Mach Discussion => Mach4 General Discussion => Topic started by: Plasron on September 04, 2019, 12:49:14 PM
We have a windows 10 laptop 64 bit , I found out it has a SSD, Solid State Drive, will this computer work with Mach4 and Warp9 ESS ?
Thanks in advance
Ron
Why wouldn’t it work?
Yes ssd are faster than HDD been using on the the cnc controller Mach4 ind ESS touch screen
Thanks Stuart
We may go back to Mach3 this Mach4 is way over my head.
I was able to get the X Motor to make a slight sound, the Motors tab in Mach4 is beyond me as to how to get them to run.
Thanks again
Ron
Ron,
IMHO it would be worth the effort to get Mach4 running. Warp9 has a great how-to that'll step you right thru the process. If you've got a working machine running on Mach3 you're most of the way there.
Tom
Ron
In Mach 4 motors tab
Click check box then click the name and turn it blue then you can config the motor
