Dim builddate As StringDim test As IntegerDim b As BooleanDim b1 As BooleanDim channel(6) As BooleanDim Period(6) As LongDim duty(6) As Long                ' dim ' tried type as long and singleFor v=1 To 8setUserlabel(v," ")sleep(20)Next v              ' clean screen. program needs 8 userlabels (1 to 8) and one wide buttonSet device = CreateObject("PoKeysDevice_DLL.PoKeysDevice")         ' declaresetbuttontext "activation" connectb=device.getbuilddate(builddate)message bsetuserlabel(3,"Build date  "&builddate )' test for communicationssetbuttontext "PWM" For v=0 To 5channel(v)=trueperiod(v)=12000000duty(v)= 6000000Next v' set start values ' here is problem ? I tried many syntax combos ? error is' class does not support automation or does not support expected interfaceb = device.SetPWMOutputs (channel() ,Period() ,duty() ) b = device.GetPWMOutputs (channel() ,Period() ,duty() )For v=3 To 8setuserlabel ( v , str$(b1) & Str$(b) & " " &   str$(period(v-3)) &  Str$(duty(v-3))   )Next v' show datadisconnectEndSub disconnectb=device.DisconnectDevice()End Sub      Sub connecttest=device.enumeratedevices()a$="Devices"+str$(test)setuserlabel (1,a$)b=device.ConnectToDevice (0)a$="Connection " + str$(b)setuserlabel(2,a$)If b <> true Then StopEnd Sub  
