Installation:
Run the setup.exe file.
Recommended to install in a directory under your Mach3 installation e.g.: 'c:\mach3\machme'
No Mach or system files are altered.
A program group will be created, default: MachMe, and an uninstall will be created as well 'unins000.exe'.
A help file 'MachMe.chm' will be installed, accesable through the programs menu->help.  Depending on your operating system you may have to 'unblock' this file.  Find the help file and right-click. Select unblock if available.
The first time that you run MachMe you will be given a dialog box to enter the 'mach3.exe' file location.  Either browse to the file (recommended), or type in full path and file name.
Next you will be prompted for the profile xml file that you want to use.
