G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: terror_storm on May 26, 2014, 12:08:59 PM
In CamBam (free version) the tool path looks correct, with multiple depth increments and multiple passes of the profile. When I load the gcode into M3 (free version) it only "loads" the top profile pass. It does not seem to recognize the additional passes & depth cuts. It will run one pass of the profile and then quit. I expect it to increase the depth of the bit, then run the profile again.
What am I doing wrong? Is this a limitation to the free version of M3?
Thanks!
The demo version has a 500 line gcode limit. CamBam may also have a restriction of some type. If neither of those is the problem, post the code here so we can see whats going on.
The file is only 147 lines long. See attached.
Runs fine here 4 passes to the bottom. WHEN you say it quits does it return to the top of the program or just STOPS at the line it is on?
Is there any message displayed? It works fine here as well.
Works fine for me, too.
Well this is embarrassing. I thought I overwrote an old pure 2D file with a new one with depth, but I must not have. Works for me now, too.
If you can't tell, I'm a n00b at this. From this experience I learned to look at the code. I didn't even notice until BR mentioned to look at it, "what line it is on". I then noticed the code was very short.
Thanks again for the help!
no problem , always a big help to get a fresh set of eyes to look at it.
(;-)TP
