Mach Discussion => Mach Screens => Topic started by: BigZ on April 02, 2008, 08:48:17 PM
Trying to modify Greolts screen for a laser edge finder for a camera. Unfortunately can't access the script most of the time when I double click or modify/move the buttons. when I finally can modfiy them parts of the screen are jumbled up and it locks up again. >:(
Liam
One thing I figured out the hard way is this, set it to a res. that you can see the entire screen. If you can and scroll over to a place the buttons at the other extreme can't be seen, go back and now you can't edit them. Also disable the background image. THere are a couple of videos on it in the tutorial, video tutorials section.
;D ;D... Screen4 is like a woman with PMT........You have to tip toe around trying hard not to offend it...... ;D ;D
I use a large screen so have not seen some of the issues with elements jumping out of place when scrolling.
Greg
Cheers Brett it was the res causing the problem.
Greg after 4 frustrating hours last night the woman with PMT was about to get the tip of my toe.
All I have to do now is figure how turn the camera plugin on with a button.
Liam
