textFilePath = "C:\mach3\FixOffsetInfo.txt"Set objFSO = CreateObject("Scripting.FileSystemObject")Set objTextFile = objFSO.CreateTextFile(textFilePath)Num=5221Do Until num=10320Num=Num+1N = GetVar(num)Dt= Date()Tm= Time()If N <>"0" ThenobjTextFile.WriteLine("Parameter# "& num &"  * "& N  & Chr(13) & Chr(10))ElseEnd IfLoopobjTextFile.WriteLine("**")objTextFile.WriteLine("  Date: " &Dt &" Time: " &Tm)objTextFile.CloseDim sCOMMAND As String sCOMMAND="print c:\mach3\FixOffsetInfo.txt" Shell("c:\winnt2\system32\cmd.exe /c" & sCOMMAND)End
