safe spindle direction calculation #Drill variables drlgsel : -1 #Drill Select Initialize drillref : 0 #Select drill reference peckacel$ : 0 #Fractional percent to reduce peck2 when usecan.. : no drlgcode : 0 #Save Gcode in drill sav_dgcode : 0 #Drill gcode saved #Subprogram variables mr_rt_actv : 0 #Flag to indicate if G51/G68 is active #0=Off, 1=Toolchange, 2=Subprogram call/start, G68 #3=Absolute start, both rt_csav : 0 #C saved value end_sub_mny : 0 #Many tool setting captured at transform sub end #Rotary/Index variables csav : 0 #C saved value prvcabs : 0 #Saved cabs from pe_inc_calc, #Used for rotary feed and direction calculations cdelta : 0 #Calculation for angle change rev : 0 #Calculation for deg/min sav_rev : 0 #Saved revolution counter indx_out : c9k #Rotation direction calculation fmt 16 indx_mc #Rotation direction calculation #Vector Constants for Rotatary Calculations aaxisx : 1 #A axis rotation vector constant aaxisy : 0 #A axis rotation vector constant aaxisz : 0 #A axis rotation vector constant baxisx : 0 #B axis rotation vector constant baxisy : 1 #B axis rotation vector constant baxisz : 0 #B axis rotation vector constant caxisx : 0 #C axis rotation vector constant caxisy : 0 #C axis rotation vector constant caxisz : 1 #C axis rotation vector constant #Feedrate calculation variables frdelta : 0 #Calculation for deg/min frinv : 0 #Feedrate inverse time frdeg : 0 #Feedrate deg/min actual prvfrdeg : 0 #Feedrate deg/min actual ldelta : 0 #Calculation for deg/min, linear cldelta : 0 #Calculation for deg/min, linear and rotary circum : 0 #Calculation for deg/min ipr_type : 0 #Feedrate for Rotary, 0 = UPM, 1 = DPM, 2 = Inverse #Misc variables tcnt : 0 # Count the number of tool changes toolcount : 1 # Tool counter for logic control toolcountn : 0 # Next tool counter for logic control toolcountp : 0 # Previous tool counter for logic control tooltotal : 0 # Tool tool count nexttool : 0 # Next actual tool nexttp : 0 # Next tool plane prvtp : 0 # Previous tool plane counter : 0 # Counter nstrlen : 0 # Length of string last_op_id : 0 # Previous internal operation id last_cuttype : 0 # Previous cuttype stock_typ : 0 # Predator Stock Type cyl_typ : 0 # Predator Cyl Stock Type z_min$ : 99999 # Min Z z_tmin : 99999 # Overall min Z z_max$ : -99999# Max Z z_tmax : -99999# Overall max Z tapflg : 0 # Flag for tap cycle sav_mi9 : 0 # Saved mi9 value rotretflg : 0 compwarnflg : 0 # -------------------------------------------------------------------------- # FORMULAS - global formulas # -------------------------------------------------------------------------- toolcountn = toolcount + 1 # Index! toolcountp = toolcount - 1 # Index! # -------------------------------------------------------------------------- # Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta # -------------------------------------------------------------------------- #Default english/metric position format statements fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (:) fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place fs2 3 0.4 0.3d #Decimal, delta, 4/3 place #Common format statements fs2 4 1 0 1 0 #Integer, not leading fs2 5 2 0 2 0l #Integer, force two leading fs2 6 3 0 3 0l #Integer, force three leading fs2 7 4 0 4 0l #Integer, force four leading fs2 8 5 0 5 0l #Integer, force five leading fs2 9 0.1 0.1 #Decimal, absolute, 1 place fs2 10 0.2 0.2 #Decimal, absolute, 2 place fs2 11 0.3 0.3 #Decimal, absolute, 3 place fs2 12 0.4 0.4 #Decimal, absolute, 4 place fs2 13 0.5 0.5 #Decimal, absolute, 5 place fs2 14 0.3 0.3d #Decimal, delta, 3 place fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place (feedrate) fs2 16 1 0 1 0n #Integer, forced output fs 17 1.4lt #Decimal, absolute, four trailing # -------------------------------------------------------------------------- #String and string selector definitions for NC output # -------------------------------------------------------------------------- #Numbered question 164. string to detect Rotary axis y/n sq164 #Address string definitions stri "I" strj "J" strk "K" strm "M" strn "N" stro "O" strp "P" srad "R" srminus "R-" sblank #Cantext string definitions (spaces must be padded here) sm00 "M00" sm01 "M01" scant5 "G04 P1" strtextno strcantext #Transform mirror and rotate codes strns_mir_on "G51.1" #Programmable mirror image code strns_mir_off "G50.1" #Programmable mirror image cancel code strns_rot_on "G68" #Coordinate System Rotation strns_rot_off "G69" #Coordinate System Rotation Cancel #Launch HTML.set during posting sdll "C:\Mcam9\Chooks\MP_Multi.dll" # Name of the .DLL to be called spost1 "HTML.SET" snci "" sparams1 "" sspace " " # Contains a SPACE character ssq "'" # Contains a Single Quote character sdq '"' # Contains a Double Quote character # -------------------------------------------------------------------------- # Error messages # -------------------------------------------------------------------------- saxiswarn "WARNING-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') OVERWRITTEN BY OPERATION" saxisoff "ERROR-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') IS DISABLED" saxiserror "ERROR-INVALID ROTARY AXIS ASSIGNMENT ('rot_on_x') FOR CURRENT OPERATION" sindxerror "WARNING-INDEX ANGLE DOES NOT MATCH POST SETTING ('ctable')" stlorgerr "ERROR-TOOL ORIGIN DOES NOT MATCH CENTER OF ROTATION IN POLAR MILLING" shomeserror "ERROR-G92 WORK OFFSET ('wcstype') DOES NOT SUPPORT TRANSFORM SUBPROGRAM" sprgnerror "ERROR-SUBPROGRAM NUMBER MATCHES THE MAIN PROGRAM NUMBER" scompwarn "WARNING-CUTTER COMP APPLIED ON ARC MOVE" # -------------------------------------------------------------------------- # Misc strings # -------------------------------------------------------------------------- snull "" # Null character string sdot "." # dot string stest1 "" # Test string 1 stilde "~" # Tidle string snocomm "DEFINE TOOL NAMES" stoper "" # String for tool notes spostname "" # Post name snullop "UNDEFINED OPERATION" slicense "NovaLab" # ------------------------------------------------------------------------ # Parameter Tables # ------------------------------------------------------------------------ fprmtbl 13 2 # Multisurf Finish 10010 stock # Amount of stock to leave on drive surfs 10227 check # Amount of stock to leave on check surfs fprmtbl 14 2 # Multisurf Rough 10010 stock # Amount of stock to leave on drive surfs 10227 check # Amount of stock to leave on check surfs # -------------------------------------------------------------------------- # Buffer 3 - Holds the variable 'tlplnno' for each toolpath segment # -------------------------------------------------------------------------- rc3 : 1 wc3 : 1 fbuf 3 0 1 0 0 # Buffer 3 # -------------------------------------------------------------------------- # Buffer 4 - Holds the variable 't' for each toolpath segment # -------------------------------------------------------------------------- rc4 : 1 wc4 : 1 fbuf 4 0 1 0 0 # Buffer 4 # -------------------------------------------------------------------------- # Buffer 5 - Min / Max # -------------------------------------------------------------------------- b5_gcode : 0 b5_zmin : 0 b5_zmax : 0 rc5 : 2 wc5 : 1 size5 : 0 fbuf 5 0 3 0 0 #Min / Max # -------------------------------------------------------------------------- # Question format statements # -------------------------------------------------------------------------- fq 1 stock_typ "Predator Stock [0=Box,1=Cylindrical]" fq 2 cyl_typ "Cylindrical Stock Axis [1=X,2=Y,3=Z]" # -------------------------------------------------------------------------- # Strings - String labels must start with 's' - they are not pre-assigned # -------------------------------------------------------------------------- #Select operation note sop00 "NULL......." # String definition sop01 "CONTOUR...." # " " sop02 "CONTOUR...." # " " sop03 "DRILL/MISC." # " " sop04 "POCKET....." # " " sop05 "RULED......" # " " sop06 "2D-SWEPT..." # " " sop07 "3D-SWEPT..." # " " sop08 "REVOLVED..." # " " sop09 "LOFT......." # " " sop10 "COONS......" # " " sop11 "FILLET....." # " " sop12 "FLOWLINE..." # " " sop13 "M.FINISH..." # " " sop14 "M.ROUGH...." # " " sop15 "POINT......" # " " sop16 "DRILL5AX..." # " " sop17 "CURVE5AX..." # " " sop18 "SWARF5AX..." # " " sop19 "FACING....." # " " sop20 "OP20......." # " " sopnote # Target string fstrsel sop00 opcode$ sopnote 21 -1 # -------------------------------------------------------------------------- #Select operation note sdr00 "DRILL/CBORE" # String definition sdr01 "PECK DRILL." # " " sdr02 "CHIP BREAK." # " " sdr03 "TAP........" # " " sdr04 "BORE 1....." # " " sdr05 "BORE 2....." # " " sdr06 "FINE BORE.." # " " sdr07 "MISC 2....." # " " sdr08 "CUST 9....." # " " sdr09 "CUST 10...." # " " sdr10 "CUST 11...." # " " sdr11 "CUST 12...." # " " sdr12 "CUST 13...." # " " sdr13 "CUST 14...." # " " sdr14 "CUST 15...." # " " sdr15 "CUST 16...." # " " sdr16 "CUST 17...." # " " sdr17 "CUST 18...." # " " sdr18 "CUST 19...." # " " sdr19 "CUST 20...." # " " sdrnote # Target string fstrsel sdr00 nextdc$ sdrnote 20 -1 # -------------------------------------------------------------------------- # Select month smon00 "" smon01 "JAN" smon02 "FEB" smon03 "MAR" smon04 "APR" smon05 "MAY" smon06 "JUN" smon07 "JUL" smon08 "AUG" smon09 "SEP" smon10 "OCT" smon11 "NOV" smon12 "DEC" smonth fstrsel smon00 month$ smonth 13 -1 # -------------------------------------------------------------------------- # General G and M Code String select tables # -------------------------------------------------------------------------- # Motion G code selection sg00 G00 #Rapid sg01 G01 #Linear feed sg02 G02 #Circular interpolation CW sg03 G03 #Circular interpolation CCW sg04 G04 #Dwell sgcode #Target for string fstrsel sg00 gcode$ sgcode 5 -1 # -------------------------------------------------------------------------- # Select work plane G code sg17 G17 #XY plane code sg19 G19 #YZ plane code sg18 G18 #XZ plane code sgplane #Target string fstrsel sg17 plane$ sgplane 3 -1 # -------------------------------------------------------------------------- #Select english/metric code sg20 G20 #Inch code sg21 G21 #Metric code smetric #Target string fstrsel sg20 met_tool$ smetric 2 -1 # -------------------------------------------------------------------------- # Cutter compensation G code selection scc0 G40 #Cancel cutter compensation scc1 G41 #Cutter compensation left scc2 G42 #Cutter compensation right sccomp #Target for string fstrsel scc0 cc_pos$ sccomp 3 -1 # -------------------------------------------------------------------------- # Canned drill cycle string select sg81 G81 #drill - no dwell sg81d G82 #drill - with dwell sg83 G83 #peck drill - no dwell sg83d G83 #peck drill - with dwell sg73 G73 #chip break - no dwell sg73d G73 #chip break - with dwell sg84 G84 #tap - right hand sg84d G74 #tap - left hand sg85 G85 #bore #1 - no dwell sg85d G89 #bore #1 - with dwell sg86 G86 #bore #2 - no dwell sg86d G86 #bore #2 - with dwell sgm1 G76 #misc #1 - no dwell sgm1d G76 #misc #1 - with dwell sgm2 G81 #misc #2 - no dwell sgm2d G82 #misc #2 - with dwell sgc9 G81 #custom #9 - no dwell sgc9d G82 #custom #9 - with dwell sgdrill #Target for string fstrsel sg81 drlgsel sgdrill 18 -1 # -------------------------------------------------------------------------- # Select incremental or absolute G code sg90 G90 #Absolute code sg91 G91 #Incremental code sgabsinc #Target string fstrsel sg90 absinc$ sgabsinc 2 -1 # -------------------------------------------------------------------------- # Feed mode G code selection sg94 G94 #UPM sg94d G94 #DPM, See pfcalc_deg if you use another gcode sg93 G93 #Inverse sgfeed #Target for string fstrsel sg94 ipr_type sgfeed 3 -1 # -------------------------------------------------------------------------- #Canned drill cycle reference height sg98 G98 #Reference at initht sg99 G99 #Reference at refht sgdrlref #Target for string fstrsel sg98 drillref sgdrlref 2 -1 # Drill cycle G string select # -------------------------------------------------------------------------- # Generate string for spindle sm04 M04 #Spindle reverse sm05 M05 #Spindle off sm03 M03 #Spindle forward spindle #Target for string fstrsel sm04 spdir2 spindle 3 -1 # -------------------------------------------------------------------------- # Coolant M code selection sm09 M09 #Coolant Off (Use sm09_0 through sm09_2) sm08 M08 #Coolant Flood sm08_1 M07 #Coolant Mist sm08_2 M08 #Coolant Tool sm09_0 M09 #Coolant Flood Off sm09_1 M09 #Coolant Mist Off sm09_2 M09 #Coolant Tool Off scoolant #Target for string fstrsel sm09 coolant$ scoolant 7 -1 # -------------------------------------------------------------------------- # Table unlock and lock codes slock M10 #Axis lock sunlock M11 #Axis unlock # -------------------------------------------------------------------------- # Table rotation direction # Table rotation direction, index sindx_cw M22 #Rotate CW code sindx_ccw M21 #Rotate CCW code sindx_mc #Target for string fstrsel sindx_cw indx_mc sindx_mc 2 -1 # -------------------------------------------------------------------------- # Define the gear selection code flktbl 1 3 #Lookup table definition - table no. - no. entries 40 0 #Low gear range 41 400 #Med gear range 42 2250 #Hi gear range # -------------------------------------------------------------------------- # Toolchange / NC output Variable Formats # -------------------------------------------------------------------------- fmt T 4 t$ #Tool No fmt T 4 first_tool$ #First Tool Used fmt T 4 next_tool$ #Next Tool Used fmt D 4 tloffno$ #Diameter Offset No fmt H 4 tlngno$ #Length Offset No fmt G 4 g_wcs #WCS G address fmt P 4 p_wcs #WCS P address fmt S 4 speed #Spindle Speed fmt M 4 gear #Gear range # -------------------------------------------------------------------------- fmt N 4 n$ #Sequence number fmt X 2 xabs #X position output fmt Y 2 yabs #Y position output fmt Z 2 zabs #Z position output fmt X 3 xinc #X position output fmt Y 3 yinc #Y position output fmt Z 3 zinc #Z position output fmt A 11 cabs #C axis position fmt A 14 cinc #C axis position fmt A 4 indx_out #Index position fmt R 14 rt_cinc #C axis position, G68 fmt I 3 i$ #Arc center description in X fmt J 3 j$ #Arc center description in Y fmt K 3 k$ #Arc center description in Z fmt K 2 lead #Helical lead fmt R 2 arcrad$ #Arc Radius fmt F 15 feed #Feedrate fmt P 11 dwell$ #Dwell fmt M 5 cantext$ #Canned text # -------------------------------------------------------------------------- #Move comment (pound) to output colon with program numbers fmt O 7 progno$ #Program number #fmt ":" 7 progno$ #Program number fmt O 7 main_prg_no$ #Program number #fmt ":" 7 main_prg_no #Program number fmt O 7 sub_prg_no$ #Program number #fmt ":" 7 sub_prg_no$ #Program number fmt P 7 sub_prg_call#Program number fmt X 2 sub_trnsx$ #Rotation point fmt Y 2 sub_trnsy$ #Rotation point fmt Z 2 sub_trnsz$ #Rotation point # -------------------------------------------------------------------------- fmt Q 2 peck1$ #First peck increment (positive) fmt 2 peck2$ #Second or last peck (positive) fmt 2 peckclr$ #Safety distance fmt 2 retr$ #Retract height fmt Q 2 shftdrl$ #Fine bore tool shift fmt Z 2 zdrl$ #Depth of drill point fmt Z 2 tosz$ #Drilling top of stock fmt N 4 n_tap_thds$ #Number of threads per inch (tpi) / Pitch (mm) fmt F 2 pitch #Tap pitch (inches per thread) fmt R 2 refht_a #Reference height fmt R 2 refht_i #Reference height # -------------------------------------------------------------------------- fmt "TOOL - " 4 tnote # Note format fmt " DIA. OFF. - " 4 toffnote # Note format fmt " LEN. - " 4 tlngnote # Note format fmt " DIA. - " 1 tldianote # Note format # -------------------------------------------------------------------------- fmt D 17 tldia$ # Note format fmt R 17 tcr$ # Note format fmt D 2 tldia_pred # Predator VCNC format fmt C 2 tcr_pred # Predator VCNC format fmt D 2 tldia_meta # MetaCut View format fmt R 2 tcr_meta # MetaCut View format fmt F 2 flute_meta # MetaCut View format fmt L 2 oa_meta # MetaCut View format fmt A 2 ta_meta # MetaCut View format fmt TD 2 td_meta # MetaCut View format fmt CD 2 cd_meta # MetaCut View format fmt CL 2 cl_meta # MetaCut View format fmt SD 2 sd_meta # MetaCut View format fmt C 4 tipcomp # MetaCut View format fmt 2 slot # 20004 Parameter line fmt 2 tool_type fmt 2 matl_type fmt 2 corner_rad_type fmt 2 diameter fmt 2 corner_rad fmt 2 threads fmt A 2 tip_angle fmt 2 dia_off fmt 2 len_off fmt 2 tool_feed fmt 2 plunge fmt 2 retract fmt 2 rpm fmt 2 coolant1 fmt 2 n_flutes1 fmt A 2 tip_angle_ch fmt 2 cut_ability # 20006 Parameter line fmt 2 step_r_xy fmt 2 step_r_z fmt 2 step_f_xy fmt 2 step_f_z fmt 2 tip_dia fmt 2 min_dia fmt 2 thd_ang fmt 2 pilot_dia # 20007 Parameter line fmt H 2 flute_len fmt 2 oa_len fmt 2 shldr_len fmt 2 arbor_dia fmt 2 hldr_dia fmt 2 hldr_len fmt 2 spindle_ccw fmt 2 sfm fmt 2 fpt fmt 2 metric fmt 2 stock # Amount of Stock left on drive surfs fmt 2 check # Amount of Stock left on check surfs fmt S 4 cyl_typ # Predator Cylindral Stock Type fmt L 2 stck_ht$ fmt W 2 stck_wdth$ fmt H 2 stck_thck$ fmt D 2 stck_diam fmt X 2 stck_x$ fmt Y 2 stck_y$ fmt Z 2 stck_z$ fmt X 2 stck_x_min fmt Y 2 stck_y_min fmt Z 2 stck_z_min fmt X 2 stck_meta_ht fmt Y 2 stck_meta_wdth fmt Z 2 stck_meta_thck fmt OX 2 stck_meta_ox fmt OY 2 stck_meta_oy fmt OZ 2 stck_meta_oz fmt X 2 x_tmin # Total x_min fmt X 2 x_tmax # Total x_max fmt Y 2 y_tmin # Total y_min fmt Y 2 y_tmax # Total y_max fmt Z 2 z_tmin # Total z_min fmt Z 2 z_tmax # Total z_max fmt Z 2 min_depth # Tool z_min fmt Z 2 max_depth # Tool z_max fmt 2 vers_no$ # Mastercam version fmt 2 m_vers_no$ # Minor version number # -------------------------------------------------------------------------- # Tool Comment / Manual Entry Section # -------------------------------------------------------------------------- ptoolcomment #Comment for tool tnote = t$ toffnote = tloffno$ tlngnote = tlngno$ tldianote = tldia$ "(", pstrtool, *tnote, *toffnote, *tlngnote, *tldianote, ")", e$ pstrtool #Comment for tool if strtool$ <> sblank, [ strtool$ = ucase(strtool$) *strtool$, " " ] pcomment$ #Comment from manual entry (must call pcomment2 if booleans) pcomment2 pcomment2 #Comment from manual entry spaces$ = 0 scomm$ = ucase (scomm$) #1005 - Comment option 1 #1006 - Comment option 2 #1007 - Define comment with output line #1008 - Define NC parameter comment #1026 - ? if gcode$ = 1005, pbld, n$, pspc, "(", scomm$, ")" if gcode$ = 1006, pbld, n$, pspc, "(", scomm$, ")" #Comments #if gcode = 1006, pbld, n, pspc, scomm #Codes if gcode$ = 1007, "(", scomm$, ")" if gcode$ >= 1008, pbld, n$, pspc, "(", scomm$, ")" if gcode$ = 1026, pbld, scomm$ if gcode$ <> 1007 & gcode$ <> 1026, e$ spaces$ = sav_spc ptoolcomm # Comments from tool library spaces$ = 0 strtool$=ucase(strtool$) if strtool$<>snull, pspc1, "(", *strtool$, ")", e$ else, pspc1, "(", "DEFINE TOOL NAMES", ")", e$ spaces$ = sav_spc plistcomm # Comments from tool library strtool$=ucase(strtool$) if strtool$<>snull, *strtool$ else, "DEFINE TOOL NAMES" if strtool$=snull, stest1=snocomm+stilde else, stest1=strtool$+stilde nstrlen = strstr(stilde,stest1)-1 counter = 1 while counter <= (25-nstrlen), pspace pmetacomm # Comments from tool library strtool$=ucase(strtool$) if strtool$<>snull, *strtool$ else, "DEFINE TOOL NAMES" pspace # Creates spaces based on tool comment length " " counter = counter + 1 ptspace # Creates spaces based on tool number if t$<10, " " phspace # Creates spaces based on length offset number if tlngno$<10, " " pdspace # Creates spaces based on diameter offset number if tloffno$<10, " " pdiamspc # Creates spaces based on diameter offset number if tldia$<10, " " pspc # Creates spaces based tool level setting if sav_spc = one & omitseq$ = no$, " " pspc1 # Creates spaces based tool level setting if sav_spc = one, " " popnote # Operation note for tool table if opcode$ = 3, *sdrnote else, *sopnote pstock # Comment amount of stock to leave spaces$=0 if (opcode$=13 | opcode$=14), [ pbld, n$, pspc, "(TOOLPATH - ", *stoper, ")", e$ pbld, n$, pspc, "(STOCK LEFT ON DRIVE SURFS = ", *stock, ")", e$ if check<>0, pbld, n$, pspc, "(STOCK LEFT ON CHECK SURFS = ", *check, ")", e$ ] spaces$=sav_spc ppredstck # Predator stock spaces$=0 q1 if stock_typ = 1, [ cyl_typ = rot_on_x q2 ] if stock_typ = 0, ppredbox if stock_typ = 1, [ if cyl_typ = 1, ppredcylx if cyl_typ = 2, ppredcyly if cyl_typ = 3, ppredcylz ] spaces$=sav_spc ppredbox # Predator Box Stock if stck_crnr$ = 0, [ stck_x_min = stck_x$ - stck_ht$/2 stck_y_min = stck_y$ - stck_wdth$/2 ] if stck_crnr$ = 1 | stck_crnr$ = 5, [ stck_x_min = stck_x$ stck_y_min = stck_y$ - stck_wdth$ ] if stck_crnr$ = 2 | stck_crnr$ = 6, [ stck_x_min = stck_x$ - stck_ht$ stck_y_min = stck_y$ - stck_wdth$ ] if stck_crnr$ = 3 | stck_crnr$ = 7, [ stck_x_min = stck_x$ - stck_ht$ stck_y_min = stck_y$ ] if stck_crnr$ = 4 | stck_crnr$ = 8, [ stck_x_min = stck_x$ stck_y_min = stck_y$ ] if stck_crnr$ <= 4, stck_z_min = stck_z$ - stck_thck$ else, stck_z_min = stck_z$ "(SBOX ", *stck_x_min, " ", *stck_y_min, " ", *stck_z_min, " ", *stck_ht$, " ", *stck_wdth$, " ", *stck_thck$, ")" ppredcylx # Predator Cyl-X Stock if stck_crnr$ = 0, [ stck_x_min = stck_x$ - stck_ht$/2 stck_y_min = stck_y$ ] if stck_crnr$ = 1 | stck_crnr$ = 5, [ stck_x_min = stck_x$ stck_y_min = stck_y$ - stck_wdth$/2 ] if stck_crnr$ = 2 | stck_crnr$ = 6, [ stck_x_min = stck_x$ - stck_ht$ stck_y_min = stck_y$ - stck_wdth$/2 ] if stck_crnr$ = 3 | stck_crnr$ = 7, [ stck_x_min = stck_x$ - stck_ht$ stck_y_min = stck_y$ + stck_wdth$/2 ] if stck_crnr$ = 4 | stck_crnr$ = 8, [ stck_x_min = stck_x$ stck_y_min = stck_y$ + stck_wdth$/2 ] if stck_crnr$ <= 4, stck_z_min = stck_z$ - stck_thck$/2 else, stck_z_min = stck_z$ + stck_thck$/2 stck_diam = stck_wdth$ if stck_thck$ > stck_wdth$, stck_diam = stck_thck$ stck_ht$ = stck_ht$ "(SCYL ", *cyl_typ, " ", *stck_x_min, " ", *stck_y_min, " ", *stck_z_min, " ", *stck_diam, " ", *stck_ht$, ")" ppredcyly # Predator Cyl-Y Stock if stck_crnr$ = 0, [ stck_x_min = stck_x$ stck_y_min = stck_y$ - stck_wdth$/2 ] if stck_crnr$ = 1 | stck_crnr$ = 5, [ stck_x_min = stck_x$ + stck_ht$/2 stck_y_min = stck_y$ - stck_wdth$ ] if stck_crnr$ = 2 | stck_crnr$ = 6, [ stck_x_min = stck_x$ - stck_ht$/2 stck_y_min = stck_y$ - stck_wdth$ ] if stck_crnr$ = 3 | stck_crnr$ = 7, [ stck_x_min = stck_x$ - stck_ht$/2 stck_y_min = stck_y$ ] if stck_crnr$ = 4 | stck_crnr$ = 8, [ stck_x_min = stck_x$ + stck_ht$/2 stck_y_min = stck_y$ ] if stck_crnr$ <= 4, stck_z_min = stck_z$ - stck_thck$/2 else, stck_z_min = stck_z$ + stck_thck$/2 stck_diam = stck_ht$ if stck_thck$ > stck_ht$, stck_diam = stck_thck$ stck_ht$ = stck_wdth$ "(SCYL ", *cyl_typ, " ", *stck_x_min, " ", *stck_y_min, " ", *stck_z_min, " ", *stck_diam, " ", *stck_ht$, ")" ppredcylz # Predator Cyl-Z Stock if stck_crnr$ = 0, [ stck_x_min = stck_x$ stck_y_min = stck_y$ ] if stck_crnr$ = 1 | stck_crnr$ = 5, [ stck_x_min = stck_x$ + stck_ht$/2 stck_y_min = stck_y$ - stck_wdth$/2 ] if stck_crnr$ = 2 | stck_crnr$ = 6, [ stck_x_min = stck_x$ - stck_ht$/2 stck_y_min = stck_y$ - stck_wdth$/2 ] if stck_crnr$ = 3 | stck_crnr$ = 7, [ stck_x_min = stck_x$ - stck_ht$/2 stck_y_min = stck_y$ + stck_wdth$/2 ] if stck_crnr$ = 4 | stck_crnr$ = 8, [ stck_x_min = stck_x$ + stck_ht$/2 stck_y_min = stck_y$ + stck_wdth$/2 ] if stck_crnr$ <= 4, stck_z_min = stck_z$ - stck_thck$ else, stck_z_min = stck_z$ stck_diam = stck_ht$ if stck_wdth$ > stck_ht$, stck_diam = stck_wdth$ stck_ht$ = stck_thck$ "(SCYL ", *cyl_typ, " ", *stck_x_min, " ", *stck_y_min, " ", *stck_z_min, " ", *stck_diam, " ", *stck_ht$, ")" pmetastck # MetaCut View stock if stck_crnr$ = 0, [ stck_meta_ox = stck_x$ * m_one - (tox$ * m_one) stck_meta_oy = stck_y$ * m_one - (toy$ * m_one) ] if stck_crnr$ = 1 | stck_crnr$ = 5, [ stck_meta_ox = (stck_x$ + stck_ht$/2) * m_one - (tox$ * m_one) stck_meta_oy = (stck_y$ - stck_wdth$/2) * m_one - (toy$ * m_one) ] if stck_crnr$ = 2 | stck_crnr$ = 6, [ stck_meta_ox = (stck_x$ - stck_ht$/2) * m_one - (tox$ * m_one) stck_meta_oy = (stck_y$ - stck_wdth$/2) * m_one - (toy$ * m_one) ] if stck_crnr$ = 3 | stck_crnr$ = 7, [ stck_meta_ox = (stck_x$ - stck_ht$/2) * m_one - (tox$ * m_one) stck_meta_oy = (stck_y$ + stck_wdth$/2) * m_one - (toy$ * m_one) ] if stck_crnr$ = 4 | stck_crnr$ = 8, [ stck_meta_ox = (stck_x$ + stck_ht$/2) * m_one - (tox$ * m_one) stck_meta_oy = (stck_y$ + stck_wdth$/2) * m_one - (toy$ * m_one) ] if stck_crnr$ <= 4, stck_meta_oz = stck_z$ * m_one - (toz$ * m_one) else, stck_meta_oz = (stck_z$ + stck_thck$) * m_one - (toz$ * m_one) stck_meta_ht = stck_ht$ stck_meta_wdth = stck_wdth$ stck_meta_thck = stck_thck$ #(NWDSTOCK X8. Y8. Z1.25 OTC OX-4. OY-4. OZ0.) spaces$=0 "(NWDSTOCK ", *stck_meta_ht, " ", *stck_meta_wdth, " ", *stck_meta_thck, " OTC ", *stck_meta_ox, " ", *stck_meta_oy, " ", *stck_meta_oz, ")" spaces$=sav_spc pstop # Stop routine pretract pcom_moveb if mi10$=one, n$, *sm00, e$ sav_absinc = absinc$ if wcstype > one, absinc$ = zero if lock_codes = 1 & not(index) & rot_on_x, pbld, n$, *sunlock, "(UNLOCK)", e$ pcan1, pbld, n$, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout, *speed, *spindle, pgear, strcantext, e$ if lock_codes = 1 & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, "(LOCK)", e$ pbld, n$, *tlngno$, pfzout, scoolant, next_tool$, e$ sav_coolant = coolant$ if coolant$ = 1, sm09 = sm09_0 if coolant$ = 2, sm09 = sm09_1 if coolant$ = 3, sm09 = sm09_2 absinc$ = sav_absinc # -------------------------------------------------------------------------- # Misc. Output # -------------------------------------------------------------------------- pparameter$ # Run parameter table if opcode$=13 | opcode$=14, result = fprm (opcode$) if prmcode$ = 10000, stoper = ucase(sparameter$) if prmcode$ = 10055, spostname = ucase(sparameter$) if stoper=snull, stoper = snullop pwrttparam$ #Information from parameters if prmcode$ = 20004, slot = rpar(sparameter$, 16) if prmcode$ = 20006, cut_ability = rpar(sparameter$,8) if prmcode$ = 20007, pilot_dia = rpar(sparameter$, 11) # -------------------------------------------------------------------------- # Start of File and Toolchange Setup # -------------------------------------------------------------------------- psof0$ #Start of file for tool zero psof$ psof$ #Start of file for non-zero tool number ptravel pwritbuf5 pcuttype toolchng = one if ntools$ = one, [ #skip single tool outputs, stagetool must be on #stagetool = m_one !next_tool$ ] tooltotal = rbuf(4,0) #Reads total tool and null tool changes if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn) else, nexttool = first_tool$ if tool_table = 2, ppredstck,e$ if tool_table = 3, pmetastck,e$ spaces$=0 if output_z = yes$ & tcnt > 1, [ "(OVERALL MAX - ", *z_tmax, ")", e$ "(OVERALL MIN - ", *z_tmin, ")", e$ ] spaces$=sav_spc if plane$ < 0, plane$ = 0 pbld, n$, *sgcode, *sgplane, *smetric, "G40", "G44", "G80", *sgabsinc, e$ sav_absinc = absinc$ if wcstype <= one, #Work coordinate system [ absinc$ = one # pfbld, n, sgabsinc, "G28", "Z0.", e # pfbld, n, "G28", "X0.", "Y0.", e # pfbld, n, "G92", *xh, *yh, *zh, e absinc$ = sav_absinc ] sav_mi9 = mi9$ sav_workofs = workofs$ if sav_workofs < 0, sav_workofs = 0 ptlchg_com ptlchg_com #Tool change common blocks pcom_moveb c_mmlt$ #Multiple tool subprogram call #ptoolcomment comment$ pcan if plane$ < 0, plane$ = 0 if stagetool >= zero, pbld, n$, *t$, "M06", ptoolcomm, e$ spaces$=0 if output_z = yes$, [ preadbuf5 if (opcode$ > 0 & opcode$ < 16) | opcode$ = 19, [ n$, pspc, "(", "MAX - ", *max_depth, ")", e$ n$, pspc, "(", "MIN - ", *min_depth, ")", e$ ] ] spaces$=sav_spc pstock pindex sav_absinc = absinc$ if wcstype > one, absinc$ = zero if lock_codes = 1 & not(index) & rot_on_x, pbld, n$, *sunlock, "(UNLOCK)", e$ pbld, n$, *sgcode, pfzout, scoolant, e$ pcan1, pbld, n$, *sgcode, pwcs, pfxout, pfyout, pfcout, *speed, *spindle, pgear, strcantext, e$ if lock_codes = 1 & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, "(LOCK)", e$ sav_coolant = coolant$ if coolant$ = 1, sm09 = sm09_0 if coolant$ = 2, sm09 = sm09_1 if coolant$ = 3, sm09 = sm09_2 absinc$ = sav_absinc pcom_movea toolchng = zero c_msng$ #Single tool subprogram call last_op_id = op_id$ last_cuttype = cuttype ptlchg0$ #Call from NCI null tool change (tool number repeats) pcuttype pcom_moveb toolcount = toolcount + 1 prvtp = rbuf(3,toolcountp) if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn) else, nexttool = first_tool$ if mi10$=one & op_id$<>last_op_id | (tlplnno$ <> prvtp & ret_on_indx), pstop c_mmlt$ #Multiple tool subprogram call comment$ pcan if plane$ < 0, plane$ = 0 pbld, n$, sgplane, e$ pspindchng if coolant$ <> 0 & coolant$ <> sav_coolant & sav_coolant, pbld, n$, sm09, e$ pbld, n$, scoolant, e$ sav_coolant = coolant$ if coolant$ = 1, sm09 = sm09_0 if coolant$ = 2, sm09 = sm09_1 if coolant$ = 3, sm09 = sm09_2 if op_id$<>last_op_id, pstock if sav_mi9 = 1, workofs$ = sav_workofs if (wcstype > one & workofs$ <> prv_workofs$) | (tlplnno$ <> prvtp & ret_on_indx), [ sav_absinc = absinc$ absinc$ = zero if fmtrnd(prv_cabs) <> fmtrnd(cabs), [ if lock_codes = 1 & not(index) & rot_on_x, pbld, n$, *sunlock, "(UNLOCK)", e$ pbld, n$, pwcs, pfxout, pfyout, pfzout, pfcout, e$ if lock_codes = 1 & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, "(LOCK)", e$ ] else, [ pbld, n$, pwcs, pfxout, pfyout, pfzout, pcout, e$ ] pe_inc_calc ps_inc_calc absinc$ = sav_absinc ] if lock_codes = 1 & cuttype <> last_cuttype & cuttype > 0, pbld, n$, *sunlock, "(UNLOCK)", e$ if cuttype = zero, ppos_cax_lin if lock_codes = 1 & cuttype <> last_cuttype & cuttype = 0 & fmtrnd(prv_cabs) = fmtrnd(cabs), pbld, n$, *slock, "(LOCK)", e$ if gcode$ = one, plinout else, prapidout pcom_movea c_msng$ #Single tool subprogram call last_op_id = op_id$ last_cuttype = cuttype ptlchg$ #Tool change pcuttype toolchng = one toolcount = toolcount + 1 if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn) else, nexttool = first_tool$ # if wcstype = one, #Work coordinate system # [ # pfbld, n, "G28", "X0.", "Y0.", e # pfbld, n, "G92", *xh, *yh, *zh, e # ] if mi10$=one, n$, *sm00, e$ ptlchg_com pretract #End of tool path, toolchange sav_absinc = absinc$ absinc$ = one sav_coolant = coolant$ coolant$ = zero #cc_pos is reset in the toolchange here cc_pos$ = zero gcode$ = zero pcan pbld, n$, sccomp, *sm05, psub_end_mny, e$ #if lock_codes = 1 & rot_on_x, pbld, n, *sunlock, "(UNLOCK)", e #pbld, n, "G28", "X0.", "Y0.", protretinc, e #if lock_codes = 1 & rot_on_x & cuttype = 0, pbld, n, *slock, "(LOCK)", e if abs(cabs) > 360 & nextop$ <> 1003, [ if lock_codes = 1, pbld, n$, *sunlock, "(UNLOCK)", e$ rotretflg = 1 #pbld, n, 'G28', protretinc, e rotretflg = 0 if lock_codes = 1 & cuttype = 0, pbld, n$, *slock, "(LOCK)", e$ ] pcan2 absinc$ = sav_absinc coolant$ = sav_coolant protretinc #Reset the C axis revolution counter if frc_cinit & rot_on_x, [ rev = zero sav_rev = zero cabs = zero csav = zero indx_out = zero if index, e$, pindxcalc, pindex else, *cabs prvcabs = zero !csav, !cabs ] peof0$ #End of file for tool zero peof$ peof$ #End of file for non-zero tool pretract if lock_codes = 1 & rot_on_x, pbld, n$, *sunlock, "(UNLOCK)", e$ rotretflg = 1 #pbld, n, "G28", "X0.", "Y0.", protretinc, e rotretflg = 0 if lock_codes = 1 & rot_on_x, pbld, n$, *slock, "(LOCK)", e$ comment$ #Remove pound character to output first tool with staged tools #if stagetool = one, pbld, n, *first_tool, e n$, *sg90, e$ n$, "M30", e$ mergesub$ clearsub$ mergeaux$ clearaux$ "%", e$ #snci = spathnci + snamenci + sextnci #sparams1 = ssq + sdq + snci + sdq + sspace + sdq + spathpst + spost1 + sdq + sspace + sdq + spathnc + sdq + ssq #ppost #Called after posting is complete and all files are closed #result = fexist(sdll) #if result = 1, result = dll(sdll,sparams1) pwcs #G54+ coordinate setting at toolchange if wcstype = two | wcstype > three, [ sav_frc_wcs = force_wcs if sub_level$ > 0, force_wcs = zero if sav_mi9 = 1, workofs$ = sav_workofs if workofs$ < 0, workofs$ = 0 if workofs$ <> prv_workofs$ | (force_wcs & toolchng), [ if workofs$ < 6, [ g_wcs = workofs$ + 54 *g_wcs ] else, [ p_wcs = workofs$ - five "G54.1", *p_wcs ] ] force_wcs = sav_frc_wcs !workofs$ ] pgear #Find spindle gear from lookup table if use_gear = one, [ gear = frange (one, speed) *gear ] #Toolchange setup pspindchng #Spindle speed change if prv_spdir2 <> spdir2 & prv_speed <> zero, pbld, n$, *sm05, e$ if prv_speed <> speed | prv_spdir2 <> spdir2, [ if speed, pbld, n$, *speed, *spindle, pgear, e$ ] !speed, !spdir2 pspindle #Spindle speed calculations for RPM speed = abs(ss$) if maxss$ = zero | maxss$ > max_speed, maxss$ = max_speed #zero indicates spindle off (not a mistake) if speed, [ if speed > max_speed, speed = maxss$ if speed < min_speed, speed = min_speed ] spdir2 = fsg3(spdir$) pq$ #Setup post based on switch settings sav_spc = spaces$ if stagetool = one, bldnxtool$ = one #Rotaxtyp = 1 sets initial matrix to top #Rotaxtyp = -2 sets initial matrix to front if vmc, rotaxtyp$ = one else, rotaxtyp$ = -2 #Shut off rotary axis if, Q164. Enable Rotary Axis button? n if ucase(sq164) = strn, rot_on_x = zero if arctype$ = one | arctype$ = four, [ result = newfs(two, i$) result = newfs(two, j$) result = newfs(two, k$) ] else, [ result = newfs(three, i$) result = newfs(three, j$) result = newfs(three, k$) ] if usecanned = yes$, pusecannedyes else, pusecannedno pheader$ #Call before start of file if met_tool$ = one, #Metric constants and variable adjustments [ ltol$ = ltol_m vtol$ = vtol_m maxfeedpm = maxfeedpm_m ] result = nwadrs(srotary, cabs) result = nwadrs(srotary, cinc) result = nwadrs(srotary, indx_out) "%", e$ spaces$=0 *progno$, " (", sprogname$, ")", e$ spathnc$ = ucase(spathnc$) smcname$ = ucase(smcname$) #"(PROGRAM NAME - ", sprogname, ")", e #"(DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, ")", e "(MASTERCAM - V", *vers_no$, ")", e$ "(MC9 FILE - ", smcpath$, smcname$, smcext$, ")", e$ "(POST - ", spostname, ")", e$ stck_matl$ = ucase(stck_matl$) "(MATERIAL - ", stck_matl$, ")", e$ "(PROGRAM - ", sprogname$, sextnc$, ")", e$ "(DATE - ", *smonth, "-", day$ , "-", year$ , ")", e$ "(TIME - ", time$ , ")", e$ "(POST DEV - ", *slicense, ")", e$ spaces$=sav_spc if seqno$ = 0, omitseq$ = yes$ sav_rot_on_x = rot_on_x rot_on_x = 0 sav_progno = progno$ #seqno = 10 #seqinc = 10 #n = seqno ptoolend$ #End of tool path, before reading new tool data !speed, !spdir2 ptlchg1002$ #Call at actual toolchange, end last path here if op_id$ <> last_op_id, [ #if cuttype <> one, sav_rev = rev #Axis Sub does not update to rev # CNC Mpfan V9.1 sav_rev = rev #Axis Sub does not update to rev if one_rev = one | workofs$ <> prv_workofs$, sav_rev = 0 ] pspindle whatline$ = four #Required for vector toolpaths if gcode$ = 1000, [ #Null toolchange ] else, [ #Toolchange and Start of file if gcode$ = 1002, [ #Actual toolchange pretract ] if stagetool = one, prv_next_tool$ = m_one prv_xia = vequ(xh$) prv_feed = c9k ] # -------------------------------------------------------------------------- # Motion NC output # -------------------------------------------------------------------------- #The variables for absolute output are xabs, yabs, zabs. #The variables for incremental output are xinc, yinc, zinc. # -------------------------------------------------------------------------- prapidout #Output to NC of linear movement - rapid pcan1, pbld, n$, sgplane, `sgcode, pccdia, pxout, pyout, pzout, pcout, strcantext, scoolant, e$ plinout #Output to NC of linear movement - feed pcan1, pbld, n$, sgfeed, sgplane, `sgcode, pccdia, pxout, pyout, pzout, pcout, `feed, strcantext, scoolant, e$ pcirout #Output to NC of circular interpolation if compwarn, pcompwarn if hel_2100 = one, pcirout2 else, pcirout1 pcirout1 #Output to NC of circular interpolation pcan1, pbld, n$, `sgfeed, sgplane, sgcode, sgabsinc, pccdia, pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e$ pcirout2 #Output to NC of circular interpolation if (plane$ = zero & abs(zinc)>=0.0005) | (plane$ = one & abs(xinc)>=0.0005) | (plane$ = two & abs(yinc)>=0.0005), phelout else, pcirout1 phelout #Output to NC of helical interpolation if plane$ = zero, [ result = nwadrs(strk, lead) lead = abs(zinc/sweep$*360) ] if plane$ = one, [ result = nwadrs(stri, lead) lead = abs(xinc/sweep$*360) ] if plane$ = two, [ result = nwadrs(strj, lead) lead = abs(yinc/sweep$*360) ] pcan1, pbld, n$, `sgfeed, sgplane, sgcode, pccdia, pxout, pyout, pzout, *lead, pcout, parc, feed, strcantext, scoolant, e$ pcom_moveb #Common motion preparation routines, before pxyzcout ps_inc_calc pncoutput #Movement output pcom_moveb comment$ if coolant$ <> 0 & coolant$ <> sav_coolant, [ pbld, n$, sm09, e$ sav_coolant = coolant$ ] if coolant$ = 1, sm09 = sm09_0 if coolant$ = 2, sm09 = sm09_1 if coolant$ = 3, sm09 = sm09_2 if cool_zmove = yes$ & (nextop$=1003 | (nextop$=1011 & t$<>abs(nexttool))), coolant$ = zero pcan if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning if gcode$ = zero, prapidout if gcode$ = one, plinout if gcode$ > one & gcode$ < four, pcirout if mr_rt_actv, #Restore absolute/incremental for G51/G68 [ absinc$ = sav_absinc mr_rt_actv = zero ] pcom_movea pcom_movea #Common motion preparation routines, after pcan2 pe_inc_calc pdwl_spd$ #Call from NCI gcode 4 pspindle comment$ pspindchng pcan if fmtrnd(dwell$), pcan1, pbld, n$, *sgcode, *dwell$, strcantext, e$ else, pcan1, pbld, n$, strcantext, e$ pcan2 prapid$ #Output to NC of linear movement - rapid pncoutput pzrapid$ #Output to NC of linear movement - rapid Z only pncoutput plin$ #Output to NC of linear movement - feed pncoutput pz$ #Output to NC of linear movement - feed Z only pncoutput pmx$ #Output to NC of vector NCI pncoutput pcir$ #Output to NC of circular interpolation pncoutput #Pre-process rotary motion control flags pmx0$ #5 axis gcode setup if drillcur$ = zero, [ if fr$ = -2,gcode$ = zero else, gcode$ = one ] plin0$ #Linear movement, mill motion test pmotion_su pcir0$ #Circular interpolation, mill arc motion test pmotion_su # -------------------------------------------------------------------------- # Motion output components # -------------------------------------------------------------------------- pbld #Canned text - block delete if bld, '/' pfbld #Force - block delete "/" pcompwarn #Cutter Compensation Check if prv_cc_pos$ <> cc_pos$ & cc_pos$ & gcode$ > 1, [ if compwarnflg = 0, result = mprint(scompwarn,1) spaces$ = 0 pbld, n$, pspc, *sm00, pspc, "(", scompwarn, ")", e$ spaces$ = sav_spc compwarnflg = 1 ] pccdia #Cutter Compensation #Force Dxx# if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k sccomp if cc_pos$, tloffno$ pfxout #Force X axis output if absinc$ = zero, *xabs, !xinc else, *xinc, !xabs pxout #X output if absinc$ = zero, xabs, !xinc else, xinc, !xabs pfyout #Force Y axis output if absinc$ = zero, *yabs, !yinc else, *yinc, !yabs pyout #Y output if absinc$ = zero, yabs, !yinc else, yinc, !yabs pfzout #Force Z axis output if absinc$ = zero, *zabs, !zinc else, *zinc, !zabs pzout #Z output if absinc$ = zero, zabs, !zinc else, zinc, !zabs pfcout #Force C axis output if index = zero & rot_on_x, [ if absinc$ = zero, *cabs, !cinc else, *cinc, !cabs ] pcout #C axis output if index = zero & rot_on_x, [ if absinc$ = zero, cabs, !cinc else, cinc, !cabs ] pindex #Index output if index & rot_on_x, [ if fmtrnd(prv_indx_out) <> fmtrnd(indx_out), [ if lock_codes = 1 & rotretflg = 0, pbld, n$, *sunlock, "(UNLOCK)", e$ pbld, n$, `sindx_mc, indx_out, e$ if lock_codes = 1 & cuttype = 0 & rotretflg = 0, pbld, n$, *slock, "(LOCK)", e$ ] !cabs, !cinc ] parc #Select the arc output if arcoutput$ = zero | full_arc_flg$ | arc_pitch$, [ #Arc output for IJK # If you do NOT want to force out the I,J,K values, # remove the "*" asterisks on the *i, *j, *k 's below... if plane$ = zero, *i$, *j$, k$ #XY plane code - G17 if plane$ = one, i$, *j$, *k$ #YZ plane code - G19 if plane$ = two, *i$, j$, *k$ #XZ plane code - G18 ] else, [ #Arc output for R if abs(sweep$)<=180 | arcoutput$=one, result = nwadrs(srad, arcrad$) else, result = nwadrs(srminus, arcrad$) *arcrad$ ] ppos_cax_lin #Position the rotary axis before move - rapid if index, pindex else, [ if fmtrnd(prv_cabs) <> fmtrnd(cabs) & rot_on_x, [ sav_gcode = gcode$ gcode$ = zero if lock_codes = 1 & not(index), pbld, n$, *sunlock, "(UNLOCK)", e$ pbld, n$, sgcode, pcout, e$ if lock_codes = 1 & not(index) & cuttype = 0, pbld, n$, *slock, "(LOCK)", e$ !cia ps_cinc_calc gcode$ = sav_gcode ] ] # -------------------------------------------------------------------------- # Drilling # -------------------------------------------------------------------------- pdrill0$ #Pre-process before drill call sav_dgcode = gcode$ #Capture gcode for 5 axis drill pdrlcommonb #Canned Drill Cycle common call, before if sav_dgcode = 81, [ result = newfs (two, zinc) if tap_feed = one & drillcyc$ = three, result = newfs (two, feed) #Tap feeds with 4/3 decimal places if drillcyc$ = three, drlgsel = fsg1(-ss$) + drillcyc$ * two else, drlgsel = fsg2(dwell$) + drillcyc$ * two if initht$ <> refht$, drillref = zero else, drillref = one prv_refht_a = c9k prv_refht_i = c9k prv_dwell$ = zero ] if cuttype = three, sav_dgcode = gcode$ else, z$ = depth$ if cuttype = one, prv_zia = initht$ + (rotdia$/two) else, prv_zia = refht$ #Fanuc style - G91 Z depth from R level #else, prv_zia = initht #G91 Z depth from initial height pcom_moveb feed = fr_pos$ comment$ pcan #5 axis must map the true Z, correct Z calculation here if cuttype = three, [ prv_zia = zabs + (-depth$) + initht$ zia = fmtrnd(zabs) zinc = zia - prv_zia ] pbld, n$, e$ prdrlout #R drill position if cuttype = one, refht_a = refht$ + (rotdia$ / two) else, refht_a = refht$ refht_i = refht$ - initht$ if cuttype = three, refht_a = w$ if absinc$ = zero, refht_a, !refht_i else, refht_i, !refht_a pdrlxy #Drill XY coordinates if force_dpts, pfxout, pfyout else, pxout, pyout pdrill$ #Canned Drill Cycle pdrlcommonb pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, prdrlout, dwell$, *feed, strcantext, e$ pcom_movea ppeck$ #Canned Peck Drill Cycle pdrlcommonb pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, prdrlout, *peck1$, *feed, strcantext, e$ pcom_movea pchpbrk$ #Canned Chip Break Cycle pdrlcommonb pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, prdrlout, *peck1$, *feed, strcantext, e$ pcom_movea ptap$ #Canned Tap Cycle pdrlcommonb #RH/LH based on spindle direction if use_pitch, pbld, n$, "G95", e$ if use_pitch = 0, [ pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, prdrlout, *feed, strcantext, e$ ] else, [ if met_tool$, pitch = n_tap_thds$ # Tap pitch (mm per thread) else, pitch = 1/n_tap_thds$ # Tap pitch (inches per thread) pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, prdrlout, *pitch, !feed, strcantext, e$ ] pcom_movea tapflg = 1 pbore1$ #Canned Bore #1 Cycle pdrlcommonb pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, prdrlout, dwell$, *feed, strcantext, e$ pcom_movea pbore2$ #Canned Bore #2 Cycle pdrlcommonb pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, prdrlout, *feed, strcantext, e$ pcom_movea pmisc1$ #Canned Misc #1 Cycle pdrlcommonb pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, prdrlout, shftdrl$, dwell$, *feed, strcantext, e$ pcom_movea pmisc2$ #Canned Misc #2 Cycle (User Option) pdrill$ pdrill_2$ #Canned Drill Cycle, additional points pdrlcommonb pcan1, pbld, n$, pdrlxy, pzout, pcout, prdrlout, dwell$, feed, strcantext, e$ pcom_movea ppeck_2$ #Canned Peck Drill Cycle pdrill_2$ pchpbrk_2$ #Canned Chip Break Cycle pdrill_2$ ptap_2$ #Canned Tap Cycle pdrill_2$ pbore1_2$ #Canned Bore #1 Cycle pdrill_2$ pbore2_2$ #Canned Bore #2 Cycle pdrill_2$ pmisc1_2$ #Canned Misc #1 Cycle pdrill_2$ pmisc2_2$ #Canned Misc #2 Cycle pdrill_2$ pdrlcst$ #Custom drill cycles 8 - 19 (user option) #Use this postblock to customize drilling cycles 8 - 19 pdrlcommonb #if drillcyc = 8, pcan1, pbld, n, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, # prdrlout, dwell, *feed, strcantext, e if drillcyc$ = 8, [ sub_prg_call = peck1$ pcan1, pbld, n$, *sg00, pfxout, pfyout, strcantext, e$ pbld, n$, "M98", *sub_prg_call, e$ ] else, "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e$ pcom_movea pdrlcst_2$ #Custom drill cycles 8 - 19, additional points (user option) #Use this postblock to customize drilling cycles 8 - 19 pdrlcommonb #if drillcyc = 8, pcan1, pbld, n, pdrlxy, pzout, pcout, prdrlout, dwell, # feed, strcantext, e if drillcyc$ = 8, [ sub_prg_call = peck1$ pcan1, pbld, n$, *sg00, pfxout, pfyout, strcantext, e$ pbld, n$, "M98", *sub_prg_call, e$ ] else, "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e$ pcom_movea pcanceldc$ #Cancel canned drill cycle result = newfs (three, zinc) if tap_feed = one & drillcyc$ = three, result = newfs (15, feed) #Cancel tap feeds with 4/3 decimal places z$ = initht$ !z$ if cuttype = one, prv_zia = initht$ + (rotdia$/two) else, prv_zia = initht$ pxyzcout !zabs, !zinc prv_gcode$ = zero if cool_zmove = yes$ & (nextop$=1003 | (nextop$=1011 & t$<>abs(nexttool))), coolant$ = zero pcan if drillcyc$ <> 8, pcan1, pbld, n$, "G80", scoolant, strcantext, e$ if use_pitch & tapflg = 1, pbld, n$, "G94", e$ pcan2 tapflg = 0 # -------------------------------------------------------------------------- #Subprogram postblocks #sub_trnstyp - 0=mirror, 1=rotate, 2=scale, 3=translate #sub_trnmthd (mirror) - 0=X axis, 1=Y axis, 2=line #sub_trnmthd (rotate) - 0=tplane, 1=tplane origin only, 2=coordinates # -------------------------------------------------------------------------- psub_call_m$ #Call to main level, single tool psub_call_trans psub_call_mm$ #Call to main level, multiple tools psub_call_trans psub_call_trans #Translate level calls from toolchange, user if wcstype <= one, result = mprint(shomeserror,1) sav_absinc = absinc$ pindex #Mirror or Rotate Coord's if sub_trnstyp$ = zero | (sub_trnstyp$ = one & mr_rt_actv), [ #The original pattern is not mirrored or rotated if sub_sec_no$, [ absinc$ = zero if sub_trnstyp$, psub_rotate else, psub_mirror ] mr_rt_actv = three ] else, #Translate [ if sub_mny_t$, [ if wcstype > one, absinc$ = zero if lock_codes = 1 & not(index) & rot_on_x, pbld, n$, *sunlock, "(UNLOCK)", e$ pbld, n$, *sgcode, pwcs, pfxout, pfyout, pfzout, pfcout, e$ if lock_codes = 1 & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, "(LOCK)", e$ pe_inc_calc ps_inc_calc ] ] absinc$ = sav_absinc result = nwadrs(strp, main_prg_no$) main_prg_no$ = main_prg_no$ + sav_progno #Add sub number offset if sav_progno = main_prg_no$, result = mprint(sprgnerror,1) pbld, n$, "M98", *main_prg_no$, e$ prv_feed = c9k #Force feed in sub psub_mirror #Mirror start code, user #Mirror Y axis if sub_trnmthd$, pbld, n$, strns_mir_on, *sub_trnsx$, e$ #Mirror X axis else, pbld, n$, strns_mir_on, *sub_trnsy$, e$ psub_rotate #Rotate start code, user pbld, n$, *sgcode, strns_rot_on, *sub_trnsx$, *sub_trnsy$, [absinc$ = one], *rt_cinc, e$ psub_st_m$ #Header in main level result = nwadrs(stro, main_prg_no$) #sav_n1 = n #n = seqno " ", e$ *main_prg_no$, e$ spaces$ = 0 if scomm0$ <> snull, "(", *scomm0$, ")", e$ spaces$ = sav_spc #G51/G68 requires absolute position on first move if mr_rt_actv & absinc$ = one, [ sav_absinc = absinc$ absinc$ = zero prv_absinc$ = m_one prv_xabs = m_one prv_yabs = m_one ] else, pbld, n$, e$ psub_end_m$ #End in main level n$, "M99", e$ prv_absinc$ = -1 #n = sav_n1 #Reset update variables for subs at main level #Mirror or Rotate cancel, output is forced if (sub_trnstyp$ = zero & esub_sec_no$ > zero) | (sub_trnstyp$ = one & esub_sec_no$ = esub_totl_no$-one & sub_trnmthd$ = two), [ subout$ = zero no_nc_out$ = m_one sav_absinc = absinc$ #Mirror cancel if sub_trnstyp$ = zero, [ absinc$ = zero pbld, n$, strns_mir_off, *sub_trnsx$, *sub_trnsy$, e$ ] else, #Rotate cancel [ pbld, n$, strns_rot_off, e$ ] absinc$ = sav_absinc no_nc_out$ = zero ] end_sub_mny = sub_mny_t$ psub_end_mny #End in main level for many tools sub, user #Check for coming out of xform with stage tool. if end_sub_mny & stagetool = one, [ *t$ end_sub_mny = zero ] psub_call_s$ #Call to sub level result = nwadrs(strp, sub_prg_no$) sub_prg_no$ = sub_prg_no$ + sav_progno + 1000 #Add sub number offset if sav_progno = sub_prg_no$, result = mprint(sprgnerror,1) pbld, n$, "M98", *sub_prg_no$, e$ psub_st_s$ #Header in sub level result = nwadrs(stro, sub_prg_no$) #sav_n2 = n #n = seqno " ", e$ *sub_prg_no$, e$ spaces$ = 0 if scomm0$ <> snull, "(", *scomm0$, ")", e$ spaces$ = sav_spc pbld, n$, e$ psub_end_s$ #End in sub level n$, "M99", e$ prv_absinc$ = -1 #n = sav_n2 # -------------------------------------------------------------------------- # Canned Text # -------------------------------------------------------------------------- pcan #Canned text - before output call strcantext = sblank if cant_no$ > zero, [ if cant_pos1$ = zero, pcant_1 if cant_pos2$ = zero, pcant_2 if cant_pos3$ = zero, pcant_3 if cant_pos4$ = zero, pcant_4 if cant_pos5$ = zero, pcant_5 if cant_pos6$ = zero, pcant_6 if cant_pos7$ = zero, pcant_7 if cant_pos8$ = zero, pcant_8 if cant_pos9$ = zero, pcant_9 if cant_pos10$ = zero, pcant_10 pbld, n$, strcantext, e$ strcantext = sblank ] pcan1 #Canned text - with move strcantext = sblank if cant_no$ > zero, [ if cant_pos1$ = one, pcant_1 if cant_pos2$ = one, pcant_2 if cant_pos3$ = one, pcant_3 if cant_pos4$ = one, pcant_4 if cant_pos5$ = one, pcant_5 if cant_pos6$ = one, pcant_6 if cant_pos7$ = one, pcant_7 if cant_pos8$ = one, pcant_8 if cant_pos9$ = one, pcant_9 if cant_pos10$ = one, pcant_10 ] if cstop$, strcantext = strcantext + sm00 if cgstop$, strcantext = strcantext + sm01 #Output of strcantext occurs at the end of the output line pcan2 #Canned text - after output call strcantext = sblank if cant_no$ > zero, [ if cant_pos1$ = two, pcant_1 if cant_pos2$ = two, pcant_2 if cant_pos3$ = two, pcant_3 if cant_pos4$ = two, pcant_4 if cant_pos5$ = two, pcant_5 if cant_pos6$ = two, pcant_6 if cant_pos7$ = two, pcant_7 if cant_pos8$ = two, pcant_8 if cant_pos9$ = two, pcant_9 if cant_pos10$ = two, pcant_10 pbld, n$, strcantext, e$ strcantext = sblank ] pcant_1 #Canned text - output call cantext$ = cant_val1$ pcant_out pcant_2 #Canned text - output call cantext$ = cant_val2$ pcant_out pcant_3 #Canned text - output call cantext$ = cant_val3$ pcant_out pcant_4 #Canned text - output call cantext$ = cant_val4$ pcant_out pcant_5 #Canned text - output call cantext$ = cant_val5$ pcant_out pcant_6 #Canned text - output call cantext$ = cant_val6$ pcant_out pcant_7 #Canned text - output call cantext$ = cant_val7$ pcant_out pcant_8 #Canned text - output call cantext$ = cant_val8$ pcant_out pcant_9 #Canned text - output call cantext$ = cant_val9$ pcant_out pcant_10 #Canned text - output call cantext$ = cant_val10$ pcant_out pcant_out #Canned text - build the string for output #Assign string select type outputs if cantext$ = three, bld = one if cantext$ = four, bld = zero #Build the cantext string if cantext$ = one, strcantext = strcantext + sm00 if cantext$ = two, strcantext = strcantext + sm01 if cantext$ > four, [ strtextno = no2str(cantext$) strcantext = strcantext + strm + strtextno ] # -------------------------------------------------------------------------- # Position calculations, generally these do not need to be modified # -------------------------------------------------------------------------- pmiscint$ #Capture the top level absinc for subprograms if sub_level$ <= zero, absinc$ = mi2$ #Disable cutpos2 if not 4 axis, saves time if rot_on_x = zero, cutpos2$ = m_one pusecannedyes # Use canned drilling cycles usecandrill$ = yes$ # Use canned cycle for drill usecanpeck$ = yes$ # Use canned cycle for Peck usecanchip$ = yes$ # Use canned cycle for Chip Break usecantap$ = yes$ # Use canned cycle for Tap usecanbore1$ = yes$ # Use canned cycle for Bore1 usecanbore2$ = yes$ # Use canned cycle for Bore2 usecanmisc1$ = yes$ # Use canned cycle for Misc1 usecanmisc2$ = yes$ # Use canned cycle for Misc2 pusecannedno # Use canned drilling cycles usecandrill$ = no$ # Use canned cycle for drill usecanpeck$ = no$ # Use canned cycle for Peck usecanchip$ = no$ # Use canned cycle for Chip Break usecantap$ = no$ # Use canned cycle for Tap usecanbore1$ = no$ # Use canned cycle for Bore1 usecanbore2$ = no$ # Use canned cycle for Bore2 usecanmisc1$ = no$ # Use canned cycle for Misc1 usecanmisc2$ = no$ # Use canned cycle for Misc2 pmotion_su #Motion Setup (Set brklinestype & linarc) brklinestype$ = zero linarc$ = zero if rot_on_x, [ if cuttype = one, linarc$ = one #Axis subs if cuttype = two, #Polar [ brklinestype$ = rotary_axis$ + three linarc$ = one ] ] pcuttype #Determine the cut type #cuttype (0 = Tool Plane, 1 = Axis Subs, 2 = Polar, 3 = 4/5 axis) cuttype = rotary_type$ if cuttype = three, cuttype = zero if mill5$, [ if rot_on_x = zero, result = mprint(saxisoff,1) cuttype = three ] if rotary_axis$, [ if rotary_axis$ <> rot_on_x, result = mprint(saxiswarn,1) rot_on_x = rotary_axis$ ] #Check for Tool Origin in Polar Milling if cuttype = two & (tox$ | toy$ | toz$), result = mprint(stlorgerr,1) #Transform Rotate, set mr_rt_actv if user selected 'coordinates' if sub_trnstyp$ = one & sub_trnmthd$ = two, [ #Calculate the rotation incremental angle for G68 rt_csav = atan2(sub_m2$, sub_m1$) rt_cinc = prv_rt_csav - rt_csav while rt_cinc > 180, rt_cinc = rt_cinc - 360 while rt_cinc < -180,rt_cinc = rt_cinc + 360 if rot_ccw_pos = one, rt_cinc = -rt_cinc !rt_csav if sub_sec_no$, mr_rt_actv = two else, mr_rt_actv = one ] else, mr_rt_actv = zero pfcalc_u_min pmotion_su pxyzcout #Map coordinates if rot_on_x, [ if cuttype = zero, pxyzcout0 #Toolplane Positioning if cuttype = one, pxyzcout1 #Axis Substitution if cuttype = two, pxyzcout2 #Polar Conversion if cuttype = three, pxyzcout3 #Simulatneous 4 axis (Multi-axis) if rot_ccw_pos = one, csav = -csav if mr_rt_actv <> two, [ pcoutrev if index, pindxcalc pfcalc ] else, feed = fr_pos$ ] else, [ xabs = vequ (x$) feed = fr_pos$ ] pxyzcout0 #Toolplane Positioning xabs = vequ (x$) if cuttype = 2 & rot_on_x = two & vmc, c$ = atan2(vtoolx$,-vtooly$) if rot_on_x = two, csav = -c$ else, csav = c$ pxyzcout1 #Axis substitution if rot_on_x = one, #X axis substitution [ xabs = x$ yabs = zero zabs = z$ + (rotdia$ / two) csav = y$ * (360 / (pi$ * rotdia$)) ] else, #Y axis substitution [ xabs = zero yabs = y$ zabs = z$ + (rotdia$ / two) csav = -x$ * (360 / (pi$ * rotdia$)) ] if c$ <> 0, [ if rot_on_x = two, csav = -c$ else, csav = c$ ] pxyzcout2 #polar interpolation #Drill polar is toolplane drilling toward center #if not a coincident axis #Also, Capture initial index position for Polar Milling if (opcode$ = three & rot_on_x <> three), pxyzcout0 else, [ if rot_on_x = one, #X axis rotation [ csav = atan2(y$, z$) #Z+ zero axisx$ = vequ(aaxisx) xabs = rotp(csav, x$) ] if rot_on_x = two, #Y axis rotation [ csav = atan2(-x$, z$) #Z+ zero axisx$ = vequ(baxisx) xabs = rotp(csav, x$) ] if rot_on_x = three, #Z axis rotation [ csav = atan2(-y$, x$) #X+ zero #csav = -atan2(y, -x) #X- zero #csav = -atan2(x, y) #Y+ zero #csav = -atan2(-x, -y) #Y- zero axisx$ = vequ(caxisx) xabs = rotp(csav, x$) ] csav = csav + c$ ] pxyzcout3 #Multisurf rotary axis motion if rot_on_x = one, #Multisurf Rotary about X [ csav = atan2 (vtooly$, vtoolz$) axisx$ = vequ (aaxisx) ] if rot_on_x = two, #Multisurf Rotary about Y [ csav = atan2 (-vtoolx$, vtoolz$) axisx$ = vequ (baxisx) ] xabs = rotp (csav, x$) u$ = rotp (csav, u$) csav = csav + c$ pcoutrev #Rotary axis revolution calculation (Modify for wind-up) cdelta = csav - prv_csav while abs(cdelta) > ctol, #If motion exceeds ctol, add wind-up [ if cdelta > zero, [ rev = rev - one cdelta = cdelta - 360 ] else, [ rev = rev + one cdelta = cdelta + 360 ] ] if cuttype <> one, cabs = rev * 360 + csav else, cabs = sav_rev * 360 + csav if (cuttype = zero | opcode$ = 3 | (gcode$ = 0 & cuttype <> one)) & one_rev = one, [ while fmtrnd(cabs) >= 360, [ cabs = cabs - 360 rev = rev - 1 ] while fmtrnd(cabs) < 0, [ cabs = cabs + 360 rev = rev + 1 ] #while fmtrnd(cabs) < -360, # [ # cabs = cabs + 720 # rev = rev + 2 # ] if abs(cdelta) >= 0.0005, prv_cabs = c9k ] !csav pindxcalc #Index move calculations, direction is shortest #Check if in tolerance cdelta = frac(abs(csav)/ctable) if cdelta > ixtol & cdelta < 1-ixtol, result = mprint(sindxerror,1) cdelta = prvcabs - cabs #Phase shift delta 10 revolutions, check odd/even if frac(int((cdelta + 3600)/180)/two), indx_mc = one else, indx_mc = zero #Set range 0-360 indx_out = csav while indx_out < 0, indx_out = indx_out + 360 while indx_out > 360, indx_out = indx_out - 360 #Feedrate calculations pfcalc #Feedrate calculations, gcode 0 does not evaluate if gcode$ <> zero, [ if abs(fmtrnd(cabs)-prvcabs) <= 0.001 | index | not(rot_feed) | opcode$ = 3, pfcalc_u_min else, [ #if cuttype = one & (cutpos2 <= one), #Proposed change if cuttype = one & (cutpos2$ <= one | cutpos2$ = four & (opcode$ < 5 & opcode$ > 12)), pfcalc_u_min else, pfclc_deg_inv ] if ipr_type <> prv_ipr_type, prv_feed = c9k ] pfcalc_u_min #Feedrate unit/min ipr_type = zero feed = fr_pos$ if feed > maxfeedpm, feed = maxfeedpm prvfrdeg = feed pfclc_deg_inv #Feedrate deg/min circum = zabs * two * pi$ if cuttype = two & rot_on_x = three, circum = sqrt(xabs^2 + yabs^2) * two * pi$ if circum = zero, circum = c9k #Don't allow Zero ldelta = sqrt((xabs-prv_xabs)^2+(yabs-prv_yabs)^2+(zabs-prv_zabs)^2) cdelta = ((abs(cabs - prvcabs))/360)*circum if ldelta = zero, cldelta = cdelta else, cldelta = sqrt(cdelta^two + ldelta^two) if cldelta = zero, cldelta = c9k if use_frinv, [ #Feedrate inverse calculation ipr_type = two prv_feed = c9k #Always force feed if cuttype = three, cldelta = sqrt((x$-prv_x$)^2+(y$-prv_y$)^2+(z$-prv_z$)^2) frinv = fr_pos$/cldelta # 1/min #frinv = fr_pos/(60*cldelta) # 1/sec if rot_feed & opcode$ <> 3 & opcode$ <> 16, [ if frinv > maxfrinv, frinv = maxfrinv feed = frinv ] ] else, [ #Feedrate deg/min control and calculation ipr_type = zero #Change to ipr_type = one to force new DPM #frdeg = abs(cdelta/cldelta) * abs(fr_pos * (360/circum)) frdeg = fr_pos$ * abs((cabs - prvcabs)/cldelta) if abs(frdeg - prvfrdeg) > frdegstp | ipr_type <> prv_ipr_type, [ #Control output of frdeg if rot_feed & opcode$ <> 3 & opcode$ <> 16, [ prvfrdeg = frdeg feed = frdeg ] ] if frdeg > maxfrdeg & rot_feed, feed = maxfrdeg ] #Incremental calculations ps_inc_calc #Incremental calculations, start xia = fmtrnd(xabs) yia = fmtrnd(yabs) zia = fmtrnd(zabs) xinc = vsub (xia, prv_xia) ps_cinc_calc ps_cinc_calc #Incremental calculations, start rotary cia = fmtrnd(cabs) cinc = cia - prv_cia pe_inc_calc #Incremental calculations, end prvcabs = fmtrnd(cabs) #Avoid updating until called explicitly !xia, !yia, !zia, !cia !x$, !y$, !z$ # -------------------------------------------------------------------------- # Tooltable Output # -------------------------------------------------------------------------- pwrtt$ # Write tool table, scans entire file, null tools are negative if rotaxis$ > 0 | rotary_type$ > 0 | mill5$ <> 0, [ rot_on_x = sav_rot_on_x output_z = no$ ] #if vmc = 0 & tlplnno <> 2, rot_on_x = sav_rot_on_x #if vmc = 1 & tlplnno > 1, rot_on_x = sav_rot_on_x if tlplnno$ > 1, rot_on_x = sav_rot_on_x tlplnno$ = wbuf(3,wc3) #Buffers out tool plane values t$ = wbuf(4,wc4) #Buffers out tool number values if tool_table = 1, ptooltable,e$ if tool_table = 2, ppredtool,e$ if tool_table = 3, pmetatool,e$ if t$ >= zero, tcnt = tcnt + one ptravel pwritbuf5 ptooltable # Write tool table, scans entire file, null tools are negative tnote = t$ toffnote = tloffno$ tlngnote = tlngno$ spaces$=0 if t$ >= zero, [ if tcr$>0, "(", *t$, ptspace, " | ", plistcomm, " | ", *tlngno$, phspace, " | ", *tloffno$, pdspace, " | ", *tldia$, punit, pdiamspc, " | ", *tcr$, " | ", popnote, ")" if tcr$=0, "(", *t$, ptspace, " | ", plistcomm, " | ", *tlngno$, phspace, " | ", *tloffno$, pdspace, " | ", *tldia$, punit, pdiamspc, " | ", " | ", popnote, ")" ] #if t >= zero, # [ # "(", *t, ptspace, " - ", plistcomm, ")" # ] #if t >= zero, # [ # if tcr>0, "(", *tnote, " ", *toffnote, " ", *tlngnote, " ", *tldia, " ", *tcr, " ", popnote, ")" # if tcr=0, "(", *tnote, " ", *toffnote, " ", *tlngnote, " ", *tldia, " ", popnote, ")" # ] spaces$=sav_spc punit # Tool unit if met_tool$, "mm" else, 34 ptravel # Tool travel limit calculation if x_min$ < x_tmin, x_tmin = x_min$ if x_max$ > x_tmax, x_tmax = x_max$ if y_min$ < y_tmin, y_tmin = y_min$ if y_max$ > y_tmax, y_tmax = y_max$ if z_min$ < z_tmin, z_tmin = z_min$ if z_max$ > z_tmax, z_tmax = z_max$ ppredtool # Write tool setup info for Predator Virtual CNC #if tool_typ = 1, styp1 # CENTER DRILL 1 - NTG/S4 #if tool_typ = 2, styp2 # SPOT DRILL 2 - S4 #if tool_typ = 3, styp3 # DRILL 3 - S4 #if tool_typ = 4, styp4 # TAP-RH 4 - S4 - MAX 179 ANGLE #if tool_typ = 5, styp5 # TAP-LH 5 - S4 - MAX 179 ANGLE #if tool_typ = 6, styp6 # REAMER 6 - S3/S1/S2 #if tool_typ = 7, styp7 # BORING BAR 7 - S3/S1/S2 #if tool_typ = 8, styp8 # COUNTER BORE 8 - NTG #if tool_typ = 9, styp9 # COUNTER SINK 9 - NTG/S4 #if tool_typ = 10, styp10 # END MILL FLAT 10 - S1 #if tool_typ = 11, styp11 # END MILL SPHERE 11 - S2 #if tool_typ = 12, styp12 # CHAMFER MILL 12 - S7/NTG #if tool_typ = 13, styp13 # FACE MILL 13 - S7/S9/NTG #if tool_typ = 14, styp14 # SLOT MILL 14 - NTG/S1 #if tool_typ = 15, styp15 # CORNER RAD MILL 15 - S5/FLAT #if tool_typ = 16, styp16 # DOVETAIL MILL 16 - DOVETAIL/NTG #if tool_typ = 17, styp17 # TAPER MILL 17 - S7/S9/S10 #if tool_typ = 18, styp18 # LOLLIPOP MILL 18 - S6 #if tool_typ = 19, styp19 # END MILL BULL 19 - S3 tcr_pred = tcr$ tldia_pred = tldia$ tip_angle_ch = tip_angle*2 spaces$=0 if t$ >= zero, [ # CENTER DRILL if tool_typ$ = 1, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)" # SPOT DRILL if tool_typ$ = 2, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)" # DRILL if tool_typ$ = 3, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)" # TAP-RH if tool_typ$ = 4, [ if tip_angle <= 179, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)" else, "(MTOOL ", *t$, " ", *tldia_pred, " ", "A179.", " ", *flute_len, " S4)" ] # TAP-LH if tool_typ$ = 5, [ if tip_angle <= 179, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)" else, "(MTOOL ", *t$, " ", *tldia_pred, " ", "A179.", " ", *flute_len, " S4)" ] # REAMER if tool_typ$ = 6, [ if tcr$ = 0, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S1)" if tcr$ = tlrad$, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S2)" if tcr$ > 0 & tcr$ < tlrad$, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S3)" ] # BORING BAR if tool_typ$ = 7, [ if tcr$ = 0, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S1)" if tcr$ = tlrad$, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S2)" if tcr$ > 0 & tcr$ < tlrad$, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S3)" ] # COUNTER BORE if tool_typ$ = 8, [ if tcr$ = 0, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S1)" if tcr$ = tlrad$, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S2)" if tcr$ > 0 & tcr$ < tlrad$, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S3)" ] # COUNTER SINK if tool_typ$ = 9, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)" # END MILL FLAT if tool_typ$ = 10, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S1)" # END MILL SPHERE if tool_typ$ = 11, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S2)" # CHAMFER MILL if tool_typ$ = 12, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle_ch, " ", *flute_len, " S7)" # FACE MILL if tool_typ$ = 13, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S1)" # SLOT MILL if tool_typ$ = 14, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S1)" # CORNER RAD MILL if tool_typ$ = 15, [ if tcr$ = 0, "(MTOOL ", *t$, " ", *tldia_pred, " ", *flute_len, " S1)" else, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S5)" ] # DOVETAIL MILL if tool_typ$ = 16, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S8)" # TAPER MILL if tool_typ$ = 17, [ if tcr$ = 0, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S7)" if tcr$ = tlrad$, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S9)" if tcr$ > 0 & tcr$ < tlrad$, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tcr_pred, " ", *tip_angle, " ", *flute_len, " S10)" ] # LOLLIPOP MILL if tool_typ$ = 18, "(MTOOL ", *t$, " ", *tldia_pred, " S6)" # END MILL BULL if tool_typ$ = 19, "(MTOOL ", *t$, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S3)" ] spaces$=sav_spc pmetatool # Write tool setup info for MetaCut View tcr_meta = tcr$ if tool_typ$ = 13 | tool_typ$ = 17, tldia_meta = tldia$ + (2 *(flute_len * tan(tip_angle))) else, tldia_meta = tldia$ if cctotip$ = 0, tipcomp = 1 else, tipcomp = 0 if tool_typ$ = 10 | opcode$ = 3, tipcomp = 0 if tool_typ$ = 12, td_meta = tip_dia else, td_meta = 0 if tool_typ$ = 13 | tool_typ$ = 17, td_meta = tldia$ flute_meta = flute_len oa_meta = oa_len ta_meta = tip_angle cd_meta = hldr_dia cl_meta = hldr_len sd_meta = cd_meta #(NWDTOOL NAME"1/2 CHAMFER MILL" T1 D.5 R0. F2. L3. A45. TD.06 CD2. CL1. SD2. C0) # N = "Tool name" # T = Tool No. # D = Tool Dia. # R = Corner Radius # F = Flute Length # L = Tool over all length # A = Tip angle or Taper angle # TD = Tip Dia. # CD = Colllet/Holder Dia. # CL = Collet/Holder Height # SD = Spindle Dia. (set equal to Collet Diameter) # C = tip or center 0 = tip 1 = center spaces$=0 if t$ >= zero, "(NWDTOOL N", 34, pmetacomm, 34, " ", *t$, " ", *tldia_meta, " ", [if tcr_meta > 0, *tcr_meta, " "], *flute_meta, " ", *oa_meta, " ", [if ta_meta<>180, *ta_meta, " "], [if td_meta > 0, *td_meta, " "], *cd_meta, " ", *cl_meta, " ", *sd_meta, " ", *tipcomp, ")" spaces$=sav_spc # -------------------------------------------------------------------------- # Buffer 5 Read / Write Routines # -------------------------------------------------------------------------- pwritbuf5 # Write Buffer 1 b5_gcode = gcode$ b5_zmin = z_min$ b5_zmax = z_max$ b5_gcode = wbuf(5, wc5) preadbuf5 # Read Buffer 1 size5 = rbuf(5,0) b5_gcode = 1000 min_depth = 99999 max_depth = -99999 while rc5 <= size5 & b5_gcode = 1000, [ if rc5 <= size5, b5_gcode = rbuf(5,rc5) if b5_zmin < min_depth, min_depth = b5_zmin if b5_zmax > max_depth, max_depth = b5_zmax ] # -------------------------------------------------------------------------- # Numbered questions for Mastercam # -------------------------------------------------------------------------- 38. Rapid feedrate? 80.0 1538. Rapid feedrate (metric)? 2000.0 #76. Configuration file name? 80. Communications port number for receive and transmit (1 or 2) ? 2 81. Data rate (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 9600 82. Parity (E/O/N)? E 83. Data bits (7 or 8)? 7 84. Stop bits (1 or 2)? 2 85. Strip line feeds? N 86. Delay after end of line (seconds)? 0 87. Ascii, Eia, or Binary (A/E/B)? A 88. Echo keyboard to screen in terminal emulation? n 89. Strip carriage returns? N 90. Drive and subdirectory for NC files? 91. Name of executable post processor? MP 92. Name of reverse post processor? RP 93. Reverse post PST file name? RPFAN 100. Number of places BEFORE the decimal point for sequence numbers? 0 101. Number of places AFTER the decimal point for sequence numbers? 0 103. Maximum spindle speed? 2000 107. Average time for tool change (seconds)? 30.0 159. Show first and last position as fully compensated in simulation? n 161. Enable Home Position button? y 162. Enable Reference Point button? y 163. Enable Misc. Values button? y 164. Enable Rotary Axis button? y 165. Enable Tool Plane button? y 166. Enable Construction Plane button? y 167. Enable Tool Display button? y 168. Check tplane during automatic work origin creation? y # -------------------------------------------------------------------------- # Default Miscellaneous Real Values # -------------------------------------------------------------------------- 201. Default miscellaneous real variable 1 (mr1)? 0.0 202. Default miscellaneous real variable 2 (mr2)? 0.0 203. Default miscellaneous real variable 3 (mr3)? 0.0 204. Default miscellaneous real variable 4 (mr4)? 0.0 205. Default miscellaneous real variable 5 (mr5)? 0.0 206. Default miscellaneous real variable 6 (mr6)? 0.0 207. Default miscellaneous real variable 7 (mr7)? 0.0 208. Default miscellaneous real variable 8 (mr8)? 0.0 209. Default miscellaneous real variable 9 (mr9)? 0.0 210. Default miscellaneous real variable 10 (mr10)? 0.0 # -------------------------------------------------------------------------- # Default Miscellaneous Real Values (METRIC) # -------------------------------------------------------------------------- 1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0 1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0 1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0 1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0 1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0 1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0 1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0 1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0 1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0 1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0 # -------------------------------------------------------------------------- # Enable/Disable Miscellaneous Real Variable switches # -------------------------------------------------------------------------- 1611. Enable miscellaneous real variable 1? y 1612. Enable miscellaneous real variable 2? y 1613. Enable miscellaneous real variable 3? y 1614. Enable miscellaneous real variable 4? y 1615. Enable miscellaneous real variable 5? y 1616. Enable miscellaneous real variable 6? y 1617. Enable miscellaneous real variable 7? y 1618. Enable miscellaneous real variable 8? y 1619. Enable miscellaneous real variable 9? y 1620. Enable miscellaneous real variable 10? y # -------------------------------------------------------------------------- # Default Miscellaneous Integer Values # -------------------------------------------------------------------------- 301. Miscellaneous integer variable 1 (mi1)? 0 302. Absolute or Incremental [0=ABS,1=INC] (mi2)? 0 303. Miscellaneous integer variable 3 (mi3)? 0 304. Miscellaneous integer variable 4 (mi4)? 0 305. Miscellaneous integer variable 5 (mi5)? 0 306. Miscellaneous integer variable 6 (mi6)? 0 307. Miscellaneous integer variable 7 (mi7)? 0 308. Miscellaneous integer variable 8 (mi8)? 0 309. Lock on First WCS [0=No,1=Yes] (mi9)? 0 310. M00 before operation [0=No,1=Yes] (mi10)? 0 # -------------------------------------------------------------------------- # Enable/Disable Miscellaneous Integer Variable switches # -------------------------------------------------------------------------- 1621. Enable miscellaneous integer variable 1? y 1622. Enable miscellaneous integer variable 2? y 1623. Enable miscellaneous integer variable 3? y 1624. Enable miscellaneous integer variable 4? y 1625. Enable miscellaneous integer variable 5? y 1626. Enable miscellaneous integer variable 6? y 1627. Enable miscellaneous integer variable 7? y 1628. Enable miscellaneous integer variable 8? y 1629. Enable miscellaneous integer variable 9? y 1630. Enable miscellaneous integer variable 10? y # -------------------------------------------------------------------------- # Configuration File association parameters (default is "y") # -------------------------------------------------------------------------- #400. Name of associated cfg file? 401. Read SYSTEM COLORS section? y 402. Read ALLOCATIONS section? y 403. Read TOLERANCES section? y 404. Read DATA PATHS section? y 405. Read COMMUNICATIONS section? y 406. Read DRAFT SETTINGS section? y 407. Read MISCELLANEOUS section? y 408. Read NC SETTINGS section? y 409. Read DIALOG SCRIPTS section? y 410. Read DESIGN SETTINGS section? y 411. Read PLOTTER SETTINGS section? y 412. Read ALT-KEY ASSIGNMENTS section? y 413. Read CAD section? y 414. Read START/EXIT section? y 415. Read SCREEN section? y 416. Read FILE NAMES section? y 1500. Chook to execute from 'Misc. values' button? 1501. Insert parameter information in the ascii NCI? n 1502. Write operation information to binary file (.ops)? y 1503. Write transform operations (0=transform ops, 1=source ops, 2=both)? 1 1520. Display a warning when cutter compensation in control simulation finds an error? n 1521. Number of controller look-ahead blocks for CDC in control? 2 1530. Ignore work offset numbers when processing subprograms? y 1531. Ignore contour flags when processing subprograms? y # Do NOT manually change the answer for Q.1999 ! 1999. Product major version number that post supports? 9 3001. Machine acceleration? 2 3002. timing size? .1 [CTRL_TEXT_END]
