'place after each chain cut in project to 'to remove 0.0015 accum.of movement'that is not shown by DRO's in Mach3'***requires home soft limits to be set to '*** X min -0.0015'*** Y min -0.0015'*** Z max  0.0015'Edit G-code'1. Place M209 after Each Z1.0'2. copy last Y movement to after each '   Next X movement so that Mach3 '   will show correct tool path'   In tool path window'*******************************************'*******************************************'1. manually Set axis To home location With'   control box off'2. turn On control box'3. Ref. mach. And work coordinates To zero'4. Jog To start location of project'5. Ref. work coord. To zero '6. Regen toolpath window'******************************************'******************************************'******************************************'*** Written by www.runetec.com 4/6/09 ****'***          AS IS                    ****'******************************************'$$$$$$$$$$$ Send donation To:$$$$$$$$$$$$$'$$	Lauri Koponen                    $$'$$	372 Millard Hill Rd              $$'$$	Newfield, NY 14867               $$'$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$                   '******************************************'******************************************'******************************************varx = 0'zero var to perventvary = 0'accum. of variables valuesvarz = 0varx1 = 0'zero var to perventvary1 = 0'accum. of variables valuesvarz1 = 0varx1 = GetDRO(0)'set var to DRO'svary1 = GetDRO(1)varz1 = GetDRO(2)code "G28"While IsMoving()'wait for movementWend            'to stop varx = GetDRO(0)'set var to DRO'svary = GetDRO(1)varz = GetDRO(2)SetDRO(0,0)SetDRO(1,0)SetDRO(2,0)DoButton( 24 )DoButton( 23 )DoButton( 22 )DoButton( 25 )code "G28.1 X-0.003"'remove un-wanted shiftcode "G28.1 Y-0.003"code "G28.1 Z0.003"While IsMoving()'wait for movementWend            'to stop DoButton( 24 )DoButton( 23 )DoButton( 22 )DoButton( 25 )SetDRO(0,0)SetDRO(1,0)SetDRO(2,0)code "G28.1 X-0.0015"'remove un-wanted shiftcode "G28.1 Y-0.0015"code "G28.1 Z0.0015"While IsMoving()'wait for movementWend            'to stop DoButton( 24 )DoButton( 23 )DoButton( 22 )DoButton( 25 )SetDRO(0,0)SetDRO(1,0)SetDRO(2,0)varz = varz * -1'return to start positionvarx = varx * -1vary = vary * -1code "G0 Y" & varycode "G0 X" & varx  'return to starting pointcode "G0 Z" & varzWhile IsMoving()'wait for movementWend            'to stop SetDRO(0,0)'required to returnSetDRO(1,0)'DRO's to state before Macro callSetDRO(2,0)code "G0 Z" & varz1code "G0 Y" & vary1code "G0 X" & varx1  'return to starting pointvarx = 0'zero var to perventvary = 0'accum. of variables valuesvarz = 0varx1 = 0'zero var to perventvary1 = 0'accum. of variables valuesvarz1 = 0
