G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: ttharp on January 02, 2014, 11:35:10 AM
I have recently built a diy cnc and have successfully run gcode from others on the internet. I have also written some myself and used some of mach's wizards to create some. All with very good success.
Machine and mach appear to be set up correctly. I recently purchased aspire and am attempting to create gcode from vector images. I can create the tool paths and everything looks good in the preview model. I export the gcode and load and run it on my cnc and it stops before the project is finished. I have done this with 2 different projects and i can't figure out why it's stopping.
if someone wouldn't mind looking over my attached code for errors i would appreciate it.
Travis
You need a licensed version of Mach3 to cut more than 500 lines of g-code.
my copy of mach should be licensed
i will double check to make sure there is not some type of registration error
Your name should be in the title bar, or in Help > About Mach3.
Ok. Thanks. This fixed it. I thought I had registered the copy but I had not. Sorry to have you answer this question for probably the thousandth time.
Sent from my iPhone using Tapatalk (http://tapatalk.com/m?id=1)
