G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: boblee on March 16, 2007, 07:47:52 PM
Hi Guys I have a text file that I developed from a kayak designing software it doesn't export to dxf.
Can any body tell me how to take those x/y cordinates and write a gcode file that I could cut with mach?
Material thickness is 3/4". This is a station form for a kayak that I modified with the kayak software .
I'm trying to build a kayak for my girls .
I'm sure its not hard I just don't know how to format the gcode ( which gcodes to use and where ) its just a 2d file . can anybody help me?
Thanks Bob
Hi Bob,
what formats will the software export?
Graham.
Hi Graham only a text file or a csv file
I have sent you a PM
Graham.
Hi Graham be patient I'm on dialup
You should be able to do it pretty easily with Excel
Hi ger21 Graham is doing a great job how would it be done with excel is there a less painful way for both of us ?
Load the .csv into Excel, insert columns of G1, X, and Y in the appropriate places. Use Concatenate function to create each line. You'd need to manually add rapids here and there probably.
I probably spoke too soon, especially not having seen the data you have. Is Graham creating a model from the poiints first, then using CAM? That's probably the preferable route, now that I'm thinking about it.
Ger21 I sent you a PM.
Thanks Bob
