General CNC Chat > Show"N"Tell ( Your Machines)
Controller and drivers
TJoensen:
Ok,
What am trying to do with the enable signal? Get 24v output?
TJoensen
joeaverage:
no, it will form a conductive path. You need to supply 24V from the MB2 to pin 16, 0V from the MB2 to pin 1 and then connect
the Enable output of the MB2 to pin 15.
When the DYN4 is enabled pin 15 will be 24V, when disabled 0V.
TJoensen:
Hey,
I tried to connect the driver, like you said.
If I'm measuring voltage between pin 15 and pin 1, I get 0V when motor is disabled and 13,78V when motor is enabled.
Tjoensen
joeaverage:
I'm surprised that the voltage drops that much but it suggests that there is current flowing into the DYN4 and should be
sufficient to turn the opto diode on.
You should now be able to hook up the step/dir signals and the servo should run.
How have you programmed the drive?
TJoensen:
Hey,
Programmed the drive how?
TJoensen
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
