Mach Discussion => VB and the development of wizards => Topic started by: fer_mayrl on February 19, 2007, 05:24:49 PM
Ok, I have a VB script running in the macro pump, and it uses 99% of my computers resources, so sometimes it slows down, It may be my way of coding or something. Anyone here sees something wrong with the code?
BB=0
CC=0
DD=0
EE=0
FF=0
Do While GetUserLed(1020)=1
Code "G01 A36"
While IsMoving()
Sleep 100
Wend
If IsActive(Input1)=TRUE Then
BB=1
Else
BB=0
End If
If BB=0 And DD=0 And FF=0 Then
DeActivateSignal(OUTPUT1)
DeActivateSignal(OUTPUT2)
DeActivateSignal(OUTPUT3)
ElseIf BB=1 And DD=0 And FF=0 Then
ElseIf BB=0 And DD=1 And FF=0 Then
ElseIf BB=0 And DD=0 And FF=1 Then
ElseIf BB=1 And DD=1 And FF=1 Then
ElseIf BB=1 And DD=0 And FF=1 Then
ElseIf BB=1 And DD=1 And FF=0 Then
ElseIf BB=0 And DD=1 And FF=1 Then
End If
CODE "G04 P375"
While IsMoving()
Sleep 100
WEnd
CODE "G04 P375"
While IsMoving()
Sleep 100
WEnd
FF=EE
EE=DD
DD=CC
CC=BB
Loop
End
Hey Fer,
I remember seeing something about this a while back. I can't remember for the life of me what it was for sure. I think it may have been the While if statements.
Do you have this line at the start of your code?
Declare Sub Sleep Lib "Kernel32" (ByVal dwMilliseconds As Long)
no, let me add it, and let you know
Fernando
Is there a VB command, that acts as a dwell? i dont know, like:
DWELL 100
or
PAUSE 100
where the 100 is in milliseconds?
Regards
Fernando
Thanks a lot Ger,
That did it, CPU load less than 1%
Still, Is there a DWELL or PAUSE command?
Regards
Fernando
the code"G4" doesn't work for you? I don't know of a "pause", but I'm not a programmer either. :)
It delays, but its not as precise As I would like it to be... I could try lowering the argument on the sleep command to make it better
Fernando
