:D Win a free Grex :D!!!!!!!!!!!!!!!!!!! ;D Mach licenses ;D & a :o G100 plugin :o
[/u][/color][/size]
You can win this package worth more than ;D $600.00 ;D by guessing the number of chips in the picture below. The winner will be announced May 29th unless someone guesses it spot on before that time. If no one gets it spot on by then, I will award it to who ever is closest. I will be giving hints from time to time so keep an eye on it. The first hint is, the number is between 3,000,000 and 2,000,000. Only one entry per member. It can however be edited at any time. In other words, you can go to your original post and edit the number you wish to submit. That is, until we lock it on the 26th.
If anyone doesn't know what this competition is for here are links to pages that will help you understand.
http://www.artsoftcontrols.com/
http://www.geckodrive.com/product.cfm?pid=19
Special thanks to Benny, Mariss of Gecko Drives, Stephen Hardy and Artsoft for putting this into motion.
Hi:
Can you post a higher resolution picture, I keep losing count due to pixelation of the image. I keep losing count at about
673.. I know there must be more than that..
LOL. :-)
Art
Well using the Beverly Hillbilly math, whis naught tymes naught is naught I guess 2,662,798 ;D
If I need to re cyfer it, let me know!
Mike
edited to add the # of completion
1..2...3.....
1...2....3.....
Alright, I'll just say......2,304,000!
Hi, the correct number is 2,746,200 i just finnished counting! cul brian f.
Hmmmmm.......
Based on the size of the cutter, angle of the light, material being cut, noise coefficient of the influx jitter, and local weather (here not there), I'll say: 2,134,618.
Doug
Hello !!!
My bet is 2,915,767
See ya
2,601,572
Well lets see. on: May 14, 2007, 06:46:20 pm the moon was about to rise giving max magnetic pull at 11:05 pm. The Earth's diameter is about 12,750 km, and the distance from the Earth to the Moon is about 385,000 km.. So its obvious 2,883,888 chips.
Later
Bob
2,608,713 did not count the ones on the floor....gabriel
Ok Brett,
Did somebody actualy count these or is this a random number? My guess is 2,867,648
The answer is obviously 2,411,499
1) Mach is 340.29 meters/sec
2) Mach3 then is 1,020.87 meters/sec
3) IPM is used a lot in CNC. Mach3 is 2,411,499 IPM
My answer doesn't count because I used a calculator.
Mariss
definitely 2,743,928.... definitely definitely 2,743,928 (Rain man)
2,718,281.828459045..... :)
- Bob
How about 2,894,576 ? Type a 2, mash the number pad and delete everything beyond seven figures.
T.J.
Since "lots" is not deterministic enough, how about 2,430,875.
George
Tumble in sleep at *********
Will try again tomorrow.
All your other posts have been deleted. The rules clearly state one entry per person. The first answer given by an entrant will be the only entry.Benny
Sorry i did not read the rules good.
So hereby my only and the only good answer 2.997.874 (did not count the broken chips)
Greetings:
Willem
2,405,251 using a formula for random kaos.
I think it is:
2,000,063
Adrian
mmmmmmmmmmm wonder who counted them in the first place? I know it couldn't have been you Brett, you cant count past 231/2, by that time you have run out of fingers and toes :D
Hi All.
Considering this was my mess I probably am disqualified from guessing but I will share some info that might help narrow things down a little.
I used a 2 flute high helix solid carbide end-mill.
The spindle speed was 5700 rpm.
The cut speed average was 24 ipm.
The stock started out at 2" x 2" x 3.5" - 6061 about 70% was removed.
The rough down was .250 depth of cut with .1 step over.
This was the 8th part cut that day.
It was 95 degrees in the shop.
The mill was controlled with a Grex and Mach.
I was wearing shorts and was probably drinking beer by then.
It filled a 20 gallon shop vac bag about 3/4 the way up. And it took me many hours to clean the mill.
Hope that helps!!
Oh and here is another pic that will make it easier to count the chips on the floor ;)
Chad
Hi how about 2999999
Chad,
What is the diameter of the 20 gallon vacuum?
I might have to recalculate my formula.
Codemangler
If someone pays me $550 bucks I'll tell them how many chips there are.
I think it is:
2,777,071
Granado
2,225,847
My guess is 2,369,148 - but as with most things these days, according to my wife, I've probably got it wrong again!
LOL, all of you are cracking me up. This is fun.
Chad, I bet you had no idea what a mess you were making. ;D
Pure Guesswork now with some calcs 2,736,001 I see someone else worked it out the same so I added 1
Hi Guys
I just removed a virus file that was named A0093027.exe. I haven't had a virus in a long time so it must be a sign. I'm going to win! I'm sure of it! I hope I win. If I don't win I'll never own a G-Rex. 1 in a million chance. Hmmm, pretty long odds. Wonder if I can haggle Benny down to 20 bucks for the answer. I've spent way too much money on hobby CNC and I've been put on wifey credit hold so this is my only hope. Please god please!!!
I'll go with 2,093,027
Derek
Hi all,
Just my two cents. 2,501,786 no, maybe 2,701,678no maybe 2,500,076
My guess.. 2,999,999
I'm thinkin'............ 2,500,000 +/- 1
Tim
Hmmmm.
It's obviously larger than an buttload....
...but seems smaller than an a$$load......
My guess is that it's a $hitload
Think my guess would have to be 2,567,890
Assuming a 50% duty cycle and a full 8 hour day, 2,736,000!
2218782 Can't win if you don't play (from a cheesy Florida lottery billboard)
OKl I'll play - having subjected the clues given so far to a bit of dimensional analysis, the spread sheet says that a crucial piece of info is missing... Please provide a hint re the diameter of the cutter used and I will have the magic formulas provide THE answer as my entry.
OK - I'll play.
I've carefully considered the clues given so far; subjected them to a bit of dimensional analysis and constructed a modelling spread sheet... alas, two crucial piece of info are still needed....
1) what diameter cutter was used?
2) I also need to know what type of shoe soles you were wearing and how many times you left the area during the job (to subtract out the chips removed via this process).
With these missing pieces I can complete the variables of the formula (and use some rational estimations of finish vs roughing feed/speed ratios), and I will have the magic model provide my answer for entry.
Hi Guys
You just as well quick i think I got it 2,299,371 But again I could be wrong that would be the first time ha ha ah aha
My very un-scientific answer is 2,851,769 LMK
Well, I blew up the photo and every pixel has one chip in it. At 800 x 600 resolution that would only be 480,000 chips ;~)....
But my best actual guess is 2,543,496.1478543365232, to be more accurate.... Just a hunch....
Steve
Can't win if you don't register and guess, so:
2,007,529
Needed that 6 so 2,007,529
i made a mistake at 2,195,644 but i think it should be 2,206,457. :'(
but at the new count i've got it!
2 + secons quater(2) +day(06 + month(4) + year(57) thats my birthay and also the amount of chips!! ;D
Best Regards,
Christian
Hi All,
If the figure is between 2 000 000 and 3 000 000 then it's got to be 2 500 000.
Keep my fingers crossed.
Greg ??? ??? ???
2,607,770
Well, I hate to be a sadist, but I'll go for a free anything... My estimation would be 2,613,497 chips. I'll take my prize now thanks!
Obviously 2,718,281.828
Considering feed, spindle speed and size of part remaining.... 2305100
If I was a master of wit and repartee I would post a very clever comment.
But I'm not so.....2,758,686
Well, given the air temp in the shop, the gravitational pull on the machine, plus the fluctuation in dirty current. I'd have to guess the amount of chips at 2,918,763. This is also taking into fact that the muffler bearings and the watchamacullat were fuctioning properly.
Qoute: Have fun, live everday like it is your last, and remember: You'll never see a U-Haul behind any hearse.
OK Ben, the correct answer is 2,221,164 chips, I take cash or cheques, send me the money pronto...
Splint
2,431,111 to be exact!
Bob
My Grandmother says it looks like the dandruff from her old man and reckons it was 2.3 Kilograms worth. or about 2,421,567 pieces.
So that's my guess. 2,421,567
PS. what was the chip load,spindle speed, feed rate and time of the cut?
Rich
Well the majority of people are voting above 2,500,000.
90% of people think that they are right 70% of the time when deciding a point with any other person, and we know that actually only 50% of the people can be right, so therefore 60% of the people who voted so far are too high, and there's a 60% chance that its below 2,500,000.
Now when we say 'between' 2,000,000 and 3,000,000 is that inclusive or exclusive, because my count could be out by a factor of '1' and someone else could win if we're not sure?
So lets say its 'inclusive'. That gives us a range of +- 250,000, which means I'm already 50% more likely to be right that anyone else! ;D
Soooo.....its spelled 'g-rex' .......... g is the 7th letter in the alphabet, and the symbol '-' is 12 buttons from the left on my keyboard. 'r' is the 18th letter in the alphabet, 'e' is 5th, and x is the 24th letter in the alphabet.
So thats 7 x 12 = 84 ...... x 18 = 1512 ..... x 5 = 7560 ..... x 24 = 181,440
This is post number 53, so breaking that down it's '5' and '3'
so 181,440 x 5 = 907,200
and x 3 = 2,721,600
Using our original logic, we know that we're probably out by 500,000....... so 2,721,600 - 500,000 = 2,221,600 which is withing our range of probability of 500,000. :P
My 'Guess' is 2,221,600
Oh no baccu! You posted while I was typing and made my previous post number 54 instead of 53.....this has screwed up all of my calculations....guess it's up to luck now.... :D
LOL, I love it. ;D
Sorry, guys.. somethign went wrong with the photo attachments., we're trying to fix..
My shot in the dark; 2345678.
Pete.
I counted
2,500,0001. (Hmmm, I must of missed 5 hiding down at the bottom of the pile so make that 2,500,006.)
Oh, no, their must have been more hiding, so make that 2,507,006.
Alan
two million + stone cold + a magnum = 2,316,357
2,070,680
2,800,000
I'd ask my engineer friend but he's always off by at least .1 ;D
So here goes.
2,285,391
My guess is 2.763.870
Per
I see a chip that is broken in two pieces, must i count thatone as one or as two chips?
Greetings:
Willem
Well Willem, that one we counted as 1.5 I think. ;D
I can't tell you where it is placed but you must use 6 to win this race.
Hmmmm...... maybe 2,000,006
Well I just spent the last half hour adding up all the entries and finding the average and it was wrong ! then I computed all the feeds and speeds with the mass removed at two flutes per 24ipm but since they were'nt being productive with such a light chipload ! that calculation was obviously wrong too ! So .... 2 plus hint plus hint = 2,673,600 just has to be the correct answer ! Almost forgot "Thanks Benny" the checks on its way !
AHA ! the task is impossible ! 1) stated find exact number of chips in photo ! 2) could only be done with a mathmatical calc 3) calc at best would only be an estimation 4) calc would be for total of all chips absolute except that calc would include time cutter was entering or leaving matr'l leaving answer eroneous 5) The only answer that would be even remotely possible is the one that has been selected and settled upon as "The correct answer" 6) That means that we are not trying to guess the number of chips in photo but the answer that has been selected and aggreed upon ! 7) Benny ! I had to cancell the check !
So my guess for the agreed upon winning number would have to be ......... 2,673,686 +/- <326,394>
Quick and dirty answer - 2, 666,666. No time to write more. Have to go recheck my count.
Bob @ BobsShop
2,300,600
2,634,285
2,362,437 Must be some climb cutting going on there. ;)
:o Well, it just keeps getting better. Steve Hardy has been nice enough to throw in a free G100 plugin as well. :o
[/u][/color][/size]
I guess 2,715,371 or for the Europeans 2.715.371 :), as it is the first prime number I thought of between 2 and 3 million
I got it, I got it !!!!
2,286,000
Arnie
Must be:
2,007,526
Lemo ;D
As before, I can't tell you it's place but if you would use a 7, it would help in this race.
2,547,895 just because
1 poatato chip on the control cabinet
roonster71
Eanie Meanie Miney Moe its
2,624,622
Cam
That's easy; exactly 2,500,000 chips. How do I know,well I wrote a little macro and I no longer designate a design for a part,I just designate how many chips I want. So I kept adding chips starting at '1' chip(I should have known there was more than one) and all of a sudden I was up to 2.5 million and the part looked exactly like the one in the photo.So,I'm right.-Keith
2,418,376
with the right cutting fluid , i'd say theirs 2,796,346
=2.513.024
Hi ! ???
2,830,000
I would have to say 2,976,803
Chris
2_157_362
JJ
2,676,503 ;D
So easy.....
2,712,143
I guess 2,345,678.
Dave,
Thanks for the hint, Brett!
2,700,077
Glenn
Between 3 and 2 millions huh?....
My bet 2 500 000..
OK OK... the guy said the clue was in the middle... why not HAHAHAHAHA
Cheers!
2,736,543
How did you count them to find out?
I count 2,500,000 plus or minus 500k
too easy... 682,412. I meant 2,682,412.
Gianni
my bet is 2695200 :)
good luck to all !
Pablo
Hi.
It's obviously 2,436,932 chips. Thats also counting the ones visible on the near side of the splash board.
Rod
Here's my guess: 2,835,642
2,407,777
How you will count actual number of chips ?
2,893,672
2,634,979 chips!
2,865,746 good luck to everybody. Murat..
:)5070605
rik
2 652 136 but thats just a WAG
I'll guess 2,222,222.
How long did it take to count them?
At 1 per second, that's 2.5 months worth of 8 hour days!
I am going with 2,774,361
I will throw in my guess at 2,789,381.
In other words as not to cause any confusion, Two million seven hundred and eighty nine thousand three hundred and eighty one. Phew!
May be 2,345,678 ? (http://)
My guess is: 2 157 378 :o
/Pär
2.565.788
My guess is 1,999,999
Lessee...has to be greater than 2,643,561, and it is certainly less than 2,643,563, :D so...
I'd say it's 2,643,562
I would guess 18567 chips.
ErnieD
2,901,123
The voices in my head say that is the right number, but they also tell me to not take my medicine anymore also so not sure I trust them.
My guess is: 2,013,123
2,653,001
This is based on calculations done on the back of a burning piece of tree bark in the dark with a blindfold on and both hand tied behind my back...............
It's 2,747,100
Q
How about 2,796,420
My guess is 2,999,999
My guess is 2,138,1941
It's quite obvious that its 2,263,572 chips. I don't know why everyone else is having such a hard time counting.
Hi
I reckon 2037921
My guess is 2,348,197 assumming it is only the chips visible in the photograph field-of-view. Now who in their right mind would count each and every chip? Can we ask for a re-count, because I am sure there are some hanging chips-on-chips (chads) that will break off as the chips are handled and skew the count higher.
There nothing like a stack of 13's.
My Guess is 2,131,313.
0x200000 Hex (ie: 2097152 base 10)
2,795,324
My answer would be ... far to many. You should never let it get this messy!
Mark
I used the smash the keypad method...
2,546,545
my guess is 2,246,860
cheers
Ian
It looks like 2,674,361 to me!
I guess... counting all the mess and interpolating whats behind the other mess and behind that it should be exact: 2,475,921 and if this isn't the exact number it should be more or less the same ;D
WAG = 2,376,194
Maybe, 2.015.737 chips
2226100
I'll go with 2,906,323
Mario
My 'count' is 2467846 :)
Colin
I would have to guess 2,750,370
I sent the underwear gnomes in to count them personally and they came back with 2,768,425 pairs of underwear, completely forgetting to go count the chips, so that'll have to do.
Ok there is 2,353,000 Based on spindle speed and feed. ;D
Regards
Mark
2,958,125
I want to see "certified documentation" of the final count, by a neutral 3rd party!
Not just an amount pulled from a mayonaisse jar kept under Funk & Wagner's Porch! ;D
2,965,214 - approximately
2,345,678
Obviously the work of the devil.... I guess 2,666,569
Mark-O
Okay, here's my guess:
2,312,657
2,417,122
I'd say 2,484,926
2745842
2 105 425
2,763,451
2,486,541
last 6 number chosen by randomly stabbing at the key pad with my eyes closed. took a few attempts as I don't think "/" "+" or Num Lock are valid numeric digits.
its 2,007,068
easy 2,398,573
My guess is: 2,987,654
I know. After counting them there is 2,636,437
1 lb of material / 30 minutes of cutting X 1 hour to see it was coded wrong + 1 trip to store for new vaccum bag = 2,389,473 to the 12 power of chips
Hmmm,
2,456,394 :o
my guesstimate: 2,758,904
475 chips per inch of travel
.1 step over
70% of 2 x 2 x 3.5 removed
about 1.3 x 2 x 3.5 removed
20 passes length-wise for each .25 plunge
6 plunges to get 1.3" depth.
1 finish pass
8 parts.
About 459,800 chips
found math mistake :D
2,777,777
Carl Lance
Hello, Count me in at 2,375,640
Having spent the weekend machining the same job and counting them ... 2784908 and a half
Re: Guess and win a G100 Grex
my guess is 2,987,365
My current guess is 2,436,872...Bentbarrel :P
I would like to note for the group that listing prime numbers is probably going to be incorrect. Just a thought.
2,419,200
Size of material, number of flutes, number of passes, etc...
counting those on the floor it's 2.015.081
giorgio
HI,just finished counting( the 79 time >:( ) ;took me 23 hours and 31 minutes and the result is: 2 867 322 i'm sure!!! ;D
This is fun.
My guess 2,613,017
This is a good one, my expert eye tells me the number is : 2,867,994
Thanks for the fun
Paul a.k.a tenmetalman
2,999,999
Poppa
I'm not counting the ones behind the oil can, so I hope you don't either. :)
Unless I missed one, I have counted 2,973,358
2,468,013 i didn't count the partials though.
226,835
Terry
Too many to count!!! is my guess
Hi
I reckon about 2,600 587
I will try at 2,670,428 give or take 1,000,000. :)
Dean
I think it is 2140140
Colin
ok I'll say 2 021 359
2,352,985
Bill
2,000,999
Well I'm just about chip blind! But I think 2,875,123 give or take a few. Gary
I'll Say, 2,880,696
Hank S.
Yeah
th' th' th' three million, seven hundred and twenty four thousand six hundred and ninety seven, yeah definately... it's an excellent driver... yeah...
I will say about 2,362,153 maybe one more ;)
greetings Juan
i THINK 3190
ok, let's go,
2 658 427 chips
Jean-Baptiste DUBOIS
2,187,323
John
I'll say 2,238,969....
Guessing in the low numbers, say 2,233,333
DaveA.
I shouldn't have tried to count after a couple of drinks. The Answer is a blurry 2,659,819.
Looks like 2,011,575 to me
2,491,302
i lost count.. but i guess: 2,678,940
2,375,556 PLUS 1 MORE ON THE TIP OF THE CUTTING FLUID BOTTLE = 2,375,557
I'd say 2,060,708
I 'll guess it is 2.101.000 !!
It's 2.643.226.-
2,125,250.... I hope....
You guys are way off. It's 983,418
My Guess is 2,473,682 chips ;D
2,600,001 is my guess
Hello To all,
the number is 2,755,650
My question if the cutter cuts an already cut chip does that count as one or two, but then the answer is real answer is obvious. The real answer is there is only one chip in the picture. BUT it was pointed out the answer is between 2-3 mil. Now I see the problem with my part making. I'm trying to cut once measure twice when I should just cut several million times and the piece will be a perfect match. Gee, I need the Grex so I can randomly cut til I get it right ;-)
2,670,035 (I quite trying to make the part after this number of attempts)
2,004,990
2,499,999
Lets try 2,999,997.998 or just 2,999,998
Todd
now is someone gonna actually count this or just simply calculate based on the length of the program and the number of teeth in the cutter ect.. ect.. cause Im not comfortable unless every chip is hand counted.
2,132,006
My guess is 2,999,999,999. ;)
This has to be a winner, so really, really need this prise. So i say 2,980,600 chips, good luck to all
Ahh what the heck ... I say 2,867,530. I just want to konw who is actually going to count them all..lol
Jeff T.
I guess there's more chips than anyone is actually going to count, and if they really do count all the chips, I hope nobudy demands a recount! LA!!!!!!!
I guess 2,000,001
bonsoir,
je n'ai pas tout compris, mais pour moi le nombre est 2,605,007
2,345,678
obviously it is 2.478.474 chips
Bengt
Who knows
2,786,789
Ian
2.456.789
455,555,030
2200496
2,495,987 plus or minus 1.
Steve
it looks like my machine after 12 hours of foam cuts. My guess is 2507237 chips . ???
2,834,278
i will be guessing 2,647,854
2,186,150
Mike
How about 2,700,000 chips?
Ok, probably end up being the same as someone else's answer - 2,465,789
I guess 2,210,243
Mark
Who has counted these mountain of chips?
There are most likeley 2,972,361 chips.
Otherwise I guessed wrong. ;D
Some one had allot of time to dream this one up. :o
2,865,195 + or - 2.5%
why + or - 2.5% ,
Well - I don't think a person of sound mind would have or could have a accurate count
of all those chips. ::)
But If some one did count of all those chips, That person is a braver person than I. :-X
Or just needs to get a life. :D
KB7CGA
Nope again al wrong, a2+b2 Goldprice * USD + € gives 3.245.258 chips, 12 cc cutting oil and 1 1/2 gram labrador hairs
Tack care Black Labrador hair !!
and now the results of the Austrian jury
2 759 687
alex
MY guess 2,271,989
Harold
2,569,456 WJS
My guess is;
2,843,756
My guess is:
2,765,428
Interesting :-\
2700000 chips.
Gidday.......No no no! not like that!........ Its easy.........you just count the number of chips in a cubic inch - 22112.163 .......x number of cubic inches 98 = 2,166,992 rounded up and not counting the ones that were swallowed.
cliffh
I guess 2922537
My guess is 2,344,321.
Steve
O jeeees!!!!!! Doesnt everyone know this number? It is plainly obvious. Its 2,768,706, and to think it was right in front of all of you the whole time!
Cheers!
Coog
with me good eye i can see.. 2.784.511
2,345,678 seems about right.
cheers
Steve
Hi all, If someone would send me the gcode and the tool details I'd have it dead to rights. I reckon 2,576,382
Les
I'll go with 2,355,725.
Math calc with my Birth Date as the seed... as good as any other method! :)
(BirthMonth*BirthDay*BirthYear)^2/20=2,355,724.8
Paul, Central OR
..........254000!!!!!!
Guys I have actually read every post to see whats being guessed and some good laughs are to be had! But I got to say I counted a few dozen guesses not actually between 2 and 3 mill??? Those of you may want to redo those guestimations.
O and by the way I have the right answer so everyone else should go back and erase theirs so I will just win it now! :D
2.879,173.2 chips
unless there are a few still on the cutter.
West.
I'll go with 2,356,726.
Regards
Oddman
I can see 2,500,000 but some might say 2,500,001 if you count that little chad over on the left. Use the 2,500,000 anyway , please check my current postal address before sending winnings.
hmmm...
has to be an easy number to remember,
otherwise there would be either;
sticky notes all over the place, or
somebody recounting everytime they forgot the number
so, my [undeucated] guess is
2,345,678
next, problem...
if I actually win,
I don't have anything _worth_ putting these on..:)
enjoy..
I'd say around 50000 but I can't count anyway LOL
875000
No I think there are only 1,9,08,785 chips
tmsmith
2194304 is my guess :)
Did you count them all Brett?
How about 2,100,000
Scott
LOL, down to the thousands anyway. ;)
I like symmetry in my numbers.
Brian N.
I just read 'The Secret' & I believe (stringly & confidently) that the number of chips is 2,785,136. I've already emailed Oprah to tell her about my win - that's how confident I am. Please forward my prize to me by UPS asap.
In the event of you incorrectly counting the chips & not realising that I have won I am sending Oprah to correct you. - DON'T RISK IT !
my guess would be a confirmed 2,678,469. No need for anymore guesses.
Aussies are good blokes and shelias.
2,856,372
I'd love to win.
Brian
2,945,887 looks good to me...
2,397,000 chips!
here it is 2,853,400
5,911,999 ::)
I printed the picture, then took a picture of a known number of chips and weighed it. I then compared the weight of the two pictures. According to my calculation there are 2,467,890 chips in the picture.
LOL
FRom the look of them I think those are inch chips - and I'm used to metric ones - but I can probably do the conversion - hang on ...
OK - it's
2,179,835
Mark
10 fingers + 10 toes = 2,916,427 chips.
According to Al Gore, there are 2,500,002 chads......I mean chips.
We need to setup a vaccum fund for Art! Sure makes a mees of chips....803,612
2,769,396 more or less... Zane
??? Hay, Not fair, all the good numbers are already taken!
But I'll settle for 2,530,399
:D Mike
Taking the mean of the guesses of myself, my wife my daughter, and my father-in-law and given the amount of time it would take the average person to loose sanity and start drooling on the shop floor from trying to count all those chips, the result comes to 2443620.625 rounded up to the nearest whole number is 2,443,621. So there you go 2,443,621 no question. By the way, we would all like to know how you yourself came to a figure of how many chips are there, and at which mental institution did they treat you after you were finished? ;D
2,400,000
I'm not very imaginative.
Doug
::)2.998.357 :D
My count is 2,250,572 and I feel lucky.
2,892,646 that's the ticket.
2,549,112
I think it is 2,675,844 Sorry guys, but you already have your opportunity. :D
My guess.....2,567,123
Hey,
2,222,222
GreG
My guess is 2,670,666 chips
Doesn't look over 2,000,069 from here.............
2,000,000.5 chips, I saw a broken one in the corner. better check your tool for wear or damage.
Bk
2,193,564
Due to fluxuations in the sub space quantum trillium bypass filter I am unable to refine my calculations to this number, 2,897,991.119886 !!!! :o ;D
hi;
my guess is 2853322
rasta
I'll say 2,250,025
hmm put me down for 2,112,353
looks about right .
;D
Ok Its 2366324
Ouch Glad I didn't have to count them myself...
2,863,127
IT is 1432654
Here's my un-educated guess: 2,141,592 chips !
From my point of view it is nearly 2,323,146, isn't it?
Darn. I keep getting interupted! ok. 1..2..3.. 2,657,812
zovass
OK, I'll fall for this co-op marketing gag... besides I like both ArtSoft and Gecko and have bought Mach3, G100 Plugin, G100, and G203v products and then some!
... drum roll ... ... ... ... 2,971,323
ps- I hope your tracking indicates great success! you all are GREAT!!!
-Haik
I think there are about 2,867,487.
Well here goes my number into the pile 2,567,080
Hello,
Just in case I was lucky, I would say 2,578,373 ?
By.
And the winning number is 2,669,321 ..i think :-*
how about 403?
2171717
(I'm afraid for how many notifications I'll receive )
2,676,200
I'd say around 489.005
I see a definite pattern in the way the chips have fallen and taking into account the wind factor caused by the rotation of the machine that cut these chips and the atmospheric conditions in the ionosphere directly above said machine I am in no doubt that the total number of chip including the very small ones is 2,726,841
Lawrie
2350214
Hi
I do not see any micro chips(witch off cource the GRex would be made off)
Metal debri is about 2 060 901
So I guess my final awnser will be .....................electronic chips = 0 ???
Thanks Deon
It will be nice to win a G100 Grex ;D
HI, I just finished making my machine look the same and so I can categorically tell you that the weight of metal is 2lb 1.25oz and the number of chips is 2,634,772. I assume that at the end of the competition you will post a photo showing all the chips laid out in a straight line so we can count 'em and verify the result........ ;) Ian
2,754,844
Hard to count :)
After using image enhacement software as used by NASA, I counted 2 345 607 chips including many half chips, but by definition even a half chip is still a chip therefore my answer must remain at
2 345 607
This is a beast of a problem, so my guess is 2,666,666
2466774 No....?
Hi
2,345,678
my guess:
2,411,504
maybe a little bit luck
I say its 2,800,532
Mark
okay okay!!!! I quit At 3,678,278
I'll bite. My guess 2,500,607
Tante this fun?!!! :D
I don’t think there is a way to count them quickly, or any one loosing the time doing it, but my guess is 2,537,854
i would guesstemate 2739672
2,867,530(9) ;D
Too old to count ,
too young to die !
hmmmm 2,345,678
My guess would be 2,678,000 unless future clues say otherwise.
2,753,111
Bruce M
2,368,526
Vince
Placing my number right in the middle of the largest gap... 2076964
Here is my guess 2,871,976
Thanks Bruce ;D
2747426
2,305,007
2,595,950 ???
You make mention that if someone gets it right you will stop us all and tell us then. If this fails to happen then on the 29th you will pick the closest person. Now during all that you make mention that it is one entry per person but we are allowed to come back and edit our entries right?
Here is the 64chip question.... How often are you looking at all the answers and recording who picked what number? is this done hourly/daily/weekly/once per leapfrog year?
I need answers the counting is making my braing turn into something like green mint jelly!
Coog
LOL, I try and check them everday, no set time. I will start posting a time they have been checked and lock it while checking starting tomorrow.
My guess is 2,612,748
Good point Coog.
Applying all the useful hints.
I'd guess hmm. Let's see, how about 2,345,678.
my guess is 2,716,814
rod
2881424. Exactly random. Let me know if I win.
-Mike
2687000
You call that a pile of chips? I'll show you a pile of chips !! --- Well someday soon I'll learn how to post pictures. 2,111,111 is my guess.
Keep up the good work.
Mike B
Based on the volume of the material left (ML) and making an assumption of the size of the material at start (MS). Then applying the formula..... WTF = MS-ML... and facturing in what appears to be a single flute spiral upcut end mill (EM) and the speed of the mill (RPM) factured be the feed of the tool (FR) WTF = MS-ML/EM X RPM/FR The final answer is WTF = 2,363,673 ???
As the chips are down I would guess 2,607,726
For lack of a witty comment that hasn't already been thought of or submitted.....
I guess 2,304,587
Well here goes.......... 2,873,589 chips. lol and I bet I am only off by 3%
Scott L Golden.............love Mach 3 & Geck0 s !!!!!!!!!!!!!!!!!!!!!!!!!!!
My guess is 2,798,212
2.844245E-6
Hi, All
Until I do a re-count, it's 2,760,082, There's some pretty small chip's in there, My eye's hurt now.
Hope I'm Close, Chip
Who's going to do the re-count, Could be some hanging chip's/chad's in there.
My guess: 2,028,028.
Nita
Based strickly on a number pulled out of the air, my guess is 2,475,027 chips, (give or take a couple) ;)
My guess is 2,777,789
2,345,678
2,305,604
2,345,341
Hi, Still cant work out how to edit my guess but I'll change it to:
2,347,286 chips
good luck to all
Duuuuh, I say, I say, I say 2,438,546 chips
Ok here the good count !!! 2 500 001 chips :D
I figured that the number of chips has some connection to the resolution of the image,
So calculating bytes and converting to bits I have concluded there is
2,425,494 chips
Bill files
2584691
Hi All My Bet 2,785,426 ::)
my guess is 2,842,720
18,483
ferrettboy911
Online
Blog entries (0)
Re: Win a G-Rex ( Competition)
« Reply #30 on: May 24, 2007, 09:00:31 am »
ok, hhmm...simple as smashing atoms, ......2,500,001.
I presume it would be exactly 2,425,371
My guess is 2,408,762
Bert
2,767,235 chips !
Daryn
Assuming there are 3056 chips per square inch, and the bed is 72" x 12" and approx 1" deep, that would make 720 square inches @ 3056 per square inch
Plus a few thousand on the floor I reckon 2,219,320
That's easy: 2,000,870
Hi For my first post into this great fourm is: 2,643,415
Just finished counting!
WOW, I'm glad all of those chips aren't on someones shoulder. Now, THAT would be BAD.
I did some quick calculations using a secret formula in an Excel spreadsheet and came up with 2,607,080 chips! (And then modded it to conform to the hints)
And not one chocolate chip in the bunch. At least there aren't any buffalo chips, either!!!
Great fun, thanks all,
HayTay
I'd say 2,666,666
because thats just an evily large amount of chips to clean up
2000855
I just checked and no one has gotten it yet. Only 2 days left.
:D
;D
:P
Just wondered what all those effects looked like. :o
I am guessing as 2.983.645
Thank you
Hami Akdurak
akdurakh@yahoo.com
2,322,234
Chris
Here's another first post.
My guess 2,901,650
Andrew
I just finished counting with significant help
of my relatives and friends, and after 23 days 8 h and 31 min
of counting a piece per sec , I can pronounce that we have:
2017860 chips.
Good luck to G-rex on the market!
My guess is: 2760800
But I have no ideia how did they were counted ....
Filipe
my guess
2,870,600
bill
Don't know if this number has been posted yet or not, but my guess is 2,718,281.
Ryk
2,183,268
I guess it is 2,694,354
It's Gotta be 2,843,672
2810706
I'll try 2,678,000
I guess it would be 2,666,666. who knows!
No winner yet. I know, because I just checked.
There's going to be as many guesses as there are chips. Who's going to count them.
My guess is 2,876,543
Sage
I don't know much about aluminum, but if they were steel chips, there would be 2825379 of them. If they were steel. :)
??? 2486354 ::)
What the heck, it's worth a try. 2,567,424
-John
The number is 2,004,999
Login name : rajratna4u
I would like to know how you derived the number of chips, but for fun I will take a WAG at it, how about " 2,678,000" Thanks,
My guess : 2.786.000
Two post come to mind. They are so close yet so far away. Any of your guesses should be entered as one of the three following formats. X,*********,********* or X.*********.********* or ******************X . With nothing else attached, ( with a space before and after the number ).
895,457
it is 2,678,000 as H2 = 6, H3 =7, H4=8, H5=0....lol
Zoltan
Well, we are really getting down to the nitty gritty. I wish someone would get it so I don't have to go through the 400 post. Read the hints.
http://www.artsoftcontrols.com/forum/index.php?topic=3267.0
2.911.235
2,680,700
baby needs a new pair of drives
We have a winner!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 7th page, post 338.
;D Congratulations nik ;D
[/size][/color]
Thank you all for participating. Nik, send me a PM with your Personal info.
